1. Starting and stopping Foreman
Foreman provides the foreman-maintain service command to manage Foreman services from the command line. This is useful when creating a backup of Foreman. For more information on creating backups, see Backing up Foreman server and Smart Proxy server.
2. Tuning Foreman server with predefined profiles
If your Foreman deployment includes more than 5000 hosts, you can use predefined tuning profiles to improve performance of Foreman.
Note that you cannot use tuning profiles on Smart Proxies.
You can choose one of the profiles depending on the number of hosts your Foreman manages and available hardware resources.
When you run the foreman-installer command with the --tuning option, deployment configuration settings are applied to Foreman in the following order:
  1. The default tuning profile defined in the /usr/share/foreman-installer/config/foreman.hiera/tuning/common.yaml file
  2. The tuning profile that you want to apply to your deployment and is defined in the /usr/share/foreman-installer/config/foreman.hiera/tuning/sizes/ directory
  3. Optional: If you have configured a /etc/foreman-installer/custom-hiera.yaml file, Foreman applies these configuration settings.
default
Number of hosts: 0 – 5000
RAM: 20G
Number of CPU cores: 4
medium
Number of hosts: 5001 – 10000
RAM: 32G
Number of CPU cores: 8
large
Number of hosts: 10001 – 20000
RAM: 64G
Number of CPU cores: 16
extra-large
Number of hosts: 20001 – 60000
RAM: 128G
Number of CPU cores: 32
extra-extra-large
Number of hosts: 60000+
RAM: 256G
Number of CPU cores: 48+
  1. Optional: If you have configured the custom-hiera.yaml file on Foreman server, back up the /etc/foreman-installer/custom-hiera.yaml file to custom-hiera.original. You can use the backup file to restore the /etc/foreman-installer/custom-hiera.yaml file to its original state if it becomes corrupted:
    # cp /etc/foreman-installer/custom-hiera.yaml \
    /etc/foreman-installer/custom-hiera.original
  2. Optional: If you have configured the custom-hiera.yaml file on Foreman server, review the definitions of the default tuning profile in /usr/share/foreman-installer/config/foreman.hiera/tuning/common.yaml and the tuning profile that you want to apply in /usr/share/foreman-installer/config/foreman.hiera/tuning/sizes/. Compare the configuration entries against the entries in your /etc/foreman-installer/custom-hiera.yaml file and remove any duplicated configuration settings in your /etc/foreman-installer/custom-hiera.yaml file.
  3. Enter the foreman-installer command with the --tuning option for the profile that you want to apply. For example, you can apply the medium tuning profile settings:
3. Migrating from internal Foreman databases to external databases
3.1. PostgreSQL as an external database considerations
Foreman, Katello, and Candlepin use the PostgreSQL database. If you want to use PostgreSQL as an external database, the following information can help you decide if this option is right for your Foreman configuration. Foreman supports PostgreSQL version 13.
Advantages of external PostgreSQL
Disadvantages of external PostgreSQL
3.2. Installing PostgreSQL
  • The prepared host has base operating system repositories enabled.
  • The prepared host has sufficient disk space available for the /var/lib/pgsql directory. The expected installation size is 100 MB and the expected runtime size is 20 GB.
  1. On your new database server, install PostgreSQL:
    # dnf install postgresql-server postgresql-contrib
  2. Initialize the PostgreSQL database:
    # postgresql-setup --initdb
    • max_connections: 500
    • shared_buffers: 512MB
    • work_mem: 4MB
    listen_addresses = '*'
  5. Add the following line to the end of the file to use SCRAM for authentication:
  6. Edit the /var/lib/pgsql/data/pg_hba.conf file:
  7. Add the following line to the file:
      host  all   all   Foreman_ip/32   scram-sha-256
  8. Start and enable the PostgreSQL service:
  9. Update the firewall configuration. For example, using the firewall-cmd command:
    1. Open the postgresql port:
    2. Make the changes persistent:
  10. Switch to the postgres user and start the PostgreSQL client:
    $ su - postgres -c psql
  11. Create three databases and dedicated roles: one for Foreman, one for Candlepin, and one for Pulp:
  12. Exit the postgres user:
    # \q
  • From Foreman server, test that you can access the database:
    # PGPASSWORD='Foreman_Password' pg_isready --host=postgres.example.com --port=5432 --username=foreman --dbname=foreman
    # PGPASSWORD='Candlepin_Password' pg_isready --host=postgres.example.com --port=5432 --username=candlepin --dbname=candlepin
    # PGPASSWORD='Pulpcore_Password' pg_isready --host=postgres.example.com --port=5432 --username=pulp --dbname=pulpcore
    If the connection succeeded, this displays an accepting connections message.
3.3. Migrating to external databases
  • You have installed and configured a PostgreSQL server on an external server.
  1. On Foreman server, stop all Foreman services except for PostgreSQL:
  2. Create your target directory for the Foreman backup:
    # mkdir /var/My_Migration_Backup_Directory
    # foreman-maintain backup online \
    --preserve-directory \
    --skip-pulp-content \
    PGPASSWORD='Foreman_Password' pg_restore --host=postgres.example.com --username=foreman --dbname=foreman < /var/My_Migration_Backup_Directory/foreman.dump
    PGPASSWORD='Candlepin_Password' pg_restore --host=postgres.example.com --username=candlepin --dbname=candlepin < /var/My_Migration_Backup_Directory/candlepin.dump
    PGPASSWORD='Pulpcore_Password' pg_restore --host=postgres.example.com --username=pulp --dbname=pulpcore < /var/My_Migration_Backup_Directory/pulpcore.dump
    # foreman-installer \
    --foreman-proxy-content-pulpcore-postgresql-user pulp \
    --foreman-db-manage false \
    --foreman-db-password Foreman_Password
  6. Remove the PostgreSQL package on Foreman server:
    # dnf remove postgresql-server
  7. Remove the PostgreSQL data directory:
    # rm -fr /var/lib/pgsql/data
4. Preparing for disaster recovery and recovering from data loss
How do I back up?
How do I back up?
Store the following critical data on network attached storage: content in /var/lib/pulp and database in /var/lib/pgsql. Replicate this storage into a different data center. Attach the storage to a Foreman server that is a clone of the primary Foreman server but runs passively.
How do I back up?
Dual active Foreman server
How do I back up?
4.2. Disaster recovery by virtualizing your Foreman server
4.2.1. Preparing for disaster recovery by virtualizing your Foreman server
  3. To verify that you will be able to restore Foreman services in case of a disaster, assess the functionality of the test Foreman server. For more information, see Retrieving the status of services by using Hammer CLI.
4.2.2. Recovering from disaster by restoring a VM snapshot of Foreman server
4.2.3. Retrieving the status of services by using Hammer CLI
    $ hammer ping
  • Perform a health check:
4.3. Disaster recovery for active and passive Foreman server with external storage
4.3.1. Preparing for disaster recovery with active and passive Foreman server with external storage
  2. Back up your active Foreman server and restore it on a system that will serve as your passive Foreman server. For more information, see Backing up Foreman server and Smart Proxy server and Restoring Foreman server or Smart Proxy server from a backup.
  4. Assess the functionality of the test Foreman server. For more information, see Retrieving the status of services by using Hammer CLI.
4.3.2. Recovering from disaster with active and passive server with external storage
  5. Assess the functionality of your new active Foreman server. For more information, see Retrieving the status of services by using Hammer CLI.
4.3.3. Retrieving the status of services by using Hammer CLI
    $ hammer ping
4.4. Disaster recovery for active and passive Foreman server with backup and restore
4.4.1. Preparing for disaster recovery with active and passive Foreman server and backup and restore
  1. Define a schedule for periodic offline backups of your active Foreman server. Consider your tolerance for potential data loss and your storage options: Taking backups frequently will result in smaller amounts of data loss in case of a disaster, but backups require a significant amount of storage space. For information about the size of Foreman backups, see Estimating the size of a backup.
    You can combine full backups with incremental backups. For an example of a cron job that ensures regular backups, see Example of a weekly full backup followed by daily incremental backups.
  2. Schedule periodic offline backups of your active Foreman server to be taken according to the schedule you defined. For information about performing backups, see Backing up Foreman server and Smart Proxy server.
  3. Ensure that the backup directories are encrypted and regularly synchronized to a secure location. By default, Foreman stores the backups in the /var/foreman-backup directory.
    Foreman server backups contain sensitive information from the /root/ssl-build directory. For example, they can contain hostnames, ssh keys, request files, and SSL certificates. Encrypting or moving the backups to a secure location helps minimize the risk of damage or unauthorized access to the hosts.
  4. Restore the most recent backup on a system that will serve as your passive Foreman server. For information about restoring backups, see Restoring Foreman server or Smart Proxy server from a backup.
    3. Assess the functionality of the test Foreman server. For more information, see Retrieving the status of services by using Hammer CLI.
4.4.2. Recovering from disaster with active and passive server and backup and restore
  3. Assess the functionality of your new active Foreman server. For more information, see Retrieving the status of services by using Hammer CLI.
