1. Tuning Foreman server performance with predefined profiles
If your Foreman deployment includes a large number of hosts, you can use predefined tuning profiles to configure your Foreman server to use the optimal amount of CPU cores and memory. This can help improve Foreman performance.
1.1. How predefined tuning profiles apply
When you run the foreman-installer command with the --tuning option, deployment configuration settings from multiple sources are applied to Foreman in a specific order. This order defines the priority of these settings.
Foreman loads tuning configuration settings from the following sources:
Custom Hiera settings
If you use custom Hiera settings on your Foreman server, you can find them in the /etc/foreman-installer/custom-hiera.yaml file.
Predefined tuning profile
This is the profile that you select when running the foreman-installer command with the --tuning option. The settings for these profiles are defined in the /usr/share/foreman-installer/config/foreman.hiera/tuning/sizes/ directory.
Base tuning profile
The settings for this profile are defined in the /usr/share/foreman-installer/config/foreman.hiera/tuning/common.yaml file.
When merging these settings, Foreman applies them in the following order:
  • Custom settings in the /etc/foreman-installer/custom-hiera.yaml file override the settings in any predefined profile and the base profile.
  • Predefined profile settings override the settings in the base profile.
1.2. Predefined tuning profiles
The following predefined tuning profiles are available in Foreman to right-size your Foreman server based on the number of hosts your Foreman manages and available hardware resources.
The predefined tuning profiles are available in the /usr/share/foreman-installer/config/foreman.hiera/tuning/sizes directory. Each profile targets a managed-host range and minimum RAM and CPU cores.
Table 1. Predefined tuning profiles
Tuning profile Number of hosts RAM Number of CPU cores
default
0 – 5000
20G
4
medium
5001 – 10000
32G
8
large
10001 – 20000
64G
16
extra-large
20001 – 60000
128G
32
extra-extra-large
60000+
256G
48+
1.3. Applying a predefined tuning profile
Run foreman-installer with the --tuning option to apply a profile. Choosing the right tuning profile helps your Foreman server use its CPU cores and memory better.
You cannot use predefined tuning profiles on Smart Proxy servers.
  1. If you use a custom-hiera.yaml file on your Foreman server, perform the following steps:
    1. Optional: Back up your custom-hiera.yaml file:
      # cp /etc/foreman-installer/custom-hiera.yaml \
      /etc/foreman-installer/custom-hiera.original.yaml
      This ensures you can restore the custom-hiera.yaml file to its original state if it becomes corrupted.
    2. Review the definitions of the base tuning profile in /usr/share/foreman-installer/config/foreman.hiera/tuning/common.yaml and the tuning profile that you want to apply in /usr/share/foreman-installer/config/foreman.hiera/tuning/sizes/.
    3. Compare the configuration entries against the entries in your /etc/foreman-installer/custom-hiera.yaml file.
    4. Remove any duplicated configuration settings that you find in custom-hiera.yaml. This ensures the settings in custom-hiera.yaml do not override the settings in the base tuning profile and your chosen predefined tuning profile.
  2. Apply the tuning profile:
2. Migrating from internal Foreman databases to external databases
2.1. Determining whether your Foreman server uses internal or external databases
You can confirm whether your Foreman server uses internal or external databases by checking the status of the PostgreSQL database service.
  • On Foreman server, query the status of your databases:
2.2. PostgreSQL as an external database considerations
Foreman, Katello, and Candlepin use the PostgreSQL database. If you want to use PostgreSQL as an external database, the following information can help you decide if this option is right for your Foreman configuration. Foreman supports PostgreSQL version 13.
Advantages of external PostgreSQL
Disadvantages of external PostgreSQL
2.3. Installing PostgreSQL as an external database
Install and configure PostgreSQL on a dedicated host if you want to use an external database with your Foreman server.
  • The prepared host has base operating system repositories enabled.
  • The prepared host has sufficient disk space available for the /var/lib/pgsql directory. The expected installation size is 100 MB and the expected runtime size is 20 GB.
  1. On your new database server, install PostgreSQL:
    # dnf install postgresql-server postgresql-contrib
  2. Initialize the PostgreSQL database:
    # postgresql-setup --initdb
    • max_connections: 500
    • shared_buffers: 512MB
    • work_mem: 4MB
    listen_addresses = '*'
  5. Add the following line to the end of the file to use SCRAM for authentication:
  6. Edit the /var/lib/pgsql/data/pg_hba.conf file:
  7. Add the following line to the file:
      host  all   all   Foreman_ip/32   scram-sha-256
  8. Start and enable the PostgreSQL service:
  9. Update the firewall configuration. For example, using the firewall-cmd command:
    1. Open the postgresql port:
    2. Make the changes persistent:
  10. Switch to the postgres user and start the PostgreSQL client:
    $ su - postgres -c psql
  11. Create three databases and dedicated roles: one for Foreman, one for Candlepin, and one for Pulp:
  12. Exit the postgres user:
    # \q
  • From Foreman server, test that you can access the database:
    # PGPASSWORD='Foreman_Password' pg_isready --host=postgres.example.com --port=5432 --username=foreman --dbname=foreman
    # PGPASSWORD='Candlepin_Password' pg_isready --host=postgres.example.com --port=5432 --username=candlepin --dbname=candlepin
    # PGPASSWORD='Pulpcore_Password' pg_isready --host=postgres.example.com --port=5432 --username=pulp --dbname=pulpcore
    If the connection succeeded, this displays an accepting connections message.
2.4. Migrating to external databases
  • You have installed and configured a PostgreSQL server on an external server.
  1. On Foreman server, stop all Foreman services except for PostgreSQL:
  2. Create your target directory for the Foreman backup:
    # mkdir /var/My_Migration_Backup_Directory
    # foreman-maintain backup online \
    --preserve-directory \
    --skip-pulp-content \
    PGPASSWORD='Foreman_Password' pg_restore --host=postgres.example.com --username=foreman --dbname=foreman < /var/My_Migration_Backup_Directory/foreman.dump
    PGPASSWORD='Candlepin_Password' pg_restore --host=postgres.example.com --username=candlepin --dbname=candlepin < /var/My_Migration_Backup_Directory/candlepin.dump
    PGPASSWORD='Pulpcore_Password' pg_restore --host=postgres.example.com --username=pulp --dbname=pulpcore < /var/My_Migration_Backup_Directory/pulpcore.dump
    # foreman-installer \
    --foreman-proxy-content-pulpcore-postgresql-user pulp \
    --foreman-db-manage false \
    --foreman-db-password Foreman_Password
  6. Remove the PostgreSQL package on Foreman server:
    # dnf remove postgresql-server
  7. Remove the PostgreSQL data directory:
    # rm -fr /var/lib/pgsql/data
3. Preparing for disaster recovery and recovering from data loss
How do I back up?
How do I back up?
Store the following critical data on network attached storage: content in /var/lib/pulp and database in /var/lib/pgsql. Replicate this storage into a different data center. Attach the storage to a Foreman server that is a clone of the primary Foreman server but runs passively.
How do I back up?
Dual active Foreman server
How do I back up?
3.2. Disaster recovery by virtualizing your Foreman server
3.2.1. Preparing for disaster recovery by virtualizing your Foreman server
  3. To verify that you will be able to restore Foreman services in case of a disaster, assess the functionality of the test Foreman server. For more information, see Retrieving the status of services by using Hammer CLI.
3.2.2. Recovering from disaster by restoring a VM snapshot of Foreman server
3.2.3. Retrieving the status of services by using Hammer CLI
    $ hammer ping
  • Perform a health check:
3.3. Disaster recovery for active and passive Foreman server with external storage
3.3.1. Preparing for disaster recovery with active and passive Foreman server with external storage
  2. Back up your active Foreman server and restore it on a system that will serve as your passive Foreman server. For more information, see Backing up Foreman server and Smart Proxy server and Restoring Foreman server or Smart Proxy server from a backup.
  4. Assess the functionality of the test Foreman server. For more information, see Retrieving the status of services by using Hammer CLI.
3.3.2. Recovering from disaster with active and passive server with external storage
  5. Assess the functionality of your new active Foreman server. For more information, see Retrieving the status of services by using Hammer CLI.
3.3.3. Retrieving the status of services by using Hammer CLI
    $ hammer ping
3.4. Disaster recovery for active and passive Foreman server with backup and restore
3.4.1. Preparing for disaster recovery with active and passive Foreman server and backup and restore
  1. Define a schedule for periodic offline backups of your active Foreman server. Consider your tolerance for potential data loss and your storage options: Taking backups frequently will result in smaller amounts of data loss in case of a disaster, but backups require a significant amount of storage space. For information about the size of Foreman backups, see Estimating the size of a backup.
    You can combine full backups with incremental backups. For an example of a cron job that ensures regular backups, see Example of a weekly full backup followed by daily incremental backups.
  2. Schedule periodic offline backups of your active Foreman server to be taken according to the schedule you defined. For information about performing backups, see Backing up Foreman server and Smart Proxy server.
  3. Ensure that the backup directories are encrypted and regularly synchronized to a secure location. By default, Foreman stores the backups in the /var/foreman-backup directory.
    Foreman server backups contain sensitive information from the /root/ssl-build directory. For example, they can contain hostnames, ssh keys, request files, and SSL certificates. Encrypting or moving the backups to a secure location helps minimize the risk of damage or unauthorized access to the hosts.
  4. Restore the most recent backup on a system that will serve as your passive Foreman server. For information about restoring backups, see Restoring Foreman server or Smart Proxy server from a backup.
    3. Assess the functionality of the test Foreman server. For more information, see Retrieving the status of services by using Hammer CLI.
3.4.2. Recovering from disaster with active and passive server and backup and restore
  3. Assess the functionality of your new active Foreman server. For more information, see Retrieving the status of services by using Hammer CLI.
3.4.3. Retrieving the status of services by using Hammer CLI
    $ hammer ping
3.4.4. Example of a weekly full backup followed by daily incremental backups
#!/bin/bash -e
else
fi
exit 0
3.5. Disaster recovery with two active Foreman servers
3.5.1. Preparing for disaster recovery with two active Foreman servers
Ansible playbooks can help you automate failover, re-registration, and synchronization. For more information, see Using the Foreman Ansible Collection.
  1. Back up your Foreman server. For more information, see Backing up Foreman server and Smart Proxy server.
  2. Restore the backup on a system that will serve as your other Foreman server. For more information, see Restoring Foreman server or Smart Proxy server from a backup.
  5. Automate running the foreman-maintain health check command on both servers. The health check verifies whether the servers remain fully operational.
  2. Verify that your foreman-maintain health check automation reported an error.
3.5.2. Recovering from disaster with two active Foreman servers
If the health checks implemented in Preparing for disaster recovery with two active Foreman servers report an issue on one of your Foreman servers, it might mean that the server has failed. If the server is down, you must re-register hosts to the other server.
  2. If foreman-maintain health check reported a problem, ensure that the server is powered off.
4. Managing users and roles
Foreman users represent individuals who access your Foreman and are scoped to organizations and locations. You assign roles to users to control which actions they can perform in your environment.
4.1. Managing Foreman users
4.1.1. Creating a user by using Foreman web UI
Create user accounts from the Foreman web UI to grant individuals access to your Foreman environment.
  2. Click Create User.
  3. Enter the account details for the new user.
  4. Click Submit to create the user.
    • On the User tab, select an authentication source from the Authorized by list:
    • On the Organizations tab, select organizations for the user. Select the default organization from the Default on login list. Foreman uses this organization for the user after login.
    • On the Locations tab, select locations for the user. Select the default location from the Default on login list. Foreman uses this location for the user after login.
4.1.2. Creating a user by using Hammer CLI
Create user accounts by using Hammer CLI to grant individuals access to your Foreman environment.
