1. Foreman use cases
Foreman is a centralized tool for provisioning, content delivery, remote management, and monitoring of multiple Enterprise Linux deployments. With Foreman, you can deploy, configure, and maintain your systems across physical, virtual, and cloud environments.
Foreman helps you provision hosts, manage patches and content, and strengthen security across physical, virtual, and cloud environments. You can also benefit from AI-powered assistance by deploying the Model Context Protocol (MCP) server for Foreman, which enables you to interact with your infrastructure using natural language.
Foreman focuses on the following use cases:
Provisioning
Deploy consistently configured hosts on bare metal, virtual machines, and cloud instances from a unified interface.
Foreman automates key stages of the deployment lifecycle, including network configuration, operating system installation, and post-installation tasks. For example, you can define templates, partition layouts, and available software to achieve flexibility in how you deploy hosts.
This approach helps reduce deployment time, standardize the provisioning process, and support scaling of your infrastructure.
Patch management and content distribution
Apply updates to hosts in a consistent, scalable, and repeatable manner. Import, organize, and distribute content to hosts.
In the context of Foreman, content is defined as the software installed on hosts. For example, you can use Foreman to distribute a broad range of content ranging from packages and errata to container images, Ansible content, and custom file types.
Foreman enables you to import, organize, and distribute content to hosts while staying in control of which versions of content reaches which hosts and when. For example, you can schedule maintenance windows, test updates in staging environments, and roll out patches across your infrastructure with controlled deployment strategies.
This approach provides enhanced control over what software runs in your environment and reduces the manual effort required to keep hosts up to date.
Security management
Reduce the effort required to secure hosts at scale.
Foreman helps you enforce security policies, scan for vulnerabilities, and remediate compliance violations across your infrastructure. For example, you can integrate Foreman with security scanning tools, track compliance against security baselines, and set up procedures to help ensure hosts meet regulatory requirements.
This capability enables centralized security oversight, supports incident response, and helps reduce the attack surface of your hosts.
Knowledge and analytics
Identify potential issues and gain a comprehensive view of your infrastructure.
Foreman collects data from hosts, generates reports on system status and trends, and provides dashboards that visualize infrastructure health. For example, you can monitor resource utilization, track configuration changes, and identify patterns.
This knowledge helps you make informed decisions about your infrastructure and spot potential problems.
Configuration management
Apply configurations to hosts in a consistent and repeatable manner.
Foreman integrates with configuration management tools to define desired state, enforce policies, and remediate drift across your infrastructure. For example, you can manage configurations as code, version control your infrastructure definitions, and automate updates to help keep hosts compliant with organizational standards.
This approach reduces the risk of manual configuration errors and helps maintain consistency across your hosts.
2. Foreman architecture and components
As you are evaluating Foreman for your organization, understanding the roles and relationships of major components helps you determine what infrastructure to deploy and how components interact.
2.1. Major Foreman components
A typical Foreman deployment consists of the following components: a Foreman server, Smart Proxy servers, and hosts that receive content and configuration from Foreman server and Smart Proxy servers.
Foreman server
Foreman server is the central component of your Foreman deployment.
  • Configuration of hosts
  • Host provisioning
  • Patch management
  • Subscription management
    Foreman server delegates content distribution, host provisioning, and communication to Smart Proxy servers. Foreman server itself also includes a Smart Proxy.
Smart Proxy server
  • Mirroring content from Foreman server to establish content sources in various geographical or logical locations. By registering a host to a Smart Proxy server, you can configure this host to receive content and configuration from the Smart Proxy in their location instead of from the central Foreman server.
    By using content views, you can specify the exact subset of content that Smart Proxy server makes available to hosts.
Hosts in Foreman
With Foreman, you can manage hosts at scale, including monitoring, provisioning, remote execution, subscription management, content management, and configuration management. You can also group hosts by using features such as host groups and host collections.
2.2. Smart Proxy server features
Smart Proxy servers provide local host management services and can mirror content from Foreman server.
To mirror content from Foreman server, Smart Proxy servers provide the following functionalities:
Repository synchronization
Smart Proxy servers pull content for selected lifecycle environments from Foreman server and make this content available to the hosts they manage.
Content delivery
Hosts configured to use Smart Proxy server download content from that Smart Proxy rather than from Foreman server.
Host action delivery
Smart Proxy server executes scheduled actions on hosts.
