1. Tune performance with predefined profiles
If your Foreman deployment includes a large number of hosts, you can use predefined tuning profiles to configure your Foreman server to use the optimal amount of CPU cores and memory. This can help improve Foreman performance.
Select the profile that best matches your use case:
Table 1. Predefined tuning profiles Tuning profile Number of hosts RAM Number of CPU cores default
0 – 5000
20G
4
medium
5001 – 10000
32G
8
large
10001 – 20000
64G
16
extra-large
20001 – 60000
128G
32
extra-extra-large
60000+
256G
48+
Apply a predefined tuning profile to your Foreman server:
# foremanctl deploy --tuning My_profile
Replace
My_profilewith the name of the profile you want to apply.
2. Reduce Foreman server load with an external database
When you install Foreman, PostgreSQL runs on the same server as Foreman by default. If you use internal databases but need to reduce server load, you can migrate them to external databases.
2.1. Determine whether your Foreman server uses internal or external databases
You can confirm whether your Foreman server uses internal or external databases by checking PostgreSQL deployment on the server.
On Foreman server, inspect the status of the local PostgreSQL container service:
# systemctl status postgresql.service
When Foreman server uses internal databases, the
postgresql.serviceunit is active. -
When Foreman server uses external databases, the local
postgresql.serviceunit is inactive or not enabled.
This check reflects steady-state configuration. During a migration to external databases, the local
postgresql.serviceunit is still active until you remove the internal PostgreSQL deployment. -
2.2. External PostgreSQL considerations
Foreman, Katello, and Candlepin use PostgreSQL. Review the advantages and disadvantages of external PostgreSQL to decide if this option fits your Foreman configuration.
Foreman supports PostgreSQL version 16, which is available in Enterprise Linux 10 repositories. By default, internal PostgreSQL runs in a Podman container on Foreman server. An external database runs on a dedicated host that you provision and maintain separately.
- Advantages of external PostgreSQL
Increase in free memory and free CPU on Foreman
Flexibility to set
shared_bufferson the PostgreSQL database to a high number without the risk of interfering with other services on Foreman -
Flexibility to tune the PostgreSQL server’s system without adversely affecting Foreman operations
- Disadvantages of external PostgreSQL
If either Foreman or the PostgreSQL database server suffers a hardware or storage failure, Foreman is not operational
If there is latency between the Foreman server and database server, performance can suffer
2.3. Install PostgreSQL as an external database
Install and configure PostgreSQL on a dedicated host if you want to use an external database with your Foreman server.
The prepared host has base operating system repositories enabled.
The prepared host has enough disk space available for the
/var/lib/pgsqldirectory. The expected installation size is 100 MB and the expected runtime size is 20 GB.
On your new database server, install PostgreSQL:
# dnf install postgresql-server postgresql-contrib
Initialize the PostgreSQL database:
# postgresql-setup --initdb
Edit the
Note that you must adjust the default configuration of external PostgreSQL to work with Foreman. The base recommended external database configuration adjustments are as follows:
max_connections: 500
shared_buffers: 512MB
work_mem: 4MB
Remove the
Add the following line to the end of the file to use Salted Challenge Response Authentication Mechanism (SCRAM) for authentication:
Edit the
host all all Foreman_ip/32 scram-sha-256
Start and enable the PostgreSQL service:
Update the firewall configuration. For example, using the
firewall-cmdcommand:-
Open the postgresql port:
Make the changes persistent:
Switch to the
Create three databases and dedicated roles: one for Foreman, one for Candlepin, and one for Pulp:
CREATE USER "foreman" WITH PASSWORD 'Foreman_Password'; CREATE DATABASE foreman OWNER foreman; CREATE USER "candlepin" WITH PASSWORD 'Candlepin_Password'; CREATE DATABASE candlepin OWNER candlepin; CREATE USER "pulp" WITH PASSWORD 'Pulpcore_Password'; CREATE DATABASE pulpcore OWNER pulp;
Exit the
postgresuser:# \q
From Foreman server, test that you can access the database:
# PGPASSWORD='Foreman_Password' pg_isready --host=postgres.example.com --port=5432 --username=foreman --dbname=foreman # PGPASSWORD='Candlepin_Password' pg_isready --host=postgres.example.com --port=5432 --username=candlepin --dbname=candlepin # PGPASSWORD='Pulpcore_Password' pg_isready --host=postgres.example.com --port=5432 --username=pulp --dbname=pulpcore
If the connection succeeded, this displays an
accepting connectionsmessage.
2.4. Move Foreman databases to an external host
Migrate internal PostgreSQL databases from Foreman server to a dedicated external host when you need to reduce server load or manage the database independently.
Insights in Foreman requires internal database mode. You cannot migrate to an external database while Insights in Foreman is enabled on Foreman server. |
You have installed and configured a PostgreSQL server on an external server.
You have confirmed that Foreman server currently uses internal databases. For more information, see Determine whether your Foreman server uses internal or external databases.
You have scheduled a maintenance window. The
foremanctl backupcommand stops all Foreman services during the backup process.
On Foreman server, create a directory for the backup:
# mkdir /var/My_Migration_Backup_Directory/
# foremanctl backup /var/My_Migration_Backup_Directory/
The backup stops all Foreman services, creates database dumps, and then restarts the services. The command creates a timestamped subdirectory, such as
/var/My_Migration_Backup_Directory/foreman-backup-TIMESTAMP/, that containsforeman.dump,candlepin.dump, andpulp.dumpfiles.NoteThe backup fails if Foreman tasks are running. Wait for active tasks to finish before you run the backup, or add the
--wait-for-tasksflag to wait for running tasks to complete. -
Verify the backup:
# ls -lh /var/My_Migration_Backup_Directory/foreman-backup-*/ # cat /var/My_Migration_Backup_Directory/foreman-backup-*/metadata.yml # ls -lh /var/My_Migration_Backup_Directory/foreman-backup-*/*.dump
Confirm that the timestamped backup directory contains
foreman.dump,candlepin.dump,pulp.dump, andmetadata.ymlfiles. -
PGPASSWORD='Foreman_Password' pg_restore --host=postgres.example.com --username=foreman --dbname=foreman < /var/My_Migration_Backup_Directory/foreman-backup-TIMESTAMP/foreman.dump PGPASSWORD='Candlepin_Password' pg_restore --host=postgres.example.com --username=candlepin --dbname=candlepin < /var/My_Migration_Backup_Directory/foreman-backup-TIMESTAMP/candlepin.dump PGPASSWORD='Pulpcore_Password' pg_restore --host=postgres.example.com --username=pulp --dbname=pulpcore < /var/My_Migration_Backup_Directory/foreman-backup-TIMESTAMP/pulp.dump
Replace
foreman-backup-TIMESTAMPwith the timestamped directory that the backup created. -
Use the
foremanctl deploycommand to update Foreman to point to the new external databases:# foremanctl deploy \ --database-mode external \ --database-host postgres.example.com \ --database-port 5432 \ --foreman-database-name foreman \ --foreman-database-user foreman \ --foreman-database-password Foreman_Password \ --candlepin-database-name candlepin \ --candlepin-database-user candlepin \ --candlepin-database-password Candlepin_Password \ --pulp-database-name pulpcore \ --pulp-database-user pulp \ --pulp-database-password Pulpcore_Password
For a complete list of external database parameters, including optional SSL connection options, see Deploy Foreman server configuration with an external database.
Verify that Foreman server is operational:
# foremanctl health $ hammer ping
Confirm that
foremanctl healthreports no failures and thathammer pingreturns a successful response before you remove the internal PostgreSQL deployment. -
Remove the obsolete internal PostgreSQL deployment on Foreman server:
The internal PostgreSQL database runs as a container managed by the
postgresql.servicesystemd unit.# systemctl disable --now postgresql.service # rm -rf /var/lib/pgsql/data
NoteWhen you switch to external databases,
foremanctl deploydoes not remove Podman quadlet unit files under/etc/containers/systemd/, such aspostgresql.containerandpostgresql.image, or Podman secrets, such aspostgresql-admin-password. Stopping the service and removing/var/lib/pgsql/datadisables the internal database and frees the data volume.
3. Prepare for disaster recovery and recover from data loss
- Snapshots of virtualized Foreman server
- How do I back up?
Virtualize your Foreman server and use the hypervisor tools to take virtual machine snapshots of the server. This method is suitable if you can run Foreman in a virtual machine.
- Active and passive Foreman server, with external storage
- How do I back up?
/var/lib/pulpand database in/var/lib/pgsql. Replicate this storage into a different data center. Attach the storage to a Foreman server that is a clone of the primary Foreman server but runs passively. - How will I recover in case of a disruptive event?
