1. Starting and stopping orcharhino
orcharhino provides the foreman-maintain service command to manage orcharhino services from the command line. This is useful when creating a backup of orcharhino. For more information on creating backups, see Backing up orcharhino Server and orcharhino Proxy Server.
After installing orcharhino with the foreman-installer command, all orcharhino services are started and enabled automatically. View the list of these services by executing:
To stop orcharhino services, execute:
To start orcharhino services, execute:
To restart orcharhino services, execute:
2. Tuning orcharhino Server with predefined profiles
If your orcharhino deployment includes more than 5000 hosts, you can use predefined tuning profiles to improve performance of orcharhino.
Note that you cannot use tuning profiles on orcharhino Proxies.
You can choose one of the profiles depending on the number of hosts your orcharhino manages and available hardware resources.
When you run the foreman-installer command with the --tuning option, deployment configuration settings are applied to orcharhino in the following order:
  1. The default tuning profile defined in the /usr/share/foreman-installer/config/foreman.hiera/tuning/common.yaml file
  2. The tuning profile that you want to apply to your deployment and is defined in the /usr/share/foreman-installer/config/foreman.hiera/tuning/sizes/ directory
  3. Optional: If you have configured a /etc/foreman-installer/custom-hiera.yaml file, orcharhino applies these configuration settings.
default
Number of hosts: 0 – 5000
RAM: 20G
Number of CPU cores: 4
medium
Number of hosts: 5001 – 10000
RAM: 32G
Number of CPU cores: 8
large
Number of hosts: 10001 – 20000
RAM: 64G
Number of CPU cores: 16
extra-large
Number of hosts: 20001 – 60000
RAM: 128G
Number of CPU cores: 32
extra-extra-large
Number of hosts: 60000+
RAM: 256G
Number of CPU cores: 48+
  1. Optional: If you have configured the custom-hiera.yaml file on orcharhino Server, back up the /etc/foreman-installer/custom-hiera.yaml file to custom-hiera.original. You can use the backup file to restore the /etc/foreman-installer/custom-hiera.yaml file to its original state if it becomes corrupted:
    # cp /etc/foreman-installer/custom-hiera.yaml \
    /etc/foreman-installer/custom-hiera.original
  2. Optional: If you have configured the custom-hiera.yaml file on orcharhino Server, review the definitions of the default tuning profile in /usr/share/foreman-installer/config/foreman.hiera/tuning/common.yaml and the tuning profile that you want to apply in /usr/share/foreman-installer/config/foreman.hiera/tuning/sizes/. Compare the configuration entries against the entries in your /etc/foreman-installer/custom-hiera.yaml file and remove any duplicated configuration settings in your /etc/foreman-installer/custom-hiera.yaml file.
  3. Enter the foreman-installer command with the --tuning option for the profile that you want to apply. For example, to apply the medium tuning profile settings, enter the following command:
3. Migrating from internal orcharhino databases to external databases
When you install orcharhino, the foreman-installer command installs PostgreSQL databases on the same server as orcharhino. If you are using the default internal databases but want to start using external databases to help with the server load, you can migrate your internal databases to external databases.
To confirm whether your orcharhino Server has internal or external databases, you can query the status of your databases:
  1. Installing PostgreSQL. Prepare PostgreSQL with databases for Foreman, Pulp, and Candlepin with dedicated users owning them.
  2. Migrating to external databases. Edit the parameters of foreman-installer to point to the new databases, and run foreman-installer.
3.1. PostgreSQL as an external database considerations
Foreman, Katello, and Candlepin use the PostgreSQL database. If you want to use PostgreSQL as an external database, the following information can help you decide if this option is right for your orcharhino configuration. orcharhino supports PostgreSQL version 13.
Advantages of external PostgreSQL
  • Increase in free memory and free CPU on orcharhino
  • Flexibility to set shared_buffers on the PostgreSQL database to a high number without the risk of interfering with other services on orcharhino
  • Flexibility to tune the PostgreSQL server’s system without adversely affecting orcharhino operations
Disadvantages of external PostgreSQL
  • If either orcharhino or the PostgreSQL database server suffers a hardware or storage failure, orcharhino is not operational
  • If there is latency between the orcharhino server and database server, performance can suffer
3.2. Installing PostgreSQL
  • The prepared host must meet orcharhino Storage requirements.
  • The prepared host has base operating system repositories enabled.
  1. On your new database server, install PostgreSQL:
    # dnf install postgresql-server postgresql-contrib
  2. Initialize the PostgreSQL database:
    # postgresql-setup --initdb
    Note that the default configuration of external PostgreSQL needs to be adjusted to work with orcharhino. The base recommended external database configuration adjustments are as follows:
    • max_connections: 500
    • shared_buffers: 512MB
    • work_mem: 4MB
    listen_addresses = '*'
  5. Add the following line to the end of the file to use SCRAM for authentication:
  6. Edit the /var/lib/pgsql/data/pg_hba.conf file:
  7. Add the following line to the file:
      host  all   all   orcharhino_ip/32   scram-sha-256
  8. Start and enable the PostgreSQL service:
  9. Open the postgresql port:
  10. Make the changes persistent:
  11. Switch to the postgres user and start the PostgreSQL client:
    $ su - postgres -c psql
  12. Create three databases and dedicated roles: one for Foreman, one for Candlepin, and one for Pulp:
  13. Exit the postgres user:
    # \q
  14. From orcharhino Server, test that you can access the database. If the connection succeeds, the commands return 1.
    # PGPASSWORD='Foreman_Password' psql -h postgres.example.com -p 5432 -U foreman -d foreman -c "SELECT 1 as ping"
3.3. Migrating to external databases
Back up and transfer existing data, then use the foreman-installer command to configure orcharhino to connect to an external PostgreSQL database server.
  • You have installed and configured a PostgreSQL server on an external server.
  1. On orcharhino Server, stop all orcharhino services except for PostgreSQL:
  2. Create your target directory for the orcharhino backup:
    # mkdir /var/My_Migration_Backup_Directory
    # foreman-maintain backup online \
    --preserve-directory \
    --skip-pulp-content \
    PGPASSWORD='Foreman_Password' pg_restore -h postgres.example.com -U foreman -d foreman < /var/My_Migration_Backup_Directory/foreman.dump
    PGPASSWORD='Candlepin_Password' pg_restore -h postgres.example.com -U candlepin -d candlepin < /var/My_Migration_Backup_Directory/candlepin.dump
    PGPASSWORD='Pulpcore_Password' pg_restore -h postgres.example.com -U pulp -d pulpcore < /var/My_Migration_Backup_Directory/pulpcore.dump
  5. Use the foreman-installer command to update orcharhino to point to the new databases:
    # foreman-installer \
    --foreman-proxy-content-pulpcore-postgresql-user pulp \
    --foreman-db-manage false \
    --foreman-db-password Foreman_Password
  6. Remove the PostgreSQL package on orcharhino Server:
    # dnf remove postgresql-server
  7. Remove the PostgreSQL data directory:
    # rm -fr /var/lib/pgsql/data
4. Automating orcharhino management with orcharhino Ansible Collection
orcharhino Ansible Collection is a set of Ansible modules that interact with the orcharhino API. You can use these modules to automate many aspects of orcharhino administration.
4.1. Installing the orcharhino Ansible modules
Modules from the orcharhino Ansible Collection are provided by the ansible-collection-theforeman-foreman package. On your orcharhino Server, the package is installed by default. If you want to execute your playbooks on a different system, you must first install the package that provides them.
You can execute your playbooks on any system that can reach the orcharhino API. This can also be your orcharhino Server itself.
  • Install the ansible-collection-theforeman-foreman package:
  • Display the list of Ansible modules that are now available on your system:
    # ansible-doc --list theforeman.foreman
Next steps
  • You can now use the installed Ansible modules to execute playbooks.
4.2. Creating a playbook with modules from orcharhino Ansible Collection
Ansible modules from the orcharhino Ansible Collection must be able to communicate with the orcharhino API over HTTPS. In your playbooks, include parameters specifying how to authenticate to enable the connection to API.
Do not store sensitive credentials, such as username and password, directly in your playbooks or environment variables. The following examples use Ansible vault to manage sensitive data.
  • A user account in orcharhino exists with permissions to perform the action defined in your playbook.
  • You have access to one of the following types of authentication credentials for that user:
    • Username and password
    • Username and Personal Access Token
  • A system that you will execute your playbook against. The following examples use localhost.
    This system must be able to reach the orcharhino API. You can choose from these options:
    • A system that can reach the orcharhino API directly. You can use your orcharhino Server, your orcharhino Proxy Servers, or any other system in your environment.
    • A system without a direct connection to the orcharhino API that uses an HTTP proxy to connect to orcharhino.
  1. Store your sensitive variables in an encrypted file:
    1. Create an Ansible vault. For example, to create a vault named My_Vault.yml:
      $ ansible-vault create My_Vault.yml
    2. After the ansible-vault create command opens an editor, provide the required parameters in the key: value format.
      If you want to authenticate with orcharhino username and password:
      My_Username: My_Admin_User_Account
      My_Password: My_Admin_Password
      My_Server_URL: https://orcharhino.example.com
      If you want to authenticate with orcharhino username and Personal Access Token (PAT):
      My_Password: My_PAT
    3. If you use an HTTP proxy to reach the orcharhino API, store it in the vault too:
      My_HTTP_Proxy: "http://proxy.example.com:8080"
    4. Save your changes and close the editor. Ansible encrypts the data in the vault.
  2. Create a playbook file that references the vault file:
    The following YAML snippets include the module_defaults keyword to pass vault variables as parameters to all modules from the theforeman.foreman.foreman group that are used in the playbook. Module defaults groups simplify parameter management by enabling you to define common parameters to groups of modules rather than having to pass the parameters to each module individually.
    1. Provide details on how to authenticate to the orcharhino API.
      If you are authenticating with orcharhino username and password or PAT, map the username, password, and server_url parameters to the contents of My_Vault.yml:
      - name: My Playbook
        hosts: localhost
        vars_files:
          - My_Vault.yml
        module_defaults:
          group/theforeman.foreman.foreman:
            username: "{{ My_Username }}"
            password: "{{ My_Password }}"
            server_url: "{{ My_Server_URL }}"
        tasks:
    2. If you need to use an HTTP proxy to reach the orcharhino API, set the https_proxy environment variable:
      - name: My Playbook
        hosts: localhost
        vars_files:
          - My_Vault.yml
        environment:
          https_proxy: "{{ My_HTTP_Proxy }}"
        module_defaults:
        tasks:
    3. In the tasks: section, define the tasks that you want your playbook to perform.
  3. Validate the playbook syntax:
    $ ansible-playbook --syntax-check --ask-vault-pass My_Playbook.yml
    Note that this command only validates the syntax. It does not protect against a valid but incorrect configuration.
  4. Run the playbook:
    $ ansible-playbook --ask-vault-pass My_Playbook.yml
Example 1. Example Ansible playbook: Ensure that domain new.example.com exists in orcharhino
The theforeman.foreman.domain module can create, update, and delete domains. This example playbook uses theforeman.foreman.domain to ensure that a domain named new.example.com exists and is managed by orcharhino. For additional examples, see Example playbooks based on modules from orcharhino Ansible Collection.
- name: Domain management
  hosts: localhost
  vars_files:
    - My_Vault.yml
  module_defaults:
  tasks:
    - name: Ensure domain new.example.com exists
      theforeman.foreman.domain:
The settings specified in the example playbook include the following:
vars_files
The name of the vault file that stores the variables My_Username, My_Password, and My_Server_URL.
module_defaults
The module defaults group that maps the variables from the vault file to the username, password, and server_url module parameters.
name
The name of the domain that you want to ensure exists in orcharhino.
For more information, see the Ansible module documentation with ansible-doc theforeman.foreman.domain.
4.3. Example playbooks based on modules from orcharhino Ansible Collection
All playbooks based on modules from orcharhino Ansible Collection must include parameters detailing how to connect to the orcharhino API. The following examples use Ansible vault and module defaults group to provide these parameters, and they authenticate using a username and password. For more information, see Creating a playbook with modules from orcharhino Ansible Collection.
Example 2. Example Ansible playbook: Enable repositories and create a content view
This example playbook uses the following modules:
  • theforeman.foreman.repository_set
  • theforeman.foreman.content_view
The playbook ensures repositories are enabled and a content view that contains these repositories exists.
Before you run this playbook, ensure that you have uploaded a manifest and can access the Red Hat CDN.
