1. Foreman use cases
Foreman is a centralized tool for provisioning, content delivery, remote management, and monitoring of multiple Enterprise Linux deployments. With Foreman, you can deploy, configure, and maintain your systems across physical, virtual, and cloud environments.
Foreman helps you provision hosts, manage patches and content, and strengthen security across physical, virtual, and cloud environments. You can also benefit from AI-powered assistance by deploying the Model Context Protocol (MCP) server for Foreman, which enables you to interact with your infrastructure using natural language.
Foreman focuses on the following use cases:
- Provisioning
Deploy consistently configured hosts on bare metal, virtual machines, and cloud instances from a unified interface.
Foreman automates key stages of the deployment lifecycle, including network configuration, operating system installation, and post-installation tasks. For example, you can define templates, partition layouts, and available software to achieve flexibility in how you deploy hosts.
This approach helps reduce deployment time, standardize the provisioning process, and support scaling of your infrastructure.
- Patch management and content distribution
Apply updates to hosts in a consistent, scalable, and repeatable manner. Import, organize, and distribute content to hosts.
NoteIn the context of Foreman, content is defined as the software installed on hosts. For example, you can use Foreman to distribute a broad range of content ranging from packages and errata to container images, Ansible content, and custom file types.
Foreman enables you to import, organize, and distribute content to hosts while staying in control of which versions of content reaches which hosts and when. For example, you can schedule maintenance windows, test updates in staging environments, and roll out patches across your infrastructure with controlled deployment strategies.
This approach provides enhanced control over what software runs in your environment and reduces the manual effort required to keep hosts up to date.
- Security management
Reduce the effort required to secure hosts at scale.
Foreman helps you enforce security policies, scan for vulnerabilities, and remediate compliance violations across your infrastructure. For example, you can integrate Foreman with security scanning tools, track compliance against security baselines, and set up procedures to help ensure hosts meet regulatory requirements.
This capability enables centralized security oversight, supports incident response, and helps reduce the attack surface of your hosts.
- Knowledge and analytics
Identify potential issues and gain a comprehensive view of your infrastructure.
Foreman collects data from hosts, generates reports on system status and trends, and provides dashboards that visualize infrastructure health. For example, you can monitor resource utilization, track configuration changes, and identify patterns.
This knowledge helps you make informed decisions about your infrastructure and spot potential problems.
- Configuration management
Apply configurations to hosts in a consistent and repeatable manner.
Foreman integrates with configuration management tools to define desired state, enforce policies, and remediate drift across your infrastructure. For example, you can manage configurations as code, version control your infrastructure definitions, and automate updates to help keep hosts compliant with organizational standards.
This approach reduces the risk of manual configuration errors and helps maintain consistency across your hosts.
2. Foreman architecture and components
As you are evaluating Foreman for your organization, understanding the roles and relationships of major components helps you determine what infrastructure to deploy and how components interact.
2.1. Major Foreman components
A typical Foreman deployment consists of the following components: a Foreman server, Smart Proxy servers, and hosts that receive content and configuration from Foreman server and Smart Proxy servers.
- Foreman server
Foreman server is the central component of your Foreman deployment.
A typical Foreman deployment includes one Foreman server on which you perform the following operations:
Content lifecycle management
Configuration of Smart Proxy servers
Configuration of hosts
Host provisioning
Patch management
Subscription management
Foreman server delegates content distribution, host provisioning, and communication to Smart Proxy servers. Foreman server itself also includes a Smart Proxy.
Foreman server also contains a fine-grained authentication system. You can grant Foreman users permissions to access precisely the parts of the infrastructure for which they are responsible.
- Smart Proxy server
With Smart Proxy servers, you can extend the reach and scalability of your Foreman deployment. Smart Proxy servers provide the following functionalities in a Foreman deployment:
Running localized services to discover, provision, control, and configure hosts.
Mirroring content from Foreman server to establish content sources in various geographical or logical locations. By registering a host to a Smart Proxy server, you can configure this host to receive content and configuration from the Smart Proxy in their location instead of from the central Foreman server.
By using content views, you can specify the exact subset of content that Smart Proxy server makes available to hosts.
- Hosts in Foreman
With Foreman, you can manage hosts at scale, including monitoring, provisioning, remote execution, subscription management, content management, and configuration management. You can also group hosts by using features such as host groups and host collections.
2.2. Smart Proxy server features
Smart Proxy servers provide local host management services and can mirror content from Foreman server.
To mirror content from Foreman server, Smart Proxy servers provide the following functionalities:
- Repository synchronization
Smart Proxy servers pull content for selected lifecycle environments from Foreman server and make this content available to the hosts they manage.
- Content delivery
Hosts configured to use Smart Proxy server download content from that Smart Proxy rather than from Foreman server.
- Host action delivery
Smart Proxy server executes scheduled actions on hosts.
- Red Hat Subscription Management (RHSM) proxy
Hosts are registered to their associated Smart Proxy servers rather than to the central Foreman server or the Red Hat Customer Portal.
You can use Smart Proxy to run the following services for infrastructure and host management:
- DHCP
Smart Proxy can manage a DHCP server, including integration with an existing solution, such as ISC DHCP servers, Active Directory, and Libvirt instances.
- DNS
Smart Proxy can manage a DNS server, including integration with an existing solution, such as ISC BIND and Active Directory.
- TFTP
Smart Proxy can integrate with any UNIX-based TFTP server.
- Realm
Smart Proxy can manage Kerberos realms or domains so that hosts can join them automatically during provisioning. Smart Proxy can integrate with an existing infrastructure, including FreeIPA and Active Directory.
- Puppet server
Smart Proxy can act as a configuration management server by running an OpenVox server.
- Puppet Certificate Authority
Smart Proxy can integrate with the Puppet certificate authority (CA) to provide certificates to hosts.
Smart Proxy can provide power management for hosts by using the Intelligent Platform Management Interface (IPMI) or Redfish standards.
- Provisioning template proxy
Smart Proxy can serve provisioning templates to hosts.
- OpenSCAP
Smart Proxy can perform security compliance scans on hosts.
- Remote execution (REX)
Smart Proxy can run remote job execution on hosts.
