1. Accessing orcharhino
After orcharhino has been installed and configured, use the orcharhino management UI interface to log in to orcharhino for further configuration.
1.1. Importing the Katello Root CA Certificate
The first time you log in to orcharhino, you might see a warning informing you that you are using the default self-signed certificate and you might not be able to connect this browser to orcharhino until the root CA certificate is imported in the browser. Use the following procedure to locate the root CA certificate on orcharhino and to import it into your browser.
To use the CLI instead of the orcharhino management UI, see CLI Procedure.
Your orcharhino is installed and configured.
Identify the fully qualified domain name of your orcharhino Server:
# hostname -f
Access the
pubdirectory on your orcharhino Server using a web browser pointed to the fully qualified domain name:https://orcharhino.example.com/pub
When you access orcharhino for the first time, an untrusted connection warning displays in your web browser. Accept the self-signed certificate and add the orcharhino URL as a security exception to override the settings. This procedure might differ depending on the browser being used. Ensure that the orcharhino URL is valid before you accept the security exception.
Select
katello-server-ca.crt. -
Import the certificate into your browser as a certificate authority and trust it to identify websites.
From the orcharhino CLI, copy the
katello-server-ca.crtfile to the machine you use to access the orcharhino management UI:# scp /var/www/html/pub/katello-server-ca.crt username@hostname:remotefile
In the browser, import the
katello-server-ca.crtcertificate as a certificate authority and trust it to identify websites.
1.2. Logging in to orcharhino
Use the web user interface to log in to orcharhino for further configuration.
Ensure that the Katello root CA certificate is installed in your browser. For more information, see Importing the Katello Root CA Certificate.
Access orcharhino Server using a web browser pointed to the fully qualified domain name:
Enter the user name and password created during the configuration process. If a user was not created during the configuration process, the default user name is admin. If you have problems logging in, you can reset the password. For more information, see Resetting the Administrative User Password.
1.3. Using FreeIPA credentials to log in to the orcharhino Hammer CLI
This section describes how to log in to your orcharhino Hammer CLI with your FreeIPA (IdM) login and password.
You have enrolled your orcharhino Server into FreeIPA and configured it to use FreeIPA for authentication. More specifically, you have enabled access both to the orcharhino management UI and the orcharhino API.
The host on which you run this procedure is configured to use FreeIPA credentials to log users in to your orcharhino Hammer CLI.
The host is an FreeIPA client.
An FreeIPA server is running and reachable by the host.
Obtain a Kerberos ticket-granting ticket (TGT) on behalf of a orcharhino user:
$ kinit idm_user
WarningIf, when you were setting FreeIPA to be the authentication provider, you enabled access to both the orcharhino API and the orcharhino management UI, an attacker can now obtain an API session after the user receives the Kerberos TGT. The attack is possible even if the user did not previously enter the orcharhino login credentials anywhere, for example in the browser.
If automatic negotiate authentication is not enabled, use the TGT to authenticate to Hammer manually:
$ hammer auth login negotiate
Optional: Destroy all cached Kerberos tickets in the collection:
$ kdestroy -A
Use any
hammercommand to ensure that the system does not ask you to authenticate again:$ hammer host list
To log out of Hammer, enter: |
1.4. Using FreeIPA credentials to log in to the orcharhino management UI with a Firefox browser
This section describes how to use the Firefox browser to log in to your orcharhino management UI with your FreeIPA (IdM) login and password.
You have enrolled your orcharhino Server into FreeIPA and configured the server to use FreeIPA for authentication.
The host on which you are using a Firefox browser to log in to the orcharhino management UI is an FreeIPA client.
You have a valid FreeIPA login and password.
ATIX AG recommends using the latest stable Firefox browser.
Your Firefox browser is configured for Single Sign-On (SSO).
Obtain the Kerberos ticket granting ticket (TGT) for yourself using your FreeIPA credentials:
$ kinit idm_user Password for idm_user@EXAMPLE.COM:
In your browser address bar, enter the URL of your orcharhino Server.
Alternatively, you can skip the first two steps and enter your login and password in the fields displayed on the orcharhino management UI. This is also the only option if the host from which you are accessing the orcharhino management UI is not an FreeIPA client. |
1.5. Using FreeIPA credentials to log in to the orcharhino management UI with a Chrome browser
This section describes how to use a Chrome browser to log in to your orcharhino management UI with your FreeIPA login and password.
The host on which you are using the Chrome browser to log in to the orcharhino management UI is an FreeIPA client.
ATIX AG recommends using the latest stable Chrome browser.
Enable the Chrome browser to use Kerberos authentication:
NoteInstead of allowlisting the whole domain, you can also allowlist a specific orcharhino Server.
Obtain the Kerberos ticket-granting ticket (TGT) for yourself using your FreeIPA credentials:
$ kinit idm_user Password for idm_user@_EXAMPLE.COM:
Alternatively, you can skip the first three steps and enter your login and password in the fields displayed on the orcharhino management UI. This is also the only option if the host from which you are accessing the orcharhino management UI is not an FreeIPA client. |
1.6. Navigation Tabs in the orcharhino management UI
Use the navigation tabs to browse the orcharhino management UI.
| Navigation Tabs | Description |
Any Context |
Clicking this tab changes the organization and location. If no organization or location is selected, the default organization is Any Organization and the default location is Any Location. Use this tab to change to different values. |
Monitor |
Content |
Provides content management tools. This includes Content Views, Activation Keys, and Lifecycle Environments. |
Hosts |
Configure |
Provides general configuration tools and data including Host Groups and Puppet data. |
Infrastructure |
Provides tools on configuring how orcharhino interacts with the environment. |
User Name |
Provides user administration where users can edit their personal information. |
Administer |
Provides advanced configuration for settings such as Users and RBAC, as well as general settings. |
1.7. Changing the Password
In the orcharhino management UI, click your user name at the top right corner.
Select My Account from the menu.
In the Current Password field, enter the current password.
In the Password field, enter a new password.
In the Verify field, enter the new password again.
Click Submit to save your new password.
1.8. Resetting the Administrative User Password
Log in to the base operating system where orcharhino Server is installed.
Enter the following command to reset the password:
# foreman-rake permissions:reset Reset to user: admin, password: qwJxBptxb7Gfcjj5
Use this password to reset the password in the orcharhino management UI.
Edit the
~/.hammer/cli.modules.d/foreman.ymlfile on orcharhino Server to add the new password:# vi ~/.hammer/cli.modules.d/foreman.yml
To set the password, enter the following command:
Edit the
1.9. Setting a Custom Message on the Login Page
In the orcharhino management UI, navigate to Administer > Settings, and click the General tab.
Click the edit button next to Login page footer text, and enter the desired text to be displayed on the login page. For example, this text may be a warning message required by your company.
Click Save.
Log out of the orcharhino management UI and verify that the custom text is now displayed on the login page below the orcharhino version number.
2. Starting and Stopping orcharhino
orcharhino provides the foreman-maintain service command to manage orcharhino services from the command line.
This is useful when creating a backup of orcharhino.
For more information on creating backups, see Backing Up orcharhino Server and orcharhino Proxy.
After installing orcharhino with the foreman-installer command, all orcharhino services are started and enabled automatically.
To stop orcharhino services, execute:
To start orcharhino services, execute:
To restart orcharhino services, execute:
3. Tuning orcharhino Server with Predefined Profiles
If your orcharhino deployment includes more than 5000 hosts, you can use predefined tuning profiles to improve performance of orcharhino.
Note that you cannot use tuning profiles on orcharhino Proxies.
You can choose one of the profiles depending on the number of hosts your orcharhino manages and available hardware resources.
When you run the foreman-installer command with the --tuning option, deployment configuration settings are applied to orcharhino in the following order:
The default tuning profile defined in the
/usr/share/foreman-installer/config/foreman.hiera/tuning/common.yamlfile -
The tuning profile that you want to apply to your deployment and is defined in the
/usr/share/foreman-installer/config/foreman.hiera/tuning/sizes/directory -
Optional: If you have configured a
/etc/foreman-installer/custom-hiera.yamlfile, orcharhino applies these configuration settings.
- default
Number of managed hosts: 0 – 5000
RAM: 20G
Number of CPU cores: 4
- medium
Number of managed hosts: 5001 – 10000
RAM: 32G
Number of CPU cores: 8
- large
Number of managed hosts: 10001 – 20000
RAM: 64G
Number of CPU cores: 16
- extra-large
Number of managed hosts: 20001 – 60000
RAM: 128G
Number of CPU cores: 32
- extra-extra-large
Number of managed hosts: 60000+
RAM: 256G
Number of CPU cores: 48+
Optional: If you have configured the
custom-hiera.yamlfile on orcharhino Server, back up the/etc/foreman-installer/custom-hiera.yamlfile tocustom-hiera.original. You can use the backup file to restore the/etc/foreman-installer/custom-hiera.yamlfile to its original state if it becomes corrupted:# cp /etc/foreman-installer/custom-hiera.yaml \ /etc/foreman-installer/custom-hiera.original
custom-hiera.yamlfile on orcharhino Server, review the definitions of the default tuning profile in/usr/share/foreman-installer/config/foreman.hiera/tuning/common.yamland the tuning profile that you want to apply in/usr/share/foreman-installer/config/foreman.hiera/tuning/sizes/. Compare the configuration entries against the entries in your/etc/foreman-installer/custom-hiera.yamlfile and remove any duplicated configuration settings in your/etc/foreman-installer/custom-hiera.yamlfile. -
Enter the
foreman-installercommand with the--tuningoption for the profile that you want to apply. For example, to apply the medium tuning profile settings, enter the following command:# foreman-installer --tuning medium
4. Migrating from Internal orcharhino Databases to External Databases
When you install orcharhino, the foreman-installer command installs PostgreSQL databases on the same server as orcharhino. If you are using the default internal databases but want to start using external databases to help with the server load, you can migrate your internal databases to external databases.
To confirm whether your orcharhino Server has internal or external databases, you can query the status of your databases:
Preparing a Host for External Databases. Prepare a Red Hat Enterprise Linux 8 server to host the external databases.
Installing PostgreSQL. Prepare PostgreSQL with databases for orcharhino, Pulp and Candlepin with dedicated users owning them.
Migrating to External Databases. Edit the parameters of
foreman-installerto point to the new databases, and runforeman-installer.
4.1. PostgreSQL as an External Database Considerations
Foreman, Katello, and Candlepin use the PostgreSQL database. If you want to use PostgreSQL as an external database, the following information can help you decide if this option is right for your orcharhino configuration. orcharhino supports PostgreSQL version 12.
Increase in free memory and free CPU on orcharhino
Flexibility to set
shared_bufferson the PostgreSQL database to a high number without the risk of interfering with other services on orcharhino -
Flexibility to tune the PostgreSQL server’s system without adversely affecting orcharhino operations
If either orcharhino or the PostgreSQL database server suffers a hardware or storage failure, orcharhino is not operational
If there is latency between the orcharhino server and database server, performance can suffer
4.2. Preparing a Host for External Databases
The prepared host must meet orcharhino’s Storage Requirements.
Ensure the prepared host has the same content available as your orcharhino Server.
4.3. Installing PostgreSQL
You can install only the same version of PostgreSQL that is installed with the foreman-installer tool during an internal database installation.