- name: Ensure RHEL 9 repositories are enabled and a content view exists
  hosts: localhost
  vars_files:
    - My_Vault.yml
  module_defaults:
  tasks:
    - name: Ensure RHEL 9 BaseOS repositories are enabled
      theforeman.foreman.repository_set:
        name: "Red Hat Enterprise Linux 9 for x86_64 - BaseOS (RPMs)"
        organization: "Default Organization"
        product: "Red Hat Enterprise Linux for x86_64"
        repositories:
        - releasever: "9"
        state: enabled
    - name: Ensure RHEL 9 AppStream repositories are enabled
        name: "Red Hat Enterprise Linux 9 for x86_64 - AppStream (RPMs)"
        repositories:
        - releasever: "9"
        state: enabled
    - name: Ensure a content view for RHEL 9 repositories exists
      theforeman.foreman.content_view:
        name: "RHEL 9 content view"
        repositories:
          - name: "Red Hat Enterprise Linux 9 for x86_64 - BaseOS RPMs 9"
          - name: "Red Hat Enterprise Linux 9 for x86_64 - AppStream RPMs 9"
For more information, see the Ansible module documentation with the following commands:
  • ansible-doc theforeman.foreman.repository_sync
  • ansible-doc theforeman.foreman.content_view
Example 3. Example Ansible playbook: Synchronize repositories and publish a content view
  • theforeman.foreman.repository_sync
  • theforeman.foreman.content_view_version
The playbook synchronizes repositories and publishes the content view that includes them.
Before you run this playbook, ensure that you have enabled the required repositories and created a content view. For an example playbook that ensures this, see Example Ansible playbook: Enable repositories and create a content view.
- name: Ensure RHEL 9 repositories are synced and content view is published
  hosts: localhost
  vars_files:
    - My_Vault.yml
  module_defaults:
  tasks:
    - name: Sync RHEL repositories
      theforeman.foreman.repository_sync:
    - name: Publish RHEL 9 content view
      theforeman.foreman.content_view_version:
        content_view: "RHEL 9 content view"
  • ansible-doc theforeman.foreman.content_view_version
  • Use the ansible-doc --list theforeman.foreman command to display the orcharhino Ansible modules installed on your system.
5. Preparing for disaster recovery and recovering from data loss
ATIX AG recommends preparing a disaster recovery plan to ensure the continuity of orcharhino services in case of a disruptive event. These guidelines help ensure that you will be able to restore your orcharhino deployment to an operational state after an incident.
Choose a disaster recovery plan that best helps ensure the continuity of orcharhino services in your deployment.
Snapshots of virtualized orcharhino Server
How do I back up?
Virtualize your orcharhino Server and use the hypervisor tools to take virtual machine snapshots of the server. This method is suitable if you can run orcharhino in a virtual machine.
To recover orcharhino services, restore a virtual machine snapshot.
Active and passive orcharhino Server, with external storage
How do I back up?
Store the following critical data on network attached storage: content in /var/lib/pulp and database in /var/lib/pgsql. Replicate this storage into a different data center. Attach the storage to a orcharhino Server that is a clone of the primary orcharhino Server but runs passively.
To recover orcharhino services, switch DNS records of the active orcharhino Server with the passive orcharhino Server. This ensures that the passive server becomes the active server. All hosts remain connected without configuration updates.
Active and passive orcharhino Server, with backup and restore
How do I back up?
Ensure periodic backups of your orcharhino Server. Copy this backup to a passive orcharhino Server and restore it on the passive server.
Dual active orcharhino Server
How do I back up?
Operate an active, independent orcharhino Server per data center. Hosts from each data center are registered to the orcharhino Server in that data center. Then configure automation to ensure recovery in case of a disruptive event. For example, you can periodically run a health check and if the health check discovers that the current orcharhino Server a host is registered to does not resolve, the host is re-registered to the other orcharhino Server.
To minimize downtime, you can automate the recovery in various ways. For example, you can use the orcharhino Ansible collection. For more information, see Automating orcharhino management with orcharhino Ansible Collection in Administering orcharhino.
To recover orcharhino services, re-register all hosts to the orcharhino Server in the other data center.
You must ensure that content synchronization and content view creation are synchronized to create the same content view in each orcharhino and prevent content drift. Content drift occurs when available content deviates from the intended state defined by a content view. If you fail to prevent content drift, expect inconsistency in the content that is available to hosts.
5.2. Disaster recovery by virtualizing your orcharhino Server
If you virtualize your orcharhino Server and ensure that you take regular snapshots of the virtual machine (VM), you can respond to various disaster scenarios by restoring your orcharhino deployment from one of your snapshots.
The details for how to implement this scenario depend on your choice of a virtualization platform. Due to the variety of different hypervisors and their capabilities, ATIX AG does not provide detailed instructions for any specific virtualization platform.
5.2.1. Prerequisites
5.2.2. Preparing for disaster recovery by virtualizing your orcharhino Server
Implement a reliable process for regularly taking VM snapshots of your virtualized orcharhino Server and for backing up your snapshots for long-term storage.
  1. Define a schedule for taking periodic snapshots of your virtualized orcharhino Server. Consider your tolerance for potential data loss: Taking snapshots frequently will result in smaller amounts of data loss in case of a disaster. However, creating a snapshot takes time, and the snapshots also require storage space.
  3. Using your hypervisor, schedule periodic snapshots of your orcharhino Server.
  5. If you are using an external database that runs on a different machine than your orcharhino Server, create snapshots and backups on the same schedule as your orcharhino Server.
  2. Use the latest snapshot of your orcharhino Server and restore it in an isolated environment.
  3. To verify that you will be able to restore orcharhino services in case of a disaster, assess the functionality of the test orcharhino Server. See Retrieving the status of services.
5.2.3. Recovering from disaster by restoring a VM snapshot of orcharhino Server
In case of a disaster, use a virtual machine (VM) snapshot of your orcharhino Server to restore orcharhino services.
Ensure that the hostname of your orcharhino Server does not change during recovery. The IP address can change.
  3. If you are using an external database that runs on a different machine than your orcharhino Server, ensure that you restore the database from a snapshot taken at the same time as or before the orcharhino Server snapshot.
  4. Update DNS records so that the orcharhino Server hostname resolves to the new IP address. This redirects traffic from the old server to the new server and you will not need to re-register your hosts.
5.2.4. Retrieving the status of services
orcharhino uses a set of back-end services. When troubleshooting, you can check the status of orcharhino services.
  • In the orcharhino management UI, navigate to Administer > About.
    • On the Smart Proxies tab, view the status of all orcharhino Proxies.
    • On the Compute Resources tab, view the status of attached compute resource providers.
    • In the Backend System Status table, view the status of all back-end services.
CLI procedure
  • Get information from the database and orcharhino services:
    $ hammer ping
  • Perform a health check:
5.3. Disaster recovery for active and passive orcharhino Server with external storage
To prepare for disaster recovery, you can configure two orcharhino Servers and store critical data externally on shared storage. The primary server is active while the secondary server remains passive. If the primary server fails, the shared storage is attached to your secondary server, which turns the secondary server into your new primary server.
5.3.1. Prerequisites
5.3.2. Preparing for disaster recovery with active and passive orcharhino Server with external storage
Create your passive orcharhino Server as a backup of your active orcharhino Server. Ensure that the /var/lib/pulp and /var/lib/pgsql directories on your shared storage are available to both servers.
  1. Replicate the /var/lib/pulp and /var/lib/pgsql directories from the active orcharhino Server to your shared storage.
  2. Back up your active orcharhino Server and restore it on a system that will serve as your passive orcharhino Server. For more information, see Backing up orcharhino Server and orcharhino Proxy Server and Restoring orcharhino Server or orcharhino Proxy Server from a backup.
  4. Assess the functionality of the test orcharhino Server. For more information, see Retrieving the status of services.
5.3.3. Recovering from disaster with active and passive server with external storage
If your active orcharhino Server fails, detach it from the shared storage and make sure your passive server can access the data stored on the shared storage. This turns the passive server into your new active server.
  5. Assess the functionality of your new active orcharhino Server. For more information, see Retrieving the status of services.
5.3.4. Retrieving the status of services
CLI procedure
    $ hammer ping
5.4. Disaster recovery for active and passive orcharhino Server with backup and restore
To prepare for disaster recovery, you can configure two orcharhino Servers: an active primary server and a passive secondary server. You configure periodic backups of the primary server. If the primary server fails, you can restore a backup on the secondary server to turn it into your new primary server.
5.4.1. Prerequisites
5.4.2. Preparing for disaster recovery with active and passive orcharhino Server and backup and restore
Create your passive orcharhino Server by restoring a backup of your active orcharhino Server. Configure periodic backups of the active server.
  1. Define a schedule for periodic offline backups of your active orcharhino Server. Consider your tolerance for potential data loss and your storage options: Taking backups frequently will result in smaller amounts of data loss in case of a disaster, but backups require a significant amount of storage space. For information about the size of orcharhino backups, see Estimating the size of a backup.
    You can combine full backups with incremental backups. For an example of a cron job that ensures regular backups, see Example of a weekly full backup followed by daily incremental backups.
  2. Schedule periodic offline backups of your active orcharhino Server to be taken according to the schedule you defined. For information about performing backups, see Backing up orcharhino Server and orcharhino Proxy Server.
  3. Ensure that the backup directories are encrypted and regularly synchronized to a secure location. By default, orcharhino stores the backups in the /var/orcharhino-backup directory.
    orcharhino Server backups contain sensitive information from the /root/ssl-build directory. For example, they can contain hostnames, ssh keys, request files, and SSL certificates. Encrypting or moving the backups to a secure location helps minimize the risk of damage or unauthorized access to the hosts.
  4. Restore the most recent backup on a system that will serve as your passive orcharhino Server. For information about restoring backups, see Restoring orcharhino Server or orcharhino Proxy Server from a backup.
  1. Verify that orcharhino takes backups according to the schedule you defined.
    3. Assess the functionality of the test orcharhino Server. For more information, see Retrieving the status of services.
5.4.3. Recovering from disaster with active and passive server and backup and restore
If your active orcharhino Server fails, activate your passive secondary server.
  3. Assess the functionality of your new active orcharhino Server. For more information, see Retrieving the status of services.
5.4.4. Retrieving the status of services
CLI procedure
    $ hammer ping
5.4.5. Example of a weekly full backup followed by daily incremental backups
#!/bin/bash -e
else
fi
exit 0
5.5. Disaster recovery with two active orcharhino Servers
To prepare for disaster recovery, you can configure two orcharhino Servers and operate each server in a different data center. If one of the servers fails, you can re-register all hosts from the failed server to the other server.
5.5.1. Prerequisites
5.5.2. Preparing for disaster recovery with two active orcharhino Servers
Create a second orcharhino Server by restoring a backup of your first orcharhino Server. Configure both servers to operate independently in their respective data centers, but ensure that their content does not drift apart over time.
  1. Back up your orcharhino Server. For more information, see Backing up orcharhino Server and orcharhino Proxy Server.
  2. Restore the backup on a system that will serve as your other orcharhino Server. For more information, see Restoring orcharhino Server or orcharhino Proxy Server from a backup.
  4. Register hosts to your servers so that each server manages hosts in its respective data center. For example, register all hosts in My_Data_Center_1 to one orcharhino Server and all hosts in My_Data_Center_2 to the other orcharhino Server.
  5. Automate running the foreman-maintain health check command on both servers. The health check verifies whether the servers remain fully operational.
  2. Verify that your foreman-maintain health check automation reported an error.
5.5.3. Recovering from disaster with two active orcharhino Servers
If the health checks implemented in Preparing for disaster recovery with two active orcharhino Servers report an issue on one of your orcharhino Servers, it might mean that the server has failed. If the server is down, you must re-register hosts to the other server.
  2. If foreman-maintain health check reported a problem, ensure that the server is powered off.
6. Managing users and roles
A User defines a set of details for individuals who use the system. Users can be associated with organizations and environments, so that when they create new entities, the default settings are automatically used. Users can also have one or more roles attached, which grants them rights to view and manage organizations and environments. See Managing users for more information on working with users.
You can manage permissions of several users at once by organizing them into user groups. User groups themselves can be further grouped to create a hierarchy of permissions. For more information on creating user groups, see Creating and managing user groups.
Roles define a set of permissions and access levels. Each role contains one on more permission filters that specify the actions allowed for the role. Actions are grouped according to the Resource type. Once a role has been created, users and user groups can be associated with that role. This way, you can assign the same set of permissions to large groups of users. orcharhino provides a set of predefined roles and also enables creating custom roles and permission filters as described in Creating and managing roles.
6.1. Managing users
As an administrator, you can create, modify and remove orcharhino users. You can also configure access permissions for a user or a group of users by assigning them different roles.
6.1.1. Creating a user
Use this procedure to create a user. To use the CLI instead of the orcharhino management UI, see the CLI procedure.
  1. In the orcharhino management UI, navigate to Administer > Users.
  2. Click Create User.
  3. Enter the account details for the new user.
  4. Click Submit to create the user.
  • On the User tab, select an authentication source from the Authorized by list:
  • On the Organizations tab, select an organization for the user. Specify the default organization orcharhino selects for the user after login from the Default on login list.
