1. Accessing Foreman
1.1. Logging in to Foreman
Use the web user interface to log in to Foreman for further configuration.
    https://foreman.example.com/
  2. Enter the user name and password created during the configuration process. If a user was not created during the configuration process, the default user name is admin. If you have problems logging in, you can reset the password. For more information, see Resetting the Administrative User Password.
1.2. Using FreeIPA credentials to log in to the Foreman Hammer CLI
This section describes how to log in to your Foreman Hammer CLI with your FreeIPA (IdM) login and password.
  • You have enrolled your Foreman server into FreeIPA and configured it to use FreeIPA for authentication. More specifically, you have enabled access both to the Foreman web UI and the Foreman API. For more information, see Using FreeIPA in Installing Foreman 3.5 Server on RHEL/CentOS.
  • The host on which you run this procedure is configured to use FreeIPA credentials to log users in to your Foreman Hammer CLI. For more information, see Configuring the Hammer CLI to Use FreeIPA User Authentication in Installing Foreman 3.5 Server on RHEL/CentOS.
  • The host is an FreeIPA client.
  • An FreeIPA server is running and reachable by the host.
  1. Obtain a Kerberos ticket-granting ticket (TGT) on behalf of a Foreman user:
    $ kinit idm_user
    Warning
    If, when you were setting FreeIPA to be the authentication provider, you enabled access to both the Foreman API and the Foreman web UI, an attacker can now obtain an API session after the user receives the Kerberos TGT. The attack is possible even if the user did not previously enter the Foreman login credentials anywhere, for example in the browser.
  2. If automatic negotiate authentication is not enabled, use the TGT to authenticate to Hammer manually:
    $ hammer auth login negotiate
  3. Optional: Destroy all cached Kerberos tickets in the collection:
    $ kdestroy -A
  • Use any hammer command to ensure that the system does not ask you to authenticate again:
    $ hammer host list
To log out of Hammer, enter: hammer auth logout.
1.3. Using FreeIPA credentials to log in to the Foreman web UI with a Firefox browser
This section describes how to use the Firefox browser to log in to your Foreman web UI with your FreeIPA (IdM) login and password.
  • You have enrolled your Foreman server into FreeIPA and configured the server to use FreeIPA for authentication. For more information, see Using FreeIPA in Installing Foreman 3.5 Server on RHEL/CentOS.
  • The host on which you are using a Firefox browser to log in to the Foreman web UI is an FreeIPA client.
  • You have a valid FreeIPA login and password.
  • Foreman community recommends using the latest stable Firefox browser.
  • Your Firefox browser is configured for Single Sign-On (SSO).
  1. Obtain the Kerberos ticket granting ticket (TGT) for yourself using your FreeIPA credentials:
    $ kinit idm_user
    Password for idm_user@EXAMPLE.COM:
  2. In your browser address bar, enter the URL of your Foreman server.
Alternatively, you can skip the first two steps and enter your login and password in the fields displayed on the Foreman web UI. This is also the only option if the host from which you are accessing the Foreman web UI is not an FreeIPA client.
1.4. Using FreeIPA credentials to log in to the Foreman web UI with a Chrome browser
This section describes how to use a Chrome browser to log in to your Foreman web UI with your FreeIPA login and password.
  • The host on which you are using the Chrome browser to log in to the Foreman web UI is an FreeIPA client.
  • Foreman community recommends using the latest stable Chrome browser.
  1. Enable the Chrome browser to use Kerberos authentication:
    Instead of allowlisting the whole domain, you can also allowlist a specific Foreman server.
  2. Obtain the Kerberos ticket-granting ticket (TGT) for yourself using your FreeIPA credentials:
    $ kinit idm_user
    Password for idm_user@_EXAMPLE.COM:
  3. In your browser address bar, enter the URL of your Foreman server.
Alternatively, you can skip the first three steps and enter your login and password in the fields displayed on the Foreman web UI. This is also the only option if the host from which you are accessing the Foreman web UI is not an FreeIPA client.
Navigation Tabs Description
Any Context
Monitor
Content
Hosts
Configure
Infrastructure
User Name
notification bell
Administer
1.6. Changing the Password
1.7. Resetting the Administrative User Password
  1. Log in to the base operating system where Foreman server is installed.
1.8. Setting a Custom Message on the Login Page
  3. Click Save.
Foreman provides the foreman-maintain service command to manage Foreman services from the command line. This is useful when creating a backup of Foreman. For more information on creating backups, see Backing Up Foreman server and Smart Proxy Server.
3. Managing Foreman with Ansible Collections
3.1. Installing the Foreman Ansible Modules
3.2. Viewing the Foreman Ansible Modules
4. Managing Users and Roles
4.1. Managing Users
4.1.1. Creating a User
  2. Click Create User.
      • INTERNAL: to enable the user to be managed inside Foreman server.
      • EXTERNAL: to configure external authentication as described in Configuring External Authentication in Installing Foreman 3.5 Server on RHEL/CentOS.
CLI procedure
    # hammer user create \
    --login My_User_Name \
    --mail My_User_Mail \
    --password My_User_Password
4.1.2. Assigning Roles to a User
  7. Click Submit.
CLI procedure
4.1.3. Impersonating a Different User Account
4.1.4. Creating an API-Only User
Prerequisite
    # openssl rand -hex 32
4.2. Managing SSH Keys
For information on SSH keys and SSH key creation, see Using SSH-based Authentication in Red Hat Enterprise Linux 8 Configuring basic system settings.
4.2.1. Managing SSH Keys for a User
  3. Click on the SSH Keys tab.
    • To Add SSH key
      2. Click Add SSH Key.
      5. Click Submit.
    • To Remove SSH key
CLI procedure
    # hammer user ssh-keys add \
    --user-id user_id \
    --name key_name \
    --key-file ~/.ssh/id_rsa.pub
    --user-id user_id \
    --name key_name \
4.3. Managing Personal Access Tokens
    {"foreman_version":"3.5.0","result":"ok","status":200,"version":"3.5.1.10","api_version":2}
4.4. Creating and Managing User Groups
4.4.1. User Groups
With Foreman, you can assign permissions to groups of users. You can also create user groups as collections of other user groups. If using an external authentication source, you can map Foreman user groups to external user groups as described in Configuring External User Groups in Installing Foreman 3.5 Server on RHEL/CentOS.
