1. Accessing Foreman
1.1. Importing the Katello Root CA Certificate
The first time you log in to Foreman, you might see a warning informing you that you are using the default self-signed certificate and you might not be able to connect this browser to Foreman until the root CA certificate is imported in the browser. Use the following procedure to locate the root CA certificate on Foreman and to import it into your browser.
To use the CLI instead of the Foreman web UI, see CLI Procedure.
Prerequisite
  • Your Foreman is installed and configured.
  1. Identify the fully qualified domain name of your Foreman server:
    # hostname -f
  2. Access the pub directory on your Foreman server using a web browser pointed to the fully qualified domain name:
    https://foreman.example.com/pub
  3. When you access Foreman for the first time, an untrusted connection warning displays in your web browser. Accept the self-signed certificate and add the Foreman URL as a security exception to override the settings. This procedure might differ depending on the browser being used. Ensure that the Foreman URL is valid before you accept the security exception.
  4. Select katello-server-ca.crt.
  5. Import the certificate into your browser as a certificate authority and trust it to identify websites.
CLI procedure
  1. From the Foreman CLI, copy the katello-server-ca.crt file to the machine you use to access the Foreman web UI:
    # scp /var/www/html/pub/katello-server-ca.crt username@hostname:remotefile
  2. In the browser, import the katello-server-ca.crt certificate as a certificate authority and trust it to identify websites.
1.2. Logging in to Foreman
Use the web user interface to log in to Foreman for further configuration.
Prerequisite
  2. Enter the user name and password created during the configuration process. If a user was not created during the configuration process, the default user name is admin. If you have problems logging in, you can reset the password. For more information, see Resetting the Administrative User Password.
1.3. Using FreeIPA credentials to log in to the Foreman Hammer CLI
This section describes how to log in to your Foreman Hammer CLI with your FreeIPA (IdM) login and password.
  • You have enrolled your Foreman server into FreeIPA and configured it to use FreeIPA for authentication. More specifically, you have enabled access both to the Foreman web UI and the Foreman API. For more information, see Using FreeIPA in Installing Foreman Server with Katello 4.9 Plugin on CentOS/RHEL.
  • The host on which you run this procedure is configured to use FreeIPA credentials to log users in to your Foreman Hammer CLI. For more information, see Configuring the Hammer CLI to Use FreeIPA User Authentication in Installing Foreman Server with Katello 4.9 Plugin on CentOS/RHEL.
  • The host is an FreeIPA client.
  • An FreeIPA server is running and reachable by the host.
  1. Obtain a Kerberos ticket-granting ticket (TGT) on behalf of a Foreman user:
    $ kinit idm_user
    Warning
    If, when you were setting FreeIPA to be the authentication provider, you enabled access to both the Foreman API and the Foreman web UI, an attacker can now obtain an API session after the user receives the Kerberos TGT. The attack is possible even if the user did not previously enter the Foreman login credentials anywhere, for example in the browser.
  2. If automatic negotiate authentication is not enabled, use the TGT to authenticate to Hammer manually:
    $ hammer auth login negotiate
  3. Optional: Destroy all cached Kerberos tickets in the collection:
    $ kdestroy -A
  • Use any hammer command to ensure that the system does not ask you to authenticate again:
    $ hammer host list
To log out of Hammer, enter: hammer auth logout.
1.4. Using FreeIPA credentials to log in to the Foreman web UI with a Firefox browser
This section describes how to use the Firefox browser to log in to your Foreman web UI with your FreeIPA (IdM) login and password.
  • You have enrolled your Foreman server into FreeIPA and configured the server to use FreeIPA for authentication. For more information, see Using FreeIPA in Installing Foreman Server with Katello 4.9 Plugin on CentOS/RHEL.
  • The host on which you are using a Firefox browser to log in to the Foreman web UI is an FreeIPA client.
  • You have a valid FreeIPA login and password.
  • Foreman community recommends using the latest stable Firefox browser.
  • Your Firefox browser is configured for Single Sign-On (SSO).
  1. Obtain the Kerberos ticket granting ticket (TGT) for yourself using your FreeIPA credentials:
    $ kinit idm_user
    Password for idm_user@EXAMPLE.COM:
  2. In your browser address bar, enter the URL of your Foreman server.
Alternatively, you can skip the first two steps and enter your login and password in the fields displayed on the Foreman web UI. This is also the only option if the host from which you are accessing the Foreman web UI is not an FreeIPA client.
1.5. Using FreeIPA credentials to log in to the Foreman web UI with a Chrome browser
This section describes how to use a Chrome browser to log in to your Foreman web UI with your FreeIPA login and password.
  • The host on which you are using the Chrome browser to log in to the Foreman web UI is an FreeIPA client.
  • Foreman community recommends using the latest stable Chrome browser.
  1. Enable the Chrome browser to use Kerberos authentication:
    Instead of allowlisting the whole domain, you can also allowlist a specific Foreman server.
  2. Obtain the Kerberos ticket-granting ticket (TGT) for yourself using your FreeIPA credentials:
    $ kinit idm_user
    Password for idm_user@_EXAMPLE.COM:
  3. In your browser address bar, enter the URL of your Foreman server.
Alternatively, you can skip the first three steps and enter your login and password in the fields displayed on the Foreman web UI. This is also the only option if the host from which you are accessing the Foreman web UI is not an FreeIPA client.
Navigation Tabs Description
Any Context
Monitor
Content
Provides content management tools. This includes Content Views, Activation Keys, and Lifecycle Environments.
Hosts
Configure
Infrastructure
User Name
notification bell
Administer
1.7. Changing the Password
  1. In the Foreman web UI, click your user name at the top right corner.
  6. Click Submit to save your new password.
1.8. Resetting the Administrative User Password
  1. Log in to the base operating system where Foreman server is installed.
1.9. Setting a Custom Message on the Login Page
  3. Click Save.
Foreman provides the foreman-maintain service command to manage Foreman services from the command line. This is useful when creating a backup of Foreman. For more information on creating backups, see Backing Up Foreman server and Smart Proxy Server.
3. Tuning Foreman server with Predefined Profiles
If your Foreman deployment includes more than 5000 hosts, you can use predefined tuning profiles to improve performance of Foreman.
Note that you cannot use tuning profiles on Smart Proxies.
You can choose one of the profiles depending on the number of hosts your Foreman manages and available hardware resources.
