1. Foreman overview
Foreman is a centralized tool for provisioning, content delivery, remote management, and monitoring of multiple Enterprise Linux deployments. With Foreman, you can deploy, configure, and maintain your systems across physical, virtual, and cloud environments.
2. Content and patch management with Foreman
With Foreman, you can provide content and apply patches to hosts systematically in all lifecycle stages.
2.1. Content flow in Foreman
Content flow in Foreman involves management and distribution of content from external sources to hosts.
Content in Foreman flows from external content sources to Foreman server. Smart Proxy servers mirror the content from Foreman server to hosts.
- External content sources
You can configure many content sources with Foreman. The supported content sources include the Red Hat Customer Portal, custom Deb and Yum repositories, PyPI, Git repositories, Ansible collections, container registries, SCAP repositories, or internal data stores of your organization.
- Foreman server
On your Foreman server, you plan and manage the content lifecycle.
- Smart Proxy servers
By creating Smart Proxy servers, you can establish content sources in various locations based on your needs. For example, you can establish a content source for each geographical location or multiple content sources for a data center with separate networks.
- Hosts
By assigning a host system to a Smart Proxy server or directly to your Foreman server, you ensure the host receives the content they provide. Hosts can be physical or virtual.
See Major Foreman components for details.
2.2. Content views in Foreman
A content view is a deliberately curated subset of content that your hosts can access. By creating a content view, you can define the software versions used by a particular environment or Smart Proxy server.
Each content view creates a set of repositories across each environment. Your Foreman server stores and manages these repositories. For example, you can create content views in the following ways:
A content view with older package versions for a production environment and another content view with newer package versions for a Development environment.
A content view with a package repository required by an operating system and another content view with a package repository required by an application.
A composite content view for a modular approach to managing content views. For example, you can use one content view for content for managing an operating system and another content view for content for managing an application. By creating a composite content view that combines both content views, you create a new repository that merges the repositories from each of the content views. However, the repositories for the content views still exist and you can keep managing them separately as well.
You can access unprotected repositories in the Default Organization View content view.
The URL consists of your Smart Proxy FQDN, /pulp/content/, your organization label, /Library/custom/, your product label, /, your repository label, and a trailing /, for example, https://foreman.example.com/pulp/content/Example/Library/custom/AlmaLinux_9/BaseOS/.
| Development | Testing | Production | |
Version of the content view |
Version 2 |
Version 1 |
Version 1 |
Contents of the content view |
my-software-1.1-0.noarch.rpm |
my-software-1.0-0.noarch.rpm |
Version 2 |
Version 2 |
Version 1 |
With Distribute archived content view versions enabled, you can access unprotected repositories in published content view versions.
The URL consists of your Smart Proxy FQDN, /pulp/content/, your organization label, /content_views/, your content view, your content view version, /custom/, your product label, /, your repository label, and a trailing /, for example, https://foreman.example.com/pulp/content/Example/content_views/AlmaLinux_9/2.1/custom/AlmaLinux_9/BaseOS/.
If you want to access the latest published content view, the URL consists of your Smart Proxy FQDN, /pulp/content/, your organization label, your lifecycle, your content view, /custom/, your product label, /, your repository label, and a trailing /, for example, https://foreman.example.com/pulp/content/Example/Production/AlmaLinux_9/custom/AlmaLinux_9/AlmaLinux_9/.
For more information, see Managing content views in Managing content.
2.3. Lifecycle environments and environment paths
You can promote content along the environment path to the next lifecycle environment when required. When you promote a content view from one environment to the next environment in the application lifecycle, Foreman updates the repository and publishes the packages. For example, if development ends on a particular version of an application, you can promote this version to the testing environment and start development on the next version.
2.4. Content types in Foreman
With Foreman, you can import and manage many content types. You can use any custom content and content from Red Hat, Canonical, Oracle, and SUSE.
- RPM packages
Import RPM packages from any repository, for example from Amazon, Oracle, Red Hat, SUSE, and custom repositories. Foreman server downloads the RPM packages and stores them locally. You can use these repositories and their RPM packages in content views.
- Deb packages
- Kickstart trees
- Provisioning templates
Templates to provision hosts running EL based on synchronized content and Debian, Ubuntu, or SUSE Linux Enterprise Server based on local installation media. Foreman contains predefined AutoYaST, Kickstart, and Preseed templates as well as the ability to create your own, which are used to provision systems and customize the installation.
- ISO and KVM images
Download and manage media for installation and provisioning. For example, Foreman downloads, stores, and manages ISO images and guest images for specific Red Hat Enterprise Linux and non-Red Hat operating systems.
- OSTree
- Custom file type
2.5. Additional resources
For information about how to manage content with Foreman, see Managing content.
3. Provisioning management with Foreman
3.1. Provisioning methods in Foreman
With Foreman, you can provision hosts by using the following methods.
- Bare-metal hosts
Foreman provisions bare-metal hosts primarily by using PXE boot and MAC address identification. When provisioning bare-metal hosts with Foreman, you can do the following:
Create host entries and specify the MAC address of the physical host to provision.
Boot blank hosts to use the Foreman Discovery service, which creates a pool of hosts that are ready for provisioning.
Provision hosts with UEFI Secure Boot.
Boot and provision hosts by using PXE-less methods.
- Cloud providers
Foreman connects to private and public cloud providers to provision instances of hosts from images stored in the cloud environment. When provisioning from cloud with Foreman, you can do the following:
Select which hardware profile to use.
Provision cloud instances from specific providers by using their APIs.
- Virtualization infrastructure
Foreman connects to virtualization infrastructure services, such as oVirt and VMware. When provisioning virtual machines with Foreman, you can do the following:
Provision virtual machines from virtual image templates.
Use the same PXE-based boot methods that you use to provision bare-metal hosts.
