1. Foreman use cases
Foreman is a centralized tool for provisioning, content delivery, remote management, and monitoring of multiple Enterprise Linux deployments. With Foreman, you can deploy, configure, and maintain your systems across physical, virtual, and cloud environments.
Foreman is now containerized, which represents a significant architectural change. Some features described below are currently unavailable. They require adaptation for containerized environments before they can be made available again. |
Foreman helps you provision hosts, manage patches and content, and strengthen security across physical, virtual, and cloud environments. You can also benefit from AI-powered assistance by deploying the Model Context Protocol (MCP) server for Foreman, which enables you to interact with your infrastructure using natural language.
Foreman focuses on the following use cases:
- Provisioning
Deploy consistently configured hosts on bare metal, virtual machines, and cloud instances from a unified interface.
Foreman automates key stages of the deployment lifecycle, including network configuration, operating system installation, and post-installation tasks. For example, you can define templates, partition layouts, and available software to achieve flexibility in how you deploy hosts.
This approach helps reduce deployment time, standardize the provisioning process, and support scaling of your infrastructure.
- Patch management and content distribution
Apply updates to hosts in a consistent, scalable, and repeatable manner. Import, organize, and distribute content to hosts.
NoteIn the context of Foreman, content is defined as the software installed on hosts. For example, you can use Foreman to distribute a broad range of content ranging from packages and errata to container images, Ansible content, and custom file types.
Foreman enables you to import, organize, and distribute content to hosts while staying in control of which versions of content reaches which hosts and when. For example, you can schedule maintenance windows, test updates in staging environments, and roll out patches across your infrastructure with controlled deployment strategies.
This approach provides enhanced control over what software runs in your environment and reduces the manual effort required to keep hosts up to date.
- Security management
Reduce the effort required to secure hosts at scale.
Foreman helps you enforce security policies, scan for vulnerabilities, and remediate compliance violations across your infrastructure. For example, you can integrate Foreman with security scanning tools, track compliance against security baselines, and set up procedures to help ensure hosts meet regulatory requirements.
This capability enables centralized security oversight, supports incident response, and helps reduce the attack surface of your hosts.
- Knowledge and analytics
Identify potential issues and gain a comprehensive view of your infrastructure.
Foreman collects data from hosts, generates reports on system status and trends, and provides dashboards that visualize infrastructure health. For example, you can monitor resource utilization, track configuration changes, and identify patterns.
This knowledge helps you make informed decisions about your infrastructure and spot potential problems.
- Configuration management
Apply configurations to hosts in a consistent and repeatable manner.
Foreman integrates with configuration management tools to define desired state, enforce policies, and remediate drift across your infrastructure. For example, you can manage configurations as code, version control your infrastructure definitions, and automate updates to help keep hosts compliant with organizational standards.
This approach reduces the risk of manual configuration errors and helps maintain consistency across your hosts.
2. Supported client architectures
Verify that your client architectures are supported before deploying Foreman.
2.1. Foreman operating system
You can deploy Foreman on the supported operating systems listed below.
Enterprise Linux 9 (x86_64)
Enterprise Linux 10 (x86_64)
2.2. Client operating systems
Amazon Linux
Debian
Enterprise Linux 10, 9, and 8
Fedora
openSUSE/SUSE Linux Enterprise Server
Ubuntu
Ansible
OpenSCAP
OpenSSH
Puppet
Salt
Windows Remote Management (WinRM)
Operating system installers that can perform unattended installations, such as Anaconda or Debian-installer
Katello host tools
Subscription Manager
Tracer utility
3. Security hardening features in Foreman
Foreman supports multiple security mechanisms for additional layers of protection. Understanding these capabilities helps you evaluate how Foreman can support the security requirements of your organization.
You can use the following security capabilities in Foreman to enhance the security of your deployment:
- Federal Information Processing Standards (FIPS) Mode
If your Enterprise Linux operating systems supports FIPS, you can install Foreman server and Smart Proxy server on a FIPS-enabled host. Note that Foreman itself is not FIPS-certified.
NoteForeman supports DEFAULT and FIPS crypto-policies. The FUTURE crypto-policy is not supported for Foreman server and Smart Proxy server installations.