    If a user is not assigned to an organization, their access is limited.
CLI procedure
  • Create a user:
    $ hammer user create \
    --login My_User_Name \
    --mail My_User_Mail \
    --password My_User_Password
    The --auth-source-id 1 setting means that the user is authenticated internally, you can specify an external authentication source as an alternative. Add the --admin option to grant administrator privileges to the user. Specifying organization IDs is not required.
    You can modify the user details later by using the hammer user update command.
  • For more information about creating user accounts by using Hammer, enter hammer user create --help.
API request
$ curl \
--header "Accept:application/json" \
--header "Content-Type:application/json" \
--request POST \
--user My_User_Name:My_Password \
https://orcharhino.example.com/api/users \
| python3 -m json.tool
6.1.2. Assigning roles to a user
Use this procedure to assign roles to a user. To use the CLI instead of the orcharhino management UI, see the CLI procedure.
    If a user account is not listed, check that you are currently viewing the correct organization. To list all the users in orcharhino, click Default Organization and then Any Organization.
  7. Click Submit.
CLI procedure
    $ hammer user add-role --id user_id --role role_name
6.1.3. Impersonating a different user account
Administrators can impersonate other authenticated users for testing and troubleshooting purposes by temporarily logging on to the orcharhino management UI as a different user. When impersonating another user, the administrator has permissions to access exactly what the impersonated user can access in the system, including the same menus.
  • Ensure that you are logged on to the orcharhino management UI as a user with administrator privileges for orcharhino.
6.1.4. Creating an API-only user
You can create users that can interact only with the orcharhino API.
  1. Log in to your orcharhino as admin.
    # openssl rand -hex 32
6.2. Managing SSH keys
6.2.1. Managing SSH keys for a user
Use this procedure to add or remove SSH keys for a user. To use the CLI instead of the orcharhino management UI, see the CLI procedure.
  • Ensure that you are logged in to the orcharhino management UI as an Admin user of orcharhino or a user with the create_ssh_key permission enabled for adding SSH key and destroy_ssh_key permission for removing a key.
  3. Click on the SSH Keys tab.
    • To Add SSH key
      2. Click Add SSH Key.
      5. Click Submit.
    • To Remove SSH key
CLI procedure
    $ hammer user ssh-keys add \
    --user-id user_id \
    --name key_name \
    --key-file ~/.ssh/id_rsa.pub
    --user-id user_id \
    --name key_name \
6.3. Managing Personal Access Tokens
6.3.1. Creating a Personal Access Token
  1. Make an API request to your orcharhino Server and authenticate with your Personal Access Token:
    $ curl \
    https://orcharhino.example.com/api/status
    {"orcharhino_version":"7.0.0","result":"ok","status":200,"version":"3.5.1.10","api_version":2}
6.3.2. Revoking a Personal Access Token
  1. Make an API request to your orcharhino Server and try to authenticate with the revoked Personal Access Token:
    $ curl \
6.4. Creating and managing user groups
6.4.1. User groups
With orcharhino, you can assign permissions to groups of users. You can also create user groups as collections of other user groups. If you use an external authentication source, you can map orcharhino user groups to external user groups as described in Configuring external user groups in Configuring authentication for orcharhino users.
6.4.2. Creating a user group
  1. In the orcharhino management UI, navigate to Administer > User Groups.
  2. Click Create User group.
  5. Click Submit.
CLI procedure
    $ hammer user-group create \
    --name My_User_Group_Name \
6.4.3. Removing a user group
Use the following procedure to remove a user group from orcharhino.
6.5. Creating and managing roles
Users in orcharhino can have one or more roles assigned. These roles are associated with permissions that enable users to perform specified administrative actions in orcharhino. Permission filters define the actions allowed for a certain resource type.
orcharhino provides a set of predefined roles with permissions sufficient for standard tasks. For a list of these roles, see Predefined roles available in orcharhino. You can also configure custom roles.
One of the predefined roles is the Default role. orcharhino assigns the Default role to every user in the system. By default, the Default role grants only a limited set of permissions. Be aware that if you add a permission to the Default role, every orcharhino users will gain that permission. Assigning a different role to a user does not remove the Default role from the user.
The following types of roles are commonly defined within various orcharhino deployments:
6.5.1. Creating a role
  1. In the orcharhino management UI, navigate to Administer > Roles.
  2. Click Create Role.
CLI procedure
To serve its purpose, a role must contain permissions. After creating a role, proceed to Adding permissions to a role.
6.5.2. Cloning a role
Use the orcharhino management UI to clone a role.
  1. In the orcharhino management UI, navigate to Administer > Roles and select Clone from the drop-down menu to the right of the required role.
6.5.3. Adding permissions to a role
Use this procedure to add permissions to a role. To use the CLI instead of the orcharhino management UI, see the CLI procedure.
  5. Depending on the Resource type selected, you can select or deselect the Unlimited and Override checkbox. The Unlimited checkbox is selected by default, which means that the permission is applied on all resources of the selected type. When you disable the Unlimited checkbox, the Search field activates. In this field you can specify further filtering with use of the orcharhino search syntax. For more information, see Granular permission filtering. When you enable the Override checkbox, you can add additional locations and organizations to allow the role to access the resource type in the additional locations and organizations; you can also remove an already associated location and organization from the resource type to restrict access.
  6. Click Next.
CLI procedure
  2. Add permissions to a role:
    $ hammer filter create \
    --role My_Role_Name
6.5.4. Viewing permissions of a role
Use the orcharhino management UI to view the permissions of a role.
The Filters page contains a table of permissions assigned to a role grouped by the resource type. It is also possible to generate a complete table of permissions and actions that you can use on your orcharhino system. For more information, see Creating a complete permission table.
6.5.5. Creating a complete permission table
  • Ensure that the foreman-console package is installed on orcharhino Server:
    # dnf install foreman-console
  1. Start the orcharhino console with the following command:
    # foreman-rake console
    end.join("\n")
    f.write(result)
  3. Press Ctrl + D to exit the orcharhino console.
    </table>
6.5.6. Removing a role
Use the following procedure to remove a role from orcharhino.
6.6. Predefined roles available in orcharhino
The following table provides an overview of permissions that predefined roles in orcharhino grant to a user.
For a complete set of predefined roles and the permissions they grant, log in to orcharhino management UI as the privileged user and navigate to Administer > Roles. For more information, see Viewing permissions of a role.
Predefined role Permissions the role provides Additional information
Auditor
View the Audit log.
Default role
View tasks and jobs invocations.
orcharhino automatically assigns this role to every user in the system.
Manager
Organization admin
Site manager
View permissions for various items.
Permissions to manage hosts in the infrastructure.
System admin
Edit global settings in Administer > Settings.
View, create, edit, and destroy users, user groups, and roles.
View, create, edit, destroy, and assign organizations and locations but not view resources within them.
Users with this role can create users and assign all roles to them. Give this role only to trusted users.
Viewer
View the configuration of every element of the orcharhino structure, logs, reports, and statistics.
6.7. Granular permission filtering
As mentioned in Adding permissions to a role, orcharhino provides the ability to limit the configured user permissions to selected instances of a resource type. These granular filters are queries to the orcharhino database and are supported by the majority of resource types.
6.7.1. Creating a granular permission filter
Use this procedure to create a granular filter. To use the CLI instead of the orcharhino management UI, see the CLI procedure.
orcharhino does not apply search conditions to create actions. For example, limiting the create_locations action with name = "Default Location" expression in the search field does not prevent the user from assigning a custom name to the newly created location.
field_name operator value
  • operator specifies the type of comparison between field_name and value. See Supported operators for granular search for an overview of applicable operators.
CLI procedure
    --permission-ids 91 \
    --search "name ~ ccv*" \
    --role qa-user
This command adds to the qa-user role a permission to view, create, edit, and destroy content views that only applies to content views with name starting with ccv.
6.7.2. Examples of using granular permission filters
Applying permissions for the host resource type
hostgroup = host-editors
name ^ (XXXX, Yyyy, zzzz)
Dev
You can limit user permissions to a certain organization or location with the use of the granular permission filter in the Search field. However, some resource types provide a GUI alternative, an Override checkbox that provides the Locations and Organizations tabs. On these tabs, you can select from the list of available organizations and locations. For more information, see Creating an organization-specific manager role.
Use the orcharhino management UI to create an administrative role restricted to a single organization named org-1.
6.7.3. Supported operators for granular search
Table 1. Logical operators
Operator
and
Combines search criteria.
not
Negates an expression.
has
Table 2. Symbolic operators
Operator
7. Configuring email notifications
Email notifications are created by orcharhino Server periodically or after completion of certain events. The periodic notifications can be sent daily, weekly or monthly.
For an overview of available notification types, see Email notification types.
orcharhino Server does not enable outgoing emails by default, therefore you must review your email configuration.
7.1. Email notification types
orcharhino can create the following email notifications:
Audit summary
A summary of all activity audited by orcharhino Server.
Compliance policy summary
Content view promote failure
Content view publish failure
Host built
Host errata advisory
orcharhino Proxy sync failure
A notification sent after orcharhino Proxy synchronization fails.
Promote errata
Repository sync failure
Sync errata
For a complete list of email notification types, navigate to Administer > Users in the orcharhino management UI, click the Username of the required user, and select the Email Preferences tab.
7.2. Configuring email notification preferences
You can configure orcharhino to send email messages to individual users registered to orcharhino. orcharhino sends the email to the email address that has been added to the account, if present. Users can edit the email address by clicking on their name in the top-right of the orcharhino management UI and selecting My account.
Configure email notifications for a user from the orcharhino management UI.
If you want to send email notifications to a group email address instead of an individual email address, create a user account with the group email address and minimal orcharhino permissions, then subscribe the user account to the desired notification types.
  6. Click Submit.
7.3. Testing email delivery
  2. Click on the username.
  2. Verify orcharhino Server’s email configuration.
  4. If your orcharhino Server uses the Postfix service for email delivery, the test email might be held in the queue. To verify, enter the mailq command to list the current mail queue. If the test email is held in the queue, mailq displays the following message:
    BE68482A783    1922 Thu Oct  3 05:13:36  orcharhino-noreply@example.com
    To fix the problem, start the Postfix service on your orcharhino Server:
    # systemctl start postfix
7.4. Testing email notifications
  • daily
  • weekly
  • monthly
7.5. Changing email notification settings for a host
orcharhino can send event notifications for a host to the host’s registered owner. You can configure orcharhino to send email notifications either to an individual user or a user group. When set to a user group, all group members who are subscribed to the email type receive a message.
  1. In the orcharhino management UI, navigate to Hosts > All Hosts, locate the host that you want to view, and click Edit in the Actions column.
  2. Go to the Additional Information tab. If the checkbox Include this host within orcharhino reporting is checked, then the email notifications are enabled on that host.
8. Backing up orcharhino Server and orcharhino Proxy Server
You can back up your orcharhino deployment to ensure the continuity of your orcharhino deployment and associated data in the event of a disaster. If your deployment uses custom configurations, you must consider how to handle these custom configurations when you plan your backup and disaster recovery policy.
If you create a new instance of the orcharhino Server, decommission the old instances after restoring the backup. Cloned instances are not supposed to run in parallel in a production environment.
To create a backup of your orcharhino Server or orcharhino Proxy Server and all associated data, use the foreman-maintain backup command. Backing up to a separate storage device on a separate system is highly recommended.
orcharhino services are unavailable during the backup. Therefore, you must ensure that no other tasks are scheduled by other administrators. You can schedule a backup by using cron. For more information, see the Example of a weekly full backup followed by daily incremental backups.
During offline backups, the services are inactive and orcharhino is in a maintenance mode. All the traffic from outside on port 443 is rejected by a firewall to ensure there are no modifications triggered.
Conventional backup methods
You can also use conventional backup methods.
If you plan to use the foreman-maintain backup command to create a backup, do not stop orcharhino services.
8.1. Estimating the size of a backup
The full backup creates uncompressed archives of PostgreSQL and Pulp database files, and orcharhino configuration files. Compression occurs after the archives are created to decrease the time when orcharhino services are unavailable.
  • Uncompressed orcharhino database and configuration files
  • Compressed orcharhino database and configuration files
  1. Enter the du command to estimate the size of uncompressed directories containing orcharhino database and configuration files:
    100G    /var/lib/pgsql/data
    100G	/var/lib/pulp
    # du -csh /var/lib/tftpboot /etc /root/ssl-build \
    16M   /var/lib/tftpboot
    37M   /etc
    900K  /root/ssl-build
    100K  /var/www/html/pub
    2M    /opt/puppetlabs
    942M  total
    Table 3. Backup data compression ratio
    PostgreSQL database files
    /var/lib/pgsql/data
    80 – 85%
    100 GB → 20 GB
    Pulp RPM files
    /var/lib/pulp
    (not compressed)
    100 GB
    Configuration files
    /var/lib/tftpboot
    /etc
    /root/ssl-build
    /var/www/html/pub
    /opt/puppetlabs
    85%
    942 MB → 141 MB
8.2. Performing a full backup of orcharhino Server or orcharhino Proxy Server
orcharhino uses the foreman-maintain backup command to make backups.