To recover Foreman services, switch DNS records of the active Foreman server with the passive Foreman server. This ensures that the passive server becomes the active server. All hosts remain connected without configuration updates.
- Active and passive Foreman server, with backup and restore
- How do I back up?
Ensure periodic backups of your Foreman server. Copy this backup to a passive Foreman server and restore it on the passive server.
- Dual active Foreman server
- How do I back up?
Operate an active, independent Foreman server per data center. Hosts from each data center are registered to the Foreman server in that data center. Then configure automation to ensure recovery in case of a disruptive event. For example, you can periodically run a health check and if the health check discovers that the current Foreman server a host is registered to does not resolve, the host is re-registered to the other Foreman server.
To recover Foreman services, re-register all hosts to the Foreman server in the other data center.
3.1. Disaster recovery by virtualizing your Foreman server
If you virtualize your Foreman server and ensure that you take regular snapshots of the virtual machine (VM), you can respond to various disaster scenarios by restoring your Foreman deployment from one of your snapshots.
The details for how to implement this scenario depend on your choice of a virtualization platform. Due to the variety of different hypervisors and their capabilities, Foreman community does not provide detailed instructions for any specific virtualization platform. |
3.1.1. Prepare for failures by virtualizing your Foreman server
Implement a reliable process for regularly taking VM snapshots of your virtualized Foreman server and for backing up your snapshots for long-term storage.
You have reviewed Prepare for disaster recovery and recover from data loss and determined that this disaster recovery plan works for you.
Your Foreman server is deployed as a VM.
Define a schedule for taking periodic snapshots of your virtualized Foreman server. Consider your tolerance for potential data loss: Taking snapshots frequently will result in smaller amounts of data loss in case of a disaster. However, creating a snapshot takes time, and the snapshots also require storage space.
Using your hypervisor, schedule periodic snapshots of your Foreman server.
If you are using an external database that runs on a different machine than your Foreman server, create snapshots and backups on the same schedule as your Foreman server.
Use the latest snapshot of your Foreman server and restore it in an isolated environment.
To verify that you will be able to restore Foreman services in case of a disaster, assess the functionality of the test Foreman server. For more information, see Retrieve status of services by using Hammer CLI.
3.1.2. Recover from disaster by restoring a VM snapshot of Foreman server
In case of a disaster, use a virtual machine (VM) snapshot of your Foreman server to restore Foreman services.
Ensure that the hostname of your Foreman server does not change during recovery. The IP address can change. |
If you are using an external database that runs on a different machine than your Foreman server, ensure that you restore the database from a snapshot taken at the same time as or before the Foreman server snapshot.
Update DNS records so that the Foreman server hostname resolves to the new IP address. This redirects traffic from the old server to the new server and you will not need to re-register your hosts.
Assess the functionality of your restored Foreman server. For more information, see Retrieve status of services by using Hammer CLI.
3.1.3. Retrieve status of services by using Hammer CLI
Get information from the database and Foreman services:
$ hammer ping
# systemctl status foreman.target --with-dependencies
Perform a health check:
$ foremanctl health
Run
foremanctl health --helpfor more information.
3.2. Disaster recovery for active and passive Foreman server with external storage
To prepare for disaster recovery, you can configure two Foreman servers and store critical data externally on shared storage. The primary server is active while the secondary server remains passive. If the primary server fails, the shared storage is attached to your secondary server, which turns the secondary server into your new primary server.
3.2.1. Prepare for failures with a passive Foreman server with external storage
Create your passive Foreman server as a backup of your active Foreman server.
Your shared storage meets the requirements for holding the contents of
/var/lib/pulpand/var/lib/pgsql. For more information, see Storage requirements. -
You have configured your Foreman server to use external databases. For more information, see Reduce Foreman server load with an external database.
Replicate the
/var/lib/pulpand/var/lib/pgsqldirectories from the active Foreman server to your shared storage. -
Back up your active Foreman server and restore it on a system that will serve as your passive Foreman server. For more information, see Back up Foreman and Restore Foreman from backup.
Assess the functionality of the test Foreman server. For more information, see Retrieve status of services by using Hammer CLI.
3.2.2. Recover from disaster with active and passive Foreman server with external storage
If your active Foreman server fails, detach it from the shared storage and make sure your passive server can access the data stored on the shared storage. This turns the passive server into your new active server.
Assess the functionality of your new active Foreman server. For more information, see Retrieve status of services by using Hammer CLI.
3.2.3. Retrieve status of services by using Hammer CLI
$ hammer ping
$ foremanctl health
Run
3.3. Disaster recovery for active and passive Foreman server with backup and restore
To prepare for disaster recovery, you can configure two Foreman servers: an active primary server and a passive secondary server. You configure periodic backups of the primary server. If the primary server fails, you can restore a backup on the secondary server to turn it into your new primary server.
3.3.1. Prepare for failures with a passive Foreman server and backup
Create your passive Foreman server by restoring a backup of your active Foreman server. Configure periodic backups of the active server.
You have a Foreman server installed.
Define a schedule for periodic offline backups of your active Foreman server. Consider your tolerance for potential data loss and your storage options: Taking backups frequently will result in smaller amounts of data loss in case of a disaster, but backups require a significant amount of storage space. For information about the size of Foreman backups, see Estimate the size of a backup.
Incremental backups are not available. For an example of a
cronjob that ensures regular full backups, see Example of a weekly full backup. -
Schedule periodic offline backups of your active Foreman server to be taken according to the schedule you defined. For information about performing backups, see Back up Foreman.
Ensure that the backup directories are encrypted and regularly synchronized to a secure location.
ImportantForeman server backups contain sensitive information from the
/root/ssl-builddirectory. For example, they can contain hostnames, ssh keys, request files, and SSL certificates. Encrypting or moving the backups to a secure location helps minimize the risk of damage or unauthorized access to the hosts. -
Restore the most recent backup on a system that will serve as your passive Foreman server. For information about restoring backups, see Restore Foreman from backup.
Verify that Foreman takes backups according to the schedule you defined.
3.3.2. Recover from disaster with active and passive Foreman server and backup and restore
If your active Foreman server fails, activate your passive secondary server.
3.3.3. Retrieve status of services by using Hammer CLI
$ hammer ping
$ foremanctl health
Run
3.4. Disaster recovery with two active Foreman servers
To prepare for disaster recovery, you can configure two Foreman servers and operate each server in a different data center. If one of the servers fails, you can re-register all hosts from the failed server to the other server.
3.4.1. Prepare for failures with two active Foreman servers
Create a second Foreman server by restoring a backup of your first Foreman server. Configure both servers to operate independently in their respective data centers, but ensure that their content does not drift apart over time.
Ansible playbooks can help you automate failover, re-registration, and synchronization. For more information, see Using the Foreman Ansible Collection. |
Back up your Foreman server. For more information, see Back up Foreman.
Restore the backup on a system that will serve as your other Foreman server. For more information, see Restore Foreman from backup.
Register hosts to your servers so that each server manages hosts in its respective data center. For example, register all hosts in My_Data_Center_1 to one Foreman server and all hosts in My_Data_Center_2 to the other Foreman server.
Automate running the
foremanctl healthcommand on both servers. The health check verifies whether the servers remain fully operational.
Verify that your
foremanctl healthautomation reported an error. -
3.4.2. Recover from disaster with two active Foreman servers
If the health checks implemented in Prepare for failures with two active Foreman servers report an issue on one of your Foreman servers, it might mean that the server has failed. If the server is down, you must re-register hosts to the other server.
$ foremanctl health
If
foremanctl healthreported a problem, ensure that the server is powered off. -
4. Manage users and roles
Foreman users represent individuals who access your Foreman and are scoped to organizations and locations. You assign roles to users to control which actions they can perform in your environment.
4.1. Create and manage Foreman users
4.1.1. Create a user by using Foreman web UI
Create user accounts from the Foreman web UI to grant individuals access to your Foreman environment.
Click Create User.
Enter the account details for the new user.
On the User tab, select an authentication source from the Authorized by list:
INTERNAL: to manage the user inside Foreman server.
EXTERNAL: to manage the user with external authentication. For more information, see Configuring authentication for Foreman users.
On the Organizations tab, select organizations for the user. Select the default organization from the Default on login list. Foreman uses this organization for the user after login.
On the Locations tab, select locations for the user. Select the default location from the Default on login list. Foreman uses this location for the user after login.
4.1.2. Create a user by using Hammer CLI
Create user accounts by using Hammer CLI to grant individuals access to your Foreman environment.
