1. Accessing Foreman
1.1. Installing the Katello Root CA Certificate
The first time you log on to Foreman, you might see a warning informing you that you are using the default self-signed certificate and you might not be able to connect this browser to Foreman until the root CA certificate is installed in the browser. Use the following procedure to locate the root CA certificate on Foreman and to install it in your browser.
  • Your Foreman is installed and configured.
  1. Identify the fully qualified domain name of your Foreman server:
    # hostname -f
  2. Access the pub directory on your Foreman server using a web browser pointed to the fully qualified domain name:
    https://foreman.example.com/pub
  3. When you access Foreman for the first time, an untrusted connection warning displays in your web browser. Accept the self-signed certificate and add the Foreman URL as a security exception to override the settings. This procedure might differ depending on the browser being used. Ensure that the Foreman URL is valid before you accept the security exception.
  4. Select katello-server-ca.crt.
  5. Import the certificate into your browser as a certificate authority and trust it to identify websites.
Importing the Katello Root CA Certificate Manually
  1. From the Foreman CLI, copy the katello-server-ca.crt file to the machine you use to access the Foreman web UI:
    # scp /var/www/html/pub/katello-server-ca.crt username@hostname:remotefile
  2. In the browser, import the katello-server-ca.crt certificate as a certificate authority and trust it to identify websites.
1.2. Logging on to Foreman
Use the web user interface to log on to Foreman for further configuration.
  2. Enter the user name and password created during the configuration process. If a user was not created during the configuration process, the default user name is admin. If you have problems logging on, you can reset the password. For more information, see Resetting the Administrative User Password.
Navigation Tabs Description
Any Context
Monitor
Content
Hosts
Configure
Infrastructure
User Name
notification bell
Administer
1.4. Changing the Password
1.5. Resetting the Administrative User Password
  1. Log on to the base operating system where Foreman server is installed.
1.6. Setting a Custom Message on the Login Page
  3. Click Save.
Foreman provides the foreman-maintain service command to manage Foreman services from the command line. This is useful when creating a backup of Foreman. For more information on creating backups, see Backing Up Foreman server and Smart Proxy server.
  1. Preparing a Host for External Databases. Prepare a Enterprise Linux 8 or Enterprise Linux 7 server to host the external databases.
Foreman, Katello, and Candlepin use the PostgreSQL database. If you want to use PostgreSQL as an external database, the following information can help you decide if this option is right for your Foreman configuration. Foreman supports PostgreSQL version 12.
Advantages of External PostgreSQL:
Install a freshly provisioned system with the latest Enterprise Linux 8 or Enterprise Linux 7 server to host the external databases.
    • For Enterprise Linux 7:
      # subscription-manager repos --enable=rhel-server-rhscl-7-rpms \
      --enable=rhel-7-server-rpms
3.3. Installing PostgreSQL
You can install only the same version of PostgreSQL that is installed with the foreman-installer tool during an internal database installation. You can install PostgreSQL using Enterprise Linux 8 or Red Hat Enterprise Linux Server 7 repositories. Foreman supports PostgreSQL version 12.
3.3.1. Installing PostgreSQL on Enterprise Linux 8
    # dnf install postgresql-server
    # postgresql-setup initdb
    listen_addresses = '*'
  5. Edit the /var/lib/pgsql/data/pg_hba.conf file:
      host  all   all   Foreman_ip/24   md5
    # systemctl start postgresql
    # systemctl enable postgresql
    $ su - postgres -c psql
  10. Create three databases and dedicated roles: one for Foreman, one for Candlepin, and one for Pulp:
  11. Exit the postgres user:
    # \q
  12. From Foreman server, test that you can access the database. If the connection succeeds, the commands return 1.
3.3.2. Installing PostgreSQL on Enterprise Linux 7
    # yum install rh-postgresql12-postgresql-server \
    rh-postgresql12-syspaths \
    rh-postgresql12-postgresql-evr
  3. Edit the /var/opt/rh/rh-postgresql12/lib/pgsql/data/postgresql.conf file:
    # vi /var/opt/rh/rh-postgresql12/lib/pgsql/data/postgresql.conf
  5. Edit the /var/opt/rh/rh-postgresql12/lib/pgsql/data/pg_hba.conf file:
    # vi /var/opt/rh/rh-postgresql12/lib/pgsql/data/pg_hba.conf
    # \q
  1. On Foreman server, stop Foreman services:
    foreman-installer --scenario foreman \
        --foreman-db-manage false \
        --foreman-proxy-content-pulpcore-postgresql-user pulp
4.1. Installing the Foreman Ansible Modules
Starting with Ansible 2.10, you can view the installed Foreman Ansible modules by running:
When using Ansible before 2.10, you can view the installed Foreman Ansible modules by listing the content of the following directory:
5. Managing Users and Roles
5.1. User Management
5.1.1. Creating a User
  2. Click Create User.
CLI procedure
    # hammer user create \
    --login My_User_Name \
    --mail My_User_Mail \
    --password My_User_Password
  7. Click Submit.
CLI procedure
5.1.4. Creating an API-Only User
Prerequisite
  1. You have created a user and assigned roles to them. Note that this user must be authorized internally. For more information, see Creating a User and Assigning Roles to a User.
    # openssl rand -hex 32
5.2. SSH Key Management
Adding SSH keys to a user allows deployment of SSH keys during provisioning. For information on deploying SSH keys during provisioning, see Deploying SSH Keys during Provisioning in the Provisioning guide.
For information on SSH keys and SSH key creation, see Using SSH-based Authentication in the Red Hat Enterprise Linux 7 System Administrator’s Guide.
Ensure that you are logged in to the Foreman web UI as an Admin user of Foreman or a user with the create_ssh_key permission enabled for adding SSH key and destroy_ssh_key permission for removing a key.
  3. Click on the SSH Keys tab.
    • To Add SSH key
      2. Click Add SSH Key.
      5. Click Submit.
    • To Remove SSH key
CLI procedure
    # hammer user ssh-keys add \
    --user-id user_id \
    --name key_name \
    --key-file ~/.ssh/id_rsa.pub
    --user-id user_id \
    --name key_name \
5.3. Managing Personal Access Tokens
5.3.1. Creating a Personal Access Token
    {"foreman_version":"2.5.0","result":"ok","status":200,"version":"3.5.1.10","api_version":2}
5.3.2. Revoking a Personal Access Token
5.4. Creating and Managing User Groups
5.4.1. User Groups
With Foreman, you can assign permissions to groups of users. You can also create user groups as collections of other user groups. If using an external authentication source, you can map Foreman user groups to external user groups as described in Configuring External User Groups.
5.4.2. Creating a User Group
  2. Click Create User group.
  5. Click Submit.
CLI procedure
    # hammer user-group create \
    --name My_User_Group_Name \
5.4.3. Removing a User Group
5.5. Creating and Managing Roles
5.5.1. Creating a Role
  2. Click Create Role.
CLI procedure
5.5.2. Cloning a Role
5.5.3. Adding Permissions to a Role
  5. Depending on the Resource type selected, you can select or deselect the Unlimited and Override checkbox. The Unlimited checkbox is selected by default, which means that the permission is applied on all resources of the selected type. When you disable the Unlimited checkbox, the Search field activates. In this field you can specify further filtering with use of the Foreman search syntax. For more information, see Granular Permission Filtering. When you enable the Override checkbox, you can add additional locations and organizations to allow the role to access the resource type in the additional locations and organizations; you can also remove an already associated location and organization from the resource type to restrict access.
  6. Click Next.
CLI procedure
  2. Add permissions to a role:
    # hammer filter create \
    --role My_Role_Name
5.5.4. Viewing Permissions of a Role
5.5.5. Creating a Complete Permission Table
    # yum install foreman-console
    # foreman-rake console
    end.join("\n")
    f.write(result)
    </table>
5.5.6. Removing a Role
5.6. Predefined Roles Available in Foreman
To view the exact set of permissions a predefined role grants, display the role in Foreman web UI as the privileged user. For more information, see Viewing Permissions of a Role.
Table 1. Permissions provided by role
Role Permissions Provided by Role
Access Insights Admin
Add and edit Insights rules.
Access Insights Viewer
View Insight reports.
Ansible Roles Manager
Bookmarks manager
Boot disk access
Download the boot disk.
Compliance manager
Compliance viewer
Create ARF report
Create compliance reports.
Default role
Discovery Manager
Discovery Reader
Edit hosts
Edit partition tables
Manager
Organization admin
Red Hat Access Logs
Remote Execution Manager
Control which roles have permission to run infrastructure jobs.
Remote Execution User
Run remote execution jobs against hosts.
Site manager
System admin
  • Edit global settings in Administer > Settings.
Tasks manager
View and edit Foreman tasks.
Tasks reader
Viewer
View hosts
Virt-who Manager
Virt-who Reporter
Virt-who Viewer
5.7. Granular Permission Filtering
5.7.1. Granular Permission Filter
5.7.2. Creating a Granular Permission Filter
field_name operator value
CLI procedure
    --permission-ids 91 \
    --search "name ~ ccv*" \
    --role qa-user
5.7.3. Examples of Using Granular Permission Filters
hostgroup = host-editors
name ^ (XXXX, Yyyy, zzzz)
Dev
5.7.4. Supported Operators for Granular Search
Table 2. Logical Operators
Operator
and
Combines search criteria.
not
Negates an expression.
has
Table 3. Symbolic Operators
Operator
6. Email Notifications
The events that trigger a notification are the following:
  • Host build
  • Content View promotion
  • Error reported by host
  • Repository sync
If you want email notifications sent to a group’s email address, instead of an individual’s email address, create a user account with the group’s email address and minimal Foreman permissions, then subscribe the user account to the desired notification types.
Foreman server does not enable outgoing emails by default, therefore you must review your email configuration. For more information, see Configuring Foreman server for Outgoing Emails in Installing Foreman server from a Connected Network.
6.1. Configuring Email Notifications
  6. Click Submit.
6.2. Testing Email Delivery
  2. Click on the username.
6.3. Testing Email Notifications
  • daily
  • weekly
  • monthly
6.4. Notification Types
The following are the notifications created by Foreman:
  • OpenSCAP policy summary: A summary of OpenSCAP policy reports and their results.
  • Puppet error state: A notification sent after a host reports an error related to Puppet.
  • Puppet summary: A summary of Puppet reports.
6.5. Changing Email Notification Settings for a Host
Security compliance management is the ongoing process of defining security policies, auditing systems for compliance with those policies, and resolving instances of non-compliance. Any non-compliance is managed according to the organization’s configuration management policies. Security policies range in scope from host-specific to industry-wide, therefore, flexibility in their definition is required.
With Foreman, you can schedule compliance auditing and reporting on all registered hosts.
Foreman uses the Security Content Automation Protocol (SCAP) standard to define security policies.
SCAP is a framework of several specifications based on XML, such as checklists described in the Extensible Checklist Configuration Description Format (XCCDF) and vulnerabilities described in the Open Vulnerability and Assessment Language (OVAL). These specifications are encapsulated as data stream files.
Checklist items in XCCDF, also known as rules, express the desired configuration of a system item. For example, a rule may specify that no one can log in to a host over SSH using the root user account. Rules can be grouped into one or more XCCDF profiles, which allows multiple profiles to share a rule.
The OpenSCAP scanner tool evaluates system items on a host against the rules and generates a report in the Asset Reporting Format (ARF), which is then returned to Foreman for monitoring and analysis.
Table 4. Specifications in the SCAP Framework 1.3 supported by the OpenSCAP scanner
Title
Version
SCAP
1.3
XCCDF
Extensible Configuration Checklist Description Format
1.2
OVAL
5.11
Asset Identification
1.1
ARF
1.1
CCE
5.0
CPE
Common Platform Enumeration
2.3
CVE
2.0
CVSS
2.0
7.2. SCAP Content in Foreman
SCAP content is a SCAP data-stream file that contains implementation of compliance, configuration, or security baselines. A single data stream usually includes multiple XCCDF profiles. An XCCDF profile defines an industry standard or custom security standard against which you can evaluate compliance of host configuration in Foreman, such as Protection Profile for General Purpose Operating Systems (OSPP), Health Insurance Portability and Accountability Act (HIPAA), and PCI-DSS v3.2.1 Control Baseline for Enterprise Linux 9. You can adapt existing XCCDF profiles according to your requirements using tailoring files.
In Foreman, you use an XCCDF profile from SCAP content and, eventually, a tailoring file, to define a compliance policy. Foreman includes default SCAP contents from SCAP Security Guide provided by the OpenSCAP project.
