With the Representational State Transfer (REST) API of Foreman, you can control your Foreman environment outside of the standard web interface. That way, you can integrate your Foreman with custom scripts or external applications over HTTP.
  • Broad client support – any programming language, framework, or system with support for HTTP protocol can use the API.
  • Self-descriptive – client applications require minimal knowledge of the Foreman infrastructure because a user discovers many details at runtime.
  • Resource-based model – the resource-based REST model provides a natural way to manage a virtualization platform.
  • Integrate with enterprise IT systems.
  • Integrate with third-party applications.
  • Perform automated maintenance or error checking tasks.
  • Automate repetitive tasks with scripts.
To accomplish the tasks listed above, you must combine the API reference information with your specific integration or automation requirements.
Hammer serves as a human-friendly interface to Foreman API. Use Hammer for interactive tasks and testing API calls, but use the API directly for better performance when executing many commands in scripts.
1.3. Built-in Foreman API documentation
Access built-in Foreman API documentation on your Foreman server to understand available operations, endpoints, and parameters without leaving Foreman web UI.
View the full API reference on your Foreman server at the following URL:
https://foreman.example.com/apidoc/
2. Foreman API request and response syntax
Understanding the basic syntax of API requests and JSON responses enables you to construct valid API calls and interpret the returned data.
Even though versions 1 and 2 of the Foreman API are available, Foreman community only supports version 2.
2.1. API request composition
You can use the built-in API reference documentation to compose valid API requests.
HTTP_METHOD API_ROUTE
$ curl \
--data @My_Input_File.json \
--header "Accept: application/json" \
--output My_Output_File
--request HTTP_METHOD \
API_ROUTE \
| python3 -m json.tool
--data
For POST and PUT requests, use the --data option to pass JSON-formatted data.
--header
When passing the JSON data with the --data option, you must specify the following headers with the --header option.
--output
When downloading content from Foreman server, specify the output file with the --output option.
--request
To use curl for the API call, specify an HTTP method with the --request option. For example, --request POST.
--user
Provide Foreman user credentials with the --user option.
API_ROUTE
Use the API route in the following format: \https://foreman.example.com/api/architectures. In Foreman, version 2 of the API is the default. Therefore, it is not necessary to use v2 in the URL for API calls.
json.tool
Redirect the output to the Python json.tool module to make the output easier to read.
2.1.1. Use the GET HTTP method
  • Submit a GET request by using curl.
    Example API request:
    $ curl \
    --request GET \
    --user My_User_Name:My_Password \
    https://foreman.example.com/api/hosts \
    Example API response:
      "total": 2,
      "subtotal": 2,
      "page": 1,
      "per_page": 20,
      "search": null,
      "sort": {
        "by": null,
        "order": null
      "results":
        output truncated
    The response from the API indicates that there are two results in total, this is the first page of the results, and the maximum results per page is set to 20. For more information, see JSON response format.
2.1.2. Filter hosts using API search queries
You can combine search parameters in your API queries to filter hosts. This way you can target specific hosts by their operating system or hardware model.
  2. Click the Search field to display a list of search parameters.
  3. Locate the search parameters that you want to use. For this example, locate os_title and model.
  4. Combine the search parameters in your API query as follows:
    Example request:
    $ curl \
    --data-urlencode 'search=os_title="RedHat 7.7",model="PowerEdge R330"' \
    --get \
    https://foreman.example.com/api/v2/hosts \
    Example response:
        "results": [
                "model_id": 1,
                "model_name": "PowerEdge R330",
                "name": "foreman.example.com",
                "operatingsystem_id": 1,
                "operatingsystem_name": "RedHat 7.7",
        "search": "os_title=\"RedHat 7.7\",model=\"PowerEdge R330\"",
        "subtotal": 1,
        "total": 11
2.2. Pagination parameters for API searches
You can control how many results an API query returns per page and which page to retrieve in order to manage large datasets efficiently.
The number of items to be presented is set using the setting entries_per_page, which defaults to 20. However, you can change it per request by using the parameter per_page.
This example returns a list of architectures for an organization with ID 1 in pages. The list contains 5 entries per page and returns the second page.
Example API request
$ curl \
--request GET \
'https://foreman.example.com/api/architectures?organization_id=1&per_page=5&page=2'
2.2.1. Multiple page returns in API responses
You can iterate through multiple pages of API results to retrieve complete datasets when the total number of items exceeds the per-page limit.