Create a user:
$ hammer user create \ --auth-source-id My_Authentication_Source \ --login My_User_Name \ --mail My_User_Mail \ --organization-ids My_Organization_ID_1,My_Organization_ID_2 \ --location-ids My_Location_ID_1,My_Location_ID_2 \ --password My_User_Password
Append
--auth-source-id 1so that the user is authenticated internally. Runhammer auth-source listto get a list of authentication sources. Add the--adminoption to grant administrator privileges to the user.You can modify the user details later by using the
hammer user updatecommand.
4.1.3. Assign roles to a user by using Foreman web UI
Assign roles to a user in the Foreman web UI to control which permissions and resources they can access in your environment.
NoteIf a user account is not listed, check that you are currently viewing the correct organization. To list all the users in Foreman, click Default Organization and then Any Organization.
Click Submit.
4.1.4. Assign roles to a user by using Hammer CLI
Assign roles to a user with Hammer CLI to grant the permissions they need to perform tasks in Foreman.
Assign roles to a user:
$ hammer user add-role \ --id My_User_ID \ --role My_Role_Name
4.1.5. Impersonate a different user account
As an administrator, you can impersonate another user by logging on to the Foreman web UI as that user. Impersonating another user is useful for testing and troubleshooting purposes because you can access exactly what the impersonated user can access in the system, including the same menus.
You are logged on to the Foreman web UI as a user with administrator privileges for Foreman.
4.1.6. Create an API-only user
You can create a user account that can interact only with the Foreman API. This is useful for service accounts or integrations that must not use the Foreman web UI.
You have created a user and assigned roles to them. Note that this user must be authorized internally. For more information, see Manage users and roles.
Log in to your Foreman as admin.
# openssl rand -hex 32
Create a Personal Access Token for the user. For more information, see Create a Personal Access Token.
4.2. SSH key management
Add SSH keys to user accounts so Foreman can deploy those keys during host provisioning.
4.2.1. Manage SSH keys for a user by using Foreman web UI
Add or remove SSH keys for a user in the Foreman web UI to control which keys Foreman deploys during provisioning.
You are logged in to the Foreman web UI as an Admin user of Foreman or a user with the
create_ssh_keypermission enabled for adding SSH key anddestroy_ssh_keypermission for removing a key.
Click on the SSH Keys tab.
To Add SSH key
Click Add SSH Key.
Click Submit.
To Remove SSH key
4.2.2. Manage SSH keys for a user by using Hammer CLI
Add or remove SSH keys for a user with Hammer CLI to manage which keys Foreman deploys during provisioning.
To add an SSH key to a user, you must specify either the path to the public SSH key file, or the content of the public SSH key copied to the clipboard:
$ hammer user ssh-keys add \ --user-id user_id \ --name key_name \ --key-file ~/.ssh/id_rsa.pub
$ hammer user ssh-keys add \ --user-id user_id \ --name key_name \ --key ecdsa-sha2-nistp256 AAAAE2VjZHNhLXNoYTItbmlzdHAyNTYAAAAIbmlzdHAyNtYAAABBBHHS2KmNyIYa27Qaa7EHp+2l99ucGStx4P77e03ZvE3yVRJEFikpoP3MJtYYfIe8k 1/46MTIZo9CPTX4CYUHeN8= host@user
4.3. Create and revoke Personal Access Tokens
4.3.1. Create a Personal Access Token
200, for example:{"foreman_version":"5.0.0","result":"ok","status":200,"version":"3.5.1.10","api_version":2}If you go back to Personal Access Tokens tab, you can see the updated Last Used time next to your Personal Access Token.
4.3.2. Revoke a Personal Access Token
4.4. Create and manage user groups
With Foreman, you can assign permissions to groups of users. You can also create user groups as collections of other user groups. If you use an external authentication source, you can map Foreman user groups to external user groups.
4.4.1. Create a user group by using Foreman web UI
Create a user group in the Foreman web UI and define which roles the group will have.
In the Foreman web UI, navigate to Administer > User Groups.
Click Create User group.
Click Submit.
4.4.2. Create a user group by using Hammer CLI
Create a user group by using Hammer CLI and define which roles the group will have.
Create a user group:
$ hammer user-group create \ --name My_User_Group_Name \ --role-ids My_Role_ID_1,My_Role_ID_2 \ --user-ids My_User_ID_1,My_User_ID_2
4.4.3. Remove a user group
Remove a user group from Foreman when you no longer need it or when you want to reorganize how permissions are assigned.
Click Delete to the right of the user group you want to delete.
Click Confirm to delete the user group.
4.4.4. Associate external users with user groups
Foreman does not associate external users with their user group automatically. To associate these external users with their user group, you must create the user group on your Foreman server.
When you create a Foreman user group with the same name as in the external source, members of the external user group automatically become members of the Foreman user group and receive the associated permissions. The configuration of external user groups depends on the type of external authentication.
If you use a FreeIPA or AD server, configure Foreman to use FreeIPA or AD authentication. For more information, see Configuring authentication for Foreman users.
Ensure that at least one external user authenticates for the first time.
Retain a copy of the external group names you want to use. You can find the group membership of external users:
# id username
In the Foreman web UI, navigate to Administer > User Groups, and click Create User Group.
Specify the name of the new user group. Do not select any users to avoid adding users automatically when you refresh the external user group.
Click the Roles tab and select the roles you want to assign to the user group. Alternatively, select the Administrator checkbox to assign all available permissions.
Click the External groups tab, then click Add external user group, and select an authentication source from the Auth source drop-down menu.
Click Submit.
5. Monitor Foreman server with email alerts
Email notifications are created by Foreman server periodically or after completion of certain events. The periodic notifications can be sent daily, weekly or monthly.
Foreman server does not enable outgoing emails by default, therefore you must review your email configuration. |
5.1. Email notification types
You can configure Foreman to send email notifications for system events such as host builds, errata updates, content synchronization failures, and audit summaries to stay informed about important activities in your environment.
- Audit summary
A summary of all activity audited by Foreman server.
- Compliance policy summary
- Content view promote failure
- Content view publish failure
- Host built
- Host errata advisory
- Promote errata
- Repository sync failure
- Smart Proxy sync failure
A notification sent after Smart Proxy synchronization fails.
- Sync errata
5.2. Configure Foreman server for outgoing emails
To send email messages from Foreman server, you can use an SMTP server.
In the Foreman web UI, navigate to Administer > Settings.
Click the Email tab and set the configuration options to match your preferred delivery method. The changes have an immediate effect.
The following example shows the configuration options for using an SMTP server:
Table 2. Using an SMTP server as a delivery method Name Example value Additional information Delivery method
SMTP
SMTP address
smtp.example.com
SMTP authentication
login
SMTP HELO/EHLO domain
example.com
SMTP password
password
Use the login credentials for the SMTP server.
SMTP port
25
SMTP username
user@example.com
The following example uses gmail.com as an SMTP server:
Table 3. Using gmail.com as an SMTP server Name Example value Additional information Delivery method
SMTP
SMTP address
smtp.gmail.com
SMTP authentication
plain
smtp.gmail.com
SMTP enable StartTLS auto
SMTP password
app password
Use the Google app password. For more information, see Sign in with app passwords in Google Help Center.
SMTP port
587
SMTP username
user@gmail.com
Use the Google account name.
NoteForeman does not support configuring CA certificates for communication with SMTP servers.
Click Test email to send a test message to the user’s email address to confirm the configuration is working. If a message fails to send, the Foreman web UI displays an error. View the Foreman logs for further details:
# journalctl --unit foreman
5.3. Configure email notification preferences
You can configure Foreman to send email messages to individual users registered to Foreman. Foreman sends the email to the email address that has been added to the account, if present.
Users can edit the email address by clicking on their name in the top right of the Foreman web UI and selecting My account.
If you want to send email notifications to a group email address instead of an individual email address, create a user account with the group email address and minimal Foreman permissions, then subscribe the user account to the desired notification types. |
view_mail_notifications.
Click Submit.
5.4. Test email delivery
Click on the username.
If the email is delivered, the verification is complete.
If the email is not delivered, perform the following diagnostic steps:
Verify Foreman server’s email configuration.
If your Foreman server uses the Postfix service for email delivery, the test email might be held in the queue. To verify, enter the
mailqcommand to list the current mail queue. If the test email is held in the queue,mailqdisplays the following message:postqueue: warning: Mail system is down -- accessing queue directly -Queue ID- --Size-- ----Arrival Time---- -Sender/Recipient------- BE68482A783 1922 Thu Oct 3 05:13:36 foreman-noreply@example.com
To fix the problem, start the Postfix service on your Foreman server:
# systemctl start postfix
5.5. Test email notifications
Trigger email notifications:
daily
weekly
monthly
5.6. Change email notification settings for a host
You can enable or disable email notifications for a host to control whether its events trigger alerts. Foreman sends these notifications to the registered owner of the host.
