1. Foreman overview and concepts
Foreman is a centralized tool for provisioning, remote management, and monitoring of multiple Enterprise Linux deployments. With Foreman, you can deploy, configure, and maintain your systems across physical, virtual, and cloud environments.
2. Content and patch management with Foreman
With Foreman, you can provide content and apply patches to hosts systematically in all lifecycle stages.
2.1. Content flow in Foreman
Content flow in Foreman involves management and distribution of content from external sources to hosts.
Content in Foreman flows from external content sources to Foreman server. Smart Proxy servers mirror the content from Foreman server to hosts.
External content sources
You can configure many content sources with Foreman. The supported content sources include the Red Hat Customer Portal, Git repositories, Ansible collections, Docker Hub, SCAP repositories, or internal data stores of your organization.
Foreman server
On your Foreman server, you plan and manage the content lifecycle.
Smart Proxy servers
By creating Smart Proxy servers, you can establish content sources in various locations based on your needs. For example, you can establish a content source for each geographical location or multiple content sources for a data center with separate networks.
Hosts
By assigning a host system to a Smart Proxy server or directly to your Foreman server, you ensure the host receives the content they provide. Hosts can be physical or virtual.
2.2. Content views in Foreman
Default Organization View
Version of the content view
Version 2
Version 1
Version 1
Contents of the content view
my-software-1.1-0.noarch.rpm
my-software-1.0-0.noarch.rpm
Version 2
Version 2
Version 1
2.3. Content types in Foreman
With Foreman, you can import and manage many content types.
RPM packages
Import RPM packages from any repository, for example from Amazon, Oracle, Red Hat, SUSE, and custom repositories. Foreman server downloads the RPM packages and stores them locally. You can use these repositories and their RPM packages in content views.
Deb packages
Kickstart trees
Provisioning templates
Templates to provision hosts running EL based on synchronized content and Debian, Ubuntu, or SUSE Linux Enterprise Server based on local installation media. Foreman contains predefined AutoYaST, Kickstart, and Preseed templates as well as the ability to create your own, which are used to provision systems and customize the installation.
ISO and KVM images
Download and manage media for installation and provisioning. For example, Foreman downloads, stores, and manages ISO images and guest images for specific Red Hat Enterprise Linux and non-Red Hat operating systems.
OSTree
Custom file type
2.4. Additional resources
  • For information about how to manage content with Foreman, see Managing content.
3. Subscription management with Foreman
With Foreman, you can track usage of software subscriptions and assign subscriptions according to your needs.
3.1. Simple content access (SCA) in Foreman
Simple Content Access (SCA) in Foreman simplifies management of software entitlements. With SCA, you can add valid subscriptions to a subscription allocation or manifest and refresh within Foreman. Therefore, with SCA enabled, you do not need to attach subscriptions individually to hosts.
Simple Content Access (SCA) replaces the previous entitlement-based method of subscription management. New organizations default to having SCA enabled. Entitlement-based subscription management is deprecated. For more information, see Release notes.
3.2. Additional resources
  • For more information about how to manage subscriptions with Foreman, see Managing content.
4. Provisioning management with Foreman
4.1. Provisioning methods in Foreman
With Foreman, you can provision hosts by using the following methods.
Bare-metal hosts
Foreman provisions bare-metal hosts primarily by using PXE boot and MAC address identification. When provisioning bare-metal hosts with Foreman, you can do the following:
  • Create host entries and specify the MAC address of the physical host to provision.
  • Boot blank hosts to use the Foreman Discovery service, which creates a pool of hosts that are ready for provisioning.
  • Boot and provision hosts by using PXE-less methods.
Cloud providers
Foreman connects to private and public cloud providers to provision instances of hosts from images stored in the cloud environment. When provisioning from cloud with Foreman, you can do the following:
  • Select which hardware profile to use.
  • Provision cloud instances from specific providers by using their APIs.
Virtualization infrastructure
Foreman connects to virtualization infrastructure services, such as oVirt and VMware. When provisioning virtual machines with Foreman, you can do the following:
  • Provision virtual machines from virtual image templates.
  • Use the same PXE-based boot methods that you use to provision bare-metal hosts.