4.4.3. Retrieving the status of services by using Hammer CLI
    $ hammer ping
4.4.4. Example of a weekly full backup followed by daily incremental backups
#!/bin/bash -e
else
fi
exit 0
4.5. Disaster recovery with two active Foreman servers
4.5.1. Preparing for disaster recovery with two active Foreman servers
Ansible playbooks can help you automate failover, re-registration, and synchronization. For more information, see Using the Foreman Ansible Collection.
  1. Back up your Foreman server. For more information, see Backing up Foreman server and Smart Proxy server.
  2. Restore the backup on a system that will serve as your other Foreman server. For more information, see Restoring Foreman server or Smart Proxy server from a backup.
  5. Automate running the foreman-maintain health check command on both servers. The health check verifies whether the servers remain fully operational.
  2. Verify that your foreman-maintain health check automation reported an error.
4.5.2. Recovering from disaster with two active Foreman servers
If the health checks implemented in Preparing for disaster recovery with two active Foreman servers report an issue on one of your Foreman servers, it might mean that the server has failed. If the server is down, you must re-register hosts to the other server.
  2. If foreman-maintain health check reported a problem, ensure that the server is powered off.
5. Managing users and roles
A User defines a set of details for individuals who use the system. Users can be associated with organizations and environments, so that when they create new entities, the default settings are automatically used. Users can also have one or more roles attached, which grants them rights to view and manage organizations and environments.
5.1. Managing users
5.1.1. Creating a user by using Foreman web UI
Use this procedure to create a user from the Foreman web UI.
  2. Click Create User.
  3. Enter the account details for the new user.
  4. Click Submit to create the user.
    • On the User tab, select an authentication source from the Authorized by list:
    • On the Organizations tab, select organizations for the user. Select the default organization from the Default on login list. Foreman uses this organization for the user after login.
    • On the Locations tab, select locations for the user. Select the default location from the Default on login list. Foreman uses this location for the user after login.
5.1.2. Creating a user by using Hammer CLI
Use this procedure to create a user by using Hammer CLI.
  • Create a user:
    $ hammer user create \
    --login My_User_Name \
    --mail My_User_Mail \
    --location-ids My_Location_ID_1,My_Location_ID_2 \
    --password My_User_Password
    Append --auth-source-id 1 so that the user is authenticated internally. Run hammer auth-source list to get a list of authentication sources. Add the --admin option to grant administrator privileges to the user.
    You can modify the user details later by using the hammer user update command.
5.1.3. Assigning roles to a user by using Foreman web UI
Use this procedure to assign roles to a user from the Foreman web UI.
  7. Click Submit.
5.1.4. Assigning roles to a user by using Hammer CLI
Use this procedure to assign roles to a user by using Hammer CLI.
  • Assign roles to a user:
    $ hammer user add-role \
    --id My_User_ID \
    --role My_Role_Name
5.1.5. Impersonating a different user account
5.1.6. Creating an API-only user
  • You have created a user and assigned roles to them. Note that this user must be authorized internally. For more information, see Managing users and roles.
    # openssl rand -hex 32
5.2. Managing SSH keys
For information on SSH keys and SSH key creation, see Using secure communications between two systems with OpenSSH in Red Hat Enterprise Linux 9 Configuring basic system settings.
5.2.1. Managing SSH keys for a user by using Foreman web UI
Use this procedure to add or remove SSH keys for a user from the Foreman web UI.
  3. Click on the SSH Keys tab.
    • To Add SSH key
      2. Click Add SSH Key.
      5. Click Submit.
    • To Remove SSH key
5.2.2. Managing SSH keys for a user by using Hammer CLI
Use this procedure to add or remove SSH keys for a user by using Hammer CLI.
  1. To add an SSH key to a user, you must specify either the path to the public SSH key file, or the content of the public SSH key copied to the clipboard:
      $ hammer user ssh-keys add \
      --user-id user_id \
      --name key_name \
      --key-file ~/.ssh/id_rsa.pub
      --user-id user_id \
      --name key_name \
  2. To delete an SSH key from a user, enter the following command:
  3. To view an SSH key attached to a user, enter the following command:
  4. To list SSH keys attached to a user, enter the following command:
5.3. Managing Personal Access Tokens
5.3.1. Creating a Personal Access Token
    $ curl \
    {"foreman_version":"3.19.0","result":"ok","status":200,"version":"3.5.1.10","api_version":2}
5.3.2. Revoking a Personal Access Token
    $ curl \
5.4. Creating and managing user groups
5.4.1. User groups
With Foreman, you can assign permissions to groups of users. You can also create user groups as collections of other user groups. If you use an external authentication source, you can map Foreman user groups to external user groups as described in Configuring external user groups in Configuring authentication for Foreman users.
5.4.2. Creating a user group by using Foreman web UI
  2. Click Create User group.
  5. Click Submit.
5.4.3. Creating a user group by using Hammer CLI
  • Create a user group:
    $ hammer user-group create \
    --name My_User_Group_Name \
5.4.4. Removing a user group
6. Creating and managing roles
Roles define a set of permissions and access levels. Each role contains one or more permission filters that specify the actions allowed for the role. Actions are grouped according to the Resource type. Once a role has been created, users and user groups can be associated with that role. This way, you can assign the same set of permissions to large groups of users.
6.1. Creating a role by using Foreman web UI
Use this procedure to create a role by using Foreman web UI.
  2. Click Create Role.
Next steps
  • Add permissions to the role. To serve its purpose, a role must contain permissions.
6.2. Creating a role by using Hammer CLI
Use this procedure to create a role by using Hammer CLI.
  • Create a role:
Next steps
6.3. Cloning a role
Example 1. Creating an organization-specific manager role
  5. Click org-1 admin, and click Filters to view all associated filters. The default filters work for most use cases. However, you can optionally click Edit to change the properties for each filter. You can also click New filter to associate new filters with this role.
6.4. Adding permissions to a role by using Foreman web UI
Use this procedure to add permissions to a role by using Foreman web UI.
  5. Click Next.
  6. Click Submit to save changes.
6.5. Adding permissions to a role by using Hammer CLI
Use this procedure to add permissions to a role by using Hammer CLI.
  2. Add permissions to a role:
    $ hammer filter create \
    --role My_Role_Name
6.6. Viewing permissions of a role
6.7. Creating a complete permission table
    # dnf install foreman-console
  1. Start the Foreman console:
    # foreman-rake console
    end.join("\n")
    f.write("<table border=\"1\"><tr><td>Permission name</td><td>Actions</td><td>Resource type</td></tr>\n")
    f.write(result)
    f.write("</table>\n")
6.8. Removing a role
6.9. Predefined roles available in Foreman
Predefined role Permissions the role provides Additional information
Auditor
View the Audit log.
Default role
View tasks and jobs invocations.
Foreman automatically assigns this role to every user in the system.
Manager
Organization admin
Site manager
View permissions for various items.
Permissions to manage hosts in the infrastructure.
System admin
Edit global settings in Administer > Settings.
View, create, edit, and destroy users, user groups, and roles.
View, create, edit, destroy, and assign organizations and locations but not view resources within them.
Users with this role can create users and assign all roles to them. Give this role only to trusted users.
Viewer
View the configuration of every element of the Foreman structure, logs, reports, and statistics.
6.10. Granular permission filtering
Foreman provides the ability to limit the configured user permissions to selected instances of a resource type. These granular filters are queries to the Foreman database and are supported by the majority of resource types.
6.10.1. Creating a granular permission filter by using Foreman web UI
Use this procedure to create a granular permission filter from the Foreman web UI.
  1. Specify a query in the Search field on the Edit Filter page. Queries have the following form:
    field_name operator value
    • operator specifies the type of comparison between field_name and value. See Supported operators for granular search for an overview of applicable operators.
6.10.2. Creating a granular permission filter by using Hammer CLI
Use this procedure to create a granular permission filter by using Hammer CLI.
    --permission-ids 91 \
    --search "name ~ ccv*" \
    --role qa-user
    This command adds to the qa-user role a permission to view, create, edit, and destroy content views that only applies to content views with name starting with ccv.
6.10.3. Examples of using granular permission filters
As an administrator, you can allow selected users to make changes in a certain part of the environment path. For example, you can allow users to work with content while it is in the development stage of the application lifecycle, but not once the content is pushed to production.
The following query applies any permissions specified for the Host resource type only to hosts in the group named host-editors:
hostgroup = host-editors
name ^ (XXXX, Yyyy, zzzz)
Dev
6.10.4. Supported operators for granular search
You can use logical and symbolic operators to build precise search queries when limiting user permissions.
Table 1. Logical operators
Operator
and
Combines search criteria.
not
Negates an expression.
has
Table 2. Symbolic operators
Operator
7. Configuring email notifications
Foreman server does not enable outgoing emails by default, therefore you must review your email configuration. For more information, see Configuring Foreman server for Outgoing Emails in Installing Foreman Server with Katello 4.21 plugin (containerized) on Enterprise Linux.
7.1. Email notification types
You can configure Foreman to send email notifications for system events such as host builds, errata updates, content synchronization failures, and audit summaries to stay informed about important activities in your environment.
Audit summary
A summary of all activity audited by Foreman server.
Compliance policy summary
Content view promote failure
Content view publish failure
Host built
Host errata advisory
Promote errata
Repository sync failure
Smart Proxy sync failure
A notification sent after Smart Proxy synchronization fails.