In the Foreman web UI, navigate to Hosts > All Hosts, locate the host that you want to view, and click Edit in the Actions column.
Go to the Additional Information tab. If the Enabled checkbox is checked, then email notifications are enabled on that host.
6. Back up Foreman
6.1. Foreman backup planning
Backing up your Foreman server and Smart Proxy server requires you to plan scheduling, storage, and security so you avoid disruption and protect sensitive data.
6.1.1. Available backup methods
Choose a backup method based on how long you can keep Foreman services unavailable and how much time you can allocate for the backup.
- Offline backup
All Foreman services are stopped during an offline backup to ensure data consistency. The backup process includes the following actions:
Preflight checks to verify that no tasks are running and that the database is consistent.
Service shutdown to stop all Foreman services cleanly.
PostgreSQL database dumps to backup content and configuration.
Configuration backup to archive the foremanctl state and configuration.
Content backup to back up Pulp content directory. This is an optional action. You can skip this action by using the
--skip-pulp-contentoption with theforemanctl backupcommand. -
Service restart to restore all Foreman services.
- Incremental backup
Incremental backups are offline backups that capture only files that have changed since a previous backup. They require less time and storage than a full offline backup.
The backup process creates snapshot files that track changes, allowing you to chain incremental backups. All backups in the chain are required for restore.
- Conventional backup
Conventional backup methods, such as virtual machine snapshots or file system backups, operate outside of Foreman. You must stop all Foreman services for the duration of the backup.
For more information, see Create a conventional backup.
6.1.2. Best practices for backing up Foreman
Apply these recommendations when scheduling and storing backups so you protect sensitive data and avoid conflicts with other administrators.
Foreman community recommends backing up Foreman to a separate storage device on a separate system.
Foreman services are unavailable during the backup. Coordinate with other administrators to ensure no conflicting tasks run during the backup window.
WarningRequest other users of Foreman server or Smart Proxy server to save any changes and warn them that Foreman services are unavailable for the duration of the backup. Ensure no other tasks are scheduled for the same time as the backup.
You can schedule a backup by using
cron.NoteDuring offline backups, the services are inactive and Foreman is in a maintenance mode. A firewall rejects traffic from outside on port 443 to ensure there are no modifications triggered.
Encrypt or move the backup to a secure location to minimize the risk of damage or unauthorized access to the hosts. A backup has sensitive information from the
/root/ssl-builddirectory. For example, it can have hostnames, SSH keys, request files and SSL certificates. -
Because the
foremanctl backupcommand does not automatically delete old backups, consider implementing backup retention policies, including rotating old backups and monitoring backup storage usage.
6.1.3. Directories created during backups
The foremanctl backup command creates a time-stamped subdirectory in the backup directory that you specify.
The foremanctl backup command does not overwrite backups, therefore you must select the correct directory or subdirectory when restoring from a backup.
Foreman names each subdirectory foreman-backup-TIMESTAMP, for example foreman-backup-20260617T104115.
The foreman-backup- prefix is the same for Foreman server and Smart Proxy server backups.
Foreman stores the backup in the directory that you specify as an argument to the foremanctl backup command.
For example, running the foremanctl backup /var/backup command creates the backup in the /var/backup/ directory, for example /var/backup/foreman-backup-20260617T104115/.
To identify which deployment a backup was taken from, read the metadata.yml file inside the subdirectory.
6.1.4. Estimate the size of a backup
Estimate how much disk space a Foreman backup requires so you can ensure enough storage is available and avoid backup failures.
Calculate the size of the uncompressed backup data:
Determine the size of PostgreSQL database data:
# du -sh /var/lib/pgsql/data 100G /var/lib/pgsql/data
Determine the size of Pulp data:
# du -sh /var/lib/pulp 100G /var/lib/pulp
Determine the size of the foremanctl configuration files:
# du -sh /var/lib/foremanctl 10MB /var/lib/foremanctl
Calculate the expected size of the compressed backup data:
The compression ratio of the backup data is as follows:
Table 4. Backup data compression ratio Data type Directory Compression ratio PostgreSQL database files
/var/lib/pgsql/data80 – 85%
Pulp data
/var/lib/pulpNot compressed
/var/lib/foremanctl85%
In this example, the backup data is compressed as follows:
100 GB of PostgreSQL database data is compressed to 15-20 GB
100 GB of Pulp data is not compressed and occupies 100 GB of space
10 MB of foremanctl configuration is compressed to 1.5 MB
Add up the size of the uncompressed and compressed data, and add a 20% safety margin. For example:
201 GB of uncompressed data + 120 GB of compressed data = 321 GB
20% safety margin = 64 GB
Total space required: 321 GB + 64 GB = 385 GB
To ensure a successful backup or restore, 385 GB of space must be allocated for the backup location.
6.2. Perform a full offline backup
Run a full offline backup on Foreman server and Smart Proxy server to capture all Foreman content and configuration. A full backup is useful when you want to prepare for a future restore from scratch.
Your backup location must have sufficient available disk space to store the backup. For more information, see Estimate the size of a backup.
To enable Foreman to save the backup to an NFS share, the
rootuser of your Foreman server or Smart Proxy server must be able to write to the NFS share. NFS export options such asroot_squashandall_squashare known to prevent this.For more information, see Deploying an NFS server on Red Hat Enterprise Linux 9 and Export options for securing an NFS server on Red Hat Enterprise Linux 9.
For more information, see Deploying an NFS server on Red Hat Enterprise Linux 10 and Export options for securing an NFS server on Red Hat Enterprise Linux 10.
Warning
Request other users of Foreman server or Smart Proxy server to save any changes and warn them that Foreman services are unavailable for the duration of the backup. Ensure no other tasks are scheduled for the same time as the backup. |
Back up your Foreman server:
# foremanctl backup /var/foreman-backup
Back up your Smart Proxy server:
# foremanctl backup /var/foreman-proxy-backup
6.3. Perform an offline backup without Pulp content
Run an offline backup that excludes the contents of the Pulp directory. A backup without Pulp content is useful for debugging purposes and is only intended to provide access to configuration files without backing up the Pulp database.
Warning
Do not use a backup without Pulp content to restore your Foreman server or Smart Proxy server for production use cases. |
Back up your Foreman server without Pulp content:
# foremanctl backup --skip-pulp-content /var/foreman-backup
Back up your Smart Proxy server without Pulp content:
# foremanctl backup --skip-pulp-content /var/foreman-proxy-backup
6.4. Perform an incremental backup
Run an incremental backup to perform an offline backup that captures any changes since a previous full backup. Incremental backups use less time and storage than a full offline backup.
Perform a full offline backup. For more information, see Perform a full offline backup.
Create the first incremental backup by specifying the full backup directory as the base:
# foremanctl backup /var/backup --base-backup /var/backup/full_backup
This creates a new backup directory containing only files changed since the full backup.
Create the second incremental backup by specifying the first incremental backup as the base:
# foremanctl backup /var/backup --base-backup /var/backup/first_incremental_backup
This creates a directory for the second incremental backup in your backup directory.
NoteYou can point to a different version of the backup, and make a series of increments with that version of the backup as the starting point. For example, if you want to make a new incremental backup from the full backup rather than the first or second incremental backup, point to the full backup directory:
You can chain incremental backups, but all backups in the chain are required for restore.
6.5. Example of a weekly full backup
The following cron line runs a full backup every Sunday.
0 0 * * 0 PATH=/sbin:/bin:/usr/sbin:/usr/bin foremanctl backup /var/backup_directory
Note that the foremanctl backup command requires /sbin and /usr/sbin directories to be in PATH.
6.6. Example of a weekly full backup followed by daily incremental backups
#!/bin/bash -e
foremanctl backup $DESTINATION
ls -td -- $DESTINATION// | head -n 1 > $DESTINATION/.last_full_backup
else
foremanctl backup $DESTINATION --base-backup "$(cat
$DESTINATION/.last_full_backup)"
fi
else
LAST=$(ls -td -- $DESTINATION// | head -n 1)
foremanctl backup $DESTINATION --base-backup "$LAST"
fi
exit 0
6.7. Create a conventional backup
You can use conventional backup methods to back up your Foreman server or Smart Proxy server. Unlike Foreman backup methods, conventional backup methods require you to stop Foreman services.