Bash script
$ for i in seq 1 3; do \
  curl \
  --request GET \
  "https://foreman.example.com/katello/api/content_views?per_page=5&page=$i"; \
done
2.2.2. Use the POST HTTP method
Use the POST HTTP method to create new resources such as activation keys or hosts.
You must submit the data in JSON format. For more information, see JSON data format for API requests.
  1. Create a test file, for example, activation-key.json, with the following content:
    {"organization_id":1, "name":"TestKey", "description":"Just for testing"}
  2. Create an activation key by applying the data in the activation-key.json file.
    $ curl \
    --request POST \
    --data @activation-key.json \
    https://foreman.example.com/katello/api/activation_keys \
        "service_level": null,
        "content_overrides": [],
        "id": 2,
        "name": "TestKey",
        "description": "Just for testing",
        "unlimited_hosts": true,
        "content_view_environment_labels": "",
        "usage_count": 0,
        "user_id": 3,
        "max_hosts": null,
        "release_version": null,
        "purpose_usage": null,
        "purpose_role": null,
        "organization_id": 1,
        "organization": {
            "name": "Default Organization",
            "label": "Default_Organization",
            "id": 1
        "created_at": "2026-10-19 07:11:45 UTC",
        "updated_at": "2026-10-19 07:11:45 UTC",
        "content_view_environments": [],
        "host_collections": [],
        "multi_content_view_environment": false,
        "permissions": {
            "view_activation_keys": true,
            "edit_activation_keys": true,
            "destroy_activation_keys": true
  • In the Foreman web UI, navigate to Content > Lifecycle > Activation Keys to view your activation keys.
2.2.3. Use the PUT HTTP method
Use the PUT HTTP method to update existing resources such as changing activation key properties or host configurations.
  1. Edit the activation-key.json file created previously as follows:
    {"organization_id":1, "name":"TestKey", "description":"Just for testing","max_hosts":"10" }
  2. Apply the changes in the JSON file.
    $ curl \
    --request PUT \
    https://foreman.example.com/katello/api/activation_keys/2 \
        "id": 2,
        "name": "TestKey",
        "unlimited_hosts": false,
        "usage_count": 0,
        "user_id": 3,
        "max_hosts": 10,
        "organization": {
            "id": 1
        "updated_at": "2026-10-19 07:20:12 UTC",
        "permissions": {
  • In the Foreman web UI, navigate to Content > Lifecycle > Activation Keys to view the updated activation keys.
2.2.4. Use the DELETE HTTP method
Use the DELETE HTTP method with an API route to permanently remove resources such as activation keys or hosts from Foreman.
This example deletes the TestKey activation key, whose ID is 2.
  • Submit a DELETE request by using curl.
    $ curl \
    --request DELETE \
    output omitted
        "started_at": "2024-02-16 12:58:17 UTC",
        "ended_at": "2024-02-16 12:58:18 UTC",
        "state": "stopped",
        "result": "success",
        "progress": 1.0,
        "input": {
            "activation_key": {
                "id": 2,
                "name": "TestKey"
    output truncated
2.3. JSON response format
Foreman API returns results in JSON format, which you can parse programmatically to extract data from single-object responses or collections responses.
2.3.1. JSON response format for single objects
You can use single-object JSON responses to work with a single object. API requests to a single object require the unique identifier :id of the object.
API request
$ curl \
--request GET \
https://foreman.example.com/api/domains/23 \
API response
    "id": 23,
    "name": "qa.lab.example.com",
    "fullname": "QA",
    "dns_id": 10,
    "created_at": "2024-08-13T09:02:31Z",
    "updated_at": "2024-08-13T09:02:31Z"
2.3.2. JSON response format for collections
Collections return lists of objects, such as hosts and domains. Each response includes pagination metadata and a results section containing the data you can iterate through.
Example API request
$ curl \
--request GET \
https://foreman.example.com/api/domains \
    "total": 3,
    "subtotal": 3,
    "page": 1,
    "per_page": 20,
    "search": null,
    "sort": {
        "by": null,
        "order": null
    "results": [
            "id": 23,
            "fullname": "QA",
            "dns_id": 10,
            "id": 25,
            "name": "dev.lab.example.com",
            "fullname": "DEVEL",
            "dns_id": 8,
            "created_at": "2024-08-13T08:32:48Z",
            "updated_at": "2024-08-14T07:04:03Z"
            "id": 32,
            "name": "hr.lab.example.com",
            "fullname": "HR",
            "dns_id": 8,
            "created_at": "2024-08-16T08:32:48Z",
            "updated_at": "2024-08-16T07:04:03Z"
2.3.3. JSON response metadata
Review the metadata fields in Foreman API responses to understand pagination, search results, and collection information when working with the API.
total
subtotal
page
The page number.
per_page
limit
offset
search
The search string based on scoped_scoped syntax.
sort
  • by – Specifies by what field the API sorts the collection.
