1. Tune Foreman server performance with predefined profiles
If your Foreman deployment includes a large number of hosts, you can use predefined tuning profiles to configure your Foreman server to use the optimal amount of CPU cores and memory. This can help improve Foreman performance.
1.1. How predefined tuning profiles apply
When you run the foreman-installer command with the --tuning option, deployment configuration settings from multiple sources are applied to Foreman in a specific order.
This order defines the priority of these settings.
Foreman loads tuning configuration settings from the following sources:
- Custom Hiera settings
If you use custom Hiera settings on your Foreman server, you can find them in the
/etc/foreman-installer/custom-hiera.yamlfile. - Predefined tuning profile
This is the profile that you select when running the
foreman-installercommand with the--tuningoption. The settings for these profiles are defined in the/usr/share/foreman-installer/config/foreman.hiera/tuning/sizes/directory. - Base tuning profile
The settings for this profile are defined in the
/usr/share/foreman-installer/config/foreman.hiera/tuning/common.yamlfile.
When merging these settings, Foreman applies them in the following order:
Custom settings in the
/etc/foreman-installer/custom-hiera.yamlfile override the settings in any predefined profile and the base profile. -
Predefined profile settings override the settings in the base profile.
1.2. Predefined tuning profiles
The following predefined tuning profiles are available in Foreman to right-size your Foreman server based on the number of hosts your Foreman manages and available hardware resources.
The predefined tuning profiles are available in the /usr/share/foreman-installer/config/foreman.hiera/tuning/sizes directory.
Each profile targets a managed-host range and minimum RAM and CPU cores.
| Tuning profile | Number of hosts | RAM | Number of CPU cores |
default |
0 – 5000 |
20G |
4 |
medium |
5001 – 10000 |
32G |
8 |
large |
10001 – 20000 |
64G |
16 |
extra-large |
20001 – 60000 |
128G |
32 |
extra-extra-large |
60000+ |
256G |
48+ |
1.3. Apply a predefined tuning profile
Run foreman-installer with the --tuning option to apply a profile.
Choosing the right tuning profile helps your Foreman server use its CPU cores and memory better.
You cannot use predefined tuning profiles on Smart Proxy servers. |
If you use a
custom-hiera.yamlfile on your Foreman server, perform the following steps:-
Optional: Back up your
custom-hiera.yamlfile:# cp /etc/foreman-installer/custom-hiera.yaml \ /etc/foreman-installer/custom-hiera.original.yaml
This ensures you can restore the
custom-hiera.yamlfile to its original state if it becomes corrupted. -
Review the definitions of the base tuning profile in
/usr/share/foreman-installer/config/foreman.hiera/tuning/common.yamland the tuning profile that you want to apply in/usr/share/foreman-installer/config/foreman.hiera/tuning/sizes/. -
Compare the configuration entries against the entries in your
Remove any duplicated configuration settings that you find in
custom-hiera.yaml. This ensures the settings incustom-hiera.yamldo not override the settings in the base tuning profile and your chosen predefined tuning profile.
Apply the tuning profile:
2. Reduce Foreman server load with an external database
When you install Foreman, PostgreSQL runs on the same server as Foreman by default. If you use internal databases but need to reduce server load, you can migrate them to external databases.
2.1. Determine whether your Foreman server uses internal or external databases
You can confirm whether your Foreman server uses internal or external databases by checking PostgreSQL deployment on the server.
On Foreman server, query the status of your databases:
2.2. External PostgreSQL considerations
Foreman, Katello, and Candlepin use PostgreSQL. Review the advantages and disadvantages of external PostgreSQL to decide if this option fits your Foreman configuration.
Foreman supports PostgreSQL version 13.
- Advantages of external PostgreSQL
Increase in free memory and free CPU on Foreman
Flexibility to set
shared_bufferson the PostgreSQL database to a high number without the risk of interfering with other services on Foreman -
Flexibility to tune the PostgreSQL server’s system without adversely affecting Foreman operations
- Disadvantages of external PostgreSQL
If either Foreman or the PostgreSQL database server suffers a hardware or storage failure, Foreman is not operational
If there is latency between the Foreman server and database server, performance can suffer
2.3. Install PostgreSQL as an external database
Install and configure PostgreSQL on a dedicated host if you want to use an external database with your Foreman server.
The prepared host has base operating system repositories enabled.
The prepared host has enough disk space available for the
/var/lib/pgsqldirectory. The expected installation size is 100 MB and the expected runtime size is 20 GB.
On your new database server, install PostgreSQL:
# dnf install postgresql-server postgresql-contrib
Initialize the PostgreSQL database:
# postgresql-setup --initdb
Edit the
Note that you must adjust the default configuration of external PostgreSQL to work with Foreman. The base recommended external database configuration adjustments are as follows:
max_connections: 500
shared_buffers: 512MB
work_mem: 4MB
Remove the
Add the following line to the end of the file to use Salted Challenge Response Authentication Mechanism (SCRAM) for authentication:
Edit the
host all all Foreman_ip/32 scram-sha-256
Start and enable the PostgreSQL service:
Update the firewall configuration. For example, using the
firewall-cmdcommand:-
Open the postgresql port:
Make the changes persistent:
Switch to the
Create three databases and dedicated roles: one for Foreman, one for Candlepin, and one for Pulp:
CREATE USER "foreman" WITH PASSWORD 'Foreman_Password'; CREATE DATABASE foreman OWNER foreman; CREATE USER "candlepin" WITH PASSWORD 'Candlepin_Password'; CREATE DATABASE candlepin OWNER candlepin; CREATE USER "pulp" WITH PASSWORD 'Pulpcore_Password'; CREATE DATABASE pulpcore OWNER pulp;
Exit the
postgresuser:# \q
From Foreman server, test that you can access the database:
# PGPASSWORD='Foreman_Password' pg_isready --host=postgres.example.com --port=5432 --username=foreman --dbname=foreman # PGPASSWORD='Candlepin_Password' pg_isready --host=postgres.example.com --port=5432 --username=candlepin --dbname=candlepin # PGPASSWORD='Pulpcore_Password' pg_isready --host=postgres.example.com --port=5432 --username=pulp --dbname=pulpcore
If the connection succeeded, this displays an
accepting connectionsmessage.
2.4. Move Foreman databases to an external host
Migrate internal PostgreSQL databases from Foreman server to a dedicated external host when you need to reduce server load or manage the database independently.
Insights in Foreman requires internal database mode. You cannot migrate to an external database while Insights in Foreman is enabled on Foreman server. |
You have installed and configured a PostgreSQL server on an external server.
You have confirmed that Foreman server currently uses internal databases. For more information, see Determine whether your Foreman server uses internal or external databases.
You have scheduled a maintenance window.
On Foreman server, stop all Foreman services except for PostgreSQL:
Create your target directory for the Foreman backup:
# mkdir /var/My_Migration_Backup_Directory
# foreman-maintain backup online \ --preserve-directory \ --skip-pulp-content \ /var/My_Migration_Backup_Directory
PGPASSWORD='Foreman_Password' pg_restore --host=postgres.example.com --username=foreman --dbname=foreman < /var/My_Migration_Backup_Directory/foreman.dump PGPASSWORD='Candlepin_Password' pg_restore --host=postgres.example.com --username=candlepin --dbname=candlepin < /var/My_Migration_Backup_Directory/candlepin.dump PGPASSWORD='Pulpcore_Password' pg_restore --host=postgres.example.com --username=pulp --dbname=pulpcore < /var/My_Migration_Backup_Directory/pulpcore.dump
Use the
foreman-installercommand to update Foreman to point to the new databases:# foreman-installer \ --katello-candlepin-manage-db false \ --katello-candlepin-db-host postgres.example.com \ --katello-candlepin-db-name candlepin \ --katello-candlepin-db-user candlepin \ --katello-candlepin-db-password Candlepin_Password \ --foreman-proxy-content-pulpcore-manage-postgresql false \ --foreman-proxy-content-pulpcore-postgresql-host postgres.example.com \ --foreman-proxy-content-pulpcore-postgresql-db-name pulpcore \ --foreman-proxy-content-pulpcore-postgresql-user pulp \ --foreman-proxy-content-pulpcore-postgresql-password Pulpcore_Password \ --foreman-db-manage false \ --foreman-db-host postgres.example.com \ --foreman-db-database foreman \ --foreman-db-username foreman \ --foreman-db-password Foreman_Password
Remove the PostgreSQL package on Foreman server:
# dnf remove postgresql-server
Remove the PostgreSQL data directory:
# rm -fr /var/lib/pgsql/data
3. Prepare for disaster recovery and recover from data loss
- Snapshots of virtualized Foreman server
- How do I back up?
Virtualize your Foreman server and use the hypervisor tools to take virtual machine snapshots of the server. This method is suitable if you can run Foreman in a virtual machine.
- Active and passive Foreman server, with external storage
- How do I back up?
/var/lib/pulpand database in/var/lib/pgsql. Replicate this storage into a different data center. Attach the storage to a Foreman server that is a clone of the primary Foreman server but runs passively. - How will I recover in case of a disruptive event?
To recover Foreman services, switch DNS records of the active Foreman server with the passive Foreman server. This ensures that the passive server becomes the active server. All hosts remain connected without configuration updates.
- Active and passive Foreman server, with backup and restore
- How do I back up?
Ensure periodic backups of your Foreman server. Copy this backup to a passive Foreman server and restore it on the passive server.
- Dual active Foreman server
- How do I back up?
Operate an active, independent Foreman server per data center. Hosts from each data center are registered to the Foreman server in that data center. Then configure automation to ensure recovery in case of a disruptive event. For example, you can periodically run a health check and if the health check discovers that the current Foreman server a host is registered to does not resolve, the host is re-registered to the other Foreman server.
To recover Foreman services, re-register all hosts to the Foreman server in the other data center.
3.1. Disaster recovery by virtualizing your Foreman server
If you virtualize your Foreman server and ensure that you take regular snapshots of the virtual machine (VM), you can respond to various disaster scenarios by restoring your Foreman deployment from one of your snapshots.
The details for how to implement this scenario depend on your choice of a virtualization platform. Due to the variety of different hypervisors and their capabilities, Foreman community does not provide detailed instructions for any specific virtualization platform. |
3.1.1. Prepare for failures by virtualizing your Foreman server
Implement a reliable process for regularly taking VM snapshots of your virtualized Foreman server and for backing up your snapshots for long-term storage.
You have reviewed Prepare for disaster recovery and recover from data loss and determined that this disaster recovery plan works for you.
Your Foreman server is deployed as a VM.
Define a schedule for taking periodic snapshots of your virtualized Foreman server. Consider your tolerance for potential data loss: Taking snapshots frequently will result in smaller amounts of data loss in case of a disaster. However, creating a snapshot takes time, and the snapshots also require storage space.
Using your hypervisor, schedule periodic snapshots of your Foreman server.
If you are using an external database that runs on a different machine than your Foreman server, create snapshots and backups on the same schedule as your Foreman server.
Use the latest snapshot of your Foreman server and restore it in an isolated environment.
To verify that you will be able to restore Foreman services in case of a disaster, assess the functionality of the test Foreman server. For more information, see Retrieve status of services by using Hammer CLI.
3.1.2. Recover from disaster by restoring a VM snapshot of Foreman server
In case of a disaster, use a virtual machine (VM) snapshot of your Foreman server to restore Foreman services.
Ensure that the hostname of your Foreman server does not change during recovery. The IP address can change. |
If you are using an external database that runs on a different machine than your Foreman server, ensure that you restore the database from a snapshot taken at the same time as or before the Foreman server snapshot.
Update DNS records so that the Foreman server hostname resolves to the new IP address. This redirects traffic from the old server to the new server and you will not need to re-register your hosts.
Assess the functionality of your restored Foreman server. For more information, see Retrieve status of services by using Hammer CLI.
3.1.3. Retrieve status of services by using Hammer CLI
Get information from the database and Foreman services:
$ hammer ping
Run
Perform a health check:
Run
3.2. Disaster recovery for active and passive Foreman server with external storage
To prepare for disaster recovery, you can configure two Foreman servers and store critical data externally on shared storage. The primary server is active while the secondary server remains passive. If the primary server fails, the shared storage is attached to your secondary server, which turns the secondary server into your new primary server.
3.2.1. Prepare for failures with a passive Foreman server with external storage
Create your passive Foreman server as a backup of your active Foreman server.
Your shared storage meets the requirements for holding the contents of
/var/lib/pulpand/var/lib/pgsql. For more information, see Storage requirements. -
You have configured your Foreman server to use external databases. For more information, see Reduce Foreman server load with an external database.
Replicate the
/var/lib/pulpand/var/lib/pgsqldirectories from the active Foreman server to your shared storage. -
Back up your active Foreman server and restore it on a system that will serve as your passive Foreman server. For more information, see Back up Foreman and Restore Foreman from backup.
Assess the functionality of the test Foreman server. For more information, see Retrieve status of services by using Hammer CLI.
3.2.2. Recover from disaster with active and passive Foreman server with external storage
If your active Foreman server fails, detach it from the shared storage and make sure your passive server can access the data stored on the shared storage. This turns the passive server into your new active server.
Assess the functionality of your new active Foreman server. For more information, see Retrieve status of services by using Hammer CLI.
3.2.3. Retrieve status of services by using Hammer CLI
$ hammer ping
Run
Run
3.3. Disaster recovery for active and passive Foreman server with backup and restore
To prepare for disaster recovery, you can configure two Foreman servers: an active primary server and a passive secondary server. You configure periodic backups of the primary server. If the primary server fails, you can restore a backup on the secondary server to turn it into your new primary server.
3.3.1. Prepare for failures with a passive Foreman server and backup
Create your passive Foreman server by restoring a backup of your active Foreman server. Configure periodic backups of the active server.
You have a Foreman server installed.
Define a schedule for periodic offline backups of your active Foreman server. Consider your tolerance for potential data loss and your storage options: Taking backups frequently will result in smaller amounts of data loss in case of a disaster, but backups require a significant amount of storage space. For information about the size of Foreman backups, see Estimate the size of a backup.
cronjob that ensures regular backups, see Example of a weekly full backup followed by daily incremental backups. -
Schedule periodic offline backups of your active Foreman server to be taken according to the schedule you defined. For information about performing backups, see Back up Foreman.