4.4.2. Creating a User Group
  2. Click Create User group.
  5. Click Submit.
CLI procedure
    # hammer user-group create \
    --name My_User_Group_Name \
4.4.3. Removing a User Group
4.5. Creating and Managing Roles
4.5.1. Creating a Role
  2. Click Create Role.
CLI procedure
4.5.2. Cloning a Role
4.5.3. Adding Permissions to a Role
  5. Depending on the Resource type selected, you can select or deselect the Unlimited and Override checkbox. The Unlimited checkbox is selected by default, which means that the permission is applied on all resources of the selected type. When you disable the Unlimited checkbox, the Search field activates. In this field you can specify further filtering with use of the Foreman search syntax. For more information, see Granular Permission Filtering. When you enable the Override checkbox, you can add additional locations and organizations to allow the role to access the resource type in the additional locations and organizations; you can also remove an already associated location and organization from the resource type to restrict access.
  6. Click Next.
CLI procedure
  2. Add permissions to a role:
    # hammer filter create \
    --role My_Role_Name
4.5.4. Viewing Permissions of a Role
4.5.5. Creating a Complete Permission Table
    # dnf install foreman-console
  1. Start the Foreman console with the following command:
    # foreman-rake console
    end.join("\n")
    f.write(result)
    </table>
4.5.6. Removing a Role
4.6. Predefined Roles Available in Foreman
To view the exact set of permissions a predefined role grants, display the role in Foreman web UI as the privileged user. For more information, see Viewing Permissions of a Role.
Table 1. Permissions provided by role
Role Permissions Provided by Role
Access Insights Admin
Add and edit Insights rules.
Access Insights Viewer
View Insight reports.
Ansible Roles Manager
Bookmarks manager
Boot disk access
Download the boot disk.
Compliance manager
Compliance viewer
Create ARF report
Create compliance reports.
Default role
Discovery Manager
Discovery Reader
Edit hosts
Edit partition tables
Manager
Organization admin
Red Hat Access Logs
Remote Execution Manager
Control which roles have permission to run infrastructure jobs.
Remote Execution User
Run remote execution jobs against hosts.
Site manager
System admin
  • Edit global settings in Administer > Settings.
Tasks manager
View and edit Foreman tasks.
Tasks reader
Viewer
View hosts
Virt-who Manager
Virt-who Reporter
Virt-who Viewer
4.7. Granular Permission Filtering
4.7.1. Creating a Granular Permission Filter
field_name operator value
CLI procedure
    --permission-ids 91 \
    --search "name ~ ccv*" \
    --role qa-user
4.7.2. Examples of Using Granular Permission Filters
hostgroup = host-editors
name ^ (XXXX, Yyyy, zzzz)
Dev
4.7.3. Supported Operators for Granular Search
Table 2. Logical Operators
Operator
and
Combines search criteria.
not
Negates an expression.
has
Table 3. Symbolic Operators
Operator
5. Configuring Email Notifications
Foreman server does not enable outgoing emails by default, therefore you must review your email configuration. For more information, see Configuring Foreman server for Outgoing Emails in Installing Foreman 3.5 Server on RHEL/CentOS.
5.1. Email Notification Types
  • Compliance policy summary: A summary of OpenSCAP policy reports and their results.
5.2. Configuring Email Notification Preferences
  6. Click Submit.
5.3. Testing Email Delivery
  2. Click on the username.
    # systemctl start postfix
5.4. Testing Email Notifications
  • daily
  • weekly
  • monthly
5.5. Changing Email Notification Settings for a Host
6. Managing Security Compliance
Security compliance management is the ongoing process of defining security policies, auditing systems for compliance with those policies, and resolving instances of non-compliance. Any non-compliance is managed according to the organization’s configuration management policies. Security policies range in scope from host-specific to industry-wide, therefore, flexibility in their definition is required.
With Foreman, you can schedule compliance auditing and reporting on all registered hosts.
6.1. Security Content Automation Protocol
Foreman uses the Security Content Automation Protocol (SCAP) standard to define security policies.
SCAP is a framework of several specifications based on XML, such as checklists described in the Extensible Checklist Configuration Description Format (XCCDF) and vulnerabilities described in the Open Vulnerability and Assessment Language (OVAL). These specifications are encapsulated as data stream files.
Checklist items in XCCDF, also known as rules, express the desired configuration of a system item. For example, a rule may specify that no one can log in to a host over SSH using the root user account. Rules can be grouped into one or more XCCDF profiles, which allows multiple profiles to share a rule.
The OpenSCAP scanner tool evaluates system items on a host against the rules and generates a report in the Asset Reporting Format (ARF), which is then returned to Foreman for monitoring and analysis.
Table 4. Specifications in the SCAP Framework 1.3 supported by the OpenSCAP scanner
Title
Version
SCAP
1.3
XCCDF
Extensible Configuration Checklist Description Format
1.2
OVAL
5.11
Asset Identification
1.1
ARF
1.1
CCE
5.0
CPE
Common Platform Enumeration
2.3
CVE
2.0
CVSS
2.0
6.2. SCAP Content in Foreman
SCAP content is a SCAP data-stream file that contains implementation of compliance, configuration, or security baselines. A single data stream usually includes multiple XCCDF profiles. An XCCDF profile defines an industry standard or custom security standard against which you can evaluate compliance of host configuration in Foreman, such as Protection Profile for General Purpose Operating Systems (OSPP), Health Insurance Portability and Accountability Act (HIPAA), and PCI-DSS v3.2.1 Control Baseline for Enterprise Linux 9. You can adapt existing XCCDF profiles according to your requirements using tailoring files.
In Foreman, you use an XCCDF profile from SCAP content and, eventually, a tailoring file, to define a compliance policy. Foreman includes default SCAP contents from SCAP Security Guide provided by the OpenSCAP project.