  • order – The sort order, either ASC for ascending or DESC for descending.
results
The collection of objects.
2.3.4. API response codes
Table 1. API response codes
Response Explanation
200 OK
For a successful request action: show, index, update, or delete (GET, PUT, DELETE requests).
201 Created
For a successful create action (POST request).
301 Moved Permanently
Redirect when Foreman is restricted to use HTTPS and HTTP is attempted.
400 Bad Request
A required parameter is missing or the search query has invalid syntax.
401 Unauthorized
Failed to authorize the user, for example, due to incorrect credentials.
403 Forbidden
The user has insufficient permissions to perform the action or read the resource, or the action is unsupported in general.
404 Not Found
The record with the given ID does not exist. It can appear in show and delete actions when the requested record does not exist; or in create, update and delete actions when one of the associated records does not exist.
409 Conflict
Could not delete the record due to existing dependencies, for example, host groups that still contain hosts.
415 Unsupported Media Type
The content type of the HTTP request is not JSON.
422 Unprocessable Entity
Failed to create an entity due to some validation errors. Applies to create or update actions only.
500 Internal Server Error
Unexpected internal server error.
503 Service Unavailable
The server is not running.
2.4. API error message reference
3. API request authentication
You must authenticate API calls to Foreman server by using SSL certificates and valid user credentials, with options for HTTP basic authentication, SSL client certificates, or personal access tokens.
3.1. Certificate trust requirements for the Foreman API
Foreman requires HTTPS for all API communications to provide encryption and identity verification. You can use either self-signed certificates or custom SSL certificates you configure.
Foreman 5.0 does not support non-SSL communications.
By default, Foreman server uses a self-signed certificate. This certificate acts as both the server certificate to verify the encryption key and the certificate authority (CA) to trust the identity of Foreman server.
3.2. Trust the Foreman CA certificate for API clients
Configure SSL authentication to enable secure API requests to Foreman by installing and trusting the CA certificate.
  1. Obtain a certificate from your Foreman server by using one of the following options:
    • If you plan to call the API from a remote server, download the CA certificate:
      $ curl \
      --output /etc/pki/ca-trust/source/anchors/foreman.example.com-katello-server-ca.crt \
      http://foreman.example.com/pub/katello-server-ca.crt
    • If you plan to call the API directly on your Foreman server, copy the certificate to the /etc/pki/ca-trust/source/anchors directory:
      # cp /var/www/html/pub/katello-server-ca.crt /etc/pki/ca-trust/source/anchors/foreman.example.com-katello-server-ca.crt
  2. Add the certificate to the list of trusted CAs:
    $ update-ca-trust extract
  • Verify that your client trusts the Foreman SSL certificate by entering the API request without the --cacert option:
    $ curl \
    --request GET \
3.3. HTTP Basic authentication for the Foreman API
You must provide valid Foreman credentials to access the Foreman API.
The API uses HTTP Basic authentication to send encoded user credentials in the Authorization header. If a request does not include an appropriate Authorization header, the API returns a 401 Authorization Required error.
Basic authentication involves potentially sensitive information, for example, it sends passwords as plain text. The REST API requires HTTPS for transport-level encryption of plain text requests.
Some base64 libraries break encoded credentials into multiple lines and terminate each line with a newline character. This invalidates the header and causes a faulty request. The Authorization header requires the encoded credentials to be on a single line within the header.
3.4. Personal access tokens for the Foreman API
You can use Personal Access Tokens to authenticate API requests instead of passwords. Additionally, you can manage your security by setting expiration dates or revoking tokens at any time.
3.4.1. Create a Personal Access Token
  • Your user account has a role that grants the create_personal_access_tokens permission.
    $ curl \
    {"foreman_version":"5.0.0","result":"ok","status":200,"version":"3.5.1.10","api_version":2}
3.4.2. Revoke a Personal Access Token
    $ curl \
4. API request examples
You can interact with Foreman API using curl for quick testing, Ruby for automation scripts with apipie bindings, or Python for integration with existing Python-based workflows.
4.1. API requests with curl
You can use curl to test API endpoints, debug requests, and perform quick operations without writing scripts.
You can use curl to manipulate resources on your Foreman server. API calls to Foreman require data in json format.