Sync errata
7.2. Configuring email notification preferences
You can configure Foreman to send email messages to individual users registered to Foreman. Foreman sends the email to the email address that has been added to the account, if present.
Users can edit the email address by clicking on their name in the top right of the Foreman web UI and selecting My account.
  6. Click Submit.
7.3. Testing email delivery
  2. Click on the username.
  • If the email is delivered, the verification is complete.
Troubleshooting
  • If the email is not delivered, perform the following diagnostic steps:
      # systemctl start postfix
7.4. Testing email notifications
  • Trigger email notifications:
  • daily
  • weekly
  • monthly
7.5. Changing email notification settings for a host
8. Backing up Foreman server and Smart Proxy server
8.1. Backup process overview
You use the foreman-maintain backup command to capture your Foreman server or Smart Proxy server and associated data. Backups require downtime, therefore you must plan scheduling, storage, and security so you avoid disruption and protect sensitive content.
The foreman-maintain backup command creates a backup of your Foreman server or Smart Proxy server and all associated data. Foreman community recommends backing up Foreman to a separate storage device on a separate system.
Foreman services are unavailable during the backup. Therefore, you must ensure that no other tasks are scheduled by other administrators. You can schedule a backup by using cron.
During offline backups, the services are inactive and Foreman is in a maintenance mode. All the traffic from outside on port 443 is rejected by a firewall to ensure there are no modifications triggered.
8.2. Estimating the size of a backup
    100G    /var/lib/pgsql/data
    100G	/var/lib/pulp
    # du -csh /var/lib/tftpboot /etc /root/ssl-build \
    16M   /var/lib/tftpboot
    37M   /etc
    900K  /root/ssl-build
    100K  /var/www/html/pub
    2M    /opt/puppetlabs
    942M  total
    Table 3. Backup data compression ratio
    PostgreSQL database files
    /var/lib/pgsql/data
    80 – 85%
    100 GB → 20 GB
    Pulp RPM files
    /var/lib/pulp
    (not compressed)
    100 GB
    Configuration files
    /var/lib/tftpboot
    /etc
    /root/ssl-build
    /var/www/html/pub
    /opt/puppetlabs
    85%
    942 MB → 141 MB
8.3. Offline backup and online backup
You can perform an offline backup or an online backup to back up your Foreman server.
There are two main methods of backing up Foreman server:
  • Offline backup
    All Foreman services are shut down during an offline backup.
  • Online backup
  • Offline backup:
  • Online backup:
8.4. Directories created during backups
  • foreman-backup on Foreman
8.5. Performing a full backup of Foreman server or Smart Proxy server
Warning
  • On Foreman server, perform a full backup:
  • On Smart Proxy server, perform a full backup:
8.6. Performing a backup without Pulp content
Warning
8.7. Performing an incremental backup
Warning
  1. Perform a full offline backup:
  2. Create a directory within your backup directory to store the first incremental backup:
  3. Create the second incremental backup by including the path to the first incremental backup to indicate the starting point for the next increment. This creates a directory for the second incremental backup in your backup directory:
8.8. Example of a weekly full backup followed by daily incremental backups
#!/bin/bash -e
else
fi
exit 0
8.9. Performing an online backup
You can perform an online backup to create a system backup while keeping most services running. This is useful when you need to maintain system availability during backup operations.
When you perform an online backup, most Foreman services remain running and usable. Background workers are shut down to ensure consistent backups. Operations that require background workers remain in pending state. The backup process ensures that the Pulp data (/var/lib/pulp) is not altered during the backup. Any changes to the Pulp data during the backup will result in restart of the backup process, taking additional time.
Warning
Request other users of Foreman server or Smart Proxy server to save any changes and warn them that some Foreman services may be unavailable for the duration of the backup. Ensure no other tasks are scheduled for the same time as the backup.
  • On your Foreman server, perform an online backup:
8.10. Creating a conventional backup
You can use conventional backup methods to back up your Foreman server or Smart Proxy server.
Stopping Foreman services is required when creating a snapshot or conventional backup. Do not stop Foreman services if you are using the foreman-maintain backup command to create a backup.
  1. When creating a snapshot or conventional backup, stop all Foreman services:
  2. Create the snapshot or conventional backup. For more information, see Recovering and restoring a system in Red Hat Enterprise Linux 9 Configuring basic system settings.
  3. Start Foreman services after creating a snapshot or conventional backup:
9. Restoring Foreman server or Smart Proxy server from a backup
If you have created a backup of Foreman server or Smart Proxy server, you can restore the server from the backup data. This process outlines how to restore the backup on the same server that generated the backup, and all data covered by the backup is deleted on the target system. If the original system is unavailable, provision a system with the same configuration settings and host name.
You cannot restore backups of a system without FIPS enabled on a FIPS enabled system.
9.1. Restoring from a full backup
    # df -h /var/backup_directory
    # restorecon -Rv /
  2. Copy the backup data to the local file system on Foreman server. Use /var/ or /var/tmp/.
Troubleshooting
  • Review the /var/log/foreman/production.log and /var/log/messages log files.
9.2. Restoring from incremental backups
  1. Restore the last full backup using the instructions in Restoring from a full backup.
  2. Remove the full backup data from the local file system on Foreman server, for example, /var/ or /var/tmp/.
  3. Copy the incremental backup data to the local file system on Foreman server, for example, /var/ or /var/tmp/.
Troubleshooting
9.3. Restoring Smart Proxy server by using a virtual machine snapshot
You can use virtual machine snapshots to back up and restore your Smart Proxy server for quick recovery after server failure or configuration issues. Configure or redeploy the host and complete installation. Then synchronize content from Foreman server to your Smart Proxy server.
  • Ensure that you either select the relevant organization and location context of your Smart Proxy server or choose Any Organization and Any Location.
  1. If your Smart Proxy server is a virtual machine, include it in your backup strategy by using VM snapshots. Creating weekly snapshots that you can restore from is recommended.
  2. After a failure, either restore your Smart Proxy server from a snapshot by using your hypervisor tools, or deploy a new Smart Proxy server and ensure that the host name is the same as before, and then install the Smart Proxy certificates. You may still have them on Foreman server, the package name ends in -certs.tar, alternately create new ones.
  3. Follow the procedures in Installing Smart Proxy server until you can confirm, in the Foreman web UI, that Smart Proxy server is connected to Foreman server.
  4. In the Foreman web UI, navigate to Infrastructure > Smart Proxies.
  5. Select your Smart Proxy server.
  6. On the Overview tab, click Synchronize.
    • Select Optimized Sync to synchronize content from your Foreman server to your Smart Proxy server that bypasses unnecessary steps to speed up performance.
    • Select Complete Sync to perform a complete sync from your Foreman server to your Smart Proxy server that synchronizes content even if the metadata has not changed.
10. Renaming Foreman server or Smart Proxy server
To rename Foreman server or Smart Proxy server, use the katello-change-hostname script.
If you change the domain name of your Foreman server or Smart Proxy server, you must update the hostname by using the katello-change-hostname script to avoid networking issues.
10.1. Renaming Foreman server
The host name of Foreman server is used by Foreman server components, all Smart Proxy servers, and hosts registered to it for communication. This procedure ensures that in addition to renaming Foreman server, you also update all references to point to the new host name.
Warning
Renaming your Foreman server host shuts down all Foreman services on that host. The services restart after the renaming is complete.
  • Back up your Foreman server before changing its host name. If you fail to successfully rename it, restore it from the backup. For more information, see Backing up Foreman server and Smart Proxy server.
  • Run the hostname and hostname -f commands on Foreman server. If both commands do not return the FQDN of Foreman server, the katello-change-hostname script will fail to complete.
    If the hostname command returns the shortname of Foreman server instead of the FQDN, use hostnamectl set-hostname My_Old_FQDN to set the old FQDN correctly before using the katello-change-hostname script.
  • If Foreman server has a custom SSL certificate installed, obtain a new certificate for the new FQDN of the host. For more information, see Configuring Foreman server with a Custom SSL Certificate in Installing Foreman Server with Katello 4.21 plugin (containerized) on Enterprise Linux.
  1. On Foreman server, run the katello-change-hostname script, and provide the new host name. Choose one of the following methods:
    • If your Foreman server is installed with the default self-signed SSL certificates:
      --username My_Username \
      --password 'My_Password'
      --password 'My_Password' \
  2. If you have created a custom SSL certificate for the new Foreman server host name, run the Foreman installation script to install the certificate. For more information about installing a custom SSL certificate, see Deploying a Custom SSL Certificate to Foreman server in Installing Foreman Server with Katello 4.21 plugin (containerized) on Enterprise Linux.
  3. Reregister all hosts and Smart Proxy servers that are registered to Foreman server. For more information, see Registering hosts by using global registration in Managing hosts.
    # foreman-installer \
    --foreman-proxy-trusted-hosts new-foreman.example.com
    # hammer proxy list
    # hammer proxy content synchronize \
    --id My_Smart_Proxy_ID
  7. If you use the virt-who agent, update the virt-who configuration files with the new host name.
  8. If you use external authentication, reconfigure Foreman server for external authentication after you run the katello-change-hostname script. For more information, see Configuring authentication for Foreman users.
