1. Accessing orcharhino
After orcharhino has been installed and configured, use the orcharhino management UI interface to log in to orcharhino for further configuration.
1.1. Importing the Katello Root CA Certificate
The first time you log in to orcharhino, you might see a warning informing you that you are using the default self-signed certificate and you might not be able to connect this browser to orcharhino until the root CA certificate is imported in the browser. Use the following procedure to locate the root CA certificate on orcharhino and to import it into your browser.
To use the CLI instead of the orcharhino management UI, see CLI Procedure.
Your orcharhino is installed and configured.
Identify the fully qualified domain name of your orcharhino Server:
# hostname -f
Access the
pub
directory on your orcharhino Server using a web browser pointed to the fully qualified domain name:https://orcharhino.example.com/pub
When you access orcharhino for the first time, an untrusted connection warning displays in your web browser. Accept the self-signed certificate and add the orcharhino URL as a security exception to override the settings. This procedure might differ depending on the browser being used. Ensure that the orcharhino URL is valid before you accept the security exception.
Select
katello-server-ca.crt
Import the certificate into your browser as a certificate authority and trust it to identify websites.
From the orcharhino CLI, copy the
file to the machine you use to access the orcharhino management UI:# scp /var/www/html/pub/katello-server-ca.crt username@hostname:remotefile
In the browser, import the
certificate as a certificate authority and trust it to identify websites.
1.2. Logging in to orcharhino
Use the web user interface to log in to orcharhino for further configuration.
Ensure that the Katello root CA certificate is installed in your browser. For more information, see Importing the Katello Root CA Certificate.
Access orcharhino Server using a web browser pointed to the fully qualified domain name:
Enter the user name and password created during the configuration process. If a user was not created during the configuration process, the default user name is admin. If you have problems logging in, you can reset the password. For more information, see Resetting the Administrative User Password.
1.3. Navigation Tabs in the orcharhino management UI
Use the navigation tabs to browse the orcharhino management UI.
Navigation Tabs | Description |
Any Context |
Clicking this tab changes the organization and location. If no organization or location is selected, the default organization is Any Organization and the default location is Any Location. Use this tab to change to different values. |
Monitor |
Content |
Provides content management tools. This includes Content Views, Activation Keys, and Life Cycle Environments. |
Hosts |
Configure |
Provides general configuration tools and data including Host Groups and Puppet data. |
Infrastructure |
Provides tools on configuring how orcharhino interacts with the environment. |
User Name |
Provides user administration where users can edit their personal information. |
Administer |
Provides advanced configuration for settings such as Users and RBAC, as well as general settings. |
1.4. Changing the Password
Click your user name at the top right corner.
Select My Account from the menu.
In the Current Password field, enter the current password.
In the Password field, enter a new password.
In the Verify field, enter the new password again.
Click the Submit button to save your new password.
1.5. Resetting the Administrative User Password
Log in to the base operating system where orcharhino Server is installed.
Enter the following command to reset the password:
# foreman-rake permissions:reset Reset to user: admin, password: qwJxBptxb7Gfcjj5
Use this password to reset the password in the orcharhino management UI.
Edit the
~/.hammer/cli.modules.d/foreman.yml
file on orcharhino Server to add the new password:# vi ~/.hammer/cli.modules.d/foreman.yml
Unless you update the ~/.hammer/cli.modules.d/foreman.yml
file, you cannot use the new password with Hammer CLI.
To set the password, enter the following command:
Edit the
1.6. Setting a Custom Message on the Login Page
In the orcharhino management UI, navigate to Administer > Settings, and click the General tab.
Click the edit button next to Login page footer text, and enter the desired text to be displayed on the login page. For example, this text may be a warning message required by your company.
Click Save.
Log out of the orcharhino management UI and verify that the custom text is now displayed on the login page below the orcharhino version number.
2. Starting and Stopping orcharhino
orcharhino provides the foreman-maintain service
command to manage orcharhino services from the command line.
This is useful when creating a backup of orcharhino.
For more information on creating backups, see Backing Up orcharhino Server and orcharhino Proxy.
After installing orcharhino with the foreman-installer
command, all orcharhino services are started and enabled automatically.
To stop orcharhino services, execute:
To start orcharhino services, execute:
To restart orcharhino services, execute:
3. Migrating from Internal orcharhino Databases to External Databases
When you install orcharhino, the foreman-installer command installs PostgreSQL databases on the same server as orcharhino. If you are using the default internal databases but want to start using external databases to help with the server load, you can migrate your internal databases to external databases.
To confirm whether your orcharhino Server has internal or external databases, you can query the status of your databases:
Preparing a Host for External Databases. Prepare a Red Hat Enterprise Linux 8 server to host the external databases.
Installing PostgreSQL. Prepare PostgreSQL with databases for orcharhino, Pulp and Candlepin with dedicated users owning them.
Migrating to External Databases. Edit the parameters of
foreman-installer
to point to the new databases, and runforeman-installer
Foreman, Katello, and Candlepin use the PostgreSQL database. If you want to use PostgreSQL as an external database, the following information can help you decide if this option is right for your orcharhino configuration. orcharhino supports PostgreSQL version 12.
Increase in free memory and free CPU on orcharhino
Flexibility to set
shared_buffers
on the PostgreSQL database to a high number without the risk of interfering with other services on orcharhino -
Flexibility to tune the PostgreSQL server’s system without adversely affecting orcharhino operations
If either orcharhino or the PostgreSQL database server suffers a hardware or storage failure, orcharhino is not operational
If there is latency between the orcharhino server and database server, performance can suffer
The prepared host must meet orcharhino’s Storage Requirements.
Ensure the prepared host has the same content available as your orcharhino Server.
3.3. Installing PostgreSQL
You can install only the same version of PostgreSQL that is installed with the foreman-installer
tool during an internal database installation.
To install PostgreSQL, enter the following command:
# dnf install postgresql-server postgresql-evr
To initialize PostgreSQL, enter the following command:
# postgresql-setup initdb
Edit the
/var/lib/pgsql/data/postgresql.conf
file:# vi /var/lib/pgsql/data/postgresql.conf
Note that the default configuration of external PostgreSQL needs to be adjusted to work with orcharhino. The base recommended external database configuration adjustments are as follows:
max_connections: 500
shared_buffers: 512MB
work_mem: 4MB
Remove the
and edit to listen to inbound connections:listen_addresses = '*'
Edit the
/var/lib/pgsql/data/pg_hba.conf
file:# vi /var/lib/pgsql/data/pg_hba.conf
host all all orcharhino_ip/32 md5
To start, and enable PostgreSQL service, enter the following commands:
Open the postgresql port on the external PostgreSQL server:
# firewall-cmd --add-service=postgresql # firewall-cmd --runtime-to-permanent
Switch to the
postgres
user and start the PostgreSQL client:$ su - postgres -c psql
Create three databases and dedicated roles: one for orcharhino, one for Candlepin, and one for Pulp:
CREATE USER "foreman" WITH PASSWORD 'Foreman_Password'; CREATE USER "candlepin" WITH PASSWORD 'Candlepin_Password'; CREATE USER "pulp" WITH PASSWORD 'Pulpcore_Password'; CREATE DATABASE foreman OWNER foreman; CREATE DATABASE candlepin OWNER candlepin; CREATE DATABASE pulpcore OWNER pulp;
Exit the
postgres
user:# \q
From orcharhino Server, test that you can access the database. If the connection succeeds, the commands return
1
.# PGPASSWORD='Foreman_Password' psql -h postgres.example.com -p 5432 -U foreman -d foreman -c "SELECT 1 as ping" # PGPASSWORD='Candlepin_Password' psql -h postgres.example.com -p 5432 -U candlepin -d candlepin -c "SELECT 1 as ping" # PGPASSWORD='Pulpcore_Password' psql -h postgres.example.com -p 5432 -U pulp -d pulpcore -c "SELECT 1 as ping"
Back up and transfer existing data, then use the foreman-installer
command to configure orcharhino to connect to an external PostgreSQL database server.
You have installed and configured a PostgreSQL server on a Red Hat Enterprise Linux server.
On orcharhino Server, stop orcharhino services:
Start the PostgreSQL services:
# systemctl start postgresql
PGPASSWORD='Foreman_Password' pg_restore -h postgres.example.com -U foreman -d foreman < /var/migration_backup/foreman.dump PGPASSWORD='Candlepin_Password' pg_restore -h postgres.example.com -U candlepin -d candlepin < /var/migration_backup/candlepin.dump PGPASSWORD='Pulpcore_Password' pg_restore -h postgres.example.com -U pulp -d pulpcore < /var/migration_backup/pulpcore.dump
Use the
foreman-installer
command to update orcharhino to point to the new databases:foreman-installer --scenario katello \ --foreman-db-host postgres.example.com \ --foreman-db-password Foreman_Password \ --foreman-db-database foreman \ --foreman-db-manage false \ --foreman-db-username foreman \ --katello-candlepin-db-host postgres.example.com \ --katello-candlepin-db-name candlepin \ --katello-candlepin-db-password Candlepin_Password \ --katello-candlepin-manage-db false \ --katello-candlepin-db-user candlepin \ --foreman-proxy-content-pulpcore-manage-postgresql false \ --foreman-proxy-content-pulpcore-postgresql-host postgres.example.com \ --foreman-proxy-content-pulpcore-postgresql-db-name pulpcore \ --foreman-proxy-content-pulpcore-postgresql-password Pulpcore_Password \ --foreman-proxy-content-pulpcore-postgresql-user pulp
4. Managing orcharhino with Ansible Collections
orcharhino Ansible Collections is a set of Ansible modules that interact with the orcharhino API. You can use orcharhino Ansible Collections to manage and automate many aspects of orcharhino.
5. Managing Users and Roles
Roles define a set of permissions and access levels. Each role contains one on more permission filters that specify the actions allowed for the role. Actions are grouped according to the Resource type. Once a role has been created, users and user groups can be associated with that role. This way, you can assign the same set of permissions to large groups of users. orcharhino provides a set of predefined roles and also enables creating custom roles and permission filters as described in Creating and Managing Roles.
5.1. Managing Users
As an administrator, you can create, modify and remove orcharhino users. You can also configure access permissions for a user or a group of users by assigning them different roles.
5.1.1. Creating a User
Use this procedure to create a user. To use the CLI instead of the orcharhino management UI, see the CLI procedure.
Click Create User.
In the Login field, enter a username for the user.
In the Firstname and Lastname fields, enter the real first name and last name of the user.
In the Mail field, enter the user’s email address.
In the Description field, add a description of the new user.
Select a specific language for the user from the Language list.
Select a timezone for the user from the Timezone list.
By default, orcharhino Server uses the language and timezone settings of the user’s browser.
Set a password for the user:
From the Authorized by list, select the source by which the user is authenticated.
INTERNAL: to enable the user to be managed inside orcharhino Server.
EXTERNAL: to configure external authentication as described in Configuring External Authentication in Installing orcharhino Server.
Enter an initial password for the user in the Password field and the Verify field.
To create a user, enter the following command:
# hammer user create \ --auth-source-id My_Authentication_Source \ --login My_User_Name \ --mail My_User_Mail \ --organization-ids My_Organization_ID_1,My_Organization_ID_2 \ --password My_User_Password
The
--auth-source-id 1
setting means that the user is authenticated internally, you can specify an external authentication source as an alternative. Add the--admin
option to grant administrator privileges to the user. Specifying organization IDs is not required, you can modify the user details later using theupdate
subcommand.
For more information about user related subcommands, enter hammer user --help
Use this procedure to assign roles to a user. To use the CLI instead of the orcharhino management UI, see the CLI procedure.
NoteIf a user account is not listed, check that you are currently viewing the correct organization. To list all the users in orcharhino, click Default Organization and then Any Organization.
Click Submit.
Administrators can impersonate other authenticated users for testing and troubleshooting purposes by temporarily logging on to the orcharhino management UI as a different user. When impersonating another user, the administrator has permissions to access exactly what the impersonated user can access in the system, including the same menus.
Ensure that you are logged on to the orcharhino management UI as a user with administrator privileges for orcharhino.
5.1.4. Creating an API-Only User
You can create users that can interact only with the orcharhino API.
You have created a user and assigned roles to them. Note that this user must be authorized internally. For more information, see Creating a User and Assigning Roles to a User.
Log in to your orcharhino as admin.
# openssl rand -hex 32
5.2. Managing SSH Keys
Use this procedure to add or remove SSH keys for a user. To use the CLI instead of the orcharhino management UI, see the CLI procedure.
Ensure that you are logged in to the orcharhino management UI as an Admin user of orcharhino or a user with the create_ssh_key permission enabled for adding SSH key and destroy_ssh_key permission for removing a key.
Click on the SSH Keys tab.
To Add SSH key
Click Add SSH Key.
Click Submit.
To Remove SSH key
# hammer user ssh-keys add \ --user-id user_id \ --name key_name \ --key-file ~/.ssh/id_rsa.pub
# hammer user ssh-keys add \ --user-id user_id \ --name key_name \ --key ecdsa-sha2-nistp256 AAAAE2VjZHNhLXNoYTItbmlzdHAyNTYAAAAIbmlzdHAyNtYAAABBBHHS2KmNyIYa27Qaa7EHp+2l99ucGStx4P77e03ZvE3yVRJEFikpoP3MJtYYfIe8k 1/46MTIZo9CPTX4CYUHeN8= host@user
5.3. Managing Personal Access Tokens
5.3.1. Creating a Personal Access Token
# curl https://orcharhino.example.com/api/status --user My_Username:My_Personal_Access_Token
200
, for example:{"orcharhino_version":"6.5.0","result":"ok","status":200,"version":"3.5.1.10","api_version":2}
5.3.2. Revoking a Personal Access Token
5.4. Creating and Managing User Groups
5.4.1. User Groups
With orcharhino, you can assign permissions to groups of users. You can also create user groups as collections of other user groups. If using an external authentication source, you can map orcharhino user groups to external user groups as described in Configuring External User Groups in Installing orcharhino Server.