When you run the foreman-installer command with the --tuning option, deployment configuration settings are applied to Foreman in the following order:
  1. The default tuning profile defined in the /usr/share/foreman-installer/config/foreman.hiera/tuning/common.yaml file
  2. The tuning profile that you want to apply to your deployment and is defined in the /usr/share/foreman-installer/config/foreman.hiera/tuning/sizes/ directory
  3. Optional: If you have configured a /etc/foreman-installer/custom-hiera.yaml file, Foreman applies these configuration settings.
default
Number of managed hosts: 0 – 5000
RAM: 20G
Number of CPU cores: 4
medium
Number of managed hosts: 5001 – 10000
RAM: 32G
Number of CPU cores: 8
large
Number of managed hosts: 10001 – 20000
RAM: 64G
Number of CPU cores: 16
extra-large
Number of managed hosts: 20001 – 60000
RAM: 128G
Number of CPU cores: 32
extra-extra-large
Number of managed hosts: 60000+
RAM: 256G
Number of CPU cores: 48+
  1. Optional: If you have configured the custom-hiera.yaml file on Foreman server, back up the /etc/foreman-installer/custom-hiera.yaml file to custom-hiera.original. You can use the backup file to restore the /etc/foreman-installer/custom-hiera.yaml file to its original state if it becomes corrupted:
    # cp /etc/foreman-installer/custom-hiera.yaml \
    /etc/foreman-installer/custom-hiera.original
  2. Optional: If you have configured the custom-hiera.yaml file on Foreman server, review the definitions of the default tuning profile in /usr/share/foreman-installer/config/foreman.hiera/tuning/common.yaml and the tuning profile that you want to apply in /usr/share/foreman-installer/config/foreman.hiera/tuning/sizes/. Compare the configuration entries against the entries in your /etc/foreman-installer/custom-hiera.yaml file and remove any duplicated configuration settings in your /etc/foreman-installer/custom-hiera.yaml file.
  3. Enter the foreman-installer command with the --tuning option for the profile that you want to apply. For example, to apply the medium tuning profile settings, enter the following command:
4. Migrating from Internal Foreman Databases to External Databases
  1. Preparing a Host for External Databases. Prepare a Red Hat Enterprise Linux 8 server to host the external databases.
4.1. PostgreSQL as an External Database Considerations
Foreman, Katello, and Candlepin use the PostgreSQL database. If you want to use PostgreSQL as an external database, the following information can help you decide if this option is right for your Foreman configuration. Foreman supports PostgreSQL version 12.
Advantages of External PostgreSQL
4.2. Preparing a Host for External Databases
Prerequisite
    --enable=rhel-8-for-x86_64-baseos-rpms \
    --enable=rhel-8-for-x86_64-appstream-rpms
  3. Install the katello-repos-latest.rpm package
    # dnf install https://yum.theforeman.org/releases/3.7/el8/x86_64/foreman-release.rpm \
    https://yum.theforeman.org/katello/4.9/katello/el8/x86_64/katello-repos-latest.rpm
  4. Enable the following modules:
    # dnf module enable katello:el8 pulpcore:el8
    Enablement of the module katello:el8 warns about a conflict with postgresql:10 and ruby:2.5 as these modules are set to the default module versions on Enterprise Linux 8. The module katello:el8 has a dependency for the modules postgresql:12 and ruby:2.7 that will be enabled with the katello:el8 module. These warnings do not cause installation process failure, hence can be ignored safely.
4.3. Installing PostgreSQL
You can install only the same version of PostgreSQL that is installed with the foreman-installer tool during an internal database installation. Foreman supports PostgreSQL version 12.
    # dnf install postgresql-server postgresql-evr postgresql-contrib
    # postgresql-setup initdb
    • max_connections: 500
    • shared_buffers: 512MB
    • work_mem: 4MB
    listen_addresses = '*'
  5. Edit the /var/lib/pgsql/data/pg_hba.conf file:
    $ su - postgres -c psql
  10. Create three databases and dedicated roles: one for Foreman, one for Candlepin, and one for Pulp:
  11. Connect to the Pulp database:
    postgres=# \c pulpcore
    You are now connected to database "pulpcore" as user "postgres".
  12. Create the hstore extension:
    pulpcore=# CREATE EXTENSION IF NOT EXISTS "hstore";
    CREATE EXTENSION
  13. Exit the postgres user:
    # \q
  14. From Foreman server, test that you can access the database. If the connection succeeds, the commands return 1.
4.4. Migrating to External Databases
Prerequisite
  • You have installed and configured a PostgreSQL server on a Enterprise Linux server.
  1. On Foreman server, stop Foreman services:
    # systemctl start postgresql
    # foreman-maintain backup online \
    --preserve-directory \
    --skip-pulp-content \
    /var/migration_backup
    # foreman-installer --scenario katello \
    --foreman-db-manage false \
    --foreman-proxy-content-pulpcore-postgresql-user pulp \
    --katello-candlepin-manage-db false
5. Managing Foreman with Ansible Collections
5.1. Installing the Foreman Ansible Modules
5.2. Viewing the Foreman Ansible Modules
All modules are in the theforeman.foreman namespace and can be referred to in the format theforeman.foreman.module_name. For example, to display information about the activation_key module, enter the following command:
6. Preparing for disaster recovery and recovering from data loss
How do I back up?
How do I back up?
Store the following critical data on network attached storage: content in /var/lib/pulp and database in /var/lib/pgsql. Replicate this storage into a different data center. Attach the storage to a Foreman server that is a clone of the primary Foreman server but runs passively.
How do I back up?
Dual active Foreman server
How do I back up?
To minimize downtime, you can automate the recovery in various ways. For example, you can use the Foreman Ansible collection. For more information, see Managing Foreman with Ansible in Administering Foreman.
6.2. Disaster recovery by virtualizing your Foreman server
6.2.1. Prerequisites
6.2.2. Preparing for disaster recovery by virtualizing your Foreman server
  3. To verify that you will be able to restore Foreman services in case of a disaster, assess the functionality of the test Foreman server. See Retrieving the Status of Services.
6.2.3. Recovering from disaster by restoring a VM snapshot of Foreman server
6.2.4. Retrieving the Status of Services
Foreman uses a set of back-end services. When troubleshooting, you can check the status of Foreman services.
  • In the Foreman web UI, navigate to Administer > About.
    • On the Smart Proxies tab, view the status of all Smart Proxies.
    • On the Compute Resources tab, view the status of attached compute resource providers.
    • In the Backend System Status table, view the status of all back-end services.
CLI procedure
    # hammer ping
  • Perform a health check:
6.3. Disaster recovery for active and passive Foreman server with external storage
6.3.1. Prerequisites
6.3.2. Preparing for disaster recovery with active and passive Foreman server with external storage
  2. Back up your active Foreman server and restore it on a system that will serve as your passive Foreman server. For more information, see Backing Up Foreman server and Smart Proxy Server and Restoring Foreman server or Smart Proxy Server from a Backup.
  4. Assess the functionality of the test Foreman server. For more information, see Retrieving the Status of Services.
6.3.3. Recovering from disaster with active and passive server with external storage
  5. Assess the functionality of your new active Foreman server. For more information, see Retrieving the Status of Services.