There are two main methods of backing up orcharhino Server:
  • Offline backup
    All orcharhino services are shut down during an offline backup.
  • Online backup
    Only orcharhino services that affect the consistency of the backup, including all background workers, are shut down while the backup process is running. Online backups check for consistency and require more time than offline backups.
Offline backups
Online backups
Directory creation
  • orcharhino-backup on orcharhino
  • foreman-proxy-backup on orcharhino Proxy
Remote databases
You can use both online and offline methods to back up remote databases, but if you use offline method, the foreman-maintain backup command performs a database dump.
Backing up to a remote NFS share
To enable orcharhino to save the backup to an NFS share, ensure that the root user of your orcharhino Server or orcharhino Proxy Server can write to the NFS share. NFS export options such as root_squash and all_squash are known to prevent this.
Warning
Request other users of orcharhino Server or orcharhino Proxy Server to save any changes and warn them that orcharhino services are unavailable for the duration of the backup. Ensure no other tasks are scheduled for the same time as the backup.
  • On orcharhino Server, enter the following command:
    # foreman-maintain backup offline /var/orcharhino-backup
  • On orcharhino Proxy Server, enter the following command:
8.3. Performing a backup without Pulp content
Warning
8.4. Performing an incremental backup
Warning
8.5. Example of a weekly full backup followed by daily incremental backups
#!/bin/bash -e
else
fi
exit 0
8.6. Performing an online backup
Risks associated with online backups
When you perform an online backup, most orcharhino services remain running and usable. Background workers are shut down to ensure consistent backups. Operations that require background workers remain in pending state. The backup process ensures that the Pulp data (/var/lib/pulp) is not altered during the backup. Any changes to the Pulp data during the backup will result in restart of the backup process, taking additional time.
Warning
Request other users of orcharhino Server or orcharhino Proxy Server to save any changes and warn them that some orcharhino services may be unavailable for the duration of the backup. Ensure no other tasks are scheduled for the same time as the backup.
9. Restoring orcharhino Server or orcharhino Proxy Server from a backup
You can restore orcharhino Server or orcharhino Proxy Server from the backup data that you create as part of Backing up orcharhino Server and orcharhino Proxy Server. This process outlines how to restore the backup on the same server that generated the backup, and all data covered by the backup is deleted on the target system. If the original system is unavailable, provision a system with the same configuration settings and host name.
You cannot restore backups of a system without FIPS enabled on a FIPS enabled system.
9.1. Restoring from a full backup
Use this procedure to restore orcharhino or orcharhino Proxy Server from a full backup. When the restore process completes, all processes are online, and all databases and system configuration revert to the state at the time of the backup.
  • Ensure that you are restoring to the correct instance. The orcharhino instance must have the same host name, configuration, and be the same minor version (X.Y) as the original system.
  • Ensure that you have enough space to store this data on the base system of orcharhino Server or orcharhino Proxy Server as well as enough space after the restoration to contain all the data in the /etc/ and /var/ directories contained within the backup.
    # df -h /var/backup_directory
    # restorecon -Rv /
  1. Choose the appropriate method to install orcharhino or orcharhino Proxy:
  2. Copy the backup data to the local file system on orcharhino Server. Use /var/ or /var/tmp/.
9.2. Restoring from incremental backups
Use this procedure to restore orcharhino or orcharhino Proxy Server from incremental backups. If you have multiple branches of incremental backups, select your full backup and each incremental backup for the branch you want to restore, in chronological order.
  1. Restore the last full backup using the instructions in Restoring from a full backup.
  2. Remove the full backup data from the local file system on orcharhino Server, for example, /var/ or /var/tmp/.
  3. Copy the incremental backup data to the local file system on orcharhino Server, for example, /var/ or /var/tmp/.
9.3. Backup and restore orcharhino Proxy Server by using a virtual machine snapshot
If your orcharhino Proxy Server is a virtual machine, you can restore it from a snapshot. Creating weekly snapshots to restore from is recommended. In the event of failure, you can install, or configure a new orcharhino Proxy Server, and then synchronize the database content from orcharhino Server.
If required, deploy a new orcharhino Proxy Server, ensuring the host name is the same as before, and then install the orcharhino Proxy certificates. You may still have them on orcharhino Server, the package name ends in -certs.tar, alternately create new ones. Follow the procedures in Installing orcharhino Proxy Server until you can confirm, in the orcharhino management UI, that orcharhino Proxy Server is connected to orcharhino Server. Then use the procedure Synchronizing content from orcharhino Server to orcharhino Proxy Servers to synchronize from orcharhino.
9.3.1. Synchronizing content from orcharhino Server to orcharhino Proxy Servers
Use this procedure to synchronize content from your orcharhino Server to your orcharhino Proxy Server.
  • Ensure that you either select the relevant organization and location context of your orcharhino Proxy Server or choose Any Organization and Any Location.
  1. In the orcharhino management UI, navigate to Infrastructure > orcharhino Proxies.
  2. Select your orcharhino Proxy Server.
  3. On the Overview tab, click Synchronize.
    • Select Optimized Sync to synchronize content from your orcharhino Server to your orcharhino Proxy Server that bypasses unnecessary steps to speed up performance.
    • Select Complete Sync to perform a complete sync from your orcharhino Server to your orcharhino Proxy Server that synchronizes content even if the metadata has not changed.
10. Renaming orcharhino Server or orcharhino Proxy Server
To rename orcharhino Server or orcharhino Proxy Server, use the katello-change-hostname script.
If you change the domain name of your orcharhino Server or orcharhino Proxy Server, you must update the hostname by using the katello-change-hostname script to avoid networking issues.
10.1. Renaming orcharhino Server
The host name of orcharhino Server is used by orcharhino Server components, all orcharhino Proxy Servers, and hosts registered to it for communication. This procedure ensures that in addition to renaming orcharhino Server, you also update all references to point to the new host name.
Warning
Renaming your orcharhino Server host shuts down all orcharhino services on that host. The services restart after the renaming is complete.
  • Back up your orcharhino Server before changing its host name. If you fail to successfully rename it, restore it from the backup. For more information, see Backing up orcharhino Server and orcharhino Proxy Server.
  • Run the hostname and hostname -f commands on orcharhino Server. If both commands do not return the FQDN of orcharhino Server, the katello-change-hostname script will fail to complete.
    If the hostname command returns the shortname of orcharhino Server instead of the FQDN, use hostnamectl set-hostname My_Old_FQDN to set the old FQDN correctly before using the katello-change-hostname script.
  • If orcharhino Server has a custom SSL certificate installed, obtain a new certificate for the new FQDN of the host.
  1. On orcharhino Server, run the katello-change-hostname script, and provide the new host name. Choose one of the following methods:
    • If your orcharhino Server is installed with the default self-signed SSL certificates:
      # katello-change-hostname new-orcharhino \
      --username My_Username \
      --password 'My_Password'
    • If your orcharhino Server is installed with custom SSL certificates:
      --password 'My_Password' \
  2. If you have created a custom SSL certificate for the new orcharhino Server host name, run the orcharhino installation script to install the certificate.
  3. Reregister all hosts and orcharhino Proxy Servers that are registered to orcharhino Server. For more information, see Registering hosts by using global registration in Managing hosts.
  4. On all orcharhino Proxy Servers, run the orcharhino installation script to update references to the new host name:
    # foreman-installer \
    --foreman-proxy-foreman-base-url https://new-orcharhino.example.com \
    --foreman-proxy-trusted-hosts new-orcharhino.example.com
  5. On orcharhino Server, list all orcharhino Proxy Servers:
    # hammer proxy list
  6. On orcharhino Server, synchronize content for each orcharhino Proxy Server:
    # hammer proxy content synchronize \
    --id My_orcharhino_Proxy_ID
  7. If you use the virt-who agent, update the virt-who configuration files with the new host name.
  8. If you use external authentication, reconfigure orcharhino Server for external authentication after you run the katello-change-hostname script. For more information, see Configuring authentication for orcharhino users.
10.2. Renaming orcharhino Proxy Server
The host name of orcharhino Proxy Server is referenced by orcharhino Server components and all hosts registered to it. This procedure ensures that in addition to renaming orcharhino Proxy Server, you also update all references to the new host name.
Warning
Renaming your orcharhino Proxy Server host shuts down all orcharhino services on that host. The services restart after the renaming is complete.
  • Back up your orcharhino Proxy Server before renaming. If you fail to successfully rename it, restore it from the backup. For more information, see Backing up orcharhino Server and orcharhino Proxy Server.
  • Run the hostname and hostname -f commands on orcharhino Proxy Server. If both commands do not return the FQDN of orcharhino Proxy Server, the katello-change-hostname script will fail to complete.
    If the hostname command returns the shortname of orcharhino Proxy Server instead of the FQDN, use hostnamectl set-hostname My_Old_FQDN to set the old FQDN correctly before attempting to use the katello-change-hostname script.
  1. On your orcharhino Server, generate a new certificates archive file for your orcharhino Proxy Server.
    • If you are using the default SSL certificate, regenerate the default SSL certificates:
      --certs-tar /root/new-orcharhino-proxy.example.com-certs.tar \
      --foreman-proxy-fqdn new-orcharhino-proxy.example.com
    • If you are using a custom SSL certificate, create a new SSL certificate for your orcharhino Proxy Server.
  2. On your orcharhino Server, copy the certificates archive file to your orcharhino Proxy Server. For example, to copy the archive file to the root user’s home directory:
    # scp /root/new-orcharhino-proxy.example.com-certs.tar root@orcharhino-proxy.example.com:
  3. On your orcharhino Proxy Server, run the katello-change-hostname script and provide the host’s new name, orcharhino credentials, and certificates archive file name.
    # katello-change-hostname new-orcharhino-proxy.example.com \
  4. If you have created a custom certificate for your orcharhino Proxy Server, deploy the certificate to your orcharhino Proxy Server by entering the foreman-installer command that the foreman-proxy-certs-generate command returned in a previous step.
  5. Reregister all hosts that are registered to your orcharhino Proxy Server. For more information, see Registering hosts and setting up host integration in Managing hosts.
  6. Update the orcharhino Proxy host name in the orcharhino management UI.
    2. Locate orcharhino Proxy Server in the list, and click Edit.
    3. Edit the Name and URL fields to match orcharhino Proxy Server’s new host name, then click Submit.
    4. On your DNS server, add a record for the new hostname of your orcharhino Proxy Server, and delete the record of the previous host name.
11. Maintaining orcharhino Server
This chapter provides information on how to maintain orcharhino Server, including information on how to recover Pulp from a full disk, how to work with audit records, and how to clean unused tasks.
11.1. Deleting audit records manually
11.2. Deleting audit records automatically
You can automatically delete audit records using the Saved audits interval setting. This setting is empty by default, meaning orcharhino does not automatically delete the audit records.
  1. In the orcharhino management UI, navigate to Administer > Settings.
  3. Set the value of the setting to the number of days after which you want orcharhino to delete the audit records.
11.3. Anonymizing audit records
11.4. Deleting report records
Report records are created automatically in orcharhino. You can use the foreman-rake reports:expire command to remove reports at any time. You can also use a cron job to schedule report record deletions at the set interval that you want.
11.5. Configuring the cleaning unused tasks feature
orcharhino performs regular cleaning to reduce disc space in the database and limit the rate of disk growth. As a result, orcharhino backup completes faster and overall performance is higher.
By default, orcharhino executes a cron job that cleans tasks every day at 19:45. orcharhino removes the following tasks during the cleaning:
  • To configure the time at which orcharhino runs the cron job, set the --foreman-plugin-tasks-cron-line parameter to the time you want in cron format. For example, to schedule the cron job to run every day at 15:00, enter the following command:
  • To configure the period after which orcharhino deletes the tasks, edit the :rules: section in the /etc/foreman/plugins/foreman-tasks.yaml file.
  • To disable regular task cleanup on orcharhino, enter the following command:
  • To reenable regular task cleanup on orcharhino, enter the following command:
11.6. Deleting task records
Task records are created automatically in orcharhino. You can use the foreman-rake foreman_tasks:cleanup command to remove tasks at any time. You can also use a cron job to schedule Task record deletions at the set interval that you want.
11.7. Deleting a task by ID
  1. Connect to your orcharhino Server using SSH:
    # ssh root@orcharhino.example.com
  2. Optional: View the task:
  3. Delete the task:
  4. Optional: Ensure the task has been removed from orcharhino Server:
11.8. Recovering from a full disk
    1. Remove orphaned content:
    2. Change the download policy from Immediate to On Demand for as many repositories as possible and remove already downloaded packages.