You can configure a Smart Proxy server for a specific limited purpose by enabling only selected features on that Smart Proxy. Common configurations include the following:
- Content Smart Proxies: Pulp
Smart Proxies with this service provide content synchronized from Foreman server to hosts.
- Configuration Smart Proxies: Pulp + Puppet + PuppetCA
Smart Proxies with these services provide content and run configuration services for hosts.
- Smart Proxies with DNS + DHCP + TFTP + Pulp + Puppet + PuppetCA
Smart Proxies with these services provide a full set of Smart Proxy features. By configuring a Smart Proxy with all these features, you can isolate hosts assigned to that Smart Proxy by providing a single point of connection for the hosts.
2.3. Key open source components of Foreman
Foreman consists of several open source projects integrated with each other.
- Foreman
- Katello
- Candlepin
- Pulp
3. Administration tools for Foreman
Foreman offers multiple tools for administrators to manage the deployment. Understanding the available administration tools helps you select the approach that fits your workflow and automation needs.
3.1. Foreman web UI for management from your browser
3.2. Hammer CLI for management from the command line
You can configure and manage your Foreman server with CLI commands by using Hammer.
Create shell scripts based on Hammer commands for basic task automation.
Redirect output from Hammer to other tools.
Use the
--debugoption with Hammer to test responses to API calls before applying the API calls in a script. For example:hammer --debug organization list.
To issue Hammer commands, a user must have access to your Foreman server.
To ensure a user-friendly and intuitive experience, the Foreman web UI takes priority when developing new functionality. Therefore, some features that are available in the Foreman web UI might not yet be available for Hammer. |
3.3. Foreman API for automation and integration
Self-descriptive – client applications require minimal knowledge of the Foreman infrastructure because users discover many details at runtime.
API commands differ between versions of Foreman. When you prepare to upgrade Foreman server, update all the scripts that contain Foreman API commands. |
3.4. Foreman Ansible Collection
Modules from the Foreman Ansible Collection are provided by the ansible-collection-theforeman-foreman package.
Before you can use the modules, you must install the package on the system where you run your playbooks.
Using the modules, you can write playbooks to automate the administration of your Foreman.
3.5. MCP server for AI-powered assistance
Foreman provides a Model Context Protocol (MCP) server so that you can query and manage your Foreman inventory from MCP-compatible AI applications by using natural language.
You deploy the MCP server from a container image that Foreman community provides and connect it to the AI application that runs your MCP client. The MCP server accesses Foreman with your credentials, so your MCP client cannot obtain data that you do not have permission to access.
By default, the MCP server is read-only. You can query your inventory and generate reports from it, for example, a report of all subnets and the hosts that are assigned to them.
When you start the MCP server, you can also grant it permissions to change your Foreman. For example, you can start remote execution jobs on your hosts, and publish and promote content views.
3.6. Remote execution in Foreman
With remote execution, you can run jobs on hosts from Smart Proxies by using shell scripts or Ansible roles and playbooks.
Run jobs on multiple hosts at once.
Use variables in your commands for more granular control over the jobs you run.
Use host facts and parameters to populate the variable values.
Specify custom values for templates when you run the command.
Communication for remote execution occurs through Smart Proxy server, which means that Foreman server does not require direct access to the target host, and can scale to manage many hosts.
3.7. Automated installation with Kickstart
You can automate the installation process of a Foreman server or Smart Proxy server by creating a Kickstart file that contains all the information that is required for the installation.
When you run a Foreman Kickstart script, the script performs the following actions:
4. Supported client architectures
Verify that your client architectures are supported before deploying Foreman.
4.1. Foreman operating system
You can deploy Foreman on the supported operating systems listed below.
Enterprise Linux 9 (x86_64)
4.2. Client operating systems
Amazon Linux
Debian
Enterprise Linux 10, 9, and 8
Fedora
openSUSE/SUSE Linux Enterprise Server
Ubuntu
Ansible
OpenSCAP
OpenSSH
Puppet
Salt
Windows Remote Management (WinRM)
Operating system installers that can perform unattended installations, such as Anaconda or Debian-installer
Katello host tools
Tracer utility
5. Security hardening features in Foreman
Foreman supports multiple security mechanisms for additional layers of protection. Understanding these capabilities helps you evaluate how Foreman can support the security requirements of your organization.
You can use the following security capabilities in Foreman to enhance the security of your deployment:
- Federal Information Processing Standards (FIPS) Mode
If your Enterprise Linux operating systems supports FIPS, you can install Foreman server and Smart Proxy server on a FIPS-enabled host. Note that Foreman itself is not FIPS-certified.
NoteForeman supports DEFAULT and FIPS crypto-policies. The FUTURE crypto-policy is not supported for Foreman server and Smart Proxy server installations.
If you want to run Foreman server or Smart Proxy server on a FIPS-enabled host, FIPS must be enabled on the host before installing. You cannot enable FIPS mode on Foreman server or Smart Proxy server after installation.
NoteIf you manage FIPS-enabled hosts, you must also run Foreman server and Smart Proxy servers in FIPS mode. If the server does not run in FIPS mode in this situation, you might experience unexpected behavior. For example, the hosts might not be able to run remote execution jobs from the server.
- File Access Policy Daemon (
fapolicyd) -
Foreman server and Smart Proxy servers can run on hosts that have the
fapolicydservice enabled.The
fapolicyddaemon helps prevent unauthorized code execution and enhances system integrity by enforcing file access policies.You can enable or disable
fapolicydon your Foreman server and Smart Proxy servers at any time. - Post-Quantum Cryptography (PQC)
Foreman can synchronize and distribute Red Hat Enterprise Linux 10 content signed with the Module-Lattice-Based Digital Signature Standard (ML-DSA). ML-DSA is a quantum-resistant cryptographic signature algorithm designed to protect content integrity against potential attacks from quantum computers.
Foreman community does not currently support full PQC compatibility for Foreman.
- Security-Enhanced Linux (SELinux)
Foreman server and Smart Proxy servers must be run on hosts with SELinux enabled.
The SELinux collection of security modules enforces policies that define which processes can access specific system resources, providing protection against unauthorized access and exploitation.
To maintain a high-security environment, Foreman community recommends running Foreman with SELinux in enforcing mode. This ensures that access control policies are strictly enforced and minimizes the risk of privilege escalation or unauthorized actions.
