1. orcharhino overview
orcharhino is a centralized tool for provisioning, remote management, and monitoring of multiple Enterprise Linux deployments. With orcharhino, you can deploy, configure, and maintain your systems across physical, virtual, and cloud environments.
2. Content and patch management with orcharhino
With orcharhino, you can provide content and apply patches to hosts systematically in all lifecycle stages.
2.1. Content flow in orcharhino
Content flow in orcharhino involves management and distribution of content from external sources to hosts.
Content in orcharhino flows from external content sources to orcharhino Server. orcharhino Proxy Servers mirror the content from orcharhino Server to hosts.
- External content sources
You can configure many content sources with orcharhino. The supported content sources include the Red Hat Customer Portal, custom Deb and Yum repositories, Git repositories, Ansible collections, Docker Hub, SCAP repositories, or internal data stores of your organization.
- orcharhino Server
On your orcharhino Server, you plan and manage the content lifecycle.
- orcharhino Proxy Servers
By creating orcharhino Proxy Servers, you can establish content sources in various locations based on your needs. For example, you can establish a content source for each geographical location or multiple content sources for a data center with separate networks.
- Hosts
By assigning a host system to a orcharhino Proxy Server or directly to your orcharhino Server, you ensure the host receives the content they provide. Hosts can be physical or virtual.
See Major orcharhino components for details.
2.2. Content views in orcharhino
A content view is a deliberately curated subset of content that your hosts can access. By creating a content view, you can define the software versions used by a particular environment or orcharhino Proxy Server.
Each content view creates a set of repositories across each environment. Your orcharhino Server stores and manages these repositories. For example, you can create content views in the following ways:
A content view with older package versions for a production environment and another content view with newer package versions for a Development environment.
A content view with a package repository required by an operating system and another content view with a package repository required by an application.
A composite content view for a modular approach to managing content views. For example, you can use one content view for content for managing an operating system and another content view for content for managing an application. By creating a composite content view that combines both content views, you create a new repository that merges the repositories from each of the content views. However, the repositories for the content views still exist and you can keep managing them separately as well.
A Default Organization View is an application-controlled content view for all content that is synchronized to orcharhino. You can register a host to the Library environment on orcharhino to consume the Default Organization View without configuring content views and lifecycle environments.
You can access unprotected repositories in the Default Organization View content view.
The URL consists of your orcharhino Proxy FQDN, /pulp/content/, your organization label, /Library/custom/, your product label, /, your repository label, and a trailing /, for example, https://orcharhino.example.com/pulp/content/Example/Library/custom/AlmaLinux_9/BaseOS/.
When you promote a content view from one environment to the next environment in the application lifecycle, orcharhino updates the repository and publishes the packages.
| Development | Testing | Production | |
Version of the content view |
Version 2 |
Version 1 |
Version 1 |
Contents of the content view |
my-software-1.1-0.noarch.rpm |
my-software-1.0-0.noarch.rpm |
Version 2 |
Version 2 |
Version 1 |
With Distribute archived content view versions enabled, you can access unprotected repositories in published content view versions.
The URL consists of your orcharhino Proxy FQDN, /pulp/content/, your organization label, /content_views/, your content view, your content view version, /custom/, your product label, /, your repository label, and a trailing /, for example, https://orcharhino.example.com/pulp/content/Example/content_views/AlmaLinux_9/2.1/custom/AlmaLinux_9/BaseOS/.
If you want to access the latest published content view, the URL consists of your orcharhino Proxy FQDN, /pulp/content/, your organization label, your lifecycle, your content view, /custom/, your product label, /, your repository label, and a trailing /, for example, https://orcharhino.example.com/pulp/content/Example/Production/AlmaLinux_9/custom/AlmaLinux_9/AlmaLinux_9/.
You can use these URLs to provide versioned orcharhino Clients during host registration.
For more information, see Managing content views in Managing content.
2.3. Lifecycle environments and environment paths
You can promote content along the environment path to the next lifecycle environment when required. When you promote a content view from one environment to the next environment in the application lifecycle, orcharhino updates the repository and publishes the packages. For example, if development ends on a particular version of an application, you can promote this version to the testing environment and start development on the next version.
2.4. Content types in orcharhino
With orcharhino, you can import and manage many content types. You can use content from Red Hat as well as from Canonical, Oracle, SUSE, and other custom content.
For example, orcharhino supports the following content types:
- RPM packages
Import RPM packages from any repository, for example from Amazon, Oracle, Red Hat, SUSE, and custom repositories. orcharhino Server downloads the RPM packages and stores them locally. You can use these repositories and their RPM packages in content views.
- Deb packages
- Kickstart trees
Import the Kickstart trees to provision a host. New systems access these Kickstart trees over a network to use as base content for their installation. orcharhino contains predefined Kickstart templates. You can also create your own Kickstart templates.
- Provisioning templates
Templates to provision hosts running EL based on synchronized content and Debian, Ubuntu, or SUSE Linux Enterprise Server based on local installation media. orcharhino contains predefined AutoYaST, Kickstart, and Preseed templates as well as the ability to create your own, which are used to provision systems and customize the installation.
- ISO and KVM images
Download and manage media for installation and provisioning. For example, orcharhino downloads, stores, and manages ISO images and guest images for specific Enterprise Linux operating systems.
- Custom file type
2.5. Additional resources
For information about how to manage content with orcharhino, see Managing content.
3. Provisioning management with orcharhino
With orcharhino, you can provision hosts on various compute resources with many provisioning methods from a unified interface.
3.1. Provisioning methods in orcharhino
With orcharhino, you can provision hosts by using the following methods.
- Bare-metal hosts
orcharhino provisions bare-metal hosts primarily by using PXE boot and MAC address identification. When provisioning bare-metal hosts with orcharhino, you can do the following:
Create host entries and specify the MAC address of the physical host to provision.
Boot blank hosts to use the orcharhino Discovery service, which creates a pool of hosts that are ready for provisioning.
Provision hosts with UEFI Secure Boot.
Boot and provision hosts by using PXE-less methods.
- Cloud providers
orcharhino connects to private and public cloud providers to provision instances of hosts from images stored in the cloud environment. When provisioning from cloud with orcharhino, you can do the following:
Select which hardware profile to use.
Provision cloud instances from specific providers by using their APIs.
- Virtualization infrastructure
orcharhino connects to virtualization infrastructure services, such as oVirt and VMware. When provisioning virtual machines with orcharhino, you can do the following:
Provision virtual machines from virtual image templates.
Use the same PXE-based boot methods that you use to provision bare-metal hosts.
For more information, see compute resources.
3.2. Additional resources
For information about how to provision hosts with orcharhino, see Provisioning hosts.
4. Major orcharhino components
A typical orcharhino deployment consists of the following components: a orcharhino Server, orcharhino Proxy Servers that mirror content from orcharhino Server, and hosts that receive content and configuration from orcharhino Server and orcharhino Proxy Servers.
4.1. orcharhino Server overview
orcharhino Server is the central component of a orcharhino deployment where you plan and manage the content lifecycle.
A typical orcharhino deployment includes one orcharhino Server on which you perform the following operations:
Content lifecycle management
Configuration of orcharhino Proxy Servers
Configuration of hosts
Host provisioning
Patch management
Subscription management
orcharhino Server delegates content distribution, host provisioning, and communication to orcharhino Proxy Servers. orcharhino Server itself also includes a orcharhino Proxy.
orcharhino Server also contains a fine-grained authentication system. You can grant orcharhino users permissions to access precisely the parts of the infrastructure for which they are responsible.
For more information about managing permissions, see Managing Users and Roles in Administering orcharhino.