3.2. Additional resources
For information about how to provision hosts with Foreman, see Provisioning hosts.
4. Major Foreman components
A typical Foreman deployment consists of the following components: a Foreman server, Smart Proxy servers that mirror content from Foreman server, and hosts that receive content and configuration from Foreman server and Smart Proxy servers.
4.1. Foreman server overview
Foreman server is the central component of a Foreman deployment where you plan and manage the content lifecycle.
A typical Foreman deployment includes one Foreman server on which you perform the following operations:
Content lifecycle management
Configuration of Smart Proxy servers
Configuration of hosts
Host provisioning
Patch management
Subscription management
Foreman server delegates content distribution, host provisioning, and communication to Smart Proxy servers. Foreman server itself also includes a Smart Proxy.
Foreman server also contains a fine-grained authentication system. You can grant Foreman users permissions to access precisely the parts of the infrastructure for which they are responsible.
For more information about managing permissions, see Managing users and roles in Administering Foreman.
4.2. Smart Proxy overview
With Smart Proxy servers, you can extend the reach and scalability of your Foreman deployment. Smart Proxy servers provide the following functionalities in a Foreman deployment:
Running localized services to discover, provision, control, and configure hosts.
Mirroring content from Foreman server to establish content sources in various geographical or logical locations. By registering a host to a Smart Proxy server, you can configure this host to receive content and configuration from the Smart Proxy in their location instead of from the central Foreman server.
By using content views, you can specify the exact subset of content that Smart Proxy server makes available to hosts. For more information, see Content and patch management with Foreman.
4.3. Overview of hosts in Foreman
With Foreman, you can manage hosts at scale, including monitoring, provisioning, remote execution, configuration management, software management, and subscription management.
4.4. List of key open source components of Foreman
- Foreman
- Katello
- Candlepin
- Pulp
4.5. Smart Proxy features
Smart Proxy servers provide local host management services and can mirror content from Foreman server.
To mirror content from Foreman server, Smart Proxy servers provide the following functionalities:
- Repository synchronization
Smart Proxy servers pull content for selected lifecycle environments from Foreman server and make this content available to the hosts they manage.
- Content delivery
Hosts configured to use Smart Proxy server download content from that Smart Proxy rather than from Foreman server.
- Host action delivery
Smart Proxy server executes scheduled actions on hosts.
- Red Hat Subscription Management (RHSM) proxy
Hosts are registered to their associated Smart Proxy servers rather than to the central Foreman server or the Red Hat Customer Portal.
You can use Smart Proxy to run the following services for infrastructure and host management:
- DHCP
Smart Proxy can manage a DHCP server, including integration with an existing solution, such as ISC DHCP servers, Active Directory, and Libvirt instances.
- DNS
Smart Proxy can manage a DNS server, including integration with an existing solution, such as ISC BIND and Active Directory.
- TFTP
Smart Proxy can integrate with any UNIX-based TFTP server.
- Realm
Smart Proxy can manage Kerberos realms or domains so that hosts can join them automatically during provisioning. Smart Proxy can integrate with an existing infrastructure, including FreeIPA and Active Directory.
- Puppet server
Smart Proxy can act as a configuration management server by running an OpenVox server.
- Puppet Certificate Authority
Smart Proxy can integrate with the Puppet certificate authority (CA) to provide certificates to hosts.
Smart Proxy can provide power management for hosts by using the Intelligent Platform Management Interface (IPMI) or Redfish standards.
- Provisioning template proxy
Smart Proxy can serve provisioning templates to hosts.
- OpenSCAP
Smart Proxy can perform security compliance scans on hosts.
- Remote Execution (REX)
Smart Proxy can run remote job execution on hosts.
You can configure a Smart Proxy server for a specific limited purpose by enabling only selected features on that Smart Proxy. Common configurations include the following:
- Infrastructure Smart Proxies: DNS + DHCP + TFTP
Smart Proxies with these services provide infrastructure services for hosts and have all necessary services for provisioning new hosts.
- Content Smart Proxies: Pulp
Smart Proxies with this service provide content synchronized from Foreman server to hosts.
- Configuration Smart Proxies: Pulp + Puppet + PuppetCA
Smart Proxies with these services provide content and run configuration services for hosts.
- Smart Proxies with DNS + DHCP + TFTP + Pulp + Puppet + PuppetCA
Smart Proxies with these services provide a full set of Smart Proxy features. By configuring a Smart Proxy with all these features, you can isolate hosts assigned to that Smart Proxy by providing a single point of connection for the hosts.
4.6. Smart Proxy networking
The communication between Foreman server and hosts registered to a Smart Proxy server is routed through that Smart Proxy server. Smart Proxy server also provides Foreman services to hosts.
Many of the services that Smart Proxy server manages use dedicated network ports. However, Smart Proxy server ensures that all communications from the host to Foreman server use a single source IP address, which simplifies firewall administration.
In this topology, Smart Proxy provides a single endpoint for all host network communications so that in remote network segments, only firewall ports to the Smart Proxy itself must be open.
In this topology, hosts connect to Foreman server rather than a Smart Proxy. This applies also to Smart Proxies themselves because the Smart Proxy server is a host of Foreman server.
Ports and firewall requirements in Installing Foreman Server with Katello 4.17 plugin on Enterprise Linux
Ports and firewall requirements in Installing a Smart Proxy Server 3.15 on Enterprise Linux
4.7. Additional resources
See Installing a Smart Proxy Server 3.15 on Enterprise Linux for details on Smart Proxy server requirements, installation, and scalability considerations.
See Configuring Smart Proxies with a load balancer for details on distributing load among Smart Proxy servers.
5. Foreman infrastructure organization concepts
You can use several elements to structure and organize the resources within your Foreman environment.
