1. Introduction to orcharhino API
orcharhino provides a Representational State Transfer (REST) API. The API provides software developers and system administrators with control over their orcharhino environment outside of the standard web interface. The REST API is useful for developers and administrators who aim to integrate the functionality of orcharhino with custom scripts or external applications that access the API over HTTP.
1.1. Overview of the orcharhino API
The orcharhino API offers several benefits and supports various use cases for integrating the API into your workflows.
Self-descriptive – client applications require minimal knowledge of the orcharhino infrastructure because a user discovers many details at runtime.
1.2. orcharhino API compared to Hammer CLI
For many tasks, you can use both Hammer and orcharhino API. In these situations, you can choose whether Hammer or orcharhino API is the more suitable tool for your use case.
You can use Hammer as a human-friendly interface to orcharhino API.
1.3. Getting help with orcharhino API
You can use the API reference on your orcharhino Server to view information about API endpoints supported for orcharhino API integrations.
View the full API reference on your orcharhino Server at the following URL:
https://orcharhino.example.com/apidoc/
Replace orcharhino.example.com with the FQDN of your orcharhino Server.
2. API syntax
You can review the basic syntax of API requests and JSON responses.
Even though versions 1 and 2 of the orcharhino API are available, ATIX AG only supports version 2. |
2.1. API request composition
You can use the information from the built-in API reference documentation to compose API requests.
HTTP_METHOD API_ROUTE
$ curl \ --request HTTP_METHOD \ --insecure \ --user My_User_Name:My_Password \ --data @My_Input_File.json \ --header "Accept:application/json" \ --header "Content-Type:application/json" \ --output My_Output_File API_ROUTE \ | python3 -m json.tool
--request-
To use
curlfor the API call, specify an HTTP method with the--requestoption. For example,--request POST. --insecure-
Add the
--insecureoption to skip SSL peer certificate verification check. ATIX AG recommends you to configure SSL authentication and use secured calls. For more information, see SSL authentication overview. --user-
Provide orcharhino user credentials with the
--useroption. --data-
For
POSTandPUTrequests, use the--dataoption to pass JSON-formatted data. For more information, see Passing JSON data to the API request. --header-
When passing the JSON data with the
--dataoption, you must specify the following headers with the--headeroption. For more information, see Passing JSON data to the API request. --output-
When downloading content from orcharhino Server, specify the output file with the
--outputoption. API_ROUTE-
Use the API route in the following format:
https://orcharhino.example.com/api/architectures. In orcharhino, version 2 of the API is the default. Therefore, it is not necessary to usev2in the URL for API calls. json.tool-
Redirect the output to the Python
json.toolmodule to make the output easier to read.
2.1.1. Using the GET HTTP method
Submit a GET request by using
curl.Example API request:
$ curl \ --request GET \ --user My_User_Name:My_Password \ https://orcharhino.example.com/api/hosts \ | python3 -m json.tool
Example API response:
{ "total": 2, "subtotal": 2, "page": 1, "per_page": 20, "search": null, "sort": { "by": null, "order": null }, "results": output truncated }The response from the API indicates that there are two results in total, this is the first page of the results, and the maximum results per page is set to 20. For more information, see JSON response format.
2.1.2. Using the POST HTTP method
Use the POST HTTP verb to submit data to the API to create an entry or resource. You must submit the data in JSON format. For more information, see Passing JSON data to the API request.
Create a test file, for example,
activation-key.json, with the following content:{"organization_id":1, "name":"TestKey", "description":"Just for testing"} -
Create an activation key by applying the data in the
activation-key.jsonfile.Example API request:
$ curl \ --header "Accept:application/json" \ --header "Content-Type:application/json" \ --request POST \ --user My_User_Name:My_Password \ --data @activation-key.json \ https://orcharhino.example.com/katello/api/activation_keys \ | python3 -m json.tool
{ "id": 2, "name": "TestKey", "description": "Just for testing", "unlimited_hosts": true, "auto_attach": true, "content_view_id": null, "environment_id": null, "usage_count": 0, "user_id": 3, "max_hosts": null, "release_version": null, "service_level": null, "content_overrides": [ ], "organization": { "name": "Default Organization", "label": "Default_Organization", "id": 1 }, "created_at": "2024-02-16 12:37:47 UTC", "updated_at": "2024-02-16 12:37:48 UTC", "content_view": null, "environment": null, "products": null, "host_collections": [ ], "permissions": { "view_activation_keys": true, "edit_activation_keys": true, "destroy_activation_keys": true } }
In the orcharhino management UI, navigate to Content > Lifecycle > Activation Keys to view your activation keys.
2.1.3. Using the PUT HTTP method
Use the PUT HTTP method to change an existing value or append to an existing resource. You must submit the data in JSON format. For more information, see Passing JSON data to the API request.
This example updates the TestKey activation key created in the previous example.
Edit the
activation-key.jsonfile created previously as follows:{"organization_id":1, "name":"TestKey", "description":"Just for testing","max_hosts":"10" } -
Apply the changes in the JSON file.
$ curl \ --request PUT \ --header "Accept:application/json" \ --header "Content-Type:application/json" \ --user My_User_Name:My_Password \ --data @activation-key.json \ https://orcharhino.example.com/katello/api/activation_keys/2 \ | python3 -m json.tool
{ "id": 2, "name": "TestKey", "description": "Just for testing", "unlimited_hosts": false, "auto_attach": true, "content_view_id": null, "environment_id": null, "usage_count": 0, "user_id": 3, "max_hosts": 10, "release_version": null, "service_level": null, "content_overrides": [ ], "organization": { "name": "Default Organization", "label": "Default_Organization", "id": 1 }, "created_at": "2024-02-16 12:37:47 UTC", "updated_at": "2024-02-16 12:46:17 UTC", "content_view": null, "environment": null, "products": null, "host_collections": [ ], "permissions": { "view_activation_keys": true, "edit_activation_keys": true, "destroy_activation_keys": true } }
In the orcharhino management UI, navigate to Content > Lifecycle > Activation Keys to view the updated activation keys.
2.1.4. Using the DELETE HTTP method
To delete a resource, use the DELETE method with an API route that includes the ID of the resource you want to delete.
This example deletes the TestKey activation key which ID is 2.
Submit a DELETE request by using
$ curl \ --header "Accept:application/json" \ --header "Content-Type:application/json" \ --request DELETE \ --user My_User_Name:My_Password \ https://orcharhino.example.com/katello/api/activation_keys/2 \ | python3 -m json.tool
output omitted "started_at": "2024-02-16 12:58:17 UTC", "ended_at": "2024-02-16 12:58:18 UTC", "state": "stopped", "result": "success", "progress": 1.0, "input": { "activation_key": { "id": 2, "name": "TestKey" output truncated
2.2. JSON response format
Calls to the API return results in JSON format. The API call returns the result for a single-option response or for responses collections.