4.2. orcharhino Proxy overview
With orcharhino Proxy Servers, you can extend the reach and scalability of your orcharhino deployment. orcharhino Proxy Servers provide the following functionalities in a orcharhino deployment:
Mirroring content from orcharhino Server to establish content sources in various geographical or logical locations. By registering a host to a orcharhino Proxy Server, you can configure this host to receive content and configuration from the orcharhino Proxy in their location instead of from the central orcharhino Server.
Running localized services to discover, provision, control, and configure hosts.
By using content views, you can specify the exact subset of content that orcharhino Proxy Server makes available to hosts. For more information, see Content and patch management with orcharhino.
4.3. Overview of hosts in orcharhino
A host is any Linux client that orcharhino manages. Hosts can be physical or virtual.
You can deploy virtual hosts on any platform supported by orcharhino, such as Amazon EC2, Google Compute Engine, libvirt, Microsoft Azure, Oracle Linux Virtualization Manager, oVirt, Proxmox, RHV, and VMware vSphere.
With orcharhino, you can manage hosts at scale, including monitoring, provisioning, remote execution, configuration management, software management, and subscription management.
4.4. List of key open source components of orcharhino Server
orcharhino consists of several open source projects integrated with each other, such as the following:
- Foreman
- Katello
Katello is an optional plugin of Foreman that extends Foreman capabilities with additional features for content, subscription, and repository management. Katello enables orcharhino to subscribe to repositories and to download content.
- Candlepin
- Pulp
4.5. orcharhino Proxy features
orcharhino Proxy Servers provide local host management services and can mirror content from orcharhino Server.
To mirror content from orcharhino Server, orcharhino Proxy provides the following functionalities:
- Repository synchronization
orcharhino Proxy Servers pull content for selected lifecycle environments from orcharhino Server and make this content available to the hosts they manage.
- Content delivery
Hosts configured to use orcharhino Proxy Server download content from that orcharhino Proxy rather than from orcharhino Server.
- Host action delivery
orcharhino Proxy Server executes scheduled actions on hosts.
- Red Hat Subscription Management (RHSM) proxy
Hosts are registered to their associated orcharhino Proxy Servers rather than to the central orcharhino Server or the Red Hat Customer Portal.
You can use orcharhino Proxy to run the following services for infrastructure and host management:
- DHCP
orcharhino Proxy can manage a DHCP server, including integration with an existing solution, such as ISC DHCP servers, Active Directory, and Libvirt instances.
- DNS
orcharhino Proxy can manage a DNS server, including integration with an existing solution, such as ISC BIND and Active Directory.
- TFTP
orcharhino Proxy can integrate with any UNIX-based TFTP server.
- Realm
orcharhino Proxy can manage Kerberos realms or domains so that hosts can join them automatically during provisioning. orcharhino Proxy can integrate with an existing infrastructure, including FreeIPA and Active Directory.
- Puppet server
orcharhino Proxy can act as a configuration management server by running a Puppet server.
- Puppet Certificate Authority
orcharhino Proxy can integrate with the Puppet certificate authority (CA) to provide certificates to hosts.
orcharhino Proxy can provide power management for hosts by using the Intelligent Platform Management Interface (IPMI) or Redfish standards.
- Provisioning template proxy
orcharhino Proxy can serve provisioning templates to hosts.
- OpenSCAP
orcharhino Proxy can perform security compliance scans on hosts.
- Remote Execution (REX)
orcharhino Proxy can run remote job execution on hosts.
You can configure a orcharhino Proxy Server for a specific limited purpose by enabling only selected features on that orcharhino Proxy. Common configurations include the following:
- Infrastructure orcharhino Proxies: DNS + DHCP + TFTP
orcharhino Proxies with these services provide infrastructure services for hosts and have all necessary services for provisioning new hosts.
- Content orcharhino Proxies: Pulp
orcharhino Proxies with this service provide content synchronized from orcharhino Server to hosts.
- Configuration orcharhino Proxies: Pulp + Puppet + PuppetCA
orcharhino Proxies with these services provide content and run configuration services for hosts.
- orcharhino Proxies with DNS + DHCP + TFTP + Pulp + Puppet + PuppetCA
orcharhino Proxies with these services provide a full set of orcharhino Proxy features. By configuring a orcharhino Proxy with all these features, you can isolate hosts assigned to that orcharhino Proxy by providing a single point of connection for the hosts.
4.6. orcharhino Proxy networking
The communication between orcharhino Server and hosts registered to a orcharhino Proxy Server is routed through that orcharhino Proxy Server. orcharhino Proxy Server also provides orcharhino services to hosts.
Many of the services that orcharhino Proxy Server manages use dedicated network ports. However, orcharhino Proxy Server ensures that all communications from the host to orcharhino Server use a single source IP address, which simplifies firewall administration.
In this topology, orcharhino Proxy provides a single endpoint for all host network communications so that in remote network segments, only firewall ports to the orcharhino Proxy itself must be open.
In this topology, hosts connect to orcharhino Server rather than a orcharhino Proxy. This applies also to orcharhino Proxies themselves because the orcharhino Proxy Server is a host of orcharhino Server.
You can find complete instructions for configuring the host-based firewall to open the required ports in the following documents:
Ports and Firewalls Requirements in Installing orcharhino Server
Ports and Firewalls Requirements in Installing orcharhino Proxy Server
4.7. Additional resources
See Installing orcharhino Proxy Server for details on orcharhino Proxy Server requirements, installation, and scalability considerations.
See Configuring orcharhino Proxies with a load balancer for details on distributing load among orcharhino Proxy Servers.
5. orcharhino infrastructure organization concepts
You can use several elements to structure and organize the resources within your orcharhino environment.
5.1. Organizations and locations in orcharhino
On your orcharhino Server, you can define organizations and locations to help organize content, hosts, and configurations. Organizations and locations enable you to arrange orcharhino resources into logically structured groups. For example, you can create groups based on ownership, purpose, content, or security level. You can create and manage multiple organizations through orcharhino, then divide and assign subscriptions to each individual organization.
- Organizations
Organizations typically represent different business units, departments, or teams, such as Finance, Marketing, or Web Development. Each organization requires a separate Red Hat subscription manifest.
- Locations
Locations typically represent physical locations, such as countries or cities.
You can use locations to map the network infrastructure to prevent incorrect host placement or configuration. While you cannot assign a subnet, domain, or compute resources directly to a orcharhino Proxy Server, you can assign them to a location.
Unlike organizations, locations can have a hierarchical structure.
orcharhino Server defines all locations and organizations. Each orcharhino Proxy Server synchronizes content and handles configuration of hosts in a different location.
Your orcharhino Server retains the management function, while the content and configuration is synchronized between your orcharhino Server and orcharhino Proxy Servers assigned to certain locations.
The system administrator creates the following organizations on their orcharhino Server:
Finance
Marketing
Sales
Additionally, the administrator creates the following locations on their orcharhino Server:
United States
United Kingdom
Japan
Boston
Phoenix
San Francisco
5.2. Host groups overview
A host group acts as a template for common host settings.
With host groups, you can define many settings for hosts, such as lifecycle environment, content view, or Ansible roles that are available to the hosts. Instead of defining the settings individually for each host, you can use host groups to define common settings once and apply them to multiple hosts.
When you change the settings of an existing host group, the new settings do not propagate to the hosts assigned to the host group. Only Puppet class settings get updated on hosts after you change them in the host group. |
5.3. Host collections overview
A host collection is a group of content hosts.
With host collections, you can perform the same action on multiple hosts at once. These actions include installing, removing, and updating packages and errata, and assigning content view environments.