In addition to these security capabilities, regularly updating security policies and configurations, as well as monitoring system logs, can help detect and respond to potential threats effectively on both Foreman server and Smart Proxy server.
6. Networking considerations in Foreman
For the components of Foreman architecture to communicate, the required network ports must be open to enable incoming and outgoing traffic between the components. Identify firewall port and networking requirements to ensure Foreman components can communicate properly.
6.1. Smart Proxy server networking
The communication between Foreman server and hosts registered to a Smart Proxy server is routed through that Smart Proxy server. Smart Proxy server also provides Foreman services to hosts.
In a topology with hosts connecting to a Smart Proxy server, Smart Proxy server provides a single endpoint for all host network communications so that in remote network segments, only firewall ports to the Smart Proxy server itself must be open. Hosts do not need direct access to Foreman server.
In a topology with hosts connecting directly to Foreman server, hosts need direct network access to Foreman server. This applies to all Smart Proxy servers because they are hosts of Foreman server.
6.2. Foreman server port and firewall requirements
The following tables indicate the destination port and the direction of incoming and outgoing traffic for Foreman server.
| Destination Port | Protocol | Service | Source | Required For | Description |
53 |
TCP and UDP |
DNS |
DNS Servers and clients |
Name resolution |
DNS (optional) |
67 |
UDP |
DHCP |
Client |
Dynamic IP |
DHCP (optional) |
69 |
UDP |
TFTP |
Client |
TFTP Server (optional) |
443 |
TCP |
HTTPS |
Smart Proxy |
Foreman API |
Communication from Smart Proxy |
443 |
TCP |
HTTPS |
Client |
Global Registration |
Registering hosts to Foreman Port 443 is required for sending installed packages and traces, registration initiation, and uploading facts. |
443 |
TCP |
HTTPS |
Foreman |
Content Mirroring |
Management |
443 |
TCP |
HTTPS |
Foreman |
Smart Proxy API |
Smart Proxy functionality |
443, 80 |
TCP |
HTTPS, HTTP |
Smart Proxy |
Content Retrieval |
Content |
443, 80 |
TCP |
HTTPS, HTTP |
Client |
Content Retrieval |
Content |
1883 |
TCP |
MQTT |
Client |
Pull based REX (optional) |
Hosts for REX job notification (optional) |
4505 – 4506 |
TCP |
MQTT |
Client |
Salt (optional) |
Salt Master to Salt Minions |
5910 – 5930 |
TCP |
HTTPS |
Browsers |
Compute Resource’s virtual console |
8000 |
TCP |
HTTP |
Client |
Provisioning templates |
Template retrieval for client installers, iPXE or UEFI HTTP Boot |
8000 |
TCP |
HTTPS |
Client |
PXE Boot |
Installation |
8140 |
TCP |
HTTPS |
Client |
OpenVox agent |
Client updates (optional) |
9090 |
TCP |
HTTPS |
Foreman |
Smart Proxy API |
9090 |
TCP |
HTTPS |
Client |
OpenSCAP |
Configure Client (if the OpenSCAP plugin is installed) |
9090 |
TCP |
HTTPS |
Discovered Node |
Discovery |
Host Discovery and provisioning (if the Discovery plugin is installed) |
9090 |
TCP |
HTTPS |
Client |
9191 |
TCP |
HTTPS |
Client |
Salt (optional) |
Salt API |
| Destination Port | Protocol | Service | Destination | Required For | Description |
ICMP |
ping |
Client |
DHCP |
Free IP checking (optional) |
7 |
TCP |
echo |
Client |
DHCP |
22 |
TCP |
SSH |
Target host |
Remote execution |
Run jobs |
22, 16514 |
TCP |
SSH SSH/TLS |
Compute Resource |
Foreman originated communications, for compute resources in libvirt |
53 |
TCP and UDP |
DNS |
DNS Servers on the internet |
DNS Server |
Resolve DNS records (optional) |
53 |
TCP and UDP |
DNS |
DNS Server |
Smart Proxy DNS |
Validation of DNS conflicts (optional) |
53 |
TCP and UDP |
DNS |
DNS Server |
Orchestration |
Validation of DNS conflicts |
68 |
UDP |
DHCP |
Client |
Dynamic IP |
DHCP (optional) |
80 |
TCP |
HTTP |
Remote repository |
Content Sync |
Remote repositories |
389, 636 |
TCP |
LDAP, LDAPS |
External LDAP Server |
LDAP |
LDAP authentication, necessary only if external authentication is enabled.
The port can be customized if |
443 |
TCP |
HTTPS |
Amazon EC2, Azure, Google Compute Engine |
Compute resources |
Virtual machine interactions (query/create/destroy) (optional) |
443 |
TCP |
HTTPS |
Smart Proxy |
Content mirroring |
Initiation |
443 |
TCP |
HTTPS |
Infoblox DHCP Server |
DHCP management |
When using Infoblox for DHCP, management of the DHCP leases (optional) |
623 |
Client |
Power management |
BMC On/Off/Cycle/Status |
5000 |
TCP |
HTTPS |
OpenStack Compute Resource |
Compute resources |
5900 – 5930 |
TCP |
SSL/TLS |
Hypervisor |
noVNC console |
Launch noVNC console |
5985 |
TCP |
HTTP |
Client |
WinRM |
Configure Client running Windows |
5986 |
TCP |
HTTPS |
Client |
WinRM |
7911 |
TCP |
DHCP, OMAPI |
DHCP Server |
DHCP |
The DHCP target is configured using ISC and |
8443 |
TCP |
HTTPS |
Client |
Discovery |
Smart Proxy sends reboot command to the discovered host (optional) |
9090 |
TCP |
HTTPS |
Smart Proxy |
Smart Proxy API |
Management of Smart Proxies |
6.3. Smart Proxy port and firewall requirements
The following tables indicate the destination port and the direction of incoming and outgoing traffic for Smart Proxy servers.