To install PostgreSQL, enter the following command:
# dnf install postgresql-server postgresql-evr postgresql-contrib
To initialize PostgreSQL, enter the following command:
# postgresql-setup initdb
Edit the
Note that the default configuration of external PostgreSQL needs to be adjusted to work with orcharhino. The base recommended external database configuration adjustments are as follows:
max_connections: 500
shared_buffers: 512MB
work_mem: 4MB
Remove the
Edit the
host all all orcharhino_ip/32 md5
To start, and enable PostgreSQL service, enter the following commands:
Open the postgresql port on the external PostgreSQL server:
# firewall-cmd --add-service=postgresql # firewall-cmd --runtime-to-permanent
Switch to the
Create three databases and dedicated roles: one for orcharhino, one for Candlepin, and one for Pulp:
CREATE USER "foreman" WITH PASSWORD 'Foreman_Password'; CREATE USER "candlepin" WITH PASSWORD 'Candlepin_Password'; CREATE USER "pulp" WITH PASSWORD 'Pulpcore_Password'; CREATE DATABASE foreman OWNER foreman; CREATE DATABASE candlepin OWNER candlepin; CREATE DATABASE pulpcore OWNER pulp;
Connect to the Pulp database:
postgres=# \c pulpcore You are now connected to database "pulpcore" as user "postgres".
Create the
hstoreextension:pulpcore=# CREATE EXTENSION IF NOT EXISTS "hstore"; CREATE EXTENSION
Exit the
postgresuser:# \q
From orcharhino Server, test that you can access the database. If the connection succeeds, the commands return
1.# PGPASSWORD='Foreman_Password' psql -h postgres.example.com -p 5432 -U foreman -d foreman -c "SELECT 1 as ping" # PGPASSWORD='Candlepin_Password' psql -h postgres.example.com -p 5432 -U candlepin -d candlepin -c "SELECT 1 as ping" # PGPASSWORD='Pulpcore_Password' psql -h postgres.example.com -p 5432 -U pulp -d pulpcore -c "SELECT 1 as ping"
4.4. Migrating to External Databases
Back up and transfer existing data, then use the foreman-installer command to configure orcharhino to connect to an external PostgreSQL database server.
You have installed and configured a PostgreSQL server on a Enterprise Linux server.
On orcharhino Server, stop orcharhino services:
Start the PostgreSQL services:
# systemctl start postgresql
# foreman-maintain backup online \ --preserve-directory \ --skip-pulp-content \ /var/migration_backup
PGPASSWORD='Foreman_Password' pg_restore -h postgres.example.com -U foreman -d foreman < /var/migration_backup/foreman.dump PGPASSWORD='Candlepin_Password' pg_restore -h postgres.example.com -U candlepin -d candlepin < /var/migration_backup/candlepin.dump PGPASSWORD='Pulpcore_Password' pg_restore -h postgres.example.com -U pulp -d pulpcore < /var/migration_backup/pulpcore.dump
Use the
foreman-installercommand to update orcharhino to point to the new databases:# foreman-installer --scenario katello \ --foreman-db-database foreman \ --foreman-db-host postgres.example.com \ --foreman-db-manage false \ --foreman-db-password Foreman_Password \ --foreman-db-username foreman \ --foreman-proxy-content-pulpcore-manage-postgresql false \ --foreman-proxy-content-pulpcore-postgresql-db-name pulpcore \ --foreman-proxy-content-pulpcore-postgresql-host postgres.example.com \ --foreman-proxy-content-pulpcore-postgresql-password Pulpcore_Password \ --foreman-proxy-content-pulpcore-postgresql-user pulp \ --katello-candlepin-db-host postgres.example.com \ --katello-candlepin-db-name candlepin \ --katello-candlepin-db-password Candlepin_Password \ --katello-candlepin-db-user candlepin \ --katello-candlepin-manage-db false
5. Managing orcharhino with Ansible Collections
orcharhino Ansible Collections is a set of Ansible modules that interact with the orcharhino API. You can use orcharhino Ansible Collections to manage and automate many aspects of orcharhino.
6. Preparing for disaster recovery and recovering from data loss
ATIX AG recommends preparing a disaster recovery plan to ensure the continuity of orcharhino services in case of a disruptive event. These guidelines help ensure that you will be able to restore your orcharhino deployment to an operational state after an incident.
6.1. Overview of recommended disaster recovery plans
Choose a disaster recovery plan that best helps ensure the continuity of orcharhino services in your deployment.
- Snapshots of virtualized orcharhino Server
- How do I back up?
Virtualize your orcharhino Server and use the hypervisor tools to take virtual machine snapshots of the server. This method is suitable if you can run orcharhino in a virtual machine.
To recover orcharhino services, restore a virtual machine snapshot.
- Active and passive orcharhino Server, with external storage
- How do I back up?
/var/lib/pulpand database in/var/lib/pgsql. Replicate this storage into a different data center. Attach the storage to a orcharhino Server that is a clone of the primary orcharhino Server but runs passively. - How will I recover in case of a disruptive event?
To recover orcharhino services, switch DNS records of the active orcharhino Server with the passive orcharhino Server. This ensures that the passive server becomes the active server. All hosts remain connected without configuration updates.
- Active and passive orcharhino Server, with backup and restore
- How do I back up?
Ensure periodic backups of your orcharhino Server. Copy this backup to a passive orcharhino Server and restore it on the passive server.
- Dual active orcharhino Server
- How do I back up?
Operate an active, independent orcharhino Server per data center. Hosts from each data center are registered to the orcharhino Server in that data center. Then configure automation to ensure recovery in case of a disruptive event. For example, you can periodically run a health check and if the health check discovers that the current orcharhino Server a host is registered to does not resolve, the host is re-registered to the other orcharhino Server.
To minimize downtime, you can automate the recovery in various ways. For example, you can use the orcharhino Ansible collection. For more information, see Managing orcharhino with Ansible in Administering orcharhino.
To recover orcharhino services, re-register all hosts to the orcharhino Server in the other data center.
You must ensure that content synchronization and content view creation are synchronized to create the same content view in each orcharhino and prevent content drift. Content drift occurs when available content deviates from the intended state defined by a content view. If you fail to prevent content drift, expect inconsistency in the content that is available to hosts.
6.2. Disaster recovery by virtualizing your orcharhino Server
If you virtualize your orcharhino Server and ensure that you take regular snapshots of the virtual machine (VM), you can respond to various disaster scenarios by restoring your orcharhino deployment from one of your snapshots.
The details for how to implement this scenario depend on your choice of a virtualization platform. Due to the variety of different hypervisors and their capabilities, ATIX AG does not provide detailed instructions for any specific virtualization platform. |
6.2.1. Prerequisites
Review Overview of recommended disaster recovery plans to make sure that this disaster recovery plan works for you.
Your orcharhino Server is deployed as a VM.
6.2.2. Preparing for disaster recovery by virtualizing your orcharhino Server
Implement a reliable process for regularly taking VM snapshots of your virtualized orcharhino Server and for backing up your snapshots for long-term storage.
Define a schedule for taking periodic snapshots of your virtualized orcharhino Server. Consider your tolerance for potential data loss: Taking snapshots frequently will result in smaller amounts of data loss in case of a disaster. However, creating a snapshot takes time, and the snapshots also require storage space.
Using your hypervisor, schedule periodic snapshots of your orcharhino Server.
If you are using an external database that runs on a different machine than your orcharhino Server, create snapshots and backups on the same schedule as your orcharhino Server.
Use the latest snapshot of your orcharhino Server and restore it in an isolated environment.
To verify that you will be able to restore orcharhino services in case of a disaster, assess the functionality of the test orcharhino Server. See Retrieving the Status of Services.
6.2.3. Recovering from disaster by restoring a VM snapshot of orcharhino Server
In case of a disaster, use a virtual machine (VM) snapshot of your orcharhino Server to restore orcharhino services.
Ensure that the hostname of your orcharhino Server does not change during recovery. The IP address can change. |
If you are using an external database that runs on a different machine than your orcharhino Server, ensure that you restore the database from a snapshot taken at the same time as or before the orcharhino Server snapshot.
Update DNS records so that the orcharhino Server hostname resolves to the new IP address. This redirects traffic from the old server to the new server and you will not need to re-register your hosts.
Assess the functionality of your restored orcharhino Server. See Retrieving the Status of Services.
6.2.4. Retrieving the Status of Services
orcharhino uses a set of back-end services. When troubleshooting, you can check the status of orcharhino services.
In the orcharhino management UI, navigate to Administer > About.
On the Smart Proxies tab, view the status of all orcharhino Proxies.
On the Compute Resources tab, view the status of attached compute resource providers.
In the Backend System Status table, view the status of all back-end services.
Get information from the database and orcharhino services:
# hammer ping
Run
Perform a health check:
Run
6.3. Disaster recovery for active and passive orcharhino Server with external storage
To prepare for disaster recovery, you can configure two orcharhino Servers and store critical data externally on shared storage. The primary server is active while the secondary server remains passive. If the primary server fails, the shared storage is attached to your secondary server, which turns the secondary server into your new primary server.
6.3.1. Prerequisites
Review Overview of recommended disaster recovery plans to ensure that this disaster recovery plan works for you.
Review Storage requirements and Storage guidelines in Installing orcharhino Server. Ensure that your shared storage meets the requirements of holding the contents of
/var/lib/pulpand/var/lib/pgsql. -
You have configured your orcharhino Server to use external databases. For more information, see Using external databases in Installing orcharhino Server.
6.3.2. Preparing for disaster recovery with active and passive orcharhino Server with external storage
Create your passive orcharhino Server as a backup of your active orcharhino Server.
Replicate the
/var/lib/pulpand/var/lib/pgsqldirectories from the active orcharhino Server to your shared storage. -
Back up your active orcharhino Server and restore it on a system that will serve as your passive orcharhino Server. For more information, see Backing Up orcharhino Server and orcharhino Proxy and Restoring orcharhino Server or orcharhino Proxy from a Backup.
Assess the functionality of the test orcharhino Server. For more information, see Retrieving the Status of Services.
6.3.3. Recovering from disaster with active and passive server with external storage
If your active orcharhino Server fails, detach it from the shared storage and make sure your passive server can access the data stored on the shared storage. This turns the passive server into your new active server.
Assess the functionality of your new active orcharhino Server. For more information, see Retrieving the Status of Services.
6.3.4. Retrieving the Status of Services
# hammer ping
Run
Run
6.4. Disaster recovery for active and passive orcharhino Server with backup and restore
To prepare for disaster recovery, you can configure two orcharhino Servers: an active primary server and a passive secondary server. You configure periodic backups of the primary server. If the primary server fails, you can restore a backup on the secondary server to turn it into your new primary server.
6.4.1. Prerequisites
You have a orcharhino Server installed.
6.4.2. Preparing for disaster recovery with active and passive orcharhino Server and backup and restore
Create your passive orcharhino Server by restoring a backup of your active orcharhino Server. Configure periodic backups of the active server.
Define a schedule for periodic offline backups of your active orcharhino Server. Consider your tolerance for potential data loss and your storage options: Taking backups frequently will result in smaller amounts of data loss in case of a disaster, but backups require a significant amount of storage space. For information about the size of orcharhino backups, see Estimating the Size of a Backup.
cronjob that ensures regular backups, see Example of a Weekly Full Backup Followed by Daily Incremental Backups. -
Schedule periodic offline backups of your active orcharhino Server to be taken according to the schedule you defined. For information about performing backups, see Backing Up orcharhino Server and orcharhino Proxy.
Ensure that the backup directories are encrypted and regularly synchronized to a secure location. By default, orcharhino stores the backups in the
/var/orcharhino-backupdirectory.Importantorcharhino Server backups contain sensitive information from the
/root/ssl-builddirectory. For example, they can contain hostnames, ssh keys, request files, and SSL certificates. Encrypting or moving the backups to a secure location helps minimize the risk of damage or unauthorized access to the hosts. -
Restore the most recent backup on a system that will serve as your passive orcharhino Server. For information about restoring backups, see Restoring orcharhino Server or orcharhino Proxy from a Backup.