    3. Grow the file system on the LV with the /var/lib/pulp directory on it.
      1. Stop orcharhino services:
      3. Start orcharhino services:
11.9. Reclaiming PostgreSQL space
The PostgreSQL database can use a large amount of disk space especially in heavily loaded deployments. Use this procedure to reclaim some of this disk space on orcharhino.
11.10. Reclaiming space from on demand repositories
If you set the download policy to on demand, orcharhino downloads packages only when the clients request them. You can clean up these packages to reclaim space.
Space reclamation requires an existing repository. For deleted repositories, wait for the next scheduled orphan cleanup or remove orphaned content manually:
For a single repository
  • In the orcharhino management UI, navigate to Content > Products.
  • Select a product.
  • On the Repositories tab, click the repository name.
  • From the Select Actions list, select Reclaim Space.
For multiple repositories
  • Select the product name.
  • On the Repositories tab, select the checkbox of the repositories.
  • Click Reclaim Space at the top right corner.
For orcharhino Proxies
  • In the orcharhino management UI, navigate to Infrastructure > orcharhino Proxies.
  • Select the orcharhino Proxy Server.
  • Click Reclaim space.
12. Renewing certificates
You can renew the CA certificate on orcharhino Server or the custom SSL certificate on orcharhino Server as well as on orcharhino Proxy Server.
12.1. Planning for self-signed CA certificate renewal
If you need to update the Certification Authority (CA) certificate on your orcharhino Server, add the new CA certificate and use a temporary dual CA certificate file to retain the HTTPS connections to your orcharhino Server during the renewal.
  1. Add the new SSL certificate to the CA certificate file on orcharhino Server and keep the old SSL certificate.
  2. Renew the certificates on orcharhino Server and any orcharhino Proxy Servers.
  3. Deploy the dual CA certificate on hosts.
  4. Remove the old certificate from the CA certificates file on orcharhino Server, so the CA certificate file contains only the new SSL certificate.
  5. Renew the certificates on orcharhino Server and any orcharhino Proxy Servers.
  6. Deploy the new CA certificate on hosts.
12.2. Renewing a custom SSL certificate on orcharhino Server
Use this procedure to update your custom SSL certificate for orcharhino Server.
  • You must create a new Certificate Signing Request (CSR) and send it to the Certificate Authority to sign the certificate. Refer to the Configuring orcharhino Server with a custom SSL certificate guide before creating a new CSR because the Server certificate must have X.509 v3 Key Usage and Extended Key Usage extensions with required values. In return, you will receive the orcharhino Server certificate and CA bundle.
  • Before deploying a renewed custom certificate on your orcharhino Server, validate the custom SSL input files. Note that for the katello-certs-check command to work correctly, Common Name (CN) in the certificate must match the FQDN of orcharhino Server:
    # katello-certs-check -t orcharhino \
    -b /root/orcharhino_cert/ca_cert_bundle.pem \
    -c /root/orcharhino_cert/orcharhino_cert.pem \
    -k /root/orcharhino_cert/orcharhino_cert_key.pem
    If the command is successful, it returns the following foreman-installer command. You can use this command to deploy the renewed CA certificates to orcharhino Server:
    # foreman-installer --scenario katello \
    --certs-server-cert "/root/orcharhino_cert/orcharhino_cert.pem" \
    --certs-server-key "/root/orcharhino_cert/orcharhino_cert_key.pem" \
    --certs-server-ca-cert "/root/orcharhino_cert/ca_cert_bundle.pem" \
    --certs-update-server \
    --certs-update-server-ca
Do not delete the certificate files after you deploy the certificate. They are required when upgrading orcharhino Server.
  1. Access the orcharhino management UI from your local machine. For example, https://orcharhino.example.com.
  2. In your browser, view the certificate details to verify the deployed certificate.
Next steps
12.3. Renewing a custom SSL certificate on orcharhino Proxy Server
Use this procedure to update your custom SSL certificate for orcharhino Proxy Server. The foreman-installer command, which the foreman-proxy-certs-generate command returns, is unique to each orcharhino Proxy Server. You cannot use the same command on more than one orcharhino Proxy Server.
  • You must create a new Certificate Signing Request and send it to the Certificate Authority to sign the certificate. Refer to the Configuring orcharhino Server with a custom SSL certificate guide before creating a new CSR because the orcharhino Server certificate must have X.509 v3 Key Usage and Extended Key Usage extensions with required values. In return, you will receive the orcharhino Proxy Server certificate and CA bundle.
  1. On your orcharhino Server, validate the custom SSL certificate input files:
    # katello-certs-check -t orcharhino-proxy \
    -b /root/orcharhino-proxy_cert/ca_cert_bundle.pem \
    -c /root/orcharhino-proxy_cert/orcharhino-proxy_cert.pem \
    -k /root/orcharhino-proxy_cert/orcharhino-proxy_cert_key.pem
  2. On your orcharhino Server, generate the certificate archive file for your orcharhino Proxy Server:
    --certs-tar "/root/My_Certificates/orcharhino-proxy.example.com-certs.tar" \
    --foreman-proxy-fqdn "orcharhino-proxy.example.com" \
    --server-ca-cert "/root/My_Certificates/ca_cert_bundle.pem" \
    --server-cert "/root/My_Certificates/orcharhino-proxy_cert.pem" \
    --server-key "/root/My_Certificates/orcharhino-proxy_cert_key.pem"
  3. On your orcharhino Server, copy the certificate archive file to your orcharhino Proxy Server:
    # scp /root/My_Certificates/orcharhino-proxy.example.com-certs.tar user@orcharhino-proxy.example.com:
  4. Retain a copy of the foreman-installer command that the foreman-proxy-certs-generate command returns for deploying the certificate to your orcharhino Proxy Server.
  5. Deploy the certificate on your orcharhino Proxy Server using the foreman-installer command returned by the foreman-proxy-certs-generate command:
    # foreman-installer --scenario foreman-proxy-content \
    --certs-tar-file "/root/My_Certificates/orcharhino-proxy.example.com-certs.tar" \
    --foreman-proxy-foreman-base-url "https://orcharhino.example.com" \
    --foreman-proxy-register-in-foreman "true"
Do not delete the certificate archive file on the orcharhino Proxy Server after you deploy the certificate. They are required when upgrading orcharhino Proxy Server.
Next steps
13. Synchronizing template repositories
In orcharhino, you can synchronize repositories of job templates, provisioning templates, report templates, and partition table templates between orcharhino Server and a version control system or local directory.
This section details the workflow for installing and configuring the Template Sync plugin and performing exporting and importing tasks.
13.1. Enabling the Template Sync plugin
  1. Enable the plugin on your orcharhino Server:
  2. Optional: Enable the Hammer CLI plugin on your orcharhino Server:
  1. In the orcharhino management UI, navigate to Administer > About.
  2. On the Plugins tab, ensure that the page includes the Template Sync plugin.
Next steps
  1. In the orcharhino management UI, navigate to Administer > Settings > Template Sync to configure the plugin. For more information, see Template sync settings.
13.2. Synchronizing templates with an existing repository
If you store templates in a repository under a version control system, you can synchronize the templates between your orcharhino Server and the repository.
  1. If you want to use HTTPS to connect to the repository and you use a self-signed certificate authority (CA) on your Git server:
    1. Create a new directory under the /usr/share/foreman/ directory to store the Git configuration for the certificate:
      # mkdir --parents /usr/share/foreman/.config/git
    2. Create a file named config in the new directory:
      # touch /usr/share/foreman/.config/git/config
    3. Allow the foreman user access to the .config directory:
      # chown --recursive foreman /usr/share/foreman/.config
    4. Update the Git global configuration for the foreman user with the path to your self-signed CA certificate:
      # sudo --user foreman git config --global http.sslCAPath Path_To_CA_Certificate
  2. If you want to use SSH to connect to the repository:
    1. Create an SSH key pair if you do not already have it. Do not specify a passphrase.
    2. Configure your version control server with the public key from your orcharhino, which resides in /usr/share/foreman/.ssh/id_rsa.pub.
    3. Accept the Git SSH host key as the foreman user:
      # sudo --user foreman ssh git.example.com
  3. In the orcharhino management UI, provide details for your Git repository:
    1. Navigate to Administer > Settings.
    2. Click the Template Sync tab.
    3. Change the Branch setting to define the target branch of the repository.
    4. Change the Repo setting to define the repository URL.
    5. If you want to use an HTTP proxy to connect to the repository, change the HTTP proxy policy setting to Global default HTTP proxy or Custom HTTP proxy.
Next steps
13.3. Synchronizing templates with a local directory
If you store templates in a local directory that is tracked under a version control system, you can synchronize the templates between your orcharhino Server and the local directory.
  • Each template must contain the location and organization that the template belongs to. This applies to all template types. Before you import a template, ensure that you add the following section to the template:
    kind: provision
    oses:
    - My_first_Operating_System
    - My_second_Operating_System
    locations:
    - My_first_Location
    - My_second_Location
    organizations:
    - My_first_Organization
    - My_second_Organization
  1. On your orcharhino Server, in /var/lib/foreman, create a directory for storing templates:
    # mkdir /var/lib/foreman/My_Templates_Dir
    You can place your templates to a custom directory outside /var/lib/foreman, but you have to ensure that the Foreman service can read its contents. The directory must have the correct file permissions and the foreman_lib_t SELinux label.
  2. Change the owner of the new templates directory to the foreman user:
    # chown foreman /var/lib/foreman/My_Templates_Dir
  3. Change the Repo setting on the Template Sync tab to match the /var/lib/foreman/My_Templates_Dir/ directory.
13.4. Importing templates
You can import templates from a repository of your choice. You can use different protocols to point to your repository, for example /tmp/dir, git://example.com, https://example.com, and ssh://example.com.
The templates provided by orcharhino are locked and you cannot import them by default. To overwrite this behavior, change the Force import setting in the Template Sync menu to yes or add the force parameter -d '{ "force": "true" }' to the import command.
    kind: provision
    oses:
    locations:
    - My_first_Location
    organizations:
To use the API, see the API procedure.
To use Ansible, see the Ansible procedure.
  1. In the orcharhino management UI, navigate to Hosts > Templates > Sync Templates.
  2. Click Import.
  3. Each field is populated with values configured in Administer > Settings > Template Sync. Change the values as required for the templates you want to import. For more information about each field, see Template sync settings.
  4. Click Submit.
The orcharhino management UI displays the status of the import. The status is not persistent; if you leave the status page, you cannot return to it.
CLI procedure
  • To import a template from a repository, enter the following command:
    $ hammer import-templates \
    --branch "My_Branch" \
    --filter '.*Template Name$' \
    --prefix "[Custom Index] " \
    --repo "https://git.example.com/path/to/repository"
    For better indexing and management of your templates, use --prefix to set a category for your templates. To select certain templates from a large repository, use --filter to define the title of the templates that you want to import. For example --filter '.*Ansible Default$' imports various Ansible Default templates.
API procedure
  1. Send a POST request to api/v2/templates/import:
    # curl -H "Accept:application/json" \
    -H "Content-Type:application/json" \
    -u login:password \
    -k https://orcharhino.example.com/api/v2/templates/import \
    -X POST
    If the import is successful, you receive {"message":"Success"}.
Ansible procedure
  • Use the theforeman.foreman.templates_import module.
For more information, see the Ansible module documentation with ansible-doc theforeman.foreman.templates_import.
13.5. Exporting templates
You can export templates to an existing repository.
  2. Click Export.
  3. Each field is populated with values configured in Administer > Settings > Template Sync. Change the values as required for the templates you want to export. For more information about each field, see Template sync settings.
  4. Click Submit.
The orcharhino management UI displays the status of the export. The status is not persistent; if you leave the status page, you cannot return to it.
CLI procedure
  1. To export the templates to a repository, enter the following command:
    $ hammer export-templates \
    This command clones the repository, makes changes in a commit, and pushes back to the repository. You can use the --branch "My_Branch" option to export the templates to a specific branch.
API procedure
  1. Send a POST request to api/v2/templates/export:
    -u login:password \
    -k https://orcharhino.example.com/api/v2/templates/export \
    -X POST
    If the export is successful, you receive {"message":"Success"}.
You can override default API settings by specifying them in the request with the -d parameter. The following example exports templates to the git.example.com/templates repository:
-u login:password \
-X POST \
-d "{\"repo\":\"git.example.com/templates\"}"
13.6. Uninstalling the Foreman templates plugin
Use the following procedure to avoid errors after removing the foreman_templates plugin.
  1. Disable the plugin using the orcharhino installer:
  2. Clean custom data of the plugin. The command does not affect any templates that you created.
  3. Uninstall the plugin:
14. Logging and reporting problems
The following sections describe the most commonly used log files and debugging tools available in orcharhino.