Ensure that the backup directories are encrypted and regularly synchronized to a secure location. By default, Foreman stores the backups in the
/var/foreman-backupdirectory.ImportantForeman server backups contain sensitive information from the
/root/ssl-builddirectory. For example, they can contain hostnames, ssh keys, request files, and SSL certificates. Encrypting or moving the backups to a secure location helps minimize the risk of damage or unauthorized access to the hosts. -
Restore the most recent backup on a system that will serve as your passive Foreman server. For information about restoring backups, see Restore Foreman from backup.
Verify that Foreman takes backups according to the schedule you defined.
3.3.2. Recover from disaster with active and passive Foreman server and backup and restore
If your active Foreman server fails, activate your passive secondary server.
3.3.3. Retrieve status of services by using Hammer CLI
$ hammer ping
Run
Run
3.3.4. Example of a weekly full backup followed by daily incremental backups
#!/bin/bash -e
else
fi
exit 0
Note that the {foreman-maintain backup} command requires /sbin and /usr/sbin directories to be in PATH and the --assumeyes option is used to skip the confirmation prompt.
3.4. Disaster recovery with two active Foreman servers
To prepare for disaster recovery, you can configure two Foreman servers and operate each server in a different data center. If one of the servers fails, you can re-register all hosts from the failed server to the other server.
3.4.1. Prepare for failures with two active Foreman servers
Create a second Foreman server by restoring a backup of your first Foreman server. Configure both servers to operate independently in their respective data centers, but ensure that their content does not drift apart over time.
Ansible playbooks can help you automate failover, re-registration, and synchronization. For more information, see Using the Foreman Ansible Collection. |
Back up your Foreman server. For more information, see Back up Foreman.
Restore the backup on a system that will serve as your other Foreman server. For more information, see Restore Foreman from backup.
Register hosts to your servers so that each server manages hosts in its respective data center. For example, register all hosts in My_Data_Center_1 to one Foreman server and all hosts in My_Data_Center_2 to the other Foreman server.
Automate running the
Verify that your
3.4.2. Recover from disaster with two active Foreman servers
If the health checks implemented in Prepare for failures with two active Foreman servers report an issue on one of your Foreman servers, it might mean that the server has failed. If the server is down, you must re-register hosts to the other server.
If
4. Manage users and roles
Foreman users represent individuals who access your Foreman and are scoped to organizations and locations. You assign roles to users to control which actions they can perform in your environment.
4.1. Create and manage Foreman users
4.1.1. Create a user by using Foreman web UI
Create user accounts from the Foreman web UI to grant individuals access to your Foreman environment.
Click Create User.
Enter the account details for the new user.
On the User tab, select an authentication source from the Authorized by list:
INTERNAL: to manage the user inside Foreman server.
EXTERNAL: to manage the user with external authentication. For more information, see Configuring authentication for Foreman users.
On the Organizations tab, select organizations for the user. Select the default organization from the Default on login list. Foreman uses this organization for the user after login.
On the Locations tab, select locations for the user. Select the default location from the Default on login list. Foreman uses this location for the user after login.
4.1.2. Create a user by using Hammer CLI
Create user accounts by using Hammer CLI to grant individuals access to your Foreman environment.
Create a user:
$ hammer user create \ --auth-source-id My_Authentication_Source \ --login My_User_Name \ --mail My_User_Mail \ --organization-ids My_Organization_ID_1,My_Organization_ID_2 \ --location-ids My_Location_ID_1,My_Location_ID_2 \ --password My_User_Password
Append
--auth-source-id 1so that the user is authenticated internally. Runhammer auth-source listto get a list of authentication sources. Add the--adminoption to grant administrator privileges to the user.You can modify the user details later by using the
hammer user updatecommand.
4.1.3. Assign roles to a user by using Foreman web UI
Assign roles to a user in the Foreman web UI to control which permissions and resources they can access in your environment.
NoteIf a user account is not listed, check that you are currently viewing the correct organization. To list all the users in Foreman, click Default Organization and then Any Organization.
Click Submit.
4.1.4. Assign roles to a user by using Hammer CLI
Assign roles to a user with Hammer CLI to grant the permissions they need to perform tasks in Foreman.
Assign roles to a user:
$ hammer user add-role \ --id My_User_ID \ --role My_Role_Name
4.1.5. Impersonate a different user account
As an administrator, you can impersonate another user by logging on to the Foreman web UI as that user. Impersonating another user is useful for testing and troubleshooting purposes because you can access exactly what the impersonated user can access in the system, including the same menus.
You are logged on to the Foreman web UI as a user with administrator privileges for Foreman.
4.1.6. Create an API-only user
You can create a user account that can interact only with the Foreman API. This is useful for service accounts or integrations that must not use the Foreman web UI.
You have created a user and assigned roles to them. Note that this user must be authorized internally. For more information, see Manage users and roles.
Log in to your Foreman as admin.
# openssl rand -hex 32
Create a Personal Access Token for the user. For more information, see Create a Personal Access Token.
4.2. SSH key management
Add SSH keys to user accounts so Foreman can deploy those keys during host provisioning.
4.2.1. Manage SSH keys for a user by using Foreman web UI
Add or remove SSH keys for a user in the Foreman web UI to control which keys Foreman deploys during provisioning.
You are logged in to the Foreman web UI as an Admin user of Foreman or a user with the
create_ssh_keypermission enabled for adding SSH key anddestroy_ssh_keypermission for removing a key.
Click on the SSH Keys tab.
To Add SSH key
Click Add SSH Key.
Click Submit.
To Remove SSH key
4.2.2. Manage SSH keys for a user by using Hammer CLI
Add or remove SSH keys for a user with Hammer CLI to manage which keys Foreman deploys during provisioning.
To add an SSH key to a user, you must specify either the path to the public SSH key file, or the content of the public SSH key copied to the clipboard:
$ hammer user ssh-keys add \ --user-id user_id \ --name key_name \ --key-file ~/.ssh/id_rsa.pub
$ hammer user ssh-keys add \ --user-id user_id \ --name key_name \ --key ecdsa-sha2-nistp256 AAAAE2VjZHNhLXNoYTItbmlzdHAyNTYAAAAIbmlzdHAyNtYAAABBBHHS2KmNyIYa27Qaa7EHp+2l99ucGStx4P77e03ZvE3yVRJEFikpoP3MJtYYfIe8k 1/46MTIZo9CPTX4CYUHeN8= host@user
4.3. Create and revoke Personal Access Tokens
4.3.1. Create a Personal Access Token
200, for example:{"foreman_version":"5.0.0","result":"ok","status":200,"version":"3.5.1.10","api_version":2}If you go back to Personal Access Tokens tab, you can see the updated Last Used time next to your Personal Access Token.
4.3.2. Revoke a Personal Access Token
4.4. Create and manage user groups
With Foreman, you can assign permissions to groups of users. You can also create user groups as collections of other user groups. If you use an external authentication source, you can map Foreman user groups to external user groups.
4.4.1. Create a user group by using Foreman web UI
Create a user group in the Foreman web UI and define which roles the group will have.
In the Foreman web UI, navigate to Administer > User Groups.
Click Create User group.
Click Submit.
4.4.2. Create a user group by using Hammer CLI
Create a user group by using Hammer CLI and define which roles the group will have.
Create a user group:
$ hammer user-group create \ --name My_User_Group_Name \ --role-ids My_Role_ID_1,My_Role_ID_2 \ --user-ids My_User_ID_1,My_User_ID_2
4.4.3. Remove a user group
Remove a user group from Foreman when you no longer need it or when you want to reorganize how permissions are assigned.
Click Delete to the right of the user group you want to delete.
Click Confirm to delete the user group.
4.4.4. Associate external users with user groups
Foreman does not associate external users with their user group automatically. To associate these external users with their user group, you must create the user group on your Foreman server.
When you create a Foreman user group with the same name as in the external source, members of the external user group automatically become members of the Foreman user group and receive the associated permissions. The configuration of external user groups depends on the type of external authentication.
If you use an LDAP server, configure Foreman to use LDAP authentication. For more information, see Configuring authentication for Foreman users.
When using external user groups from an LDAP source, you cannot use the
$loginvariable as a substitute for the account user name. You must use either an anonymous or dedicated service user. -
If you use a FreeIPA or AD server, configure Foreman to use FreeIPA or AD authentication. For more information, see Configuring authentication for Foreman users.
Ensure that at least one external user authenticates for the first time.
Retain a copy of the external group names you want to use. You can find the group membership of external users:
# id username
In the Foreman web UI, navigate to Administer > User Groups, and click Create User Group.
Specify the name of the new user group. Do not select any users to avoid adding users automatically when you refresh the external user group.
Click the Roles tab and select the roles you want to assign to the user group. Alternatively, select the Administrator checkbox to assign all available permissions.
Click the External groups tab, then click Add external user group, and select an authentication source from the Auth source drop-down menu.
Click Submit.
5. Create and manage roles
Roles define a set of permissions and access levels through permission filters. Assign roles to users and user groups to control which actions they can perform in your environment.
5.1. Best practices for role-based access control in Foreman
When implementing role-based access control in Foreman, consider the following guidelines for optimal results.
Define the expected tasks and responsibilities: Define the subset of the Foreman infrastructure that you want the role to access as well as actions permitted on this subset. Think of the responsibilities of the role and how it differs from other roles.
Use predefined roles whenever possible: Foreman provides several sample roles that you can use. Copying and editing an existing role can be a good start for creating a custom role.
Adopt a granular approach to user role management: Define roles with specific and well-scoped permissions. Note that each user can have multiple roles assigned and that permissions from these roles are cumulative.
Add permissions gradually and test the results: When creating a custom role, start with a limited set of permissions and add permissions one by one, while testing continuously. Ensure to test your custom role to verify that it works as intended.
Consider areas of interest and granting read-only access: Even though a role has a limited area of responsibility, it might need a wider set of permissions. Therefore, you can grant the role a read-only access to parts of Foreman infrastructure that influence its area of responsibility.
5.2. Create a role by using Foreman web UI
Create a role by using the Foreman web UI. You can add permissions to the role to control which actions users can perform.
In the Foreman web UI, navigate to Administer > Roles.
Click Create Role.
Provide a Name for the role.
Add permissions to the role. To serve its purpose, a role must contain permissions.
5.3. Create a role by using Hammer CLI
Create a role by using Hammer CLI. You can add permissions to the role to control which actions users can perform.
Create a role:
5.4. Clone a role
Clone an existing role in the Foreman web UI to quickly create a new role with similar permissions. You can edit the cloned role to customize permissions for your environment.
In the Foreman web UI, navigate to Administer > Roles and select Clone from the drop-down menu to the right of the required role.
Click org-1 admin, and click Filters to view all associated filters. The default filters work for most use cases. However, you can optionally click Edit to change the properties for each filter. You can also click New filter to associate new filters with this role.
5.5. Add permissions to a role by using Foreman web UI
Add permissions to a role in the Foreman web UI to define which actions users with that role can perform.
Click Next.
Click Submit to save changes.
5.6. Add permissions to a role by using Hammer CLI
Add permissions to a role by using Hammer CLI to define which actions users with that role can perform.
Add permissions to a role:
$ hammer filter create \ --permission-ids My_Permission_ID_1,My_Permission_ID_2 \ --role My_Role_Name
For more information about roles and permissions parameters, enter the
hammer role --helpandhammer filter --helpcommands.
5.7. View permissions of a role
View the permissions assigned to a role in the Foreman web UI to verify which actions users with that role can perform.
The Filters page contains a table of permissions assigned to a role grouped by the resource type.
5.8. Remove a role
You can remove a role from the Foreman web UI if you no longer need it to grant permissions to users.
Select Delete from the drop-down list to the right of the role to be deleted.
Click Confirm to delete the role.
5.9. Predefined roles available in Foreman
Review predefined roles in Foreman to understand which permissions each role grants before assigning roles to users.
For a complete set of predefined roles and the permissions they grant, log in to Foreman web UI as the privileged user and navigate to Administer > Roles. For more information, see View permissions of a role.
Auditor |
View the Audit log. |
Default role |
Foreman automatically assigns this role to every user in the system. |
Manager |
Organization admin |
Site manager |
System admin |
Viewer |
View the configuration of every element of the Foreman structure, logs, reports, and statistics. |
5.10. Granular permission filtering
With granular permission filters, you can limit permissions of a user to selected instances of a resource type.
5.10.1. Create a granular permission filter by using Foreman web UI
Create a granular permission filter in the Foreman web UI to limit role permissions to specific resource instances.
Specify a query in the Search field on the Edit Filter page. Queries have the following form:
field_name operator value
operator specifies the type of comparison between field_name and value. See Supported operators for granular search for an overview of applicable operators.
NoteFor most resource types, the Search field provides a drop-down list suggesting the available parameters. This list appears after placing the cursor in the search field. For many resource types, you can combine queries using logical operators such as and, not and has operators.
5.10.2. Create a granular permission filter by using Hammer CLI
Create a granular permission filter by using Hammer CLI to limit role permissions to specific resource instances.
hammer filter createcommand with the--searchoption to limit permission filters, for example:$ hammer filter create \ --permission-ids 91 \ --search "name ~ ccv*" \ --role qa-user
This command adds to the qa-user role a permission to view, create, edit, and destroy content views that only applies to content views with name starting with
ccv.
5.10.3. Examples of using granular permission filters
As an administrator, you can allow selected users to make changes in a certain part of the environment path. For example, you can allow users to work with content while it is in the development stage of the application lifecycle, but not once the content is pushed to production.
The following query applies any permissions specified for the Host resource type only to hosts in the group named host-editors:
hostgroup = host-editors
name ^ (XXXX, Yyyy, zzzz)
Dev
5.10.4. Supported operators for granular search
You can use logical and symbolic operators to build precise search queries when limiting user permissions.
Operator |
Description |
and |
Combines search criteria. |
not |
Negates an expression. |
has |
Operator |
Description |
6. Monitor Foreman server with email alerts
Email notifications are created by Foreman server periodically or after completion of certain events. The periodic notifications can be sent daily, weekly or monthly.
Foreman server does not enable outgoing emails by default, therefore you must review your email configuration. |
6.1. Email notification types
You can configure Foreman to send email notifications for system events such as host builds, errata updates, content synchronization failures, and audit summaries to stay informed about important activities in your environment.