10.2. Renaming Smart Proxy server
The host name of Smart Proxy server is referenced by Foreman server components and all hosts registered to it. This procedure ensures that in addition to renaming Smart Proxy server, you also update all references to the new host name.
Warning
Renaming your Smart Proxy server host shuts down all Foreman services on that host. The services restart after the renaming is complete.
  • Back up your Smart Proxy server before renaming. If you fail to successfully rename it, restore it from the backup. For more information, see Backing up Foreman server and Smart Proxy server.
  • Run the hostname and hostname -f commands on Smart Proxy server. If both commands do not return the FQDN of Smart Proxy server, the katello-change-hostname script will fail to complete.
    If the hostname command returns the shortname of Smart Proxy server instead of the FQDN, use hostnamectl set-hostname My_Old_FQDN to set the old FQDN correctly before attempting to use the katello-change-hostname script.
  1. On your Foreman server, generate a new certificates archive file for your Smart Proxy server.
    • If you are using the default SSL certificate, regenerate the default SSL certificates:
      --certs-tar /root/new-smartproxy.example.com-certs.tar \
      --foreman-proxy-fqdn new-smartproxy.example.com
    • If you are using a custom SSL certificate, create a new SSL certificate for your Smart Proxy server. For more information, see Configuring Smart Proxy server with a custom SSL certificate in Installing a Smart Proxy Server 3.19 on Enterprise Linux.
  2. On your Foreman server, copy the certificates archive file to your Smart Proxy server. For example, to copy the archive file to the root user’s home directory:
  3. On your Smart Proxy server, run the katello-change-hostname script and provide the host’s new name, Foreman credentials, and certificates archive file name.
    # katello-change-hostname new-smartproxy.example.com \
  4. If you have created a custom certificate for your Smart Proxy server, deploy the certificate to your Smart Proxy server by entering the foreman-installer command that the foreman-proxy-certs-generate command returned in a previous step. For more information, see Deploying a Custom SSL Certificate to Smart Proxy server in Installing a Smart Proxy Server 3.19 on Enterprise Linux.
  5. Reregister all hosts that are registered to your Smart Proxy server. For more information, see Registering hosts to Foreman in Managing hosts.
  6. Update the Smart Proxy host name in the Foreman web UI.
    2. Locate Smart Proxy server in the list, and click Edit.
    3. Edit the Name and URL fields to match Smart Proxy server’s new host name, then click Submit.
    4. On your DNS server, add a record for the new hostname of your Smart Proxy server, and delete the record of the previous host name.
11. Maintaining Foreman server
This chapter provides information on how to maintain Foreman server, including information on how to recover Pulp from a full disk, how to work with audit records, and how to clean unused tasks.
11.1. Deleting audit records manually
11.2. Deleting audit records automatically
11.3. Anonymizing audit records
  • Use the foreman-rake audits:anonymize command to remove any user account or IP information while maintaining the audit records in the database. You can also use a cron job to schedule anonymizing the audit records at the set interval that you want.
    For example, you can anonymize audit records that are older than seven days:
11.4. Deleting report records
You can delete report records to remove old reports from your Foreman. This is useful for maintaining a clean and organized report history.
Report records are created automatically in Foreman.
  • Use the foreman-rake reports:expire command to remove reports at any time. You can also use a cron job to schedule report record deletions at the set interval that you want.
    For example, you can delete report records that are older than seven days:
11.5. Configuring the cleaning unused tasks feature
11.6. Deleting task records
You can delete task records to remove old or unnecessary tasks from your Foreman. This helps maintain system performance and keeps your task history organized.
Task records are created automatically in Foreman.
  • Use the foreman-rake foreman_tasks:cleanup command to remove tasks at any time. You can also use a cron job to schedule Task record deletions at the set interval that you want.
    For example, you can delete task records from successful repository synchronizations:
11.7. Deleting a task by ID
  2. Optional: View the task:
  3. Delete the task:
11.8. Recovering from a full disk
    1. Remove orphaned content:
    3. Grow the file system on the LV with the /var/lib/pulp directory on it. For more information, see Growing a logical volume and file system in Red Hat Enterprise Linux 9 Configuring and managing logical volumes.
      1. Stop Foreman services:
      3. Start Foreman services:
11.9. Reclaiming PostgreSQL space
11.10. Reclaiming space from on demand repositories
Space reclamation requires an existing repository. For deleted repositories, wait for the next scheduled orphan cleanup or remove orphaned content manually:
  1. If you want to reclaim space for a single repository:
    2. Select a product.
    3. On the Repositories tab, click the repository name.
    4. From the Select Actions list, select Reclaim Space.
  2. If you want to reclaim space for multiple repositories:
    2. Select the product name.
    3. On the Repositories tab, select the checkbox of the repositories.
    4. Click Reclaim Space at the top right corner.
  3. If you want to reclaim space for Smart Proxies:
    2. Select the Smart Proxy server.
    3. Click Reclaim space.
12. Renewing certificates
You can renew the CA certificate on Foreman server or the SSL certificate on Foreman server as well as on Smart Proxy server.
12.1. Planning for self-signed CA certificate renewal
If you need to update the Certification Authority (CA) certificate on your Foreman server, add the new CA certificate and use a temporary dual CA certificate file to retain the HTTPS connections to your Foreman server during the renewal.
  1. Add the new SSL certificate to the CA certificate file on Foreman server and keep the old SSL certificate.
  2. Renew the certificates on Foreman server and any Smart Proxy servers.
  3. Deploy the dual CA certificate on hosts.
  4. Remove the old certificate from the CA certificates file on Foreman server, so the CA certificate file contains only the new SSL certificate.
  5. Renew the certificates on Foreman server and any Smart Proxy servers.
  6. Deploy the new CA certificate on hosts.
12.2. Renewing a SSL certificate on Foreman server
Use this procedure to update your SSL certificate for Foreman server.
  • You must create a new Certificate Signing Request (CSR) and send it to the Certificate Authority to sign the certificate. Refer to the Configuring Foreman server with a custom SSL certificate guide before creating a new CSR because the Server certificate must have X.509 v3 Key Usage and Extended Key Usage extensions with required values. In return, you will receive the Foreman server certificate and CA bundle.
  • Deploy the renewed CA certificates to Foreman server:
    # foreman-installer --scenario katello \
    --certs-server-cert "/root/foreman_cert/foreman_cert.pem" \
    --certs-server-key "/root/foreman_cert/foreman_cert_key.pem" \
    --certs-server-ca-cert "/root/foreman_cert/ca_cert_bundle.pem" \
    --certs-update-server \
    --certs-update-server-ca
    Do not delete the certificate files after you deploy the certificate. They are required when upgrading Foreman server.
  1. Access the Foreman web UI from your local machine. For example, https://foreman.example.com.
  2. In your browser, view the certificate details to verify the deployed certificate.
Next steps
12.3. Renewing a SSL certificate on Smart Proxy server
Use this procedure to update your SSL certificate for Smart Proxy server. The foreman-installer command, which the foreman-proxy-certs-generate command returns, is unique to each Smart Proxy server. You cannot use the same command on more than one Smart Proxy server.
  • You must create a new Certificate Signing Request and send it to the Certificate Authority to sign the certificate. Refer to the Configuring Foreman server with a custom SSL certificate guide before creating a new CSR because the Foreman server certificate must have X.509 v3 Key Usage and Extended Key Usage extensions with required values. In return, you will receive the Smart Proxy server certificate and CA bundle.
  1. On your Foreman server, generate the certificate archive file for your Smart Proxy server:
    --certs-tar "/root/My_Certificates/smartproxy.example.com-certs.tar" \
    --foreman-proxy-fqdn "smartproxy.example.com" \
    --server-ca-cert "/root/My_Certificates/ca_cert_bundle.pem" \
    --server-cert "/root/My_Certificates/smart-proxy_cert.pem" \
    --server-key "/root/My_Certificates/smart-proxy_cert_key.pem"
  2. On your Foreman server, copy the certificate archive file to your Smart Proxy server:
  3. Retain a copy of the foreman-installer command that the foreman-proxy-certs-generate command returns for deploying the certificate to your Smart Proxy server.
  4. Deploy the certificate on your Smart Proxy server using the foreman-installer command returned by the foreman-proxy-certs-generate command:
    # foreman-installer --scenario foreman-proxy-content \
    --certs-tar-file "/root/My_Certificates/smartproxy.example.com-certs.tar" \
    --foreman-proxy-foreman-base-url "https://foreman.example.com"
    Do not delete the certificate archive file on the Smart Proxy server after you deploy the certificate. They are required when upgrading Smart Proxy server.
Next steps
13. Synchronizing template repositories
In Foreman, you can synchronize repositories of job templates, provisioning templates, report templates, and partition table templates between Foreman server and a version control system or local directory. This section details the workflow for installing and configuring the Template Sync plugin and performing exporting and importing tasks.
13.1. Enabling the Template Sync plugin
You can enable the Template Sync plugin to synchronize provisioning templates, report templates, and other templates between your Foreman server and a version control system or local directory. This is useful when you want to manage templates in Git repositories or keep templates synchronized across multiple Foreman instances.