5.1. Organizations and locations in Foreman
On your Foreman server, you can define organizations and locations to help organize content, hosts, and configurations. Organizations and locations enable you to arrange Foreman resources into logically structured groups. For example, you can create groups based on ownership, purpose, content, or security level. You can create and manage multiple organizations through Foreman, then divide and assign subscriptions to each individual organization.
- Organizations
Organizations typically represent different business units, departments, or teams, such as Finance, Marketing, or Web Development. To manage Red Hat content, each organization requires a separate Red Hat subscription manifest.
- Locations
Locations typically represent physical locations, such as countries or cities.
You can use locations to map the network infrastructure to prevent incorrect host placement or configuration. While you cannot assign a subnet, domain, or compute resources directly to a Smart Proxy server, you can assign them to a location.
Unlike organizations, locations can have a hierarchical structure.
Foreman server defines all locations and organizations. Each Smart Proxy server synchronizes content and handles configuration of hosts in a different location.
Your Foreman server retains the management function, while the content and configuration is synchronized between your Foreman server and Smart Proxy servers assigned to certain locations.
The system administrator creates the following organizations on their Foreman server:
Finance
Marketing
Sales
Additionally, the administrator creates the following locations on their Foreman server:
United States
United Kingdom
Japan
Boston
Phoenix
San Francisco
5.2. Host groups overview
A host group acts as a template for common host settings.
With host groups, you can define many settings for hosts, such as lifecycle environment, content view, or Ansible roles that are available to the hosts. Instead of defining the settings individually for each host, you can use host groups to define common settings once and apply them to multiple hosts.
When you change the settings of an existing host group, the new settings do not propagate to the hosts assigned to the host group. Only Puppet class settings get updated on hosts after you change them in the host group. |
5.3. Host collections overview
A host collection is a group of content hosts.
With host collections, you can perform the same action on multiple hosts at once. These actions include installing, removing, and updating packages and errata, and assigning content view environments.
For example, you can use host collections to group hosts by function, department, or business unit.
5.4. Additional resources
For examples of Foreman deployment, see Common deployment scenarios.
6. Tools for administration of Foreman
6.1. Foreman web UI overview
You can manage and monitor your Foreman infrastructure from a browser with the Foreman web UI. For example, you can use the following navigation features in the Foreman web UI:
| Navigation feature | Description |
Organization dropdown |
Choose the organization you want to manage. |
Location dropdown |
Choose the location you want to manage. |
Monitor |
Content |
Provides content management tools. This includes content views, activation keys, and lifecycle environments. |
Hosts |
Configure |
Provides general configuration tools and data, including host groups and Ansible content. |
Infrastructure |
Provides tools on configuring how Foreman interacts with the environment. |
Administer |
Provides advanced configuration for settings such as users, role-based access control (RBAC), and general settings. |
6.2. Hammer CLI overview
You can configure and manage your Foreman server with CLI commands by using Hammer.
Create shell scripts based on Hammer commands for basic task automation.
Redirect output from Hammer to other tools.
Use the
--debugoption with Hammer to test responses to API calls before applying the API calls in a script. For example:hammer --debug organization list.
To issue Hammer commands, a user must have access to your Foreman server.
To ensure a user-friendly and intuitive experience, the Foreman web UI takes priority when developing new functionality. Therefore, some features that are available in the Foreman web UI might not yet be available for Hammer. |
For more information about Hammer CLI, see Using the Hammer CLI tool.
6.3. Foreman API overview
You can write custom scripts and external applications that access the Foreman API over HTTP with the Representational State Transfer (REST) API provided by Foreman server. Use the REST API to integrate with enterprise IT systems and third-party applications, perform automated maintenance or error checking tasks, and automate repetitive tasks with scripts.
Configure any programming language, framework, or system with support for HTTP protocol to use the API.
Create client applications that require minimal knowledge of the Foreman infrastructure because users discover many details at runtime.
Adopt the resource-based REST model for intuitively managing a virtualization platform.
API commands differ between versions of Foreman. When you prepare to upgrade Foreman server, update all the scripts that contain Foreman API commands. |
For more information on Foreman API, see Using the Foreman REST API.
6.4. Remote execution in Foreman
With remote execution, you can run jobs on hosts from Smart Proxies by using shell scripts or Ansible roles and playbooks.
Run jobs on multiple hosts at once.
Use variables in your commands for more granular control over the jobs you run.
Use host facts and parameters to populate the variable values.
Specify custom values for templates when you run the command.
Communication for remote execution occurs through Smart Proxy server, which means that Foreman server does not require direct access to the target host, and can scale to manage many hosts.
Foreman uses ERB syntax job templates. For more information, see Template writing reference in Managing hosts.
See Configuring and setting up remote jobs in Configuring hosts by using Ansible.
6.5. Automating Foreman management with Foreman Ansible Collection
For more information about using Ansible to configure hosts, see Configuring hosts by using Ansible.
For more information about automating Foreman using Ansible, see Automating Foreman management with Foreman Ansible Collection in Administering Foreman.
6.6. Kickstart workflow
You can automate the installation process of a Foreman server or Smart Proxy server by creating a Kickstart file that contains all the information that is required for the installation.
When you run a Foreman Kickstart script, the script performs the following actions:
For more information about Kickstart, see Automated installation workflow in Automatically installing RHEL 9.
7. Supported usage and versions of Foreman components
7.1. Foreman server operating system
Foreman has packages for Enterprise Linux 9, Debian 12, and Ubuntu 22.04. Katello plugin packages, which provide content management capabilities, are only available for Enterprise Linux.
7.2. Client operating systems
Using Foreman, you can manage multiple operating systems that have Foreman clients:
Amazon Linux
Debian
Enterprise Linux 10, 9, and 8
Fedora
OpenSUSE
Ubuntu
Ansible
OpenSCAP
OpenSSH
Puppet
Salt
Windows Remote Management (WinRM)
Operating system installers that can perform unattended installations, such as Anaconda or Debian-installer
Katello host tools
Tracer utility
8. Deployment path for Foreman
8.1. Installing a Foreman server
Installing an instance of Foreman server on a dedicated server is the first step to a working Foreman infrastructure.