5.4.2. Creating a User Group
In the orcharhino management UI, navigate to Administer > User Groups.
Click Create User group.
Click Submit.
To create a user group, enter the following command:
# hammer user-group create \ --name My_User_Group_Name \ --role-ids My_Role_ID_1,My_Role_ID_2 \ --user-ids My_User_ID_1,My_User_ID_2
5.5. Creating and Managing Roles
orcharhino provides a set of predefined roles with permissions sufficient for standard tasks, as listed in Predefined Roles Available in orcharhino. It is also possible to configure custom roles, and assign one or more permission filters to them. Permission filters define the actions allowed for a certain resource type. Certain orcharhino plug-ins create roles automatically.
5.5.1. Creating a Role
In the orcharhino management UI, navigate to Administer > Roles.
Click Create Role.
Provide a Name for the role.
5.5.2. Cloning a Role
Use the orcharhino management UI to clone a role.
In the orcharhino management UI, navigate to Administer > Roles and select Clone from the drop-down menu to the right of the required role.
5.5.3. Adding Permissions to a Role
Use this procedure to add permissions to a role. To use the CLI instead of the orcharhino management UI, see the CLI procedure.
Depending on the Resource type selected, you can select or deselect the Unlimited and Override checkbox. The Unlimited checkbox is selected by default, which means that the permission is applied on all resources of the selected type. When you disable the Unlimited checkbox, the Search field activates. In this field you can specify further filtering with use of the orcharhino search syntax. For more information, see Granular Permission Filtering. When you enable the Override checkbox, you can add additional locations and organizations to allow the role to access the resource type in the additional locations and organizations; you can also remove an already associated location and organization from the resource type to restrict access.
Click Next.
Click Submit to save changes.
Add permissions to a role:
# hammer filter create \ --permission-ids My_Permission_ID_1,My_Permission_ID_2 \ --role My_Role_Name
For more information about roles and permissions parameters, enter the hammer role --help
and hammer filter --help
commands.
5.5.4. Viewing Permissions of a Role
Use the orcharhino management UI to view the permissions of a role.
The Filters page contains a table of permissions assigned to a role grouped by the resource type. It is also possible to generate a complete table of permissions and actions that you can use on your orcharhino system. For more information, see Creating a Complete Permission Table.
5.5.5. Creating a Complete Permission Table
Ensure that the required packages are installed. Execute the following command on orcharhino Server:
# dnf install foreman-console
Start the orcharhino console with the following command:
# foreman-rake console
f = File.open('/tmp/table.html', 'w') result = Foreman::AccessControl.permissions {|a,b| a.security_block <=> b.security_block}.collect do |p| actions = p.actions.collect { |a| "<li>#{a}</li>" } "<tr><td>#{p.name}</td><td><ul>#{actions.join('')}</ul></td><td>#{p.resource_type}</td></tr>" end.join("\n") f.write(result)
The above syntax creates a table of permissions and saves it to the
/tmp/table.html
file. -
Press
Ctrl
+D
to exit the orcharhino console. Insert the following text at the first line of/tmp/table.html
:<table border="1"><tr><td>Permission name</td><td>Actions</td><td>Resource type</td></tr>
/tmp/table.html
:</table>
Open
/tmp/table.html
in a web browser to view the table.
5.6. Predefined Roles Available in orcharhino
The following table provides an overview of permissions that predefined roles in orcharhino grant to a user.
To view the exact set of permissions a predefined role grants, display the role in orcharhino management UI as the privileged user. For more information, see Viewing Permissions of a Role.
Role | Permissions Provided by Role |
Access Insights Admin |
Add and edit Insights rules. |
Access Insights Viewer |
View Insight reports. |
Ansible Roles Manager |
Play roles on hosts and host groups. View, destroy, and import Ansible roles. View, edit, create, destroy, and import Ansible variables. |
Ansible Tower Inventory Reader |
View facts, hosts, and host groups. |
Bookmarks manager |
Create, edit, and delete bookmarks. |
Boot disk access |
Download the boot disk. |
Compliance manager |
View, create, edit, and destroy SCAP content files, compliance policies, and tailoring files. View compliance reports. |
Compliance viewer |
Create ARF report |
Create compliance reports. |
Default role |
The set of permissions that every user is granted, irrespective of any other roles. |
Discovery Manager |
View, provision, edit, and destroy discovered hosts and manage discovery rules. |
Discovery Reader |
View hosts and discovery rules. |
Edit hosts |
View, create, edit, destroy, and build hosts. |
Edit partition tables |
View, create, edit and destroy partition tables. |
Manager |
Organization admin |
All permissions except permissions for managing organizations. An administrator role defined per organization. The role has no visibility into resources in other organizations. By cloning this role and assigning an organization, you can delegate administration of that organization to a user. |
Red Hat Access Logs |
View the log viewer and the logs. |
Remote Execution Manager |
Control which roles have permission to run infrastructure jobs. |
Remote Execution User |
Run remote execution jobs against hosts. |
Site manager |
System admin |
Users with this role can create users and assign all roles to them. Therefore, ensure to give this role only to trusted users. |
Tasks manager |
View and edit orcharhino tasks. |
Tasks reader |
A role that can only view orcharhino tasks. |
Viewer |
A passive role that provides the ability to view the configuration of every element of the orcharhino structure, logs, reports, and statistics. |
View hosts |
A role that can only view hosts. |
Virt-who Manager |
A role with full virt-who permissions. |
Virt-who Reporter |
Upload reports generated by virt-who to orcharhino. It can be used if you configure virt-who manually and require a user role that has limited virt-who permissions. |
Virt-who Viewer |
View virt-who configurations. Users with this role can deploy virt-who instances using existing virt-who configurations. |
5.7. Granular Permission Filtering
As mentioned in Adding Permissions to a Role, orcharhino provides the ability to limit the configured user permissions to selected instances of a resource type. These granular filters are queries to the orcharhino database and are supported by the majority of resource types.
5.7.1. Creating a Granular Permission Filter
Use this procedure to create a granular filter. To use the CLI instead of the orcharhino management UI, see the CLI procedure.
orcharhino does not apply search conditions to create actions. For example, limiting the create_locations action with name = "Default Location" expression in the search field does not prevent the user from assigning a custom name to the newly created location.
field_name operator value
operator specifies the type of comparison between field_name and value. See Supported Operators for Granular Search for an overview of applicable operators.
command with the--search
option to limit permission filters, for example:# hammer filter create \ --permission-ids 91 \ --search "name ~ ccv*" \ --role qa-user
This command adds to the qa-user role a permission to view, create, edit, and destroy Content Views that only applies to Content Views with name starting with ccv
5.7.2. Examples of Using Granular Permission Filters
hostgroup = host-editors
name ^ (XXXX, Yyyy, zzzz)
Dev
Use the orcharhino management UI to create an administrative role restricted to a single organization named org-1.
5.7.3. Supported Operators for Granular Search
Operator |
Description |
and |
Combines search criteria. |
not |
Negates an expression. |
has |
Operator |
Description |
6. Configuring Email Notifications
Email notifications are created by orcharhino Server periodically or after completion of certain events. The periodic notifications can be sent daily, weekly or monthly.
orcharhino Server does not enable outgoing emails by default, therefore you must review your email configuration. |
6.1. Email Notification Types
orcharhino can create the following email notifications:
Audit summary: A summary of all activity audited by orcharhino Server.
Host built: A notification sent when a host is built.
Host errata advisory: A summary of applicable and installable errata for hosts managed by the user.
Compliance policy summary: A summary of OpenSCAP policy reports and their results.
Promote errata: A notification sent only after a Content View promotion. It contains a summary of errata applicable and installable to hosts registered to the promoted Content View. This allows a user to monitor what updates have been applied to which hosts.
Sync errata: A notification sent only after synchronizing a repository. It contains a summary of new errata introduced by the synchronization.
For a complete list of email notification types, navigate to Administer > Users in the orcharhino management UI, click the Username of the required user, and select the Email Preferences tab.
6.2. Configuring Email Notification Preferences
You can configure orcharhino to send email messages to individual users registered to orcharhino. orcharhino sends the email to the email address that has been added to the account, if present. Users can edit the email address by clicking on their name in the top-right of the orcharhino management UI and selecting My account.
Configure email notifications for a user from the orcharhino management UI.
If you want to send email notifications to a group email address instead of an individual email address, create a user account with the group email address and minimal orcharhino permissions, then subscribe the user account to the desired notification types. |
Click Submit.
6.3. Testing Email Delivery
Click on the username.
Verify orcharhino Server’s email configuration.
6.4. Testing Email Notifications
To trigger the notifications, execute the following command:
daily
weekly
monthly
6.5. Changing Email Notification Settings for a Host
orcharhino can send event notifications for a host to the host’s registered owner. You can configure orcharhino to send email notifications either to an individual user or a user group. When set to a user group, all group members who are subscribed to the email type receive a message.
In the orcharhino management UI, navigate to Hosts > All Hosts, locate the host that you want to view, and click Edit in the Actions column.
Go to the Additional Information tab. If the checkbox Include this host within orcharhino reporting is checked, then the email notifications are enabled on that host.
Security compliance management is the ongoing process of defining security policies, auditing systems for compliance with those policies, and resolving instances of non-compliance. Any non-compliance is managed according to the organization’s configuration management policies. Security policies range in scope from host-specific to industry-wide, therefore, flexibility in their definition is required.
With orcharhino, you can schedule compliance auditing and reporting on all registered hosts.
orcharhino uses the Security Content Automation Protocol (SCAP) standard to define security policies.
SCAP is a framework of several specifications based on XML, such as checklists described in the Extensible Checklist Configuration Description Format (XCCDF) and vulnerabilities described in the Open Vulnerability and Assessment Language (OVAL). These specifications are encapsulated as data stream files.
Checklist items in XCCDF, also known as rules, express the desired configuration of a system item.
For example, a rule may specify that no one can log in to a host over SSH using the root
user account.
Rules can be grouped into one or more XCCDF profiles, which allows multiple profiles to share a rule.
The OpenSCAP scanner tool evaluates system items on a host against the rules and generates a report in the Asset Reporting Format (ARF), which is then returned to orcharhino for monitoring and analysis.
Title |
Description |
Version |
SCAP |
Security Content Automation Protocol |
1.3 |
XCCDF |
Extensible Configuration Checklist Description Format |
1.2 |
OVAL |
Open Vulnerability and Assessment Language |
5.11 |
Asset Identification |
1.1 |
ARF |
Asset Reporting Format |
1.1 |
CCE |
Common Configuration Enumeration |
5.0 |
CPE |
Common Platform Enumeration |
2.3 |
CVE |
Common Vulnerabilities and Exposures |
2.0 |
CVSS |
Common Vulnerability Scoring System |
2.0 |
For more information about SCAP, see the OpenSCAP project.
7.2. SCAP Content in orcharhino
SCAP content is a SCAP data-stream file that contains implementation of compliance, configuration, or security baselines. A single data stream usually includes multiple XCCDF profiles. An XCCDF profile defines an industry standard or custom security standard against which you can evaluate compliance of host configuration in orcharhino, such as Protection Profile for General Purpose Operating Systems (OSPP), Health Insurance Portability and Accountability Act (HIPAA), and PCI-DSS v3.2.1 Control Baseline for Enterprise Linux 9. You can adapt existing XCCDF profiles according to your requirements using tailoring files.
In orcharhino, you use an XCCDF profile from SCAP content and, eventually, a tailoring file, to define a compliance policy. orcharhino includes default SCAP contents from SCAP Security Guide provided by the OpenSCAP project.
7.3. Compliance Policy Deployment Options
You can use one of the following methods to deploy compliance policies:
- Ansible deployment
You use an Ansible role to configure hosts for compliance scans.
- Puppet deployment
You use a Puppet class and the Puppet agent to configure hosts for compliance scans.
- Manual deployment
You manually configure hosts for compliance scans.
7.4. Installing the OpenSCAP Plug-in
You can install and enable the OpenSCAP plug-in to generate SCAP compliance reports. The OpenSCAP plug-in consists of the OpenSCAP orcharhino plug-in, the OpenSCAP Hammer CLI plug-in, the OpenSCAP orcharhino Proxy plug-in, and the module for Puppet policy deployment.
Install the OpenSCAP plug-in on your orcharhino Server:
# foreman-installer \ --enable-foreman-plugin-openscap \ --enable-foreman-cli-openscap \ --enable-foreman-proxy-plugin-openscap \ --foreman-proxy-plugin-openscap-puppet-module true
Optional: Install the OpenSCAP plug-in on any orcharhino Proxies:
# foreman-installer \ --enable-foreman-proxy-plugin-openscap \ --foreman-proxy-plugin-openscap-puppet-module true
7.5. Configuring Compliance Policy Deployment Methods
Use one the following procedures to configure orcharhino for the method that you have selected to deploy compliance policies. You will select one of these methods when you later create a compliance policy.