For more information on how to download, deploy, modify, and create your own content, see:
7.2.1. Supported SCAP Versions
Foreman supports content of SCAP versions 1.2 and 1.3.
7.3. Compliance Policy Deployment Options
You can use one of the following methods to deploy compliance policies:
Ansible deployment
You use an Ansible role to configure hosts for compliance scans.
Puppet deployment
You use a Puppet class and the Puppet agent to configure hosts for compliance scans.
Manual deployment
You manually configure hosts for compliance scans.
7.4. Installing the OpenSCAP Plug-in
You can install and enable the OpenSCAP plug-in to generate SCAP compliance reports. The OpenSCAP plug-in consists of the OpenSCAP Foreman plug-in, the OpenSCAP Hammer CLI plug-in, the OpenSCAP Smart Proxy plug-in, and the module for Puppet policy deployment.
    # foreman-installer \
    --enable-foreman-plugin-openscap \
    --enable-foreman-cli-openscap \
    --foreman-proxy-plugin-openscap-puppet-module true
  2. Optional: Install the OpenSCAP plug-in on any Smart Proxy servers:
7.5. Configuring Compliance Policy Deployment Methods
Use one the following procedures to configure Foreman for the method that you have selected to deploy compliance policies. You will select one of these methods when you later create a compliance policy.
Procedure for Ansible deployment
  1. Import the theforeman.foreman_scap_client Ansible role.
    For more information, see Configuring Foreman to use Ansible.
  2. Assign the created policy and the theforeman.foreman_scap_client Ansible role to a host or host group.
  3. To trigger the deployment, run the Ansible role on the host or host group either manually, or set up a recurring job by using remote execution for regular policy updates.
    For more information, see Configuring and Setting Up Remote Jobs in Managing Hosts.
Procedure for Puppet deployment
  1. Ensure Puppet is enabled.
  2. Ensure the Puppet agent is installed on hosts.
  3. Import the Puppet environment that contains the foreman_scap_client Puppet module.
    For more information, see Configuring Hosts Using Puppet.
  4. Assign the created policy and the foreman_scap_client Puppet class to a host or host group.
    Puppet triggers the deployment on the next regular run or you can run Puppet manually. Puppet runs every 30 minutes by default.
Procedure for manual deployment
  • For the manual deployment method, no additional Foreman configuration is required.
7.6. Listing Available SCAP Contents
Use this procedure to view what SCAP contents are already loaded in Foreman. To use the CLI instead of the Foreman web UI, see the CLI procedure.
Prerequisite
  • Your user account has the view_scap_contents permission.
  • In the Foreman web UI, navigate to Hosts > Compliance – SCAP contents.
CLI procedure
  • Run the following Hammer command on Foreman server:
    # hammer scap-content list \
    --location "My_Location" \
7.7. Configuring SCAP Contents
You can upload SCAP data streams and tailoring files to define compliance policies.
7.7.1. Loading the Default SCAP Contents
By loading the default SCAP contents on Foreman server, you ensure that the data streams from the SCAP Security Guide (SSG) are loaded and assigned to all organizations and locations.
SSG is provided by the operating system of Foreman server and installed in /usr/share/xml/scap/ssg/content/. Note that the available data streams depend on the operating system version on which Foreman runs.
  • Your user account has a role assigned that has the create_scap_contents permission.
  • Use the following Hammer command on Foreman server:
7.7.2. Getting Supported SCAP Contents for RHEL
You can get the latest SCAP Security Guide (SSG) for Red Hat Enterprise Linux on the Red Hat Customer Portal. You have to get a version of SSG that is designated for the minor RHEL version of your hosts.
  1. Access the SCAP Security Guide in the package browser.
  2. From the Version menu, select the latest SSG version for the minor version of RHEL that your hosts are running. For example, for RHEL 8.6, select a version named *.el8_6.
  3. Download the package RPM.
  4. Extract the data-stream file (*-ds.xml) from the RPM. For example:
    $ rpm2cpio scap-security-guide-0.1.69-3.el8_6.noarch.rpm \
    | cpio -iv --to-stdout ./usr/share/xml/scap/ssg/content/ssg-rhel8-ds.xml \
    > ssg-rhel-8.6-ds.xml
  5. Upload the data stream to Foreman. For more information, see Uploading Additional SCAP Content.
7.7.3. Uploading Additional SCAP Content
You can upload additional SCAP content into Foreman server, either content created by yourself or obtained elsewhere. For example, you can get the latest OpenSCAP contents for additional systems from the SSG GitHub repository. To use the CLI instead of the Foreman web UI, see the CLI procedure.
Prerequisite
  • Your user account has the create_scap_contents permission.
  • You have acquired a SCAP data-stream file.
  1. In the Foreman web UI, navigate to Hosts > Compliance > SCAP contents.
  2. Click Upload New SCAP Content.
  3. Enter a title in the Title text box, such as My SCAP Content.
  4. In Scap File, click Choose file, navigate to the location containing a SCAP data-stream file and click Open.
  5. On the Locations tab, select locations.
  6. On the Organizations tab, select organizations.
  7. Click Submit.
If the SCAP content file is loaded successfully, a message similar to Successfully created My SCAP Content is displayed.
CLI procedure
  1. Place the SCAP data-stream file to a directory on your Foreman server, such as /usr/share/xml/scap/my_content/.
  2. Run the following Hammer command on Foreman server:
    # hammer scap-content bulk-upload --type directory \
    --directory /usr/share/xml/scap/my_content/ \
7.7.4. Tailoring XCCDF Profiles
You can customize existing XCCDF profiles using tailoring files without editing the original SCAP content. A single tailoring file can contain customizations of multiple XCCDF profiles.
You can create a tailoring file using the SCAP Workbench tool. For more information on using the SCAP Workbench tool, see Customizing SCAP Security Guide for your use case.
Then you can assign a tailoring file to a compliance policy to customize an XCCDF profile in the policy.
7.7.5. Uploading a Tailoring File
After uploading a tailoring file, you can apply it in a compliance policy to customize an XCCDF profile.
Prerequisite
  • Your user account has the create_tailoring_files permission.
  1. In the Foreman web UI, navigate to Hosts > Compliance – Tailoring Files and click New Tailoring File.
  3. Click Choose File, navigate to the location containing the tailoring file and select Open.
  4. Click Submit to upload the chosen tailoring file.
7.8. Managing Compliance Policies
A compliance policy is a scheduled audit that checks the specified hosts for compliance against a specific XCCDF profile from a SCAP content.
You specify the schedule for scans on Foreman server and the scans are performed on hosts. When a scan completes, a report in ARF format is generated and uploaded to Foreman server. The compliance policy makes no changes to the scanned host.
A compliance policy defines a SCAP client configuration and a cron schedule. The policy is then deployed together with the SCAP client on hosts to which the policy is assigned.
7.8.1. Compliance Policy
A scheduled audit, also known as a compliance policy, is a scheduled task that checks the specified hosts for compliance against an XCCDF profile. The schedule for scans is specified by Foreman server and the scans are performed on the host. When a scan completes, an Asset Reporting File (ARF) is generated in XML format and uploaded to Foreman server. You can see the results of the scan in the compliance policy dashboard. No changes are made to the scanned host by the compliance policy. The SCAP content includes several profiles with associated rules but policies are not included by default.
7.8.2. Creating a Compliance Policy
By creating a compliance policy, you can define and plan your security compliance requirements, and ensure that your hosts remain compliant to your security policies.
  1. In the Foreman web UI, navigate to Hosts > Compliance – Policies.
  2. Click New Policy or New Compliance Policy.
  3. Select the deployment method: Ansible, Puppet, or Manual. Then click Next.
  4. Enter a name for this policy, a description (optional), then click Next.
  5. Select the SCAP Content and XCCDF Profile to be applied, then click Next.
    Note that Foreman does not detect whether the selected XCCDF profile contains any rules. An empty XCCDF profile, such as the Default XCCDF Profile, will return empty reports.
  6. Optional: To customize the XCCDF profile, select a Tailoring File and a XCCDF Profile in Tailoring File, then click Next.
  7. Specify the scheduled time when the policy is to be applied. Select Weekly, Monthly, or Custom from the Period list. The Custom option allows for greater flexibility in the policy’s schedule.
  8. Select the locations to which to apply the policy, then click Next.
  9. Select the organizations to which to apply the policy, then click Next.
  10. Optional: Select the host groups to which to assign the policy.
  11. Click Submit.
7.8.3. Viewing a Compliance Policy
You can preview the rules which will be applied by specific OpenSCAP content and profile combination. This is useful when you plan policies.
Prerequisite
  • Your user account has the view_policies permission.
  2. In the Actions column of the required policy, click Show Guide or select it from the list.
7.8.4. Editing a Compliance Policy
Puppet agent applies an edited policy to the host on the next run. By default, this occurs every 30 minutes. If you use Ansible, you must run the Ansible role manually again or have configured a recurring remote execution job that runs the Ansible role on hosts.
Prerequisite
  • Your user account has the view_policies and edit_policies permissions.
  2. Click the name of the required policy.
  4. Click Submit.
7.8.5. Deleting a Compliance Policy
Prerequisite
  • Your user account has the view_policies and destroy_policies permissions.
  2. In the Actions column of the required policy, select Delete from the list.
7.9. Deploying Compliance Policies
To deploy a compliance policy, you must install the SCAP client, update the cron schedule file, and upload the SCAP content selected in the policy onto a host.
7.9.1. Deploying a Policy in a Host Group Using Ansible
After you deploy a compliance policy in a host group using Ansible, the Ansible role installs the SCAP client and configures OpenSCAP scans on the hosts according to the selected compliance policy.
  1. In the Foreman web UI, navigate to Configure > Host Groups.
  2. Click the host group that you want to configure for OpenSCAP reporting.
  4. On the Ansible Roles tab, assign the theforeman.foreman_scap_client Ansible role.
  5. Optional: On the Parameters tab, configure any Ansible variables of the role.
  6. Click Submit to save your changes.
  7. In the row of the required host group, navigate to the Actions column and select Run all Ansible roles.
7.9.2. Deploying a Policy on a Host Using Ansible
After you deploy a compliance policy on a host using Ansible, the Ansible role installs the SCAP client and configures OpenSCAP scans on the host according to the selected compliance policy.
  2. From the OpenSCAP Smart Proxy list, select the Smart Proxy with OpenSCAP enabled that you want to use.
  3. On the Ansible Roles tab, add the theforeman.foreman_scap_client Ansible role.
  4. Optional: On the Parameters tab, configure any Ansible variables of the role.
  6. Click the Hosts breadcrumbs link to navigate back to the host index page.
  8. Click Select Action.
  10. In the Assign Compliance Policy window, select Remember hosts selection for the next bulk action.
  11. Select the required policy from the list of available policies and click Submit.
  12. Click Select Action.
  13. Select Run all Ansible roles from the list.
7.9.3. Deploying a Policy in a Host Group Using Puppet
After you deploy a compliance policy in a host group using Puppet, the Puppet agent installs the SCAP client and configures OpenSCAP scans on the hosts on the next Puppet run according to the selected compliance policy.
  3. In the Environment list, select the Puppet environment that contains the foreman_scap_client* Puppet classes.
  4. In the OpenSCAP Smart Proxy list, select the Smart Proxy with OpenSCAP enabled that you want to use.
  5. On the Puppet ENC tab, add the foreman_scap_client Puppet class.
  6. Optional: Configure any Puppet Class Parameters.
7.9.4. Deploying a Policy on a Host Using Puppet
After you deploy a compliance policy on a host using Puppet, the Puppet agent installs the SCAP client and configures OpenSCAP scans on the host on the next Puppet run according to the selected compliance policy.
  2. From the Environment list, select the Puppet environment that contains the foreman_scap_client and foreman_scap_client::params Puppet classes.
  4. On the Puppet ENC tab, add the foreman_scap_client Puppet class.
  5. Optional: Configure any Puppet Class Parameters.
7.10. Running a Security Compliance Scan on Demand
Hosts perform OpenSCAP scans regularly by the CRON schedule defined in the compliance policies assigned to hosts. However, you can also run a scan on a host for all configured compliance policies manually at any time.
  • Your user account has the view_hosts, create_job_invocations, and view_job_invocations permissions.
  • You have created a compliance policy and deployed it on the host.
  1. Navigate to Hosts > All Hosts.
  2. Click the hostname of the required host.
  3. On the host details page, expand the Schedule a job dropdown menu.
  4. Select Run OpenSCAP scan.
  1. In the host details overview, locate the Recent jobs card.
  2. Select the Running tab. Unless the job has already finished, the table shows a job called Run scan for all OpenSCAP policies.