Hosts are registered to their associated Smart Proxy servers rather than to the central Foreman server or the Red Hat Customer Portal.
You can use Smart Proxy to run the following services for infrastructure and host management:
DHCP
DNS
TFTP
Realm
Puppet server
Puppet Certificate Authority
Provisioning template proxy
OpenSCAP
Remote execution (REX)
Content Smart Proxies: Pulp
Smart Proxies with this service provide content synchronized from Foreman server to hosts.
Configuration Smart Proxies: Pulp + Puppet + PuppetCA
Smart Proxies with these services provide content and run configuration services for hosts.
Smart Proxies with DNS + DHCP + TFTP + Pulp + Puppet + PuppetCA
Smart Proxies with these services provide a full set of Smart Proxy features. By configuring a Smart Proxy with all these features, you can isolate hosts assigned to that Smart Proxy by providing a single point of connection for the hosts.
2.3. Key open source components of Foreman
Foreman consists of several open source projects integrated with each other.
Foreman
Katello
Candlepin
Pulp
3. Administration tools for Foreman
Foreman offers multiple tools for administrators to manage the deployment. Understanding the available administration tools helps you select the approach that fits your workflow and automation needs.
3.1. Foreman web UI for management from your browser
3.2. Hammer CLI for management from the command line
3.3. Foreman API for automation and integration
  • Broad client support – any programming language, framework, or system with support for HTTP protocol can use the API.
  • Self-descriptive – client applications require minimal knowledge of the Foreman infrastructure because users discover many details at runtime.
  • Resource-based model – the resource-based REST model provides a natural way to manage a virtualization platform.
  • Integrate with enterprise IT systems.
  • Integrate with third-party applications.
  • Perform automated maintenance or error checking tasks.
  • Automate repetitive tasks with scripts.
3.4. Foreman Ansible Collection
Modules from the Foreman Ansible Collection are provided by the ansible-collection-theforeman-foreman package. Before you can use the modules, you must install the package on the system where you run your playbooks.
Using the modules, you can write playbooks to automate the administration of your Foreman.
3.5. MCP server for AI-powered assistance
Foreman provides a Model Context Protocol (MCP) server so that you can query and manage your Foreman inventory from MCP-compatible AI applications by using natural language.
You deploy the MCP server from a container image that Foreman community provides and connect it to the AI application that runs your MCP client. The MCP server accesses Foreman with your credentials, so your MCP client cannot obtain data that you do not have permission to access.
By default, the MCP server is read-only. You can query your inventory and generate reports from it, for example, a report of all subnets and the hosts that are assigned to them.
When you start the MCP server, you can also grant it permissions to change your Foreman. For example, you can start remote execution jobs on your hosts, and publish and promote content views.
3.6. Remote execution in Foreman
3.7. Automated installation with Kickstart
You can automate the installation process of a Foreman server or Smart Proxy server by creating a Kickstart file that contains all the information that is required for the installation.
When you run a Foreman Kickstart script, the script performs the following actions:
  1. It specifies the installation location of a Foreman server or a Smart Proxy server.
  2. It installs the predefined packages.
  3. It installs Subscription Manager.
  4. It uses Activation Keys to subscribe the hosts to Foreman.
  5. It installs Puppet, and configures a puppet.conf file to indicate the Foreman or Smart Proxy instance.
  6. It enables Puppet to run and request a certificate.
  7. It runs user defined snippets.
4. Supported client architectures
Verify that your client architectures are supported before deploying Foreman.
4.1. Foreman operating system
You can deploy Foreman on the supported operating systems listed below.
  • Enterprise Linux 9 (x86_64)
4.2. Client operating systems
  • Amazon Linux
  • Debian
  • Fedora
  • Ubuntu
  • Ansible
  • OpenSCAP
  • OpenSSH
  • Puppet
  • Salt
  • Katello host tools
  • Subscription Manager
  • Tracer utility
5. Security hardening features in Foreman
Foreman supports multiple security mechanisms for additional layers of protection. Understanding these capabilities helps you evaluate how Foreman can support the security requirements of your organization.
You can use the following security capabilities in Foreman to enhance the security of your deployment:
If your Enterprise Linux operating systems supports FIPS, you can install Foreman server and Smart Proxy server on a FIPS-enabled host. Note that Foreman itself is not FIPS-certified.
Foreman supports DEFAULT and FIPS crypto-policies. The FUTURE crypto-policy is not supported for Foreman server and Smart Proxy server installations.