For complete information on installing a Foreman server, including prerequisites and predefined tuning profiles, see Installing Foreman Server with Katello 4.17 plugin on Enterprise Linux.
8.1.1. Configuring Foreman server with external database
Running the foreman-installer command, used to install a Foreman server, also installs PostgreSQL databases on the server.
However, you can configure your Foreman server to use external databases instead.
Moving to external databases distributes the workload and can reduce overall Foreman memory usage.
Frequent remote execution tasks. This requires a high volume of records in PostgreSQL and generates heavy database workloads.
High disk I/O workloads from frequent repository synchronization or content view publishing. This requires Foreman to create a record in PostgreSQL for each job.
High volume of hosts.
High volume of synchronized content.
For more information about using an external database, see Using external databases with Foreman in Installing Foreman Server with Katello 4.17 plugin on Enterprise Linux.
8.2. Configuring external authentication in Foreman
Foreman includes native support for authentication with a username and password. If you require additional methods of authentication, configure your Foreman server to use an external authentication source.
| Username and password | Single sign-on (SSO) | One-time password (OTP) | Time-based one-time password (TOTP) | PIV cards | |
Active Directory (direct integration) |
Yes |
Yes |
No |
No |
No |
FreeIPA |
Yes (Linux and Active Directory users) |
Yes (Linux users only) |
No |
No |
No |
Quarkus-based Keycloak |
Yes |
Yes |
Yes |
Yes |
Yes |
Wildfly-based Keycloak |
Yes |
Yes |
Yes |
Yes |
Yes |
LDAP |
Yes |
No |
No |
No |
No |
For more information, see Configuring authentication for Foreman users.
8.3. Planning organization and location context
Resources and users can generally only access resources within their own context, which makes configuring organizations and locations an integral part of access management in Foreman.
If you use host groups to bundle provisioning and configuration information, avoid mismatching resources from mutually exclusive contexts. For example, setting a subnet from one organization or location and a compute resource from a different organization or location creates an invalid host group. |
For examples of deployment scenarios, see Common deployment scenarios.
For information about managing organizations and locations, see Managing organizations and locations in Foreman.
8.4. Installing Smart Proxy servers
By installing Smart Proxy servers, you extend the reach and scalability of your Foreman deployment. Setting up a Smart Proxy server registers the base operating system on which you are installing to Foreman server and configures the new Smart Proxy server to provide the required services within your Foreman deployment.
You can install a Smart Proxy server in each of your geographic locations. By assigning a Smart Proxy to each location, you decrease the load on Foreman server, increase redundancy, and reduce bandwidth usage.
The maximum number of Smart Proxy servers that Foreman server can support has no fixed limit. It was tested that a Foreman server can support 17 Smart Proxy servers with 2 vCPUs. |
Decide what services you want to enable on each Smart Proxy server. You can configure the DNS, DHCP, and TFTP services on one of your Smart Proxy servers or you can use an external server to provide these services to your Smart Proxy servers.
For information on installing Smart Proxy servers, including prerequisites and configuring external services, see Installing a Smart Proxy Server 3.15 on Enterprise Linux.
For information on tuning performance by using Smart Proxies, see Smart Proxy configuration tuning in Tuning performance of Foreman.
8.5. Adding a Red Hat subscription to Foreman
If you want to manage hosts running Red Hat Enterprise Linux, import a Red Hat manifest. For more information, see Managing Red Hat subscriptions in Managing content. |
A Red Hat subscription manifest is a set of encrypted files that contains your subscription information. Foreman server uses this information to access the Red Hat CDN and find what repositories are available for the associated subscription.
Warning
Deleting a subscription manifest removes all the subscriptions attached to running hosts and activation keys. |
For instructions about creating and importing a Red Hat subscription manifest, see Managing Red Hat subscriptions in Managing content.
For details about using subscription manifests with Foreman, see Creating and managing manifests for a connected Satellite Server.
8.6. Defining your content library
To ensure that your Foreman server can manage software and provide it to your hosts, you must create repositories and synchronize them.
- Red Hat content
The Red Hat subscription manifest determines what Red Hat repositories your Foreman server can access. Red Hat content is already organized into products.
For example, Red Hat Enterprise Linux Server is a product in Foreman. The repositories for the Red Hat Enterprise Linux Server product consist of different versions, architectures, and add-ons. When you enable a Red Hat repository, Foreman automatically creates an associated product.
- Oracle ULN content
You can use Foreman to manage hosts running Oracle Linux. For more information, see Creating ULN repositories in Managing content.
- SUSE content
You can use Foreman to manage hosts running SUSE Linux Enterprise Server. For more information, see Managing SUSE content in Managing content.
- Ubuntu ESM content
You can use Foreman to manage hosts running Ubuntu. For more information, see Synchronizing Ubuntu Expanded Security Maintenance content in Managing content.
- Other sources of content
To distribute content from custom sources, you must create products and repositories manually. You can organize other content into products however you want.
For example, you can create an EPEL (Extra Packages for Enterprise Linux) product and add an "EPEL 9 x86_64" repository to it.
Creating repositories allows you to choose the specific software required for your environment. By creating only the necessary repositories, you avoid downloading unnecessary content.
Synchronizing repositories downloads the content from Red Hat CDN or another source to your Foreman server. The synchronized content is stored on your Foreman server, eliminating the need for hosts to access the repositories. You can synchronize repositories manually, or you can create a sync plan to ensure synchronization runs on a regular basis.
For more information, see Basic content management workflow.
For more information about Deb content, see Adding Deb repositories in Managing content.
For more information about Yum content, see Adding RPM repositories in Managing content.