For example, you can use host collections to group hosts by function, department, or business unit.
5.4. Additional resources
For examples of orcharhino deployment, see Common deployment scenarios.
6. Tools for administration of orcharhino
You can use multiple tools to manage orcharhino.
6.1. orcharhino management UI overview
You can manage and monitor your orcharhino infrastructure from a browser with the orcharhino management UI. For example, you can use the following navigation features in the orcharhino management UI:
| Navigation feature | Description |
Organization dropdown |
Choose the organization you want to manage. |
Location dropdown |
Choose the location you want to manage. |
Monitor |
Content |
Provides content management tools. This includes content views, activation keys, and lifecycle environments. |
Hosts |
Configure |
Provides general configuration tools and data, including host groups and Ansible content. |
Infrastructure |
Provides tools on configuring how orcharhino interacts with the environment. |
Administer |
Provides advanced configuration for settings such as users, role-based access control (RBAC), and general settings. |
6.2. Hammer CLI overview
You can configure and manage your orcharhino Server with CLI commands by using Hammer.
Create shell scripts based on Hammer commands for basic task automation.
Redirect output from Hammer to other tools.
Use the
--debugoption with Hammer to test responses to API calls before applying the API calls in a script. For example:hammer --debug organization list.
To issue Hammer commands, a user must have access to your orcharhino Server.
To ensure a user-friendly and intuitive experience, the orcharhino management UI takes priority when developing new functionality. Therefore, some features that are available in the orcharhino management UI might not yet be available for Hammer. |
In the background, each Hammer command first establishes a binding to the API, then sends a request. This can have performance implications when executing a large number of Hammer commands in sequence. In contrast, scripts that use API commands communicate directly with the orcharhino API and they establish the binding only once.
See Using the Hammer CLI tool for details on using Hammer CLI.
6.3. orcharhino API overview
You can write custom scripts and external applications that access the orcharhino API over HTTP with the Representational State Transfer (REST) API provided by orcharhino Server. Use the REST API to integrate with enterprise IT systems and third-party applications, perform automated maintenance or error checking tasks, and automate repetitive tasks with scripts.
Configure any programming language, framework, or system with support for HTTP protocol to use the API.
Create client applications that require minimal knowledge of the orcharhino infrastructure because users discover many details at runtime.
Adopt the resource-based REST model for intuitively managing a virtualization platform.
Scripts based on API commands communicate directly with the orcharhino API, which makes them faster than scripts based on Hammer commands or Ansible Playbooks relying on modules within theforeman.foreman.
API commands differ between versions of orcharhino. When you prepare to upgrade orcharhino Server, update all the scripts that contain orcharhino API commands. |
See Using the orcharhino REST API for details on using the orcharhino API.
6.4. Remote execution in orcharhino
With remote execution, you can run jobs on hosts from orcharhino Proxies by using shell scripts or Ansible roles and playbooks.
Use remote execution for the following benefits in orcharhino:
Run jobs on multiple hosts at once.
Use variables in your commands for more granular control over the jobs you run.
Use host facts and parameters to populate the variable values.
Specify custom values for templates when you run the command.
Communication for remote execution occurs through orcharhino Proxy Server, which means that orcharhino Server does not require direct access to the target host, and can scale to manage many hosts.
orcharhino uses ERB syntax job templates. For more information, see Template Writing Reference in Managing hosts.
By default, orcharhino includes several job templates for shell scripts and Ansible.
See Configuring and Setting Up Remote Jobs in Configuring hosts by using Ansible.
6.5. Automating orcharhino management with orcharhino Ansible Collection
orcharhino Ansible Collection is a set of Ansible modules that interact with the orcharhino API. You can use these modules to automate many aspects of orcharhino administration.
For more information about using Ansible to configure hosts, see Configuring hosts by using Ansible.
For more information about automating orcharhino using Ansible, see Automating orcharhino management with orcharhino Ansible Collection in Administering orcharhino.
6.6. Kickstart workflow
You can automate the installation process of a orcharhino Server or orcharhino Proxy Server by creating a Kickstart file that contains all the information that is required for the installation.
When you run a orcharhino Kickstart script, the script performs the following actions:
It specifies the installation location of a orcharhino Server or a orcharhino Proxy Server.
It uses Activation Keys to subscribe the hosts to orcharhino.
puppet.conffile to indicate the orcharhino or orcharhino Proxy instance. -
For more information about Kickstart, see Automated installation workflow in Automatically installing RHEL 9.
7. Supported usage and versions of orcharhino components
orcharhino supports the following use cases, architectures, and versions.
7.1. Client operating systems
Using orcharhino, you can manage multiple operating systems that have orcharhino clients:
AlmaLinux
Amazon Linux
CentOS
Debian
Oracle Linux
Red Hat Enterprise Linux
Rocky Linux
Ubuntu
orcharhino can integrate with the following client features:
Ansible
OpenSCAP
OpenSSH
Puppet
Salt
Windows Remote Management (WinRM)
Operating system installers that can perform unattended installations, such as Anaconda or Debian-installer
Katello host tools
Tracer utility
8. Deployment path for orcharhino
During installation and initial configuration of orcharhino, you can customize your deployment to fit your specific needs and operational environment. By customizing each stage of the deployment process, you can choose deployment options that meet the requirements of your organization.
8.1. Installing a orcharhino Server
Installing an instance of orcharhino Server on a dedicated server is the first step to a working orcharhino infrastructure.
For complete information on installing a orcharhino Server, including prerequisites and predefined tuning profiles, see Installing orcharhino Server.
8.1.1. Configuring orcharhino Server with external database
Running the foreman-installer command, used to install a orcharhino Server, also installs PostgreSQL databases on the server.
However, you can configure your orcharhino Server to use external databases instead.
Moving to external databases distributes the workload and can reduce overall orcharhino memory usage.
Consider using external databases if you plan to use your orcharhino deployment for the following scenarios:
Frequent remote execution tasks. This requires a high volume of records in PostgreSQL and generates heavy database workloads.
High disk I/O workloads from frequent repository synchronization or content view publishing. This requires orcharhino to create a record in PostgreSQL for each job.
High volume of hosts.
High volume of synchronized content.
For more information about using an external database, see Using external databases with orcharhino in Installing orcharhino Server.
8.2. Configuring external authentication in orcharhino
orcharhino includes native support for authentication with a username and password. If you require additional methods of authentication, configure your orcharhino Server to use an external authentication source.
| Username and password | Single sign-on (SSO) | One-time password (OTP) | Time-based one-time password (TOTP) | PIV cards | |
Active Directory (direct integration) |
Yes |
Yes |
No |
No |
No |
FreeIPA |
Yes (Linux and Active Directory users) |
Yes (Linux users only) |
No |
No |
No |
Quarkus-based Keycloak |
Yes |
Yes |
Yes |
Yes |
Yes |
Wildfly-based Keycloak |
Yes |
Yes |
Yes |
Yes |
Yes |
LDAP |
Yes |
No |
No |
No |
No |
For more information, see Configuring authentication for orcharhino users.
8.3. Planning organization and location context
Context in orcharhino consists of organizations and locations. You can associate most resources, for example hosts, subnets, and domains, with at least one organization and location context.
Resources and users can generally only access resources within their own context, which makes configuring organizations and locations an integral part of access management in orcharhino.
If you use host groups to bundle provisioning and configuration information, avoid mismatching resources from mutually exclusive contexts. For example, setting a subnet from one organization or location and a compute resource from a different organization or location creates an invalid host group. |
For examples of deployment scenarios, see Common deployment scenarios.
