1. Starting and stopping Foreman
Foreman provides the foreman-maintain service command to manage Foreman services from the command line. This is useful when creating a backup of Foreman. For more information on creating backups, see Backing up Foreman server and Smart Proxy server.
2. Tuning Foreman server with predefined profiles
If your Foreman deployment includes more than 5000 hosts, you can use predefined tuning profiles to improve performance of Foreman.
Note that you cannot use tuning profiles on Smart Proxies.
You can choose one of the profiles depending on the number of hosts your Foreman manages and available hardware resources.
When you run the foreman-installer command with the --tuning option, deployment configuration settings are applied to Foreman in the following order:
  1. The default tuning profile defined in the /usr/share/foreman-installer/config/foreman.hiera/tuning/common.yaml file
  2. The tuning profile that you want to apply to your deployment and is defined in the /usr/share/foreman-installer/config/foreman.hiera/tuning/sizes/ directory
  3. Optional: If you have configured a /etc/foreman-installer/custom-hiera.yaml file, Foreman applies these configuration settings.
default
Number of hosts: 0 – 5000
RAM: 20G
Number of CPU cores: 4
medium
Number of hosts: 5001 – 10000
RAM: 32G
Number of CPU cores: 8
large
Number of hosts: 10001 – 20000
RAM: 64G
Number of CPU cores: 16
extra-large
Number of hosts: 20001 – 60000
RAM: 128G
Number of CPU cores: 32
extra-extra-large
Number of hosts: 60000+
RAM: 256G
Number of CPU cores: 48+
  1. Optional: If you have configured the custom-hiera.yaml file on Foreman server, back up the /etc/foreman-installer/custom-hiera.yaml file to custom-hiera.original. You can use the backup file to restore the /etc/foreman-installer/custom-hiera.yaml file to its original state if it becomes corrupted:
    # cp /etc/foreman-installer/custom-hiera.yaml \
    /etc/foreman-installer/custom-hiera.original
  2. Optional: If you have configured the custom-hiera.yaml file on Foreman server, review the definitions of the default tuning profile in /usr/share/foreman-installer/config/foreman.hiera/tuning/common.yaml and the tuning profile that you want to apply in /usr/share/foreman-installer/config/foreman.hiera/tuning/sizes/. Compare the configuration entries against the entries in your /etc/foreman-installer/custom-hiera.yaml file and remove any duplicated configuration settings in your /etc/foreman-installer/custom-hiera.yaml file.
  3. Enter the foreman-installer command with the --tuning option for the profile that you want to apply. For example, to apply the medium tuning profile settings, enter the following command:
3. Migrating from internal Foreman databases to external databases
  1. Installing PostgreSQL. Prepare PostgreSQL with databases for Foreman, Pulp, and Candlepin with dedicated users owning them.
  2. Migrating to external databases. Edit the parameters of foreman-installer to point to the new databases, and run foreman-installer.
3.1. PostgreSQL as an external database considerations
Foreman, Katello, and Candlepin use the PostgreSQL database. If you want to use PostgreSQL as an external database, the following information can help you decide if this option is right for your Foreman configuration. Foreman supports PostgreSQL version 13.
Advantages of external PostgreSQL
Disadvantages of external PostgreSQL
3.2. Installing PostgreSQL
  • The prepared host must meet Foreman Storage requirements.
  • The prepared host has base operating system repositories enabled.
  1. On your new database server, install PostgreSQL:
    # dnf install postgresql-server postgresql-contrib
  2. Initialize the PostgreSQL database:
    # postgresql-setup --initdb
    • max_connections: 500
    • shared_buffers: 512MB
    • work_mem: 4MB
    listen_addresses = '*'
  5. Add the following line to the end of the file to use SCRAM for authentication:
  6. Edit the /var/lib/pgsql/data/pg_hba.conf file:
  7. Add the following line to the file:
      host  all   all   Foreman_ip/32   scram-sha-256
  8. Start and enable the PostgreSQL service:
  9. Open the postgresql port:
  10. Make the changes persistent:
  11. Switch to the postgres user and start the PostgreSQL client:
    $ su - postgres -c psql
  12. Create three databases and dedicated roles: one for Foreman, one for Candlepin, and one for Pulp:
  13. Exit the postgres user:
    # \q
  14. From Foreman server, test that you can access the database. If the connection succeeds, the commands return 1.
    # PGPASSWORD='Foreman_Password' psql -h postgres.example.com -p 5432 -U foreman -d foreman -c "SELECT 1 as ping"
3.3. Migrating to external databases
  • You have installed and configured a PostgreSQL server on an external server.
  1. On Foreman server, stop all Foreman services except for PostgreSQL:
  2. Create your target directory for the Foreman backup:
    # mkdir /var/My_Migration_Backup_Directory
    # foreman-maintain backup online \
    --preserve-directory \
    --skip-pulp-content \
    PGPASSWORD='Foreman_Password' pg_restore -h postgres.example.com -U foreman -d foreman < /var/My_Migration_Backup_Directory/foreman.dump
    PGPASSWORD='Candlepin_Password' pg_restore -h postgres.example.com -U candlepin -d candlepin < /var/My_Migration_Backup_Directory/candlepin.dump
    PGPASSWORD='Pulpcore_Password' pg_restore -h postgres.example.com -U pulp -d pulpcore < /var/My_Migration_Backup_Directory/pulpcore.dump
    # foreman-installer \
    --foreman-proxy-content-pulpcore-postgresql-user pulp \
    --foreman-db-manage false \
    --foreman-db-password Foreman_Password
  6. Remove the PostgreSQL package on Foreman server:
    # dnf remove postgresql-server
  7. Remove the PostgreSQL data directory:
    # rm -fr /var/lib/pgsql/data
4. Automating Foreman management with Foreman Ansible Collection
4.1. Installing the Foreman Ansible modules
Modules from the Foreman Ansible Collection are provided by the ansible-collection-theforeman-foreman package. Before you can use the modules, you must install the package on the system where you run your playbooks.
You can execute your playbooks on any system that can reach the Foreman API. This can also be your Foreman server itself.
  • Install the ansible-collection-theforeman-foreman package:
  • Display the list of Ansible modules that are now available on your system:
    # ansible-doc --list theforeman.foreman
Next steps
  • You can now use the installed Ansible modules to execute playbooks.
4.2. Creating a playbook with modules from Foreman Ansible Collection
Ansible modules from the Foreman Ansible Collection must be able to communicate with the Foreman API over HTTPS. In your playbooks, include parameters specifying how to authenticate to enable the connection to API.
Do not store sensitive credentials, such as username and password, directly in your playbooks or environment variables. The following examples use Ansible vault to manage sensitive data.
  • A user account in Foreman exists with permissions to perform the action defined in your playbook.
  • You have access to one of the following types of authentication credentials for that user:
    • Username and password
    • Username and Personal Access Token
  • A system that you will execute your playbook against. The following examples use localhost.
    This system must be able to reach the Foreman API. You can choose from these options:
    • A system that can reach the Foreman API directly. You can use your Foreman server, your Smart Proxy servers, or any other system in your environment.
    • A system without a direct connection to the Foreman API that uses an HTTP proxy to connect to Foreman.
  1. Store your sensitive variables in an encrypted file:
    1. Create an Ansible vault. For example, to create a vault named My_Vault.yml:
      $ ansible-vault create My_Vault.yml
    2. After the ansible-vault create command opens an editor, provide the required parameters in the key: value format.
      If you want to authenticate with Foreman username and password:
      My_Username: My_Admin_User_Account
      My_Password: My_Admin_Password
      My_Server_URL: https://foreman.example.com
      If you want to authenticate with Foreman username and Personal Access Token (PAT):
      My_Password: My_PAT
    3. If you use an HTTP proxy to reach the Foreman API, store it in the vault too:
      My_HTTP_Proxy: "http://proxy.example.com:8080"
    4. Save your changes and close the editor. Ansible encrypts the data in the vault.
  2. Create a playbook file that references the vault file:
    The following YAML snippets include the module_defaults keyword to pass vault variables as parameters to all modules from the theforeman.foreman.foreman group that are used in the playbook. Module defaults groups simplify parameter management by enabling you to define common parameters to groups of modules rather than having to pass the parameters to each module individually.
    1. Provide details on how to authenticate to the Foreman API.
      If you are authenticating with Foreman username and password or PAT, map the username, password, and server_url parameters to the contents of My_Vault.yml:
      - name: My Playbook
        hosts: localhost
        vars_files:
          - My_Vault.yml
        module_defaults:
          group/theforeman.foreman.foreman:
            username: "{{ My_Username }}"
            password: "{{ My_Password }}"
            server_url: "{{ My_Server_URL }}"
        tasks:
    2. If you need to use an HTTP proxy to reach the Foreman API, set the https_proxy environment variable:
      - name: My Playbook
        hosts: localhost
        vars_files:
          - My_Vault.yml
        environment:
          https_proxy: "{{ My_HTTP_Proxy }}"
        module_defaults:
        tasks:
    3. In the tasks: section, define the tasks that you want your playbook to perform.
  3. Validate the playbook syntax:
    $ ansible-playbook --syntax-check --ask-vault-pass My_Playbook.yml
    Note that this command only validates the syntax. It does not protect against a valid but incorrect configuration.
