1. Introduction
In the context of Foreman, content is defined as the software installed on systems. This includes, but is not limited to, the base operating system, middleware services, and end-user applications. With Foreman, you can manage the various types of content for Red Hat Enterprise Linux systems at every stage of the software life cycle.
The Katello plug-in provides content management features to Foreman. You can only use this guide if you have the Katello plug-in installed. |
Foreman manages the following content:
- Subscription management
- Content management
1.1. Content Management Types Overview
With Foreman, you can manage the following Red Hat content types:
- RPM Packages
Import RPM files from repositories related to your Red Hat subscriptions. Foreman server downloads the RPM files from Red Hat’s Content Delivery Network and stores them locally. You can use these repositories and their RPM files in Content Views.
- Kickstart Trees
Import the kickstart trees for creating a system. New systems access these kickstart trees over a network to use as base content for their installation. Foreman also contains some predefined kickstart templates as well as the ability to create your own, which are used to provision systems and customize the installation.
You can also manage other types of content in Foreman. For example:
- ISO and KVM Images
Download and manage media for installation and provisioning. For example, Foreman downloads, stores and manages ISO images and guest images for specific Red Hat Enterprise Linux and non-Red Hat operating systems.
You can use the procedure to add content for any type of content you require, for example, SSL certificates and OVAL files.
1.2. Basic content management workflow
This is a quick overview of the tasks involved in the basic content management workflow in Foreman. If you have installed Foreman with Katello and want to synchronize and manage Enterprise Linux content on your hosts, follow the steps in this chapter.
Create repository to mirror content from CentOS Stream.
Synchronize the Content.
Create
Activation Keys. -
Register Hosts to consume this content.
Manage RPMs on hosts using the
katello-agent.
1.2.1. Creating repositories to synchronize
In the Foreman web UI, navigate to Content > Products.
Click Repo Discovery.
In the Repository Type field, select Yum Repositories.
In the URL to Discover field, enter the CentOS Stream URL
http://mirror.centos.org/centos/8-stream. -
Click Discover.
Select
/AppStream/x86_64/os/and/BaseOS/x86_64/os/repositories. -
Click Create Selected.
In the Product field select New Product.
In the Name field enter CentOS Stream or desired product name.
Click Run Repository Creation.
To view your newly created product, navigate to Content > Products, and select the name of the new product.
1.2.2. Synchronizing content from an upstream repository
Use the following procedure to mirror the contents of the upstream Centos repositories.
Select your new CentOS Stream product from the previous procedure.
Locate the AppStream x86_64 os and BaseOS x86_64 os repositories.
Select both repositories
Click Sync Now
1.2.3. Creating an Activation Key
Use the following procedure to create an activation key that you can use to subscribe your hosts to content managed by Foreman.
In the Foreman web UI, navigate to Content > Activation keys and click Create Activation Key.
In the Name field, enter the name of the activation key.
In the Description field, enter a description for the activation key.
From the Environment list, select the Library.
From the Content View list, select Default Organization View.
Click Save.
Click on the Subscriptions tab on the Activation Key’s details page.
Click on the Add tab.
Select all the product subscriptions in the table.
Click Add Selected to save.
1.2.4. Registering a CentOS Stream host to Foreman
Use the following procedure to register an existing CentOS Stream host to Foreman
Log on to the Centos 8 host you want register.
Download the consumer RPM for your Foreman server.
This is located in the
pubdirectory on Foreman server’s web server. For example, for a Foreman server with the host nameforeman.example.com, enter the following command on the host to register:# rpm -Uvh http://foreman.example.com/pub/katello-ca-consumer-latest.noarch.rpm
This RPM installs the necessary certificates for accessing repositories on Foreman server and configures Red Hat Subscription Manager to use the server’s URL.
On the host, enter the following command to register the host to Foreman using the activation key:
# subscription-manager register --activationkey="My_Activation_Key" --org="My_Organization"
After registration, enter the yum repolist command to update
/etc/yum.repos.d/redhat.repoand enable content from Foreman server.# yum repolist repo id repo name Default_Organization_Centos_Stream_AppStream_x86_64_os AppStream x86_64 os Default_Organization_Centos_Stream_BaseOS_x86_64_os BaseOS x86_64 Uploading Enabled Repositories Report
Check the
/etc/yum.repos.d/redhat.confand ensure that the appropriate repositories have been enabled.
1.2.5. Using Content Views
Foreman uses the concept of Content Views to create snapshots of a set of repositories and make them available to hosts registered to it.
For example, if you want a group of hosts to have access to a specific version of a set of repositories, add those repositories to a Content View, publish and promote to a lifecycle environment. You can then register hosts to this Content View. These hosts have access only to repositories at the version specified in the Content View.
This means that you can continue to update repositories on your server while your hosts still consume only the versions of the repositories that they are registered to.
If you do not use Content Views and lifecycle environments, all your hosts consume content from the Default Content View and Library environment, which is a snapshot of the latest version of the content on your server.
For more information about content management using Content Views and application lifecycles, see:
1.2.6. Creating a Content View
Use the following procedure to create a Content view.
In the Foreman web UI, navigate to Content > Content Views and click Create New View.
In the Name field, enter Centos content view.
In the Description field, enter a description for the Content View.
Click Save.
1.2.7. Adding Repositories
Use the following procedure to add the upstream CentOS repositories to your Content view.
In the Foreman web UI, navigate to Content > Content Views > Select CentOS content view > Yum Content Dropdown> Repositories.
Click on Add section on the Repository selection page.
Click Add Repositories
1.2.8. Publishing the Content View
Use the following procedure to publish the Content View.
In the Foreman web UI, navigate to Content > Content Views, and select your new Content View.
Click on Publish New Version button on the top right of page.
Click Save
1.2.9. Creating an Activation Key to consume the Content View
In the Name field, enter CentOS or the name of your new activation key.
From the Content View list, select Centos content view.
Click Save.
Click the Subscriptions tab on the Activation Key’s details page.
Click the Add tab.
Select your new CentOS Stream product in the table.
Use your activation key to register a host to the Content View. For more information on registering a host, see https://docs.theforeman.org/3.0/Managing_Hosts/index-foreman-el.html#registering-a-host_managing-hosts
1.2.10. Registering a CentOS Stream host to consume content from published Content View
You can also register the host to the published Content View without an activation key using the following command:
# subscription-manager register --org=My_Organization --environment=Library/Centos_content_view
1.2.11. Managing the Lifecycle of the Content View
The default location of any new Content View is in the Library Environment. Optionally, you can add a new environment and promote your Content View to it. Use the following procedure to create a new Lifecycle Enviroment.
In the Foreman web UI, navigate to Content > Lifecycle Environment and click Create Environment Path.
In the Name field, enter Production or the name of your new environment to add to the end of Library environment.
In the Description field, add an optional description for your new lifecycle environment.
Click Save
1.2.12. Promoting your Content View to the new Lifecycle Environment
You can now promote your new Content View to the Production environment using the following procedure.
In the Foreman web UI, navigate to Content > Content Views > Select your Content View
On the Versions tab Click Promote for desired version under the Actions column.
Select Production lifecycle environment from the available promotion paths.
Add an optional Description
Click Promote Version
1.2.13. Registering a CentOS Stream host to consume content from a promoted Content View in the production environment
To register a host to consume content from the Content View in the Production lifecycle environment, enter the following command:
# subscription-manager register --org="My_Organization" --environment="Production/Centos_content_view"
2. Managing Organizations
Organizations divide Foreman resources into logical groups based on ownership, purpose, content, security level, or other divisions. You can create and manage multiple organizations through Foreman, then divide and assign your Red Hat subscriptions to each individual organization. This provides a method of managing the content of several individual organizations under one management system. Here are some examples of organization management:
- Single Organization
A small business with a simple system administration chain. In this case, you can create a single organization for the business and assign content to it.
- Multiple Organizations
A large company that owns several smaller business units. For example, a company with separate system administration and software development groups. In this case, you can create organizations for the company and each of the business units it owns. This keeps the system infrastructure for each separate. You can then assign content to each organization based on its needs.
- External Organizations
A company that manages external systems for other organizations. For example, a company offering cloud computing and web hosting resources to customers. In this case, you can create an organization for the company’s own system infrastructure and then an organization for each external business. You can then assign content to each organization where necessary.
A default installation of Foreman has a default organization called Default_Organization.
If a new user is not assigned a default organization, their access is limited. To grant systems rights to users, assign them to a default organization. The next time the user logs on to Foreman, the user’s account has the correct system rights.
2.1. Creating an Organization
Use this procedure to create an organization. To use the CLI instead of the Foreman web UI, see CLI procedure.
In the Foreman web UI, navigate to Administer > Organizations.
Click New Organization.
In the Name field, enter a name for the organization.
In the Label field, enter a unique identifier for the organization. This is used for creating and mapping certain assets, such as directories for content storage. Use letters, numbers, underscores, and dashes, but no spaces.
Optional: in the Description field, enter a description for the organization.
Click Submit.
If you have hosts with no organization assigned, select the hosts that you want to add to the organization, then click Proceed to Edit.
In the Edit page, assign the infrastructure resources that you want to add to the organization. This includes networking resources, installation media, kickstart templates, and other parameters. You can return to this page at any time by navigating to Administer > Organizations and then selecting an organization to edit.
Click Submit.
To create an organization, enter the following command:
# hammer organization create \ --name "your_organization_name" \ --label "your_organization_label \ --description "your_organization_description"
Optional: To edit an organization, enter the
hammer organization updatecommand. For example, the following command assigns a compute resource to the organization:# hammer organization update \ --name "your_organization_name" \ --compute-resource-ids 1
2.2. Setting the Organization Context
An organization context defines the organization to use for a host and its associated resources.
The organization menu is the first menu item in the menu bar, on the upper left of the Foreman web UI. If you have not selected a current organization, the menu says Any Organization. Click the Any Organization button and select the organization to use.
While using the CLI, include either --organization "your_organization_name" or --organization-label "your_organization_label" as an option.
For example:
# hammer subscription list --organization "Default_Organization"
This command outputs subscriptions allocated for the Default_Organization.
2.3. Creating an Organization Debug Certificate
If you require a debug certificate for your organization, use the following procedure.
To create a debug certificate for an organization, complete the following steps:
Select an organization that you want to generate a debug certificate for.
Click Generate and Download.
Save the certificate file in a secure location.
Debug Certificates are automatically generated for provisioning template downloads if they do not already exist in the organization for which they are being downloaded.
2.4. Browsing Repository Content Using an Organization Debug Certificate
You can view an organization’s repository content using a web browser or using the API if you have a debug certificate for that organization.
Create and download an organization certificate as described in Creating an Organization Debug Certificate.
Open the X.509 certificate, for example, for the default organization:
$ vi 'Default Organization-key-cert.pem'
Copy the contents of the file from
-----BEGIN RSA PRIVATE KEY-----to-----END RSA PRIVATE KEY-----, into akey.pemfile. -
-----BEGIN CERTIFICATE-----to-----END CERTIFICATE-----, into acert.pemfile.
To use a browser, you must first convert the X.509 certificate to a format your browser supports and then import the certificate.
To use an organization debug certificate in Firefox, complete the following steps:
To create a PKCS12 format certificate, enter the following command:
$ openssl pkcs12 -keypbe PBE-SHA1-3DES -certpbe PBE-SHA1-3DES -export -in cert.pem -inkey key.pem -out organization_label.pfx -name organization_name
In the Firefox browser, navigate to Edit > Preferences > Advanced Tab.
Select View Certificates, and click the Your Certificates tab.
Click Import and select the
.pfxfile to load. -
In the address bar, enter a URL in the following format to browse for repositories:
http://foreman.example.com/pulp/repos/organization_label
Pulp uses the organization label, therefore, you must enter the organization label into the URL.
To use the organization debug certificate with CURL, enter the following command:
$ curl -k --cert cert.pem --key key.pem \ http://foreman.example.com/pulp/repos/Default_Organization/Library/content/dist/rhel/server/7/7Server/x86_64/sat-tools/2.5/os/
Ensure that the paths to cert.pem and key.pem are the correct absolute paths otherwise the command fails silently.
2.5. Deleting an Organization
You can delete an organization if the organization is not associated with any life cycle environments or host groups. If there are any life cycle environments or host groups associated with the organization you are about to delete, remove them by navigating to Administer > Organizations and clicking the relevant organization. Do not delete the default organization created during installation because the default organization is a placeholder for any unassociated hosts in the Foreman environment. There must be at least one organization in the environment at any given time.
From the list to the right of the name of the organization you want to delete, select Delete.
Click OK to delete the organization.
Enter the following command to retrieve the ID of the organization that you want to delete:
# hammer organization list
From the output, note the ID of the organization that you want to delete.
Enter the following command to delete an organization:
# hammer organization delete --id Organization_ID
3. Managing Locations
Locations function similar to organizations: they provide a method to group resources and assign hosts. Organizations and locations have the following conceptual differences:
Locations are based on physical or geographical settings.
Locations have a hierarchical structure.
3.1. Creating a Location
Use this procedure to create a location so that you can manage your hosts and resources by location. To use the CLI instead of the Foreman web UI, see the CLI procedure.
In the Foreman web UI, navigate to Administer > Locations.
Click New Location.
Optional: from the Parent list, select a parent location. This creates a location hierarchy.
In the Name field, enter a name for the location.
Optional: in the Description field, enter a description for the location.
Click Submit.
If you have hosts with no location assigned, add any hosts that you want to assign to the new location, then click Proceed to Edit.
Assign any infrastructure resources that you want to add to the location. This includes networking resources, installation media, kickstart templates, and other parameters. You can return to this page at any time by navigating to Administer > Locations and then selecting a location to edit.
Click Submit to save your changes.
Enter the following command to create a location:
# hammer location create \ --parent-id "parent_location_id" \ --name "your_location_name" \ --description "your_location_description"
3.2. Creating Multiple Locations
The following example Bash script creates three locations - London, Munich, Boston - and assigns them to the Example Organization.
ORG="Example Organization"
LOCATIONS="London Munich Boston"
for LOC in ${LOCATIONS}
do
hammer location create --name "${LOC}"
hammer location add-organization --name "${LOC}" --organization "${ORG}"
done
3.3. Setting the Location Context
A location context defines the location to use for a host and its associated resources.
The location menu is the second menu item in the menu bar, on the upper left of the Foreman web UI. If you have not selected a current location, the menu displays Any Location. Click Any location and select the location to use.
While using the CLI, include either --location "your_location_name" or --location-id "your_location_id" as an option.
For example:
# hammer subscription list --location "Default_Location"
This command outputs subscriptions allocated for the Default_Location.
3.4. Deleting a Location
You can delete a location if the location is not associated with any life cycle environments or host groups. If there are any life cycle environments or host groups associated with the location you are about to delete, remove them by navigating to Administer > Locations and clicking the relevant location. Do not delete the default location created during installation because the default location is a placeholder for any unassociated hosts in the Foreman environment. There must be at least one location in the environment at any given time.