Stop all Foreman services:
# systemctl stop foreman.target
Create the snapshot or conventional backup. For more information, see Recovering and restoring a system in Red Hat Enterprise Linux 10 Configuring basic system settings.
Start Foreman services:
# systemctl start foreman.target
7. Restore Foreman from backup
You can restore Foreman server or Smart Proxy server from a backup to recover after failure or data loss. This helps ensure the continuity of your Foreman deployment and associated data in case a disaster occurs.
7.1. Restore from a full backup
Restore Foreman server or Smart Proxy server from a full backup to return the system to the state at the time of the backup. When the restore process completes, all processes are online, and all databases and system configuration revert to the state at the time of the backup.
The restore process can take a long time to complete.
The foremanctl restore command performs the following actions:
Validation checks to verify the backup integrity, disk space, and system requirements
Restoring databases, Pulp content, encryption keys, OAuth secrets, and passwords
Configuring and starting of services
Confirming that services are running as expected
Your Foreman server must have the same hostname, configuration, and be the same minor version (X.Y) as the original system. If the original system that experienced a failure is unavailable, provision a system with the same configuration and hostname.
The target directory must exist and be writable. The target directory is read from the configuration files contained within the backup archive.
If the original system had the Federal Information Processing Standards (FIPS) mode enabled, the system on which you are restoring must also be FIPS-enabled.
Your system must have enough space to extract the backup data. Your system must also have enough space left for the backup data after the restoration. For more information, see Estimate the size of a backup.
Restore the correct SELinux contexts:
# restorecon -Rv /
Install Foreman server or Smart Proxy server on the system where you want to restore the backup.
Copy the backup data to the local file system on your Foreman server or Smart Proxy server. This procedure uses /var/backup_directory.
Optional: Validate the backup to ensure that all files required for the restore process exist and the backup metadata is valid:
# foremanctl restore /var/backup_directory --validate
Run the restoration script:
# foremanctl restore /var/backup_directory --force
The
--forceoption is required to confirm that the data from the fresh Foreman deployment installed on the system will be permanently deleted and replaced by the data from the backup.
If you create a new instance of Foreman server or Smart Proxy server, decommission the old instance after restoring the backup. Cloned instances are not supposed to run in parallel in a production environment.
7.2. Restore from incremental backups
Restore Foreman server or Smart Proxy server from an incremental backup to return the system to the state at the time of the backup. When the restore process completes, all processes are online, and all databases and system configuration revert to the state at the time of the backup.
If you have multiple branches of incremental backups, select your full backup and each incremental backup for the branch you want to restore, in chronological order.
If the backed up system had FIPS enabled, the system on which you are restoring must also have FIPS enabled.
Restore the last full backup by following the instructions in Restore from a full backup.
Copy the incremental backup data to the local file system on Foreman server.
# foremanctl restore /var/backup/first_incremental_backup --force # foremanctl restore /var/backup/second_incremental_backup --force
The
--forceflag is required for subsequent restores because the system is already deployed.
Review the Foreman logs by using
journalctl:# journalctl --unit foreman
7.3. Restore Smart Proxy server by using a virtual machine snapshot
Restore Smart Proxy server from a virtual machine snapshot to return the system to the state at the time of the snapshot. You can use virtual machine snapshots to back up and restore your Smart Proxy server for quick recovery after server failure or configuration issues.
You have selected the relevant organization and location context of your Smart Proxy server, or chosen Any Organization and Any Location.
If your Smart Proxy server is a virtual machine, include it in your backup strategy by using VM snapshots. Creating weekly snapshots that you can restore from is recommended.
After a failure, either restore your Smart Proxy server from a snapshot by using your hypervisor tools, or deploy a new Smart Proxy server and ensure that the host name is the same as before, and then install the Smart Proxy certificates. You can reuse the existing authentication bundle from the
/var/lib/foremanctl/certs/bundles/directory on your Foreman server. If the bundle is no longer available, regenerate it by adding the--certificate-renewoption to theforemanctl auth-bundlecommand. -
Follow the procedures in Installing Smart Proxy server until you can confirm, in the Foreman web UI, that Smart Proxy server is connected to Foreman server.
In the Foreman web UI, navigate to Infrastructure > Smart Proxies.
Select your Smart Proxy server.
Select Optimized Sync to synchronize content from your Foreman server to your Smart Proxy server that bypasses unnecessary steps to speed up performance.
Select Complete Sync to perform a complete sync from your Foreman server to your Smart Proxy server that synchronizes content even if the metadata has not changed.
8. Configure Foreman for Insights analytics
You can configure Foreman to connect to Insights hosted in the Red Hat Hybrid Cloud Console so your Red Hat Enterprise Linux hosts receive suggestions for improvement.
8.1. Insights recommendations
Insights is a set of analytical services by Red Hat for hosts running Red Hat Enterprise Linux. Insights services analyze host data and provide suggestions for host improvements.
- Insights services
Insights services include:
Advisor, which provides recommendations for host improvements. Advisor groups related recommendations into pathways.
Vulnerability, which provides reports on vulnerabilities found on your hosts.
Compliance, which provides reports on compliance with regulatory requirements.
Insights services hosted in the Red Hat Hybrid Cloud Console are not limited to the listed services.
- Hosted Insights
When you use Insights hosted in the Red Hat Hybrid Cloud Console, the Insights client on your hosts collects data and Foreman forwards it to the hosted Insights services for analysis.
If you use Insights in the Red Hat Hybrid Cloud Console:
You can use Insights services online in the Red Hat Hybrid Cloud Console.
The Insights client collects data of your hosts and Foreman forwards the data to the Red Hat Hybrid Cloud Console to calculate recommendations.
You can view and remediate those recommendations in the Foreman web UI.
Foreman uploads host inventory reports to the Red Hat Hybrid Cloud Console.
You have control over how much information is included in those reports.
8.2. Data control settings for hosted Insights
You can configure how Foreman handles the data collected from hosts before uploading it to the Red Hat Hybrid Cloud Console and how Foreman handles hosts in the Red Hat Hybrid Cloud Console that are no longer managed by Foreman.
8.2.1. Minimize collected data
Use minimal data collection to limit host data sent to Red Hat while keeping the Subscriptions service active. Other Insights services are disabled because they require installed package data.
You can use minimal reporting to limit the amount of system data sent to the Subscriptions service, which remains active. Other Insights services are disabled because they require installed package data, which minimal reports do not include. Reports are still processed daily during the midnight synchronization cycle.
Minimal reports also exclude hostnames, IP addresses, and installed packages. Therefore, obfuscation and exclusion settings do not apply.
If you switch to Analytics data collection, Foreman enables the following settings by default:
Obfuscate host names
Obfuscate host ipv4 addresses
Exclude installed packages
Review and adjust these settings to control what data Foreman shares.
"report_slice_id": "de92044d-9d77-4895-83c4-a476f5020519",
"hosts": [
"account": "123456789",
"subscription_manager_id": "9fc621b9-08c3-4085-a749-bfed38c3052e",
"insights_id": "9fc621b9-08c3-4085-a749-bfed38c3052e",
"bios_uuid": "203F234F-58C7-4237-8DDF-A17A2838A66C",
"bios_vendor": "SeaBIOS",
"bios_version": "1.16.1-1.el9",
"arch": "x86_64",
"infrastructure_type": "virtual",
"system_profile": {
"installed_products": [
"name": "Red Hat Enterprise Linux for x86_64",
"id": "479"
"cores_per_socket": 1,
"system_memory_bytes": 3836579840,
"number_of_cpus": 1,
"number_of_sockets": 1
"cpu_socket(s)": "1"
edit_settingspermission. -
Existing data in Insights Inventory has been deleted before switching to minimal reporting. To remove existing data of a system, navigate to Inventory > Systems in the Red Hat Hybrid Cloud Console, select the system, and click Delete.
You have selected an organization and location.
In the Foreman web UI, navigate to Insights > Inventory Upload.
Select the Minimal data collection setting from the dropdown menu under Settings.
When you select this option, Foreman also updates the corresponding setting on the Insights tab under Administer > Settings.
Click the Generate and upload report button to create a new inventory report and send it to the Red Hat Hybrid Cloud Console.
8.2.2. Obfuscate hostnames and IP addresses
You can configure Foreman to obfuscate hostnames and IP addresses when uploading host data to Insights. Obfuscation ensures that sensitive identifying information is not exposed.
When obfuscation settings are enabled, Foreman obfuscates hostnames and IP addresses.
If obfuscation settings are enabled and the host has its own insights-client obfuscation settings, Foreman honors the host settings.