If you want to run Foreman server or Smart Proxy server on a FIPS-enabled host, FIPS must be enabled on the host before installing. You cannot enable FIPS mode on Foreman server or Smart Proxy server after installation.
If you manage FIPS-enabled hosts, you must also run Foreman server and Smart Proxy servers in FIPS mode. If the server does not run in FIPS mode in this situation, you might experience unexpected behavior. For example, the hosts might not be able to run remote execution jobs from the server.
Foreman server and Smart Proxy servers can run on hosts that have the fapolicyd service enabled.
The fapolicyd daemon helps prevent unauthorized code execution and enhances system integrity by enforcing file access policies.
You can enable or disable fapolicyd on your Foreman server and Smart Proxy servers at any time.
Foreman can synchronize and distribute Red Hat Enterprise Linux 10 content signed with the Module-Lattice-Based Digital Signature Standard (ML-DSA). ML-DSA is a quantum-resistant cryptographic signature algorithm designed to protect content integrity against potential attacks from quantum computers.
Foreman community does not currently support full PQC compatibility for Foreman.
Foreman server and Smart Proxy servers must be run on hosts with SELinux enabled.
The SELinux collection of security modules enforces policies that define which processes can access specific system resources, providing protection against unauthorized access and exploitation.
To maintain a high-security environment, Foreman community recommends running Foreman with SELinux in enforcing mode. This ensures that access control policies are strictly enforced and minimizes the risk of privilege escalation or unauthorized actions.
In addition to these security capabilities, regularly updating security policies and configurations, as well as monitoring system logs, can help detect and respond to potential threats effectively on both Foreman server and Smart Proxy server.
6. Networking considerations in Foreman
For the components of Foreman architecture to communicate, the required network ports must be open to enable incoming and outgoing traffic between the components. Identify firewall port and networking requirements to ensure Foreman components can communicate properly.
6.1. Smart Proxy server networking
6.2. Foreman server port and firewall requirements
53
TCP and UDP
DNS
DNS Servers and clients
Name resolution
DNS (optional)
67
UDP
DHCP
Client
Dynamic IP
DHCP (optional)
69
UDP
TFTP
Client
TFTP Server (optional)
TCP
HTTPS
Smart Proxy
Foreman API
TCP
HTTPS
Client
Global Registration
Registering hosts to Foreman
TCP
HTTPS
Foreman
Content Mirroring
Management
TCP
HTTPS
Foreman
Smart Proxy API
Smart Proxy functionality
443, 80
TCP
HTTPS, HTTP
Smart Proxy
Content Retrieval
Content
443, 80
TCP
HTTPS, HTTP
Client
Content Retrieval
Content
1883
TCP
MQTT
Client
Pull based REX (optional)
Hosts for REX job notification (optional)
4505 – 4506
TCP
MQTT
Client
Salt (optional)
Salt Master to Salt Minions
5910 – 5930
TCP
HTTPS
Browsers
8000
TCP
HTTP
Client
Provisioning templates
8000
TCP
HTTPS
Client
PXE Boot
Installation
8140
TCP
HTTPS
Client
OpenVox agent
Client updates (optional)
9090
TCP
HTTPS
Foreman
Smart Proxy API
9090
TCP
HTTPS
Client
OpenSCAP
9090
TCP
HTTPS
Discovered Node
Discovery
Host Discovery and provisioning (if the Discovery plugin is installed)
9090
TCP
HTTPS
Client
9191
TCP
HTTPS
Client
Salt (optional)
Salt API
ICMP
ping
Client
DHCP
Free IP checking (optional)
7
TCP
echo
Client
DHCP
22
TCP
SSH
Target host
Remote execution
Run jobs
22, 16514
TCP
SSH SSH/TLS
Compute Resource
53
TCP and UDP
DNS
DNS Servers on the internet
DNS Server
53
TCP and UDP
DNS
DNS Server
Smart Proxy DNS
53
TCP and UDP
DNS
DNS Server
Orchestration
Validation of DNS conflicts
68
UDP
DHCP
Client
Dynamic IP
DHCP (optional)
80
TCP
HTTP
Remote repository
Content Sync
Remote repositories
389, 636
TCP
LDAP, LDAPS
External LDAP Server
LDAP
TCP
HTTPS
Compute resources
TCP
HTTPS
Smart Proxy
Content mirroring
Initiation
TCP
HTTPS
Infoblox DHCP Server
DHCP management
623
Client
Power management