If you want to run Foreman server or Smart Proxy server on a FIPS-enabled host, FIPS must be enabled on the host before installing. You cannot enable FIPS mode on Foreman server or Smart Proxy server after installation.
NoteIf you manage FIPS-enabled hosts, you must also run Foreman server and Smart Proxy servers in FIPS mode. If the server does not run in FIPS mode in this situation, you might experience unexpected behavior. For example, the hosts might not be able to run remote execution jobs from the server.
- File Access Policy Daemon (
fapolicyd) -
Foreman server and Smart Proxy servers can run on hosts that have the
fapolicydservice enabled.The
fapolicyddaemon helps prevent unauthorized code execution and enhances system integrity by enforcing file access policies.You can enable or disable
fapolicydon your Foreman server and Smart Proxy servers at any time. - Post-Quantum Cryptography (PQC)
Foreman can synchronize and distribute Red Hat Enterprise Linux 10 content signed with the Module-Lattice-Based Digital Signature Standard (ML-DSA). ML-DSA is a quantum-resistant cryptographic signature algorithm designed to protect content integrity against potential attacks from quantum computers.
Foreman community does not currently support full PQC compatibility for Foreman.
- Security-Enhanced Linux (SELinux)
Foreman server and Smart Proxy servers must be run on hosts with SELinux enabled.
The SELinux collection of security modules enforces policies that define which processes can access specific system resources, providing protection against unauthorized access and exploitation.
To maintain a high-security environment, Foreman community recommends running Foreman with SELinux in enforcing mode. This ensures that access control policies are strictly enforced and minimizes the risk of privilege escalation or unauthorized actions.
In addition to these security capabilities, regularly updating security policies and configurations, as well as monitoring system logs, can help detect and respond to potential threats effectively on both Foreman server and Smart Proxy server.
Switching RHEL to FIPS mode in Red Hat Enterprise Linux 9 Security hardening
Using system-wide cryptographic policies in Red Hat Enterprise Linux 9 Security hardening
Switching RHEL to FIPS mode in Red Hat Enterprise Linux 10 Security hardening
Using system-wide cryptographic policies in Red Hat Enterprise Linux 10 Security hardening
4. Networking considerations in Foreman
For the components of Foreman architecture to communicate, the required network ports must be open to enable incoming and outgoing traffic between the components. Identify firewall port and networking requirements to ensure Foreman components can communicate properly.
4.1. Smart Proxy server networking
The communication between Foreman server and hosts registered to a Smart Proxy server is routed through that Smart Proxy server. Smart Proxy server also provides Foreman services to hosts.
In a topology with hosts connecting to a Smart Proxy server, Smart Proxy server provides a single endpoint for all host network communications so that in remote network segments, only firewall ports to the Smart Proxy server itself must be open. Hosts do not need direct access to Foreman server.
In a topology with hosts connecting directly to Foreman server, hosts need direct network access to Foreman server. This applies to all Smart Proxy servers because they are hosts of Foreman server.
4.2. Foreman server port and firewall requirements
The following tables indicate the destination port and the direction of incoming and outgoing traffic for Foreman server.
| Destination Port | Protocol | Service | Source | Required For | Description |
443 |
TCP |
HTTPS |
Smart Proxy |
Foreman API |
Communication from Smart Proxy |
443 |
TCP |
HTTPS |
Client |
Global Registration |
Registering hosts to Foreman Port 443 is required for sending installed packages and traces, registration initiation, and uploading facts. |
443 |
TCP |
HTTPS |
Foreman |
Content Mirroring |
Management |
443 |
TCP |
HTTPS |
Foreman |
Smart Proxy API |
Smart Proxy functionality |
443, 80 |
TCP |
HTTPS, HTTP |
Smart Proxy |
Content Retrieval |
Content |
443, 80 |
TCP |
HTTPS, HTTP |
Client |
Content Retrieval |
Content |
5910 – 5930 |
TCP |
HTTPS |
Browsers |
Compute Resource’s virtual console |
8443 |
TCP |
HTTPS |
Foreman |
Smart Proxy API |
8443 |
TCP |
HTTPS |
Client |
Pull based REX (optional) |
Hosts for REX job notification (optional) |
9191 |
TCP |
HTTPS |
Client |
Salt (optional) |
Salt API |
| Destination Port | Protocol | Service | Destination | Required For | Description |
22 |
TCP |
SSH |
Target host |
Remote execution |
Run jobs |
22, 16514 |
TCP |
SSH SSH/TLS |
Compute Resource |
Foreman originated communications, for compute resources in libvirt |
80 |
TCP |
HTTP |
Remote repository |
Content Sync |
Remote repositories |
389, 636 |
TCP |
LDAP, LDAPS |
External LDAP Server |
LDAP |
LDAP authentication, necessary only if external authentication is enabled.