If obfuscation settings are disabled, Foreman does not obfuscate hostnames or IP addresses unless the client has obfuscation enabled in insights-client.
By default, Foreman applies global obfuscation settings unless an insights-client on the host overrides the settings with its own configuration.
Obfuscation only works when Minimal data collection is disabled. If Minimal data collection is enabled, hostnames and IP addresses are not included in reports, making obfuscation unnecessary and inactive. |
Your hosts have
insights-clientinstalled and configured.
Enable the Obfuscate host names setting to obfuscate host names sent to the Red Hat Hybrid Cloud Console.
Enable the Obfuscate host ipv4 addresses setting to obfuscate IPv4 addresses sent to the Red Hat Hybrid Cloud Console.
In the Organization dropdown menu, select the organization that uploaded the host data.
Click Generate report to create a fresh report with obfuscated data.
Click Download report to download the host inventory report.
Verify that the hostname is
randomhostname.example.comand the IP address is obfuscated.
Click Generate and upload report to create and upload a new report with obfuscated data to the Red Hat Hybrid Cloud Console.
8.2.3. Remove hosts from Insights inventory
When hosts are removed from Foreman, they can also be removed from the inventory of Insights, either automatically or manually. You can configure automatic removal of hosts from the Insights Inventory during Red Hat Hybrid Cloud Console synchronization with Foreman that occurs daily by default.
If you leave the setting disabled, you can still remove the bulk of hosts from the Inventory manually.
If Automatic mismatch deletion is enabled, Foreman removes any hosts from the Red Hat Hybrid Cloud Console that are not registered in Foreman. Enable this setting only when all hosts are registered through Foreman. If any hosts are registered through other Foreman instances or directly to the Red Hat Hybrid Cloud Console, Foreman deletes them.
Automatic mismatch deletion runs once a day as a scheduled task. After removing hosts from Foreman, hosts are deleted from the Red Hat Hybrid Cloud Console inventory during the next scheduled sync. Clicking Sync all inventory status updates the status of hosts but does not trigger immediate deletion. |
Your Foreman account has a role that grants the
view_foreman_rh_cloudandedit_settingspermissions.
Enable the Automatic mismatch deletion setting.
9. Reduce storage use on Foreman server
Foreman server can accumulate a large amount of data over time, which can use a significant amount of disk space. You can clean up task records or reclaim disk space to reduce storage use.
9.1. Clean task records
Task records track background jobs that Foreman executes, such as synchronizing repositories. Foreman cleans up outdated tasks automatically, and you can also clean them up manually to save database space.
During the automatic task cleanup, Foreman removes the following tasks: * Tasks that have finished successfully and are older than thirty days * All tasks that are older than a year
9.1.1. Delete task records
Foreman creates task records automatically. To remove old and unnecessary task records, you can delete them. This helps maintain system performance and keeps your task history organized.
Use the
foreman-rake foreman_tasks:cleanupcommand to remove tasks at any time. You can also use a cron job to schedule Task record deletions at the set interval that you want.For example, you can delete task records from successful repository synchronizations:
9.1.2. Delete a task by ID
Optional: View the task:
On your Foreman server, delete the task:
Optional: Ensure the task has been removed from Foreman server:
9.2. Reclaim disk space
Foreman can consume a significant amount of disk space, especially in large deployments. By reclaiming disk space, you can reduce the amount of disk space used by Foreman.
9.2.1. Recover from a full disk
If a logical volume (LV) with the Pulp database on it is full, Pulp tasks can fail due to insufficient space. You can recover from the situation by increasing the amount of free space available on the LV.
Ensure that the LV with the
Remove orphaned content:
Change the download policy from Immediate to On Demand for as many repositories as possible and remove already downloaded packages. See the Red Hat Knowledgebase solution How to change syncing policy for Repositories on Satellite from "Immediate" to "On-Demand" on the Red Hat Customer Portal for instructions.
/var/lib/pulpdirectory on it. For more information, see Growing a logical volume and file system in Red Hat Enterprise Linux 9 Configuring and managing logical volumes.NoteIf you use an untypical file system (other than for example ext3, ext4, or xfs), you might need to unmount the file system so that it is not in use. In that case, complete the following steps:
Stop Foreman services:
9.2.2. Reclaim PostgreSQL space
If the PostgreSQL database is using a large amount of disk space, you can reclaim space by vacuuming the database. By reclaiming PostgreSQL space, you can reduce the amount of disk space used by Foreman.
postgresqlservice:# systemctl stop foreman.target # systemctl start postgresql.service
Reclaim space on the database:
# podman exec postgresql vacuumdb --full --all -U postgres
9.2.3. Reclaim space from on-demand repositories
If you want to reclaim space for a single repository:
In the Foreman web UI, navigate to Content > Products.
Select a product.
If you want to reclaim space for multiple repositories:
Select the product name.
If you want to reclaim space for Smart Proxies:
Select the Smart Proxy that lists Pulpcore in the Features column.
On the Overview tab, from the Synchronize menu, select Reclaim Space.
10. Renew Foreman server certificates
You can renew default self-signed server and client certificates as well as the default self-signed certificate authority on Foreman server to prevent them from expiring. You can also renew the custom SSL certificate as well as the custom certificate authority certificate on Foreman server and on Smart Proxy server.
10.1. Renew self-signed certificates on Foreman server
You can renew expired self-signed server and client certificates on Foreman server to restore secure connections. You can also specify a custom validity period instead of the default 7300 days.
Renew server and client certificates:
# foremanctl deploy --certificate-renew
To set a custom validity period, append
--certificate-validity-days My_Dayswith the validity period in days for the new certificate.
In your browser, go to your Foreman server login page, for example,
https://foreman.example.com, and inspect the certificate in the browser. This is typically displayed as a shield, padlock, or tune icon next to the address bar depending on your browser. -
On the command line, verify the new certificate validity period:
# echo | openssl s_client -connect 127.0.0.1:443 2>/dev/null | openssl x509 -noout -dates
The output displays the
notBeforeandnotAfterdates of the certificate, wherenotBeforeis the date when the certificate becomes valid andnotAfteris the date when it expires.
10.2. Renew self-signed CA certificates
The self-signed certificate authority (CA) certificate on your Foreman server is valid for 20 years by default. If you need to renew it because the expiration date is close, follow the below procedure.
Renew CA certificates:
# foremanctl deploy --certificate-ca-renew
--certificate-ca-validity-days My_Dayswith the validity period in days for the new certificate.
https://foreman.example.com, and inspect the CA certificate in the browser. This is typically displayed as a shield, padlock, or tune icon next to the address bar depending on your browser. -
The output displays the whole SSL connection information. Check the
NotBeforeandNotAfterdates of CA entry in the "Certificate chain" section, whereNotBeforeis the date when the certificate becomes valid andNotAfteris the date when it expires.
Refresh the CA certificate on your Smart Proxy servers. For more information, see Configure Smart Proxy server with SSL certificates.
Refresh the CA certificate on your hosts. For more information, see Refresh the CA certificate on hosts.
10.3. Renew a custom SSL certificate on Foreman server
You can deploy a renewed custom SSL certificate on Foreman server to replace an expiring certificate and maintain trusted access to the Foreman web UI and API.
You have created a new Certificate Signing Request (CSR) and sent it to the Certificate Authority to sign the certificate. Refer to the Configure Foreman server with a custom SSL certificate guide before creating a new CSR because the Server certificate must have X.509 v3
Key UsageandExtended Key Usageextensions with required values. In return, you will receive the Foreman server certificate and CA bundle.
Deploy the renewed CA certificates to Foreman server:
# foremanctl deploy \ --certificate-source custom_server \ --certificate-server-certificate "/root/foreman_cert/foreman_cert.pem" \ --certificate-server-key "/root/foreman_cert/foreman_cert_key.pem" \ --certificate-server-ca-certificate "/root/foreman_cert/ca_cert_bundle.pem"
Access the Foreman web UI from your local machine. For example,
https://foreman.example.com. -
10.4. Renew a custom server CA certificate
If you need to update the certification authority (CA) certificate that signed your Foreman server and Smart Proxy servers certificates, add the new CA certificate and use a temporary dual CA certificate file to retain the HTTPS connections to your Foreman server during the renewal.
Check if the existing server certificate can be validated with the new CA certificate:
# openssl verify -CAfile /root/foreman_cert/old_ca_cert_bundle.pem /root/foreman_cert/foreman_cert.pem
If the check did not succeed, use both the old and the new CA certificate while updating consumers.