BMC On/Off/Cycle/Status
5000
TCP
HTTPS
OpenStack Compute Resource
Compute resources
5900 – 5930
TCP
SSL/TLS
Hypervisor
noVNC console
Launch noVNC console
5985
TCP
HTTP
Client
WinRM
5986
TCP
HTTPS
Client
WinRM
7911
TCP
DHCP, OMAPI
DHCP Server
DHCP
8443
TCP
HTTPS
Client
Discovery
9090
TCP
HTTPS
Smart Proxy
Smart Proxy API
Management of Smart Proxies
6.3. Smart Proxy port and firewall requirements
443, 80
TCP
HTTPS, HTTP
Client
Content Retrieval
Content
TCP
HTTPS
Foreman
Content Mirroring
Management
TCP
HTTPS
Foreman
Smart Proxy API
TCP
HTTPS
Client
Host registration
Initiation
Uploading facts
1883
TCP
MQTT
Client
8000
TCP
HTTP
Client
8000
TCP
HTTP
Client
PXE Boot
Installation
8140
TCP
HTTPS
Client
OpenVox agent
8443
TCP
HTTPS
Client
Host registration
9090
TCP
HTTPS
Foreman
Smart Proxy API
9090
TCP
HTTPS
Client
Register Endpoint
9090
TCP
HTTPS
Client
OpenSCAP
9090
TCP
HTTPS
Discovered host
Discovery
9090
TCP
HTTPS
Client
ICMP
ping
Client
DHCP
7
TCP
echo
Client
DHCP
22
TCP
SSH
Target host
Remote execution
Run jobs (optional)
TCP
HTTPS
Foreman
Smart Proxy
Smart Proxy
Configuration management Template retrieval
OpenSCAP Remote execution result upload
TCP
HTTPS
Foreman
Content
Sync
TCP
HTTPS
Foreman
Client communication
Forward requests from Client to Foreman
TCP
HTTPS
DHCP management
623
Client
Power management
7911
TCP
DHCP, OMAPI
DHCP Server
DHCP
9090
TCP
HTTPS
Client
Discovery
7. Content flow in Foreman
Content flow in Foreman involves management and distribution of content from external sources to hosts.
Content in Foreman flows from external content sources to Foreman server. Smart Proxy servers mirror the content from Foreman server to hosts.
External content sources
You can configure many content sources with Foreman. The supported content sources include the Red Hat Customer Portal, custom Deb and Yum repositories, PyPI, Git repositories, Ansible collections, container registries, SCAP repositories, or internal data stores of your organization.
Foreman server
On your Foreman server, you plan and manage the content lifecycle.
Smart Proxy servers
By creating Smart Proxy servers, you can establish content sources in various locations based on your needs. For example, you can establish a content source for each geographical location or multiple content sources for a data center with separate networks.
Hosts
By assigning a host system to a Smart Proxy server or directly to your Foreman server, you ensure the host receives the content they provide. Hosts can be physical or virtual.
8. Provisioning methods in Foreman
Network based
This method uses an operating system installer, such as Anaconda, Debian Installer, Agama, or AutoYaST, and a template-generated file with installation options downloaded from Foreman, such as Agama, AutoYaST, Kickstart, Preseed, or Preseed Autoinstall templates.
PXE-less Discovery with kexec
Boot disk based
Image based
Figure 1. Choosing a provisioning method
9. Expense management for Red Hat subscriptions
Red Hat provides you with several tools to control costs and optimize spending on Red Hat subscriptions. This is useful if you plan to manage Red Hat Enterprise Linux hosts.
9.1. Subscriptions usage data
For the purposes of expense management and to optimize your spending, track your subscriptions usage data that you can get from your Foreman environment and Red Hat. You can track usage, capacity, and utilization of your Red Hat subscriptions.
Usage
Measures the consumption of installed Red Hat products.
This data tells you: How much am I using? For example: I have 42 hypervisors, each with 2 sockets, tagged with the Production usage type.
Capacity
Measures the amount of Red Hat products that have been purchased. It is the upper limit of usage.
This data tells you: How much have I purchased? For example: I purchased QTY 52 of RH00001. Each RH00001 covers a 2-socket hypervisor and all of its guests.
Utilization
Measures how much of the purchased capacity has been exhausted.
This data tells you: How much of my capacity is being used? For example: I am using 42 of my 52 RH00001, leaving 10 free for additional use.