To delete a location, complete the following steps:
Select Delete from the list to the right of the name of the location you want to delete.
Click OK to delete the location.
Enter the following command to retrieve the ID of the location that you want to delete:
# hammer location list
From the output, note the ID of the location that you want to delete.
Enter the following command to delete the location:
# hammer location delete --id Location ID
4. Managing Subscriptions
Foreman can import content from the Red Hat Content Delivery Network (CDN). Foreman requires a Subscription Manifest to find, access, and download content from the corresponding repositories. You must have a Subscription Manifest containing a subscription allocation for each organization on Foreman server. All subscription information is available in your Red Hat Customer Portal account.
Before you can complete the tasks in this chapter, you must create a Subscription Manifest in the Customer Portal.
To create, manage, and export a Subscription Manifest in the Customer Portal, see Using Manifests in the Using Red Hat Subscription Management guide.
Use this chapter to import a Subscription Manifest and manage the manifest within the Foreman web UI.
You can manage more than one organization if you have more than one subscription allocation. Foreman requires a single allocation for each organization configured in Foreman server. The advantage of this is that each organization maintains separate subscriptions so that you can support multiple organizations, each with their own Red Hat accounts.
Manually attach the future-dated subscriptions to your content hosts before the current subscriptions expire. Do not rely on the auto-attach method because this method is designed for a different purpose and might not work. For more information, see Attaching Subscriptions to Content Hosts.
4.1. Importing a Subscription Manifest into Foreman server
Use the following procedure to import a Subscription Manifest into Foreman server.
This is for users of the Katello plug-in and Red Hat operating systems only.
You must have a Subscription Manifest file exported from the Customer Portal. For more information, see Using Manifests in the Using Red Hat Subscription Management guide.
In the Foreman web UI, ensure the context is set to the organization you want to use.
Navigate to Content > Subscriptions and click Manage Manifest.
In the Manage Manifest window, click Browse.
Navigate to the location that contains the Subscription Manifest file, then click Open. If the Manage Manifest window does not close automatically, click Close to return to the Subscriptions window.
Copy the Subscription Manifest file from your client to Foreman server:
Log in to Foreman server as the
rootuser and import the Subscription Manifest file:# hammer subscription upload \ --file ~/manifest_file.zip \ --organization "My_Organization"
You can now enable repositories and import Red Hat content. For detailed information, see Importing Content in the Content Management Guide.
You can now enable repositories and import Red Hat content. For more information, see Importing Content.
4.2. Locating a Subscription in the Foreman web UI
When you import a Subscription Manifest into Foreman server, the subscriptions from your manifest are listed in the Subscriptions window. If you have a high volume of subscriptions, you can filter the results to find a specific subscription.
You must have a Subscription Manifest file imported to Foreman server. For more information, see Importing a Subscription Manifest into Foreman server.
To locate a subscription, complete the following steps:
Navigate to Content > Subscriptions.
In the Subscriptions window, click the Search field to view the list of search criteria for building your search query.
Select search criteria to display further options.
When you have built your search query, click the search icon.
4.3. Adding Subscriptions to Subscription Allocations in the Foreman web UI
Use the following procedure to add subscriptions to a subscription allocation in the Foreman web UI.
To add subscriptions to a subscription allocation, complete the following steps:
In the Subscriptions window, click Add Subscriptions.
On the row of each subscription you want to add, enter the quantity in the Quantity to Allocate column.
Click Submit.
4.4. Removing Subscriptions from Subscription Allocations in the Foreman web UI
Use the following procedure to remove subscriptions from a subscription allocation in the Foreman web UI.
Manifests must not be deleted. If you delete the manifest from the Red Hat Customer Portal or in the Foreman web UI, all of the entitlements for all of your content hosts will be removed. |
To remove subscriptions, complete the following steps:
On the row of each subscription you want to remove, select the corresponding check box.
Click Delete, and then confirm deletion.
4.5. Updating and Refreshing Subscription Manifests
Renewing a subscription
Adjusting subscription quantities
Purchasing additional subscriptions
In the Subscriptions window, click Manage Manifest.
In the Manage Manifest window, click Refresh.
4.6. Attaching Subscriptions to Content Hosts
For more information about updating multiple hosts, see Bulk Updating Content Hosts' Subscriptions.
In Foreman, you must maintain a Red Hat Enterprise Linux Smart Management subscription for every Red Hat Enterprise Linux host that you want to manage.
However, you are not required to attach Smart Management subscriptions to each content host. Smart Management subscriptions cannot attach automatically to content hosts in Foreman because they are not associated with any product certificates. Adding a Smart Management subscription to a content host does not provide any content or repository access. If you want, you can add a Smart Management subscription to a manifest for your own recording or tracking purposes.
Navigate to Hosts > Content Hosts.
On the row of each content host whose subscription you want to change, select the corresponding check box.
From the Select Action list, select Manage Subscriptions.
Optionally, enter a key and value in the Search field to filter the subscriptions displayed.
Select the check box to the left of the subscriptions that you want to add or remove and click Add Selected or Remove Selected as required.
Click Done to save the changes.
Connect to Foreman server as the root user, and then list the available subscriptions:
# hammer subscription list \ --organization-id 1
Attach a subscription to the host:
# hammer host subscription attach \ --host host_name \ --subscription-id subscription_id
4.7. Bulk Updating Content Hosts' Subscriptions
To update multiple content hosts, complete the following steps:
Select the check box to the left of the subscriptions to be added or removed and click Add Selected or Remove Selected as required.
5. Importing Content
This chapter outlines how you can import different types of content to Foreman. If you want to import Rpms, Files, or different content types to Foreman, it is done with largely the same procedures in this chapter.
For example, you can use the following chapters for information on specific types of content but the underlying procedures are the same:
5.1. Using Products and Repositories in Foreman
Both Red Hat content and non-RH content in Foreman have similarities:
The relationship between a product and its repositories is the same and the repositories still require synchronization.
products require a subscription for clients to access, similar to subscriptions to Red Hat Products. Foreman creates a subscription for each product you create.
Red Hat Content is already organized into Products. For example, Red Hat Enterprise Linux Server is a Product in Foreman. The repositories for that Product consist of different versions, architectures, and add-ons. For Red Hat repositories, products are created automatically after enabling the repository. See Enabling Red Hat Repositories
Other content can be organized into Products however you want. For example, you might create an EPEL (Extra Packages for Enterprise Linux) product and add an "EPEL 7 x86_64" repository to it.
For more information about creating and packaging RPMs, see the RPM Packaging Guide in the Red Hat Enterprise Linux documentation.
5.2. Importing SSL Certificates
Before you synchronize content from an external source, you might need to import SSL certificates into your product. This might include client certs and keys or CA certificates for the upstream repositories you want to synchronize.
If you require SSL certificates and keys to download RPMs, you can add them to Foreman.
In the Foreman web UI, navigate to Content > Content Credentials. In the Content Credentials window, click Create Content Credential.
In the Name field, enter a name for your SSL certificate.
From the Type list, select SSL Certificate.
In the Content Credentials Content field, paste your SSL certificate, or click Browse to upload your SSL certificate.
Click Save.
5.3. Creating a Product
Use this procedure to create a product that you can then add repositories to. To use the CLI instead of the Foreman web UI, see the CLI procedure.
In the Foreman web UI, navigate to Content > Products, click Create Product.
In the Name field, enter a name for the product. Foreman automatically completes the Label field based on what you have entered for Name.
Optional: From the GPG Key list, select the GPG key for the product.
Optional: From the SSL CA Cert list, select the SSL CA certificate for the product.
Optional: From the SSL Client Cert list, select the SSL client certificate for the product.
Optional: From the SSL Client Key list, select the SSL client key for the product.
Optional: From the Sync Plan list, select an existing sync plan or click Create Sync Plan and create a sync plan for your product requirements.
In the Description field, enter a description of the product.
Click Save.
# hammer product create \ --name "My_Product" \ --sync-plan "Example Plan" \ --description "Content from My Repositories" \ --organization "My_Organization"
5.4. Adding RPM Repositories
Use this procedure to add RPM repositories in Foreman. To use the CLI instead of the Foreman web UI, see the CLI procedure.
The Products window in the Foreman web UI also provides a Repo Discovery function that finds all repositories from a URL and you can select which ones to add to your product.
For example, you can use the Repo Discovery to search http://yum.postgresql.org/9.5/redhat/ and list all repositories for different Red Hat Enterprise Linux versions and architectures.
This helps users save time importing multiple repositories from a single source.
In the Foreman web UI, navigate to Content > Products and select the product that you want to use, and then click New Repository.
In the Name field, enter a name for the repository. Foreman automatically completes the Label field based on what you have entered for Name.
From the Type list, select the type of repository. You can select either a repository for RPM files (
yum), Docker images (docker), Files (file) or other. Note that if theyumcontent type is selected, you can restrict whether the repository is available to a host based on the host’s architecture and OS version. -
Optional: From the Restrict to Architecture list, select the architecture. Ensure that No restriction, which is the default value, is selected to make the repository available to all hosts regardless of the architecture.
Optional: From the Restrict to OS Version list, select the OS version. Ensure that No restriction, which is the default value, is selected to make the repository available to all hosts regardless of the OS version.
In the URL field, enter the URL of the external repository to use as a source.
From the Download Policy list, select the type of synchronization Foreman server performs. See Download Policies Overview
Ensure that the Mirror on Sync check box is selected. This ensures that the content that is no longer part of the upstream repository is removed during synchronization.
From the Checksum list, select the checksum type for the repository.
Optional: If you want, you can clear the Publish via HTTP check box to disable this repository from publishing through HTTP.
Click Save.
Enter the following command to create the repository:
# hammer repository create \ --name "My_Repository" \ --content-type "yum" \ --os-version "My_OS_Version" \ --arch "My_System_Architecture" \ --publish-via-http true \ --url http://yum.postgresql.org/9.5/redhat/rhel-7-x86_64/ \ --gpg-key "My_Repository" \ --product "My_Product" \ --organization "My_Organization"
Continue to Syncing Repositories to sync the repository
5.5. Enabling Red Hat Repositories
If outside network access requires usage of an HTTP Proxy, configure a default HTTP Proxy for your server. See Adding a default HTTP Proxy
To select the repositories to synchronize, you must first identify the product that contains the repository, and then enable that repository based on the relevant release version and base architecture. For Red Hat Enterprise Linux 8, you must enable both AppStream and BaseOS repositories.
The difference between associating Red Hat Enterprise Linux operating system with either 7 Server repositories or 7.X repositories is that 7 Server repositories contain all the latest updates while Red Hat Enterprise Linux 7.X repositories stop getting updates after the next minor version release. Note that Kickstart repositories only have minor versions.
To provision Red Hat Enterprise Linux 8 clients, you require the Red Hat Enterprise Linux 8 for x86_64 - AppStream (RPMS) and Red Hat Enterprise Linux 8 for x86_64 - BaseOS (RPMs) repositories.
To provision Red Hat Enterprise Linux 7 clients, you require the Red Hat Enterprise Linux 7 Server (RPMs) repository.
In the Foreman web UI, navigate to Content > Red Hat Repositories.
To find repositories, either enter the repository name, or toggle the Recommended Repositories button to the on position to view a list of repositories that you require.
In the Available Repositories pane, click a repository to expand the repository set.
Click the Enable icon next to the base architecture and release version that you want.
To search for your product, enter the following command:
List the repository set for the product:
# hammer repository-set list \ --product "Red Hat Enterprise Linux Server" \ --organization "My_Organization"
Enable the repository using either the name or ID number. Include the release version, for example,
7Serverand base architecture, for example,x86_64. For example:# hammer repository-set enable \ --name "Red Hat Enterprise Linux 7 Server (RPMs)" \ --releasever "7Server" \ --basearch "x86_64" \ --product "Red Hat Enterprise Linux Server" \ --organization "My_Organization"
5.6. Syncing Repositories
In the Foreman web UI, navigate to Content > Products and select the product that contains the repositories that you want to synchronize.
Select the repositories that you want to synchronize and click Sync Now.
To view the progress of the synchronization in the Foreman web UI, navigate to Content > Sync Status and expand the corresponding product or repository tree.
Synchronize an entire Product:
# hammer product synchronize \ --name "My_Product" \ --organization "My_Organization"
Synchronize the repository individually:
# hammer repository synchronize \ --name "My_Repository" \ --product "My Product" \ --organization "My_Organization"
| Single Package (10Mb) | Minor Release (750Mb) | Major Release (6Gb) | |
256 Kbps |
5 Mins 27 Secs |
6 Hrs 49 Mins 36 Secs |
2 Days 7 Hrs 55 Mins |
512 Kbps |
2 Mins 43.84 Secs |
3 Hrs 24 Mins 48 Secs |
1 Day 3 Hrs 57 Mins |
T1 (1.5 Mbps) |
54.33 Secs |
1 Hr 7 Mins 54.78 Secs |
9 Hrs 16 Mins 20.57 Secs |
10 Mbps |
8.39 Secs |
10 Mins 29.15 Secs |
1 Hr 25 Mins 53.96 Secs |
100 Mbps |
0.84 Secs |
1 Min 2.91 Secs |
8 Mins 35.4 Secs |
1000 Mbps |
0.08 Secs |
6.29 Secs |
51.54 Secs |
Create a synchronization plan to ensure updates on a regular basis. See: Creating a Synchronization Plan
5.7. Synchronizing All Repositories in an Organization
To synchronize all repositories within an organization, run the following Bash script on your Foreman server:
ORG="Your_Organization"
for i in $(hammer --no-headers --csv repository list --organization $ORG | awk -F, {'print $1'})
do
done
5.8. Download Policies Overview
Foreman provides multiple download policies for synchronizing RPM content. For example, you might want to download only the content metadata while deferring the actual content download for later.
Foreman server has the following policies:
- Immediate
Foreman server downloads all metadata and packages during synchronization.
- On Demand
Foreman server downloads only the metadata during synchronization. Foreman server only fetches and stores packages on the file system when Smart Proxies or directly connected clients request them. This setting has no effect if you set a corresponding repository on a Smart Proxy to Immediate because Foreman server is forced to download all the packages.
The On Demand policy acts as a Lazy Synchronization feature because they save time synchronizing content.
The lazy synchronization feature must be used only for yum repositories.
You can add the packages to Content Views and promote to life cycle environments as normal.
Smart Proxy server offers the following policies:
- Immediate
Smart Proxy server downloads all metadata and packages during synchronization. Do not use this setting if the corresponding repository on Foreman server is set to On Demand as Foreman server is forced to download all the packages.
- On Demand
Smart Proxy server only downloads the metadata during synchronization. Smart Proxy server fetches and stores packages only on the file system when directly connected clients request them. When you use an On Demand download policy, content is downloaded from Foreman server if it is not available on Smart Proxy server.
- Inherit
Smart Proxy server inherits the download policy for the repository from the corresponding repository on Foreman server.
5.9. Changing the Default Download Policy
You can set the default download policy that Foreman applies to repositories that you create in all organizations.