- Audit summary
A summary of all activity audited by Foreman server.
- Compliance policy summary
- Content view promote failure
- Content view publish failure
- Host built
- Host errata advisory
- Promote errata
- Repository sync failure
- Smart Proxy sync failure
A notification sent after Smart Proxy synchronization fails.
- Sync errata
6.2. Configure Foreman server for outgoing emails
To send email messages from Foreman server, you can use an SMTP server or the sendmail command.
The Use an SMTP service instead. For the most recent list of major functionality that has been deprecated or removed within Foreman, refer to the Deprecated features section of the Foreman release notes. |
Some SMTP servers with anti-spam protection or greylisting features are known to cause problems.
To set up outgoing email with such a service, install and configure an SMTP service on Foreman server for relay or use the |
In the Foreman web UI, navigate to Administer > Settings.
Click the Email tab and set the configuration options to match your preferred delivery method. The changes have an immediate effect.
The following example shows the configuration options for using an SMTP server:
Table 4. Using an SMTP server as a delivery method Name Example value Additional information Delivery method
SMTP
SMTP address
smtp.example.com
SMTP authentication
login
SMTP HELO/EHLO domain
example.com
SMTP password
password
Use the login credentials for the SMTP server.
SMTP port
25
SMTP username
user@example.com
The following example uses gmail.com as an SMTP server:
Table 5. Using gmail.com as an SMTP server Name Example value Additional information Delivery method
SMTP
SMTP address
smtp.gmail.com
SMTP authentication
plain
smtp.gmail.com
SMTP enable StartTLS auto
SMTP password
app password
Use the Google app password. For more information, see Sign in with app passwords in Google Help Center.
SMTP port
587
SMTP username
user@gmail.com
Use the Google account name.
The following example uses the
sendmailcommand as a delivery method:Table 6. Using sendmail as a delivery method Name Example value Additional information Delivery method
Sendmail
Sendmail location
/usr/sbin/sendmail
For security reasons, both Sendmail location and Sendmail argument settings are read-only and can be only set in
/etc/foreman/settings.yaml. Both settings currently cannot be set viaforeman-installer. This is being tracked in issue #33543. For more information see the sendmail 1 man page.Sendmail arguments
-i
To send email by using an SMTP server that uses TLS authentication, also perform one of the following steps:
Mark the CA certificate of the SMTP server as trusted. To do so, execute the following commands on Foreman server:
# cp mailca.crt /etc/pki/ca-trust/source/anchors/ # update-ca-trust extract
Where
mailca.crtis the CA certificate of the SMTP server. -
Alternatively, in the Foreman web UI, set the
SMTP enable StartTLS autooption toNo.
Click Test email to send a test message to the user’s email address to confirm the configuration is working. If a message fails to send, the Foreman web UI displays an error. See the log at
/var/log/foreman/production.logfor further details.
6.3. Configure email notification preferences
You can configure Foreman to send email messages to individual users registered to Foreman. Foreman sends the email to the email address that has been added to the account, if present.
Users can edit the email address by clicking on their name in the top right of the Foreman web UI and selecting My account.
If you want to send email notifications to a group email address instead of an individual email address, create a user account with the group email address and minimal Foreman permissions, then subscribe the user account to the desired notification types. |
view_mail_notifications.
Click Submit.
6.4. Test email delivery
Click on the username.
If the email is delivered, the verification is complete.
If the email is not delivered, perform the following diagnostic steps:
Verify Foreman server’s email configuration.
If your Foreman server uses the Postfix service for email delivery, the test email might be held in the queue. To verify, enter the
mailqcommand to list the current mail queue. If the test email is held in the queue,mailqdisplays the following message:postqueue: warning: Mail system is down -- accessing queue directly -Queue ID- --Size-- ----Arrival Time---- -Sender/Recipient------- BE68482A783 1922 Thu Oct 3 05:13:36 foreman-noreply@example.com
To fix the problem, start the Postfix service on your Foreman server:
# systemctl start postfix
6.5. Test email notifications
Trigger email notifications:
daily
weekly
monthly
6.6. Change email notification settings for a host
You can enable or disable email notifications for a host to control whether its events trigger alerts. Foreman sends these notifications to the registered owner of the host.
In the Foreman web UI, navigate to Hosts > All Hosts, locate the host that you want to view, and click Edit in the Actions column.
Go to the Additional Information tab. If the Enabled checkbox is checked, then email notifications are enabled on that host.
7. Back up Foreman
7.1. Foreman backup planning
Backing up your Foreman server and Smart Proxy server requires you to plan scheduling, storage, and security so you avoid disruption and protect sensitive data.
7.1.1. Available backup methods
Choose a backup method based on how long you can keep Foreman services unavailable and how much time you can allocate for the backup.
- Offline backup
All Foreman services are stopped during an offline backup to ensure data consistency.
For more details, read help information for the offline backup:
- Incremental backup
Incremental backups are offline backups that capture only files that have changed since a previous backup. They require less time and storage than a full offline backup.
- Online backup
For more details, read help information for the online backup:
- Conventional backup
Conventional backup methods, such as virtual machine snapshots or file system backups, operate outside of Foreman. You must stop all Foreman services for the duration of the backup.
For more information, see Create a conventional backup.
7.1.2. Best practices for backing up Foreman
Apply these recommendations when scheduling and storing backups so you protect sensitive data and avoid conflicts with other administrators.
Foreman community recommends backing up Foreman to a separate storage device on a separate system.
Foreman services are unavailable during the backup. Coordinate with other administrators to ensure no conflicting tasks run during the backup window.
WarningRequest other users of Foreman server or Smart Proxy server to save any changes and warn them that Foreman services are unavailable for the duration of the backup. Ensure no other tasks are scheduled for the same time as the backup.
You can schedule a backup by using
cron.NoteDuring offline backups, the services are inactive and Foreman is in a maintenance mode. A firewall rejects traffic from outside on port 443 to ensure there are no modifications triggered.
Encrypt or move the backup to a secure location to minimize the risk of damage or unauthorized access to the hosts. A backup has sensitive information from the
/root/ssl-builddirectory. For example, it can have hostnames, SSH keys, request files and SSL certificates.
7.1.3. Directories created during backups
Foreman creates the following default backup directories:
foreman-backupon Foreman server -
foreman-proxy-backupon Smart Proxy server
7.1.4. Estimate the size of a backup
Estimate how much disk space a Foreman backup requires so you can ensure enough storage is available and avoid backup failures.
Calculate the size of the uncompressed backup data:
Determine the size of PostgreSQL database data:
# du -sh /var/lib/pgsql/data 100G /var/lib/pgsql/data
Determine the size of Pulp data:
# du -sh /var/lib/pulp 100G /var/lib/pulp
Determine the size of the configuration files:
# du -csh /var/lib/tftpboot /etc /root/ssl-build \ /var/www/html/pub /opt/puppetlabs 16M /var/lib/tftpboot 37M /etc 900K /root/ssl-build 100K /var/www/html/pub 2M /opt/puppetlabs 942M total
Calculate the expected size of the compressed backup data:
The compression ratio of the backup data is as follows:
Table 7. Backup data compression ratio Data type Directory Ratio Example results PostgreSQL database files
/var/lib/pgsql/data80 – 85%
100 GB → 20 GB
Pulp RPM files
/var/lib/pulp(not compressed)
100 GB
Configuration files
/var/lib/tftpboot/etc/root/ssl-build/var/www/html/pub/opt/puppetlabs85%
942 MB → 141 MB
Add up the size of the uncompressed and compressed data, and add a 20% safety margin.
This example requires 201 GB plus 120 GB for the uncompressed and compressed backup data, 321 GB in total. With 64 GB of extra space, allocate 385 GB of space for the backup location.
7.2. Perform a full offline backup
Run a full offline backup on Foreman server and Smart Proxy server to capture all Foreman content and configuration. A full backup is useful when you want to prepare for a future restore from scratch.
Your backup location must have sufficient available disk space to store the backup. For more information, see Estimate the size of a backup.
To enable Foreman to save the backup to an NFS share, the
rootuser of your Foreman server or Smart Proxy server must be able to write to the NFS share. NFS export options such asroot_squashandall_squashare known to prevent this.For more information, see Deploying an NFS server on Red Hat Enterprise Linux 9 and Export options for securing an NFS server on Red Hat Enterprise Linux 9.
Warning
Request other users of Foreman server or Smart Proxy server to save any changes and warn them that Foreman services are unavailable for the duration of the backup. Ensure no other tasks are scheduled for the same time as the backup. |
Back up your Foreman server:
Back up your Smart Proxy server:
7.3. Perform an offline backup without Pulp content
Run an offline backup that excludes the contents of the Pulp directory. A backup without Pulp content is useful for debugging purposes and is only intended to provide access to configuration files without backing up the Pulp database.
Warning
Do not use a backup without Pulp content to restore your Foreman server or Smart Proxy server for production use cases. |
Back up your Foreman server without Pulp content:
Back up your Smart Proxy server without Pulp content:
7.4. Perform an incremental backup
Run an incremental backup to perform an offline backup that captures any changes since a previous full backup. Incremental backups use less time and storage than a full offline backup.
Perform a full offline backup. For more information, see Perform a full offline backup.
Create a directory within your backup directory to store the first incremental backup:
Create the second incremental backup by including the path to the first incremental backup to indicate the starting point for the next increment. This creates a directory for the second incremental backup in your backup directory:
7.5. Example of a weekly full backup followed by daily incremental backups
#!/bin/bash -e
else
fi
exit 0
7.6. Perform an online backup
Run an online backup to create a Foreman backup while keeping most services running. This is useful when you need to maintain system availability during backup operations.
When you perform an online backup, most Foreman services remain running and usable.
Background workers are shut down to ensure consistent backups.
Operations that require background workers remain in pending state.
The backup process ensures that the Pulp data (/var/lib/pulp) is not altered during the backup.
Any changes to the Pulp data during the backup will result in restart of the backup process, taking additional time.
Perform an online backup on your Foreman server:
7.7. Create a conventional backup
You can use conventional backup methods to back up your Foreman server or Smart Proxy server. Unlike Foreman backup methods, conventional backup methods require you to stop Foreman services.
Stop all Foreman services:
Create the snapshot or conventional backup. For more information, see Recovering and restoring a system in Red Hat Enterprise Linux 9 Configuring basic system settings.
Start Foreman services:
8. Restore Foreman from backup
You can restore Foreman server or Smart Proxy server from a backup to recover after failure or data loss. This helps ensure the continuity of your Foreman deployment and associated data in case a disaster occurs.
8.1. Restore from a full backup
Restore Foreman server or Smart Proxy server from a full backup to return the system to the state at the time of the backup. When the restore process completes, all processes are online, and all databases and system configuration revert to the state at the time of the backup.
Your Foreman server must have the same hostname, configuration, and be the same minor version (X.Y) as the original system. If the original system that experienced a failure is unavailable, provision a system with the same configuration and hostname.
The target directory must exist and be writable. The target directory is read from the configuration files contained within the backup archive.
If the original system had the Federal Information Processing Standards (FIPS) mode enabled, the system on which you are restoring must also be FIPS-enabled.
Ensure that you have enough space to store the backup data on the base system of Foreman server or Smart Proxy server as well as enough space after the restoration to contain all the data in the
/etc/and/var/directories contained within the backup.To check the space used by a directory:
To check for free space:
# df -h /var/backup_directory
Add the
Restore the correct SELinux contexts:
# restorecon -Rv /
Choose the appropriate method to install Foreman or Smart Proxy:
To install Foreman server from a connected network, follow the procedures in Installing Foreman Server with Katello 5.0 plugin on Enterprise Linux.
To install a Smart Proxy server, follow the procedures in Installing a Smart Proxy Server 5.0 on Enterprise Linux.
Copy the backup data to the local file system on your Foreman server or Smart Proxy server. This procedure uses /var/backup_directory.
Run the restoration script:
If you create a new instance of Foreman server or Smart Proxy server, decommission the old instance after restoring the backup. Cloned instances are not supposed to run in parallel in a production environment.
Review the
/var/log/foreman/production.logand/var/log/messageslog files.
8.2. Restore from incremental backups
Restore Foreman server or Smart Proxy server from an incremental backup to return the system to the state at the time of the backup. When the restore process completes, all processes are online, and all databases and system configuration revert to the state at the time of the backup.
If you have multiple branches of incremental backups, select your full backup and each incremental backup for the branch you want to restore, in chronological order.
If the backed up system had FIPS enabled, the system on which you are restoring must also have FIPS enabled.
Restore the last full backup by following the instructions in Restore from a full backup.
Remove the full backup data from the local file system on Foreman server, for example,
/var/or/var/tmp/. -
Copy the incremental backup data to the local file system on Foreman server, for example,
/var/or/var/tmp/. -
Review the
8.3. Restore Smart Proxy server by using a virtual machine snapshot
Restore Smart Proxy server from a virtual machine snapshot to return the system to the state at the time of the snapshot. You can use virtual machine snapshots to back up and restore your Smart Proxy server for quick recovery after server failure or configuration issues.
You have selected the relevant organization and location context of your Smart Proxy server, or chosen Any Organization and Any Location.
If your Smart Proxy server is a virtual machine, include it in your backup strategy by using VM snapshots. Creating weekly snapshots that you can restore from is recommended.
After a failure, either restore your Smart Proxy server from a snapshot by using your hypervisor tools, or deploy a new Smart Proxy server and ensure that the host name is the same as before, and then install the Smart Proxy certificates. You may still have them on Foreman server, the package name ends in -certs.tar, alternately create new ones.
Follow the procedures in Installing Smart Proxy server until you can confirm, in the Foreman web UI, that Smart Proxy server is connected to Foreman server.
In the Foreman web UI, navigate to Infrastructure > Smart Proxies.
Select your Smart Proxy server.
Select Optimized Sync to synchronize content from your Foreman server to your Smart Proxy server that bypasses unnecessary steps to speed up performance.
Select Complete Sync to perform a complete sync from your Foreman server to your Smart Proxy server that synchronizes content even if the metadata has not changed.
9. Rename Foreman server or Smart Proxy server
You can rename Foreman server or Smart Proxy server when its hostname or domain changes. After renaming, it is important to update all references to avoid communication and certificate errors.