  4. Run the playbook:
    $ ansible-playbook --ask-vault-pass My_Playbook.yml
Example 1. Example Ansible playbook: Ensure that domain new.example.com exists in Foreman
The theforeman.foreman.domain module can create, update, and delete domains. This example playbook uses theforeman.foreman.domain to ensure that a domain named new.example.com exists and is managed by Foreman. For additional examples, see Example playbooks based on modules from Foreman Ansible Collection.
- name: Domain management
  hosts: localhost
  vars_files:
    - My_Vault.yml
  module_defaults:
  tasks:
    - name: Ensure domain new.example.com exists
      theforeman.foreman.domain:
The settings specified in the example playbook include the following:
vars_files
The name of the vault file that stores the variables My_Username, My_Password, and My_Server_URL.
module_defaults
The module defaults group that maps the variables from the vault file to the username, password, and server_url module parameters.
name
The name of the domain that you want to ensure exists in Foreman.
For more information, see the Ansible module documentation with ansible-doc theforeman.foreman.domain.
4.3. Example playbooks based on modules from Foreman Ansible Collection
All playbooks based on modules from Foreman Ansible Collection must include parameters detailing how to connect to the Foreman API. The following examples use Ansible vault and module defaults group to provide these parameters, and they authenticate using a username and password. For more information, see Creating a playbook with modules from Foreman Ansible Collection.
Example 2. Example Ansible playbook: Enable repositories and create a content view
This example playbook uses the following modules:
  • theforeman.foreman.repository_set
  • theforeman.foreman.content_view
The playbook ensures repositories are enabled and a content view that contains these repositories exists.
Before you run this playbook, ensure that you have uploaded a manifest and can access the Red Hat CDN.
- name: Ensure RHEL 9 repositories are enabled and a content view exists
  hosts: localhost
  vars_files:
    - My_Vault.yml
  module_defaults:
  tasks:
    - name: Ensure RHEL 9 BaseOS repositories are enabled
      theforeman.foreman.repository_set:
        name: "Red Hat Enterprise Linux 9 for x86_64 - BaseOS (RPMs)"
        organization: "Default Organization"
        product: "Red Hat Enterprise Linux for x86_64"
        repositories:
        - releasever: "9"
        state: enabled
    - name: Ensure RHEL 9 AppStream repositories are enabled
        name: "Red Hat Enterprise Linux 9 for x86_64 - AppStream (RPMs)"
        repositories:
        - releasever: "9"
        state: enabled
    - name: Ensure a content view for RHEL 9 repositories exists
      theforeman.foreman.content_view:
        name: "RHEL 9 content view"
        repositories:
          - name: "Red Hat Enterprise Linux 9 for x86_64 - BaseOS RPMs 9"
          - name: "Red Hat Enterprise Linux 9 for x86_64 - AppStream RPMs 9"
For more information, see the Ansible module documentation with the following commands:
  • ansible-doc theforeman.foreman.repository_sync
  • ansible-doc theforeman.foreman.content_view
Example 3. Example Ansible playbook: Synchronize repositories and publish a content view
  • theforeman.foreman.repository_sync
  • theforeman.foreman.content_view_version
The playbook synchronizes repositories and publishes the content view that includes them.
Before you run this playbook, ensure that you have enabled the required repositories and created a content view. For an example playbook that ensures this, see Example Ansible playbook: Enable repositories and create a content view.
- name: Ensure RHEL 9 repositories are synced and content view is published
  hosts: localhost
  vars_files:
    - My_Vault.yml
  module_defaults:
  tasks:
    - name: Sync RHEL repositories
      theforeman.foreman.repository_sync:
    - name: Publish RHEL 9 content view
      theforeman.foreman.content_view_version:
        content_view: "RHEL 9 content view"
  • ansible-doc theforeman.foreman.content_view_version
  • Use the ansible-doc --list theforeman.foreman command to display the Foreman Ansible modules installed on your system.
  • See Ansible Galaxy for a complete list of Foreman Ansible modules and other related information.
5. Preparing for disaster recovery and recovering from data loss
How do I back up?
How do I back up?
Store the following critical data on network attached storage: content in /var/lib/pulp and database in /var/lib/pgsql. Replicate this storage into a different data center. Attach the storage to a Foreman server that is a clone of the primary Foreman server but runs passively.
How do I back up?
Dual active Foreman server
How do I back up?
To minimize downtime, you can automate the recovery in various ways. For example, you can use the Foreman Ansible collection. For more information, see Automating Foreman management with Foreman Ansible Collection in Administering Foreman.
5.2. Disaster recovery by virtualizing your Foreman server
5.2.1. Prerequisites
5.2.2. Preparing for disaster recovery by virtualizing your Foreman server
  3. To verify that you will be able to restore Foreman services in case of a disaster, assess the functionality of the test Foreman server. See Retrieving the status of services.
5.2.3. Recovering from disaster by restoring a VM snapshot of Foreman server
5.2.4. Retrieving the status of services
Foreman uses a set of back-end services. When troubleshooting, you can check the status of Foreman services.
  • In the Foreman web UI, navigate to Administer > About.
    • On the Smart Proxies tab, view the status of all Smart Proxies.
    • On the Compute Resources tab, view the status of attached compute resource providers.
    • In the Backend System Status table, view the status of all back-end services.
CLI procedure
    $ hammer ping
  • Perform a health check:
5.3. Disaster recovery for active and passive Foreman server with external storage
5.3.1. Prerequisites
  • Review Overview of recommended disaster recovery plans to ensure that this disaster recovery plan works for you.
  • Review Storage requirements and Storage guidelines in Installing Foreman Server with Katello 4.16 plugin on Enterprise Linux. Ensure that your shared storage meets the requirements of holding the contents of /var/lib/pulp and /var/lib/pgsql.
  • You have configured your Foreman server to use external databases. For more information, see Using external databases in Installing Foreman Server with Katello 4.16 plugin on Enterprise Linux.
5.3.2. Preparing for disaster recovery with active and passive Foreman server with external storage
  2. Back up your active Foreman server and restore it on a system that will serve as your passive Foreman server. For more information, see Backing up Foreman server and Smart Proxy server and Restoring Foreman server or Smart Proxy server from a backup.
  4. Assess the functionality of the test Foreman server. For more information, see Retrieving the status of services.
5.3.3. Recovering from disaster with active and passive server with external storage
  5. Assess the functionality of your new active Foreman server. For more information, see Retrieving the status of services.
5.3.4. Retrieving the status of services
CLI procedure
    $ hammer ping
5.4. Disaster recovery for active and passive Foreman server with backup and restore
5.4.1. Prerequisites
5.4.2. Preparing for disaster recovery with active and passive Foreman server and backup and restore
  1. Define a schedule for periodic offline backups of your active Foreman server. Consider your tolerance for potential data loss and your storage options: Taking backups frequently will result in smaller amounts of data loss in case of a disaster, but backups require a significant amount of storage space. For information about the size of Foreman backups, see Estimating the size of a backup.
    You can combine full backups with incremental backups. For an example of a cron job that ensures regular backups, see Example of a weekly full backup followed by daily incremental backups.
  2. Schedule periodic offline backups of your active Foreman server to be taken according to the schedule you defined. For information about performing backups, see Backing up Foreman server and Smart Proxy server.
  3. Ensure that the backup directories are encrypted and regularly synchronized to a secure location. By default, Foreman stores the backups in the /var/foreman-backup directory.
    Foreman server backups contain sensitive information from the /root/ssl-build directory. For example, they can contain hostnames, ssh keys, request files, and SSL certificates. Encrypting or moving the backups to a secure location helps minimize the risk of damage or unauthorized access to the hosts.
  4. Restore the most recent backup on a system that will serve as your passive Foreman server. For information about restoring backups, see Restoring Foreman server or Smart Proxy server from a backup.
    3. Assess the functionality of the test Foreman server. For more information, see Retrieving the status of services.
5.4.3. Recovering from disaster with active and passive server and backup and restore
  3. Assess the functionality of your new active Foreman server. For more information, see Retrieving the status of services.
5.4.4. Retrieving the status of services
CLI procedure
    $ hammer ping
5.4.5. Example of a weekly full backup followed by daily incremental backups
#!/bin/bash -e
else
fi
exit 0
5.5. Disaster recovery with two active Foreman servers
5.5.1. Prerequisites
5.5.2. Preparing for disaster recovery with two active Foreman servers
  1. Back up your Foreman server. For more information, see Backing up Foreman server and Smart Proxy server.
  2. Restore the backup on a system that will serve as your other Foreman server. For more information, see Restoring Foreman server or Smart Proxy server from a backup.
  5. Automate running the foreman-maintain health check command on both servers. The health check verifies whether the servers remain fully operational.
  2. Verify that your foreman-maintain health check automation reported an error.
5.5.3. Recovering from disaster with two active Foreman servers
If the health checks implemented in Preparing for disaster recovery with two active Foreman servers report an issue on one of your Foreman servers, it might mean that the server has failed. If the server is down, you must re-register hosts to the other server.