8.4. Installing orcharhino Proxy Servers
By installing orcharhino Proxy Servers, you extend the reach and scalability of your orcharhino deployment. Setting up a orcharhino Proxy Server registers the base operating system on which you are installing to orcharhino Server and configures the new orcharhino Proxy Server to provide the required services within your orcharhino deployment.
You can install a orcharhino Proxy Server in each of your geographic locations. By assigning a orcharhino Proxy to each location, you decrease the load on orcharhino Server, increase redundancy, and reduce bandwidth usage.
The maximum number of orcharhino Proxy Servers that orcharhino Server can support has no fixed limit. It was tested that a orcharhino Server can support 17 orcharhino Proxy Servers with 2 vCPUs. |
Decide what services you want to enable on each orcharhino Proxy Server. You can configure the DNS, DHCP, and TFTP services on one of your orcharhino Proxy Servers or you can use an external server to provide these services to your orcharhino Proxy Servers.
For information on installing orcharhino Proxy Servers, including prerequisites and configuring external services, see Installing orcharhino Proxy Server.
For information on tuning performance by using orcharhino Proxies, see orcharhino Proxy configuration tuning in Tuning performance of orcharhino.
8.5. Adding a Red Hat subscription to orcharhino
If you want to manage hosts running Red Hat Enterprise Linux, import a Red Hat manifest. For more information, see Managing Red Hat subscriptions in Managing content. |
A Red Hat subscription manifest is a set of encrypted files that contains your subscription information. orcharhino Server uses this information to access the Red Hat CDN and find what repositories are available for the associated subscription.
Warning
Deleting a subscription manifest removes all the subscriptions attached to running hosts and activation keys. |
For instructions about creating and importing a Red Hat subscription manifest, see Managing Red Hat subscriptions in Managing content.
For details about using subscription manifests with orcharhino, see Creating and managing manifests for a connected Satellite Server.
8.6. Defining your content library
To ensure that your orcharhino Server can manage software and provide it to your hosts, you must create repositories and synchronize them.
- Red Hat content
The Red Hat subscription manifest determines what Red Hat repositories your orcharhino Server can access. Red Hat content is already organized into products.
For example, Red Hat Enterprise Linux Server is a product in orcharhino. The repositories for the Red Hat Enterprise Linux Server product consist of different versions, architectures, and add-ons. When you enable a Red Hat repository, orcharhino automatically creates an associated product.
- SUSE content
You can use orcharhino to manage hosts running SUSE Linux Enterprise Server. For more information, see Managing SUSE content in Managing content.
- Other sources of content
To distribute content from custom sources, you must create products and repositories manually. You can organize other content into custom products however you want.
For example, you can create an EPEL (Extra Packages for Enterprise Linux) product and add an "EPEL 9 x86_64" repository to it.
Creating repositories allows you to choose the specific software required for your environment. By creating only the necessary repositories, you avoid downloading unnecessary content.
Synchronizing repositories downloads the content from Red Hat CDN or another source to your orcharhino Server. The synchronized content is stored on your orcharhino Server, eliminating the need for hosts to access the repositories. You can synchronize repositories manually, or you can create a sync plan to ensure synchronization runs on a regular basis.
For more information, including procedures for enabling and synchronizing repositories, see Importing custom content in Managing content.
8.7. Defining content access strategies for hosts
When defining your content lifecycle in orcharhino, you can use content views and lifecycle environments to define which hosts can access which content and content versions. By default, orcharhino includes the Default Organization View content view and the Library lifecycle environment.
- Default Organization View
The Default Organization View is the default content view in orcharhino that contains all the content that is synchronized to orcharhino. After you update your content, such as by adding or removing a repository, the update is immediately reflected in Default Organization View.
- Library
The Library lifecycle environment is the default lifecycle environment in orcharhino. Every newly published content view version is automatically published to the Library lifecycle environment. You can also promote specific content view versions to the Library lifecycle environment if needed.
For more information, see Managing application lifecycles, Managing content views, and Restricting hosts' access to content in Managing content.
For examples of content view deployments, see Common deployment scenarios.
8.8. Defining role-based access control policies
Users in orcharhino can have one or more roles assigned. These roles are associated with permissions that enable users to perform specified administrative actions in orcharhino. Permission filters define the actions allowed for a certain resource type.
orcharhino provides a set of predefined roles with permissions sufficient for standard tasks. You can also configure custom roles.
One of the predefined roles is the Default role. orcharhino assigns the Default role to every user in the system. By default, the Default role grants only a limited set of permissions. Be aware that if you add a permission to the Default role, every orcharhino users will gain that permission. Assigning a different role to a user does not remove the Default role from the user. |
The following types of roles are commonly defined within various orcharhino deployments:
- Roles related to applications or parts of infrastructure
- Roles related to a particular stage of the software lifecycle
- Roles related to specific tasks
For more information, including details about creating custom roles and granting permissions to roles, see Managing users and roles in Administering orcharhino.
8.8.1. Best practices for role-based access control in orcharhino
Define the expected tasks and responsibilities: Define the subset of the orcharhino infrastructure that you want the role to access as well as actions permitted on this subset. Think of the responsibilities of the role and how it differs from other roles.
Use predefined roles whenever possible: orcharhino provides several sample roles that you can use. Copying and editing an existing role can be a good start for creating a custom role.
Adopt a granular approach to user role management: Define roles with specific and well-scoped permissions. Note that each user can have multiple roles assigned and that permissions from these roles are cumulative.
Add permissions gradually and test the results: When creating a custom role, start with a limited set of permissions and add permissions one by one, while testing continuously. Ensure to test your custom role to verify that it works as intended.
Consider areas of interest and granting read-only access: Even though a role has a limited area of responsibility, it might need a wider set of permissions. Therefore, you can grant the role a read-only access to parts of orcharhino infrastructure that influence its area of responsibility.
8.9. Configuring provisioning
After your basic orcharhino infrastructure is in place, you can start configuring provisioning to ensure that orcharhino can seamlessly create, configure, and manage hosts.
The process depends on whether you want to provision bare-metal hosts, virtual machines, or cloud instances, but it includes defining installation media, configuring provisioning templates, and other tasks. If you are provisioning virtual machines or cloud instances, you must also integrate your compute provider with orcharhino by connecting the provider as a compute resource to orcharhino.
The following orcharhino features support automating the provisioning of your hosts:
Provisioning templates enable you to define the way orcharhino installs an operating system on your hosts.
The Discovery service enables you to detect unknown hosts and virtual machines on the provisioning network.
Host groups enable you to standardize provisioning of host configurations.
For a complete guide to provisioning, see Provisioning hosts.
8.10. Overview of recommended disaster recovery plans
Choose a disaster recovery plan that best helps ensure the continuity of orcharhino services in your deployment.
- Snapshots of virtualized orcharhino Server
- How do I back up?
Virtualize your orcharhino Server and use the hypervisor tools to take virtual machine snapshots of the server. This method is suitable if you can run orcharhino in a virtual machine.
To recover orcharhino services, restore a virtual machine snapshot.
- Active and passive orcharhino Server, with external storage
- How do I back up?
/var/lib/pulpand database in/var/lib/pgsql. Replicate this storage into a different data center. Attach the storage to a orcharhino Server that is a clone of the primary orcharhino Server but runs passively. - How will I recover in case of a disruptive event?
To recover orcharhino services, switch DNS records of the active orcharhino Server with the passive orcharhino Server. This ensures that the passive server becomes the active server. All hosts remain connected without configuration updates.
- Active and passive orcharhino Server, with backup and restore
- How do I back up?
Ensure periodic backups of your orcharhino Server. Copy this backup to a passive orcharhino Server and restore it on the passive server.