9.2. Subscriptions tracking tools
You can track subscriptions usage by combining the following tools.
System Purpose
Defines non-technical system attributes for hosts to aid accurate inventory reporting:
  • Service Level Agreement (SLA): Self-Support, Standard, Premium
  • Usage type: Production, Development/Test
  • Role: Server, Workstation
System purpose is configured by using the Subscription Manager tool.
Insights client
Collects data from hosts and sends it to Foreman. Foreman then forwards the data and host inventory to the Red Hat Hybrid Cloud Console for analysis. You can install the Insights client on Red Hat Enterprise Linux hosts during host registration, host provisioning, or using remote execution.
Subscriptions service
Provides capacity data, calculates utilization, and reports subscription usage in connected scenarios. This service is hosted on the Red Hat Hybrid Cloud Console.
Foreman
Provides reports on products installed on hosts. You can download these reports in various formats, such as YAML, JSON, HTML, and CSV. You can use these reports to calculate utilization locally.
9.3. Subscriptions tracking scenarios
You can track your subscription usage in one of the following scenarios, depending on your environment and data sensitivity.
Connected scenario
You share all collected data with Red Hat.
  • Foreman uploads inventory data to the Red Hat Hybrid Cloud Console automatically.
  • Red Hat Hybrid Cloud Console provides all services.
  • Services powered by Red Hat Lightspeed analyze the data.
  • Subscriptions service in the Red Hat Hybrid Cloud Console calculates utilization data.
Connected data-sensitive scenario
You share just enough data with Red Hat to enable subscription reporting.
  • You control what data is uploaded by enabling obfuscation or exclusion settings.
  • Red Hat Hybrid Cloud Console provides limited services.
Disconnected scenario
You do not share any data with Red Hat. Instead, you track your subscription usage as follows:
  • You can get usage data from the Host - Installed Products report in Foreman.
  • You can get capacity data from the Subscriptions service in the Red Hat Hybrid Cloud Console.
  • You can calculate utilization data locally using a tool of your choosing.
10. Deployment path for Foreman
10.1. Foreman server installation overview
  • High disk I/O workloads from frequent repository synchronization or content view publishing. This requires Foreman to create a record in PostgreSQL for each job.
  • High volume of hosts.
10.2. External authentication methods available in Foreman
FreeIPA
Yes (Linux users only)
Quarkus-based Keycloak
Wildfly-based Keycloak
LDAP
10.3. Organization and location planning and assignment
Organizations and locations enable you to arrange Foreman resources into logically structured groups. For example, you can create groups based on ownership, purpose, content, or security level. You can create and manage multiple organizations through Foreman, then divide and assign subscriptions to each individual organization.
Organizations
Organizations can represent different business units, departments, or teams, such as Finance, Marketing, or Web Development. To manage Red Hat content, each organization requires a separate Red Hat subscription manifest.
Locations
Foreman server defines all locations and organizations. Each Smart Proxy server synchronizes content and handles configuration of hosts in a different location.
Your Foreman server retains the management function, while the content and configuration is synchronized between your Foreman server and Smart Proxy servers assigned to certain locations.
Example 1. Example of using organizations and locations in Foreman
  • Finance
  • Marketing
  • Sales
  • United States
  • United Kingdom
  • Japan
  • Boston
  • Phoenix
  • San Francisco
10.4. Smart Proxy servers installation overview
10.5. Content library and content access strategy
To ensure that your Foreman can manage software and provide it to your hosts, you create repositories and synchronize them. You can also define which hosts can access which content and content versions.
Your Foreman content library can include various types of content. Creating repositories allows you to choose the specific software required for your environment. By creating only the necessary repositories, you avoid downloading unnecessary content.
Synchronizing repositories downloads the content from Canonical, Oracle, Red Hat, SUSE, or other sources to your Foreman server. The synchronized content is stored on your Foreman server, eliminating the need for hosts to access the repositories. You can synchronize repositories manually, or you can create a sync plan to ensure synchronization runs on a regular basis.
By default, Foreman includes the Default Organization View content view and the Library lifecycle environment.
The Default Organization View is the default content view in Foreman that contains all the content that is synchronized to Foreman. After you update your content, such as by adding or removing a repository, the update is immediately reflected in Default Organization View.