  1. Enable the plugin on your Foreman server:
  2. Optional: Enable the Hammer CLI plugin on your Foreman server:
  2. On the Plugins tab, ensure that the page includes the Template Sync plugin.
Next steps
  1. In the Foreman web UI, navigate to Administer > Settings > Template Sync to configure the plugin. For more information, see Template sync settings.
13.2. Synchronizing templates with an existing repository
If you store templates in a repository under a version control system, you can synchronize the templates between your Foreman server and the repository.
  1. If you want to use HTTPS to connect to the repository and you use a self-signed certificate authority (CA) on your Git server:
    1. Create a new directory under the /usr/share/foreman/ directory to store the Git configuration for the certificate:
      # mkdir --parents /usr/share/foreman/.config/git
    2. Create a file named config in the new directory:
      # touch /usr/share/foreman/.config/git/config
    3. Allow the foreman user access to the .config directory:
      # chown --recursive foreman /usr/share/foreman/.config
    4. Update the Git global configuration for the foreman user with the path to your self-signed CA certificate:
      # sudo --user foreman git config --global http.sslCAPath Path_To_CA_Certificate
  2. If you want to use SSH to connect to the repository:
    1. Create an SSH key pair if you do not already have it. Do not specify a passphrase.
    2. Configure your version control server with the public key from your Foreman, which resides in /usr/share/foreman/.ssh/id_rsa.pub.
    3. Accept the Git SSH host key as the foreman user:
      # sudo --user foreman ssh git.example.com
  3. In the Foreman web UI, provide details for your Git repository:
    1. Navigate to Administer > Settings.
    2. Click the Template Sync tab.
    3. Change the Branch setting to define the target branch of the repository.
    4. Change the Repo setting to define the repository URL.
    5. If you want to use an HTTP proxy to connect to the repository, change the HTTP proxy policy setting to Global default HTTP proxy or Custom HTTP proxy.
Next steps
  • Import templates from your repository or export templates to your repository.
13.3. Synchronizing templates with a local directory
If you store templates in a local directory that is tracked under a version control system, you can synchronize the templates between your Foreman server and the local directory.
  • Each template must contain the location and organization that the template belongs to. This applies to all template types. Before you import a template, ensure that you add the following section to the template:
    kind: provision
    oses:
    - My_first_Operating_System
    - My_second_Operating_System
    locations:
    - My_first_Location
    - My_second_Location
    organizations:
    - My_first_Organization
    - My_second_Organization
  1. On your Foreman server, in /var/lib/foreman, create a directory for storing templates:
    # mkdir /var/lib/foreman/My_Templates_Dir
    You can place your templates to a custom directory outside /var/lib/foreman, but you have to ensure that the Foreman service can read its contents. The directory must have the correct file permissions and the foreman_lib_t SELinux label.
  2. Change the owner of the new templates directory to the foreman user:
    # chown foreman /var/lib/foreman/My_Templates_Dir
  3. Change the Repo setting on the Template Sync tab to match the /var/lib/foreman/My_Templates_Dir/ directory.
13.4. Importing templates by using Foreman web UI
You can import templates from a repository of your choice from the Foreman web UI. You can use different protocols to point to your repository, for example /tmp/dir, git://example.com, https://example.com, and ssh://example.com.
The templates provided by Foreman are locked and you cannot import them by default. To overwrite this behavior, change the Force import setting in the Template Sync menu to yes or add the force parameter -d '{ "force": "true" }' to the import command.
  • Before you import a template, ensure that you add the following section to the template:
    kind: provision
    oses:
    locations:
    - My_first_Location
    organizations:
  1. In the Foreman web UI, navigate to Hosts > Templates > Sync Templates.
  2. Click Import.
  3. Each field is populated with values configured in Administer > Settings > Template Sync. Change the values as required for the templates you want to import. For more information about each field, see Template sync settings.
  4. Click Submit.
13.5. Importing templates by using Hammer CLI
You can import templates from a repository of your choice by using Hammer CLI. You can use different protocols to point to your repository, for example /tmp/dir, git://example.com, https://example.com, and ssh://example.com.
    kind: provision
    oses:
    locations:
    - My_first_Location
    organizations:
  • Import a template from a repository:
    $ hammer import-templates \
    --branch "My_Branch" \
    --filter '.*Template Name$' \
    --prefix "[Custom Index] " \
    --repo "https://git.example.com/path/to/repository"
    For better indexing and management of your templates, use --prefix to set a category for your templates. To select certain templates from a large repository, use --filter to define the title of the templates that you want to import. For example --filter '.*Ansible Default$' imports various Ansible Default templates.
13.6. Importing templates by using Foreman API
You can import templates from a repository of your choice by using Foreman API. You can use different protocols to point to your repository, for example /tmp/dir, git://example.com, https://example.com, and ssh://example.com.
    kind: provision
    oses:
    locations:
    - My_first_Location
    organizations:
  • Send a POST request to api/v2/templates/import:
    $ curl \
    --header "Accept: application/json" \
    --request POST \
    https://foreman.example.com/api/v2/templates/import
    If the import is successful, you receive {"message":"Success"}.
13.7. Importing templates using Ansible
You can import templates from a repository of your choice. You can use different protocols to point to your repository, for example /tmp/dir, git://example.com, https://example.com, and ssh://example.com.
  • Use the theforeman.foreman.templates_import module.
13.8. Exporting templates by using Foreman web UI
You can export templates to an existing repository from the Foreman web UI.
  2. Click Export.
  3. Each field is populated with values configured in Administer > Settings > Template Sync. Change the values as required for the templates you want to export. For more information about each field, see Template sync settings.
  4. Click Submit.
13.9. Exporting templates by using Hammer CLI
You can export templates to an existing repository.
  • Export all templates to a repository:
    $ hammer export-templates \
    This command clones the repository, makes changes in a commit, and pushes back to the repository. You can use the --branch "My_Branch" option to export the templates to a specific branch.
13.10. Exporting templates by using Foreman API
You can export templates to an existing repository by using Foreman API.
  1. Send a POST request to api/v2/templates/export:
    $ curl \
    --request POST \
    https://foreman.example.com/api/v2/templates/export
    If the export is successful, you receive {"message":"Success"}.
    You can override default API settings by specifying them in the request with the -d parameter. The following example exports templates to the git.example.com/templates repository:
    $ curl \
    --data "{\"repo\":\"git.example.com/templates\"}" \
    --request POST \
13.11. Uninstalling the Foreman templates plugin
  1. Disable the plugin using the Foreman installer:
  2. Clean custom data of the plugin. The command does not affect any templates that you created.
  3. Uninstall the plugin:
14. Monitoring Foreman resources
You can use Foreman web UI to monitor your Foreman environment and hosts. This includes details of hosts, such as configuration or compliance, and information about content and Smart Proxies.
14.1. Using the Foreman content dashboard
The Foreman content dashboard contains various widgets which provide an overview of the host configuration, content views, compliance reports, and hosts currently registered, promotions and synchronization, and a list of the latest notifications.
Host Configuration Status
Table 4. Host configuration states
Icon State Description
host state config okay
host state config error
Hosts in error state
host state config report
host state config pending
host state config outofsync
Out of sync hosts
host state config noreport
Hosts with no reports
host state config noalert
Hosts with alerts disabled
Host Configuration Chart
Latest Events
New Hosts
Task Status
Latest Warning/Error Tasks
Discovered Hosts
Latest Errata
Content Views
Sync Overview
Host Collections
A list of all host collections in Foreman and their status, including the number of hosts in each host collection.
Virt-who Configuration Status
Table 5. virt-who configuration states
State Description
No Reports
No Change
OK
Total Configurations
Latest Compliance Reports
Compliance Reports Breakdown
Insights Actions
Insights Risk Summary
14.2. Managing tasks
You can monitor and manage all planned or performed tasks, such as repositories synchronized, errata applied, and content views published, to track progress, troubleshoot issues, or adjust timeout settings for low bandwidth or high latency environments.
Reviewing the log
Adjusting timeout settings
Disabling checking for services
  5. Click Save.
14.3. Configuring RSS notifications
You can configure custom RSS feed notifications to receive event alerts from your preferred sources, such as project blogs or internal news feeds, instead of the default notification sources.
14.4. Monitoring Foreman server
  2. Obtain a list of all audit attributes:
14.5. Monitoring Smart Proxy server
14.5.1. Viewing general Smart Proxy information
You can view general information about your Smart Proxies in the Foreman web UI, such as their status, enabled features, and managed hosts, to verify configuration or troubleshoot connectivity issues.
In the Features column, you can verify if, for example, your Smart Proxy provides a DHCP service or acts as a Pulp mirror. Smart Proxy features can be enabled during installation or configured in addition. For more information, see Installing Smart Proxy server.
14.5.2. Monitoring services
You can view the status and configuration details of Smart Proxy services in Foreman web UI. This helps you verify that your Smart Proxy services are running correctly and troubleshoot any issues.
  • In the Foreman web UI, navigate to Infrastructure > Smart Proxies and click the name of the selected Smart Proxy.
    • At the Services tab, you can find basic information on Smart Proxy services, such as the list of DNS domains, or the number of Pulp workers.
      The appearance of the page depends on what services are enabled on Smart Proxy server. Services providing more detailed status information can have dedicated tabs at the Smart Proxy page. For more information, see Monitoring Puppet.