  2. If foreman-maintain health check reported a problem, ensure that the server is powered off.
6. Managing users and roles
A User defines a set of details for individuals who use the system. Users can be associated with organizations and environments, so that when they create new entities, the default settings are automatically used. Users can also have one or more roles attached, which grants them rights to view and manage organizations and environments. See Managing users for more information on working with users.
You can manage permissions of several users at once by organizing them into user groups. User groups themselves can be further grouped to create a hierarchy of permissions. For more information on creating user groups, see Creating and managing user groups.
Roles define a set of permissions and access levels. Each role contains one on more permission filters that specify the actions allowed for the role. Actions are grouped according to the Resource type. Once a role has been created, users and user groups can be associated with that role. This way, you can assign the same set of permissions to large groups of users. Foreman provides a set of predefined roles and also enables creating custom roles and permission filters as described in Creating and managing roles.
6.1. Managing users
6.1.1. Creating a user
  2. Click Create User.
  3. Enter the account details for the new user.
  4. Click Submit to create the user.
  • On the User tab, select an authentication source from the Authorized by list:
  • On the Organizations tab, select an organization for the user. Specify the default organization Foreman selects for the user after login from the Default on login list.
    If a user is not assigned to an organization, their access is limited.
CLI procedure
  • Create a user:
    $ hammer user create \
    --login My_User_Name \
    --mail My_User_Mail \
    --password My_User_Password
    The --auth-source-id 1 setting means that the user is authenticated internally, you can specify an external authentication source as an alternative. Add the --admin option to grant administrator privileges to the user. Specifying organization IDs is not required.
    You can modify the user details later by using the hammer user update command.
  • For more information about creating user accounts by using Hammer, enter hammer user create --help.
API request
$ curl \
--header "Accept:application/json" \
--header "Content-Type:application/json" \
--request POST \
--user My_User_Name:My_Password \
https://foreman.example.com/api/users \
| python3 -m json.tool
6.1.2. Assigning roles to a user
  7. Click Submit.
CLI procedure
    $ hammer user add-role --id user_id --role role_name
6.1.3. Impersonating a different user account
6.1.4. Creating an API-only user
    # openssl rand -hex 32
6.2. Managing SSH keys
For information on SSH keys and SSH key creation, see Using secure communications between two systems with OpenSSH in Red Hat Enterprise Linux 9 Configuring basic system settings.
6.2.1. Managing SSH keys for a user
  3. Click on the SSH Keys tab.
    • To Add SSH key
      2. Click Add SSH Key.
      5. Click Submit.
    • To Remove SSH key
CLI procedure
    $ hammer user ssh-keys add \
    --user-id user_id \
    --name key_name \
    --key-file ~/.ssh/id_rsa.pub
    --user-id user_id \
    --name key_name \
6.3. Managing Personal Access Tokens
6.3.1. Creating a Personal Access Token
    $ curl \
    {"foreman_version":"3.14.0","result":"ok","status":200,"version":"3.5.1.10","api_version":2}
6.3.2. Revoking a Personal Access Token
    $ curl \
6.4. Creating and managing user groups
6.4.1. User groups
With Foreman, you can assign permissions to groups of users. You can also create user groups as collections of other user groups. If you use an external authentication source, you can map Foreman user groups to external user groups as described in Configuring external user groups in Configuring authentication for Foreman users.
6.4.2. Creating a user group
  2. Click Create User group.
  5. Click Submit.
CLI procedure
    $ hammer user-group create \
    --name My_User_Group_Name \
6.4.3. Removing a user group
6.5. Creating and managing roles
Foreman provides a set of predefined roles with permissions sufficient for standard tasks. For a list of these roles, see Predefined roles available in Foreman. You can also configure custom roles.
6.5.1. Creating a role
  2. Click Create Role.
CLI procedure
To serve its purpose, a role must contain permissions. After creating a role, proceed to Adding permissions to a role.
6.5.2. Cloning a role
6.5.3. Adding permissions to a role
  5. Depending on the Resource type selected, you can select or deselect the Unlimited and Override checkbox. The Unlimited checkbox is selected by default, which means that the permission is applied on all resources of the selected type. When you disable the Unlimited checkbox, the Search field activates. In this field you can specify further filtering with use of the Foreman search syntax. For more information, see Granular permission filtering. When you enable the Override checkbox, you can add additional locations and organizations to allow the role to access the resource type in the additional locations and organizations; you can also remove an already associated location and organization from the resource type to restrict access.
  6. Click Next.
CLI procedure
  2. Add permissions to a role:
    $ hammer filter create \
    --role My_Role_Name
6.5.4. Viewing permissions of a role
6.5.5. Creating a complete permission table
    # dnf install foreman-console
  1. Start the Foreman console with the following command:
    # foreman-rake console
    end.join("\n")
    f.write(result)
    </table>
6.5.6. Removing a role
6.6. Predefined roles available in Foreman
Predefined role Permissions the role provides Additional information
Auditor
View the Audit log.
Default role
View tasks and jobs invocations.
Foreman automatically assigns this role to every user in the system.
Manager
Organization admin
Site manager
View permissions for various items.
Permissions to manage hosts in the infrastructure.
System admin
Edit global settings in Administer > Settings.
View, create, edit, and destroy users, user groups, and roles.
View, create, edit, destroy, and assign organizations and locations but not view resources within them.
Users with this role can create users and assign all roles to them. Give this role only to trusted users.
Viewer
View the configuration of every element of the Foreman structure, logs, reports, and statistics.
6.7. Granular permission filtering
As mentioned in Adding permissions to a role, Foreman provides the ability to limit the configured user permissions to selected instances of a resource type. These granular filters are queries to the Foreman database and are supported by the majority of resource types.
6.7.1. Creating a granular permission filter
field_name operator value
  • operator specifies the type of comparison between field_name and value. See Supported operators for granular search for an overview of applicable operators.
CLI procedure
    --permission-ids 91 \
    --search "name ~ ccv*" \
    --role qa-user
This command adds to the qa-user role a permission to view, create, edit, and destroy content views that only applies to content views with name starting with ccv.
6.7.2. Examples of using granular permission filters
Applying permissions for the host resource type
hostgroup = host-editors
name ^ (XXXX, Yyyy, zzzz)
Dev
You can limit user permissions to a certain organization or location with the use of the granular permission filter in the Search field. However, some resource types provide a GUI alternative, an Override checkbox that provides the Locations and Organizations tabs. On these tabs, you can select from the list of available organizations and locations. For more information, see Creating an organization-specific manager role.
6.7.3. Supported operators for granular search
Table 1. Logical operators
Operator
and
Combines search criteria.
not
Negates an expression.
has
Table 2. Symbolic operators
Operator
7. Configuring email notifications
For an overview of available notification types, see Email notification types.
Foreman server does not enable outgoing emails by default, therefore you must review your email configuration. For more information, see Configuring Foreman server for Outgoing Emails in Installing Foreman Server with Katello 4.16 plugin on Enterprise Linux.
7.1. Email notification types
Audit summary
A summary of all activity audited by Foreman server.
Compliance policy summary
Content view promote failure
Content view publish failure
Host built
Host errata advisory
Promote errata
Repository sync failure
Smart Proxy sync failure
A notification sent after Smart Proxy synchronization fails.
Sync errata
7.2. Configuring email notification preferences
  6. Click Submit.
7.3. Testing email delivery
  2. Click on the username.
    # systemctl start postfix
7.4. Testing email notifications
  • daily
  • weekly
  • monthly
7.5. Changing email notification settings for a host
  2. Go to the Additional Information tab. If the Enabled checkbox is checked, then email notifications are enabled on that host.
8. Backing up Foreman server and Smart Proxy server
Foreman services are unavailable during the backup. Therefore, you must ensure that no other tasks are scheduled by other administrators. You can schedule a backup by using cron. For more information, see the Example of a weekly full backup followed by daily incremental backups.
During offline backups, the services are inactive and Foreman is in a maintenance mode. All the traffic from outside on port 443 is rejected by a firewall to ensure there are no modifications triggered.
Conventional backup methods
You can also use conventional backup methods. For more information, see Recovering and restoring a system in Red Hat Enterprise Linux 9 Configuring basic system settings.
8.1. Estimating the size of a backup
    100G    /var/lib/pgsql/data
    100G	/var/lib/pulp
    # du -csh /var/lib/tftpboot /etc /root/ssl-build \
    16M   /var/lib/tftpboot
    37M   /etc
    900K  /root/ssl-build
    100K  /var/www/html/pub
    2M    /opt/puppetlabs
    942M  total
    Table 3. Backup data compression ratio
    PostgreSQL database files
    /var/lib/pgsql/data
    80 – 85%
    100 GB → 20 GB
    Pulp RPM files
    /var/lib/pulp
    (not compressed)
    100 GB
    Configuration files
    /var/lib/tftpboot
    /etc
    /root/ssl-build
    /var/www/html/pub
    /opt/puppetlabs
    85%
    942 MB → 141 MB
8.2. Performing a full backup of Foreman server or Smart Proxy server
There are two main methods of backing up Foreman server:
  • Offline backup
    All Foreman services are shut down during an offline backup.
  • Online backup
Offline backups
Online backups
Directory creation
  • foreman-backup on Foreman
Remote databases
You can use both online and offline methods to back up remote databases, but if you use offline method, the foreman-maintain backup command performs a database dump.