ICMP to Port 7 UDP and TCP must not be rejected, but can be dropped. The DHCP Smart Proxy sends an ECHO REQUEST to the Client network to verify that an IP address is free. A response prevents IP addresses from being allocated. |
443, 80 |
TCP |
HTTPS, HTTP |
Client |
Content Retrieval |
Content |
443 |
TCP |
HTTPS |
Foreman |
Content Mirroring |
Management |
443 |
TCP |
HTTPS |
Foreman |
Smart Proxy API |
443 |
TCP |
HTTPS |
Client |
Host registration |
Initiation Uploading facts Sending installed packages and traces |
1883 |
TCP |
MQTT |
Client |
8000 |
TCP |
HTTP |
Client |
8000 |
TCP |
HTTP |
Client |
PXE Boot |
Installation |
8140 |
TCP |
HTTPS |
Client |
OpenVox agent |
8443 |
TCP |
HTTPS |
Client |
Host registration |
Deprecated and only needed for Client hosts deployed before upgrades |
9090 |
TCP |
HTTPS |
Foreman |
Smart Proxy API |
9090 |
TCP |
HTTPS |
Client |
Register Endpoint |
Client registration with Smart Proxy servers |
9090 |
TCP |
HTTPS |
Client |
OpenSCAP |
9090 |
TCP |
HTTPS |
Discovered host |
Discovery |
9090 |
TCP |
HTTPS |
Client |
ICMP |
ping |
Client |
DHCP |
7 |
TCP |
echo |
Client |
DHCP |
22 |
TCP |
SSH |
Target host |
Remote execution |
Run jobs |
443 |
TCP |
HTTPS |
Foreman |
Smart Proxy |
Smart Proxy Configuration management Template retrieval OpenSCAP Remote execution result upload |
443 |
TCP |
HTTPS |
Foreman |
Content |
Sync |
443 |
TCP |
HTTPS |
Foreman |
Client communication |
Forward requests from Client to Foreman |
443 |
TCP |
HTTPS |
DHCP management |
623 |
Client |
Power management |
7911 |
TCP |
DHCP, OMAPI |
DHCP Server |
DHCP |
9090 |
TCP |
HTTPS |
Client |
Discovery |
7. Content flow in Foreman
Content flow in Foreman involves management and distribution of content from external sources to hosts.
Content in Foreman flows from external content sources to Foreman server. Smart Proxy servers mirror the content from Foreman server to hosts.
- External content sources
You can configure many content sources with Foreman. The supported content sources include the Red Hat Customer Portal, custom Deb and Yum repositories, PyPI, Git repositories, Ansible collections, container registries, SCAP repositories, or internal data stores of your organization.
- Foreman server
On your Foreman server, you plan and manage the content lifecycle.
- Smart Proxy servers
By creating Smart Proxy servers, you can establish content sources in various locations based on your needs. For example, you can establish a content source for each geographical location or multiple content sources for a data center with separate networks.
- Hosts
By assigning a host system to a Smart Proxy server or directly to your Foreman server, you ensure the host receives the content they provide. Hosts can be physical or virtual.
8. Provisioning methods in Foreman
- Network based
You must configure the necessary network booting services, such as DHCP or TFTP. When you create a host entry, you select a PXE loader that can configure DHCP options for network booting if Smart Proxy is set up to configure the DHCP service automatically.
This method uses an operating system installer, such as Anaconda, Debian Installer, Agama, or AutoYaST, and a template-generated file with installation options downloaded from Foreman, such as
Agama,AutoYaST,Kickstart,Preseed, orPreseed Autoinstalltemplates.- Network based with PXE Discovery
- PXE-less Discovery with kexec
Kernel execute is a Technology Preview feature only. Technology Preview features are not supported by Foreman community. Foreman community does not recommend using them in production. These features provide early access to upcoming product features, enabling customers to test functionality and provide feedback during the development process. |
- Boot disk based
- Image based
9. Expense management for Red Hat subscriptions
Red Hat provides you with several tools to control costs and optimize spending on Red Hat subscriptions. This is useful if you plan to manage Red Hat Enterprise Linux hosts.
9.1. Subscriptions usage data
For the purposes of expense management and to optimize your spending, track your subscriptions usage data that you can get from your Foreman environment and Red Hat. You can track usage, capacity, and utilization of your Red Hat subscriptions.
- Usage
Measures the consumption of installed Red Hat products.
This data tells you: How much am I using? For example: I have 42 hypervisors, each with 2 sockets, tagged with the Production usage type.
- Capacity
Measures the amount of Red Hat products that have been purchased. It is the upper limit of usage.
This data tells you: How much have I purchased? For example: I purchased QTY 52 of RH00001. Each RH00001 covers a 2-socket hypervisor and all of its guests.
- Utilization
Measures how much of the purchased capacity has been exhausted.
This data tells you: How much of my capacity is being used? For example: I am using 42 of my 52 RH00001, leaving 10 free for additional use.
9.2. Subscriptions tracking tools
You can track subscriptions usage by combining the following tools.
- System Purpose
Defines non-technical system attributes for hosts to aid accurate inventory reporting:
Service Level Agreement (SLA): Self-Support, Standard, Premium
Usage type: Production, Development/Test
Role: Server, Workstation
System purpose is configured by using the Subscription Manager tool.
- Insights client
Collects data from hosts and sends it to Foreman. Foreman then forwards the data and host inventory to the Red Hat Hybrid Cloud Console for analysis. You can install the Insights client on Red Hat Enterprise Linux hosts during host registration, host provisioning, or using remote execution.
- Subscriptions service
Provides capacity data, calculates utilization, and reports subscription usage in connected scenarios. This service is hosted on the Red Hat Hybrid Cloud Console.
- Foreman
Provides reports on products installed on hosts. You can download these reports in various formats, such as YAML, JSON, HTML, and CSV. You can use these reports to calculate utilization locally.
9.3. Subscriptions tracking scenarios
You can track your subscription usage in one of the following scenarios, depending on your environment and data sensitivity.
- Connected scenario
You share all collected data with Red Hat.
Foreman uploads inventory data to the Red Hat Hybrid Cloud Console automatically.
Red Hat Hybrid Cloud Console provides all services.
Services powered by Red Hat Lightspeed analyze the data.
Subscriptions service in the Red Hat Hybrid Cloud Console calculates utilization data.
- Connected data-sensitive scenario
You share just enough data with Red Hat to enable subscription reporting.