14.1. Logging levels of orcharhino components
You can set logging levels for individual orcharhino components. The default logging level is info. You can increase the logging level of orcharhino components to troubleshoot orcharhino. Increasing the logging level to debug provides the most detailed information.
14.1.1. Increasing the logging level for Foreman
By default, you can find the log in /var/log/foreman/production.log. For more information, see Configuring logging type and layout.
For more information about orcharhino logging settings, use foreman-installer with the --full-help option:
14.1.2. Increasing the logging level for Hammer
    :log_level: 'debug'
14.1.3. Increasing the logging level for orcharhino Proxy
By default, you can find the log in /var/log/foreman-proxy/proxy.log. For more information, see Configuring logging type and layout.
    # foreman-installer --foreman-proxy-log-level DEBUG
14.1.4. Increasing the logging level for Candlepin
You can find the logs in /var/log/candlepin/candlepin.log and /var/log/candlepin/error.log.
  1. Set the logging level to DEBUG:
    # foreman-installer --katello-candlepin-loggers log4j.logger.org.candlepin:DEBUG
    --katello-candlepin-loggers log4j.logger.org.candlepin:DEBUG \
    --katello-candlepin-loggers log4j.logger.org.candlepin.resource.ConsumerResource:WARN \
    --katello-candlepin-loggers log4j.logger.org.candlepin.resource.HypervisorResource:WARN
14.1.5. Increasing the logging level for Redis
  1. In /etc/redis/redis.conf, set the logging level to debug:
    loglevel debug
  2. Restart the Redis service:
    # systemctl restart redis
14.1.6. Increasing the logging level for foreman-installer
foreman-installer writes logs to /var/log/foreman-installer/.
  • Increase the logging level of the foreman-installer utility:
14.1.7. Increasing the logging level for Pulp
Pulp logs to the systemd journal. You can view the logs using journalctl --unit 'pulpcore*'.
  1. In /etc/pulp/settings.py, set the logging level to DEBUG:
  2. Restart the Pulp services:
    # systemctl restart \
    pulpcore-api \
    pulpcore-content \
    pulpcore-resource-manager \
    pulpcore-worker@\*
14.1.8. Increasing the logging level for Puppet agent
  • Set the logging level to debug:
    # foreman-installer --puppet-agent-additional-settings log_level:debug
14.1.9. Increasing the logging level for Puppet server
    # foreman-installer --puppet-server-additional-settings log_level:debug
14.1.10. Increasing the logging level for Salt
Salt Master logs to /var/log/salt/master. Salt Minions log to /var/log/salt/minion.
You can increase the logging level for Salt Master or Salt Minion:
  • In /etc/salt/master or /etc/salt/minion, set the logging level to debug:
    log_level: debug
14.2. Configuring logging levels with Hammer CLI
You can use Hammer to log debugging information for various orcharhino components. The default logging level is INFO.
  • To list the components whose logging level you can change by using hammer:
    $ hammer admin logging --list
  • To set DEBUG level logging for all components:
    $ hammer admin logging --all --level-debug
  • To set PRODUCTION level logging for all components:
    $ hammer admin logging --all --level-production
  • To set DEBUG level logging for a specific component:
    $ hammer admin logging --components My_Component --level-debug
  • To list all available logging options:
    $ hammer admin logging --help
14.3. Configuring logging type and layout
By default, orcharhino uses file-based logging. You can use foreman-installer to change the logging type and logging layout.
Procedure for configuring logging with journal
    --foreman-proxy-log JOURNAL
    • /var/log/foreman-proxy.log
Procedure for configuring logging to JSON output
  1. On your orcharhino Server, enable logging to JSON output for foreman-installer:
    --foreman-logging-layout json \
    --foreman-logging-type file
  2. Optional: Inspect the log messages using jq:
    # cat /var/log/foreman/production.log | jq
14.4. Selective debugging with individual loggers
    --foreman-loggers ldap:true \
    --foreman-loggers sql:true
14.5. Overview of individual loggers
The following list provides an overview of selected loggers. You can find the complete list of loggers with their default values in /usr/share/foreman/config/application.rb under Foreman::Logging.add_loggers.
app
Default value: true.
audit
background
blob
dynflow
ldap
Default value: false.
notifications
permissions
sql
telemetry
templates
14.6. Retrieving the status of services
orcharhino uses a set of back-end services. When troubleshooting, you can check the status of orcharhino services.
  • In the orcharhino management UI, navigate to Administer > About.
    • On the Smart Proxies tab, view the status of all orcharhino Proxies.
    • On the Compute Resources tab, view the status of attached compute resource providers.
    • In the Backend System Status table, view the status of all back-end services.
CLI procedure
  • Get information from the database and orcharhino services:
    $ hammer ping
  • Perform a health check:
14.7. Restarting services
orcharhino uses a set of back-end services. When troubleshooting, you can restart the services if needed.
  • Restart orcharhino services:
14.8. Utilities for processing log information
You can collect information from log files to troubleshoot orcharhino.
sosreport
The sos report command collects configuration and diagnostic information from a Linux system, such as the running kernel version, loaded modules, running services, and system and service configuration files. Additionally, it collects information about orcharhino, such as its back-end services and tasks. This output is stored in a tar file located at /var/tmp/sosreport-XXX-20171002230919.tar.xz.
For more information, run sos report --help or see SOS user documentation.
The sos report command removes security information such as passwords, tokens, and keys while collecting information. However, the tar files can still contain sensitive information about the orcharhino Server. Send the tar files directly to the intended recipient and not to a public target.
foreman-tail
The foreman-tail command displays orcharhino logs in real time.
14.9. Log file directories
The following table provides an overview of selected log directories on orcharhino Server:
/var/log/candlepin/
Subscription management
Installer
/var/log/foreman-maintain/
Foreman maintain
Foreman proxy
/var/log/foreman/
Foreman
/var/log/httpd/
Apache HTTP server
/var/log/messages/
Various other log messages
Puppet
/var/log/tomcat/
Candlepin web service logs
14.10. System journal metadata
The following table lists metadata that the journald service uses in orcharhino. You can use this metadata to filter your queries.
AUDIT_ACTION
Audit action performed
AUDIT_TYPE
Audit resource type
AUDIT_ID
AUDIT_ATTRIBUTE
AUDIT_FIELD_OLD
AUDIT_FIELD_NEW
AUDIT_ID
AUDIT_ATTRIBUTE
Example: Name or description
EXCEPTION_MESSAGE
EXCEPTION_CLASS
EXCEPTION_BACKTRACE
LOC_ID
Location database ID
LOC_NAME
Location name
LOC_LABEL
Location label
LOGGER
Logger name
ORG_ID
Organization database ID
ORG_NAME
Organization name
ORG_LABEL
Organization label
REMOTE_IP
Remote IP address of a client
REQUEST
SESSION
TEMPLATE_NAME
Template name
TEMPLATE_DIGEST
TEMPLATE_HOST_NAME
TEMPLATE_HOST_ID
USER_LOGIN
User login name
15. Monitoring resources
The following chapter details how to configure monitoring and reporting for managed systems. This includes host configuration, content views, compliance, registered hosts, promotions, and synchronization.
15.1. Using the orcharhino content dashboard
The orcharhino content dashboard contains various widgets which provide an overview of the host configuration, content views, compliance reports, and hosts currently registered, promotions and synchronization, and a list of the latest notifications.
In the orcharhino management UI, navigate to Monitor > Dashboard to access the content dashboard. The dashboard can be rearranged by clicking on a widget and dragging it to a different position. The following widgets are available:
Host Configuration Status
Table 4. Host configuration states
Icon State Description
host state config okay
host state config error
Hosts in error state
host state config report
host state config pending
host state config outofsync
Out of sync hosts
host state config noreport
Hosts with no reports
host state config noalert
Hosts with alerts disabled
Host Configuration Chart
Latest Events
New Hosts
Task Status
Latest Warning/Error Tasks
Discovered Hosts
Latest Errata
A list of all errata available for hosts registered to orcharhino.
Content Views
A list of all content views in orcharhino and their publish status.
Sync Overview
An overview of all products or repositories enabled in orcharhino and their synchronization status. All products that are in the queue for synchronization, are unsynchronized or have been previously synchronized are listed in this section.
Host Collections
A list of all host collections in orcharhino and their status, including the number of content hosts in each host collection.
Virt-who Configuration Status
Table 5. virt-who configuration states
State Description
No Reports
No report has been received because either an error occurred during the virt-who configuration deployment, or the configuration has not been deployed yet, or virt-who cannot connect to orcharhino during the scheduled interval.
No Change
OK
Total Configurations
Latest Compliance Reports
Compliance Reports Breakdown
Red Hat Insights Actions
Red Hat Insights is a tool embedded in orcharhino that checks the environment and suggests actions you can take. The actions are divided into 4 categories: Availability, Stability, Performance, and Security.
Red Hat Insights Risk Summary
It is not possible to change the date format displayed in the orcharhino management UI.
15.1.1. Managing tasks
orcharhino keeps a complete log of all planned or performed tasks, such as repositories synchronised, errata applied, and content views published. To review the log, navigate to Monitor > orcharhino Tasks > Tasks.
To adjust timeout settings
To disable checking for services
  5. Click Save.
15.2. Configuring RSS notifications
To view orcharhino event notification alerts, click the Notifications icon in the upper right of the screen.
By default, the Notifications area displays RSS feed events published in the orcharhino news.
You can configure the RSS feed notifications by changing the URL feed. The supported feed format is RSS 2.0 and Atom.
To configure RSS feed notifications
  1. In the orcharhino management UI, navigate to Administer > Settings and select the Notifications tab.
15.3. Monitoring orcharhino Server
Audit records list the changes made by all users on orcharhino. This information can be used for maintenance and troubleshooting.
  1. In the orcharhino management UI, navigate to Monitor > Audits to view the audit records.
15.4. Monitoring orcharhino Proxy Server
The following section shows how to use the orcharhino management UI to find orcharhino Proxy information valuable for maintenance and troubleshooting.
15.4.1. Viewing general orcharhino Proxy information
In the orcharhino management UI, navigate to Infrastructure > orcharhino Proxies to view a table of orcharhino Proxy Servers registered to orcharhino Server. The information contained in the table answers the following questions:
Is orcharhino Proxy Server running?
This is indicated by a green icon in the Status column. A red icon indicates an inactive orcharhino Proxy, use the service foreman-proxy restart command on orcharhino Proxy Server to activate it.
What services are enabled on orcharhino Proxy Server?
In the Features column, you can verify if, for example, your orcharhino Proxy provides a DHCP service or acts as a Pulp mirror. orcharhino Proxy features can be enabled during installation or configured in addition. For more information, see Installing orcharhino Proxy Server.
What organizations and locations is orcharhino Proxy Server assigned to?
A orcharhino Proxy Server can be assigned to multiple organizations and locations, but only orcharhino Proxies belonging to the currently selected organization are displayed. To list all orcharhino Proxies, select Any Organization from the context menu in the top left corner.
After changing the orcharhino Proxy configuration, select Refresh from the drop-down menu in the Actions column to ensure the orcharhino Proxy table is up to date.
Click the orcharhino Proxy name to view further details. At the Overview tab, you can find the same information as in the orcharhino Proxy table. In addition, you can answer to the following questions:
Which hosts are managed by orcharhino Proxy Server?
How much storage space is available on orcharhino Proxy Server?
The amount of storage space occupied by the Pulp content in /var/lib/pulp is displayed. Also the remaining storage space available on the orcharhino Proxy can be ascertained.
15.4.2. Monitoring services
In the orcharhino management UI, navigate to Infrastructure > orcharhino Proxies and click the name of the selected orcharhino Proxy. At the Services tab, you can find basic information on orcharhino Proxy services, such as the list of DNS domains, or the number of Pulp workers. The appearance of the page depends on what services are enabled on orcharhino Proxy Server. Services providing more detailed status information can have dedicated tabs at the orcharhino Proxy page. For more information, see Monitoring Puppet.
15.4.3. Monitoring Puppet
In the orcharhino management UI, navigate to Infrastructure > orcharhino Proxies and click the name of the selected orcharhino Proxy. At the Puppet tab you can find the following:
  • A table of CA certificates associated with the orcharhino Proxy at the Certificates sub-tab. Here you can inspect the certificate expiry data, or cancel the certificate by clicking Revoke.
The Puppet and Puppet CA tabs are available only if you have Puppet enabled in your orcharhino.
16. Limiting host resources
You can use the Resource Quota plugin to limit users' access to host resources during host provisioning.
In a typical usage scenario, orcharhino manages multiple compute resources for multiple departments. To share managed resources in a fair and predictable way, administrators can assign resource quotas to users and user groups.
Supported resource types
  • CPU cores
  • Memory
  • Disk space
Supported compute resources
  • VMware
  • libvirt
16.1. Installing the Resource Quota plugin
To limit host resources for your orcharhino users, install the Resource Quota plugin.