For more information on how to download, deploy, modify, and create your own content, see:
6.2.1. Supported SCAP Versions
Foreman supports content of SCAP versions 1.2 and 1.3.
6.3. Compliance Policy Deployment Options
You can use one of the following methods to deploy compliance policies:
Ansible deployment
You use an Ansible role to configure hosts for compliance scans.
Puppet deployment
You use a Puppet class and the Puppet agent to configure hosts for compliance scans.
Manual deployment
You manually configure hosts for compliance scans.
6.4. Installing the OpenSCAP Plug-in
You can install and enable the OpenSCAP plug-in to generate SCAP compliance reports. The OpenSCAP plug-in consists of the OpenSCAP Foreman plug-in, the OpenSCAP Hammer CLI plug-in, the OpenSCAP Smart Proxy plug-in, and the module for Puppet policy deployment.
    # foreman-installer \
    --enable-foreman-plugin-openscap \
    --enable-foreman-cli-openscap \
    --foreman-proxy-plugin-openscap-puppet-module true
  2. Optional: Install the OpenSCAP plug-in on any Smart Proxy servers:
6.5. Configuring Compliance Policy Deployment Methods
Use one the following procedures to configure Foreman for the method that you have selected to deploy compliance policies. You will select one of these methods when you later create a compliance policy.
Procedure for Ansible deployment
  1. Import the theforeman.foreman_scap_client Ansible role.
    For more information, see Configuring Hosts Using Ansible.
  2. Assign the created policy and the theforeman.foreman_scap_client Ansible role to a host or host group.
  3. To trigger the deployment, run the Ansible role on the host or host group either manually, or set up a recurring job by using remote execution for regular policy updates.
    For more information, see Configuring and Setting Up Remote Jobs in Managing Hosts.
Procedure for Puppet deployment
  1. Ensure Puppet is enabled.
  2. Ensure the Puppet agent is installed on hosts.
  3. Import the Puppet environment that contains the foreman_scap_client Puppet module.
    For more information, see Configuring Hosts Using Puppet.
  4. Assign the created policy and the foreman_scap_client Puppet class to a host or host group.
    Puppet triggers the deployment on the next regular run or you can run Puppet manually. Puppet runs every 30 minutes by default.
Procedure for manual deployment
  • For the manual deployment method, no additional Foreman configuration is required.
6.6. Listing Available SCAP Contents
Use this procedure to view what SCAP contents are already loaded in Foreman. To use the CLI instead of the Foreman web UI, see the CLI procedure.
Prerequisite
  • Your user account has the view_scap_contents permission.
  • In the Foreman web UI, navigate to Hosts > Compliance – SCAP contents.
CLI procedure
  • Run the following Hammer command on Foreman server:
    # hammer scap-content list \
    --location "My_Location" \
6.7. Configuring SCAP Contents
You can upload SCAP data streams and tailoring files to define compliance policies.
6.7.1. Loading the Default SCAP Contents
By loading the default SCAP contents on Foreman server, you ensure that the data streams from the SCAP Security Guide (SSG) are loaded and assigned to all organizations and locations.
SSG is provided by the operating system of Foreman server and installed in /usr/share/xml/scap/ssg/content/. Note that the available data streams depend on the operating system version on which Foreman runs.
  • Your user account has a role assigned that has the create_scap_contents permission.
  • Use the following Hammer command on Foreman server:
6.7.2. Getting Supported SCAP Contents for RHEL
You can get the latest SCAP Security Guide (SSG) for Red Hat Enterprise Linux on the Red Hat Customer Portal. You have to get a version of SSG that is designated for the minor RHEL version of your hosts.
  1. Access the SCAP Security Guide in the package browser.
  2. From the Version menu, select the latest SSG version for the minor version of RHEL that your hosts are running. For example, for RHEL 8.6, select a version named *.el8_6.
  3. Download the package RPM.
  4. Extract the data-stream file (*-ds.xml) from the RPM. For example:
    $ rpm2cpio scap-security-guide-0.1.69-3.el8_6.noarch.rpm \
    | cpio -iv --to-stdout ./usr/share/xml/scap/ssg/content/ssg-rhel8-ds.xml \
    > ssg-rhel-8.6-ds.xml
  5. Upload the data stream to Foreman. For more information, see Uploading Additional SCAP Content.
6.7.3. Uploading Additional SCAP Content
You can upload additional SCAP content into Foreman server, either content created by yourself or obtained elsewhere. For example, you can get the latest OpenSCAP contents for additional systems from the SSG GitHub repository. To use the CLI instead of the Foreman web UI, see the CLI procedure.
Prerequisite
  • Your user account has the create_scap_contents permission.
  • You have acquired a SCAP data-stream file.
  1. In the Foreman web UI, navigate to Hosts > Compliance > SCAP contents.
  2. Click Upload New SCAP Content.
  3. Enter a title in the Title text box, such as My SCAP Content.
  4. In Scap File, click Choose file, navigate to the location containing a SCAP data-stream file and click Open.
  5. On the Locations tab, select locations.
  6. On the Organizations tab, select organizations.
  7. Click Submit.
If the SCAP content file is loaded successfully, a message similar to Successfully created My SCAP Content is displayed.
CLI procedure
  1. Place the SCAP data-stream file to a directory on your Foreman server, such as /usr/share/xml/scap/my_content/.
  2. Run the following Hammer command on Foreman server:
    # hammer scap-content bulk-upload --type directory \
    --directory /usr/share/xml/scap/my_content/ \
6.7.4. Tailoring XCCDF Profiles
You can customize existing XCCDF profiles using tailoring files without editing the original SCAP content. A single tailoring file can contain customizations of multiple XCCDF profiles.
You can create a tailoring file using the SCAP Workbench tool. For more information on using the SCAP Workbench tool, see Customizing SCAP Security Guide for your use case.
Then you can assign a tailoring file to a compliance policy to customize an XCCDF profile in the policy.
6.7.5. Uploading a Tailoring File
After uploading a tailoring file, you can apply it in a compliance policy to customize an XCCDF profile.
Prerequisite
  • Your user account has the create_tailoring_files permission.