6.3.4. Retrieving the Status of Services
CLI procedure
    # hammer ping
6.4. Disaster recovery for active and passive Foreman server with backup and restore
6.4.1. Prerequisites
6.4.2. Preparing for disaster recovery with active and passive Foreman server and backup and restore
  1. Define a schedule for periodic offline backups of your active Foreman server. Consider your tolerance for potential data loss and your storage options: Taking backups frequently will result in smaller amounts of data loss in case of a disaster, but backups require a significant amount of storage space. For information about the size of Foreman backups, see Estimating the Size of a Backup.
    You can combine full backups with incremental backups. For an example of a cron job that ensures regular backups, see Example of a Weekly Full Backup Followed by Daily Incremental Backups.
  2. Schedule periodic offline backups of your active Foreman server to be taken according to the schedule you defined. For information about performing backups, see Backing Up Foreman server and Smart Proxy Server.
  3. Ensure that the backup directories are encrypted and regularly synchronized to a secure location. By default, Foreman stores the backups in the /var/foreman-backup directory.
    Foreman server backups contain sensitive information from the /root/ssl-build directory. For example, they can contain hostnames, ssh keys, request files, and SSL certificates. Encrypting or moving the backups to a secure location helps minimize the risk of damage or unauthorized access to the hosts.
  4. Restore the most recent backup on a system that will serve as your passive Foreman server. For information about restoring backups, see Restoring Foreman server or Smart Proxy Server from a Backup.
    3. Assess the functionality of the test Foreman server. For more information, see Retrieving the Status of Services.
6.4.3. Recovering from disaster with active and passive server and backup and restore
  3. Assess the functionality of your new active Foreman server. For more information, see Retrieving the Status of Services.
6.4.4. Retrieving the Status of Services
CLI procedure
    # hammer ping
6.4.5. Example of a Weekly Full Backup Followed by Daily Incremental Backups
#!/bin/bash -e
else
fi
exit 0
6.5. Disaster recovery with two active Foreman servers
6.5.1. Prerequisites
6.5.2. Preparing for disaster recovery with two active Foreman servers
  1. Back up your Foreman server. For more information, see Backing Up Foreman server and Smart Proxy Server.
  2. Restore the backup on a system that will serve as your other Foreman server. For more information, see Restoring Foreman server or Smart Proxy Server from a Backup.
  5. Automate running the foreman-maintain health check command on both servers. The health check verifies whether the servers remain fully operational.
  2. Verify that your foreman-maintain health check automation reported an error.
6.5.3. Recovering from disaster with two active Foreman servers
If the health checks implemented in Preparing for disaster recovery with two active Foreman servers report an issue on one of your Foreman servers, it might mean that the server has failed. If the server is down, you must re-register hosts to the other server.
  2. If foreman-maintain health check reported a problem, ensure that the server is powered off.
  • Ansible playbooks can help you automate failover, re-registration, and synchronization. For more information, see Managing Foreman with Ansible in Administering Foreman.
7. Managing Users and Roles
7.1. Managing Users
7.1.1. Creating a User
  2. Click Create User.
      • INTERNAL: to enable the user to be managed inside Foreman server.
      • EXTERNAL: to configure external authentication as described in Configuring External Authentication in Installing Foreman Server with Katello 4.9 Plugin on CentOS/RHEL.
CLI procedure
    # hammer user create \
    --login My_User_Name \
    --mail My_User_Mail \
    --password My_User_Password
7.1.2. Assigning Roles to a User
  7. Click Submit.
CLI procedure
7.1.3. Impersonating a Different User Account
7.1.4. Creating an API-Only User
Prerequisite
    # openssl rand -hex 32
7.2. Managing SSH Keys
For information on SSH keys and SSH key creation, see Using SSH-based Authentication in Red Hat Enterprise Linux 8 Configuring basic system settings.
7.2.1. Managing SSH Keys for a User
  3. Click on the SSH Keys tab.
    • To Add SSH key
      2. Click Add SSH Key.
      5. Click Submit.
    • To Remove SSH key
CLI procedure
    # hammer user ssh-keys add \
    --user-id user_id \
    --name key_name \
    --key-file ~/.ssh/id_rsa.pub
    --user-id user_id \
    --name key_name \
7.3. Managing Personal Access Tokens
7.3.1. Creating a Personal Access Token
    {"foreman_version":"3.7.0","result":"ok","status":200,"version":"3.5.1.10","api_version":2}
7.3.2. Revoking a Personal Access Token
7.4. Creating and Managing User Groups
7.4.1. User Groups
With Foreman, you can assign permissions to groups of users. You can also create user groups as collections of other user groups. If using an external authentication source, you can map Foreman user groups to external user groups as described in Configuring External User Groups in Installing Foreman Server with Katello 4.9 Plugin on CentOS/RHEL.
7.4.2. Creating a User Group
  2. Click Create User group.
  5. Click Submit.
CLI procedure
    # hammer user-group create \
    --name My_User_Group_Name \
7.4.3. Removing a User Group
7.5. Creating and Managing Roles
7.5.1. Creating a Role
  2. Click Create Role.
CLI procedure
7.5.2. Cloning a Role
7.5.3. Adding Permissions to a Role
  5. Depending on the Resource type selected, you can select or deselect the Unlimited and Override checkbox. The Unlimited checkbox is selected by default, which means that the permission is applied on all resources of the selected type. When you disable the Unlimited checkbox, the Search field activates. In this field you can specify further filtering with use of the Foreman search syntax. For more information, see Granular Permission Filtering. When you enable the Override checkbox, you can add additional locations and organizations to allow the role to access the resource type in the additional locations and organizations; you can also remove an already associated location and organization from the resource type to restrict access.
  6. Click Next.
CLI procedure
  2. Add permissions to a role:
    # hammer filter create \
    --role My_Role_Name
7.5.4. Viewing Permissions of a Role
7.5.5. Creating a Complete Permission Table
    # dnf install foreman-console
  1. Start the Foreman console with the following command:
    # foreman-rake console
    end.join("\n")
    f.write(result)
    </table>
7.5.6. Removing a Role
7.6. Predefined Roles Available in Foreman
For a complete set of predefined roles and the permissions they grant, log in to Foreman web UI as the privileged user and navigate to Administer > Roles. For more information, see Viewing Permissions of a Role.
Predefined role Permissions the role provides Additional information
Auditor
View the Audit log.
Default role
View tasks and jobs invocations.
Foreman automatically assigns this role to every user in the system.
Manager
Organization admin
Site manager
View permissions for various items.
Permissions to manage hosts in the infrastructure.
System admin
Edit global settings in Administer > Settings.
View, create, edit, and destroy users, user groups, and roles.
View, create, edit, destroy, and assign organizations and locations but not view resources within them.
Users with this role can create users and assign all roles to them. Give this role only to trusted users.
Viewer
View the configuration of every element of the Foreman structure, logs, reports, and statistics.