  1. Install the plugin on your orcharhino Server:
  2. Optional: Install the Hammer CLI plugin on your orcharhino Server:
16.2. Managing resource quotas
You can create, edit, and delete resource quotas in orcharhino management UI. All resource quotas are listed on Configure > Resource Quotas.
16.2.1. Creating a resource quota
Create a resource quota to limit the resource consumption of orcharhino users. To use the CLI instead of the orcharhino management UI, see the CLI procedure.
  1. In the orcharhino management UI, navigate to Configure > Resource Quotas.
  2. Click Create resource quota.
  3. Specify the name, CPU cores, memory, and disk space.
  4. Click Create resource quota to submit the resource quota to orcharhino.
CLI procedure
  • Create a resource quota:
    $ hammer resource-quota create \
    --cpu-cores My_CPU_Cores \
    --description My_Resource_Quota_Description \
    --disk-space My_Disk_Space_in_GiB \
    --memory My_Memory_in_MiB \
    --name "My_Resource_Quota_Name"
    For all options, see hammer resource-quota create --help.
16.2.2. Editing a resource quota
You can edit a resource quota to adjust available resources to orcharhino users. To use the CLI instead of the orcharhino management UI, see the CLI procedure.
  2. Select your resource quota.
  3. Adjust the CPU cores, Memory, or Disk space and click Apply to submit your changes to orcharhino.
CLI procedure
  1. Optional: List all resource quotas:
  2. Edit a resource quota:
    $ hammer resource-quota update \
    --id My_Resource_Quota_ID \
    If you set the value to 0, users cannot consume any resource at all. To reset resource quotas, you can use --remove-cpu-cores-limit, --remove-disk-space-limit, and --remove-memory-limit.
    For all options, see hammer resource-quota update --help.
16.2.3. Deleting a resource quota
You can delete a resource quota from orcharhino. To use the CLI instead of the orcharhino management UI, see the CLI procedure.
  2. In the Actions column, click Delete for your resource quota.
CLI procedure
  2. Delete a resource quota:
    For all options, see hammer resource-quota delete --help.
16.3. Assigning resource quotas to users
You can assign resource quotas to users or user groups. A user can select one of their assigned resource quotas during host provisioning. If Resource Quota optional assignment is set to No, a user does not have to assign a resource quota. You can use the resource_quota filter in the orcharhino management UI to view users or user groups with assigned resource quotas.
16.3.1. Assigning resource quotas to a user
You can assign resource quotas to a user to limit the resource consumption of that orcharhino user. To use the CLI instead of the orcharhino management UI, see the CLI procedure.
  1. In the orcharhino management UI, navigate to Administer > Users.
  2. Select a user.
  3. On the Resource Quota tab, assign resource quotas to the user.
  4. If you want to make the usage of resource quotas optional, select the Optional Assignment checkbox.
    This means that orcharhino will not prevent users from consuming more resources than their assigned quota.
  5. Click Submit to assign resource quotas to a user.
CLI procedure
  1. Optional: List all orcharhino users:
  2. Optional: List all resource quotas:
  3. Assign resource quotas to a user:
    $ hammer user update \
    --id My_User_ID \
    --resource-quota-ids My_Resource_Quota_IDs
    If you want to make resource quota optional, add the --resource-quota-is-optional true option.
    For all options, see hammer user update --help.
16.3.2. Assigning resource quotas to a user group
You can assign resource quotas to a user group to limit the resource consumption of that orcharhino user group. All users of the user group share the pool of resources. To use the CLI instead of the orcharhino management UI, see the CLI procedure.
  1. In the orcharhino management UI, navigate to Administer > User Groups.
  2. On the Resource Quota tab, assign resource quotas to the user group.
  3. Click Submit to assign resource quotas to a user group.
CLI procedure
  1. Optional: List all orcharhino user groups:
  3. Assign resource quotas to a user group:
    $ hammer user-group update \
    --id My_User_Group_ID \
    For all options, see hammer user-group update --help.
16.4. Resource Quota settings
You can configure the following global orcharhino settings for the Resource Quota plugin:
orcharhino will not limit the resource consumption if a resource quota is exceeded.
orcharhino will not enforce selecting a resource quota during host provisioning. The global setting overwrites user-specific and user group-specific configuration options.
17. Using webhooks
A webhook is a way for a web page or web application to provide other applications with information in real time. Webhooks are only triggered after an event occurs. The request usually contains details of the event. An event triggers callbacks, such as sending an e-mail confirming a host has been provisioned. You can use webhooks to define a call to an external API based on orcharhino internal event by using a fire-and-forget message exchange pattern. The application sending the request does not wait for the response, or ignores it.
The typical use case for webhooks in orcharhino is making a call to a monitoring system when a host is created or deleted.
Webhooks are useful where the action you want to perform in the external system can be achieved through its API. Where it is necessary to run additional commands or edit files, the shellhooks plugin for orcharhino Proxies is available. The shellhooks plugin enables you to define a shell script on the orcharhino Proxy that can be executed through the API.
17.1. Installing the webhooks plugin
Use the following procedure to install the webhooks plugin. Then, you can configure orcharhino Server to send webhook requests.
  • Install the webhooks plugin by running the following command:
  • Optional: Install the webhooks CLI plugin:
17.2. Creating a webhook template
Webhook templates are used to generate the body of HTTP request to a configured target when a webhook is triggered. Use the following procedure to create a webhook template in the orcharhino management UI.
  1. In the orcharhino management UI, navigate to Administer > Webhook > Webhook Templates.
    A webhook HTTP payload must be created using orcharhino template syntax. The webhook template can use a special variable called @object that can represent the main object of the event. @object can be missing in case of certain events. You can determine what data are actually available with the @payload variable.
    For more information, see Template Writing Reference in Managing hosts and for available template macros and methods, visit /templates_doc on orcharhino Server.
  7. Click Submit.
Examples
Running remote execution jobs
Creating users
17.3. Creating a webhook
You can customize events, payloads, HTTP authentication, content type, and headers through the orcharhino management UI.
Use the following procedure to create a webhook in the orcharhino management UI.
  1. In the orcharhino management UI, navigate to Administer > Webhook > Webhooks.
  2. Click Create new.
  6. Click Template to select a template. Webhook templates are used to generate the body of the HTTP request to orcharhino Server when a webhook is triggered.
  7. Enter an HTTP method.
  9. Click the Credentials tab.
  11. Optional: Uncheck Verify SSL if you do not want to verify the server certificate against the system certificate store or orcharhino CA.
17.4. Available webhook events
The following table contains a list of webhook events that are available from the orcharhino management UI. Action events trigger webhooks only on success, so if an action fails, a webhook is not triggered.
A content view was successfully promoted.
Run OpenSCAP scan.
Runs an Ansible Playbook containing all the roles defined for a host.
Actions Remote Execution Run Host Job Ansible Run orcharhino Proxy Upgrade Succeeded
Upgrade orcharhino Proxies on given orcharhino Proxy Servers.
Run an Ansible Playbook against given hosts.
Run an Ansible Playbook to enable the web console on given hosts.
Perform a single Puppet run.
Build Entered
Build Exited
Common database operations on a content view.
Domain
Host
Hostgroup
Model
Status Changed
Subnet
Template Render Performed
Template
User
17.5. Shellhooks
With webhooks, you can only map one orcharhino event to one API call. For advanced integrations, where a single shell script can contain multiple commands, you can install a orcharhino Proxy shellhooks plugin that exposes executables by using a REST HTTP API.
You can then configure a webhook to reach out to a orcharhino Proxy API to run a predefined shellhook. A shellhook is an executable script that can be written in any language provided that it can be executed. The shellhook can for example contain commands or edit files.
You can pass input to shellhook script through the webhook payload. This input is redirected to standard input of the shellhook script. You can pass arguments to shellhook script by using HTTP headers in format X-Shellhook-Arg-1 to X-Shellhook-Arg-99. For more information on passing arguments to shellhook script, see:
The HTTP method must be POST. An example URL would be: https://orcharhino-proxy.example.com:9090/shellhook/My_Script.
You must enable orcharhino Proxy Authorization for each webhook connected to a shellhook to enable it to authorize a call.
Standard output and standard error output are redirected to the orcharhino Proxy logs as messages with debug or warning levels respectively.
For an example on creating a shellhook script, see Creating a shellhook to print arguments.
17.6. Installing the shellhooks plugin
Optionally, you can install and enable the shellhooks plugin on each orcharhino Proxy used for shellhooks.
  • Install the shellhooks plugin on your orcharhino Proxy:
17.7. Passing arguments to shellhook script using webhooks
      "X-Shellhook-Arg-1": "VALUE",
      "X-Shellhook-Arg-2": "VALUE"
Example
17.8. Passing arguments to shellhook script using curl
    "X-Shellhook-Arg-1: VALUE"
    "X-Shellhook-Arg-2: VALUE"
Example
$ curl \
--data "" \
--header "Content-Type: text/plain" \
--header "X-Shellhook-Arg-1: Version 1.0" \
--header "X-Shellhook-Arg-2: My content view" \
--request POST \
--show-error \
--silent \
17.9. Creating a shellhook to print arguments
  1. Modify the /var/lib/foreman-proxy/shellhooks/print_args script to print arguments to standard error output so you can see them in the orcharhino Proxy logs:
    #!/bin/sh
    echo "$@" >&2
  2. In the orcharhino management UI, navigate to Administer > Webhook > Webhooks.
  3. Click Create new.
  6. In the Target URL field, enter the URL of your orcharhino Proxy Server followed by :9090/shellhook/print_args:
    https://orcharhino-proxy.example.com:9090/shellhook/print_args
  8. On the Credentials tab, check orcharhino Proxy Authorization.
        "X-Shellhook-Arg-1": "Hello",
        "X-Shellhook-Arg-2": "World!"
  10. Click Submit. You now have successfully created a shellhook that prints "Hello World!" to orcharhino Proxy logs every time you a remote execution job succeeds.
  1. Run a remote execution job on any host. You can use time as a command. For more information, see Executing a Remote Job in Managing hosts.
  2. Verify that the shellhook script was triggered and printed "Hello World!" to orcharhino Proxy Server logs:
    [W] [3520] Hello World!
18. Searching and bookmarking
orcharhino features powerful search functionality on most pages of the orcharhino management UI. It enables you to search all kinds of resources that orcharhino manages. Searches accept both free text and syntax-based queries, which can be built by using input prediction. Search queries can be saved as bookmarks for future reuse.
18.1. Building search queries
As you start typing a search query, a list of valid options to complete the current part of the query appears. You can either select an option from the list and keep building the query by using the prediction, or continue typing. To learn how free text is interpreted by the search engine, see Using free text search.
18.1.1. Query syntax
parameter operator value
18.1.2. Query operators
Table 6. Comparison operators accepted by search
EQUALS
hostgroup = RHEL7
NOT EQUALS
LIKE
hostgroup ~ rhel%
NOT LIKE
GREATER THAN
registered_at <= Yesterday
LESS THAN
IN
release_version !^ 7
NOT IN
HAS or set?
NOT HAS or null?
Table 7. Logical operators accepted by search
and
<whitespace>
or
not
18.1.3. Query values
Text Values
Examples:
hostgroup = "Web servers"
hostgroup = Web servers
Temporal Values
  • "10 January 2017"
  • "10 Jan 2017"
  • 10-January-2017
  • 10/January/2017
  • "January 10, 2017"
Warning
18.2. Using free text search
18.3. Managing bookmarks
18.3.1. Creating bookmarks
  1. In the orcharhino management UI, navigate to the page where you want to create a bookmark.
  7. Click Submit.
18.3.2. Deleting bookmarks
  1. In the orcharhino management UI, navigate to Administer > Bookmarks.
18.4. Using keyboard shortcuts
You can use keyboard shortcuts to quickly focus search bars.
  • To focus the vertical navigation search bar, press Ctrl + Shift + F.
  • To focus the page search bar, press /.
Appendix A: Administration settings
This section contains information about settings that you can edit in the orcharhino management UI by navigating to Administer > Settings.
A.1. General settings
Administrator email address
orcharhino URL
URL where your orcharhino instance is reachable. See also Provisioning > Unattended URL.
Entries per page
20
Number of records shown per page in orcharhino
Fix DB cache
orcharhino maintains a cache of permissions and roles. When set to Yes, orcharhino recreates this cache on the next restart.
DB pending seed
orcharhino Proxy request timeout
60
Open and read timeout for HTTP requests from orcharhino to orcharhino Proxy (in seconds).
Login page footer text
HTTP(S) proxy
Set a proxy for outgoing HTTP(S) connections from the orcharhino product. System-wide proxies must be configured at the operating system level.
HTTP(S) proxy except hosts
Show Experimental Labs
Display FQDN for hosts
If set to Yes, orcharhino displays names of hosts as fully qualified domain names (FQDNs).