For more information, including procedures for enabling and synchronizing repositories, see Importing content in Managing content.
8.7. Defining content access strategies for hosts
When defining your content lifecycle in Foreman, you can use content views and lifecycle environments to define which hosts can access which content and content versions. By default, Foreman includes the Default Organization View content view and the Library lifecycle environment.
- Default Organization View
The Default Organization View is the default content view in Foreman that contains all the content that is synchronized to Foreman. After you update your content, such as by adding or removing a repository, the update is immediately reflected in Default Organization View.
- Library
The Library lifecycle environment is the default lifecycle environment in Foreman. Every newly published content view version is automatically published to the Library lifecycle environment. You can also promote specific content view versions to the Library lifecycle environment if needed.
For more information, see Managing application lifecycles, Managing content views, and Restricting hosts' access to content in Managing content.
For examples of content view deployments, see Common deployment scenarios.
8.8. Defining role-based access control policies
One of the predefined roles is the Default role. Foreman assigns the Default role to every user in the system. By default, the Default role grants only a limited set of permissions. Be aware that if you add a permission to the Default role, every Foreman users will gain that permission. Assigning a different role to a user does not remove the Default role from the user. |
- Roles related to applications or parts of infrastructure
- Roles related to a particular stage of the software lifecycle
- Roles related to specific tasks
For more information, including details about creating custom roles and granting permissions to roles, see Managing users and roles in Administering Foreman.
8.8.1. Best practices for role-based access control in Foreman
Define the expected tasks and responsibilities: Define the subset of the Foreman infrastructure that you want the role to access as well as actions permitted on this subset. Think of the responsibilities of the role and how it differs from other roles.
Use predefined roles whenever possible: Foreman provides several sample roles that you can use. Copying and editing an existing role can be a good start for creating a custom role.
Adopt a granular approach to user role management: Define roles with specific and well-scoped permissions. Note that each user can have multiple roles assigned and that permissions from these roles are cumulative.
Add permissions gradually and test the results: When creating a custom role, start with a limited set of permissions and add permissions one by one, while testing continuously. Ensure to test your custom role to verify that it works as intended.
Consider areas of interest and granting read-only access: Even though a role has a limited area of responsibility, it might need a wider set of permissions. Therefore, you can grant the role a read-only access to parts of Foreman infrastructure that influence its area of responsibility.
8.9. Configuring provisioning
The process depends on whether you want to provision bare-metal hosts, virtual machines, or cloud instances, but it includes defining installation media, configuring provisioning templates, and other tasks. If you are provisioning virtual machines or cloud instances, you must also integrate your compute provider with Foreman by connecting the provider as a compute resource to Foreman.
Provisioning templates enable you to define the way Foreman installs an operating system on your hosts.
The Discovery service enables you to detect unknown hosts and virtual machines on the provisioning network.
This requires the Discovery plugin. For more information, see Installing the Discovery service in Provisioning hosts.
Host groups enable you to standardize provisioning of host configurations.
For a complete guide to provisioning, see Provisioning hosts.
8.10. Overview of recommended disaster recovery plans
- Snapshots of virtualized Foreman server
- How do I back up?
Virtualize your Foreman server and use the hypervisor tools to take virtual machine snapshots of the server. This method is suitable if you can run Foreman in a virtual machine.
- Active and passive Foreman server, with external storage
- How do I back up?
/var/lib/pulpand database in/var/lib/pgsql. Replicate this storage into a different data center. Attach the storage to a Foreman server that is a clone of the primary Foreman server but runs passively. - How will I recover in case of a disruptive event?
To recover Foreman services, switch DNS records of the active Foreman server with the passive Foreman server. This ensures that the passive server becomes the active server. All hosts remain connected without configuration updates.
- Active and passive Foreman server, with backup and restore
- How do I back up?
Ensure periodic backups of your Foreman server. Copy this backup to a passive Foreman server and restore it on the passive server.
- Dual active Foreman server
- How do I back up?
Operate an active, independent Foreman server per data center. Hosts from each data center are registered to the Foreman server in that data center. Then configure automation to ensure recovery in case of a disruptive event. For example, you can periodically run a health check and if the health check discovers that the current Foreman server a host is registered to does not resolve, the host is re-registered to the other Foreman server.
To minimize downtime, you can automate the recovery in various ways. For example, you can use the Foreman Ansible collection. For more information, see Automating Foreman management with Foreman Ansible Collection in Administering Foreman.
To recover Foreman services, re-register all hosts to the Foreman server in the other data center.
For a complete guide to disaster recovery, see Preparing for disaster recovery and recovering from data loss in Administering Foreman.
To create backups of your Foreman server and Smart Proxy servers, use the
foreman-maintain backupcommand. For more information, see Backing up Foreman server and Smart Proxy server in Administering Foreman. -
To back up your hosts, you can use remote execution to configure recurring backup tasks that Foreman will run on the hosts. For more information, see Configuring and setting up remote jobs in Managing hosts.
To create snapshots of hosts, you can use the Snapshot Management plugin. For more information, see Creating snapshots of a host in Managing hosts.
8.11. Additional deployment tasks
Foreman offers a range of additional capabilities that you can use to further enhance your Foreman deployment. For example:
- Remote execution commands on hosts
- Automating tasks with a configuration management tool
- Security management with OpenSCAP
You can enable the OpenSCAP plugin on your Foreman server and any Smart Proxy servers. With OpenSCAP, you can manage compliance policies and run security compliance scans on your hosts. After the scan completes, a compliance report is uploaded to your Foreman server.
- Load balancing
With load balancing configured on your Smart Proxy servers, you can improve performance on Smart Proxy servers while also improving performance and stability for host connections to Foreman.
For more information, see Configuring Smart Proxies with a load balancer.