Import the
theforeman.foreman_scap_client
Ansible role.For more information, see Configuring Hosts Using Ansible.
Assign the created policy and the
Ansible role to a host or host group. -
To trigger the deployment, run the Ansible role on the host or host group either manually, or set up a recurring job by using remote execution for regular policy updates.
For more information, see Configuring and Setting Up Remote Jobs in Managing Hosts.
Ensure Puppet is enabled.
Ensure the Puppet agent is installed on hosts.
Import the Puppet environment that contains the
foreman_scap_client
Puppet module.For more information, see Configuring Hosts Using Puppet.
foreman_scap_client
Puppet class to a host or host group.Puppet triggers the deployment on the next regular run or you can run Puppet manually. Puppet runs every 30 minutes by default.
For the manual deployment method, no additional orcharhino configuration is required.
7.6. Listing Available SCAP Contents
Use this procedure to view what SCAP contents are already loaded in orcharhino. To use the CLI instead of the orcharhino management UI, see the CLI procedure.
Your user account has the
view_scap_contents
permission.
In the orcharhino management UI, navigate to Hosts > Compliance – SCAP contents.
Run the following Hammer command on orcharhino Server:
# hammer scap-content list \ --location "My_Location" \ --organization "My_Organization"
7.7. Configuring SCAP Contents
You can upload SCAP data streams and tailoring files to define compliance policies.
7.7.1. Loading the Default SCAP Contents
By loading the default SCAP contents on orcharhino Server, you ensure that the data streams from the SCAP Security Guide (SSG) are loaded and assigned to all organizations and locations.
SSG is provided by the operating system of orcharhino Server and installed in /usr/share/xml/scap/ssg/content/
Note that the available data streams depend on the operating system version on which orcharhino runs.
Your user account has a role assigned that has the
create_scap_contents
permission.
Use the following Hammer command on orcharhino Server:
7.7.2. Getting Supported SCAP Contents for RHEL
You can get the latest SCAP Security Guide (SSG) for Red Hat Enterprise Linux on the Red Hat Customer Portal. You have to get a version of SSG that is designated for the minor RHEL version of your hosts.
Access the SCAP Security Guide in the package browser.
From the Version menu, select the latest SSG version for the minor version of RHEL that your hosts are running. For example, for RHEL 8.6, select a version named
*.el8_6
Download the package RPM.
Extract the data-stream file (
*-ds.xml
) from the RPM. For example:$ rpm2cpio scap-security-guide-0.1.69-3.el8_6.noarch.rpm \ | cpio -iv --to-stdout ./usr/share/xml/scap/ssg/content/ssg-rhel8-ds.xml \ > ssg-rhel-8.6-ds.xml
Upload the data stream to orcharhino. For more information, see Uploading Additional SCAP Content.
Supported versions of the SCAP Security Guide in RHEL in the Red Hat Knowledgebase
SCAP Security Guide profiles supported in RHEL 9 in Red Hat Enterprise Linux 9 Security hardening
SCAP Security Guide profiles supported in RHEL 8 in Red Hat Enterprise Linux 8 Security hardening
SCAP Security Guide profiles supported in RHEL 7 in Red Hat Enterprise Linux 7 Security Guide
7.7.3. Uploading Additional SCAP Content
You can upload additional SCAP content into orcharhino Server, either content created by yourself or obtained elsewhere. For example, you can get the latest OpenSCAP contents for additional systems from the SSG GitHub repository. To use the CLI instead of the orcharhino management UI, see the CLI procedure.
permission. -
You have acquired a SCAP data-stream file.
In the orcharhino management UI, navigate to Hosts > Compliance > SCAP contents.
Click Upload New SCAP Content.
Enter a title in the Title text box, such as
My SCAP Content
In Scap File, click Choose file, navigate to the location containing a SCAP data-stream file and click Open.
On the Locations tab, select locations.
On the Organizations tab, select organizations.
Click Submit.
If the SCAP content file is loaded successfully, a message similar to Successfully created My SCAP Content
is displayed.
Place the SCAP data-stream file to a directory on your orcharhino Server, such as
/usr/share/xml/scap/my_content/
# hammer scap-content bulk-upload --type directory \ --directory /usr/share/xml/scap/my_content/ \ --location "My_Location" \ --organization "My_Organization"
List the available SCAP contents. The list of SCAP contents includes the new title.
7.7.4. Tailoring XCCDF Profiles
You can customize existing XCCDF profiles using tailoring files without editing the original SCAP content. A single tailoring file can contain customizations of multiple XCCDF profiles.
You can create a tailoring file using the SCAP Workbench tool. For more information on using the SCAP Workbench tool, see Customizing SCAP Security Guide for your use case.
Then you can assign a tailoring file to a compliance policy to customize an XCCDF profile in the policy.
7.7.5. Uploading a Tailoring File
After uploading a tailoring file, you can apply it in a compliance policy to customize an XCCDF profile.
create_tailoring_files
permission.
In the orcharhino management UI, navigate to Hosts > Compliance – Tailoring Files and click New Tailoring File.
Enter a name in the Name text box.
Click Choose File, navigate to the location containing the tailoring file and select Open.
Click Submit to upload the chosen tailoring file.
7.8. Managing Compliance Policies
A compliance policy is a scheduled audit that checks the specified hosts for compliance against a specific XCCDF profile from a SCAP content.
You specify the schedule for scans on orcharhino Server and the scans are performed on hosts. When a scan completes, a report in ARF format is generated and uploaded to orcharhino Server. The compliance policy makes no changes to the scanned host.
A compliance policy defines a SCAP client configuration and a cron schedule. The policy is then deployed together with the SCAP client on hosts to which the policy is assigned.
7.8.1. Creating a Compliance Policy
By creating a compliance policy, you can define and plan your security compliance requirements, and ensure that your hosts remain compliant to your security policies.
You have configured orcharhino for your selected compliance policy deployment method.
You have available SCAP contents, and eventually tailoring files, in orcharhino.
To verify what SCAP contents are available, see Listing Available SCAP Contents.
To upload SCAP contents and tailoring files, see Configuring SCAP Contents.
view_policies
andcreate_policies
permissions.
In the orcharhino management UI, navigate to Hosts > Compliance – Policies.
Click New Policy or New Compliance Policy.
Select the deployment method: Ansible, Puppet, or Manual. Then click Next.
Enter a name for this policy, a description (optional), then click Next.
Select the SCAP Content and XCCDF Profile to be applied, then click Next.
Note that orcharhino does not detect whether the selected XCCDF profile contains any rules. An empty XCCDF profile, such as the
Default XCCDF Profile
, will return empty reports. -
Optional: To customize the XCCDF profile, select a Tailoring File and a XCCDF Profile in Tailoring File, then click Next.
Specify the scheduled time when the policy is to be applied. Select Weekly, Monthly, or Custom from the Period list. The Custom option allows for greater flexibility in the policy’s schedule.
If you select Weekly, also select the desired day of the week from the Weekday list.
If you select Monthly, also specify the desired day of the month in the Day of month field.
If you select Custom, enter a valid Cron expression in the Cron line field.
Select the locations to which to apply the policy, then click Next.
Select the organizations to which to apply the policy, then click Next.
Optional: Select the host groups to which to assign the policy.
Click Submit.
7.8.2. Viewing a Compliance Policy
You can preview the rules which will be applied by specific OpenSCAP content and profile combination. This is useful when you plan policies.
view_policies
permission.
In the Actions column of the required policy, click Show Guide or select it from the list.
7.8.3. Editing a Compliance Policy
In the orcharhino management UI, you can edit compliance policies.
Puppet agent applies an edited policy to the host on the next run. By default, this occurs every 30 minutes. If you use Ansible, you must run the Ansible role manually again or have configured a recurring remote execution job that runs the Ansible role on hosts.
view_policies
andedit_policies
permissions.
Click the name of the required policy.
Edit the necessary attributes.
Click Submit.
7.8.4. Deleting a Compliance Policy
In the orcharhino management UI, you can delete existing compliance policies.
view_policies
anddestroy_policies
permissions.
In the Actions column of the required policy, select Delete from the list.
Click OK in the confirmation message.
7.9. Deploying Compliance Policies
To deploy a compliance policy, you must install the SCAP client, update the cron schedule file, and upload the SCAP content selected in the policy onto a host.
7.9.1. Deploying a Policy in a Host Group Using Ansible
After you deploy a compliance policy in a host group using Ansible, the Ansible role installs the SCAP client and configures OpenSCAP scans on the hosts according to the selected compliance policy.
You have enabled OpenSCAP on your orcharhino Proxy. For more information, see Installing the OpenSCAP Plug-in.
You have enabled and synced the operating system repositories to orcharhino, and enabled them on the hosts:
Red Hat Enterprise Linux 9 for x86_64 - BaseOS and Appstream (RPMs) –
rhel-9-for-x86_64-baseos-rpms
andrhel-9-for-x86_64-appstream-rpms
Red Hat Enterprise Linux 8 for x86_64 - BaseOS and Appstream (RPMs) –
rhel-8-for-x86_64-baseos-rpms
andrhel-8-for-x86_64-appstream-rpms
Red Hat Enterprise Linux 7 Server and Extras (RPMs) –
rhel-7-server-rpms
andrhel-7-server-extras-rpms
You have enabled and synced the orcharhino Client repository to orcharhino, and enabled it on the hosts.
You have created a compliance policy with the Ansible deployment option and assigned the host group.
In the orcharhino management UI, navigate to Configure > Host Groups.
Click the host group that you want to configure for OpenSCAP reporting.
From the OpenSCAP orcharhino Proxy list, select the orcharhino Proxy with OpenSCAP enabled that you want to use.
On the Ansible Roles tab, assign the
Ansible role. -
Optional: On the Parameters tab, configure any Ansible variables of the role.
Click Submit to save your changes.
In the row of the required host group, navigate to the Actions column and select Run all Ansible roles.
7.9.2. Deploying a Policy on a Host Using Ansible
After you deploy a compliance policy on a host using Ansible, the Ansible role installs the SCAP client and configures OpenSCAP scans on the host according to the selected compliance policy.
rhel-7-server-rpms
You have enabled and synced the orcharhino Client repository to orcharhino, and enabled it on the host.
You have created a compliance policy with the Ansible deployment option.
In the orcharhino management UI, navigate to Hosts > All Hosts, and select Edit on the host you want to configure for OpenSCAP reporting.
On the Ansible Roles tab, add the
Ansible role. -
Click the Hosts breadcrumbs link to navigate back to the host index page.
Select the host or hosts to which you want to add the policy.
Click Select Action.
Select Assign Compliance Policy from the list.
In the Assign Compliance Policy window, select Remember hosts selection for the next bulk action.
Select the required policy from the list of available policies and click Submit.
Select Run all Ansible roles from the list.
7.9.3. Deploying a Policy in a Host Group Using Puppet
After you deploy a compliance policy in a host group using Puppet, the Puppet agent installs the SCAP client and configures OpenSCAP scans on the hosts on the next Puppet run according to the selected compliance policy.
rhel-7-server-rpms
You have created a compliance policy with the Puppet deployment option and assigned the host group.
In the Environment list, select the Puppet environment that contains the
foreman_scap_client*
Puppet classes. -
In the OpenSCAP orcharhino Proxy list, select the orcharhino Proxy with OpenSCAP enabled that you want to use.
On the Puppet ENC tab, add the
foreman_scap_client
Puppet class. -
Optional: Configure any Puppet Class Parameters.
7.9.4. Deploying a Policy on a Host Using Puppet
After you deploy a compliance policy on a host using Puppet, the Puppet agent installs the SCAP client and configures OpenSCAP scans on the host on the next Puppet run according to the selected compliance policy.
rhel-7-server-rpms
You have created a compliance policy with the Puppet deployment option.
From the Environment list, select the Puppet environment that contains the
foreman_scap_client
andforeman_scap_client::params
Puppet classes. -
foreman_scap_client
Puppet class. -
7.10. Running a Security Compliance Scan on Demand
Hosts perform OpenSCAP scans regularly by the CRON schedule defined in the compliance policies assigned to hosts. However, you can also run a scan on a host for all configured compliance policies manually at any time.
view_hosts
,create_job_invocations
, andview_job_invocations
permissions. -
You have created a compliance policy and deployed it on the host.
For more information about managing policies, see Managing Compliance Policies.
For more information about deploying policies, see Deploying Compliance Policies.
Navigate to Hosts > All Hosts.
Click the hostname of the required host.
On the host details page, expand the Schedule a job dropdown menu.
Select Run OpenSCAP scan.
In the host details overview, locate the Recent jobs card.
Select the Running tab. Unless the job has already finished, the table shows a job called Run scan for all OpenSCAP policies.
On the Recent jobs card, select the Finished tab.
If the job has finished successfully, you should see the succeeded status in the row of the job.
Optional: Click the job name to review invocation details.
7.11. Monitoring Compliance
With orcharhino, you can centralize compliance monitoring and management. A compliance dashboard provides an overview of compliance of hosts and the ability to view details for each host within the scope of that policy. Compliance reports provide a detailed analysis of compliance of each host with the applicable policy. With this information, you can evaluate the risks presented by each host and manage the resources required to bring hosts into compliance. By monitoring compliance with SCAP, you can verify policy compliance and detect changes in compliance.
7.11.1. Searching Compliance Reports
Use the Compliance Reports search field to filter the list of available reports on any subset of hosts.
In the orcharhino management UI, navigate to Hosts > Reports.