7.7. Granular Permission Filtering
7.7.1. Creating a Granular Permission Filter
field_name operator value
CLI procedure
    --permission-ids 91 \
    --search "name ~ ccv*" \
    --role qa-user
7.7.2. Examples of Using Granular Permission Filters
hostgroup = host-editors
name ^ (XXXX, Yyyy, zzzz)
Dev
7.7.3. Supported Operators for Granular Search
Table 1. Logical Operators
Operator
and
Combines search criteria.
not
Negates an expression.
has
Table 2. Symbolic Operators
Operator
8. Configuring Email Notifications
Foreman server does not enable outgoing emails by default, therefore you must review your email configuration. For more information, see Configuring Foreman server for Outgoing Emails in Installing Foreman Server with Katello 4.9 Plugin on CentOS/RHEL.
8.1. Email Notification Types
  • Compliance policy summary: A summary of OpenSCAP policy reports and their results.
8.2. Configuring Email Notification Preferences
  6. Click Submit.
8.3. Testing Email Delivery
  2. Click on the username.
    # systemctl start postfix
8.4. Testing Email Notifications
  • daily
  • weekly
  • monthly
8.5. Changing Email Notification Settings for a Host
9. Backing Up Foreman server and Smart Proxy Server
Conventional Backup Methods
You can also use conventional backup methods. For more information, see Recovering and restoring a system in Red Hat Enterprise Linux 8 Configuring basic system settings.
9.1. Estimating the Size of a Backup
    100G    /var/lib/pgsql/data
    100G	/var/lib/pulp
    886M  /var/lib/qpidd
    16M   /var/lib/tftpboot
    37M   /etc
    900K  /root/ssl-build
    100K  /var/www/html/pub
    2M    /opt/puppetlabs
    942M  total
    Table 3. Backup Data Compression Ratio
    PostgreSQL database files
    /var/lib/pgsql/data
    80 – 85%
    100 GB → 20 GB
    Pulp RPM files
    /var/lib/pulp
    (not compressed)
    100 GB
    Configuration files
    /var/lib/qpidd
    /var/lib/tftpboot
    /etc
    /root/ssl-build
    /var/www/html/pub
    /opt/puppetlabs
    85%
    942 MB → 141 MB
9.2. Performing a Full Backup of Foreman server or Smart Proxy Server
  • Offline backup
  • Online backup
  • Snapshot backups
Offline backups
Online backups
Snapshots backups
Directory creation
  • foreman-backup on Foreman
Remote databases
Backing up to a remote NFS share
To enable Foreman to save the backup to an NFS share, ensure that the root user of your Foreman server or Smart Proxy server can write to the NFS share. NFS export options such as root_squash and all_squash are known to prevent this.
Warning
9.3. Performing a Backup without Pulp Content
Warning
9.4. Performing an Incremental Backup
Warning
9.5. Example of a Weekly Full Backup Followed by Daily Incremental Backups
#!/bin/bash -e
else
fi
exit 0
9.6. Performing an Online Backup
Warning
9.7. Performing a Snapshot Backup
# foreman-maintain backup snapshot -h
Warning
  • The system uses LVM for the directories that you snapshot: /var/lib/pulp/ and /var/lib/pgsql.
9.8. White-listing and Skipping Steps When Performing Backups
    # foreman-maintain backup online \
    --whitelist backup-metadata \
10. Restoring Foreman server or Smart Proxy Server from a Backup
You can restore Foreman server or Smart Proxy server from the backup data that you create as part of Backing Up Foreman server and Smart Proxy Server. This process outlines how to restore the backup on the same server that generated the backup, and all data covered by the backup is deleted on the target system. If the original system is unavailable, provision a system with the same configuration settings and host name.
10.1. Restoring from a Full Backup
    # df -h /var/backup_directory
    # restorecon -Rv /
Additional Resources
10.2. Restoring from Incremental Backups
10.3. Backup and Restore Smart Proxy Server Using a Virtual Machine Snapshot
If required, deploy a new Smart Proxy server, ensuring the host name is the same as before, and then install the Smart Proxy certificates. You may still have them on Foreman server, the package name ends in -certs.tar, alternately create new ones. Follow the procedures in Installing Smart Proxy server until you can confirm, in the Foreman web UI, that Smart Proxy server is connected to Foreman server. Then use the procedure Synchronizing Content from Foreman server to Smart Proxy servers to synchronize from Foreman.
10.3.1. Synchronizing Content from Foreman server to Smart Proxy servers
Use this procedure to synchronize content from your Foreman server to your Smart Proxy server.
Prerequisite
  • Ensure that you either select the relevant organization and location context of your Smart Proxy server or choose Any Organization and Any Location.
  2. Select your Smart Proxy server.
  3. On the Overview tab, click Synchronize.
    • Select Optimized Sync to synchronize content from your Foreman server to your Smart Proxy server that bypasses unnecessary steps to speed up performance.
    • Select Complete Sync to perform a complete sync from your Foreman server to your Smart Proxy server that synchronizes content even if the metadata has not changed.
11. Renaming Foreman Server or Smart Proxy Server
To rename Foreman server or Smart Proxy server, use the katello-change-hostname script.
When changing the domain name of your Foreman server or Smart Proxy server, update the hostname using katello-change-hostname to avoid networking issues.
11.1. Renaming Foreman server
The host name of Foreman server is used by Foreman server components, all Smart Proxy servers, and hosts registered to it for communication. This procedure ensures that in addition to renaming Foreman server, you also update all references to point to the new host name.
Warning
Renaming your Foreman server host shuts down all Foreman services on that host. The services restart after the renaming is complete.
  • Back up your Foreman server before changing its host name. If you fail to successfully rename it, restore it from the backup. For more information, see Backing Up Foreman server and Smart Proxy Server.
  • Run the hostname and hostname -f commands on Foreman server. If both commands do not return the FQDN of Foreman server, the katello-change-hostname script will fail to complete.
    If the hostname command returns the shortname of Foreman server instead of the FQDN, use hostnamectl set-hostname My_Old_FQDN to set the old FQDN correctly before using the katello-change-hostname script.
  • If Foreman server has a custom SSL certificate installed, obtain a new certificate for the new FQDN of the host. For more information, see Configuring Foreman server with a Custom SSL Certificate in Installing Foreman Server with Katello 4.9 Plugin on CentOS/RHEL.
  1. On Foreman server, run the katello-change-hostname script, and provide the new host name. Choose one of the following methods:
    • If your Foreman server is installed with the default self-signed SSL certificates, enter the following command:
      --username admin \
      --password password
      --username admin \
      --password password \
  2. If you have created a custom SSL certificate for the new Foreman server host name, run the Foreman installation script to install the certificate. For more information about installing a custom SSL certificate, see Deploying a Custom SSL Certificate to Foreman server in Installing Foreman Server with Katello 4.9 Plugin on CentOS/RHEL.