  3. On the Recent jobs card, select the Finished tab.
  4. If the job has finished successfully, you should see the succeeded status in the row of the job.
  5. Optional: Click the job name to review invocation details.
7.11. Monitoring Compliance
With Foreman, you can centralize compliance monitoring and management. A compliance dashboard provides an overview of compliance of hosts and the ability to view details for each host within the scope of that policy. Compliance reports provide a detailed analysis of compliance of each host with the applicable policy. With this information, you can evaluate the risks presented by each host and manage the resources required to bring hosts into compliance. By monitoring compliance with SCAP, you can verify policy compliance and detect changes in compliance.
7.11.1. Searching Compliance Reports
Use the Compliance Reports search field to filter the list of available reports on any subset of hosts.
  2. Optional: To see a list of available search parameters, click the empty Search field.
  3. Enter the search query in the Search field and click Search. The search query is case insensitive.
Search Query Examples
Find all compliance reports for which more than five rules failed
failed > 5
Find all compliance reports created after January 1, 2023, for hosts with hostnames that contain prod-
host ~ prod- AND date > "Jan 1, 2023"
Find all reports generated by the rhel7_audit compliance policy from an hour ago
Find reports that pass an XCCDF rule
Find reports that fail an XCCDF rule
Find reports that have a result different than fail or pass for an XCCDF rule
  • You can create complex queries with the following logical operators: and, not and has. For more information about logical operators, see Supported Operators for Granular Search in Administering Foreman.
  • You cannot use regular expressions in a search query. However, you can use multiple fields in a single search expression. For more information about all available search operators, see Supported Operators for Granular Search in Administering Foreman.
  • You can bookmark a search to reuse the same search query. For more information, see Creating Bookmarks in Administering Foreman.
7.11.2. Compliance Email Notifications
Foreman server sends an OpenSCAP Summary email to all users who subscribe to the Compliance policy summary email notifications. For more information on subscribing to email notifications, see Configuring Email Notifications.
Each time a policy is run, Foreman checks the results against the previous run, noting any changes between them. The email is sent according to the frequency requested by each subscriber, providing a summary of each policy and its most recent result.
7.11.3. Viewing Compliance Policy Statistics
You can view a compliance policy dashboard to verify compliance reports of a particular policy. The compliance policy dashboard provides a statistical summary of compliance of hosts and the ability to view report details for each host within the scope of that policy.
Consider prioritizing the following hosts when viewing compliance reports:
  • Hosts which were evaluated as Failed
  • Hosts labelled as Never audited because their status is unknown
Prerequisite
  2. In the row of the required policy, navigate to the Actions column and click Dashboard.
7.11.4. Examining Hosts per Rule Compliance Result
You can examine a simplified report and use policy rules to list hosts that have a certain compliance result, such as failing a particular rule.
Prerequisite
  • Your user account has the view_arf_reports and view_hosts permissions.
  2. In the Reported At column, navigate to the report of the required host and compliance policy, and click the time link.
  3. Foreman displays a simplified list of policy rules with the results of the scan.
  4. Optional: Filter the rules by check result. From the Show log messages dropdown list, select one of the following filters:
    • Failed and othered – to view rules that have failed or have not been checked during the scan,
    • Failed only – to view only rules that have failed.
  5. Optional: Examine the details of the rule. In the Message column, click the icon next to the name of the rule.
  6. In the row of the required rule, navigate to the Actions column and click Hosts failing this rule.
7.11.5. Examining Compliance Failures of a Host
You can examine a full compliance report, determine why a host failed compliance on a rule, and, in some cases, see how to remediate a case of non-compliance.
Warning
Do not implement any of the recommended remedial actions or scripts without first testing them in a non-production environment. Remediation might render the system non-functional.
  • Introduction
  • Evaluation Characteristics
  • Compliance and Scoring
  • Rule Overview
Prerequisite
  2. In the row of the required host, navigate to the Actions column and click Full Report to view the complete details of an evaluation report.
  3. Navigate to the Evaluation Characteristics area to review basic details about the evaluation of the host against a specific profile.
  4. Navigate to the Compliance and Scoring area to review evaluation statistics and the host compliance score.
  5. Navigate to the Rule Overview to examine the rules.
  6. Optional: Deselect the check statuses that you want to hide, such as pass, notapplicable, or fixed.
  7. Optional: From the Group rule by dropdown menu, select the criterion for the grouping of rules, such as Severity.
  8. Optional: Enter a search string into the search field to filter rules by title. The search is case insensitive and applied dynamically as you type.
  9. Click the title of a rule to inspect further result details:
    • The rationale for the rule.
7.11.6. Deleting a Compliance Report
Prerequisite
  • Your user account has the view_arf_reports and destroy_arf_reports permissions.
  3. Click OK.
7.11.7. Deleting Multiple Compliance Reports
You can delete multiple compliance policies simultaneously. However, in the Foreman web UI, compliance policies are paginated, so you must delete one page of reports at a time.
Prerequisite
8. Backing Up Foreman server and Smart Proxy server
The instances created using the backup tool are not supposed to run in parallel in a production environment. You must decommission any old instances after restoring the backup.
Conventional Backup Methods
You can also use conventional backup methods. For more information, see System Backup and Recovery in the Red Hat Enterprise Linux 7 System Administrator’s Guide.
8.1. Estimating the Size of a Backup
    For Enterprise Linux 8:
    100G    /var/lib/pgsql/data
    100G	/var/lib/pulp
    886M  /var/lib/qpidd
    16M   /var/lib/tftpboot
    37M   /etc
    900K  /root/ssl-build
    100K  /var/www/html/pub
    2M    /opt/puppetlabs
    942M  total
    For Enterprise Linux 7:
    # du -sh /var/opt/rh/rh-postgresql12/lib/pgsql/data /var/lib/pulp
    100G    /var/opt/rh/rh-postgresql12/lib/pgsql/data
    100G	/var/lib/pulp
    886M  /var/lib/qpidd
    37M   /etc
    2M    /opt/puppetlabs
    942M  total
    Table 5. Backup Data Compression Ratio for Enterprise Linux 8
    PostgreSQL database files
    /var/lib/pgsql/data
    80 – 85%
    100 GB → 20 GB
    Pulp RPM files
    /var/lib/pulp
    (not compressed)
    100 GB
    Configuration files
    /var/lib/qpidd
    /var/lib/tftpboot
    /etc
    /root/ssl-build
    /var/www/html/pub
    /opt/puppetlabs
    85%
    942 MB → 141 MB
    Table 6. Backup Data Compression Ratio for Enterprise Linux 7
    80 - 85%
    100 GB → 20 GB
    Pulp RPM files
    /var/lib/pulp
    (not compressed)
    100 GB
    Configuration files
    /var/lib/qpidd
    /var/lib/tftpboot
    /etc
    /root/ssl-build
    /var/www/html/pub
    /opt/puppetlabs
    85%
    942 MB → 141 MB
8.2. Performing a Full Backup of Foreman server or Smart Proxy server
  • Offline backup
  • Online backup
  • Snapshot backups
Offline backups
Online backups
Snapshots backups
Directory creation
  • foreman-backup on Foreman
Remote databases
Warning
8.3. Performing a Backup without Pulp Content
Warning
8.4. Performing an Incremental Backup
Warning
8.5. Example of a Weekly Full Backup Followed by Daily Incremental Backups
#!/bin/bash -e
else
fi
exit 0
8.6. Performing an Online Backup
Warning
8.7. Performing a Snapshot Backup
Warning
  • The system uses LVM for the directories that you snapshot: /var/lib/pulp/, and /var/opt/rh/rh-postgresql12/lib/pgsql.
8.8. White-listing and Skipping Steps When Performing Backups
9. Restoring Foreman server or Smart Proxy server from a Backup
You can restore Foreman server or Smart Proxy server from the backup data that you create as part of Backing Up Foreman server and Smart Proxy server. This process outlines how to restore the backup on the same server that generated the backup, and all data covered by the backup is deleted on the target system. If the original system is unavailable, provision a system with the same configuration settings and host name.
9.1. Restoring from a Full Backup
    # df -h /var/backup_directory
    # restorecon -Rnv /
Additional Resources
9.2. Restoring from Incremental Backups
9.3. Backup and Restore Smart Proxy server Using a Virtual Machine Snapshot
9.3.1. Synchronizing an External Smart Proxy
10. Renaming Foreman server or Smart Proxy server
To rename Foreman server or Smart Proxy server, you must use the katello-change-hostname script.
If you rename Foreman server, you must reregister all Foreman clients and configure each Smart Proxy server to point them to the new Foreman host name. If you use custom SSL certificates, you must regenerate them with the new host name. If you use virt-who, you must update the virt-who configuration files with the new host name.
If you rename Smart Proxy server, you must reregister all Smart Proxy clients and update the Smart Proxy host name in the Foreman web UI. If you use custom SSL certificates, you must regenerate them with the new host name.
Warning
The renaming process shuts down all Foreman server services on the host being renamed. When the renaming is complete, all services are restarted.
10.1. Renaming Foreman server
The host name of Foreman server is used by Foreman server components, all Smart Proxy servers, and hosts registered to it for communication. This procedure ensures that you update all references to the new host name.
If you use external authentication, you must reconfigure Foreman server for external authentication after you run the katello-change-hostname script. The katello-change-hostname script breaks external authentication for Foreman server. For more information about configuring external authentication, see Configuring External Authentication.
If you use virt-who, you must update the virt-who configuration files with the new host name after you run the katello-change-hostname script.
  • Both the hostname and hostname -f commands must return the FQDN of Foreman server or the katello-change-hostname script will fail to complete. If the hostname command returns the shortname of Foreman server instead of the FQDN, use hostnamectl set-hostname old_fqdn to set the old FQDN correctly before attempting to use the katello-change-hostname script.
  • Perform a backup of Foreman server before changing a host name. If the renaming process is not successful, you must restore it from a backup. For more information, see Backing Up Foreman server and Smart Proxy server.
  • Optional: If Foreman server has a custom SSL certificate installed, a new certificate must be obtained for the host’s new name. For more information, see Configuring Foreman server with a Custom SSL Certificate in Installing Foreman server from a Connected Network.
  1. On Foreman server, choose the appropriate method to run the katello-change-hostname script, providing the new host name and Foreman credentials:
    • If your Foreman server is installed with default self-signed SSL certificates, enter the following command:
      --username admin \
      --password password
      --username admin \
      --password password \
  2. Optional: If you have created a custom SSL certificate for the new Foreman server host name, run the Foreman installation script to install the certificate. For more information about installing a custom SSL certificate, see Deploying a Custom SSL Certificate to Foreman server in Installing Foreman server from a Connected Network.
  3. Reregister all Foreman hosts. For more information, see Registering Hosts in Managing Hosts.
    --foreman-proxy-trusted-hosts new-foreman.example.com \
    --puppet-server-foreman-url https://new-foreman.example.com
    # hammer proxy list
    # hammer proxy_content synchronize \
    --id proxy_id_number
10.2. Renaming Smart Proxy server
The host name of Smart Proxy server is referenced by Foreman server components, and all hosts registered to it. This procedure ensures that you update all references to the new host name.
  • Both the hostname and hostname -f commands must return the FQDN of Smart Proxy server or the katello-change-hostname script will fail to complete.
  • If the hostname command returns the shortname of Smart Proxy server instead of the FQDN, use hostnamectl set-hostname old_fqdn to set the old FQDN correctly before attempting to use the katello-change-hostname script.
  • Backup Smart Proxy server. The katello-change-hostname script makes irreversible changes to Smart Proxy server. If the renaming process is not successful, you must restore it from a backup.
    Perform a backup before changing a host name. For more information, see Backing Up Foreman server and Smart Proxy server.
  1. On Foreman server, generate a new certificates archive file for Smart Proxy server.
    • If you are using the default SSL certificate, enter the following command:
      --foreman-proxy-fqdn new-smartproxy.example.com \
      --certs-tar /root/new-smartproxy.example.com-certs.tar
    • If you are using a custom SSL certificate, create a new SSL certificate for Smart Proxy server. For more information, see Configuring Smart Proxy server with a Custom SSL Certificate in Installing Smart Proxy server.
  2. On Foreman server, copy the certificates archive file to Smart Proxy server, providing the root user’s password when prompted. In this example the archive file is copied to the root user’s home directory, but you may prefer to copy it elsewhere.