Optional: To see a list of available search parameters, click the empty Search field.
Enter the search query in the Search field and click Search. The search query is case insensitive.
- Find all compliance reports for which more than five rules failed
failed > 5
- Find all compliance reports created after January 1, 2023, for hosts with hostnames that contain
prod-
host ~ prod- AND date > "Jan 1, 2023"
- Find all reports generated by the
rhel7_audit
compliance policy from an hour ago
- Find reports that pass an XCCDF rule
- Find reports that fail an XCCDF rule
- Find reports that have a result different than fail or pass for an XCCDF rule
You can create complex queries with the following logical operators:
and
,not
andhas
. For more information about logical operators, see Supported Operators for Granular Search in Administering orcharhino. -
You cannot use regular expressions in a search query. However, you can use multiple fields in a single search expression. For more information about all available search operators, see Supported Operators for Granular Search in Administering orcharhino.
You can bookmark a search to reuse the same search query. For more information, see Creating Bookmarks in Administering orcharhino.
7.11.2. Compliance Email Notifications
orcharhino Server sends an OpenSCAP Summary email to all users who subscribe to the Compliance policy summary email notifications. For more information on subscribing to email notifications, see Configuring Email Notification Preferences.
Each time a policy is run, orcharhino checks the results against the previous run, noting any changes between them. The email is sent according to the frequency requested by each subscriber, providing a summary of each policy and its most recent result.
7.11.3. Viewing Compliance Policy Statistics
You can view a compliance policy dashboard to verify compliance reports of a particular policy. The compliance policy dashboard provides a statistical summary of compliance of hosts and the ability to view report details for each host within the scope of that policy.
Consider prioritizing the following hosts when viewing compliance reports:
Hosts which were evaluated as
Failed
Hosts labelled as
Never audited
because their status is unknown
view_policies
permission.
In the orcharhino management UI, navigate to Hosts > Policies.
In the row of the required policy, navigate to the Actions column and click Dashboard.
7.11.4. Examining Hosts per Rule Compliance Result
You can examine a simplified report and use policy rules to list hosts that have a certain compliance result, such as failing a particular rule.
view_arf_reports
andview_hosts
permissions.
In the Reported At column, navigate to the report of the required host and compliance policy, and click the time link.
orcharhino displays a simplified list of policy rules with the results of the scan.
Optional: Filter the rules by check result. From the Show log messages dropdown list, select one of the following filters:
Failed and othered – to view rules that have failed or have not been checked during the scan,
Failed only – to view only rules that have failed.
Optional: Examine the details of the rule. In the Message column, click the icon next to the name of the rule.
In the row of the required rule, navigate to the Actions column and click Hosts failing this rule.
7.11.5. Examining Compliance Failures of a Host
You can examine a full compliance report, determine why a host failed compliance on a rule, and, in some cases, see how to remediate a case of non-compliance.
Warning
Do not implement any of the recommended remedial actions or scripts without first testing them in a non-production environment. Remediation might render the system non-functional. |
Introduction
Evaluation Characteristics
Compliance and Scoring
Rule Overview
view_arf_reports
andview_hosts
permissions.
In the orcharhino management UI, navigate to Hosts > Reports to list all compliance reports.
In the row of the required host, navigate to the Actions column and click Full Report to view the complete details of an evaluation report.
Navigate to the Evaluation Characteristics area to review basic details about the evaluation of the host against a specific profile.
Navigate to the Compliance and Scoring area to review evaluation statistics and the host compliance score.
Navigate to the Rule Overview to examine the rules.
Optional: Deselect the check statuses that you want to hide, such as pass, notapplicable, or fixed.
Optional: From the Group rule by dropdown menu, select the criterion for the grouping of rules, such as Severity.
Optional: Enter a search string into the search field to filter rules by title. The search is case insensitive and applied dynamically as you type.
Click the title of a rule to inspect further result details:
A description of the rule with instructions for bringing the host into compliance if available.
The rationale for the rule.
In some cases, a remediation script.
7.11.6. Deleting a Compliance Report
You can delete compliance reports on your orcharhino.
view_arf_reports
anddestroy_arf_reports
permissions.
In the Compliance Reports window, identify the policy that you want to delete and, on the right of the policy’s name, select Delete.
Click OK.
7.11.7. Deleting Multiple Compliance Reports
You can delete multiple compliance policies simultaneously. However, in the orcharhino management UI, compliance policies are paginated, so you must delete one page of reports at a time.
view_arf_reports
permissions.
In the Compliance Reports window, select the compliance reports that you want to delete.
In the upper right of the list, select Delete reports.
Repeat these steps for as many pages as you want to delete.
8. Backing Up orcharhino Server and orcharhino Proxy
You can back up your orcharhino deployment to ensure the continuity of your orcharhino deployment and associated data in the event of a disaster. If your deployment uses custom configurations, you must consider how to handle these custom configurations when you plan your backup and disaster recovery policy.
If you create a new instance of the orcharhino Server, decomission the old instances after restoring the backup. Cloned instances are not supposed to run in parallel in a production environment. |
To create a backup of your orcharhino Server or orcharhino Proxy and all associated data, use the foreman-maintain backup
command.
orcharhino services are unavailable during the backup.
You can schedule a backup using cron
For more information, see the Example of a Weekly Full Backup Followed by Daily Incremental Backups.
During offline or snapshot backups, the services are inactive and orcharhino is in a maintenance mode. All the traffic from outside on port 443 is rejected by a firewall to ensure there are no modifications triggered.
A backup contains sensitive information from the /root/ssl-build
directory.
You can also use conventional backup methods.
If you plan to use the |
When creating a snapshot or conventional backup, you must stop all services as follows:
Start the services after creating a snapshot or conventional backup:
8.1. Estimating the Size of a Backup
The full backup creates uncompressed archives of PostgreSQL and Pulp database files, and orcharhino configuration files. Compression occurs after the archives are created to decrease the time when orcharhino services are unavailable.
Uncompressed orcharhino database and configuration files
Compressed orcharhino database and configuration files
Enter the
du
command to estimate the size of uncompressed directories containing orcharhino database and configuration files:# du -sh /var/lib/pgsql/data /var/lib/pulp 100G /var/lib/pgsql/data 100G /var/lib/pulp # du -csh /var/lib/qpidd /var/lib/tftpboot /etc /root/ssl-build \ /var/www/html/pub /opt/puppetlabs 886M /var/lib/qpidd 16M /var/lib/tftpboot 37M /etc 900K /root/ssl-build 100K /var/www/html/pub 2M /opt/puppetlabs 942M total
Table 5. Backup Data Compression Ratio Data type Directory Ratio Example results PostgreSQL database files
/var/lib/pgsql/data
80 – 85%
100 GB → 20 GB
Pulp RPM files
/var/lib/pulp
(not compressed)
100 GB
Configuration files
/var/lib/qpidd
/var/lib/tftpboot
/etc
/root/ssl-build
/var/www/html/pub
/opt/puppetlabs
85%
942 MB → 141 MB
8.2. Performing a Full Backup of orcharhino Server or orcharhino Proxy
orcharhino uses the foreman-maintain backup
command to make backups.
There are three main methods of backing up orcharhino Server:
Offline backup
Online backup
Snapshot backups
The foreman-maintain backup
command creates a time-stamped subdirectory in the backup directory that you specify.
command does not overwrite backups, therefore you must select the correct directory or subdirectory when restoring from a backup or an incremental backup.
command stops and restarts services as required.
When you run the foreman-maintain backup offline
command, the following default backup directories are created:
orcharhino-backup
on orcharhino -
foreman-proxy-backup
on orcharhino Proxy
If you want to set a custom directory name, add the --preserve-directory
option and add a directory name.
If you use the --preserve-directory
option, no data is removed if the backup fails.
Note that if you use a local PostgreSQL database, the postgres
user requires write access to the backup directory.
You can use the foreman-maintain backup
command to back up remote databases.
You can use both online and offline methods to back up remote databases, but if you use offline methods, such as snapshot, the foreman-maintain backup
command performs a database dump.
Ensure that your backup location has sufficient available disk space to store the backup. For more information, see Estimating the Size of a Backup.
Warning
Request other users of orcharhino Server or orcharhino Proxy to save any changes and warn them that orcharhino services are unavailable for the duration of the backup. Ensure no other tasks are scheduled for the same time as the backup. |
On orcharhino Server, enter the following command:
# foreman-maintain backup offline /var/orcharhino-backup
On orcharhino Proxy, enter the following command:
8.3. Performing a Backup without Pulp Content
Warning
8.4. Performing an Incremental Backup
Warning
To perform a full offline backup, enter the following command:
To create a directory within your backup directory to store the first incremental back up, enter the
command with the--incremental
option:# foreman-maintain backup offline --incremental /var/backup_directory/full_backup /var/backup_directory
To create the second incremental backup, enter the
option and include the path to the first incremental backup to indicate the starting point for the next increment. This creates a directory for the second incremental backup in your backup directory:# foreman-maintain backup offline --incremental /var/backup_directory/first_incremental_backup /var/backup_directory
8.5. Example of a Weekly Full Backup Followed by Daily Incremental Backups
#!/bin/bash -e PATH=/sbin:/bin:/usr/sbin:/usr/bin DESTINATION=/var/backup_directory if [[ $(date +%w) == 0 ]]; then foreman-maintain backup offline --assumeyes $DESTINATION else LAST=$(ls -td -- $DESTINATION/*/ | head -n 1) foreman-maintain backup offline --assumeyes --incremental "$LAST" $DESTINATION fi exit 0
Note that the foreman-maintain backup
command requires /sbin
and /usr/sbin
directories to be in PATH
and the --assumeyes
option is used to skip the confirmation prompt.
8.6. Performing an Online Backup
When performing an online backup, if there are procedures affecting the Pulp database, the Pulp part of the backup procedure repeats until it is no longer being altered. Because the backup of the Pulp database is the most time consuming part of backing up orcharhino, if you make a change that alters the Pulp database during this time, the backup procedure keeps restarting.
Warning
To perform an online backup, enter the following command:
8.7. Performing a Snapshot Backup
The snapshot backup method is faster than a full offline backup and therefore reduces orcharhino downtime.
Warning
Request other orcharhino Server or orcharhino Proxy users to save any changes and warn them that orcharhino services are unavailable for the duration of the backup. Ensure no other tasks are scheduled for the same time as the backup. |
The system uses LVM for the directories that you snapshot:
/var/lib/pulp/
, and/var/lib/pgsql
The free disk space in the relevant volume group (VG) is three times the size of the snapshot. More precisely, the VG must have enough space unreserved by the member logical volumes (LVs) to accommodate new snapshots. In addition, one of the LVs must have enough free space for the backup directory.
The target backup directory is on a different LV than the directories that you snapshot.
To perform a snapshot backup, enter the
command:# foreman-maintain backup snapshot /var/backup_directory
The foreman-maintain backup snapshot
command creates snapshots when the services are active, and stops all services which can impact the backup.
This makes the maintenance window shorter.
After the successful snapshot, all services are restarted and LVM snapshots are removed.
8.8. White-listing and Skipping Steps When Performing Backups
A backup using the foreman-maintain backup
command proceeds in a sequence of steps.
To skip part of the backup add the --whitelist
option to the command and add the step label that you want to omit.
To display a list of available step labels, enter the following command:
To skip a step of the backup, enter the
command with the--whitelist
option. For example:# foreman-maintain backup online --whitelist backup-metadata -y /var/backup_directory
9. Restoring orcharhino Server or orcharhino Proxy from a Backup
You can restore orcharhino Server or orcharhino Proxy from the backup data that you create as part of Backing Up orcharhino Server and orcharhino Proxy. This process outlines how to restore the backup on the same server that generated the backup, and all data covered by the backup is deleted on the target system. If the original system is unavailable, provision a system with the same configuration settings and host name.
9.1. Restoring from a Full Backup
Use this procedure to restore orcharhino or orcharhino Proxy from a full backup. When the restore process completes, all processes are online, and all databases and system configuration revert to the state at the time of the backup.
Ensure that you are restoring to the correct instance. The orcharhino instance must have the same host name, configuration, and be the same minor version (X.Y) as the original system.
Ensure that you have enough space to store this data on the base system of orcharhino Server or orcharhino Proxy as well as enough space after the restoration to contain all the data in the
/etc/
and/var/
directories contained within the backup.To check the space used by a directory, enter the following command:
# df -h /var/backup_directory
Add the
--total
option to get a total of the results from more than one directory. -
# restorecon -Rv /
Choose the appropriate method to install orcharhino or orcharhino Proxy:
To install orcharhino Server from a connected network, follow the procedures in Installing orcharhino Server.
To install a orcharhino Proxy, follow the procedures in Installing orcharhino Proxy.
Copy the backup data to orcharhino Server’s local file system. Use
/var/
or/var/tmp/
Run the restoration script.
For troubleshooting, you can check
/var/log/foreman/production.log
and/var/log/messages
9.2. Restoring from Incremental Backups
Use this procedure to restore orcharhino or orcharhino Proxy from incremental backups. If you have multiple branches of incremental backups, select your full backup and each incremental backup for the branch you want to restore, in chronological order.
Restore the last full backup using the instructions in Restoring from a Full Backup.
Remove the full backup data from orcharhino Server’s local file system, for example,
/var/
or/var/tmp/
Copy the incremental backup data to orcharhino Server’s local file system, for example,
/var/
or/var/tmp/
9.3. Backup and Restore orcharhino Proxy Using a Virtual Machine Snapshot
If your orcharhino Proxy is a virtual machine, you can restore it from a snapshot. Creating weekly snapshots to restore from is recommended. In the event of failure, you can install, or configure a new orcharhino Proxy, and then synchronize the database content from orcharhino Server.