Backing up to a remote NFS share
To enable Foreman to save the backup to an NFS share, ensure that the root user of your Foreman server or Smart Proxy server can write to the NFS share. NFS export options such as root_squash and all_squash are known to prevent this.
Warning
8.3. Performing a backup without Pulp content
Warning
8.4. Performing an incremental backup
Warning
8.5. Example of a weekly full backup followed by daily incremental backups
#!/bin/bash -e
else
fi
exit 0
8.6. Performing an online backup
Risks associated with online backups
When you perform an online backup, most Foreman services remain running and usable. Background workers are shut down to ensure consistent backups. Operations that require background workers remain in pending state. The backup process ensures that the Pulp data (/var/lib/pulp) is not altered during the backup. Any changes to the Pulp data during the backup will result in restart of the backup process, taking additional time.
Warning
Request other users of Foreman server or Smart Proxy server to save any changes and warn them that some Foreman services may be unavailable for the duration of the backup. Ensure no other tasks are scheduled for the same time as the backup.
9. Restoring Foreman server or Smart Proxy server from a backup
You can restore Foreman server or Smart Proxy server from the backup data that you create as part of Backing up Foreman server and Smart Proxy server. This process outlines how to restore the backup on the same server that generated the backup, and all data covered by the backup is deleted on the target system. If the original system is unavailable, provision a system with the same configuration settings and host name.
You cannot restore backups of a system without FIPS enabled on a FIPS enabled system.
9.1. Restoring from a full backup
    # df -h /var/backup_directory
    # restorecon -Rv /
  2. Copy the backup data to the local file system on Foreman server. Use /var/ or /var/tmp/.
9.2. Restoring from incremental backups
  1. Restore the last full backup using the instructions in Restoring from a full backup.
  2. Remove the full backup data from the local file system on Foreman server, for example, /var/ or /var/tmp/.
  3. Copy the incremental backup data to the local file system on Foreman server, for example, /var/ or /var/tmp/.
9.3. Backup and restore Smart Proxy server by using a virtual machine snapshot
If required, deploy a new Smart Proxy server, ensuring the host name is the same as before, and then install the Smart Proxy certificates. You may still have them on Foreman server, the package name ends in -certs.tar, alternately create new ones. Follow the procedures in Installing Smart Proxy server until you can confirm, in the Foreman web UI, that Smart Proxy server is connected to Foreman server. Then use the procedure Synchronizing content from Foreman server to Smart Proxy servers to synchronize from Foreman.
9.3.1. Synchronizing content from Foreman server to Smart Proxy servers
Use this procedure to synchronize content from your Foreman server to your Smart Proxy server.
  • Ensure that you either select the relevant organization and location context of your Smart Proxy server or choose Any Organization and Any Location.
  2. Select your Smart Proxy server.
  3. On the Overview tab, click Synchronize.
    • Select Optimized Sync to synchronize content from your Foreman server to your Smart Proxy server that bypasses unnecessary steps to speed up performance.
    • Select Complete Sync to perform a complete sync from your Foreman server to your Smart Proxy server that synchronizes content even if the metadata has not changed.
10. Renaming Foreman server or Smart Proxy server
To rename Foreman server or Smart Proxy server, use the katello-change-hostname script.
If you change the domain name of your Foreman server or Smart Proxy server, you must update the hostname by using the katello-change-hostname script to avoid networking issues.
10.1. Renaming Foreman server
The host name of Foreman server is used by Foreman server components, all Smart Proxy servers, and hosts registered to it for communication. This procedure ensures that in addition to renaming Foreman server, you also update all references to point to the new host name.
Warning
Renaming your Foreman server host shuts down all Foreman services on that host. The services restart after the renaming is complete.
  • Back up your Foreman server before changing its host name. If you fail to successfully rename it, restore it from the backup. For more information, see Backing up Foreman server and Smart Proxy server.
  • Run the hostname and hostname -f commands on Foreman server. If both commands do not return the FQDN of Foreman server, the katello-change-hostname script will fail to complete.
    If the hostname command returns the shortname of Foreman server instead of the FQDN, use hostnamectl set-hostname My_Old_FQDN to set the old FQDN correctly before using the katello-change-hostname script.
  • If Foreman server has a custom SSL certificate installed, obtain a new certificate for the new FQDN of the host. For more information, see Configuring Foreman server with a Custom SSL Certificate in Installing Foreman Server with Katello 4.16 plugin on Enterprise Linux.
  1. On Foreman server, run the katello-change-hostname script, and provide the new host name. Choose one of the following methods:
    • If your Foreman server is installed with the default self-signed SSL certificates:
      --username My_Username \
      --password 'My_Password'
      --password 'My_Password' \
  2. If you have created a custom SSL certificate for the new Foreman server host name, run the Foreman installation script to install the certificate. For more information about installing a custom SSL certificate, see Deploying a Custom SSL Certificate to Foreman server in Installing Foreman Server with Katello 4.16 plugin on Enterprise Linux.
  3. Reregister all hosts and Smart Proxy servers that are registered to Foreman server. For more information, see Registering hosts by using global registration in Managing hosts.
    # foreman-installer \
    --foreman-proxy-trusted-hosts new-foreman.example.com
    # hammer proxy list
    # hammer proxy content synchronize \
    --id My_Smart_Proxy_ID
  7. If you use the virt-who agent, update the virt-who configuration files with the new host name.
  8. If you use external authentication, reconfigure Foreman server for external authentication after you run the katello-change-hostname script. For more information, see Configuring authentication for Foreman users.
10.2. Renaming Smart Proxy server
The host name of Smart Proxy server is referenced by Foreman server components and all hosts registered to it. This procedure ensures that in addition to renaming Smart Proxy server, you also update all references to the new host name.
Warning
Renaming your Smart Proxy server host shuts down all Foreman services on that host. The services restart after the renaming is complete.
  • Back up your Smart Proxy server before renaming. If you fail to successfully rename it, restore it from the backup. For more information, see Backing up Foreman server and Smart Proxy server.
  • Run the hostname and hostname -f commands on Smart Proxy server. If both commands do not return the FQDN of Smart Proxy server, the katello-change-hostname script will fail to complete.
    If the hostname command returns the shortname of Smart Proxy server instead of the FQDN, use hostnamectl set-hostname My_Old_FQDN to set the old FQDN correctly before attempting to use the katello-change-hostname script.
  1. On your Foreman server, generate a new certificates archive file for your Smart Proxy server.
    • If you are using the default SSL certificate, regenerate the default SSL certificates:
      --certs-tar /root/new-smartproxy.example.com-certs.tar \
      --foreman-proxy-fqdn new-smartproxy.example.com
    • If you are using a custom SSL certificate, create a new SSL certificate for your Smart Proxy server. For more information, see Configuring Smart Proxy server with a Custom SSL Certificate in Installing a Smart Proxy Server 3.14 on Enterprise Linux.
  2. On your Foreman server, copy the certificates archive file to your Smart Proxy server. For example, to copy the archive file to the root user’s home directory:
  3. On your Smart Proxy server, run the katello-change-hostname script and provide the host’s new name, Foreman credentials, and certificates archive file name.
    # katello-change-hostname new-smartproxy.example.com \
  4. If you have created a custom certificate for your Smart Proxy server, deploy the certificate to your Smart Proxy server by entering the foreman-installer command that the foreman-proxy-certs-generate command returned in a previous step. For more information, see Deploying a Custom SSL Certificate to Smart Proxy server in Installing a Smart Proxy Server 3.14 on Enterprise Linux.
  5. Reregister all hosts that are registered to your Smart Proxy server. For more information, see Registering hosts and setting up host integration in Managing hosts.
  6. Update the Smart Proxy host name in the Foreman web UI.
    2. Locate Smart Proxy server in the list, and click Edit.
    3. Edit the Name and URL fields to match Smart Proxy server’s new host name, then click Submit.
    4. On your DNS server, add a record for the new hostname of your Smart Proxy server, and delete the record of the previous host name.
11. Maintaining Foreman server
This chapter provides information on how to maintain Foreman server, including information on how to recover Pulp from a full disk, how to work with audit records, and how to clean unused tasks.
11.1. Deleting audit records manually
11.2. Deleting audit records automatically
11.3. Anonymizing audit records
11.4. Deleting report records
11.5. Configuring the cleaning unused tasks feature
11.6. Deleting task records
11.7. Deleting a task by ID
  2. Optional: View the task:
  3. Delete the task:
11.8. Recovering from a full disk
    1. Remove orphaned content:
    3. Grow the file system on the LV with the /var/lib/pulp directory on it. For more information, see Growing a logical volume and file system in Red Hat Enterprise Linux 9 Configuring and managing logical volumes.
      1. Stop Foreman services:
      3. Start Foreman services:
11.9. Reclaiming PostgreSQL space
11.10. Reclaiming space from on demand repositories
Space reclamation requires an existing repository. For deleted repositories, wait for the next scheduled orphan cleanup or remove orphaned content manually:
For a single repository
  • In the Foreman web UI, navigate to Content > Products.
  • Select a product.
  • On the Repositories tab, click the repository name.
  • From the Select Actions list, select Reclaim Space.
For multiple repositories
  • Select the product name.
  • On the Repositories tab, select the checkbox of the repositories.