Depending on whether it is a Red Hat or non-Red Hat repository, Foreman uses separate settings. Changing the default value does not change existing settings.
To change the default download policy for repositories, complete the following steps:
In the Foreman web UI, navigate to Administer > Settings.
Click the Content tab.
Change the default download policy depending on your requirements:
To change the default download policy for a Red Hat repository, change the value of the Default Red Hat Repository download policy setting.
To change the default download policy for a non-Red Hat repository, change the value of the Default Custom Repository download policy setting.
To change the default download policy for Red Hat repositories to one of
immediateoron_demand, enter the following command:# hammer settings set \ --name default_redhat_download_policy \ --value immediate
To change the default download policy for a repository to one of
immediateoron_demand, enter the following command:# hammer settings set \ --name default_download_policy \ --value immediate
5.10. Changing the Download Policy for a Repository
Select the required product name.
On the Repositories tab, click the required repository name, locate the Download Policy field, and click the edit icon.
From the list, select the required download policy and then click
Save.
List the repositories for an organization:
# hammer repository list \ --organization-label organization-label
Change the download policy for a repository to one of
immediateoron_demand:# hammer repository update \ --organization-label organization-label \ --product "Red Hat Enterprise Linux Server" \ --name "Red Hat Enterprise Linux 7 Server Kickstart x86_64 7.5" \ --download-policy immediate
5.11. Uploading Content to RPM Repositories
You can upload individual RPMs and source RPMs to RPM repositories. You can upload RPMs using the Foreman web UI or the Hammer CLI. You must use the Hammer CLI to upload source RPMs.
In the Foreman web UI, click Content > Products.
Click the name of the product.
In the Repositories tab, click the name of the RPM repository.
Under Upload Package, click Browse… and select the RPM you want to upload.
Click Upload.
Enter the following command to upload an RPM:
# hammer repository upload-content \ --id repo_ID \ --path /path/to/example-package.rpm
Enter the following command to upload a source RPM:
# hammer repository upload-content \ --content-type srpm \ --id repo_ID \ --path /path/to/example-package.src.rpm
When the upload is complete, you can view information about a source RPM by using the commands
hammer srpm listandhammer srpm info --id srpm_ID.
5.12. Recovering a Repository
In the case of repository corruption, you can recover it by using an advanced synchronization, which has three options:
- Optimized Sync
Synchronizes the repository bypassing RPMs that have no detected differences from the upstream RPMs.
- Complete Sync
Synchronizes all RPMs regardless of detected changes. Use this option if specific RPMs could not be downloaded to the local repository even though they exist in the upstream repository.
- Validate Content Sync
Synchronizes all RPMs and then verifies the checksum of all RPMs locally. If the checksum of an RPM differs from the upstream, it re-downloads the RPM. This option is relevant only for
yumrepositories. Use this option if you have one of the following errors:-
Specific RPMs cause a
404error while synchronizing withyum. -
Package does not match intended downloaderror, which means that specific RPMs are corrupted.
Select the product containing the corrupted repository.
Select the name of a repository you want to synchronize.
From the Select Action menu, select Advanced Sync.
Select the option and click Sync.
Obtain a list of repository IDs:
Synchronize a corrupted repository using the necessary option:
For the optimized synchronization:
# hammer repository synchronize --id 1
For the complete synchronization:
# hammer repository synchronize --skip-metadata-check true --id 1
For the validate content synchronization:
# hammer repository synchronize --validate-contents true --id 1
5.13. Adding a New HTTP Proxy
Use this procedure to add HTTP proxies to Foreman. You can then specify which HTTP proxy to use for Products, repositories, and supported compute resources.
If Foreman server uses a proxy to communicate with subscription.rhsm.redhat.com or subscription.rhn.redhat.com, and cdn.redhat.com then the proxy must not perform SSL inspection on these communications.
In the Foreman web UI, navigate to Infrastructure > HTTP Proxies and select New HTTP Proxy.
In the Name field, enter a name for the HTTP proxy.
In the URL field, enter the URL for the HTTP proxy, including the port number. The following host names are available:
Host name Port Protocol subscription.rhsm.redhat.com
HTTPS
HTTPS
cdn.redhat.com
HTTPS
If your HTTP proxy requires authentication, enter a Username and Password.
Optional: In the Test URL field, enter the HTTP proxy URL, then click Test Connection to ensure that you can connect to the HTTP proxy from Foreman.
Click the Locations tab and add a location.
Click the Organization tab and add an organization.
Click Submit.
On Foreman server, enter the following command to add a new HTTP proxy:
# hammer http-proxy create --name proxy-name \ --url proxy-URL:port-number
If your HTTP proxy requires authentication, add the
--username nameand--password passwordoptions.
For further information, see the Knowledgebase article How to access Red Hat Subscription Manager (RHSM) through a firewall or proxy on the Red Hat Customer Portal.
5.14. Changing the HTTP Proxy Policy for a Product
In the Foreman web UI, navigate to Content > Products and select the check box next to each of the Products that you want to change.
From the Select Action list, select Manage HTTP Proxy.
Select an HTTP Proxy Policy from the list:
Global Default: Use the global default proxy setting.
No HTTP Proxy: Do not use an HTTP proxy, even if a global default proxy is configured.
Use specific HTTP Proxy: Select an HTTP Proxy from the list. You must add HTTP proxies to Foreman before you can select a proxy from this list. For more information, see Adding a New HTTP Proxy.
Click Update.
5.15. Changing the HTTP Proxy Policy for a Repository
For granular control over network traffic, you can set an HTTP proxy policy for each repository. To use the CLI instead of the Foreman web UI, see the CLI procedure.
In the Foreman web UI, navigate to Content > Products and click the name of the Product that contains the repository.
In the Repositories tab, click the name of the repository.
Locate the HTTP Proxy field and click the edit icon.
Click Save.
On Foreman server, enter the following command, specifying the HTTP proxy policy you want to use:
# hammer repository update --id repository-ID \ --http-proxy-policy policy
Specify one of the following options for
--http-proxy-policy:-
none: Do not use an HTTP proxy, even if a global default proxy is configured. -
global_default_http_proxy: Use the global default proxy setting. -
use_selected_http_proxy: Specify an HTTP proxy using either--http-proxy proxy-nameor--http-proxy-id proxy-ID. To add a new HTTP proxy to Foreman, see Adding a New HTTP Proxy.
5.16. Creating a Synchronization Plan
A synchronization plan checks and updates the content at a scheduled date and time. In Foreman, you can create a synchronization plan and assign products to the plan.
In the Foreman web UI, navigate to Content > Sync Plans and click New Sync Plan.
In the Name field, enter a name for the plan.
In the Description field, enter a description of the plan.
From the Interval list, select the interval at which you want the plan to run.
From the Start Date and Start Time lists, select when to start running the synchronization plan.
Click Save.
Click the Products tab, then click Add. Select the Red Hat Enterprise Linux Server product and click Add Selected.
To create the synchronization plan, enter the following command:
# hammer sync-plan create \ --name "Red Hat Products 2" \ --description "Example Plan for Red Hat Products" \ --interval daily \ --sync-date "2016-02-01 01:00:00" \ --enabled true \ --organization "My_Organization"
Assign the Red Hat Enterprise Linux Server product to it:
# hammer product set-sync-plan \ --name "Red Hat Enterprise Linux Server" \ --sync-plan "Red Hat Products" \ --organization "My_Organization"
View the available synchronization plans for an organization to verify that the synchronization plan is created:
# hammer sync-plan list --organization "Default Organization"
5.17. Assigning a Synchronization Plan to Multiple Products
Use this procedure to assign a synchronization plan to the products in an organization that have been synchronized at least once and contain at least one repository
To assign a synchronization plan to the selected products, complete the following steps:
Run the following Bash script:
ORG="Your_Organization" SYNC_PLAN="daily_sync_at_3_a.m" for i in $(hammer --no-headers --csv product list --organization $ORG --per-page 999 | grep -vi not_synced | awk -F, {'{ if ($5!=0) print $1}'}) do hammer sync-plan create --name $SYNC_PLAN --interval daily --sync-date "2018-06-20 03:00:00" --enabled true --organization $ORG hammer product set-sync-plan --sync-plan $SYNC_PLAN --organization $ORG --id $i done -
After executing the script, view the products assigned the synchronization plan:
5.18. Limiting Synchronization Concurrency
By default each Repository Synchronization job can fetch up to 10 files at a time. This can be adjusted on a per repository basis.
To do so from the CLI:
# hammer repository update --organization $ORG --download-concurrency 5 --id $REPO_ID
5.19. Importing a GPG Key
When clients are consuming signed content, ensure that the clients are configured to validate the installation of RPMs with the appropriate GPG Key. This helps to ensure that only packages from authorized sources can be installed.
Ensure that you have a copy of the GPG key used to sign the RPM content that you want to use and manage in Foreman. Most RPM distribution providers provide their GPG Key on their website. You can also extract this manually from an RPM:
Download a copy of the version specific repository package to your client system:
Extract the RPM file without installing it:
In the Foreman web UI, navigate to Content > Content Credentials and in the upper-right of the window, click Create Content Credential.
Enter the name of your repository and select GPG Key from the Type list.
Either paste the GPG key into the Content Credential Contents field, or click Browse and select the GPG key file that you want to import.
If your repository contains content signed by multiple GPG keys, you must enter all required GPG keys in the Content Credential Contents field with new lines between each key, for example:
-----BEGIN PGP PUBLIC KEY BLOCK----- mQINBFy/HE4BEADttv2TCPzVrre+aJ9f5QsR6oWZMm7N5Lwxjm5x5zA9BLiPPGFN 4aTUR/g+K1S0aqCU+ZS3Rnxb+6fnBxD+COH9kMqXHi3M5UNzbp5WhCdUpISXjjpU XIFFWBPuBfyr/FKRknFH15P+9kLZLxCpVZZLsweLWCuw+JKCMmnA =F6VG -----END PGP PUBLIC KEY BLOCK----- -----BEGIN PGP PUBLIC KEY BLOCK----- mQINBFw467UBEACmREzDeK/kuScCmfJfHJa0Wgh/2fbJLLt3KSvsgDhORIptf+PP OTFDlKuLkJx99ZYG5xMnBG47C7ByoMec1j94YeXczuBbynOyyPlvduma/zf8oB9e Wl5GnzcLGAnUSRamfqGUWcyMMinHHIKIc1X1P4I= =WPpI -----END PGP PUBLIC KEY BLOCK-----
Click Save.
Copy the GPG key to your Foreman server:
Upload the GPG key to Foreman:
# hammer gpg create \ --key ~/RPM-GPG-KEY-EXAMPLE-95 \ --name "My_Repository" \ --organization "My_Organization"
6. Managing Application Life Cycles
This chapter outlines the application life cycle in Foreman and how to create and remove application life cycles for Foreman and Smart Proxy.
6.1. Application Life Cycle Overview
The application life cycle is a concept central to Foreman’s content management functions. The application life cycle defines how a particular system and its software look at a particular stage. For example, an application life cycle might be simple; you might only have a development stage and production stage. In this case the application life cycle might look like this:
Development
Production
However, a more complex application life cycle might have further stages, such as a phase for testing or a beta release. This adds extra stages to the application life cycle:
Development
Testing
Beta Release
Production
Foreman provides methods to customize each application life cycle stage so that it suits your specifications.
Each stage in the application life cycle is called an environment in Foreman. Each environment uses a specific collection of content. Foreman defines these content collections as a Content View. Each Content View acts as a filter where you can define what repositories, and packages to include in a particular environment. This provides a method for you to define specific sets of content to designate to each environment.
For example, an email server might only require a simple application life cycle where you have a production-level server for real-world use and a test server for trying out the latest mail server packages. When the test server passes the initial phase, you can set the production-level server to use the new packages.
Another example is a development life cycle for a software product. To develop a new piece of software in a development environment, test it in a quality assurance environment, pre-release as a beta, then release the software as a production-level application.
6.2. Promoting Content across the Application Life Cycle
In the application life cycle chain, when content moves from one environment to the next, this is called promotion.
| Development | Testing | Production |
example_software-1.1-0.noarch.rpm |
example_software-1.0-0.noarch.rpm |
After completing development on the patch, you promote the RPM to the Testing environment so the Quality Engineering team can review the patch. The application life cycle then contains the following package versions in each environment:
While the Quality Engineering team reviews the patch, the Development team starts work on example_software 2.0. This results in the following application life cycle:
exampleware-2.0-0.noarch.rpm |
exampleware-1.1-0.noarch.rpm |
exampleware-1.0-0.noarch.rpm |
example_software-2.0-0.noarch.rpm |
6.3. Creating a Life Cycle Environment Path
To create an application life cycle for developing and releasing software, use the Library environment as the initial environment to create environment paths. Then optionally add additional environments to the environment paths.
In the Foreman web UI, navigate to Content > Lifecycle Environments.
Click New Environment Path to start a new application life cycle.
In the Name field, enter a name for your environment.
In the Description field, enter a description for your environment.
Click Save.
Optional: To add an environment to the environment path, click Add New Environment, complete the Name and Description fields, and select the prior environment from the Prior Environment list.
To create an environment path, enter the
hammer lifecycle-environment createcommand and specify the Library environment with the--prioroption:# hammer lifecycle-environment create \ --name "Environment Path Name" \ --description "Environment Path Description" \ --prior "Library" \ --organization "My_Organization"
Optional: To add an environment to the environment path, enter the
hammer lifecycle-environment createcommand and specify the parent environment with the--prioroption:# hammer lifecycle-environment create \ --name "Environment Name" \ --description "Environment Description" \ --prior "Prior Environment Name" \ --organization "My_Organization"
To view the chain of the life cycle environment, enter the following command:
6.4. Removing Life Cycle Environments from Foreman server
Use this procedure to remove a life cycle environment.
In the Foreman web UI, navigate to Content > Life Cycle Environments.
Click the name of the life cycle environment that you want to remove, and then click Remove Environment.
Click Remove to remove the environment.
List the life cycle environments for your organization and note the name of the life cycle environment you want to remove:
# hammer lifecycle-environment list --organization "My_Organization"
Use the
hammer lifecycle-environment deletecommand to remove an environment:# hammer lifecycle-environment delete \ --name "your_environment" \ --organization "My_Organization"
6.5. Removing Life Cycle Environments from Smart Proxy server
When life cycle environments are no longer relevant to the host system or environments are added incorrectly to Smart Proxy server, you can remove the life cycle environments from Smart Proxy server.
You can use both the Foreman web UI and the Hammer to remove life cycle environments from Smart Proxy.
In the Foreman web UI, navigate to Infrastructure > Smart Proxies, and select the Smart Proxy that you want to remove a life cycle from.
Click Edit and click the Life Cycle Environments tab.
From the right menu, select the life cycle environments that you want to remove from Smart Proxy, and then click Submit.
To synchronize Smart Proxy’s content, click the Overview tab, and then click Synchronize.
Select either Optimized Sync or Complete Sync.