  3. On Smart Proxy server, run the katello-change-hostname script and provide the host’s new name, Foreman credentials, and certificates archive filename.
    # katello-change-hostname new-smartproxy.example.com --username admin \
  4. Optional: If you have created a custom certificate for Smart Proxy server, on Smart Proxy server, to deploy the certificate, enter the foreman-installer command that the foreman-proxy-certs-generate command returns. For more information, see Deploying a Custom SSL Certificate to Smart Proxy server in Installing Smart Proxy server.
  5. On all Smart Proxy clients, enter the following commands to reinstall the bootstrap RPM, reregister clients, and refresh their subscriptions.
    You can use remote execution feature to perform this step. For more information, see Configuring and Setting up Remote Jobs in the Managing Hosts Guide.
    # yum remove -y katello-ca-consumer*
    # rpm -Uvh http://new-smartproxy.example.com/pub/katello-ca-consumer-latest.noarch.rpm
    # subscription-manager register --org="Default_Organization" \
    --environment="Library" \
    --force
    # subscription-manager refresh
  6. In the Foreman web UI, navigate to Infrastructure > Smart Proxies.
  7. Locate Smart Proxy server in the list, and click Edit to the right of it.
  8. Edit the Name and URL fields to match Smart Proxy server’s new host name, then click Submit.
  9. On your DNS server, add a record for Smart Proxy server’s new host name, and delete the record for the previous host name.
11. Maintaining Foreman server
11.1. Deleting Audit Records
Audit records are created automatically in Foreman. You can use the foreman-rake audits:expire command to remove audits at any time. You can also use a cron job to schedule audit record deletions at the set interval that you want.
By default, using the foreman-rake audits:expire command removes audit records that are older than 90 days. You can specify the number of days to keep the audit records by adding the days option and add the number of days.
11.2. Anonymizing Audit Records
11.3. Deleting Report Records
11.4. Configuring the Cleaning Unused Tasks Feature
11.5. Deleting Task Records
11.6. Deleting a Task by ID
  2. Optional: View the task:
  3. Delete the task:
11.7. Recovering from a Full Disk
    1. Remove orphaned content:
    3. Grow the file system on the LV with the /var/lib/pulp directory on it. For more information, see Growing a File System on a Logical Volume in the Red Hat Enterprise Linux 7 Logical Volume Manager Administration Guide.
      1. Stop Foreman services:
      3. Start Foreman services:
11.8. Reclaiming PostgreSQL Space
12. Logging and Reporting Problems
12.1. Enabling Debug Logging
12.2. Increasing the Logging Levels to Help with Debugging
# hammer admin logging --list
12.2.1. Increasing the Logging Level For Hammer
:log_level: 'debug'
12.2.2. Increasing the Logging Level On Smart Proxy
:log_level: DEBUG
Caution
12.2.3. Increasing the Logging Level For Candlepin
You can find the log for Candlepin in /var/log/candlepin/candlepin.log. Errors are also logged to a separate file for easier debugging /var/log/candlepin/error.log.
Extend /etc/candlepin/candlepin.conf:
log4j.logger.org.candlepin=DEBUG
Ensure to restart the tomcat service afterwards:
# systemctl restart tomcat
log4j.logger.org.candlepin.resource.ConsumerResource=WARN
log4j.logger.org.candlepin.resource.HypervisorResource=WARN
12.2.4. Increasing the Logging Level On Foreman
    :logging:
      :production:
        :type: file
        :layout: pattern
        :level: debug
    :loggers:
      :ldap:
        :enabled: true
      :permissions:
        :enabled: true
      :sql:
        :enabled: true
  3. Restart Foreman services:
12.2.5. Increasing the Logging Level For Qpid Dispatch Router
Qpid logs to syslog and can be viewed in /var/log/messages or with journalctl. Enable debug logging in /etc/qpid-dispatch/qdrouterd.conf:
enable: debug+
Ensure to restart the Qpid Dispatch Router afterwards:
# systemctl restart qdrouterd
Caution
12.2.6. Increasing the Logging Level For Qpid Broker
Qpid logs to syslog and can be viewed in /var/log/messages or with journalctl. Set the log level in /etc/qpid/qpidd.conf:
log-enable=debug+
Ensure to restart the Qpid Broker afterwards:
# systemctl restart qpidd
Caution
Running the installer will revert this change.
12.2.7. Increasing the Logging Level For Redis
loglevel debug
12.2.8. Increasing the Logging Level For Postgres
You can find the log for Postgres in /var/opt/rh/rh-postgresql12/lib/pgsql/data/log/. Uncomment the log_statement in /var/opt/rh/rh-postgresql12/lib/pgsql/data/postgresql.conf:
log_statement = 'all'
Ensure to restart Foreman services afterwards:
Caution
12.2.9. Increasing the Logging Level For Foreman Installer
12.2.10. Increasing the Logging Level For Pulp
By default, Pulp logs to syslog and can be viewed in /var/log/messages or with journalctl. Add the following config to the /etc/pulp/settings.py file:
Ensure to restart the Pulp services afterwards:
# systemctl restart \
pulpcore-api \
pulpcore-content \
pulpcore-resource-manager \
pulpcore-worker@1 \
pulpcore-worker@2 \
rh-redis5-redis
12.2.11. Increasing the Logging Level For Puppet Agent
  1. Add the following line to the [agent] block in the /etc/puppetlabs/puppet/puppet.conf file:
    [agent]
        log_level = debug
12.2.12. Increasing the Logging Level For Puppet Server
    [master]
        log_level = debug
  2. Restart the Puppet server:
12.2.13. Increasing the Logging Level For Salt
You can increase the log level for Salt Master (/etc/salt/master) and Salt Minion (/etc/salt/minion) by changing the following option:
log_level: debug
Salt Master logs to /var/log/salt/master and Salt Minions log to /var/log/salt/minion.
12.3. Retrieving the Status of Services
CLI procedure
    # hammer ping
12.4. Restarting Services
Foreman uses a set of back-end services to perform tasks. You you experience an issue with your Foreman, check the status of Foreman services.
Tip
12.5. Enabling Individual Loggers
app
audit
background
blob
dynflow
ldap
notifications
permissions
sql
telemetry
templates
    # foreman-installer \
    --foreman-loggers ldap:true \
    --foreman-loggers sql:true
12.6. Configuring Logging to Journal or File-based Logging
Foreman uses file-based logging by default. You can use the foreman-installer command to reconfigure logging.
Procedure for configuring logging with Journal
    --foreman-proxy-log JOURNAL
    --reset-foreman-logging-layout \
    --reset-foreman-proxy-log
    • /var/log/foreman-proxy.log
12.7. Log File Directories Provided by Foreman
Table 7. Log File Directories for Reporting and Troubleshooting
/var/log/candlepin
Subscription management
Installer
/var/log/foreman-maintain
Foreman maintain
Foreman proxy
/var/log/foreman
Foreman
/var/log/httpd
Apache HTTP server
/var/log/messages
Various other log messages
Configuration management
/var/log/rhsm
/var/log/tomcat
Candlepin webservice logs
12.8. Utilities for Collecting Log Information
sosreport
The collection process removes security information such as passwords, tokens, and keys while collecting information. However, the tar files can still contain sensitive information about the Foreman server. Foreman community recommends that you send this information directly to the intended recipient and not to a public target.
12.9. System Journal Metadata
Table 8. System Journal Metadata
Name Description
AUDIT_ACTION
Audit action performed
AUDIT_TYPE
Audit resource type
AUDIT_ID
AUDIT_ATTRIBUTE
AUDIT_FIELD_OLD
AUDIT_FIELD_NEW
AUDIT_ID
AUDIT_ATTRIBUTE
Example: Name or description
EXCEPTION_MESSAGE
EXCEPTION_CLASS
EXCEPTION_BACKTRACE
LOC_ID
Location database ID
LOC_NAME
Location name
LOC_LABEL
Location label
LOGGER
Logger name
ORG_ID
Organization database ID
ORG_NAME
Organization name
ORG_LABEL
Organization label
REMOTE_IP
Remote IP address of a client
REQUEST
SESSION
TEMPLATE_NAME
Template name
TEMPLATE_DIGEST
TEMPLATE_HOST_NAME
TEMPLATE_HOST_ID
USER_LOGIN
User login name
13. Configuring External Authentication
By using external authentication you can derive user and user group permissions from user group membership in an external identity provider. When you use external authentication, you do not have to create these users and maintain their group membership manually on Foreman server. In case the external source does not provide email, it will be requested during the first login through Foreman web UI.
Important User and Group Account Information
All user and group accounts must be local accounts. This is to ensure that there are no authentication conflicts between local accounts on your Foreman server and accounts in your Active Directory domain.
Your system is not affected by this conflict if your user and group accounts exist in both /etc/passwd and /etc/group files. For example, to check if entries for puppet, apache, foreman and foreman-proxy groups exist in both /etc/passwd and /etc/group files, enter the following commands:
# cat /etc/passwd | grep 'puppet\|apache\|foreman\|foreman-proxy'
# cat /etc/group | grep 'puppet\|apache\|foreman\|foreman-proxy'
Scenarios for Configuring External Authentication
Foreman supports the following general scenarios for configuring external authentication:
  • Using Lightweight Directory Access Protocol (LDAP) server as an external identity provider. LDAP is a set of open protocols used to access centrally stored information over a network. With Foreman, you can manage LDAP entirely through the Foreman web UI. For more information, see Using LDAP. Though you can use LDAP to connect to a FreeIPA or AD server, the setup does not support server discovery, cross-forest trusts, or single sign-on with Kerberos in Foreman’s web UI.
  • Using a FreeIPA server as an external identity provider. FreeIPA deals with the management of individual identities, their credentials and privileges used in a networking environment. Configuration using FreeIPA cannot be completed using only the Foreman web UI and requires some interaction with the CLI. For more information see Using FreeIPA.
  • Using Active Directory (AD) integrated with FreeIPA through cross-forest Kerberos trust as an external identity provider. For more information see Active Directory with Cross-Forest Trust.
  • Using Keycloak as an OpenID provider for external authentication to Foreman. For more information, see Configuring Foreman with Keycloak Authentication.
  • Using Keycloak as an OpenID provider for external authentication to Foreman with TOTP. For more information, see Configuring Keycloak Authentication with TOTP.
  • Using Keycloak as an OpenID provider for external authentication to Foreman with PIV cards. For more information, see Configuring Keycloak Authentication with PIV Cards.
As well as providing access to Foreman server, hosts provisioned with Foreman can also be integrated with FreeIPA realms. Foreman has a realm feature that automatically manages the life cycle of any system registered to a realm or domain provider. For more information, see External Authentication for Provisioned Hosts.
Table 9. Authentication Overview
Type Authentication User Groups
FreeIPA
Kerberos or LDAP
Active Directory
Kerberos or LDAP
POSIX
LDAP
13.1. Using LDAP
Foreman supports LDAP authentication using one or multiple LDAP directories.
If you require Foreman to use TLS to establish a secure LDAP connection (LDAPS), first obtain certificates used by the LDAP server you are connecting to and mark them as trusted on the base operating system of your Foreman server as described below. If your LDAP server uses a certificate chain with intermediate certificate authorities, all of the root and intermediate certificates in the chain must be trusted, so ensure all certificates are obtained. If you do not require secure LDAP at this time, proceed to Configuring Foreman to use LDAP.
Using SSSD Configuration
Though direct LDAP integration is covered in this section, Red Hat recommends that you use SSSD and configure it against FreeIPA, AD, or an LDAP server. SSSD improves the consistency of the authentication process. For more information about the preferred configurations, see Using Active Directory. You can also cache the SSSD credentials and use them for LDAP authentication. For more information on SSSD, see Configuring SSSD in the Red Hat Enterprise Linux 7 System-Level Authentication Guide.
Users cannot use both FreeIPA and LDAP as an authentication method. Once a user authenticates using one method, they cannot use the other method.
To change the authentication method for a user, you have to remove the automatically created user from Foreman.
For more information on using FreeIPA as an authentication method, see Using FreeIPA.
13.1.1. Configuring TLS for Secure LDAP
Use the Foreman CLI to configure TLS for secure LDAP (LDAPS).
  1. Obtain the Certificate from the LDAP Server.
    1. If you use Active Directory Certificate Services, export the Enterprise PKI CA Certificate using the Base-64 encoded X.509 format. See How to configure Active Directory authentication with TLS on Foreman for information on creating and exporting a CA certificate from an Active Directory server.