The port can be customized if |
443 |
TCP |
HTTPS |
Smart Proxy |
Content mirroring |
Initiation |
623 |
Client |
Power management |
BMC On/Off/Cycle/Status |
5000 |
TCP |
HTTPS |
OpenStack Compute Resource |
Compute resources |
Virtual machine interactions (query/create/destroy) (optional) |
5900 – 5930 |
TCP |
SSL/TLS |
Hypervisor |
noVNC console |
Launch noVNC console |
5985 |
TCP |
HTTP |
Client |
WinRM |
Configure Client running Windows |
5986 |
TCP |
HTTPS |
Client |
WinRM |
9090 |
TCP |
HTTPS |
Client |
Discovery |
Smart Proxy sends reboot command to the discovered host (optional) |
8443 |
TCP |
HTTPS |
Smart Proxy |
Smart Proxy API |
Management of Smart Proxies |
4.3. Smart Proxy port and firewall requirements
The following tables indicate the destination port and the direction of incoming and outgoing traffic for Smart Proxy servers.
53 |
TCP and UDP |
DNS |
DNS Servers and clients |
Name resolution |
DNS (optional) |
67 |
UDP |
DHCP |
Client |
Dynamic IP |
DHCP (optional) |
69 |
UDP |
TFTP |
Client |
TFTP Server (optional) |
443, 80 |
TCP |
HTTPS, HTTP |
Client |
Content Retrieval |
Content |
443 |
TCP |
HTTPS |
Foreman |
Content Mirroring |
Management |
443 |
TCP |
HTTPS |
Foreman |
Smart Proxy API |
443 |
TCP |
HTTPS |
Client |
Host registration |
Initiation Uploading facts Sending installed packages and traces |
8443 |
TCP |
HTTPS |
Client |
Host registration |
Deprecated and only needed for Client hosts deployed before upgrades |
9090 |
TCP |
HTTPS |
Client |
Host registration |
8443 |
TCP |
HTTPS |
Foreman |
Smart Proxy API |
8443 |
TCP |
HTTPS |
Client |
Register Endpoint |
Client registration with Smart Proxy servers |
8443 |
TCP |
HTTPS |
Client |
22 |
TCP |
SSH |
Target host |
Remote execution |
Run jobs (optional) |
53 |
TCP and UDP |
DNS |
DNS Servers on the internet |
DNS Server |
Resolve DNS records (optional) |
53 |
TCP and UDP |
DNS |
DNS Server |
Smart Proxy DNS |
Validation of DNS conflicts (optional) |
68 |
UDP |
DHCP |
Client |
Dynamic IP |
DHCP (optional) |
443 |
TCP |
HTTPS |
Foreman |
Smart Proxy |
Smart Proxy Configuration management Remote execution result upload |
443 |
TCP |
HTTPS |
Foreman |
Content |
Sync |
443 |
TCP |
HTTPS |
Foreman |
Client communication |
Forward requests from Client to Foreman |
5. Deployment path for Foreman
5.1. Foreman server installation overview
Installing an instance of Foreman server on a dedicated server is the first step to a working Foreman infrastructure.
A default Foreman server installation includes installing PostgreSQL databases on the server. However, you can configure your Foreman server to use external databases instead. Moving to external databases distributes the workload and can reduce overall Foreman memory usage.
Frequent remote execution tasks. This requires a high volume of records in PostgreSQL and generates heavy database workloads.
High disk I/O workloads from frequent repository synchronization or content view publishing. This requires Foreman to create a record in PostgreSQL for each job.