  • Create a user:
    $ hammer user create \
    --login My_User_Name \
    --mail My_User_Mail \
    --location-ids My_Location_ID_1,My_Location_ID_2 \
    --password My_User_Password
    Append --auth-source-id 1 so that the user is authenticated internally. Run hammer auth-source list to get a list of authentication sources. Add the --admin option to grant administrator privileges to the user.
    You can modify the user details later by using the hammer user update command.
4.1.3. Assigning roles to a user by using Foreman web UI
Assign roles to a user in the Foreman web UI to control which permissions and resources they can access in your environment.
  7. Click Submit.
4.1.4. Assigning roles to a user by using Hammer CLI
Assign roles to a user with Hammer CLI to grant the permissions they need to perform tasks in Foreman.
  • Assign roles to a user:
    $ hammer user add-role \
    --id My_User_ID \
    --role My_Role_Name
4.1.5. Impersonating a different user account
As an administrator, you can impersonate another user by logging on to the Foreman web UI as that user. Impersonating another user is useful for testing and troubleshooting purposes because you can access exactly what the impersonated user can access in the system, including the same menus.
  • You are logged on to the Foreman web UI as a user with administrator privileges for Foreman.
4.1.6. Creating an API-only user
You can create a user account that can interact only with the Foreman API. This is useful for service accounts or integrations that must not use the Foreman web UI.
  • You have created a user and assigned roles to them. Note that this user must be authorized internally. For more information, see Managing users and roles.
    # openssl rand -hex 32
4.2. Managing SSH keys
Add SSH keys to user accounts so Foreman can deploy those keys during host provisioning.
4.2.1. Managing SSH keys for a user by using Foreman web UI
Add or remove SSH keys for a user in the Foreman web UI to control which keys Foreman deploys during provisioning.
  • You are logged in to the Foreman web UI as an Admin user of Foreman or a user with the create_ssh_key permission enabled for adding SSH key and destroy_ssh_key permission for removing a key.
  3. Click on the SSH Keys tab.
    • To Add SSH key
      2. Click Add SSH Key.
      5. Click Submit.
    • To Remove SSH key
4.2.2. Managing SSH keys for a user by using Hammer CLI
Add or remove SSH keys for a user with Hammer CLI to manage which keys Foreman deploys during provisioning.
  1. To add an SSH key to a user, you must specify either the path to the public SSH key file, or the content of the public SSH key copied to the clipboard:
      $ hammer user ssh-keys add \
      --user-id user_id \
      --name key_name \
      --key-file ~/.ssh/id_rsa.pub
      --user-id user_id \
      --name key_name \
  2. To delete an SSH key from a user, enter the following command:
  3. To view an SSH key attached to a user, enter the following command:
  4. To list SSH keys attached to a user, enter the following command:
4.3. Managing Personal Access Tokens
  • Your user account has a role that grants the create_personal_access_tokens permission.
    $ curl \
    {"foreman_version":"3.17.0","result":"ok","status":200,"version":"3.5.1.10","api_version":2}
    $ curl \
4.4. Creating and managing user groups
With Foreman, you can assign permissions to groups of users. You can also create user groups as collections of other user groups.
4.4.1. Creating a user group by using Foreman web UI
Create a user group in the Foreman web UI and define which roles the group will have.
  2. Click Create User group.
  5. Click Submit.
4.4.2. Creating a user group by using Hammer CLI
Create a user group by using Hammer CLI and define which roles the group will have.
  • Create a user group:
    $ hammer user-group create \
    --name My_User_Group_Name \
4.4.3. Removing a user group
Remove a user group from Foreman when you no longer need it or when you want to reorganize how permissions are assigned.
5. Creating and managing roles
Roles define a set of permissions and access levels through permission filters. Assign roles to users and user groups to control which actions they can perform in your environment.
5.1. Creating a role by using Foreman web UI
Create a role by using the Foreman web UI. You can add permissions to the role to control which actions users can perform.
  2. Click Create Role.
Next steps
  • Add permissions to the role. To serve its purpose, a role must contain permissions.
5.2. Creating a role by using Hammer CLI
Create a role by using Hammer CLI. You can add permissions to the role to control which actions users can perform.
  • Create a role:
Next steps
5.3. Cloning a role
Clone an existing role in the Foreman web UI to quickly create a new role with similar permissions. You can edit the cloned role to customize permissions for your environment.
Example 1. Creating an organization-specific manager role
  5. Click org-1 admin, and click Filters to view all associated filters. The default filters work for most use cases. However, you can optionally click Edit to change the properties for each filter. You can also click New filter to associate new filters with this role.
5.4. Adding permissions to a role by using Foreman web UI
Add permissions to a role in the Foreman web UI to define which actions users with that role can perform.
  5. Click Next.
  6. Click Submit to save changes.
5.5. Adding permissions to a role by using Hammer CLI
Add permissions to a role by using Hammer CLI to define which actions users with that role can perform.
  2. Add permissions to a role:
    $ hammer filter create \
    --role My_Role_Name
5.6. Viewing permissions of a role
View the permissions assigned to a role in the Foreman web UI to verify which actions users with that role can perform.
5.7. Creating a complete permission table
Generate a complete permission table from the Foreman console to review all available permissions and actions on your Foreman.
  • The foreman-console package is installed on Foreman server.
  1. Start the Foreman console:
    # foreman-rake console
    end.join("\n")
    f.write(result)
    </table>
5.8. Removing a role
You can remove a role from the Foreman web UI if you no longer need it to grant permissions to users.
5.9. Predefined roles available in Foreman
Review predefined roles in Foreman to understand which permissions each role grants before assigning roles to users.
Predefined role Permissions the role provides Additional information
Auditor
View the Audit log.
Default role
View tasks and jobs invocations.
Foreman automatically assigns this role to every user in the system.
Manager
Organization admin
Site manager
View permissions for various items.
Permissions to manage hosts in the infrastructure.
System admin
Edit global settings in Administer > Settings.
View, create, edit, and destroy users, user groups, and roles.
View, create, edit, destroy, and assign organizations and locations but not view resources within them.
Users with this role can create users and assign all roles to them. Give this role only to trusted users.
Viewer
View the configuration of every element of the Foreman structure, logs, reports, and statistics.
5.10. Granular permission filtering
With granular permission filters, you can limit permissions of a user to selected instances of a resource type.
5.10.1. Creating a granular permission filter by using Foreman web UI
Create a granular permission filter in the Foreman web UI to limit role permissions to specific resource instances.
  1. Specify a query in the Search field on the Edit Filter page. Queries have the following form:
    field_name operator value
    • operator specifies the type of comparison between field_name and value. See Supported operators for granular search for an overview of applicable operators.
5.10.2. Creating a granular permission filter by using Hammer CLI
Create a granular permission filter by using Hammer CLI to limit role permissions to specific resource instances.
    --permission-ids 91 \
    --search "name ~ ccv*" \
    --role qa-user
    This command adds to the qa-user role a permission to view, create, edit, and destroy content views that only applies to content views with name starting with ccv.
5.10.3. Examples of using granular permission filters
As an administrator, you can allow selected users to make changes in a certain part of the environment path. For example, you can allow users to work with content while it is in the development stage of the application lifecycle, but not once the content is pushed to production.
The following query applies any permissions specified for the Host resource type only to hosts in the group named host-editors:
hostgroup = host-editors
name ^ (XXXX, Yyyy, zzzz)
Dev
5.10.4. Supported operators for granular search
You can use logical and symbolic operators to build precise search queries when limiting user permissions.
Table 2. Logical operators
Operator
and
Combines search criteria.
not
Negates an expression.
has
Table 3. Symbolic operators
Operator
6. Configuring email notifications
Foreman server does not enable outgoing emails by default, therefore you must review your email configuration.
6.1. Email notification types
You can configure Foreman to send email notifications for system events such as host builds, errata updates, content synchronization failures, and audit summaries to stay informed about important activities in your environment.
Audit summary
A summary of all activity audited by Foreman server.
Compliance policy summary
Content view promote failure
Content view publish failure
Host built
Host errata advisory
Promote errata
Repository sync failure
Smart Proxy sync failure
A notification sent after Smart Proxy synchronization fails.
Sync errata
6.2. Configuring email notification preferences
You can configure Foreman to send email messages to individual users registered to Foreman. Foreman sends the email to the email address that has been added to the account, if present.
Users can edit the email address by clicking on their name in the top right of the Foreman web UI and selecting My account.
  6. Click Submit.
6.3. Testing email delivery
  2. Click on the username.
  • If the email is delivered, the verification is complete.
Troubleshooting
  • If the email is not delivered, perform the following diagnostic steps:
      # systemctl start postfix
6.4. Testing email notifications
  • Trigger email notifications:
  • daily
  • weekly
  • monthly
6.5. Changing email notification settings for a host
You can enable or disable email notifications for a host to control whether its events trigger alerts. Foreman sends these notifications to the registered owner of the host.
  2. Go to the Additional Information tab. If the Enabled checkbox is checked, then email notifications are enabled on that host.
7. Backing up Foreman server and Smart Proxy server
7.1. Planning Foreman server and Smart Proxy server backup
Backing up your Foreman server or Smart Proxy server requires you to plan scheduling, storage, and security so you avoid disruption and protect sensitive data.
7.1.1. Available backup methods
Choose an offline or online backup method based on how long you can keep Foreman services unavailable and how much time you can allocate for the backup.
Offline backup
All Foreman services are shut down during an offline backup.
For more details, read help information for the offline backup:
Online backup
For more details, read help information for the online backup:
7.1.2. Best practices for backing up Foreman server and Smart Proxy servers
Apply these recommendations when scheduling and storing backups so you protect sensitive data and avoid conflicts with other administrators.
  • Foreman community recommends backing up Foreman to a separate storage device on a separate system. The foreman-maintain backup command creates a backup of your Foreman server or Smart Proxy server and all associated data.
  • Foreman services are unavailable during the backup. Coordinate with other administrators to ensure no conflicting tasks run during the backup window.
    Warning
    You can schedule a backup by using cron.
    During offline backups, the services are inactive and Foreman is in a maintenance mode. A firewall rejects traffic from outside on port 443 to ensure there are no modifications triggered.
  • Encrypt or move the backup to a secure location to minimize the risk of damage or unauthorized access to the hosts. A backup has sensitive information from the /root/ssl-build directory. For example, it can have hostnames, SSH keys, request files and SSL certificates.
7.1.3. Directories created during backups
  • foreman-backup on Foreman
7.1.4. Estimating the size of a backup
Estimate how much disk space a Foreman backup requires so you can ensure enough storage is available and avoid backup failures.
Compression occurs after the archives are created to decrease the time when Foreman services are unavailable.
  1. Estimate the size of uncompressed directories containing Foreman database and configuration files:
    100G    /var/lib/pgsql/data
    100G	/var/lib/pulp
    # du -csh /var/lib/tftpboot /etc /root/ssl-build \
    16M   /var/lib/tftpboot
    37M   /etc
    900K  /root/ssl-build
    100K  /var/www/html/pub
    2M    /opt/puppetlabs
    942M  total
    Table 4. Backup data compression ratio
    PostgreSQL database files
    /var/lib/pgsql/data
    80 – 85%
    100 GB → 20 GB
    Pulp RPM files
    /var/lib/pulp
    (not compressed)
    100 GB
    Configuration files
    /var/lib/tftpboot
    /etc
    /root/ssl-build
    /var/www/html/pub
    /opt/puppetlabs
    85%
    942 MB → 141 MB
7.2. Performing a full backup of Foreman server or Smart Proxy server
Run a full offline backup on Foreman server or Smart Proxy server to capture all Foreman content and configuration. A full backup is useful when you want to prepare for a future restore from scratch.