2.2.1. JSON response format for single objects
You can use single-object JSON responses to work with a single object.
API requests to a single object require the unique identifier :id of the object.
This is an example of the format for a single-object request for the orcharhino domain which ID is 23:
- API request
$ curl \ --request GET \ --user My_User_Name:My_Password \ https://orcharhino.example.com/api/domains/23 \ | python3 -m json.tool
- API response
{ "id": 23, "name": "qa.lab.example.com", "fullname": "QA", "dns_id": 10, "created_at": "2024-08-13T09:02:31Z", "updated_at": "2024-08-13T09:02:31Z" }
2.2.2. JSON response format for collections
Collections are a list of objects such as hosts and domains. The format for a collection JSON response consists of a metadata fields section and a results section.
This is an example of the format for a collection request for a list of orcharhino domains:
- Example API request
$ curl \ --request GET \ --user My_User_Name:My_Password \ https://orcharhino.example.com/api/domains \ | python3 -m json.tool
- Example API response
{ "total": 3, "subtotal": 3, "page": 1, "per_page": 20, "search": null, "sort": { "by": null, "order": null }, "results": [ { "id": 23, "name": "qa.lab.example.com", "fullname": "QA", "dns_id": 10, "created_at": "2024-08-13T09:02:31Z", "updated_at": "2024-08-13T09:02:31Z" }, { "id": 25, "name": "dev.lab.example.com", "fullname": "DEVEL", "dns_id": 8, "created_at": "2024-08-13T08:32:48Z", "updated_at": "2024-08-14T07:04:03Z" }, { "id": 32, "name": "hr.lab.example.com", "fullname": "HR", "dns_id": 8, "created_at": "2024-08-16T08:32:48Z", "updated_at": "2024-08-16T07:04:03Z" } ] }
2.2.3. JSON response metadata
Review the metadata fields in orcharhino API responses to understand pagination, search results, and collection information when working with the API.
orcharhino API responses contain the following metadata fields:
total-
subtotal-
page-
The page number.
per_page-
limit-
offset-
search-
The search string based on
scoped_scopedsyntax. sort-
by– Specifies by what field the API sorts the collection. -
order– The sort order, either ASC for ascending or DESC for descending.
results-
The collection of objects.
2.3. Relating API error messages to the API reference
3. API call authentication
Interaction with the orcharhino API requires SSL authentication with orcharhino Server CA certificate and authentication with valid orcharhino user credentials. You can use the following authentication methods.
3.1. SSL authentication overview
orcharhino uses HTTPS, which provides a degree of encryption and identity verification when communicating with orcharhino Server. orcharhino 7.3 does not support non-SSL communications.
By default, orcharhino Server uses a self-signed certificate. This certificate acts as both the server certificate to verify the encryption key and the certificate authority (CA) to trust the identity of orcharhino Server.
You can configure orcharhino Server to use a custom SSL certificate. For more information, see Configuring orcharhino Server with a custom SSL certificate in Installing orcharhino Server.
3.1.1. Configuring SSL authentication
Configure an SSL authentication for the API requests to orcharhino Server.
Obtain a certificate from your orcharhino Server by using one of the following options:
If you plan to call the API from a remote server, download the CA certificate:
$ curl \ --output /etc/pki/ca-trust/source/anchors/orcharhino.example.com-katello-server-ca.crt \ http://orcharhino.example.com/pub/katello-server-ca.crt
If you plan to call the API directly on your orcharhino Server, copy the certificate to the
/etc/pki/ca-trust/source/anchorsdirectory:# cp /var/www/html/pub/katello-server-ca.crt /etc/pki/ca-trust/source/anchors/orcharhino.example.com-katello-server-ca.crt
Add the certificate to the list of trusted CAs:
$ update-ca-trust extract
Verify that your client trusts the orcharhino SSL certificate by entering the API request without the
--cacertoption:$ curl \ --request GET \ --user My_User_Name:My_Password \ https://orcharhino.example.com/api/v2/hosts
3.2. HTTP authentication overview
All requests to the orcharhino API require a valid orcharhino user name and password.
The API uses Basic HTTP authentication to encode these credentials and add to the Authorization header.
For more information about Basic authentication, see RFC 2617 HTTP Authentication: Basic and Digest Access Authentication.
If a request does not include an appropriate Authorization header, the API returns a 401 Authorization Required error.
Basic authentication involves potentially sensitive information, for example, it sends passwords as plain text. The REST API requires HTTPS for transport-level encryption of plain text requests. |
Some base64 libraries break encoded credentials into multiple lines and terminate each line with a newline character.
This invalidates the header and causes a faulty request.
The Authorization header requires the encoded credentials to be on a single line within the header.
3.3. Token authentication overview
orcharhino supports Personal Access Tokens that you can use to authenticate API requests instead of using your password. You can set an expiration date for your Personal Access Token and you can revoke it if you decide it should expire before the expiration date.
3.3.1. Creating a Personal Access Token
$ curl \ --user My_Username:My_Personal_Access_Token \ https://orcharhino.example.com/api/status
200, for example:{"orcharhino_version":"7.3.0","result":"ok","status":200,"version":"3.5.1.10","api_version":2}If you go back to Personal Access Tokens tab, you can see the updated Last Used time next to your Personal Access Token.
3.3.2. Revoking a Personal Access Token
4. API requests in various languages
You can review the following examples of sending API requests to orcharhino from curl, Ruby, or Python.
4.1. Calling the API in curl
You can use curl with the orcharhino API to perform various tasks.
You can use curl to manipulate resources on your orcharhino Server.
API calls to orcharhino require data in json format.
orcharhino requires the use of HTTPS, and by default, a certificate for host identification.
If you have not added the orcharhino Server certificate as described in SSL authentication overview, then you can use the --insecure option to bypass certificate checks.
For user authentication, you can use the --user option to provide orcharhino user credentials in the form --user My_User_Name:_My_Password.
If you do not include the password, the command prompts you to enter it.
To reduce security risks, do not include the password as part of the command, because it then becomes part of your shell history.
For simplicity, the examples in this section include the password.
4.1.1. Passing JSON data to the API request
You can pass data to orcharhino Server with the API request. The data must be in JSON format.
- JSON-formatted string
Enclose the quoted JSON-formatted data in curly braces
{}. When passing a value for a JSON type parameter, you must escape quotation marks"with backslashes\. For example, within curly braces, you must format"Example JSON Variable"as\"Example JSON Variable\":--data {"id":44, "smart_class_parameter":{"override":"true", "parameter_type":"json", "default_value":"{\"GRUB_CMDLINE_LINUX\": {\"audit\":\"1\",\"crashkernel\":\"true\"}}"}} - JSON-formatted file
The unquoted JSON-formatted data enclosed in a file and specified by the
@sign and the filename. For example:--data @file.json
You can use your favorite text editor.