  3. Reregister all Foreman hosts. For more information, see Registering Hosts in Managing Hosts.
    # foreman-installer \
    --foreman-proxy-trusted-hosts new-foreman.example.com \
    --puppet-server-foreman-url https://new-foreman.example.com
    # hammer proxy list
    # hammer proxy content synchronize \
    --id Mysmart-proxy_ID_
  7. If you use the virt-who agent, update the virt-who configuration files with the new host name.
  8. If you use external authentication, reconfigure Foreman server for external authentication after you run the katello-change-hostname script. For more information, see Configuring External Authentication in Installing Foreman Server with Katello 4.9 Plugin on CentOS/RHEL.
11.2. Renaming Smart Proxy Server
The host name of Smart Proxy server is referenced by Foreman server components and all hosts registered to it. This procedure ensures that in addition to renaming Smart Proxy server, you also update all references to the new host name.
Warning
Renaming your Smart Proxy server host shuts down all Foreman services on that host. The services restart after the renaming is complete.
  • Back up your Smart Proxy server before renaming. If you fail to successfully rename it, restore it from the backup. For more information, see Backing Up Foreman server and Smart Proxy Server.
  • Run the hostname and hostname -f commands on Smart Proxy server. If both commands do not return the FQDN of Smart Proxy server, the katello-change-hostname script will fail to complete.
    If the hostname command returns the shortname of Smart Proxy server instead of the FQDN, use hostnamectl set-hostname My_Old_FQDN to set the old FQDN correctly before attempting to use the katello-change-hostname script.
  1. On Foreman server, generate a new certificates archive file for Smart Proxy server.
    • If you are using the default SSL certificate, enter the following command:
      --foreman-proxy-fqdn new-smartproxy.example.com \
      --certs-tar /root/new-smartproxy.example.com-certs.tar
    • If you are using a custom SSL certificate, create a new SSL certificate for Smart Proxy server. For more information, see Configuring Smart Proxy server with a Custom SSL Certificate in Installing a Smart Proxy Server 3.7 on CentOS/RHEL.
  2. On Foreman server, copy the certificates archive file to Smart Proxy server. For example, to copy the archive file to the root user’s home directory:
  3. On Smart Proxy server, run the katello-change-hostname script and provide the host’s new name, Foreman credentials, and certificates archive file name.
    # katello-change-hostname new-smartproxy.example.com --username admin \
  4. If you have created a custom certificate for Smart Proxy server, deploy the certificate on Smart Proxy server by entering the foreman-installer command that the foreman-proxy-certs-generate command returned in a previous step. For more information, see Deploying a Custom SSL Certificate to Smart Proxy server in Installing a Smart Proxy Server 3.7 on CentOS/RHEL.
  5. On all Smart Proxy clients, enter the following commands to reinstall the bootstrap RPM, reregister clients, and refresh their subscriptions.
    You can use the remote execution feature to perform this step. For more information, see Configuring and Setting up Remote Jobs in Managing Hosts.
    # dnf remove katello-ca-consumer*
    # dnf install http://new-smartproxy.example.com/pub/katello-ca-consumer-latest.noarch.rpm
    # subscription-manager register --org="My_Organization" \
    --environment="Library" \
    --force
    # subscription-manager refresh
  6. Update the Smart Proxy host name in the Foreman web UI.
    2. Locate Smart Proxy server in the list, and click Edit.
    3. Edit the Name and URL fields to match Smart Proxy server’s new host name, then click Submit.
    4. On your DNS server, add a record for the new hostname of your Smart Proxy server, and delete the record of the previous host name.
12. Maintaining Foreman server
12.1. Deleting Audit Records Manually
12.2. Deleting Audit Records Automatically
12.3. Anonymizing Audit Records
12.4. Deleting Report Records
12.5. Configuring the Cleaning Unused Tasks Feature
12.6. Deleting Task Records
12.7. Deleting a Task by ID
  2. Optional: View the task:
  3. Delete the task:
12.8. Recovering from a Full Disk
    1. Remove orphaned content:
    3. Grow the file system on the LV with the /var/lib/pulp directory on it. For more information, see Growing a logical volume and file system in Red Hat Enterprise Linux 8 Configuring and managing logical volumes.
      1. Stop Foreman services:
      3. Start Foreman services:
12.9. Reclaiming PostgreSQL Space
12.10. Reclaiming Space From On Demand Repositories
Space reclamation requires an existing repository. For deleted repositories, wait for the next scheduled orphan cleanup or remove orphaned content manually:
For a single repository
  • In the Foreman web UI, navigate to Content > Products.
  • Select a product.
  • On the Repositories tab, click the repository name.
  • From the Select Actions list, select Reclaim Space.
For multiple repositories
  • Select the product name.
  • On the Repositories tab, select the checkbox of the repositories.
  • Click Reclaim Space at the top right corner.
For Smart Proxies
  • In the Foreman web UI, navigate to Infrastructure > Smart Proxies.
  • Select the Smart Proxy server.
  • Click Reclaim space.
13. Renewing the SSL Certificate
This chapter provides information on how to renew the SSL certificate on Foreman server as well as on Smart Proxy server.
13.1. Renewing a SSL Certificate on Foreman server
Use this procedure to update your SSL certificate for Foreman server.
Prerequisite
  • You must create a new Certificate Signing Request (CSR) and send it to the Certificate Authority to sign the certificate. Refer to the Configuring Foreman server with a Custom SSL Certificate guide before creating a new CSR because the Server certificate must have X.509 v3 Key Usage and Extended Key Usage extensions with required values. In return, you will receive the Foreman server certificate and CA bundle.
  • Before deploying a renewed custom certificate on your Foreman server, validate the SSL input files. Note that for the katello-certs-check command to work correctly, Common Name (CN) in the certificate must match the FQDN of Foreman server:
    # katello-certs-check -t foreman \
    -b /root/foreman_cert/ca_cert_bundle.pem \
    -c /root/foreman_cert/foreman_cert.pem \
    -k /root/foreman_cert/foreman_cert_key.pem
    If the command is successful, it returns the following foreman-installer command. You can use this command to deploy the renewed CA certificates to Foreman server:
    # foreman-installer --scenario katello \
    --certs-server-cert "/root/foreman_cert/foreman_cert.pem" \
    --certs-server-key "/root/foreman_cert/foreman_cert_key.pem" \
    --certs-server-ca-cert "/root/foreman_cert/ca_cert_bundle.pem" \
    --certs-update-server \
    --certs-update-server-ca
Do not delete the certificate files after you deploy the certificate. They are required when upgrading Foreman server.
If a new consumer package katello-ca-consumer-latest.noarch.rpm is generated due to a different Certificate Signing Authority, all the clients registered to Foreman server must be updated.