Warning
  1. Back up your Foreman server:
  2. Back up your Smart Proxy server:
7.3. Performing a backup without Pulp content
Run an offline backup that excludes the contents of the Pulp directory. A backup without Pulp content is useful for debugging purposes and is only intended to provide access to configuration files without backing up the Pulp database.
Warning
Do not use a backup without Pulp content to restore your Foreman server or Smart Proxy server for production use cases.
  • Back up your Foreman server without Pulp content:
7.4. Performing an incremental backup
Run an incremental backup to perform an offline backup that captures any changes since a previous full backup. Incremental backups use less time and storage than a full offline backup.
  1. Perform a full offline backup. For more information, see Performing a full backup of Foreman server or Smart Proxy server.
  2. Create a directory within your backup directory to store the first incremental backup:
  3. Create the second incremental backup by including the path to the first incremental backup to indicate the starting point for the next increment. This creates a directory for the second incremental backup in your backup directory:
7.5. Example of a weekly full backup followed by daily incremental backups
#!/bin/bash -e
else
fi
exit 0
7.6. Performing an online backup
Run an online backup to create a Foreman backup while keeping most services running. This is useful when you need to maintain system availability during backup operations.
When you perform an online backup, most Foreman services remain running and usable. Background workers are shut down to ensure consistent backups. Operations that require background workers remain in pending state. The backup process ensures that the Pulp data (/var/lib/pulp) is not altered during the backup. Any changes to the Pulp data during the backup will result in restart of the backup process, taking additional time.
  • Perform an online backup on your Foreman server:
7.7. Creating a conventional backup
You can use conventional backup methods to back up your Foreman server or Smart Proxy server. Unlike Foreman backup methods, conventional backup methods require you to stop Foreman services.
  1. When creating a snapshot or conventional backup, stop all Foreman services:
  2. Create the snapshot or conventional backup. For more information, see Recovering and restoring a system in Red Hat Enterprise Linux 9 Configuring basic system settings.
  3. Start Foreman services after creating a snapshot or conventional backup:
8. Restoring Foreman server or Smart Proxy server from a backup
You can restore Foreman server or Smart Proxy server from a backup to recover after failure or data loss. This process outlines how to restore the backup on the same server that generated the backup, and all data covered by the backup is deleted on the target system. If the original system is unavailable, provision a system with the same configuration settings and host name.
8.1. Restoring from a full backup
Restore Foreman server or Smart Proxy server from a full backup return the system to the state at the time of the backup. When the restore process completes, all processes are online, and all databases and system configuration revert to the state at the time of the backup.
  • Your Foreman server must have the same host name, configuration, and be the same minor version (X.Y) as the original system.
  • The target directory must exist and be writable. The target directory is read from the configuration files contained within the backup archive.
  • If the backed up system had FIPS enabled, the system on which you are restoring must also have FIPS enabled.
  1. Ensure that you have enough space to store the backup data on the base system of Foreman server or Smart Proxy server as well as enough space after the restoration to contain all the data in the /etc/ and /var/ directories contained within the backup.
    To check the space used by a directory:
    To check for free space:
    # df -h /var/backup_directory
  2. Restore the correct SELinux contexts:
    # restorecon -Rv /
  3. Choose the appropriate method to install Foreman or Smart Proxy:
  4. Copy the backup data to the local file system on Foreman server. Use /var/ or /var/tmp/.
  5. Run the restoration script.
Next steps
  • If you create a new instance of Foreman server or Smart Proxy server, decommission the old instance after restoring the backup. Cloned instances are not supposed to run in parallel in a production environment.
Troubleshooting
  • Review the /var/log/foreman/production.log and /var/log/messages log files.
8.2. Restoring from incremental backups
Restore Foreman server or Smart Proxy server from an incremental backup to return the system to the state at the time of the backup. When the restore process completes, all processes are online, and all databases and system configuration revert to the state at the time of the backup.
If you have multiple branches of incremental backups, select your full backup and each incremental backup for the branch you want to restore, in chronological order.
  1. Restore the last full backup using the instructions in Restoring from a full backup.
  2. Remove the full backup data from the local file system on Foreman server, for example, /var/ or /var/tmp/.
  3. Copy the incremental backup data to the local file system on Foreman server, for example, /var/ or /var/tmp/.
Next steps
Troubleshooting
8.3. Restoring Smart Proxy server by using a virtual machine snapshot
Restore Smart Proxy server from a virtual machine snapshot to return the system to the state at the time of the snapshot. You can use virtual machine snapshots to back up and restore your Smart Proxy server for quick recovery after server failure or configuration issues.
  • You have selected the relevant organization and location context of your Smart Proxy server, or chosen Any Organization and Any Location.
  1. If your Smart Proxy server is a virtual machine, include it in your backup strategy by using VM snapshots. Creating weekly snapshots that you can restore from is recommended.
  2. After a failure, either restore your Smart Proxy server from a snapshot by using your hypervisor tools, or deploy a new Smart Proxy server and ensure that the host name is the same as before, and then install the Smart Proxy certificates. You may still have them on Foreman server, the package name ends in -certs.tar, alternately create new ones.
  3. Follow the procedures in Installing Smart Proxy server until you can confirm, in the Foreman web UI, that Smart Proxy server is connected to Foreman server.
  4. In the Foreman web UI, navigate to Infrastructure > Smart Proxies.
  5. Select your Smart Proxy server.
  6. On the Overview tab, click Synchronize.
    • Select Optimized Sync to synchronize content from your Foreman server to your Smart Proxy server that bypasses unnecessary steps to speed up performance.
    • Select Complete Sync to perform a complete sync from your Foreman server to your Smart Proxy server that synchronizes content even if the metadata has not changed.
9. Renaming Foreman server or Smart Proxy server
You can rename Foreman server or Smart Proxy server when its hostname or domain changes. After renaming, it is important to update all references to avoid communication and certificate errors.
9.1. Renaming Foreman server
Rename Foreman server when its hostname or domain changes so that components, Smart Proxy servers, and registered hosts continue to communicate correctly. Use the katello-change-hostname script and update all references to the new hostname.
Warning
Renaming your Foreman server host shuts down all Foreman services on that host. The services restart after the renaming is complete.
  • You have a backup of your Foreman server before changing its host name. If you fail to successfully rename it, restore it from the backup. For more information, see Backing up Foreman server and Smart Proxy server.
  • The hostname and hostname -f commands on Foreman server both return the FQDN of Foreman server. If both commands do not return the FQDN of Foreman server, the katello-change-hostname script will fail to complete.
    If the hostname command returns the shortname of Foreman server instead of the FQDN, use hostnamectl set-hostname My_Old_FQDN to set the old FQDN correctly before using the katello-change-hostname script.
  • If Foreman server has a custom SSL certificate installed, you have a new certificate for the new FQDN of the host. For more information, see Configuring Foreman server with a Custom SSL Certificate in Installing Foreman Server with Katello 4.19 plugin on Enterprise Linux.
  1. On Foreman server, run the katello-change-hostname script, and provide the new host name. Choose one of the following methods:
    • If your Foreman server is installed with the default self-signed SSL certificates:
      --username My_Username \
      --password 'My_Password'
      --password 'My_Password' \
  2. If you have created a custom SSL certificate for the new Foreman server host name, run the Foreman installation script to install the certificate. For more information about installing a custom SSL certificate, see Deploying a Custom SSL Certificate to Foreman server in Installing Foreman Server with Katello 4.19 plugin on Enterprise Linux.
  3. Reregister all hosts and Smart Proxy servers that are registered to Foreman server. For more information, see Registering hosts by using global registration in Managing hosts.
    # foreman-installer \
    --foreman-proxy-trusted-hosts new-foreman.example.com
    # hammer proxy list
    # hammer proxy content synchronize \
    --id My_Smart_Proxy_ID
  7. If you use the virt-who agent, update the virt-who configuration files with the new host name.
  8. If you use external authentication, reconfigure Foreman server for external authentication after you run the katello-change-hostname script. For more information, see Configuring authentication for Foreman users.
9.2. Renaming Smart Proxy server
Rename Smart Proxy server when its hostname or domain changes so that Foreman components and registered hosts continue to communicate correctly. Use the katello-change-hostname script and update certificates and references to the new hostname.
Warning
Renaming your Smart Proxy server host shuts down all Foreman services on that host. The services restart after the renaming is complete.
  • You have a backup of your Smart Proxy server before renaming. If you fail to successfully rename it, restore it from the backup. For more information, see Backing up Foreman server and Smart Proxy server.
  • The hostname and hostname -f commands on Smart Proxy server both return the FQDN of Smart Proxy server. If both commands do not return the FQDN of Smart Proxy server, the katello-change-hostname script will fail to complete.
    If the hostname command returns the shortname of Smart Proxy server instead of the FQDN, use hostnamectl set-hostname My_Old_FQDN to set the old FQDN correctly before attempting to use the katello-change-hostname script.
  1. On your Foreman server, generate a new certificates archive file for your Smart Proxy server.
    • If you are using the default SSL certificate, regenerate the default SSL certificates:
      --certs-tar /root/new-smartproxy.example.com-certs.tar \
      --foreman-proxy-fqdn new-smartproxy.example.com
    • If you are using a custom SSL certificate, create a new SSL certificate for your Smart Proxy server. For more information, see Configuring Smart Proxy server with a Custom SSL Certificate in Installing a Smart Proxy Server 3.17 on Enterprise Linux.
  2. On your Foreman server, copy the certificates archive file to your Smart Proxy server. For example, to copy the archive file to the root user’s home directory:
  3. On your Smart Proxy server, run the katello-change-hostname script and provide the host’s new name, Foreman credentials, and certificates archive file name.
    # katello-change-hostname new-smartproxy.example.com \
  4. If you have created a custom certificate for your Smart Proxy server, deploy the certificate to your Smart Proxy server by entering the foreman-installer command that the foreman-proxy-certs-generate command returned in a previous step. For more information, see Deploying a Custom SSL Certificate to Smart Proxy server in Installing a Smart Proxy Server 3.17 on Enterprise Linux.
  5. Reregister all hosts that are registered to your Smart Proxy server. For more information, see Registering hosts to Foreman in Managing hosts.
  6. Update the Smart Proxy host name in the Foreman web UI.
    2. Locate Smart Proxy server in the list, and click Edit.
    3. Edit the Name and URL fields to match Smart Proxy server’s new host name, then click Submit.
    4. On your DNS server, add a record for the new hostname of your Smart Proxy server, and delete the record of the previous host name.
10. Configuring Foreman for Insights analytics
You can configure Foreman to connect to Insights hosted in the Red Hat Hybrid Cloud Console so your Red Hat Enterprise Linux hosts receive suggestions for improvement.
10.1. Insights overview
Insights is a set of analytical services by Red Hat for hosts running Red Hat Enterprise Linux. Insights services analyze host data and provide suggestions for host improvements.
Insights services
Insights services include:
  • Advisor, which provides recommendations for host improvements.
  • Vulnerability, which provides reports on vulnerabilities found on your hosts.
  • Compliance, which provides reports on compliance with regulatory requirements.
Insights services hosted in the Red Hat Hybrid Cloud Console are not limited to the listed services.
Hosted Insights
When you use Insights hosted in the Red Hat Hybrid Cloud Console, the Insights client on your hosts collects data and Foreman forwards it to the hosted Insights services for analysis.
If you use Insights in the Red Hat Hybrid Cloud Console:
  • You can use Insights services online in the Red Hat Hybrid Cloud Console.
  • The Insights client collects data of your hosts and Foreman forwards the data to the Red Hat Hybrid Cloud Console to calculate recommendations.