Verify that orcharhino takes backups according to the schedule you defined.
6.4.3. Recovering from disaster with active and passive server and backup and restore
If your active orcharhino Server fails, activate your passive secondary server.
6.4.4. Retrieving the Status of Services
# hammer ping
Run
Run
6.4.5. Example of a Weekly Full Backup Followed by Daily Incremental Backups
#!/bin/bash -e PATH=/sbin:/bin:/usr/sbin:/usr/bin DESTINATION=/var/backup_directory if [[ $(date +%w) == 0 ]]; then foreman-maintain backup offline --assumeyes $DESTINATION else LAST=$(ls -td -- $DESTINATION/*/ | head -n 1) foreman-maintain backup offline --assumeyes --incremental "$LAST" $DESTINATION fi exit 0
6.5. Disaster recovery with two active orcharhino Servers
To prepare for disaster recovery, you can configure two orcharhino Servers and operate each server in a different data center. If one of the servers fails, you can re-register all hosts from the failed server to the other server.
6.5.1. Prerequisites
6.5.2. Preparing for disaster recovery with two active orcharhino Servers
Create a second orcharhino Server by restoring a backup of your first orcharhino Server. Configure both servers to operate independently in their respective data centers, but ensure that their content does not drift apart over time.
Back up your orcharhino Server. For more information, see Backing Up orcharhino Server and orcharhino Proxy.
Restore the backup on a system that will serve as your other orcharhino Server. For more information, see Restoring orcharhino Server or orcharhino Proxy from a Backup.
Register hosts to your servers so that each server manages hosts in its respective data center. For example, register all hosts in My_Data_Center_1 to one orcharhino Server and all hosts in My_Data_Center_2 to the other orcharhino Server.
Automate running the
Verify that your
Ansible playbooks can help you automate failover, re-registration, and synchronization. For more information, see Managing orcharhino with Ansible in Administering orcharhino.
For more information on synchronizing repositories, see Synchronizing repositories in Managing Content.
For more information on synchronizing content between orcharhino Servers, including ISS, export, and import, see Synchronizing content between orcharhino Servers in Managing Content.
6.5.3. Recovering from disaster with two active orcharhino Servers
If the health checks implemented in Preparing for disaster recovery with two active orcharhino Servers report an issue on one of your orcharhino Servers, it might mean that the server has failed. If the server is down, you must re-register hosts to the other server.
If
7. Managing Users and Roles
Roles define a set of permissions and access levels. Each role contains one on more permission filters that specify the actions allowed for the role. Actions are grouped according to the Resource type. Once a role has been created, users and user groups can be associated with that role. This way, you can assign the same set of permissions to large groups of users. orcharhino provides a set of predefined roles and also enables creating custom roles and permission filters as described in Creating and Managing Roles.
7.1. Managing Users
As an administrator, you can create, modify and remove orcharhino users. You can also configure access permissions for a user or a group of users by assigning them different roles.
7.1.1. Creating a User
Use this procedure to create a user. To use the CLI instead of the orcharhino management UI, see the CLI procedure.
Click Create User.
In the Login field, enter a username for the user.
In the Firstname and Lastname fields, enter the real first name and last name of the user.
In the Mail field, enter the user’s email address.
In the Description field, add a description of the new user.
Select a specific language for the user from the Language list.
Select a timezone for the user from the Timezone list.
By default, orcharhino Server uses the language and timezone settings of the user’s browser.
Set a password for the user:
From the Authorized by list, select the source by which the user is authenticated.
INTERNAL: to enable the user to be managed inside orcharhino Server.
EXTERNAL: to configure external authentication as described in Configuring External Authentication in Installing orcharhino Server.
Enter an initial password for the user in the Password field and the Verify field.
To create a user, enter the following command:
# hammer user create \ --auth-source-id My_Authentication_Source \ --login My_User_Name \ --mail My_User_Mail \ --organization-ids My_Organization_ID_1,My_Organization_ID_2 \ --password My_User_Password
The
--auth-source-id 1setting means that the user is authenticated internally, you can specify an external authentication source as an alternative. Add the--adminoption to grant administrator privileges to the user. Specifying organization IDs is not required, you can modify the user details later using theupdatesubcommand.
7.1.2. Assigning Roles to a User
Use this procedure to assign roles to a user. To use the CLI instead of the orcharhino management UI, see the CLI procedure.
NoteIf a user account is not listed, check that you are currently viewing the correct organization. To list all the users in orcharhino, click Default Organization and then Any Organization.
Click Submit.
7.1.3. Impersonating a Different User Account
Administrators can impersonate other authenticated users for testing and troubleshooting purposes by temporarily logging on to the orcharhino management UI as a different user. When impersonating another user, the administrator has permissions to access exactly what the impersonated user can access in the system, including the same menus.
Ensure that you are logged on to the orcharhino management UI as a user with administrator privileges for orcharhino.
7.1.4. Creating an API-Only User
You can create users that can interact only with the orcharhino API.
You have created a user and assigned roles to them. Note that this user must be authorized internally. For more information, see the following sections:
Log in to your orcharhino as admin.
# openssl rand -hex 32
7.2. Managing SSH Keys
7.2.1. Managing SSH Keys for a User
Use this procedure to add or remove SSH keys for a user. To use the CLI instead of the orcharhino management UI, see the CLI procedure.
Ensure that you are logged in to the orcharhino management UI as an Admin user of orcharhino or a user with the create_ssh_key permission enabled for adding SSH key and destroy_ssh_key permission for removing a key.
Click on the SSH Keys tab.
To Add SSH key
Click Add SSH Key.
Click Submit.
To Remove SSH key
# hammer user ssh-keys add \ --user-id user_id \ --name key_name \ --key-file ~/.ssh/id_rsa.pub
# hammer user ssh-keys add \ --user-id user_id \ --name key_name \ --key ecdsa-sha2-nistp256 AAAAE2VjZHNhLXNoYTItbmlzdHAyNTYAAAAIbmlzdHAyNtYAAABBBHHS2KmNyIYa27Qaa7EHp+2l99ucGStx4P77e03ZvE3yVRJEFikpoP3MJtYYfIe8k 1/46MTIZo9CPTX4CYUHeN8= host@user
7.3. Managing Personal Access Tokens
7.3.1. Creating a Personal Access Token
# curl https://orcharhino.example.com/api/status --user My_Username:My_Personal_Access_Token
200, for example:{"orcharhino_version":"6.6.0","result":"ok","status":200,"version":"3.5.1.10","api_version":2}If you go back to Personal Access Tokens tab, you can see the updated Last Used time next to your Personal Access Token.
7.3.2. Revoking a Personal Access Token
7.4. Creating and Managing User Groups
7.4.1. User Groups
With orcharhino, you can assign permissions to groups of users. You can also create user groups as collections of other user groups. If using an external authentication source, you can map orcharhino user groups to external user groups as described in Configuring External User Groups in Installing orcharhino Server.
7.4.2. Creating a User Group
In the orcharhino management UI, navigate to Administer > User Groups.
Click Create User group.
Click Submit.
To create a user group, enter the following command:
# hammer user-group create \ --name My_User_Group_Name \ --role-ids My_Role_ID_1,My_Role_ID_2 \ --user-ids My_User_ID_1,My_User_ID_2
7.5. Creating and Managing Roles
orcharhino provides a set of predefined roles with permissions sufficient for standard tasks, as listed in Predefined Roles Available in orcharhino. It is also possible to configure custom roles, and assign one or more permission filters to them. Permission filters define the actions allowed for a certain resource type. Certain orcharhino plug-ins create roles automatically.
7.5.1. Creating a Role
In the orcharhino management UI, navigate to Administer > Roles.
Click Create Role.
Provide a Name for the role.
7.5.2. Cloning a Role
Use the orcharhino management UI to clone a role.
In the orcharhino management UI, navigate to Administer > Roles and select Clone from the drop-down menu to the right of the required role.
7.5.3. Adding Permissions to a Role
Use this procedure to add permissions to a role. To use the CLI instead of the orcharhino management UI, see the CLI procedure.
Depending on the Resource type selected, you can select or deselect the Unlimited and Override checkbox. The Unlimited checkbox is selected by default, which means that the permission is applied on all resources of the selected type. When you disable the Unlimited checkbox, the Search field activates. In this field you can specify further filtering with use of the orcharhino search syntax. For more information, see Granular Permission Filtering. When you enable the Override checkbox, you can add additional locations and organizations to allow the role to access the resource type in the additional locations and organizations; you can also remove an already associated location and organization from the resource type to restrict access.
Click Next.
Click Submit to save changes.
Add permissions to a role:
# hammer filter create \ --permission-ids My_Permission_ID_1,My_Permission_ID_2 \ --role My_Role_Name
7.5.4. Viewing Permissions of a Role
Use the orcharhino management UI to view the permissions of a role.
The Filters page contains a table of permissions assigned to a role grouped by the resource type. It is also possible to generate a complete table of permissions and actions that you can use on your orcharhino system. For more information, see Creating a Complete Permission Table.
7.5.5. Creating a Complete Permission Table
Ensure that the
foreman-consolepackage is installed on orcharhino Server:# dnf install foreman-console
Start the orcharhino console with the following command:
# foreman-rake console
/tmp/table.htmlfile. -
Press
Ctrl+Dto exit the orcharhino console. -
/tmp/table.html:<table border="1"><tr><td>Permission name</td><td>Actions</td><td>Resource type</td></tr>
/tmp/table.html:</table>
Open
7.6. Predefined Roles Available in orcharhino
The following table provides an overview of permissions that predefined roles in orcharhino grant to a user.
For a complete set of predefined roles and the permissions they grant, log in to orcharhino management UI as the privileged user and navigate to Administer > Roles. For more information, see Viewing Permissions of a Role.
Auditor |
View the Audit log. |
Default role |
orcharhino automatically assigns this role to every user in the system. |
Manager |
Organization admin |
Site manager |
System admin |
Viewer |
View the configuration of every element of the orcharhino structure, logs, reports, and statistics. |
7.7. Granular Permission Filtering
As mentioned in Adding Permissions to a Role, orcharhino provides the ability to limit the configured user permissions to selected instances of a resource type. These granular filters are queries to the orcharhino database and are supported by the majority of resource types.
7.7.1. Creating a Granular Permission Filter
Use this procedure to create a granular filter. To use the CLI instead of the orcharhino management UI, see the CLI procedure.
orcharhino does not apply search conditions to create actions. For example, limiting the create_locations action with name = "Default Location" expression in the search field does not prevent the user from assigning a custom name to the newly created location.
field_name operator value
operator specifies the type of comparison between field_name and value. See Supported Operators for Granular Search for an overview of applicable operators.
hammer filter createcommand with the--searchoption to limit permission filters, for example:# hammer filter create \ --permission-ids 91 \ --search "name ~ ccv*" \ --role qa-user
7.7.2. Examples of Using Granular Permission Filters
hostgroup = host-editors
name ^ (XXXX, Yyyy, zzzz)
Dev
Use the orcharhino management UI to create an administrative role restricted to a single organization named org-1.
7.7.3. Supported Operators for Granular Search
Operator |
Description |
and |
Combines search criteria. |
not |
Negates an expression. |
has |
Operator |
Description |
8. Configuring Email Notifications
Email notifications are created by orcharhino Server periodically or after completion of certain events. The periodic notifications can be sent daily, weekly or monthly.
orcharhino Server does not enable outgoing emails by default, therefore you must review your email configuration. |
8.1. Email Notification Types
orcharhino can create the following email notifications:
Audit summary: A summary of all activity audited by orcharhino Server.
Host built: A notification sent when a host is built.
Host errata advisory: A summary of applicable and installable errata for hosts managed by the user.
