1. Introduction to Foreman
Foreman is a centralized tool for provisioning, remote management, and monitoring of multiple Enterprise Linux deployments. With Foreman, you can deploy, configure, and maintain your systems across physical, virtual, and cloud environments.
2. Provisioning management with Foreman
2.1. Provisioning methods in Foreman
Network based
This method uses an operating system installer, such as Anaconda, Debian Installer, Agama, or AutoYaST, and a template-generated file with installation options downloaded from Foreman, such as Agama, AutoYaST, Kickstart, Preseed, or Preseed Autoinstall templates.
PXE-less Discovery with kexec
Boot disk based
Image based
Figure 1. Choosing a provisioning method
3. Major Foreman components
A typical Foreman deployment consists of the following components: a Foreman server, Smart Proxy servers, and hosts that receive configuration from Foreman server and Smart Proxy servers.
3.1. Foreman server overview
Foreman server is the central component of a Foreman deployment.
  • Configuration of hosts
  • Host provisioning
Foreman server delegates host provisioning and communication to Smart Proxy servers. Foreman server itself also includes a Smart Proxy.
3.2. Smart Proxy overview
3.3. Overview of hosts in Foreman
With Foreman, you can manage hosts at scale, including monitoring, provisioning, remote execution, and configuration management. You can also group hosts by using features such as host groups and host collections.
3.4. List of key open source components of Foreman
Foreman
Katello
Candlepin
Pulp
3.5. Smart Proxy features
Smart Proxy servers provide local host management services.
Smart Proxies provide the following functionalities:
DHCP
DNS
TFTP
Realm
Puppet server
Puppet Certificate Authority
Provisioning template proxy
OpenSCAP
Remote Execution (REX)
Infrastructure Smart Proxies: DNS + DHCP + TFTP
Smart Proxies with these services provide infrastructure services for hosts and have all necessary services for provisioning new hosts.
4. Tools for administration of Foreman
4.1. Foreman web UI overview
4.2. Hammer CLI overview
4.3. Foreman API overview
You can write custom scripts and external applications that access the Foreman API over HTTP with the Representational State Transfer (REST) API provided by Foreman server.
  • Create client applications that require minimal knowledge of the Foreman infrastructure because users discover many details at runtime.
4.4. MCP server overview
Foreman provides a Model Context Protocol (MCP) server so that you can query and manage your Foreman inventory from MCP-compatible AI applications by using natural language.
You deploy the MCP server from a container image that Foreman community provides and connect it to the AI application that runs your MCP client. The MCP server accesses Foreman with your credentials, so your MCP client cannot obtain data that you do not have permission to access.
By default, the MCP server is read-only. You can query your inventory and generate reports from it, for example, a report of all subnets and the hosts that are assigned to them.
When you start the MCP server, you can also grant it permissions to change your Foreman. For example, you can start remote execution jobs on your hosts, and publish and promote content views.
4.5. Remote execution in Foreman
4.6. Automating Foreman management with Foreman Ansible Collection
5. Supported usage and versions of Foreman components
5.1. Foreman operating system
You can install Foreman on the following supported operating systems.
You can run Foreman server and Smart Proxy servers on Enterprise Linux 9, Debian 12, and Ubuntu 22.04. Katello plugin packages, which provide content management capabilities, are only available for Enterprise Linux.
5.2. Client operating systems
  • Amazon Linux
  • Debian
  • Fedora
  • Ubuntu
  • Ansible
  • OpenSCAP
  • OpenSSH
  • Puppet
  • Salt
6. Networking considerations in Foreman
For the components of Foreman architecture to communicate, the required network ports must be open to enable incoming and outgoing traffic between the components.
6.1. Smart Proxy networking
6.2. Foreman server port and firewall requirements
53
TCP and UDP
DNS
DNS Servers and clients
Name resolution
DNS (optional)
67
UDP
DHCP
Client
Dynamic IP
DHCP (optional)
69
UDP
TFTP
Client
TFTP Server (optional)
TCP
HTTPS
Smart Proxy
Foreman API
TCP
HTTPS
Client
Global Registration
Registering hosts to Foreman
Port 443 is required for registration initiation, and uploading facts.