9.1. Rename Foreman server
Rename Foreman server when its hostname or domain changes so that components, Smart Proxy servers, and registered hosts continue to communicate correctly.
Use the katello-change-hostname script and update all references to the new hostname.
Warning
Renaming your Foreman server host shuts down all Foreman services on that host. The services restart after the renaming is complete. |
You have a backup of your Foreman server before changing its host name. If you fail to successfully rename it, restore it from the backup. For more information, see Back up Foreman.
The
hostnameandhostname -fcommands on Foreman server both return the FQDN of Foreman server. If both commands do not return the FQDN of Foreman server, thekatello-change-hostnamescript will fail to complete.If the
hostnamecommand returns the shortname of Foreman server instead of the FQDN, usehostnamectl set-hostname My_Old_FQDNto set the old FQDN correctly before using thekatello-change-hostnamescript. -
If Foreman server has a custom SSL certificate installed, you have a new certificate for the new FQDN of the host. For more information, see Configure Foreman server with a custom SSL certificate.
On Foreman server, run the
katello-change-hostnamescript, and provide the new host name. Choose one of the following methods:-
If your Foreman server is installed with the default self-signed SSL certificates:
# katello-change-hostname new-foreman \ --username My_Username \ --password 'My_Password'
If your Foreman server is installed with custom SSL certificates:
# katello-change-hostname new-foreman \ --username My_Username \ --password 'My_Password' \ --custom-cert "/root/ownca/test.com/test.com.crt" \ --custom-key "/root/ownca/test.com/test.com.key"
If you have created a custom SSL certificate for the new Foreman server host name, run the Foreman installation script to install the certificate. For more information about installing a custom SSL certificate, see Deploy a Custom SSL Certificate to Foreman server.
Reregister all hosts and Smart Proxy servers that are registered to Foreman server. For more information, see Register hosts to Foreman by using global registration.
On all Smart Proxy servers, run the Foreman installation script to update references to the new host name:
# foreman-installer \ --foreman-proxy-foreman-base-url https://new-foreman.example.com \ --foreman-proxy-trusted-hosts new-foreman.example.com
On Foreman server, list all Smart Proxy servers:
# hammer proxy list
On Foreman server, synchronize content for each Smart Proxy server:
# hammer proxy content synchronize \ --id My_Smart_Proxy_ID
If you use external authentication, reconfigure Foreman server for external authentication after you run the
katello-change-hostnamescript. For more information, see Configuring authentication for Foreman users.
9.2. Rename Smart Proxy server
Rename Smart Proxy server when its hostname or domain changes so that Foreman components and registered hosts continue to communicate correctly.
Use the katello-change-hostname script and update certificates and references to the new hostname.
Warning
Renaming your Smart Proxy server host shuts down all Foreman services on that host. The services restart after the renaming is complete. |
You have a backup of your Smart Proxy server before renaming. If you fail to successfully rename it, restore it from the backup. For more information, see Back up Foreman.
The
hostnameandhostname -fcommands on Smart Proxy server both return the FQDN of Smart Proxy server. If both commands do not return the FQDN of Smart Proxy server, thekatello-change-hostnamescript will fail to complete.If the
hostnamecommand returns the shortname of Smart Proxy server instead of the FQDN, usehostnamectl set-hostname My_Old_FQDNto set the old FQDN correctly before attempting to use thekatello-change-hostnamescript.
On your Foreman server, generate a new certificates archive file for your Smart Proxy server.
If you are using the default SSL certificate, regenerate the default SSL certificates:
# foreman-proxy-certs-generate \ --certs-tar /root/new-smartproxy.example.com-certs.tar \ --foreman-proxy-fqdn new-smartproxy.example.com
.tarfile. -
If you are using a custom SSL certificate, create a new SSL certificate for your Smart Proxy server. For more information, see Configure Smart Proxy server with a custom SSL certificate.
On your Foreman server, copy the certificates archive file to your Smart Proxy server. For example, to copy the archive file to the
rootuser’s home directory:# scp /root/new-smartproxy.example.com-certs.tar root@smartproxy.example.com:
On your Smart Proxy server, run the
katello-change-hostnamescript and provide the host’s new name, Foreman credentials, and certificates archive file name.# katello-change-hostname new-smartproxy.example.com \ --certs-tar /root/new-smartproxy.example.com-certs.tar \ --password 'My_Password' \ --username My_Username
.tarfile. -
If you have created a custom certificate for your Smart Proxy server, deploy the certificate to your Smart Proxy server by entering the
foreman-installercommand that theforeman-proxy-certs-generatecommand returned in a previous step. For more information, see Deploy a Custom SSL Certificate to Smart Proxy server. -
Reregister all hosts that are registered to your Smart Proxy server. For more information, see Registering hosts to Foreman.
Update the Smart Proxy host name in the Foreman web UI.
Locate Smart Proxy server in the list, and click Edit.
Edit the Name and URL fields to match Smart Proxy server’s new host name, then click Submit.
On your DNS server, add a record for the new hostname of your Smart Proxy server, and delete the record of the previous host name.
10. Configure Foreman for Insights analytics
You can configure Foreman to connect to Insights hosted in the Red Hat Hybrid Cloud Console so your Red Hat Enterprise Linux hosts receive suggestions for improvement.
10.1. Insights recommendations
Insights is a set of analytical services by Red Hat for hosts running Red Hat Enterprise Linux. Insights services analyze host data and provide suggestions for host improvements.
- Insights services
Insights services include:
Advisor, which provides recommendations for host improvements. Advisor groups related recommendations into pathways.
Vulnerability, which provides reports on vulnerabilities found on your hosts.
Compliance, which provides reports on compliance with regulatory requirements.
Insights services hosted in the Red Hat Hybrid Cloud Console are not limited to the listed services.
- Hosted Insights
When you use Insights hosted in the Red Hat Hybrid Cloud Console, the Insights client on your hosts collects data and Foreman forwards it to the hosted Insights services for analysis.
If you use Insights in the Red Hat Hybrid Cloud Console:
You can use Insights services online in the Red Hat Hybrid Cloud Console.
The Insights client collects data of your hosts and Foreman forwards the data to the Red Hat Hybrid Cloud Console to calculate recommendations.
You can view and remediate those recommendations both in the Foreman web UI and in the Red Hat Hybrid Cloud Console.
Foreman uploads host inventory reports to the Red Hat Hybrid Cloud Console.
You have control over how much information is included in those reports.
10.2. Hosted Insights enablement
Enable the integration between Foreman and hosted Insights in the Red Hat Hybrid Cloud Console to upload host inventory and receive cloud-based recommendations for your hosts.
10.2.1. Install Red Hat Cloud plugin
Install the Red Hat Cloud plugin on your Foreman server to upload inventory reports to the Red Hat Hybrid Cloud Console. This step is required before you configure the cloud connector.
Install the Red Hat Cloud plugin on your Foreman server:
# foreman-installer --enable-foreman-plugin-rh-cloud
In the Foreman web UI, navigate to Administer > About.
On the Plugins tab, verify that it lists the
foreman_rh_cloudplugin.
10.2.2. Add Foreman server SSH key to authorized keys
To run remote execution jobs on Foreman server itself, add the Foreman server SSH key to authorized keys on your Foreman server.
You can access your Foreman server by using SSH as root.
If the
~root/.ssh/authorized_keysfile does not exist, create it with restrictive ownership and permissions:-
If the
~root/.sshdirectory does not exist, create it:# mkdir ~root/.ssh
Ensure that the directory is owned by the
rootuser:# chown root:root ~root/.ssh
Ensure that the directory is accessible only to the
rootuser:# chmod 700 ~root/.ssh
Create the
authorized_keysfile:# touch ~root/.ssh/authorized_keys
Ensure that the
authorized_keysfile is owned by therootuser:# chown root:root ~root/.ssh/authorized_keys
Ensure that the
authorized_keysfile is accessible only to therootuser:# chmod 600 ~root/.ssh/authorized_keys
Add the SSH key of the
foreman-proxyuser to theauthorized_keysfile:# cat ~foreman-proxy/.ssh/id_rsa_foreman_proxy.pub >>~root/.ssh/authorized_keys
10.2.3. Configure Foreman server for cloud connection
You can configure Foreman server to connect to the Red Hat Hybrid Cloud Console by using remote execution. This enables inventory upload and cloud-based features such as Insights for your hosts.
You have installed the Red Hat Cloud plugin on your Foreman server. For more information, see Install Red Hat Cloud plugin.
Your environment is configured for remote execution. For more information, see Run automated workflows on hosts.
Foreman server must be registered with Red Hat Subscription Management. You can verify the status by running
subscription-manager status. -
You have added the SSH key to authorized keys on your Foreman server. For more information, see Add Foreman server SSH key to authorized keys.
Your Foreman account has a role that grants the
execute_jobs_on_infrastructure_hostspermission.Note that this permission is not included in the default Remote Execution User role.
In the Foreman web UI, navigate to Insights > Inventory Upload.
Click Configure cloud connector.
Click Confirm.
In the Foreman web UI, navigate to Monitor > Foreman Tasks > Tasks.
Find the job with the name
Remote action: Configure cloud connector. -
Verify that the job completed successfully.
Install the Insights client on hosts. For more information, see Monitor hosts by using Insights in Red Hat Hybrid Cloud Console.
10.3. Data control settings for hosted Insights
You can configure how Foreman handles the data collected from hosts before uploading it to the Red Hat Hybrid Cloud Console and how Foreman handles hosts in the Red Hat Hybrid Cloud Console that are no longer managed by Foreman.
10.3.1. Minimize collected data
Use minimal data collection to limit host data sent to Red Hat while keeping the Subscriptions service active. Other Insights services are disabled because they require installed package data.
You can use minimal reporting to limit the amount of system data sent to the Subscriptions service, which remains active. Other Insights services are disabled because they require installed package data, which minimal reports do not include. Reports are still processed daily during the midnight synchronization cycle.
Minimal reports also exclude hostnames, IP addresses, and installed packages. Therefore, obfuscation and exclusion settings do not apply.
If you switch to Analytics data collection, Foreman enables the following settings by default:
Obfuscate host names
Obfuscate host ipv4 addresses
Exclude installed packages
Review and adjust these settings to control what data Foreman shares.
"report_slice_id": "de92044d-9d77-4895-83c4-a476f5020519",
"hosts": [
"account": "123456789",
"subscription_manager_id": "9fc621b9-08c3-4085-a749-bfed38c3052e",
"insights_id": "9fc621b9-08c3-4085-a749-bfed38c3052e",
"bios_uuid": "203F234F-58C7-4237-8DDF-A17A2838A66C",
"bios_vendor": "SeaBIOS",
"bios_version": "1.16.1-1.el9",
"arch": "x86_64",
"infrastructure_type": "virtual",
"system_profile": {
"installed_products": [
"name": "Red Hat Enterprise Linux for x86_64",
"id": "479"
"cores_per_socket": 1,
"system_memory_bytes": 3836579840,
"number_of_cpus": 1,
"number_of_sockets": 1
"cpu_socket(s)": "1"
edit_settingspermission. -
Existing data in Insights Inventory has been deleted before switching to minimal reporting. To remove existing data of a system, navigate to Inventory > Systems in the Red Hat Hybrid Cloud Console, select the system, and click Delete.
You have selected an organization and location.
Select the Minimal data collection setting from the dropdown menu under Settings.
When you select this option, Foreman also updates the corresponding setting on the Insights tab under Administer > Settings.
Click the Generate and upload report button to create a new inventory report and send it to the Red Hat Hybrid Cloud Console.
10.3.2. Obfuscate hostnames and IP addresses
You can configure Foreman to obfuscate hostnames and IP addresses when uploading host data to Insights. Obfuscation ensures that sensitive identifying information is not exposed.
When obfuscation settings are enabled, Foreman obfuscates hostnames and IP addresses.
If obfuscation settings are enabled and the host has its own insights-client obfuscation settings, Foreman honors the host settings.
If obfuscation settings are disabled, Foreman does not obfuscate hostnames or IP addresses unless the client has obfuscation enabled in insights-client.
By default, Foreman applies global obfuscation settings unless an insights-client on the host overrides the settings with its own configuration.
Obfuscation only works when Minimal data collection is disabled. If Minimal data collection is enabled, hostnames and IP addresses are not included in reports, making obfuscation unnecessary and inactive. |
Your hosts have
insights-clientinstalled and configured.
Enable the Obfuscate host names setting to obfuscate host names sent to the Red Hat Hybrid Cloud Console.
Enable the Obfuscate host ipv4 addresses setting to obfuscate IPv4 addresses sent to the Red Hat Hybrid Cloud Console.
In the Organization dropdown menu, select the organization that uploaded the host data.
Click Generate report to create a fresh report with obfuscated data.
Click Download report to download the host inventory report.
Verify that the hostname is
randomhostname.example.comand the IP address is obfuscated.
Click Generate and upload report to create and upload a new report with obfuscated data to the Red Hat Hybrid Cloud Console.
10.3.3. Remove hosts from Insights inventory
When hosts are removed from Foreman, they can also be removed from the inventory of Insights, either automatically or manually. You can configure automatic removal of hosts from the Insights Inventory during Red Hat Hybrid Cloud Console synchronization with Foreman that occurs daily by default.
If you leave the setting disabled, you can still remove the bulk of hosts from the Inventory manually.
If Automatic mismatch deletion is enabled, Foreman removes any hosts from the Red Hat Hybrid Cloud Console that are not registered in Foreman. Enable this setting only when all hosts are registered through Foreman. If any hosts are registered through other Foreman instances or directly to the Red Hat Hybrid Cloud Console, Foreman deletes them.
Automatic mismatch deletion runs once a day as a scheduled task. After removing hosts from Foreman, hosts are deleted from the Red Hat Hybrid Cloud Console inventory during the next scheduled sync. Clicking Sync all inventory status updates the status of hosts but does not trigger immediate deletion. |
view_foreman_rh_cloudandedit_settingspermissions.
Enable the Automatic mismatch deletion setting.
10.4. Disable hosted Insights
If you do not want to use the hosted Insights services in the Red Hat Hybrid Cloud Console, you can disable the integration between Foreman and the Red Hat Hybrid Cloud Console.