You control what data is uploaded by enabling obfuscation or exclusion settings.
Red Hat Hybrid Cloud Console provides limited services.
- Disconnected scenario
You do not share any data with Red Hat. Instead, you track your subscription usage as follows:
You can get usage data from the Host - Installed Products report in Foreman.
You can get capacity data from the Subscriptions service in the Red Hat Hybrid Cloud Console.
You can calculate utilization data locally using a tool of your choosing.
10. Deployment path for Foreman
10.1. Foreman server installation overview
Installing an instance of Foreman server on a dedicated server is the first step to a working Foreman infrastructure.
A default Foreman server installation includes installing PostgreSQL databases on the server. However, you can configure your Foreman server to use external databases instead. Moving to external databases distributes the workload and can reduce overall Foreman memory usage.
Frequent remote execution tasks. This requires a high volume of records in PostgreSQL and generates heavy database workloads.
High disk I/O workloads from frequent repository synchronization or content view publishing. This requires Foreman to create a record in PostgreSQL for each job.
High volume of hosts.
High volume of synchronized content.
10.2. External authentication methods available in Foreman
Foreman includes native support for authentication with a username and password. If you require additional methods of authentication, configure your Foreman server to use an external authentication source.
| Username and password | Single sign-on (SSO) | One-time password (OTP) | Time-based one-time password (TOTP) | PIV cards | |
Active Directory (direct integration) |
Yes |
Yes |
No |
No |
No |
FreeIPA |
Yes (Linux and Active Directory users) |
Yes (Linux users only) |
No |
No |
No |
Quarkus-based Keycloak |
Yes |
Yes |
Yes |
Yes |
Yes |
Wildfly-based Keycloak |
Yes |
Yes |
Yes |
Yes |
Yes |
LDAP |
Yes |
No |
No |
No |
No |
10.3. Organization and location planning and assignment
Organizations and locations enable you to arrange Foreman resources into logically structured groups. For example, you can create groups based on ownership, purpose, content, or security level. You can create and manage multiple organizations through Foreman, then divide and assign subscriptions to each individual organization.
- Organizations
Organizations can represent different business units, departments, or teams, such as Finance, Marketing, or Web Development. To manage Red Hat content, each organization requires a separate Red Hat subscription manifest.
- Locations
You can use locations to map the network infrastructure to prevent incorrect host placement or configuration. While you cannot assign a subnet, domain, or compute resources directly to a Smart Proxy server, you can assign them to a location.
Foreman server defines all locations and organizations. Each Smart Proxy server synchronizes content and handles configuration of hosts in a different location.
Your Foreman server retains the management function, while the content and configuration is synchronized between your Foreman server and Smart Proxy servers assigned to certain locations.
If you use host groups to bundle provisioning and configuration information, avoid mismatching resources from mutually exclusive contexts. For example, setting a subnet from one organization or location and a compute resource from a different organization or location creates an invalid host group. |
The system administrator creates the following organizations on their Foreman server:
Finance
Marketing
Sales
Additionally, the administrator creates the following locations on their Foreman server:
United States
United Kingdom
Japan
Boston
Phoenix
San Francisco
10.4. Smart Proxy servers installation overview
By installing Smart Proxy servers, you extend the reach and scalability of your Foreman deployment. You register each Smart Proxy server to Foreman server and configure it to provide the required services within your Foreman deployment.
You can install a Smart Proxy server in each of your geographic locations. By assigning a Smart Proxy to each location, you decrease the load on Foreman server, increase redundancy, and reduce bandwidth usage.
The maximum number of Smart Proxy servers that Foreman server can support has no fixed limit. It was tested that a Foreman server can support 17 Smart Proxy servers with 2 vCPUs. |
Decide what services you want to enable on each Smart Proxy server. You can configure the DNS, DHCP, and TFTP services on one of your Smart Proxy servers or you can use an external server to provide these services to your Smart Proxy servers.
10.5. Content library and content access strategy
To ensure that your Foreman can manage software and provide it to your hosts, you create repositories and synchronize them. You can also define which hosts can access which content and content versions.
Your Foreman content library can include various types of content. Creating repositories allows you to choose the specific software required for your environment. By creating only the necessary repositories, you avoid downloading unnecessary content.
Synchronizing repositories downloads the content from Canonical, Oracle, Red Hat, SUSE, or other sources to your Foreman server. The synchronized content is stored on your Foreman server, eliminating the need for hosts to access the repositories. You can synchronize repositories manually, or you can create a sync plan to ensure synchronization runs on a regular basis.
By default, Foreman includes the Default Organization View content view and the Library lifecycle environment.
- Default Organization View
The Default Organization View is the default content view in Foreman that contains all the content that is synchronized to Foreman. After you update your content, such as by adding or removing a repository, the update is immediately reflected in Default Organization View.
- Library
The Library lifecycle environment is the default lifecycle environment in Foreman. Every newly published content view version is automatically published to the Library lifecycle environment. You can also promote specific content view versions to the Library lifecycle environment if needed.
10.6. Role-based access control policies
One of the predefined roles is the Default role. Foreman assigns the Default role to every user in the system. By default, the Default role grants only a limited set of permissions. Be aware that if you add a permission to the Default role, every Foreman users will gain that permission. Assigning a different role to a user does not remove the Default role from the user. |
- Roles related to applications or parts of infrastructure
- Roles related to a particular stage of the software lifecycle
- Roles related to specific tasks
10.7. Provisioning configuration in Foreman
Provisioning templates enable you to define the way Foreman installs an operating system on your hosts.
The Discovery service enables you to detect unknown hosts and virtual machines on the provisioning network.
Host groups enable you to standardize provisioning of host configurations.
10.8. Subscriptions tracking configuration
For successful tracking of your subscriptions usage, you have to perform the following configuration tasks.
In both connected and disconnected scenarios, perform the following task:
Set the system purpose for hosts in Foreman.
In the connected scenarios, also perform the following tasks:
If you use a hypervisor with virtual machines, configure virt-who on Foreman server.
Configure inventory upload in Foreman and install the Insights client on hosts.
Activate the Subscriptions service in the Red Hat Hybrid Cloud Console if needed.