4505 – 4506
TCP
MQTT
Client
Salt (optional)
Salt Master to Salt Minions
5910 – 5930
TCP
HTTPS
Browsers
8000
TCP
HTTP
Client
Provisioning templates
8000
TCP
HTTPS
Client
PXE Boot
Installation
8140
TCP
HTTPS
Client
OpenVox agent
Client updates (optional)
8443
TCP
HTTPS
Foreman
Smart Proxy API
Smart Proxy functionality
8443
TCP
HTTPS
Client
OpenSCAP
8443
TCP
HTTPS
Discovered Node
Discovery
9191
TCP
HTTPS
Client
Salt (optional)
Salt API
ICMP
ping
Client
DHCP
Free IP checking (optional)
7
TCP
echo
Client
DHCP
22
TCP
SSH
Target host
Remote execution
Run jobs
22, 16514
TCP
SSH SSH/TLS
Compute Resource
53
TCP and UDP
DNS
DNS Servers on the internet
DNS Server
53
TCP and UDP
DNS
DNS Server
Smart Proxy DNS
53
TCP and UDP
DNS
DNS Server
Orchestration
Validation of DNS conflicts
68
UDP
DHCP
Client
Dynamic IP
DHCP (optional)
80
TCP
HTTP
Remote repository
Content Sync
Remote repositories
389, 636
TCP
LDAP, LDAPS
External LDAP Server
LDAP
TCP
HTTPS
Compute resources
TCP
HTTPS
Infoblox DHCP Server
DHCP management
623
Client
Power management
BMC On/Off/Cycle/Status
5000
TCP
HTTPS
OpenStack Compute Resource
Compute resources
5900 – 5930
TCP
SSL/TLS
Hypervisor
noVNC console
Launch noVNC console
5985
TCP
HTTP
Client
WinRM
5986
TCP
HTTPS
Client
WinRM
7911
TCP
DHCP, OMAPI
DHCP Server
DHCP
8443
TCP
HTTPS
Client
Discovery
8443
TCP
HTTPS
Smart Proxy
Smart Proxy API
Management of Smart Proxies
6.3. Smart Proxy port and firewall requirements
53
TCP and UDP
DNS
Name resolution
DNS (optional)
67
UDP
DHCP
Client
Dynamic IP
DHCP (optional)
69
UDP
TFTP
Client
8000
TCP
HTTP
Client
8000
TCP
HTTP
Client
PXE Boot
Installation
8140
TCP
HTTPS
Client
OpenVox agent
8443
TCP
HTTPS
Foreman
Smart Proxy API
8443
TCP
HTTPS
Client
Register Endpoint
8443
TCP
HTTPS
Client
OpenSCAP
8443
TCP
HTTPS
Discovered Node
Discovery
ICMP
ping
Client
DHCP
7
TCP
echo
Client
DHCP
22
TCP
SSH
Target host
Remote execution
Run jobs
53
TCP and UDP
DNS
DNS Server
53
TCP and UDP
DNS
DNS Server
Smart Proxy DNS
68
UDP
DHCP
Client
Dynamic IP
DHCP (optional)
TCP
HTTPS
Foreman
Smart Proxy
Smart Proxy
Configuration management
Template retrieval
OpenSCAP
TCP
HTTPS
DHCP management
623
Client
Power management
7911
TCP
DHCP, OMAPI
DHCP Server
DHCP
8443
TCP
HTTPS
Client
Discovery
7. Deployment path for Foreman
7.1. Installing a Foreman server
7.1.1. Configuring Foreman server with external database
  • High volume of hosts.
7.2. Configuring external authentication in Foreman
FreeIPA
Yes (Linux users only)
LDAP
7.3. Planning organization and location context
Organizations and locations enable you to arrange Foreman resources into logically structured groups. For example, you can create groups based on ownership, purpose, or security level.
Organizations
Organizations can represent different business units, departments, or teams, such as Finance, Marketing, or Web Development.
Locations
Foreman server defines all locations and organizations. Each Smart Proxy server handles configuration of hosts in a different location.
Your Foreman server retains the management function, while the configuration is synchronized between your Foreman server and Smart Proxy servers assigned to certain locations.
Some resources in Foreman, such as Ansible roles and operating systems, are not part of any organization or location context.
Example 1. Example of using organizations and locations in Foreman
  • Finance
  • Marketing
  • Sales
  • United States
  • United Kingdom
  • Japan
  • Boston
  • Phoenix
  • San Francisco
7.4. Installing Smart Proxy servers
7.5. Defining role-based access control policies
7.5.1. Roles in Foreman
7.5.2. Best practices for role-based access control in Foreman
When implementing role-based access control in Foreman, consider the following guidelines for optimal results.