The Red Hat Cloud plugin is installed on Foreman server.
Uninstall the Red Hat Cloud plugin on Foreman server:
# foreman-installer --no-enable-foreman-plugin-rh-cloud
Remove the Red Hat Cloud package and its dependencies from Foreman server:
# dnf remove rubygem-foreman_rh_cloud
Restart the Foreman services:
On the Plugins tab, verify that it does not list the
11. Reduce storage use on Foreman server
Foreman server can accumulate a large amount of data over time, which can use a significant amount of disk space. You can clean up database records or reclaim disk space to reduce storage use.
11.1. Delete audit records
Audit records log changes that users make to Foreman resources, such as creating hosts or editing settings. You can clean up outdated audit records by deleting them.
11.1.1. Delete audit records manually
Number_Of_Days.
11.1.2. Delete audit records automatically
This setting is empty by default, meaning Foreman does not automatically delete the audit records.
Set the value of the setting to the number of days after which you want Foreman to delete the audit records.
11.2. Delete report records
Foreman creates report records automatically. To remove old and unnecessary report records, you can delete them. This is useful for maintaining a clean and organized report history.
Use the
foreman-rake reports:expirecommand to remove reports at any time. You can also use a cron job to schedule report record deletions at the set interval that you want.By default, using the
foreman-rake reports:expirecommand removes report records that are older than 90 days. You can specify the number of days to keep the report records by adding the days option and add the number of days.For example, you can delete report records that are older than seven days:
11.3. Clean task records
Task records track background jobs that Foreman executes, such as synchronizing repositories. Configure automatic cleanup or manually clean up outdated tasks to save database space.
11.3.1. Configure the cleaning unused tasks feature
Foreman automatically cleans up old tasks. You can configure the automatic cleaning process according to your needs.
To configure the time at which Foreman runs the cron job, set the
To configure the period after which Foreman deletes the tasks, edit the
To disable regular task cleanup on Foreman, enter the following command:
To reenable regular task cleanup on Foreman, enter the following command:
11.3.2. Delete task records
Foreman creates task records automatically. To remove old and unnecessary task records, you can delete them. This helps maintain system performance and keeps your task history organized.
Use the
foreman-rake foreman_tasks:cleanupcommand to remove tasks at any time. You can also use a cron job to schedule Task record deletions at the set interval that you want.For example, you can delete task records from successful repository synchronizations:
11.3.3. Delete a task by ID
Optional: View the task:
On your Foreman server, delete the task:
Optional: Ensure the task has been removed from Foreman server:
11.4. Reclaim disk space
Foreman can consume a significant amount of disk space, especially in large deployments. By reclaiming disk space, you can reduce the amount of disk space used by Foreman.
11.4.1. Recover from a full disk
If a logical volume (LV) with the Pulp database on it is full, Pulp tasks can fail due to insufficient space. You can recover from the situation by increasing the amount of free space available on the LV.
Ensure that the LV with the
Remove orphaned content:
Change the download policy from Immediate to On Demand for as many repositories as possible and remove already downloaded packages. See the Red Hat Knowledgebase solution How to change syncing policy for Repositories on Satellite from "Immediate" to "On-Demand" on the Red Hat Customer Portal for instructions.
/var/lib/pulpdirectory on it. For more information, see Growing a logical volume and file system in Red Hat Enterprise Linux 9 Configuring and managing logical volumes.NoteIf you use an untypical file system (other than for example ext3, ext4, or xfs), you might need to unmount the file system so that it is not in use. In that case, complete the following steps:
Stop Foreman services:
11.4.2. Reclaim PostgreSQL space
If the PostgreSQL database is using a large amount of disk space, you can reclaim space by vacuuming the database. By reclaiming PostgreSQL space, you can reduce the amount of disk space used by Foreman.
Switch to the
11.4.3. Reclaim space from on-demand repositories
If you want to reclaim space for a single repository:
In the Foreman web UI, navigate to Content > Products.
Select a product.
If you want to reclaim space for multiple repositories:
Select the product name.
If you want to reclaim space for Smart Proxies:
Select the Smart Proxy that lists Pulpcore in the Features column.
On the Overview tab, from the Synchronize menu, select Reclaim Space.
12. Renew Foreman server certificates
You can renew the CA certificate on Foreman server or the custom SSL certificate on Foreman server as well as on Smart Proxy server.
12.1. Renew a custom SSL certificate on Foreman server
You can deploy a renewed custom SSL certificate on Foreman server to replace an expiring certificate and maintain trusted access to the Foreman web UI and API.
You have created a new Certificate Signing Request (CSR) and sent it to the Certificate Authority to sign the certificate. Refer to the Configure Foreman server with a custom SSL certificate guide before creating a new CSR because the Server certificate must have X.509 v3
Key UsageandExtended Key Usageextensions with required values. In return, you will receive the Foreman server certificate and CA bundle.
Deploy the renewed CA certificates to Foreman server:
# foreman-installer --scenario katello \ --certs-server-cert "/root/foreman_cert/foreman_cert.pem" \ --certs-server-key "/root/foreman_cert/foreman_cert_key.pem" \ --certs-server-ca-cert "/root/foreman_cert/ca_cert_bundle.pem" \ --certs-update-server \ --certs-update-server-ca
ImportantDo not delete the certificate files after you deploy the certificate. They are required when upgrading Foreman server.
Access the Foreman web UI from your local machine. For example,
https://foreman.example.com. -
If you have changed the CA certificate on Foreman server, refresh the CA certificate on your hosts. For more information, see Refresh the CA certificate on hosts.
12.2. Renew a custom server CA certificate
If you need to update the certification authority (CA) certificate that signed your Foreman server and Smart Proxy servers certificates, add the new CA certificate and use a temporary dual CA certificate file to retain the HTTPS connections to your Foreman server during the renewal.
Check if the existing server certificate can be validated with the new CA certificate:
# openssl verify -CAfile /root/foreman_cert/old_ca_cert_bundle.pem /root/foreman_cert/foreman_cert.pem
If the check did not succeed, use both the old and the new CA certificate while updating consumers.
Add the new SSL certificate to the CA certificate file on Foreman server and keep the old SSL certificate:
# cat /root/foreman_cert/old_ca_cert_bundle.pem /root/foreman_cert/new_ca_cert_bundle.pem > /root/foreman_cert/ca_cert_bundle.pem
Renew the certificates on Foreman server:
Refresh the certificates on any Smart Proxy servers.
Deploy the dual CA certificate on hosts.
Remove the old certificate from the CA certificates file on Foreman server, so the CA certificate file contains only the new SSL certificate:
# cat /root/foreman_cert/new_ca_cert_bundle.pem > /root/foreman_cert/ca_cert_bundle.pem
Deploy the new CA certificate on hosts.
12.3. Renew a custom SSL certificate on Smart Proxy server
You can deploy a renewed custom SSL certificate on each Smart Proxy server before it expires to maintain secure communication with Foreman server.
Run a unique foreman-installer command on each server because the output of foreman-proxy-certs-generate cannot be reused.
You have created a new Certificate Signing Request and sent it to the Certificate Authority to sign the certificate. Refer to the Configure Foreman server with a custom SSL certificate guide before creating a new CSR because the Foreman server certificate must have X.509 v3
Key UsageandExtended Key Usageextensions with required values. In return, you will receive the Smart Proxy server certificate and CA bundle.
On your Foreman server, generate the certificate archive file for your Smart Proxy server:
# foreman-proxy-certs-generate \ --certs-tar "/root/My_Certificates/smartproxy.example.com-certs.tar" \ --certs-update-server \ --foreman-proxy-fqdn "smartproxy.example.com" \ --server-ca-cert "/root/My_Certificates/ca_cert_bundle.pem" \ --server-cert "/root/My_Certificates/smart-proxy_cert.pem" \ --server-key "/root/My_Certificates/smart-proxy_cert_key.pem"
On your Foreman server, copy the certificate archive file to your Smart Proxy server:
Retain a copy of the
foreman-installercommand that theforeman-proxy-certs-generatecommand returns for deploying the certificate to your Smart Proxy server. -
Deploy the certificate on your Smart Proxy server using the
foreman-installercommand returned by theforeman-proxy-certs-generatecommand:# foreman-installer --scenario foreman-proxy-content \ --certs-tar-file "/root/My_Certificates/smartproxy.example.com-certs.tar" \ --certs-update-server \ --foreman-proxy-foreman-base-url "https://foreman.example.com"
ImportantDo not delete the certificate archive file on the Smart Proxy server after you deploy the certificate. They are required when upgrading Smart Proxy server.
13. Synchronize template repositories
You can synchronize repositories of job templates, provisioning templates, report templates, and partition table templates between Foreman server and a version control system or local directory. You can use the Template Sync plugin to export and import templates.
13.1. Enable the Templates plugin
You can enable the Templates plugin to synchronize provisioning, report, and other templates between your Foreman server and a version control system or local directory. This helps manage templates in Git repositories or keep them synchronized across Foreman instances.
Enable the plugin on your Foreman server:
Optional: Enable the Hammer CLI plugin on your Foreman server:
On the Plugins tab, ensure that the page includes the foreman_templates plugin.
In the Foreman web UI, navigate to Administer > Settings > Template Sync to configure the plugin. For more information, see Template sync settings.
13.2. Synchronize templates with an existing repository
If you store templates in a repository under a version control system, you can synchronize the templates between your Foreman server and the repository.
If you want to use HTTPS to connect to the repository and you use a self-signed certificate authority (CA) on your Git server:
Create a new directory under the
/usr/share/foreman/directory to store the Git configuration for the certificate:# mkdir --parents /usr/share/foreman/.config/git
Create a file named
configin the new directory:# touch /usr/share/foreman/.config/git/config
Allow the
foremanuser access to the.configdirectory:# chown --recursive foreman /usr/share/foreman/.config
Update the Git global configuration for the
foremanuser with the path to your self-signed CA certificate:# sudo --user foreman git config --global http.sslCAPath Path_To_CA_Certificate
If you want to use SSH to connect to the repository:
Create an SSH key pair if you do not already have it. Do not specify a passphrase.
Configure your version control server with the public key from your Foreman, which resides in
/usr/share/foreman/.ssh/id_rsa.pub. -
Accept the Git SSH host key as the
foremanuser:# sudo --user foreman ssh git.example.com
In the Foreman web UI, provide details for your Git repository:
Navigate to Administer > Settings.
Click the Template Sync tab.
Change the Branch setting to define the target branch of the repository.
Change the Repo setting to define the repository URL.
If you want to use an HTTP proxy to connect to the repository, change the HTTP proxy policy setting to
Global default HTTP proxyorCustom HTTP proxy.
Import templates from your repository or export templates to your repository.
13.3. Synchronize templates with a local directory
If you store templates in a local directory that is tracked under a version control system, you can synchronize the templates between your Foreman server and the local directory.
Each template must contain the location and organization that the template belongs to. This applies to all template types. Before you import a template, ensure that you add the following section to the template:
<%# kind: provision name: My_Provisioning_Template oses: - My_first_Operating_System - My_second_Operating_System locations: - My_first_Location - My_second_Location organizations: - My_first_Organization - My_second_Organization %>
On your Foreman server, in
/var/lib/foreman, create a directory for storing templates:# mkdir /var/lib/foreman/My_Templates_Dir
NoteYou can place your templates to a custom directory outside
/var/lib/foreman, but you have to ensure that theForemanservice can read its contents. The directory must have the correct file permissions and theforeman_lib_tSELinux label. -
Change the owner of the new templates directory to the
foremanuser:# chown foreman /var/lib/foreman/My_Templates_Dir
Change the Repo setting on the Template Sync tab to match the
/var/lib/foreman/My_Templates_Dir/directory.
13.4. Import templates by using Foreman web UI
You can import templates from a repository of your choice from the Foreman web UI.
You can use different protocols to point to your repository, for example /tmp/dir, git://example.com, https://example.com, and ssh://example.com.
The templates provided by Foreman are locked and you cannot import them by default.
To overwrite this behavior, change the |
In the Foreman web UI, navigate to Hosts > Templates > Sync Templates.
Click Import.
Each field is populated with values configured in Administer > Settings > Template Sync. Change the values as required for the templates you want to import. For more information about each field, see Template sync settings.
Click Submit.
13.5. Import templates by using Hammer CLI
You can import templates from a repository of your choice by using Hammer CLI.
Import a template from a repository:
$ hammer import-templates \ --branch "My_Branch" \ --filter '.*Template Name$' \ --organization "My_Organization" \ --prefix "[Custom Index] " \ --repo "https://git.example.com/path/to/repository"
For better indexing and management of your templates, use
--prefixto set a category for your templates. To select certain templates from a large repository, use--filterto define the title of the templates that you want to import. For example--filter '.*Ansible Default$'imports various Ansible Default templates.
13.6. Import templates by using Foreman API
You can import templates from a repository of your choice by using Foreman API.
Send a
POSTrequest toapi/v2/templates/import:$ curl \ --header "Accept: application/json" \ --header "Content-Type: application/json" \ --request POST \ --user "My_User_Name:My_Password" \ https://foreman.example.com/api/v2/templates/import
If the import is successful, you receive
{"message":"Success"}.
13.7. Import templates using Ansible
You can import templates from a repository of your choice.
Use the
theforeman.foreman.templates_importmodule.
13.8. Export templates by using Foreman web UI
You can export templates to an existing repository from the Foreman web UI. This is useful for backing up customized templates and keeping them synchronized with your version control system.
Click Export.
Each field is populated with values configured in Administer > Settings > Template Sync. Change the values as required for the templates you want to export. For more information about each field, see Template sync settings.
Click Submit.
13.9. Export templates by using Hammer CLI
You can export templates to an existing repository by using Hammer CLI. This is useful for backing up customized templates and keeping them synchronized with your version control system.
Export all templates to a repository:
$ hammer export-templates \ --organization "My_Organization" \ --repo "https://git.example.com/path/to/repository"
NoteThis command clones the repository, makes changes in a commit, and pushes back to the repository. You can use the
--branch "My_Branch"option to export the templates to a specific branch.
13.10. Export templates by using Foreman API
You can export templates to an existing repository by using Foreman API. This is useful for backing up customized templates and keeping them synchronized with your version control system.