  • Click Reclaim Space at the top right corner.
For Smart Proxies
  • In the Foreman web UI, navigate to Infrastructure > Smart Proxies.
  • Select the Smart Proxy server.
  • Click Reclaim space.
12. Renewing certificates
You can renew the CA certificate on Foreman server or the SSL certificate on Foreman server as well as on Smart Proxy server.
12.1. Planning for self-signed CA certificate renewal
If you need to update the Certification Authority (CA) certificate on your Foreman server, add the new CA certificate and use a temporary dual CA certificate file to retain the HTTPS connections to your Foreman server during the renewal.
  1. Add the new SSL certificate to the CA certificate file on Foreman server and keep the old SSL certificate.
  2. Renew the certificates on Foreman server and any Smart Proxy servers.
  3. Deploy the dual CA certificate on hosts.
  4. Remove the old certificate from the CA certificates file on Foreman server, so the CA certificate file contains only the new SSL certificate.
  5. Renew the certificates on Foreman server and any Smart Proxy servers.
  6. Deploy the new CA certificate on hosts.
12.2. Renewing a SSL certificate on Foreman server
Use this procedure to update your SSL certificate for Foreman server.
  • You must create a new Certificate Signing Request (CSR) and send it to the Certificate Authority to sign the certificate. Refer to the Configuring Foreman server with a custom SSL certificate guide before creating a new CSR because the Server certificate must have X.509 v3 Key Usage and Extended Key Usage extensions with required values. In return, you will receive the Foreman server certificate and CA bundle.
  • Before deploying a renewed custom certificate on your Foreman server, validate the SSL input files. Note that for the katello-certs-check command to work correctly, Common Name (CN) in the certificate must match the FQDN of Foreman server:
    # katello-certs-check -t foreman \
    -b /root/foreman_cert/ca_cert_bundle.pem \
    -c /root/foreman_cert/foreman_cert.pem \
    -k /root/foreman_cert/foreman_cert_key.pem
    If the command is successful, it returns the following foreman-installer command. You can use this command to deploy the renewed CA certificates to Foreman server:
    # foreman-installer --scenario katello \
    --certs-server-cert "/root/foreman_cert/foreman_cert.pem" \
    --certs-server-key "/root/foreman_cert/foreman_cert_key.pem" \
    --certs-server-ca-cert "/root/foreman_cert/ca_cert_bundle.pem" \
    --certs-update-server \
    --certs-update-server-ca
Do not delete the certificate files after you deploy the certificate. They are required when upgrading Foreman server.
  1. Access the Foreman web UI from your local machine. For example, https://foreman.example.com.
  2. In your browser, view the certificate details to verify the deployed certificate.
Next steps
12.3. Renewing a SSL certificate on Smart Proxy server
Use this procedure to update your SSL certificate for Smart Proxy server. The foreman-installer command, which the foreman-proxy-certs-generate command returns, is unique to each Smart Proxy server. You cannot use the same command on more than one Smart Proxy server.
  • You must create a new Certificate Signing Request and send it to the Certificate Authority to sign the certificate. Refer to the Configuring Foreman server with a custom SSL certificate guide before creating a new CSR because the Foreman server certificate must have X.509 v3 Key Usage and Extended Key Usage extensions with required values. In return, you will receive the Smart Proxy server certificate and CA bundle.
  1. On your Foreman server, validate the SSL certificate input files:
    # katello-certs-check -t smart-proxy \
    -b /root/smart-proxy_cert/ca_cert_bundle.pem \
    -c /root/smart-proxy_cert/smart-proxy_cert.pem \
    -k /root/smart-proxy_cert/smart-proxy_cert_key.pem
  2. On your Foreman server, generate the certificate archive file for your Smart Proxy server:
    --certs-tar "/root/My_Certificates/smartproxy.example.com-certs.tar" \
    --foreman-proxy-fqdn "smartproxy.example.com" \
    --server-ca-cert "/root/My_Certificates/ca_cert_bundle.pem" \
    --server-cert "/root/My_Certificates/smart-proxy_cert.pem" \
    --server-key "/root/My_Certificates/smart-proxy_cert_key.pem"
  3. On your Foreman server, copy the certificate archive file to your Smart Proxy server:
  4. Retain a copy of the foreman-installer command that the foreman-proxy-certs-generate command returns for deploying the certificate to your Smart Proxy server.
  5. Deploy the certificate on your Smart Proxy server using the foreman-installer command returned by the foreman-proxy-certs-generate command:
    # foreman-installer --scenario foreman-proxy-content \
    --certs-tar-file "/root/My_Certificates/smartproxy.example.com-certs.tar" \
    --foreman-proxy-foreman-base-url "https://foreman.example.com" \
    --foreman-proxy-register-in-foreman "true"
Do not delete the certificate archive file on the Smart Proxy server after you deploy the certificate. They are required when upgrading Smart Proxy server.
Next steps
13. Synchronizing template repositories
In Foreman, you can synchronize repositories of job templates, provisioning templates, report templates, and partition table templates between Foreman server and a version control system or local directory.
This section details the workflow for installing and configuring the Template Sync plugin and performing exporting and importing tasks.
13.1. Enabling the Template Sync plugin
  1. Enable the plugin on your Foreman server:
  2. Optional: Enable the Hammer CLI plugin on your Foreman server:
  2. On the Plugins tab, ensure that the page includes the Template Sync plugin.
Next steps
  1. In the Foreman web UI, navigate to Administer > Settings > Template Sync to configure the plugin. For more information, see Template sync settings.
13.2. Synchronizing templates with an existing repository
If you store templates in a repository under a version control system, you can synchronize the templates between your Foreman server and the repository.
  1. If you want to use HTTPS to connect to the repository and you use a self-signed certificate authority (CA) on your Git server:
    1. Create a new directory under the /usr/share/foreman/ directory to store the Git configuration for the certificate:
      # mkdir --parents /usr/share/foreman/.config/git
    2. Create a file named config in the new directory:
      # touch /usr/share/foreman/.config/git/config
    3. Allow the foreman user access to the .config directory:
      # chown --recursive foreman /usr/share/foreman/.config
    4. Update the Git global configuration for the foreman user with the path to your self-signed CA certificate:
      # sudo --user foreman git config --global http.sslCAPath Path_To_CA_Certificate
  2. If you want to use SSH to connect to the repository:
    1. Create an SSH key pair if you do not already have it. Do not specify a passphrase.
    2. Configure your version control server with the public key from your Foreman, which resides in /usr/share/foreman/.ssh/id_rsa.pub.
    3. Accept the Git SSH host key as the foreman user:
      # sudo --user foreman ssh git.example.com
  3. In the Foreman web UI, provide details for your Git repository:
    1. Navigate to Administer > Settings.
    2. Click the Template Sync tab.
    3. Change the Branch setting to define the target branch of the repository.
    4. Change the Repo setting to define the repository URL.
    5. If you want to use an HTTP proxy to connect to the repository, change the HTTP proxy policy setting to Global default HTTP proxy or Custom HTTP proxy.
Next steps
13.3. Synchronizing templates with a local directory
If you store templates in a local directory that is tracked under a version control system, you can synchronize the templates between your Foreman server and the local directory.
  • Each template must contain the location and organization that the template belongs to. This applies to all template types. Before you import a template, ensure that you add the following section to the template:
    kind: provision
    oses:
    - My_first_Operating_System
    - My_second_Operating_System
    locations:
    - My_first_Location
    - My_second_Location
    organizations:
    - My_first_Organization
    - My_second_Organization
  1. On your Foreman server, in /var/lib/foreman, create a directory for storing templates:
    # mkdir /var/lib/foreman/My_Templates_Dir
    You can place your templates to a custom directory outside /var/lib/foreman, but you have to ensure that the Foreman service can read its contents. The directory must have the correct file permissions and the foreman_lib_t SELinux label.
  2. Change the owner of the new templates directory to the foreman user:
    # chown foreman /var/lib/foreman/My_Templates_Dir
  3. Change the Repo setting on the Template Sync tab to match the /var/lib/foreman/My_Templates_Dir/ directory.
13.4. Importing templates
You can import templates from a repository of your choice. You can use different protocols to point to your repository, for example /tmp/dir, git://example.com, https://example.com, and ssh://example.com.
The templates provided by Foreman are locked and you cannot import them by default. To overwrite this behavior, change the Force import setting in the Template Sync menu to yes or add the force parameter -d '{ "force": "true" }' to the import command.
    kind: provision
    oses:
    locations:
    - My_first_Location
    organizations:
To use the API, see the API procedure.
To use Ansible, see the Ansible procedure.
  1. In the Foreman web UI, navigate to Hosts > Templates > Sync Templates.
  2. Click Import.
  3. Each field is populated with values configured in Administer > Settings > Template Sync. Change the values as required for the templates you want to import. For more information about each field, see Template sync settings.
  4. Click Submit.
CLI procedure
  • To import a template from a repository, enter the following command:
    $ hammer import-templates \
    --branch "My_Branch" \
    --filter '.*Template Name$' \
    --prefix "[Custom Index] " \
    --repo "https://git.example.com/path/to/repository"
    For better indexing and management of your templates, use --prefix to set a category for your templates. To select certain templates from a large repository, use --filter to define the title of the templates that you want to import. For example --filter '.*Ansible Default$' imports various Ansible Default templates.