  • Define the expected tasks and responsibilities: Define the subset of the Foreman infrastructure that you want the role to access as well as actions permitted on this subset. Think of the responsibilities of the role and how it differs from other roles.
  • Use predefined roles whenever possible: Foreman provides several sample roles that you can use. Copying and editing an existing role can be a good start for creating a custom role.
  • Consider areas of interest and granting read-only access: Even though a role has a limited area of responsibility, it might need a wider set of permissions. Therefore, you can grant the role a read-only access to parts of Foreman infrastructure that influence its area of responsibility.
7.6. Configuring provisioning
How do I back up?
How do I back up?
Store the following critical data on network attached storage: database in /var/lib/pgsql. Replicate this storage into a different data center. Attach the storage to a Foreman server that is a clone of the primary Foreman server but runs passively.
How do I back up?
Dual active Foreman server
How do I back up?
7.8. Additional deployment tasks
Load balancing
8. Common deployment scenarios
8.1. Single location with segregated subnets
8.2. Deploying Foreman on AWS
One-region setup
One-region setup
Figure 2. One-region setup
Figure 3. Site-to-site VPN connection between the AWS region and the on-premises data center
Figure 4. Direct connection using the external DNS host name
Connecting different regions
Figure 5. Site-to-site VPN connection between AWS regions
Figure 6. Direct connection using the external DNS host name
9. Provisioning requirements in Foreman
9.1. PXE booting in Foreman
PXE sequence
PXE booting requirements
  • Network requirements:
  • Client requirements:
  • Foreman requirements:
9.2. HTTP booting in Foreman
    • The TCP port 8443 is open for the client to download the boot loader from the Smart Proxy using the HTTPS protocol.
      • https://smartproxy.example.com:8443
    • Ensure that the TCP port 8443 is open for the client to download the boot loader from the Smart Proxy through HTTPS.
foreman
N/A
foreman
N/A
yes
/usr/share/foreman
/sbin/nologin
foreman-proxy
N/A
foreman-proxy
N/A
yes
/usr/share/foreman-proxy
/sbin/nologin
www-data
33
www-data
33
no
/var/www
/usr/sbin/nologin
postgres
26
postgres
26
no
/var/lib/postgresql
/bin/bash
puppet
52
puppet
52
no
/sbin/nologin
Ansible
Answer file
ARF report
Audits
Boot disk
Catalog
Compliance policy
Compute profile
Compute resource
Configuration Management
Discovered host
Discovery image
Discovery plugin
Enables automatic bare-metal discovery of unknown hosts on the provisioning network. The plugin consists of three components: services running on Foreman server and Smart Proxy server, and the Discovery image running on host.
Discovery rule
Enterprise Linux
  • AlmaLinux
  • CentOS Stream
  • Oracle Linux
  • Red Hat Enterprise Linux
  • Rocky Linux
ERB
Facter
Facts
Foreman
Full host image
Generic image
Hammer
Host
Host collection
Host group
Host image
Job
Location
Migrating Foreman
OpenSCAP
Organization
Parameter
Permission
Provisioning
  • Agama templates for SUSE Linux Enterprise Server 16
  • AutoYaST templates for SUSE Linux Enterprise Server 15 and 12
  • Kickstart templates for AlmaLinux, Amazon Linux, CentOS, Oracle Linux, Red Hat Enterprise Linux, and Rocky Linux
  • Preseed Autoinstall templates for Ubuntu
  • Preseed templates for Debian
Puppet
OpenVox agent
Puppet environment
Puppet manifest
OpenVox server
Puppet module
PXE
Recurring logic
Remote execution (REX)
Resource type
Role
Salt
SCAP content
Smart Proxy server
Smart Proxy servers can provide DHCP, DNS, and TFTP services and act as an Ansible control node, OpenVox server, or Salt Master in separate networks. They interact with Foreman server in a client-server model.
Subnet image
Subscription Manager
Tailoring files
Task
Trend
Updating Foreman
The process of advancing your Foreman server and Smart Proxy server installations from one patch release to the next, for example Foreman 3.19.0 to Foreman 3.19.1.
Upgrading Foreman
The process of advancing your Foreman server and Smart Proxy server installations from one minor release to the next, for example Foreman 3.18 to Foreman 3.19.
User group
User
Virtualization
virt-who
XCCDF profiles
Report issue