You can use syntax checker to find and avoid mistakes.
You can use tools to check the validity of JSON data or to reformat it.
$ json_verify < file.json
4.1.2. Retrieving a list of resources
This section outlines how to use curl with the orcharhino API to request information from orcharhino.
These examples include both requests and responses.
This example is a basic request that returns a list of orcharhino resources, orcharhino users in this case. Such requests return a list of data wrapped in metadata, while other request types only return the actual object.
$ curl \ --request GET \ --user My_User_Name:My_Password \ https://orcharhino.example.com/api/users \ | python3 -m json.tool
{ "page": 1, "per_page": 20, "results": [ { "admin": false, "auth_source_id": 1, "auth_source_name": "Internal", "created_at": "2024-09-21 08:59:22 UTC", "default_location": null, "default_organization": null, "description": "", "effective_admin": false, "firstname": "", "id": 5, "last_login_on": "2024-09-21 09:03:25 UTC", "lastname": "", "locale": null, "locations": [], "login": "test", "mail": "test@example.com", "organizations": [ { "id": 1, "name": "Default Organization" } ], "ssh_keys": [], "timezone": null, "updated_at": "2024-09-21 09:04:45 UTC" }, { "admin": true, "auth_source_id": 1, "auth_source_name": "Internal", "created_at": "2024-09-20 07:09:41 UTC", "default_location": null, "default_organization": { "description": null, "id": 1, "name": "Default Organization", "title": "Default Organization" }, "description": "", "effective_admin": true, "firstname": "Admin", "id": 4, "last_login_on": "2024-12-07 07:31:09 UTC", "lastname": "User", "locale": null, "locations": [ { "id": 2, "name": "Default Location" } ], "login": "admin", "mail": "admin@example.com", "organizations": [ { "id": 1, "name": "Default Organization" } ], "ssh_keys": [], "timezone": null, "updated_at": "2024-11-14 08:19:46 UTC" } ], "search": null, "sort": { "by": null, "order": null }, "subtotal": 2, "total": 2 }
4.1.3. Creating a user
$ curl \ --header "Accept:application/json" \ --header "Content-Type:application/json" \ --request POST \ --user My_User_Name:My_Password \ --data "{\"firstname\":\"Test Name\",\"mail\":\"test@example.com\",\"login\":\"test_user\",\"password\":\"password123\",\"auth_source_id\":1}" \ https://orcharhino.example.com/api/users \ | python3 -m json.tool
4.1.4. Modifying a user
This example modifies given name and login of a user account named test_user.
$ curl \ --header "Accept:application/json" \ --header "Content-Type:application/json" \ --request PUT \ --user My_User_Name:My_Password \ --data "{\"firstname\":\"New Test Name\",\"mail\":\"test@example.com\",\"login\":\"new_test_user\",\"password\":\"password123\",\"auth_source_id\":1}" \ https://orcharhino.example.com/api/users/8 \ | python3 -m json.tool
4.2. Calling the API in Ruby
You can use Ruby with the orcharhino API to perform various tasks.
These are example scripts and commands. Ensure you review these scripts carefully before use, and replace any variables, user names, passwords, and other information to suit your own deployment. |
4.2.1. Creating objects by using Ruby
This script connects to the orcharhino API, creates an organization, and then creates three lifecycle environments in the organization. If the organization already exists, the script uses that organization. If any of the lifecycle environments already exist in the organization, the script raises an error and quits.
#!/usr/bin/ruby
require 'rest-client'
require 'json'
url = 'https://orcharhino.example.com/api/v2/'
katello_url = "#{url}/katello/api/v2/"
$username = '_My_User_Name_'
$password = '_My_Password_'
org_name = "_My_Organization_"
environments = [ "Development", "Testing", "Production" ]
# Performs a GET by using the passed URL location
def get_json(location)
response = RestClient::Request.new(
:method => :get,
:url => location,
:user => $username,
:password => $password,
:headers => { :accept => :json,
:content_type => :json }
).execute
JSON.parse(response.to_str)
end
# Performs a POST and passes the data to the URL location
def post_json(location, json_data)
:method => :post,
:url => location,
:user => $username,
:content_type => :json},
:payload => json_data
).execute
end
# Creates a hash with ids mapping to names for an array of records
def id_name_map(records)
records.inject({}) do |map, record|
map.update(record['id'] => record['name'])
end
end
# Get list of existing organizations
orgs = get_json("#{katello_url}/organizations")
org_list = id_name_map(orgs['results'])
if !org_list.has_value?(org_name)
# If our organization is not found, create it
puts "Creating organization: \t#{org_name}"
org_id = post_json("#{katello_url}/organizations", JSON.generate({"name"=> org_name}))["id"]
else
# Our organization exists, so let's grab it
org_id = org_list.key(org_name)
puts "Organization \"#{org_name}\" exists"
end
# Get list of organization's lifecycle environments
envs = get_json("#{katello_url}/organizations/#{org_id}/environments")
env_list = id_name_map(envs['results'])
prior_env_id = env_list.key("Library")
# Exit the script if at least one life cycle environment already exists
environments.each do |e|
if env_list.has_value?(e)
puts "ERROR: One of the Environments is not unique to organization"
exit
end
end
# Create life cycle environments
environments.each do |environment|
puts "Creating environment: \t#{environment}"
prior_env_id = post_json("#{katello_url}/organizations/#{org_id}/environments", JSON.generate({"name" => environment, "organization_id" => org_id, "prior_id" => prior_env_id}))["id"]
end
4.2.2. Using apipie bindings with Ruby
Apipie bindings are the Ruby bindings for apipie documented API calls. They fetch and cache the API definition from orcharhino and then generate API calls as needed.
#!/usr/bin/ruby
require 'apipie-bindings'
# Create an instance of apipie bindings
@api = ApipieBindings::API.new({
:uri => 'https://orcharhino.example.com/',
:username => 'admin',
:password => 'changeme',
:api_version => 2
# Performs an API call with default options
def call_api(resource_name, action_name, params = {})
http_headers = {}
apipie_options = { :skip_validation => true }
@api.resource(resource_name).call(action_name, params, http_headers, apipie_options)
end
# Creates a hash with IDs mapping to names for an array of records
end
end
orgs = call_api(:organizations, :index)
org_id = call_api(:organizations, :create, {'organization' => { :name => org_name }})['id']
else
end
# Get list of organization's life cycle environments
envs = call_api(:lifecycle_environments, :index, {'organization_id' => org_id})
exit
end
end
prior_env_id = call_api(:lifecycle_environments, :create, {"name" => environment, "organization_id" => org_id, "prior_id" => prior_env_id })['id']
end
4.3. Calling the API in Python
You can use Python with the orcharhino API to perform various tasks.