If required, deploy a new orcharhino Proxy, ensuring the host name is the same as before, and then install the orcharhino Proxy certificates. You may still have them on orcharhino Server, the package name ends in -certs.tar, alternately create new ones. Follow the procedures in Installing orcharhino Proxy until you can confirm, in the orcharhino management UI, that orcharhino Proxy is connected to orcharhino Server. Then use the procedure Synchronizing an External orcharhino Proxy to synchronize from orcharhino.
9.3.1. Synchronizing an External orcharhino Proxy
Synchronize an external orcharhino Proxy with orcharhino.
To synchronize an external orcharhino Proxy, select the relevant organization and location in the orcharhino management UI, or choose Any Organization and Any Location.
In the orcharhino management UI, navigate to Infrastructure > orcharhino Proxies and click the name of the orcharhino Proxy to synchronize.
On the Overview tab, select Synchronize.
10. Renaming orcharhino Server or orcharhino Proxy
To rename orcharhino Server or orcharhino Proxy, use the katello-change-hostname
script.
When changing the domain name of your orcharhino Server or orcharhino Proxy, update the hostname using |
10.1. Renaming orcharhino Server
The host name of orcharhino Server is used by orcharhino Server components, all orcharhino Proxies, and hosts registered to it for communication. This procedure ensures that in addition to renaming orcharhino Server, you also update all references to point to the new host name.
Warning
Renaming your orcharhino Server host shuts down all orcharhino services on that host. The services restart after the renaming is complete. |
Back up your orcharhino Server before changing its host name. If you fail to successfully rename it, restore it from the backup. For more information, see Backing Up orcharhino Server and orcharhino Proxy.
Run the
hostname
andhostname -f
commands on orcharhino Server. If both commands do not return the FQDN of orcharhino Server, thekatello-change-hostname
script will fail to complete.If the
hostname
command returns the shortname of orcharhino Server instead of the FQDN, usehostnamectl set-hostname My_Old_FQDN
to set the old FQDN correctly before using thekatello-change-hostname
script. -
If orcharhino Server has a custom SSL certificate installed, obtain a new certificate for the new FQDN of the host.
On orcharhino Server, run the
script, and provide the new host name. Choose one of the following methods:-
If your orcharhino Server is installed with the default self-signed SSL certificates, enter the following command:
# katello-change-hostname new-orcharhino \ --username admin \ --password password
If your orcharhino Server is installed with custom SSL certificates:
# katello-change-hostname new-orcharhino \ --username admin \ --password password \ --custom-cert "/root/ownca/test.com/test.com.crt" \ --custom-key "/root/ownca/test.com/test.com.key"
If you have created a custom SSL certificate for the new orcharhino Server host name, run the orcharhino installation script to install the certificate.
Reregister all orcharhino hosts. For more information, see Registering Hosts in Managing Hosts.
On all orcharhino Proxies, run the orcharhino installation script to update references to the new host name:
# foreman-installer \ --foreman-proxy-foreman-base-url https://new-orcharhino.example.com \ --foreman-proxy-trusted-hosts new-orcharhino.example.com \ --puppet-server-foreman-url https://new-orcharhino.example.com
On orcharhino Server, list all orcharhino Proxies:
# hammer proxy list
On orcharhino Server, synchronize content for each orcharhino Proxy:
# hammer proxy content synchronize \ --id Myorcharhino-proxy_ID_
If you use external authentication, reconfigure orcharhino Server for external authentication after you run the
script.
10.2. Renaming orcharhino Proxy
The host name of orcharhino Proxy is referenced by orcharhino Server components and all hosts registered to it. This procedure ensures that in addition to renaming orcharhino Proxy, you also update all references to the new host name.
Warning
Renaming your orcharhino Proxy host shuts down all orcharhino services on that host. The services restart after the renaming is complete. |
Back up your orcharhino Proxy before renaming. If you fail to successfully rename it, restore it from the backup. For more information, see Backing Up orcharhino Server and orcharhino Proxy.
Run the
hostname
andhostname -f
commands on orcharhino Proxy. If both commands do not return the FQDN of orcharhino Proxy, thekatello-change-hostname
hostname
command returns the shortname of orcharhino Proxy instead of the FQDN, usehostnamectl set-hostname My_Old_FQDN
to set the old FQDN correctly before attempting to use thekatello-change-hostname
script.
On orcharhino Server, generate a new certificates archive file for orcharhino Proxy.
If you are using the default SSL certificate, enter the following command:
# foreman-proxy-certs-generate \ --foreman-proxy-fqdn new-orcharhino-proxy.example.com \ --certs-tar /root/new-orcharhino-proxy.example.com-certs.tar
.tar
file. -
If you are using a custom SSL certificate, create a new SSL certificate for orcharhino Proxy. For more information, see Configuring orcharhino Proxy with a Custom SSL Certificate in Installing orcharhino Proxy.
On orcharhino Server, copy the certificates archive file to orcharhino Proxy. For example, to copy the archive file to the
root
user’s home directory:# scp /root/new-orcharhino-proxy.example.com-certs.tar root@orcharhino-proxy.example.com:
On orcharhino Proxy, run the
script and provide the host’s new name, orcharhino credentials, and certificates archive file name.# katello-change-hostname new-orcharhino-proxy.example.com --username admin \ --password password \ --certs-tar /root/new-orcharhino-proxy.example.com-certs.tar
.tar
file. -
If you have created a custom certificate for orcharhino Proxy, deploy the certificate on orcharhino Proxy by entering the
foreman-installer
command that theforeman-proxy-certs-generate
command returned in a previous step. For more information, see Deploying a Custom SSL Certificate to orcharhino Proxy in Installing orcharhino Proxy. -
On all orcharhino Proxy clients, enter the following commands to reinstall the bootstrap RPM, reregister clients, and refresh their subscriptions.
You can use the remote execution feature to perform this step. For more information, see Configuring and Setting up Remote Jobs in Managing Hosts.
# dnf remove katello-ca-consumer* # dnf install http://new-orcharhino-proxy.example.com/pub/katello-ca-consumer-latest.noarch.rpm # subscription-manager register --org="My_Organization" \ --environment="Library" \ --force # subscription-manager refresh
Update the orcharhino Proxy host name in the orcharhino management UI.
In the orcharhino management UI, navigate to Infrastructure > orcharhino Proxies.
Locate orcharhino Proxy in the list, and click Edit.
Edit the Name and URL fields to match orcharhino Proxy’s new host name, then click Submit.
On your DNS server, add a record for the new hostname of your orcharhino Proxy, and delete the record of the previous host name.
11. Maintaining orcharhino Server
This chapter provides information on how to maintain a orcharhino Server, including information on how to work with audit records, how to clean unused tasks, and how to recover Pulp from a full disk.
11.1. Deleting Audit Records Manually
You can use the foreman-rake audits:expire
command to remove audit records at any time.
command:# foreman-rake audits:expire days=Number_Of_Days
Number_Of_Days
11.2. Deleting Audit Records Automatically
You can automatically delete audit records using the Saved audits interval
setting.
This setting is empty by default, meaning orcharhino does not automatically delete the audit records.
In the orcharhino management UI, navigate to Administer > Settings.
Set the value of the setting to the number of days after which you want orcharhino to delete the audit records.
11.3. Anonymizing Audit Records
You can use the foreman-rake audits:anonymize
command to remove any user account or IP information while maintaining the audit records in the database.
You can also use a cron job to schedule anonymizing the audit records at the set interval that you want.
By default, using the foreman-rake audits:anonymize
command anonymizes audit records that are older than 90 days.
You can specify the number of days to keep the audit records by adding the days option and add the number of days.
11.4. Deleting Report Records
Report records are created automatically in orcharhino.
You can use the foreman-rake reports:expire
command to remove reports at any time.
You can also use a cron job to schedule report record deletions at the set interval that you want.
By default, using the foreman-rake reports:expire
command removes report records that are older than 90 days.
You can specify the number of days to keep the report records by adding the days option and add the number of days.
11.5. Configuring the Cleaning Unused Tasks Feature
orcharhino performs regular cleaning to reduce disc space in the database and limit the rate of disk growth. As a result, orcharhino backup completes faster and overall performance is higher.
By default, orcharhino executes a cron job that cleans tasks every day at 19:45. orcharhino removes the following tasks during the cleaning:
To configure the time at which orcharhino runs the cron job, set the
--foreman-plugin-tasks-cron-line
parameter to the time you want in cron format. For example, to schedule the cron job to run every day at 15:00, enter the following command:# foreman-installer --foreman-plugin-tasks-cron-line "00 15 * * *"
To configure the period after which orcharhino deletes the tasks, edit the
:rules:
section in the/etc/foreman/plugins/foreman-tasks.yaml
file. -
To disable regular task cleanup on orcharhino, enter the following command:
To reenable regular task cleanup on orcharhino, enter the following command:
11.6. Deleting Task Records
Task records are created automatically in orcharhino.
You can use the foreman-rake foreman_tasks:cleanup
command to remove tasks at any time.
You can also use a cron job to schedule Task record deletions at the set interval that you want.
11.7. Deleting a Task by ID
Connect to your orcharhino Server using SSH:
# ssh root@orcharhino.example.com
Optional: View the task:
Delete the task:
Optional: Ensure the task has been removed from orcharhino Server:
11.8. Recovering from a Full Disk
Ensure that the LV with the
/var/lib/pulp
directory on it has sufficient free space. Here are some ways to achieve that:-
Remove orphaned content:
Change the download policy from Immediate to On Demand for as many repositories as possible and remove already downloaded packages.
/var/lib/pulp
directory on it.NoteIf you use an untypical file system (other than for example ext3, ext4, or xfs), you might need to unmount the file system so that it is not in use. In that case, complete the following steps:
Stop orcharhino services:
Start orcharhino services:
11.9. Reclaiming PostgreSQL Space
The PostgreSQL database can use a large amount of disk space especially in heavily loaded deployments. Use this procedure to reclaim some of this disk space on orcharhino.
postgresql
service:# foreman-maintain service stop --exclude postgresql
Switch to the
postgres
user and reclaim space on the database:# su - postgres -c 'vacuumdb --full --all'
11.10. Reclaiming Space From On Demand Repositories
If you set the download policy to on demand, orcharhino downloads packages only when the clients request them. You can clean up these packages to reclaim space.
In the orcharhino management UI, navigate to Content > Products.
Select a product.
Select the product name.
Select the orcharhino Proxy.
Click Reclaim space.
12. Renewing the Custom SSL Certificate
This chapter provides information on how to renew the custom SSL certificate on orcharhino Server as well as on orcharhino Proxy.
12.1. Renewing a Custom SSL Certificate on orcharhino Server
Use this procedure to update your custom SSL certificate for orcharhino Server.
You must create a new Certificate Signing Request (CSR) and send it to the Certificate Authority to sign the certificate. Refer to the Configuring orcharhino Server with a Custom SSL Certificate guide before creating a new CSR because the Server certificate must have X.509 v3
Key Usage
andExtended Key Usage
extensions with required values. In return, you will receive the orcharhino Server certificate and CA bundle.
Before deploying a renewed custom certificate on your orcharhino Server, validate the custom SSL input files. Note that for the
katello-certs-check
command to work correctly, Common Name (CN) in the certificate must match the FQDN of orcharhino Server:# katello-certs-check -t orcharhino \ -b /root/orcharhino_cert/ca_cert_bundle.pem \ -c /root/orcharhino_cert/orcharhino_cert.pem \ -k /root/orcharhino_cert/orcharhino_cert_key.pem
If the command is successful, it returns the following
foreman-installer
command. You can use this command to deploy the renewed CA certificates to orcharhino Server:# foreman-installer --scenario katello \ --certs-server-cert "/root/orcharhino_cert/orcharhino_cert.pem" \ --certs-server-key "/root/orcharhino_cert/orcharhino_key.pem" \ --certs-server-ca-cert "/root/orcharhino_cert/ca_cert_bundle.pem" \ --certs-update-server \ --certs-update-server-ca
Do not delete the certificate files after you deploy the certificate. They are required when upgrading orcharhino Server. |
If a new consumer package |
Access the orcharhino management UI from your local machine. For example, https://orcharhino.example.com.
12.2. Renewing a Custom SSL certificate on orcharhino Proxy
Use this procedure to update your custom SSL certificate for orcharhino Proxy.
The foreman-installer
command, which the foreman-proxy-certs-generate
command returns, is unique to each orcharhino Proxy.
You cannot use the same command on more than one orcharhino Proxy.
You must create a new Certificate Signing Request and send it to the Certificate Authority to sign the certificate. Refer to the Configuring orcharhino Server with a Custom SSL Certificate guide before creating a new CSR because the orcharhino Server certificate must have X.509 v3
Key Usage
extensions with required values. In return, you will receive the orcharhino Proxy certificate and CA bundle.