High volume of hosts.
High volume of synchronized content.
5.2. External authentication methods available in Foreman
Foreman includes native support for authentication with a username and password. If you require additional methods of authentication, configure your Foreman server to use an external authentication source.
| Username and password | Single sign-on (SSO) | One-time password (OTP) | Time-based one-time password (TOTP) | PIV cards | |
FreeIPA |
Yes (Linux and Active Directory users) |
Yes (Linux users only) |
No |
No |
No |
LDAP |
Yes |
No |
No |
No |
No |
5.3. Organization and location planning and assignment
Organizations and locations enable you to arrange Foreman resources into logically structured groups. For example, you can create groups based on ownership, purpose, content, or security level. You can create and manage multiple organizations through Foreman, then divide and assign subscriptions to each individual organization.
- Organizations
Organizations can represent different business units, departments, or teams, such as Finance, Marketing, or Web Development. To manage Red Hat content, each organization requires a separate Red Hat subscription manifest.
- Locations
You can use locations to map the network infrastructure to prevent incorrect host placement or configuration. While you cannot assign a subnet, domain, or compute resources directly to a Smart Proxy server, you can assign them to a location.
Foreman server defines all locations and organizations. Each Smart Proxy server synchronizes content and handles configuration of hosts in a different location.
Your Foreman server retains the management function, while the content and configuration is synchronized between your Foreman server and Smart Proxy servers assigned to certain locations.
If you use host groups to bundle provisioning and configuration information, avoid mismatching resources from mutually exclusive contexts. For example, setting a subnet from one organization or location and a compute resource from a different organization or location creates an invalid host group. |
The system administrator creates the following organizations on their Foreman server:
Finance
Marketing
Sales
Additionally, the administrator creates the following locations on their Foreman server:
United States
United Kingdom
Japan
Boston
Phoenix
San Francisco
5.4. Smart Proxy servers installation overview
By installing Smart Proxy servers, you extend the reach and scalability of your Foreman deployment. You register each Smart Proxy server to Foreman server and configure it to provide the required services within your Foreman deployment.
You can install a Smart Proxy server in each of your geographic locations. By assigning a Smart Proxy to each location, you decrease the load on Foreman server, increase redundancy, and reduce bandwidth usage.
The maximum number of Smart Proxy servers that Foreman server can support has no fixed limit. It was tested that a Foreman server can support 17 Smart Proxy servers with 2 vCPUs. |
Decide what services you want to enable on each Smart Proxy server. You can configure the DNS, DHCP, and TFTP services on one of your Smart Proxy servers or you can use an external server to provide these services to your Smart Proxy servers.
5.5. Content library and content access strategy
To ensure that your Foreman can manage software and provide it to your hosts, you create repositories and synchronize them. You can also define which hosts can access which content and content versions.
Your Foreman content library can include various types of content. Creating repositories allows you to choose the specific software required for your environment. By creating only the necessary repositories, you avoid downloading unnecessary content.
Synchronizing repositories downloads the content from Canonical, Oracle, Red Hat, SUSE, or other sources to your Foreman server. The synchronized content is stored on your Foreman server, eliminating the need for hosts to access the repositories. You can synchronize repositories manually, or you can create a sync plan to ensure synchronization runs on a regular basis.
By default, Foreman includes the Default Organization View content view and the Library lifecycle environment.
- Default Organization View
The Default Organization View is the default content view in Foreman that contains all the content that is synchronized to Foreman. After you update your content, such as by adding or removing a repository, the update is immediately reflected in Default Organization View.
- Library
The Library lifecycle environment is the default lifecycle environment in Foreman. Every newly published content view version is automatically published to the Library lifecycle environment. You can also promote specific content view versions to the Library lifecycle environment if needed.
5.6. Role-based access control policies
One of the predefined roles is the Default role. Foreman assigns the Default role to every user in the system. By default, the Default role grants only a limited set of permissions. Be aware that if you add a permission to the Default role, every Foreman users will gain that permission. Assigning a different role to a user does not remove the Default role from the user. |
- Roles related to applications or parts of infrastructure
- Roles related to a particular stage of the software lifecycle
- Roles related to specific tasks