  • You can view and remediate those recommendations both in the Foreman web UI and in the Red Hat Hybrid Cloud Console.
  • Foreman uploads host inventory reports to the Red Hat Hybrid Cloud Console.
  • You have control over how much information is included in those reports.
10.2. Enabling hosted Insights
Enable the integration between Foreman and hosted Insights in the Red Hat Hybrid Cloud Console to upload host inventory and receive cloud-based recommendations for your hosts.
10.2.1. Installing Red Hat Cloud plugin
Install the Red Hat Cloud plugin on your Foreman server to upload inventory reports to the Red Hat Hybrid Cloud Console. This step is required before you configure the cloud connector.
  • Install the Red Hat Cloud plugin on your Foreman server:
    # foreman-installer --enable-foreman-plugin-rh-cloud
  2. On the Plugins tab, verify that it lists the foreman_rh_cloud plugin.
10.2.2. Adding Foreman server SSH key to authorized keys
To run remote execution jobs on Foreman server itself, add the Foreman server SSH key to authorized keys on your Foreman server.
  • You can access your Foreman server by using SSH as root.
  1. If the ~root/.ssh/authorized_keys file does not exist, create it with restrictive ownership and permissions:
    1. If the ~root/.ssh directory does not exist, create it:
      # mkdir ~root/.ssh
    2. Ensure that the directory is owned by the root user:
      # chown root:root ~root/.ssh
    3. Ensure that the directory is accessible only to the root user:
      # chmod 700 ~root/.ssh
    4. Create the authorized_keys file:
      # touch ~root/.ssh/authorized_keys
    5. Ensure that the authorized_keys file is owned by the root user:
      # chown root:root ~root/.ssh/authorized_keys
    6. Ensure that the authorized_keys file is accessible only to the root user:
      # chmod 600 ~root/.ssh/authorized_keys
  2. Add the SSH key of the foreman-proxy user to the authorized_keys file:
    # cat ~foreman-proxy/.ssh/id_rsa_foreman_proxy.pub >>~root/.ssh/authorized_keys
10.2.3. Configuring Foreman server for cloud connection
You can configure Foreman server to connect to the Red Hat Hybrid Cloud Console by using remote execution. This enables inventory upload and cloud-based features such as Insights for your hosts.
  • You have installed the Red Hat Cloud plugin on your Foreman server. For more information, see Installing Red Hat Cloud plugin.
  • Your environment is configured for remote execution. For more information, see Configuring and setting up remote jobs in Managing hosts.
  • Foreman server must be registered with Red Hat Subscription Management. You can verify the status by running subscription-manager status.
  • You have added the SSH key to authorized keys on your Foreman server. For more information, see Adding Foreman server SSH key to authorized keys.
  • Your Foreman account has a role that grants the execute_jobs_on_infrastructure_hosts permission.
    Note that this permission is not included in the default Remote Execution User role.
  1. In the Foreman web UI, navigate to Insights > Inventory Upload.
  2. Click Configure cloud connector.
  3. Click Confirm.
  1. In the Foreman web UI, navigate to Monitor > Foreman Tasks > Tasks.
  2. Find the job with the name Remote action: Configure cloud connector.
  3. Verify that the job completed successfully.
Next steps
10.3. Data control settings for hosted Insights
You can configure how Foreman handles the data collected from hosts before uploading it to the Red Hat Hybrid Cloud Console and how Foreman handles hosts in the Red Hat Hybrid Cloud Console that are no longer managed by Foreman.
10.3.1. Minimizing collected data
Use minimal data collection to limit host data sent to Red Hat while keeping the Subscriptions service active. Other Insights services are disabled because they require installed package data.
You can use minimal reporting to limit the amount of system data sent to the Subscriptions service, which remains active. Other Insights services are disabled because they require installed package data, which minimal reports do not include. Reports are still processed daily during the midnight synchronization cycle.
Minimal reports also exclude hostnames, IP addresses, and installed packages. Therefore, obfuscation and exclusion settings do not apply.
If you switch to Analytics data collection, Foreman enables the following settings by default:
  • Obfuscate host names
  • Obfuscate host ipv4 addresses
  • Exclude installed packages
Review and adjust these settings to control what data Foreman shares.
Example 2. Example of data collected in a minimal report
  "report_slice_id": "de92044d-9d77-4895-83c4-a476f5020519",
  "hosts": [
      "account": "123456789",
      "subscription_manager_id": "9fc621b9-08c3-4085-a749-bfed38c3052e",
      "insights_id": "9fc621b9-08c3-4085-a749-bfed38c3052e",
      "bios_uuid": "203F234F-58C7-4237-8DDF-A17A2838A66C",
      "bios_vendor": "SeaBIOS",
      "bios_version": "1.16.1-1.el9",
      "arch": "x86_64",
      "infrastructure_type": "virtual",
      "system_profile": {
        "installed_products": [
            "name": "Red Hat Enterprise Linux for x86_64",
            "id": "479"
        "cores_per_socket": 1,
        "system_memory_bytes": 3836579840,
        "number_of_cpus": 1,
        "number_of_sockets": 1
      "cpu_socket(s)": "1"
  • Your user account has a role that grants the edit_settings permission.
  • Existing data in Insights Inventory has been deleted before switching to minimal reporting. To remove existing data of a system, navigate to Inventory > Systems in the Red Hat Hybrid Cloud Console, select the system, and click Delete.
  • You have selected an organization and location.
  2. Select the Minimal data collection setting from the dropdown menu under Settings.
  3. When you select this option, Foreman also updates the corresponding setting on the Insights tab under Administer > Settings.
  4. Click the Generate and upload report button to create a new inventory report and send it to the Red Hat Hybrid Cloud Console.
10.3.2. Obfuscating hostnames and IP addresses
You can configure Foreman to obfuscate hostnames and IP addresses when uploading host data to Insights. Obfuscation ensures that sensitive identifying information is not exposed.
When obfuscation settings are enabled, Foreman obfuscates hostnames and IP addresses. If obfuscation settings are enabled and the host has its own insights-client obfuscation settings, Foreman honors the host settings. If obfuscation settings are disabled, Foreman does not obfuscate hostnames or IP addresses unless the client has obfuscation enabled in insights-client.
By default, Foreman applies global obfuscation settings unless an insights-client on the host overrides the settings with its own configuration.
Obfuscation only works when Minimal data collection is disabled. If Minimal data collection is enabled, hostnames and IP addresses are not included in reports, making obfuscation unnecessary and inactive.
  • Your hosts have insights-client installed and configured.
  2. Enable the Obfuscate host names setting to obfuscate host names sent to the Red Hat Hybrid Cloud Console.
  3. Enable the Obfuscate host ipv4 addresses setting to obfuscate IPv4 addresses sent to the Red Hat Hybrid Cloud Console.
  2. In the Organization dropdown menu, select the organization that uploaded the host data.
  3. Click Generate report to create a fresh report with obfuscated data.
  4. Click Download report to download the host inventory report.
  5. Verify that the hostname is randomhostname.example.com and the IP address is obfuscated.
Next steps
  • Click Generate and upload report to create and upload a new report with obfuscated data to the Red Hat Hybrid Cloud Console.
10.3.3. Removing hosts from the Insights Inventory
When hosts are removed from Foreman, they can also be removed from the inventory of Insights, either automatically or manually. You can configure automatic removal of hosts from the Insights Inventory during Red Hat Hybrid Cloud Console synchronization with Foreman that occurs daily by default.
If you leave the setting disabled, you can still remove the bulk of hosts from the Inventory manually.
If Automatic mismatch deletion is enabled, Foreman removes any hosts from the Red Hat Hybrid Cloud Console that are not registered in Foreman. Enable this setting only when all hosts are registered through Foreman. If any hosts are registered through other Foreman instances or directly to the Red Hat Hybrid Cloud Console, Foreman deletes them.
Automatic mismatch deletion runs once a day as a scheduled task. After removing hosts from Foreman, hosts are deleted from the Red Hat Hybrid Cloud Console inventory during the next scheduled sync. Clicking Sync all inventory status updates the status of hosts but does not trigger immediate deletion.
  • Your Foreman account has a role that grants the view_foreman_rh_cloud and edit_settings permissions.
  2. Enable the Automatic mismatch deletion setting.
10.4. Disabling hosted Insights
If you do not want to use the hosted Insights services in the Red Hat Hybrid Cloud Console, you can disable the integration between Foreman and the Red Hat Hybrid Cloud Console.
  • The Red Hat Cloud plugin is installed on Foreman server.
  1. Uninstall the Red Hat Cloud plugin on Foreman server:
    # foreman-installer --no-enable-foreman-plugin-rh-cloud
  2. Remove the Red Hat Cloud package and its dependencies from Foreman server:
    # dnf remove rubygem-foreman_rh_cloud
  3. Restart the Foreman services:
  2. On the Plugins tab, verify that it does not list the foreman_rh_cloud plugin.
11. Reducing storage use on Foreman server
Foreman server can accumulate a large amount of data over time, which can use a significant amount of disk space. You can clean up database records or reclaim disk space to reduce storage use.
11.1. Cleaning audit records
Audit records log changes that users make to Foreman resources, such as creating hosts or editing settings. You can clean up outdated audit records by deleting them.
11.1.1. Deleting audit records manually
11.1.2. Deleting audit records automatically
11.2. Cleaning report records
Report records are configuration reports that hosts send to Foreman after Puppet, Ansible, or Salt runs. Clean up outdated reports to reduce database growth and storage use.
11.2.1. Deleting report records
Foreman creates report records automatically. To remove old and unnecessary report records, you can delete them. This is useful for maintaining a clean and organized report history.
  • Use the foreman-rake reports:expire command to remove reports at any time. You can also use a cron job to schedule report record deletions at the set interval that you want.
    For example, you can delete report records that are older than seven days:
11.3. Cleaning task records
Task records track background jobs that Foreman executes, such as synchronizing repositories. Configure automatic cleanup or manually clean up outdated tasks to save database space.
11.3.1. Configuring the cleaning unused tasks feature
Foreman automatically cleans up old tasks. You can configure the automatic cleaning process according to your needs.
11.3.2. Deleting task records
Foreman creates task records automatically. To remove old and unnecessary task records, you can delete them. This helps maintain system performance and keeps your task history organized.
  • Use the foreman-rake foreman_tasks:cleanup command to remove tasks at any time. You can also use a cron job to schedule Task record deletions at the set interval that you want.
    For example, you can delete task records from successful repository synchronizations:
11.3.3. Deleting a task by ID
  2. Optional: View the task:
  3. Delete the task:
11.4. Reclaiming disk space
Foreman can consume a significant amount of disk space, especially in large deployments. By reclaiming disk space, you can reduce the amount of disk space used by Foreman.
11.4.1. Recovering from a full disk
If a logical volume (LV) with the Pulp database on it is full, Pulp tasks can fail due to insufficient space. You can recover from the situation by increasing the amount of free space available on the LV.
    1. Remove orphaned content:
    3. Grow the file system on the LV with the /var/lib/pulp directory on it. For more information, see Growing a logical volume and file system in Red Hat Enterprise Linux 9 Configuring and managing logical volumes.
      1. Stop Foreman services:
      3. Start Foreman services:
11.4.2. Reclaiming PostgreSQL space
If the PostgreSQL database is using a large amount of disk space, you can reclaim space by vacuuming the database. By reclaiming PostgreSQL space, you can reduce the amount of disk space used by Foreman.