- Dual active orcharhino Server
- How do I back up?
Operate an active, independent orcharhino Server per data center. Hosts from each data center are registered to the orcharhino Server in that data center. Then configure automation to ensure recovery in case of a disruptive event. For example, you can periodically run a health check and if the health check discovers that the current orcharhino Server a host is registered to does not resolve, the host is re-registered to the other orcharhino Server.
To minimize downtime, you can automate the recovery in various ways. For example, you can use the orcharhino Ansible collection. For more information, see Automating orcharhino management with orcharhino Ansible Collection in Administering orcharhino.
To recover orcharhino services, re-register all hosts to the orcharhino Server in the other data center.
You must ensure that content synchronization and content view creation are synchronized to create the same content view in each orcharhino and prevent content drift. Content drift occurs when available content deviates from the intended state defined by a content view. If you fail to prevent content drift, expect inconsistency in the content that is available to hosts.
For a complete guide to disaster recovery, see Preparing for disaster recovery and recovering from data loss in Administering orcharhino.
To create backups of your orcharhino Server and orcharhino Proxy Servers, use the
foreman-maintain backupcommand. For more information, see Backing up orcharhino Server and orcharhino Proxy Server in Administering orcharhino. -
To back up your hosts, you can use remote execution to configure recurring backup tasks that orcharhino will run on the hosts. For more information, see Configuring and setting up remote jobs in Managing hosts.
To create snapshots of hosts, you can use the Snapshot Management plugin. For more information, see Creating snapshots of a host in Managing hosts.
8.11. Additional deployment tasks
orcharhino offers a range of additional capabilities that you can use to further enhance your orcharhino deployment. For example:
- Remote execution commands on hosts
With remote execution, you can perform various tasks on multiple hosts simultaneously. orcharhino supports the following modes of transport for remote execution: pull-based mode (over MQTT/HTTPS) and push-based mode (over SSH).
- Automating tasks with a configuration management tool
By integrating orcharhino with a configuration management tool, you can automate repetitive tasks and ensure consistent configuration of your hosts.
For more information on using Ansible with orcharhino, see Configuring hosts by using Ansible. You will need to enable the Ansible plugin on your orcharhino Server.
For more information on using Puppet with orcharhino, see Configuring hosts by using Puppet.
For more information on using Salt with orcharhino, see Configuring hosts by using Salt. You will need to enable the Salt plugin on your orcharhino Server.
- Security management with OpenSCAP
You can enable the OpenSCAP plugin on your orcharhino Server and any orcharhino Proxy Servers. With OpenSCAP, you can manage compliance policies and run security compliance scans on your hosts. After the scan completes, a compliance report is uploaded to your orcharhino Server.
- Load balancing
With load balancing configured on your orcharhino Proxy Servers, you can improve performance on orcharhino Proxy Servers while also improving performance and stability for host connections to orcharhino.
For more information, see Configuring orcharhino Proxies with a load balancer.
- Incident management with Red Hat Insights
With Red Hat Insights enabled on your orcharhino Server, you can identify key risks to stability, security, and performance.
For more information, see Performing additional configuration on orcharhino Server in Installing orcharhino Server.
9. Common deployment scenarios
This section provides a brief overview of common deployment scenarios for orcharhino. Note that many variations and combinations of the following layouts are possible.
9.1. Single location with segregated subnets
Your infrastructure might require multiple isolated subnets even if orcharhino is deployed in a single geographic location. This can be achieved for example by deploying multiple orcharhino Proxy Servers with DHCP and DNS services, but the recommended way is to create segregated subnets using a single orcharhino Proxy. This orcharhino Proxy is then used to manage hosts and compute resources in those segregated networks to ensure they only have to access the orcharhino Proxy for provisioning, configuration, errata, and general management. For more information on configuring subnets, see Managing hosts.
9.2. Multiple locations
ATIX AG recommends to create at least one orcharhino Proxy Server per geographic location. This practice can save bandwidth since hosts obtain content from a local orcharhino Proxy Server. Synchronization of content from remote repositories is done only by the orcharhino Proxy, not by each host in a location. In addition, this layout makes the provisioning infrastructure more reliable and easier to configure.
9.3. Content view scenarios
A single lifecycle environment – content from Library is promoted directly to the production stage. This approach limits the complexity but still allows for testing the content within the Library before making it available to hosts.
A single lifecycle environment path – both operating system and applications content is promoted through the same path. The path can consist of several stages (for example Development, QA, Production), which enables thorough testing but requires additional effort.
Application specific lifecycle environment paths – each application has a separate path, which allows for individual application release cycles. You can associate specific compute resources with application lifecycle stages to facilitate testing. On the other hand, this scenario increases the maintenance complexity.
9.4. orcharhino Server with multiple manifests
If you plan to have more than one Red Hat Network account, or if you want to manage systems belonging to another entity that is also a Red Hat Network account holder, then you and the other account holder can assign subscriptions, as required, to manifests. A customer that does not have a orcharhino subscription can create a Subscription Asset Manager manifest, which can be used with orcharhino, if they have other valid subscriptions. You can then use the multiple manifests in one orcharhino Server to manage multiple organizations.
If you must manage systems but do not have access to the subscriptions for the RPMs, you must use Red Hat Enterprise Linux orcharhino Add-On. For more information, see orcharhino Add-On.
The following diagram shows two Red Hat Network account holders, who want their systems to be managed by the same orcharhino installation. In this scenario, Example Corporation 1 can allocate any subset of their 60 subscriptions, in this example they have allocated 30, to a manifest. This can be imported into the orcharhino as a distinct Organization. This allows system administrators the ability to manage Example Corporation 1’s systems using orcharhino completely independently of Example Corporation 2’s organizations (R&D, Operations, and Engineering).
When creating a Red Hat subscription manifest:
Add the subscription for orcharhino Server to the manifest if planning a disconnected or self-registered orcharhino Server. This is not necessary for a connected orcharhino Server that is subscribed using the Subscription Manager utility on the base system.
Add subscriptions for all orcharhino Proxy Servers you want to create.
Add subscriptions for all Red Hat products you want to manage with orcharhino.
Note the date when the subscriptions are due to expire and plan for their renewal before the expiry date.
Create one manifest per organization. You can use multiple manifests and they can be from different Red Hat subscriptions.
orcharhino allows the use of future-dated subscriptions in the manifest. This enables uninterrupted access to repositories when future-dated subscriptions are added to a manifest before the expiry date of existing subscriptions.
Note that the Red Hat subscription manifest can be modified and reloaded to orcharhino Server in case of any changes in your infrastructure, or when adding more subscriptions. Manifests should not be deleted. If you delete the manifest from the Red Hat Customer Portal or in the orcharhino management UI it will unregister all of your content hosts.
9.5. Host group structures
- Flat structure
- Lifecycle environment based structure
In this hierarchy, the first host group level is reserved for parameters specific to a lifecycle environment. The second level contains operating system related definitions, and the third level contains application specific settings. Such structure is useful in scenarios where responsibilities are divided among lifecycle environments (for example, a dedicated owner for the Development, QA, and Production lifecycle stages).
- Application based structure
- Location based structure
In this hierarchy, the distribution of locations is aligned with the host group structure. In a scenario where the location (orcharhino Proxy Server) topology determines many other attributes, this approach is the best option. On the other hand, this structure complicates sharing parameters across locations, therefore in complex environments with a large number of applications, the number of host group changes required for each configuration change increases significantly.
9.6. Inter-Server Synchronization scenarios
orcharhino uses Inter-Server Synchronization (ISS) to synchronize content between two orcharhino Servers including those that are air gapped.