    2. Download the LDAP server certificate to a temporary location onto Foreman server and remove it when finished.
      For example, /tmp/example.crt. The filename extensions .cer and .crt are only conventions and can refer to DER binary or PEM ASCII format certificates.
  2. Trust the Certificate from the LDAP Server.
    Foreman server requires the CA certificates for LDAP authentication to be individual files in /etc/pki/tls/certs/ directory.
    1. Use the install command to install the imported certificate into the /etc/pki/tls/certs/ directory with the correct permissions:
      # install /tmp/example.crt /etc/pki/tls/certs/
    2. Enter the following command as root to trust the example.crt certificate obtained from the LDAP server:
      # ln -s example.crt /etc/pki/tls/certs/$(openssl \
      x509 -noout -hash -in \
      /etc/pki/tls/certs/example.crt).0
    3. Restart the httpd service:
      # systemctl restart httpd
13.1.2. Configuring Foreman to use LDAP
In the Foreman web UI, configure Foreman to use LDAP.
Note that if you need single sign-on functionality with Kerberos on Foreman web UI, you should use FreeIPA and AD external authentication instead. For more information, see:
  1. Set the Network Information System (NIS) service boolean to true to prevent SELinux from stopping outgoing LDAP connections:
    # setsebool -P nis_enabled on
  2. In the Foreman web UI, navigate to Administer > Authentication Sources.
  3. Click Create LDAP Authentication Source.
  4. On the LDAP server tab, enter the LDAP server’s name, host name, port, and server type. The default port is 389, the default server type is POSIX (alternatively you can select FreeIPA or Active Directory depending on the type of authentication server). For TLS encrypted connections, select the LDAPS checkbox to enable encryption. The port should change to 636, which is the default for LDAPS.
  5. On the Account tab, enter the account information and domain name details. See Description of LDAP Settings for descriptions and examples.
  6. On the Attribute mappings tab, map LDAP attributes to Foreman attributes. You can map login name, first name, last name, email address, and photo attributes. See Example Settings for LDAP Connections for examples.
  7. On the Locations tab, select locations from the left table. Selected locations are assigned to users created from the LDAP authentication source, and available after their first login.
  8. On the Organizations tab, select organizations from the left table. Selected organizations are assigned to users created from the LDAP authentication source, and available after their first login.
  9. Click Submit.
  10. Configure new accounts for LDAP users:
    • If you did not select Automatically Create Accounts In Foreman checkbox, see Creating a User to create user accounts manually.
    • If you selected the Automatically Create Accounts In Foreman checkbox, LDAP users can now log in to Foreman using their LDAP accounts and passwords. After they log in for the first time, the Foreman administrator has to assign roles to them manually. See Assigning Roles to a User to assign user accounts appropriate roles in Foreman.
13.1.3. Description of LDAP Settings
Table 10. Account Tab Settings
Setting Description
Account
The user name of the LDAP account that has read access to the LDAP server. User name is not required if the server allows anonymous reading, otherwise use the full path to the user’s object. For example:
uid=$login,cn=users,cn=accounts,dc=example,dc=com
The $login variable stores the username entered on the login page as a literal string. The value is accessed when the variable is expanded.
The variable cannot be used with external user groups from an LDAP source because Foreman needs to retrieve the group list without the user logging in. Use either an anonymous, or dedicated service user.
Account password
The LDAP password for the user defined in the Account username field. This field can remain blank if the Account username is using the $login variable.
Base DN
The top level domain name of the LDAP directory.
Groups base DN
The top level domain name of the LDAP directory tree that contains groups.
LDAP filter
A filter to restrict LDAP queries.
If this checkbox is selected, Foreman creates user accounts for LDAP users when they log in to Foreman for the first time. After they log in for the first time, the Foreman administrator has to assign roles to them manually. See Assigning Roles to a User to assign user accounts appropriate roles in Foreman.
Usergroup Sync
If this option is selected, the user group membership of a user is automatically synchronized when the user logs in, which ensures the membership is always up to date. If this option is cleared, Foreman relies on a cron job to regularly synchronize group membership (every 30 minutes by default). For more information, see Configuring External User Groups.
13.1.4. Example Settings for LDAP Connections
Table 11. Example Settings for Active Directory, Free IPA or Red Hat Identity Management and POSIX LDAP Connections
Setting Active Directory FreeIPA or Red Hat Identity Management POSIX (OpenLDAP)
Account
DOMAIN\redhat
uid=redhat,cn=users, cn=accounts,dc=example, dc=com
uid=redhat,ou=users, dc=example,dc=com
Account password
P@ssword
Base DN
DC=example,DC=COM
dc=example,dc=com
dc=example,dc=com
Groups Base DN
CN=Users,DC=example,DC=com
cn=groups,cn=accounts, dc=example,dc=com
cn=employee,ou=userclass, dc=example,dc=com
Login name attribute
userPrincipalName
uid
uid
First name attribute
givenName
givenName
givenName
Last name attribute
sn
sn
sn
Email address attribute
mail
mail
mail
Photo attribute
thumbnailPhoto
userPrincipalName allows the use of whitespace in usernames. The login name attribute sAMAccountName (which is not listed in the table above) provides backwards compatibility with legacy Microsoft systems. sAMAccountName does not allow the use of whitespace in usernames.
13.1.5. Example LDAP Filters
As an administrator, you can create LDAP filters to restrict the access of specific users to Foreman.
Table 12. Example filters for allowing specific users to login
User Filter
User1
(distinguishedName=cn=User1,cn=Users,dc=domain,dc=example)
User1, User3
(memberOf=cn=Group1,cn=Users,dc=domain,dc=example)
User2, User3
(memberOf=cn=Group2,cn=Users,dc=domain,dc=example)
User1, User2, User3
(|(memberOf=cn=Group1,cn=Users,dc=domain,dc=example)(memberOf=cn=Group2,cn=Users,dc=domain,dc=example))
User1, User2, User3
(memberOf:1.2.840.113556.1.4.1941:=cn=Users,dc=domain,dc=example)
Group Users is a nested group that contains groups Group1 and Group2. If you want to filter all users from a nested group, you must add memberOf:1.2.840.113556.1.4.1941:= before the nested group name. See the last example in the table above.
LDAP directory structure
DC=Domain,DC=Example
   |----- CN=Users
         |----- CN=Group1
         |----- CN=Group2
         |----- CN=User1
         |----- CN=User2
         |----- CN=User3
LDAP group membership
Group Members
Group1
User1, User3
Group2
User2, User3
13.2. Using FreeIPA
This section shows how to integrate Foreman server with a FreeIPA server and how to enable host-based access control.
You can attach FreeIPA as an external authentication source with no single sign-on support. For more information, see Using LDAP.
Prerequisite
  • The base operating system of Foreman server must be enrolled in the FreeIPA domain by the FreeIPA administrator of your organization.
The examples in this chapter assume separation between FreeIPA and Foreman configuration. However, if you have administrator privileges for both servers, you can configure FreeIPA as described in Red Hat Enterprise Linux 7 Linux Domain Identity, Authentication, and Policy Guide.
13.2.1. Configuring FreeIPA Authentication on Foreman server
In the Foreman CLI, configure FreeIPA authentication by first creating a host entry on the FreeIPA server.
  1. On the FreeIPA server, to authenticate, enter the following command and enter your password when prompted:
    # kinit admin
  2. To verify that you have authenticated, enter the following command:
    # klist
  3. On the FreeIPA server, create a host entry for Foreman server and generate a one-time password, for example:
    The generated one-time password must be used on the client to complete FreeIPA-enrollment.
    For more information on host configuration properties, see About Host Entry Configuration Properties in the Red Hat Enterprise Linux 7 Linux Domain Identity, Authentication, and Policy guide.
  4. Create an HTTP service for Foreman server, for example:
    # ipa service-add HTTP/hostname
    For more information on managing services, see Managing Services in the Red Hat Enterprise Linux 7 Linux Domain Identity, Authentication, and Policy guide.
  5. On Foreman server, install the IPA client:
    # yum install ipa-client
  6. On Foreman server, enter the following command as root to configure FreeIPA-enrollment:
  7. If Foreman server is running on Red Hat Enterprise Linux 7, execute the following command:
    The installer is dependent on packages which, on Red Hat Enterprise Linux 7, are in the optional repository rhel-7-server-optional-rpms.
  8. If Foreman server is running on Debian, ensure that the hostname is set to the fully qualified domain name (FQDN); the short name is not sufficient:
    # hostname
    foreman.example.com
    Otherwise the installer cannot generate the right principal name that is needed to join the realm.
  9. Set foreman-ipa-authentication to true, using the following command:
    # foreman-installer --foreman-ipa-authentication=true
  10. Restart Foreman services:
External users can now log in to Foreman using their FreeIPA credentials. They can now choose to either log in to Foreman server directly using their username and password or take advantage of the configured Kerberos single sign-on and obtain a ticket on their client machine and be logged in automatically. The two-factor authentication with one-time password (2FA OTP) is also supported. If the user in FreeIPA is configured for 2FA, and Foreman server is running on Red Hat Enterprise Linux 7, this user can also authenticate to Foreman with an OTP.
13.2.2. Configuring Host-Based Authentication Control
HBAC rules define which machine within the domain a FreeIPA user is allowed to access. You can configure HBAC on the FreeIPA server to prevent selected users from accessing Foreman server. With this approach, you can prevent Foreman from creating database entries for users that are not allowed to log in. For more information on HBAC, see Configuring Host-Based Access Control in the Red Hat Enterprise Linux 7 Linux Domain Identity, Authentication, and Policy guide.
    # kinit admin
    # klist
  3. Create HBAC service and rule on the FreeIPA server and link them together. The following examples use the PAM service name foreman-prod. Execute the following commands on the FreeIPA server:
    # ipa hbacsvc-add foreman-prod
    # ipa hbacrule-add allow_foreman_prod
    # ipa hbacrule-add-service allow_foreman_prod --hbacsvcs=foreman-prod
  4. Add the user who is to have access to the service foreman-prod, and the hostname of Foreman server:
    # ipa hbacrule-add-user allow_foreman_prod --user=username
    # ipa hbacrule-add-host allow_foreman_prod --hosts=foreman.example.com
    Alternatively, host groups and user groups can be added to the allowforeman_prod_ rule.
  5. To check the status of the rule, execute:
    # ipa hbacrule-find foreman-prod
    # ipa hbactest --user=username --host=foreman.example.com --service=foreman-prod
  6. Ensure the allow_all rule is disabled on the FreeIPA server. For instructions on how to do so without disrupting other services see the How to configure HBAC rules in IdM article on the Red Hat Customer Portal.
  7. Configure the FreeIPA integration with Foreman server as described in Configuring FreeIPA Authentication on Foreman server. On Foreman server, define the PAM service as root:
    # foreman-installer --foreman-pam-service=foreman-prod
13.3. Using Active Directory
This section shows how to use direct Active Directory (AD) as an external authentication source for Foreman server.
You can attach Active Directory as an external authentication source with no single sign-on support. For more information, see Using LDAP. For an example configuration, see How to configure Active Directory authentication with TLS on Foreman.
Direct AD integration means that Foreman server is joined directly to the AD domain where the identity is stored. The recommended setup consists of two steps:
13.3.1. GSS-Proxy
The traditional process of Kerberos authentication in Apache requires the Apache process to have read access to the keytab file. GSS-Proxy allows you to implement stricter privilege separation for the Apache server by removing access to the keytab file while preserving Kerberos authentication functionality. When using AD as an external authentication source for Foreman, it is recommended to implement GSS-proxy, because the keys in the keytab file are the same as the host keys.
Perform the following procedures on Enterprise Linux that acts as a base operating system for your Foreman server. For the examples in this section EXAMPLE.ORG is the Kerberos realm for the AD domain. By completing the procedures, users that belong to the EXAMPLE.ORG realm can log in to Foreman server.
13.3.2. Enrolling Foreman server with the AD Server
In the Foreman CLI, enroll Foreman server with the Active Directory server.
Prerequisite
  • GSS-proxy and nfs-utils are installed.
    # yum install gssproxy nfs-utils
  1. Install the required packages:
  2. Enroll Foreman server with the AD server. You may need to have administrator permissions to perform the following command:
    # realm join -v EXAMPLE.ORG --membership-software=samba -U Administrator
13.3.3. Configuring Direct AD Integration with GSS-Proxy
In the Foreman CLI, configure the direct Active Directory integration with GSS-proxy.