Select Smart Proxy server that you want from the list and take note of its id:
# hammer capsule list
To verify Smart Proxy server’s details, enter the following command:
# hammer capsule info --id capsule_id
Verify the list of life cycle environments currently attached to Smart Proxy server and take note of the environment id:
# hammer capsule content lifecycle-environments \ --id capsule_id
Remove the life cycle environment from Smart Proxy server:
# hammer capsule content remove-lifecycle-environment \ --id capsule_id \ --lifecycle-environment-id lifecycle_environment_id
Repeat this step for every life cycle environment that you want to remove from Smart Proxy server.
Synchronize the content from Foreman server’s environment to Smart Proxy server:
# hammer capsule content synchronize \ --id capsule_id
6.6. Adding Life Cycle Environments to Smart Proxy servers
If your Smart Proxy server has the content functionality enabled, you must add an environment so that Smart Proxy can synchronize content from Foreman server and provide content to host systems.
Do not assign the Library lifecycle environment to your Smart Proxy server because it triggers an automated Smart Proxy sync every time the CDN updates a repository. This might consume multiple system resources on Smart Proxies, network bandwidth between Foreman and Smart Proxies, and available disk space on Smart Proxies.
You can use Hammer CLI on Foreman server or the Foreman web UI.
In the Foreman web UI, navigate to Infrastructure > Smart Proxies, and select the Smart Proxy that you want to add a life cycle to.
From the left menu, select the life cycle environments that you want to add to Smart Proxy and click Submit.
To synchronize the content on the Smart Proxy, click the Overview tab and click Synchronize.
To display a list of all Smart Proxy servers, on Foreman server, enter the following command:
Note the Smart Proxy ID of the Smart Proxy that you want to add a life cycle to.
Using the ID, verify the details of your Smart Proxy:
To view the life cycle environments available for your Smart Proxy server, enter the following command and note the ID and the organization name:
# hammer capsule content available-lifecycle-environments --id capsule_id
Add the life cycle environment to your Smart Proxy server:
# hammer capsule content add-lifecycle-environment \ --id capsule_id --organization "My_Organization" \ --lifecycle-environment-id lifecycle-environment_id
Repeat for each life cycle environment you want to add to Smart Proxy server.
Synchronize the content from Foreman to Smart Proxy.
To synchronize all content from your Foreman server environment to Smart Proxy server, enter the following command:
# hammer capsule content synchronize --id capsule_id
To synchronize a specific life cycle environment from your Foreman server to Smart Proxy server, enter the following command:
# hammer capsule content synchronize --id external_capsule_id \ --lifecycle-environment-id lifecycle-environment_id
7. Managing Content Views
Foreman uses Content Views to create customized repositories from the repositories. To do this, you must define which repositories to use and then apply certain filters to the content. These filters include both package filters, package group filters, errata filters, and module stream filters. You can use Content Views to define which software versions a particular environment uses. For example, a Production environment might use a Content View containing older package versions, while a Development environment might use a Content View containing newer package versions.
Each Content View creates a set of repositories across each environment, which Foreman server stores and manages. When you promote a Content View from one environment to the next environment in the application life cycle, the respective repository on Foreman server updates and publishes the packages.
| Development | Testing | Production | |
Content View Version and Contents |
Version 2 - example_software-1.1-0.noarch.rpm |
Version 1 - example_software-1.0-0.noarch.rpm |
The repositories for Testing and Production contain the example_software-1.0-0.noarch.rpm package.
If you promote Version 2 of the Content View from Development to Testing, the repository for Testing regenerates and then contains the example_software-1.1-0.noarch.rpm package:
Create a Content View.
Add one or more repositories that you want to the Content View.
Optionally, create one or more filters to refine the content of the Content View.
Optionally, resolve any package dependencies for a Content View.
Publish the Content View.
Optionally, promote the Content View to another environment.
Attach the content host to the Content View.
If a repository is not associated with the Content View, the file /etc/yum.repos.d/redhat.repo remains empty and systems registered to it cannot receive updates.
Package dependency is a complication of package management. For more information about how to manage package dependencies within Content Views, see Resolving Package Dependencies.
7.1. Creating a Content View
Use this procedure to create a simple Content View. To use the CLI instead of the Foreman web UI, see the CLI procedure.
While you can stipulate whether you want to resolve any package dependencies on a Content View by Content View basis, you might want to change the default Foreman settings to enable or disable package resolution for all Content Views. For more information, see Resolving Package Dependencies.
In the Name field, enter a name for the view. Foreman automatically completes the Label field from the name you enter.
In the Description field, enter a description of the view.
Optional: if you want to solve dependencies automatically every time you publish this Content View, select the Solve Dependencies check box. Dependency solving slows the publishing time and might ignore any Content View filters you use. This can also cause errors when resolving dependencies for errata.
Click Save to create the Content View.
In the Repository Selection area, select the repositories that you want to add to your Content View, then click Add Repositories.
Click Publish New Version and in the Description field, enter information about the version to log changes.
Click Save.
Optional: to force metadata regeneration on Yum repositories, from the Actions list for your Content View versions, select Regenerate Repository Metadata.
You can view the Content View in the Content Views window. To view more information about the Content View, click the Content View name.
To register a host to your content view, see Registering Hosts in the Managing Hosts guide.
Create the Content View and add repositories:
# hammer content-view create \ --name "Example_Content_View" \ --description "Example Content View" \ --repository-ids 1,2 \ --organization "My_Organization"
For the
--repository-idsoption, you can find the IDs in the output of thehammer repository listcommand. -
Publish the view:
# hammer content-view publish \ --name "Example_Content_View" \ --description "Example Content View" \ --organization "My_Organization"
Optional: To add a repository to an existing Content View, enter the following command:
#Â hammer content-view add-repository \ --name "Example_Content_View" \ --organization "My_Organization" \ --repository-id repository_ID
Foreman server creates the new version of the view and publishes it to the Library environment.
7.2. Viewing Module Streams
In Foreman, you can view the module streams of the repositories in your Content Views.
To view module streams for the repositories in your content view, complete the following steps:
In the Foreman web UI, navigate to Content > Content Views, and select the Content View that contains the modules you want to view.
Click the Versions tab and select the Content View version that you want to view.
Click the Module Streams tab to view the module streams that are available for the Content View.
Use the Filter field to refine the list of modules.
To view the information about the module, click the module.
7.3. Promoting a Content View
Use this procedure to promote Content Views across different lifecycle environments. To use the CLI instead of the Foreman web UI, see the CLI procedure.
promote_or_remove_content_views -
promote_or_remove_content_views_to_environment.
The promote_or_remove_content_views permission restricts which Content Views a user can promote.
The promote_or_remove_content_views_to_environment permission restricts the environments to which a user can promote Content Views.
In the Foreman web UI, navigate to Content > Content Views and select the Content View that you want to promote.
Click the Versions tab for the Content View.
Select the version that you want to promote and in the Actions column, click Promote.
Select the environment where you want to promote the Content View, and click Promote Version.
Click the Promote button again. This time select the Testing environment and click Promote Version.
Finally click on the Promote button again. Select the Production environment and click Promote Version.
Promote the Content View using the
hammer content-view version promoteeach time:# hammer content-view version promote \ --content-view "Database" \ --version 1 \ --to-lifecycle-environment "Development" \ --organization "My_Organization" # hammer content-view version promote \ --content-view "Database" \ --version 1 \ --to-lifecycle-environment "Testing" \ --organization "My_Organization" # hammer content-view version promote \ --content-view "Database" \ --version 1 \ --to-lifecycle-environment "Production" \ --organization "My_Organization"
7.4. Promoting a Content View Across All Life Cycle Environments within an Organization
Use this procedure to promote Content Views across all lifecycle environments within an organization.
To promote a Content Views version across all lifecycle environments within an organization, complete the following steps:
To promote a selected Content View version from Library across all life cycle environments within an organization, run the following Bash script:
ORG="Your_Organization" CVV_ID=3 for i in $(hammer --no-headers --csv lifecycle-environment list --organization $ORG | awk -F, {'print $1'} | sort -n) do hammer content-view version promote --organization $ORG --to-lifecycle-environment-id $i --id $CVV_ID done -
Display information about your Content View version to verify that it is promoted to the required lifecycle environments:
#Â hammer content-view version info --id 3
7.5. Composite Content Views Overview
| example_software |
Application |
Database |
Operating System |
Red Hat Enterprise Linux (Operating System)
PostgreSQL (Database)
MariaDB (Database)
| Composite Content View 1 - example_software on PostgreSQL |
example_software (Application) |
PostgreSQL (Database) |
Red Hat Enterprise Linux (Operating System) |
| Composite Content View 2 - example_software on MariaDB |
MariaDB (Database) |
You cannot include more than one of each repository in Composite Content Views. For example, if you attempt to include two Content Views using the same repository in a Composite Content View, Foreman server reports an error.
7.6. Creating a Composite Content View
Use this procedure to create a composite content view. To use the CLI instead of the Foreman web UI, see the CLI procedure.
In the Foreman web UI, navigate to Content > Content Views and click Create New View.
Select the Composite View? check box to create a Composite Content View.
Optional: select the Auto Publish check box if you want the Composite Content View to be republished automatically when a Content View is republished.
Click Save.
In the Add Content Views area, select the Content Views that you want to add to the Composite Content View, and then click Add Content Views.
Click Publish New Version to publish the Composite Content View. In the Description field, enter a description and click Save.
Click Promote and select the lifecycle environments to promote the Composite Content View to, enter a description, and then click Promote Version.
Before you create the Composite Content Views, list the version IDs for your existing Content Views:
# hammer content-view version list \ --organization "My_Organization"
Create a new Composite Content View. When the
--auto-publishoption is set toyes, the Composite Content View is automatically republished when a Content View it includes is republished:# hammer content-view create \ --composite \ --auto-publish yes \ --name "Example_Composite_Content_View" \ --description "Example Composite Content View" \ --organization "My_Organization"
Add a component Content View to the Composite Content View. You must include the Content View Version ID and use the
--latestoption. To include multiple component Content Views to the Composite Content View, repeat this step for every Content View you want to include:# hammer content-view component add \ --component-content-view-id Content_View_Version_ID \ --latest \ --composite-content-view "Example_Composite_Content_View"
Publish the Composite Content View:
# hammer content-view publish \ --name "Example_Composite_Content_View" \ --description "Initial version of Composite Content View" \ --organization "My_Organization"
Promote the Composite Content View across all environments:
# hammer content-view version promote \ --content-view "Example_Composite_Content_View" \ --version 1 \ --to-lifecycle-environment "Development" \ --organization "My_Organization" # hammer content-view version promote \ --content-view "Example_Composite_Content_View" \ --version 1 \ --to-lifecycle-environment "Testing" \ --organization "My_Organization" # hammer content-view version promote \ --content-view "Example_Composite_Content_View" \ --version 1 \ --to-lifecycle-environment "Production" \ --organization "My_Organization"
7.7. Content Filter Overview
Content Views also use filters to include or restrict certain RPM content. Without these filters, a Content View includes everything from the selected repositories.
| Filter Type | Description |
Include |
You start with no content, then select which content to add from the selected repositories. Use this filter to combine multiple content items. |
Exclude |
You start with all content from selected repositories, then select which content to remove. Use this filter when you want to use most of a particular content repository but exclude certain packages, such as blacklisted packages. The filter uses all content in the repository except for the content you select. |
There are also five types of content to filter:
| Content Type | Description |
Package |
Filter packages based on their name and version number. The Package option filters non-modular RPM packages and errata. |
Package Group |
Filter packages based on package groups. The list of package groups is based on the repositories added to the Content View. |
Erratum (by ID) |
Select which specific errata to add to the filter. The list of Errata is based on the repositories added to the Content View. |
Erratum (by Date and Type) |
Select a issued or updated date range and errata type (Bugfix, Enhancement, or Security) to add to the filter. |
Module Streams |
Select whether to include or exclude specific module streams. The Module Streams option filters modular RPMs and errata, but does not filter non-modular content that is associated with the selected module stream. |
7.8. Resolving Package Dependencies
In Foreman, you can use the package dependency resolution feature to ensure that any dependencies that packages have within a Content View are added to the dependent repository as part of the Content View publication process.
You can select to resolve package dependencies for any Content View that you want, or you can change the default setting to enable or disable resolving package dependencies for all new Content Views.
Note that resolving package dependencies can cause significant delays to Content View promotion. The package dependency resolution feature does not consider packages that are installed on your system independently of the Content View or solve dependencies across repositories.
Filters do not resolve any dependencies of the packages listed in the filters. This might require some level of testing to determine what dependencies are required.
If you add a filter that excludes some packages that are required and the Content View has dependency resolution enabled, Foreman ignores the rules you create in your filter in favor of resolving the package dependency.
If you create a content filter for security purposes, to resolve a package dependency, Foreman can add packages that you might consider insecure.
To resolve package dependencies by default, complete the following steps:
In the Foreman web UI, navigate to Administer > Settings and click the Content tab.
Locate the Content View Dependency Solving Default, and select Yes.
You can also set the default level of dependency resolution that you want. You can select between adding packages to solve dependencies only if the required package does not exist, or to add the latest packages to resolve the dependency even if the package exists in the repository.
To set the default level of dependency resolution, complete the following steps:
Locate the Content View Dependency Solving Algorithm and select one of the following options:
To add the package that resolves the dependency only if it does not exist in the repository, select Conservative.
To add the package that resolves the dependency regardless of whether or not it exists in the repository, select Greedy.
7.9. Content Filter Examples
Create a repository with the base Red Hat Enterprise Linux packages. This filter requires a Red Hat Enterprise Linux repository added to the Content View.
Filter:
Inclusion Type: Include
Content Type: Package Group
Filter: Select only the Base package group
Create a repository that excludes all errata, except for security updates, after a certain date. This is useful if you want to perform system updates on a regular basis with the exception of critical security updates, which must be applied immediately. This filter requires a Red Hat Enterprise Linux repository added to the Content View.
Filter:
Inclusion Type: Exclude
Content Type: Erratum (by Date and Type)
Filter: Select only the Bugfix and Enhancement errata types, and clear the Security errata type. Set the Date Type to Updated On. Set the Start Date to the date you want to restrict errata. Leave the End Date blank to ensure any new non-security errata is filtered.
Filter 1:
Filter 2:
Filter 1:
Content Type: Module Stream
Filter: Select only the specific module stream that you want for the Content View, for example ant, and click Add Module Stream.
Filter 2:
Filter: Add a rule to filter any non-modular packages that you want to exclude from the Content View. If you do not filter the packages, the Content View filter includes all non-modular packages associated with the module stream ant. Add a rule to exclude all
*packages, or specify the package names that you want to exclude.
7.10. Creating a Content Filter
Use this procedure to create a content filter. To use the CLI instead of the Foreman web UI, see the CLI procedure.
In the Foreman web UI, navigate to Content > Content Views and select a Content View.
Navigate to Yum Content > Filters and click New Filter.