4.3.1. Creating objects by using Python
This script connects to the orcharhino API, creates an organization, and then creates three environments in the organization. If the organization already exists, the script uses that organization. If any of the environments already exist in the organization, the script raises an error and quits.
#!/usr/bin/python3
import json
import sys
try:
import requests
except ImportError:
print("Please install the python-requests module.")
sys.exit(-1)
# URL to your orcharhino Server
URL = "https://orcharhino.example.com"
FOREMAN_API = f"{URL}/api/"
KATELLO_API = f"{URL}/katello/api/"
POST_HEADERS = {'content-type': 'application/json'}
# Default credentials to login to orcharhino
USERNAME = "admin"
PASSWORD = "changeme"
# Ignore SSL for now
SSL_VERIFY = False
# Name of the organization to be either created or used
ORG_NAME = "MyOrg"
# Name for life cycle environments to be either created or used
ENVIRONMENTS = ["Development", "Testing", "Production"]
def get_json(location):
r = requests.get(location, auth=(USERNAME, PASSWORD), verify=SSL_VERIFY)
return r.json()
def post_json(location, json_data):
result = requests.post(
location,
data=json_data,
verify=SSL_VERIFY,
headers=POST_HEADERS
return result.json()
def main():
Main routine that creates or re-uses an organization and
life cycle environments.
If life cycle environments already
exist, exit out.
# Check if our organization already exists
org = get_json(f"{FOREMAN_API}/organizations/{ORG_NAME}")
if org.get('error', None):
org_id = post_json(
f"{FOREMAN_API}/organizations/",
json.dumps({"name": ORG_NAME})
)["id"]
print("Creating organization:\t" + ORG_NAME)
else:
org_id = org['id']
print(f"Organization '{ORG_NAME}' exists.")
# Now, let's fetch all available life cycle environments for this org...
envs = get_json(
f"{KATELLO_API}/organizations/{org_id}/environments/"
# ...and add them to a dictionary, with respective 'Prior' environment
prior_env_id = 0
env_list = {}
for env in envs['results']:
env_list[env['id']] = env['name']
prior_env_id = env['id'] if env['name'] == "Library" else prior_env_id
if all(environment in env_list.values() for environment in ENVIRONMENTS):
print("ERROR: One of the Environments is not unique to organization")
sys.exit(-1)
for environment in ENVIRONMENTS:
new_env_id = post_json(
f"{KATELLO_API}/organizations/{org_id}/environments/",
json.dumps({
"name": environment,
"organization_id": org_id,
"prior": prior_env_id
)["id"]
print("Creating environment:\t" + environment)
prior_env_id = new_env_id
if __name__ == "__main__":
main()
4.3.2. Retrieving resource information by using Python
This is an example script that uses Python for various API requests.
#!/usr/bin/env python3
import json
import sys
try:
import requests
except ImportError:
sys.exit(-1)
HOSTNAME = "orcharhino.example.com"
# URL for the API to your orcharhino Server
FOREMAN_API = f"https://{HOSTNAME}/api/"
KATELLO_API = f"https://{HOSTNAME}/katello/api/v2/"
USERNAME = "admin"
PASSWORD = "password"
SSL_VERIFY = False
#SSL_VERIFY = "./path/to/CA-certificate.crt" # Put the path to your CA certificate here to allow SSL_VERIFY
def get_json(url):
r = requests.get(url, auth=(USERNAME, PASSWORD), verify=SSL_VERIFY)
return r.json()
def get_results(url):
jsn = get_json(url)
if jsn.get('error'):
print("Error: " + jsn['error']['message'])
else:
if jsn.get('results'):
return jsn['results']
elif 'results' not in jsn:
return jsn
else:
print("No results found")
return None
def display_all_results(url):
results = get_results(url)
if results:
print(json.dumps(results, indent=4, sort_keys=True))
def display_info_for_hosts(url):
hosts = get_results(url)
if hosts:
print(f"{'ID':10}{'Name':40}{'IP':30}{'Operating System':30}")
for host in hosts:
print(f"{str(host['id']):10}{host['name']:40}{str(host['ip']):30}{str(host['operatingsystem_name']):30}")
def display_info_for_subs(url):
subs = get_results(url)
if subs:
print(f"{'ID':10}{'Name':90}{'Start Date':30}")
for sub in subs:
print(f"{str(sub['id']):10}{sub['name']:90}{str(sub['start_date']):30}")
def main():
host = HOSTNAME
print(f"Displaying all info for host {host} ...")
display_all_results(FOREMAN_API + 'hosts/' + host)
print(f"Displaying all facts for host {host} ...")
display_all_results(FOREMAN_API + f'hosts/{host}/facts')
host_pattern = 'example'
print(f"Displaying basic info for hosts matching pattern '{host_pattern}'...")
display_info_for_hosts(FOREMAN_API + 'hosts?per_page=1&search=name~' + host_pattern)
print(f"Displaying basic info for subscriptions")
display_info_for_subs(KATELLO_API + 'subscriptions')
environment = 'production'
print(f"Displaying basic info for hosts in environment {environment}...")
display_info_for_hosts(FOREMAN_API + 'hosts?search=environment=' + environment)
main()
5. API cheat sheet
You can review the following examples of how to use the orcharhino API to perform various tasks.
You can use the API on orcharhino Server via HTTPS on port 443.
For example, in Ruby, you can specify the orcharhino Server URL as follows:
katello_url = 'https://orcharhino.example.com/katello/api/v2/'
The following examples use curl for sending API requests.
For more information, see Calling the API in curl.
5.1. Working with hosts
Review the following examples to understand how to compose API requests that target host entries.
5.1.1. Listing hosts
$ curl \ --request GET \ --user My_User_Name:My_Password \ https://orcharhino.example.com/api/v2/hosts \ | python3 -m json.tool
- API response
{ ... "total" => 2, "subtotal" => 2, "page" => 1, "per_page" => 1000, "search" => nil, "sort" => { "by" => nil, "order" => nil }, "results" => [ ... }
5.1.2. Requesting information for a host
This request returns information for the host orcharhino.example.com.
$ curl \ --request GET \ --user My_User_Name:My_Password \ https://orcharhino.example.com/api/v2/hosts/orcharhino.example.com \ | python3 -m json.tool
{ "all_puppetclasses": [], "architecture_id": 1, "architecture_name": "x86_64", "build": false, "capabilities": [ "build" ], "certname": "orcharhino.example.com", "comment": null, "compute_profile_id": null, ... }
5.1.3. Listing host facts
This request returns all facts for the host orcharhino.example.com.