4.2. Additional resources
5. Major Foreman components
A typical Foreman deployment consists of the following components: a Foreman server, Smart Proxy servers that mirror content from Foreman server, and hosts that receive content and configuration from Foreman server and Smart Proxy servers.
5.1. Foreman Server overview
Foreman server is the central component of a Foreman deployment where you plan and manage the content lifecycle.
  • Configuration of hosts
  • Host provisioning
  • Patch management
  • Subscription management
Foreman server delegates content distribution, host provisioning, and communication to Smart Proxy servers. Foreman server itself also includes a Smart Proxy.
5.2. Organizations and locations in Foreman
On your Foreman server, you can define multiple organizations and locations to help organize content, hosts, and configurations.
Organizations
Organizations typically represent different business units, departments, or teams, such as Finance, Marketing, or Web Development.
Locations
Locations typically represent physical locations, such as countries or cities.
5.3. Smart Proxy overview
  • Mirroring content from Foreman server to establish content sources in various geographical or logical locations. By registering a host to a Smart Proxy server, you can configure this host to receive content and configuration from the Smart Proxy in their location instead of from the central Foreman server.
By using content views, you can specify the exact subset of content that Smart Proxy server makes available to hosts. For more information, see Content and patch management with Foreman.
5.4. Overview of hosts in Foreman
With Foreman, you can manage hosts at scale, including monitoring, provisioning, remote execution, configuration management, software management, and subscription management.
5.5. List of key open source components of Foreman Server
Foreman
Katello
Candlepin
Pulp
5.6. Smart Proxy features
Smart Proxy servers provide local host management services. With the Katello plugin, they can also mirror content from Foreman server.
If you have the Katello plugin installed, you can use Smart Proxy to mirror content from Foreman server:
Repository synchronization
Smart Proxy servers pull content for selected lifecycle environments from Foreman server and make this content available to the hosts they manage.
Content delivery
Hosts configured to use Smart Proxy server download content from that Smart Proxy rather than from Foreman server.
Host action delivery
Smart Proxy server executes scheduled actions on hosts.
Hosts are registered to their associated Smart Proxy servers rather than to the central Foreman server or the Red Hat Customer Portal.
You can use Smart Proxy to run the following services for infrastructure and host management:
DHCP
DNS
TFTP
Realm
Puppet server
Puppet Certificate Authority
Provisioning template proxy
OpenSCAP
Remote Execution (REX)
Infrastructure Smart Proxies: DNS + DHCP + TFTP
Smart Proxies with these services provide infrastructure services for hosts and have all necessary services for provisioning new hosts.
Content Smart Proxies: Pulp
Smart Proxies with this service provide content synchronized from Foreman server to hosts.
Configuration Smart Proxies: Pulp + Puppet + PuppetCA
Smart Proxies with these services provide content and run configuration services for hosts.
Smart Proxies with DNS + DHCP + TFTP + Pulp + Puppet + PuppetCA
Smart Proxies with these services provide a full set of Smart Proxy features. By configuring a Smart Proxy with all these features, you can isolate hosts assigned to that Smart Proxy by providing a single point of connection for the hosts.
5.7. Smart Proxy networking
Many of the services that Smart Proxy server manages use dedicated network ports. However, Smart Proxy server ensures that all communications from the host to Foreman server use a single source IP address, which simplifies firewall administration.
Foreman topology with hosts connecting to a Smart Proxy
In this topology, Smart Proxy provides a single endpoint for all host network communications so that in remote network segments, only firewall ports to the Smart Proxy itself must be open.
Foreman topology with a host
Figure 1. How Foreman components interact when hosts connect to a Smart Proxy
Foreman topology with hosts connecting directly to Foreman server
In this topology, hosts connect to Foreman server rather than a Smart Proxy. This applies also to Smart Proxies themselves because the Smart Proxy server is a host of Foreman server.
Foreman topology with a direct host
Figure 2. How Foreman components interact when hosts connect directly to Foreman server
You can find complete instructions for configuring the host-based firewall to open the required ports in the following documents:
5.8. Additional resources
6. Tools for administration of Foreman
6.1. Foreman web UI overview
You can manage and monitor your Foreman infrastructure from a browser with the Foreman web UI. For example, you can use the following navigation features in the Foreman web UI:
Navigation feature Description
Organization dropdown
Choose the organization you want to manage.