11.4.3. Reclaiming space from on-demand repositories
Space reclamation requires an existing repository. For deleted repositories, wait for the next scheduled orphan cleanup or remove orphaned content manually:
  1. If you want to reclaim space for a single repository:
    2. Select a product.
    3. On the Repositories tab, click the repository name.
    4. From the Select Actions list, select Reclaim Space.
  2. If you want to reclaim space for multiple repositories:
    2. Select the product name.
    3. On the Repositories tab, select the checkbox of the repositories.
    4. Click Reclaim Space at the top right corner.
  3. If you want to reclaim space for Smart Proxies:
    2. Select the Smart Proxy server.
    3. Click Reclaim space.
12. Renewing certificates
You can renew the CA certificate on Foreman server or the SSL certificate on Foreman server as well as on Smart Proxy server.
12.1. Planning for self-signed CA certificate renewal
If you need to update the Certification Authority (CA) certificate on your Foreman server, add the new CA certificate and use a temporary dual CA certificate file to retain the HTTPS connections to your Foreman server during the renewal.
  1. Add the new SSL certificate to the CA certificate file on Foreman server and keep the old SSL certificate.
  2. Renew the certificates on Foreman server and any Smart Proxy servers.
  3. Deploy the dual CA certificate on hosts.
  4. Remove the old certificate from the CA certificates file on Foreman server, so the CA certificate file contains only the new SSL certificate.
  5. Renew the certificates on Foreman server and any Smart Proxy servers.
  6. Deploy the new CA certificate on hosts.
12.2. Renewing a SSL certificate on Foreman server
You can deploy a renewed SSL certificate on Foreman server to replace an expiring certificate and maintain trusted access to the Foreman web UI and API.
  • You have created a new Certificate Signing Request (CSR) and sent it to the Certificate Authority to sign the certificate. Refer to the Configuring Foreman server with a custom SSL certificate guide before creating a new CSR because the Server certificate must have X.509 v3 Key Usage and Extended Key Usage extensions with required values. In return, you will receive the Foreman server certificate and CA bundle.
  • Deploy the renewed CA certificates to Foreman server:
    # foreman-installer --scenario katello \
    --certs-server-cert "/root/foreman_cert/foreman_cert.pem" \
    --certs-server-key "/root/foreman_cert/foreman_cert_key.pem" \
    --certs-server-ca-cert "/root/foreman_cert/ca_cert_bundle.pem" \
    --certs-update-server \
    --certs-update-server-ca
    Do not delete the certificate files after you deploy the certificate. They are required when upgrading Foreman server.
  1. Access the Foreman web UI from your local machine. For example, https://foreman.example.com.
  2. In your browser, view the certificate details to verify the deployed certificate.
Next steps
12.3. Renewing a SSL certificate on Smart Proxy server
You can deploy a renewed SSL certificate on each Smart Proxy server before it expires to maintain secure communication with Foreman server. Run a unique foreman-installer command on each server because the output of foreman-proxy-certs-generate cannot be reused.
  • You have created a new Certificate Signing Request and sent it to the Certificate Authority to sign the certificate. Refer to the Configuring Foreman server with a custom SSL certificate guide before creating a new CSR because the Foreman server certificate must have X.509 v3 Key Usage and Extended Key Usage extensions with required values. In return, you will receive the Smart Proxy server certificate and CA bundle.
  1. On your Foreman server, generate the certificate archive file for your Smart Proxy server:
    --certs-tar "/root/My_Certificates/smartproxy.example.com-certs.tar" \
    --foreman-proxy-fqdn "smartproxy.example.com" \
    --server-ca-cert "/root/My_Certificates/ca_cert_bundle.pem" \
    --server-cert "/root/My_Certificates/smart-proxy_cert.pem" \
    --server-key "/root/My_Certificates/smart-proxy_cert_key.pem"
  2. On your Foreman server, copy the certificate archive file to your Smart Proxy server:
  3. Retain a copy of the foreman-installer command that the foreman-proxy-certs-generate command returns for deploying the certificate to your Smart Proxy server.
  4. Deploy the certificate on your Smart Proxy server using the foreman-installer command returned by the foreman-proxy-certs-generate command:
    # foreman-installer --scenario foreman-proxy-content \
    --certs-tar-file "/root/My_Certificates/smartproxy.example.com-certs.tar" \
    --foreman-proxy-foreman-base-url "https://foreman.example.com"
    Do not delete the certificate archive file on the Smart Proxy server after you deploy the certificate. They are required when upgrading Smart Proxy server.
Next steps
13. Synchronizing template repositories
You can synchronize repositories of job templates, provisioning templates, report templates, and partition table templates between Foreman server and a version control system or local directory. You can use the Template Sync plugin to export and import templates.
13.1. Enabling the Template Sync plugin
You can enable the Template Sync plugin to synchronize provisioning templates, report templates, and other templates between your Foreman server and a version control system or local directory. This is useful when you want to manage templates in Git repositories or keep templates synchronized across multiple Foreman instances.
  1. Enable the plugin on your Foreman server:
  2. Optional: Enable the Hammer CLI plugin on your Foreman server:
  2. On the Plugins tab, ensure that the page includes the Template Sync plugin.
Next steps
  1. In the Foreman web UI, navigate to Administer > Settings > Template Sync to configure the plugin. For more information, see Template sync settings.
13.2. Synchronizing templates with an existing repository
If you store templates in a repository under a version control system, you can synchronize the templates between your Foreman server and the repository.
  1. If you want to use HTTPS to connect to the repository and you use a self-signed certificate authority (CA) on your Git server:
    1. Create a new directory under the /usr/share/foreman/ directory to store the Git configuration for the certificate:
      # mkdir --parents /usr/share/foreman/.config/git
    2. Create a file named config in the new directory:
      # touch /usr/share/foreman/.config/git/config
    3. Allow the foreman user access to the .config directory:
      # chown --recursive foreman /usr/share/foreman/.config
    4. Update the Git global configuration for the foreman user with the path to your self-signed CA certificate:
      # sudo --user foreman git config --global http.sslCAPath Path_To_CA_Certificate
  2. If you want to use SSH to connect to the repository:
    1. Create an SSH key pair if you do not already have it. Do not specify a passphrase.
    2. Configure your version control server with the public key from your Foreman, which resides in /usr/share/foreman/.ssh/id_rsa.pub.
    3. Accept the Git SSH host key as the foreman user:
      # sudo --user foreman ssh git.example.com
  3. In the Foreman web UI, provide details for your Git repository:
    1. Navigate to Administer > Settings.
    2. Click the Template Sync tab.
    3. Change the Branch setting to define the target branch of the repository.
    4. Change the Repo setting to define the repository URL.
    5. If you want to use an HTTP proxy to connect to the repository, change the HTTP proxy policy setting to Global default HTTP proxy or Custom HTTP proxy.
Next steps
  • Import templates from your repository or export templates to your repository.
13.3. Synchronizing templates with a local directory
If you store templates in a local directory that is tracked under a version control system, you can synchronize the templates between your Foreman server and the local directory.
  • Each template must contain the location and organization that the template belongs to. This applies to all template types. Before you import a template, ensure that you add the following section to the template:
    kind: provision
    oses:
    - My_first_Operating_System
    - My_second_Operating_System
    locations:
    - My_first_Location
    - My_second_Location
    organizations:
    - My_first_Organization
    - My_second_Organization
  1. On your Foreman server, in /var/lib/foreman, create a directory for storing templates:
    # mkdir /var/lib/foreman/My_Templates_Dir
    You can place your templates to a custom directory outside /var/lib/foreman, but you have to ensure that the Foreman service can read its contents. The directory must have the correct file permissions and the foreman_lib_t SELinux label.
  2. Change the owner of the new templates directory to the foreman user:
    # chown foreman /var/lib/foreman/My_Templates_Dir
  3. Change the Repo setting on the Template Sync tab to match the /var/lib/foreman/My_Templates_Dir/ directory.
13.4. Importing templates by using Foreman web UI
You can import templates from a repository of your choice from the Foreman web UI. You can use different protocols to point to your repository, for example /tmp/dir, git://example.com, https://example.com, and ssh://example.com.
The templates provided by Foreman are locked and you cannot import them by default. To overwrite this behavior, change the Force import setting in the Template Sync menu to yes or add the force parameter -d '{ "force": "true" }' to the import command.
  • Before you import a template, ensure that you add the following section to the template:
    kind: provision
    oses:
    locations:
    - My_first_Location
    organizations:
  1. In the Foreman web UI, navigate to Hosts > Templates > Sync Templates.
  2. Click Import.
  3. Each field is populated with values configured in Administer > Settings > Template Sync. Change the values as required for the templates you want to import. For more information about each field, see Template sync settings.
  4. Click Submit.
13.5. Importing templates by using Hammer CLI
You can import templates from a repository of your choice by using Hammer CLI. You can use different protocols to point to your repository, for example /tmp/dir, git://example.com, https://example.com, and ssh://example.com.
    kind: provision
    oses:
    locations:
    - My_first_Location
    organizations:
  • Import a template from a repository:
    $ hammer import-templates \
    --branch "My_Branch" \
    --filter '.*Template Name$' \
    --prefix "[Custom Index] " \
    --repo "https://git.example.com/path/to/repository"
    For better indexing and management of your templates, use --prefix to set a category for your templates. To select certain templates from a large repository, use --filter to define the title of the templates that you want to import. For example --filter '.*Ansible Default$' imports various Ansible Default templates.
13.6. Importing templates by using Foreman API
You can import templates from a repository of your choice by using Foreman API. You can use different protocols to point to your repository, for example /tmp/dir, git://example.com, https://example.com, and ssh://example.com.
    kind: provision
    oses:
    locations:
    - My_first_Location
    organizations:
  • Send a POST request to api/v2/templates/import:
    # curl -H "Accept:application/json" \
    -H "Content-Type:application/json" \
    -u login:password \
    -k https://foreman.example.com/api/v2/templates/import \
    -X POST
    If the import is successful, you receive {"message":"Success"}.
13.7. Importing templates using Ansible
You can import templates from a repository of your choice. You can use different protocols to point to your repository, for example /tmp/dir, git://example.com, https://example.com, and ssh://example.com.
  • Use the theforeman.foreman.templates_import module.
13.8. Exporting templates by using Foreman web UI
You can export templates to an existing repository from the Foreman web UI. This is useful for backing up customized templates and keeping them synchronized with your version control system.
  2. Click Export.
  3. Each field is populated with values configured in Administer > Settings > Template Sync. Change the values as required for the templates you want to export. For more information about each field, see Template sync settings.
  4. Click Submit.
13.9. Exporting templates by using Hammer CLI
You can export templates to an existing repository by using Hammer CLI. This is useful for backing up customized templates and keeping them synchronized with your version control system.
  • Export all templates to a repository:
    $ hammer export-templates \
    This command clones the repository, makes changes in a commit, and pushes back to the repository. You can use the --branch "My_Branch" option to export the templates to a specific branch.
13.10. Exporting templates by using Foreman API
You can export templates to an existing repository by using Foreman API. This is useful for backing up customized templates and keeping them synchronized with your version control system.
  1. Send a POST request to api/v2/templates/export:
    -u login:password \
    -k https://foreman.example.com/api/v2/templates/export \
    -X POST
    If the export is successful, you receive {"message":"Success"}.
    You can override default API settings by specifying them in the request with the -d parameter. The following example exports templates to the git.example.com/templates repository:
    -u login:password \
    -X POST \
    -d "{\"repo\":\"git.example.com/templates\"}"
13.11. Uninstalling the Foreman templates plugin
  1. Disable the plugin using the Foreman installer:
  2. Clean custom data of the plugin. The command does not affect any templates that you created.
  3. Uninstall the plugin:
14. Monitoring Foreman resources
You can use Foreman web UI to monitor your Foreman environment and hosts. This includes details of hosts, such as configuration or compliance, and information about content and Smart Proxies.