Compliance policy summary: A summary of OpenSCAP policy reports and their results.
Promote errata: A notification sent only after a Content View promotion. It contains a summary of errata applicable and installable to hosts registered to the promoted Content View. This allows a user to monitor what updates have been applied to which hosts.
Sync errata: A notification sent only after synchronizing a repository. It contains a summary of new errata introduced by the synchronization.
For a complete list of email notification types, navigate to Administer > Users in the orcharhino management UI, click the Username of the required user, and select the Email Preferences tab.
8.2. Configuring Email Notification Preferences
You can configure orcharhino to send email messages to individual users registered to orcharhino. orcharhino sends the email to the email address that has been added to the account, if present. Users can edit the email address by clicking on their name in the top-right of the orcharhino management UI and selecting My account.
Configure email notifications for a user from the orcharhino management UI.
If you want to send email notifications to a group email address instead of an individual email address, create a user account with the group email address and minimal orcharhino permissions, then subscribe the user account to the desired notification types. |
view_mail_notifications.
Click Submit.
8.3. Testing Email Delivery
Click on the username.
Verify orcharhino Server’s email configuration.
If your orcharhino Server uses the Postfix service for email delivery, the test email might be held in the queue. To verify, enter the
mailqcommand to list the current mail queue. If the test email is held in the queue,mailqdisplays the following message:postqueue: warning: Mail system is down -- accessing queue directly -Queue ID- --Size-- ----Arrival Time---- -Sender/Recipient------- BE68482A783 1922 Thu Oct 3 05:13:36 orcharhino-noreply@example.com
To fix the problem, start the Postfix service on your orcharhino Server:
# systemctl start postfix
8.4. Testing Email Notifications
To trigger the notifications, execute the following command:
daily
weekly
monthly
8.5. Changing Email Notification Settings for a Host
orcharhino can send event notifications for a host to the host’s registered owner. You can configure orcharhino to send email notifications either to an individual user or a user group. When set to a user group, all group members who are subscribed to the email type receive a message.
In the orcharhino management UI, navigate to Hosts > All Hosts, locate the host that you want to view, and click Edit in the Actions column.
Go to the Additional Information tab. If the checkbox Include this host within orcharhino reporting is checked, then the email notifications are enabled on that host.
9. Backing Up orcharhino Server and orcharhino Proxy
You can back up your orcharhino deployment to ensure the continuity of your orcharhino deployment and associated data in the event of a disaster. If your deployment uses custom configurations, you must consider how to handle these custom configurations when you plan your backup and disaster recovery policy.
If you create a new instance of the orcharhino Server, decommission the old instances after restoring the backup. Cloned instances are not supposed to run in parallel in a production environment. |
To create a backup of your orcharhino Server or orcharhino Proxy and all associated data, use the foreman-maintain backup command.
orcharhino services are unavailable during the backup.
You can schedule a backup using cron.
For more information, see the Example of a Weekly Full Backup Followed by Daily Incremental Backups.
During offline or snapshot backups, the services are inactive and orcharhino is in a maintenance mode. All the traffic from outside on port 443 is rejected by a firewall to ensure there are no modifications triggered.
A backup contains sensitive information from the /root/ssl-build directory.
You can also use conventional backup methods.
If you plan to use the |
When creating a snapshot or conventional backup, you must stop all services as follows:
Start the services after creating a snapshot or conventional backup:
9.1. Estimating the Size of a Backup
The full backup creates uncompressed archives of PostgreSQL and Pulp database files, and orcharhino configuration files. Compression occurs after the archives are created to decrease the time when orcharhino services are unavailable.
Uncompressed orcharhino database and configuration files
Compressed orcharhino database and configuration files
Enter the
ducommand to estimate the size of uncompressed directories containing orcharhino database and configuration files:# du -sh /var/lib/pgsql/data /var/lib/pulp 100G /var/lib/pgsql/data 100G /var/lib/pulp # du -csh /var/lib/tftpboot /etc /root/ssl-build \ /var/www/html/pub /opt/puppetlabs 16M /var/lib/tftpboot 37M /etc 900K /root/ssl-build 100K /var/www/html/pub 2M /opt/puppetlabs 942M total
Table 3. Backup Data Compression Ratio Data type Directory Ratio Example results PostgreSQL database files
/var/lib/pgsql/data80 – 85%
100 GB → 20 GB
Pulp RPM files
/var/lib/pulp(not compressed)
100 GB
Configuration files
/var/lib/tftpboot
/etc
/root/ssl-build
/var/www/html/pub
/opt/puppetlabs85%
942 MB → 141 MB
9.2. Performing a Full Backup of orcharhino Server or orcharhino Proxy
orcharhino uses the foreman-maintain backup command to make backups.
There are three main methods of backing up orcharhino Server:
Offline backup
Online backup
Snapshot backups
orcharhino-backupon orcharhino -
foreman-proxy-backupon orcharhino Proxy
To enable orcharhino to save the backup to an NFS share, ensure that the root user of your orcharhino Server or orcharhino Proxy can write to the NFS share.
NFS export options such as root_squash and all_squash are known to prevent this.
Ensure that your backup location has sufficient available disk space to store the backup. For more information, see Estimating the Size of a Backup.
Warning
Request other users of orcharhino Server or orcharhino Proxy to save any changes and warn them that orcharhino services are unavailable for the duration of the backup. Ensure no other tasks are scheduled for the same time as the backup. |
On orcharhino Server, enter the following command:
# foreman-maintain backup offline /var/orcharhino-backup
On orcharhino Proxy, enter the following command:
9.3. Performing a Backup without Pulp Content
Warning
9.4. Performing an Incremental Backup
Warning
To perform a full offline backup, enter the following command:
To create a directory within your backup directory to store the first incremental back up, enter the
foreman-maintain backupcommand with the--incrementaloption:# foreman-maintain backup offline --incremental /var/backup_directory/full_backup /var/backup_directory
To create the second incremental backup, enter the
foreman-maintain backupcommand with the--incrementaloption and include the path to the first incremental backup to indicate the starting point for the next increment. This creates a directory for the second incremental backup in your backup directory:# foreman-maintain backup offline --incremental /var/backup_directory/first_incremental_backup /var/backup_directory
9.5. Example of a Weekly Full Backup Followed by Daily Incremental Backups
9.6. Performing an Online Backup
When performing an online backup, if there are procedures affecting the Pulp database, the Pulp part of the backup procedure repeats until it is no longer being altered. Because the backup of the Pulp database is the most time consuming part of backing up orcharhino, if you make a change that alters the Pulp database during this time, the backup procedure keeps restarting.
Warning
To perform an online backup, enter the following command:
9.7. Performing a Snapshot Backup
The snapshot backup method is faster than a full offline backup and therefore reduces orcharhino downtime.
# foreman-maintain backup snapshot -h
Warning
Request other orcharhino Server or orcharhino Proxy users to save any changes and warn them that orcharhino services are unavailable for the duration of the backup. Ensure no other tasks are scheduled for the same time as the backup. |
The system uses LVM for the directories that you snapshot:
/var/lib/pulp/and/var/lib/pgsql. -
The free disk space in the relevant volume group (VG) is three times the size of the snapshot. More precisely, the VG must have enough space unreserved by the member logical volumes (LVs) to accommodate new snapshots. In addition, one of the LVs must have enough free space for the backup directory.
The target backup directory is on a different LV than the directories that you snapshot.
To perform a snapshot backup, enter the
foreman-maintain backup snapshotcommand:# foreman-maintain backup snapshot /var/backup_directory
The foreman-maintain backup snapshot command creates snapshots when the services are active, and stops all services which can impact the backup.
This makes the maintenance window shorter.
After the successful snapshot, all services are restarted and LVM snapshots are removed.
9.8. White-listing and Skipping Steps When Performing Backups
A backup using the foreman-maintain backup command proceeds in a sequence of steps.
To skip part of the backup add the --whitelist option to the command and add the step label that you want to omit.
To display a list of available step labels, enter the following command:
To skip a step of the backup, enter the
foreman-maintain backupcommand with the--whitelistoption. For example:# foreman-maintain backup online \ --whitelist backup-metadata \ /var/backup_directory
10. Restoring orcharhino Server or orcharhino Proxy from a Backup
You can restore orcharhino Server or orcharhino Proxy from the backup data that you create as part of Backing Up orcharhino Server and orcharhino Proxy. This process outlines how to restore the backup on the same server that generated the backup, and all data covered by the backup is deleted on the target system. If the original system is unavailable, provision a system with the same configuration settings and host name.
10.1. Restoring from a Full Backup
Use this procedure to restore orcharhino or orcharhino Proxy from a full backup. When the restore process completes, all processes are online, and all databases and system configuration revert to the state at the time of the backup.
Ensure that you are restoring to the correct instance. The orcharhino instance must have the same host name, configuration, and be the same minor version (X.Y) as the original system.
Ensure that you have enough space to store this data on the base system of orcharhino Server or orcharhino Proxy as well as enough space after the restoration to contain all the data in the
/etc/and/var/directories contained within the backup.To check the space used by a directory, enter the following command:
# df -h /var/backup_directory
Add the
# restorecon -Rv /
Choose the appropriate method to install orcharhino or orcharhino Proxy:
To install orcharhino Server from a connected network, follow the procedures in Installing orcharhino Server.
To install a orcharhino Proxy, follow the procedures in Installing orcharhino Proxy.
Copy the backup data to orcharhino Server’s local file system. Use
/var/or/var/tmp/. -
Run the restoration script.
For troubleshooting, you can check
/var/log/foreman/production.logand/var/log/messages.
10.2. Restoring from Incremental Backups
Use this procedure to restore orcharhino or orcharhino Proxy from incremental backups. If you have multiple branches of incremental backups, select your full backup and each incremental backup for the branch you want to restore, in chronological order.
Restore the last full backup using the instructions in Restoring from a Full Backup.
Remove the full backup data from orcharhino Server’s local file system, for example,
/var/or/var/tmp/. -
Copy the incremental backup data to orcharhino Server’s local file system, for example,
/var/or/var/tmp/. -
10.3. Backup and Restore orcharhino Proxy Using a Virtual Machine Snapshot
If your orcharhino Proxy is a virtual machine, you can restore it from a snapshot. Creating weekly snapshots to restore from is recommended. In the event of failure, you can install, or configure a new orcharhino Proxy, and then synchronize the database content from orcharhino Server.
If required, deploy a new orcharhino Proxy, ensuring the host name is the same as before, and then install the orcharhino Proxy certificates. You may still have them on orcharhino Server, the package name ends in -certs.tar, alternately create new ones. Follow the procedures in Installing orcharhino Proxy until you can confirm, in the orcharhino management UI, that orcharhino Proxy is connected to orcharhino Server. Then use the procedure Synchronizing Content from orcharhino Server to orcharhino Proxies to synchronize from orcharhino.
10.3.1. Synchronizing Content from orcharhino Server to orcharhino Proxies
Use this procedure to synchronize content from your orcharhino Server to your orcharhino Proxy.
Ensure that you either select the relevant organization and location context of your orcharhino Proxy or choose Any Organization and Any Location.
In the orcharhino management UI, navigate to Infrastructure > orcharhino Proxies.
Select your orcharhino Proxy.
Select Optimized Sync to synchronize content from your orcharhino Server to your orcharhino Proxy that bypasses unnecessary steps to speed up performance.
Select Complete Sync to perform a complete sync from your orcharhino Server to your orcharhino Proxy that synchronizes content even if the metadata has not changed.
11. Renaming orcharhino Server or orcharhino Proxy
To rename orcharhino Server or orcharhino Proxy, use the katello-change-hostname script.