9. Common deployment scenarios
9.1. Single location with segregated subnets
Your infrastructure might require multiple isolated subnets even if Foreman is deployed in a single geographic location. This can be achieved for example by deploying multiple Smart Proxy servers with DHCP and DNS services, but the recommended way is to create segregated subnets using a single Smart Proxy. This Smart Proxy is then used to manage hosts and compute resources in those segregated networks to ensure they only have to access the Smart Proxy for provisioning, configuration, errata, and general management. For more information on configuring subnets, see Managing hosts.
9.2. Multiple locations
Foreman community recommends to create at least one Smart Proxy server per geographic location. This practice can save bandwidth since hosts obtain content from a local Smart Proxy server. Synchronization of content from remote repositories is done only by the Smart Proxy, not by each host in a location. In addition, this layout makes the provisioning infrastructure more reliable and easier to configure.
9.3. Content view scenarios
A single lifecycle environment – content from Library is promoted directly to the production stage. This approach limits the complexity but still allows for testing the content within the Library before making it available to hosts.
A single lifecycle environment path – both operating system and applications content is promoted through the same path. The path can consist of several stages, which enables thorough testing but requires additional effort. For example, you can use the Development, QA, and Production stages.
Application specific lifecycle environment paths – each application has a separate path, which allows for individual application release cycles. You can associate specific compute resources with application lifecycle stages to facilitate testing. However, this scenario increases the maintenance complexity.
Host specific content view – a dedicated content view for each host type. This approach can be useful in deployments with a small number of host types (up to 30). However, it prevents sharing content across host types as well as separation based on criteria other than the host type, for example, between operating system and applications. With critical updates every content view has to be updated, which increases maintenance efforts.
9.4. Foreman server with multiple manifests
If you plan to have more than one Red Hat Network account, or if you want to manage systems belonging to another entity that is also a Red Hat Network account holder, then you and the other account holder can assign subscriptions, as required, to manifests. A customer that does not have a Foreman subscription can create a Subscription Asset Manager manifest, which can be used with Foreman, if they have other valid subscriptions. You can then use the multiple manifests in one Foreman server to manage multiple organizations.
The following diagram shows two Red Hat Network account holders, who want their systems to be managed by the same Foreman installation. In this scenario, Example Corporation 1 can allocate any subset of their 60 subscriptions, in this example they have allocated 30, to a manifest. This can be imported into the Foreman as a distinct Organization. This allows system administrators the ability to manage Example Corporation 1’s systems using Foreman completely independently of Example Corporation 2’s organizations (R&D, Operations, and Engineering).
When creating a Red Hat subscription manifest:
Add the subscription for Foreman server to the manifest if planning a disconnected or self-registered Foreman server. This is not necessary for a connected Foreman server that is subscribed using the Subscription Manager utility on the base system.
Add subscriptions for all Smart Proxy servers you want to create.
Add subscriptions for all Red Hat products you want to manage with Foreman.
Note the date when the subscriptions are due to expire and plan for their renewal before the expiry date.
Create one manifest per organization. You can use multiple manifests and they can be from different Red Hat subscriptions.
Foreman allows the use of future-dated subscriptions in the manifest. This enables uninterrupted access to repositories when future-dated subscriptions are added to a manifest before the expiry date of existing subscriptions.
Note that the Red Hat subscription manifest can be modified and reloaded to Foreman server in case of any changes in your infrastructure, or when adding more subscriptions. Manifests should not be deleted. If you delete the manifest from the Red Hat Customer Portal or in the Foreman web UI it will unregister all of your content hosts.
9.5. Host group structures
- Flat structure
- Lifecycle environment based structure
- Application based structure
- Location based structure
In this hierarchy, the distribution of locations is aligned with the host group structure. In a scenario where the location or Smart Proxy server topology determines many other attributes, this approach is the best option. However, this structure complicates sharing parameters across locations, therefore in complex environments with a large number of applications, the number of host group changes required for each configuration change increases significantly.
9.6. Inter-Server Synchronization scenarios
Foreman uses Inter-Server Synchronization (ISS) to synchronize content between two Foreman servers including those that are air gapped.
If you want to copy some but not all content from your Foreman server to other Foreman servers. For example, you have content views that your IT department consumes from Foreman server, and you want to copy content from those content views to other Foreman servers.
If you want to copy all Library content from your Foreman server to other Foreman servers. For example, you have products and repositories that your IT department consumes from Foreman server in the Library, and you want to copy all products and repositories in that organization to other Foreman servers.
You cannot use ISS to synchronize content from Foreman server to Smart Proxy server. Smart Proxy server supports synchronization natively. For more information, see Smart Proxy server Overview in Planning for Foreman. |
9.6.1. ISS network sync in a disconnected scenario
The upstream Foreman server is connected to the Internet. This server consumes content from the Red Hat Content Delivery Network (CDN) or custom sources.
The downstream Foreman server is completely isolated from all external networks.
The downstream Foreman server can communicate with a connected upstream Foreman server over an internal network.
You can configure your downstream Foreman server to synchronize content from the upstream Foreman server over the network.
9.6.2. ISS export sync in an air-gapped scenario
The upstream Foreman server is connected to the Internet. This server consumes content from the Red Hat CDN or custom sources.
The downstream Foreman server does not have a network connection to a connected upstream Foreman server.
The only way for an air-gapped downstream Foreman server to receive content updates is by exporting payload from the upstream Foreman server, bringing it physically to the downstream Foreman server, and importing the payload. For more information, see Synchronizing Content Between Foreman servers in Managing content.
You can configure your downstream Foreman server to synchronize content by using exports.
9.7. Deploying Foreman on AWS
You can run Foreman server, Smart Proxy servers, and hosts in your Amazon Web Services (AWS) environment. You can deploy Foreman on Amazon Web Services (AWS) in several scenarios.
This is the least complex configuration of Foreman in AWS. Deploy both Foreman server and the hosts residing within the same region and within the Virtual Private Cloud (VPC) You can also use a different availability zone.