Location dropdown
Choose the location you want to manage.
Monitor
Content
Provides content management tools. This includes content views, activation keys, and lifecycle environments.
Hosts
Configure
Provides general configuration tools and data, including host groups and Ansible content.
Infrastructure
notification bell
Administer
Provides advanced configuration for settings such as users, role-based access control (RBAC), and general settings.
6.2. Hammer CLI overview
6.3. Foreman API overview
You can write custom scripts and external applications that access the Foreman API over HTTP with the Representational State Transfer (REST) API provided by Foreman server. Use the REST API to integrate with enterprise IT systems and third-party applications, perform automated maintenance or error checking tasks, and automate repetitive tasks with scripts.
  • Create client applications that require minimal knowledge of the Foreman infrastructure because users discover many details at runtime.
6.4. Remote execution in Foreman
Foreman uses ERB syntax job templates. For more information, see Template Writing Reference in Managing hosts.
6.5. Managing Foreman with Ansible
Foreman Ansible Collections is a set of Ansible modules that interact with the Foreman API. You can manage and automate many aspects of Foreman with Foreman Ansible collections.
6.6. Kickstart workflow
You can automate the installation process of a Foreman server or Smart Proxy server by creating a Kickstart file that contains all the information that is required for the installation.
When you run a Foreman Kickstart script, the script performs the following actions:
  1. It specifies the installation location of a Foreman server or a Smart Proxy server.
  2. It installs the predefined packages.
  3. It installs Subscription Manager.
  4. It uses Activation Keys to subscribe the hosts to Foreman.
  5. It installs Puppet, and configures a puppet.conf file to indicate the Foreman or Smart Proxy instance.
  6. It enables Puppet to run and request a certificate.
  7. It runs user defined snippets.
For more information about Kickstart, see Automated installation workflow in Automatically installing RHEL 9.
7. Supported usage and versions of Foreman components
7.1. Foreman server operating system
Foreman has packages for Enterprise Linux 8 and 9, Debian 11 and Ubuntu 20.04 and 22.04. Katello plugin packages, which provide content management capabilities, are only available for Enterprise Linux.
7.2. Client operating systems
Using Foreman, you can manage multiple operating systems that have Foreman clients:
  • Amazon Linux
  • Debian
  • Enterprise Linux 9 and 8
  • Fedora
  • OpenSUSE
  • SUSE Linux Enterprise Server
  • Ubuntu
  • Ansible
  • OpenSCAP
  • OpenSSH
  • Puppet
  • Salt
  • Katello host tools
  • Subscription Manager
  • Tracer utility
8. Common deployment scenarios
8.1. Single location
An integrated Smart Proxy is a virtual Smart Proxy server that is created by default in Foreman server during the installation process. This means Foreman server can be used to provision directly connected hosts for Foreman deployment in a single geographical location, therefore only one physical server is needed. The base systems of isolated Smart Proxies can be directly managed by Foreman server, however it is not recommended to use this layout to manage other hosts in remote locations.
8.2. Single location with segregated subnets
Your infrastructure might require multiple isolated subnets even if Foreman is deployed in a single geographic location. This can be achieved for example by deploying multiple Smart Proxy servers with DHCP and DNS services, but the recommended way is to create segregated subnets using a single Smart Proxy. This Smart Proxy is then used to manage hosts and compute resources in those segregated networks to ensure they only have to access the Smart Proxy for provisioning, configuration, errata, and general management. For more information on configuring subnets see Managing Hosts.
8.3. Multiple locations
It is recommended to create at least one Smart Proxy server per geographic location. This practice can save bandwidth since hosts obtain content from a local Smart Proxy server. Synchronization of content from remote repositories is done only by the Smart Proxy, not by each host in a location. In addition, this layout makes the provisioning infrastructure more reliable and easier to configure.
Content Flow in Foreman
8.4. Smart Proxy with external services
You can configure a Smart Proxy server (integrated or standalone) to use external DNS, DHCP, or TFTP service. If you already have a server that provides these services in your environment, you can integrate it with your Foreman deployment. For information about how to configure a Smart Proxy with external services, see Configuring Smart Proxy server with External Services in Installing a Smart Proxy Server 3.12 on Enterprise Linux.