Monitor hosts by using Insights in Red Hat Hybrid Cloud Console
Activating and opening the subscriptions service in Getting Started with the Subscriptions Service
Monitoring hosts by using Insights in Red Hat Hybrid Cloud Console
10.9. Additional deployment tasks
- Remote execution commands on hosts
For more information, see Configure and set up remote jobs.
- Automating tasks with a configuration management tool
- Security management with OpenSCAP
You can enable the OpenSCAP plugin on your Foreman server and any Smart Proxy servers. With OpenSCAP, you can manage compliance policies and run security compliance scans on your hosts. After the scan completes, a compliance report is uploaded to your Foreman server.
- Load balancing
With load balancing configured on your Smart Proxy servers, you can improve performance on Smart Proxy servers while also improving performance and stability for host connections to Foreman.
For more information, see Configuring Smart Proxies with a load balancer.
- Preparing for disaster recovery
By preparing a disaster recovery plan, you can ensure the continuity of Foreman services in case of a disruptive event. This helps you restore your Foreman deployment to an operational state after an incident.
For more information, see Prepare for disaster recovery and recover from data loss.
11. Common deployment scenarios
11.1. Single location scenario with segregated subnets
If your infrastructure requires multiple isolated networks in one geographic location, you can create segregated subnets and manage them with a single Smart Proxy.
Your infrastructure might require multiple isolated subnets even if Foreman is deployed in a single geographic location. This can be achieved for example by deploying multiple Smart Proxy servers with DHCP and DNS services, but the recommended way is to create segregated subnets using a single Smart Proxy. This Smart Proxy is then used to manage hosts and compute resources in those segregated networks to ensure they only have to access the Smart Proxy for provisioning, configuration, errata, and general management.
11.2. Multiple location scenarios
Create at least one Smart Proxy server per geographic location to save bandwidth by having hosts obtain content locally. Only your Smart Proxy server synchronizes content from remote repositories, making your provisioning infrastructure more reliable and easier to configure.
Foreman community recommends to create at least one Smart Proxy server per geographic location. This practice can save bandwidth since hosts obtain content from a local Smart Proxy server. Synchronization of content from remote repositories is done only by the Smart Proxy, not by each host in a location. In addition, this layout makes the provisioning infrastructure more reliable and easier to configure.
11.3. Content view scenarios
A single lifecycle environment – content from Library is promoted directly to the production stage. This approach limits the complexity but still allows for testing the content within the Library before making it available to hosts.
A single lifecycle environment path – both operating system and applications content is promoted through the same path. The path can consist of several stages, which enables thorough testing but requires additional effort. For example, you can use the Development, QA, and Production stages.
Application specific lifecycle environment paths – each application has a separate path, which allows for individual application release cycles. You can associate specific compute resources with application lifecycle stages to facilitate testing. However, this scenario increases the maintenance complexity.
Host specific content view – a dedicated content view for each host type. This approach can be useful in deployments with a small number of host types (up to 30). However, it prevents sharing content across host types as well as separation based on criteria other than the host type, for example, between operating system and applications. With critical updates every content view has to be updated, which increases maintenance efforts.
11.4. Multiple manifest scenario
You can use many Red Hat Network subscription manifests in one Foreman server to manage systems from different Red Hat Network accounts or entities. This allows you to assign subscriptions to separate organizations and manage those organizations independently.
If you plan to have more than one Red Hat Network account, or if you want to manage systems belonging to another entity that is also a Red Hat Network account holder, then you and the other account holder can assign subscriptions, as required, to manifests. A customer that does not have a Foreman subscription can create a Subscription Asset Manager manifest, which can be used with Foreman, if they have other valid subscriptions. You can then use the multiple manifests in one Foreman server to manage multiple organizations.
The following diagram shows two Red Hat Network account holders, who want their systems to be managed by the same Foreman installation. In this scenario, Example Corporation 1 can allocate any subset of their 60 subscriptions, in this example they have allocated 30, to a manifest. This can be imported into the Foreman as a distinct Organization. This allows system administrators the ability to manage Example Corporation 1’s systems using Foreman completely independently of Example Corporation 2’s organizations (R&D, Operations, and Engineering).
When creating a Red Hat subscription manifest:
Add the subscription for Foreman server to the manifest if planning a disconnected or self-registered Foreman server. This is not necessary for a connected Foreman server that is subscribed using the Subscription Manager utility on the base system.
Add subscriptions for all Smart Proxy servers you want to create.
Add subscriptions for all Red Hat products you want to manage with Foreman.
Note the date when the subscriptions are due to expire and plan for their renewal before the expiry date.
Create one manifest per organization. You can use multiple manifests and they can be from different Red Hat subscriptions.
Foreman allows the use of future-dated subscriptions in the manifest. This enables uninterrupted access to repositories when future-dated subscriptions are added to a manifest before the expiry date of existing subscriptions.
Note that the Red Hat subscription manifest can be modified and reloaded to Foreman server in case of any changes in your infrastructure, or when adding more subscriptions. Manifests should not be deleted. If you delete the manifest from the Red Hat Customer Portal or in the Foreman web UI it will unregister all of your hosts.
11.5. Host group structure scenarios
- Flat structure
- Lifecycle environment based structure
- Application based structure
- Location based structure
In this hierarchy, the distribution of locations is aligned with the host group structure. In a scenario where the location or Smart Proxy server topology determines many other attributes, this approach is the best option. However, this structure complicates sharing parameters across locations, therefore in complex environments with a large number of applications, the number of host group changes required for each configuration change increases significantly.
11.6. Inter-Server Synchronization deployment scenarios
You can use Inter-Server Synchronization to synchronize content between Foreman servers, including air-gapped servers. In these scenarios, you copy selected content views or all Library content from an upstream server to downstream servers over a network or through physical export.
Foreman uses Inter-Server Synchronization (ISS) to synchronize content between two Foreman servers including those that are air gapped.
If you want to copy some but not all content from your Foreman server to other Foreman servers. For example, you have content views that your IT department consumes from Foreman server, and you want to copy content from those content views to other Foreman servers.
If you want to copy all Library content from your Foreman server to other Foreman servers. For example, you have products and repositories that your IT department consumes from Foreman server in the Library, and you want to copy all products and repositories in that organization to other Foreman servers.