In the Name field, enter a name for your filter.
From the Content Type list, select the content type that you want to filter. Depending on what you select for the new filter’s content type, different options appear.
From the Inclusion Type list, select either Include or Exclude.
In the Description field, enter a description for the filter, and click Save.
Depending on what you enter for Content Type, add rules to create the filter that you want.
Click the Affected repositories tab to select which specific repositories use this filter.
Click Publish New Version to publish the filtered repository. In the Description field, enter a description of the changes, and click Save.
Add a filter to the Content View. Use the
--inclusion falseoption to set the filter to an Exclude filter:# hammer content-view filter create \ --name "Errata Filter" \ --type erratum --content-view "Example_Content_View" \ --description "My latest filter" \ --inclusion false \ --organization "My_Organization"
Add a rule to the filter:
# hammer content-view filter rule create \ --content-view "Example_Content_View" \ --content-view-filter "Errata Filter" \ --start-date "YYYY-MM-DD" \ --types enhancement,bugfix \ --date-type updated \ --organization "My_Organization"
Publish the Content View:
# hammer content-view publish \ --name "Example_Content_View" \ --description "Adding errata filter" \ --organization "My_Organization"
Promote the view across all environments:
# hammer content-view version promote \ --content-view "Example_Content_View" \ --version 1 \ --to-lifecycle-environment "Development" \ --organization "My_Organization" # hammer content-view version promote \ --content-view "Example_Content_View" \ --version 1 \ --to-lifecycle-environment "Testing" \ --organization "My_Organization" # hammer content-view version promote \ --content-view "Example_Content_View" \ --version 1 \ --to-lifecycle-environment "Production" \ --organization "My_Organization"
8. Synchronizing Content Between Foreman servers
Foreman uses Inter-Foreman Synchronization (ISS) to synchronize content Foreman servers, or between organizations on Foreman server.
You can use ISS in the following scenarios:
If you want to copy some but not all content from your Foreman server to other Foreman servers. For example, you have Content Views that your IT department validates on Foreman server, and you want to copy content from those Content Views to other Foreman servers.
If you want to clone a Content View from one organization to another organization on Foreman server.
You cannot use ISS to synchronize content from Foreman server to Smart Proxy server. Smart Proxy server supports synchronization natively. For more information, see Smart Proxy server Overview in Planning for Foreman.
8.1. Exporting a Content View Version
You can export a version of a Content View to an archive file from Foreman server and use this archive file to create the same Content View version on another Foreman server or on another Foreman server organization. Foreman does not export composite Content Views. The exported archive file contains the following data:
A JSON file containing Content View version metadata
An archive file containing all the repositories included into the Content View version
Foreman server exports only RPM and kickstart files added to a version of a Content View. Foreman does not export the following content:
Puppet content
Docker content
OSTree content
Content View definitions and metadata, such as package filters.
To export a Content View, ensure that Foreman server where you want to export meets the following conditions:
Ensure that the export directory has free storage space to accommodate the export.
Ensure that the
/var/lib/pulp/exportsdirectory has free storage space equivalent to the size of the repositories being exported for temporary files created during the export process. -
Ensure that you set download policy to Immediate for all repositories within the Content View you export. For more information, see Download Policies Overview.
Ensure that you synchronize Products that you export to the required date.
List versions of the Content View that are available for export:
# hammer content-view version list --organization=export-org --content-view=view ---|----------|---------|-------------|----------------------- ID | NAME | VERSION | DESCRIPTION | LIFECYCLE ENVIRONMENTS ---|----------|---------|-------------|----------------------- 5 | view 3.0 | 3.0 | | Library 4 | view 2.0 | 2.0 | | 3 | view 1.0 | 1.0 | | ---|----------|---------|-------------|----------------------
Get the version number of desired version. The following example targets version 1.0 for export.
# hammer content-export complete version --content-view=view --version=1.0 --organization=export-21527
Verify that the archive containing the exported version of a Content View is located in the export directory:
# ls -lh /var/lib/pulp/exports/export-21527/view/1.0/2021-02-25T18-59-26-00-00/
You require all three files, for example, the
tar.gzarchive file, thetoc.jsonandmetadata.jsonto import the content successfully.
# hammer content-export complete version --content-view=view --version=1.0 --organization=export-21527 --chunk-size-mb=10 # ls -lh /var/lib/pulp/exports/export-21527/view/1.0/2021-02-25T21-15-22-00-00/
Exporting complete versions can be a very expensive operation on storage space and resources. Content View versions that have multiple Red Hat Enterprise Linux trees can occupy several gigabytes of the space on Foreman server.
You can use the Incremental Export functionality to help reduce demands on your infrastructure.
Incremental Export exports only content that changes from the previously exported version.
Generally, incremental changes are smaller than full exports.
ln the following example, since version 1.0 has already been exported and the command targets version 2.0 for export.
To use incremental export, complete the following steps.
# hammer content-export incremental version --content-view=view --version=2.0 --organization=export-21527 # ls -lh /var/lib/pulp/exports/export-21527/view/2.0/2021-02-25T21-45-34-00-00/
8.2. Examining the exports
You can query on the exports that you previously have created via the hammer content-export list command.
hammer content-export list --organization=export-21527 ---|--------------------|-----------------------------------------------------------------------|-------------|----------------------|-------------------------|-------------------------|------------------------ ID | DESTINATION SERVER | PATH | TYPE | CONTENT VIEW VERSION | CONTENT VIEW VERSION ID | CREATED AT | UPDATED AT ---|--------------------|-----------------------------------------------------------------------|-------------|----------------------|-------------------------|-------------------------|------------------------ 1 | | /var/lib/pulp/exports/export-21527/view/1.0/2021-02-25T18-59-26-00-00 | complete | view 1.0 | 3 | 2021-02-25 18:59:30 UTC | 2021-02-25 18:59:30 UTC 2 | | /var/lib/pulp/exports/export-21527/view/1.0/2021-02-25T21-15-22-00-00 | complete | view 1.0 | 3 | 2021-02-25 21:15:26 UTC | 2021-02-25 21:15:26 UTC 3 | | /var/lib/pulp/exports/export-21527/view/2.0/2021-02-25T21-45-34-00-00 | incremental | view 2.0 | 4 | 2021-02-25 21:45:37 UTC | 2021-02-25 21:45:37 UTC ---|--------------------|-----------------------------------------------------------------------|-------------|----------------------|-------------------------|-------------------------|------------------------
8.3. Importing a Content View Version
You can use the archive that the hammer content-export command outputs to create a version of a Content View with the same content as the exported Content View version.
For more information about exporting a Content View version, see Exporting a Content View Version.
When you import a Content View version, it has the same major and minor version numbers and contains the same repositories with the same packages and errata.
You can customize the version numbers by changing the major and minor settings in the json file that is located in the exported archive.
To import a Content View, ensure that Foreman server where you want to import meets the following conditions:
The exported archive must be in a directory under
/var/lib/pulp/imports. -
The directory must have
pulp:pulppermissions so that Pulp can read and write the.jsonfiles in that directory. -
The user importing the content view version must have the 'Content Importer' Role.
Copy the archived file with the exported Content View version to the
/var/lib/pulp/importsdirectory on Foreman server where you want to import. -
Set the SELinux permission of the archive files to
pulp:pulp.# chown -R pulp:pulp /var/lib/pulp/imports/2021-02-25T21-15-22-00-00/
Verify that the SELinux permission change occurs:
On Foreman server where you want to import, create a Content View with the same name and label as the exported Content View with the
Import Onlyoption set. For more information, see Creating a Content View. -
Ensure that you enable the repositories that the Products in the exported Content View version include. For more information, see Enabling Red Hat Repositories.
In the Foreman web UI, navigate to Content > Products, click the Yum content tab and add the same
Yumcontent that the exported Content View version includes. -
Identify the Content View that you want to import
# hammer content-view list --organization=import-20639 ----------------|---------------------------|--------------------------------------|-----------|---------------------|--------------- CONTENT VIEW ID | NAME | LABEL | COMPOSITE | LAST PUBLISHED | REPOSITORY IDS ----------------|---------------------------|--------------------------------------|-----------|---------------------|--------------- 4 | Default Organization View | 6e13cfca-cfb3-4870-9d8b-3bdc0caf97c9 | false | 2021/03/01 22:50:10 | 5 | view | view | false | | ----------------|---------------------------|--------------------------------------|-----------|---------------------|--------------- +
To import the Content View version to Foreman server, enter the following command:
# hammer content-import version --content-view=view \ --organization=import-20639 \ --path=/var/lib/pulp/imports/2021-02-25T21-15-22-00-00/Note that you must enter the full path
/var/lib/pulp/imports/<path>. Relative paths do not work. -
To verify that you import the Content View version successfully, list Content Views for your organization:
# hammer content-view version list --content-view=view \ --organization=import-20639 ---|----------|---------|-------------|----------------------- ID | NAME | VERSION | DESCRIPTION | LIFECYCLE ENVIRONMENTS ---|----------|---------|-------------|----------------------- 7 | view 1.0 | 1.0 | | Library ---|----------|---------|-------------|-----------------------
8.4. Exporting a Content View Version
You can export contents of all Yum repositories in the Library environment of an organization to an archive file from Foreman server and use this archive file to create the same repositories in another Foreman server or in another Foreman server organization. The exported archive file contains the following data:
An archive file containing all the repositories from the Library environment of the organization.
Foreman server exports only RPM and kickstart files included in a Content View version. Foreman does not export the following content:
Puppet content
Docker content
OSTree content
To export the contents of the Library lifecycle environment of the organization, ensure that Foreman server where you want to export meets the following conditions:
Ensure that the
Ensure that you set download policy to Immediate for all repositories within the Library lifecycle environment you export. For more information, see Download Policies Overview.
Use the organization name or ID to export.
# hammer content-export complete library --organization=export-21527
# ls -lh /var/lib/pulp/exports/export-21527/Export-Library/1.0/2021-03-02T03-35-24-00-00 total 68M -rw-r--r--. 1 pulp pulp 68M Mar 2 03:35 export-1e25417c-6d09-49d4-b9a5-23df4db3d52a-20210302_0335.tar.gz -rw-r--r--. 1 pulp pulp 333 Mar 2 03:35 export-1e25417c-6d09-49d4-b9a5-23df4db3d52a-20210302_0335-toc.json -rw-r--r--. 1 root root 443 Mar 2 03:35 metadata.json
tar.gz, thetoc.jsonand themetadata.jsonfile to be able to import. -
A new Content View Export-Library is created in the organization. This content view contains all the repositories belonging to this organization. A new version of this Content View is published and exported automatically.
In many cases the exported archive content may be several gigabytes in size. We may want to split it smaller sizes or chunks. We can use the --chunk-size-mb flag directly in the export command to handle this. In the example below we specify --chunk-size-mb=10 to split the archives in 10 MB chunks.
# hammer content-export complete library --organization=export-21527 --chunk-size-mb=10 [.....................................................................................................................................................................................................................................] [100%] Generated /var/lib/pulp/exports/export-21527/Export-Library/2.0/2021-03-02T04-01-25-00-00/metadata.json # ls -lh /var/lib/pulp/exports/export-21527/Export-Library/2.0/2021-03-02T04-01-25-00-00/ total 68M -rw-r--r--. 1 pulp pulp 10M Mar 2 04:01 export-fa948a08-b307-492e-86f0-39cd41c87958-20210302_0401.tar.gz.0000 -rw-r--r--. 1 pulp pulp 10M Mar 2 04:01 export-fa948a08-b307-492e-86f0-39cd41c87958-20210302_0401.tar.gz.0001 -rw-r--r--. 1 pulp pulp 10M Mar 2 04:01 export-fa948a08-b307-492e-86f0-39cd41c87958-20210302_0401.tar.gz.0002 -rw-r--r--. 1 pulp pulp 10M Mar 2 04:01 export-fa948a08-b307-492e-86f0-39cd41c87958-20210302_0401.tar.gz.0003 -rw-r--r--. 1 pulp pulp 10M Mar 2 04:01 export-fa948a08-b307-492e-86f0-39cd41c87958-20210302_0401.tar.gz.0004 -rw-r--r--. 1 pulp pulp 10M Mar 2 04:01 export-fa948a08-b307-492e-86f0-39cd41c87958-20210302_0401.tar.gz.0005 -rw-r--r--. 1 pulp pulp 7.7M Mar 2 04:01 export-fa948a08-b307-492e-86f0-39cd41c87958-20210302_0401.tar.gz.0006 -rw-r--r--. 1 pulp pulp 1.2K Mar 2 04:01 export-fa948a08-b307-492e-86f0-39cd41c87958-20210302_0401-toc.json -rw-r--r--. 1 root root 443 Mar 2 04:01 metadata.json
Exporting Library content can be a very expensive operation in terms of space and resources. Organization that have multiple RHEL trees may occupy several gigabytes of the space on Foreman server.
Foreman server offers Incremental Export to help with this scenario. Incremental Export exports only things that changed from the previous export. These would be typically smaller than the full exports. In the example below we will incrementally export what changed from the previous export of all the repositories in the Library lifecycle environment.
# hammer content-export incremental library --organization=export-21527 [............................................................................................................................................................................................................] [100%] Generated /var/lib/pulp/exports/export-21527/Export-Library/3.0/2021-03-02T04-22-14-00-00/metadata.json # ls -lh /var/lib/pulp/exports/export-21527/Export-Library/3.0/2021-03-02T04-22-14-00-00/ total 172K -rw-r--r--. 1 pulp pulp 161K Mar 2 04:22 export-436882d8-de5a-48e9-a30a-17169318f908-20210302_0422.tar.gz -rw-r--r--. 1 pulp pulp 333 Mar 2 04:22 export-436882d8-de5a-48e9-a30a-17169318f908-20210302_0422-toc.json -rw-r--r--. 1 root root 492 Mar 2 04:22 metadata.json
Since nothing changed between the previous export and now in the Organization’s library environment the change files are really small.
8.5. Importing a Content View Version
You can use the archive that the hammer content-export command outputs to import into the Library lifecycle environment of another organization
For more information about exporting contents from the Library environment, see Exporting a Content View Version.
To import in to an Organization’s library lifecycle environment ensure that Foreman server where you want to import meets the following conditions:
The products and repositories in the organization need to match the product/repository structure in the content archive being imported.
Set the permission of the archive files to
pulp:pulp.# chown -R pulp:pulp /var/lib/pulp/imports/2021-03-02T03-35-24-00-00 # ls -lh /var/lib/pulp/imports/2021-03-02T03-35-24-00-00 total 68M -rw-r--r--. 1 pulp pulp 68M Mar 2 04:29 export-1e25417c-6d09-49d4-b9a5-23df4db3d52a-20210302_0335.tar.gz -rw-r--r--. 1 pulp pulp 333 Mar 2 04:29 export-1e25417c-6d09-49d4-b9a5-23df4db3d52a-20210302_0335-toc.json -rw-r--r--. 1 pulp pulp 443 Mar 2 04:29 metadata.json
On Foreman server where you want to import, create/enable repositories the same name and label as the exported content.