Prerequisite
  1. Create the /etc/ipa/ directory and the default.conf file:
    # mkdir /etc/ipa
    # touch /etc/ipa/default.conf
  2. To the default.conf file, add the following content:
    [global]
    server = unused
    realm = EXAMPLE.ORG
  3. Create the /etc/net-keytab.conf file with the following content:
    [global]
    workgroup = EXAMPLE
    realm = EXAMPLE.ORG
    kerberos method = system keytab
    security = ads
  4. Determine the effective user ID of the Apache user:
    # id apache
  5. Create the /etc/gssproxy/00-http.conf file with the following content:
    [service/HTTP]
    mechs = krb5
    cred_store = keytab:/etc/httpd/conf/http.keytab
    cred_store = ccache:/var/lib/gssproxy/clients/krb5cc_%U
    euid = ID_of_Apache_User
  6. Create a keytab entry:
    # KRB5_KTNAME=FILE:/etc/httpd/conf/http.keytab net ads keytab add HTTP -U administrator -d3 -s /etc/net-keytab.conf
    # chown root.apache /etc/httpd/conf/http.keytab
    # chmod 640 /etc/httpd/conf/http.keytab
  7. Enable IPA authentication in Foreman:
  8. Start and enable the gssproxy service:
    # systemctl restart gssproxy.service
    # systemctl enable gssproxy.service
  9. To configure the Apache server to use the gssproxy service, create a systemd drop-in file and add the following content to it:
    # mkdir -p /etc/systemd/system/httpd.service.d/
    # vi /etc/systemd/system/httpd.service.d/gssproxy.conf
    [Service]
    Environment=GSS_USE_PROXY=1
  10. Apply changes to the service:
    # systemctl daemon-reload
  11. Start and enable the httpd service:
    # systemctl restart httpd.service
With direct AD integration, HBAC through FreeIPA is not available. As an alternative, you can use Group Policy Objects (GPO) that enable administrators to centrally manage policies in AD environments. To ensure correct GPO to PAM service mapping, add the following SSSD configuration to /etc/sssd/sssd.conf:
access_provider = ad
ad_gpo_access_control = enforcing
ad_gpo_map_service = +foreman
Here, foreman is the PAM service name.
Verify that SSO is working as expected.
  1. Retrieve the Kerberos ticket of the LDAP user, using the following command:
    # kinit ldapuser
  2. View the Kerberos ticket, using the following command:
    # klist
  3. View output from successful SSO-based authentication, using the following command:
    # curl -k -u : --negotiate https://foreman.example.com/users/extlogin
    <html><body>You are being <a href="https://foreman.example.com/users/4-ldapuserexample-com/edit">redirected</a>.</body></html>
13.3.4. Kerberos Configuration in Web Browsers
For information on configuring the Firefox browser see Configuring Firefox to Use Kerberos for Single Sign-On in the Red Hat Enterprise Linux System-Level Authentication guide.
If you use the Internet Explorer browser, add Foreman server to the list of Local Intranet or Trusted sites, and turn on the Enable Integrated Windows Authentication setting. See the Internet Explorer documentation for details.
13.3.5. Active Directory with Cross-Forest Trust
Kerberos can create cross-forest trust that defines a relationship between two otherwise separate domain forests. A domain forest is a hierarchical structure of domains; both AD and FreeIPA constitute a forest. With a trust relationship enabled between AD and FreeIPA, users of AD can access Linux hosts and services using a single set of credentials. For more information on cross-forest trusts, see Creating Cross-forest Trusts with Active Directory and Identity Management in the Red Hat Enterprise Linux Windows Integration guide.
From the Foreman point of view, the configuration process is the same as integration with FreeIPA server without cross-forest trust configured. Foreman server has to be enrolled in the IdM domain and integrated as described in Using FreeIPA.
13.3.6. Configuring the FreeIPA Server to Use Cross-Forest Trust
  1. Enable HBAC:
    1. Create an external group and add the AD group to it.
    2. Add the new external group to a POSIX group.
    3. Use the POSIX group in a HBAC rule.
  2. Configure sssd to transfer additional attributes of AD users.
    • Add the AD user attributes to the nss and domain sections in /etc/sssd/sssd.conf. For example:
      [nss]
      user_attributes=+mail, +sn, +givenname
      [domain/EXAMPLE.com]
      krb5_store_password_if_offline = True
      ldap_user_extra_attrs=email:mail, lastname:sn, firstname:givenname
      [ifp]
      allowed_uids = ipaapi, root
      user_attributes=+email, +firstname, +lastname
    • Verify the AD attributes value.
      # dbus-send --print-reply --system --dest=org.freedesktop.sssd.infopipe /org/freedesktop/sssd/infopipe org.freedesktop.sssd.infopipe.GetUserAttr string:ad-user@ad-domain array:string:email,firstname,lastname
13.4. Configuring External User Groups
Foreman does not associate external users with their user group automatically. You must create a user group with the same name as in the external source on Foreman. Members of the external user group then automatically become members of the Foreman user group and receive the associated permissions.
  • If you use an LDAP server, configure Foreman to use LDAP authentication. For more information see Using LDAP.
    When using external user groups from an LDAP source, you cannot use the $login variable as a substitute for the account user name. You must use either an anonymous or dedicated service user.
  • If you use a FreeIPA or AD server, configure Foreman to use FreeIPA or AD authentication. For more information, see Configuring External Authentication.
  • Ensure that at least one external user authenticates for the first time.
  • Retain a copy of the external group names you want to use. To find the group membership of external users, enter the following command:
    # id username
  1. In the Foreman web UI, navigate to Administer > User Groups, and click Create User Group.
  2. Specify the name of the new user group. Do not select any users to avoid adding users automatically when you refresh the external user group.
  3. Click the Roles tab and select the roles you want to assign to the user group. Alternatively, select the Administrator checkbox to assign all available permissions.
  4. Click the External groups tab, then click Add external user group, and select an authentication source from the Auth source drop-down menu.
  5. Click Submit.
13.5. Refreshing External User Groups for LDAP
  1. In the Foreman web UI, navigate to Administer > Usergroups and select a user group.
  2. On the External Groups tab, click Refresh to the right of the required user group.
CLI procedure
  • Enter the following command:
13.6. Refreshing External User Groups for FreeIPA or AD
External user groups based on FreeIPA or AD are refreshed only when a group member logs in to Foreman. It is not possible to alter user membership of external user groups in the Foreman web UI, such changes are overwritten on the next group refresh.
13.7. External Authentication for Provisioned Hosts
Use this section to configure Foreman server or Smart Proxy server for FreeIPA realm support, then add hosts to the FreeIPA realm group.
  • Foreman server that is registered to the Content Delivery Network or an external Smart Proxy server that is registered to Foreman server.
  • A deployed realm or domain provider such as FreeIPA.
To install and configure FreeIPA packages on Foreman server or Smart Proxy server:
To use FreeIPA for provisioned hosts, complete the following steps to install and configure FreeIPA packages on Foreman server or Smart Proxy server:
  1. Install the ipa-client package on Foreman server or Smart Proxy server:
  2. Configure the server as a FreeIPA client:
  3. Create a realm proxy user, realm-smart-proxy, and the relevant roles in FreeIPA:
    # foreman-prepare-realm admin realm-smart-proxy
To configure Foreman server or Smart Proxy server for FreeIPA Realm Support:
Complete the following procedure on Foreman and every Smart Proxy that you want to use:
  1. Copy the /root/freeipa.keytab file to any Smart Proxy server that you want to include in the same principal and realm:
    # scp /root/freeipa.keytab root@smartproxy.example.com:/etc/foreman-proxy/freeipa.keytab
  2. Move the /root/freeipa.keytab file to the /etc/foreman-proxy directory and set the ownership settings to the foreman-proxy user:
    # mv /root/freeipa.keytab /etc/foreman-proxy
    # chown foreman-proxy:foreman-proxy /etc/foreman-proxy/freeipa.keytab
  3. Enter the following command on all Smart Proxies that you want to include in the realm. If you use the integrated Smart Proxy on Foreman, enter this command on Foreman server:
    # foreman-installer --foreman-proxy-realm true \
    --foreman-proxy-realm-keytab /etc/foreman-proxy/freeipa.keytab \
    --foreman-proxy-realm-principal realm-smart-proxy@EXAMPLE.COM \
    --foreman-proxy-realm-provider freeipa
    You can also use these options when you first configure the Foreman server.
  4. Ensure that the most updated versions of the ca-certificates package is installed and trust the FreeIPA Certificate Authority:
    # cp /etc/ipa/ca.crt /etc/pki/ca-trust/source/anchors/ipa.crt
    # update-ca-trust enable
    # update-ca-trust
  5. Optional: If you configure FreeIPA on an existing Foreman server or Smart Proxy server, complete the following steps to ensure that the configuration changes take effect:
    1. Restart the foreman-proxy service:
    2. In the Foreman web UI, navigate to Infrastructure > Smart Proxies.
    3. Locate the Smart Proxy you have configured for FreeIPA and from the list in the Actions column, select Refresh.
To create a realm for the FreeIPA-enabled Smart Proxy
After you configure your integrated or external Smart Proxy with FreeIPA, you must create a realm and add the FreeIPA-configured Smart Proxy to the realm.
  1. In the Foreman web UI, navigate to Infrastructure > Realms and click Create Realm.
  2. In the Name field, enter a name for the realm.
  3. From the Realm Type list, select the type of realm.
  4. From the Realm Smart Proxy list, select Smart Proxy server where you have configured FreeIPA.
  5. Click the Locations tab and from the Locations list, select the location where you want to add the new realm.
  6. Click the Organizations tab and from the Organizations list, select the organization where you want to add the new realm.
  7. Click Submit.
Updating Host Groups with Realm Information
  1. In the Foreman web UI, navigate to Configure > Host Groups, select the host group that you want to update, and click the Network tab.
  2. From the Realm list, select the realm you create as part of this procedure, and then click Submit.
Adding Hosts to a FreeIPA Host Group
FreeIPA supports the ability to set up automatic membership rules based on a system’s attributes. Foreman’s realm feature provides administrators with the ability to map the Foreman host groups to the FreeIPA parameter userclass which allow administrators to configure automembership.
When nested host groups are used, they are sent to the FreeIPA server as they are displayed in the Foreman User Interface. For example, "Parent/Child/Child".
Foreman server or Smart Proxy server sends updates to the FreeIPA server, however automembership rules are only applied at initial registration.
To Add Hosts to a FreeIPA Host Group:
  1. On the FreeIPA server, create a host group:
  2. Create an automembership rule:
    # ipa automember-add --type=hostgroup hostgroup_name automember_rule
    • automember-add flags the group as an automember group.
    • --type=hostgroup identifies that the target group is a host group, not a user group.
    • automember_rule adds the name you want to identify the automember rule by.
  3. Define an automembership condition based on the userclass attribute:
    # ipa automember-add-condition --key=userclass --type=hostgroup --inclusive-regex=^webserver hostgroup_name
    Added condition(s) to "hostgroup_name"
    Automember Rule: automember_rule
    Inclusive Regex: userclass=^webserver
    Number of conditions added 1
    • automember-add-condition adds regular expression conditions to identify group members.
    • --key=userclass specifies the key attribute as userclass.
    • --inclusive-regex= ^webserver identifies matching values with a regular expression pattern.
    • hostgroup_name – identifies the target host group’s name.
When a system is added to Foreman server’s hostgroup_name host group, it is added automatically to the FreeIPA server’s "hostgroup_name" host group. FreeIPA host groups allow for Host-Based Access Controls (HBAC), sudo policies and other FreeIPA functions.
13.8. Configuring Foreman with Keycloak Authentication
Use this section to configure Foreman to use Keycloak as an OpenID provider for external authentication.
13.8.1. Prerequisites for Configuring Foreman with Keycloak Authentication
Before configuring Foreman with Keycloak external authentication, ensure that you meet the following requirements:
  • A working installation of Keycloak server that uses HTTPS instead of HTTP.
  • A Keycloak account with admin privileges.
  • A realm for Foreman user accounts created in Keycloak.
  • If the certificates or the CA are self-signed, ensure that they are added to the end-user certificate trust store.
  • Users imported or added to Keycloak.
    If you have an existing user database configured such as LDAP or Kerberos, you can import users from it by configuring user federation. For more information, see User Storage Federation in the Red Hat Single Sign-On Server Administration Guide.
    If you do not have an existing user database configured, you can manually create users in Keycloak. For more information, see Creating New Users in the Red Hat Single Sign-On Server Administration Guide.
13.8.2. Registering Foreman as a Keycloak Client
Use this procedure to register Foreman to Keycloak as a client and configure Foreman to use Keycloak as an authentication source.