You cannot use ISS to synchronize content from Foreman server to Smart Proxy server. Smart Proxy server supports synchronization natively. |
The upstream Foreman server is connected to the internet. This server consumes content from the Red Hat Content Delivery Network (CDN) or custom sources.
The downstream Foreman server is completely isolated from all external networks.
The downstream Foreman server can communicate with a connected upstream Foreman server over an internal network.
You can configure your downstream Foreman server to synchronize content from the upstream Foreman server over the network.
The upstream Foreman server is connected to the internet. This server consumes content from the Red Hat CDN or custom sources.
The downstream Foreman server does not have a network connection to a connected upstream Foreman server.
The only way for an air-gapped downstream Foreman server to receive content updates is by exporting payload from the upstream Foreman server, bringing it physically to the downstream Foreman server, and importing the payload.
You can configure your downstream Foreman server to synchronize content by using exports.
11.7. Foreman deployment scenarios on AWS
You can deploy Foreman server, Smart Proxy servers, and hosts in Amazon Web Services (AWS) using various configurations. Options range from simple single-region setups to multi-region deployments with VPN connections or direct connections between on-premises and cloud environments.
You can run Foreman server, Smart Proxy servers, and hosts in your Amazon Web Services (AWS) environment. You can deploy Foreman on Amazon Web Services (AWS) in several scenarios.
- One-region setup
This is the least complex configuration of Foreman in AWS. Deploy both Foreman server and the hosts residing within the same region and within the Virtual Private Cloud (VPC) You can also use a different availability zone.
Figure 7. One-region setup - Connecting on-premises and AWS region
Create a VPN connection between the on-premises location and the AWS region where your Smart Proxy server is located. It is also possible to use the external host name of Foreman server when you register the instance that runs Smart Proxy.
Figure 8. Site-to-site VPN connection between the AWS region and the on-premises data center
Figure 9. Direct connection using the external DNS host name - Connecting different regions
Create a site-to-site VPN connection between different regions so that you can use the internal DNS host name when you register the instance that runs Smart Proxy to Foreman server. If you do not establish a site-to-site VPN connection, use the external DNS host name when you register the instance that runs Smart Proxy to Foreman server.
NoteMost public cloud providers do not charge for data being transferred into a region or between availability zones within a single region. However, they charge for data leaving the region to the internet.
Figure 10. Site-to-site VPN connection between AWS regions
Figure 11. Direct connection using the external DNS host name
12. Provisioning requirements in Foreman
12.1. PXE booting in Foreman
- PXE sequence
initrdand Kickstart. -
- PXE booting requirements
Network requirements:
Client requirements:
Ensure that all the network-based firewalls are configured to allow clients on the subnet to access the Smart Proxy.
Foreman requirements:
12.2. HTTP booting in Foreman
- HTTP booting requirements with managed DHCP
All the network-based firewalls are configured to allow clients on the subnet to access the Smart Proxy. For more information, see Networking considerations in Foreman.
NoteAlthough TFTP protocol is not used for HTTP UEFI Booting, Foreman uses TFTP Smart Proxy API to deploy boot loader configuration.
Ensure that the TCP port 8000 is open for the client to download the boot loader and Kickstart templates from the Smart Proxy.
The TCP port 9090 is open for the client to download the boot loader from the Smart Proxy using the HTTPS protocol.
The subnet that functions as the host’s provisioning interface has a DHCP Smart Proxy, an HTTP Boot Smart Proxy, a TFTP Smart Proxy, and a Templates Smart Proxy
- HTTP booting requirements with unmanaged DHCP
http://smartproxy.example.com:8000 -
https://smartproxy.example.com:9090
Ensure that all the network-based firewalls are configured to allow clients on the subnet to access the Smart Proxy. For more information, see Networking considerations in Foreman.
Ensure that the TCP port 8000 is open for the client to download boot loader and Kickstart templates from the Smart Proxy.
Ensure that the TCP port 9090 is open for the client to download the boot loader from the Smart Proxy through HTTPS.
Ensure that the host provisioning interface subnet has an HTTP Boot Smart Proxy set.
12.3. Secure Boot in Foreman
When Foreman is installed on Enterprise Linux using foreman-installer, grub2 and shim boot loaders that are signed by Red Hat are deployed into the TFTP and HTTP UEFI Boot directory.
PXE loader options named "SecureBoot" configure hosts to load shim.efi.
On Debian and Ubuntu operating systems, the grub2 boot loader is created using the grub2-mkimage unsigned.
To perform the Secure Boot, the boot loader must be manually signed and key enrolled into the EFI firmware.
Alternatively, grub2 from Ubuntu or Enterprise Linux can be copied to perform booting.
foreman |
N/A |
foreman |
N/A |
yes |
/usr/share/foreman |
/sbin/nologin |
foreman-proxy |
N/A |
foreman-proxy |
N/A |
yes |
/usr/share/foreman-proxy |
/sbin/nologin |
apache |
48 |
apache |
48 |
no |
/usr/share/httpd |
/sbin/nologin |
postgres |
26 |
postgres |
26 |
no |
/var/lib/pgsql |
/bin/bash |
pulp |
N/A |
pulp |
N/A |
no |
N/A |
/sbin/nologin |
puppet |
52 |
puppet |
52 |
no |
/sbin/nologin |
saslauth |
N/A |
saslauth |
76 |
no |
/run/saslauthd |
/sbin/nologin |
tomcat |
53 |
tomcat |
53 |
no |
/usr/share/tomcat |
/bin/nologin |
unbound |
N/A |
unbound |
N/A |
yes |
/etc/unbound |
/sbin/nologin |
- Activation key
Activation keys are used by Subscription Manager to register hosts to Foreman. They define content view environment associations, content overrides, system purpose attributes, and other parameters to be associated with a newly created host.
You can use them on multiple machines and they behave like configuration information rather than traditional software license keys. You can also use multiple activation keys with a single host. When you register a host using an activation key, certain content from Foreman is provided to the host. The content that is made available depends on the content in the activation key’s content view environments, any content overrides present, any repository-level restrictions such as operating system or architecture, and system purpose attributes such as release version.