  1. In the Foreman web UI, navigate to Hosts > Compliance – Tailoring Files and click New Tailoring File.
  3. Click Choose File, navigate to the location containing the tailoring file and select Open.
  4. Click Submit to upload the chosen tailoring file.
6.8. Managing Compliance Policies
A compliance policy is a scheduled audit that checks the specified hosts for compliance against a specific XCCDF profile from a SCAP content.
You specify the schedule for scans on Foreman server and the scans are performed on hosts. When a scan completes, a report in ARF format is generated and uploaded to Foreman server. The compliance policy makes no changes to the scanned host.
A compliance policy defines a SCAP client configuration and a cron schedule. The policy is then deployed together with the SCAP client on hosts to which the policy is assigned.
6.8.1. Creating a Compliance Policy
By creating a compliance policy, you can define and plan your security compliance requirements, and ensure that your hosts remain compliant to your security policies.
  1. In the Foreman web UI, navigate to Hosts > Compliance – Policies.
  2. Click New Policy or New Compliance Policy.
  3. Select the deployment method: Ansible, Puppet, or Manual. Then click Next.
  4. Enter a name for this policy, a description (optional), then click Next.
  5. Select the SCAP Content and XCCDF Profile to be applied, then click Next.
    Note that Foreman does not detect whether the selected XCCDF profile contains any rules. An empty XCCDF profile, such as the Default XCCDF Profile, will return empty reports.
  6. Optional: To customize the XCCDF profile, select a Tailoring File and a XCCDF Profile in Tailoring File, then click Next.
  7. Specify the scheduled time when the policy is to be applied. Select Weekly, Monthly, or Custom from the Period list. The Custom option allows for greater flexibility in the policy’s schedule.
  8. Select the locations to which to apply the policy, then click Next.
  9. Select the organizations to which to apply the policy, then click Next.
  10. Optional: Select the host groups to which to assign the policy.
  11. Click Submit.
6.8.2. Viewing a Compliance Policy
You can preview the rules which will be applied by specific OpenSCAP content and profile combination. This is useful when you plan policies.
Prerequisite
  • Your user account has the view_policies permission.
  2. In the Actions column of the required policy, click Show Guide or select it from the list.
6.8.3. Editing a Compliance Policy
Puppet agent applies an edited policy to the host on the next run. By default, this occurs every 30 minutes. If you use Ansible, you must run the Ansible role manually again or have configured a recurring remote execution job that runs the Ansible role on hosts.
Prerequisite
  • Your user account has the view_policies and edit_policies permissions.
  2. Click the name of the required policy.
  4. Click Submit.
6.8.4. Deleting a Compliance Policy
Prerequisite
  • Your user account has the view_policies and destroy_policies permissions.
  2. In the Actions column of the required policy, select Delete from the list.
6.9. Deploying Compliance Policies
To deploy a compliance policy, you must install the SCAP client, update the cron schedule file, and upload the SCAP content selected in the policy onto a host.
6.9.1. Deploying a Policy in a Host Group Using Ansible
After you deploy a compliance policy in a host group using Ansible, the Ansible role installs the SCAP client and configures OpenSCAP scans on the hosts according to the selected compliance policy.
  • You have enabled OpenSCAP on your Smart Proxy. For more information, see Installing the OpenSCAP Plug-in.
  • You have enabled and synced the operating system repositories to Foreman, and enabled them on the hosts:
    • Red Hat Enterprise Linux 9 for x86_64 - BaseOS and Appstream (RPMs) – rhel-9-for-x86_64-baseos-rpms and rhel-9-for-x86_64-appstream-rpms
    • Red Hat Enterprise Linux 8 for x86_64 - BaseOS and Appstream (RPMs) – rhel-8-for-x86_64-baseos-rpms and rhel-8-for-x86_64-appstream-rpms
    • Red Hat Enterprise Linux 7 Server and Extras (RPMs) – rhel-7-server-rpms and rhel-7-server-extras-rpms
  • You have enabled and synced the https://yum.theforeman.org/client/3.5/ repository to Foreman, and enabled it on the hosts.
  • You have created a compliance policy with the Ansible deployment option and assigned the host group.
  1. In the Foreman web UI, navigate to Configure > Host Groups.
  2. Click the host group that you want to configure for OpenSCAP reporting.
  4. On the Ansible Roles tab, assign the theforeman.foreman_scap_client Ansible role.
  5. Optional: On the Parameters tab, configure any Ansible variables of the role.
  6. Click Submit to save your changes.
  7. In the row of the required host group, navigate to the Actions column and select Run all Ansible roles.
6.9.2. Deploying a Policy on a Host Using Ansible
After you deploy a compliance policy on a host using Ansible, the Ansible role installs the SCAP client and configures OpenSCAP scans on the host according to the selected compliance policy.
  • You have enabled and synced the https://yum.theforeman.org/client/3.5/ repository to Foreman, and enabled it on the host.
  • You have created a compliance policy with the Ansible deployment option.
  2. From the OpenSCAP Smart Proxy list, select the Smart Proxy with OpenSCAP enabled that you want to use.
  3. On the Ansible Roles tab, add the theforeman.foreman_scap_client Ansible role.
  4. Optional: On the Parameters tab, configure any Ansible variables of the role.
  6. Click the Hosts breadcrumbs link to navigate back to the host index page.
  8. Click Select Action.
  10. In the Assign Compliance Policy window, select Remember hosts selection for the next bulk action.
  11. Select the required policy from the list of available policies and click Submit.
  12. Click Select Action.
  13. Select Run all Ansible roles from the list.
6.9.3. Deploying a Policy in a Host Group Using Puppet
After you deploy a compliance policy in a host group using Puppet, the Puppet agent installs the SCAP client and configures OpenSCAP scans on the hosts on the next Puppet run according to the selected compliance policy.
  • You have created a compliance policy with the Puppet deployment option and assigned the host group.