  1. Access the Foreman web UI from your local machine. For example, https://foreman.example.com.
  2. In your browser, view the certificate details to verify the deployed certificate.
13.2. Renewing a SSL certificate on Smart Proxy server
Use this procedure to update your SSL certificate for Smart Proxy server. The foreman-installer command, which the foreman-proxy-certs-generate command returns, is unique to each Smart Proxy server. You cannot use the same command on more than one Smart Proxy server.
Prerequisite
  • You must create a new Certificate Signing Request and send it to the Certificate Authority to sign the certificate. Refer to the Configuring Foreman server with a Custom SSL Certificate guide before creating a new CSR because the Foreman server certificate must have X.509 v3 Key Usage and Extended Key Usage extensions with required values. In return, you will receive the Smart Proxy server certificate and CA bundle.
  1. On your Foreman server, validate the SSL certificate input files:
    # katello-certs-check -t smart-proxy \
    -b /root/smart-proxy_cert/ca_cert_bundle.pem \
    -c /root/smart-proxy_cert/smart-proxy_cert.pem \
    -k /root/smart-proxy_cert/smart-proxy_cert_key.pem
  2. On your Foreman server, generate the certificate archive file for your Smart Proxy server:
    --certs-tar "/root/My_Certificates/smartproxy.example.com-certs.tar" \
    --foreman-proxy-fqdn "smartproxy.example.com" \
    --server-ca-cert "/root/My_Certificates/ca_cert_bundle.pem" \
    --server-cert "/root/My_Certificates/smart-proxy_cert.pem" \
    --server-key "/root/My_Certificates/smart-proxy_cert_key.pem"
  3. On your Foreman server, copy the certificate archive file to your Smart Proxy server:
  4. Retain a copy of the foreman-installer command that the foreman-proxy-certs-generate command returns for deploying the certificate to your Smart Proxy server.
  5. Deploy the certificate on your Smart Proxy server using the foreman-installer command returned by the foreman-proxy-certs-generate command:
    # foreman-installer --scenario foreman-proxy-content \
    --certs-tar-file "/root/My_Certificates/smartproxy.example.com-certs.tar" \
    --foreman-proxy-foreman-base-url "https://foreman.example.com" \
    --foreman-proxy-register-in-foreman "true"
Do not delete the certificate archive file on the Smart Proxy server after you deploy the certificate. They are required when upgrading Smart Proxy server.
If a new consumer package katello-ca-consumer-latest.noarch.rpm is generated due to a different Certificate Signing Authority, all the clients registered to Smart Proxy server must be updated.
14. Logging and Reporting Problems
The following sections describe the most commonly used log files and debugging tools available in Foreman.
14.1. Increasing Logging Levels to Help with Debugging
You can increase the logging level of Foreman components to troubleshoot Foreman. Increasing the logging level to debug provides the most detailed information. The default logging level is info.
14.1.1. Increasing the Logging Level for the Foreman Application
To increase logging for the Foreman Application:
14.1.2. Increasing the Logging Level for Hammer
To increase logging for Hammer:
:log_level: 'debug'
14.1.3. Increasing the Logging Level for Smart Proxy
You can find the log in /var/log/foreman-proxy/proxy.log.
To increase logging for Smart Proxy:
    # foreman-installer --foreman-proxy-log-level DEBUG
Running foreman-installer will revert the setting back to default.
14.1.4. Increasing the Logging Level for Candlepin
You can find the logs in /var/log/candlepin/candlepin.log and /var/log/candlepin/error.log.
To increase logging for Candlepin:
  1. In /etc/candlepin/candlepin.conf, set the logging level to DEBUG:
    log4j.logger.org.candlepin=DEBUG
  2. Restart the tomcat service:
    # systemctl restart tomcat
log4j.logger.org.candlepin.resource.ConsumerResource=WARN
log4j.logger.org.candlepin.resource.HypervisorResource=WARN
14.1.5. Increasing the Logging Level for Qpid Dispatch Router
Qpid logs to syslog. You can view the log in /var/log/messages or with journalctl.
To increase logging for Qpid Dispatch Router:
  1. In /etc/qpid-dispatch/qdrouterd.conf, set the logging level to debug:
    enable: debug+
  2. Restart the Qpid Dispatch Router:
    # systemctl restart qdrouterd
14.1.6. Increasing the Logging Level For Qpid Broker
To increase logging for Qpid Broker:
  1. In /etc/qpid/qpidd.conf, set the logging level to debug:
    log-enable=debug+
  2. Restart Qpid Broker:
    # systemctl restart qpidd
14.1.7. Increasing the Logging Level For Redis
To increase logging for Redis:
  1. In /etc/redis.conf, set the logging level to debug:
    loglevel debug
  2. Restart the Redis service:
    # systemctl restart redis
14.1.8. Increasing the Logging Level For Foreman Installer
You can find the log files in /var/log/foreman-installer/.
To increase the logging level of the Foreman installer, add the --verbose-log-level debug option during the installation:
14.1.9. Increasing the Logging Level For Pulp
By default, Pulp logs to syslog. You can view the log in /var/log/messages or with journalctl.
To increase logging for Pulp:
  1. In /etc/pulp/settings.py, set the logging level to DEBUG:
  2. Restart the Pulp services:
    # systemctl restart \
    pulpcore-api \
    pulpcore-content \
    pulpcore-resource-manager \
    pulpcore-worker@1 \
    pulpcore-worker@2 \
    redis
14.1.10. Increasing the Logging Level For Puppet Agent
To increase logging for Puppet agent:
    # foreman-installer --puppet-agent-additional-settings log_level:debug
14.1.11. Increasing the Logging Level For Puppet Server
To increase logging for Puppet server:
    # foreman-installer --puppet-server-additional-settings log_level:debug
  2. Restart the Puppet server:
14.2. Configuring Logging Levels with Hammer CLI
You can use Hammer to log debugging information for various Foreman components. The default logging level is INFO.
  • To list the components whose logging level you can change by using hammer:
    # hammer admin logging --list
  • To set DEBUG level logging for all components:
  • To set PRODUCTION level logging for all components:
  • To set DEBUG level logging for a specific component:
    # hammer admin logging --components My_Component --level-debug
  • To list all available logging options:
    # hammer admin logging --help
14.3. Configuring Logging to Journal or File-based Logging
Foreman uses file-based logging by default. You can use the foreman-installer command to reconfigure logging.
Procedure for configuring logging with Journal
    --foreman-proxy-log JOURNAL
    --reset-foreman-logging-layout \
    • /var/log/foreman-proxy.log
14.4. Selective Debugging with Individual Loggers
    --foreman-loggers ldap:true \
    --foreman-loggers sql:true
14.5. Overview of Individual Loggers
The following list provides an overview of selected loggers. You can find the complete list of loggers with their default values in /usr/share/foreman/config/application.rb under Foreman::Logging.add_loggers.
app
Default value: true.
audit
background
blob
dynflow
ldap
Default value: false.
notifications
permissions
sql
telemetry
templates
14.6. Retrieving the Status of Services
Foreman uses a set of back-end services. When troubleshooting, you can check the status of Foreman services.