When changing the domain name of your orcharhino Server or orcharhino Proxy, update the hostname using |
11.1. Renaming orcharhino Server
The host name of orcharhino Server is used by orcharhino Server components, all orcharhino Proxies, and hosts registered to it for communication. This procedure ensures that in addition to renaming orcharhino Server, you also update all references to point to the new host name.
Warning
Renaming your orcharhino Server host shuts down all orcharhino services on that host. The services restart after the renaming is complete. |
Back up your orcharhino Server before changing its host name. If you fail to successfully rename it, restore it from the backup. For more information, see Backing Up orcharhino Server and orcharhino Proxy.
Run the
hostnameandhostname -fcommands on orcharhino Server. If both commands do not return the FQDN of orcharhino Server, thekatello-change-hostnamescript will fail to complete.If the
hostnamecommand returns the shortname of orcharhino Server instead of the FQDN, usehostnamectl set-hostname My_Old_FQDNto set the old FQDN correctly before using thekatello-change-hostnamescript. -
If orcharhino Server has a custom SSL certificate installed, obtain a new certificate for the new FQDN of the host.
On orcharhino Server, run the
katello-change-hostnamescript, and provide the new host name. Choose one of the following methods:-
If your orcharhino Server is installed with the default self-signed SSL certificates, enter the following command:
# katello-change-hostname new-orcharhino \ --username admin \ --password password
If your orcharhino Server is installed with custom SSL certificates:
# katello-change-hostname new-orcharhino \ --username admin \ --password password \ --custom-cert "/root/ownca/test.com/test.com.crt" \ --custom-key "/root/ownca/test.com/test.com.key"
If you have created a custom SSL certificate for the new orcharhino Server host name, run the orcharhino installation script to install the certificate.
Reregister all orcharhino hosts. For more information, see Registering Hosts in Managing Hosts.
On all orcharhino Proxies, run the orcharhino installation script to update references to the new host name:
# foreman-installer \ --foreman-proxy-foreman-base-url https://new-orcharhino.example.com \ --foreman-proxy-trusted-hosts new-orcharhino.example.com
On orcharhino Server, list all orcharhino Proxies:
# hammer proxy list
On orcharhino Server, synchronize content for each orcharhino Proxy:
# hammer proxy content synchronize \ --id Myorcharhino-proxy_ID_
If you use external authentication, reconfigure orcharhino Server for external authentication after you run the
11.2. Renaming orcharhino Proxy
The host name of orcharhino Proxy is referenced by orcharhino Server components and all hosts registered to it. This procedure ensures that in addition to renaming orcharhino Proxy, you also update all references to the new host name.
Warning
Renaming your orcharhino Proxy host shuts down all orcharhino services on that host. The services restart after the renaming is complete. |
Back up your orcharhino Proxy before renaming. If you fail to successfully rename it, restore it from the backup. For more information, see Backing Up orcharhino Server and orcharhino Proxy.
Run the
hostnameandhostname -fcommands on orcharhino Proxy. If both commands do not return the FQDN of orcharhino Proxy, thekatello-change-hostnamescript will fail to complete.If the
hostnamecommand returns the shortname of orcharhino Proxy instead of the FQDN, usehostnamectl set-hostname My_Old_FQDNto set the old FQDN correctly before attempting to use thekatello-change-hostnamescript.
On orcharhino Server, generate a new certificates archive file for orcharhino Proxy.
If you are using the default SSL certificate, enter the following command:
# foreman-proxy-certs-generate \ --foreman-proxy-fqdn new-orcharhino-proxy.example.com \ --certs-tar /root/new-orcharhino-proxy.example.com-certs.tar
.tarfile. -
If you are using a custom SSL certificate, create a new SSL certificate for orcharhino Proxy. For more information, see Configuring orcharhino Proxy with a Custom SSL Certificate in Installing orcharhino Proxy.
On orcharhino Server, copy the certificates archive file to orcharhino Proxy. For example, to copy the archive file to the
rootuser’s home directory:# scp /root/new-orcharhino-proxy.example.com-certs.tar root@orcharhino-proxy.example.com:
On orcharhino Proxy, run the
katello-change-hostnamescript and provide the host’s new name, orcharhino credentials, and certificates archive file name.# katello-change-hostname new-orcharhino-proxy.example.com --username admin \ --password password \ --certs-tar /root/new-orcharhino-proxy.example.com-certs.tar
.tarfile. -
If you have created a custom certificate for orcharhino Proxy, deploy the certificate on orcharhino Proxy by entering the
foreman-installercommand that theforeman-proxy-certs-generatecommand returned in a previous step. For more information, see Deploying a Custom SSL Certificate to orcharhino Proxy in Installing orcharhino Proxy. -
On all orcharhino Proxy clients, enter the following commands to reinstall the bootstrap RPM, reregister clients, and refresh their subscriptions.
You can use the remote execution feature to perform this step. For more information, see Configuring and Setting up Remote Jobs in Managing Hosts.
# dnf remove katello-ca-consumer* # dnf install http://new-orcharhino-proxy.example.com/pub/katello-ca-consumer-latest.noarch.rpm # subscription-manager register --org="My_Organization" \ --environment="Library" \ --force # subscription-manager refresh
Update the orcharhino Proxy host name in the orcharhino management UI.
Locate orcharhino Proxy in the list, and click Edit.
Edit the Name and URL fields to match orcharhino Proxy’s new host name, then click Submit.
On your DNS server, add a record for the new hostname of your orcharhino Proxy, and delete the record of the previous host name.
12. Maintaining orcharhino Server
This chapter provides information on how to maintain a orcharhino Server, including information on how to work with audit records, how to clean unused tasks, and how to recover Pulp from a full disk.
12.1. Deleting Audit Records Manually
Number_Of_Days.
12.2. Deleting Audit Records Automatically
This setting is empty by default, meaning orcharhino does not automatically delete the audit records.
In the orcharhino management UI, navigate to Administer > Settings.
Set the value of the setting to the number of days after which you want orcharhino to delete the audit records.
12.3. Anonymizing Audit Records
You can use the foreman-rake audits:anonymize command to remove any user account or IP information while maintaining the audit records in the database.
You can also use a cron job to schedule anonymizing the audit records at the set interval that you want.
By default, using the foreman-rake audits:anonymize command anonymizes audit records that are older than 90 days.
You can specify the number of days to keep the audit records by adding the days option and add the number of days.
12.4. Deleting Report Records
Report records are created automatically in orcharhino.
You can use the foreman-rake reports:expire command to remove reports at any time.
You can also use a cron job to schedule report record deletions at the set interval that you want.
By default, using the foreman-rake reports:expire command removes report records that are older than 90 days.
You can specify the number of days to keep the report records by adding the days option and add the number of days.
12.5. Configuring the Cleaning Unused Tasks Feature
orcharhino performs regular cleaning to reduce disc space in the database and limit the rate of disk growth. As a result, orcharhino backup completes faster and overall performance is higher.
By default, orcharhino executes a cron job that cleans tasks every day at 19:45. orcharhino removes the following tasks during the cleaning:
To configure the time at which orcharhino runs the cron job, set the
To configure the period after which orcharhino deletes the tasks, edit the
To disable regular task cleanup on orcharhino, enter the following command:
To reenable regular task cleanup on orcharhino, enter the following command:
12.6. Deleting Task Records
Task records are created automatically in orcharhino.
You can use the foreman-rake foreman_tasks:cleanup command to remove tasks at any time.
You can also use a cron job to schedule Task record deletions at the set interval that you want.
12.7. Deleting a Task by ID
Connect to your orcharhino Server using SSH:
# ssh root@orcharhino.example.com
Optional: View the task:
Delete the task:
Optional: Ensure the task has been removed from orcharhino Server:
12.8. Recovering from a Full Disk
Ensure that the LV with the
Remove orphaned content:
Change the download policy from Immediate to On Demand for as many repositories as possible and remove already downloaded packages.
/var/lib/pulpdirectory on it.NoteIf you use an untypical file system (other than for example ext3, ext4, or xfs), you might need to unmount the file system so that it is not in use. In that case, complete the following steps:
Stop orcharhino services:
Start orcharhino services:
12.9. Reclaiming PostgreSQL Space
The PostgreSQL database can use a large amount of disk space especially in heavily loaded deployments. Use this procedure to reclaim some of this disk space on orcharhino.
Switch to the
12.10. Reclaiming Space From On Demand Repositories
If you set the download policy to on demand, orcharhino downloads packages only when the clients request them. You can clean up these packages to reclaim space.
In the orcharhino management UI, navigate to Content > Products.
Select a product.
Select the product name.
Select the orcharhino Proxy.
Click Reclaim space.
13. Renewing the Custom SSL Certificate
This chapter provides information on how to renew the custom SSL certificate on orcharhino Server as well as on orcharhino Proxy.
13.1. Renewing a Custom SSL Certificate on orcharhino Server
Use this procedure to update your custom SSL certificate for orcharhino Server.
You must create a new Certificate Signing Request (CSR) and send it to the Certificate Authority to sign the certificate. Refer to the Configuring orcharhino Server with a Custom SSL Certificate guide before creating a new CSR because the Server certificate must have X.509 v3
Key UsageandExtended Key Usageextensions with required values. In return, you will receive the orcharhino Server certificate and CA bundle.
Before deploying a renewed custom certificate on your orcharhino Server, validate the custom SSL input files. Note that for the
katello-certs-checkcommand to work correctly, Common Name (CN) in the certificate must match the FQDN of orcharhino Server:# katello-certs-check -t orcharhino \ -b /root/orcharhino_cert/ca_cert_bundle.pem \ -c /root/orcharhino_cert/orcharhino_cert.pem \ -k /root/orcharhino_cert/orcharhino_cert_key.pem
If the command is successful, it returns the following
foreman-installercommand. You can use this command to deploy the renewed CA certificates to orcharhino Server:# foreman-installer --scenario katello \ --certs-server-cert "/root/orcharhino_cert/orcharhino_cert.pem" \ --certs-server-key "/root/orcharhino_cert/orcharhino_cert_key.pem" \ --certs-server-ca-cert "/root/orcharhino_cert/ca_cert_bundle.pem" \ --certs-update-server \ --certs-update-server-ca
Do not delete the certificate files after you deploy the certificate. They are required when upgrading orcharhino Server. |
If a new consumer package |
Access the orcharhino management UI from your local machine. For example, https://orcharhino.example.com.
13.2. Renewing a Custom SSL certificate on orcharhino Proxy
Use this procedure to update your custom SSL certificate for orcharhino Proxy.
The foreman-installer command, which the foreman-proxy-certs-generate command returns, is unique to each orcharhino Proxy.
You cannot use the same command on more than one orcharhino Proxy.
You must create a new Certificate Signing Request and send it to the Certificate Authority to sign the certificate. Refer to the Configuring orcharhino Server with a Custom SSL Certificate guide before creating a new CSR because the orcharhino Server certificate must have X.509 v3
Key UsageandExtended Key Usageextensions with required values. In return, you will receive the orcharhino Proxy certificate and CA bundle.