Send a
POSTrequest toapi/v2/templates/export:$ curl \ --header "Accept: application/json" \ --header "Content-Type: application/json" \ --request POST \ --user "My_User_Name:My_Password" \ https://foreman.example.com/api/v2/templates/export
If the export is successful, you receive
{"message":"Success"}.NoteYou can override default API settings by specifying them in the request with the
-dparameter. The following example exports templates to thegit.example.com/templatesrepository:$ curl \ --data "{\"repo\":\"git.example.com/templates\"}" \ --header "Accept: application/json" \ --header "Content-Type: application/json" \ --request POST \ --user "My_User_Name:My_Password" \ https://foreman.example.com/api/v2/templates/export
13.11. Disable the Templates plugin
Disable the plugin using the Foreman installer:
Clean custom data of the plugin. The command does not affect any templates that you created.
Uninstall the plugin:
14. Monitor Foreman resources
You can use Foreman web UI to monitor your Foreman environment and hosts. This includes details of hosts, such as configuration or compliance, and information about content and Smart Proxies.
14.1. Foreman dashboard
The Foreman dashboard contains various widgets. Use the dashboard to get a quick overview of the resources currently in use in Foreman.
In the Foreman web UI, navigate to Monitor > Dashboard to access the dashboard. The dashboard can be rearranged by clicking on a widget and dragging it to a different position. The following widgets are available:
- Host Configuration Status
Table 8. Host configuration states Icon State Description
Hosts in error state
noopmode.
Out of sync hosts
Hosts with no reports
Hosts with alerts disabled
- Host Configuration Chart
- Latest Events
- New Hosts
- Task Status
- Latest Warning/Error Tasks
- Discovered Hosts
- Latest Errata
- Content Views
- Sync Overview
- Host Collections
A list of all host collections in Foreman and their status, including the number of hosts in each host collection.
virt-whodaemon running on hosts in the environment. The following table shows the possible states.Table 9. virt-who configuration states State Description No Reports
No Change
OK
Total Configurations
- Latest Compliance Reports
- Insights Actions
- Insights Risk Summary
14.2. Track Foreman task progress
You can monitor and manage all planned or performed tasks, such as repositories synchronized, errata applied, and content views published. This is useful to track progress, troubleshoot issues, or adjust timeout settings for low bandwidth or high latency environments.
- Reviewing the log
- Adjusting timeout settings
In the Foreman web UI, navigate to Administer > Settings.
NoteAdjusting the %_finish_timeout values might help in case of low bandwidth. Adjusting the %_accept_timeout values might help in case of high latency.
- Disabling checking for services
Click Save.
14.3. Review audit records of Foreman changes
Audit records list the changes made by all users on Foreman. You can use this information for maintenance and troubleshooting.
In the Foreman web UI, navigate to Monitor > Audits to view the audit records.
Obtain a list of all audit attributes:
14.4. Check Smart Proxy server status
In the Foreman web UI, you can find various information about Smart Proxy server and its services. This information is useful to maintain Smart Proxy server and troubleshoot any issues.
14.4.1. General Smart Proxy information overview
You can view general information about your Smart Proxies in the Foreman web UI, such as their status, enabled features, and managed hosts, to verify configuration or troubleshoot connectivity issues.
In the Foreman web UI, navigate to Infrastructure > Smart Proxies to view a table of Smart Proxy servers registered to Foreman server. The information contained in the table answers the following questions:
- Is Smart Proxy server running?
This is indicated by a green icon in the Status column. A red icon indicates an inactive Smart Proxy, use the
service foreman-proxy restartcommand on Smart Proxy server to activate it. - What services are enabled on Smart Proxy server?
In the Features column, you can verify if, for example, your Smart Proxy provides a DHCP service or acts as a Pulp mirror. Smart Proxy features can be enabled during installation or configured in addition.
- What organizations and locations is Smart Proxy server assigned to?
A Smart Proxy server can be assigned to multiple organizations and locations, but only Smart Proxies belonging to the currently selected organization are displayed. To list all Smart Proxies, select Any Organization from the context menu in the top left corner.
After changing the Smart Proxy configuration, select Refresh from the drop-down menu in the Actions column to ensure the Smart Proxy table is up to date.
Click the Smart Proxy name to view further details. At the Overview tab, you can find the same information as in the Smart Proxy table. In addition, you can answer to the following questions:
- Which hosts are managed by Smart Proxy server?
- How much storage space is available on Smart Proxy server?
/var/lib/pulpis displayed. Also the remaining storage space available on the Smart Proxy can be ascertained.
14.4.2. Monitor Smart Proxy services
You can view the status and configuration details of Smart Proxy services in Foreman web UI. This helps you verify that your Smart Proxy services are running correctly and troubleshoot any issues.
In the Foreman web UI, navigate to Infrastructure > Smart Proxies and click the name of the selected Smart Proxy.
At the Services tab, you can find basic information on Smart Proxy services, such as the list of DNS domains, or the number of Pulp workers.
The appearance of the page depends on what services are enabled on Smart Proxy server. Services providing more detailed status information can have dedicated tabs at the Smart Proxy page. For more information, see Monitor Puppet on Smart Proxy.
14.5. Monitor Puppet on Smart Proxy
You can monitor Puppet activity and certificate management for each Smart Proxy.
The Puppet and Puppet CA tabs are available only if you have Puppet enabled in your Foreman. |
Click the name of your Smart Proxy.
At the Puppet tab you can find the following:
A table of CA certificates associated with the Smart Proxy at the Certificates sub-tab. Here you can inspect the certificate expiry data, or cancel the certificate by clicking Revoke.
15. Limit host resources
You can use the Resource Quota plugin to limit users' access to host resources during host provisioning.
Each host is assigned to exactly one resource quota.
By default, Foreman assigns the Unassigned resource quota to hosts during global registration.
This means that the host is not assigned to a specific pool of resources.
- Supported resource types
CPU cores
Memory
Disk space
- Supported compute resources
VMware
libvirt
15.1. Install the Resource Quota plugin
Install the plugin on your Foreman server:
Optional: Install the Hammer CLI plugin on your Foreman server:
15.2. Manage resource quotas
15.2.1. Create a resource quota by using Foreman web UI
Create a resource quota to limit the resource consumption of Foreman users by using the Foreman web UI.
In the Foreman web UI, navigate to Configure > Resource Quotas.
Click Create resource quota.
Specify the name, CPU cores, memory, and disk space.
Click Create resource quota to submit the resource quota to Foreman.
15.2.2. Create a resource quota by using Hammer CLI
Create a resource quota to limit the resource consumption of Foreman users by using Hammer CLI.
Create a resource quota:
$ hammer resource-quota create \ --cpu-cores My_CPU_Cores \ --description My_Resource_Quota_Description \ --disk-space My_Disk_Space_in_GiB \ --memory My_Memory_in_MiB \ --name "My_Resource_Quota_Name"
For all options, see
hammer resource-quota create --help.
15.2.3. Edit a resource quota by using Foreman web UI
You can edit a resource quota to adjust available resources to Foreman users by using Foreman web UI.
Select your resource quota.
Adjust the CPU cores, Memory, or Disk space and click Apply to submit your changes to Foreman.
15.2.4. Edit a resource quota by using Hammer CLI
You can edit a resource quota to adjust available resources to Foreman users by using Hammer CLI.
Optional: List all resource quotas:
Edit a resource quota:
$ hammer resource-quota update \ --cpu-cores My_CPU_Cores \ --description My_Resource_Quota_Description \ --disk-space My_Disk_Space_in_GiB \ --id My_Resource_Quota_ID \ --memory My_Memory_in_MiB \ --name "My_Resource_Quota_Name"
If you set the value to
0, users cannot consume any resource at all. To reset resource quotas, you can use--remove-cpu-cores-limit,--remove-disk-space-limit, and--remove-memory-limit.For all options, see
hammer resource-quota update --help.
15.2.5. Delete a resource quota by using Foreman web UI
You can delete a resource quota from Foreman by using Foreman web UI.
In the Actions column, click Delete for your resource quota.
15.2.6. Delete a resource quota by using Hammer CLI
You can delete a resource quota from Foreman by using Hammer CLI.
Delete a resource quota:
hammer resource-quota delete --help.
15.3. Assign resource quotas to users
You can assign resource quotas to users or user groups.
A user can select one of their assigned resource quotas during host provisioning.
If Resource Quota optional assignment is set to No, a user does not have to assign a resource quota.
You can use the resource_quota filter in the Foreman web UI to view users or user groups with assigned resource quotas.
15.3.1. Assign resource quotas to a user by using Foreman web UI
You can assign resource quotas to a user to limit the resource consumption of that Foreman user by using Foreman web UI.
Select a user.
On the Resource Quota tab, assign resource quotas to the user.
If you want to make the usage of resource quotas optional, select the Optional Assignment checkbox.
Click Submit to assign resource quotas to a user.
15.3.2. Assign resource quotas to a user by using Hammer CLI
You can assign resource quotas to a user to limit the resource consumption of that Foreman user by using Hammer CLI
Optional: List all Foreman users:
Assign resource quotas to a user:
$ hammer user update \ --id My_User_ID \ --resource-quota-ids My_Resource_Quota_IDs
If you want to make resource quota optional, add the
--resource-quota-is-optional trueoption.For all options, see
hammer user update --help.
15.3.3. Assign resource quotas to a user group by using Foreman web UI
You can assign resource quotas to a user group to limit the resource consumption of that Foreman user group. All users of the user group share the pool of resources.
In the Foreman web UI, navigate to Administer > User Groups.
On the Resource Quota tab, assign resource quotas to the user group.
Click Submit to assign resource quotas to a user group.
15.3.4. Assign resource quotas to a user group by using Hammer CLI
You can assign resource quotas to a user group to limit the resource consumption of that Foreman user group by using Hammer CLI. All users of the user group share the pool of resources.
Optional: List all Foreman user groups:
Assign resource quotas to a user group:
$ hammer user-group update \ --id My_User_Group_ID \ --resource-quota-ids My_Resource_Quota_IDs
hammer user-group update --help.
15.4. View resource quotas by using Foreman web UI
You can use Foreman web UI to view the resource quota of hosts.
In the search bar, filter your hosts. For example,
resource_quota = Unassigned.For more information, see Tips for working in Foreman web UI efficiently.
15.5. View resource quotas by using Hammer CLI
Optional: Retrieve the ID of your host:
$ hammer host list
Display the resource quota assigned to your host:
$ hammer host info \ --fields "Id,Name,Resource quota id" \ --id My_Host_ID
15.6. Resource Quota settings
- Global Resource Quota no action
- Resource Quota optional assignment
16. Use webhooks in Foreman
16.1. Webhook behavior and integration
You can use webhooks as a way to integrate Foreman with external systems. For example, webhooks can integrate with monitoring systems to send alerts when a host is created or deleted.
Because webhooks use HTTP, no new infrastructure needs be added to existing web services. Webhooks are useful where the action you want to perform in the external system can be achieved through its API.
Where it is necessary to run additional commands or edit files, the shellhooks plugin for Smart Proxies is available. The shellhooks plugin enables you to define a shell script on the Smart Proxy that can be executed through the API.
16.2. Install the webhooks plugin
Use the following procedure to install the webhooks plugin. Then, you can configure Foreman server to send webhook requests.
On your Foreman server, install the webhooks plugin:
Optional: Install the webhooks CLI plugin:
16.3. Create a webhook template
Webhook templates are used to generate the body of HTTP request to a configured target when a webhook is triggered. You can create a webhook template in the Foreman web UI.
In the Foreman web UI, navigate to Administer > Webhook > Webhook Templates.
A webhook HTTP payload must be created using Foreman template syntax. The webhook template can use a special variable called
@objectthat can represent the main object of the event.@objectcan be missing in case of certain events. You can determine what data are actually available with the@payloadvariable.For more information, see Template Writing Reference and for available template macros and methods, visit
/templates_docon Foreman server. -
Click Submit.
16.4. Create a webhook
When creating a webhook in the Foreman web UI, you can customize events, payloads, HTTP authentication, content type, and headers.
When configuring webhooks with endpoints with non-standard HTTP or HTTPS ports, an SELinux port must be assigned, see Configure SELinux to ensure access to Foreman on custom ports. |
In the Foreman web UI, navigate to Administer > Webhook > Webhooks.
Click Create new.
Click Template to select a template. Webhook templates are used to generate the body of the HTTP request to Foreman server when a webhook is triggered.
Enter an HTTP method.
Click the Credentials tab.
Optional: Uncheck Verify SSL if you do not want to verify the server certificate against the system certificate store or Foreman CA.
Review the webhook events that are available from the Foreman web UI.
A content view was successfully promoted. |
Run OpenSCAP scan. |
Runs an Ansible Playbook containing all the roles defined for a host. |
Upgrade Smart Proxies on given Smart Proxy servers. |
Run an Ansible Playbook against given hosts. |
Run an Ansible Playbook to enable the web console on given hosts. |
Custom event: |
Custom event: |
Common database operations on a configuration report. |
Common database operations on a content view. |
Custom event: |
16.6. Shellhooks plugin for Smart Proxy
With webhooks, you can only map one Foreman event to one API call. For advanced integrations, where a single shell script can contain multiple commands, you can install a Smart Proxy shellhooks plugin that exposes executables by using a REST HTTP API.
You can then configure a webhook to reach out to a Smart Proxy API to run a predefined shellhook. A shellhook is an executable script that can be written in any language provided that it can be executed. The shellhook can for example contain commands or edit files.
You can pass arguments to shellhook script by using HTTP headers in format X-Shellhook-Arg-1 to X-Shellhook-Arg-99.
The HTTP method must be POST.
An example URL would be: https://smartproxy.example.com:9090/shellhook/My_Script.
Unlike the |
You must enable Smart Proxy Authorization for each webhook connected to a shellhook to enable it to authorize a call.
Standard output and standard error output are redirected to the Smart Proxy logs as messages with debug or warning levels respectively.
16.7. Install the shellhooks plugin
Optionally, you can install and enable the shellhooks plugin on each Smart Proxy used for shellhooks.
Install the shellhooks plugin on your Smart Proxy:
16.8. Pass arguments to shellhook script using webhooks
You can pass dynamic values from a webhook event to a shellhook script by configuring HTTP headers when you create the webhook. This enables your script to use event-specific data such as object IDs or names without parsing the webhook payload.