9. Deployment considerations
9.1. Foreman server with external database
When you install Foreman, the foreman-installer command creates databases on the same server that you install Foreman. Depending on your requirements, moving to external databases can provide increased working memory for Foreman, which can improve response times for database operating requests. Moving to external databases distributes the workload and can increase the capacity for performance tuning.
  • Frequent remote execution tasks. This creates a high volume of records in PostgreSQL and generates heavy database workloads.
  • High disk I/O workloads from frequent repository synchronization or Content View publishing. This causes Foreman to create a record in PostgreSQL for each job.
  • High volume of hosts.
  • High volume of synced content.
For more information about using an external database, see Using External Databases with Foreman in Installing Foreman Server with Katello 4.14 plugin on Enterprise Linux.
9.2. Locations and topology
This section outlines general considerations that should help you to specify your Foreman deployment scenario. The most common deployment scenarios are listed in Common deployment scenarios. The defining questions are:
  • How many Smart Proxy servers do I need? – The number of geographic locations where your organization operates should translate to the number of Smart Proxy servers. By assigning a Smart Proxy to each location, you decrease the load on Foreman server, increase redundancy, and reduce bandwidth usage. Foreman server itself can act as a Smart Proxy (it contains an integrated Smart Proxy by default). This can be used in single location deployments and to provision the base system’s of Smart Proxy servers. Using the integrated Smart Proxy to communicate with hosts in remote locations is not recommended as it can lead to suboptimal network utilization.
  • What services will be provided by Smart Proxy servers? – After establishing the number of Smart Proxies, decide what services will be enabled on each Smart Proxy. Even though the whole stack of content and configuration management capabilities is available, some infrastructure services (DNS, DHCP, TFTP) can be outside of a Foreman administrator’s control. In such case, Smart Proxies have to integrate with those external services (see Smart Proxy with external services).
  • What compute resources do I need for my hosts? – Apart from provisioning bare-metal hosts, you can use various compute resources supported by Foreman. To learn about provisioning on different compute resources see Provisioning hosts.
9.3. Content sources
The Red Hat Subscription Manifest determines what Red Hat repositories are accessible from your Foreman server. Once you enable a Red Hat repository, an associated Foreman product is created automatically. For distributing content from custom sources you need to create products and repositories manually. Red Hat repositories are signed with GPG keys by default, and it is recommended to create GPG keys also for your custom repositories.
Yum repositories that contain only RPM packages support the On demand download policy, which reduces synchronization time and storage space. The On demand download policy saves space and time by only downloading packages when requested by hosts. For detailed instructions on setting up content sources, see Importing Content in Managing content.
A custom repository within Foreman server is in most cases populated with content from an external staging server. Such servers lie outside of the Foreman infrastructure, however, it is recommended to use a revision control system (such as Git) on these servers to have better control over the custom content.
9.4. Content lifecycle
Foreman provides features for precise management of the content lifecycle. A lifecycle environment represents a stage in the content lifecycle, a Content View is a filtered set of content, and can be considered as a defined subset of content. By associating Content Views with lifecycle environments, you make content available to hosts in a defined way.
Content Lifecycle in Foreman
For a detailed overview of the content management process see Importing Custom Content in Managing content. The following section provides general scenarios for deploying content views as well as lifecycle environments.
  • A single lifecycle environment path – both operating system and applications content is promoted through the same path. The path can consist of several stages (for example Development, QA, Production), which enables thorough testing but requires additional effort.
  • Application specific lifecycle environment paths – each application has a separate path, which allows for individual application release cycles. You can associate specific compute resources with application lifecycle stages to facilitate testing. On the other hand, this scenario increases the maintenance complexity.
  • Host specific content view – a dedicated content view for each host type. This approach can be useful in deployments with a small number of host types (up to 30). However, it prevents sharing content across host types as well as separation based on criteria other than the host type (for example between operating system and applications). With critical updates every content view has to be updated, which increases maintenance efforts.
9.5. Content deployment
Content deployment manages errata and packages on content hosts. Foreman can be configured to perform remote execution over MQTT/HTTPS (pull-based) or SSH (push-based). While remote execution is enabled on Foreman server by default, it is disabled on Smart Proxy servers and content hosts. You must enable it manually.