On your orcharhino Server, validate the custom SSL certificate input files:
# katello-certs-check -t orcharhino-proxy \ -b /root/orcharhino-proxy_cert/ca_cert_bundle.pem \ -c /root/orcharhino-proxy_cert/orcharhino-proxy_cert.pem \ -k /root/orcharhino-proxy_cert/orcharhino-proxy_cert_key.pem
On your orcharhino Server, generate the certificate archive file for your orcharhino Proxy:
# foreman-proxy-certs-generate \ --certs-tar "/root/My_Certificates/orcharhino-proxy.example.com-certs.tar" \ --certs-update-server \ --foreman-proxy-fqdn "orcharhino-proxy.example.com" \ --server-ca-cert "/root/My_Certificates/ca_cert_bundle.pem" \ --server-cert "/root/My_Certificates/orcharhino-proxy_cert.pem" \ --server-key "/root/My_Certificates/orcharhino-proxy_cert_key.pem"
On your orcharhino Server, copy the certificate archive file to your orcharhino Proxy:
# scp /root/My_Certificates/orcharhino-proxy.example.com-certs.tar user@orcharhino-proxy.example.com:
Retain a copy of the
foreman-installercommand that theforeman-proxy-certs-generatecommand returns for deploying the certificate to your orcharhino Proxy. -
Deploy the certificate on your orcharhino Proxy using the
foreman-installercommand returned by theforeman-proxy-certs-generatecommand:# orcharhino-installer --no-enable-foreman \ --certs-tar-file "/root/My_Certificates/orcharhino-proxy.example.com-certs.tar" \ --certs-update-server \ --foreman-proxy-foreman-base-url "https://orcharhino.example.com" \ --foreman-proxy-register-in-foreman "true"
Do not delete the certificate archive file on the orcharhino Proxy after you deploy the certificate. They are required when upgrading orcharhino Proxy. |
14. Logging and Reporting Problems
The following sections describe the most commonly used log files and debugging tools available in orcharhino.
14.1. Increasing Logging Levels to Help with Debugging
You can increase the logging level of orcharhino components to troubleshoot orcharhino.
Increasing the logging level to debug provides the most detailed information.
The default logging level is info.
14.1.1. Increasing the Logging Level for the Foreman Application
To increase logging for the Foreman Application:
Set the logging level to
debug:# foreman-installer --foreman-logging-level debug
For more information about orcharhino logging settings, use foreman-installer with the --full-help option:
14.1.2. Increasing the Logging Level for Hammer
To increase logging for Hammer:
In
/etc/hammer/cli_config.yml, set the:log_level:option todebug:
:log_level: 'debug'
14.1.3. Increasing the Logging Level for orcharhino Proxy
You can find the log in /var/log/foreman-proxy/proxy.log.
To increase logging for orcharhino Proxy:
debug:# foreman-installer --foreman-proxy-log-level DEBUG
Running foreman-installer will revert the setting back to default. |
14.1.4. Increasing the Logging Level for Candlepin
You can find the logs in /var/log/candlepin/candlepin.log and /var/log/candlepin/error.log.
To increase logging for Candlepin:
In
/etc/candlepin/candlepin.conf, set the logging level toDEBUG:log4j.logger.org.candlepin=DEBUG
Restart the
tomcatservice:# systemctl restart tomcat
log4j.logger.org.candlepin.resource.ConsumerResource=WARN log4j.logger.org.candlepin.resource.HypervisorResource=WARN
14.1.5. Increasing the Logging Level For Redis
To increase logging for Redis:
In
/etc/redis.conf, set the logging level todebug:loglevel debug
Restart the Redis service:
# systemctl restart redis
Running foreman-installer will revert the setting to default. |
14.1.6. Increasing the Logging Level For orcharhino Installer
You can find the log files in /var/log/foreman-installer/.
To increase the logging level of the orcharhino installer, add the --verbose-log-level debug option during the installation:
14.1.7. Increasing the Logging Level For Pulp
By default, Pulp logs to syslog.
You can view the log in /var/log/messages or with journalctl.
To increase logging for Pulp:
In
/etc/pulp/settings.py, set the logging level toDEBUG:LOGGING = {"dynaconf_merge": True, "loggers": {'': {'handlers': ['console'], 'level': 'DEBUG'}}} -
Restart the Pulp services:
# systemctl restart \ pulpcore-api \ pulpcore-content \ pulpcore-resource-manager \ pulpcore-worker@1 \ pulpcore-worker@2 \ redis
14.1.8. Increasing the Logging Level For Puppet Agent
To increase logging for Puppet agent:
debug:# foreman-installer --puppet-agent-additional-settings log_level:debug
14.1.9. Increasing the Logging Level For Puppet Server
To increase logging for Puppet server:
debug:# foreman-installer --puppet-server-additional-settings log_level:debug
Restart the Puppet server:
14.2. Configuring Logging Levels with Hammer CLI
You can use Hammer to log debugging information for various orcharhino components.
The default logging level is INFO.
To list the components whose logging level you can change by using
hammer:# hammer admin logging --list
To set
DEBUGlevel logging for all components:# hammer admin logging --all --level-debug # foreman-maintain service restart
To set
PRODUCTIONlevel logging for all components:# hammer admin logging --all --level-production # foreman-maintain service restart
To set
DEBUGlevel logging for a specific component:# hammer admin logging --components My_Component --level-debug # foreman-maintain service restart
To list all available logging options:
# hammer admin logging --help
14.3. Configuring Logging to Journal or File-based Logging
orcharhino uses file-based logging by default.
You can use the foreman-installer command to reconfigure logging.
Enter the following
foreman-installercommand to configure logging to thejournaldservice:# foreman-installer \ --foreman-logging-type journald \ --foreman-proxy-log JOURNAL
Optional: To inspect the log messages, use the
Enter the following
foreman-installercommand to configure file-based logging:# foreman-installer \ --reset-foreman-logging-type \ --reset-foreman-proxy-log
Optional: To inspect the log messages, view these files:
/var/log/foreman-proxy.log
14.4. Selective Debugging with Individual Loggers
14.5. Overview of Individual Loggers
The following list provides an overview of selected loggers.
app-
Default value: true.
audit-
background-
blob-
ImportantThe bloblogger might contain sensitive data. dynflow-
ldap-
Default value: false.
notifications-
permissions-
sql-
telemetry-
templates-
14.6. Retrieving the Status of Services
orcharhino uses a set of back-end services. When troubleshooting, you can check the status of orcharhino services.
In the orcharhino management UI, navigate to Administer > About.
On the Smart Proxies tab, view the status of all orcharhino Proxies.
On the Compute Resources tab, view the status of attached compute resource providers.
In the Backend System Status table, view the status of all back-end services.
Get information from the database and orcharhino services:
# hammer ping
Run
Perform a health check:
Run
14.7. Restarting Services
orcharhino uses a set of back-end services. When troubleshooting, you can restart the services if needed.
Restart orcharhino services:
14.8. Utilities for Processing Log Information
You can collect information from log files to troubleshoot orcharhino.
- orcharhino-debug
The
orcharhino-debugcommand collects configuration and log file data for orcharhino, its back-end services, and system information. This output is stored in a tar file. By default, the tar file is located at/tmp/orcharhino-debug-xxx.tar.xz.Additionally, the
orcharhino-debugcommand exports tasks run during the last 60 days. By default, the output tar file is located at/tmp/task-export-xxx.tar.xz. If the file is missing, see the file/tmp/task-export.logto learn why task export was unsuccessful. There is no timeout when running this command.For more information, run
orcharhino-debug -h.ImportantThe
orcharhino-debugcommand removes security information such as passwords, tokens, and keys while collecting information. However, the tar files can still contain sensitive information about the orcharhino Server. Send the tar files directly to the intended recipient and not to a public target. - foreman-tail
The
foreman-tailcommand displays orcharhino logs in real time.For more information, see the
foreman-tail(8)man page.
14.9. Log File Directories
The following table provides an overview of selected log directories on orcharhino Server:
Subscription management |
Installer |
Foreman maintain |
Foreman proxy |
Foreman |
Apache HTTP server |
Various other log messages |
Puppet |
Candlepin web service logs |
14.10. System Journal Metadata
The following table lists metadata that the journald service uses in orcharhino.
You can use this metadata to filter your queries.
- AUDIT_ACTION
Audit action performed
- AUDIT_TYPE
Audit resource type
- AUDIT_ID
- AUDIT_ATTRIBUTE
- AUDIT_FIELD_OLD
- AUDIT_FIELD_NEW
- AUDIT_ID
- AUDIT_ATTRIBUTE
Example: Name or description
- EXCEPTION_MESSAGE
- EXCEPTION_CLASS
- EXCEPTION_BACKTRACE
- LOC_ID
Location database ID
- LOC_NAME
Location name
- LOC_LABEL
Location label
- LOGGER
Logger name
- ORG_ID
Organization database ID
- ORG_NAME
Organization name
- ORG_LABEL
Organization label
- REMOTE_IP
Remote IP address of a client
- REQUEST
- SESSION
- TEMPLATE_NAME
Template name
- TEMPLATE_DIGEST
- TEMPLATE_HOST_NAME
- TEMPLATE_HOST_ID
- USER_LOGIN
User login name
15. Monitoring Resources
15.1. Using the orcharhino Content Dashboard
The orcharhino content dashboard contains various widgets which provide an overview of the host configuration, Content Views, compliance reports, subscriptions and hosts currently registered, promotions and synchronization, and a list of the latest notifications.
In the orcharhino management UI, navigate to Monitor > Dashboard to access the content dashboard. The dashboard can be rearranged by clicking on a widget and dragging it to a different position. The following widgets are available:
- Host Configuration Status
Table 4. Host Configuration States Icon State Description
Hosts in error state
noopmode.
Out of sync hosts
Hosts with no reports
Hosts with alerts disabled
- Host Configuration Chart
- Latest Events
- New Hosts
- Task Status
- Latest Warning/Error Tasks
- Discovered Hosts
- Latest Errata
A list of all errata available for hosts registered to orcharhino.
- Content Views
A list of all Content Views in orcharhino and their publish status.
- Sync Overview
An overview of all products or repositories enabled in orcharhino and their synchronization status. All products that are in the queue for synchronization, are unsynchronized or have been previously synchronized are listed in this section.
- Host Subscription Status
An overview of the subscriptions currently consumed by the hosts registered to orcharhino. A subscription is a purchased certificate that unlocks access to software, upgrades, and security fixes for hosts. The following table shows the possible states of subscriptions.
Table 5. Host Subscription States Icon State Description
Invalid
Partial
Valid
- Subscription Status
- Host Collections
A list of all host collections in orcharhino and their status, including the number of content hosts in each host collection.
virt-whodaemon running on hosts in the environment. The following table shows the possible states.Table 6. Virt-who Configuration States State Description No Reports
No report has been received because either an error occurred during the virt-who configuration deployment, or the configuration has not been deployed yet, or virt-who cannot connect to orcharhino during the scheduled interval.
No Change
OK
Total Configurations
- Latest Compliance Reports
- Red Hat Insights Actions
Red Hat Insights is a tool embedded in orcharhino that checks the environment and suggests actions you can take. The actions are divided into 4 categories: Availability, Stability, Performance, and Security.
- Red Hat Insights Risk Summary
NoteIt is not possible to change the date format displayed in the orcharhino management UI.
15.1.1. Managing Tasks
orcharhino keeps a complete log of all planned or performed tasks, such as repositories synchronised, errata applied, and Content Views published. To review the log, navigate to Monitor > orcharhino Tasks > Tasks.
Adjusting the %_finish_timeout values might help in case of low bandwidth. Adjusting the %_accept_timeout values might help in case of high latency. |
Click Save.
15.2. Configuring RSS Notifications
To view orcharhino event notification alerts, click the Notifications icon in the upper right of the screen.
By default, the Notifications area displays RSS feed events published in the orcharhino news.
You can configure the RSS feed notifications by changing the URL feed. The supported feed format is RSS 2.0 and Atom.
In the orcharhino management UI, navigate to Administer > Settings and select the Notifications tab.
15.3. Monitoring orcharhino Server
Audit records list the changes made by all users on orcharhino. This information can be used for maintenance and troubleshooting.
In the orcharhino management UI, navigate to Monitor > Audits to view the audit records.