On your orcharhino Server, validate the custom SSL certificate input files:
# katello-certs-check -t orcharhino-proxy \ -b /root/orcharhino-proxy_cert/ca_cert_bundle.pem \ -c /root/orcharhino-proxy_cert/orcharhino-proxy_cert.pem \ -k /root/orcharhino-proxy_cert/orcharhino-proxy_cert_key.pem
On your orcharhino Server, generate the certificate archive file for your orcharhino Proxy:
foreman-proxy-certs-generate --foreman-proxy-fqdn "orcharhino-proxy.example.com" \ --certs-tar "/root/My_Certificates/orcharhino-proxy.example.com-certs.tar" \ --server-cert "/root/My_Certificates/orcharhino-proxy_cert.pem" \ --server-key "/root/My_Certificates/orcharhino-proxy_cert_key.pem" \ --server-ca-cert "/root/My_Certificates/ca_cert_bundle.pem" \ --certs-update-server
On your orcharhino Server, copy the certificate archive file to your orcharhino Proxy:
# scp /root/My_Certificates/orcharhino-proxy.example.com-certs.tar user@orcharhino-proxy.example.com:
Retain a copy of the
foreman-installer
command returns for deploying the certificate to your orcharhino Proxy. -
Deploy the certificate on your orcharhino Proxy using the
foreman-installer
command returned by theforeman-proxy-certs-generate
command:# orcharhino-installer --no-enable-foreman \ --foreman-proxy-register-in-foreman "true" \ --foreman-proxy-foreman-base-url "https://orcharhino.example.com" \ --certs-tar-file "/root/My_Certificates/orcharhino-proxy.example.com-certs.tar" \ --certs-update-server
Do not delete the certificate archive file on the orcharhino Proxy after you deploy the certificate. They are required when upgrading orcharhino Proxy. |
13. Logging and Reporting Problems
This chapter provides information on how to log and report problems in orcharhino, including information on relevant log files, how to enable debug logging, how to open a support case and attach the relevant log tar files, and how to access support cases within the orcharhino management UI.
For more information about orcharhino logging settings, use foreman-installer
with the --full-help
option:
13.1. Enabling Debug Logging
Debug logging provides the most detailed log information and can help with troubleshooting issues that can arise with orcharhino and its components. In the orcharhino CLI, enable debug logging to log detailed debugging information for orcharhino.
To enable debug logging, enter the following command:
13.2. Increasing the Logging Levels to Help with Debugging
By default, orcharhino comes with :INFO
level logging enabled.
You can increase or decrease the log levels on your orcharhino.
# hammer admin logging --all --level-debug # foreman-maintain service restart
INFO
# hammer admin logging --all --level-production # foreman-maintain service restart
# hammer admin logging --list -----------|-------------------------------------|------------------------------------- COMPONENT | AUTO-DETECTED BY EXISTENCE OF | DESTINATIONS -----------|-------------------------------------|------------------------------------- dhcpd | /etc/dhcp/dhcpd.conf | syslog /var/log/dhcpd-debug.log postgresql | /var/lib/pgsql/data/postgresql.conf | syslog /var/lib/pgsql/data/pg_log/ proxy | /etc/foreman-proxy/settings.yml | /var/log/foreman-proxy/proxy.log qpidd | /etc/qpid/qpidd.conf | syslog rails | /etc/foreman/settings.yaml | /var/log/foreman/production.log tomcat | /etc/candlepin/candlepin.conf | /var/log/candlepin/ /var/log/tomcat/ virt-who | /etc/sysconfig/virt-who | syslog -----------|-------------------------------------|-------------------------------------
13.2.1. Increasing the Logging Level For Hammer
You can find the log for Hammer in ~/.hammer/log/hammer.log
Edit /etc/hammer/cli_config.yml
and set the :log_level:
:log_level: 'debug'
13.2.2. Increasing the Logging Level On orcharhino Proxy
You can find the log for orcharhino Proxy in /var/log/foreman-proxy/proxy.log
Uncomment the DEBUG
line in /etc/foreman-proxy/settings.yml
:log_level: DEBUG
Ensure to restart the foreman-proxy
service afterwards:
Caution
Running the installer will revert this change back. |
13.2.3. Increasing the Logging Level For Candlepin
You can find the log for Candlepin in /var/log/candlepin/candlepin.log
Errors are also logged to a separate file for easier debugging /var/log/candlepin/error.log
Extend /etc/candlepin/candlepin.conf
log4j.logger.org.candlepin=DEBUG
Ensure to restart the tomcat
service afterwards:
# systemctl restart tomcat
log4j.logger.org.candlepin.resource.ConsumerResource=WARN log4j.logger.org.candlepin.resource.HypervisorResource=WARN
13.2.4. Increasing the Logging Level On orcharhino
You can find the log for orcharhino in /var/log/foreman/production.log
orcharhino stores logs for Apache in:
/var/log/httpd/foreman_error.log
/var/log/httpd/foreman_access.log
/var/log/httpd/foreman_ssl_error.log
/var/log/httpd/foreman_ssl_access.log
Set the logging level in
::logging: :production: :type: file :layout: pattern :level: debug
Enable selected loggers in
::loggers: :ldap: :enabled: true :permissions: :enabled: true :sql: :enabled: true
Restart orcharhino services:
You can find the complete list of loggers with their default values in /usr/share/foreman/config/application.rb
in the Foreman::Logging.add_loggers
command.
13.2.5. Increasing the Logging Level For Qpid Dispatch Router
Qpid logs to syslog and can be viewed in /var/log/messages
or with journalctl
Enable debug logging in /etc/qpid-dispatch/qdrouterd.conf
enable: debug+
Ensure to restart the Qpid Dispatch Router afterwards:
# systemctl restart qdrouterd
Caution
13.2.6. Increasing the Logging Level For Qpid Broker
or with journalctl
Set the log level in /etc/qpid/qpidd.conf
log-enable=debug+
Ensure to restart the Qpid Broker afterwards:
# systemctl restart qpidd
Caution
Running the installer will revert this change. |
13.2.7. Increasing the Logging Level For Redis
You can find the log for Redis in /var/log/redis/redis.log
Set the log level in /etc/opt/rh/rh-redis5/redis.conf
loglevel debug
13.2.8. Increasing the Logging Level For Postgres
You can find the log for Postgres in /var/lib/pgsql/data/log
Uncomment the log_statement
in /var/lib/pgsql/data/postgresql.conf
log_statement = 'all'
Ensure to restart orcharhino services afterwards:
Caution
Based on the size of your orcharhino installation, this can cause disk space to fill up very quickly. Only turn this on if absolutely needed. |
13.2.9. Increasing the Logging Level For orcharhino Installer
You can find the log files in /var/log/foreman-installer/
To increase the log level of the orcharhino Installer during an install:
13.2.10. Increasing the Logging Level For Pulp
By default, Pulp logs to syslog and can be viewed in /var/log/messages
or with journalctl
Add the following config to the /etc/pulp/settings.py
file:
Ensure to restart the Pulp services afterwards:
# systemctl restart \ pulpcore-api \ pulpcore-content \ pulpcore-resource-manager \ pulpcore-worker@1 \ pulpcore-worker@2 \ rh-redis5-redis
13.2.11. Increasing the Logging Level For Puppet Agent
You can increase the logging level for Puppet agent on your orcharhino Server.
Add the following line to the
[agent]
block in the/etc/puppetlabs/puppet/puppet.conf
file:[agent] log_level = debug
13.2.12. Increasing the Logging Level For Puppet Server
You can increase the logging level for Puppet server on your orcharhino Server.
[master]
block in/etc/puppetlabs/puppet/puppet.conf
file:[master] log_level = debug
Restart the Puppet server:
You can find the logs in /var/log/puppetlabs/puppetserver/
13.3. Retrieving the Status of Services
In the orcharhino management UI, navigate to Administer > About.
On the Smart Proxies tab, you can view the status of all orcharhino Proxies.
On the Compute Resources tab, you can view the status of attached compute resource providers.
In the Backend System Status table, you can view the status of all back-end services.
Run
hammer ping
to get information from the database and orcharhino services:# hammer ping
Use
foreman-maintain
to check the status of the services running in systemd:# foreman-maintain service status
Use
foreman-maintain
to perform a health check:$ foreman-maintain health check
13.4. Restarting Services
orcharhino uses a set of back-end services to perform tasks. You you experience an issue with your orcharhino, check the status of orcharhino services.
Use
foreman-maintain
to restart orcharhino services:# foreman-maintain service restart
Tip
Run |
13.5. Enabling Individual Loggers
You can enable individual loggers for selective logging. orcharhino uses the following loggers:
app
audit
background
blob
ImportantThe blob
logger might contain sensitive data. dynflow
ldap
notifications
permissions
sql
telemetry
templates
Enable the individual loggers that you want. For example, to enable
sql
andldap
loggers, enter the following command:# foreman-installer \ --foreman-loggers ldap:true \ --foreman-loggers sql:true
Optional: To reset loggers to their default values, enter the following command:
13.6. Configuring Logging to Journal or File-based Logging
orcharhino uses file-based logging by default.
You can use the foreman-installer
command to reconfigure logging.
Enter the following
foreman-installer
command to configure logging to thejournald
service:# foreman-installer \ --foreman-logging-layout pattern \ --foreman-logging-type journald \ --foreman-proxy-log JOURNAL
Optional: To inspect the log messages, use the
journalctl
utility. For example:-
journalctl --unit foreman
andjournalctl --unit foreman-proxy
show messages for theforeman
andforeman-proxy
units -
journalctl REQUEST=request_ID
shows messages for a specified request
Enter the following
foreman-installer
command to configure file-based logging:# foreman-installer \ --reset-foreman-logging-layout \ --reset-foreman-logging-type \ --reset-foreman-proxy-log
Optional: To inspect the log messages, view these files:
/var/log/foreman-proxy.log
13.7. Log File Directories Provided by orcharhino
orcharhino provides system information in the form of notifications and log files.
Log File Directories | Description of Log File Content |
Subscription management |
Installer |
Foreman maintain |
Foreman proxy |
Foreman |
Apache HTTP server |
Various other log messages |
Configuration management |
Candlepin webservice logs |
You can also use the foreman-tail
command to follow many of the log files related to orcharhino.
You can run foreman-tail -l
to list the processes and services that it follows.
13.8. Utilities for Collecting Log Information
You can collect information from log files to troubleshoot orcharhino.
- foreman-debug
The
foreman-debug
command collects configuration and log file data for orcharhino, its back-end services, and system information. This information is collected and written to a tar file. By default, the output tar file is located at/tmp/foreman-debug-xxx.tar.xz
Additionally, the foreman-debug
command exports tasks run during the last 60 days.
By default, the output tar file is located at /tmp/task-export-xxx.tar.xz
If the file is missing, see the file /tmp/task-export.log
to learn why task export was unsuccessful.
There is no timeout when running this command.
For more information, run orcharhino-debug -h
The collection process removes security information such as passwords, tokens, and keys while collecting information. However, the tar files can still contain sensitive information about the orcharhino Server. ATIX AG recommends that you send this information directly to the intended recipient and not to a public target. |
13.9. System Journal Metadata
The following table lists metadata that the journald
service uses in orcharhino.
You can use this metadata to filter your queries.
Name | Description |
AUDIT_ACTION |
Audit action performed Example: Create, update, or delete |
AUDIT_TYPE |
Audit resource type Example: Host, Subnet, or ContentView |
AUDIT_ID |
Audit resource database ID as a number |
AUDIT_ATTRIBUTE |
Audit resource field or an updated database column |
AUDIT_FIELD_OLD |
Old audit value of an update action |
AUDIT_FIELD_NEW |
New audit value of an update action |
AUDIT_ID |
Record database ID of the audit subject |
AUDIT_ATTRIBUTE |
Attribute name or column on which an action was performed Example: Name or description |
EXCEPTION_MESSAGE |
Exception message when error is logged |
EXCEPTION_CLASS |
Exception Ruby class when error is logged |
EXCEPTION_BACKTRACE |
Exception backtrace as a multiline string when error is logged |
LOC_ID |
Location database ID |
LOC_NAME |
Location name |
LOC_LABEL |
Location label |
LOGGER |
Logger name To see the current list of loggers enabled by default, enter this command: # awk '/add_loggers/,/^$/' /usr/share/foreman/config/application.rb |
ORG_ID |
Organization database ID |
ORG_NAME |
Organization name |
ORG_LABEL |
Organization label |
REMOTE_IP |
Remote IP address of a client |
REQUEST |
Request ID generated by the Action Dispatch module |
SESSION |
Random ID generated per session or a request for a sessionless request |
TEMPLATE_NAME |
Template name |
TEMPLATE_DIGEST |
Digest (SHA256) of rendered template contents |
TEMPLATE_HOST_NAME |
Host name for a rendered template if present |
TEMPLATE_HOST_ID |
Host database ID for a rendered template if present |
USER_LOGIN |
User login name |
14. Monitoring Resources
14.1. Using the orcharhino Content Dashboard
The orcharhino content dashboard contains various widgets which provide an overview of the host configuration, Content Views, compliance reports, subscriptions and hosts currently registered, promotions and synchronization, and a list of the latest notifications.
In the orcharhino management UI, navigate to Monitor > Dashboard to access the content dashboard. The dashboard can be rearranged by clicking on a widget and dragging it to a different position. The following widgets are available:
- Host Configuration Status
Table 8. Host Configuration States Icon State Description Hosts that had performed modifications without error
Hosts in error state
noop
mode.Out of sync hosts
Hosts with no reports
Hosts with alerts disabled
- Host Configuration Chart
- Latest Events
- New Hosts
- Task Status
- Latest Warning/Error Tasks
- Discovered Hosts
- Latest Errata
A list of all errata available for hosts registered to orcharhino.
- Content Views
A list of all Content Views in orcharhino and their publish status.