14.1. Using the Foreman content dashboard
The Foreman content dashboard contains various widgets. Use the dashboard to get a quick overview of the resources currently in use in Foreman.
Host Configuration Status
Table 5. Host configuration states
Icon State Description
host state config okay
host state config error
Hosts in error state
host state config report
host state config pending
host state config outofsync
Out of sync hosts
host state config noreport
Hosts with no reports
host state config noalert
Hosts with alerts disabled
Host Configuration Chart
Latest Events
New Hosts
Task Status
Latest Warning/Error Tasks
Discovered Hosts
Latest Errata
Content Views
Sync Overview
Host Collections
Virt-who Configuration Status
Table 6. virt-who configuration states
State Description
No Reports
No Change
OK
Total Configurations
Latest Compliance Reports
Compliance Reports Breakdown
Insights Actions
Insights Risk Summary
14.2. Foreman task management
You can monitor and manage all planned or performed tasks, such as repositories synchronized, errata applied, and content views published. This is useful to track progress, troubleshoot issues, or adjust timeout settings for low bandwidth or high latency environments.
Reviewing the log
Adjusting timeout settings
Disabling checking for services
  5. Click Save.
14.3. Configuring RSS notifications
You can configure custom RSS feed notifications to receive event alerts from your preferred sources, such as project blogs or internal news feeds, instead of the default notification sources.
14.4. Monitoring Foreman server
Audit records list the changes made by all users on Foreman. You can use this information for maintenance and troubleshooting.
  2. Obtain a list of all audit attributes:
14.5. Monitoring Smart Proxy server
In the Foreman web UI, you can find various information about Smart Proxy server and its services. This information is useful to maintain Smart Proxy server and troubleshoot any issues.
14.5.1. Viewing general Smart Proxy information
You can view general information about your Smart Proxies in the Foreman web UI, such as their status, enabled features, and managed hosts, to verify configuration or troubleshoot connectivity issues.
In the Features column, you can verify if, for example, your Smart Proxy provides a DHCP service or acts as a Pulp mirror. Smart Proxy features can be enabled during installation or configured in addition. For more information, see Installing Smart Proxy server.
14.5.2. Monitoring Smart Proxy services
You can view the status and configuration details of Smart Proxy services in Foreman web UI. This helps you verify that your Smart Proxy services are running correctly and troubleshoot any issues.
  • In the Foreman web UI, navigate to Infrastructure > Smart Proxies and click the name of the selected Smart Proxy.
    • At the Services tab, you can find basic information on Smart Proxy services, such as the list of DNS domains, or the number of Pulp workers.
      The appearance of the page depends on what services are enabled on Smart Proxy server. Services providing more detailed status information can have dedicated tabs at the Smart Proxy page. For more information, see Monitoring Puppet on Smart Proxy.
14.5.3. Monitoring Puppet on Smart Proxy
You can monitor Puppet activity and certificate management for each Smart Proxy.
  2. Click the name of your Smart Proxy.
    • At the Puppet tab you can find the following:
    • At the Puppet CA tab you can find the following:
15. Limiting host resources
You can use the Resource Quota plugin to limit users' access to host resources during host provisioning. Each host is assigned to exactly one resource quota. By default, Foreman assigns the Unassigned resource quota to hosts during global registration. This means that the host is not assigned to a specific pool of resources.
Supported resource types
  • CPU cores
  • Memory
  • Disk space
Supported compute resources
  • VMware
  • libvirt
15.1. Installing the Resource Quota plugin
  1. Install the plugin on your Foreman server:
  2. Optional: Install the Hammer CLI plugin on your Foreman server:
15.2. Managing resource quotas
15.2.1. Creating a resource quota by using Foreman web UI
Create a resource quota to limit the resource consumption of Foreman users by using the Foreman web UI.
  1. In the Foreman web UI, navigate to Configure > Resource Quotas.
  2. Click Create resource quota.
  3. Specify the name, CPU cores, memory, and disk space.
  4. Click Create resource quota to submit the resource quota to Foreman.
15.2.2. Creating a resource quota by using Hammer CLI
Create a resource quota to limit the resource consumption of Foreman users by using Hammer CLI.
  • Create a resource quota:
    $ hammer resource-quota create \
    --cpu-cores My_CPU_Cores \
    --description My_Resource_Quota_Description \
    --disk-space My_Disk_Space_in_GiB \
    --memory My_Memory_in_MiB \
    --name "My_Resource_Quota_Name"
    For all options, see hammer resource-quota create --help.
15.2.3. Editing a resource quota by using Foreman web UI
You can edit a resource quota to adjust available resources to Foreman users by using Foreman web UI.
  2. Select your resource quota.
  3. Adjust the CPU cores, Memory, or Disk space and click Apply to submit your changes to Foreman.
15.2.4. Editing a resource quota by using Hammer CLI
You can edit a resource quota to adjust available resources to Foreman users by using Hammer CLI.
  1. Optional: List all resource quotas:
  2. Edit a resource quota:
    $ hammer resource-quota update \
    --id My_Resource_Quota_ID \
    If you set the value to 0, users cannot consume any resource at all. To reset resource quotas, you can use --remove-cpu-cores-limit, --remove-disk-space-limit, and --remove-memory-limit.
    For all options, see hammer resource-quota update --help.
15.2.5. Deleting a resource quota by using Foreman web UI
You can delete a resource quota from Foreman by using Foreman web UI.
  2. In the Actions column, click Delete for your resource quota.
15.2.6. Deleting a resource quota by using Hammer CLI
You can delete a resource quota from Foreman by using Hammer CLI.
  2. Delete a resource quota:
    For all options, see hammer resource-quota delete --help.
15.3. Assigning resource quotas to users
You can assign resource quotas to users or user groups. A user can select one of their assigned resource quotas during host provisioning. If Resource Quota optional assignment is set to No, a user does not have to assign a resource quota. You can use the resource_quota filter in the Foreman web UI to view users or user groups with assigned resource quotas.
15.3.1. Assigning resource quotas to a user by using Foreman web UI
You can assign resource quotas to a user to limit the resource consumption of that Foreman user by using Foreman web UI.
  2. Select a user.
  3. On the Resource Quota tab, assign resource quotas to the user.
  4. If you want to make the usage of resource quotas optional, select the Optional Assignment checkbox.
  5. Click Submit to assign resource quotas to a user.
15.3.2. Assigning resource quotas to a user by using Hammer CLI
You can assign resource quotas to a user to limit the resource consumption of that Foreman user by using Hammer CLI
  1. Optional: List all Foreman users:
  2. Optional: List all resource quotas:
  3. Assign resource quotas to a user:
    $ hammer user update \
    --id My_User_ID \
    --resource-quota-ids My_Resource_Quota_IDs
    If you want to make resource quota optional, add the --resource-quota-is-optional true option.
    For all options, see hammer user update --help.
15.3.3. Assigning resource quotas to a user group by using Foreman web UI
You can assign resource quotas to a user group to limit the resource consumption of that Foreman user group. All users of the user group share the pool of resources.
  2. On the Resource Quota tab, assign resource quotas to the user group.
  3. Click Submit to assign resource quotas to a user group.
15.3.4. Assigning resource quotas to a user group by using Hammer CLI
You can assign resource quotas to a user group to limit the resource consumption of that Foreman user group by using Hammer CLI. All users of the user group share the pool of resources.
  1. Optional: List all Foreman user groups:
  3. Assign resource quotas to a user group:
    $ hammer user-group update \
    --id My_User_Group_ID \
    For all options, see hammer user-group update --help.
15.4. Viewing resource quotas by using Foreman web UI
You can use Foreman web UI to view the resource quota of hosts.
  2. In the search bar, filter your hosts. For example, resource_quota = Unassigned.
    For more information, see Working efficiently with Foreman web UI.
15.5. Viewing resource quotas by using Hammer CLI
  1. Optional: Retrieve the ID of your host:
    $ hammer host list
  2. Display the resource quota assigned to your host:
    $ hammer host info \
    --fields "Id,Name,Resource quota id" \
    --id My_Host_ID
15.6. Resource Quota settings
16. Using webhooks in Foreman
16.1. Webhook behavior and integration
You can use webhooks as a way to integrate Foreman with external systems. For example, webhooks can integrate with monitoring systems to send alerts when a host is created or deleted.
Because webhooks use HTTP, no new infrastructure needs be added to existing web services. Webhooks are useful where the action you want to perform in the external system can be achieved through its API.
Where it is necessary to run additional commands or edit files, the shellhooks plugin for Smart Proxies is available. The shellhooks plugin enables you to define a shell script on the Smart Proxy that can be executed through the API.
16.2. Installing the webhooks plugin
  1. On your Foreman server, install the webhooks plugin:
  2. Optional: Install the webhooks CLI plugin:
16.3. Creating a webhook template
Webhook templates are used to generate the body of HTTP request to a configured target when a webhook is triggered. You can create a webhook template in the Foreman web UI.
    For more information, see Template Writing Reference in Managing hosts and for available template macros and methods, visit /templates_doc on Foreman server.
  7. Click Submit.
Example 3. Creating a webhook template
Running remote execution jobs
Creating users
16.4. Creating a webhook
When creating a webhook in the Foreman web UI, you can customize events, payloads, HTTP authentication, content type, and headers.
When configuring webhooks with endpoints with non-standard HTTP or HTTPS ports, an SELinux port must be assigned, see Configuring SELinux to ensure access to Foreman on custom ports in Installing Foreman Server with Katello 4.19 plugin on Enterprise Linux.
  2. Click Create new.
  7. Enter an HTTP method.
  9. Click the Credentials tab.
Review the webhook events that are available from the Foreman web UI.
A content view was successfully promoted.
Run OpenSCAP scan.
Runs an Ansible Playbook containing all the roles defined for a host.
Run an Ansible Playbook against given hosts.
Run an Ansible Playbook to enable the web console on given hosts.
Perform a single Puppet run.
Build Entered
Build Exited
Common database operations on a content view.
Domain
Host
Hostgroup
Model
Status Changed
Subnet
Template Render Performed
Template
User
16.6. Shellhooks plugin for Smart Proxy
With webhooks, you can only map one Foreman event to one API call. For advanced integrations, where a single shell script can contain multiple commands, you can install a Smart Proxy shellhooks plugin that exposes executables by using a REST HTTP API.
You can then configure a webhook to reach out to a Smart Proxy API to run a predefined shellhook. A shellhook is an executable script that can be written in any language provided that it can be executed. The shellhook can for example contain commands or edit files.
You can pass input to shellhook script through the webhook payload. This input is redirected to standard input of the shellhook script. You can pass arguments to shellhook script by using HTTP headers in format X-Shellhook-Arg-1 to X-Shellhook-Arg-99.
The HTTP method must be POST. An example URL would be: https://smartproxy.example.com:9090/shellhook/My_Script.
16.7. Installing the shellhooks plugin
Optionally, you can install and enable the shellhooks plugin on each Smart Proxy used for shellhooks.
  • Install the shellhooks plugin on your Smart Proxy:
16.8. Passing arguments to shellhook script using webhooks
You can pass dynamic values from a webhook event to a shellhook script by configuring HTTP headers when you create the webhook. This enables your script to use event-specific data such as object IDs or names without parsing the webhook payload.
      "X-Shellhook-Arg-1": "VALUE",
      "X-Shellhook-Arg-2": "VALUE"
Example 4. Passing arguments to shellhook script using webhooks
16.9. Passing arguments to shellhook script using curl
You can pass custom values to a shellhook script by using a curl request. Use this when you need to test a script manually or call it directly, rather than through webhook automation.