Foreman requires the use of HTTPS, and by default, a certificate for host identification.
For user authentication, you can use the --user option to provide Foreman user credentials in the form --user My_User_Name:My_Password. If you do not include the password, the command prompts you to enter it. To reduce security risks, do not include the password as part of the command, because it then becomes part of your shell history. For simplicity, the examples in this section include the password.
4.1.1. JSON data format for API requests
You can pass JSON-formatted data to Foreman API requests either as inline strings or external files.
--header "Content-Type: application/json"
JSON-formatted string
Enclose the quoted JSON-formatted data in curly braces {}. When passing a value for a JSON type parameter, you must escape quotation marks " with backslashes \. For example, within curly braces, you must format "Example JSON Variable" as \"Example JSON Variable\":
--data {"id":44, "smart_class_parameter":{"override":"true", "parameter_type":"json", "default_value":"{\"GRUB_CMDLINE_LINUX\": {\"audit\":\"1\",\"crashkernel\":\"true\"}}"}}
JSON-formatted file
The unquoted JSON-formatted data enclosed in a file and specified by the @ sign and the filename. For example:
--data @file.json
  • You can use your favorite text editor.
  • You can use syntax checker to find and avoid mistakes.
  • You can use tools to check the validity of JSON data or to reformat it.
$ json_verify < file.json
4.1.2. Resource list retrieval API request
You can retrieve lists of Foreman resources such as users, hosts, or organizations using GET requests, with responses containing both metadata for pagination and the actual resource data.
Example API request
$ curl \
--request GET \
https://foreman.example.com/api/users \
    "page": 1,
    "per_page": 20,
    "results": [
            "admin": false,
            "auth_source_id": 1,
            "auth_source_name": "Internal",
            "created_at": "2024-09-21 08:59:22 UTC",
            "default_location": null,
            "default_organization": null,
            "description": "",
            "effective_admin": false,
            "firstname": "",
            "id": 5,
            "last_login_on": "2024-09-21 09:03:25 UTC",
            "lastname": "",
            "locale": null,
            "locations": [],
            "login": "test",
            "mail": "test@example.com",
            "organizations": [
                    "id": 1,
            "ssh_keys": [],
            "timezone": null,
            "updated_at": "2024-09-21 09:04:45 UTC"
            "admin": true,
            "created_at": "2024-09-20 07:09:41 UTC",
            "default_organization": {
                "description": null,
                "id": 1,
                "title": "Default Organization"
            "description": "",
            "effective_admin": true,
            "firstname": "Admin",
            "id": 4,
            "last_login_on": "2024-12-07 07:31:09 UTC",
            "lastname": "User",
            "locale": null,
            "locations": [
                    "id": 2,
                    "name": "Default Location"
            "login": "admin",
            "mail": "admin@example.com",
            "organizations": [
                    "id": 1,
            "ssh_keys": [],
            "timezone": null,
            "updated_at": "2024-11-14 08:19:46 UTC"
    "search": null,
    "sort": {
        "by": null,
        "order": null
    "subtotal": 2,
    "total": 2
4.1.3. User creation API request
You can create Foreman user accounts using POST requests.
Example API request
$ curl \
--request POST \
4.1.4. User modification API request
You can modify Foreman user accounts using PUT requests by specifying the user ID and the fields you want to update, such as login name or email address.
This example changes the given name and login for the test_user account.
Example API request
$ curl \
--request PUT \
--data "{\"firstname\":\"New Test Name\",\"mail\":\"test@example.com\",\"login\":\"new_test_user\",\"password\":\"password123\",\"auth_source_id\":1}" \
https://foreman.example.com/api/users/8 \
4.2. API requests with Ruby
You can use Ruby to automate complex Foreman workflows. Use REST client libraries or apipie bindings to get type-safe API calls with built-in validation.
These are example scripts and commands. Ensure you review these scripts carefully before use, and replace any variables, user names, passwords, and other information to suit your own deployment.
4.2.1. Object creation with Ruby
You can use Ruby-based REST clients to create Foreman organizations and lifecycle environments programmatically, with built-in error handling for existing resources.
This script connects to the Foreman API, creates an organization, and then creates three lifecycle environments in the organization. If the organization already exists, the script uses that organization. If any of the lifecycle environments already exist in the organization, the script returns an error and exits.