For more information, see Create a webhook.
16.9. Pass arguments to shellhook script using curl
You can pass custom values to a shellhook script by using a curl request. Use this when you need to test a script manually or call it directly, rather than through webhook automation.
$ curl \ --data "" \ --header "Content-Type: text/plain" \ --header "X-Shellhook-Arg-1: Version 1.0" \ --header "X-Shellhook-Arg-2: My content view" \ --request POST \ --show-error \ --silent \ https://smartproxy.example.com:9090/shellhook/My_Script
16.10. Create a shellhook to print arguments
You have the webhooks and shellhooks plugins installed. For more information, see:
Modify the
/var/lib/foreman-proxy/shellhooks/print_argsscript to print arguments to standard error output so you can see them in the Smart Proxy logs:#!/bin/sh # # Prints all arguments to stderr # echo "$@" >&2 -
Click Create new.
In the Target URL field, enter the URL of your Smart Proxy server followed by
:9090/shellhook/print_args:https://smartproxy.example.com:9090/shellhook/print_args
Note that
On the Credentials tab, check Smart Proxy Authorization.
Click Submit. You now have successfully created a shellhook that prints "Hello World!" to Smart Proxy logs every time you a remote execution job succeeds.
timeas a command. For more information, see Run automated workflows on hosts. -
Verify that the shellhook script was triggered and printed "Hello World!" to Smart Proxy server logs:
17. Tips for working in Foreman web UI efficiently
The Foreman web UI includes search, bookmarking, keyboard shortcuts, and various settings to help you work more efficiently.
17.1. Notable keyboard shortcuts and navigation tips
Use these keyboard shortcuts and techniques to navigate and search more efficiently in the Foreman web UI.
Ctrl + Shift + Ffocuses the vertical navigation search bar-
After pressing this shortcut, you can start typing in the vertical navigation search bar.
/focuses the page search bar-
After pressing this shortcut, you can start typing in the page search bar.
- Saving searches as bookmarks
You can save a search you frequently use as a bookmark. After entering your search query in the search field, click the arrow next to the Search button and select Bookmark this search. You can then give the bookmark a name and choose whether to make it public or private.
To manage all bookmarks, navigate to Administer > Bookmarks.
- Compact table mode
Navigate to the user menu in the top bar and select My account. Under the UI Preferences tab, you can enable compact table mode. With compact table mode enabled, Foreman web UI displays table rows with less space between items.
- Instance title setting
If you have multiple Foreman instances, you can configure Foreman web UI to always show a banner with the instance title in the top bar to help you identify which instance you are currently using. To set an instance title, navigate to Administer > Settings, and edit the Instance title setting on the General tab. To set a color for the instance title banner, edit the Instance color setting.
17.2. Foreman web UI search query reference
Use search query syntax and operators in the Foreman web UI to filter lists of resources on Foreman web UI pages. Parameter-based queries help you find the resources you need faster and more precisely than free-text search in large inventories.
Search queries in the page search bar follow the pattern:
parameter operator value
To search text with whitespaces, enclose it in quotes:
hostgroup = "Web Servers"
Typing without specifying a parameter searches across multiple fields simultaneously, also known as free-text search.
For example, typing 64 in the search bar on the hosts page displays all hosts that have 64 in their name, IP address, MAC address, and architecture.
Free text search is slower and less accurate than parameter-based queries. Use specific parameters whenever possible for better performance and precision. |
The search bar supports multiple date and time formats, including the following:
"10 January 2017"
"10 Jan 2017"
10-January-2017
10/January/2017
"January 10, 2017"
Today, yesterday, and similar keywords
| Operator | Short Name | Description |
EQUALS |
NOT EQUALS |
LIKE |
Accepts text or temporal values. The search is not case-sensitive. Accepts the following wildcards: _ for a single character, % or * for any number of characters including zero. If no wildcard is specified, the string is treated as if surrounded by wildcards: %rhel7% |
NOT LIKE |
GREATER THAN |
LESS THAN |
IN |
NOT IN |
HAS or set? |
NOT HAS or null? |
| Operator | Alternative Notations | ||
and |
<whitespace> |
or |
not |
17.3. Useful search examples
The following examples demonstrate useful ways to filter and find resources in Foreman web UI. Use them as starting points to build your own searches that match your specific needs.
These search examples show how to filter hosts and are based on host attribute search parameters. You can use them on Foreman web UI pages that list hosts, such as Hosts > All Hosts. You can apply the same syntax to filter other resources on other Foreman web UI pages.
- Find hosts by host global status and sub-status
Hosts that have an OK global status:
global_status = ok
Hosts that have an Error or Warning global status:
global_status = error or global_status = warning
Hosts that have at least one pending resource:
status.pending > 0
Hosts that restarted some service during last run:
status.restarted > 0
Hosts that have an interesting last run that might indicate something has happened:
status.interesting = true
- Find hosts that need attention
Hosts with security updates available:
errata_status = security_needed
Hosts that have email notifications for configuration errors enabled and are in a failed state:
status.enabled = true AND status.failed = true
Hosts that have not generated a report recently:
last_report < "7 days ago"
- Find hosts by configuration, environment, or registration date
Hosts in production that belong to a host group whose name includes a variation of the word "webservers":
environment = production AND hostgroup ~ webservers
Hosts registered in the last month:
registered_at > "30 days ago"
Hosts registered between specific dates:
registered_at > 1-January-2026 AND registered_at < 31-January-2026
- Exclude specific results
All hosts except hosts in a host group named "exceptions":
NOT hostgroup = exceptions
Hosts that are not compliant with policies:
compliance_status != compliant
This search query requires the OpenSCAP plugin.
- Use wildcards for flexible matching
Hosts with names that include the strings "web" and "prod":
name ~ web*prod*
Host groups starting with a specific prefix:
hostgroup ~ rhel%
Appendix A: Commands for managing Foreman services
Foreman provides the foreman-maintain service command to manage Foreman services from the command line.
After installing Foreman with the foreman-installer command, all Foreman services are started and enabled automatically.
Appendix B: Log and report problems
Review the most commonly used log files and debugging tools available in Foreman.
B.1. Configure logging type and layout
By default, Foreman uses file-based logging.
You can use foreman-installer to change the logging type and logging layout.
To use the
journaldservice for logging:-
Change the logging type to
journald:# foreman-installer \ --foreman-logging-type journald \ --foreman-proxy-log JOURNAL
Inspect the log messages by using the
To use file-based logging:
Change the logging type to file-based:
# foreman-installer \ --reset-foreman-logging-type \ --reset-foreman-proxy-log
Inspect the log messages by viewing these files:
/var/log/foreman-proxy.log
To use JSON output:
Change the logging layout to JSON:
# foreman-installer \ --foreman-logging-layout json \ --foreman-logging-type file
jq:# cat /var/log/foreman/production.log | jq
B.2. Enable individual loggers for selective debugging
You can enable individual loggers to collect detailed diagnostics for specific Foreman components when you troubleshoot integration or performance issues, without increasing the global logging level.
B.3. Overview of individual loggers
Review selected loggers and their default values.
app-
Default value: true.
audit-
background-
blob-
ImportantThe
bloblogger might contain sensitive data. dynflow-
ldap-
Default value: false.
notifications-
permissions-
sql-
telemetry-
templates-
B.4. Retrieve status of services by using Hammer CLI
Get information from the database and Foreman services:
$ hammer ping
Run
Perform a health check:
Run
B.5. Restart Foreman services
Restart Foreman services:
B.6. Utilities for processing log information
- sosreport
The
sos reportcommand collects configuration and diagnostic information from a Linux system, such as the running kernel version, loaded modules, running services, and system and service configuration files. Additionally, it collects information about Foreman, such as its back-end services and tasks. This output is stored in a tar file located at/var/tmp/sosreport-XXX-20171002230919.tar.xz.For more information, run
sos report --helpor see SOS user documentation.ImportantThe
sos reportcommand removes security information such as passwords, tokens, and keys while collecting information. However, the tar files can still contain sensitive information about the Foreman server. Send the tar files directly to the intended recipient and not to a public target. - foreman-tail
The
foreman-tailcommand displays Foreman logs in real time.For more information, see the
foreman-tail(8)man page.
B.7. Log file directories
The following table provides an overview of selected log directories on Foreman server.
Subscription management |
Installer |
Foreman maintain |
Foreman proxy |
Foreman |
Apache HTTP server |
Various other log messages |
Puppet |
Candlepin web service logs |
B.8. System journal metadata
The journald service uses metadata fields to filter logs.
You can use these fields to filter logs when troubleshooting.
- AUDIT_ACTION
Audit action performed
- AUDIT_TYPE
Audit resource type
- AUDIT_ID
- AUDIT_ATTRIBUTE
- AUDIT_FIELD_OLD
- AUDIT_FIELD_NEW
- AUDIT_ID
- AUDIT_ATTRIBUTE
Example: Name or description
- EXCEPTION_MESSAGE
- EXCEPTION_CLASS
- EXCEPTION_BACKTRACE
- LOC_ID
Location database ID
- LOC_NAME
Location name
- LOC_LABEL
Location label
- LOGGER
Logger name
- ORG_ID
Organization database ID
- ORG_NAME
Organization name
- ORG_LABEL
Organization label
- REMOTE_IP
Remote IP address of a client
- REQUEST
- SESSION
- TEMPLATE_NAME
Template name
- TEMPLATE_DIGEST
- TEMPLATE_HOST_NAME
- TEMPLATE_HOST_ID
- USER_LOGIN
User login name
Appendix C: Increase logging levels of Foreman components
Foreman components use configurable logging levels to record operational events.
Increase the level to debug when you need detailed output to troubleshoot a specific service.
C.1. Increase the logging level for Foreman
Increase Foreman logging to debug to capture detailed Foreman activity when diagnosing application or API issues.
Reset the level when debugging is complete to avoid excessive log volume.
By default, Foreman writes logs to /var/log/foreman/production.log.
For more information, see Configure logging type and layout.
For more information about Foreman logging settings, use # foreman-installer --full-help | grep logging |
Set the logging level to
debug:# foreman-installer --foreman-logging-level debug
C.2. Increase the logging level for Hammer
Increase Hammer logging to debug to capture detailed CLI activity when troubleshooting command-line errors or API responses.
Hammer writes logs to ~/.hammer/log/hammer.log.
In
/etc/hammer/cli_config.yml, set the:log_level:option todebug::log_level: 'debug'
C.3. Increase the logging level for Smart Proxy
Increase Smart Proxy logging to debug to capture detailed Smart Proxy activity when troubleshooting communication between Foreman and hosts.
By default, Smart Proxy writes logs to /var/log/foreman-proxy/proxy.log.
debug:# foreman-installer --foreman-proxy-log-level DEBUG
C.4. Increase the logging level for Candlepin
Increase Candlepin logging to DEBUG when you need detailed subscription and content management diagnostics on your Foreman.
Candlepin writes logs to /var/log/candlepin/candlepin.log and /var/log/candlepin/error.log.
DEBUG:# foreman-installer --katello-candlepin-loggers log4j.logger.org.candlepin:DEBUG
# foreman-installer \ --katello-candlepin-loggers log4j.logger.org.candlepin:DEBUG \ --katello-candlepin-loggers log4j.logger.org.candlepin.resource.ConsumerResource:WARN \ --katello-candlepin-loggers log4j.logger.org.candlepin.resource.HypervisorResource:WARN
C.5. Increase the logging level for Redis
Increase Redis logging to debug to capture detailed cache activity when troubleshooting performance or connectivity issues.
Redis writes logs to /var/log/redis/redis.log.
In
/etc/redis/redis.conf, set the logging level todebug:loglevel debug -
Restart the Redis service:
# systemctl restart redis
NoteRunning
foreman-installerwill revert the setting to default.
C.6. Increase the logging level for foreman-installer
Increase foreman-installer verbose output to debug when you need detailed installation and configuration diagnostics during setup or upgrades.
Increase the logging level of the
foreman-installerutility:# foreman-installer --verbose-log-level debug
C.7. Increase the logging level for Pulp
Increase Pulp logging to DEBUG when you need detailed content repository diagnostics.
Pulp writes logs to the systemd journal.
You can view them with journalctl --unit 'pulpcore*'.
In
/etc/pulp/settings.py, set the logging level toDEBUG:LOGGING = {"dynaconf_merge": True, "loggers": {'': {'handlers': ['console'], 'level': 'DEBUG'}}} -
Restart the Pulp services:
# systemctl restart \ pulpcore-api \ pulpcore-content \ pulpcore-resource-manager \ pulpcore-worker@\*
NoteRunning
C.8. Increase the logging level for OpenVox agent
Increase OpenVox agent logging to debug when you need detailed configuration application diagnostics on hosts.
OpenVox agent writes logs to /var/log/puppetlabs/puppet/.
You have enabled Puppet on your Foreman. For more information, see Enable Puppet integration with Foreman.
debug:# foreman-installer --puppet-agent-additional-settings log_level:debug
C.9. Increase the logging level for OpenVox server
Increase OpenVox server logging to debug when you need detailed catalog compilation and agent communication diagnostics.
OpenVox server writes logs to /var/log/puppetlabs/puppetserver/.
debug:# foreman-installer --puppet-server-additional-settings log_level:debug
C.10. Increase the logging level for Salt
Increase Salt Master or Minion logging to debug when you need detailed remote execution or state application diagnostics.
Salt Master writes logs to /var/log/salt/master and Salt Minions write logs to /var/log/salt/minion.
In
/etc/salt/masteror/etc/salt/minion, set the logging level todebug:log_level: debug
Appendix D: Anonymize audit records
Use the
foreman-rake audits:anonymizecommand to remove any user account or IP information while maintaining the audit records in the database. You can also use a cron job to schedule anonymizing the audit records at the set interval that you want.By default, using the
foreman-rake audits:anonymizecommand anonymizes audit records that are older than 90 days. You can specify the number of days to keep the audit records by adding the days option and add the number of days.For example, you can anonymize audit records that are older than seven days:
Appendix E: Administration settings information
In the Foreman web UI, you can edit various settings to configure Foreman. You can find these settings by navigating to Administer > Settings.