API procedure
  1. Send a POST request to api/v2/templates/import:
    # curl -H "Accept:application/json" \
    -H "Content-Type:application/json" \
    -u login:password \
    -k https://foreman.example.com/api/v2/templates/import \
    -X POST
    If the import is successful, you receive {"message":"Success"}.
Ansible procedure
  • Use the theforeman.foreman.templates_import module.
For more information, see the Ansible module documentation with ansible-doc theforeman.foreman.templates_import.
13.5. Exporting templates
You can export templates to an existing repository.
  2. Click Export.
  3. Each field is populated with values configured in Administer > Settings > Template Sync. Change the values as required for the templates you want to export. For more information about each field, see Template sync settings.
  4. Click Submit.
CLI procedure
  1. To export the templates to a repository, enter the following command:
    $ hammer export-templates \
    This command clones the repository, makes changes in a commit, and pushes back to the repository. You can use the --branch "My_Branch" option to export the templates to a specific branch.
API procedure
  1. Send a POST request to api/v2/templates/export:
    -u login:password \
    -k https://foreman.example.com/api/v2/templates/export \
    -X POST
    If the export is successful, you receive {"message":"Success"}.
You can override default API settings by specifying them in the request with the -d parameter. The following example exports templates to the git.example.com/templates repository:
-u login:password \
-X POST \
-d "{\"repo\":\"git.example.com/templates\"}"
13.6. Uninstalling the Foreman templates plugin
Use the following procedure to avoid errors after removing the foreman_templates plugin.
  1. Disable the plugin using the Foreman installer:
  2. Clean custom data of the plugin. The command does not affect any templates that you created.
  3. Uninstall the plugin:
14. Logging and reporting problems
The following sections describe the most commonly used log files and debugging tools available in Foreman.
14.1. Logging levels of Foreman components
You can set logging levels for individual Foreman components. The default logging level is info. You can increase the logging level of Foreman components to troubleshoot Foreman. Increasing the logging level to debug provides the most detailed information.
14.1.1. Increasing the logging level for Foreman
By default, you can find the log in /var/log/foreman/production.log. For more information, see Configuring logging type and layout.
14.1.2. Increasing the logging level for Hammer
    :log_level: 'debug'
14.1.3. Increasing the logging level for Smart Proxy
By default, you can find the log in /var/log/foreman-proxy/proxy.log. For more information, see Configuring logging type and layout.
    # foreman-installer --foreman-proxy-log-level DEBUG
14.1.4. Increasing the logging level for Candlepin
You can find the logs in /var/log/candlepin/candlepin.log and /var/log/candlepin/error.log.
  1. Set the logging level to DEBUG:
    # foreman-installer --katello-candlepin-loggers log4j.logger.org.candlepin:DEBUG
    --katello-candlepin-loggers log4j.logger.org.candlepin:DEBUG \
    --katello-candlepin-loggers log4j.logger.org.candlepin.resource.ConsumerResource:WARN \
    --katello-candlepin-loggers log4j.logger.org.candlepin.resource.HypervisorResource:WARN
14.1.5. Increasing the logging level for Redis
  1. In /etc/redis/redis.conf, set the logging level to debug:
    loglevel debug
  2. Restart the Redis service:
    # systemctl restart redis
14.1.6. Increasing the logging level for foreman-installer
foreman-installer writes logs to /var/log/foreman-installer/.
  • Increase the logging level of the foreman-installer utility:
14.1.7. Increasing the logging level for Pulp
Pulp logs to the systemd journal. You can view the logs using journalctl --unit 'pulpcore*'.
  1. In /etc/pulp/settings.py, set the logging level to DEBUG:
  2. Restart the Pulp services:
    # systemctl restart \
    pulpcore-api \
    pulpcore-content \
    pulpcore-resource-manager \
    pulpcore-worker@\*
14.1.8. Increasing the logging level for OpenVox agent
  • Set the logging level to debug:
    # foreman-installer --puppet-agent-additional-settings log_level:debug
14.1.9. Increasing the logging level for OpenVox server
    # foreman-installer --puppet-server-additional-settings log_level:debug
14.1.10. Increasing the logging level for Salt
Salt Master logs to /var/log/salt/master. Salt Minions log to /var/log/salt/minion.
You can increase the logging level for Salt Master or Salt Minion:
  • In /etc/salt/master or /etc/salt/minion, set the logging level to debug:
    log_level: debug
14.2. Configuring logging levels with Hammer CLI
You can use Hammer to log debugging information for various Foreman components. The default logging level is INFO.
  • To list the components whose logging level you can change by using hammer:
    $ hammer admin logging --list
  • To set DEBUG level logging for all components:
    $ hammer admin logging --all --level-debug
  • To set PRODUCTION level logging for all components:
    $ hammer admin logging --all --level-production
  • To set DEBUG level logging for a specific component:
    $ hammer admin logging --components My_Component --level-debug
  • To list all available logging options:
    $ hammer admin logging --help
14.3. Configuring logging type and layout
By default, Foreman uses file-based logging. You can use foreman-installer to change the logging type and logging layout.
Procedure for configuring logging with journal
    --foreman-proxy-log JOURNAL
    • /var/log/foreman-proxy.log
Procedure for configuring logging to JSON output
  1. On your Foreman server, enable logging to JSON output for foreman-installer:
    --foreman-logging-layout json \
    --foreman-logging-type file
  2. Optional: Inspect the log messages using jq:
    # cat /var/log/foreman/production.log | jq
14.4. Selective debugging with individual loggers
    --foreman-loggers ldap:true \
    --foreman-loggers sql:true
14.5. Overview of individual loggers
The following list provides an overview of selected loggers. You can find the complete list of loggers with their default values in /usr/share/foreman/config/application.rb under Foreman::Logging.add_loggers.
app
Default value: true.
audit
background
blob
dynflow
ldap
Default value: false.
notifications
permissions
sql
telemetry
templates
14.6. Retrieving the status of services
Foreman uses a set of back-end services. When troubleshooting, you can check the status of Foreman services.
  • In the Foreman web UI, navigate to Administer > About.
    • On the Smart Proxies tab, view the status of all Smart Proxies.
    • On the Compute Resources tab, view the status of attached compute resource providers.
    • In the Backend System Status table, view the status of all back-end services.
CLI procedure
    $ hammer ping
  • Perform a health check:
14.7. Restarting services
  • Restart Foreman services:
14.8. Utilities for processing log information
sosreport
The sos report command collects configuration and diagnostic information from a Linux system, such as the running kernel version, loaded modules, running services, and system and service configuration files. Additionally, it collects information about Foreman, such as its back-end services and tasks. This output is stored in a tar file located at /var/tmp/sosreport-XXX-20171002230919.tar.xz.
For more information, run sos report --help or see SOS user documentation.
The sos report command removes security information such as passwords, tokens, and keys while collecting information. However, the tar files can still contain sensitive information about the Foreman server. Send the tar files directly to the intended recipient and not to a public target.
foreman-tail
14.9. Log file directories
The following table provides an overview of selected log directories on Foreman server:
/var/log/candlepin/
Subscription management
Installer
/var/log/foreman-maintain/
Foreman maintain
Foreman proxy
/var/log/foreman/
Foreman
/var/log/httpd/
Apache HTTP server
/var/log/messages/
Various other log messages
Puppet
/var/log/tomcat/
Candlepin web service logs
14.10. System journal metadata
AUDIT_ACTION
Audit action performed
AUDIT_TYPE
Audit resource type
AUDIT_ID
AUDIT_ATTRIBUTE
AUDIT_FIELD_OLD
AUDIT_FIELD_NEW
AUDIT_ID
AUDIT_ATTRIBUTE
Example: Name or description
EXCEPTION_MESSAGE
EXCEPTION_CLASS
EXCEPTION_BACKTRACE
LOC_ID
Location database ID
LOC_NAME
Location name
LOC_LABEL
Location label
LOGGER
Logger name
ORG_ID
Organization database ID
ORG_NAME
Organization name
ORG_LABEL
Organization label
REMOTE_IP
Remote IP address of a client
REQUEST
SESSION
TEMPLATE_NAME
Template name
TEMPLATE_DIGEST
TEMPLATE_HOST_NAME
TEMPLATE_HOST_ID
USER_LOGIN
User login name
15. Monitoring resources
The following chapter details how to configure monitoring and reporting for managed systems. This includes host configuration, content views, compliance, registered hosts, promotions, and synchronization.
15.1. Using the Foreman content dashboard
The Foreman content dashboard contains various widgets which provide an overview of the host configuration, content views, compliance reports, and hosts currently registered, promotions and synchronization, and a list of the latest notifications.
Host Configuration Status
Table 4. Host configuration states
Icon State Description
host state config okay
host state config error
Hosts in error state
host state config report
host state config pending
host state config outofsync
Out of sync hosts
host state config noreport
Hosts with no reports
host state config noalert
Hosts with alerts disabled
Host Configuration Chart
Latest Events
A graph shows the distribution of the running OpenVox agents during the last puppet interval which is 30 minutes by default. In this case, each column represents the number of reports received from clients during 3 minutes.