If you want to copy some but not all content from your orcharhino Server to other orcharhino Servers. For example, you have content views that your IT department consumes from orcharhino Server, and you want to copy content from those content views to other orcharhino Servers.
If you want to copy all Library content from your orcharhino Server to other orcharhino Servers. For example, you have products and repositories that your IT department consumes from orcharhino Server in the Library, and you want to copy all products and repositories in that organization to other orcharhino Servers.
You cannot use ISS to synchronize content from orcharhino Server to orcharhino Proxy Server. orcharhino Proxy Server supports synchronization natively. |
9.6.1. ISS network sync in a disconnected scenario
The upstream orcharhino Server is connected to the Internet. This server consumes content from the Red Hat Content Delivery Network (CDN) or custom sources.
The downstream orcharhino Server is completely isolated from all external networks.
The downstream orcharhino Server can communicate with a connected upstream orcharhino Server over an internal network.
You can configure your downstream orcharhino Server to synchronize content from the upstream orcharhino Server over the network.
9.6.2. ISS export sync in an air-gapped scenario
The upstream orcharhino Server is connected to the Internet. This server consumes content from the Red Hat CDN or custom sources.
The downstream orcharhino Server does not have a network connection to a connected upstream orcharhino Server.
The only way for an air-gapped downstream orcharhino Server to receive content updates is by exporting payload from the upstream orcharhino Server, bringing it physically to the downstream orcharhino Server, and importing the payload. For more information, see Synchronizing Content Between orcharhino Servers in Managing content.
You can configure your downstream orcharhino Server to synchronize content by using exports.
9.7. Scenarios for orcharhino on AWS
You can deploy orcharhino on Amazon Web Services (AWS) in several scenarios.
This is the least complex configuration of orcharhino in AWS. Deploy both orcharhino Server and the hosts residing within the same region and within the Virtual Private Cloud (VPC) You can also use a different availability zone.
Create a VPN connection between the on-premises location and the AWS region where your orcharhino Proxy Server is located. It is also possible to use the external host name of orcharhino Server when you register the instance that runs orcharhino Proxy.
Create a site-to-site VPN connection between different regions so that you can use the internal DNS host name when you register the instance that runs orcharhino Proxy to orcharhino Server. If you do not establish a site-to-site VPN connection, use the external DNS host name when you register the instance that runs orcharhino Proxy to orcharhino Server.
Most public cloud providers do not charge for data being transferred into a region or between availability zones within a single region. However, they charge for data leaving the region to the Internet. |
10. Provisioning requirements
An important feature of orcharhino is unattended provisioning of hosts. To achieve this, orcharhino uses DNS and DHCP infrastructures, PXE booting, TFTP, and Kickstart. Use this chapter to understand the working principle of these concepts.
10.1. PXE booting
10.1.1. PXE sequence
initrdand Kickstart. -
For an example of using PXE Booting by orcharhino Server, see Provisioning Workflow in Provisioning hosts.
10.1.2. PXE booting requirements
Ensure that all the network-based firewalls are configured to allow clients on the subnet to access the orcharhino Proxy. For more information, see orcharhino Proxy networking.
Ensure that both orcharhino Server and orcharhino Proxy have DNS configured and are able to resolve provisioned host names.
Ensure that the UDP port 69 is accessible by the client so that the client can access the TFTP server on the orcharhino Proxy.
Ensure that the TCP port 80 is accessible by the client to allow the client to download files and Kickstart templates from the orcharhino Proxy.
Ensure that the host provisioning interface subnet has a DHCP orcharhino Proxy set.
Ensure that the host provisioning interface subnet has a TFTP orcharhino Proxy set.
Ensure that the host provisioning interface subnet has a Templates orcharhino Proxy set.
Ensure that DHCP with the correct subnet is enabled using the orcharhino installer.
Enable TFTP using the orcharhino installer.
10.2. HTTP booting
10.2.1. HTTP booting requirements with managed DHCP
All the network-based firewalls are configured to allow clients on the subnet to access the orcharhino Proxy. For more information, see orcharhino Proxy networking.
Your client has access to the HTTP UEFI Boot orcharhino Proxy.
Although TFTP protocol is not used for HTTP UEFI Booting, orcharhino uses TFTP orcharhino Proxy API to deploy boot loader configuration.
For HTTP booting to work, ensure that orcharhino has the following configurations:
Both orcharhino Server and orcharhino Proxy have DNS configured and are able to resolve provisioned host names.
Ensure that the TCP port 8000 is open for the client to download the boot loader and Kickstart templates from the orcharhino Proxy.
The TCP port 9090 is open for the client to download the boot loader from the orcharhino Proxy using the HTTPS protocol.
The subnet that functions as the host’s provisioning interface has a DHCP orcharhino Proxy, an HTTP Boot orcharhino Proxy, a TFTP orcharhino Proxy, and a Templates orcharhino Proxy
10.2.2. HTTP booting requirements with unmanaged DHCP
http://orcharhino-proxy.example.com:8000 -
https://orcharhino-proxy.example.com:9090
Ensure that your client has access to the HTTP UEFI Boot orcharhino Proxy.
Although TFTP protocol is not used for HTTP UEFI Booting, orcharhino use TFTP orcharhino Proxy API to deploy boot loader configuration.
Ensure that the TCP port 8000 is open for the client to download boot loader and Kickstart templates from the orcharhino Proxy.
Ensure that the TCP port 9090 is open for the client to download the boot loader from the orcharhino Proxy through HTTPS.
Ensure that the host provisioning interface subnet has an HTTP Boot orcharhino Proxy set.
10.3. Secure Boot
When orcharhino is installed on Enterprise Linux using foreman-installer, grub2 and shim boot loaders that are signed by Red Hat are deployed into the TFTP and HTTP UEFI Boot directory.
PXE loader options named "SecureBoot" configure hosts to load shim.efi.
On Debian and Ubuntu operating systems, the grub2 boot loader is created using the grub2-mkimage unsigned.
To perform the Secure Boot, the boot loader must be manually signed and key enrolled into the EFI firmware.
Alternatively, grub2 from Ubuntu or Enterprise Linux can be copied to perform booting.
Appendix A: Technical users provided and required by orcharhino
During the installation of orcharhino, system accounts are created. They are used to manage files and process ownership of the components integrated into orcharhino. Some of these accounts have fixed UIDs and GIDs, while others take the next available UID and GID on the system instead. To control the UIDs and GIDs assigned to accounts, you can define accounts before installing orcharhino. Because some of the accounts have hard-coded UIDs and GIDs, it is not possible to do this with all accounts created during orcharhino installation.
The following table lists all the accounts created by orcharhino during installation. You can predefine accounts that have Yes in the Flexible UID and GID column with custom UID and GID before installing orcharhino.
Do not change the home and shell directories of system accounts because they are requirements for orcharhino to work correctly.
Because of potential conflicts with local users that orcharhino creates, you cannot use external identity providers for the system users of the orcharhino base operating system.
foreman |
N/A |
foreman |
N/A |
yes |
/usr/share/foreman |
/sbin/nologin |
foreman-proxy |
N/A |
foreman-proxy |
N/A |
yes |
/usr/share/foreman-proxy |
/sbin/nologin |
apache |
48 |
apache |
48 |
no |
/usr/share/httpd |
/sbin/nologin |
postgres |
26 |
postgres |
26 |
no |
/var/lib/pgsql |
/bin/bash |
pulp |
N/A |
pulp |
N/A |
no |
N/A |
/sbin/nologin |
puppet |
52 |
puppet |
52 |
no |
/sbin/nologin |
saslauth |
N/A |
saslauth |
76 |
no |
/run/saslauthd |
/sbin/nologin |
tomcat |
53 |
tomcat |
53 |
no |
/usr/share/tomcat |
/bin/nologin |
unbound |
N/A |
unbound |
N/A |
yes |
/etc/unbound |
/sbin/nologin |
Appendix B: Glossary of terms used in orcharhino
orcharhino is a complete lifecycle management tool for physical hosts, virtual machines, and cloud instances. Key features include automated host provisioning, configuration management, and content management including patch and errata management. You can automate tasks and quickly provision hosts, all through a single unified interface.