9.6. Provisioning
Foreman provides several features to help you automate the host provisioning, including provisioning templates, configuration management with Puppet, and host groups for standardized provisioning of host roles. For a description of the provisioning workflow see Provisioning Workflow in Provisioning hosts. The same guide contains instructions for provisioning on various compute resources.
9.7. Role based authentication
  • Roles related to applications or parts of infrastructure – for example, roles for owners of Red Hat Enterprise Linux as the operating system versus owners of application servers and database servers.
  • Roles related to a particular stage of the software lifecycle – for example, roles divided among the development, testing, and production phases, where each phase has one or more owners.
  • Roles related to specific tasks – such as security manager or license manager.
  • Define the expected tasks and responsibilities – define the subset of the Foreman infrastructure that will be accessible to the role as well as actions permitted on this subset. Think of the responsibilities of the role and how it would differ from other roles.
  • Use predefined roles whenever possible – Foreman provides a number of sample roles that can be used alone or as part of a role combination. Copying and editing an existing role can be a good start for creating a custom role.
  • Consider all affected entities – for example, a content view promotion automatically creates new Puppet Environments for the particular lifecycle environment and content view combination. Therefore, if a role is expected to promote content views, it also needs permissions to create and edit Puppet Environments.
  • Consider areas of interest – even though a role has a limited area of responsibility, there might be a wider area of interest. Therefore, you can grant the role a read only access to parts of Foreman infrastructure that influence its area of responsibility. This allows users to get earlier access to information about potential upcoming changes.
  • Add permissions step by step – test your custom role to make sure it works as intended. A good approach in case of problems is to start with a limited set of permissions, add permissions step by step, and test continuously.
For instructions on defining roles and assigning them to users, see Managing Users and Roles in Administering Foreman. The same guide contains information on configuring external authentication sources.
9.8. Additional tasks
  • Discovering bare-metal hosts – the Foreman Discovery plugin enables automatic bare-metal discovery of unknown hosts on the provisioning network. These new hosts register themselves to Foreman server and the Puppet agent on the client uploads system facts collected by Facter, such as serial ID, network interface, memory, and disk information. After registration you can initialize provisioning of those discovered hosts. For more information, see Creating Hosts from Discovered Hosts in Provisioning hosts.
  • Backup management – backup and disaster recovery instructions, see Backing Up Foreman server and Smart Proxy server in Administering Foreman. Using remote execution, you can also configure recurring backup tasks on hosts. For more information on remote execution see Configuring and Setting up Remote Jobs in Managing hosts.
  • Security management – Foreman supports security management in various ways, including update and errata management, OpenSCAP integration for system verification, update and security compliance reporting, and fine grained role based authentication. Find more information on errata management and OpenSCAP concepts in Managing hosts.
  • Incident management – Foreman supports the incident management process by providing a centralized overview of all systems including reporting and email notifications. Detailed information on each host is accessible from Foreman server, including the event history of recent changes.
  • Scripting with Hammer and API – Foreman provides a command line tool called Hammer that provides a CLI equivalent to the majority of web UI procedures. In addition, you can use the access to the Foreman API to write automation scripts in a selected programming language.
10. Organizations, locations, and lifecycle environments
Foreman takes a consolidated approach to Organization and Location management. System administrators define multiple Organizations and multiple Locations in a single Foreman server. For example, a company might have three Organizations (Finance, Marketing, and Sales) across three countries (United States, United Kingdom, and Japan). In this example, Foreman server manages all Organizations across all geographical Locations, creating nine distinct contexts for managing systems. In addition, users can define specific locations and nest them to create a hierarchy. For example, Foreman administrators might divide the United States into specific cities, such as Boston, Phoenix, or San Francisco.
Example topology for Foreman
Figure 3. Example topology for Foreman
Foreman server defines all locations and organizations. Each respective Foreman Smart Proxy server synchronizes content and handles configuration of systems in a different location.
The main Foreman server retains the management function, while the content and configuration is synchronized between the main Foreman server and a Foreman Smart Proxy server assigned to certain locations.