    "X-Shellhook-Arg-1: VALUE"
    "X-Shellhook-Arg-2: VALUE"
Example 5. Passing arguments to shellhook script using curl
$ curl \
--data "" \
--header "Content-Type: text/plain" \
--header "X-Shellhook-Arg-1: Version 1.0" \
--header "X-Shellhook-Arg-2: My content view" \
--request POST \
--show-error \
--silent \
16.10. Creating a shellhook to print arguments
    #!/bin/sh
    echo "$@" >&2
  2. In the Foreman web UI, navigate to Administer > Webhook > Webhooks.
  3. Click Create new.
  6. In the Target URL field, enter the URL of your Smart Proxy server followed by :9090/shellhook/print_args:
    https://smartproxy.example.com:9090/shellhook/print_args
        "X-Shellhook-Arg-1": "Hello",
        "X-Shellhook-Arg-2": "World!"
  1. Run a remote execution job on any host. You can use time as a command. For more information, see Configuring and setting up remote jobs in Managing hosts.
    [W] [3520] Hello World!
17. Working efficiently with Foreman web UI
The Foreman web UI includes search, bookmarking, keyboard shortcuts, and various settings to help you work more efficiently.
17.1. Efficiency tips for Foreman web UI
Use these keyboard shortcuts and techniques to navigate and search more efficiently in the Foreman web UI.
Ctrl + Shift + F focuses the vertical navigation search bar
After pressing this shortcut, you can start typing in the vertical navigation search bar.
/ focuses the page search bar
After pressing this shortcut, you can start typing in the page search bar.
Saving searches as bookmarks
You can save a search you frequently use as a bookmark. After entering your search query in the search field, click the arrow next to the Search button and select Bookmark this search. You can then give the bookmark a name and choose whether to make it public or private.
To manage all bookmarks, navigate to Administer > Bookmarks.
Compact table mode
Navigate to the user menu in the top bar and select My account. Under the UI Preferences tab, you can enable compact table mode. With compact table mode enabled, Foreman web UI displays table rows with less space between items.
Instance title setting
If you have multiple Foreman instances, you can configure Foreman web UI to always show a banner with the instance title in the top bar to help you identify which instance you are currently using. To set an instance title, navigate to Administer > Settings, and edit the Instance title setting on the General tab. To set a color for the instance title banner, edit the Instance color setting.
17.2. Foreman web UI search query reference
Use search query syntax and operators in the Foreman web UI to filter lists of resources on Foreman web UI pages. Parameter-based queries help you find the resources you need faster and more precisely than free-text search in large inventories.
Search queries in the page search bar follow the pattern:
parameter operator value
To search text with whitespaces, enclose it in quotes:
hostgroup = "Web Servers"
Typing without specifying a parameter searches across multiple fields simultaneously, also known as free-text search. For example, typing 64 in the search bar on the hosts page displays all hosts that have 64 in their name, IP address, MAC address, and architecture.
Free text search is slower and less accurate than parameter-based queries. Use specific parameters whenever possible for better performance and precision.
The search bar supports multiple date and time formats, including the following:
  • "10 January 2017"
  • "10 Jan 2017"
  • 10-January-2017
  • 10/January/2017
  • "January 10, 2017"
  • Today, yesterday, and similar keywords
Table 7. Comparison operators accepted by search
Operator Short Name Description
EQUALS
NOT EQUALS
LIKE
Accepts text or temporal values. The search is not case-sensitive. Accepts the following wildcards: _ for a single character, % or * for any number of characters including zero. If no wildcard is specified, the string is treated as if surrounded by wildcards: %rhel7%
NOT LIKE
GREATER THAN
LESS THAN
IN
NOT IN
HAS or set?
NOT HAS or null?
Table 8. Logical operators accepted by search
Operator Alternative Notations
and
<whitespace>
or
not
17.3. Useful search examples
The following examples demonstrate useful ways to filter and find resources in Foreman web UI. Use them as starting points to build your own searches that match your specific needs.
These search examples show how to filter hosts and are based on host attribute search parameters. You can use them on Foreman web UI pages that list hosts, such as Hosts > All Hosts. You can apply the same syntax to filter other resources on other Foreman web UI pages.
Find hosts by host global status and sub-status
Hosts that have an OK global status:
global_status = ok
Hosts that have an Error or Warning global status:
global_status = error or global_status = warning
Hosts that have at least one pending resource:
status.pending > 0
Hosts that restarted some service during last run:
status.restarted > 0
Hosts that have an interesting last run that might indicate something has happened:
status.interesting = true
Find hosts that need attention
Hosts with security updates available:
errata_status = security_needed
Hosts that have email notifications for configuration errors enabled and are in a failed state:
status.enabled = true AND status.failed = true
Hosts that have not generated a report recently:
last_report < "7 days ago"
Find hosts by configuration, environment, or registration date
Hosts in production that belong to a host group whose name includes a variation of the word "webservers":
environment = production AND hostgroup ~ webservers
Hosts registered in the last month:
registered_at > "30 days ago"
Hosts registered between specific dates:
registered_at > 1-January-2026 AND registered_at < 31-January-2026
Exclude specific results
All hosts except hosts in a host group named "exceptions":
NOT hostgroup = exceptions
Hosts that are not compliant with policies:
compliance_status != compliant
This search query requires the OpenSCAP plugin.
Use wildcards for flexible matching
Hosts with names that include the strings "web" and "prod":
name ~ web*prod*
Host groups starting with a specific prefix:
hostgroup ~ rhel%
Appendix A: Starting and stopping Foreman services
Foreman provides the foreman-maintain service command to manage Foreman services from the command line.
Appendix B: Logging and reporting problems
Review the most commonly used log files and debugging tools available in Foreman.
B.1. Configuring logging levels with Hammer CLI
You can use Hammer to log debugging information for various Foreman components. The default logging level is INFO.
  • To list the components whose logging level you can change by using hammer:
    $ hammer admin logging --list
  • To set DEBUG level logging for all components:
    $ hammer admin logging --all --level-debug
  • To set PRODUCTION level logging for all components:
    $ hammer admin logging --all --level-production
  • To set DEBUG level logging for a specific component:
    $ hammer admin logging --components My_Component --level-debug
  • To list all available logging options:
    $ hammer admin logging --help
B.2. Configuring logging type and layout
By default, Foreman uses file-based logging. You can use foreman-installer to change the logging type and logging layout.
  1. To use the journald service for logging:
    1. Change the logging type to journald:
      # foreman-installer \
      --foreman-proxy-log JOURNAL
    2. Inspect the log messages by using the journalctl utility. For example:
  2. To use file-based logging:
    1. Change the logging type to file-based:
      --reset-foreman-proxy-log
    2. Inspect the log messages by viewing these files:
      • /var/log/foreman-proxy.log
  3. To use JSON output:
    1. Change the logging layout to JSON:
      --foreman-logging-layout json \
      --foreman-logging-type file
    2. Inspect the log messages by using jq:
      # cat /var/log/foreman/production.log | jq
B.3. Enabling individual loggers for selective debugging
You can enable individual loggers to collect detailed diagnostics for specific Foreman components when you troubleshoot integration or performance issues, without increasing the global logging level.
    --foreman-loggers ldap:true \
    --foreman-loggers sql:true
B.4. Overview of individual loggers
Review selected loggers and their default values. You can find the complete list of loggers with their default values in /usr/share/foreman/config/application.rb under Foreman::Logging.add_loggers.
app
Default value: true.
audit
background
blob
dynflow
ldap
Default value: false.
notifications
permissions
sql
telemetry
templates
B.5. Retrieving the status of services by using Hammer CLI
    $ hammer ping
  • Perform a health check:
B.6. Restarting Foreman services
  • Restart Foreman services:
B.7. Utilities for processing log information
sosreport
The sos report command collects configuration and diagnostic information from a Linux system, such as the running kernel version, loaded modules, running services, and system and service configuration files. Additionally, it collects information about Foreman, such as its back-end services and tasks. This output is stored in a tar file located at /var/tmp/sosreport-XXX-20171002230919.tar.xz.
For more information, run sos report --help or see SOS user documentation.
The sos report command removes security information such as passwords, tokens, and keys while collecting information. However, the tar files can still contain sensitive information about the Foreman server. Send the tar files directly to the intended recipient and not to a public target.
foreman-tail
B.8. Log file directories
The following table provides an overview of selected log directories on Foreman server.
/var/log/candlepin/
Subscription management
/var/log/foreman-installer/
Installer
/var/log/foreman-maintain/
Foreman maintain
Foreman proxy
/var/log/foreman/
Foreman
/var/log/httpd/
Apache HTTP server
/var/log/messages/
Various other log messages
/var/log/puppetlabs/puppet/
Puppet
/var/log/tomcat/
Candlepin web service logs
B.9. System journal metadata
The journald service uses metadata fields to filter logs. You can use these fields to filter logs when troubleshooting.
AUDIT_ACTION
Audit action performed
AUDIT_TYPE
Audit resource type
AUDIT_ID
AUDIT_ATTRIBUTE
AUDIT_FIELD_OLD
AUDIT_FIELD_NEW
AUDIT_ID
AUDIT_ATTRIBUTE
Example: Name or description
EXCEPTION_MESSAGE
EXCEPTION_CLASS
EXCEPTION_BACKTRACE
LOC_ID
Location database ID
LOC_NAME
Location name
LOC_LABEL
Location label
LOGGER
Logger name
ORG_ID
Organization database ID
ORG_NAME
Organization name
ORG_LABEL
Organization label
REMOTE_IP
Remote IP address of a client
REQUEST
SESSION
TEMPLATE_NAME
Template name
TEMPLATE_DIGEST
TEMPLATE_HOST_NAME
TEMPLATE_HOST_ID
USER_LOGIN
User login name
Appendix C: Increasing logging levels of Foreman components
Foreman components use configurable logging levels to record operational events. Increase the level to debug when you need detailed output to troubleshoot a specific service.
C.1. Increasing the logging level for Foreman
Increase Foreman logging to debug to capture detailed Foreman activity when diagnosing application or API issues. Reset the level when debugging is complete to avoid excessive log volume.
By default, Foreman writes logs to /var/log/foreman/production.log. For more information, see Configuring logging type and layout.
C.2. Increasing the logging level for Hammer
Increase Hammer logging to debug to capture detailed CLI activity when troubleshooting command-line errors or API responses.
Hammer writes logs to ~/.hammer/log/hammer.log.
    :log_level: 'debug'
C.3. Increasing the logging level for Smart Proxy
Increase Smart Proxy logging to debug to capture detailed Smart Proxy activity when troubleshooting communication between Foreman and hosts. Reset the level when debugging is complete to avoid excessive log volume.
By default, Smart Proxy writes logs to /var/log/foreman-proxy/proxy.log. For more information, see Configuring logging type and layout.
    # foreman-installer --foreman-proxy-log-level DEBUG
C.4. Increasing the logging level for Candlepin
Increase Candlepin logging to DEBUG when you need detailed subscription and content management diagnostics on your Foreman.
Candlepin writes logs to /var/log/candlepin/candlepin.log and /var/log/candlepin/error.log.
  1. Set the logging level to DEBUG:
    # foreman-installer --katello-candlepin-loggers log4j.logger.org.candlepin:DEBUG
    --katello-candlepin-loggers log4j.logger.org.candlepin:DEBUG \
    --katello-candlepin-loggers log4j.logger.org.candlepin.resource.ConsumerResource:WARN \
    --katello-candlepin-loggers log4j.logger.org.candlepin.resource.HypervisorResource:WARN
C.5. Increasing the logging level for Redis
Increase Redis logging to debug to capture detailed cache activity when troubleshooting performance or connectivity issues.
Redis writes logs to /var/log/redis/redis.log.