  3. In the Environment list, select the Puppet environment that contains the foreman_scap_client* Puppet classes.
  4. In the OpenSCAP Smart Proxy list, select the Smart Proxy with OpenSCAP enabled that you want to use.
  5. On the Puppet ENC tab, add the foreman_scap_client Puppet class.
  6. Optional: Configure any Puppet Class Parameters.
6.9.4. Deploying a Policy on a Host Using Puppet
After you deploy a compliance policy on a host using Puppet, the Puppet agent installs the SCAP client and configures OpenSCAP scans on the host on the next Puppet run according to the selected compliance policy.
  • You have created a compliance policy with the Puppet deployment option.
  2. From the Environment list, select the Puppet environment that contains the foreman_scap_client and foreman_scap_client::params Puppet classes.
  4. On the Puppet ENC tab, add the foreman_scap_client Puppet class.
  5. Optional: Configure any Puppet Class Parameters.
6.10. Running a Security Compliance Scan on Demand
Hosts perform OpenSCAP scans regularly by the CRON schedule defined in the compliance policies assigned to hosts. However, you can also run a scan on a host for all configured compliance policies manually at any time.
  • Your user account has the view_hosts, create_job_invocations, and view_job_invocations permissions.
  • You have created a compliance policy and deployed it on the host.
  1. Navigate to Hosts > All Hosts.
  2. Click the hostname of the required host.
  3. On the host details page, expand the Schedule a job dropdown menu.
  4. Select Run OpenSCAP scan.
  1. In the host details overview, locate the Recent jobs card.
  2. Select the Running tab. Unless the job has already finished, the table shows a job called Run scan for all OpenSCAP policies.
  3. On the Recent jobs card, select the Finished tab.
  4. If the job has finished successfully, you should see the succeeded status in the row of the job.
  5. Optional: Click the job name to review invocation details.
6.11. Monitoring Compliance
With Foreman, you can centralize compliance monitoring and management. A compliance dashboard provides an overview of compliance of hosts and the ability to view details for each host within the scope of that policy. Compliance reports provide a detailed analysis of compliance of each host with the applicable policy. With this information, you can evaluate the risks presented by each host and manage the resources required to bring hosts into compliance. By monitoring compliance with SCAP, you can verify policy compliance and detect changes in compliance.
6.11.1. Searching Compliance Reports
Use the Compliance Reports search field to filter the list of available reports on any subset of hosts.
  2. Optional: To see a list of available search parameters, click the empty Search field.
  3. Enter the search query in the Search field and click Search. The search query is case insensitive.
Search Query Examples
Find all compliance reports for which more than five rules failed
failed > 5
Find all compliance reports created after January 1, 2023, for hosts with hostnames that contain prod-
host ~ prod- AND date > "Jan 1, 2023"
Find all reports generated by the rhel7_audit compliance policy from an hour ago
Find reports that pass an XCCDF rule
Find reports that fail an XCCDF rule
Find reports that have a result different than fail or pass for an XCCDF rule
  • You can create complex queries with the following logical operators: and, not and has. For more information about logical operators, see Supported Operators for Granular Search in Administering Foreman.
  • You cannot use regular expressions in a search query. However, you can use multiple fields in a single search expression. For more information about all available search operators, see Supported Operators for Granular Search in Administering Foreman.
  • You can bookmark a search to reuse the same search query. For more information, see Creating Bookmarks in Administering Foreman.
6.11.2. Compliance Email Notifications
Foreman server sends an OpenSCAP Summary email to all users who subscribe to the Compliance policy summary email notifications. For more information on subscribing to email notifications, see Configuring Email Notification Preferences.
Each time a policy is run, Foreman checks the results against the previous run, noting any changes between them. The email is sent according to the frequency requested by each subscriber, providing a summary of each policy and its most recent result.
6.11.3. Viewing Compliance Policy Statistics
You can view a compliance policy dashboard to verify compliance reports of a particular policy. The compliance policy dashboard provides a statistical summary of compliance of hosts and the ability to view report details for each host within the scope of that policy.
Consider prioritizing the following hosts when viewing compliance reports:
  • Hosts which were evaluated as Failed
  • Hosts labelled as Never audited because their status is unknown
Prerequisite
  2. In the row of the required policy, navigate to the Actions column and click Dashboard.
6.11.4. Examining Hosts per Rule Compliance Result
You can examine a simplified report and use policy rules to list hosts that have a certain compliance result, such as failing a particular rule.
Prerequisite
  • Your user account has the view_arf_reports and view_hosts permissions.
  2. In the Reported At column, navigate to the report of the required host and compliance policy, and click the time link.
  3. Foreman displays a simplified list of policy rules with the results of the scan.
  4. Optional: Filter the rules by check result. From the Show log messages dropdown list, select one of the following filters:
    • Failed and othered – to view rules that have failed or have not been checked during the scan,
    • Failed only – to view only rules that have failed.
  5. Optional: Examine the details of the rule. In the Message column, click the icon next to the name of the rule.
  6. In the row of the required rule, navigate to the Actions column and click Hosts failing this rule.
6.11.5. Examining Compliance Failures of a Host
You can examine a full compliance report, determine why a host failed compliance on a rule, and, in some cases, see how to remediate a case of non-compliance.
Warning
Do not implement any of the recommended remedial actions or scripts without first testing them in a non-production environment. Remediation might render the system non-functional.
  • Introduction
  • Evaluation Characteristics
  • Compliance and Scoring
  • Rule Overview
Prerequisite
  2. In the row of the required host, navigate to the Actions column and click Full Report to view the complete details of an evaluation report.
  3. Navigate to the Evaluation Characteristics area to review basic details about the evaluation of the host against a specific profile.
  4. Navigate to the Compliance and Scoring area to review evaluation statistics and the host compliance score.
  5. Navigate to the Rule Overview to examine the rules.
  6. Optional: Deselect the check statuses that you want to hide, such as pass, notapplicable, or fixed.
  7. Optional: From the Group rule by dropdown menu, select the criterion for the grouping of rules, such as Severity.
  8. Optional: Enter a search string into the search field to filter rules by title. The search is case insensitive and applied dynamically as you type.
  9. Click the title of a rule to inspect further result details:
    • The rationale for the rule.
6.11.6. Deleting a Compliance Report
Prerequisite
  • Your user account has the view_arf_reports and destroy_arf_reports permissions.