Identify the Organization that you wish to import into.
To import the Library content to Foreman server, enter the following command:
# hammer content-import library --organization=import-32158 \ --path=/var/lib/pulp/imports/2021-03-02T03-35-24-00-00 [............................................................................................................................................................................................................] [100%]Note you must enter the full path
To verify that you imported the Library content, check the contents of the Product and Repositories. A new Content View called
Import-Libraryis created in the target organization. This Content View is used to facilitate the library content import.
8.6. Import/Export Cheat Sheet
| Intent | Command |
Fully Export a content view version |
Incrementally Export a content view version (assuming you have already exported something) |
Fully Export an Organization’s Library |
Incrementally Export an Organization’s Library (assuming you have already exported something) |
Export a content view version promoted to the Dev Environment |
Export a content view in smaller chunks (200 mb slabs) |
Get a list of exports |
| Intent | Command |
Import to a content view version (view is a |
Import to an Organization’s Library |
9. Managing Activation Keys
Activation keys provide a method to automate system registration and subscription attachment. You can create multiple keys and associate them with different environments and Content Views. For example, you might create a basic activation key with a subscription for Red Hat Enterprise Linux workstations and associate it with Content Views from a particular environment.
Associated subscriptions and subscription attachment behavior
Available products and repositories
A life cycle environment and a Content View
Host collection membership
System purpose
When you provision a host, Foreman uses provisioning templates and other content from the Content View that you set in the host group or host settings. When the host is registered, the Content View from the activation key overwrites the original Content View from the host group or host settings. Then Foreman uses the Content View from the activation key for every future task, for example, rebuilding a host.
$ hammer hostgroup set-parameter \ --name kt_activation_keys \ --value name_of_first_key, name_of_second_key,... \ --hostgroup hostgroup_name
9.1. Creating an Activation Key
Are there any subscriptions associated with the activation key?
Is the auto-attach option enabled?
For Red Hat Enterprise Linux 8 hosts: Is there system purpose set on the activation key?
Note that Foreman automatically attaches subscriptions only for the products installed on a host. For subscriptions that do not list products installed on Red Hat Enterprise Linux by default, such as the Extended Update Support (EUS) subscription, use an activation key specifying the required subscriptions and with the auto-attach disabled.
Activation key that attaches subscriptions automatically.
With no subscriptions specified and auto-attach enabled, hosts using the activation key search for the best fitting subscription from the ones provided by the Content View associated with the activation key. This is similar to entering the
subscription-manager --auto-attachcommand. For Red Hat Enterprise Linux 8 hosts, you can configure the activation key to set system purpose on hosts during registration to enhance the automatic subscriptions attachment. -
Activation key providing a custom set of subscription for auto-attach.
Activation key with the exact set of subscriptions.
If a product, typically containing content not provided by Red Hat, is assigned to an activation key, this product is always enabled for the registered content host regardless of the auto-attach setting.
To create an activation key, complete the following steps. To use the CLI instead of the Foreman web UI, see the CLI procedure.
In the Foreman web UI, navigate to Content > Activation keys and click Create Activation Key.
In the Name field, enter the name of the activation key.
If you want to set a limit, clear the Unlimited hosts check box, and in the Limit field, enter the maximum number of systems you can register with the activation key. If you want unlimited hosts to register with the activation key, ensure the Unlimited Hosts check box is selected.
In the Description field, enter a description for the activation key.
From the Environment list, select the environment to use.
From the Content View list, select a Content View to use. If you intend to use the deprecated
Katello Agentinstead ofRemote Execution, the Content View must contain the https://yum.theforeman.org/client/3.0/ repository because it contains thekatello-agentpackage. -
Click Save.
Optional: For Red Hat Enterprise Linux 8 hosts, in the System Purpose section, you can configure the activation key with system purpose to set on hosts during registration to enhance subscriptions auto attachment.
Create the activation key:
# hammer activation-key create \ --name "My_Activation_Key" \ --unlimited-hosts \ --description "Example Stack in the Development Environment" \ --lifecycle-environment "Development" \ --content-view "Stack" \ --organization "My_Organization"
Optional: For Red Hat Enterprise Linux 8 hosts, enter the following command to configure the activation key with system purpose to set on hosts during registration to enhance subscriptions auto attachment.
# hammer activation-key update \ --organization "My_Organization" \ --name "My_Activation_Key" \ --service-level "Standard" \ --purpose-usage "Development/Test" \ --purpose-role "Red Hat Enterprise Linux Server" \ --purpose-addons "addons"
Obtain a list of your subscription IDs:
Attach the Red Hat Enterprise Linux subscription UUID to the activation key:
# hammer activation-key add-subscription \ --name "My_Activation_Key" \ --subscription-id ff808181533518d50152354246e901aa \ --organization "My_Organization"
List the product content associated with the activation key:
# hammer activation-key product-content \ --name "My_Activation_Key" \ --organization "My_Organization"
Override the default auto-enable status for the https://yum.theforeman.org/client/3.0/ repository. The default status is set to disabled. To enable, enter the following command:
# hammer activation-key content-override \ --name "My_Activation_Key" \ --content-label https://yum.theforeman.org/client/3.0/el7/x86_64/foreman-client-release.rpm \ --value 1 \ --organization "My_Organization"
9.2. Updating Subscriptions Associated with an Activation Key
Use this procedure to change the subscriptions associated with an activation key. To use the CLI instead of the Foreman web UI, see the CLI procedure.
Note that changes to an activation key apply only to machines provisioned after the change. To update subscriptions on existing content hosts, see Bulk Updating Content Hosts' Subscriptions.
In the Foreman web UI, navigate to Content > Activation keys and click the name of the activation key.
Click the Subscriptions tab.
To remove subscriptions, select List/Remove, and then select the check boxes to the left of the subscriptions to be removed and then click Remove Selected.
To add subscriptions, select Add, and then select the check boxes to the left of the subscriptions to be added and then click Add Selected.
Click the Repository Sets tab and review the repositories' status settings.
To enable or disable a repository, select the check box for a repository and then change the status using the Select Action list.
Click the Details tab, select a Content View for this activation key, and then click Save.
List the subscriptions that the activation key currently contains:
# hammer activation-key subscriptions \ --name My_Activation_Key \ --organization "My_Organization"
Remove the required subscription from the activation key:
# hammer activation-key remove-subscription \ --name "My_Activation_Key" \ --subscription-id ff808181533518d50152354246e901aa \ --organization "My_Organization"
For the
--subscription-idoption, you can use either the UUID or the ID of the subscription. -
Attach new subscription to the activation key:
For the
Override the default auto-enable status for the required repository:
# hammer activation-key content-override \ --name "My_Activation_Key" \ --content-label content_label \ --value 1 \ --organization "My_Organization"
For the
--valueoption, enter1for enable,0for disable.
9.3. Using Activation Keys for Host Registration
Registering new hosts during provisioning through Foreman. The kickstart provisioning templates in Foreman contain commands to register the host using an activation key that is defined when creating a host.
Registering existing Red Hat Enterprise Linux hosts. Configure Red Hat Subscription Manager to use Foreman server for registration and specify the activation key when running the
subscription-manager registercommand.
To use an activation key for host registration with an existing Red Hat Enterprise Linux 7 host to Foreman server, complete the following steps:
Download the consumer RPM for your Foreman server. This is located in the
pubdirectory on the host’s web server. For example, for a Foreman server with the host nameforeman.example.com, enter the following command on the host to register:# rpm -Uvh http://foreman.example.com/pub/katello-ca-consumer-latest.noarch.rpm
This RPM installs the necessary certificates for accessing repositories on Foreman server and configures Red Hat Subscription Manager to use the server’s URL.
On the host, enter the following command to register the host to Foreman using the activation key:
# subscription-manager register --activationkey="My_Activation_Key" \ --org="My_Organization"
To view a list of hosts for an organization, on Foreman server, enter the following command:
# hammer host list --organization "My_Organization"
# subscription-manager register --org="My_Organization" \ --activationkey="ak-VDC,ak-OpenShift"
Settings that conflict: Service Level, Release Version, Environment, Content View, and Product Content.
Settings that do not conflict and the host gets the union of them: Subscriptions and Host Collections.
Settings that influence the behavior of the key itself and not the host configuration: Content Host Limit and Auto-Attach.
9.4. Enabling Auto-Attach
You can enable auto-attach and have no subscriptions associated with the key. This type of key is commonly used to register virtual machines when you do not want the virtual machine to consume a physical subscription, but to inherit a host-based subscription from the hypervisor. For more information, see Configuring Virtual Machine Subscriptions in Foreman.
In the Foreman web UI, navigate to Content > Activation Keys.
Click the activation key name that you want to edit.
Click the edit icon next to Auto-Attach.
Select or clear the check box to enable or disable auto-attach.
Click Save.
Enter the following command to enable auto-attach on the activation key:
# hammer activation-key update --name "My_Activation_Key" \ --organization "My_Organization" --auto-attach true
9.5. Setting the Service Level
Click the activation key name you want to edit.
Click the edit icon next to Service Level.
Select the required service level from the list. The list only contains service levels available to the activation key.
Click Save.
Enter the following command to set a default service level to Premium on the activation key:
# hammer activation-key update --name "My_Activation_Key" \ --organization "My_Organization" --service-level premium
10. Managing Errata
As a part of Red Hat’s quality control and release process, we provide customers with updates for each release of official Red Hat RPMs. Red Hat compiles groups of related package into an erratum along with an advisory that provides a description of the update. There are three types of advisories (in order of importance):
- Security Advisory
- Bug Fix Advisory
- Product Enhancement Advisory
Foreman imports this errata information when synchronizing repositories with Red Hat’s Content Delivery Network (CDN). Foreman also provides tools to inspect and filter errata, allowing for precise update management. This way, you can select relevant updates and propagate them through Content Views to selected content hosts.
In Foreman, there are two keywords that describe an erratum’s relationship to the available content hosts:
- Applicable
- Installable
An erratum that applies to one or more content hosts and is available to install on the content host. Installable errata are available to a content host from life cycle environment and the associated Content View, but are not yet installed.
10.1. Inspecting Available Errata
The following procedure describes how to view and filter the available errata and how to display metadata of the selected advisory. To use the CLI instead of the Foreman web UI, see the CLI procedure.
Navigate to Content > Errata to view the list of available errata.
Use the filtering tools at the top of the page to limit the number of displayed errata:
Select the repository to be inspected from the list. All Repositories is selected by default.
The Applicable check box is selected by default to view only errata applicable to the selected repository. Select the Installable check box to view only errata marked as installable.
To search the table of errata, type the query in the Search field in the form of:
parameter operator value
See Parameters Available for Errata Search for the list of parameters available for search. Find the list of applicable operators in Supported Operators for Granular Search in Administering Foreman. Automatic suggestion works as you type. You can also combine queries with the use of and and or operators. For example, to display only security advisories related to the kernel package, type:
Click the Errata ID of the erratum you want to inspect:
The Details tab contains the description of the updated package as well as documentation of important fixes and enhancements provided by the update.
On the Content Hosts tab, you can apply the erratum to selected content hosts as described in Applying Errata to Multiple Hosts.
The Repositories tab lists repositories that already contain the erratum. You can filter repositories by the environment and Content View, and search for them by the repository name.
To view errata that are available for all organizations, enter the following command:
# hammer erratum list
To view details of a specific erratum, enter the following command:
You can search errata by entering the query with the
--searchoption. For example, to view applicable errata for the selected product that contains the specified bugs ordered so that the security errata are displayed on top, enter the following command:# hammer erratum list \ --product-id 7 \ --search "bug = 1213000 or bug = 1207972" \ --errata-restrict-applicable 1 \ --order "type desc"
| Parameter | Description | Example |
bug |
Search by the Bugzilla number. |
bug = 1172165 |
cve |
Search by the CVE number. |
cve = CVE-2015-0235 |
id |
Search by the errata ID. The auto-suggest system displays a list of available IDs as you type. |
id = RHBA-2014:2004 |
issued |
Search by the issue date. You can specify the exact date, like "Feb16,2015", or use keywords, for example "Yesterday", or "1 hour ago". The time range can be specified with the use of the "<" and ">" operators. |
issued < "Jan 12,2015" |
package |
Search by the full package build name. The auto-suggest system displays a list of available packages as you type. |
package = glib2-2.22.5-6.el6.i686 |
package_name |
Search by the package name. The auto-suggest system displays a list of available packages as you type. |
package_name = glib2 |
severity |
Search by the severity of the issue fixed by the security update. Specify Critical, Important, or Moderate. |
severity = Critical |
title |
Search by the advisory title. |
title ~ openssl |
type |
Search by the advisory type. Specify security, bugfix, or enhancement. |
type = bugfix |
updated |
Search by the date of the last update.
You can use the same formats as with the |
updated = "6 days ago" |
10.2. Subscribing to Errata Notifications
You can configure email notifications for Foreman users. Users receive a summary of applicable and installable errata, notifications on Content View promotion or after synchronizing a repository. For more information, see Configuring Email Notifications in the Administering Foreman guide.
10.3. Limitations to Repository Dependency Resolution
With Foreman, using incremental updates to your Content Views solves some repository dependency problems. However, dependency resolution at a repository level still remains problematic on occasion.
When a repository update becomes available with a new dependency, Foreman retrieves the newest version of the package to solve the dependency, even if there are older versions available in the existing repository package. This can create further dependency resolution problems when installing packages.
A repository on your client has the package example_repository-1.0 with the dependency example_repository-libs-1.0.
The repository also has another package example_tools-1.0.
A security erratum becomes available with the package example_tools-1.1.
The example_tools-1.1 package requires the example_repository-libs-1.1 package as a dependency.
After an incremental Content View update, the example_tools-1.1, example_tools-1.0, and example_repository-libs-1.1 are now in the repository.
The repository also has the packages example_repository-1.0 and example_repository-libs-1.0.
Note that the incremental update to the Content View did not add the package example_repository-1.1.
Because you can install all these packages using yum, no potential problem is detected.
However, when the client installs the example_tools-1.1 package, a dependency resolution problem occurs because both example_repository-libs-1.0 and example_repository-libs-1.1 cannot be installed.
There is currently no workaround for this problem. The larger the time frame, and major Y releases between the base set of RPMs and the errata being applied, the higher the chance of a problem with dependency resolution.
10.4. Creating a Content View Filter for Errata
ID - Select specific erratum to allow into your resulting repositories.
Date Range - Define a date range and include a set of errata released during that date range.
Type - Select the type of errata to include such as bug fixes, enhancements, and security updates.
Create a content filter to exclude errata after a certain date. This ensures your production systems in the application life cycle are kept up to date to a certain point. Then you can modify the filter’s start date to introduce new errata into your testing environment to test the compatibility of new packages into your application life cycle.
A Content View with the repositories that contain required errata is created. For more information, see Creating a Content View.
In the Foreman web UI, navigate to Content > Content Views and select a Content View that you want to use for applying errata.