14.5.3. Monitoring Puppet
You can monitor Puppet activity and certificate management for each Smart Proxy.
  2. Click the name of your Smart Proxy.
    • At the Puppet tab you can find the following:
    • At the Puppet CA tab you can find the following:
15. Limiting host resources
You can use the Resource Quota plugin to limit users' access to host resources during host provisioning. Each host is assigned to exactly one resource quota. By default, Foreman assigns the Unassigned resource quota to hosts during global registration. This means that the host is not assigned to a specific pool of resources.
Supported resource types
  • CPU cores
  • Memory
  • Disk space
Supported compute resources
  • VMware
  • libvirt
15.1. Installing the Resource Quota plugin
  1. Install the plugin on your Foreman server:
  2. Optional: Install the Hammer CLI plugin on your Foreman server:
15.2. Managing resource quotas
15.2.1. Creating a resource quota by using Foreman web UI
Create a resource quota to limit the resource consumption of Foreman users by using the Foreman web UI.
  1. In the Foreman web UI, navigate to Configure > Resource Quotas.
  2. Click Create resource quota.
  3. Specify the name, CPU cores, memory, and disk space.
  4. Click Create resource quota to submit the resource quota to Foreman.
15.2.2. Creating a resource quota by using Hammer CLI
Create a resource quota to limit the resource consumption of Foreman users by using Hammer CLI.
  • Create a resource quota:
    $ hammer resource-quota create \
    --cpu-cores My_CPU_Cores \
    --description My_Resource_Quota_Description \
    --disk-space My_Disk_Space_in_GiB \
    --memory My_Memory_in_MiB \
    --name "My_Resource_Quota_Name"
    For all options, see hammer resource-quota create --help.
15.2.3. Editing a resource quota by using Foreman web UI
You can edit a resource quota to adjust available resources to Foreman users by using Foreman web UI.
  2. Select your resource quota.
  3. Adjust the CPU cores, Memory, or Disk space and click Apply to submit your changes to Foreman.
15.2.4. Editing a resource quota by using Hammer CLI
You can edit a resource quota to adjust available resources to Foreman users by using Hammer CLI.
  1. Optional: List all resource quotas:
  2. Edit a resource quota:
    $ hammer resource-quota update \
    --id My_Resource_Quota_ID \
    If you set the value to 0, users cannot consume any resource at all. To reset resource quotas, you can use --remove-cpu-cores-limit, --remove-disk-space-limit, and --remove-memory-limit.
    For all options, see hammer resource-quota update --help.
15.2.5. Deleting a resource quota by using Foreman web UI
You can delete a resource quota from Foreman by using Foreman web UI.
  2. In the Actions column, click Delete for your resource quota.
15.2.6. Deleting a resource quota by using Hammer CLI
You can delete a resource quota from Foreman by using Hammer CLI.
  2. Delete a resource quota:
    For all options, see hammer resource-quota delete --help.
15.3. Assigning resource quotas to users
You can assign resource quotas to users or user groups. A user can select one of their assigned resource quotas during host provisioning. If Resource Quota optional assignment is set to No, a user does not have to assign a resource quota. You can use the resource_quota filter in the Foreman web UI to view users or user groups with assigned resource quotas.
15.3.1. Assigning resource quotas to a user by using Foreman web UI
You can assign resource quotas to a user to limit the resource consumption of that Foreman user by using Foreman web UI.
  2. Select a user.
  3. On the Resource Quota tab, assign resource quotas to the user.
  4. If you want to make the usage of resource quotas optional, select the Optional Assignment checkbox.
  5. Click Submit to assign resource quotas to a user.
15.3.2. Assigning resource quotas to a user by using Hammer CLI
You can assign resource quotas to a user to limit the resource consumption of that Foreman user by using Hammer CLI
  1. Optional: List all Foreman users:
  2. Optional: List all resource quotas:
  3. Assign resource quotas to a user:
    $ hammer user update \
    --id My_User_ID \
    --resource-quota-ids My_Resource_Quota_IDs
    If you want to make resource quota optional, add the --resource-quota-is-optional true option.
    For all options, see hammer user update --help.
15.3.3. Assigning resource quotas to a user group by using Foreman web UI
You can assign resource quotas to a user group to limit the resource consumption of that Foreman user group. All users of the user group share the pool of resources.
  2. On the Resource Quota tab, assign resource quotas to the user group.
  3. Click Submit to assign resource quotas to a user group.
15.3.4. Assigning resource quotas to a user group by using Hammer CLI
You can assign resource quotas to a user group to limit the resource consumption of that Foreman user group by using Hammer CLI. All users of the user group share the pool of resources.
  1. Optional: List all Foreman user groups:
  3. Assign resource quotas to a user group:
    $ hammer user-group update \
    --id My_User_Group_ID \
    For all options, see hammer user-group update --help.
15.4. Viewing resource quotas by using Foreman web UI
You can use Foreman web UI to view the resource quota of hosts.
  2. In the search bar, filter your hosts. For example, resource_quota = Unassigned.
    For more information, see Searching and bookmarking.
15.5. Viewing resource quotas by using Hammer CLI
  1. Optional: Retrieve the ID of your host:
    $ hammer host list
  2. Display the resource quota assigned to your host:
    $ hammer host info \
    --fields "Id,Name,Resource quota id" \
    --id My_Host_ID
15.6. Resource Quota settings
16. Using webhooks
16.1. Webhook behavior and integration
16.2. Installing the webhooks plugin
  1. On your Foreman server, install the webhooks plugin:
  2. Optional: Install the webhooks CLI plugin:
16.3. Creating a webhook template
    For more information, see Template Writing Reference in Managing hosts and for available template macros and methods, visit /templates_doc on Foreman server.
  7. Click Submit.
Example 2. Creating a webhook template
Running remote execution jobs
Creating users
16.4. Creating a webhook
When configuring webhooks with endpoints with non-standard HTTP or HTTPS ports, an SELinux port must be assigned, see Configuring SELinux to ensure access to Foreman on custom ports in Installing Foreman Server with Katello 4.21 plugin (containerized) on Enterprise Linux.
  2. Click Create new.
  7. Enter an HTTP method.
  9. Click the Credentials tab.
A content view was successfully promoted.
Run OpenSCAP scan.
Runs an Ansible Playbook containing all the roles defined for a host.
Run an Ansible Playbook against given hosts.
Run an Ansible Playbook to enable the web console on given hosts.
Perform a single Puppet run.
Build Entered
Build Exited
Config Report Created/Updated/Destroyed
Common database operations on a configuration report.
ConfigReport
Common database operations on a content view.
Domain
Host
Hostgroup
Model
Status Changed
Subnet
Template Render Performed
Template
User
16.6. Shellhooks
With webhooks, you can only map one Foreman event to one API call. For advanced integrations, where a single shell script can contain multiple commands, you can install a Smart Proxy shellhooks plugin that exposes executables by using a REST HTTP API.
You can then configure a webhook to reach out to a Smart Proxy API to run a predefined shellhook. A shellhook is an executable script that can be written in any language provided that it can be executed. The shellhook can for example contain commands or edit files.
You can pass input to shellhook script through the webhook payload. This input is redirected to standard input of the shellhook script. You can pass arguments to shellhook script by using HTTP headers in format X-Shellhook-Arg-1 to X-Shellhook-Arg-99.
The HTTP method must be POST. An example URL would be: https://smartproxy.example.com:9090/shellhook/My_Script.
16.7. Installing the shellhooks plugin
Optionally, you can install and enable the shellhooks plugin on each Smart Proxy used for shellhooks.
  • Install the shellhooks plugin on your Smart Proxy:
16.8. Passing arguments to shellhook script using webhooks
      "X-Shellhook-Arg-1": "VALUE",
      "X-Shellhook-Arg-2": "VALUE"
Example 3. Passing arguments to shellhook script using webhooks
16.9. Passing arguments to shellhook script using curl
    "X-Shellhook-Arg-1: VALUE"
    "X-Shellhook-Arg-2: VALUE"
Example 4. Passing arguments to shellhook script using curl
$ curl \
--data "" \
--header "Content-Type: text/plain" \
--header "X-Shellhook-Arg-1: Version 1.0" \
--header "X-Shellhook-Arg-2: My content view" \
--request POST \
--show-error \
--silent \
16.10. Creating a shellhook to print arguments
    #!/bin/sh
    echo "$@" >&2
  2. In the Foreman web UI, navigate to Administer > Webhook > Webhooks.
  3. Click Create new.
  6. In the Target URL field, enter the URL of your Smart Proxy server followed by :9090/shellhook/print_args:
    https://smartproxy.example.com:9090/shellhook/print_args
        "X-Shellhook-Arg-1": "Hello",
        "X-Shellhook-Arg-2": "World!"
  1. Run a remote execution job on any host. You can use time as a command. For more information, see Configuring and setting up remote jobs in Managing hosts.
    [W] [3520] Hello World!
17. Searching and bookmarking
Foreman features powerful search functionality on most pages of the Foreman web UI. It enables you to search all kinds of resources that Foreman manages. Searches accept both free text and syntax-based queries, which can be built by using input prediction. Search queries can be saved as bookmarks for future reuse.