Library
The Library lifecycle environment is the default lifecycle environment in Foreman. Every newly published content view version is automatically published to the Library lifecycle environment. You can also promote specific content view versions to the Library lifecycle environment if needed.
10.6. Role-based access control policies
10.7. Provisioning configuration in Foreman
10.8. Subscriptions tracking configuration
For successful tracking of your subscriptions usage, you have to perform the following configuration tasks.
In both connected and disconnected scenarios, perform the following task:
  • Set the system purpose for hosts in Foreman.
In the connected scenarios, also perform the following tasks:
  • If you use a hypervisor with virtual machines, configure virt-who on Foreman server.
  • Configure inventory upload in Foreman and install the Insights client on hosts.
  • Activate the Subscriptions service in the Red Hat Hybrid Cloud Console if needed.
10.9. Additional deployment tasks
For more information, see Run automated workflows on hosts.
Load balancing
Preparing for disaster recovery
By preparing a disaster recovery plan, you can ensure the continuity of Foreman services in case of a disruptive event. This helps you restore your Foreman deployment to an operational state after an incident.
11. Common deployment scenarios
11.1. Single location scenario with segregated subnets
11.2. Multiple location scenarios
Create at least one Smart Proxy server per geographic location to save bandwidth by having hosts obtain content locally. Only your Smart Proxy server synchronizes content from remote repositories, making your provisioning infrastructure more reliable and easier to configure.
Foreman community recommends to create at least one Smart Proxy server per geographic location. This practice can save bandwidth since hosts obtain content from a local Smart Proxy server. Synchronization of content from remote repositories is done only by the Smart Proxy, not by each host in a location. In addition, this layout makes the provisioning infrastructure more reliable and easier to configure.
11.3. Content view scenarios
11.4. Multiple manifest scenario
You can use many Red Hat Network subscription manifests in one Foreman server to manage systems from different Red Hat Network accounts or entities. This allows you to assign subscriptions to separate organizations and manage those organizations independently.
If you plan to have more than one Red Hat Network account, or if you want to manage systems belonging to another entity that is also a Red Hat Network account holder, then you and the other account holder can assign subscriptions, as required, to manifests. A customer that does not have a Foreman subscription can create a Subscription Asset Manager manifest, which can be used with Foreman, if they have other valid subscriptions. You can then use the multiple manifests in one Foreman server to manage multiple organizations.
The following diagram shows two Red Hat Network account holders, who want their systems to be managed by the same Foreman installation. In this scenario, Example Corporation 1 can allocate any subset of their 60 subscriptions, in this example they have allocated 30, to a manifest. This can be imported into the Foreman as a distinct Organization. This allows system administrators the ability to manage Example Corporation 1’s systems using Foreman completely independently of Example Corporation 2’s organizations (R&D, Operations, and Engineering).
Foreman server with multiple manifests
Figure 2. Foreman server with multiple manifests
  • Add the subscription for Foreman server to the manifest if planning a disconnected or self-registered Foreman server. This is not necessary for a connected Foreman server that is subscribed using the Subscription Manager utility on the base system.
  • Add subscriptions for all Smart Proxy servers you want to create.
  • Add subscriptions for all Red Hat products you want to manage with Foreman.
Foreman allows the use of future-dated subscriptions in the manifest. This enables uninterrupted access to repositories when future-dated subscriptions are added to a manifest before the expiry date of existing subscriptions.
Note that the Red Hat subscription manifest can be modified and reloaded to Foreman server in case of any changes in your infrastructure, or when adding more subscriptions. Manifests should not be deleted. If you delete the manifest from the Red Hat Customer Portal or in the Foreman web UI it will unregister all of your hosts.
11.5. Host group structure scenarios
Figure 3. Host group structuring examples
Flat structure
Application based structure
Location based structure
In this hierarchy, the distribution of locations is aligned with the host group structure. In a scenario where the location or Smart Proxy server topology determines many other attributes, this approach is the best option. However, this structure complicates sharing parameters across locations, therefore in complex environments with a large number of applications, the number of host group changes required for each configuration change increases significantly.
11.6. Inter-Server Synchronization deployment scenarios
You can use Inter-Server Synchronization to synchronize content between Foreman servers, including air-gapped servers. In these scenarios, you copy selected content views or all Library content from an upstream server to downstream servers over a network or through physical export.
Foreman uses Inter-Server Synchronization (ISS) to synchronize content between two Foreman servers including those that are air gapped.