  3. Click OK.
6.11.7. Deleting Multiple Compliance Reports
You can delete multiple compliance policies simultaneously. However, in the Foreman web UI, compliance policies are paginated, so you must delete one page of reports at a time.
Prerequisite
7. Backing Up Foreman server and Smart Proxy Server
Conventional Backup Methods
You can also use conventional backup methods. For more information, see Recovering and restoring a system in Red Hat Enterprise Linux 8 Configuring basic system settings.
7.1. Estimating the Size of a Backup
    100G    /var/lib/pgsql/data
    100G	/var/lib/pulp
    886M  /var/lib/qpidd
    16M   /var/lib/tftpboot
    37M   /etc
    900K  /root/ssl-build
    100K  /var/www/html/pub
    2M    /opt/puppetlabs
    942M  total
    Table 5. Backup Data Compression Ratio
    PostgreSQL database files
    /var/lib/pgsql/data
    80 – 85%
    100 GB → 20 GB
    Pulp RPM files
    /var/lib/pulp
    (not compressed)
    100 GB
    Configuration files
    /var/lib/qpidd
    /var/lib/tftpboot
    /etc
    /root/ssl-build
    /var/www/html/pub
    /opt/puppetlabs
    85%
    942 MB → 141 MB
7.2. Performing a Full Backup of Foreman server or Smart Proxy Server
  • Offline backup
  • Online backup
  • Snapshot backups
Offline backups
Online backups
Snapshots backups
Directory creation
  • foreman-backup on Foreman
Remote databases
Warning
7.3. Performing a Backup without Pulp Content
Warning
7.4. Performing an Incremental Backup
Warning
7.5. Example of a Weekly Full Backup Followed by Daily Incremental Backups
#!/bin/bash -e
else
fi
exit 0
7.6. Performing an Online Backup
Warning
7.7. Performing a Snapshot Backup
Warning
  • The system uses LVM for the directories that you snapshot: /var/lib/pulp/, and /var/lib/pgsql.
7.8. White-listing and Skipping Steps When Performing Backups
8. Restoring Foreman server or Smart Proxy Server from a Backup
You can restore Foreman server or Smart Proxy server from the backup data that you create as part of Backing Up Foreman server and Smart Proxy Server. This process outlines how to restore the backup on the same server that generated the backup, and all data covered by the backup is deleted on the target system. If the original system is unavailable, provision a system with the same configuration settings and host name.
8.1. Restoring from a Full Backup
    # df -h /var/backup_directory
    # restorecon -Rv /
Additional Resources
8.2. Restoring from Incremental Backups
8.3. Backup and Restore Smart Proxy Server Using a Virtual Machine Snapshot
8.3.1. Synchronizing an External Smart Proxy
9. Maintaining Foreman server
9.1. Deleting Audit Records Manually
9.2. Deleting Audit Records Automatically
9.3. Anonymizing Audit Records
9.4. Deleting Report Records
9.5. Configuring the Cleaning Unused Tasks Feature
9.6. Deleting Task Records
9.7. Deleting a Task by ID
  2. Optional: View the task:
  3. Delete the task:
9.8. Reclaiming PostgreSQL Space
10. Logging and Reporting Problems
10.1. Enabling Debug Logging
10.2. Increasing the Logging Levels to Help with Debugging
# hammer admin logging --list
10.2.1. Increasing the Logging Level For Hammer
:log_level: 'debug'
10.2.2. Increasing the Logging Level On Smart Proxy
:log_level: DEBUG
Caution
10.2.3. Increasing the Logging Level On Foreman
    :logging:
      :production:
        :type: file
        :layout: pattern
        :level: debug
    :loggers:
      :ldap:
        :enabled: true
      :permissions:
        :enabled: true
      :sql:
        :enabled: true
  3. Restart Foreman services:
10.2.4. Increasing the Logging Level For Redis
loglevel debug
10.2.5. Increasing the Logging Level For Postgres
You can find the log for Postgres in /var/lib/pgsql/data/log. Uncomment the log_statement in /var/lib/pgsql/data/postgresql.conf:
log_statement = 'all'
Ensure to restart Foreman services afterwards:
Caution
10.2.6. Increasing the Logging Level For Foreman Installer
10.2.7. Increasing the Logging Level For Puppet Agent
  1. Add the following line to the [agent] block in the /etc/puppetlabs/puppet/puppet.conf file:
    [agent]
        log_level = debug
10.2.8. Increasing the Logging Level For Puppet Server
    [master]
        log_level = debug
  2. Restart the Puppet server:
10.2.9. Increasing the Logging Level For Salt
You can increase the log level for Salt Master (/etc/salt/master) and Salt Minion (/etc/salt/minion) by changing the following option:
log_level: debug
Salt Master logs to /var/log/salt/master and Salt Minions log to /var/log/salt/minion.
10.3. Retrieving the Status of Services
CLI procedure
    # hammer ping
10.4. Restarting Services
Foreman uses a set of back-end services to perform tasks. You you experience an issue with your Foreman, check the status of Foreman services.
Tip
10.5. Enabling Individual Loggers
app
audit
background
blob
dynflow
ldap
notifications
permissions
sql
telemetry
templates
    --foreman-loggers ldap:true \
    --foreman-loggers sql:true
10.6. Configuring Logging to Journal or File-based Logging
Foreman uses file-based logging by default. You can use the foreman-installer command to reconfigure logging.
Procedure for configuring logging with Journal
    --foreman-proxy-log JOURNAL
    --reset-foreman-logging-layout \
    --reset-foreman-proxy-log
    • /var/log/foreman-proxy.log
10.7. Log File Directories Provided by Foreman
Table 6. Log File Directories for Reporting and Troubleshooting
/var/log/candlepin
Subscription management
Installer
/var/log/foreman-maintain
Foreman maintain
Foreman proxy
/var/log/foreman
Foreman
/var/log/httpd
Apache HTTP server
/var/log/messages
Various other log messages
Configuration management
/var/log/rhsm
/var/log/tomcat
Candlepin webservice logs
10.8. Utilities for Collecting Log Information
sosreport
The collection process removes security information such as passwords, tokens, and keys while collecting information. However, the tar files can still contain sensitive information about the Foreman server. Foreman community recommends that you send this information directly to the intended recipient and not to a public target.