#!/usr/bin/ruby
require 'rest-client'
require 'json'
url = 'https://foreman.example.com'
katello_url = "#{url}/katello/api/v2"
$username = '_My_User_Name_'
$password = '_My_Password_'
org_name = "_My_Organization_"
environments = [ "Development", "Testing", "Production" ]
# Performs a GET by using the passed URL location
def get_json(location)
  response = RestClient::Request.new(
    :method => :get,
    :url => location,
    :user => $username,
    :password => $password,
    :headers => { :accept => :json,
    :content_type => :json }
  ).execute
  JSON.parse(response.to_str)
end
# Performs a POST and passes the data to the URL location
def post_json(location, json_data)
    :method => :post,
    :url => location,
    :user => $username,
    :content_type => :json},
    :payload => json_data
  ).execute
end
# Creates a hash with ids mapping to names for an array of records
def id_name_map(records)
  records.inject({}) do |map, record|
    map.update(record['id'] => record['name'])
  end
end
# Get list of existing organizations
orgs = get_json("#{katello_url}/organizations")
org_list = id_name_map(orgs['results'])
if !org_list.has_value?(org_name)
  # If our organization is not found, create it
  puts "Creating organization: \t#{org_name}"
  org_id = post_json("#{katello_url}/organizations", JSON.generate({"name"=> org_name}))["id"]
else
  # Our organization exists, so let's grab it
  org_id = org_list.key(org_name)
  puts "Organization \"#{org_name}\" exists"
end
# Get list of organization's lifecycle environments
envs = get_json("#{katello_url}/organizations/#{org_id}/environments")
env_list = id_name_map(envs['results'])
prior_env_id = env_list.key("Library")
# Exit the script if at least one life cycle environment already exists
environments.each do |e|
  if env_list.has_value?(e)
    puts "ERROR: One of the Environments is not unique to organization"
    exit
  end
end
 # Create life cycle environments
environments.each do |environment|
  puts "Creating environment: \t#{environment}"
  prior_env_id = post_json("#{katello_url}/organizations/#{org_id}/environments", JSON.generate({"name" => environment, "organization_id" => org_id, "prior_id" => prior_env_id}))["id"]
end
4.2.2. Apipie bindings with Ruby
You can use apipie bindings in Ruby to automatically fetch and cache Foreman API definitions. This way, you can write type-safe API calls with built-in validation and reduce manual endpoint configuration.
#!/usr/bin/ruby
require 'apipie-bindings'
# Create an instance of apipie bindings
@api = ApipieBindings::API.new({
  :uri => 'https://foreman.example.com/',
  :username => 'admin',
  :password => 'changeme',
  :api_version => 2
# Performs an API call with default options
def call_api(resource_name, action_name, params = {})
  http_headers = {}
  apipie_options = { :skip_validation => true }
  @api.resource(resource_name).call(action_name, params, http_headers, apipie_options)
end
# Creates a hash with IDs mapping to names for an array of records
  end
end
orgs = call_api(:organizations, :index)
  org_id = call_api(:organizations, :create, {'organization' => { :name => org_name }})['id']
else
end
# Get list of organization's life cycle environments
envs = call_api(:lifecycle_environments, :index, {'organization_id' => org_id})
    exit
  end
end
  prior_env_id = call_api(:lifecycle_environments, :create, {"name" => environment, "organization_id" => org_id, "prior_id" => prior_env_id })['id']
end
4.3. API requests with Python
You can use Python with the requests module to integrate Foreman API calls into existing Python automation workflows, data processing pipelines, or DevOps tooling.
4.3.1. Object creation with Python
You can use the Python requests module to create Foreman organizations and lifecycle environments programmatically.
#!/usr/bin/python3
import json
import sys
try:
    import requests
except ImportError:
    print("Please install the python-requests module.")
    sys.exit(-1)
# URL to your Foreman server
URL = "https://foreman.example.com"
KATELLO_API = f"{URL}/katello/api/v2"
POST_HEADERS = {'content-type': 'application/json'}
# Default credentials to login to Foreman
USERNAME = "admin"
PASSWORD = "changeme"
# Ignore SSL for now
SSL_VERIFY = False
# Name of the organization to be either created or used
ORG_NAME = "MyOrg"
# Name for life cycle environments to be either created or used
ENVIRONMENTS = ["Development", "Testing", "Production"]
def get_json(location):
    r = requests.get(location, auth=(USERNAME, PASSWORD), verify=SSL_VERIFY)
    return r.json()
def post_json(location, json_data):
    result = requests.post(
        location,
        data=json_data,
        verify=SSL_VERIFY,
        headers=POST_HEADERS
    return result.json()
def main():
    Main routine that creates or re-uses an organization and
    life cycle environments.