To obtain a list of all the audit attributes, use the following command:
15.4. Monitoring orcharhino Proxy
The following section shows how to use the orcharhino management UI to find orcharhino Proxy information valuable for maintenance and troubleshooting.
15.4.1. Viewing General orcharhino Proxy Information
In the orcharhino management UI, navigate to Infrastructure > orcharhino Proxies to view a table of orcharhino Proxies registered to orcharhino Server. The information contained in the table answers the following questions:
- Is orcharhino Proxy running?
This is indicated by a green icon in the Status column. A red icon indicates an inactive orcharhino Proxy, use the
service foreman-proxy restartcommand on orcharhino Proxy to activate it. - What services are enabled on orcharhino Proxy?
In the Features column you can verify if orcharhino Proxy for example provides a DHCP service or acts as a Pulp mirror. orcharhino Proxy features can be enabled during installation or configured in addition. For more information, see Installing orcharhino Proxy.
- What organizations and locations is orcharhino Proxy assigned to?
A orcharhino Proxy can be assigned to multiple organizations and locations, but only orcharhino Proxies belonging to the currently selected organization are displayed. To list all orcharhino Proxies, select Any Organization from the context menu in the top left corner.
After changing the orcharhino Proxy configuration, select Refresh from the drop-down menu in the Actions column to ensure the orcharhino Proxy table is up to date.
Click the orcharhino Proxy name to view further details. At the Overview tab, you can find the same information as in the orcharhino Proxy table. In addition, you can answer to the following questions:
- Which hosts are managed by orcharhino Proxy?
- How much storage space is available on orcharhino Proxy?
/var/lib/pulpis displayed. Also the remaining storage space available on the orcharhino Proxy can be ascertained.
15.4.2. Monitoring Services
In the orcharhino management UI, navigate to Infrastructure > orcharhino Proxies and click the name of the selected orcharhino Proxy. At the Services tab, you can find basic information on orcharhino Proxy services, such as the list of DNS domains, or the number of Pulp workers. The appearance of the page depends on what services are enabled on orcharhino Proxy. Services providing more detailed status information can have dedicated tabs at the orcharhino Proxy page. For more information, see Monitoring Puppet.
15.4.3. Monitoring Puppet
In the orcharhino management UI, navigate to Infrastructure > orcharhino Proxies and click the name of the selected orcharhino Proxy. At the Puppet tab you can find the following:
A table of CA certificates associated with the orcharhino Proxy at the Certificates sub-tab. Here you can inspect the certificate expiry data, or cancel the certificate by clicking Revoke.
16. Using Webhooks
A webhook is a way for a web page or web application to provide other applications with information in real time. Webhooks are only triggered after an event occurs. The request usually contains details of the event. An event triggers callbacks, such as sending an e-mail confirming a host has been provisioned. Webhooks enable you to define a call to an external API based on orcharhino internal event using a fire-and-forget message exchange pattern. The application sending the request does not wait for the response, or ignores it.
The typical use case for webhooks in orcharhino is making a call to a monitoring system when a host is created or deleted.
Webhooks are useful where the action you want to perform in the external system can be achieved through its API. Where it is necessary to run additional commands or edit files, the shellhooks plugin for orcharhino Proxies is available. The shellhooks plugin enables you to define a shell script on the orcharhino Proxy that can be executed through the API.
16.1. Migrating to Webhooks
Webhooks are processed asynchronously so there is minimal risk of tampering with internals of the system.
It is not possible to migrate from foreman_hooks without creating payloads for each individual webhook script.
However, the webhooks plugin comes with several example payload templates.
You can also use the example payloads with shellhooks to simplify migration.
16.2. Installing Webhooks
Use the following procedure to install webhooks. After installing webhooks, you can configure orcharhino Server to send webhook requests.
Install webhooks using the following command:
Optional: Install the webhooks CLI plug-in:
16.3. Creating a Webhook Template
Webhook templates are used to generate the body of HTTP request to a configured target when a webhook is triggered. Use the following procedure to create a webhook template in the orcharhino management UI.
In the orcharhino management UI, navigate to Administer > Webhook > Webhook Templates.
A webhook HTTP payload must be created using orcharhino template syntax. The webhook template can use a special variable called
@objectthat can represent the main object of the event.@objectcan be missing in case of certain events. You can determine what data are actually available with the@payloadvariable.For more information, see Template Writing Reference in Managing Hosts and for available template macros and methods, visit
/templates_docon orcharhino Server. -
Click Submit.
16.4. Creating a Webhook
You can customize events, payloads, HTTP authentication, content type, and headers through the orcharhino management UI.
Use the following procedure to create a webhook in the orcharhino management UI.
In the orcharhino management UI, navigate to Administer > Webhook > Webhooks.
Click Create new.
Click Template to select a template. Webhook templates are used to generate the body of the HTTP request to orcharhino Server when a webhook is triggered.
Enter an HTTP method.
Click the Credentials tab.
Optional: Uncheck Verify SSL if you do not want to verify the server certificate against the system certificate store or orcharhino CA.
When configuring webhooks with endpoints with non-standard HTTP or HTTPS ports, an SELinux port must be assigned, see Configuring SELinux to Ensure Access to orcharhino on Custom Ports in Installing orcharhino Server.
16.5. Available Webhook Events
The following table contains a list of webhook events that are available from the orcharhino management UI.
A Content View was successfully promoted. |
Actions::Katello::ContentView::Promote |
Actions::Katello::ContentView::Publish |
Run OpenSCAP scan. |
Runs an Ansible playbook containing all the roles defined for a host. |
Actions Remote Execution Run Host Job Ansible Run Capsule Upgrade Succeeded |
Upgrade Capsules on given Capsule server hosts. |
Run an Ansible playbook against given hosts. |
Run an Ansible playbook to enable the web console on given hosts. |
Build Entered |
Custom event: |
Build Exited |
Custom event: |
Common database operations on a Content View. |
Katello::ContentView |
Domain |
Host |
Hostgroup |
Model |
Status Changed |
Custom event: |
Subnet |
Template Render Performed |
Template |
User |
16.6. Shellhooks
With webhooks, you can only map one orcharhino event to one API call. For advanced integrations, where a single shell script can contain multiple commands, you can install a orcharhino Proxy shellhooks plugin that exposes executables using a REST HTTP API.
You can then configure a webhook to reach out to a orcharhino Proxy API to run a predefined shellhook. A shellhook is an executable script that can be written in any language as long as it can be executed. The shellhook can for example contain commands or edit files.
You can pass arguments to shellhook script using HTTP headers in format X-Shellhook-Arg-1 to X-Shellhook-Arg-99.
For more information on passing arguments to shellhook script, see:
The HTTP method must be POST.
An example URL would be: https://orcharhino-proxy.example.com:8443/shellhook/My_Script.
Unlike the |
You must enable orcharhino Proxy Authorization for each webhook connected to a shellhook to enable it to authorize a call.
Standard output and standard error output are redirected to the orcharhino Proxy logs as messages with debug or warning levels respectively.
16.7. Installing the Shellhooks Plugin
Optionally, you can install and enable the shellhooks plugin on each orcharhino Proxy used for shellhooks, using the following command:
16.8. Passing Arguments to Shellhook Script Using Webhooks
16.9. Passing Arguments to Shellhook Script Using Curl
# curl -sX POST -H 'Content-Type: text/plain' \ -H "X-Shellhook-Arg-1: Version 1.0" \ -H "X-Shellhook-Arg-2: My Content View" \ --data "" https://orcharhino-proxy.example.com:8443/shellhook/My_Script
16.10. Creating a Shellhook to Print Arguments
You have the
webhooksandshellhooksplug-ins installed. For more information, see:
Modify the
/var/lib/foreman-proxy/shellhooks/print_argsscript to print arguments to standard error output so you can see them in the orcharhino Proxy logs:#!/bin/sh # # Prints all arguments to stderr # echo "$@" >&2
Click Create new.
In the Target URL field, enter the URL of your orcharhino Proxy followed by
:8443/shellhook/print_args:https://orcharhino-proxy.example.com:8443/shellhook/print_args
Note that
On the Credentials tab, check orcharhino Proxy Authorization.
Click Submit. You now have successfully created a shellhook that prints "Hello World!" to orcharhino Proxy logs every time you a remote execution job succeeds.
timeas a command. For more information, see Executing a Remote Job in Managing Hosts. -
Verify that the shellhook script was triggered and printed "Hello World!" to orcharhino Proxy logs:
17. Searching and Bookmarking
orcharhino features powerful search functionality on most pages of the orcharhino management UI. It enables you to search all kinds of resources that orcharhino manages. Searches accept both free text and syntax-based queries, which can be built using extensive input prediction. Search queries can be saved as bookmarks for future reuse.
17.1. Building Search Queries
17.1.1. Query Syntax
parameter operator value
17.1.2. Query Operators
| Operator | Short Name | Description | Example |
EQUALS |
NOT EQUALS |
LIKE |
NOT LIKE |
GREATER THAN |
LESS THAN |
IN |
NOT IN |
HAS or set? |
NOT HAS or null? |
| Operator | Alternative Notations | Example | ||
and |
<whitespace> |
or |
not |
17.1.3. Query Values
- Text Values
Examples:
hostgroup = "Web servers"The search will return hosts with assigned host group named "Web servers".
hostgroup = Web serversThe search will return hosts in the host group Web with any field matching %servers%.
- Temporal Values
"10 January 2017"
"10 Jan 2017"
10-January-2017
10/January/2017
"January 10, 2017"
Warning
17.2. Using Free Text Search
17.3. Managing Bookmarks
On some pages, there are default bookmarks available for the common searches, for example, all active or disabled hosts.
17.3.1. Creating Bookmarks
In the orcharhino management UI, navigate to the page where you want to create a bookmark.
Ensure the Public checkbox is set correctly:
Select the Public checkbox to set the bookmark as public and visible to all users.
Clear the Public checkbox to set the bookmark as private and only visible to the user who created it.
Click Submit.
17.3.2. Deleting Bookmarks
In the orcharhino management UI, navigate to Administer > Bookmarks.
This section contains information about settings that you can edit in the orcharhino management UI by navigating to Administer > Settings.
A.1. General Settings
Administrator email address |
orcharhino URL |
URL where your orcharhino instance is reachable. See also Provisioning > Unattended URL. |
Entries per page |
20 |
Number of records shown per page in orcharhino |
Fix DB cache |
No |
orcharhino maintains a cache of permissions and roles.