17.1. Query syntax
You can use query syntax to search and filter resources in Foreman by specifying parameters, operators, and values to find specific hosts, host groups, or other resources based on your criteria.
parameter operator value
17.2. Query operators
You can use comparison operators such as EQUALS, LIKE, and GREATER THAN, along with logical operators AND, OR, and NOT, to build queries that filter and search for resources based on specific criteria.
Table 6. Comparison operators accepted by search
EQUALS
hostgroup = RHEL7
NOT EQUALS
LIKE
hostgroup ~ rhel%
NOT LIKE
GREATER THAN
registered_at <= Yesterday
LESS THAN
IN
release_version !^ 7
NOT IN
HAS or set?
NOT HAS or null?
Table 7. Logical operators accepted by search
and
<whitespace>
or
not
17.3. Query values
You can use text values and temporal values in your queries, with text values requiring quotes when they contain spaces, and temporal values accepting various date and time formats to filter resources by specific criteria.
Text Values
Examples:
hostgroup = "Web servers"
hostgroup = Web servers
Temporal Values
  • "10 January 2017"
  • "10 Jan 2017"
  • 10-January-2017
  • 10/January/2017
  • "January 10, 2017"
Warning
17.4. Using free text search
You can use free text search to find resources by searching across multiple fields simultaneously.
17.5. Creating bookmarks
  7. Click Submit.
  • To confirm the creation, either select the arrow to the right of the Search button to display the list of bookmarks, or navigate to Administer > Bookmarks and then check the Bookmarks list for the name of the bookmark.
17.6. Deleting bookmarks
  • To confirm the deletion, check the Bookmarks list for the name of the bookmark.
17.7. Keyboard shortcuts
You can use keyboard shortcuts to quickly focus search bars.
  • To focus the vertical navigation search bar, press Ctrl + Shift + F.
  • To focus the page search bar, press /.
Appendix A: Logging and reporting problems
The following sections describe the most commonly used log files and debugging tools available in Foreman.
A.1. Configuring logging levels with Hammer CLI
You can use Hammer to log debugging information for various Foreman components. The default logging level is INFO.
The hammer admin plugin is a deprecated feature. Deprecated functionality is still included in Foreman and continues to be supported. However, it will be removed in a future release of this product and is not recommended for new deployments.
Use `foreman-installer` instead.
For the most recent list of major functionality that has been deprecated or removed within Foreman, refer to the Deprecated features section of the Foreman release notes.
  • To list the components whose logging level you can change by using hammer:
    $ hammer admin logging --list
  • To set DEBUG level logging for all components:
    $ hammer admin logging --all --level-debug
  • To set PRODUCTION level logging for all components:
    $ hammer admin logging --all --level-production
  • To set DEBUG level logging for a specific component:
    $ hammer admin logging --components My_Component --level-debug
  • To list all available logging options:
    $ hammer admin logging --help
A.2. Configuring logging type and layout
By default, Foreman uses file-based logging. You can use foreman-installer to change the logging type and logging layout.
Configuring logging with journal
Enter the following foreman-installer command to configure logging to the journald service:
# foreman-installer \
--foreman-proxy-log JOURNAL
To inspect the log messages, use the journalctl utility. For example:
Configuring file-based logging
Enter the following foreman-installer command to configure file-based logging:
--reset-foreman-proxy-log
To inspect the log messages, view these files:
  • /var/log/foreman-proxy.log
Procedure for configuring logging to JSON output
On your Foreman server, enable logging to JSON output for foreman-installer:
--foreman-logging-layout json \
--foreman-logging-type file
To inspect the log messages, use jq:
# cat /var/log/foreman/production.log | jq
A.3. Selective debugging with individual loggers
    --foreman-loggers ldap:true \
    --foreman-loggers sql:true
A.4. Overview of individual loggers
The following list provides an overview of selected loggers. You can find the complete list of loggers with their default values in /usr/share/foreman/config/application.rb under Foreman::Logging.add_loggers.
app
Default value: true.
audit
background
blob
dynflow
ldap
Default value: false.
notifications
permissions
sql
telemetry
templates
A.5. Retrieving the status of services by using Hammer CLI
    $ hammer ping
  • Perform a health check:
A.6. Restarting services
  • Restart Foreman services:
A.7. Utilities for processing log information
sosreport
The sos report command collects configuration and diagnostic information from a Linux system, such as the running kernel version, loaded modules, running services, and system and service configuration files. Additionally, it collects information about Foreman, such as its back-end services and tasks. This output is stored in a tar file located at /var/tmp/sosreport-XXX-20171002230919.tar.xz.
For more information, run sos report --help or see SOS user documentation.
The sos report command removes security information such as passwords, tokens, and keys while collecting information. However, the tar files can still contain sensitive information about the Foreman server. Send the tar files directly to the intended recipient and not to a public target.
foreman-tail
A.8. Log file directories
The following table provides an overview of selected log directories on Foreman server.
/var/log/candlepin/
Subscription management
/var/log/foreman-installer/
Installer
/var/log/foreman-maintain/
Foreman maintain
Foreman proxy
/var/log/foreman/
Foreman
/var/log/httpd/
Apache HTTP server
/var/log/messages/
Various other log messages
/var/log/puppetlabs/puppet/
Puppet
/var/log/tomcat/
Candlepin web service logs
A.9. System journal metadata
AUDIT_ACTION
Audit action performed
AUDIT_TYPE
Audit resource type
AUDIT_ID
AUDIT_ATTRIBUTE
AUDIT_FIELD_OLD
AUDIT_FIELD_NEW
AUDIT_ID
AUDIT_ATTRIBUTE
Example: Name or description
EXCEPTION_MESSAGE
EXCEPTION_CLASS
EXCEPTION_BACKTRACE
LOC_ID
Location database ID
LOC_NAME
Location name
LOC_LABEL
Location label
LOGGER
Logger name
ORG_ID
Organization database ID
ORG_NAME
Organization name
ORG_LABEL
Organization label
REMOTE_IP
Remote IP address of a client
REQUEST
SESSION
TEMPLATE_NAME
Template name
TEMPLATE_DIGEST
TEMPLATE_HOST_NAME
TEMPLATE_HOST_ID
USER_LOGIN
User login name
Appendix B: Increasing logging levels of Foreman components
You can set logging levels for individual Foreman components. The default logging level is info. You can increase the logging level of Foreman components to troubleshoot Foreman. Increasing the logging level to debug provides the most detailed information.
B.1. Increasing the logging level for Foreman
By default, you can find the log in /var/log/foreman/production.log. For more information, see Configuring logging type and layout.
B.2. Increasing the logging level for Hammer
    :log_level: 'debug'
B.3. Increasing the logging level for Smart Proxy
By default, you can find the log in /var/log/foreman-proxy/proxy.log. For more information, see Configuring logging type and layout.
    # foreman-installer --foreman-proxy-log-level DEBUG
B.4. Increasing the logging level for Candlepin
You can find the logs in /var/log/candlepin/candlepin.log and /var/log/candlepin/error.log.
  1. Set the logging level to DEBUG:
    # foreman-installer --katello-candlepin-loggers log4j.logger.org.candlepin:DEBUG
    --katello-candlepin-loggers log4j.logger.org.candlepin:DEBUG \
    --katello-candlepin-loggers log4j.logger.org.candlepin.resource.ConsumerResource:WARN \
    --katello-candlepin-loggers log4j.logger.org.candlepin.resource.HypervisorResource:WARN
B.5. Increasing the logging level for Redis
  1. In /etc/redis/redis.conf, set the logging level to debug:
    loglevel debug
  2. Restart the Redis service:
    # systemctl restart redis
B.6. Increasing the logging level for foreman-installer
foreman-installer writes logs to /var/log/foreman-installer/.
  • Increase the logging level of the foreman-installer utility:
B.7. Increasing the logging level for Pulp
Pulp logs to the systemd journal. You can view the logs using journalctl --unit 'pulpcore*'.
  1. In /etc/pulp/settings.py, set the logging level to DEBUG:
  2. Restart the Pulp services:
    # systemctl restart \
    pulpcore-api \
    pulpcore-content \
    pulpcore-resource-manager \
    pulpcore-worker@\*
B.8. Increasing the logging level for OpenVox agent
  • Set the logging level to debug:
    # foreman-installer --puppet-agent-additional-settings log_level:debug
B.9. Increasing the logging level for OpenVox server
    # foreman-installer --puppet-server-additional-settings log_level:debug
B.10. Increasing the logging level for Salt
Salt Master logs to /var/log/salt/master. Salt Minions log to /var/log/salt/minion.
You can increase the logging level for Salt Master or Salt Minion:
  • In /etc/salt/master or /etc/salt/minion, set the logging level to debug:
    log_level: debug
Appendix C: Administration settings
C.1. General settings
The general settings define system-wide configuration options for Foreman, including administrator email, instance URL, user interface preferences, HTTP proxy settings, and default language and time zone.
Administrator email address
Foreman URL
Entries per page
20
Fix DB cache
DB pending seed
Smart Proxy request timeout
60
Login page footer text
HTTP(S) proxy
HTTP(S) proxy except hosts
Show Experimental Labs
Display FQDN for hosts
If set to Yes, Foreman displays names of hosts as fully qualified domain names (FQDNs).