You can configure Foreman and Keycloak with two different authentication methods:
  1. Users authenticate to Foreman using the Foreman web UI.
  2. Users authenticate to Foreman using the Foreman CLI.
You must decide on how you want your users to authenticate in advance because both methods require different Foreman clients to be registered to Keycloak and configured. The steps to register and configure Foreman client in Keycloak are distinguished within the procedure.
You can also register two different Foreman clients to Keycloak if you want to use both authentication methods and configure both clients accordingly.
  1. On the Foreman server, install the following packages:
  2. Register Foreman to Keycloak as a client. Note that you the registration process for logging in using the web UI and the CLI are different. You can register two clients Foreman clients to Keycloak to be able to log in to Foreman from the web UI and the CLI.
    • If you want you users to authenticate to Foreman using the web UI, create a client as follows:
      # keycloak-httpd-client-install --app-name foreman-openidc \
      --keycloak-server-url "https://Keycloak.example.com" \
      --keycloak-admin-username "admin" \
      --keycloak-realm "Foreman_Realm" \
      --keycloak-admin-realm master \
      --keycloak-auth-role root-admin \
      -t openidc -l /users/extlogin --force
      Enter the password for the administer account when prompted. This command creates a client for Foreman in Keycloak.
      Then, configure Foreman to use Keycloak as an authentication source:
      # foreman-installer --foreman-keycloak true \
      --foreman-keycloak-app-name "foreman-openidc" \
      --foreman-keycloak-realm "Foreman_Realm"
    • If you want your users to authenticate to Foreman using the CLI, create a client as follows:
      # keycloak-httpd-client-install --app-name hammer-openidc \
13.8.3. Configuring the Foreman Client in Keycloak
Use this procedure to configure the Foreman client in the Keycloak web UI and create group and audience mappers for the Foreman client.
  1. In the Keycloak web UI, navigate to Clients and click the Foreman client.
  2. Configure access type:
    • If you want your users to authenticate to Foreman using the Foreman web UI, from the Access Type list, select confidential.
    • If you want your users to authenticate to Foreman using the CLI, from the Access Type list, select public.
  3. In the Valid redirect URI fields, add a valid redirect URI.
    • If you want your users to authenticate to Foreman using the Foreman web UI, in the blank field below the existing URI, enter a URI in the form https://foreman.example.com/users/extlogin. Note that you must add the string /users/extlogin after the Foreman FQDN.
      After completing this step, the Foreman client for logging in using the Foreman web UI must have the following Valid Redirect URIs:
      https://foreman.example.com/users/extlogin/redirect_uri
    • If you want your users to authenticate to Foreman using the CLI, in the blank field below the existing URI, enter urn:ietf:wg:oauth:2.0:oob.
      After completing this step, the Foreman client for logging in using the CLI must have the following Valid Redirect URIs:
  4. Click Save.
  5. Click the Mappers tab and click Create to add an audience mapper.
  6. In the Name field, enter a name for the audience mapper.
  7. From the Mapper Type list, select Audience.
  8. From the Included Client Audience list, select the Foreman client.
  9. Click Save.
  10. Click Create to add a group mapper so that you can specify authorization in Foreman based on group membership.
  11. In the Name field, enter a name for the group mapper.
  12. From the Mapper Type list, select Group Membership.
  13. In the Token Claim Name field, enter groups.
  14. Set the Full group path setting to OFF.
  15. Click Save.
13.8.4. Configuring Foreman Settings for Keycloak Authentication
Use this section to configure Foreman for Keycloak authentication using the Foreman web UI or the CLI.
Configuring Foreman Settings for Keycloak Authentication Using the Web UI
Use this procedure to configure Foreman settings for Keycloak authentication using the Foreman web UI.
Note that you can navigate to the following URL within your realm to obtain values to configure Foreman settings: https://Keycloak.example.com/auth/realms/Foreman_Realm/.well-known/openid-configuration
Prerequisite
  • Ensure that the Access Type setting in the Foreman client in the Keycloak web UI is set to confidential
  1. In the Foreman web UI, navigate to Administer > Settings, and click the Authentication tab.
  2. Locate the Authorize login delegation row, and in the Value column, set the value to Yes.
  3. Locate the Authorize login delegation auth source user autocreate row, and in the Value column, set the value to External.
  4. Locate the Login delegation logout URL row, and in the Value column, set the value to https://foreman.example.com/users/extlogout.
  5. Locate the OIDC Algorithm row, and in the Value column, set the algorithm for encoding on Keycloak to RS256.
  6. Locate the OIDC Audience row, and in the Value column, set the value to the client ID for Keycloak.
  7. Locate the OIDC Issuer row, and in the Value column, set the value to https://Keycloak.example.com/auth/realms/Foreman_Realm.
  8. Locate the OIDC JWKs URL row, and in the Value column, set the value to https://Keycloak.example.com/auth/realms/Foreman_Realm/protocol/openid-connect/certs.
  9. In the Foreman web UI, navigate to Administer > Authentication Sources, click the vertical ellipsis on the External card, and select Edit.
  10. Click the Locations tab and add locations that can use the Keycloak authentication source.
  11. Click the Organizations tab and add organizations that can use the Keycloak authentication source.
  12. Click Submit.
Configuring Foreman Settings for Keycloak Authentication Using the CLI
Use this procedure to configure Foreman settings for Keycloak authentication using the Foreman CLI.
Prerequisite
  • Ensure that the Access Type setting in the Foreman client in the Keycloak web UI is set to public
  1. On Foreman, set the login delegation to true so that users can authenticate using the Open IDC protocol:
    # hammer settings set --name authorize_login_delegation --value true
  2. Set the login delegation logout URL:
    # hammer settings set --name login_delegation_logout_url \
    --value https://foreman.example.com/users/extlogout
  3. Set the algorithm for encoding on Keycloak, for example, RS256:
    # hammer settings set --name oidc_algorithm --value 'RS256'
  4. Open the Keycloak.example.com/auth/realms/Keycloak_REALM/.well-known/openid-configuration URL and note the values to populate the options in the following steps.
  5. Add the value for the Hammer client in the Open IDC audience:
    # hammer settings set --name oidc_audience \
    --value "['foreman.example.com-hammer-openidc']"
    If you register several Keycloak clients to Foreman, ensure that you append all audiences in the array. For example:
    --value "['foreman.example.com-foreman-openidc', 'foreman.example.com-hammer-openidc']"
  6. Set the value for the Open IDC issuer:
    # hammer settings set --name oidc_issuer \
    --value "Keycloak.example.com/auth/realms/Keycloak_Realm"
  7. Set the value for Open IDC Java Web Token (JWT):
    # hammer settings set --name oidc_jwks_url \
    --value "Keycloak.example.com/auth/realms/Keycloak_Realm/protocol/openid-connect/certs"
  8. Retrieve the ID of the Keycloak authentication source:
  9. Set the location and organization:
    # hammer auth-source external update --id Authentication Source ID \
    --location-ids Location ID --organization-ids Organization ID
13.8.5. Logging in to the Foreman web UI Using Keycloak
Use this procedure to log in to the Foreman web UI using Keycloak.
  • In your browser, log in to Foreman and enter your credentials.
13.8.6. Logging in to the Foreman CLI Using Keycloak
Use this procedure to authenticate to the Foreman CLI using the code grant type.
  1. To authenticate to the Foreman CLI using the code grant type, enter the following command:
    # hammer auth login oauth \
    --two-factor \
    --oidc-token-endpoint 'https://Keycloak.example.com/auth/realms/ssl-realm/protocol/openid-connect/token' \
    --oidc-authorization-endpoint 'https://Keycloak.example.com/auth' \
    --oidc-client-id 'foreman.example.com-foreman-openidc' \
    --oidc-redirect-uri urn:ietf:wg:oauth:2.0:oob
  2. To retrieve the success code, navigate to the URL that the command returns and provide the required information.
  3. Copy the success code that the web UI returns.
  4. In the command prompt of hammer auth login oauth, enter the success code to authenticate to the Foreman CLI.
13.8.7. Configuring Group Mapping for Keycloak Authentication
Optionally, to implement the Role Based Access Control (RBAC), create a group in Foreman, assign a role to this group, and then map an Active Directory group to the Foreman group. As a result, anyone in the given group in Keycloak are logged in under the corresponding Foreman group. This example configures users of the Foreman-admin user group in the Active Directory to authenticate as users with administrator privileges on Foreman.
  1. In the Foreman web UI, navigate to Administer > User Groups, and click the Create User Group button.
  2. In the Name field, enter a name for the user group. The name should not be the same as in the Active Directory.
  3. Do not add users and user groups to the right-hand columns. Click the Roles tab.
  4. Select the Administer checkbox.
  5. Click the External Groups tab.
  6. Click Add external user group.
  7. In the Name field, enter the name of the Active Directory group.
  8. From the list, select EXTERNAL.
13.9. Configuring Keycloak Authentication with TOTP
Use this section to configure Foreman to use Keycloak as an OpenID provider for external authentication with TOTP cards.
13.9.1. Prerequisites for Configuring Foreman with Keycloak Authentication
13.9.2. Registering Foreman as a Keycloak Client
13.9.3. Configuring the Foreman Client in Keycloak
  4. Click Save.
  9. Click Save.
  15. Click Save.
13.9.4. Configuring Foreman Settings for Keycloak Authentication
Prerequisite
  12. Click Submit.
Prerequisite
13.9.5. Configuring Foreman with Keycloak for TOTP Authentication
Use this procedure to configure Foreman to use Keycloak as an OpenID provider for external authentication with Time-based One-time Password (TOTP).
  1. In the Keycloak web UI, navigate to the Foreman realm.
  2. Navigate to Authentication, and click the OTP Policy tab.
  3. Ensure that the Supported Applications field includes FreeOTP or Google Authenticator.
  4. Configure the OTP settings to suit your requirements.
  5. Optional: If you want to use TOTP authentication as a default authentication method for all users, click the Flows tab, and to the right of the OTP Form setting, select REQUIRED.
  6. Click the Required Actions tab.
  7. To the right of the Configure OTP row, select the Default Action checkbox.
13.9.6. Logging in to the Foreman web UI Using Keycloak TOTP Authentication
Use this procedure to log in to the Foreman web UI using Keycloak TOTP authentication.
  1. Log in to Foreman, Foreman redirects you to the Keycloak login screen.
  2. Enter your username and password, and click Log In.
  3. The first attempt to log in, Keycloak requests you to configure your client by scanning the barcode and entering the pin displayed.
  4. After you configure your client and enter a valid PIN, Keycloak redirects you to Foreman and logs you in.
13.9.7. Logging in to the Foreman CLI Using Keycloak
    --two-factor \
13.9.8. Configuring Group Mapping for Keycloak Authentication
13.10. Configuring Keycloak Authentication with PIV Cards
Use this section to configure Foreman to use Keycloak as an OpenID provider for external authentication with PIV cards.
13.10.1. Prerequisites for Configuring Foreman with Keycloak Authentication
13.10.2. Registering Foreman as a Keycloak Client
13.10.3. Configuring the Foreman Client in Keycloak
  4. Click Save.
  9. Click Save.
  15. Click Save.
13.10.4. Configuring Foreman Settings for Keycloak Authentication
Prerequisite
  12. Click Submit.
Prerequisite
13.10.5. Configuring Keycloak Settings for Authentication With PIV Cards
You must configure Keycloak settings for authentication with PIV cards.
  1. In the Keycloak web UI, navigate to the Authentication tab.
  2. From the Flows list, select Browser.
  3. Click Copy to copy this flow.
  4. In the Copy Authentication Flow window, enter a new name for the flow and click OK.
  5. In the copied flow, delete Username Password Form and OTP Form entries.
  6. Click Add execution.
  7. From the Provider list, select X509/Validate Username Form.
  8. Click Save.
  9. In the X509/Validate Username Form raw, select ALTERNATIVE.
  10. In the X509/Validate Username Form raw, click Actions > Config.
  11. In the Alias field, enter a name for this configuration.
  12. From the User Identity Source list, select Subject’s Common Name,
  13. From the User mapping method list, select Username or Email.
  14. Click Save.
  15. Navigate to Authentication > Bindings.
  16. From the Browser Flow list, select the created flow.
13.10.6. Configuring Users' OS for Keycloak Authentication with PIV Cards
Complete this procedure on each system from which you want to be able to log in to Foreman using Keycloak PIV cards.