When set to |
DB pending seed |
No |
Should the |
orcharhino Proxy request timeout |
60 |
Open and read timeout for HTTP requests from orcharhino to orcharhino Proxy (in seconds). |
Login page footer text |
HTTP(S) proxy |
Set a proxy for outgoing HTTP(S) connections from the orcharhino product. System-wide proxies must be configured at the operating system level. |
HTTP(S) proxy except hosts |
Show Experimental Labs |
No |
Display FQDN for hosts |
Yes |
If set to |
Out of sync interval |
30 |
Managed hosts report periodically, and if the time between reports exceeds this duration in minutes, hosts are considered out of sync.
orcharhino UUID |
orcharhino instance ID. Uniquely identifies a orcharhino instance. |
Default language |
Default timezone |
The timezone to use for new users. |
Instance title |
Saved audits interval |
New host details UI |
Yes |
orcharhino loads the new UI for host details. |
A.2. Tasks settings
Sync task timeout |
120 |
Enable dynflow console |
Yes |
Enable the dynflow console ( |
Yes |
The user must be authenticated as having administrative rights before accessing the dynflow console. |
Proxy action retry count |
4 |
Number of attempts permitted to start a task on the orcharhino Proxy before failing. |
Proxy action retry interval |
15 |
Allow proxy batch tasks |
Yes |
Allow triggering tasks on the orcharhino Proxy in batches. |
Proxy tasks batch size |
100 |
Number of tasks included in one request to the orcharhino Proxy if |
Tasks troubleshooting URL |
It should contain a |
1 |
A.3. Template Sync Settings
Associate |
New |
Associate templates with OS, organization and location. |
Branch |
Default branch in Git repo. |
Commit message |
Templates export made by a orcharhino user |
Dirname |
Filter |
Force import |
No |
If set to |
Lock templates |
Keep, do not lock new |
Metadata export mode |
Refresh |
Negate |
No |
Prefix |
Repo |
When exporting to |
Verbosity |
No |
A.4. Discovery Settings
Discovery location |
Discovery organization |
Interface fact |
discovery_bootif |
Create bond interfaces |
No |
Clean all facts |
No |
Hostname facts |
discovery_bootif |
Auto provisioning |
No |
Reboot |
Yes |
Hostname prefix |
mac |
Fact columns |
Highlighted facts |
Storage facts |
Software facts |
Hardware facts |
Network facts |
IPMI facts |
Lock PXE |
No |
pxelinux_discovery |
Locked PXEGrub template name |
pxegrub_discovery |
PXEGrub template to be used when pinning a host to discovery. |
pxegrub2_discovery |
Force DNS |
Yes |
Error on existing NIC |
No |
Do not permit to discover an existing managed host matching the MAC of a provisioning Network Interface Card (NIC) (errors out early). |
Type of name generator |
Fact + prefix |
Prefer IPv6 |
No |
A.5. Boot Disk Settings
iPXE directory |
ISOLINUX directory |
SYSLINUX directory |
Grub2 directory |
Host image template |
Boot disk iPXE - host |
Generic image template |
ISO generation command |
genisoimage |
Installation media caching |
Yes |
Allowed bootdisk types |
A.6. Red Hat Cloud Settings
Automatic inventory upload |
Yes |
Enable automatic upload of your host inventory to the Red Hat cloud. |
Synchronize recommendations Automatically |
No |
Enable automatic synchronization of Insights recommendations from the Red Hat cloud. |
Obfuscate host names |
No |
Obfuscate hostnames sent to the Red Hat cloud. |
Obfuscate host ipv4 addresses |
No |
Obfuscate IPv4 addresses sent to the Red Hat cloud. |
ID of the RHC daemon |
RHC daemon id. |
A.7. Content Settings
Default HTTP Proxy |
CDN SSL version |
SSL version used to communicate with the CDN. |
Kickstart default |
Kickstart default finish |
Default synced OS user-data |
Kickstart default user data |
Kickstart default PXELinux |
Default synced OS PXEGrub template |
Kickstart default PXEGrub |
Default PXEGrub template for new operating systems created from synced content. |
Kickstart default PXEGrub2 |
Kickstart default iPXE |
Kickstart default |
Discovery ATIX AG kexec |
Atomic Kickstart default |
Manifest refresh timeout |
1200 |
Yes |
Can communicate with the ATIX AG Portal for subscriptions. |
No |
Calculate errata host status based only on errata in a host’s Content View and Lifecycle Environment. |
No |
Yes |
100 |
How many repositories should be synced concurrently on a orcharhino Proxy. A smaller number may lead to longer sync times. A larger number will increase dynflow load. |
Sync orcharhino Proxies after Content View promotion |
Yes |
Whether or not to auto sync orcharhino Proxies after a Content View promotion. |
Either |
Default ATIX AG Repository download policy |
Default download policy for enabled ATIX AG repositories.
Either |
Default orcharhino Proxy download policy |
Default download policy for orcharhino Proxy syncs.
Either |
Pulp export destination filepath |
On-disk location for exported repositories. |
Pulp client key |
Pulp client cert |
Sync Connection Timeout |
300 |
Delete Host upon unregister |
No |
No |
If this is enabled, and |
Default Location |
Expire soon days |
120 |
No |
Host Duplicate DMI UUIDs |
Host Profile Assume |
Yes |
Enable new host registrations to assume registered profiles with matching hostname as long as the registering DMI UUID is not used by another host. |
No |
Enable host registrations to bypass Host Profile Assume as long as the host is in build mode. |
No |
5 |
Applicability Batch Size |
50 |
Autosearch |
Yes |
Autosearch delay |
500 |
Pulp bulk load size |
2000 |
Yes |
1440 |
No |
Yes |
Enable removal of repositories that the user has previously published in one or more Content View versions. |
A.8. Authentication Settings
OAuth active |
Yes |
orcharhino will use OAuth for API authorization. |
OAuth consumer key |
OAuth consumer key. |
OAuth consumer secret |
OAuth consumer secret. |
OAuth map users |
No |
orcharhino maps users by username in the request-header. If this is disabled, OAuth requests have administrator rights. |
Failed login attempts limit |
30 |
orcharhino blocks user logins from an incoming IP address for 5 minutes after the specified number of failed login attempts. Set to 0 to disable brute force protection. |
Restrict registered orcharhino Proxies |
Yes |
Only known orcharhino Proxies can access features that use orcharhino Proxy authentication. |
Trusted hosts |
List of hostnames, IPv4, IPv6 addresses or subnets to be trusted in addition to orcharhino Proxies for access to fact/report importers and ENC output. |
SSL certificate |
SSL Certificate path that orcharhino uses to communicate with its proxies. |
SSL CA file |
SSL CA file path that orcharhino uses to communicate with its proxies. |
SSL private key |
SSL Private Key path that orcharhino uses to communicate with its proxies. |
SSL client DN env |
HTTP_SSL_CLIENT_S_DN |
SSL client verify env |
HTTP_SSL_CLIENT_VERIFY |
SSL client cert env |
HTTP_SSL_CLIENT_CERT |
Server CA file |
SSL CA file path used in templates to verify the connection to orcharhino. |
Websockets SSL key |
Private key file path that orcharhino uses to encrypt websockets. |
Websockets SSL certificate |
Certificate path that orcharhino uses to encrypt websockets. |
Websockets encryption |
Yes |
Login delegation logout URL |
External |
Authorize login delegation |
No |
No |
Idle timeout |
60 |
BCrypt password cost |
9 |
BMC credentials access |
Yes |
OIDC JWKs URL |
Typically |
OIDC Audience |
OIDC Issuer |
OIDC Algorithm |
A.9. Email Settings
Email reply address |
Email reply address for emails that orcharhino is sending. |
Email subject prefix |
Send welcome email |
No |
Delivery method |
Sendmail |
SMTP enable StartTLS auto |
Yes |
SMTP OpenSSL verify mode |
Default verification mode |
SMTP address |
SMTP address to connect to. |
SMTP port |
25 |
SMTP port to connect to. |
SMTP HELO/EHLO domain |
HELO/EHLO domain. |
SMTP username |
SMTP password |
SMTP authentication |
none |
Sendmail arguments |
-i |
Sendmail location |
A.10. Notifications Settings
RSS enable |
Yes |
Pull RSS notifications. |
RSS URL |
A.11. Provisioning Settings
Host owner |
Default owner on provisioned hosts, if empty orcharhino uses the current user. |
Root password |
Unattended URL |
Safemode rendering |
No |
Query local nameservers |
No |
orcharhino queries the locally configured resolver instead of the SOA/NS authorities. |
Installation token lifetime |
360 |
SSH timeout |
120 |
0.0.0.0 |
No |
orcharhino updates the host IP with the IP that made the build request. |
Use short name for VMs |
No |
orcharhino uses the short hostname instead of the FQDN for creating new virtual machines. |
DNS timeout |
[5, 10, 15, 20] |
Clean up failed deployment |
Yes |
orcharhino deletes the virtual machine if the provisioning script ends with a non-zero exit code. |
iPXE intermediate script |
No |
Destroy associated VM on host delete. When enabled, VMs linked to hosts are deleted on Compute Resource. When disabled, VMs are unlinked when the host is deleted, meaning they remain on Compute Resource and can be re-associated or imported back to orcharhino again. This does not automatically power off the VM |
Maximum structured facts |
100 |
Global Registration |
CoreOS Transpiler Command |
PXEGrub2 global default |
PXELinux global default |
Global default PXEGrub template |
PXEGrub global default |
Global default PXEGrub template. This template is deployed to all configured TFTP servers. It is not affected by upgrades. |
iPXE global default |
PXEGrub2 default local boot |
PXELinux default local boot |
Local boot PXEGrub template |
PXEGrub default local boot |
Template that is selected as PXEGrub default for local boot. |
Local boot iPXE template |
iPXE default local boot |
Manage PuppetCA |
Yes |
orcharhino automates certificate signing upon provision of a new host. |
Use UUID for certificates |
No |
orcharhino uses random UUIDs for certificate signing instead of hostnames. |
A.12. Facts Settings
Yes |
orcharhino creates the host when new facts are received. |
Location fact |
orcharhino_location |
Organization fact |
orcharhino_organization |
Default location |
Default Location |
Default organization |
Default Organization |
Update hostgroup from facts |
Yes |
orcharhino updates a host’s hostgroup from its facts. |
No |
Ignore facts for domain |
No |
Update subnets from facts |
None |
orcharhino updates a host’s subnet from its facts. |
No |
Exclude pattern for facts stored in orcharhino |
Those facts are not stored in the orcharhino database.
Default Puppet environment |
production |
orcharhino defaults to this puppet environment if it cannot auto detect one. |
ENC environment |
Yes |
orcharhino explicitly sets the puppet environment in the ENC yaml output.
No |
orcharhino updates a host’s environment from its facts. |
A.13. Configuration Management Settings
Yes |
orcharhino creates the host when a report is received. |
Matchers inheritance |
Yes |
orcharhino matchers are inherited by children when evaluating smart class parameters for hostgroups, organizations, and locations. |
orcharhino evaluates host smart class parameters in this order by default. |
Yes |
orcharhino parses ERB in parameters value in the ENC output. |
No |
All hosts show a configuration status even when a Puppet orcharhino Proxy is not assigned. |
Puppet interval |
35 |
Puppet out of sync disabled |
No |
A.14. Remote Execution Settings
Fallback to Any Proxy |
No |
Enable Global Proxy |
Yes |
SSH User |
root |
Default user to use for SSH.
Effective User |
root |
Effective User Method |
sudo |
One of [ |
Effective user password |
Sync Job Templates |
Yes |
SSH Port |
22 |
Default port 22.
Connect by IP |
No |
Prefer IPv6 over IPv4 |
No |
Default SSH password |
Default SSH key passphrase |
Workers pool size |
5 |
Restart of the |
Cleanup working directories |
Yes |
Cockpit URL |
Form Job Template |
Run Command - SSH Default |
Time to pickup |
86400 |
Time in seconds within which the host has to pick up a job. If the job is not picked up within this limit, the job will be cancelled. Applies only to pull-mqtt based jobs. Defaults to one day. |
A.15. Ansible Settings
Private Key Path |
Override with the |
Connection type |
ssh |
Use this connection type by default when running Ansible playbooks.
WinRM cert Validation |
validate |
Enable or disable WinRM server certificate validation when running Ansible playbooks.
Default verbosity level |
Disabled |
orcharhino adds this level of verbosity for additional debugging output when running Ansible playbooks. |
Post-provision timeout |
360 |
Timeout (in seconds) to set when orcharhino triggers an Ansible roles task playbook after a host is fully provisioned. Set this to the maximum time you expect a host to take until it is ready after a reboot. |
Ansible report timeout |
30 |
No |
Ansible - Ansible Inventory |
orcharhino uses this template to schedule the report with Ansible inventory. |
Ansible roles to ignore |
The roles to exclude when importing roles from orcharhino Proxy.
For example: |
Number of tasks which should be sent to the orcharhino Proxy in one request if |