10.1. Organizations
10.2. Locations
10.3. Lifecycle environments
Application lifecycles are divided into lifecycle environments which represent each stage of the application lifecycle. Lifecycle environments are linked to form an environment path. You can promote content along the environment path to the next lifecycle environment when required. For example, if development ends on a particular version of an application, you can promote this version to the testing environment and start development on the next version.
An environment path containing four environments
Figure 4. An environment path containing four environments
11. Host grouping concepts
Apart from the physical topology of Smart Proxy servers, Foreman provides several logical units for grouping hosts. Hosts that are members of those groups inherit the group configuration. For example, the simple parameters that define the provisioning environment can be applied at the following levels:
  • Organizations – the highest level logical groups for hosts. Organizations provide a strong separation of content and configuration. Each organization requires a separate Red Hat Subscription Manifest, and can be thought of as a separate virtual instance of a Foreman server. Avoid the use of organizations if a lower level host grouping is applicable.
  • Locations – a grouping of hosts that should match the physical location. Locations can be used to map the network infrastructure to prevent incorrect host placement or configuration. For example, you cannot assign a subnet, domain, or compute resources directly to a Smart Proxy server, only to a location.
  • Host groups – the main carriers of host definitions including assigned Puppet classes, Content View, or operating system. It is recommended to configure the majority of settings at the host group level instead of defining hosts directly. Configuring a new host then largely becomes a matter of adding it to the right host group. As host groups can be nested, you can create a structure that best fits your requirements (see Host group structures).
  • Host collections – a host registered to Foreman server for the purpose of subscription and content management is called content host. Content hosts can be organized into host collections, which enables performing bulk actions such as package management or errata installation.
Locations and host groups can be nested. Organizations and host collections are flat.
11.1. Host group structures
Figure 5. Host group structuring examples
Flat structure
In this hierarchy, the first host group level is reserved for parameters specific to a lifecycle environment. The second level contains operating system related definitions, and the third level contains application specific settings. Such structure is useful in scenarios where responsibilities are divided among lifecycle environments (for example, a dedicated owner for the Development, QA, and Production lifecycle stages).
Application based structure
Location based structure
In this hierarchy, the distribution of locations is aligned with the host group structure. In a scenario where the location (Smart Proxy server) topology determines many other attributes, this approach is the best option. On the other hand, this structure complicates sharing parameters across locations, therefore in complex environments with a large number of applications, the number of host group changes required for each configuration change increases significantly.
12. Provisioning concepts
12.1. PXE booting
12.1.1. PXE sequence
For an example of using PXE Booting by Foreman server, see Provisioning Workflow in Provisioning hosts.
12.1.2. PXE booting requirements
Network requirements
Client requirements
  • Ensure that all the network-based firewalls are configured to allow clients on the subnet to access the Smart Proxy. For more information, see Smart Proxy networking.
Foreman requirements
12.2. HTTP booting
12.2.1. HTTP booting requirements with managed DHCP
Client requirements
  • All the network-based firewalls are configured to allow clients on the subnet to access the Smart Proxy. For more information, see Smart Proxy networking.
Although TFTP protocol is not used for HTTP UEFI Booting, Foreman uses TFTP Smart Proxy API to deploy bootloader configuration.
  • Ensure that the TCP port 8000 is open for the client to download the bootloader and Kickstart templates from the Smart Proxy.
  • The TCP port 9090 is open for the client to download the bootloader from the Smart Proxy using the HTTPS protocol.
  • The grub2-efi package is updated to the latest version. To update the grub2-efi package to the latest version and execute the installer to copy the recent bootloader from /boot into /var/lib/tftpboot directory, enter the following commands:
    # dnf upgrade grub2-efi
    # foreman-installer
12.2.2. HTTP booting requirements with unmanaged DHCP
Client requirements
    • https://smartproxy.example.com:9090
Although TFTP protocol is not used for HTTP UEFI Booting, Foreman use TFTP Smart Proxy API to deploy bootloader configuration.
  • Ensure that the TCP port 8000 is open for the client to download bootloader and Kickstart templates from the Smart Proxy.
  • Ensure that the TCP port 9090 is open for the client to download the bootloader from the Smart Proxy through HTTPS.