$ curl \ --request GET \ --user My_User_Name:My_Password \ https://orcharhino.example.com/api/v2/hosts/orcharhino.example.com/facts \ | python3 -m json.tool
{ ... "results": { "orcharhino.example.com": { "augeasversion": "1.0.0", "bios_release_date": "01/01/2007", "bios_version": "0.5.1", "blockdevice_sr0_size": "1073741312", "facterversion": "1.7.6", ... }
5.1.4. Searching for hosts with matching patterns
$ curl \ --request GET \ --user My_User_Name:My_Password \ https://orcharhino.example.com/api/v2/hosts?search=example \ | python3 -m json.tool
{ ... "results": [ { "name": "orcharhino.example.com", ... } ], "search": "example", ... }
5.1.5. Searching for hosts in an environment
$ curl \ --request GET \ --user My_User_Name:My_Password \ https://orcharhino.example.com/api/v2/hosts?search=environment=production \ | python3 -m json.tool
{ ... "results": [ { "environment_name": "production", "name": "orcharhino.example.com", ... } ], "search": "environment=production", ... }
5.1.6. Searching for hosts with a specific fact value
This query returns all hosts with the host group My Host Group.
$ curl \ --request GET \ --user My_User_Name:My_Password \ https://orcharhino.example.com/api/v2/hosts?search=hostgroup=%22My+Host+Group%22 \ | python3 -m json.tool
{ ... "results": [ { ... "hostgroup_id": 1, "hostgroup_name": "My Host Group", "name": "my-host.example.com", ... } ], "search": "hostgroup=\"My Host Group\"", ... }
5.2. Working with lifecycle environments
orcharhino divides application life cycles into lifecycle environments, which represent each stage of the application life cycle.
Lifecycle environments are linked to from an environment path.
To create linked lifecycle environments with the API, use the prior_id parameter.
You can find the built-in API reference for lifecycle environments at https://orcharhino.example.com/apidoc/v2/lifecycle_environments.html.
The API routes include /katello/api/environments and /katello/api/organizations/:organization_id/environments.
5.2.1. Listing lifecycle environments
Use this API call to list all the current lifecycle environments on your orcharhino for the default organization with ID 1.
$ curl \ --header "Accept:application/json" \ --header "Content-Type:application/json" \ --request GET \ --user My_User_Name:My_Password \ https://orcharhino.example.com/katello/api/organizations/1/environments \ | python3 -m json.tool`
output omitted "description": null, "id": 1, "label": "Library", "library": true, "name": "Library", "organization": { "id": 1, "label": "Default_Organization", "name": "Default Organization" }, "permissions": { "destroy_lifecycle_environments": false, "edit_lifecycle_environments": true, "promote_or_remove_content_views_to_environments": true, "view_lifecycle_environments": true }, "prior": null, "successor": null, output truncated
5.2.2. Creating linked lifecycle environments
Use this example to create a path of lifecycle environments.
This procedure uses the default Library environment with ID 1 as the starting point for creating lifecycle environments.
Choose an existing lifecycle environment that you want to use as a starting point. List the environment by using its ID. In this case, the environment with ID
1:Example request:
$ curl \ --request GET \ --user My_User_Name:My_Password \ https://orcharhino.example.com/katello/api/environments/1 \ | python3 -m json.tool
Example response:
output omitted "id": 1, "label": "Library", output omitted "prior": null, "successor": null, output truncated -
Create a JSON file, for example,
life-cycle.json, with the following content:{"organization_id":1,"label":"api-dev","name":"API Development","prior":1} -
Create a lifecycle environment by using the
prioroption set to1.Example request:
$ curl \ --header "Accept:application/json" \ --header "Content-Type:application/json" \ --request POST \ --user My_User_Name:My_Password \ --data @life-cycle.json \ https://orcharhino.example.com/katello/api/environments \ | python3 -m json.tool
Example response:
output omitted "description": null, "id": 2, "label": "api-dev", "library": false, "name": "API Development", "organization": { "id": 1, "label": "Default_Organization", "name": "Default Organization" }, "permissions": { "destroy_lifecycle_environments": true, "edit_lifecycle_environments": true, "promote_or_remove_content_views_to_environments": true, "view_lifecycle_environments": true }, "prior": { "id": 1, "name": "Library" }, output truncatedIn the command output, you can see the ID for this lifecycle environment is
2, and the lifecycle environment before this one is1. Use the lifecycle environment with ID2to create a successor to this environment. -
Edit the previously created
life-cycle.jsonfile to update thelabel,name, andpriorvalues.{"organization_id":1,"label":"api-qa","name":"API QA","prior":2} -
Create a lifecycle environment using the
prioroption set to2.Example request:
Example response:
output omitted "description": null, "id": 3, "label": "api-qa", "library": false, "name": "API QA", "organization": { "id": 1, "label": "Default_Organization", "name": "Default Organization" }, "permissions": { "destroy_lifecycle_environments": true, "edit_lifecycle_environments": true, "promote_or_remove_content_views_to_environments": true, "view_lifecycle_environments": true }, "prior": { "id": 2, "name": "API Development" }, "successor": null, output truncatedIn the command output, you can see the ID for this lifecycle environment is
3, and the lifecycle environment before this one is2.
5.2.3. Updating a lifecycle environment
You can update a lifecycle environment using a PUT command.
This example request updates a description of the lifecycle environment with ID 3.
$ curl \ --header "Accept:application/json" \ --header "Content-Type:application/json" \ --request POST \ --user My_User_Name:My_Password \ --data '{"description":"Quality Acceptance Testing"}' \ https://orcharhino.example.com/katello/api/environments/3 \ | python3 -m json.tool - Example API response
output omitted "description": "Quality Acceptance Testing", "id": 3, "label": "api-qa", "library": false, "name": "API QA", "organization": { "id": 1, "label": "Default_Organization", "name": "Default Organization" }, "permissions": { "destroy_lifecycle_environments": true, "edit_lifecycle_environments": true, "promote_or_remove_content_views_to_environments": true, "view_lifecycle_environments": true }, "prior": { "id": 2, "name": "API Development" }, output truncated
5.2.4. Deleting a lifecycle environment
You can delete a lifecycle environment if it has no successor.
When deleting lifecycle environments, delete them in reverse order.
$ curl \ --request DELETE \ --user My_User_Name:My_Password \ https://orcharhino.example.com/katello/api/environments/:id
5.3. Uploading Content to orcharhino Server
You can use the orcharhino API to upload and import large files to your orcharhino Server.
This process involves four steps:
Create an upload request.
Upload the content.
Import the content.
Delete the upload request.
The maximum file size that you can upload is 2 MB. For information about uploading larger content, see Uploading content larger than 2 MB.
Assign the package name to the variable
$ export name=jq-1.6-2.el7.x86_64.rpm
Assign the checksum of the file to the variable
checksum:Example request:
$ export checksum=$(sha256sum $name|cut -c 1-65)
Assign the file size to the variable
$ export size=$(du -bs $name|cut -f 1)
Create an upload request that returns the upload ID of the request by using
sizeandchecksum.Example request:
$ curl \ --header 'Content-Type: application/json' \ --request POST \ --user My_User_Name:My_Password \ --data "{\"size\": \"$size\", \"checksum\":\"$checksum\"}" \ https://orcharhino.example.com/katello/api/v2/repositories/76/content_uploadswhere 76, in this case, is an example Repository ID.
Example request:
{"upload_id":"37eb5900-597e-4ac3-9bc5-2250c302fdc4"} -
Assign the upload ID to the variable
upload_id:$ export upload_id=37eb5900-597e-4ac3-9bc5-2250c302fdc4
Assign the path of the package you want to upload to the variable
path:$ export path=/root/jq/jq-1.6-2.el7.x86_64.rpm
Upload your content. Ensure you use the correct MIME type when you upload data. The API uses the
application/jsonMIME type for the requests to orcharhino unless stated otherwise. Combine the upload ID, MIME type, and other parameters to upload content.Example request:
$ curl \ --user My_User_Name:My_Password \ --header Accept:application/json \ --header Content-Type:multipart/form-data \ --request PUT \ --data-urlencode size=$size \ --data-urlencode offset=0 \ --data-urlencode content@${path} \ https://orcharhino.example.com/katello/api/v2/repositories/76/content_uploads/$upload_id -
After you have uploaded the content to your orcharhino Server, you need to import it into the appropriate repository. Until you complete this step, orcharhino Server does not detect the new content.
Example request:
$ curl \ --header "Content-Type:application/json" \ --request PUT \ --user My_User_Name:My_Password \ --data "{\"uploads\":[{\"id\": \"$upload_id\", \"name\": \"$name\", \"checksum\": \"$checksum\" }]}" \ https://orcharhino.example.com/katello/api/v2/repositories/76/import_uploads -
After you have successfully uploaded and imported your content, you can delete the upload request. This frees any temporary disk space that data is using during the upload.
Example request:
$ curl \ --header 'Content-Type: application/json' \ --request DELETE \ --user My_User_Name:My_Password \ --data "{}" \ https://orcharhino.example.com/katello/api/v2/repositories/76/content_uploads/$upload_id
5.3.1. Uploading content larger than 2 MB
The following example demonstrates how to split a large file into chunks, create an upload request, upload the individual files, import them to orcharhino, and then delete the upload request. Note that this example uses sample content, host names, user names, repository ID, and file names.
name:$ export name=bpftool-3.10.0-1160.2.1.el7.centos.plus.x86_64.rpm
checksum:$ export checksum=$(sha256sum $name|cut -c 1-65)
size:$ export size=$(du -bs $name|cut -f 1)
The following command creates a new upload request and returns the upload ID of the request using
Example output
Split the file in 2MB chunks:
$ split \ --bytes 2MB \ --numeric-suffixes \ --suffix-length=1 \ bpftool-3.10.0-1160.2.1.el7.centos.plus.x86_64.rpm bpftool
View the file chunks:
$ ls -l bpftool[0-9]
Example output:
-rw-r--r--. 1 root root 2000000 Mar 31 14:15 bpftool0 -rw-r--r--. 1 root root 2000000 Mar 31 14:15 bpftool1 -rw-r--r--. 1 root root 2000000 Mar 31 14:15 bpftool2 -rw-r--r--. 1 root root 2000000 Mar 31 14:15 bpftool3 -rw-r--r--. 1 root root 868648 Mar 31 14:15 bpftool4 -
Assign the prefix of the split files to the variable path.
$ export path=/root/tmp/bpftool
Upload the file chunks. The offset starts at 0 bytes for the first chunk and increases by 2000000 bytes for each file. Note the use of the offset parameter and how it relates to the file size. Note also that the indexes are used after the path variable, for example, ${path}0, ${path}1.
Example requests:
$ curl \ --user My_User_Name:My_Password \ --header Accept:application/json \ --header Content-Type:multipart/form-data \ --request PUT \ --data-urlencode size=$size \ --data-urlencode offset=0 \ --data-urlencode content@${path}0 \ https://orcharhino.example.com/katello/api/v2/repositories/76/content_uploads/$upload_id $ curl \ --user My_User_Name:My_Password \ --header Accept:application/json \ --header Content-Type:multipart/form-data \ --request PUT \ --data-urlencode size=$size \ --data-urlencode offset=2000000 \ --data-urlencode content@${path}1 \ https://orcharhino.example.com/katello/api/v2/repositories/76/content_uploads/$upload_id $ curl \ --user My_User_Name:My_Password \ --header Accept:application/json \ --header Content-Type:multipart/form-data \ --request PUT \ --data-urlencode size=$size \ --data-urlencode offset=4000000 \ --data-urlencode content@${path}2 \ https://orcharhino.example.com/katello/api/v2/repositories/76/content_uploads/$upload_id $ curl \ --user My_User_Name:My_Password \ --header Accept:application/json \ --header Content-Type:multipart/form-data \ --request PUT \ --data-urlencode size=$size \ --data-urlencode offset=6000000 --data-urlencode content@${path}3 \ https://orcharhino.example.com/katello/api/v2/repositories/76/content_uploads/$upload_id $ curl \ --user My_User_Name:My_Password \ --header Accept:application/json \ --header Content-Type:multipart/form-data \ --request PUT \ --data-urlencode size=$size \ --data-urlencode offset=8000000 \ --data-urlencode content@${path}4 \ https://orcharhino.example.com/katello/api/v2/repositories/76/content_uploads/$upload_id -
Import the complete upload to the repository:
Delete the upload request:
5.3.2. Uploading duplicate content
You can reuse existing content in orcharhino instead of uploading duplicate content to orcharhino through the API.
Upload content to orcharhino:
$ curl \ --header 'Content-Type: application/json' \ --request POST \ --user My_User_Name:My_Password \ --data "{\"size\": \"$size\", \"checksum\":\"$checksum\"}" \ https://orcharhino.example.com/katello/api/v2/repositories/76/content_uploadsThe call will return a content unit ID instead of an upload ID, similar to this:
{"content_unit_href":"/pulp/api/v3/content/file/files/c1bcdfb8-d840-4604-845e-86e82454c747/"}You can copy this output and call import uploads directly to add the content to a repository.
$ curl \ --header "Content-Type:application/json" \ --request PUT \ --user My_User_Name:My_Password \ --data "{\"uploads\":[{\"content_unit_id\": \"/pulp/api/v3/content/file/files/c1bcdfb8-d840-4604-845e-86e82454c747/\", \"name\": \"$name\", \ \"checksum\": \"$checksum\" }]}" \ https://orcharhino.example.com/katello/api/v2/repositories/76/import_uploadsNote that the call changes from using
upload_idto usingcontent_unit_id.
5.4. Using extended searches
You can find search parameters that you can use to build your search queries in the orcharhino management UI. For more information, see Searching and bookmarking in Administering orcharhino.
In the orcharhino management UI, navigate to Hosts > All Hosts.
Click the Search field to display a list of search parameters.
Locate the search parameters that you want to use. For this example, locate os_title and model.
Combine the search parameters in your API query as follows:
Example request:
$ curl \ --user My_User_Name:My_Password \ https://orcharhino.example.com/api/v2/hosts?search=os_title=\"RedHat+7.7\",model=\"PowerEdge+R330\" \ | python3 -m json.tool
Example response:
{ ... "results": [ { "model_id": 1, "model_name": "PowerEdge R330", "name": "orcharhino.example.com", "operatingsystem_id": 1, "operatingsystem_name": "RedHat 7.7", ... } ], "search": "os_title=\"RedHat 7.7\",model=\"PowerEdge R330\"", "subtotal": 1, "total": 11 }
5.5. Using searches with pagination control
You can use the per_page and page pagination parameters to limit the search results that an API search query returns.
The number of items to be presented is set using the setting entries_per_page, which defaults to 20.
However, you can change it per request by using the parameter per_page.
This example returns a list of architectures for an organization with ID 1 in pages.
The list contains 5 entries per page and returns the second page.
$ curl \ --request GET \ --user My_User_Name:My_Password \ https://orcharhino.example.com/katello/api/architectures?organization_id=1&per_page=5&page=2
5.5.1. Returning multiple pages
You can use a for loop structure to get multiple pages of results.
This example returns pages 1 to 3 of Content Views with 5 results per page.
- Bash script
$ for i inseq 1 3; do \ curl \ --request GET \ --user My_User_Name:My_Password \ https://orcharhino.example.com/katello/api/content_views?per_page=5&page=$i; \ done
5.6. Overriding Smart Class parameters
You can search for Smart Parameters by using the API and supply a value to override a Smart Parameter in a Class.
You can find the full list of attributes that you can modify in the built-in API reference at https://orcharhino.example.com/apidoc/v2/smart_class_parameters/update.html.
Find the ID of the Smart Class parameter you want to change:
List all Smart Class Parameters.
Example request:
$ curl \ --request GET \ --user My_User_Name:My_Password \ https://orcharhino.example.com/api/smart_class_parameters
If you know the Puppet class ID, for example 5, you can restrict the scope: Example request:
$ curl \ --request GET \ --user My_User_Name:My_Password \ https://orcharhino.example.com/api/puppetclasses/5/smart_class_parameters
Both calls accept a search parameter. You can view the full list of searchable fields in the orcharhino management UI. Navigate to Configure > Smart variables and click in the search query box to reveal the list of fields.
Two particularly useful search parameters are
puppetclass_nameandkey, which you can use to search for a specific parameter. For example, use the--dataoption to pass URL encoded data.Example request:
$ curl \ --request GET \ --user My_User_Name:My_Password \ --data 'search=puppetclass_name = access_insights_client and key = authmethod' \ https://orcharhino.example.com/api/smart_class_parameters
orcharhino supports standard scoped-search syntax.
When you find the ID of the parameter, list the full details including current override values.
Example request:
$ curl \ --request GET \ --user My_User_Name:My_Password \ https://orcharhino.example.com/api/smart_class_parameters/63
Enable overriding of parameter values.
Example request:
$ curl \ --header "Accept:application/json" \ --header "Content-Type:application/json" \ --request PUT \ --user My_User_Name:My_Password \ --data '{"smart_class_parameter":{"override":true}}' \ https://orcharhino.example.com/api/smart_class_parameters/63Note that you cannot create or delete the parameters manually. You can only modify their attributes. orcharhino creates and deletes parameters only upon class import from orcharhino Proxies.
Add custom override matchers.
Example request:
$ curl \ --header "Accept:application/json" \ --header "Content-Type:application/json" \ --request PUT \ --user My_User_Name:My_Password \ --data '{"smart_class_parameter":{"override_value":{"match":"hostgroup=Test","value":"2.4.6"}}}' \ https://orcharhino.example.com/api/smart_class_parameters/63For more information about override values, see
https://orcharhino.example.com/apidoc/v2/override_values.html. -
You can delete override values.
Example request:
$ curl \ --request DELETE \ --user My_User_Name:My_Password \ https://orcharhino.example.com/api/smart_class_parameters/63/override_values/3
5.7. Modifying a Smart Class parameter by using an external file
You can modify a Puppet Smart Class parameter by using an external file.
Using external files simplifies working with JSON data. You can use an editor with syntax highlighting to avoid and locate mistakes. This example uses a MOTD Puppet manifest.
Search for the Puppet Class by name,
motdin this case.Example request:
$ curl \ --header "Accept:application/json" \ --header "Content-Type:application/json" \ --request GET \ --user My_User_Name:My_Password \ https://orcharhino.example.com/api/smart_class_parameters?search=puppetclass_name=motd \ | python3 -m json.tool
Examine the following output. Each Smart Class Parameter has an ID that is global for the same orcharhino instance. The
contentparameter of themotdclass hasid=3. Do not confuse this with the Puppet Class ID that displays before the Puppet Class name.Example response:
{ "avoid_duplicates": false, "created_at": "2024-02-06 12:37:48 UTC", # Remove this line. "default_value": "", # Add a new value here. "description": "", "hidden_value": "", "hidden_value?": false, "id": 3, "merge_default": false, "merge_overrides": false, "override": false, # Set the override value totrue. "override_value_order": "fqdn\nhostgroup\nos\ndomain", "override_values": [], # Remove this line. "override_values_count": 0, "parameter": "content", "parameter_type": "string", "puppetclass_id": 3, "puppetclass_name": "motd", "required": false, "updated_at": "2024-02-07 11:56:55 UTC", # Remove this line. "use_puppet_default": false, "validator_rule": null, "validator_type": "" } -
Use the parameter ID
3to get the information specific to themotdparameter and redirect the output to a file, for example, output_file.json.Example request:
$ curl \ --header "Accept:application/json" \ --header "Content-Type:application/json" \ --request GET \ --user My_User_Name:My_Password \ https://orcharhino.example.com/api/smart_class_parameters/3 \ | python3 -m json.tool > output_file.json
Copy the file created in the previous step to a new file for editing, for example,
changed_file.json:$ cp output_file.json changed_file.json
Modify the required values in the file. In this example, change the content parameter of the
motdmodule, which requires changing theoverrideoption fromfalsetotrue:{ "avoid_duplicates": false, "created_at": "2024-02-06 12:37:48 UTC", # Remove this line. "default_value": "", # Add a new value here. "description": "", "hidden_value": "", "hidden_value?": false, "id": 3, "merge_default": false, "merge_overrides": false, "override": false, # Set the override value totrue. "override_value_order": "fqdn\nhostgroup\nos\ndomain", "override_values": [], # Remove this line. "override_values_count": 0, "parameter": "content", "parameter_type": "string", "puppetclass_id": 3, "puppetclass_name": "motd", "required": false, "updated_at": "2024-02-07 11:56:55 UTC", # Remove this line. "use_puppet_default": false, "validator_rule": null, "validator_type": "" } -
After editing the file, verify that it looks as follows and then save the changes:
{ "avoid_duplicates": false, "default_value": "No Unauthorized Access Allowed", "description": "", "hidden_value": "", "hidden_value?": false, "id": 3, "merge_default": false, "merge_overrides": false, "override": true, "override_value_order": "fqdn\nhostgroup\nos\ndomain", "override_values_count": 0, "parameter": "content", "parameter_type": "string", "puppetclass_id": 3, "puppetclass_name": "motd", "required": false, "use_puppet_default": false, "validator_rule": null, "validator_type": "" } -
Submit the file to orcharhino:
$ curl \ --header "Accept:application/json" \ --header "Content-Type:application/json" \ --request PUT \ --user My_User_Name:My_Password \ --data @changed_file.json \ https://orcharhino.example.com/api/smart_class_parameters/3
5.8. Deleting OpenSCAP reports
In orcharhino Server, you can delete one or more OpenSCAP reports. However, when you delete reports, you must delete one page at a time. If you want to delete all OpenSCAP reports, use the bash script that follows.
List all OpenSCAP reports. Note the IDs of the reports that you want to delete.
Example request:
$ curl \ --user My_User_Name:My_Password \ https://orcharhino.example.com/api/v2/compliance/arf_reports/ \ | python3 -m json.tool
Example response:
{ "page": 1, "per_page": 20, "results": [ { "created_at": "2024-05-16 13:27:09 UTC", "failed": 0, "host": "host1.example.com", "id": 404, "othered": 0, "passed": 0, "updated_at": "2024-05-16 13:27:09 UTC" }, { "created_at": "2024-05-16 13:26:07 UTC", "failed": 0, "host": "host2.example.com, "id": 405, "othered": 0, "passed": 0, "updated_at": "2024-05-16 13:26:07 UTC" }, { "created_at": "2024-05-16 13:25:07 UTC", "failed": 0, "host": "host3.example.com", "id": 406, "othered": 0, "passed": 0, "updated_at": "2024-05-16 13:25:07 UTC" }, { "created_at": "2024-05-16 13:24:07 UTC", "failed": 0, "host": "host4.example.com", "id": 407, "othered": 0, "passed": 0, "updated_at": "2024-05-16 13:24:07 UTC" }, ], "search": null, "sort": { "by": null, "order": null }, "subtotal": 29, "total": 29 -
Using an ID from the previous step, delete the OpenSCAP report. Repeat for each ID that you want to delete.
Example request:
$ curl \ --user My_User_Name:My_Password \ --header "Content-Type: application/json" \ --request DELETE \ https://orcharhino.example.com/api/v2/compliance/arf_reports/405
Example response:
HTTP/1.1 200 OK Date: Thu, 18 May 2024 07:14:36 GMT Server: Apache/2.4.6 (Enterprise Linux) X-Frame-Options: SAMEORIGIN X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff Foreman_version: 3.11.0.76 Foreman_api_version: 2 Apipie-Checksum: 2d39dc59aed19120d2359f7515e10d76 Cache-Control: max-age=0, private, must-revalidate X-Request-Id: f47eb877-35c7-41fe-b866-34274b56c506 X-Runtime: 0.661831 X-Powered-By: Phusion Passenger 4.0.18 Set-Cookie: request_method=DELETE; path=/ Set-Cookie: _session_id=d58fe2649e6788b87f46eabf8a461edd; path=/; secure; HttpOnly ETag: "2574955fc0afc47cb5394ce95553f428" Status: 200 OK Vary: Accept-Encoding Transfer-Encoding: chunked Content-Type: application/json; charset=utf-8
#!/bin/bash
# this script removes all ARF reports from your orcharhino Server
# settings
USER="My_User_Name"
PASS="My_Password"
URI="https://orcharhino.example.com"
# check amount of reports
while [ $(curl --user $USER:$PASS $URI/api/v2/compliance/arf_reports/ | python3 -m json.tool | grep \"\total\": | cut --fields=2 --delimiter":" | cut --fields=1 --delimiter"," | sed "s/ //g") -gt 0 ]; do
# fetch reports
for i in $(curl --user $USER:$PASS $URI/api/v2/compliance/arf_reports/ | python3 -m json.tool | grep \"\id\": | cut --fields=2 --delimiter":" | cut --fields=1 --delimiter"," | sed "s/ //g")
# delete reports
do
curl --user $USER:$PASS --header "Content-Type: application/json" --request DELETE $URI/api/v2/compliance/arf_reports/$i
done
done
Appendix A: API response codes
The orcharhino API provides HTTP response status codes for API calls. The following codes are common for all resources in the orcharhino API.
| Response | Explanation |
200 OK |
For a successful request action: show, index, update, or delete (GET, PUT, DELETE requests). |
201 Created |
For a successful create action (POST request). |
301 Moved Permanently |
Redirect when orcharhino is restricted to use HTTPS and HTTP is attempted. |
400 Bad Request |
A required parameter is missing or the search query has invalid syntax. |
401 Unauthorized |
Failed to authorize the user, for example, due to incorrect credentials. |
403 Forbidden |
The user has insufficient permissions to perform the action or read the resource, or the action is unsupported in general. |
404 Not Found |
The record with the given ID does not exist. It can appear in show and delete actions when the requested record does not exist; or in create, update and delete actions when one of the associated records does not exist. |
409 Conflict |
Could not delete the record due to existing dependencies, for example, host groups that still contain hosts. |
415 Unsupported Media Type |
The content type of the HTTP request is not JSON. |
422 Unprocessable Entity |
Failed to create an entity due to some validation errors. Applies to create or update actions only. |
500 Internal Server Error |
Unexpected internal server error. |
503 Service Unavailable |
The server is not running. |
Appendix B: Creating a complete permission table
Ensure that the
foreman-consolepackage is installed on orcharhino Server:# dnf install foreman-console
Start the orcharhino console:
# foreman-rake console
/tmp/table.htmlfile. -
Press
Ctrl+Dto exit the orcharhino console. -
/tmp/table.html:<table border="1"><tr><td>Permission name</td><td>Actions</td><td>Resource type</td></tr> -
/tmp/table.html:</table> -
Open