10.9. System Journal Metadata
Table 7. System Journal Metadata
Name Description
AUDIT_ACTION
Audit action performed
AUDIT_TYPE
Audit resource type
AUDIT_ID
AUDIT_ATTRIBUTE
AUDIT_FIELD_OLD
AUDIT_FIELD_NEW
AUDIT_ID
AUDIT_ATTRIBUTE
Example: Name or description
EXCEPTION_MESSAGE
EXCEPTION_CLASS
EXCEPTION_BACKTRACE
LOC_ID
Location database ID
LOC_NAME
Location name
LOC_LABEL
Location label
LOGGER
Logger name
ORG_ID
Organization database ID
ORG_NAME
Organization name
ORG_LABEL
Organization label
REMOTE_IP
Remote IP address of a client
REQUEST
SESSION
TEMPLATE_NAME
Template name
TEMPLATE_DIGEST
TEMPLATE_HOST_NAME
TEMPLATE_HOST_ID
USER_LOGIN
User login name
11. Monitoring Resources
11.1. Using the Foreman Content Dashboard
Host Configuration Status
Table 8. Host Configuration States
Icon State Description
host state config okay
host state config error
Hosts in error state
host state config report
host state config pending
host state config outofsync
Out of sync hosts
host state config noreport
Hosts with no reports
host state config noalert
Hosts with alerts disabled
Host Configuration Chart
Latest Events
New Hosts
Task Status
Latest Warning/Error Tasks
Discovered Hosts
Latest Errata
Content Views
Sync Overview
Host Subscription Status
Table 9. Host Subscription States
host state sub invalid
Invalid
host state sub partial
Partial
host state sub valid
Valid
Subscription Status
Host Collections
Virt-who Configuration Status
Table 10. Virt-who Configuration States
State Description
No Reports
No Change
OK
Total Configurations
Latest Compliance Reports
Compliance Reports Breakdown
Red Hat Insights Actions
Red Hat Insights Risk Summary
11.1.1. Managing Tasks
To Adjust Timeout Settings:
  5. Click Save.
11.2. Configuring RSS Notifications
11.3. Monitoring Foreman server
11.4. Monitoring Smart Proxy Server
11.4.1. Viewing General Smart Proxy Information
11.4.2. Monitoring Services
11.4.3. Monitoring Puppet
12. Using Webhooks
12.1. Migrating to Webhooks
12.2. Installing Webhooks
  • Optional: you can install the CLI plugin using the following command:
12.3. Creating a Webhook Template
  1. In the Foreman web UI, navigate to Administer > Webhook Templates.
  7. Click Submit.
Examples
Running remote execution jobs
Creating users
12.4. Creating a Webhook
  1. In the Foreman web UI, navigate to Administer > Webhooks.
  2. Click Create new.
  7. Enter an HTTP method.
  9. Click the Credentials tab.
When configuring webhooks with endpoints with non-standard HTTP or HTTPS ports, an SELinux port must be assigned, see Configuring SELinux to Ensure Access to Foreman on Custom Ports in Installing Foreman 3.5 Server on RHEL/CentOS.
12.5. Available Webhook Events
A Content View was successfully promoted.
Run OpenSCAP scan.
Perform a single Puppet run.
Build Entered
Build Exited
Common database operations on a Content View.
Domain
Host
Hostgroup
Model
Status Changed
Subnet
Template Render Performed
Template
User
12.6. Shellhooks
12.7. Installing the Shellhooks Plugin
12.8. Passing Arguments to Shellhook Script Using Webhooks
      "X-Shellhook-Arg-1": "VALUE",
      "X-Shellhook-Arg-2": "VALUE"
Example
12.9. Passing Arguments to Shellhook Script Using Curl
    "X-Shellhook-Arg-1: VALUE"
    "X-Shellhook-Arg-2: VALUE"
Example
-H "X-Shellhook-Arg-2: My Content View" \
--data "" https://smartproxy.example.com:8443/shellhook/My_Script
12.10. Creating a Shellhook to Print Arguments
Prerequisite
    #!/bin/sh
    echo "$@" >&2
  2. In the Foreman web UI, navigate to Administer > Webhooks.
  3. Click Create new.
        "X-Shellhook-Arg-1": "Hello",
        "X-Shellhook-Arg-2": "World!"
  1. Run a remote execution job on any host. You can use time as a command. For more information, see Executing a Remote Job in Managing Hosts.
    [W] [3520] Hello World!
13. Searching and Bookmarking
13.1. Building Search Queries
13.1.1. Query Syntax
parameter operator value
13.1.2. Query Operators
Table 11. Comparison Operators Accepted by Search
EQUALS
hostgroup = RHEL7
NOT EQUALS
LIKE
hostgroup ~ rhel%
NOT LIKE
GREATER THAN
registered_at <= Yesterday
LESS THAN
IN
release_version !^ 7
NOT IN
HAS or set?
NOT HAS or null?
Table 12. Logical Operators Accepted by Search
and
<whitespace>
or
not
13.1.3. Query Values
Text Values
Examples:
hostgroup = "Web servers"
hostgroup = Web servers
Temporal Values
  • "10 January 2017"
  • "10 Jan 2017"
  • 10-January-2017
  • 10/January/2017
  • "January 10, 2017"
Warning
13.2. Using Free Text Search
13.3. Managing Bookmarks
13.3.1. Creating Bookmarks
  7. Click Submit.
13.3.2. Deleting Bookmarks
A.1. General Settings
Administrator email address
Foreman URL
Entries per page
20
Fix DB cache
DB pending seed
Smart Proxy request timeout
60
Login page footer text
HTTP(S) proxy
HTTP(S) proxy except hosts
Show Experimental Labs
Out of sync interval
30
Foreman UUID
Default language
Default timezone
Instance title
New host details UI
A.2. Tasks settings
Sync task timeout
120
Enable dynflow console
Proxy action retry count
4
Proxy action retry interval
15
Allow proxy batch tasks
Proxy tasks batch size
100
Tasks troubleshooting URL
Polling intervals multiplier
1
A.3. Template Sync Settings
Associate
Branch
Default branch in Git repo.