  • In the Foreman web UI, navigate to Administer > About.
    • On the Smart Proxies tab, view the status of all Smart Proxies.
    • On the Compute Resources tab, view the status of attached compute resource providers.
    • In the Backend System Status table, view the status of all back-end services.
CLI procedure
    # hammer ping
  • Perform a health check:
14.7. Restarting Services
  • Restart Foreman services:
14.8. Utilities for Processing Log Information
sosreport
The sosreport command collects configuration and diagnostic information from a Linux system, such as the running Kernel version, loaded modules, running services, and system and service configuration files. This output is stored in a tar file located at /var/tmp/sosreport-XXX-20171002230919.tar.xz.
For more information, run sosreport --help or see What is a sosreport and how can I create one?.
The sosreport command removes security information such as passwords, tokens, and keys while collecting information. However, the tar files can still contain sensitive information about the Foreman server. Send the tar files directly to the intended recipient and not to a public target.
foreman-tail
14.9. Log File Directories
The following table provides an overview of selected log directories on Foreman server:
/var/log/candlepin/
Subscription management
Installer
/var/log/foreman-maintain/
Foreman maintain
Foreman proxy
/var/log/foreman/
Foreman
/var/log/httpd/
Apache HTTP server
/var/log/messages/
Various other log messages
Puppet
/var/log/tomcat/
Candlepin web service logs
14.10. System Journal Metadata
AUDIT_ACTION
Audit action performed
AUDIT_TYPE
Audit resource type
AUDIT_ID
AUDIT_ATTRIBUTE
AUDIT_FIELD_OLD
AUDIT_FIELD_NEW
AUDIT_ID
AUDIT_ATTRIBUTE
Example: Name or description
EXCEPTION_MESSAGE
EXCEPTION_CLASS
EXCEPTION_BACKTRACE
LOC_ID
Location database ID
LOC_NAME
Location name
LOC_LABEL
Location label
LOGGER
Logger name
ORG_ID
Organization database ID
ORG_NAME
Organization name
ORG_LABEL
Organization label
REMOTE_IP
Remote IP address of a client
REQUEST
SESSION
TEMPLATE_NAME
Template name
TEMPLATE_DIGEST
TEMPLATE_HOST_NAME
TEMPLATE_HOST_ID
USER_LOGIN
User login name
15. Monitoring Resources
15.1. Using the Foreman Content Dashboard
Host Configuration Status
Table 4. Host Configuration States
Icon State Description
host state config okay
host state config error
Hosts in error state
host state config report
host state config pending
host state config outofsync
Out of sync hosts
host state config noreport
Hosts with no reports
host state config noalert
Hosts with alerts disabled
Host Configuration Chart
Latest Events
New Hosts
Task Status
Latest Warning/Error Tasks
Discovered Hosts
Latest Errata
Content Views
Sync Overview
Host Subscription Status
Table 5. Host Subscription States
host state sub invalid
Invalid
host state sub partial
Partial
host state sub valid
Valid
Subscription Status
Host Collections
Virt-who Configuration Status
Table 6. Virt-who Configuration States
State Description
No Reports
No Change
OK
Total Configurations
Latest Compliance Reports
Compliance Reports Breakdown
Red Hat Insights Actions
Red Hat Insights Risk Summary
15.1.1. Managing Tasks
To Adjust Timeout Settings:
  5. Click Save.
15.2. Configuring RSS Notifications
15.3. Monitoring Foreman server
15.4. Monitoring Smart Proxy Server
15.4.1. Viewing General Smart Proxy Information
15.4.2. Monitoring Services
15.4.3. Monitoring Puppet
16. Using Webhooks
16.1. Migrating to Webhooks
16.2. Installing Webhooks
  • Optional: Install the webhooks CLI plug-in:
16.3. Creating a Webhook Template
  1. In the Foreman web UI, navigate to Administer > Webhook Templates.
  7. Click Submit.
Examples
Running remote execution jobs
Creating users
16.4. Creating a Webhook
  1. In the Foreman web UI, navigate to Administer > Webhooks.
  2. Click Create new.
  7. Enter an HTTP method.
  9. Click the Credentials tab.
When configuring webhooks with endpoints with non-standard HTTP or HTTPS ports, an SELinux port must be assigned, see Configuring SELinux to Ensure Access to Foreman on Custom Ports in Installing Foreman Server with Katello 4.9 Plugin on CentOS/RHEL.
16.5. Available Webhook Events
A Content View was successfully promoted.
Run OpenSCAP scan.
Perform a single Puppet run.
Build Entered
Build Exited
Common database operations on a Content View.
Domain
Host
Hostgroup
Model
Status Changed
Subnet
Template Render Performed
Template
User
16.6. Shellhooks
The HTTP method must be POST. An example URL would be: https://smartproxy.example.com:9090/shellhook/My_Script.
16.7. Installing the Shellhooks Plugin
16.8. Passing Arguments to Shellhook Script Using Webhooks
      "X-Shellhook-Arg-1": "VALUE",
      "X-Shellhook-Arg-2": "VALUE"
Example
16.9. Passing Arguments to Shellhook Script Using Curl
    "X-Shellhook-Arg-1: VALUE"
    "X-Shellhook-Arg-2: VALUE"
Example
-H "X-Shellhook-Arg-2: My Content View" \
--data "" https://smartproxy.example.com:9090/shellhook/My_Script
16.10. Creating a Shellhook to Print Arguments
Prerequisite
    #!/bin/sh
    echo "$@" >&2
  2. In the Foreman web UI, navigate to Administer > Webhooks.
  3. Click Create new.
  6. In the Target URL field, enter the URL of your Smart Proxy server followed by :9090/shellhook/print_args:
    https://smartproxy.example.com:9090/shellhook/print_args
        "X-Shellhook-Arg-1": "Hello",
        "X-Shellhook-Arg-2": "World!"
  1. Run a remote execution job on any host. You can use time as a command. For more information, see Executing a Remote Job in Managing Hosts.
    [W] [3520] Hello World!
17. Searching and Bookmarking
17.1. Building Search Queries
17.1.1. Query Syntax
parameter operator value
17.1.2. Query Operators
Table 7. Comparison Operators Accepted by Search
EQUALS
hostgroup = RHEL7
NOT EQUALS
LIKE
hostgroup ~ rhel%
NOT LIKE
GREATER THAN
registered_at <= Yesterday
LESS THAN
IN
release_version !^ 7
NOT IN
HAS or set?
NOT HAS or null?