Add the new SSL certificate to the CA certificate file on Foreman server and keep the old SSL certificate:
# cat /root/foreman_cert/old_ca_cert_bundle.pem /root/foreman_cert/new_ca_cert_bundle.pem > /root/foreman_cert/ca_cert_bundle.pem
Renew the certificates on Foreman server:
Refresh the certificates on any Smart Proxy servers.
Deploy the dual CA certificate on hosts.
Remove the old certificate from the CA certificates file on Foreman server, so the CA certificate file contains only the new SSL certificate:
# cat /root/foreman_cert/new_ca_cert_bundle.pem > /root/foreman_cert/ca_cert_bundle.pem
Deploy the new CA certificate on hosts.
11. Manage logs for Foreman
With centralized logging, you can monitor Foreman service health, diagnose errors, and control log retention and disk usage in a single interface. You can also collect diagnostic data and attach it to support cases.
11.1. Foreman logging architecture
Foreman server manages all service logs by using a centralized system built on systemd and journald.
Instead of searching through separate log files in different directories, you can manage all service activity from a single pipeline.
All Foreman services send their log output to stdout by default.
The container runtime automatically captures this data stream and passes it to the logging daemon.
You interact with the logging architecture through the following key components:
With the
journaldservice, you collect and store all service logs in one place. By default, you lose log history when the system reboots asjournaldstores log data in volatile memory. You can configurejournaldto store logs in persistent storage so that you can retain log history across system restarts.For details on configuring the
journaldservice, see the official Red Hat Enterprise Linux documentation. -
With
journalctl, you can view, search, and filter logs for any service from a single interface without opening individual log files. -
Use the
foremanctl deploycommand to change log levels or adjust logging verbosity.
11.2. View service logs
You can view and filter logs for any Foreman service by using journalctl with the appropriate unit filter.
Use correlation IDs to trace a single request across multiple services such as Foreman and Pulp.
Foreman server is installed and running.
You have root access to your Foreman server.
To view logs for a specific service:
# journalctl --unit My_Service
To follow log output in real time, add the
--followflag:# journalctl --follow --unit My_Service
For example:
# journalctl --follow --unit foreman
Example output:
Aug 10 07:19:29 foreman.example.com foreman[1632]: 2026-08-10T07:19:29 [I|app|eb515c9c] Started GET "/api/v2/ping" for 192.168.124.1 Aug 10 07:19:29 foreman.example.com foreman[1632]: 2026-08-10T07:19:29 [I|app|eb515c9c] Processing by Api::V2::PingController#ping as JSON Aug 10 07:19:29 foreman.example.com foreman[1632]: 2026-08-10T07:19:29 [I|app|eb515c9c] Completed 200 OK in 186ms (Views: 12.8ms | ActiveRecord: 8.1ms | Allocations: 42460)
In this output,
eb515c9cis the correlation ID. -
To trace a request across services, locate the correlation ID in the log output and filter by it:
# journalctl --grep My_Correlation_ID
For example:
# journalctl --grep eb515c9c
Example output:
Aug 10 07:19:29 foreman.example.com foreman[1632]: 2026-08-10T07:19:29 [I|app|eb515c9c] Started GET "/api/v2/ping" for 192.168.124.1 Aug 10 07:19:29 foreman.example.com foreman[1632]: 2026-08-10T07:19:29 [I|app|eb515c9c] Processing by Api::V2::PingController#ping as JSON Aug 10 07:19:29 foreman.example.com pulp-api[1193]: pulp [eb515c9c-cb85-44fa-bd6e-c49eaab71bc5]: "GET /pulp/api/v3/status/ HTTP/1.1" 200 6250 Aug 10 07:19:29 foreman.example.com foreman[1632]: 2026-08-10T07:19:29 [I|app|eb515c9c] Completed 200 OK in 186ms (Views: 12.8ms | ActiveRecord: 8.1ms | Allocations: 42460)
Verify that the command returns log entries for the expected service:
# journalctl --unit My_Service -n 5
11.3. Set service log levels
You can set the log level for Foreman services by using foremanctl deploy parameters.
At the initial deployment, when the containers are first created, the log level is set to the default value of info.
You can change the log level for all services or for individual services.
To set the global log level for all supported services, run:
# foremanctl deploy --log-level Log_Level
For example, to set the global log level to
debug, run:# foremanctl deploy --log-level debug
To override the log level for a specific service, use a service-specific parameter, such as
--foreman-log-leveland--foreman-proxy-log-level.For example, to set only Foreman to
errorwhile keeping other services at the global level, run:# foremanctl deploy --foreman-log-level error
After you complete debugging, reset the log level to the default to avoid filling up host disk space:
# foremanctl deploy --reset-foreman-log-level
NoteEach service inherits the default value from the
log-levelparameter, unless you set the value for the service by using theMy_Service-log-levelparameter. Runningforemanctl deploy --log-level New_Log_Levelorforemanctl deploy --reset-log-leveldoes not affect the--My_Service-log-levelparameters.
Verify that a new log level took effect as actions occur:
# journalctl --unit foreman --follow
11.3.1. Log level parameters
You can control the log detail level of containerized Foreman services with the foremanctl deploy log level parameters.
The --log-level parameter sets the global baseline for all services.
The valid values are: debug, info, warn, error, fatal out of which info is the default.
Per-service parameters override this value and translate it to the native vocabulary of each service:
--foreman-log-level-
Foreman service. Values:
debug,info,warn,error,fatal. --foreman-proxy-log-level-
Foreman Proxy. Values:
debug,info,warn,error,fatal. --pulp-log-level-
Pulp services (
pulpcore-api,pulpcore-content,pulpcore-worker). Values:debug,info,warning,error,critical. --valkey-log-level-
Valkey. Independent of
--log-level. Values:debug,verbose,notice,warning,nothing. Default:notice.
These services do not have dedicated foremanctl deploy log level parameters and are not affected by the global --log-level parameter:
Candlepin
PostgreSQL
httpd
12. Monitor Foreman resources
You can use Foreman web UI to monitor your Foreman environment and hosts. This includes details of hosts, such as configuration or compliance, and information about content and Smart Proxies.
12.1. Foreman dashboard
The Foreman dashboard contains various widgets. Use the dashboard to get a quick overview of the resources currently in use in Foreman.
In the Foreman web UI, navigate to Monitor > Dashboard to access the dashboard. The dashboard can be rearranged by clicking on a widget and dragging it to a different position. The following widgets are available:
- Host Configuration Status
Table 5. Host configuration states Icon State Description
Hosts in error state
noopmode.
Out of sync hosts
Hosts with no reports
Hosts with alerts disabled
- Host Configuration Chart
- Latest Events
- New Hosts
- Task Status
- Latest Warning/Error Tasks
- Discovered Hosts
- Latest Errata
- Content Views
- Sync Overview
- Host Collections
A list of all host collections in Foreman and their status, including the number of hosts in each host collection.
virt-whodaemon running on hosts in the environment. The following table shows the possible states.Table 6. virt-who configuration states State Description No Reports
No Change
OK
Total Configurations
- Latest Compliance Reports
- Insights Actions
- Insights Risk Summary
12.2. Track Foreman task progress
You can monitor and manage all planned or performed tasks, such as repositories synchronized, errata applied, and content views published. This is useful to track progress, troubleshoot issues, or adjust timeout settings for low bandwidth or high latency environments.
- Reviewing the log
- Adjusting timeout settings
NoteAdjusting the %_finish_timeout values might help in case of low bandwidth. Adjusting the %_accept_timeout values might help in case of high latency.
- Disabling checking for services
Click Save.
12.3. Review audit records of Foreman changes
Audit records list the changes made by all users on Foreman. You can use this information for maintenance and troubleshooting.
In the Foreman web UI, navigate to Monitor > Audits to view the audit records.
Obtain a list of all audit attributes:
12.4. Check Smart Proxy server status
In the Foreman web UI, you can find various information about Smart Proxy server and its services. This information is useful to maintain Smart Proxy server and troubleshoot any issues.
12.4.1. General Smart Proxy information overview
You can view general information about your Smart Proxies in the Foreman web UI, such as their status, enabled features, and managed hosts, to verify configuration or troubleshoot connectivity issues.
In the Foreman web UI, navigate to Infrastructure > Smart Proxies to view a table of Smart Proxy servers registered to Foreman server. The information contained in the table answers the following questions:
- Is Smart Proxy server running?
This is indicated by a green icon in the Status column. A red icon indicates an inactive Smart Proxy, use the
service foreman-proxy restartcommand on Smart Proxy server to activate it. - What services are enabled on Smart Proxy server?
In the Features column, you can verify if, for example, your Smart Proxy provides a DHCP service or acts as a Pulp mirror. Smart Proxy features can be enabled during installation or configured in addition.