Errata Filter. -
From the Content Type list, select Erratum - Date and Type.
From the Inclusion Type list, select Exclude.
Exclude errata items from YYYY-MM-DD. -
Click Save.
For Errata Type, select the check boxes of errata types you want to exclude. For example, select the Enhancement and Bugfix check boxes and clear the Security check box to exclude enhancement and bugfix errata after certain date, but include all the security errata.
For Date Type, select one of two check boxes:
Issued On for the issued date of the erratum.
Updated On for the date of the erratum’s last update.
Select the Start Date to exclude all errata on or after the selected date.
Leave the End Date field blank.
Click Save.
Click Publish New Version to publish the resulting repository.
Enter
Adding errata filterin the Description field. -
Click Save.
Click the Versions tab.
Click Promote to the right of the published version.
Select the environments you want to promote the Content View version to.
In the Description field, enter the description for promoting.
Click Promote Version to promote this Content View version across the required environments.
Create a filter for the errata:
# hammer content-view filter create --name "Filter Name" \ --description "Exclude errata items from the YYYY-MM-DD" \ --content-view "CV Name" --organization "Default Organization" \ --type "erratum"
Create a filter rule to exclude all errata on or after the Start Date that you want to set:
# hammer content-view filter rule create --start-date "YYYY-MM-DD" \ --content-view "CV Name" --content-view-filter="Filter Name" \ --organization "Default Organization" --types=security,enhancement,bugfix
# hammer content-view publish --name "CV Name" \ --organization "Default Organization"
Promote the Content View to the lifecycle environment so that the included errata are available to that lifecycle environment:
# hammer content-view version promote \ --content-view "CV Name" \ --organization "Default Organization" \ --to-lifecycle-environment "Lifecycle Environment Name"
10.5. Adding Errata to an Incremental Content View
In the Foreman web UI, navigate to Content > Errata.
From the Errata list, click the name of the errata that you want to apply.
Select the content hosts that you want to apply the errata to, and click Apply to Hosts. This creates the incremental update to the Content View.
If you want to apply the errata to the content host, select the Apply Errata to Content Hosts immediately after publishing check box.
NoteUntil BZ#1459807 is resolved, if you apply non-installable errata to hosts registered to Smart Proxy servers, do not select the Apply errata to Content Hosts immediately after publishing check box.
Instead, after clicking Confirm, wait for the errata Content View to be promoted and for the Smart Proxy synchronization task to finish. Then, the errata will be marked as
Installableand you can use the procedure again to apply it. -
Click Confirm to apply the errata.
List the errata and its corresponding IDs:
List the different content-view versions and the corresponding IDs:
Apply a single erratum to content-view version. You can add more IDs in a comma-separated list.
# hammer content-view version incremental-update \ --content-view-version-id 319 --errata-ids 34068b
10.6. Applying Errata to a Host
Use these procedures to review and apply errata to a host.
Synchronize Foreman repositories with the latest errata available from Red Hat. For more information, see Syncing Repositories.
Register the host to an environment and Content View on Foreman server. For more information, see Registering Hosts in the Managing Hosts guide.
Configure the host for remote execution. For more information about running remote execution jobs, see Configuring and Setting up Remote Jobs in the Managing Hosts guide.
If the host is already configured to receive content updates with the deprecated Katello Agent, migrate to remote execution instead. For more information, see Migrating from Katello Agent to Remote Execution in the Managing Hosts guide. |
To apply an erratum to a RHEL 8 host, complete the following steps:
On Foreman, list all errata for the host:
# hammer host errata list \ --host client.example.com
Find the module stream an erratum belongs to:
On the host, update the module stream:
# yum update Module_Stream_Name
To apply an erratum to a RHEL 7 host, complete the following steps:
In the Foreman web UI, navigate to Hosts > Content Hosts and select the host you want to apply errata to.
Navigate to the Errata tab to see the list of errata.
Select the errata to apply and click Apply Selected. In the confirmation window, click Apply.
After the task to update all packages associated with the selected errata completes, click the Details tab to view the updated packages.
List all errata for the host:
Apply the most recent erratum to the host. Identify the erratum to apply using the erratum ID.
Using
Remote Execution# hammer job-invocation create \ --feature katello_errata_install \ --inputs errata=ERRATUM_ID1,ERRATUM_ID2 \ --search-query "name = client.example.com"
Using
Katello Agent(deprecated)# hammer host errata apply --host "client.example.com" \ --errata-ids ERRATUM_ID1,ERRATUM_ID2...
10.7. Applying Errata to Multiple Hosts
Use these procedures to review and apply errata to multiple RHEL 7 hosts.
Register the hosts to an environment and Content View on Foreman server. For more information, see Registering Hosts in the Managing Hosts guide.
Navigate to Content > Errata.
Click the name of an erratum you want to apply.
Click to Content Hosts tab.
Select the hosts you want to apply errata to and click Apply to Hosts.
Click Confirm.
Although the CLI does not have the same tools as the Foreman web UI, you can replicate a similar procedure with CLI commands.
List all installable errata:
# hammer erratum list \ --errata-restrict-installable true \ --organization "Default Organization"
Apply one of the errata to multiple hosts:
Using
Remote Execution# hammer job-invocation create \ --feature katello_errata_install \ --inputs errata=ERRATUM_ID \ --search-query "applicable_errata = ERRATUM_ID"
Using
Katello Agent(deprecated)Identify the erratum you want to use and list the hosts that this erratum is applicable to:
# hammer host list \ --search "applicable_errata = ERRATUM_ID" \ --organization "Default Organization"
for HOST inhammer --csv --csv-separator "|" host list --search "applicable_errata = ERRATUM_ID" --organization "Default Organization" | tail -n+2 | awk -F "|" '{ print $2 }'; do echo "== Applying to $HOST ==" ; hammer host errata apply --host $HOST --errata-ids ERRATUM_ID1,ERRATUM_ID2 ; doneThis command identifies all hosts with erratum_IDs as an applicable erratum and then applies the erratum to each host.
To see if an erratum is applied successfully, find the corresponding task in the output of the following command:
# hammer task list
View the state of a selected task:
10.8. Applying Errata to a Host Collection
Using Remote Execution
# hammer job-invocation create \ --feature katello_errata_install \ --inputs errata=ERRATUM_ID1,ERRATUM_ID2,... \ --search-query "host_collection = HOST_COLLECTION_NAME"
Using Katello Agent (deprecated)
# hammer host-collection erratum install \ --errata "erratum_ID1,erratum_ID2,..." \ --name "host_collection_name"\ --organization "Your_Organization"
11. Managing Container Images
With Foreman, you can import container images from various sources and distribute them to external containers using Content Views.
For information about containers, see Getting Started with Containers in Red Hat Enterprise Linux Atomic Host 7.
11.1. Importing Container Images
This procedure uses repository discovery to find container images and import them as repositories. For more information about creating a product and repository manually, see Importing Content.
In the Foreman web UI, navigate to Content > Products and click Repo Discovery.
From the Repository Type list, select Container Images.
In the Registry to Discover field, enter the URL of the registry to import images from.
In the Registry Username field, enter the name that corresponds with your user name for the container image registry.
In the Registry Password field, enter the password that corresponds with the user name that you enter.
In the Registry Search Parameter field, enter any search criteria that you want to use to filter your search, and then click Discover.
Optional: To further refine the Discovered Repository list, in the Filter field, enter any additional search criteria that you want to use.
From the Discovered Repository list, select any repositories that you want to import, and then click Create Selected.
Optional: If you want to create a product, from the Product list, select New Product.
In the Name field, enter a product name.
Optional: In the Repository Name and Repository Label columns, you can edit the repository names and labels.
Click Run Repository Creation.
When repository creation is complete, you can click each new repository to view more information.
Optional: To filter the content you import to a repository, click a repository, and then navigate to Limit Sync Tags. Click to edit, and add any tags that you want to limit the content that synchronizes to Foreman.
Navigate to Content > Products and select the name of your product.
Select the new repositories and then click Sync Now to start the synchronization process.
To view the progress of the synchronization navigate to Content > Sync Status and expand the repository tree.
When the synchronization completes, you can click Container Image Manifests to list the available manifests. From the list, you can also remove any manifests that you do not require.
Create the custom
Red Hat Container Catalogproduct:# hammer product create \ --name "Red Hat Container Catalog" \ --sync-plan "Example Plan" \ --description "Red Hat Container Catalog content" \ --organization "My_Organization"
Create the repository for the container images:
# hammer repository create \ --name "RHEL7" \ --content-type "docker" \ --url "http://registry.access.redhat.com/" \ --docker-upstream-name "rhel7" \ --product "Red Hat Container Catalog" \ --organization "My_Organization"
Synchronize the repository:
# hammer repository synchronize \ --name "RHEL7" \ --product "Red Hat Container Catalog" \ --organization "My_Organization"
11.2. Managing Container Name Patterns
When you use Foreman to create and manage your containers, as the container moves through Content View versions and different stages of the Foreman lifecycle environment, the container name changes at each stage.
For example, if you synchronize a container image with the name ssh from an upstream repository, when you add it to a Foreman product and organization and then publish as part of a Content View, the container image can have the following name: my_organization_production-custom_spin-my_product-custom_ssh.
This can create problems when you want to pull a container image because container registries can contain only one instance of a container name.
To avoid problems with Foreman naming conventions, you can set a registry name pattern to override the default name to ensure that your container name is clear for future use.
If you set the
repository.docker_upstream_nameregistry name pattern, you cannot publish or promote Content Views with container content with identical repository names to theProductionlifecycle. -
If you set the
lifecycle_environment.nameregistry name pattern, this can prevent the creation of a second container repository with the identical name.
In the Foreman web UI, navigate to Content > Lifecycle Environments, and either create a lifecycle environment or select a lifecycle environment to edit.
In the Container Image Registry area, click the edit icon to the right of Registry Name Pattern area.
Use the list of variables and examples to determine which registry name pattern you require.
In the Registry Name Pattern field, enter the registry name pattern that you want to use. For example, to use the
repository.docker_upstream_name:<%= repository.docker_upstream_name %>
Click Save.
11.3. Managing Container Registry Authentication
By default, users must authenticate to access containers images in Foreman.
You can specify whether you want users to authenticate to access container images in Foreman in a lifecycle environment.
For example, you might want to permit users to access container images from the Production lifecycle without any authentication requirement and restrict access the Development and QA environments to authenticated users.
To manage the authentication settings for accessing containers images from Foreman, complete the following steps:
In the Foreman web UI, navigate to Content > Lifecycle Environments and select the lifecycle environment that you want to manage authentication for.
To permit unauthenticated access to the containers in this lifecycle environment, select the Unauthenticated Pull check box. To restrict unauthenticated access, clear the Unauthenticated Pull check box.
Click Save.
11.4. Using Katello Container Registries
Podman and Docker can be used to fetch content from Katello container registries.
On Smart Proxies with content, the Container Gateway Smart Proxy plugin acts as the container registry. It caches authentication information from Katello and proxies incoming requests to Pulp. The Container Gateway comes default on Smart Proxies with content.
podman login foreman.example.com
Listing container images:
podman search foreman.example.com/
Pulling container images:
podman pull foreman.example.com/my-image:<optional_tag>
12. Managing ISO Images
You can use Foreman to store ISO images, either from Red Hat’s Content Delivery Network or other sources. You can also upload other files, such as virtual machine images, and publish them in repositories.
12.1. Importing ISO Images from Red Hat
The Red Hat Content Delivery Network provides ISO images for certain products. The procedure for importing this content is similar to the procedure for enabling repositories for RPM content.
In the Foreman web UI, navigate to Content > Red Hat Repositories.
In the Search field, enter an image name, for example,
Red Hat Enterprise Linux 7 Server (ISOs). -
In the Available Repositories window, expand Red Hat Enterprise Linux 7 Server (ISOs).
For the x86_64 7.2 entry, click the Enable icon to enable the repositories for the image.
Navigate to Content > Products and click Red Hat Enterprise Linux Server.
Click the Repositories tab of the Red Hat Enterprise Linux Server window, and click Red Hat Enterprise Linux 7 Server ISOs x86_64 7.2.
In the upper right of the Red Hat Enterprise Linux 7 Server ISOs x86_64 7.2 window, click Select Action and select Sync Now.
In the Foreman web UI, navigate to Content > Sync Status and expand Red Hat Enterprise Linux Server.
Locate the Red Hat Enterprise Linux Server product for
filerepositories:# hammer repository-set list \ --product "Red Hat Enterprise Linux Server" \ --organization "My_Organization" | grep "file"
Enable the
filerepository for Red Hat Enterprise Linux 7.2 Server ISO:# hammer repository-set enable \ --product "Red Hat Enterprise Linux Server" \ --name "Red Hat Enterprise Linux 7 Server (ISOs)" \ --releasever 7.2 \ --basearch x86_64 \ --organization "My_Organization"
Locate and synchronize the repository in the product:
# hammer repository list \ --product "Red Hat Enterprise Linux Server" \ --organization "My_Organization" # hammer repository synchronize \ --name "Red Hat Enterprise Linux 7 Server ISOs x86_64 7.2" \ --product "Red Hat Enterprise Linux Server" \ --organization "My_Organization"
12.2. Importing Individual ISO Images and Files
Use this procedure to manually import ISO content and other files to Foreman server. To import files, you can complete the following steps in the Foreman web UI or using the Hammer CLI. However, if the size of the file that you want to upload is larger than 15 MB, you must use the Hammer CLI to upload it to a repository.
In the Foreman web UI, navigate to Content > Products, and in the Products window, click Create Product.
In the Name field, enter a name to identify the product. This name populates the Label field.
In the GPG Key field, enter a GPG Key for the product.
From the Sync Plan list, select a synchronization plan for the product.
In the Description field, enter a description of the product.
Click Save.
In the Products window, click the new product and then click Create Repository.
In the Name field, enter a name for the repository. This automatically populates the Label field.
From the Type list, select file.
In the Upstream URL field, enter the URL of the registry to use as a source. Add a corresponding user name and password in the Upstream Username and Upstream Password fields.
Click Save.
Click the new repository.
Navigate to the Upload File and click Browse.
Select the
.isofile and click Upload.
Create the product:
# hammer product create \ --name "My_ISOs" \ --sync-plan "Example Plan" \ --description "My_Product" \ --organization "My_Organization"
Create the repository:
# hammer repository create \ --name "My_ISOs" \ --content-type "file" \ --product "My_Product" \ --organization "My_Organization"
Upload the ISO file to the repository:
# hammer repository upload-content \ --path ~/bootdisk.iso \ --id repo_ID \ --organization "My_Organization"
13. Managing File Type Content
In Foreman, you might require methods of managing and distributing SSH keys and source code files or larger files such as virtual machine images and ISO files. To achieve this, (customproduct)s in Foreman include repositories for file types. This provides a generic method to incorporate arbitrary files in a product.
You can upload files to the repository and synchronize files from an upstream Foreman server.