  • Update the grub2-efi package to the latest version and execute the installer to copy the recent bootloader from the /boot directory into the /var/lib/tftpboot directory:
    # foreman-installer
12.3. Secure boot
When Foreman is installed on Enterprise Linux using foreman-installer, grub2 and shim bootloaders that are signed by Red Hat are deployed into the TFTP and HTTP UEFI Boot directory. PXE loader options named "SecureBoot" configure hosts to load shim.efi.
On Debian and Ubuntu operating systems, the grub2 bootloader is created using the grub2-mkimage unsigned. To perform the Secure Boot, the bootloader must be manually signed and key enrolled into the EFI firmware. Alternatively, grub2 from Ubuntu or Enterprise Linux can be copied to perform booting.
# reboot
Table 1. Technical users provided and required by Foreman
foreman
N/A
foreman
N/A
yes
/usr/share/foreman
/sbin/nologin
foreman-proxy
N/A
foreman-proxy
N/A
yes
/usr/share/foreman-proxy
/sbin/nologin
apache
48
apache
48
no
/usr/share/httpd
/sbin/nologin
postgres
26
postgres
26
no
/var/lib/pgsql
/bin/bash
pulp
N/A
pulp
N/A
no
N/A
/sbin/nologin
puppet
52
puppet
52
no
/sbin/nologin
saslauth
N/A
saslauth
76
no
/run/saslauthd
/sbin/nologin
tomcat
53
tomcat
53
no
/usr/share/tomcat
/bin/nologin
unbound
N/A
unbound
N/A
yes
/etc/unbound
/sbin/nologin
Foreman is a complete lifecycle management tool for physical hosts, virtual machines, and cloud instances. Key features include automated host provisioning, configuration management, and content management including patch and errata management. You can automate tasks and quickly provision hosts, all through a single unified interface.
Activation key
Activation keys are used by Subscription Manager to register hosts to Foreman. They define content view and lifecycle environment associations, content overrides, system purpose attributes, and other parameters to be associated with a newly created host.
They are associated to exactly one lifecycle environment and exactly one content view, though this may be a composite content view. You can use them on multiple machines and they behave like configuration information rather than traditional software license keys. You can also use multiple activation keys with a single host. When you register a host using an activation key, certain content from Foreman is provided to the host. The content that is made available depends on the content in the activation key’s content view and lifecycle environment, any content overrides present, any repository-level restrictions such as operating system or architecture, and system purpose attributes such as release version.
Activation key
Ansible
For more information about using Ansible to configure hosts, see Configuring hosts by using Ansible. For more information about automating Foreman using Ansible, see Managing Foreman with Ansible in Administering Foreman.
Answer file
ARF report
Audits
Boot disk
Catalog
A document that describes the desired system state for one specific host managed by Puppet. It lists all of the resources that need to be managed, as well as any dependencies between those resources. Catalogs are compiled by an OpenVox server from Puppet Manifests and data from OpenVox agents.
Candlepin
Compliance policy
Compute profile
Compute resource
Configuration Management
Container (Docker container)
Container image
Content
A general term for everything Foreman distributes to hosts. Content includes software packages such as .rpm packages, errata, or Docker images. Content is synchronized into the Library and then promoted into lifecycle environments using content views so that they can be consumed by hosts.
The mechanism used to deliver Red Hat content to Foreman server.
Content view
Content views are named and versioned collections of repositories. When you publish a content view, Foreman creates a new content view version. This content view version is a frozen snapshot of the current state of the repositories within the content view. Any subsequent changes to the underlying repositories will no longer affect the published content view version. Once a content view is published, it can be promoted through the lifecycle environment path, or modified using incremental upgrades.
Composite content view
Discovered host
Discovery image
Discovery plugin
Enables automatic bare-metal discovery of unknown hosts on the provisioning network. The plugin consists of three components: services running on Foreman server and Smart Proxy server, and the Discovery image running on host.
Discovery rule
Docker tag
Enterprise Linux
  • AlmaLinux
  • CentOS Linux
  • CentOS Stream
  • Oracle Linux
  • Red Hat Enterprise Linux
  • Rocky Linux
ERB
Errata
Facter
Facts
Foreman
Full host image
Generic image
A boot disk for PXE-less provisioning that is not tied to a specific host. The generic image sends the host’s MAC address to Foreman server, which matches it against the host entry.