E.1. General settings information
The general settings define system-wide configuration options for Foreman, including administrator email, instance URL, user interface preferences, HTTP proxy settings, and default language and time zone.
Administrator email address |
Foreman URL |
URL where your Foreman instance is reachable. See also Provisioning > Unattended URL. |
Entries per page |
20 |
Number of records shown per page in Foreman |
Fix DB cache |
No |
Foreman maintains a cache of permissions and roles.
When set to |
DB pending seed |
No |
Should the |
Smart Proxy request timeout |
60 |
Open and read timeout for HTTP requests from Foreman to Smart Proxy (in seconds). |
Login page footer text |
HTTP(S) proxy |
Set a proxy for outgoing HTTP(S) connections from the Foreman product. System-wide proxies must be configured at the operating system level. |
HTTP(S) proxy except hosts |
Show Experimental Labs |
No |
Display FQDN for hosts |
Yes |
If set to |
Out of sync interval |
30 |
Hosts report periodically, and if the time between reports exceeds this duration in minutes, hosts are considered out of sync.
Foreman UUID |
Foreman instance ID. Uniquely identifies a Foreman instance. |
Default language |
Default timezone |
The time zone to use for new users. |
Instance title |
Saved audits interval |
New host details UI |
Yes |
Foreman loads the new UI for host details. |
Report auto gzip threshold (MiB) |
256 |
Report results above this size (in MiB) are automatically compressed with gzip before storage. Set to 0 to always compress. The maximum value is 512. |
E.2. Background tasks settings
The tasks settings define how Foreman manages background tasks, including timeouts, retry behavior, batch processing, and debugging options for the Dynflow console.
Sync task timeout |
120 |
Enable dynflow console |
Yes |
Enable the Dynflow console ( |
Yes |
The user must be authenticated as having administrative rights before accessing the Dynflow console. |
Proxy action retry count |
4 |
Number of attempts permitted to start a task on the Smart Proxy before failing. |
Proxy action retry interval |
15 |
Allow proxy batch tasks |
Yes |
Allow triggering tasks on the Smart Proxy in batches. |
Proxy tasks batch size |
100 |
Number of tasks included in one request to the Smart Proxy if |
Tasks troubleshooting URL |
It should contain a |
1 |
E.3. Template sync settings
The template sync settings define how Foreman synchronizes templates with Git repositories, including import and export behavior, filtering, locking, and metadata handling.
Associate |
New |
Associate templates with operating system, organization, and location. |
Branch |
Default branch in Git repo. |
Commit message |
Templates export made by a Foreman user |
Dirname |
Filter |
Force import |
No |
If set to |
HTTP proxy policy |
Global default HTTP proxy |
Whether to use an HTTP proxy to synchronize templates. The |
Lock templates |
Keep, do not lock new |
Metadata export mode |
Refresh |
Negate |
No |
Prefix |
Repo |
When exporting to |
Verbosity |
No |
E.4. Host Discovery settings
The Discovery settings define how Foreman handles discovered hosts, including default organization and location assignment, hostname generation, auto-provisioning behavior, and fact organization.
Discovery location |
Discovery organization |
Interface fact |
discovery_bootif |
Create bond interfaces |
No |
Clean all facts |
No |
Hostname facts |
discovery_bootif |
Auto provisioning |
No |
Reboot |
Yes |
Hostname prefix |
mac |
Fact columns |
Highlighted facts |
Storage facts |
Software facts |
Hardware facts |
Network facts |
IPMI facts |
Lock PXE |
No |
pxelinux_discovery |
pxegrub2_discovery |
Force DNS |
Yes |
Error on existing NIC |
No |
Do not permit to discover an existing host matching the MAC of a provisioning Network Interface Card (NIC) (errors out early). |
Type of name generator |
Fact + prefix |
Prefer IPv6 |
No |
E.5. Boot disk settings
iPXE directory |
ISOLINUX directory |
SYSLINUX directory |
Grub2 directory |
Host image template |
Boot disk iPXE - host |
Generic image template |
ISO generation command |
genisoimage |
Installation media caching |
Yes |
Allowed bootdisk types |
E.6. Content management settings
The content settings define how Foreman manages content repositories, subscriptions, content views, and host registration, including default templates, download policies, and synchronization behavior.
Default HTTP Proxy |
Kickstart default |
Kickstart default finish |
Default synced OS user-data |
Kickstart default user data |
Kickstart default PXELinux |
Kickstart default PXEGrub2 |
Kickstart default iPXE |
Kickstart default |
Discovery Foreman community kexec |
Atomic Kickstart default |
Manifest refresh timeout |
1200 |
Yes |
Can communicate with the Foreman community Portal for subscriptions. |
No |
Calculate errata host status based only on errata in a host’s content view and lifecycle environment. |
No |
Yes |
100 |
How many repositories should be synced concurrently on a Smart Proxy. A smaller number may lead to longer sync times. A larger number will increase dynflow load. |
Sync Smart Proxies after Content View promotion |
Yes |
Whether or not to auto sync Smart Proxies after a content view promotion. |
Either |
Default Foreman community Repository download policy |
Default download policy for enabled Foreman community repositories.
Either |
Default Smart Proxy download policy |
Default download policy for Smart Proxy syncs.
Either |
Pulp client key |
Pulp client cert |
Sync Connection Timeout |
300 |
Delete Host upon unregister |
No |
No |
If this is enabled, and |
Default Location |
Expire soon days |
120 |
No |
Host Duplicate DMI UUIDs |
Host Profile Assume |
Yes |
Enable new host registrations to assume registered profiles with matching hostname if the registering DMI UUID is not used by another host. |
No |
Enable host registrations to bypass Host Profile Assume if the host is in build mode. |
No |
5 |
Applicability Batch Size |
50 |
Autosearch |
Yes |
Autosearch delay |
500 |
Pulp bulk load size |
2000 |
Yes |
1440 |
No |
Yes |
Enable removal of repositories that the user has previously published in one or more content view versions. |
E.7. User authentication settings
The authentication settings define how Foreman handles user authentication and authorization, including OAuth configuration, SSL certificates, login delegation, idle timeouts, and OpenID Connect integration.
OAuth active |
Yes |
Foreman will use OAuth for API authorization. This setting is for internal Foreman use only. Foreman community does not support using it to configure OAuth authentication for API calls. |
OAuth consumer key |
OAuth consumer key. This setting is for internal Foreman use only. Foreman community does not support using it to configure OAuth authentication for API calls. |
OAuth consumer secret |
OAuth consumer secret. This setting is for internal Foreman use only. Foreman community does not support using it to configure OAuth authentication for API calls. |
OAuth map users |
No |
Foreman maps users by username in the request-header. If this is disabled, OAuth requests have administrator rights. This setting is for internal Foreman use only. Foreman community does not support using it to configure OAuth authentication for API calls. |
Failed login attempts limit |
30 |
Foreman blocks user logins from an incoming IP address for 5 minutes after the specified number of failed login attempts. Set to 0 to disable brute force protection. |
Restrict registered Smart Proxies |
Yes |
Only known Smart Proxies can access features that use Smart Proxy authentication. |
Trusted hosts |
List of hostnames, IPv4, IPv6 addresses or subnets to be trusted in addition to Smart Proxies for access to fact/report importers and ENC output. |
SSL certificate |
SSL Certificate path that Foreman uses to communicate with its proxies. |
SSL CA file |
SSL CA file path that Foreman uses to communicate with its proxies. |
SSL private key |
SSL Private Key path that Foreman uses to communicate with its proxies. |
SSL client DN env |
HTTP_SSL_CLIENT_S_DN |
SSL client verify env |
HTTP_SSL_CLIENT_VERIFY |
SSL client cert env |
HTTP_SSL_CLIENT_CERT |
Server CA file |
SSL CA file path used in templates to verify the connection to Foreman. |
Websockets SSL key |
Private key file path that Foreman uses to encrypt websockets. |
Websockets SSL certificate |
Certificate path that Foreman uses to encrypt websockets. |
Websockets encryption |
Yes |
Login delegation logout URL |
External |
Authorize login delegation |
No |
No |
Idle timeout |
60 |
BCrypt password cost |
9 |
BMC credentials access |
Yes |
OIDC JWKs URL |
Typically |
OIDC Audience |
OIDC Issuer |
OIDC Algorithm |
E.8. Email notification settings
The email settings define how Foreman sends email notifications, including delivery method, SMTP configuration, reply addresses, and welcome email options.
The Use an SMTP service instead. For the most recent list of major functionality that has been deprecated or removed within Foreman, refer to the Deprecated features section of the Foreman release notes. |
Email reply address |
Email reply address for emails that Foreman is sending. |
Email subject prefix |
Send welcome email |
No |
Delivery method |
Sendmail |
SMTP enable StartTLS auto |
Yes |
SMTP OpenSSL verify mode |
Default verification mode |
SMTP address |
SMTP address to connect to. |
SMTP port |
25 |
SMTP port to connect to. |
SMTP HELO/EHLO domain |
HELO/EHLO domain. |
SMTP username |
SMTP password |
SMTP authentication |
none |
Sendmail arguments |
-i |
Sendmail location |
E.9. RSS notifications settings
The notifications settings define how Foreman retrieves and displays RSS notifications from external feeds.
RSS enable |
Yes |
Pull RSS notifications. |
RSS URL |
E.10. Host provisioning settings
The provisioning settings define how Foreman provisions hosts, including default passwords, template rendering, PXE boot configuration, hostname generation, and virtual machine management.
Host owner |
Default owner on provisioned hosts, if empty Foreman uses the current user. |
Root password |
Unattended URL |
Safemode rendering |
No |
Query local nameservers |
No |
Foreman queries the locally configured resolver instead of the SOA/NS authorities. |
Installation token lifetime |
360 |
SSH timeout |
120 |
0.0.0.0 |
No |
Foreman updates the host IP with the IP that made the build request. |
Use short name for VMs |
No |
Foreman uses the short hostname instead of the FQDN for creating new virtual machines. |
DNS timeout |
[5, 10, 15, 20] |
Clean up failed deployment |
Yes |
Foreman deletes the virtual machine if the provisioning script ends with a non-zero exit code. |
iPXE intermediate script |
No |
Destroy associated VM on host delete. When enabled, VMs linked to hosts are deleted on Compute Resource. When disabled, VMs are unlinked when the host is deleted, meaning they remain on Compute Resource and can be re-associated or imported back to Foreman again. This does not automatically power off the VM |
Maximum structured facts |
100 |
Global Registration |
CoreOS Transpiler Command |
PXEGrub2 global default |
PXELinux global default |
iPXE global default |
PXEGrub2 default local boot |
PXELinux default local boot |
Local boot iPXE template |
iPXE default local boot |
Manage PuppetCA |
Yes |
Foreman automates certificate signing upon provision of a new host. |
Use UUID for certificates |
No |
Foreman uses random UUIDs for certificate signing instead of hostnames. |
E.11. Host facts settings
The facts settings define how Foreman processes and uses facts reported by hosts, including automatic host creation, location and organization assignment, interface updates, and fact filtering.
Yes |
Foreman creates the host when new facts are received. |
Location fact |
foreman_location |
Organization fact |
foreman_organization |
Default location |
Default Location |
Default organization |
Default Organization |
Update hostgroup from facts |
Yes |
Foreman updates a host’s hostgroup from its facts. |
No |
Ignore facts for domain |
No |
Update subnets from facts |
None |
Foreman updates a host’s subnet from its facts. |
No |
Exclude pattern for facts stored in Foreman |
Those facts are not stored in the foreman database.
Default Puppet environment |
production |
Foreman defaults to this puppet environment if it cannot auto detect one. |
ENC environment |
Yes |
Foreman explicitly sets the puppet environment in the ENC yaml output.
No |
Foreman updates a host’s environment from its facts. |
E.12. Configuration management settings
The configuration management settings define how Foreman integrates with configuration management tools, including automatic host creation from reports, smart class parameter evaluation, and configuration status tracking.
Yes |
Foreman creates the host when a report is received. |
Matchers inheritance |
Yes |
Foreman matchers are inherited by children when evaluating smart class parameters for hostgroups, organizations, and locations. |
Foreman evaluates host smart class parameters in this order by default. |
Yes |
Foreman parses ERB in parameters value in the ENC output. |
No |
All hosts show a configuration status even when a Puppet Smart Proxy is not assigned. |
Puppet interval |
35 |
Puppet out of sync disabled |
No |
E.13. Remote execution settings
The remote execution settings define how Foreman executes commands and scripts on remote hosts, including SSH configuration, user management, Smart Proxy selection, and job template synchronization.
Fallback to Any Proxy |
No |
Enable Global Proxy |
Yes |
SSH User |
root |
Default user to use for SSH.
Effective User |
root |
Effective User Method |
sudo |
One of [ |
Effective user password |
Sync Job Templates |
Yes |
SSH Port |
22 |
Default port 22.
Connect by IP |
No |
Prefer IPv6 over IPv4 |
No |
Default SSH password |
Default SSH key passphrase |
Workers pool size |
5 |
Restart of the |
Cleanup working directories |
Yes |
Cockpit URL |
Form Job Template |
Run Command - Script Default |
Time to pickup |
86400 |
Time in seconds within which the host has to pick up a job. If the job is not picked up within this limit, the job will be canceled. Applies only to pull-mqtt based jobs. Defaults to one day. |
E.14. Ansible integration settings
The Ansible settings define how Foreman integrates with Ansible for configuration management, including connection types, verbosity levels, timeout values, and role import behavior.
Private Key Path |
Override with the |
Connection type |
ssh |
Use this connection type by default when running Ansible Playbooks.
WinRM cert Validation |
validate |
Enable or disable WinRM server certificate validation when running Ansible Playbooks.
Default verbosity level |
Disabled |
Foreman adds this level of verbosity for additional debugging output when running Ansible Playbooks. |
Post-provision timeout |
360 |
Timeout (in seconds) to set when Foreman triggers an Ansible roles task playbook after a host is fully provisioned. Set this to the maximum time you expect a host to take until it is ready after a reboot. |
Ansible report timeout |
30 |
No |
Ansible - Ansible Inventory |
Foreman uses this template to schedule the report with Ansible inventory. |
Ansible roles to ignore |
The roles to exclude when importing roles from Smart Proxy.
For example: |
Number of tasks which should be sent to the Smart Proxy in one request if |