This alphabetically ordered glossary provides an overview of orcharhino related technical terms.
- Activation key
Activation keys are used by Subscription Manager to register hosts to orcharhino. They define content view and lifecycle environment associations, content overrides, system purpose attributes, and other parameters to be associated with a newly created host.
They are associated to exactly one lifecycle environment and exactly one content view, though this may be a composite content view. You can use them on multiple machines and they behave like configuration information rather than traditional software license keys. You can also use multiple activation keys with a single host. When you register a host using an activation key, certain content from orcharhino is provided to the host. The content that is made available depends on the content in the activation key’s content view and lifecycle environment, any content overrides present, any repository-level restrictions such as operating system or architecture, and system purpose attributes such as release version.
- Ansible
Ansible is an agentless open-source automation engine. For hosts running Linux, Ansible uses SSH to connect to hosts. For hosts running Microsoft Windows, Ansible relies on WinRM. It uses playbooks and roles to describe and bundle tasks. Within orcharhino, you can use Ansible to configure hosts and perform remote execution.
For more information about using Ansible to configure hosts, see Configuring hosts by using Ansible. For more information about automating orcharhino using Ansible, see Automating orcharhino management with orcharhino Ansible Collection in Administering orcharhino.
- Answer file
/etc/foreman-installer/scenarios.d/directory. To see the default values for installation scenario parameters, use theforeman-installer --full-helpcommand on your orcharhino Server.
- ARF report
Asset Reporting Format (ARF) reports are the result of OpenSCAP compliance scans on hosts which have a policy assigned. Summarizes the security compliance of hosts managed by orcharhino. They list compliance criteria and whether the scanned host has passed or failed.
- Audits
Provide a report on changes made by a specific user. Audits can be viewed in the orcharhino management UI under Monitor > Audits.
Enables remote power management of bare-metal hosts. In orcharhino, you can create a BMC interface to manage selected hosts.
- Boot disk
An ISO image used for PXE-less provisioning. This ISO enables the host to connect to orcharhino Server, boot the installation media, and install the operating system. There are several kinds of boot disks: host image, full host image, generic image, and subnet image.
- Catalog
A document that describes the desired system state for one specific host managed by Puppet. It lists all of the resources that need to be managed, as well as any dependencies between those resources. Catalogs are compiled by a Puppet server from Puppet Manifests and data from Puppet agents.
- Candlepin
- Compliance policy
Compliance policies refer to the application of SCAP content to hosts by using orcharhino with its OpenSCAP plugin. You can create compliance policies by using the orcharhino management UI, Hammer CLI, or API. A compliance policy requires the setting of a specific XCCDF profile from a SCAP content, optionally using a tailoring file. You can set up scheduled tasks on orcharhino that check your hosts for compliance against SCAP content. When a compliance policy scan completes, the host sends an ARF report to orcharhino.
- Compute profile
- Compute resource
A compute resource is an external virtualization or cloud infrastructure that you can attach to orcharhino. orcharhino can provision, configure, and manage hosts within attached compute resources. Examples of compute resources include VMware or libvirt and cloud providers such as Microsoft Azure or Amazon EC2.
- Configuration Management
Configuration management describes the task of configuring and maintaining hosts. In orcharhino, you can use Ansible, Puppet, and Salt to configure and maintain hosts with orcharhino as a single source of infrastructure truth.
- Container (Docker container)
An isolated application sandbox that contains all runtime dependencies required by an application. orcharhino supports container provisioning on a dedicated compute resource.
- Container image
A static snapshot of the container’s configuration. orcharhino supports various methods of importing container images as well as distributing images to hosts through content views.
- Content
A general term for everything orcharhino distributes to hosts. Content includes software packages such as
.rpmpackages, errata, or Docker images. Content is synchronized into the Library and then promoted into lifecycle environments using content views so that they can be consumed by hosts.
- Content delivery network (CDN)
The mechanism used to deliver Red Hat content to orcharhino Server.
- Content view
Content views are named and versioned collections of repositories. When you publish a content view, orcharhino creates a new content view version. This content view version is a frozen snapshot of the current state of the repositories within the content view. Any subsequent changes to the underlying repositories will no longer affect the published content view version. Once a content view is published, it can be promoted through the lifecycle environment path, or modified using incremental upgrades.
- Composite content view
- Discovered host
- Discovery image
Refers to the minimal operating system based on Enterprise Linux that is PXE-booted on hosts to acquire initial hardware information and to communicate with orcharhino Server before starting the provisioning process.
- Discovery plugin
Enables automatic bare-metal discovery of unknown hosts on the provisioning network. The plugin consists of three components: services running on orcharhino Server and orcharhino Proxy Server, and the Discovery image running on host.
- Discovery rule
- Docker tag
A mark used to differentiate container images, typically by the version of the application stored in the image. In the orcharhino management UI, you can filter images by tag under Content > Docker Tags.
- Enterprise Linux
AlmaLinux
CentOS Linux
CentOS Stream
Oracle Linux
Rocky Linux
- ERB
- Errata
- External node classifier (ENC)
A construct that provides additional data for a server to use when configuring hosts. When Puppet obtains information about nodes from an external source instead of its own database, the external source is called External node classifier. If the Puppet plugin is installed, orcharhino can act as an External node classifier to Puppet servers in a orcharhino deployment.
- Facter
- Facts
- Foreman
Foreman is an open-source component to provision and manage hosts. Foreman is the core upstream component of orcharhino.
- Full host image
- Generic image
A boot disk for PXE-less provisioning that is not tied to a specific host. The generic image sends the MAC address of your host to orcharhino Server, which matches it against the host entry.
- Hammer
Hammer is a command-line interface tool for orcharhino. You can execute Hammer commands from the command line or utilize it in scripts. You can use Hammer to automate certain recurring tasks as an alternative to orcharhino Ansible collection or orcharhino API.
- Host
A host is a physical, virtual, or cloud instance registered to orcharhino.
- Host collection
- Host group
- Host image
A boot disk used for PXE-less provisioning of a specific host. The host image only contains the boot files necessary to access the installation media on orcharhino Server.
- Installation Media
Installation media are sets of installation files used to install the base operating system during the provisioning process. An installation medium in orcharhino represents the installation files for one or more operating systems, which must be accessible over the network, either through an URL or an NFS server location. It is usually either a mirror or a CD or DVD image. Pointing the URL of the installation medium to a local copy, for example
http://orcharhino.example.com/pub/installation_media/, can improve provisioning time and reduce network load.Every operating system depends on exactly one path of an installation medium, whereas installation media paths may serve different operating systems at the same time. You can use operating system parameters such as
$version,$major, and$minorto parameterize the URL.
- Job
A command executed remotely on a host from orcharhino Server. Every job is defined in a job template.
- Katello
Katello is an open-source plugin to perform content management and subscription handling. It depends on Pulp for content management, which fetches software from repositories and stores various versions of it. It also depends on Candlepin for host registration and managing subscription manifests. The Katello plugin is always installed on orcharhino.