Hammer
Host
Host collection
Host group
Host image
Installation Media
Installation media are sets of installation files used to install the base operating system during the provisioning process. An installation medium in Foreman represents the installation files for one or more operating systems, which must be accessible over the network, either through an URL or an NFS server location. It is usually either a mirror or a CD or DVD image.
Job
Katello
Katello is an open-source plugin to perform content management and subscription handling. It depends on Pulp for content management, which fetches software from repositories and stores various versions of it. It also depends on Candlepin for host registration and managing subscription manifests.
Lazy sync
Location
Library
A container for content from all synchronized repositories on Foreman server. Libraries exist by default for each organization as the root of every lifecycle environment path and the source of content for every content view.
Lifecycle environment path
A mechanism for transferring subscriptions from the Red Hat Customer Portal to Foreman. Do not confuse with Puppet manifest.
Migrating Foreman
OpenSCAP
Organization
Parameter
Patch and release management
Patch and release management describes the process of acquiring, managing, and installing patches and software updates to your infrastructure. Using Foreman, you can keep control of the package versions available to your hosts and deliver applicable errata.
Permission
Product
Products are named collections of one or more repositories. If you manage Red Hat content and upload a Red Hat manifest, Foreman automatically groups Red Hat content within products. If you manage SUSE content using SCC Manager plugin, Foreman automatically groups SUSE content within products. For more information, see Managing SUSE content in Managing content.
Promote (a content view)
Provisioning
  • AutoYaST for SUSE Linux Enterprise Server
  • Kickstart for AlmaLinux, Amazon Linux, CentOS, Oracle Linux, Red Hat Enterprise Linux, and Rocky Linux
  • Preseed files for Debian and Ubuntu
Publish (a content view)
Pulp
Puppet
OpenVox agent
Puppet environment
Puppet manifest
OpenVox server
Puppet module
PXE
Recurring logic
Registry
Remote execution (REX)
Repository
A repository is a single source and the smallest unit of content in Foreman. You can either synchronize a repository with a URL or manually upload content to Foreman. Foreman supports multiple content types. For more information, see Content types in Foreman in Managing content. One or more repositories form a product.
Resource type
Role
Salt
SCAP content
Smart Proxy server
Smart Proxy servers can provide DHCP, DNS, and TFTP services and act as an Ansible control node, OpenVox server, or Salt Master in separate networks. They interact with Foreman server in a client-server model. Foreman server always comes bundled with an integrated Smart Proxy.
Subnet image
Subscription
Subscription Manager is a client application to register hosts to Foreman. subscription-manager uses activation keys to consume content on hosts.
SUSE Subscription
You can use Foreman to manage SUSE content. For more information, see Managing SUSE content in Managing content.
Synchronization
Synchronization describes the process of fetching content from external repositories into the Foreman server.
Sync plan
Tailoring files
Task
Trend
Updating Foreman
The process of advancing your Foreman server and Smart Proxy server installations from one patch release to the next, for example Foreman 3.12.0 to Foreman 3.12.1.
Upgrading Foreman
The process of advancing your Foreman server and Smart Proxy server installations from one minor release to the next, for example Foreman 3.11 to Foreman 3.12.
User group
User
Virtualization
virt-who
XCCDF profiles
Appendix C: CLI help
Foreman offers multiple user interfaces: Foreman web UI, Hammer CLI, API, and through Ansible collection theforeman.foreman. If you want to administer Foreman on the command line, have a look at the following help output.
Foreman services
A set of services that Foreman server and Smart Proxy servers use for operation. You can use the foreman-maintain tool to manage these services. To see the full list of services, enter the foreman-maintain service list command on the machine where Foreman or Smart Proxy server is installed. For more information, run foreman-maintain --help on your Foreman server or Smart Proxy server.
Foreman plugins
You can extend Foreman by installing plugins. For more information, run foreman-installer --full-help on your Foreman server or Smart Proxy server.
Hammer CLI
You can manage Foreman on the command line using hammer. For more information on using Hammer CLI, see Using the Hammer CLI tool or run hammer --help on your Foreman server or Smart Proxy server.
Unsupported version