When you add files to a file type repository, you can use the normal Foreman management functions such as adding a specific version to a Content View to provide version control and making the repository of files available on various Smart Proxy servers.
Clients must download the files over HTTP or HTTPS using curl -O.
You can create a file type repository in Foreman server only in a (customproduct), but there is flexibility in how you create the file type repository. You can create an independent file type repository in a directory on the system where Foreman is installed, or on a remote HTTP server, and then synchronize the contents of that directory into Foreman. This method is useful when you have multiple files to add to a Foreman repository.
13.1. Creating a File Type Repository in Foreman
The procedure for creating a file type repository is the same as the procedure for creating any content, except that when you create the repository, you select the file type. You must create a product and then add a repository.
To create a product, complete the following procedure:
In the Foreman web UI, navigate to Content > Products, click Create Product and enter the following details:
In the Name field, enter a name for the product. Foreman automatically completes the Label field based on what you have entered for Name.
Optional: From the GPG Key list, select the GPG key for the product.
Optional: From the Sync Plan list, select a synchronization plan for the product.
In the Description field, enter a description of the product, and then click Save.
To create a repository for your product, complete the following procedure:
In the Products window, select the name of a product that you want to create a repository for.
Click the Repositories tab, and then click New Repository.
In the Name field, enter a name for the repository. Foreman automatically completes the Label field based on the name.
In the Upstream URL field, enter the URL of the upstream repository to use as a source.
Select the Verify SSL check box if you want to verify that the upstream repository’s SSL certificates are signed by a trusted CA.
In the Upstream Username field, enter the user name for the upstream repository if required for authentication. Clear this field if the repository does not require authentication.
In the Upstream Password field, enter the corresponding password for the upstream repository. Clear this field if the repository does not require authentication.
Click Save.
Create a product
# hammer product create \ --name "My File Product" \ --sync-plan "Example Plan" \ --description "My files" \ --organization "My_Organization"
Table 6. Optional Parameters for the hammer product createCommandOption Description --gpg-keygpg_key_nameKey name to search by
--gpg-key-idgpg_key_idGPG key numeric identifier
--sync-plansync_plan_nameSync plan name to search by
--sync-plan-idsync_plan_idSync plan numeric identifier
Create a File Type Repository
# hammer repository create \ --name "My Files" \ --content-type "file" \ --product "My File Product" \ --organization "My_Organization"
Table 7. Optional Parameters for the hammer repository createCommandOption Description --checksum-typesha_versionRepository checksum, currently 'sha1' & 'sha256' are supported
--download-policypolicy_nameDownload policy for yum repos (either 'immediate' or 'on_demand').
--mirror-on-syncbooleanMust this repo be mirrored from the source, and stale RPMs removed, when synced? Set to
trueorfalse,yesorno,1or0.--publish-via-httpbooleanMust this also be published using HTTP? Set to
trueorfalse,yesorno,1or0.--upstream-usernamerepository_usernameUpstream repository user, if required for authentication
--upstream-passwordrepository_passwordPassword for the upstream repository user
--urlsource_repo_urlURL of the Source repository
--verify-ssl-on-syncbooleanMust Katello verify that the upstream URL’s SSL certificates are signed by a trusted CA? Set to
13.2. Creating a File Type Repository in a Local Directory
You can create a file type repository, from a directory of files, on the base system where Foreman is installed using the pulp-manifest command.
You can then synchronize the files into Foreman server.
When you add files to a file type repository, you can work with the files as with any other repository.
Use this procedure to configure a repository in a directory on the base system where Foreman is installed. To create a file type repository in a directory on a remote server, see Creating a Remote File Type Repository.
To create a file type repository in a local directory, complete the following procedure:
Ensure the Server and https://yum.theforeman.org/client/3.0/ repositories are enabled.
Install the Pulp Manifest package:
# yum install python3-pulp-manifest
Note that this command stops the Foreman service and re-runs foreman-installer. Alternatively, to prevent downtime caused by stopping the service, you can use the following:
# subscription-manager repos --enable rhel-7-server-satellite-tools-6.9-rpms # foreman-maintain packages unlock # yum install install python-pulp-manifest -y # foreman-maintain packages lock # subscription-manager repos --disable rhel-7-server-satellite-tools-6.9-rpms
This installs the package without downtime.
Create a directory that you want to use as the file type repository in the HTTP server’s public folder:
# mkdir my_file_repo
Add files to the directory or create a test file:
# touch my_file_repo/test.txt
Enter the Pulp Manifest command to create the manifest:
# pulp-manifest my_file_repo
Verify the manifest was created:
# ls my_file_repo PULP_MANIFEST test.txt
To import files from a file type repository in a local directory, complete the following procedure:
Ensure a product exists in Foreman server.
In the Foreman web UI, navigate to Content > Products.
Select the name of a product.
Click the Repositories tab and select New Repository.
In the Name field, enter a name for the repository. Foreman automatically completes this field based on what you enter for Name.
From the Type list, select the content type of the repository.
In the Upstream URL field, enter the local directory with the repository to use as the source, in the form
file:///my_file_repo. -
Select the Verify SSL check box to check the SSL certificate for the repository or clear the Verify SSL check box.
Optional: In the Upstream Username field, enter the upstream user name that you require.
Optional: In the Upstream Password field, enter the corresponding password for your upstream user name.
Select Save to save this repository entry.
To update the file type repository, complete the following steps:
Select the name of the repository you want to update.
From the Select Action menu, select Sync Now.
Visit the URL where the repository is published to see the files.
13.3. Creating a Remote File Type Repository
You can create a file type repository from a directory of files that is external to Foreman server using the pulp-manifest command.
You can then synchronize the files into Foreman server over HTTP or HTTPS.
Use this procedure to configure a repository in a directory on a remote server. To create a file type repository in a directory on the base system where Foreman server is installed, see Creating a File Type Repository in a Local Directory.
Before you create a remote file type repository, ensure the following conditions exist:
You have a Red Hat Enterprise Linux 7 server registered to your Foreman or the Red Hat CDN.
You have installed an HTTP server. For more information about configuring a web server, see The Apache HTTP Server in the Red Hat Enterprise Linux 7 System Administrator’s Guide.
To create a file type repository in a remote directory, complete the following procedure:
On your remote server, ensure that the Server and https://yum.theforeman.org/client/3.0/ repositories are enabled.
# ls /var/www/html/pub/my_file_repo PULP_MANIFEST test.txt
To import files from a remote file type repository, complete the following procedure:
Ensure a product exists in Foreman server, or create a product. For more information see Creating a File Type Repository in Foreman
Click Save.
To update the file type repository, navigate to Content > Products. Select the name of a product that contains the repository that you want to update.
In the product’s window, select the name of the repository you want to update.
Visit the URL where the repository is published to view the files.
13.4. Uploading Files To a File Type Repository in Foreman
Use this procedure to upload files to a file type repository.
Select a product by name.
Select a file type repository by name.
Click Browse to search and select the file you want to upload.
Click Upload to upload the selected file to Foreman server.
Visit the URL where the repository is published to see the file.
# hammer repository upload-content \ --id repo_ID \ --organization "My_Organization" \ --path example_file
The --path option can indicate a file, a directory of files, or a glob expression of files.
Globs must be escaped by single or double quotes.
13.5. Downloading Files to a Host From a File Type Repository in Foreman
You can download files to a client over HTTPS using curl -O, and optionally over HTTP if the Publish via HTTP repository option is selected.
You have a file type repository. See Creating a File Type Repository in Foreman for more information.
You know the name of the file you want to download to clients from the file type repository.
To use HTTPS you require the following certificates on the client:
The
katello-server-ca.crt. For more information, see Installing the Katello Root CA Certificate in the Administering Foreman guide. -
An Organization Debug Certificate. See Creating an Organization Debug Certificate for more information.
Check to see if Publish via HTTP is enabled. If it is not, you require the certificates to use HTTPS.
Copy the URL where the repository is published.
List the file type repositories.
# hammer repository list --content-type file ---|----------|-----------------|--------------|---- ID | NAME | PRODUCT | CONTENT TYPE | URL ---|----------|-----------------|--------------|---- 7 | My Files | My File Product | file | ---|----------|-----------------|--------------|----
Display the repository information.
# hammer repository info --name "My Files" --product "My File Product" --organization-id 1
If HTTP is enabled, the output is similar to this:
Publish Via HTTP: yes Published At: http://foreman.example.com/pulp/isos/uuid/
If HTTP is not enabled, the output is similar to this:
Publish Via HTTP: no Published At: https://foreman.example.com/pulp/isos/uuid/
On the client, enter a command in the appropriate format for HTTP or HTTPS:
For HTTP:
# curl -O foreman.example.com/pulp/isos/uuid/my_file
For HTTPS:
# curl -O --cert ./Default\ Organization-key-cert.pem --cacert katello-server-ca.crt foreman.example.com/pulp/isos/uuid/my_file
Your environment requires adequate hard disk space to fulfill content storage. In some situations, it is useful to use an NFS share to store this content. This appendix shows how to mount the NFS share on your Foreman server’s content management component.
Use high-bandwidth, low-latency storage for the /var/lib/pulp file system.
Foreman has many I/O-intensive operations; therefore, high-latency, low-bandwidth storage might have issues with performance degradation.
Create the NFS share. This example uses a share at
nfs.example.com:/satellite/pulp. Ensure this share provides the appropriate permissions to Foreman server and itsapacheuser. -
Stop the
foreman-maintainservices on the Foreman host:# foreman-maintain service stop
Ensure Foreman server has the
nfs-utilspackage installed:# yum install nfs-utils
You need to copy the existing contents of
/var/lib/pulpto the NFS share. First, mount the NFS share to a temporary location:# mkdir /mnt/temp # mount -o rw nfs.example.com:/satellite/pulp /mnt/temp
Copy the existing contents of
/var/lib/pulpto the temporary location:# cp -r /var/lib/pulp/* /mnt/temp/.
Set the permissions for all files on the share to use the
pulpuser. -
Unmount the temporary storage location:
# umount /mnt/temp
Remove the existing contents of
/var/lib/pulp:# rm -rf /var/lib/pulp/*
Edit the
/etc/fstabfile and add the following line:nfs.example.com:/satellite/pulp /var/lib/pulp nfs rw,hard,intr,context="system_u:object_r:pulpcore_var_lib_t:s0"
Enable the mount:
# mount -a
Confirm the NFS share mounts to
var/lib/pulp:# df Filesystem 1K-blocks Used Available Use% Mounted on ... nfs.example.com:/satellite/pulp 309506048 58632800 235128224 20% /var/lib/pulp ...
Also confirm that the existing content exists at the mount on
var/lib/pulp:# ls /var/lib/pulp
Start the
foreman-maintainservices on the Foreman host:# foreman-maintain service start
Foreman server now uses the NFS share to store content. Run a content synchronization to ensure the NFS share works as expected. For more information, see Syncing Repositories.
Appendix B: Importing Content ISOs into a Connected Foreman
Even if Foreman server can connect directly to the Red Hat Customer Portal, you can perform the initial synchronization from locally mounted content ISOs. When the initial synchronization is completed from the content ISOs, you can switch back to downloading content through the network connection. To accomplish this, download the Content ISOs for Foreman from the Red Hat Customer Portal and import them into Foreman server. For locations with bandwidth limitations, using an On Demand download policy might be more efficient than downloading and importing Content ISOs.
Note that Content ISOs previously hosted at redhat.com for import into Foreman server have been deprecated and will be removed in the next Foreman version.
You can only import content ISO images for Red Hat Enterprise Linux 8 because repodata checksum from CDN does not match the repodata checksum from the content ISO images for Red Hat Enterprise Linux 7 and lower. |
Note that if you synchronize a Red Hat Enterprise Linux ISO, all minor versions of Red Hat Enterprise Linux also synchronize. You require adequate storage on your Foreman to account for this.
This section is not required if your Foreman server is connected to the Internet. |
This example procedure performs the first synchronization of the Red Hat Enterprise Linux 8 repository from content ISO images.
Log in to the Red Hat Customer Portal at https://access.redhat.com/.
In the upper left of the window, click Downloads and select Red Hat Satellite.
Click the Content ISOs tab. This page lists all the products that are available in your subscription.
Click the link for the product name, such as RHEL 8 (x86_64), to reveal links to download ISO images.
Download the ISO images.
On Foreman, create a directory to act as a temporary store for all of the required Satellite content ISO images. This example uses
/tmp/isos/rhel8:# mkdir -p /tmp/isos/rhel8
On your workstation, copy the ISO files to Foreman server:
$ scp ~/Downloads/iso_file root@foreman.example.com:/tmp/isos/rhel8
On Foreman server, create a directory to serve as a mount point for the ISOs:
# mkdir /mnt/iso
Create a working directory to store ISO images:
# mkdir /mnt/rhel8
Temporarily mount the first ISO image:
# mount -o loop /tmp/isos/iso_file /mnt/iso
Recursively copy the contents of the first ISO to the working directory:
# cp -ruv /mnt/iso/* /mnt/rhel8/
Unmount the ISO image:
# umount /mnt/iso
Repeat the above step for each ISO until you have copied all the data from the Content ISO images into
/mnt/rhel8. -
If required, remove the empty directory used as the mount point:
# rmdir /mnt/iso
If required, remove the temporary working directory and its contents to regain space:
# rm -rf /tmp/isos/
Set the owner and the SELinux context for the directory and its contents to be the same as
/var/lib/pulp:# chcon -R --reference /var/lib/pulp /mnt/rhel8/ # chown -R apache:apache /mnt/rhel8/
Create or edit the
/etc/pulp/content/sources/conf.d/local.conffile. Append the following text into the file:[rhel-8-server] enabled: 1 priority: 0 expires: 3d name: Red Hat Enterprise Linux 8 type: yum base_url: file:///mnt/rhel8/content/dist/rhel/server/8/x86_64/os/
The
base_urlpath might differ in your content ISO. The directory specified inbase_urlmust contain therepodatadirectory, otherwise the synchronization fails. To synchronize multiple repositories, create a separate entry for each of them in the configuration file/etc/pulp/content/sources/conf.d/local.conf. -
In the Foreman, navigate to Content > Red Hat Repositories and enable the following repositories:
Red Hat Enterprise Linux 8 for x86_64 - BaseOS RPMs 8
Red Hat Enterprise Linux 8 for x86_64 - AppStream RPMs 8
Under Content > Sync Status select the repositories to be synchronized and click Synchronize Now.
Note that the Satellite web UI does not indicate which source is being used. In case of problems with a local source, Satellite pulls content through the network. To monitor the process, enter the following command on Satellite:
# journalctl -f -l SYSLOG_IDENTIFIER=pulp | grep -v worker[\-,\.]heartbeat
The above command displays interactive logs. First, Foreman server connects to the Red Hat Customer Portal to download and process repository metadata. Then, the local repository is loaded. In case of any errors, cancel the synchronization in the Foreman web UI and verify your configuration.
After successful synchronization you can detach the local source by removing its entry from /etc/pulp/content/sources/conf.d/local.conf.