  • If you want to copy some but not all content from your Foreman server to other Foreman servers. For example, you have content views that your IT department consumes from Foreman server, and you want to copy content from those content views to other Foreman servers.
  • If you want to copy all Library content from your Foreman server to other Foreman servers. For example, you have products and repositories that your IT department consumes from Foreman server in the Library, and you want to copy all products and repositories in that organization to other Foreman servers.
You cannot use ISS to synchronize content from Foreman server to Smart Proxy server. Smart Proxy server supports synchronization natively.
  • The upstream Foreman server is connected to the internet. This server consumes content from the Red Hat Content Delivery Network (CDN) or custom sources.
  • The downstream Foreman server is completely isolated from all external networks.
  • The downstream Foreman server can communicate with a connected upstream Foreman server over an internal network.
Foreman ISS disconnected scenario
Figure 4. Foreman ISS disconnected scenario
You can configure your downstream Foreman server to synchronize content from the upstream Foreman server over the network.
  • The upstream Foreman server is connected to the internet. This server consumes content from the Red Hat CDN or custom sources.
  • The downstream Foreman server does not have a network connection to a connected upstream Foreman server.
The Foreman ISS air-gapped scenario
Figure 5. Foreman ISS air-gapped scenario
The only way for an air-gapped downstream Foreman server to receive content updates is by exporting payload from the upstream Foreman server, bringing it physically to the downstream Foreman server, and importing the payload.
You can configure your downstream Foreman server to synchronize content by using exports.
11.7. Foreman deployment scenarios on AWS
One-region setup
One-region setup
Figure 6. One-region setup
Figure 7. Site-to-site VPN connection between the AWS region and the on-premises data center
Figure 8. Direct connection using the external DNS host name
Connecting different regions
Figure 9. Site-to-site VPN connection between AWS regions
Figure 10. Direct connection using the external DNS host name
12. Provisioning requirements in Foreman
12.1. PXE booting in Foreman
PXE sequence
PXE booting requirements
  • Network requirements:
  • Client requirements:
  • Foreman requirements:
12.2. HTTP booting in Foreman
    • The TCP port 9090 is open for the client to download the boot loader from the Smart Proxy using the HTTPS protocol.
      • https://smartproxy.example.com:9090
    • Ensure that the TCP port 9090 is open for the client to download the boot loader from the Smart Proxy through HTTPS.
12.3. Secure Boot in Foreman
# reboot
foreman
N/A
foreman
N/A
yes
/usr/share/foreman
/sbin/nologin
foreman-proxy
N/A
foreman-proxy
N/A
yes
/usr/share/foreman-proxy
/sbin/nologin
apache
48
apache
48
no
/usr/share/httpd
/sbin/nologin
postgres
26
postgres
26
no
/var/lib/pgsql
/bin/bash
pulp
N/A
pulp
N/A
no
N/A
/sbin/nologin
puppet
52
puppet
52
no
/sbin/nologin
saslauth
N/A
saslauth
76
no
/run/saslauthd
/sbin/nologin
tomcat
53
tomcat
53
no
/usr/share/tomcat
/bin/nologin
unbound
N/A
unbound
N/A
yes
/etc/unbound
/sbin/nologin
Activation key
Activation keys are used by Subscription Manager to register hosts to Foreman. They define content view and lifecycle environment associations, content overrides, system purpose attributes, and other parameters to be associated with a newly created host.
They are associated to exactly one lifecycle environment and exactly one content view, though this may be a composite content view. You can use them on multiple machines and they behave like configuration information rather than traditional software license keys. You can also use multiple activation keys with a single host. When you register a host using an activation key, certain content from Foreman is provided to the host. The content that is made available depends on the content in the activation key’s content view and lifecycle environment, any content overrides present, any repository-level restrictions such as operating system or architecture, and system purpose attributes such as release version.
Activation key
Ansible
Answer file
ARF report
Audits
Boot disk
Catalog
Candlepin
Compliance policy
Compute profile
Compute resource
Configuration Management
Container (Docker container)
Container image
Content
A general term for everything Foreman distributes to hosts. Content includes software packages such as .rpm packages, errata, or Docker images. Content is synchronized into the Library and then promoted into lifecycle environments using content views so that they can be consumed by hosts.
The mechanism used to deliver Red Hat content to Foreman server.