- Sync Overview
An overview of all products or repositories enabled in orcharhino and their synchronization status. All products that are in the queue for synchronization, are unsynchronized or have been previously synchronized are listed in this section.
- Host Subscription Status
An overview of the subscriptions currently consumed by the hosts registered to orcharhino. A subscription is a purchased certificate that unlocks access to software, upgrades, and security fixes for hosts. The following table shows the possible states of subscriptions.
Table 9. Host Subscription States Icon State Description Invalid
Partial
Valid
- Subscription Status
- Host Collections
A list of all host collections in orcharhino and their status, including the number of content hosts in each host collection.
virt-who
daemon running on hosts in the environment. The following table shows the possible states.Table 10. Virt-who Configuration States State Description No Reports
No report has been received because either an error occurred during the virt-who configuration deployment, or the configuration has not been deployed yet, or virt-who cannot connect to orcharhino during the scheduled interval.
No Change
OK
Total Configurations
- Latest Compliance Reports
- Red Hat Insights Actions
Red Hat Insights is a tool embedded in orcharhino that checks the environment and suggests actions you can take. The actions are divided into 4 categories: Availability, Stability, Performance, and Security.
- Red Hat Insights Risk Summary
NoteIt is not possible to change the date format displayed in the orcharhino management UI.
14.1.1. Managing Tasks
orcharhino keeps a complete log of all planned or performed tasks, such as repositories synchronised, errata applied, and Content Views published. To review the log, navigate to Monitor > Tasks.
Adjusting the %_finish_timeout values might help in case of low bandwidth. Adjusting the %_accept_timeout values might help in case of high latency. |
Click Save.
14.2. Configuring RSS Notifications
To view orcharhino event notification alerts, click the Notifications icon in the upper right of the screen.
By default, the Notifications area displays RSS feed events published in the orcharhino news.
You can configure the RSS feed notifications by changing the URL feed. The supported feed format is RSS 2.0 and Atom.
In the orcharhino management UI, navigate to Administer > Settings and select the Notifications tab.
14.3. Monitoring orcharhino Server
Audit records list the changes made by all users on orcharhino. This information can be used for maintenance and troubleshooting.
In the orcharhino management UI, navigate to Monitor > Audits to view the audit records.
To obtain a list of all the audit attributes, use the following command:
14.4. Monitoring orcharhino Proxy
The following section shows how to use the orcharhino management UI to find orcharhino Proxy information valuable for maintenance and troubleshooting.
14.4.1. Viewing General orcharhino Proxy Information
In the orcharhino management UI, navigate to Infrastructure > orcharhino Proxies to view a table of orcharhino Proxies registered to orcharhino Server. The information contained in the table answers the following questions:
- Is orcharhino Proxy running?
This is indicated by a green icon in the Status column. A red icon indicates an inactive orcharhino Proxy, use the
service foreman-proxy restart
command on orcharhino Proxy to activate it. - What services are enabled on orcharhino Proxy?
In the Features column you can verify if orcharhino Proxy for example provides a DHCP service or acts as a Pulp mirror. orcharhino Proxy features can be enabled during installation or configured in addition. For more information, see Installing orcharhino Proxy.
- What organizations and locations is orcharhino Proxy assigned to?
A orcharhino Proxy can be assigned to multiple organizations and locations, but only orcharhino Proxies belonging to the currently selected organization are displayed. To list all orcharhino Proxies, select Any Organization from the context menu in the top left corner.
After changing the orcharhino Proxy configuration, select Refresh from the drop-down menu in the Actions column to ensure the orcharhino Proxy table is up to date.
Click the orcharhino Proxy name to view further details. At the Overview tab, you can find the same information as in the orcharhino Proxy table. In addition, you can answer to the following questions:
- Which hosts are managed by orcharhino Proxy?
- How much storage space is available on orcharhino Proxy?
/var/lib/pulp
is displayed. Also the remaining storage space available on the orcharhino Proxy can be ascertained.
14.4.2. Monitoring Services
In the orcharhino management UI, navigate to Infrastructure > orcharhino Proxies and click the name of the selected orcharhino Proxy. At the Services tab, you can find basic information on orcharhino Proxy services, such as the list of DNS domains, or the number of Pulp workers. The appearance of the page depends on what services are enabled on orcharhino Proxy. Services providing more detailed status information can have dedicated tabs at the orcharhino Proxy page. For more information, see Monitoring Puppet.
14.4.3. Monitoring Puppet
In the orcharhino management UI, navigate to Infrastructure > orcharhino Proxies and click the name of the selected orcharhino Proxy. At the Puppet tab you can find the following:
A table of CA certificates associated with the orcharhino Proxy at the Certificates sub-tab. Here you can inspect the certificate expiry data, or cancel the certificate by clicking Revoke.
15. Using Webhooks
A webhook is a way for a web page or web application to provide other applications with information in real time. Webhooks are only triggered after an event occurs. The request usually contains details of the event. An event triggers callbacks, such as sending an e-mail confirming a host has been provisioned. Webhooks enable you to define a call to an external API based on orcharhino internal event using a fire-and-forget message exchange pattern. The application sending the request does not wait for the response, or ignores it.
@event_name
: Name of an event. -
@webhook_id
: Unique event ID. -
@payload
: Payload data, different for each event type. To access individual fields, use@payload[:key_name]
Ruby hash syntax. -
@payload[:object]
: Database object for events triggered by database actions (create, update, delete). Not available for custom events. -
@payload[:context]
: Additional information as hash like request and session UUID, remote IP address, user, organization and location.
The typical use case for webhooks in orcharhino is making a call to a monitoring system when a host is created or deleted.
Webhooks are useful where the action you want to perform in the external system can be achieved through its API. Where it is necessary to run additional commands or edit files, the shellhooks plugin for orcharhino Proxies is available. The shellhooks plugin enables you to define a shell script on the orcharhino Proxy that can be executed through the API.
15.1. Migrating to Webhooks
The legacy foreman_hooks
plugin provided full access to model objects that the webhooks plugin does not intentionally provide.
The number of events triggered by webhooks is substantially fewer than with foreman_hooks
Webhooks are processed asynchronously so there is minimal risk of tampering with internals of the system.
It is not possible to migrate from foreman_hooks
without creating payloads for each individual webhook script.
However, the webhooks plugin comes with several example payload templates.
You can also use the example payloads with shellhooks to simplify migration.
15.2. Installing Webhooks
Use the following procedure to install webhooks. After installing webhooks, you can configure orcharhino Server to send webhook requests.
Install webhooks using the following command:
Optional: you can install the CLI plugin using the following command:
15.3. Creating a Webhook Template
Webhook templates are used to generate the body of HTTP request to a configured target when a webhook is triggered. Use the following procedure to create a webhook template in the orcharhino management UI.
In the orcharhino management UI, navigate to Administer > Webhook Templates.
A webhook HTTP payload must be created using orcharhino template syntax. The webhook template can use a special variable called
@object
that can represent the main object of the event.@object
can be missing in case of certain events. You can determine what data are actually available with the@payload
variable.For more information, see Template Writing Reference in Managing Hosts and for available template macros and methods, visit
/templates_doc
on orcharhino Server. -
Click Submit.
For example, an application can expect a "text"
field with the webhook message.
Actions Remote Execution Run Host Job Succeeded
orActions Remote Execution Run Host Job Failed
.{ "text": "job invocation <%= @object.job_invocation_id %> finished with result <%= @object.task.result %>" }
- Creating users
User Created
event.{ "text": "user with login <%= @object.login %> and email <%= @object.mail %> created" }
15.4. Creating a Webhook
You can customize events, payloads, HTTP authentication, content type, and headers through the orcharhino management UI.
Use the following procedure to create a webhook in the orcharhino management UI.
In the orcharhino management UI, navigate to Administer > Webhooks.
Click Create new.
Click Template to select a template. Webhook templates are used to generate the body of the HTTP request to orcharhino Server when a webhook is triggered.
Enter an HTTP method.
Click the Credentials tab.
Optional: Uncheck Verify SSL if you do not want to verify the server certificate against the system certificate store or orcharhino CA.
application/json
,application/xml
ortext/plain
on the payload you define. The application does not attempt to convert the content to match the specified content type. -
When configuring webhooks with endpoints with non-standard HTTP or HTTPS ports, an SELinux port must be assigned, see Configuring SELinux to Ensure Access to orcharhino on Custom Ports in Installing orcharhino Server.
15.5. Available Webhook Events
The following table contains a list of webhook events that are available from the orcharhino management UI.
Action
events trigger webhooks only on success
, so if an action fails, a webhook is not triggered.
Event name | Description | Payload |
A Content View was successfully promoted. |
Actions::Katello::ContentView::Promote |
Actions::Katello::ContentView::Publish |
Run OpenSCAP scan. |
Runs an Ansible playbook containing all the roles defined for a host. |
Actions Remote Execution Run Host Job Ansible Run Capsule Upgrade Succeeded |
Upgrade Capsules on given Capsule server hosts. |
Run an Ansible playbook against given hosts. |
Run an Ansible playbook to enable the web console on given hosts. |
Build Entered |
Custom event: |
Build Exited |
Custom event: |
Common database operations on a Content View. |
Katello::ContentView |
Domain |
Host |
Hostgroup |
Model |
Status Changed |
Custom event: |
Subnet |
Template Render Performed |
Template |
User |
15.6. Shellhooks
With webhooks, you can only map one orcharhino event to one API call. For advanced integrations, where a single shell script can contain multiple commands, you can install a orcharhino Proxy shellhooks plugin that exposes executables using a REST HTTP API.
You can then configure a webhook to reach out to a orcharhino Proxy API to run a predefined shellhook. A shellhook is an executable script that can be written in any language as long as it can be executed. The shellhook can for example contain commands or edit files.
You must place your executable scripts in /var/lib/foreman-proxy/shellhooks
with only alphanumeric characters and underscores in their name.
You can pass arguments to shellhook script using HTTP headers in format X-Shellhook-Arg-1
to X-Shellhook-Arg-99
For more information on passing arguments to shellhook script, see:
The HTTP method must be POST.
An example URL would be: https://orcharhino-proxy.example.com:8443/shellhook/My_Script
Unlike the |
You must enable orcharhino Proxy Authorization for each webhook connected to a shellhook to enable it to authorize a call.
Standard output and standard error output are redirected to the orcharhino Proxy logs as messages with debug or warning levels respectively.
15.7. Installing the Shellhooks Plugin
Optionally, you can install and enable the shellhooks plugin on each orcharhino Proxy used for shellhooks, using the following command:
15.8. Passing Arguments to Shellhook Script Using Webhooks
{ "X-Shellhook-Arg-1": "VALUE", "X-Shellhook-Arg-2": "VALUE" }
{ "X-Shellhook-Arg-1": "<%= @object.content_view_version_id %>", "X-Shellhook-Arg-2": "<%= @object.content_view_name %>" }
15.9. Passing Arguments to Shellhook Script Using Curl
curl
, create HTTP headers in the following format:"X-Shellhook-Arg-1: VALUE" "X-Shellhook-Arg-2: VALUE"
# curl -sX POST -H 'Content-Type: text/plain' \ -H "X-Shellhook-Arg-1: Version 1.0" \ -H "X-Shellhook-Arg-2: My Content View" \ --data "" https://orcharhino-proxy.example.com:8443/shellhook/My_Script
15.10. Creating a Shellhook to Print Arguments
You have the
webhooks
andshellhooks
plug-ins installed. For more information, see:
Modify the
/var/lib/foreman-proxy/shellhooks/print_args
script to print arguments to standard error output so you can see them in the orcharhino Proxy logs:#!/bin/sh # # Prints all arguments to stderr # echo "$@" >&2
Click Create new.
In the Target URL field, enter the URL of your orcharhino Proxy followed by
:8443/shellhook/print_args
:https://orcharhino-proxy.example.com:8443/shellhook/print_args
Note that
shellhook
in the URL is singular, unlike theshellhooks
directory. -
On the Credentials tab, check orcharhino Proxy Authorization.
{ "X-Shellhook-Arg-1": "Hello", "X-Shellhook-Arg-2": "World!" }
Click Submit. You now have successfully created a shellhook that prints "Hello World!" to orcharhino Proxy logs every time you a remote execution job succeeds.
time
as a command. For more information, see Executing a Remote Job in Managing Hosts. -
Verify that the shellhook script was triggered and printed "Hello World!" to orcharhino Proxy logs:
16. Searching and Bookmarking
orcharhino features powerful search functionality on most pages of the orcharhino management UI. It enables you to search all kinds of resources that orcharhino manages. Searches accept both free text and syntax-based queries, which can be built using extensive input prediction. Search queries can be saved as bookmarks for future reuse.
16.1. Building Search Queries
16.1.1. Query Syntax
parameter operator value
16.1.2. Query Operators
Operator | Short Name | Description | Example |
EQUALS |
NOT EQUALS |
LIKE |
NOT LIKE |
GREATER THAN |
LESS THAN |
IN |
NOT IN |
HAS or set? |
NOT HAS or null? |
Operator | Alternative Notations | Example | ||
and |
<whitespace> |
or |
not |
16.1.3. Query Values
- Text Values
Examples:
hostgroup = "Web servers"
hostgroup = Web servers
- Temporal Values
"10 January 2017"
"10 Jan 2017"
10-January-2017
10/January/2017
"January 10, 2017"
Warning
16.2. Using Free Text Search
16.3. Managing Bookmarks
On some pages, there are default bookmarks available for the common searches, for example, all active
or disabled
hosts.