Create a VPN connection between the on-premises location and the AWS region where your Smart Proxy server is located. It is also possible to use the external host name of Foreman server when you register the instance that runs Smart Proxy.
Create a site-to-site VPN connection between different regions so that you can use the internal DNS host name when you register the instance that runs Smart Proxy to Foreman server. If you do not establish a site-to-site VPN connection, use the external DNS host name when you register the instance that runs Smart Proxy to Foreman server.
Most public cloud providers do not charge for data being transferred into a region or between availability zones within a single region. However, they charge for data leaving the region to the Internet. |
10. Provisioning requirements
10.1. PXE booting
10.1.1. PXE sequence
initrdand Kickstart. -
For more information about PXE Booting, see Network boot provisioning workflow in Provisioning hosts.
10.1.2. PXE booting requirements
Ensure that all the network-based firewalls are configured to allow clients on the subnet to access the Smart Proxy. For more information, see Smart Proxy networking.
10.2. HTTP booting
10.2.1. HTTP booting requirements with managed DHCP
All the network-based firewalls are configured to allow clients on the subnet to access the Smart Proxy. For more information, see Smart Proxy networking.
Although TFTP protocol is not used for HTTP UEFI Booting, Foreman uses TFTP Smart Proxy API to deploy boot loader configuration.
Ensure that the TCP port 8000 is open for the client to download the boot loader and Kickstart templates from the Smart Proxy.
The TCP port 9090 is open for the client to download the boot loader from the Smart Proxy using the HTTPS protocol.
The subnet that functions as the host’s provisioning interface has a DHCP Smart Proxy, an HTTP Boot Smart Proxy, a TFTP Smart Proxy, and a Templates Smart Proxy
10.2.2. HTTP booting requirements with unmanaged DHCP
http://smartproxy.example.com:8000 -
https://smartproxy.example.com:9090
Although TFTP protocol is not used for HTTP UEFI Booting, Foreman use TFTP Smart Proxy API to deploy boot loader configuration.
Ensure that the TCP port 8000 is open for the client to download boot loader and Kickstart templates from the Smart Proxy.
Ensure that the TCP port 9090 is open for the client to download the boot loader from the Smart Proxy through HTTPS.
Ensure that the host provisioning interface subnet has an HTTP Boot Smart Proxy set.
10.3. Secure Boot
When Foreman is installed on Enterprise Linux using foreman-installer, grub2 and shim boot loaders that are signed by Red Hat are deployed into the TFTP and HTTP UEFI Boot directory.
PXE loader options named "SecureBoot" configure hosts to load shim.efi.
On Debian and Ubuntu operating systems, the grub2 boot loader is created using the grub2-mkimage unsigned.
To perform the Secure Boot, the boot loader must be manually signed and key enrolled into the EFI firmware.
Alternatively, grub2 from Ubuntu or Enterprise Linux can be copied to perform booting.
The Foreman installation process automatically creates system accounts. They manage files and process ownership of the components integrated into Foreman. Some of these accounts have fixed UIDs and GIDs, while others take the next available UID and GID on the system instead. To control the UIDs and GIDs assigned to accounts, you can define accounts before installing Foreman. Because some of the accounts have hard-coded UIDs and GIDs, it is not possible to do this with all accounts created during Foreman installation.
foreman |
N/A |
foreman |
N/A |
yes |
/usr/share/foreman |
/sbin/nologin |
foreman-proxy |
N/A |
foreman-proxy |
N/A |
yes |
/usr/share/foreman-proxy |
/sbin/nologin |
apache |
48 |
apache |
48 |
no |
/usr/share/httpd |
/sbin/nologin |
postgres |
26 |
postgres |
26 |
no |
/var/lib/pgsql |
/bin/bash |
pulp |
N/A |
pulp |
N/A |
no |
N/A |
/sbin/nologin |
puppet |
52 |
puppet |
52 |
no |
/sbin/nologin |
saslauth |
N/A |
saslauth |
76 |
no |
/run/saslauthd |
/sbin/nologin |
tomcat |
53 |
tomcat |
53 |
no |
/usr/share/tomcat |
/bin/nologin |
unbound |
N/A |
unbound |
N/A |
yes |
/etc/unbound |
/sbin/nologin |
Foreman is a complete lifecycle management tool for physical hosts, virtual machines, and cloud instances. Key features include automated host provisioning, configuration management, and content management including patch and errata management. You can automate tasks and quickly provision hosts, all through a single unified interface.
- Activation key
Activation keys are used by Subscription Manager to register hosts to Foreman. They define content view and lifecycle environment associations, content overrides, system purpose attributes, and other parameters to be associated with a newly created host.
They are associated to exactly one lifecycle environment and exactly one content view, though this may be a composite content view. You can use them on multiple machines and they behave like configuration information rather than traditional software license keys. You can also use multiple activation keys with a single host. When you register a host using an activation key, certain content from Foreman is provided to the host. The content that is made available depends on the content in the activation key’s content view and lifecycle environment, any content overrides present, any repository-level restrictions such as operating system or architecture, and system purpose attributes such as release version.
- Ansible
For more information about using Ansible to configure hosts, see Configuring hosts by using Ansible. For more information about automating Foreman using Ansible, see Automating Foreman management with Foreman Ansible Collection in Administering Foreman.
- Answer file
- ARF report
- Audits
- Boot disk
- Catalog
- Candlepin
- Compliance policy
- Compute profile
- Compute resource
- Configuration Management
- Container (Docker container)
- Container image
- Content
A general term for everything Foreman distributes to hosts. Content includes software packages such as
.rpmpackages, errata, or Docker images. Content is synchronized into the Library and then promoted into lifecycle environments using content views so that they can be consumed by hosts.