New Hosts
Task Status
Latest Warning/Error Tasks
Discovered Hosts
Latest Errata
Content Views
Sync Overview
Host Collections
Virt-who Configuration Status
Table 5. virt-who configuration states
State Description
No Reports
No Change
OK
Total Configurations
Latest Compliance Reports
Compliance Reports Breakdown
Red Hat Insights Actions
Red Hat Insights Risk Summary
15.1.1. Managing tasks
Foreman keeps a complete log of all planned or performed tasks, such as repositories synchronised, errata applied, and content views published. To review the log, navigate to Monitor > Foreman Tasks > Tasks.
To adjust timeout settings
To disable checking for services
  5. Click Save.
15.2. Configuring RSS notifications
To configure RSS feed notifications
15.3. Monitoring Foreman server
15.4. Monitoring Smart Proxy server
15.4.1. Viewing general Smart Proxy information
In the Features column, you can verify if, for example, your Smart Proxy provides a DHCP service or acts as a Pulp mirror. Smart Proxy features can be enabled during installation or configured in addition. For more information, see Installing Smart Proxy server.
15.4.2. Monitoring services
15.4.3. Monitoring Puppet
16. Limiting host resources
You can use the Resource Quota plugin to limit users' access to host resources during host provisioning.
Supported resource types
  • CPU cores
  • Memory
  • Disk space
Supported compute resources
  • VMware
  • libvirt
16.1. Installing the Resource Quota plugin
  1. Install the plugin on your Foreman server:
  2. Optional: Install the Hammer CLI plugin on your Foreman server:
16.2. Managing resource quotas
16.2.1. Creating a resource quota
Create a resource quota to limit the resource consumption of Foreman users. To use the CLI instead of the Foreman web UI, see the CLI procedure.
  1. In the Foreman web UI, navigate to Configure > Resource Quotas.
  2. Click Create resource quota.
  3. Specify the name, CPU cores, memory, and disk space.
  4. Click Create resource quota to submit the resource quota to Foreman.
CLI procedure
  • Create a resource quota:
    $ hammer resource-quota create \
    --cpu-cores My_CPU_Cores \
    --description My_Resource_Quota_Description \
    --disk-space My_Disk_Space_in_GiB \
    --memory My_Memory_in_MiB \
    --name "My_Resource_Quota_Name"
    For all options, see hammer resource-quota create --help.
16.2.2. Editing a resource quota
You can edit a resource quota to adjust available resources to Foreman users. To use the CLI instead of the Foreman web UI, see the CLI procedure.
  2. Select your resource quota.
  3. Adjust the CPU cores, Memory, or Disk space and click Apply to submit your changes to Foreman.
CLI procedure
  1. Optional: List all resource quotas:
  2. Edit a resource quota:
    $ hammer resource-quota update \
    --id My_Resource_Quota_ID \
    If you set the value to 0, users cannot consume any resource at all. To reset resource quotas, you can use --remove-cpu-cores-limit, --remove-disk-space-limit, and --remove-memory-limit.
    For all options, see hammer resource-quota update --help.
16.2.3. Deleting a resource quota
You can delete a resource quota from Foreman. To use the CLI instead of the Foreman web UI, see the CLI procedure.
  2. In the Actions column, click Delete for your resource quota.
CLI procedure
  2. Delete a resource quota:
    For all options, see hammer resource-quota delete --help.
16.3. Assigning resource quotas to users
You can assign resource quotas to users or user groups. A user can select one of their assigned resource quotas during host provisioning. If Resource Quota optional assignment is set to No, a user does not have to assign a resource quota. You can use the resource_quota filter in the Foreman web UI to view users or user groups with assigned resource quotas.
16.3.1. Assigning resource quotas to a user
You can assign resource quotas to a user to limit the resource consumption of that Foreman user. To use the CLI instead of the Foreman web UI, see the CLI procedure.
  2. Select a user.
  3. On the Resource Quota tab, assign resource quotas to the user.
  4. If you want to make the usage of resource quotas optional, select the Optional Assignment checkbox.
  5. Click Submit to assign resource quotas to a user.
CLI procedure
  1. Optional: List all Foreman users:
  2. Optional: List all resource quotas:
  3. Assign resource quotas to a user:
    $ hammer user update \
    --id My_User_ID \
    --resource-quota-ids My_Resource_Quota_IDs
    If you want to make resource quota optional, add the --resource-quota-is-optional true option.
    For all options, see hammer user update --help.
16.3.2. Assigning resource quotas to a user group
You can assign resource quotas to a user group to limit the resource consumption of that Foreman user group. All users of the user group share the pool of resources. To use the CLI instead of the Foreman web UI, see the CLI procedure.
  2. On the Resource Quota tab, assign resource quotas to the user group.
  3. Click Submit to assign resource quotas to a user group.
CLI procedure
  1. Optional: List all Foreman user groups:
  3. Assign resource quotas to a user group:
    $ hammer user-group update \
    --id My_User_Group_ID \
    For all options, see hammer user-group update --help.
16.4. Resource Quota settings
17. Using webhooks
A webhook is a way for a web page or web application to provide other applications with information in real time. Webhooks are only triggered after an event occurs. The request usually contains details of the event. An event triggers callbacks, such as sending an e-mail confirming a host has been provisioned. You can use webhooks to define a call to an external API based on Foreman internal event by using a fire-and-forget message exchange pattern. The application sending the request does not wait for the response, or ignores it.
17.1. Installing the webhooks plugin
  • Install the webhooks plugin by running the following command:
  • Optional: Install the webhooks CLI plugin:
17.2. Creating a webhook template
    For more information, see Template Writing Reference in Managing hosts and for available template macros and methods, visit /templates_doc on Foreman server.
  7. Click Submit.
Examples
Running remote execution jobs
Creating users
17.3. Creating a webhook
  2. Click Create new.
  7. Enter an HTTP method.
  9. Click the Credentials tab.
When configuring webhooks with endpoints with non-standard HTTP or HTTPS ports, an SELinux port must be assigned, see Configuring SELinux to Ensure Access to Foreman on Custom Ports in Installing Foreman Server with Katello 4.16 plugin on Enterprise Linux.
17.4. Available webhook events
A content view was successfully promoted.
Run OpenSCAP scan.
Runs an Ansible Playbook containing all the roles defined for a host.
Run an Ansible Playbook against given hosts.
Run an Ansible Playbook to enable the web console on given hosts.
Perform a single Puppet run.
Build Entered
Build Exited
Common database operations on a content view.
Domain
Host
Hostgroup
Model
Status Changed
Subnet
Template Render Performed
Template
User
17.5. Shellhooks
With webhooks, you can only map one Foreman event to one API call. For advanced integrations, where a single shell script can contain multiple commands, you can install a Smart Proxy shellhooks plugin that exposes executables by using a REST HTTP API.
You can then configure a webhook to reach out to a Smart Proxy API to run a predefined shellhook. A shellhook is an executable script that can be written in any language provided that it can be executed. The shellhook can for example contain commands or edit files.
You can pass input to shellhook script through the webhook payload. This input is redirected to standard input of the shellhook script. You can pass arguments to shellhook script by using HTTP headers in format X-Shellhook-Arg-1 to X-Shellhook-Arg-99. For more information on passing arguments to shellhook script, see:
The HTTP method must be POST. An example URL would be: https://smartproxy.example.com:9090/shellhook/My_Script.
For an example on creating a shellhook script, see Creating a shellhook to print arguments.
17.6. Installing the shellhooks plugin
Optionally, you can install and enable the shellhooks plugin on each Smart Proxy used for shellhooks.
  • Install the shellhooks plugin on your Smart Proxy:
17.7. Passing arguments to shellhook script using webhooks
      "X-Shellhook-Arg-1": "VALUE",
      "X-Shellhook-Arg-2": "VALUE"
Example
17.8. Passing arguments to shellhook script using curl
    "X-Shellhook-Arg-1: VALUE"
    "X-Shellhook-Arg-2: VALUE"
Example
$ curl \
--data "" \
--header "Content-Type: text/plain" \
--header "X-Shellhook-Arg-1: Version 1.0" \
--header "X-Shellhook-Arg-2: My content view" \
--request POST \
--show-error \
--silent \
17.9. Creating a shellhook to print arguments
    #!/bin/sh
    echo "$@" >&2
  2. In the Foreman web UI, navigate to Administer > Webhook > Webhooks.
  3. Click Create new.
  6. In the Target URL field, enter the URL of your Smart Proxy server followed by :9090/shellhook/print_args:
    https://smartproxy.example.com:9090/shellhook/print_args
        "X-Shellhook-Arg-1": "Hello",
        "X-Shellhook-Arg-2": "World!"
  1. Run a remote execution job on any host. You can use time as a command. For more information, see Executing a Remote Job in Managing hosts.
    [W] [3520] Hello World!
18. Searching and bookmarking
Foreman features powerful search functionality on most pages of the Foreman web UI. It enables you to search all kinds of resources that Foreman manages. Searches accept both free text and syntax-based queries, which can be built by using input prediction. Search queries can be saved as bookmarks for future reuse.
18.1. Building search queries
As you start typing a search query, a list of valid options to complete the current part of the query appears. You can either select an option from the list and keep building the query by using the prediction, or continue typing. To learn how free text is interpreted by the search engine, see Using free text search.