  1. Install required packages:
    yum install opensc -y
  2. Install the Firefox browser if not installed.
  3. Launch Firefox and navigate to Preferences.
  4. Click the Privacy and Security tab.
  5. Click Security Devices.
  6. Click Load.
  7. In the Load PKCS#11 Device Driver window, in the Module Name field, enter a name for this device.
  8. In the Module filename field, enter /usr/lib64/pkcs11/opensc-pkcs11.so.
  9. Click OK.
  10. If the PIV card is connected to system, restart the pcscd service.
13.10.7. Logging in to the Foreman web UI Using Keycloak PIV Cards
Use this procedure to log in to the Foreman web UI using the Keycloak PIV cards.
  1. In Firefox, log in to Foreman and enter your credentials.
  2. When prompted, enter the PIN of the PIV card.
  3. Choose the certificate for authentication. Browser verifies this certificate with Keycloak. Once authenticated, browser redirects you back to Foreman and logs you in.
13.10.8. Logging in to the Foreman CLI Using Keycloak
    --two-factor \
13.10.9. Configuring Group Mapping for Keycloak Authentication
13.11. Disabling Keycloak Authentication
If you want to disable Keycloak authentication in Foreman, complete this procedure.
  • Enter the following command to disable Keycloak Authentication:
    # foreman-installer --reset-foreman-keycloak
14. Monitoring Resources
14.1. Using the Foreman Content Dashboard
Host Configuration Status
Table 13. Host Configuration States
Icon State Description
host state config okay
host state config error
Hosts in error state
host state config report
host state config pending
host state config outofsync
Out of sync hosts
host state config noreport
Hosts with no reports
host state config noalert
Hosts with alerts disabled
Host Configuration Chart
Latest Events
New Hosts
Task Status
Latest Warning/Error Tasks
Discovered Hosts
Latest Errata
Content Views
Sync Overview
Host Subscription Status
Table 14. Host Subscription States
host state sub invalid
Invalid
host state sub partial
Partial
host state sub valid
Valid
Subscription Status
Host Collections
Virt-who Configuration Status
Table 15. Virt-who Configuration States
State Description
No Reports
No Change
OK
Total Configurations
Latest Compliance Reports
Compliance Reports Breakdown
Red Hat Insights Actions
Red Hat Insights Risk Summary
14.1.1. Managing Tasks
To Adjust Timeout Settings:
  5. Click Save.
14.2. Configuring RSS Notifications
14.3. Monitoring Foreman server
From the About page in Foreman web UI, you can find an overview of the following:
  • System Status, including Smart Proxies, Available Providers, Compute Resources, and Plug-ins
  • Support Information
  • System Information
  • Backend System Status
  • Installed Packages
  • In the upper right corner of Foreman web UI, click Administer > About.
After Pulp failure, the status of Pulp might show OK instead of Error for up to 10 minutes due to synchronization delay.
14.4. Monitoring Smart Proxy server
14.4.1. Viewing General Smart Proxy Information
14.4.2. Monitoring Services
14.4.3. Monitoring Puppet
15. Using Webhooks
15.1. Migrating to Webhooks
15.2. Installing Webhooks
  • Optional: you can install the CLI plugin using the following command:
15.3. Creating a Webhook Template
  1. In the Foreman web UI, navigate to Administer > Webhook Templates.
  7. Click Submit.
15.4. Creating a Webhook
  1. In the Foreman web UI, navigate to Administer > Webhooks.
  2. Click Create new.
  7. Enter an HTTP method.
  9. Click the Credentials tab.
When configuring webhooks with endpoints with non-standard HTTP or HTTPS ports, an SELinux port must be assigned, see Configuring SELinux to Ensure Access to Foreman on Custom Ports in Installing Foreman 3.1 Server on RHEL/CentOS.
15.5. Available Webhook Events
A Content View was successfully promoted.
Actions Remote Execution Run Host Job Succeeded
Run OpenSCAP scan.
Perform a single Puppet run.
Build Entered
Build Exited
Common database operations on a Content View.
Domain
Host
Hostgroup
Model
Status Changed
Subnet
Template Render Performed
Template
User
15.6. Shellhooks
15.7. Installing the Shellhooks Plugin
15.8. Passing Arguments to Shellhook Script Using Webhooks
      "X-Shellhook-Arg-1": "VALUE",
      "X-Shellhook-Arg-2": "VALUE"
Example
15.9. Passing Arguments to Shellhook Script Using Curl
    "X-Shellhook-Arg-1: VALUE"
    "X-Shellhook-Arg-2: VALUE"
Example
-H "X-Shellhook-Arg-2: My Content View" \
--data "" https://smartproxy.example.com:8443/shellhook/My_Script
15.10. Creating a Shellhook to Print Arguments
Prerequisite
    #!/bin/sh
    echo "$@" >&2
  2. In the Foreman web UI, navigate to Administer > Webhooks.
  3. Click Create new.
        "X-Shellhook-Arg-1": "Hello",
        "X-Shellhook-Arg-2": "World!"
  1. Run a remote execution job on any host. You can use time as a command. For more information, see Executing a Remote Job in Managing Hosts.
    [W] [3520] Hello World!
16. Searching and Bookmarking
16.1. Building Search Queries
16.1.1. Query Syntax
parameter operator value
16.1.2. Query Operators
Table 16. Comparison Operators Accepted by Search
EQUALS
hostgroup = RHEL7
NOT EQUALS
LIKE
hostgroup ~ rhel%
NOT LIKE
GREATER THAN
registered_at <= Yesterday
LESS THAN
IN
release_version !^ 7
NOT IN
HAS or set?
NOT HAS or null?
Table 17. Logical Operators Accepted by Search
and
<whitespace>
or
not
16.1.3. Query Values
Text Values
Examples:
hostgroup = "Web servers"
hostgroup = Web servers
Temporal Values
  • "10 January 2017"
  • "10 Jan 2017"
  • 10-January-2017
  • 10/January/2017
  • "January 10, 2017"
Warning
16.2. Using Free Text Search
16.3. Managing Bookmarks
16.3.1. Creating Bookmarks
  7. Click Submit.
16.3.2. Deleting Bookmarks
A.1. General Settings
Administrator email address
Foreman URL
Entries per page
20
Fix DB cache
DB pending seed
Smart Proxy request timeout
60
Login page footer text
Show host power status
Show power status on the host index page. This feature calls to compute resource providers which may lead to decreased performance on the host listing page.
HTTP(S) proxy
HTTP(S) proxy except hosts
Show Experimental Labs
Out of sync interval
30
Foreman UUID
Default language
Default timezone
Instance title
Saved audits interval
New host details UI
A.2. Tasks settings
Sync task timeout
120
Enable dynflow console
Proxy action retry count
4
Proxy action retry interval
15
Allow proxy batch tasks
Proxy tasks batch size
100
Tasks troubleshooting URL
Polling intervals multiplier
1
A.3. Template Sync Settings
Associate
Branch
Default branch in Git repo.
Commit message
Dirname
Filter
Force import
Lock templates
Keep, do not lock new
Metadata export mode
Refresh
Default metadata export mode.
Possible options:
refresh re-renders metadata.
keep keeps existing metadata.
Negate
Prefix
Repo
/tmp/dir
git://example.com
https://example.com
ssh://example.com
Verbosity
A.4. Discovered Settings
Discovery location
Discovery organization
Interface fact
discovery_bootif
Create bond interfaces
Clean all facts
Hostname facts
discovery_bootif
Auto provisioning
Reboot
Hostname prefix
mac
Fact columns
Highlighted facts
Storage facts
Software facts
Hardware facts
Network facts
IPMI facts
Lock PXE
Locked PXELinux template name
pxelinux_discovery
Locked PXEGrub template name
pxegrub_discovery
Locked PXEGrub2 template name
pxegrub2_discovery
Force DNS
Error on existing NIC
Type of name generator
Fact + prefix
Prefer IPv6
A.5. Boot Disk Settings
iPXE directory
/usr/share/ipxe
ISOLINUX directory
/usr/share/syslinux
SYSLINUX directory
/usr/share/syslinux
Grub2 directory
/var/lib/tftpboot/grub2
Host image template
Boot disk iPXE - host
Generic image template
Boot disk iPXE - generic host
ISO generation command
genisoimage
Installation media caching
Allowed bootdisk types
A.6. Content Settings
Default HTTP Proxy
CDN SSL version
Kickstart default
Kickstart default finish
Default synced OS user-data
Kickstart default user data
Kickstart default PXELinux
Kickstart default PXEGrub
Kickstart default PXEGrub2
Kickstart default iPXE
Kickstart default
Atomic Kickstart default
Manifest refresh timeout
1200
Accept action timeout
20
Finish action timeout
3600
If this is enabled, a composite content view cannot be published or promoted, unless the component content view versions that it includes exist in the target environment.
Check services before actions
100
immediate
on_demand
on_demand
/var/lib/pulp/katello-export
/var/lib/pulp/exports
Pulp client key
Pulp client cert
Sync Connection Timeout
300
Delete Host upon unregister
Default Location
Expire soon days
120
Host Duplicate DMI UUIDs
Host Profile Assume
Host Tasks Workers Pool Size
5
Applicability Batch Size
50
Autosearch
Autosearch delay
500
Pulp bulk load size
2000
1440
A.7. Authentication Settings
OAuth active
OAuth consumer key
OAuth consumer key.
OAuth consumer secret
OAuth consumer secret.
OAuth map users
Failed login attempts limit
30
Trusted hosts
SSL certificate
/etc/foreman/client_cert.pem
SSL CA file
/etc/foreman/proxy_ca.pem
SSL private key
/etc/foreman/client_key.pem
SSL client DN env
HTTP_SSL_CLIENT_S_DN
SSL client verify env
HTTP_SSL_CLIENT_VERIFY
SSL client cert env
HTTP_SSL_CLIENT_CERT
Server CA file
Websockets SSL key
Websockets SSL certificate
Websockets encryption
Login delegation logout URL
External
Idle timeout
60
BCrypt password cost
9
BMC credentials access
OIDC JWKs URL
OIDC Audience
OIDC Issuer
OIDC Algorithm
A.8. Email Settings
Email reply address
Email subject prefix
Send welcome email
Delivery method
Sendmail
Method used to deliver email.
SMTP enable StartTLS auto
SMTP OpenSSL verify mode
Default verification mode
SMTP address
SMTP address to connect to.
SMTP port
25
SMTP port to connect to.
SMTP HELO/EHLO domain
HELO/EHLO domain.
SMTP username
SMTP password
SMTP authentication
none
Sendmail arguments
-i
Sendmail location
/usr/sbin/sendmail
A.9. Notifications Settings
RSS enable
Pull RSS notifications.
RSS URL
A.10. Provisioning Settings
Host owner
Root password
Unattended URL
Safemode rendering
Query local nameservers
Installation token lifetime
360
SSH timeout
120
0.0.0.0
Update IP from built request
Use short name for VMs
DNS timeout
[5, 10, 15, 20]
Clean up failed deployment
Random-based
iPXE intermediate script
Maximum structured facts
100
Global Registration
Global Registration template.
CoreOS Transpiler Command
PXEGrub2 global default
PXELinux global default
PXEGrub global default
Global default iPXE template
iPXE global default
Local boot PXEGrub2 template
PXEGrub2 default local boot
Local boot PXELinux template
PXELinux default local boot
Local boot PXEGrub template
PXEGrub default local boot
Local boot iPXE template
iPXE default local boot
Manage PuppetCA
Use UUID for certificates
A.11. Facts Settings
Location fact
foreman_location
Organization fact
foreman_organization
Default location
Default Location
Default organization
Default Organization
Update hostgroup from facts
Ignore facts for domain
Update subnets from facts
None
Exclude pattern for facts stored in satellite
Default Puppet environment
production
ENC environment
Update environment from facts
Matchers inheritance
[fqdn, hostgroup, os, domain]
Interpolate ERB in parameters
Puppet interval
35
Puppet out of sync disabled
Fallback to Any Proxy
Enable Global Proxy
SSH User
root
Effective User
root
Effective User Method
sudo
Effective user password
Sync Job Templates
SSH Port
22
Connect by IP
Prefer IPv6 over IPv4
Default SSH password
Default SSH key passphrase
Workers pool size
5
Cleanup working directories
Cockpit URL
Form Job Template
Run Command - SSH Default
A.14. Ansible Settings
Private Key Path
Connection type
ssh
WinRM cert Validation
validate
Default verbosity level
Disabled
Post-provision timeout
360
Ansible report timeout
30
Ansible out of sync disabled
Ansible - Ansible Inventory
Ansible roles to ignore