Out of sync interval
30
Hosts report periodically, and if the time between reports exceeds this duration in minutes, hosts are considered out of sync. You can override this on your hosts by adding the outofsync_interval parameter, per host, at Hosts > All hosts > $host > Edit > Parameters > Add Parameter.
orcharhino UUID
orcharhino instance ID. Uniquely identifies a orcharhino instance.
Default language
Default timezone
Instance title
Saved audits interval
New host details UI
orcharhino loads the new UI for host details.
A.2. Task settings
Sync task timeout
120
Enable dynflow console
Proxy action retry count
4
Number of attempts permitted to start a task on the orcharhino Proxy before failing.
Proxy action retry interval
15
Allow proxy batch tasks
Allow triggering tasks on the orcharhino Proxy in batches.
Proxy tasks batch size
100
Number of tasks included in one request to the orcharhino Proxy if foreman_tasks_proxy_batch_trigger is enabled.
Tasks troubleshooting URL
Polling intervals multiplier
1
A.3. Template sync settings
Associate
Associate templates with operating system, organization, and location.
Branch
Default branch in Git repo.
Commit message
Templates export made by a orcharhino user
Dirname
Filter
Force import
HTTP proxy policy
Whether to use an HTTP proxy to synchronize templates.
The Custom HTTP proxy value is available only if an HTTP proxy is configured under the selected organization and location and if your account has the view_http_proxies permission assigned.
Lock templates
Keep, do not lock new
Metadata export mode
Refresh
Default metadata export mode.
Possible options:
refresh re-renders metadata.
keep keeps existing metadata.
Negate
Prefix
Repo
/tmp/dir
git://example.com
https://example.com
ssh://example.com
Verbosity
A.4. Discovery settings
Discovery location
Discovery organization
Interface fact
discovery_bootif
Create bond interfaces
Clean all facts
Hostname facts
discovery_bootif
Auto provisioning
Reboot
Hostname prefix
mac
Fact columns
Highlighted facts
Storage facts
Software facts
Hardware facts
Network facts
IPMI facts
Lock PXE
Locked PXELinux template name
pxelinux_discovery
Locked PXEGrub template name
pxegrub_discovery
Locked PXEGrub2 template name
pxegrub2_discovery
Force DNS
Error on existing NIC
Do not permit to discover an existing host matching the MAC of a provisioning Network Interface Card (NIC) (errors out early).
Type of name generator
Fact + prefix
Prefer IPv6
A.5. Boot disk settings
iPXE directory
/usr/share/ipxe
ISOLINUX directory
/usr/share/syslinux
SYSLINUX directory
/usr/share/syslinux
Grub2 directory
/var/lib/tftpboot/grub2
Host image template
Boot disk iPXE - host
Generic image template
Boot disk iPXE - generic host
ISO generation command
genisoimage
Installation media caching
Allowed bootdisk types
A.6. Red Hat Cloud settings
Automatic inventory upload
Enable automatic upload of your host inventory to the Red Hat cloud.
Synchronize recommendations Automatically
Enable automatic synchronization of Insights recommendations from the Red Hat cloud.
Obfuscate host names
Obfuscate hostnames sent to the Red Hat cloud.
Obfuscate host ipv4 addresses
Obfuscate IPv4 addresses sent to the Red Hat cloud.
ID of the RHC daemon
RHC daemon id.
A.7. Content settings
Default HTTP Proxy
Kickstart default
Kickstart default finish
Default synced OS user-data
Kickstart default user data
Kickstart default PXELinux
Kickstart default PXEGrub
Kickstart default PXEGrub2
Kickstart default iPXE
Kickstart default
Discovery ATIX AG kexec
Atomic Kickstart default
Manifest refresh timeout
1200
Can communicate with the ATIX AG Portal for subscriptions.
Calculate errata host status based only on errata in a host’s content view and lifecycle environment.
Check services before actions
100
How many repositories should be synced concurrently on a orcharhino Proxy. A smaller number may lead to longer sync times. A larger number will increase dynflow load.
Sync orcharhino Proxies after Content View promotion
Whether or not to auto sync orcharhino Proxies after a content view promotion.
immediate
Default ATIX AG Repository download policy
on_demand
Default download policy for enabled ATIX AG repositories. Either immediate or on_demand.
Default orcharhino Proxy download policy
on_demand
Default download policy for orcharhino Proxy syncs. Either inherit, immediate, or on_demand.
/var/lib/pulp/katello-export
/var/lib/pulp/exports
Pulp client key
Pulp client cert
Sync Connection Timeout
300
Delete Host upon unregister
Default Location
Expire soon days
120
Host Duplicate DMI UUIDs
Host Profile Assume
Enable new host registrations to assume registered profiles with matching hostname if the registering DMI UUID is not used by another host.
Enable host registrations to bypass Host Profile Assume if the host is in build mode.
Host Tasks Workers Pool Size
5
Applicability Batch Size
50
Autosearch
Autosearch delay
500
Pulp bulk load size
2000
1440
Enable removal of repositories that the user has previously published in one or more content view versions.
A.8. Authentication settings
OAuth active
orcharhino will use OAuth for API authorization.
This setting is for internal orcharhino use only. ATIX AG does not support using it to configure OAuth authentication for API calls.
OAuth consumer key
OAuth consumer key.
OAuth consumer secret
OAuth consumer secret.
OAuth map users
orcharhino maps users by username in the request-header. If this is disabled, OAuth requests have administrator rights.
Failed login attempts limit
30
orcharhino blocks user logins from an incoming IP address for 5 minutes after the specified number of failed login attempts. Set to 0 to disable brute force protection.
Restrict registered orcharhino Proxies
Only known orcharhino Proxies can access features that use orcharhino Proxy authentication.
Trusted hosts
List of hostnames, IPv4, IPv6 addresses or subnets to be trusted in addition to orcharhino Proxies for access to fact/report importers and ENC output.
SSL certificate
/etc/foreman/client_cert.pem
SSL Certificate path that orcharhino uses to communicate with its proxies.
SSL CA file
/etc/foreman/proxy_ca.pem
SSL CA file path that orcharhino uses to communicate with its proxies.
SSL private key
/etc/foreman/client_key.pem
SSL Private Key path that orcharhino uses to communicate with its proxies.
SSL client DN env
HTTP_SSL_CLIENT_S_DN
SSL client verify env
HTTP_SSL_CLIENT_VERIFY
SSL client cert env
HTTP_SSL_CLIENT_CERT
Server CA file
SSL CA file path used in templates to verify the connection to orcharhino.
Websockets SSL key
Private key file path that orcharhino uses to encrypt websockets.
Websockets SSL certificate
Certificate path that orcharhino uses to encrypt websockets.
Websockets encryption
Login delegation logout URL
External
Idle timeout
60
BCrypt password cost
9
BMC credentials access
OIDC JWKs URL
OIDC Audience
OIDC Issuer
OIDC Algorithm
A.9. Email settings
Email reply address
Email reply address for emails that orcharhino is sending.
Email subject prefix
Send welcome email
Delivery method
Sendmail
Method used to deliver email.
SMTP enable StartTLS auto
SMTP OpenSSL verify mode
Default verification mode
SMTP address
SMTP address to connect to.
SMTP port
25
SMTP port to connect to.
SMTP HELO/EHLO domain
HELO/EHLO domain.
SMTP username
SMTP password
SMTP authentication
none
Sendmail arguments
-i
Sendmail location
/usr/sbin/sendmail
A.10. Notifications settings
RSS enable
Pull RSS notifications.
RSS URL
https://orcharhino.com/feed/
A.11. Provisioning settings
Host owner
Default owner on provisioned hosts, if empty orcharhino uses the current user.
Root password
Unattended URL
Safemode rendering
Enables safe mode rendering of provisioning templates. The default and recommended option Yes denies access to variables and any object that is not listed in orcharhino.
When set to No, any object may be accessed by a user with permission to use templating features, either by editing templates, parameters or smart variables. This permits users full remote code execution on orcharhino Server, effectively disabling all authorization. This is not a safe option, especially in larger companies.
Query local nameservers
orcharhino queries the locally configured resolver instead of the SOA/NS authorities.
Installation token lifetime
360
SSH timeout
120
0.0.0.0
Update IP from built request
orcharhino updates the host IP with the IP that made the build request.
Use short name for VMs
orcharhino uses the short hostname instead of the FQDN for creating new virtual machines.
DNS timeout
[5, 10, 15, 20]
Clean up failed deployment
orcharhino deletes the virtual machine if the provisioning script ends with a non-zero exit code.
Random-based
iPXE intermediate script
Destroy associated VM on host delete. When enabled, VMs linked to hosts are deleted on Compute Resource. When disabled, VMs are unlinked when the host is deleted, meaning they remain on Compute Resource and can be re-associated or imported back to orcharhino again. This does not automatically power off the VM
Maximum structured facts
100
Maximum number of keys in structured subtree, statistics stored in orcharhino::dropped_subtree_facts.
Global Registration
Global Registration template.
CoreOS Transpiler Command
PXEGrub2 global default
PXELinux global default
PXEGrub global default
Global default iPXE template
iPXE global default
Local boot PXEGrub2 template
PXEGrub2 default local boot
Local boot PXELinux template
PXELinux default local boot
Local boot PXEGrub template
PXEGrub default local boot
Local boot iPXE template
iPXE default local boot
Manage PuppetCA
orcharhino automates certificate signing upon provision of a new host.
Use UUID for certificates
orcharhino uses random UUIDs for certificate signing instead of hostnames.
A.12. Facts settings
orcharhino creates the host when new facts are received.
Location fact
orcharhino_location
Organization fact
orcharhino_organization
Default location
Default Location
Default organization
Default Organization
Update hostgroup from facts
orcharhino updates a host’s hostgroup from its facts.
Ignore facts for domain
Update subnets from facts
None
orcharhino updates a host’s subnet from its facts.
Exclude pattern for facts stored in orcharhino
Exclude pattern for all types of imported facts (Puppet, Ansible, rhsm). Those facts are not stored in the orcharhino database. You can use a * wildcard to match names with indexes, e.g. ignore* filters out ignore, ignore123 as well as a::ignore or even a::ignore123::b.
Default Puppet environment
production
orcharhino defaults to this puppet environment if it cannot auto detect one.
ENC environment
orcharhino explicitly sets the puppet environment in the ENC yaml output. This avoids conflicts between the environment in puppet.conf and the environment set in orcharhino.
Update environment from facts
orcharhino updates a host’s environment from its facts.
A.13. Configuration management settings
orcharhino creates the host when a report is received.
Matchers inheritance
orcharhino matchers are inherited by children when evaluating smart class parameters for hostgroups, organizations, and locations.
[fqdn, hostgroup, os, domain]
orcharhino evaluates host smart class parameters in this order by default.
Interpolate ERB in parameters
orcharhino parses ERB in parameters value in the ENC output.
All hosts show a configuration status even when a Puppet orcharhino Proxy is not assigned.
Puppet interval
35
Puppet out of sync disabled
A.14. Remote execution settings
Fallback to Any Proxy
Enable Global Proxy
SSH User
root
Effective User
root
Effective User Method
sudo
Effective user password
Sync Job Templates
SSH Port
22
Connect by IP
Prefer IPv6 over IPv4
Default SSH password
Default SSH key passphrase
Workers pool size
5
Number of workers in the pool to handle the execution of the remote execution jobs. Restart of the dynflowd/orcharhino-tasks service is required.
Cleanup working directories
Cockpit URL
Form Job Template
Run Command - Script Default
Time to pickup
86400
Time in seconds within which the host has to pick up a job. If the job is not picked up within this limit, the job will be canceled. Applies only to pull-mqtt based jobs. Defaults to one day.
A.15. Ansible settings
Private Key Path
Connection type
ssh
Use this connection type by default when running Ansible Playbooks. You can override this on hosts by adding the ansible_connection parameter.
WinRM cert Validation
validate
Enable or disable WinRM server certificate validation when running Ansible Playbooks. You can override this on hosts by adding the ansible_winrm_server_cert_validation parameter.
Default verbosity level
Disabled
orcharhino adds this level of verbosity for additional debugging output when running Ansible Playbooks.
Post-provision timeout
360
Timeout (in seconds) to set when orcharhino triggers an Ansible roles task playbook after a host is fully provisioned. Set this to the maximum time you expect a host to take until it is ready after a reboot.
Ansible report timeout
30
Ansible out of sync disabled
Ansible - Ansible Inventory
orcharhino uses this template to schedule the report with Ansible inventory.
Ansible roles to ignore
The roles to exclude when importing roles from orcharhino Proxy. The expected input is comma separated values and you can use * wildcard metacharacters. For example: foo*, *b*, *bar.
Number of tasks which should be sent to the orcharhino Proxy in one request if orcharhino_tasks_proxy_batch_trigger is enabled. If set, it overrides the orcharhino_tasks_proxy_batch_size setting for Ansible jobs.