16.3.1. Creating Bookmarks
In the orcharhino management UI, navigate to the page where you want to create a bookmark.
Ensure the Public checkbox is set correctly:
Select the Public checkbox to set the bookmark as public and visible to all users.
Clear the Public checkbox to set the bookmark as private and only visible to the user who created it.
Click Submit.
16.3.2. Deleting Bookmarks
In the orcharhino management UI, navigate to Administer > Bookmarks.
This section contains information about settings that you can edit in the orcharhino management UI by navigating to Administer > Settings.
A.1. General Settings
Setting | Default Value | Description |
Administrator email address |
orcharhino URL |
URL where your orcharhino instance is reachable. See also Provisioning > Unattended URL. |
Entries per page |
20 |
Number of records shown per page in orcharhino |
Fix DB cache |
No |
orcharhino maintains a cache of permissions and roles.
When set to |
DB pending seed |
No |
Should the |
orcharhino Proxy request timeout |
60 |
Open and read timeout for HTTP requests from orcharhino to orcharhino Proxy (in seconds). |
Login page footer text |
Show host power status |
Yes |
Show power status on the host index page. This feature calls to compute resource providers which may lead to decreased performance on the host listing page. |
HTTP(S) proxy |
Set a proxy for outgoing HTTP(S) connections from the orcharhino product. System-wide proxies must be configured at the operating system level. |
HTTP(S) proxy except hosts |
Show Experimental Labs |
No |
Append domain names to the host |
Yes |
If set to |
Out of sync interval |
30 |
Managed hosts report periodically, and if the time between reports exceeds this duration in minutes, hosts are considered out of sync.
orcharhino UUID |
orcharhino instance ID. Uniquely identifies a orcharhino instance. |
Default language |
Default timezone |
The timezone to use for new users. |
Instance title |
Saved audits interval |
New host details UI |
Yes |
orcharhino loads the new UI for host details. |
A.2. Tasks settings
Sync task timeout |
120 |
Enable dynflow console |
Yes |
Enable the dynflow console ( |
Yes |
The user must be authenticated as having administrative rights before accessing the dynflow console. |
Proxy action retry count |
4 |
Number of attempts permitted to start a task on the orcharhino Proxy before failing. |
Proxy action retry interval |
15 |
Allow proxy batch tasks |
Yes |
Allow triggering tasks on the orcharhino Proxy in batches. |
Proxy tasks batch size |
100 |
Number of tasks included in one request to the orcharhino Proxy if |
Tasks troubleshooting URL |
It should contain a |
1 |
A.3. Template Sync Settings
Associate |
New |
Associate templates with OS, organization and location. |
Branch |
Default branch in Git repo. |
Commit message |
Templates export made by a orcharhino user |
Dirname |
Filter |
Force import |
No |
If set to |
Lock templates |
Keep, do not lock new |
Metadata export mode |
Refresh |
Negate |
No |
Prefix |
Repo |
When exporting to |
Verbosity |
No |
A.4. Discovered Settings
Discovery location |
Discovery organization |
Interface fact |
discovery_bootif |
Create bond interfaces |
No |
Clean all facts |
No |
Hostname facts |
discovery_bootif |
Auto provisioning |
No |
Reboot |
Yes |
Hostname prefix |
mac |
Fact columns |
Highlighted facts |
Storage facts |
Software facts |
Hardware facts |
Network facts |
IPMI facts |
Lock PXE |
No |
pxelinux_discovery |
Locked PXEGrub template name |
pxegrub_discovery |
PXEGrub template to be used when pinning a host to discovery. |
pxegrub2_discovery |
Force DNS |
Yes |
Error on existing NIC |
No |
Do not permit to discover an existing managed host matching the MAC of a provisioning Network Interface Card (NIC) (errors out early). |
Type of name generator |
Fact + prefix |
Prefer IPv6 |
No |
A.5. Boot Disk Settings
iPXE directory |
ISOLINUX directory |
SYSLINUX directory |
Grub2 directory |
Host image template |
Boot disk iPXE - host |
Generic image template |
ISO generation command |
genisoimage |
Installation media caching |
Yes |
Allowed bootdisk types |
A.6. Content Settings
Default HTTP Proxy |
CDN SSL version |
SSL version used to communicate with the CDN. |
Kickstart default |
Kickstart default finish |
Default synced OS user-data |
Kickstart default user data |
Kickstart default PXELinux |
Default synced OS PXEGrub template |
Kickstart default PXEGrub |
Default PXEGrub template for new operating systems created from synced content. |
Kickstart default PXEGrub2 |
Kickstart default iPXE |
Kickstart default |
Discovery ATIX AG kexec |
Atomic Kickstart default |
Manifest refresh timeout |
1200 |
Accept action timeout |
20 |
Time in seconds to wait for a host to pick up a remote action. |
Finish action timeout |
3600 |
Time in seconds to wait for a host to finish a remote action. |
Yes |
Can communicate with the ATIX AG Portal for subscriptions. |
No |
Calculate errata host status based only on errata in a host’s Content View and Lifecycle Environment. |
No |
Yes |
100 |
How many repositories should be synced concurrently on a orcharhino Proxy. A smaller number may lead to longer sync times. A larger number will increase dynflow load. |
Sync orcharhino Proxies after Content View promotion |
Yes |
Whether or not to auto sync orcharhino Proxies after a Content View promotion. |
Either |
Default ATIX AG Repository download policy |
Default download policy for enabled ATIX AG repositories.
Either |
Default orcharhino Proxy download policy |
Default download policy for orcharhino Proxy syncs.
Either |
Pulp export destination filepath |
On-disk location for exported repositories. |
Pulp client key |
Pulp client cert |
Sync Connection Timeout |
300 |
Use remote execution by default |
No |
If enabled, remote execution is used instead of katello-agent for remote actions. |
Delete Host upon unregister |
No |
No |
If this is enabled, and |
Default Location |
Expire soon days |
120 |
No |
Host Duplicate DMI UUIDs |
Host Profile Assume |
Yes |
Enable new host registrations to assume registered profiles with matching hostname as long as the registering DMI UUID is not used by another host. |
No |
Enable host registrations to bypass Host Profile Assume as long as the host is in build mode. |
No |
5 |
Applicability Batch Size |
50 |
Autosearch |
Yes |
Autosearch delay |
500 |
Pulp bulk load size |
2000 |
Yes |
1440 |
No |
Yes |
Enable removal of repositories that the user has previously published in one or more Content View versions. |
A.7. Authentication Settings
OAuth active |
Yes |
orcharhino will use OAuth for API authorization. |
OAuth consumer key |
OAuth consumer key. |
OAuth consumer secret |
OAuth consumer secret. |
OAuth map users |
No |
orcharhino maps users by username in the request-header. If this is disabled, OAuth requests have administrator rights. |
Failed login attempts limit |
30 |
orcharhino blocks user logins from an incoming IP address for 5 minutes after the specified number of failed login attempts. Set to 0 to disable brute force protection. |
Restrict registered orcharhino Proxies |
Yes |
Only known orcharhino Proxies can access features that use orcharhino Proxy authentication. |
Trusted hosts |
List of hostnames, IPv4, IPv6 addresses or subnets to be trusted in addition to orcharhino Proxies for access to fact/report importers and ENC output. |
SSL certificate |
SSL Certificate path that orcharhino uses to communicate with its proxies. |
SSL CA file |
SSL CA file path that orcharhino uses to communicate with its proxies. |
SSL private key |
SSL Private Key path that orcharhino uses to communicate with its proxies. |
SSL client DN env |
HTTP_SSL_CLIENT_S_DN |
SSL client verify env |
HTTP_SSL_CLIENT_VERIFY |
SSL client cert env |
HTTP_SSL_CLIENT_CERT |
Server CA file |
SSL CA file path used in templates to verify the connection to orcharhino. |
Websockets SSL key |
Private key file path that orcharhino uses to encrypt websockets. |
Websockets SSL certificate |
Certificate path that orcharhino uses to encrypt websockets. |
Websockets encryption |
Yes |
Login delegation logout URL |
External |
Authorize login delegation |
No |
No |
Idle timeout |
60 |
BCrypt password cost |
9 |
BMC credentials access |
Yes |
OIDC JWKs URL |
Typically |
OIDC Audience |
OIDC Issuer |
OIDC Algorithm |
A.8. Email Settings
Email reply address |
Email reply address for emails that orcharhino is sending. |
Email subject prefix |
Send welcome email |
No |
Delivery method |
Sendmail |
SMTP enable StartTLS auto |
Yes |
SMTP OpenSSL verify mode |
Default verification mode |
SMTP address |
SMTP address to connect to. |
SMTP port |
25 |
SMTP port to connect to. |
SMTP HELO/EHLO domain |
HELO/EHLO domain. |
SMTP username |
SMTP password |
SMTP authentication |
none |
Sendmail arguments |
-i |
Sendmail location |
A.9. Notifications Settings
RSS enable |
Yes |
Pull RSS notifications. |
RSS URL |
A.10. Provisioning Settings
Host owner |
Default owner on provisioned hosts, if empty orcharhino uses the current user. |
Root password |
Unattended URL |
Safemode rendering |
No |
Query local nameservers |
No |
orcharhino queries the locally configured resolver instead of the SOA/NS authorities. |
Installation token lifetime |
360 |
SSH timeout |
120 |
0.0.0.0 |
No |
orcharhino updates the host IP with the IP that made the build request. |
Use short name for VMs |
No |
orcharhino uses the short hostname instead of the FQDN for creating new virtual machines. |
DNS timeout |
[5, 10, 15, 20] |
Clean up failed deployment |
Yes |
orcharhino deletes the virtual machine if the provisioning script ends with a non-zero exit code. |
iPXE intermediate script |
No |
Destroy associated VM on host delete. When enabled, VMs linked to hosts are deleted on Compute Resource. When disabled, VMs are unlinked when the host is deleted, meaning they remain on Compute Resource and can be re-associated or imported back to orcharhino again. This does not automatically power off the VM |
Maximum structured facts |
100 |
Global Registration |
CoreOS Transpiler Command |
PXEGrub2 global default |
PXELinux global default |
Global default PXEGrub template |
PXEGrub global default |
Global default PXEGrub template. This template is deployed to all configured TFTP servers. It is not affected by upgrades. |
iPXE global default |
PXEGrub2 default local boot |
PXELinux default local boot |
Local boot PXEGrub template |
PXEGrub default local boot |
Template that is selected as PXEGrub default for local boot. |
Local boot iPXE template |
iPXE default local boot |
Manage PuppetCA |
Yes |
orcharhino automates certificate signing upon provision of a new host. |
Use UUID for certificates |
No |
orcharhino uses random UUIDs for certificate signing instead of hostnames. |
A.11. Facts Settings
Yes |
orcharhino creates the host when new facts are received. |
Location fact |
orcharhino_location |
Organization fact |
orcharhino_organization |
Default location |
Default Location |
Default organization |
Default Organization |
Update hostgroup from facts |
Yes |
orcharhino updates a host’s hostgroup from its facts. |
No |
Ignore facts for domain |
No |
Update subnets from facts |
None |
orcharhino updates a host’s subnet from its facts. |
No |
Exclude pattern for facts stored in satellite |
Those facts are not stored in the orcharhino database.
Default Puppet environment |
production |
orcharhino defaults to this puppet environment if it cannot auto detect one. |
ENC environment |
Yes |
orcharhino explicitly sets the puppet environment in the ENC yaml output.
No |
orcharhino updates a host’s environment from its facts. |
Yes |
orcharhino creates the host when a report is received. |
Matchers inheritance |
Yes |
orcharhino matchers are inherited by children when evaluating smart class parameters for hostgroups, organizations, and locations. |
orcharhino evaluates host smart class parameters in this order by default. |
Yes |
orcharhino parses ERB in parameters value in the ENC output. |
No |
All hosts show a configuration status even when a Puppet orcharhino Proxy is not assigned. |
Puppet interval |
35 |
Puppet out of sync disabled |
No |
Fallback to Any Proxy |
No |
Enable Global Proxy |
Yes |
SSH User |
root |
Default user to use for SSH.
Effective User |
root |
Effective User Method |
sudo |
One of [ |
Effective user password |
Sync Job Templates |
Yes |
SSH Port |
22 |
Default port 22.
Connect by IP |
No |
Prefer IPv6 over IPv4 |
No |
Default SSH password |
Default SSH key passphrase |
Workers pool size |
5 |
Restart of the |
Cleanup working directories |
Yes |
Cockpit URL |
Form Job Template |
Run Command - SSH Default |
A.14. Ansible Settings
Private Key Path |
Override with the |
Connection type |
ssh |
Use this connection type by default when running Ansible playbooks.
WinRM cert Validation |
validate |
Enable or disable WinRM server certificate validation when running Ansible playbooks.
Default verbosity level |
Disabled |
orcharhino adds this level of verbosity for additional debugging output when running Ansible playbooks. |
Post-provision timeout |
360 |
Timeout (in seconds) to set when orcharhino triggers an Ansible roles task playbook after a host is fully provisioned. Set this to the maximum time you expect a host to take until it is ready after a reboot. |
Ansible report timeout |
30 |
No |
Ansible - Ansible Inventory |
orcharhino uses this template to schedule the report with Ansible inventory. |
Ansible roles to ignore |
The roles to exclude when importing roles from orcharhino Proxy.
For example: |
Number of tasks which should be sent to the orcharhino Proxy in one request if |