  1. In /etc/redis/redis.conf, set the logging level to debug:
    loglevel debug
  2. Restart the Redis service:
    # systemctl restart redis
C.6. Increasing the logging level for foreman-installer
Increase foreman-installer verbose output to debug when you need detailed installation and configuration diagnostics during setup or upgrades.
  • Increase the logging level of the foreman-installer utility:
C.7. Increasing the logging level for Pulp
Increase Pulp logging to DEBUG when you need detailed content repository diagnostics.
Pulp writes logs to the systemd journal. You can view them with journalctl --unit 'pulpcore*'.
  1. In /etc/pulp/settings.py, set the logging level to DEBUG:
  2. Restart the Pulp services:
    # systemctl restart \
    pulpcore-api \
    pulpcore-content \
    pulpcore-resource-manager \
    pulpcore-worker@\*
C.8. Increasing the logging level for OpenVox agent
Increase OpenVox agent logging to debug when you need detailed configuration application diagnostics on hosts.
OpenVox agent writes logs to /var/log/puppetlabs/puppet/.
  • Set the logging level to debug:
    # foreman-installer --puppet-agent-additional-settings log_level:debug
C.9. Increasing the logging level for OpenVox server
Increase OpenVox server logging to debug when you need detailed catalog compilation and agent communication diagnostics.
OpenVox server writes logs to /var/log/puppetlabs/puppetserver/.
    # foreman-installer --puppet-server-additional-settings log_level:debug
C.10. Increasing the logging level for Salt
Increase Salt Master or Minion logging to debug when you need detailed remote execution or state application diagnostics.
Salt Master writes logs to /var/log/salt/master and Salt Minions write logs to /var/log/salt/minion.
  • In /etc/salt/master or /etc/salt/minion, set the logging level to debug:
    log_level: debug
Appendix D: Anonymizing audit records
  • Use the foreman-rake audits:anonymize command to remove any user account or IP information while maintaining the audit records in the database. You can also use a cron job to schedule anonymizing the audit records at the set interval that you want.
    For example, you can anonymize audit records that are older than seven days:
Appendix E: Administration settings information
In the Foreman web UI, you can edit various settings to configure Foreman. You can find these settings by navigating to Administer > Settings.
E.1. General settings information
The general settings define system-wide configuration options for Foreman, including administrator email, instance URL, user interface preferences, HTTP proxy settings, and default language and time zone.
Administrator email address
Foreman URL
Entries per page
20
Fix DB cache
DB pending seed
Smart Proxy request timeout
60
Login page footer text
HTTP(S) proxy
HTTP(S) proxy except hosts
Show Experimental Labs
Display FQDN for hosts
If set to Yes, Foreman displays names of hosts as fully qualified domain names (FQDNs).
Out of sync interval
30
Hosts report periodically, and if the time between reports exceeds this duration in minutes, hosts are considered out of sync. You can override this on your hosts by adding the outofsync_interval parameter, per host, at Hosts > All Hosts > $host > Edit > Parameters > Add Parameter.
Foreman UUID
Default language
Default timezone
The time zone to use for new users.
Instance title
Saved audits interval
New host details UI
E.2. Background tasks settings
The tasks settings define how Foreman manages background tasks, including timeouts, retry behavior, batch processing, and debugging options for the Dynflow console.
Sync task timeout
120
Enable dynflow console
Enable the Dynflow console (/foreman_tasks/dynflow) for debugging.
The user must be authenticated as having administrative rights before accessing the Dynflow console.
Proxy action retry count
4
Proxy action retry interval
15
Allow proxy batch tasks
Proxy tasks batch size
100
Tasks troubleshooting URL
Polling intervals multiplier
1
E.3. Template sync settings
The template sync settings define how Foreman synchronizes templates with Git repositories, including import and export behavior, filtering, locking, and metadata handling.
Associate
Associate templates with operating system, organization, and location.
Branch
Default branch in Git repo.
Commit message
Dirname
Filter
Force import
HTTP proxy policy
Global default HTTP proxy
Whether to use an HTTP proxy to synchronize templates.
The Custom HTTP proxy value is available only if an HTTP proxy is configured under the selected organization and location and if your account has the view_http_proxies permission assigned.
Lock templates
Keep, do not lock new
Metadata export mode
Refresh
Default metadata export mode.
Possible options:
refresh re-renders metadata.
keep keeps existing metadata.
Negate
Prefix
Repo
/tmp/dir
git://example.com
https://example.com
ssh://example.com
Verbosity
E.4. Host Discovery settings
The Discovery settings define how Foreman handles discovered hosts, including default organization and location assignment, hostname generation, auto-provisioning behavior, and fact organization.
Discovery location
Discovery organization
Interface fact
discovery_bootif
Create bond interfaces
Clean all facts
Hostname facts
discovery_bootif
Auto provisioning
Reboot
Hostname prefix
mac
Fact columns
Highlighted facts
Storage facts
Software facts
Hardware facts
Network facts
IPMI facts
Lock PXE
Locked PXELinux template name
pxelinux_discovery
Locked PXEGrub2 template name
pxegrub2_discovery
Force DNS
Error on existing NIC
Do not permit to discover an existing host matching the MAC of a provisioning Network Interface Card (NIC) (errors out early).
Type of name generator
Fact + prefix
Prefer IPv6
E.5. Boot disk settings
iPXE directory
/usr/share/ipxe
ISOLINUX directory
/usr/share/syslinux
SYSLINUX directory
/usr/share/syslinux
Grub2 directory
/var/lib/tftpboot/grub2
Host image template
Boot disk iPXE - host
Generic image template
Boot disk iPXE - generic host
ISO generation command
genisoimage
Installation media caching
Allowed bootdisk types
E.6. Content management settings
The content settings define how Foreman manages content repositories, subscriptions, content views, and host registration, including default templates, download policies, and synchronization behavior.
Default HTTP Proxy
Kickstart default
Kickstart default finish
Default synced OS user-data
Kickstart default user data
Kickstart default PXELinux
Kickstart default PXEGrub2
Kickstart default iPXE
Kickstart default
Atomic Kickstart default
Manifest refresh timeout
1200
Calculate errata host status based only on errata in a host’s content view and lifecycle environment.
Check services before actions
100
Whether or not to auto sync Smart Proxies after a content view promotion.
immediate
on_demand
on_demand
/var/lib/pulp/exports
Pulp client key
Pulp client cert
Sync Connection Timeout
300
Delete Host upon unregister
Default Location
Expire soon days
120
Host Duplicate DMI UUIDs
Host Profile Assume
Enable new host registrations to assume registered profiles with matching hostname if the registering DMI UUID is not used by another host.
Enable host registrations to bypass Host Profile Assume if the host is in build mode.
Host Tasks Workers Pool Size
5
Applicability Batch Size
50
Autosearch
Autosearch delay
500
Pulp bulk load size
2000
1440
Enable removal of repositories that the user has previously published in one or more content view versions.
E.7. User authentication settings
The authentication settings define how Foreman handles user authentication and authorization, including OAuth configuration, SSL certificates, login delegation, idle timeouts, and OpenID Connect integration.
OAuth active
This setting is for internal Foreman use only. Foreman community does not support using it to configure OAuth authentication for API calls.
OAuth consumer key
OAuth consumer key.
OAuth consumer secret
OAuth consumer secret.
OAuth map users
Failed login attempts limit
30
Trusted hosts
SSL certificate
/etc/foreman/client_cert.pem
SSL CA file
/etc/foreman/proxy_ca.pem
SSL private key
/etc/foreman/client_key.pem
SSL client DN env
HTTP_SSL_CLIENT_S_DN
SSL client verify env
HTTP_SSL_CLIENT_VERIFY
SSL client cert env
HTTP_SSL_CLIENT_CERT
Server CA file
Websockets SSL key
Websockets SSL certificate
Websockets encryption
Login delegation logout URL
External
Idle timeout
60
BCrypt password cost
9
BMC credentials access
OIDC JWKs URL
OIDC Audience
OIDC Issuer
OIDC Algorithm
E.8. Email notification settings
The email settings define how Foreman sends email notifications, including delivery method, SMTP configuration, reply addresses, and welcome email options.
Email reply address
Email subject prefix
Send welcome email
Delivery method
Sendmail
Method used to deliver email.
SMTP enable StartTLS auto
SMTP OpenSSL verify mode
Default verification mode
SMTP address
SMTP address to connect to.
SMTP port
25
SMTP port to connect to.
SMTP HELO/EHLO domain
HELO/EHLO domain.
SMTP username
SMTP password
SMTP authentication
none
Sendmail arguments
-i
Sendmail location
/usr/sbin/sendmail
E.9. RSS notifications settings
The notifications settings define how Foreman retrieves and displays RSS notifications from external feeds.
RSS enable
Pull RSS notifications.
RSS URL
E.10. Host provisioning settings
The provisioning settings define how Foreman provisions hosts, including default passwords, template rendering, PXE boot configuration, hostname generation, and virtual machine management.
Host owner
Root password
Unattended URL
Safemode rendering
Query local nameservers
Installation token lifetime
360
SSH timeout
120
0.0.0.0
Update IP from built request
Use short name for VMs
DNS timeout
[5, 10, 15, 20]
Clean up failed deployment
Random-based
iPXE intermediate script
Maximum structured facts
100
Global Registration
Global Registration template.
CoreOS Transpiler Command
PXEGrub2 global default
PXELinux global default
Global default iPXE template
iPXE global default
Local boot PXEGrub2 template
PXEGrub2 default local boot
Local boot PXELinux template
PXELinux default local boot
Local boot iPXE template
iPXE default local boot
Manage PuppetCA
Use UUID for certificates
E.11. Host facts settings
The facts settings define how Foreman processes and uses facts reported by hosts, including automatic host creation, location and organization assignment, interface updates, and fact filtering.
Location fact
foreman_location
Organization fact
foreman_organization
Default location
Default Location
Default organization
Default Organization
Update hostgroup from facts
Ignore facts for domain
Update subnets from facts
None
Default Puppet environment
production
ENC environment
Update environment from facts
E.12. Configuration management settings
The configuration management settings define how Foreman integrates with configuration management tools, including automatic host creation from reports, smart class parameter evaluation, and configuration status tracking.
Matchers inheritance
[fqdn, hostgroup, os, domain]
Interpolate ERB in parameters
Puppet interval
35
Puppet out of sync disabled
E.13. Remote execution settings
The remote execution settings define how Foreman executes commands and scripts on remote hosts, including SSH configuration, user management, Smart Proxy selection, and job template synchronization.
Fallback to Any Proxy
Enable Global Proxy
SSH User
root
Effective User
root
Effective User Method
sudo
Effective user password
Sync Job Templates
SSH Port
22
Connect by IP
Prefer IPv6 over IPv4
Default SSH password
Default SSH key passphrase
Workers pool size
5
Cleanup working directories
Cockpit URL
Form Job Template
Run Command - Script Default
Time to pickup
86400
Time in seconds within which the host has to pick up a job. If the job is not picked up within this limit, the job will be canceled. Applies only to pull-mqtt based jobs. Defaults to one day.
E.14. Ansible integration settings
The Ansible settings define how Foreman integrates with Ansible for configuration management, including connection types, verbosity levels, timeout values, and role import behavior.
Private Key Path
Connection type
ssh
Use this connection type by default when running Ansible Playbooks. You can override this on hosts by adding the ansible_connection parameter.
WinRM cert Validation
validate
Enable or disable WinRM server certificate validation when running Ansible Playbooks. You can override this on hosts by adding the ansible_winrm_server_cert_validation parameter.
Default verbosity level
Disabled
Foreman adds this level of verbosity for additional debugging output when running Ansible Playbooks.
Post-provision timeout
360
Ansible report timeout
30
Ansible out of sync disabled
Ansible - Ansible Inventory
Ansible roles to ignore
Unsupported version