- What organizations and locations is Smart Proxy server assigned to?
A Smart Proxy server can be assigned to multiple organizations and locations, but only Smart Proxies belonging to the currently selected organization are displayed. To list all Smart Proxies, select Any Organization from the context menu in the top left corner.
After changing the Smart Proxy configuration, select Refresh from the drop-down menu in the Actions column to ensure the Smart Proxy table is up to date.
Click the Smart Proxy name to view further details. At the Overview tab, you can find the same information as in the Smart Proxy table. In addition, you can answer to the following questions:
- Which hosts are managed by Smart Proxy server?
- How much storage space is available on Smart Proxy server?
/var/lib/pulpis displayed. Also the remaining storage space available on the Smart Proxy can be ascertained.
12.4.2. Monitor Smart Proxy services
You can view the status and configuration details of Smart Proxy services in Foreman web UI. This helps you verify that your Smart Proxy services are running correctly and troubleshoot any issues.
In the Foreman web UI, navigate to Infrastructure > Smart Proxies and click the name of the selected Smart Proxy.
At the Services tab, you can find basic information on Smart Proxy services, such as the list of DNS domains, or the number of Pulp workers.
The appearance of the page depends on what services are enabled on Smart Proxy server. Services providing more detailed status information can have dedicated tabs at the Smart Proxy page.
13. Use webhooks in Foreman
13.1. Webhook behavior and integration
You can use webhooks as a way to integrate Foreman with external systems. For example, webhooks can integrate with monitoring systems to send alerts when a host is created or deleted.
Because webhooks use HTTP, no new infrastructure needs be added to existing web services. Webhooks are useful where the action you want to perform in the external system can be achieved through its API.
13.2. Install the webhooks plugin
Use the following procedure to install the webhooks plugin. Then, you can configure Foreman server to send webhook requests.
On your Foreman server, install the webhooks plugin:
# foremanctl deploy --add-feature webhooks
13.3. Create a webhook template
Webhook templates are used to generate the body of HTTP request to a configured target when a webhook is triggered. You can create a webhook template in the Foreman web UI.
In the Foreman web UI, navigate to Administer > Webhook > Webhook Templates.
A webhook HTTP payload must be created using Foreman template syntax. The webhook template can use a special variable called
@objectthat can represent the main object of the event.@objectcan be missing in case of certain events. You can determine what data are actually available with the@payloadvariable.For more information, see Template Writing Reference and for available template macros and methods, visit
/templates_docon Foreman server. -
Click Submit.
13.4. Create a webhook
When creating a webhook in the Foreman web UI, you can customize events, payloads, HTTP authentication, content type, and headers.
In the Foreman web UI, navigate to Administer > Webhook > Webhooks.
Click Create new.
Click Template to select a template. Webhook templates are used to generate the body of the HTTP request to Foreman server when a webhook is triggered.
Enter an HTTP method.
Click the Credentials tab.
Optional: Uncheck Verify SSL if you do not want to verify the server certificate against the system certificate store or Foreman CA.
13.5. Available webhook events
Review the webhook events that are available from the Foreman web UI.
A content view was successfully promoted. |
Runs an Ansible Playbook containing all the roles defined for a host. |
Upgrade Smart Proxies on given Smart Proxy servers. |
Run an Ansible Playbook against given hosts. |
Run an Ansible Playbook to enable the web console on given hosts. |
Custom event: |
Custom event: |
Common database operations on a configuration report. |
Common database operations on a content view. |
Custom event: |
14. Tips for working in Foreman web UI efficiently
The Foreman web UI includes search, bookmarking, keyboard shortcuts, and various settings to help you work more efficiently.
14.1. Notable keyboard shortcuts and navigation tips
Use these keyboard shortcuts and techniques to navigate and search more efficiently in the Foreman web UI.
Ctrl + Shift + Ffocuses the vertical navigation search bar-
After pressing this shortcut, you can start typing in the vertical navigation search bar.
/focuses the page search bar-
After pressing this shortcut, you can start typing in the page search bar.
- Saving searches as bookmarks
You can save a search you frequently use as a bookmark. After entering your search query in the search field, click the arrow next to the Search button and select Bookmark this search. You can then give the bookmark a name and choose whether to make it public or private.
To manage all bookmarks, navigate to Administer > Bookmarks.
- Compact table mode
Navigate to the user menu in the top bar and select My account. Under the UI Preferences tab, you can enable compact table mode. With compact table mode enabled, Foreman web UI displays table rows with less space between items.
- Instance title setting
If you have multiple Foreman instances, you can configure Foreman web UI to always show a banner with the instance title in the top bar to help you identify which instance you are currently using. To set an instance title, navigate to Administer > Settings, and edit the Instance title setting on the General tab. To set a color for the instance title banner, edit the Instance color setting.
14.2. Foreman web UI search query reference
Use search query syntax and operators in the Foreman web UI to filter lists of resources on Foreman web UI pages. Parameter-based queries help you find the resources you need faster and more precisely than free-text search in large inventories.
Search queries in the page search bar follow the pattern:
parameter operator value
To search text with whitespaces, enclose it in quotes:
hostgroup = "Web Servers"
Typing without specifying a parameter searches across multiple fields simultaneously, also known as free-text search.
For example, typing 64 in the search bar on the hosts page displays all hosts that have 64 in their name, IP address, MAC address, and architecture.
Free text search is slower and less accurate than parameter-based queries. Use specific parameters whenever possible for better performance and precision. |
The search bar supports multiple date and time formats, including the following:
"10 January 2017"
"10 Jan 2017"
10-January-2017
10/January/2017
"January 10, 2017"
Today, yesterday, and similar keywords
| Operator | Short Name | Description |
EQUALS |
NOT EQUALS |
LIKE |
Accepts text or temporal values. The search is not case-sensitive. Accepts the following wildcards: _ for a single character, % or * for any number of characters including zero. If no wildcard is specified, the string is treated as if surrounded by wildcards: %rhel7% |
NOT LIKE |
GREATER THAN |
LESS THAN |
IN |
NOT IN |
HAS or set? |
NOT HAS or null? |
| Operator | Alternative Notations | ||
and |
<whitespace> |
or |
not |
14.3. Useful search examples
The following examples demonstrate useful ways to filter and find resources in Foreman web UI. Use them as starting points to build your own searches that match your specific needs.
These search examples show how to filter hosts and are based on host attribute search parameters. You can use them on Foreman web UI pages that list hosts, such as Hosts > All Hosts. You can apply the same syntax to filter other resources on other Foreman web UI pages.
- Find hosts by host global status and sub-status
Hosts that have an OK global status:
global_status = ok
Hosts that have an Error or Warning global status:
global_status = error or global_status = warning
Hosts that have at least one pending resource:
status.pending > 0
Hosts that restarted some service during last run:
status.restarted > 0
Hosts that have an interesting last run that might indicate something has happened:
status.interesting = true
- Find hosts that need attention
Hosts with security updates available:
errata_status = security_needed
Hosts that have email notifications for configuration errors enabled and are in a failed state:
status.enabled = true AND status.failed = true
Hosts that have not generated a report recently:
last_report < "7 days ago"
- Find hosts by configuration, environment, or registration date
Hosts in production that belong to a host group whose name includes a variation of the word "webservers":
environment = production AND hostgroup ~ webservers
Hosts registered in the last month:
registered_at > "30 days ago"
Hosts registered between specific dates:
registered_at > 1-January-2026 AND registered_at < 31-January-2026
- Exclude specific results
All hosts except hosts in a host group named "exceptions":
NOT hostgroup = exceptions
Hosts that are not compliant with policies:
compliance_status != compliant
This search query requires the OpenSCAP plugin.
- Use wildcards for flexible matching
Hosts with names that include the strings "web" and "prod":
name ~ web*prod*
Host groups starting with a specific prefix:
hostgroup ~ rhel%
Appendix A: Commands for managing Foreman services
Foreman provides a systemd target, foreman.target, to manage Foreman services from the command line.
After installing Foreman with the foremanctl deploy command, all Foreman services are started and enabled automatically.
# systemctl list-dependencies foreman.target
# systemctl list-units $(systemctl show -p Wants --value foreman.target)
# systemctl restart foreman.target
Appendix B: Anonymize audit records
Use the
foreman-rake audits:anonymizecommand to remove any user account or IP information while maintaining the audit records in the database. Specify the number of days to keep the audit records by adding the days option and add the number of days. You can also use a cron job to schedule anonymizing the audit records at the set interval that you want.For example, you can anonymize audit records that are older than seven days:
