1. Starting and stopping orcharhino
orcharhino provides the foreman-maintain service command to manage orcharhino services from the command line.
This is useful when creating a backup of orcharhino.
For more information on creating backups, see Backing up orcharhino Server and orcharhino Proxy Server.
After installing orcharhino with the orcharhino-installer command, all orcharhino services are started and enabled automatically.
To stop orcharhino services, execute:
To start orcharhino services, execute:
To restart orcharhino services, execute:
2. Tuning orcharhino Server with predefined profiles
If your orcharhino deployment includes more than 5000 hosts, you can use predefined tuning profiles to improve performance of orcharhino.
Note that you cannot use tuning profiles on orcharhino Proxies.
You can choose one of the profiles depending on the number of hosts your orcharhino manages and available hardware resources.
When you run the orcharhino-installer command with the --tuning option, deployment configuration settings are applied to orcharhino in the following order:
The default tuning profile defined in the
/usr/share/foreman-installer/config/foreman.hiera/tuning/common.yamlfile -
The tuning profile that you want to apply to your deployment and is defined in the
/usr/share/foreman-installer/config/foreman.hiera/tuning/sizes/directory -
Optional: If you have configured a
/etc/foreman-installer/custom-hiera.yamlfile, orcharhino applies these configuration settings.
- default
Number of hosts: 0 – 5000
RAM: 20G
Number of CPU cores: 4
- medium
Number of hosts: 5001 – 10000
RAM: 32G
Number of CPU cores: 8
- large
Number of hosts: 10001 – 20000
RAM: 64G
Number of CPU cores: 16
- extra-large
Number of hosts: 20001 – 60000
RAM: 128G
Number of CPU cores: 32
- extra-extra-large
Number of hosts: 60000+
RAM: 256G
Number of CPU cores: 48+
Optional: If you have configured the
custom-hiera.yamlfile on orcharhino Server, back up the/etc/foreman-installer/custom-hiera.yamlfile tocustom-hiera.original. You can use the backup file to restore the/etc/foreman-installer/custom-hiera.yamlfile to its original state if it becomes corrupted:# cp /etc/foreman-installer/custom-hiera.yaml \ /etc/foreman-installer/custom-hiera.original
custom-hiera.yamlfile on orcharhino Server, review the definitions of the default tuning profile in/usr/share/foreman-installer/config/foreman.hiera/tuning/common.yamland the tuning profile that you want to apply in/usr/share/foreman-installer/config/foreman.hiera/tuning/sizes/. Compare the configuration entries against the entries in your/etc/foreman-installer/custom-hiera.yamlfile and remove any duplicated configuration settings in your/etc/foreman-installer/custom-hiera.yamlfile. -
Enter the
orcharhino-installercommand with the--tuningoption for the profile that you want to apply. For example, you can apply the medium tuning profile settings:# orcharhino-installer --tuning medium
3. Migrating from internal orcharhino databases to external databases
When you install orcharhino, the orcharhino-installer command installs PostgreSQL databases on the same server as orcharhino. If you are using the default internal databases but want to start using external databases to help with the server load, you can migrate your internal databases to external databases.
To confirm whether your orcharhino Server has internal or external databases, you can query the status of your databases:
Installing PostgreSQL. Prepare PostgreSQL with databases for Foreman, Pulp, and Candlepin with dedicated users owning them.
Migrating to external databases. Edit the parameters of
orcharhino-installerto point to the new databases, and runorcharhino-installer.
3.1. PostgreSQL as an external database considerations
Foreman, Katello, and Candlepin use the PostgreSQL database. If you want to use PostgreSQL as an external database, the following information can help you decide if this option is right for your orcharhino configuration. orcharhino supports PostgreSQL version 13.
- Advantages of external PostgreSQL
Increase in free memory and free CPU on orcharhino
Flexibility to set
shared_bufferson the PostgreSQL database to a high number without the risk of interfering with other services on orcharhino -
Flexibility to tune the PostgreSQL server’s system without adversely affecting orcharhino operations
- Disadvantages of external PostgreSQL
If either orcharhino or the PostgreSQL database server suffers a hardware or storage failure, orcharhino is not operational
If there is latency between the orcharhino server and database server, performance can suffer
3.2. Installing PostgreSQL
The prepared host has base operating system repositories enabled.
The prepared host has sufficient disk space available for the
/var/lib/pgsqldirectory. The expected installation size is 100 MB and the expected runtime size is 20 GB.
On your new database server, install PostgreSQL:
# dnf install postgresql-server postgresql-contrib
Initialize the PostgreSQL database:
# postgresql-setup --initdb
Edit the
Note that the default configuration of external PostgreSQL needs to be adjusted to work with orcharhino. The base recommended external database configuration adjustments are as follows:
max_connections: 500
shared_buffers: 512MB
work_mem: 4MB
Remove the
Add the following line to the end of the file to use SCRAM for authentication:
Edit the
host all all orcharhino_ip/32 scram-sha-256
Start and enable the PostgreSQL service:
Update the firewall configuration. For example, using the
firewall-cmdcommand:-
Open the postgresql port:
Make the changes persistent:
Switch to the
Create three databases and dedicated roles: one for Foreman, one for Candlepin, and one for Pulp:
CREATE USER "foreman" WITH PASSWORD 'Foreman_Password'; CREATE DATABASE foreman OWNER foreman; CREATE USER "candlepin" WITH PASSWORD 'Candlepin_Password'; CREATE DATABASE candlepin OWNER candlepin; CREATE USER "pulp" WITH PASSWORD 'Pulpcore_Password'; CREATE DATABASE pulpcore OWNER pulp;
Exit the
postgresuser:# \q
From orcharhino Server, test that you can access the database:
# PGPASSWORD='Foreman_Password' pg_isready --host=postgres.example.com --port=5432 --username=foreman --dbname=foreman # PGPASSWORD='Candlepin_Password' pg_isready --host=postgres.example.com --port=5432 --username=candlepin --dbname=candlepin # PGPASSWORD='Pulpcore_Password' pg_isready --host=postgres.example.com --port=5432 --username=pulp --dbname=pulpcore
If the connection succeeded, this displays an
accepting connectionsmessage.
3.3. Migrating to external databases
Back up and transfer existing data, then use the orcharhino-installer command to configure orcharhino to connect to an external PostgreSQL database server.
You have installed and configured a PostgreSQL server on an external server.
On orcharhino Server, stop all orcharhino services except for PostgreSQL:
Create your target directory for the orcharhino backup:
# mkdir /var/My_Migration_Backup_Directory
# foreman-maintain backup online \ --preserve-directory \ --skip-pulp-content \ /var/My_Migration_Backup_Directory
PGPASSWORD='Foreman_Password' pg_restore --host=postgres.example.com --username=foreman --dbname=foreman < /var/My_Migration_Backup_Directory/foreman.dump PGPASSWORD='Candlepin_Password' pg_restore --host=postgres.example.com --username=candlepin --dbname=candlepin < /var/My_Migration_Backup_Directory/candlepin.dump PGPASSWORD='Pulpcore_Password' pg_restore --host=postgres.example.com --username=pulp --dbname=pulpcore < /var/My_Migration_Backup_Directory/pulpcore.dump
Use the
orcharhino-installercommand to update orcharhino to point to the new databases:# orcharhino-installer \ --katello-candlepin-manage-db false \ --katello-candlepin-db-host postgres.example.com \ --katello-candlepin-db-name candlepin \ --katello-candlepin-db-user candlepin \ --katello-candlepin-db-password Candlepin_Password \ --foreman-proxy-content-pulpcore-manage-postgresql false \ --foreman-proxy-content-pulpcore-postgresql-host postgres.example.com \ --foreman-proxy-content-pulpcore-postgresql-db-name pulpcore \ --foreman-proxy-content-pulpcore-postgresql-user pulp \ --foreman-proxy-content-pulpcore-postgresql-password Pulpcore_Password \ --foreman-db-manage false \ --foreman-db-host postgres.example.com \ --foreman-db-database foreman \ --foreman-db-username foreman \ --foreman-db-password Foreman_Password
Remove the PostgreSQL package on orcharhino Server:
# dnf remove postgresql-server
Remove the PostgreSQL data directory:
# rm -fr /var/lib/pgsql/data
4. Preparing for disaster recovery and recovering from data loss
ATIX AG recommends preparing a disaster recovery plan to ensure the continuity of orcharhino services in case of a disruptive event. These guidelines help ensure that you will be able to restore your orcharhino deployment to an operational state after an incident.
4.1. Overview of recommended disaster recovery plans
Choose a disaster recovery plan that best helps ensure the continuity of orcharhino services in your deployment.
- Snapshots of virtualized orcharhino Server
- How do I back up?
Virtualize your orcharhino Server and use the hypervisor tools to take virtual machine snapshots of the server. This method is suitable if you can run orcharhino in a virtual machine.
To recover orcharhino services, restore a virtual machine snapshot.
- Active and passive orcharhino Server, with external storage
- How do I back up?
/var/lib/pulpand database in/var/lib/pgsql. Replicate this storage into a different data center. Attach the storage to a orcharhino Server that is a clone of the primary orcharhino Server but runs passively. - How will I recover in case of a disruptive event?
To recover orcharhino services, switch DNS records of the active orcharhino Server with the passive orcharhino Server. This ensures that the passive server becomes the active server. All hosts remain connected without configuration updates.
- Active and passive orcharhino Server, with backup and restore
- How do I back up?
Ensure periodic backups of your orcharhino Server. Copy this backup to a passive orcharhino Server and restore it on the passive server.
- Dual active orcharhino Server
- How do I back up?
Operate an active, independent orcharhino Server per data center. Hosts from each data center are registered to the orcharhino Server in that data center. Then configure automation to ensure recovery in case of a disruptive event. For example, you can periodically run a health check and if the health check discovers that the current orcharhino Server a host is registered to does not resolve, the host is re-registered to the other orcharhino Server.
To minimize downtime, you can automate the recovery in various ways. For example, you can use the orcharhino Ansible collection. For more information, see Using the orcharhino Ansible Collection.
To recover orcharhino services, re-register all hosts to the orcharhino Server in the other data center.
You must ensure that content synchronization and content view creation are synchronized to create the same content view in each orcharhino and prevent content drift. Content drift occurs when available content deviates from the intended state defined by a content view. If you fail to prevent content drift, expect inconsistency in the content that is available to hosts.
4.2. Disaster recovery by virtualizing your orcharhino Server
If you virtualize your orcharhino Server and ensure that you take regular snapshots of the virtual machine (VM), you can respond to various disaster scenarios by restoring your orcharhino deployment from one of your snapshots.
The details for how to implement this scenario depend on your choice of a virtualization platform. Due to the variety of different hypervisors and their capabilities, ATIX AG does not provide detailed instructions for any specific virtualization platform. |
4.2.1. Preparing for disaster recovery by virtualizing your orcharhino Server
Implement a reliable process for regularly taking VM snapshots of your virtualized orcharhino Server and for backing up your snapshots for long-term storage.
Review Overview of recommended disaster recovery plans to make sure that this disaster recovery plan works for you.
Your orcharhino Server is deployed as a VM.
Define a schedule for taking periodic snapshots of your virtualized orcharhino Server. Consider your tolerance for potential data loss: Taking snapshots frequently will result in smaller amounts of data loss in case of a disaster. However, creating a snapshot takes time, and the snapshots also require storage space.
Using your hypervisor, schedule periodic snapshots of your orcharhino Server.
If you are using an external database that runs on a different machine than your orcharhino Server, create snapshots and backups on the same schedule as your orcharhino Server.
Use the latest snapshot of your orcharhino Server and restore it in an isolated environment.
To verify that you will be able to restore orcharhino services in case of a disaster, assess the functionality of the test orcharhino Server. For more information, see Retrieving the status of services by using Hammer CLI.
4.2.2. Recovering from disaster by restoring a VM snapshot of orcharhino Server
In case of a disaster, use a virtual machine (VM) snapshot of your orcharhino Server to restore orcharhino services.
Ensure that the hostname of your orcharhino Server does not change during recovery. The IP address can change. |
If you are using an external database that runs on a different machine than your orcharhino Server, ensure that you restore the database from a snapshot taken at the same time as or before the orcharhino Server snapshot.
Update DNS records so that the orcharhino Server hostname resolves to the new IP address. This redirects traffic from the old server to the new server and you will not need to re-register your hosts.
Assess the functionality of your restored orcharhino Server. For more information, see Retrieving the status of services by using Hammer CLI.
4.2.3. Retrieving the status of services by using Hammer CLI
orcharhino uses a set of back-end services. When troubleshooting, you can check the status of orcharhino services by using Hammer CLI.
Get information from the database and orcharhino services:
$ hammer ping
Run
Perform a health check:
Run
4.3. Disaster recovery for active and passive orcharhino Server with external storage
To prepare for disaster recovery, you can configure two orcharhino Servers and store critical data externally on shared storage. The primary server is active while the secondary server remains passive. If the primary server fails, the shared storage is attached to your secondary server, which turns the secondary server into your new primary server.
4.3.1. Preparing for disaster recovery with active and passive orcharhino Server with external storage
Create your passive orcharhino Server as a backup of your active orcharhino Server.
Review Overview of recommended disaster recovery plans to ensure that this disaster recovery plan works for you.
Review Storage requirements Installing orcharhino Server. Ensure that your shared storage meets the requirements of holding the contents of
/var/lib/pulpand/var/lib/pgsql. -
You have configured your orcharhino Server to use external databases. For more information, see Migrating from internal orcharhino databases to external databases in Installing orcharhino Server.
Replicate the
/var/lib/pulpand/var/lib/pgsqldirectories from the active orcharhino Server to your shared storage. -
Back up your active orcharhino Server and restore it on a system that will serve as your passive orcharhino Server. For more information, see Backing up orcharhino Server and orcharhino Proxy Server and Restoring orcharhino Server or orcharhino Proxy Server from a backup.
Assess the functionality of the test orcharhino Server. For more information, see Retrieving the status of services by using Hammer CLI.
4.3.2. Recovering from disaster with active and passive server with external storage
If your active orcharhino Server fails, detach it from the shared storage and make sure your passive server can access the data stored on the shared storage. This turns the passive server into your new active server.
Assess the functionality of your new active orcharhino Server. For more information, see Retrieving the status of services by using Hammer CLI.
4.3.3. Retrieving the status of services by using Hammer CLI
$ hammer ping
Run
Run
4.4. Disaster recovery for active and passive orcharhino Server with backup and restore
To prepare for disaster recovery, you can configure two orcharhino Servers: an active primary server and a passive secondary server. You configure periodic backups of the primary server. If the primary server fails, you can restore a backup on the secondary server to turn it into your new primary server.
4.4.1. Preparing for disaster recovery with active and passive orcharhino Server and backup and restore
Create your passive orcharhino Server by restoring a backup of your active orcharhino Server. Configure periodic backups of the active server.
You have a orcharhino Server installed.
Define a schedule for periodic offline backups of your active orcharhino Server. Consider your tolerance for potential data loss and your storage options: Taking backups frequently will result in smaller amounts of data loss in case of a disaster, but backups require a significant amount of storage space.
cronjob that ensures regular backups, see Example of a weekly full backup followed by daily incremental backups. -
Schedule periodic offline backups of your active orcharhino Server to be taken according to the schedule you defined. For information about performing backups, see Backing up orcharhino Server and orcharhino Proxy Server.
Ensure that the backup directories are encrypted and regularly synchronized to a secure location. By default, orcharhino stores the backups in the
/var/orcharhino-backupdirectory.Importantorcharhino Server backups contain sensitive information from the
/root/ssl-builddirectory. For example, they can contain hostnames, ssh keys, request files, and SSL certificates. Encrypting or moving the backups to a secure location helps minimize the risk of damage or unauthorized access to the hosts. -
Restore the most recent backup on a system that will serve as your passive orcharhino Server. For information about restoring backups, see Restoring orcharhino Server or orcharhino Proxy Server from a backup.
Verify that orcharhino takes backups according to the schedule you defined.
4.4.2. Recovering from disaster with active and passive server and backup and restore
If your active orcharhino Server fails, activate your passive secondary server.
4.4.3. Retrieving the status of services by using Hammer CLI
$ hammer ping
Run
Run
4.4.4. Example of a weekly full backup followed by daily incremental backups
#!/bin/bash -e
else
fi
exit 0
4.5. Disaster recovery with two active orcharhino Servers
To prepare for disaster recovery, you can configure two orcharhino Servers and operate each server in a different data center. If one of the servers fails, you can re-register all hosts from the failed server to the other server.
4.5.1. Preparing for disaster recovery with two active orcharhino Servers
Create a second orcharhino Server by restoring a backup of your first orcharhino Server. Configure both servers to operate independently in their respective data centers, but ensure that their content does not drift apart over time.
Ansible playbooks can help you automate failover, re-registration, and synchronization. For more information, see Using the orcharhino Ansible Collection. |
Back up your orcharhino Server. For more information, see Backing up orcharhino Server and orcharhino Proxy Server.
Restore the backup on a system that will serve as your other orcharhino Server. For more information, see Restoring orcharhino Server or orcharhino Proxy Server from a backup.
Register hosts to your servers so that each server manages hosts in its respective data center. For example, register all hosts in My_Data_Center_1 to one orcharhino Server and all hosts in My_Data_Center_2 to the other orcharhino Server.
Automate running the
Verify that your
4.5.2. Recovering from disaster with two active orcharhino Servers
If the health checks implemented in Preparing for disaster recovery with two active orcharhino Servers report an issue on one of your orcharhino Servers, it might mean that the server has failed. If the server is down, you must re-register hosts to the other server.
If
5. Managing users and roles
A User defines a set of details for individuals who use the system. Users can be associated with organizations and environments, so that when they create new entities, the default settings are automatically used. Users can also have one or more roles attached, which grants them rights to view and manage organizations and environments.
5.1. Managing users
As an administrator, you can create, modify and remove orcharhino users. You can also configure access permissions for a user or a group of users by assigning them different roles.
5.1.1. Creating a user by using orcharhino management UI
Use this procedure to create a user from the orcharhino management UI.
Click Create User.
Enter the account details for the new user.
On the User tab, select an authentication source from the Authorized by list:
INTERNAL: to manage the user inside orcharhino Server.
EXTERNAL: to manage the user with external authentication. For more information, see Configuring authentication for orcharhino users.
On the Organizations tab, select organizations for the user. Select the default organization from the Default on login list. orcharhino uses this organization for the user after login.
On the Locations tab, select locations for the user. Select the default location from the Default on login list. orcharhino uses this location for the user after login.
5.1.2. Creating a user by using Hammer CLI
Use this procedure to create a user by using Hammer CLI.
Create a user:
$ hammer user create \ --auth-source-id My_Authentication_Source \ --login My_User_Name \ --mail My_User_Mail \ --organization-ids My_Organization_ID_1,My_Organization_ID_2 \ --location-ids My_Location_ID_1,My_Location_ID_2 \ --password My_User_Password
Append
--auth-source-id 1so that the user is authenticated internally. Runhammer auth-source listto get a list of authentication sources. Add the--adminoption to grant administrator privileges to the user.You can modify the user details later by using the
hammer user updatecommand.
5.1.3. Assigning roles to a user by using orcharhino management UI
Use this procedure to assign roles to a user from the orcharhino management UI.
NoteIf a user account is not listed, check that you are currently viewing the correct organization. To list all the users in orcharhino, click Default Organization and then Any Organization.
Click Submit.
5.1.4. Assigning roles to a user by using Hammer CLI
Use this procedure to assign roles to a user by using Hammer CLI.
Assign roles to a user:
$ hammer user add-role \ --id My_User_ID \ --role My_Role_Name
5.1.5. Impersonating a different user account
Administrators can impersonate other authenticated users for testing and troubleshooting purposes by temporarily logging on to the orcharhino management UI as a different user. When impersonating another user, the administrator has permissions to access exactly what the impersonated user can access in the system, including the same menus.
Ensure that you are logged on to the orcharhino management UI as a user with administrator privileges for orcharhino.
5.1.6. Creating an API-only user
You can create users that can interact only with the orcharhino API.
You have created a user and assigned roles to them. Note that this user must be authorized internally. For more information, see Managing users and roles.
Log in to your orcharhino as admin.
# openssl rand -hex 32
5.2. Managing SSH keys
5.2.1. Managing SSH keys for a user by using orcharhino management UI
Use this procedure to add or remove SSH keys for a user from the orcharhino management UI.
Ensure that you are logged in to the orcharhino management UI as an Admin user of orcharhino or a user with the create_ssh_key permission enabled for adding SSH key and destroy_ssh_key permission for removing a key.
Click on the SSH Keys tab.
To Add SSH key
Click Add SSH Key.
Click Submit.
To Remove SSH key
5.2.2. Managing SSH keys for a user by using Hammer CLI
Use this procedure to add or remove SSH keys for a user by using Hammer CLI.
To add an SSH key to a user, you must specify either the path to the public SSH key file, or the content of the public SSH key copied to the clipboard:
$ hammer user ssh-keys add \ --user-id user_id \ --name key_name \ --key-file ~/.ssh/id_rsa.pub
$ hammer user ssh-keys add \ --user-id user_id \ --name key_name \ --key ecdsa-sha2-nistp256 AAAAE2VjZHNhLXNoYTItbmlzdHAyNTYAAAAIbmlzdHAyNtYAAABBBHHS2KmNyIYa27Qaa7EHp+2l99ucGStx4P77e03ZvE3yVRJEFikpoP3MJtYYfIe8k 1/46MTIZo9CPTX4CYUHeN8= host@user
5.3. Managing Personal Access Tokens
5.3.1. Creating a Personal Access Token
$ curl \ --user My_Username:My_Personal_Access_Token \ https://orcharhino.example.com/api/status
200, for example:{"orcharhino_version":"7.3.0","result":"ok","status":200,"version":"3.5.1.10","api_version":2}If you go back to Personal Access Tokens tab, you can see the updated Last Used time next to your Personal Access Token.
5.3.2. Revoking a Personal Access Token
5.4. Creating and managing user groups
5.4.1. User groups
With orcharhino, you can assign permissions to groups of users. You can also create user groups as collections of other user groups. If you use an external authentication source, you can map orcharhino user groups to external user groups as described in Configuring external user groups in Configuring authentication for orcharhino users.
5.4.2. Creating a user group by using orcharhino management UI
In the orcharhino management UI, navigate to Administer > User Groups.
Click Create User group.
Click Submit.
6. Creating and managing roles
Roles define a set of permissions and access levels. Each role contains one or more permission filters that specify the actions allowed for the role. Actions are grouped according to the Resource type. Once a role has been created, users and user groups can be associated with that role. This way, you can assign the same set of permissions to large groups of users.
6.1. Creating a role by using orcharhino management UI
Use this procedure to create a role by using orcharhino management UI.
In the orcharhino management UI, navigate to Administer > Roles.
Click Create Role.
Provide a Name for the role.
Add permissions to the role. To serve its purpose, a role must contain permissions.
6.2. Creating a role by using Hammer CLI
Use this procedure to create a role by using Hammer CLI.
Create a role:
6.3. Cloning a role
Use the orcharhino management UI to clone a role.
In the orcharhino management UI, navigate to Administer > Roles and select Clone from the drop-down menu to the right of the required role.
Use the orcharhino management UI to create an administrative role restricted to a single organization named org-1.
6.4. Adding permissions to a role by using orcharhino management UI
Use this procedure to add permissions to a role by using orcharhino management UI.
Depending on the Resource type selected, you can select or deselect the Unlimited and Override checkbox. The Unlimited checkbox is selected by default, which means that the permission is applied on all resources of the selected type. When you disable the Unlimited checkbox, the Search field activates. In this field you can specify further filtering with use of the orcharhino search syntax. For more information, see Granular permission filtering. When you enable the Override checkbox, you can add additional locations and organizations to allow the role to access the resource type in the additional locations and organizations; you can also remove an already associated location and organization from the resource type to restrict access.
Click Next.
Click Submit to save changes.
6.5. Adding permissions to a role by using Hammer CLI
Use this procedure to add permissions to a role by using Hammer CLI.
Add permissions to a role:
$ hammer filter create \ --permission-ids My_Permission_ID_1,My_Permission_ID_2 \ --role My_Role_Name
For more information about roles and permissions parameters, enter the
hammer role --helpandhammer filter --helpcommands.
6.6. Viewing permissions of a role
Use the orcharhino management UI to view the permissions of a role.
The Filters page contains a table of permissions assigned to a role grouped by the resource type. It is also possible to generate a complete table of permissions and actions that you can use on your orcharhino system. For more information, see Creating a complete permission table.
6.7. Creating a complete permission table
Ensure that the
foreman-consolepackage is installed on orcharhino Server:# dnf install foreman-console
Start the orcharhino console:
# foreman-rake console
/tmp/table.htmlfile. -
Press
Ctrl+Dto exit the orcharhino console. -
/tmp/table.html:<table border="1"><tr><td>Permission name</td><td>Actions</td><td>Resource type</td></tr> -
/tmp/table.html:</table> -
Open
6.8. Removing a role
Use the following procedure to remove a role from orcharhino.
Select Delete from the drop-down list to the right of the role to be deleted.
Click Confirm to delete the role.
6.9. Predefined roles available in orcharhino
The following table provides an overview of permissions that predefined roles in orcharhino grant to a user.
For a complete set of predefined roles and the permissions they grant, log in to orcharhino management UI as the privileged user and navigate to Administer > Roles. For more information, see Viewing permissions of a role.
Auditor |
View the Audit log. |
Default role |
orcharhino automatically assigns this role to every user in the system. |
Manager |
Organization admin |
Site manager |
System admin |
Viewer |
View the configuration of every element of the orcharhino structure, logs, reports, and statistics. |
6.10. Granular permission filtering
orcharhino provides the ability to limit the configured user permissions to selected instances of a resource type. These granular filters are queries to the orcharhino database and are supported by the majority of resource types.
6.10.1. Creating a granular permission filter by using orcharhino management UI
Use this procedure to create a granular permission filter from the orcharhino management UI.
orcharhino does not apply search conditions to create actions. For example, limiting the create_locations action with name = "Default Location" expression in the search field does not prevent the user from assigning a custom name to the newly created location.
field_name operator value
operator specifies the type of comparison between field_name and value. See Supported operators for granular search for an overview of applicable operators.
NoteFor most resource types, the Search field provides a drop-down list suggesting the available parameters. This list appears after placing the cursor in the search field. For many resource types, you can combine queries using logical operators such as and, not and has operators.
6.10.2. Creating a granular permission filter by using Hammer CLI
Use this procedure to create a granular permission filter by using Hammer CLI.
hammer filter createcommand with the--searchoption to limit permission filters, for example:$ hammer filter create \ --permission-ids 91 \ --search "name ~ ccv*" \ --role qa-user
This command adds to the qa-user role a permission to view, create, edit, and destroy content views that only applies to content views with name starting with
ccv.
6.10.3. Examples of using granular permission filters
As an administrator, you can allow selected users to make changes in a certain part of the environment path. For example, you can allow users to work with content while it is in the development stage of the application lifecycle, but not once the content is pushed to production.
The following query applies any permissions specified for the Host resource type only to hosts in the group named host-editors:
hostgroup = host-editors
name ^ (XXXX, Yyyy, zzzz)
Dev
You can limit user permissions to a certain organization or location with the use of the granular permission filter in the Search field. However, some resource types provide a GUI alternative, an Override checkbox that provides the Locations and Organizations tabs. On these tabs, you can select from the list of available organizations and locations. For more information, see Cloning a role.
6.10.4. Supported operators for granular search
You can use logical and symbolic operators to build precise search queries when limiting user permissions.
Operator |
Description |
and |
Combines search criteria. |
not |
Negates an expression. |
has |
Operator |
Description |
7. Configuring email notifications
Email notifications are created by orcharhino Server periodically or after completion of certain events. The periodic notifications can be sent daily, weekly or monthly.
For an overview of available notification types, see Email notification types.
orcharhino Server does not enable outgoing emails by default, therefore you must review your email configuration. |
7.1. Email notification types
You can configure orcharhino to send email notifications for system events such as host builds, errata updates, content synchronization failures, and audit summaries to stay informed about important activities in your environment.
- Audit summary
A summary of all activity audited by orcharhino Server.
- Compliance policy summary
- Content view promote failure
- Content view publish failure
- Host built
- Host errata advisory
- orcharhino Proxy sync failure
A notification sent after orcharhino Proxy synchronization fails.
- Promote errata
- Repository sync failure
- Sync errata
For a complete list of email notification types, navigate to Administer > Users in the orcharhino management UI, click the Username of the required user, and select the Email Preferences tab.
7.2. Configuring email notification preferences
You can configure orcharhino to send email messages to individual users registered to orcharhino. orcharhino sends the email to the email address that has been added to the account, if present.
Users can edit the email address by clicking on their name in the top right of the orcharhino management UI and selecting My account.
If you want to send email notifications to a group email address instead of an individual email address, create a user account with the group email address and minimal orcharhino permissions, then subscribe the user account to the desired notification types. |
view_mail_notifications.
Click Submit.
7.3. Testing email delivery
Click on the username.
If the email is delivered, the verification is complete.
If the email is not delivered, perform the following diagnostic steps:
Verify orcharhino Server’s email configuration.
If your orcharhino Server uses the Postfix service for email delivery, the test email might be held in the queue. To verify, enter the
mailqcommand to list the current mail queue. If the test email is held in the queue,mailqdisplays the following message:postqueue: warning: Mail system is down -- accessing queue directly -Queue ID- --Size-- ----Arrival Time---- -Sender/Recipient------- BE68482A783 1922 Thu Oct 3 05:13:36 orcharhino-noreply@example.com
To fix the problem, start the Postfix service on your orcharhino Server:
# systemctl start postfix
7.4. Testing email notifications
Trigger email notifications:
daily
weekly
monthly
7.5. Changing email notification settings for a host
orcharhino can send event notifications for a host to the host’s registered owner. You can configure orcharhino to send email notifications either to an individual user or a user group. When set to a user group, all group members who are subscribed to the email type receive a message.
In the orcharhino management UI, navigate to Hosts > All Hosts, locate the host that you want to view, and click Edit in the Actions column.
Go to the Additional Information tab. If the checkbox Include this host within orcharhino reporting is checked, then the email notifications are enabled on that host.
8. Backing up orcharhino Server and orcharhino Proxy Server
You can back up your orcharhino deployment to ensure the continuity of your orcharhino deployment and associated data in case a disaster occurs. If your deployment uses custom configurations, you must consider how to handle these custom configurations when you plan your backup and disaster recovery policy.
If you create a new instance of the orcharhino Server, decommission the old instances after restoring the backup. Cloned instances are not supposed to run in parallel in a production environment. |
To create a backup of your orcharhino Server or orcharhino Proxy Server and all associated data, use the foreman-maintain backup command.
orcharhino services are unavailable during the backup.
You can schedule a backup by using cron.
For more information, see the Example of a weekly full backup followed by daily incremental backups.
During offline backups, the services are inactive and orcharhino is in a maintenance mode. All the traffic from outside on port 443 is rejected by a firewall to ensure there are no modifications triggered.
A backup contains sensitive information from the /root/ssl-build directory.
8.1. Estimating the size of a backup
The full backup creates uncompressed archives of PostgreSQL and Pulp database files, and orcharhino configuration files. Compression occurs after the archives are created to decrease the time when orcharhino services are unavailable.
Uncompressed orcharhino database and configuration files
Compressed orcharhino database and configuration files
Enter the
ducommand to estimate the size of uncompressed directories containing orcharhino database and configuration files:# du -sh /var/lib/pgsql/data /var/lib/pulp 100G /var/lib/pgsql/data 100G /var/lib/pulp # du -csh /var/lib/tftpboot /etc /root/ssl-build \ /var/www/html/pub /opt/puppetlabs 16M /var/lib/tftpboot 37M /etc 900K /root/ssl-build 100K /var/www/html/pub 2M /opt/puppetlabs 942M total
Table 3. Backup data compression ratio Data type Directory Ratio Example results PostgreSQL database files
/var/lib/pgsql/data80 – 85%
100 GB → 20 GB
Pulp RPM files
/var/lib/pulp(not compressed)
100 GB
Configuration files
/var/lib/tftpboot/etc/root/ssl-build/var/www/html/pub/opt/puppetlabs85%
942 MB → 141 MB
8.2. Offline backup and online backup
You can perform an offline backup or an online backup to back up your orcharhino Server.
There are two main methods of backing up orcharhino Server:
Offline backup
All orcharhino services are shut down during an offline backup.
Online backup
Only orcharhino services that affect the consistency of the backup, including all background workers, are shut down while the backup process is running. Online backups check for consistency and require more time than offline backups.
Offline backup:
Online backup:
8.3. Directories created during backups
orcharhino organizes backups in time-stamped subdirectories, which helps you identify and select the correct backup when restoring your system.
orcharhino-backupon orcharhino -
foreman-proxy-backupon orcharhino Proxy
8.4. Performing a full backup of orcharhino Server or orcharhino Proxy Server
orcharhino uses the foreman-maintain backup command to make backups.
Ensure that your backup location has sufficient available disk space to store the backup. For more information, see Estimating the size of a backup.
To enable orcharhino to save the backup to an NFS share, ensure that the
rootuser of your orcharhino Server or orcharhino Proxy Server can write to the NFS share. NFS export options such asroot_squashandall_squashare known to prevent this.
Warning
Request other users of orcharhino Server or orcharhino Proxy Server to save any changes and warn them that orcharhino services are unavailable for the duration of the backup. Ensure no other tasks are scheduled for the same time as the backup. |
On orcharhino Server, perform a full backup:
# foreman-maintain backup offline /var/orcharhino-backup
On orcharhino Proxy Server, perform a full backup:
8.5. Performing a backup without Pulp content
Warning
8.6. Performing an incremental backup
Warning
Perform a full offline backup:
Create a directory within your backup directory to store the first incremental backup:
Create the second incremental backup by including the path to the first incremental backup to indicate the starting point for the next increment. This creates a directory for the second incremental backup in your backup directory:
8.7. Example of a weekly full backup followed by daily incremental backups
#!/bin/bash -e
else
fi
exit 0
8.8. Performing an online backup
You can perform an online backup to create a system backup while keeping most services running. This is useful when you need to maintain system availability during backup operations.
When you perform an online backup, most orcharhino services remain running and usable.
Background workers are shut down to ensure consistent backups.
Operations that require background workers remain in pending state.
The backup process ensures that the Pulp data (/var/lib/pulp) is not altered during the backup.
Any changes to the Pulp data during the backup will result in restart of the backup process, taking additional time.
Warning
Request other users of orcharhino Server or orcharhino Proxy Server to save any changes and warn them that some orcharhino services may be unavailable for the duration of the backup. Ensure no other tasks are scheduled for the same time as the backup. |
On your orcharhino Server, perform an online backup:
8.9. Creating a conventional backup
You can use conventional backup methods to back up your orcharhino Server or orcharhino Proxy Server.
Stopping orcharhino services is required when creating a snapshot or conventional backup.
Do not stop orcharhino services if you are using the |
When creating a snapshot or conventional backup, stop all orcharhino services:
Create the snapshot or conventional backup.
Start orcharhino services after creating a snapshot or conventional backup:
9. Restoring orcharhino Server or orcharhino Proxy Server from a backup
You can restore orcharhino Server or orcharhino Proxy Server from the backup data that you create as part of Backing up orcharhino Server and orcharhino Proxy Server. This process outlines how to restore the backup on the same server that generated the backup, and all data covered by the backup is deleted on the target system. If the original system is unavailable, provision a system with the same configuration settings and host name.
You cannot restore backups of a system without FIPS enabled on a FIPS enabled system. |
9.1. Restoring from a full backup
Use this procedure to restore orcharhino or orcharhino Proxy Server from a full backup. When the restore process completes, all processes are online, and all databases and system configuration revert to the state at the time of the backup.
Ensure that you are restoring to the correct instance. The orcharhino instance must have the same host name, configuration, and be the same minor version (X.Y) as the original system.
Ensure that you have enough space to store this data on the base system of orcharhino Server or orcharhino Proxy Server as well as enough space after the restoration to contain all the data in the
/etc/and/var/directories contained within the backup.To check the space used by a directory, enter the following command:
# df -h /var/backup_directory
Add the
# restorecon -Rv /
Choose the appropriate method to install orcharhino or orcharhino Proxy:
To install orcharhino Server from a connected network, follow the procedures in Installing orcharhino Server.
To install a orcharhino Proxy Server, follow the procedures in Installing orcharhino Proxy Server.
Copy the backup data to the local file system on orcharhino Server. Use
/var/or/var/tmp/. -
Run the restoration script.
Review the
/var/log/foreman/production.logand/var/log/messageslog files.
9.2. Restoring from incremental backups
Use this procedure to restore orcharhino or orcharhino Proxy Server from incremental backups. If you have multiple branches of incremental backups, select your full backup and each incremental backup for the branch you want to restore, in chronological order.
Restore the last full backup using the instructions in Restoring from a full backup.
Remove the full backup data from the local file system on orcharhino Server, for example,
/var/or/var/tmp/. -
Copy the incremental backup data to the local file system on orcharhino Server, for example,
/var/or/var/tmp/. -
Review the
9.3. Backup and restore orcharhino Proxy Server by using a virtual machine snapshot
You can use virtual machine snapshots to back up and restore your orcharhino Proxy Server. This is useful for quick recovery in case of server failure or configuration issues.
If your orcharhino Proxy Server is a virtual machine, you can restore it from a snapshot. Creating weekly snapshots to restore from is recommended. In the event of failure, you can install, or configure a new orcharhino Proxy Server, and then synchronize the database content from orcharhino Server.
If required, deploy a new orcharhino Proxy Server, ensuring the host name is the same as before, and then install the orcharhino Proxy certificates. You may still have them on orcharhino Server, the package name ends in -certs.tar, alternately create new ones. Follow the procedures in Installing orcharhino Proxy Server until you can confirm, in the orcharhino management UI, that orcharhino Proxy Server is connected to orcharhino Server. Then use the procedure Synchronizing content from orcharhino Server to orcharhino Proxy Servers to synchronize from orcharhino.
9.3.1. Synchronizing content from orcharhino Server to orcharhino Proxy Servers
Use this procedure to synchronize content from your orcharhino Server to your orcharhino Proxy Server.
Ensure that you either select the relevant organization and location context of your orcharhino Proxy Server or choose Any Organization and Any Location.
In the orcharhino management UI, navigate to Infrastructure > orcharhino Proxies.
Select your orcharhino Proxy Server.
Select Optimized Sync to synchronize content from your orcharhino Server to your orcharhino Proxy Server that bypasses unnecessary steps to speed up performance.
Select Complete Sync to perform a complete sync from your orcharhino Server to your orcharhino Proxy Server that synchronizes content even if the metadata has not changed.
10. Renaming orcharhino Server or orcharhino Proxy Server
To rename orcharhino Server or orcharhino Proxy Server, use the katello-change-hostname script.
If you change the domain name of your orcharhino Server or orcharhino Proxy Server, you must update the hostname by using the |
10.1. Renaming orcharhino Server
The host name of orcharhino Server is used by orcharhino Server components, all orcharhino Proxy Servers, and hosts registered to it for communication. This procedure ensures that in addition to renaming orcharhino Server, you also update all references to point to the new host name.
Warning
Renaming your orcharhino Server host shuts down all orcharhino services on that host. The services restart after the renaming is complete. |
Back up your orcharhino Server before changing its host name. If you fail to successfully rename it, restore it from the backup. For more information, see Backing up orcharhino Server and orcharhino Proxy Server.
Run the
hostnameandhostname -fcommands on orcharhino Server. If both commands do not return the FQDN of orcharhino Server, thekatello-change-hostnamescript will fail to complete.If the
hostnamecommand returns the shortname of orcharhino Server instead of the FQDN, usehostnamectl set-hostname My_Old_FQDNto set the old FQDN correctly before using thekatello-change-hostnamescript. -
If orcharhino Server has a custom SSL certificate installed, obtain a new certificate for the new FQDN of the host.
On orcharhino Server, run the
katello-change-hostnamescript, and provide the new host name. Choose one of the following methods:-
If your orcharhino Server is installed with the default self-signed SSL certificates:
# katello-change-hostname new-orcharhino \ --username My_Username \ --password 'My_Password'
If your orcharhino Server is installed with custom SSL certificates:
# katello-change-hostname new-orcharhino \ --username My_Username \ --password 'My_Password' \ --custom-cert "/root/ownca/test.com/test.com.crt" \ --custom-key "/root/ownca/test.com/test.com.key"
If you have created a custom SSL certificate for the new orcharhino Server host name, run the orcharhino installation script to install the certificate.
Reregister all hosts and orcharhino Proxy Servers that are registered to orcharhino Server. For more information, see Registering hosts by using global registration in Managing hosts.
On all orcharhino Proxy Servers, run the orcharhino installation script to update references to the new host name:
# orcharhino-installer \ --foreman-proxy-foreman-base-url https://new-orcharhino.example.com \ --foreman-proxy-trusted-hosts new-orcharhino.example.com
On orcharhino Server, list all orcharhino Proxy Servers:
# hammer proxy list
On orcharhino Server, synchronize content for each orcharhino Proxy Server:
# hammer proxy content synchronize \ --id My_orcharhino_Proxy_ID
If you use external authentication, reconfigure orcharhino Server for external authentication after you run the
katello-change-hostnamescript. For more information, see Configuring authentication for orcharhino users.
10.2. Renaming orcharhino Proxy Server
The host name of orcharhino Proxy Server is referenced by orcharhino Server components and all hosts registered to it. This procedure ensures that in addition to renaming orcharhino Proxy Server, you also update all references to the new host name.
Warning
Renaming your orcharhino Proxy Server host shuts down all orcharhino services on that host. The services restart after the renaming is complete. |
Back up your orcharhino Proxy Server before renaming. If you fail to successfully rename it, restore it from the backup. For more information, see Backing up orcharhino Server and orcharhino Proxy Server.
Run the
hostnameandhostname -fcommands on orcharhino Proxy Server. If both commands do not return the FQDN of orcharhino Proxy Server, thekatello-change-hostnamescript will fail to complete.If the
hostnamecommand returns the shortname of orcharhino Proxy Server instead of the FQDN, usehostnamectl set-hostname My_Old_FQDNto set the old FQDN correctly before attempting to use thekatello-change-hostnamescript.
On your orcharhino Server, generate a new certificates archive file for your orcharhino Proxy Server.
If you are using the default SSL certificate, regenerate the default SSL certificates:
# foreman-proxy-certs-generate \ --certs-tar /root/new-orcharhino-proxy.example.com-certs.tar \ --foreman-proxy-fqdn new-orcharhino-proxy.example.com
.tarfile. -
If you are using a custom SSL certificate, create a new SSL certificate for your orcharhino Proxy Server.
On your orcharhino Server, copy the certificates archive file to your orcharhino Proxy Server. For example, to copy the archive file to the
rootuser’s home directory:# scp /root/new-orcharhino-proxy.example.com-certs.tar root@orcharhino-proxy.example.com:
On your orcharhino Proxy Server, run the
katello-change-hostnamescript and provide the host’s new name, orcharhino credentials, and certificates archive file name.# katello-change-hostname new-orcharhino-proxy.example.com \ --certs-tar /root/new-orcharhino-proxy.example.com-certs.tar \ --password 'My_Password' \ --username My_Username
.tarfile. -
If you have created a custom certificate for your orcharhino Proxy Server, deploy the certificate to your orcharhino Proxy Server by entering the
orcharhino-installercommand that theforeman-proxy-certs-generatecommand returned in a previous step. -
Reregister all hosts that are registered to your orcharhino Proxy Server. For more information, see Registering hosts and setting up host integration in Managing hosts.
Update the orcharhino Proxy host name in the orcharhino management UI.
Locate orcharhino Proxy Server in the list, and click Edit.
Edit the Name and URL fields to match orcharhino Proxy Server’s new host name, then click Submit.
On your DNS server, add a record for the new hostname of your orcharhino Proxy Server, and delete the record of the previous host name.
11. Maintaining orcharhino Server
This chapter provides information on how to maintain orcharhino Server, including information on how to recover Pulp from a full disk, how to work with audit records, and how to clean unused tasks.
11.1. Deleting audit records manually
Number_Of_Days.
11.2. Deleting audit records automatically
This setting is empty by default, meaning orcharhino does not automatically delete the audit records.
In the orcharhino management UI, navigate to Administer > Settings.
Set the value of the setting to the number of days after which you want orcharhino to delete the audit records.
11.3. Anonymizing audit records
Use the
foreman-rake audits:anonymizecommand to remove any user account or IP information while maintaining the audit records in the database. You can also use a cron job to schedule anonymizing the audit records at the set interval that you want.By default, using the
foreman-rake audits:anonymizecommand anonymizes audit records that are older than 90 days. You can specify the number of days to keep the audit records by adding the days option and add the number of days.For example, you can anonymize audit records that are older than seven days:
11.4. Deleting report records
You can delete report records to remove old reports from your orcharhino. This is useful for maintaining a clean and organized report history.
Report records are created automatically in orcharhino.
Use the
foreman-rake reports:expirecommand to remove reports at any time. You can also use a cron job to schedule report record deletions at the set interval that you want.By default, using the
foreman-rake reports:expirecommand removes report records that are older than 90 days. You can specify the number of days to keep the report records by adding the days option and add the number of days.For example, you can delete report records that are older than seven days:
11.5. Configuring the cleaning unused tasks feature
orcharhino performs regular cleaning to reduce disc space in the database and limit the rate of disk growth. As a result, orcharhino backup completes faster and overall performance is higher.
By default, orcharhino executes a cron job that cleans tasks every day at 19:45. orcharhino removes the following tasks during the cleaning:
To configure the time at which orcharhino runs the cron job, set the
--foreman-plugin-tasks-cron-lineparameter to the time you want in cron format. For example, to schedule the cron job to run every day at 15:00, enter the following command:# orcharhino-installer --foreman-plugin-tasks-cron-line "00 15 * * *"
To configure the period after which orcharhino deletes the tasks, edit the
To disable regular task cleanup on orcharhino, enter the following command:
# orcharhino-installer --foreman-plugin-tasks-automatic-cleanup false
To reenable regular task cleanup on orcharhino, enter the following command:
# orcharhino-installer --foreman-plugin-tasks-automatic-cleanup true
11.6. Deleting task records
You can delete task records to remove old or unnecessary tasks from your orcharhino. This helps maintain system performance and keeps your task history organized.
Task records are created automatically in orcharhino.
Use the
foreman-rake foreman_tasks:cleanupcommand to remove tasks at any time. You can also use a cron job to schedule Task record deletions at the set interval that you want.For example, you can delete task records from successful repository synchronizations:
11.7. Deleting a task by ID
Connect to your orcharhino Server using SSH:
# ssh root@orcharhino.example.com
Optional: View the task:
Delete the task:
Optional: Ensure the task has been removed from orcharhino Server:
11.8. Recovering from a full disk
Ensure that the LV with the
Remove orphaned content:
Change the download policy from Immediate to On Demand for as many repositories as possible and remove already downloaded packages.
/var/lib/pulpdirectory on it.NoteIf you use an untypical file system (other than for example ext3, ext4, or xfs), you might need to unmount the file system so that it is not in use. In that case, complete the following steps:
Stop orcharhino services:
Start orcharhino services:
11.9. Reclaiming PostgreSQL space
The PostgreSQL database can use a large amount of disk space especially in heavily loaded deployments. Use this procedure to reclaim some of this disk space on orcharhino.
Switch to the
11.10. Reclaiming space from on demand repositories
If you set the download policy to on demand, orcharhino downloads packages only when the clients request them. You can clean up these packages to reclaim space.
If you want to reclaim space for a single repository:
In the orcharhino management UI, navigate to Content > Products.
Select a product.
If you want to reclaim space for multiple repositories:
Select the product name.
If you want to reclaim space for orcharhino Proxies:
Select the orcharhino Proxy Server.
Click Reclaim space.
12. Renewing certificates
You can renew the CA certificate on orcharhino Server or the custom SSL certificate on orcharhino Server as well as on orcharhino Proxy Server.
12.1. Planning for self-signed CA certificate renewal
If you need to update the Certification Authority (CA) certificate on your orcharhino Server, add the new CA certificate and use a temporary dual CA certificate file to retain the HTTPS connections to your orcharhino Server during the renewal.
Add the new SSL certificate to the CA certificate file on orcharhino Server and keep the old SSL certificate.
Renew the certificates on orcharhino Server and any orcharhino Proxy Servers.
Deploy the dual CA certificate on hosts.
Remove the old certificate from the CA certificates file on orcharhino Server, so the CA certificate file contains only the new SSL certificate.
Deploy the new CA certificate on hosts.
12.2. Renewing a custom SSL certificate on orcharhino Server
Use this procedure to update your custom SSL certificate for orcharhino Server.
You must create a new Certificate Signing Request (CSR) and send it to the Certificate Authority to sign the certificate. Refer to the Configuring orcharhino Server with a custom SSL certificate guide before creating a new CSR because the Server certificate must have X.509 v3
Key UsageandExtended Key Usageextensions with required values. In return, you will receive the orcharhino Server certificate and CA bundle.
Deploy the renewed CA certificates to orcharhino Server:
# orcharhino-installer --scenario katello \ --certs-server-cert "/root/orcharhino_cert/orcharhino_cert.pem" \ --certs-server-key "/root/orcharhino_cert/orcharhino_cert_key.pem" \ --certs-server-ca-cert "/root/orcharhino_cert/ca_cert_bundle.pem" \ --certs-update-server \ --certs-update-server-ca
ImportantDo not delete the certificate files after you deploy the certificate. They are required when upgrading orcharhino Server.
Access the orcharhino management UI from your local machine. For example,
https://orcharhino.example.com. -
If you have changed the CA certificate on orcharhino Server, refresh the CA certificate on your hosts. For more information, see Refreshing the self-signed CA certificate on hosts in Managing hosts.
12.3. Renewing a custom SSL certificate on orcharhino Proxy Server
Use this procedure to update your custom SSL certificate for orcharhino Proxy Server.
The orcharhino-installer command, which the foreman-proxy-certs-generate command returns, is unique to each orcharhino Proxy Server.
You cannot use the same command on more than one orcharhino Proxy Server.
You must create a new Certificate Signing Request and send it to the Certificate Authority to sign the certificate. Refer to the Configuring orcharhino Server with a custom SSL certificate guide before creating a new CSR because the orcharhino Server certificate must have X.509 v3
Key UsageandExtended Key Usageextensions with required values. In return, you will receive the orcharhino Proxy Server certificate and CA bundle.
On your orcharhino Server, generate the certificate archive file for your orcharhino Proxy Server:
# foreman-proxy-certs-generate \ --certs-tar "/root/My_Certificates/orcharhino-proxy.example.com-certs.tar" \ --certs-update-server \ --foreman-proxy-fqdn "orcharhino-proxy.example.com" \ --server-ca-cert "/root/My_Certificates/ca_cert_bundle.pem" \ --server-cert "/root/My_Certificates/orcharhino-proxy_cert.pem" \ --server-key "/root/My_Certificates/orcharhino-proxy_cert_key.pem"
On your orcharhino Server, copy the certificate archive file to your orcharhino Proxy Server:
# scp /root/My_Certificates/orcharhino-proxy.example.com-certs.tar user@orcharhino-proxy.example.com:
Retain a copy of the
orcharhino-installercommand that theforeman-proxy-certs-generatecommand returns for deploying the certificate to your orcharhino Proxy Server. -
Deploy the certificate on your orcharhino Proxy Server using the
orcharhino-installercommand returned by theforeman-proxy-certs-generatecommand:# orcharhino-installer --scenario foreman-proxy-content \ --certs-tar-file "/root/My_Certificates/orcharhino-proxy.example.com-certs.tar" \ --certs-update-server \ --foreman-proxy-foreman-base-url "https://orcharhino.example.com"
ImportantDo not delete the certificate archive file on the orcharhino Proxy Server after you deploy the certificate. They are required when upgrading orcharhino Proxy Server.
13. Synchronizing template repositories
In orcharhino, you can synchronize repositories of job templates, provisioning templates, report templates, and partition table templates between orcharhino Server and a version control system or local directory. This section details the workflow for installing and configuring the Template Sync plugin and performing exporting and importing tasks.
13.1. Enabling the Template Sync plugin
You can enable the Template Sync plugin to synchronize provisioning templates, report templates, and other templates between your orcharhino Server and a version control system or local directory. This is useful when you want to manage templates in Git repositories or keep templates synchronized across multiple orcharhino instances.
Enable the plugin on your orcharhino Server:
# orcharhino-installer --enable-foreman-plugin-templates
Optional: Enable the Hammer CLI plugin on your orcharhino Server:
# orcharhino-installer --enable-foreman-cli-templates
In the orcharhino management UI, navigate to Administer > About.
On the Plugins tab, ensure that the page includes the Template Sync plugin.
In the orcharhino management UI, navigate to Administer > Settings > Template Sync to configure the plugin. For more information, see Template sync settings.
13.2. Synchronizing templates with an existing repository
If you store templates in a repository under a version control system, you can synchronize the templates between your orcharhino Server and the repository.
If you want to use HTTPS to connect to the repository and you use a self-signed certificate authority (CA) on your Git server:
Create a new directory under the
/usr/share/foreman/directory to store the Git configuration for the certificate:# mkdir --parents /usr/share/foreman/.config/git
Create a file named
configin the new directory:# touch /usr/share/foreman/.config/git/config
Allow the
foremanuser access to the.configdirectory:# chown --recursive foreman /usr/share/foreman/.config
Update the Git global configuration for the
foremanuser with the path to your self-signed CA certificate:# sudo --user foreman git config --global http.sslCAPath Path_To_CA_Certificate
If you want to use SSH to connect to the repository:
Create an SSH key pair if you do not already have it. Do not specify a passphrase.
Configure your version control server with the public key from your orcharhino, which resides in
/usr/share/foreman/.ssh/id_rsa.pub. -
Accept the Git SSH host key as the
foremanuser:# sudo --user foreman ssh git.example.com
In the orcharhino management UI, provide details for your Git repository:
Navigate to Administer > Settings.
Click the Template Sync tab.
Change the Branch setting to define the target branch of the repository.
Change the Repo setting to define the repository URL.
If you want to use an HTTP proxy to connect to the repository, change the HTTP proxy policy setting to
Global default HTTP proxyorCustom HTTP proxy.
Import templates from your repository or export templates to your repository.
13.3. Synchronizing templates with a local directory
If you store templates in a local directory that is tracked under a version control system, you can synchronize the templates between your orcharhino Server and the local directory.
Each template must contain the location and organization that the template belongs to. This applies to all template types. Before you import a template, ensure that you add the following section to the template:
<%# kind: provision name: My_Provisioning_Template oses: - My_first_Operating_System - My_second_Operating_System locations: - My_first_Location - My_second_Location organizations: - My_first_Organization - My_second_Organization %>
On your orcharhino Server, in
/var/lib/foreman, create a directory for storing templates:# mkdir /var/lib/foreman/My_Templates_Dir
NoteYou can place your templates to a custom directory outside
/var/lib/foreman, but you have to ensure that theForemanservice can read its contents. The directory must have the correct file permissions and theforeman_lib_tSELinux label. -
Change the owner of the new templates directory to the
foremanuser:# chown foreman /var/lib/foreman/My_Templates_Dir
Change the Repo setting on the Template Sync tab to match the
/var/lib/foreman/My_Templates_Dir/directory.
13.4. Importing templates by using orcharhino management UI
You can import templates from a repository of your choice from the orcharhino management UI.
You can use different protocols to point to your repository, for example /tmp/dir, git://example.com, https://example.com, and ssh://example.com.
The templates provided by orcharhino are locked and you cannot import them by default.
To overwrite this behavior, change the |
In the orcharhino management UI, navigate to Hosts > Templates > Sync Templates.
Click Import.
Each field is populated with values configured in Administer > Settings > Template Sync. Change the values as required for the templates you want to import. For more information about each field, see Template sync settings.
Click Submit.
The orcharhino management UI displays the status of the import. The status is not persistent; if you leave the status page, you cannot return to it.
13.5. Importing templates by using Hammer CLI
You can import templates from a repository of your choice by using Hammer CLI.
Import a template from a repository:
$ hammer import-templates \ --branch "My_Branch" \ --filter '.*Template Name$' \ --organization "My_Organization" \ --prefix "[Custom Index] " \ --repo "https://git.example.com/path/to/repository"
For better indexing and management of your templates, use
--prefixto set a category for your templates. To select certain templates from a large repository, use--filterto define the title of the templates that you want to import. For example--filter '.*Ansible Default$'imports various Ansible Default templates.
13.6. Importing templates by using orcharhino API
You can import templates from a repository of your choice by using orcharhino API.
Send a
POSTrequest toapi/v2/templates/import:# curl -H "Accept:application/json" \ -H "Content-Type:application/json" \ -u login:password \ -k https://orcharhino.example.com/api/v2/templates/import \ -X POST
If the import is successful, you receive
{"message":"Success"}.
13.7. Importing templates using Ansible
You can import templates from a repository of your choice.
Use the
theforeman.foreman.templates_importmodule.
13.8. Exporting templates by using orcharhino management UI
You can export templates to an existing repository from the orcharhino management UI.
Click Export.
Each field is populated with values configured in Administer > Settings > Template Sync. Change the values as required for the templates you want to export. For more information about each field, see Template sync settings.
Click Submit.
The orcharhino management UI displays the status of the export. The status is not persistent; if you leave the status page, you cannot return to it.
13.9. Exporting templates by using Hammer CLI
You can export templates to an existing repository.
Export all templates to a repository:
$ hammer export-templates \ --organization "My_Organization" \ --repo "https://git.example.com/path/to/repository"
NoteThis command clones the repository, makes changes in a commit, and pushes back to the repository. You can use the
--branch "My_Branch"option to export the templates to a specific branch.
13.10. Exporting templates by using orcharhino API
You can export templates to an existing repository by using orcharhino API.
Send a
POSTrequest toapi/v2/templates/export:# curl -H "Accept:application/json" \ -H "Content-Type:application/json" \ -u login:password \ -k https://orcharhino.example.com/api/v2/templates/export \ -X POST
If the export is successful, you receive
{"message":"Success"}.NoteYou can override default API settings by specifying them in the request with the
-dparameter. The following example exports templates to thegit.example.com/templatesrepository:# curl -H "Accept:application/json" \ -H "Content-Type:application/json" \ -u login:password \ -k https://orcharhino.example.com/api/v2/templates/export \ -X POST \ -d "{\"repo\":\"git.example.com/templates\"}"
13.11. Uninstalling the Foreman templates plugin
Disable the plugin using the orcharhino installer:
# orcharhino-installer --no-enable-foreman-plugin-templates
Clean custom data of the plugin. The command does not affect any templates that you created.
Uninstall the plugin:
14. Monitoring orcharhino resources
You can use orcharhino management UI to monitor your orcharhino environment and hosts. This includes details of hosts, such as configuration or compliance, and information about content and orcharhino Proxies.
14.1. Using the orcharhino content dashboard
The orcharhino content dashboard contains various widgets which provide an overview of the host configuration, content views, compliance reports, and hosts currently registered, promotions and synchronization, and a list of the latest notifications.
In the orcharhino management UI, navigate to Monitor > Dashboard to access the content dashboard. The dashboard can be rearranged by clicking on a widget and dragging it to a different position. The following widgets are available:
- Host Configuration Status
Table 4. Host configuration states Icon State Description
Hosts in error state
noopmode.
Out of sync hosts
Hosts with no reports
Hosts with alerts disabled
- Host Configuration Chart
- Latest Events
A graph shows the distribution of the running Puppet agents during the last puppet interval which is 30 minutes by default. In this case, each column represents several reports received from clients during 3 minutes.
- New Hosts
- Task Status
- Latest Warning/Error Tasks
- Discovered Hosts
- Latest Errata
A list of all errata available for hosts registered to orcharhino.
- Content Views
A list of all content views in orcharhino and their publish status.
- Sync Overview
An overview of all products or repositories enabled in orcharhino and their synchronization status. All products that are in the queue for synchronization, are unsynchronized or have been previously synchronized are listed in this section.
- Host Collections
A list of all host collections in orcharhino and their status, including the number of content hosts in each host collection.
virt-whodaemon running on hosts in the environment. The following table shows the possible states.Table 5. virt-who configuration states State Description No Reports
No report has been received because either an error occurred during the virt-who configuration deployment, or the configuration has not been deployed yet, or virt-who cannot connect to orcharhino during the scheduled interval.
No Change
OK
Total Configurations
- Latest Compliance Reports
- Insights Actions
Insights is a tool embedded in orcharhino that checks the environment and suggests actions you can take. The actions are divided into 4 categories: Availability, Stability, Performance, and Security.
- Insights Risk Summary
14.2. Managing tasks
You can monitor and manage all planned or performed tasks, such as repositories synchronized, errata applied, and content views published, to track progress, troubleshoot issues, or adjust timeout settings for low bandwidth or high latency environments.
- Reviewing the log
To review the log, in the orcharhino management UI, navigate to Monitor > orcharhino Tasks > Tasks.
- Adjusting timeout settings
NoteAdjusting the %_finish_timeout values might help in case of low bandwidth. Adjusting the %_accept_timeout values might help in case of high latency.
- Disabling checking for services
Click Save.
14.3. Configuring RSS notifications
You can configure custom RSS feed notifications to receive event alerts from your preferred sources, such as project blogs or internal news feeds, instead of the default notification sources.
To view orcharhino event notification alerts, click the Notifications icon in the upper right of the screen.
By default, the Notifications area displays RSS feed events published in the orcharhino news.
You can configure the RSS feed notifications by changing the URL feed. The supported feed format is RSS 2.0 and Atom.
In the orcharhino management UI, navigate to Administer > Settings and select the Notifications tab.
14.4. Monitoring orcharhino Server
Audit records list the changes made by all users on orcharhino. This information can be used for maintenance and troubleshooting.
In the orcharhino management UI, navigate to Monitor > Audits to view the audit records.
Obtain a list of all audit attributes:
14.5. Monitoring orcharhino Proxy Server
The following section shows how to use the orcharhino management UI to find orcharhino Proxy information valuable for maintenance and troubleshooting.
14.5.1. Viewing general orcharhino Proxy information
You can view general information about your orcharhino Proxies in the orcharhino management UI, such as their status, enabled features, and managed hosts, to verify configuration or troubleshoot connectivity issues.
In the orcharhino management UI, navigate to Infrastructure > orcharhino Proxies to view a table of orcharhino Proxy Servers registered to orcharhino Server. The information contained in the table answers the following questions:
- Is orcharhino Proxy Server running?
This is indicated by a green icon in the Status column. A red icon indicates an inactive orcharhino Proxy, use the
service foreman-proxy restartcommand on orcharhino Proxy Server to activate it. - What services are enabled on orcharhino Proxy Server?
In the Features column, you can verify if, for example, your orcharhino Proxy provides a DHCP service or acts as a Pulp mirror. orcharhino Proxy features can be enabled during installation or configured in addition. For more information, see Installing orcharhino Proxy Server.
- What organizations and locations is orcharhino Proxy Server assigned to?
A orcharhino Proxy Server can be assigned to multiple organizations and locations, but only orcharhino Proxies belonging to the currently selected organization are displayed. To list all orcharhino Proxies, select Any Organization from the context menu in the top left corner.
After changing the orcharhino Proxy configuration, select Refresh from the drop-down menu in the Actions column to ensure the orcharhino Proxy table is up to date.
Click the orcharhino Proxy name to view further details. At the Overview tab, you can find the same information as in the orcharhino Proxy table. In addition, you can answer to the following questions:
- Which hosts are managed by orcharhino Proxy Server?
- How much storage space is available on orcharhino Proxy Server?
/var/lib/pulpis displayed. Also the remaining storage space available on the orcharhino Proxy can be ascertained.
14.5.2. Monitoring services
You can view the status and configuration details of orcharhino Proxy services in orcharhino management UI. This helps you verify that your orcharhino Proxy services are running correctly and troubleshoot any issues.
In the orcharhino management UI, navigate to Infrastructure > orcharhino Proxies and click the name of the selected orcharhino Proxy.
At the Services tab, you can find basic information on orcharhino Proxy services, such as the list of DNS domains, or the number of Pulp workers.
The appearance of the page depends on what services are enabled on orcharhino Proxy Server. Services providing more detailed status information can have dedicated tabs at the orcharhino Proxy page. For more information, see Monitoring Puppet.
14.5.3. Monitoring Puppet
You can monitor Puppet activity and certificate management for each orcharhino Proxy.
The Puppet and Puppet CA tabs are available only if you have Puppet enabled in your orcharhino. |
Click the name of your orcharhino Proxy.
At the Puppet tab you can find the following:
A table of CA certificates associated with the orcharhino Proxy at the Certificates sub-tab. Here you can inspect the certificate expiry data, or cancel the certificate by clicking Revoke.
15. Limiting host resources
You can use the Resource Quota plugin to limit users' access to host resources during host provisioning.
Each host is assigned to exactly one resource quota.
By default, orcharhino assigns the Unassigned resource quota to hosts during global registration.
This means that the host is not assigned to a specific pool of resources.
In a typical usage scenario, orcharhino manages multiple compute resources for multiple departments. To share managed resources in a fair and predictable way, administrators can assign resource quotas to users and user groups.
- Supported resource types
CPU cores
Memory
Disk space
- Supported compute resources
VMware
libvirt
15.1. Installing the Resource Quota plugin
To limit host resources for your orcharhino users, install the Resource Quota plugin.
Install the plugin on your orcharhino Server:
# orcharhino-installer --enable-foreman-plugin-resource-quota
Optional: Install the Hammer CLI plugin on your orcharhino Server:
# orcharhino-installer --enable-foreman-cli-resource-quota
15.2. Managing resource quotas
You can create, edit, and delete resource quotas in orcharhino management UI. All resource quotas are listed on Configure > Resource Quotas.
15.2.1. Creating a resource quota by using orcharhino management UI
Create a resource quota to limit the resource consumption of orcharhino users by using the orcharhino management UI.
In the orcharhino management UI, navigate to Configure > Resource Quotas.
Click Create resource quota.
Specify the name, CPU cores, memory, and disk space.
Click Create resource quota to submit the resource quota to orcharhino.
15.2.2. Creating a resource quota by using Hammer CLI
Create a resource quota to limit the resource consumption of orcharhino users by using Hammer CLI.
Create a resource quota:
$ hammer resource-quota create \ --cpu-cores My_CPU_Cores \ --description My_Resource_Quota_Description \ --disk-space My_Disk_Space_in_GiB \ --memory My_Memory_in_MiB \ --name "My_Resource_Quota_Name"
For all options, see
hammer resource-quota create --help.
15.2.3. Editing a resource quota by using orcharhino management UI
You can edit a resource quota to adjust available resources to orcharhino users by using orcharhino management UI.
Select your resource quota.
Adjust the CPU cores, Memory, or Disk space and click Apply to submit your changes to orcharhino.
15.2.4. Editing a resource quota by using Hammer CLI
You can edit a resource quota to adjust available resources to orcharhino users by using Hammer CLI.
Optional: List all resource quotas:
Edit a resource quota:
$ hammer resource-quota update \ --cpu-cores My_CPU_Cores \ --description My_Resource_Quota_Description \ --disk-space My_Disk_Space_in_GiB \ --id My_Resource_Quota_ID \ --memory My_Memory_in_MiB \ --name "My_Resource_Quota_Name"
If you set the value to
0, users cannot consume any resource at all. To reset resource quotas, you can use--remove-cpu-cores-limit,--remove-disk-space-limit, and--remove-memory-limit.For all options, see
hammer resource-quota update --help.
15.2.5. Deleting a resource quota by using orcharhino management UI
You can delete a resource quota from orcharhino by using orcharhino management UI.
In the Actions column, click Delete for your resource quota.
15.2.6. Deleting a resource quota by using Hammer CLI
You can delete a resource quota from orcharhino by using Hammer CLI.
Delete a resource quota:
hammer resource-quota delete --help.
15.3. Assigning resource quotas to users
You can assign resource quotas to users or user groups.
A user can select one of their assigned resource quotas during host provisioning.
If Resource Quota optional assignment is set to No, a user does not have to assign a resource quota.
You can use the resource_quota filter in the orcharhino management UI to view users or user groups with assigned resource quotas.
15.3.1. Assigning resource quotas to a user by using orcharhino management UI
You can assign resource quotas to a user to limit the resource consumption of that orcharhino user by using orcharhino management UI.
Select a user.
On the Resource Quota tab, assign resource quotas to the user.
If you want to make the usage of resource quotas optional, select the Optional Assignment checkbox.
This means that orcharhino will not prevent users from consuming more resources than their assigned quota.
Click Submit to assign resource quotas to a user.
15.3.2. Assigning resource quotas to a user by using Hammer CLI
You can assign resource quotas to a user to limit the resource consumption of that orcharhino user by using Hammer CLI
Optional: List all orcharhino users:
Assign resource quotas to a user:
$ hammer user update \ --id My_User_ID \ --resource-quota-ids My_Resource_Quota_IDs
If you want to make resource quota optional, add the
--resource-quota-is-optional trueoption.For all options, see
hammer user update --help.
15.3.3. Assigning resource quotas to a user group by using orcharhino management UI
You can assign resource quotas to a user group to limit the resource consumption of that orcharhino user group. All users of the user group share the pool of resources.
In the orcharhino management UI, navigate to Administer > User Groups.
On the Resource Quota tab, assign resource quotas to the user group.
Click Submit to assign resource quotas to a user group.
15.3.4. Assigning resource quotas to a user group by using Hammer CLI
You can assign resource quotas to a user group to limit the resource consumption of that orcharhino user group by using Hammer CLI. All users of the user group share the pool of resources.
Optional: List all orcharhino user groups:
Assign resource quotas to a user group:
$ hammer user-group update \ --id My_User_Group_ID \ --resource-quota-ids My_Resource_Quota_IDs
hammer user-group update --help.
15.4. Viewing resource quotas by using orcharhino management UI
You can use orcharhino management UI to view the resource quota of hosts.
In the orcharhino management UI, navigate to Hosts > All Hosts.
In the search bar, filter your hosts. For example,
resource_quota = Unassigned.For more information, see Searching and bookmarking.
15.5. Viewing resource quotas by using Hammer CLI
Optional: Retrieve the ID of your host:
$ hammer host list
Display the resource quota assigned to your host:
$ hammer host info \ --fields "Id,Name,Resource quota id" \ --id My_Host_ID
15.6. Resource Quota settings
You can configure the following global orcharhino settings for the Resource Quota plugin:
- Global Resource Quota no action
orcharhino will not limit the resource consumption if a resource quota is exceeded.
- Resource Quota optional assignment
orcharhino will not enforce selecting a resource quota during host provisioning. The global setting overwrites user-specific and user group-specific configuration options.
16. Using webhooks
A webhook is a way for a web page or web application to provide other applications with information in real time. You can use webhooks to define a call to an external API based on orcharhino internal event by using a fire-and-forget message exchange pattern.
The typical use case for webhooks in orcharhino is making a call to a monitoring system when a host is created or deleted.
Webhooks are useful where the action you want to perform in the external system can be achieved through its API. Where it is necessary to run additional commands or edit files, the shellhooks plugin for orcharhino Proxies is available. The shellhooks plugin enables you to define a shell script on the orcharhino Proxy that can be executed through the API.
16.1. Installing the webhooks plugin
Use the following procedure to install the webhooks plugin. Then, you can configure orcharhino Server to send webhook requests.
On your orcharhino Server, install the webhooks plugin:
# orcharhino-installer --enable-foreman-plugin-webhooks
Optional: Install the webhooks CLI plugin:
# orcharhino-installer --enable-foreman-cli-webhooks
16.2. Creating a webhook template
Webhook templates are used to generate the body of HTTP request to a configured target when a webhook is triggered. Use the following procedure to create a webhook template in the orcharhino management UI.
In the orcharhino management UI, navigate to Administer > Webhook > Webhook Templates.
A webhook HTTP payload must be created using orcharhino template syntax. The webhook template can use a special variable called
@objectthat can represent the main object of the event.@objectcan be missing in case of certain events. You can determine what data are actually available with the@payloadvariable.For more information, see Template Writing Reference in Managing hosts and for available template macros and methods, visit
/templates_docon orcharhino Server. -
Click Submit.
16.3. Creating a webhook
You can customize events, payloads, HTTP authentication, content type, and headers through the orcharhino management UI.
Use the following procedure to create a webhook in the orcharhino management UI.
In the orcharhino management UI, navigate to Administer > Webhook > Webhooks.
Click Create new.
Click Template to select a template. Webhook templates are used to generate the body of the HTTP request to orcharhino Server when a webhook is triggered.
Enter an HTTP method.
Click the Credentials tab.
Optional: Uncheck Verify SSL if you do not want to verify the server certificate against the system certificate store or orcharhino CA.
16.4. Available webhook events
The following table contains a list of webhook events that are available from the orcharhino management UI.
A content view was successfully promoted. |
Actions::Katello::ContentView::Promote |
Actions::Katello::ContentView::Publish |
Run OpenSCAP scan. |
Runs an Ansible Playbook containing all the roles defined for a host. |
Actions Remote Execution Run Host Job Ansible Run orcharhino Proxy Upgrade Succeeded |
Upgrade orcharhino Proxies on given orcharhino Proxy Servers. |
Run an Ansible Playbook against given hosts. |
Run an Ansible Playbook to enable the web console on given hosts. |
Build Entered |
Custom event: |
Build Exited |
Custom event: |
Common database operations on a content view. |
Katello::ContentView |
Domain |
Host |
Hostgroup |
Model |
Status Changed |
Custom event: |
Subnet |
Template Render Performed |
Template |
User |
16.5. Shellhooks
With webhooks, you can only map one orcharhino event to one API call. For advanced integrations, where a single shell script can contain multiple commands, you can install a orcharhino Proxy shellhooks plugin that exposes executables by using a REST HTTP API.
You can then configure a webhook to reach out to a orcharhino Proxy API to run a predefined shellhook. A shellhook is an executable script that can be written in any language provided that it can be executed. The shellhook can for example contain commands or edit files.
You can pass arguments to shellhook script by using HTTP headers in format X-Shellhook-Arg-1 to X-Shellhook-Arg-99.
For more information on passing arguments to shellhook script, see:
The HTTP method must be POST.
An example URL would be: https://orcharhino-proxy.example.com:9090/shellhook/My_Script.
Unlike the |
You must enable orcharhino Proxy Authorization for each webhook connected to a shellhook to enable it to authorize a call.
Standard output and standard error output are redirected to the orcharhino Proxy logs as messages with debug or warning levels respectively.
For an example on creating a shellhook script, see Creating a shellhook to print arguments.
16.6. Installing the shellhooks plugin
Optionally, you can install and enable the shellhooks plugin on each orcharhino Proxy used for shellhooks.
Install the shellhooks plugin on your orcharhino Proxy:
# orcharhino-installer --enable-foreman-proxy-plugin-shellhooks
16.7. Passing arguments to shellhook script using webhooks
16.8. Passing arguments to shellhook script using curl
$ curl \ --data "" \ --header "Content-Type: text/plain" \ --header "X-Shellhook-Arg-1: Version 1.0" \ --header "X-Shellhook-Arg-2: My content view" \ --request POST \ --show-error \ --silent \ https://orcharhino-proxy.example.com:9090/shellhook/My_Script
16.9. Creating a shellhook to print arguments
You have the webhooks and shellhooks plugins installed. For more information, see:
Modify the
/var/lib/foreman-proxy/shellhooks/print_argsscript to print arguments to standard error output so you can see them in the orcharhino Proxy logs:#!/bin/sh # # Prints all arguments to stderr # echo "$@" >&2 -
Click Create new.
In the Target URL field, enter the URL of your orcharhino Proxy Server followed by
:9090/shellhook/print_args:https://orcharhino-proxy.example.com:9090/shellhook/print_args
Note that
On the Credentials tab, check orcharhino Proxy Authorization.
Click Submit. You now have successfully created a shellhook that prints "Hello World!" to orcharhino Proxy logs every time you a remote execution job succeeds.
timeas a command. For more information, see Configuring and setting up remote jobs in Managing hosts. -
Verify that the shellhook script was triggered and printed "Hello World!" to orcharhino Proxy Server logs:
17. Searching and bookmarking
orcharhino features powerful search functionality on most pages of the orcharhino management UI. It enables you to search all kinds of resources that orcharhino manages. Searches accept both free text and syntax-based queries, which can be built by using input prediction. Search queries can be saved as bookmarks for future reuse.
17.1. Query syntax
You can use query syntax to search and filter resources in orcharhino by specifying parameters, operators, and values to find specific hosts, host groups, or other resources based on your criteria.
parameter operator value
17.2. Query operators
You can use comparison operators such as EQUALS, LIKE, and GREATER THAN, along with logical operators AND, OR, and NOT, to build queries that filter and search for resources based on specific criteria.
| Operator | Short Name | Description | Example |
EQUALS |
NOT EQUALS |
LIKE |
NOT LIKE |
GREATER THAN |
LESS THAN |
IN |
NOT IN |
HAS or set? |
NOT HAS or null? |
| Operator | Alternative Notations | Example | ||
and |
<whitespace> |
or |
not |
17.3. Query values
You can use text values and temporal values in your queries, with text values requiring quotes when they contain spaces, and temporal values accepting various date and time formats to filter resources by specific criteria.
- Text Values
Examples:
hostgroup = "Web servers"The search will return hosts with assigned host group named "Web servers".
hostgroup = Web serversThe search will return hosts in the host group Web with any field matching %servers%.
- Temporal Values
"10 January 2017"
"10 Jan 2017"
10-January-2017
10/January/2017
"January 10, 2017"
Warning
17.4. Using free text search
You can use free text search to find resources by searching across multiple fields simultaneously.
17.5. Creating bookmarks
On some pages, there are default bookmarks available for the common searches, for example, all active or disabled hosts.
In the orcharhino management UI, navigate to the page where you want to create a bookmark.
Ensure the Public checkbox is set correctly:
Select the Public checkbox to set the bookmark as public and visible to all users.
Clear the Public checkbox to set the bookmark as private and only visible to the user who created it.
Click Submit.
17.6. Deleting bookmarks
In the orcharhino management UI, navigate to Administer > Bookmarks.
Appendix A: Logging and reporting problems
The following sections describe the most commonly used log files and debugging tools available in orcharhino.
A.1. Configuring logging levels with Hammer CLI
You can use Hammer to log debugging information for various orcharhino components.
The default logging level is INFO.
To list the components whose logging level you can change by using
hammer:$ hammer admin logging --list
To set
DEBUGlevel logging for all components:$ hammer admin logging --all --level-debug # foreman-maintain service restart
To set
PRODUCTIONlevel logging for all components:$ hammer admin logging --all --level-production # foreman-maintain service restart
To set
DEBUGlevel logging for a specific component:$ hammer admin logging --components My_Component --level-debug # foreman-maintain service restart
To list all available logging options:
$ hammer admin logging --help
A.2. Configuring logging type and layout
By default, orcharhino uses file-based logging.
You can use orcharhino-installer to change the logging type and logging layout.
- Configuring logging with journal
Enter the following
orcharhino-installercommand to configure logging to thejournaldservice:# orcharhino-installer \ --foreman-logging-type journald \ --foreman-proxy-log JOURNAL
To inspect the log messages, use the
- Configuring file-based logging
Enter the following
orcharhino-installercommand to configure file-based logging:# orcharhino-installer \ --reset-foreman-logging-type \ --reset-foreman-proxy-log
To inspect the log messages, view these files:
/var/log/foreman-proxy.log
- Procedure for configuring logging to JSON output
On your orcharhino Server, enable logging to JSON output for
orcharhino-installer:# orcharhino-installer \ --foreman-logging-layout json \ --foreman-logging-type file
jq:# cat /var/log/foreman/production.log | jq
A.3. Selective debugging with individual loggers
sqlandldaploggers, enter the following command:# orcharhino-installer \ --foreman-loggers ldap:true \ --foreman-loggers sql:true
# orcharhino-installer --reset-foreman-loggers
A.4. Overview of individual loggers
The following list provides an overview of selected loggers.
app-
Default value: true.
audit-
background-
blob-
ImportantThe
bloblogger might contain sensitive data. dynflow-
ldap-
Default value: false.
notifications-
permissions-
sql-
telemetry-
templates-
A.5. Retrieving the status of services by using Hammer CLI
orcharhino uses a set of back-end services. When troubleshooting, you can check the status of orcharhino services by using Hammer CLI.
Get information from the database and orcharhino services:
$ hammer ping
Run
Perform a health check:
Run
A.6. Restarting services
orcharhino uses a set of back-end services. When troubleshooting, you can restart the services if needed.
Restart orcharhino services:
A.7. Utilities for processing log information
You can collect information from log files to troubleshoot orcharhino.
- sosreport
The
sos reportcommand collects configuration and diagnostic information from a Linux system, such as the running kernel version, loaded modules, running services, and system and service configuration files. Additionally, it collects information about orcharhino, such as its back-end services and tasks. This output is stored in a tar file located at/var/tmp/sosreport-XXX-20171002230919.tar.xz.For more information, run
sos report --helpor see SOS user documentation.ImportantThe
sos reportcommand removes security information such as passwords, tokens, and keys while collecting information. However, the tar files can still contain sensitive information about the orcharhino Server. Send the tar files directly to the intended recipient and not to a public target. - foreman-tail
The
foreman-tailcommand displays orcharhino logs in real time.For more information, see the
foreman-tail(8)man page.
A.8. Log file directories
The following table provides an overview of selected log directories on orcharhino Server.
Subscription management |
Installer |
Foreman maintain |
Foreman proxy |
Foreman |
Apache HTTP server |
Various other log messages |
Puppet |
Candlepin web service logs |
A.9. System journal metadata
The following table lists metadata that the journald service uses in orcharhino.
You can use this metadata to filter your queries.
- AUDIT_ACTION
Audit action performed
- AUDIT_TYPE
Audit resource type
- AUDIT_ID
- AUDIT_ATTRIBUTE
- AUDIT_FIELD_OLD
- AUDIT_FIELD_NEW
- AUDIT_ID
- AUDIT_ATTRIBUTE
Example: Name or description
- EXCEPTION_MESSAGE
- EXCEPTION_CLASS
- EXCEPTION_BACKTRACE
- LOC_ID
Location database ID
- LOC_NAME
Location name
- LOC_LABEL
Location label
- LOGGER
Logger name
- ORG_ID
Organization database ID
- ORG_NAME
Organization name
- ORG_LABEL
Organization label
- REMOTE_IP
Remote IP address of a client
- REQUEST
- SESSION
- TEMPLATE_NAME
Template name
- TEMPLATE_DIGEST
- TEMPLATE_HOST_NAME
- TEMPLATE_HOST_ID
- USER_LOGIN
User login name
Appendix B: Increasing logging levels of orcharhino components
You can set logging levels for individual orcharhino components.
The default logging level is info.
You can increase the logging level of orcharhino components to troubleshoot orcharhino.
Increasing the logging level to debug provides the most detailed information.
B.1. Increasing the logging level for Foreman
By default, you can find the log in /var/log/foreman/production.log.
For more information, see Configuring logging type and layout.
For more information about orcharhino logging settings, use # orcharhino-installer --full-help | grep logging |
Set the logging level to
debug:# orcharhino-installer --foreman-logging-level debug
# orcharhino-installer --reset-foreman-logging-level
B.2. Increasing the logging level for Hammer
In
/etc/hammer/cli_config.yml, set the:log_level:option todebug::log_level: 'debug'
B.3. Increasing the logging level for orcharhino Proxy
By default, you can find the log in /var/log/foreman-proxy/proxy.log.
debug:# orcharhino-installer --foreman-proxy-log-level DEBUG
# orcharhino-installer --reset-foreman-proxy-log-level
B.4. Increasing the logging level for Candlepin
You can find the logs in /var/log/candlepin/candlepin.log and /var/log/candlepin/error.log.
DEBUG:# orcharhino-installer --katello-candlepin-loggers log4j.logger.org.candlepin:DEBUG
# orcharhino-installer \ --katello-candlepin-loggers log4j.logger.org.candlepin:DEBUG \ --katello-candlepin-loggers log4j.logger.org.candlepin.resource.ConsumerResource:WARN \ --katello-candlepin-loggers log4j.logger.org.candlepin.resource.HypervisorResource:WARN
# orcharhino-installer --reset-katello-candlepin-loggers
B.5. Increasing the logging level for Redis
In
/etc/redis/redis.conf, set the logging level todebug:loglevel debug -
Restart the Redis service:
# systemctl restart redis
NoteRunning
orcharhino-installerwill revert the setting to default.
B.6. Increasing the logging level for orcharhino-installer
orcharhino-installer writes logs to /var/log/foreman-installer/.
Increase the logging level of the
orcharhino-installerutility:# orcharhino-installer --verbose-log-level debug
B.7. Increasing the logging level for Pulp
Pulp logs to the systemd journal.
You can view the logs using journalctl --unit 'pulpcore*'.
In
/etc/pulp/settings.py, set the logging level toDEBUG:LOGGING = {"dynaconf_merge": True, "loggers": {'': {'handlers': ['console'], 'level': 'DEBUG'}}} -
Restart the Pulp services:
# systemctl restart \ pulpcore-api \ pulpcore-content \ pulpcore-resource-manager \ pulpcore-worker@\*
NoteRunning
B.8. Increasing the logging level for Puppet agent
You have enabled Puppet on your orcharhino. For more information, see Enabling Puppet integration with orcharhino in Configuring hosts by using Puppet.
debug:# orcharhino-installer --puppet-agent-additional-settings log_level:debug
B.9. Increasing the logging level for Puppet server
debug:# orcharhino-installer --puppet-server-additional-settings log_level:debug
Appendix C: Administration settings
This section contains information about settings that you can edit in the orcharhino management UI by navigating to Administer > Settings.
C.1. General settings
The general settings define system-wide configuration options for orcharhino, including administrator email, instance URL, user interface preferences, HTTP proxy settings, and default language and time zone.
Administrator email address |
orcharhino URL |
URL where your orcharhino instance is reachable. See also Provisioning > Unattended URL. |
Entries per page |
20 |
Number of records shown per page in orcharhino |
Fix DB cache |
No |
orcharhino maintains a cache of permissions and roles.
When set to |
DB pending seed |
No |
Should the |
orcharhino Proxy request timeout |
60 |
Open and read timeout for HTTP requests from orcharhino to orcharhino Proxy (in seconds). |
Login page footer text |
HTTP(S) proxy |
Set a proxy for outgoing HTTP(S) connections from the orcharhino product. System-wide proxies must be configured at the operating system level. |
HTTP(S) proxy except hosts |
Show Experimental Labs |
No |
Display FQDN for hosts |
Yes |
If set to |
Out of sync interval |
30 |
Hosts report periodically, and if the time between reports exceeds this duration in minutes, hosts are considered out of sync.
orcharhino UUID |
orcharhino instance ID. Uniquely identifies a orcharhino instance. |
Default language |
Default timezone |
The time zone to use for new users. |
Instance title |
Saved audits interval |
New host details UI |
Yes |
orcharhino loads the new UI for host details. |
C.2. Tasks settings
The tasks settings define how orcharhino manages background tasks, including timeouts, retry behavior, batch processing, and debugging options for the Dynflow console.
Sync task timeout |
120 |
Enable dynflow console |
Yes |
Enable the Dynflow console ( |
Yes |
The user must be authenticated as having administrative rights before accessing the Dynflow console. |
Proxy action retry count |
4 |
Number of attempts permitted to start a task on the orcharhino Proxy before failing. |
Proxy action retry interval |
15 |
Allow proxy batch tasks |
Yes |
Allow triggering tasks on the orcharhino Proxy in batches. |
Proxy tasks batch size |
100 |
Number of tasks included in one request to the orcharhino Proxy if |
Tasks troubleshooting URL |
It should contain a |
1 |
C.3. Template sync settings
The template sync settings define how orcharhino synchronizes templates with Git repositories, including import and export behavior, filtering, locking, and metadata handling.
Associate |
New |
Associate templates with operating system, organization, and location. |
Branch |
Default branch in Git repo. |
Commit message |
Templates export made by a orcharhino user |
Dirname |
Filter |
Force import |
No |
If set to |
HTTP proxy policy |
Global default HTTP proxy |
Whether to use an HTTP proxy to synchronize templates. The |
Lock templates |
Keep, do not lock new |
Metadata export mode |
Refresh |
Negate |
No |
Prefix |
Repo |
When exporting to |
Verbosity |
No |
C.4. Discovery settings
The Discovery settings define how orcharhino handles discovered hosts, including default organization and location assignment, hostname generation, auto-provisioning behavior, and fact organization.
Discovery location |
Discovery organization |
Interface fact |
discovery_bootif |
Create bond interfaces |
No |
Clean all facts |
No |
Hostname facts |
discovery_bootif |
Auto provisioning |
No |
Reboot |
Yes |
Hostname prefix |
mac |
Fact columns |
Highlighted facts |
Storage facts |
Software facts |
Hardware facts |
Network facts |
IPMI facts |
Lock PXE |
No |
pxelinux_discovery |
Locked PXEGrub template name |
pxegrub_discovery |
PXEGrub template to be used when pinning a host to discovery. |
pxegrub2_discovery |
Force DNS |
Yes |
Error on existing NIC |
No |
Do not permit to discover an existing host matching the MAC of a provisioning Network Interface Card (NIC) (errors out early). |
Type of name generator |
Fact + prefix |
Prefer IPv6 |
No |
C.5. Boot disk settings
iPXE directory |
ISOLINUX directory |
SYSLINUX directory |
Grub2 directory |
Host image template |
Boot disk iPXE - host |
Generic image template |
ISO generation command |
genisoimage |
Installation media caching |
Yes |
Allowed bootdisk types |
C.6. Red Hat Cloud settings
The Red Hat Cloud settings define how orcharhino integrates with Red Hat cloud services, including automatic inventory upload, Insights recommendations synchronization, and hostname and IP address obfuscation.
Automatic inventory upload |
Yes |
Enable automatic upload of your host inventory to the Red Hat cloud. |
Synchronize recommendations Automatically |
No |
Enable automatic synchronization of Insights recommendations from the Red Hat cloud. |
Obfuscate host names |
No |
Obfuscate hostnames sent to the Red Hat cloud. |
Obfuscate host ipv4 addresses |
No |
Obfuscate IPv4 addresses sent to the Red Hat cloud. |
ID of the RHC daemon |
RHC daemon id. |
C.7. Content settings
The content settings define how orcharhino manages content repositories, subscriptions, content views, and host registration, including default templates, download policies, and synchronization behavior.
Default HTTP Proxy |
Kickstart default |
Kickstart default finish |
Default synced OS user-data |
Kickstart default user data |
Kickstart default PXELinux |
Default synced OS PXEGrub template |
Kickstart default PXEGrub |
Default PXEGrub template for new operating systems created from synced content. |
Kickstart default PXEGrub2 |
Kickstart default iPXE |
Kickstart default |
Discovery ATIX AG kexec |
Atomic Kickstart default |
Manifest refresh timeout |
1200 |
Yes |
Can communicate with the ATIX AG Portal for subscriptions. |
No |
Calculate errata host status based only on errata in a host’s content view and lifecycle environment. |
No |
Yes |
100 |
How many repositories should be synced concurrently on a orcharhino Proxy. A smaller number may lead to longer sync times. A larger number will increase dynflow load. |
Sync orcharhino Proxies after Content View promotion |
Yes |
Whether or not to auto sync orcharhino Proxies after a content view promotion. |
Either |
Default ATIX AG Repository download policy |
Default download policy for enabled ATIX AG repositories.
Either |
Default orcharhino Proxy download policy |
Default download policy for orcharhino Proxy syncs.
Either |
Pulp export destination filepath |
On-disk location for exported repositories. |
Pulp client key |
Pulp client cert |
Sync Connection Timeout |
300 |
Delete Host upon unregister |
No |
No |
If this is enabled, and |
Default Location |
Expire soon days |
120 |
No |
Host Duplicate DMI UUIDs |
Host Profile Assume |
Yes |
Enable new host registrations to assume registered profiles with matching hostname if the registering DMI UUID is not used by another host. |
No |
Enable host registrations to bypass Host Profile Assume if the host is in build mode. |
No |
5 |
Applicability Batch Size |
50 |
Autosearch |
Yes |
Autosearch delay |
500 |
Pulp bulk load size |
2000 |
Yes |
1440 |
No |
Yes |
Enable removal of repositories that the user has previously published in one or more content view versions. |
C.8. Authentication settings
The authentication settings define how orcharhino handles user authentication and authorization, including OAuth configuration, SSL certificates, login delegation, idle timeouts, and OpenID Connect integration.
OAuth active |
Yes |
orcharhino will use OAuth for API authorization. This setting is for internal orcharhino use only. ATIX AG does not support using it to configure OAuth authentication for API calls. |
OAuth consumer key |
OAuth consumer key. This setting is for internal orcharhino use only. ATIX AG does not support using it to configure OAuth authentication for API calls. |
OAuth consumer secret |
OAuth consumer secret. This setting is for internal orcharhino use only. ATIX AG does not support using it to configure OAuth authentication for API calls. |
OAuth map users |
No |
orcharhino maps users by username in the request-header. If this is disabled, OAuth requests have administrator rights. This setting is for internal orcharhino use only. ATIX AG does not support using it to configure OAuth authentication for API calls. |
Failed login attempts limit |
30 |
orcharhino blocks user logins from an incoming IP address for 5 minutes after the specified number of failed login attempts. Set to 0 to disable brute force protection. |
Restrict registered orcharhino Proxies |
Yes |
Only known orcharhino Proxies can access features that use orcharhino Proxy authentication. |
Trusted hosts |
List of hostnames, IPv4, IPv6 addresses or subnets to be trusted in addition to orcharhino Proxies for access to fact/report importers and ENC output. |
SSL certificate |
SSL Certificate path that orcharhino uses to communicate with its proxies. |
SSL CA file |
SSL CA file path that orcharhino uses to communicate with its proxies. |
SSL private key |
SSL Private Key path that orcharhino uses to communicate with its proxies. |
SSL client DN env |
HTTP_SSL_CLIENT_S_DN |
SSL client verify env |
HTTP_SSL_CLIENT_VERIFY |
SSL client cert env |
HTTP_SSL_CLIENT_CERT |
Server CA file |
SSL CA file path used in templates to verify the connection to orcharhino. |
Websockets SSL key |
Private key file path that orcharhino uses to encrypt websockets. |
Websockets SSL certificate |
Certificate path that orcharhino uses to encrypt websockets. |
Websockets encryption |
Yes |
Login delegation logout URL |
External |
Authorize login delegation |
No |
No |
Idle timeout |
60 |
BCrypt password cost |
9 |
BMC credentials access |
Yes |
OIDC JWKs URL |
Typically |
OIDC Audience |
OIDC Issuer |
OIDC Algorithm |
C.9. Email settings
The email settings define how orcharhino sends email notifications, including delivery method, SMTP configuration, reply addresses, and welcome email options.
Email reply address |
Email reply address for emails that orcharhino is sending. |
Email subject prefix |
Send welcome email |
No |
Delivery method |
Sendmail |
SMTP enable StartTLS auto |
Yes |
SMTP OpenSSL verify mode |
Default verification mode |
SMTP address |
SMTP address to connect to. |
SMTP port |
25 |
SMTP port to connect to. |
SMTP HELO/EHLO domain |
HELO/EHLO domain. |
SMTP username |
SMTP password |
SMTP authentication |
none |
Sendmail arguments |
-i |
Sendmail location |
C.10. Notifications settings
The notifications settings define how orcharhino retrieves and displays RSS notifications from external feeds.
RSS enable |
Yes |
Pull RSS notifications. |
RSS URL |
C.11. Provisioning settings
The provisioning settings define how orcharhino provisions hosts, including default passwords, template rendering, PXE boot configuration, hostname generation, and virtual machine management.
Host owner |
Default owner on provisioned hosts, if empty orcharhino uses the current user. |
Root password |
Unattended URL |
Safemode rendering |
No |
Query local nameservers |
No |
orcharhino queries the locally configured resolver instead of the SOA/NS authorities. |
Installation token lifetime |
360 |
SSH timeout |
120 |
0.0.0.0 |
No |
orcharhino updates the host IP with the IP that made the build request. |
Use short name for VMs |
No |
orcharhino uses the short hostname instead of the FQDN for creating new virtual machines. |
DNS timeout |
[5, 10, 15, 20] |
Clean up failed deployment |
Yes |
orcharhino deletes the virtual machine if the provisioning script ends with a non-zero exit code. |
iPXE intermediate script |
No |
Destroy associated VM on host delete. When enabled, VMs linked to hosts are deleted on Compute Resource. When disabled, VMs are unlinked when the host is deleted, meaning they remain on Compute Resource and can be re-associated or imported back to orcharhino again. This does not automatically power off the VM |
Maximum structured facts |
100 |
Global Registration |
CoreOS Transpiler Command |
PXEGrub2 global default |
PXELinux global default |
Global default PXEGrub template |
PXEGrub global default |
Global default PXEGrub template. This template is deployed to all configured TFTP servers. It is not affected by upgrades. |
iPXE global default |
PXEGrub2 default local boot |
PXELinux default local boot |
Local boot PXEGrub template |
PXEGrub default local boot |
Template that is selected as PXEGrub default for local boot. |
Local boot iPXE template |
iPXE default local boot |
Manage PuppetCA |
Yes |
orcharhino automates certificate signing upon provision of a new host. |
Use UUID for certificates |
No |
orcharhino uses random UUIDs for certificate signing instead of hostnames. |
C.12. Facts settings
The facts settings define how orcharhino processes and uses facts reported by hosts, including automatic host creation, location and organization assignment, interface updates, and fact filtering.
Yes |
orcharhino creates the host when new facts are received. |
Location fact |
orcharhino_location |
Organization fact |
orcharhino_organization |
Default location |
Default Location |
Default organization |
Default Organization |
Update hostgroup from facts |
Yes |
orcharhino updates a host’s hostgroup from its facts. |
No |
Ignore facts for domain |
No |
Update subnets from facts |
None |
orcharhino updates a host’s subnet from its facts. |
No |
Exclude pattern for facts stored in orcharhino |
Those facts are not stored in the orcharhino database.
Default Puppet environment |
production |
orcharhino defaults to this puppet environment if it cannot auto detect one. |
ENC environment |
Yes |
orcharhino explicitly sets the puppet environment in the ENC yaml output.
No |
orcharhino updates a host’s environment from its facts. |
C.13. Configuration management settings
The configuration management settings define how orcharhino integrates with configuration management tools, including automatic host creation from reports, smart class parameter evaluation, and configuration status tracking.
Yes |
orcharhino creates the host when a report is received. |
Matchers inheritance |
Yes |
orcharhino matchers are inherited by children when evaluating smart class parameters for hostgroups, organizations, and locations. |
orcharhino evaluates host smart class parameters in this order by default. |
Yes |
orcharhino parses ERB in parameters value in the ENC output. |
No |
All hosts show a configuration status even when a Puppet orcharhino Proxy is not assigned. |
Puppet interval |
35 |
Puppet out of sync disabled |
No |
C.14. Remote execution settings
The remote execution settings define how orcharhino executes commands and scripts on remote hosts, including SSH configuration, user management, orcharhino Proxy selection, and job template synchronization.
Fallback to Any Proxy |
No |
Enable Global Proxy |
Yes |
SSH User |
root |
Default user to use for SSH.
Effective User |
root |
Effective User Method |
sudo |
One of [ |
Effective user password |
Sync Job Templates |
Yes |
SSH Port |
22 |
Default port 22.
Connect by IP |
No |
Prefer IPv6 over IPv4 |
No |
Default SSH password |
Default SSH key passphrase |
Workers pool size |
5 |
Restart of the |
Cleanup working directories |
Yes |
Cockpit URL |
Form Job Template |
Run Command - Script Default |
Time to pickup |
86400 |
Time in seconds within which the host has to pick up a job. If the job is not picked up within this limit, the job will be canceled. Applies only to pull-mqtt based jobs. Defaults to one day. |
C.15. Ansible settings
The Ansible settings define how orcharhino integrates with Ansible for configuration management, including connection types, verbosity levels, timeout values, and role import behavior.
Private Key Path |
Override with the |
Connection type |
ssh |
Use this connection type by default when running Ansible Playbooks.
WinRM cert Validation |
validate |
Enable or disable WinRM server certificate validation when running Ansible Playbooks.
Default verbosity level |
Disabled |
orcharhino adds this level of verbosity for additional debugging output when running Ansible Playbooks. |
Post-provision timeout |
360 |
Timeout (in seconds) to set when orcharhino triggers an Ansible roles task playbook after a host is fully provisioned. Set this to the maximum time you expect a host to take until it is ready after a reboot. |
Ansible report timeout |
30 |
No |
Ansible - Ansible Inventory |
orcharhino uses this template to schedule the report with Ansible inventory. |
Ansible roles to ignore |
The roles to exclude when importing roles from orcharhino Proxy.
For example: |
Number of tasks which should be sent to the orcharhino Proxy in one request if |