Table 8. Logical Operators Accepted by Search
and
<whitespace>
or
not
17.1.3. Query Values
Text Values
Examples:
hostgroup = "Web servers"
hostgroup = Web servers
Temporal Values
  • "10 January 2017"
  • "10 Jan 2017"
  • 10-January-2017
  • 10/January/2017
  • "January 10, 2017"
Warning
17.2. Using Free Text Search
17.3. Managing Bookmarks
17.3.1. Creating Bookmarks
  7. Click Submit.
17.3.2. Deleting Bookmarks
A.1. General Settings
Administrator email address
Foreman URL
Entries per page
20
Fix DB cache
DB pending seed
Smart Proxy request timeout
60
Login page footer text
HTTP(S) proxy
HTTP(S) proxy except hosts
Show Experimental Labs
Out of sync interval
30
Foreman UUID
Default language
Default timezone
Instance title
New host details UI
A.2. Tasks settings
Sync task timeout
120
Enable dynflow console
Proxy action retry count
4
Proxy action retry interval
15
Allow proxy batch tasks
Proxy tasks batch size
100
Tasks troubleshooting URL
Polling intervals multiplier
1
A.3. Template Sync Settings
Associate
Branch
Default branch in Git repo.
Commit message
Dirname
Filter
Force import
Lock templates
Keep, do not lock new
Metadata export mode
Refresh
Default metadata export mode.
Possible options:
refresh re-renders metadata.
keep keeps existing metadata.
Negate
Prefix
Repo
/tmp/dir
git://example.com
https://example.com
ssh://example.com
Verbosity
A.4. Discovery Settings
Discovery location
Discovery organization
Interface fact
discovery_bootif
Create bond interfaces
Clean all facts
Hostname facts
discovery_bootif
Auto provisioning
Reboot
Hostname prefix
mac
Fact columns
Highlighted facts
Storage facts
Software facts
Hardware facts
Network facts
IPMI facts
Lock PXE
Locked PXELinux template name
pxelinux_discovery
Locked PXEGrub template name
pxegrub_discovery
Locked PXEGrub2 template name
pxegrub2_discovery
Force DNS
Error on existing NIC
Type of name generator
Fact + prefix
Prefer IPv6
A.5. Boot Disk Settings
iPXE directory
/usr/share/ipxe
ISOLINUX directory
/usr/share/syslinux
SYSLINUX directory
/usr/share/syslinux
Grub2 directory
/var/lib/tftpboot/grub2
Host image template
Boot disk iPXE - host
Generic image template
Boot disk iPXE - generic host
ISO generation command
genisoimage
Installation media caching
Allowed bootdisk types
A.6. Content Settings
Default HTTP Proxy
CDN SSL version
Kickstart default
Kickstart default finish
Default synced OS user-data
Kickstart default user data
Kickstart default PXELinux
Kickstart default PXEGrub
Kickstart default PXEGrub2
Kickstart default iPXE
Kickstart default
Atomic Kickstart default
Manifest refresh timeout
1200
Accept action timeout
20
Finish action timeout
3600
Check services before actions
100
immediate
on_demand
on_demand
/var/lib/pulp/katello-export
/var/lib/pulp/exports
Pulp client key
Pulp client cert
Sync Connection Timeout
300
Delete Host upon unregister
Default Location
Expire soon days
120
Host Duplicate DMI UUIDs
Host Profile Assume
Host Tasks Workers Pool Size
5
Applicability Batch Size
50
Autosearch
Autosearch delay
500
Pulp bulk load size
2000
1440
A.7. Authentication Settings
OAuth active
OAuth consumer key
OAuth consumer key.
OAuth consumer secret
OAuth consumer secret.
OAuth map users
Failed login attempts limit
30
Trusted hosts
SSL certificate
/etc/foreman/client_cert.pem
SSL CA file
/etc/foreman/proxy_ca.pem
SSL private key
/etc/foreman/client_key.pem
SSL client DN env
HTTP_SSL_CLIENT_S_DN
SSL client verify env
HTTP_SSL_CLIENT_VERIFY
SSL client cert env
HTTP_SSL_CLIENT_CERT
Server CA file
Websockets SSL key
Websockets SSL certificate
Websockets encryption
Login delegation logout URL
External
Idle timeout
60
BCrypt password cost
9
BMC credentials access
OIDC JWKs URL
OIDC Audience
OIDC Issuer
OIDC Algorithm
A.8. Email Settings
Email reply address
Email subject prefix
Send welcome email
Delivery method
Sendmail
Method used to deliver email.
SMTP enable StartTLS auto
SMTP OpenSSL verify mode
Default verification mode
SMTP address
SMTP address to connect to.
SMTP port
25
SMTP port to connect to.
SMTP HELO/EHLO domain
HELO/EHLO domain.
SMTP username
SMTP password
SMTP authentication
none
Sendmail arguments
-i
Sendmail location
/usr/sbin/sendmail
A.9. Notifications Settings
RSS enable
Pull RSS notifications.
RSS URL
A.10. Provisioning Settings
Host owner
Root password
Unattended URL
Safemode rendering
Query local nameservers
Installation token lifetime
360
SSH timeout
120
0.0.0.0
Update IP from built request
Use short name for VMs
DNS timeout
[5, 10, 15, 20]
Clean up failed deployment
Random-based
iPXE intermediate script
Maximum structured facts
100
Global Registration
Global Registration template.
CoreOS Transpiler Command
PXEGrub2 global default
PXELinux global default
PXEGrub global default
Global default iPXE template
iPXE global default
Local boot PXEGrub2 template
PXEGrub2 default local boot
Local boot PXELinux template
PXELinux default local boot
Local boot PXEGrub template
PXEGrub default local boot
Local boot iPXE template
iPXE default local boot
Manage PuppetCA
Use UUID for certificates
A.11. Facts Settings
Location fact
foreman_location
Organization fact
foreman_organization
Default location
Default Location
Default organization
Default Organization
Update hostgroup from facts
Ignore facts for domain
Update subnets from facts
None
Default Puppet environment
production
ENC environment
Update environment from facts
Matchers inheritance
[fqdn, hostgroup, os, domain]
Interpolate ERB in parameters
Puppet interval
35
Puppet out of sync disabled
Fallback to Any Proxy
Enable Global Proxy
SSH User
root
Effective User
root
Effective User Method
sudo
Effective user password
Sync Job Templates
SSH Port
22
Connect by IP
Prefer IPv6 over IPv4
Default SSH password
Default SSH key passphrase
Workers pool size
5
Cleanup working directories
Cockpit URL
Form Job Template
Run Command - SSH Default
Time to pickup
86400
Time in seconds within which the host has to pick up a job. If the job is not picked up within this limit, the job will be cancelled. Applies only to pull-mqtt based jobs. Defaults to one day.
A.14. Ansible Settings
Private Key Path
Connection type
ssh
WinRM cert Validation
validate
Default verbosity level
Disabled
Post-provision timeout
360
Ansible report timeout
30
Ansible out of sync disabled
Ansible - Ansible Inventory
Ansible roles to ignore