- Lazy sync
- Location
A collection of default settings that represent a physical place. Location is a tag mostly used for geographical separation of hosts within orcharhino. Examples include different cities or different data centers.
- Library
A container for content from all synchronized repositories on orcharhino Server. Libraries exist by default for each organization as the root of every lifecycle environment path and the source of content for every content view.
- Lifecycle environment path
- Manifest (Red Hat subscription manifest)
A mechanism for transferring subscriptions from the Red Hat Customer Portal to orcharhino. Do not confuse with Puppet manifest.
- Migrating orcharhino
The process of moving an existing orcharhino installation to a new instance.
- OpenSCAP
A project implementing security compliance auditing according to the Security Content Automation Protocol (SCAP). OpenSCAP is integrated in orcharhino to provide compliance auditing for hosts.
- orcharhino Customer Center (OCC)
orcharhino Customer Center provides all content from ATIX AG to install, update, and run orcharhino Server and orcharhino Proxy Servers. It also provides all orcharhino Clients. For more information, see Registering orcharhino Server to OCC and orcharhino Clients gen3 in the ATIX Service Portal.
- orcharhino Proxy Server
orcharhino Proxy Servers can provide DHCP, DNS, and TFTP services and act as an Ansible control node, Puppet server, or Salt Master in separate networks. They interact with orcharhino Server in a client-server model. orcharhino Server always comes bundled with an integrated orcharhino Proxy.
orcharhino Proxy Servers are required in orcharhino deployments that manage IT infrastructure spanning across multiple networks and useful for orcharhino deployments across various geographical locations.
- Organization
An isolated collection of systems, content, and other functionality within orcharhino. Organization is a tag used for organizational separation of hosts within orcharhino. Examples include different teams or business units.
- Parameter
Defines the behavior of orcharhino components during provisioning. Depending on the parameter scope, we distinguish between global, domain, host group, and host parameters. Depending on the parameter complexity, we distinguish between simple parameters (key-value pair) and smart parameters (conditional arguments, validation, overrides).
- Patch and release management
Patch and release management describes the process of acquiring, managing, and installing patches and software updates to your infrastructure. Using orcharhino, you can keep control of the package versions available to your hosts and deliver applicable errata.
- Permission
Defines an action related to a selected part of orcharhino infrastructure (resource type). Each resource type is associated with a set of permissions, for example the Architecture resource type has the following permissions: view_architectures, create_architectures, edit_architectures, and destroy_architectures. You can group permissions into roles and associate them with users or user groups.
- Product
Products are named collections of one or more repositories. If you manage Red Hat content and upload a Red Hat manifest, orcharhino automatically groups Red Hat content within products. If you manage SUSE content using SCC Manager plugin, orcharhino automatically groups SUSE content within products. For more information, see Managing SUSE content in Managing content.
- Promote (a content view)
- Provisioning
The provisioning of a host is the deployment of the base operating system on the host and registration of the host to orcharhino. Optionally, the process continues with the supply of content and configuration. This process is ideally automated. Provisioned hosts run on compute resources or bare metal, never orcharhino Server or orcharhino Proxy Servers.
- Provisioning template
Provisioning templates are templates that automate deployment of an operating system on hosts. orcharhino contains provisioning templates for all supported host operating system families:
AutoYaST for SUSE Linux Enterprise Server
Kickstart for AlmaLinux, Amazon Linux, CentOS, Oracle Linux, Red Hat Enterprise Linux, and Rocky Linux
Preseed files for Debian and Ubuntu
- Publish (a content view)
- Pulp
- Puppet
- Puppet agent
- Puppet environment
An isolated set of Puppet agent nodes that can be associated with a specific set of Puppet Modules.
- Puppet manifest
- Puppet server
A orcharhino Proxy Server component that provides a Puppet catalog to hosts for execution by the Puppet agent.
- Puppet module
- PXE
- Recurring logic
A job executed automatically according to a schedule. In the orcharhino management UI, you can view those jobs under Monitor > Recurring logics.
- Registry
An archive of container images. orcharhino supports importing images from local and external registries. orcharhino itself can act as an image registry for hosts. However, hosts cannot push changes back to the registry.
- Remote execution (REX)
Remote execution is the process of using orcharhino to run commands on registered hosts.
- Repository
A repository is a single source and the smallest unit of content in orcharhino. You can either synchronize a repository with a URL or manually upload content to orcharhino. orcharhino supports multiple content types. One or more repositories form a product.
- Resource type
Refers to a part of orcharhino infrastructure, for example host, orcharhino Proxy, or architecture. Used in permission filtering.
- Role
Specifies a collection of permissions that are applied to a set of resources, such as hosts. Roles can be assigned to users and user groups. orcharhino provides a number of predefined roles.
- Salt
- SCAP content
SCAP stands for Security Content Automation Protocol and refers to
.xmlfiles containing the configuration and security baseline against which hosts are checked. orcharhino uses SCAP content in compliance policies.
- Subnet image
A type of generic image for PXE-less provisioning that communicates through orcharhino Proxy Server.
- Subscription
- Subscription Manager
Subscription Manager is a client application to register hosts to orcharhino.
subscription-manageruses activation keys to consume content on hosts.
- SUSE Subscription
You can use orcharhino to manage SUSE content. For more information, see Managing SUSE content in Managing content.
- Synchronization
Synchronization describes the process of fetching content from external repositories into the orcharhino Server.
- Sync plan
- Tailoring files
- Task
A background process executed on the orcharhino or orcharhino Proxy Server, such as repository synchronization or content view publishing. You can monitor the task status in the orcharhino management UI under Monitor > orcharhino Tasks > Tasks.
- Updating orcharhino
The process of advancing your orcharhino Server and orcharhino Proxy Server installations from one patch release to the next, for example orcharhino 7.0.0 to orcharhino 7.0.1.
- Upgrading orcharhino
The process of advancing your orcharhino Server and orcharhino Proxy Server installations from one minor release to the next, for example orcharhino 6.11 to orcharhino 7.0.
- User group
- User
Anyone registered to use orcharhino. Authentication and authorization is possible through built-in logic, through external resources (LDAP, Identity Management, or Active Directory), or with Kerberos.
- Virtualization
Virtualization describes the process of running multiple operating systems with various applications on a single hardware host using hypervisors like VMware, Proxmox, or libvirt. It facilitates scalability and cost savings. You can attach virtualization infrastructure as compute resources to orcharhino. Enable appropriate plugins to access this feature.
- virt-who
An agent for retrieving IDs of virtual machines from the hypervisor. When used with orcharhino, virt-who reports those IDs to orcharhino Server so that it can provide subscriptions for hosts provisioned on virtual machines.
- XCCDF profiles
Appendix C: CLI help
orcharhino offers multiple user interfaces: orcharhino management UI, Hammer CLI, API, and through Ansible collection theforeman.foreman. If you want to administer orcharhino on the command line, have a look at the following help output.
- orcharhino services
A set of services that orcharhino Server and orcharhino Proxy Servers use for operation. You can use the
foreman-maintaintool to manage these services. To see the full list of services, enter theforeman-maintain service listcommand on the machine where orcharhino or orcharhino Proxy Server is installed. For more information, runforeman-maintain --helpon your orcharhino Server or orcharhino Proxy Server.
- orcharhino plugins
You can extend orcharhino by installing plugins. For more information, run
foreman-installer --full-helpon your orcharhino Server or orcharhino Proxy Server.
- Hammer CLI
You can manage orcharhino on the command line using
hammer. For more information on using Hammer CLI, see Using the Hammer CLI tool or runhammer --helpon your orcharhino Server or orcharhino Proxy Server.