    If life cycle environments already
    exist, exit out.
    # Check if our organization already exists
    org = get_json(f"{KATELLO_API}/organizations/{ORG_NAME}")
    if org.get('error', None):
        org_id = post_json(
            f"{KATELLO_API}/organizations/",
            json.dumps({"name": ORG_NAME})
        )["id"]
        print("Creating organization:\t" + ORG_NAME)
    else:
        org_id = org['id']
        print(f"Organization '{ORG_NAME}' exists.")
    # Now, let's fetch all available life cycle environments for this org...
    envs = get_json(
        f"{KATELLO_API}/organizations/{org_id}/environments/"
    # ...and add them to a dictionary, with respective 'Prior' environment
    prior_env_id = 0
    env_list = {}
    for env in envs['results']:
        env_list[env['id']] = env['name']
        prior_env_id = env['id'] if env['name'] == "Library" else prior_env_id
    if all(environment in env_list.values() for environment in ENVIRONMENTS):
        print("ERROR: One of the Environments is not unique to organization")
        sys.exit(-1)
    for environment in ENVIRONMENTS:
        new_env_id = post_json(
            f"{KATELLO_API}/organizations/{org_id}/environments/",
            json.dumps({
                "name": environment,
                "organization_id": org_id,
                "prior_id": prior_env_id
        )["id"]
        print("Creating environment:\t" + environment)
        prior_env_id = new_env_id
if __name__ == "__main__":
    main()
4.3.2. Resource information retrieval with Python
You can use Python to retrieve and display Foreman resource information such as host details, facts, and subscriptions. With this script, you can then format the Foreman API response specifically for your reporting or monitoring workflows.
#!/usr/bin/env python3
import json
import sys
try:
    import requests
except ImportError:
    sys.exit(-1)
HOSTNAME = "foreman.example.com"
# Name of the managed host whose information you want to retrieve.
MANAGED_HOSTNAME = "host.example.com"
# URL for the API to your Foreman server
FOREMAN_API = f"https://{HOSTNAME}/api/"
KATELLO_API = f"https://{HOSTNAME}/katello/api/v2/"
USERNAME = "admin"
PASSWORD = "password"
# Name of the organization whose subscriptions you want to retrieve.
ORGANIZATION_NAME = "Default Organization"
SSL_VERIFY = False
#SSL_VERIFY = "./path/to/CA-certificate.crt" # Put the path to your CA certificate here to allow SSL_VERIFY
def get_json(url):
    r = requests.get(url, auth=(USERNAME, PASSWORD), verify=SSL_VERIFY)
    return r.json()
def get_results(url):
    jsn = get_json(url)
    if jsn.get('error'):
        print("Error: " + jsn['error']['message'])
    else:
        if jsn.get('results'):
            return jsn['results']
        elif 'results' not in jsn:
            return jsn
        else:
            print("No results found")
    return None
def display_all_results(url):
    results = get_results(url)
    if results:
        print(json.dumps(results, indent=4, sort_keys=True))
def display_info_for_hosts(url):
    hosts = get_results(url)
    if hosts:
        print(f"{'ID':10}{'Name':40}{'IP':30}{'Operating System':30}")
        for host in hosts:
            print(f"{str(host['id']):10}{host['name']:40}{str(host['ip']):30}{str(host['operatingsystem_name']):30}")
def display_info_for_subs(url):
    subs = get_results(url)
    if subs:
        print(f"{'ID':10}{'Name':90}{'Start Date':30}")
        for sub in subs:
            print(f"{str(sub['id']):10}{sub['name']:90}{str(sub['start_date']):30}")
def main():
    host = MANAGED_HOSTNAME
    print(f"Displaying all info for host {host} ...")
    display_all_results(FOREMAN_API + 'hosts/' + host)
    print(f"Displaying all facts for host {host} ...")
    display_all_results(FOREMAN_API + f'hosts/{host}/facts')
    host_pattern = 'example'
    print(f"Displaying basic info for hosts matching pattern '{host_pattern}'...")
    display_info_for_hosts(FOREMAN_API + 'hosts?per_page=1&search=name~' + host_pattern)
    print(f"Displaying basic info for subscriptions")
    organization = get_results(KATELLO_API + 'organizations/' + ORGANIZATION_NAME)
    if organization:
            KATELLO_API + f"subscriptions?organization_id=\{organization['id']}"
    else:
        print(f"Organization '{ORGANIZATION_NAME}' does not exist.")
    main()
Report issue