Commit message
Dirname
Filter
Force import
Lock templates
Keep, do not lock new
Metadata export mode
Refresh
Default metadata export mode.
Possible options:
refresh re-renders metadata.
keep keeps existing metadata.
Negate
Prefix
Repo
/tmp/dir
git://example.com
https://example.com
ssh://example.com
Verbosity
A.4. Discovery Settings
Discovery location
Discovery organization
Interface fact
discovery_bootif
Create bond interfaces
Clean all facts
Hostname facts
discovery_bootif
Auto provisioning
Reboot
Hostname prefix
mac
Fact columns
Highlighted facts
Storage facts
Software facts
Hardware facts
Network facts
IPMI facts
Lock PXE
Locked PXELinux template name
pxelinux_discovery
Locked PXEGrub template name
pxegrub_discovery
Locked PXEGrub2 template name
pxegrub2_discovery
Force DNS
Error on existing NIC
Type of name generator
Fact + prefix
Prefer IPv6
A.5. Boot Disk Settings
iPXE directory
/usr/share/ipxe
ISOLINUX directory
/usr/share/syslinux
SYSLINUX directory
/usr/share/syslinux
Grub2 directory
/var/lib/tftpboot/grub2
Host image template
Boot disk iPXE - host
Generic image template
Boot disk iPXE - generic host
ISO generation command
genisoimage
Installation media caching
Allowed bootdisk types
A.6. Content Settings
Default HTTP Proxy
CDN SSL version
Kickstart default
Kickstart default finish
Default synced OS user-data
Kickstart default user data
Kickstart default PXELinux
Kickstart default PXEGrub
Kickstart default PXEGrub2
Kickstart default iPXE
Kickstart default
Atomic Kickstart default
Manifest refresh timeout
1200
Accept action timeout
20
Finish action timeout
3600
Check services before actions
100
immediate
on_demand
on_demand
/var/lib/pulp/katello-export
/var/lib/pulp/exports
Pulp client key
Pulp client cert
Sync Connection Timeout
300
Delete Host upon unregister
Default Location
Expire soon days
120
Host Duplicate DMI UUIDs
Host Profile Assume
Host Tasks Workers Pool Size
5
Applicability Batch Size
50
Autosearch
Autosearch delay
500
Pulp bulk load size
2000
1440
A.7. Authentication Settings
OAuth active
OAuth consumer key
OAuth consumer key.
OAuth consumer secret
OAuth consumer secret.
OAuth map users
Failed login attempts limit
30
Trusted hosts
SSL certificate
/etc/foreman/client_cert.pem
SSL CA file
/etc/foreman/proxy_ca.pem
SSL private key
/etc/foreman/client_key.pem
SSL client DN env
HTTP_SSL_CLIENT_S_DN
SSL client verify env
HTTP_SSL_CLIENT_VERIFY
SSL client cert env
HTTP_SSL_CLIENT_CERT
Server CA file
Websockets SSL key
Websockets SSL certificate
Websockets encryption
Login delegation logout URL
External
Idle timeout
60
BCrypt password cost
9
BMC credentials access
OIDC JWKs URL
OIDC Audience
OIDC Issuer
OIDC Algorithm
A.8. Email Settings
Email reply address
Email subject prefix
Send welcome email
Delivery method
Sendmail
Method used to deliver email.
SMTP enable StartTLS auto
SMTP OpenSSL verify mode
Default verification mode
SMTP address
SMTP address to connect to.
SMTP port
25
SMTP port to connect to.
SMTP HELO/EHLO domain
HELO/EHLO domain.
SMTP username
SMTP password
SMTP authentication
none
Sendmail arguments
-i
Sendmail location
/usr/sbin/sendmail
A.9. Notifications Settings
RSS enable
Pull RSS notifications.
RSS URL
A.10. Provisioning Settings
Host owner
Root password
Unattended URL
Safemode rendering
Query local nameservers
Installation token lifetime
360
SSH timeout
120
0.0.0.0
Update IP from built request
Use short name for VMs
DNS timeout
[5, 10, 15, 20]
Clean up failed deployment
Random-based
iPXE intermediate script
Maximum structured facts
100
Global Registration
Global Registration template.
CoreOS Transpiler Command
PXEGrub2 global default
PXELinux global default
PXEGrub global default
Global default iPXE template
iPXE global default
Local boot PXEGrub2 template
PXEGrub2 default local boot
Local boot PXELinux template
PXELinux default local boot
Local boot PXEGrub template
PXEGrub default local boot
Local boot iPXE template
iPXE default local boot
Manage PuppetCA
Use UUID for certificates
A.11. Facts Settings
Location fact
foreman_location
Organization fact
foreman_organization
Default location
Default Location
Default organization
Default Organization
Update hostgroup from facts
Ignore facts for domain
Update subnets from facts
None
Default Puppet environment
production
ENC environment
Update environment from facts
Matchers inheritance
[fqdn, hostgroup, os, domain]
Interpolate ERB in parameters
Puppet interval
35
Puppet out of sync disabled
Fallback to Any Proxy
Enable Global Proxy
SSH User
root
Effective User
root
Effective User Method
sudo
Effective user password
Sync Job Templates
SSH Port
22
Connect by IP
Prefer IPv6 over IPv4
Default SSH password
Default SSH key passphrase
Workers pool size
5
Cleanup working directories
Cockpit URL
Form Job Template
Run Command - SSH Default
Time to pickup
86400
Time in seconds within which the host has to pick up a job. If the job is not picked up within this limit, the job will be cancelled. Applies only to pull-mqtt based jobs. Defaults to one day.
A.14. Ansible Settings
Private Key Path
Connection type
ssh
WinRM cert Validation
validate
Default verbosity level
Disabled
Post-provision timeout
360
Ansible report timeout
30
Ansible out of sync disabled
Ansible - Ansible Inventory
Ansible roles to ignore