18.1.1. Query syntax
parameter operator value
18.1.2. Query operators
Table 6. Comparison operators accepted by search
EQUALS
hostgroup = RHEL7
NOT EQUALS
LIKE
hostgroup ~ rhel%
NOT LIKE
GREATER THAN
registered_at <= Yesterday
LESS THAN
IN
release_version !^ 7
NOT IN
HAS or set?
NOT HAS or null?
Table 7. Logical operators accepted by search
and
<whitespace>
or
not
18.1.3. Query values
Text Values
Examples:
hostgroup = "Web servers"
hostgroup = Web servers
Temporal Values
  • "10 January 2017"
  • "10 Jan 2017"
  • 10-January-2017
  • 10/January/2017
  • "January 10, 2017"
Warning
18.2. Using free text search
18.3. Managing bookmarks
18.3.1. Creating bookmarks
  7. Click Submit.
18.3.2. Deleting bookmarks
18.4. Using keyboard shortcuts
You can use keyboard shortcuts to quickly focus search bars.
  • To focus the vertical navigation search bar, press Ctrl + Shift + F.
  • To focus the page search bar, press /.
Appendix A: Administration settings
A.1. General settings
Administrator email address
Foreman URL
Entries per page
20
Fix DB cache
DB pending seed
Smart Proxy request timeout
60
Login page footer text
HTTP(S) proxy
HTTP(S) proxy except hosts
Show Experimental Labs
Display FQDN for hosts
If set to Yes, Foreman displays names of hosts as fully qualified domain names (FQDNs).
Out of sync interval
30
Hosts report periodically, and if the time between reports exceeds this duration in minutes, hosts are considered out of sync. You can override this on your hosts by adding the outofsync_interval parameter, per host, at Hosts > All hosts > $host > Edit > Parameters > Add Parameter.
Foreman UUID
Default language
Default timezone
Instance title
Saved audits interval
New host details UI
A.2. Task settings
Sync task timeout
120
Enable dynflow console
Proxy action retry count
4
Proxy action retry interval
15
Allow proxy batch tasks
Proxy tasks batch size
100
Tasks troubleshooting URL
Polling intervals multiplier
1
A.3. Template sync settings
Associate
Associate templates with operating system, organization, and location.
Branch
Default branch in Git repo.
Commit message
Dirname
Filter
Force import
HTTP proxy policy
Whether to use an HTTP proxy to synchronize templates.
The Custom HTTP proxy value is available only if an HTTP proxy is configured under the selected organization and location and if your account has the view_http_proxies permission assigned.
Lock templates
Keep, do not lock new
Metadata export mode
Refresh
Default metadata export mode.
Possible options:
refresh re-renders metadata.
keep keeps existing metadata.
Negate
Prefix
Repo
/tmp/dir
git://example.com
https://example.com
ssh://example.com
Verbosity
A.4. Discovery settings
Discovery location
Discovery organization
Interface fact
discovery_bootif
Create bond interfaces
Clean all facts
Hostname facts
discovery_bootif
Auto provisioning
Reboot
Hostname prefix
mac
Fact columns
Highlighted facts
Storage facts
Software facts
Hardware facts
Network facts
IPMI facts
Lock PXE
Locked PXELinux template name
pxelinux_discovery
Locked PXEGrub template name
pxegrub_discovery
Locked PXEGrub2 template name
pxegrub2_discovery
Force DNS
Error on existing NIC
Do not permit to discover an existing host matching the MAC of a provisioning Network Interface Card (NIC) (errors out early).
Type of name generator
Fact + prefix
Prefer IPv6
A.5. Boot disk settings
iPXE directory
/usr/share/ipxe
ISOLINUX directory
/usr/share/syslinux
SYSLINUX directory
/usr/share/syslinux
Grub2 directory
/var/lib/tftpboot/grub2
Host image template
Boot disk iPXE - host
Generic image template
Boot disk iPXE - generic host
ISO generation command
genisoimage
Installation media caching
Allowed bootdisk types
A.6. Content settings
Default HTTP Proxy
Kickstart default
Kickstart default finish
Default synced OS user-data
Kickstart default user data
Kickstart default PXELinux
Kickstart default PXEGrub
Kickstart default PXEGrub2
Kickstart default iPXE
Kickstart default
Atomic Kickstart default
Manifest refresh timeout
1200
Calculate errata host status based only on errata in a host’s content view and lifecycle environment.
Check services before actions
100
Whether or not to auto sync Smart Proxies after a content view promotion.
immediate
on_demand
on_demand
/var/lib/pulp/katello-export
/var/lib/pulp/exports
Pulp client key
Pulp client cert
Sync Connection Timeout
300
Delete Host upon unregister
Default Location
Expire soon days
120
Host Duplicate DMI UUIDs
Host Profile Assume
Enable new host registrations to assume registered profiles with matching hostname if the registering DMI UUID is not used by another host.
Enable host registrations to bypass Host Profile Assume if the host is in build mode.
Host Tasks Workers Pool Size
5
Applicability Batch Size
50
Autosearch
Autosearch delay
500
Pulp bulk load size
2000
1440
Enable removal of repositories that the user has previously published in one or more content view versions.
A.7. Authentication settings
OAuth active
This setting is for internal Foreman use only. Foreman community does not support using it to configure OAuth authentication for API calls.
OAuth consumer key
OAuth consumer key.
OAuth consumer secret
OAuth consumer secret.
OAuth map users
Failed login attempts limit
30
Trusted hosts
SSL certificate
/etc/foreman/client_cert.pem
SSL CA file
/etc/foreman/proxy_ca.pem
SSL private key
/etc/foreman/client_key.pem
SSL client DN env
HTTP_SSL_CLIENT_S_DN
SSL client verify env
HTTP_SSL_CLIENT_VERIFY
SSL client cert env
HTTP_SSL_CLIENT_CERT
Server CA file
Websockets SSL key
Websockets SSL certificate
Websockets encryption
Login delegation logout URL
External
Idle timeout
60
BCrypt password cost
9
BMC credentials access
OIDC JWKs URL
OIDC Audience
OIDC Issuer
OIDC Algorithm
A.8. Email settings
Email reply address
Email subject prefix
Send welcome email
Delivery method
Sendmail
Method used to deliver email.
SMTP enable StartTLS auto
SMTP OpenSSL verify mode
Default verification mode
SMTP address
SMTP address to connect to.
SMTP port
25
SMTP port to connect to.
SMTP HELO/EHLO domain
HELO/EHLO domain.
SMTP username
SMTP password
SMTP authentication
none
Sendmail arguments
-i
Sendmail location
/usr/sbin/sendmail
A.9. Notifications settings
RSS enable
Pull RSS notifications.
RSS URL
A.10. Provisioning settings
Host owner
Root password
Unattended URL
Safemode rendering
Query local nameservers
Installation token lifetime
360
SSH timeout
120
0.0.0.0
Update IP from built request
Use short name for VMs
DNS timeout
[5, 10, 15, 20]
Clean up failed deployment
Random-based
iPXE intermediate script
Maximum structured facts
100
Global Registration
Global Registration template.
CoreOS Transpiler Command
PXEGrub2 global default
PXELinux global default
PXEGrub global default
Global default iPXE template
iPXE global default
Local boot PXEGrub2 template
PXEGrub2 default local boot
Local boot PXELinux template
PXELinux default local boot
Local boot PXEGrub template
PXEGrub default local boot
Local boot iPXE template
iPXE default local boot
Manage PuppetCA
Use UUID for certificates
A.11. Facts settings
Location fact
foreman_location
Organization fact
foreman_organization
Default location
Default Location
Default organization
Default Organization
Update hostgroup from facts
Ignore facts for domain
Update subnets from facts
None
Default Puppet environment
production
ENC environment
Update environment from facts
A.12. Configuration management settings
Matchers inheritance
[fqdn, hostgroup, os, domain]
Interpolate ERB in parameters
Puppet interval
35
Puppet out of sync disabled
A.13. Remote execution settings
Fallback to Any Proxy
Enable Global Proxy
SSH User
root
Effective User
root
Effective User Method
sudo
Effective user password
Sync Job Templates
SSH Port
22
Connect by IP
Prefer IPv6 over IPv4
Default SSH password
Default SSH key passphrase
Workers pool size
5
Cleanup working directories
Cockpit URL
Form Job Template
Run Command - Script Default
Time to pickup
86400
Time in seconds within which the host has to pick up a job. If the job is not picked up within this limit, the job will be canceled. Applies only to pull-mqtt based jobs. Defaults to one day.
A.14. Ansible settings
Private Key Path
Connection type
ssh
Use this connection type by default when running Ansible Playbooks. You can override this on hosts by adding the ansible_connection parameter.
WinRM cert Validation
validate
Enable or disable WinRM server certificate validation when running Ansible Playbooks. You can override this on hosts by adding the ansible_winrm_server_cert_validation parameter.
Default verbosity level
Disabled
Foreman adds this level of verbosity for additional debugging output when running Ansible Playbooks.
Post-provision timeout
360
Ansible report timeout
30
Ansible out of sync disabled
Ansible - Ansible Inventory
Ansible roles to ignore
Unsupported version