Content view
Content views are named and versioned collections of repositories. When you publish a content view, Foreman creates a new content view version. This content view version is a frozen snapshot of the current state of the repositories within the content view. Any subsequent changes to the underlying repositories will no longer affect the published content view version. Once a content view is published, it can be promoted through the lifecycle environment path, or modified using incremental upgrades.
Composite content view
Discovered host
Discovery image
Discovery plugin
Enables automatic bare-metal discovery of unknown hosts on the provisioning network. The plugin consists of three components: services running on Foreman server and Smart Proxy server, and the Discovery image running on host.
Discovery rule
Docker tag
Enterprise Linux
  • AlmaLinux
  • CentOS Stream
  • Oracle Linux
  • Red Hat Enterprise Linux
  • Rocky Linux
ERB
Errata
Facter
Facts
Foreman
Full host image
Generic image
Hammer
Host
Host collection
Host group
A host group is a template to build hosts that holds shared parameters, such as subnet or lifecycle environment. It helps to unify configuration management in Ansible, Puppet, and Salt by grouping hosts. You can nest host groups to create a hierarchical structure. For more information, see Working with host groups.
Host image
Installation Media
Installation media are sets of installation files used to install the base operating system during the provisioning process. An installation medium in Foreman represents the installation files for one or more operating systems, which must be accessible over the network, either through an URL or an NFS server location. It is usually either a mirror or a CD or DVD image.
Job
Katello
Katello is an open-source plugin to perform content management and subscription handling. It depends on Pulp for content management, which fetches software from repositories and stores various versions of it. It also depends on Candlepin for host registration and managing subscription manifests.
Lazy sync
Location
Library
A container for content from all synchronized repositories on Foreman server. Libraries exist by default for each organization as the root of every lifecycle environment path and the source of content for every content view.
Lifecycle environment
Lifecycle environment path
A mechanism for transferring subscriptions from the Red Hat Customer Portal to Foreman. Do not confuse with Puppet manifest.
Migrating Foreman
OpenSCAP
Organization
Parameter
Patch and release management
Patch and release management describes the process of acquiring, managing, and installing patches and software updates to your infrastructure. Using Foreman, you can keep control of the package versions available to your hosts and deliver applicable errata.
Permission
Product
Products are named collections of one or more repositories. If you manage Red Hat content and upload a Red Hat manifest, Foreman automatically groups Red Hat content within products. If you manage SUSE content using SCC Manager plugin, Foreman automatically groups SUSE content within products. For more information, see Managing SUSE content.
Promote (a content view)
The act of moving a content view from one lifecycle environment to another. For more information, see Promote a content view by using Foreman web UI.
Provisioning
  • Agama templates for SUSE Linux Enterprise Server 16
  • AutoYaST templates for SUSE Linux Enterprise Server 15 and 12
  • Kickstart templates for AlmaLinux, Amazon Linux, CentOS, Oracle Linux, Red Hat Enterprise Linux, and Rocky Linux
  • Preseed Autoinstall templates for Ubuntu
  • Preseed templates for Debian
Publish (a content view)
Pulp
Puppet
OpenVox agent
Puppet environment
Puppet manifest
OpenVox server
Puppet module
PXE
Recurring logic
Registry
Repository
A repository is a single source and the smallest unit of content in Foreman. You can either synchronize a repository with a URL or manually upload content to Foreman. Foreman supports multiple content types. For more information, see Content types in Foreman. One or more repositories form a product.
Resource type
Role
Salt
SCAP content
Smart Proxy server
Smart Proxy servers can provide DHCP, DNS, and TFTP services and act as an Ansible control node, OpenVox server, or Salt Master in separate networks. They interact with Foreman server in a client-server model. Foreman server always comes bundled with an integrated Smart Proxy.
Subnet image
Subscription
Subscription Manager is a client application to register hosts to Foreman. subscription-manager uses activation keys to consume content on hosts.
SUSE Subscription
You can use Foreman to manage SUSE content. For more information, see Managing SUSE content.
Synchronization
Synchronization describes the process of fetching content from external repositories into the Foreman server.
Sync plan
Tailoring files
Task
Trend
Updating Foreman
The process of advancing your Foreman server and Smart Proxy server installations from one patch release to the next, for example Foreman 5.0.0 to Foreman 5.0.1.
Upgrading Foreman
The process of advancing your Foreman server and Smart Proxy server installations from one minor release to the next, for example Foreman 3.19 to Foreman 5.0.
User group
User
Virtualization
virt-who
XCCDF profiles
Report issue