- Ansible
- Answer file
- ARF report
- Audits
- Boot disk
- Catalog
- Candlepin
- Compliance policy
- Compute profile
- Compute resource
- Configuration Management
- Container (Docker container)
- Container image
- Content
A general term for everything Foreman distributes to hosts. Content includes software packages such as
.rpmpackages, errata, or Docker images. Content is synchronized into the Library and then promoted into lifecycle environments using content views so that they can be consumed by hosts.
- Content delivery network (CDN)
- Content view
Content views are named and versioned collections of repositories. When you publish a content view, Foreman creates a new content view version. This content view version is a frozen snapshot of the current state of the repositories within the content view. Any subsequent changes to the underlying repositories will no longer affect the published content view version. Once a content view is published, it can be promoted through the lifecycle environment path, or modified using incremental upgrades.
- Composite content view
- Discovered host
- Discovery image
- Discovery plugin
Automatically detects unknown bare-metal hosts on the provisioning network. The plugin consists of three components: services running on Foreman server and Smart Proxy server, and the Discovery image running on host.
- Discovery rule
- Docker tag
- Enterprise Linux
AlmaLinux
CentOS Stream
Oracle Linux
Rocky Linux
- ERB
- Errata
- External node classifier (ENC)
- Facter
- Facts
- Foreman
- Full host image
- Generic image
A boot disk for PXE-less provisioning that is not tied to a specific host. The generic image sends the MAC address of your host to Foreman server, which matches it against the host entry.
- Hammer
Hammer is a command-line interface tool for Foreman. You can execute Hammer commands from the command line or use it in scripts. You can use Hammer to automate certain recurring tasks as an alternative to Foreman Ansible collection or Foreman API.
- Host
- Host collection
- Host group
A host group is a template to build hosts that holds shared parameters, such as subnet or lifecycle environment. It helps to unify configuration management in Ansible, Puppet, and Salt by grouping hosts. You can nest host groups to create a hierarchical structure. For more information, see Working with host groups.
- Host image
- Installation Media
Installation media are sets of installation files used to install the base operating system during the provisioning process. An installation medium in Foreman represents the installation files for one or more operating systems, which must be accessible over the network, either through an URL or an NFS server location. It is usually either a mirror or a CD or DVD image.
Every operating system depends on exactly one path of an installation medium, whereas installation media paths may serve different operating systems at the same time. You can use operating system parameters such as
$version,$major, and$minorto parameterize the URL.
- Job
- Katello
Katello is an open-source plugin to perform content management and subscription handling. It depends on Pulp for content management, which fetches software from repositories and stores various versions of it. It also depends on Candlepin for host registration and managing subscription manifests.
- Lazy sync
- Location
- Library
A container for content from all synchronized repositories on Foreman server. Libraries exist by default for each organization as the root of every lifecycle environment path and the source of content for every content view.
- Lifecycle environment path
- Manifest (Red Hat subscription manifest)
A mechanism for transferring subscriptions from the Red Hat Customer Portal to Foreman. Do not confuse with Puppet manifest.
- Migrating Foreman
- OpenSCAP
- Organization
- Parameter
- Patch and release management
Patch and release management describes the process of acquiring, managing, and installing patches and software updates to your infrastructure. Using Foreman, you can keep control of the package versions available to your hosts and deliver applicable errata.
- Permission
- Product
Products are named collections of one or more repositories. If you manage Red Hat content and upload a Red Hat manifest, Foreman automatically groups Red Hat content within products. If you manage SUSE content using SCC Manager plugin, Foreman automatically groups SUSE content within products. For more information, see Managing SUSE content.
- Promote (a content view)
The act of moving a content view from one lifecycle environment to another. For more information, see Promote a content view by using Foreman web UI.
- Provisioning
The provisioning of a host is the deployment of the base operating system on the host and registration of the host to Foreman. Optionally, the process continues with the supply of content and configuration. This process is ideally automated. Provisioned hosts run on compute resources or bare metal, never Foreman server or Smart Proxy servers.
Agamatemplates for SUSE Linux Enterprise Server 16 -
AutoYaSTtemplates for SUSE Linux Enterprise Server 15 and 12 -
Kickstarttemplates for AlmaLinux, Amazon Linux, CentOS, Oracle Linux, Red Hat Enterprise Linux, and Rocky Linux -
Preseed Autoinstalltemplates for Ubuntu -
Preseedtemplates for Debian
- Publish (a content view)
- Pulp
- Puppet
- OpenVox agent
- Puppet environment
- Puppet manifest
- OpenVox server
A Smart Proxy server component that provides a Puppet catalog to hosts for execution by the OpenVox agent.
- Puppet module
- PXE
- Recurring logic
- Registry
- Repository
A repository is a single source and the smallest unit of content in Foreman. You can either synchronize a repository with a URL or manually upload content to Foreman. Foreman supports multiple content types. For more information, see Content types in Foreman. One or more repositories form a product.
- Resource type
- Role
- Salt
- SCAP content
SCAP stands for Security Content Automation Protocol and refers to
.xmlfiles containing the configuration and security baseline against which hosts are checked. Foreman uses SCAP content in compliance policies.
Smart Proxy servers can provide DHCP, DNS, and TFTP services and act as an Ansible control node, OpenVox server, or Salt Master in separate networks. They interact with Foreman server in a client-server model. Foreman server always comes bundled with an integrated Smart Proxy.
Smart Proxy servers are required in Foreman deployments that manage IT infrastructure spanning across multiple networks and useful for Foreman deployments across various geographical locations.
- Subnet image
- Subscription
- Subscription Manager
subscription-manageruses activation keys to consume content on hosts.
- SUSE Subscription
You can use Foreman to manage SUSE content. For more information, see Managing SUSE content.
- Synchronization
Synchronization describes the process of fetching content from external repositories into the Foreman server.
- Sync plan
- Tailoring files
- Task
- Trend
- Updating Foreman
The process of advancing your Foreman server and Smart Proxy server installations from one patch release to the next, for example Foreman 5.1.0 to Foreman 5.1.1.
- Upgrading Foreman
The process of advancing your Foreman server and Smart Proxy server installations from one minor release to the next, for example Foreman 5.0 to Foreman 5.1.
- User group
- User
- Virtualization
- virt-who
- XCCDF profiles