- Content delivery network (CDN)
- Content view
Content views are named and versioned collections of repositories. When you publish a content view, Foreman creates a new content view version. This content view version is a frozen snapshot of the current state of the repositories within the content view. Any subsequent changes to the underlying repositories will no longer affect the published content view version. Once a content view is published, it can be promoted through the lifecycle environment path, or modified using incremental upgrades.
- Composite content view
- Discovered host
- Discovery image
- Discovery plugin
- Discovery rule
- Docker tag
- Enterprise Linux
AlmaLinux
CentOS Linux
CentOS Stream
Oracle Linux
Rocky Linux
- ERB
- Errata
- External node classifier (ENC)
- Facter
- Facts
- Foreman
- Full host image
- Generic image
A boot disk for PXE-less provisioning that is not tied to a specific host. The generic image sends the MAC address of your host to Foreman server, which matches it against the host entry.
- Hammer
- Host
- Host collection
- Host group
- Host image
- Installation Media
Installation media are sets of installation files used to install the base operating system during the provisioning process. An installation medium in Foreman represents the installation files for one or more operating systems, which must be accessible over the network, either through an URL or an NFS server location. It is usually either a mirror or a CD or DVD image.
Every operating system depends on exactly one path of an installation medium, whereas installation media paths may serve different operating systems at the same time. You can use operating system parameters such as
$version,$major, and$minorto parameterize the URL.
- Job
- Katello
Katello is an open-source plugin to perform content management and subscription handling. It depends on Pulp for content management, which fetches software from repositories and stores various versions of it. It also depends on Candlepin for host registration and managing subscription manifests.
- Lazy sync
- Location
- Library
A container for content from all synchronized repositories on Foreman server. Libraries exist by default for each organization as the root of every lifecycle environment path and the source of content for every content view.
- Lifecycle environment path
- Manifest (Red Hat subscription manifest)
A mechanism for transferring subscriptions from the Red Hat Customer Portal to Foreman. Do not confuse with Puppet manifest.
- Migrating Foreman
- OpenSCAP
- Organization
- Parameter
- Patch and release management
Patch and release management describes the process of acquiring, managing, and installing patches and software updates to your infrastructure. Using Foreman, you can keep control of the package versions available to your hosts and deliver applicable errata.
- Permission
- Product
Products are named collections of one or more repositories. If you manage Red Hat content and upload a Red Hat manifest, Foreman automatically groups Red Hat content within products. If you manage SUSE content using SCC Manager plugin, Foreman automatically groups SUSE content within products. For more information, see Managing SUSE content in Managing content.
- Promote (a content view)
- Provisioning
The provisioning of a host is the deployment of the base operating system on the host and registration of the host to Foreman. Optionally, the process continues with the supply of content and configuration. This process is ideally automated. Provisioned hosts run on compute resources or bare metal, never Foreman server or Smart Proxy servers.
AutoYaST for SUSE Linux Enterprise Server
Kickstart for AlmaLinux, Amazon Linux, CentOS, Oracle Linux, Red Hat Enterprise Linux, and Rocky Linux
Preseed files for Debian and Ubuntu
- Publish (a content view)
- Pulp
- Puppet
- OpenVox agent
- Puppet environment
- Puppet manifest
- OpenVox server
A Smart Proxy server component that provides a Puppet catalog to hosts for execution by the OpenVox agent.
- Puppet module
- PXE
- Recurring logic
- Registry
- Remote execution (REX)
- Repository
A repository is a single source and the smallest unit of content in Foreman. You can either synchronize a repository with a URL or manually upload content to Foreman. Foreman supports multiple content types. For more information, see Content types in Foreman in Managing content. One or more repositories form a product.
- Resource type
- Role
- Salt
- SCAP content
SCAP stands for Security Content Automation Protocol and refers to
.xmlfiles containing the configuration and security baseline against which hosts are checked. Foreman uses SCAP content in compliance policies.
- Smart Proxy server
Smart Proxy servers can provide DHCP, DNS, and TFTP services and act as an Ansible control node, OpenVox server, or Salt Master in separate networks. They interact with Foreman server in a client-server model. Foreman server always comes bundled with an integrated Smart Proxy.
Smart Proxy servers are required in Foreman deployments that manage IT infrastructure spanning across multiple networks and useful for Foreman deployments across various geographical locations.
- Subnet image
- Subscription
- Subscription Manager
subscription-manageruses activation keys to consume content on hosts.
- SUSE Subscription
You can use Foreman to manage SUSE content. For more information, see Managing SUSE content in Managing content.
- Synchronization
Synchronization describes the process of fetching content from external repositories into the Foreman server.
- Sync plan
- Tailoring files
- Task
- Trend
- Updating Foreman
The process of advancing your Foreman server and Smart Proxy server installations from one patch release to the next, for example Foreman 3.15.0 to Foreman 3.15.1.
- Upgrading Foreman
The process of advancing your Foreman server and Smart Proxy server installations from one minor release to the next, for example Foreman 3.14 to Foreman 3.15.
- User group
- User
- Virtualization
- virt-who
- XCCDF profiles
Appendix C: CLI help
Foreman offers multiple user interfaces: Foreman web UI, Hammer CLI, API, and through Ansible collection theforeman.foreman. If you want to administer Foreman on the command line, have a look at the following help output.
- Foreman services
foreman-maintaintool to manage these services. To see the full list of services, enter theforeman-maintain service listcommand on the machine where Foreman or Smart Proxy server is installed. For more information, runforeman-maintain --helpon your Foreman server or Smart Proxy server.
- Foreman plugins
You can extend Foreman by installing plugins. For more information, run
foreman-installer --full-helpon your Foreman server or Smart Proxy server.
- Hammer CLI
You can manage Foreman on the command line using
hammer. For more information on using Hammer CLI, see Using the Hammer CLI tool or runhammer --helpon your Foreman server or Smart Proxy server.