Out of sync interval
30
Hosts report periodically, and if the time between reports exceeds this duration in minutes, hosts are considered out of sync. You can override this on your hosts by adding the outofsync_interval parameter, per host, at Hosts > All hosts > $host > Edit > Parameters > Add Parameter.
Foreman UUID
Default language
Default timezone
The time zone to use for new users.
Instance title
Saved audits interval
New host details UI
C.2. Tasks settings
The tasks settings define how Foreman manages background tasks, including timeouts, retry behavior, batch processing, and debugging options for the Dynflow console.
Sync task timeout
120
Enable dynflow console
Enable the Dynflow console (/foreman_tasks/dynflow) for debugging.
The user must be authenticated as having administrative rights before accessing the Dynflow console.
Proxy action retry count
4
Proxy action retry interval
15
Allow proxy batch tasks
Proxy tasks batch size
100
Tasks troubleshooting URL
Polling intervals multiplier
1
C.3. Template sync settings
The template sync settings define how Foreman synchronizes templates with Git repositories, including import and export behavior, filtering, locking, and metadata handling.
Associate
Associate templates with operating system, organization, and location.
Branch
Default branch in Git repo.
Commit message
Dirname
Filter
Force import
HTTP proxy policy
Global default HTTP proxy
Whether to use an HTTP proxy to synchronize templates.
The Custom HTTP proxy value is available only if an HTTP proxy is configured under the selected organization and location and if your account has the view_http_proxies permission assigned.
Lock templates
Keep, do not lock new
Metadata export mode
Refresh
Default metadata export mode.
Possible options:
refresh re-renders metadata.
keep keeps existing metadata.
Negate
Prefix
Repo
/tmp/dir
git://example.com
https://example.com
ssh://example.com
Verbosity
C.4. Discovery settings
The Discovery settings define how Foreman handles discovered hosts, including default organization and location assignment, hostname generation, auto-provisioning behavior, and fact organization.
Discovery location
Discovery organization
Interface fact
discovery_bootif
Create bond interfaces
Clean all facts
Hostname facts
discovery_bootif
Auto provisioning
Reboot
Hostname prefix
mac
Fact columns
Highlighted facts
Storage facts
Software facts
Hardware facts
Network facts
IPMI facts
Lock PXE
Locked PXELinux template name
pxelinux_discovery
Locked PXEGrub2 template name
pxegrub2_discovery
Force DNS
Error on existing NIC
Do not permit to discover an existing host matching the MAC of a provisioning Network Interface Card (NIC) (errors out early).
Type of name generator
Fact + prefix
Prefer IPv6
C.5. Boot disk settings
iPXE directory
/usr/share/ipxe
ISOLINUX directory
/usr/share/syslinux
SYSLINUX directory
/usr/share/syslinux
Grub2 directory
/var/lib/tftpboot/grub2
Host image template
Boot disk iPXE - host
Generic image template
Boot disk iPXE - generic host
ISO generation command
genisoimage
Installation media caching
Allowed bootdisk types
C.6. Content settings
The content settings define how Foreman manages content repositories, subscriptions, content views, and host registration, including default templates, download policies, and synchronization behavior.
Default HTTP Proxy
Kickstart default
Kickstart default finish
Default synced OS user-data
Kickstart default user data
Kickstart default PXELinux
Kickstart default PXEGrub2
Kickstart default iPXE
Kickstart default
Atomic Kickstart default
Manifest refresh timeout
1200
Calculate errata host status based only on errata in a host’s content view and lifecycle environment.
Check services before actions
100
Whether or not to auto sync Smart Proxies after a content view promotion.
immediate
on_demand
on_demand
/var/lib/pulp/exports
Pulp client key
Pulp client cert
Sync Connection Timeout
300
Delete Host upon unregister
Default Location
Expire soon days
120
Host Duplicate DMI UUIDs
Host Profile Assume
Enable new host registrations to assume registered profiles with matching hostname if the registering DMI UUID is not used by another host.
Enable host registrations to bypass Host Profile Assume if the host is in build mode.
Host Tasks Workers Pool Size
5
Applicability Batch Size
50
Autosearch
Autosearch delay
500
Pulp bulk load size
2000
1440
Enable removal of repositories that the user has previously published in one or more content view versions.
C.7. Authentication settings
The authentication settings define how Foreman handles user authentication and authorization, including OAuth configuration, SSL certificates, login delegation, idle timeouts, and OpenID Connect integration.
OAuth active
This setting is for internal Foreman use only. Foreman community does not support using it to configure OAuth authentication for API calls.
OAuth consumer key
OAuth consumer key.
OAuth consumer secret
OAuth consumer secret.
OAuth map users
Failed login attempts limit
30
Trusted hosts
SSL certificate
/etc/foreman/client_cert.pem
SSL CA file
/etc/foreman/proxy_ca.pem
SSL private key
/etc/foreman/client_key.pem
SSL client DN env
HTTP_SSL_CLIENT_S_DN
SSL client verify env
HTTP_SSL_CLIENT_VERIFY
SSL client cert env
HTTP_SSL_CLIENT_CERT
Server CA file
Websockets SSL key
Websockets SSL certificate
Websockets encryption
Login delegation logout URL
External
Idle timeout
60
BCrypt password cost
9
BMC credentials access
OIDC JWKs URL
OIDC Audience
OIDC Issuer
OIDC Algorithm
C.8. Email settings
The email settings define how Foreman sends email notifications, including delivery method, SMTP configuration, reply addresses, and welcome email options.
Email reply address
Email subject prefix
Send welcome email
Delivery method
SMTP
Method used to deliver email.
SMTP enable StartTLS auto
SMTP OpenSSL verify mode
Default verification mode
SMTP address
SMTP address to connect to.
SMTP port
25
SMTP port to connect to.
SMTP HELO/EHLO domain
HELO/EHLO domain.
SMTP username
SMTP password
SMTP authentication
none
C.9. Notifications settings
The notifications settings define how Foreman retrieves and displays RSS notifications from external feeds.
RSS enable
Pull RSS notifications.
RSS URL
C.10. Provisioning settings
The provisioning settings define how Foreman provisions hosts, including default passwords, template rendering, PXE boot configuration, hostname generation, and virtual machine management.
Host owner
Root password
Unattended URL
Safemode rendering
Query local nameservers
Installation token lifetime
360
SSH timeout
120
0.0.0.0
Update IP from built request
Use short name for VMs
DNS timeout
[5, 10, 15, 20]
Clean up failed deployment
Random-based
iPXE intermediate script
Maximum structured facts
100
Global Registration
Global Registration template.
CoreOS Transpiler Command
PXEGrub2 global default
PXELinux global default
Global default iPXE template
iPXE global default
Local boot PXEGrub2 template
PXEGrub2 default local boot
Local boot PXELinux template
PXELinux default local boot
Local boot iPXE template
iPXE default local boot
Manage PuppetCA
Use UUID for certificates
C.11. Facts settings
The facts settings define how Foreman processes and uses facts reported by hosts, including automatic host creation, location and organization assignment, interface updates, and fact filtering.
Location fact
foreman_location
Organization fact
foreman_organization
Default location
Default Location
Default organization
Default Organization
Update hostgroup from facts
Ignore facts for domain
Update subnets from facts
None
Default Puppet environment
production
ENC environment
Update environment from facts
C.12. Configuration management settings
The configuration management settings define how Foreman integrates with configuration management tools, including automatic host creation from reports, smart class parameter evaluation, and configuration status tracking.
Matchers inheritance
[fqdn, hostgroup, os, domain]
Interpolate ERB in parameters
Puppet interval
35
Puppet out of sync disabled
C.13. Remote execution settings
The remote execution settings define how Foreman executes commands and scripts on remote hosts, including SSH configuration, user management, Smart Proxy selection, and job template synchronization.
Fallback to Any Proxy
Enable Global Proxy
SSH User
root
Effective User
root
Effective User Method
sudo
Effective user password
Sync Job Templates
SSH Port
22
Connect by IP
Prefer IPv6 over IPv4
Default SSH password
Default SSH key passphrase
Workers pool size
5
Cleanup working directories
Cockpit URL
Form Job Template
Run Command - Script Default
Time to pickup
86400
Time in seconds within which the host has to pick up a job. If the job is not picked up within this limit, the job will be canceled. Applies only to pull-mqtt based jobs. Defaults to one day.
C.14. Ansible settings
The Ansible settings define how Foreman integrates with Ansible for configuration management, including connection types, verbosity levels, timeout values, and role import behavior.
Private Key Path
Connection type
ssh
Use this connection type by default when running Ansible Playbooks. You can override this on hosts by adding the ansible_connection parameter.
WinRM cert Validation
validate
Enable or disable WinRM server certificate validation when running Ansible Playbooks. You can override this on hosts by adding the ansible_winrm_server_cert_validation parameter.
Default verbosity level
Disabled
Foreman adds this level of verbosity for additional debugging output when running Ansible Playbooks.
Post-provision timeout
360
Ansible report timeout
30
Ansible out of sync disabled
Ansible - Ansible Inventory
Ansible roles to ignore
Pre-release version Report issue
