1. Foreman use cases
Foreman is a centralized tool for provisioning, remote management, and monitoring of multiple Enterprise Linux deployments. With Foreman, you can deploy, configure, and maintain your systems across physical, virtual, and cloud environments.
Foreman helps you provision hosts and strengthen security across physical, virtual, and cloud environments. You can also benefit from AI-powered assistance by deploying the Model Context Protocol (MCP) server for Foreman, which enables you to interact with your infrastructure using natural language.
Foreman focuses on the following use cases:
Provisioning
Deploy consistently configured hosts on bare metal, virtual machines, and cloud instances from a unified interface.
Foreman automates key stages of the deployment lifecycle, including network configuration, operating system installation, and post-installation tasks. For example, you can define templates and partition layouts to achieve flexibility in how you deploy hosts.
This approach helps reduce deployment time, standardize the provisioning process, and support scaling of your infrastructure.
Security management
Reduce the effort required to secure hosts at scale.
Foreman helps you enforce security policies, scan for vulnerabilities, and remediate compliance violations across your infrastructure. For example, you can integrate Foreman with security scanning tools, track compliance against security baselines, and set up procedures to help ensure hosts meet regulatory requirements.
This capability enables centralized security oversight, supports incident response, and helps reduce the attack surface of your hosts.
Knowledge and analytics
Identify potential issues and gain a comprehensive view of your infrastructure.
Foreman collects data from hosts, generates reports on system status and trends, and provides dashboards that visualize infrastructure health. For example, you can monitor resource utilization, track configuration changes, and identify patterns.
This knowledge helps you make informed decisions about your infrastructure and spot potential problems.
Configuration management
Apply configurations to hosts in a consistent and repeatable manner.
Foreman integrates with configuration management tools to define desired state, enforce policies, and remediate drift across your infrastructure. For example, you can manage configurations as code, version control your infrastructure definitions, and automate updates to help keep hosts compliant with organizational standards.
This approach reduces the risk of manual configuration errors and helps maintain consistency across your hosts.
2. Foreman architecture and components
As you are evaluating Foreman for your organization, understanding the roles and relationships of major components helps you determine what infrastructure to deploy and how components interact.
2.1. Major Foreman components
A typical Foreman deployment consists of the following components: a Foreman server, Smart Proxy servers, and hosts that receive configuration from Foreman server and Smart Proxy servers.
Foreman server
Foreman server is the central component of your Foreman deployment.
  • Configuration of hosts
  • Host provisioning
    Foreman server delegates host provisioning and communication to Smart Proxy servers. Foreman server itself also includes a Smart Proxy.
Smart Proxy server
Hosts in Foreman
With Foreman, you can manage hosts at scale, including monitoring, provisioning, remote execution, and configuration management. You can also group hosts by using features such as host groups and host collections.
2.2. Smart Proxy server features
Smart Proxy servers provide local host management services.
Smart Proxies provide the following functionalities:
DHCP
DNS
TFTP
Realm
Puppet server
Puppet Certificate Authority
Provisioning template proxy
OpenSCAP
Remote execution (REX)
Infrastructure Smart Proxies: DNS + DHCP + TFTP
Smart Proxies with these services provide infrastructure services for hosts and have all necessary services for provisioning new hosts.
2.3. Key open source components of Foreman
Foreman consists of several open source projects integrated with each other.
Foreman
Katello
Candlepin
Pulp
3. Administration tools for Foreman
Foreman offers multiple tools for administrators to manage the deployment. Understanding the available administration tools helps you select the approach that fits your workflow and automation needs.
3.1. Foreman web UI for management from your browser
3.2. Hammer CLI for management from the command line
3.3. Foreman API for automation and integration
  • Broad client support – any programming language, framework, or system with support for HTTP protocol can use the API.
  • Self-descriptive – client applications require minimal knowledge of the Foreman infrastructure because users discover many details at runtime.
  • Resource-based model – the resource-based REST model provides a natural way to manage a virtualization platform.
  • Integrate with enterprise IT systems.
  • Integrate with third-party applications.
  • Perform automated maintenance or error checking tasks.
  • Automate repetitive tasks with scripts.
3.4. Foreman Ansible Collection
Modules from the Foreman Ansible Collection are provided by the ansible-collection-theforeman-foreman package. Before you can use the modules, you must install the package on the system where you run your playbooks.
Using the modules, you can write playbooks to automate the administration of your Foreman.
3.5. MCP server for AI-powered assistance
Foreman provides a Model Context Protocol (MCP) server so that you can query and manage your Foreman inventory from MCP-compatible AI applications by using natural language.
You deploy the MCP server from a container image that Foreman community provides and connect it to the AI application that runs your MCP client. The MCP server accesses Foreman with your credentials, so your MCP client cannot obtain data that you do not have permission to access.
By default, the MCP server is read-only. You can query your inventory and generate reports from it, for example, a report of all subnets and the hosts that are assigned to them.
When you start the MCP server, you can also grant it permissions to change your Foreman. For example, you can start remote execution jobs on your hosts, and publish and promote content views.
3.6. Remote execution in Foreman
4. Supported client architectures
Verify that your client architectures are supported before deploying Foreman.
4.1. Foreman operating system
You can deploy Foreman on the supported operating systems listed below.
  • Enterprise Linux 9 (x86_64)
Katello plugin packages, which provide content management capabilities, are only available for Enterprise Linux.
4.2. Client operating systems
  • Amazon Linux
  • Debian
  • Fedora
  • Ubuntu
  • Ansible
  • OpenSCAP
  • OpenSSH
  • Puppet
  • Salt
  • Katello host tools
  • Subscription Manager
  • Tracer utility
5. Security hardening features in Foreman
Foreman supports multiple security mechanisms for additional layers of protection. Understanding these capabilities helps you evaluate how Foreman can support the security requirements of your organization.
You can use the following security capabilities in Foreman to enhance the security of your deployment:
If your Enterprise Linux operating systems supports FIPS, you can install Foreman server and Smart Proxy server on a FIPS-enabled host. Note that Foreman itself is not FIPS-certified.
Foreman supports DEFAULT and FIPS crypto-policies. The FUTURE crypto-policy is not supported for Foreman server and Smart Proxy server installations.
If you want to run Foreman server or Smart Proxy server on a FIPS-enabled host, FIPS must be enabled on the host before installing. You cannot enable FIPS mode on Foreman server or Smart Proxy server after installation.
If you manage FIPS-enabled hosts, you must also run Foreman server and Smart Proxy servers in FIPS mode. If the server does not run in FIPS mode in this situation, you might experience unexpected behavior. For example, the hosts might not be able to run remote execution jobs from the server.
Foreman server and Smart Proxy servers can run on hosts that have the fapolicyd service enabled.
The fapolicyd daemon helps prevent unauthorized code execution and enhances system integrity by enforcing file access policies.
You can enable or disable fapolicyd on your Foreman server and Smart Proxy servers at any time.
Foreman community does not currently support full PQC compatibility for Foreman.
Foreman server and Smart Proxy servers must be run on hosts with SELinux enabled.
The SELinux collection of security modules enforces policies that define which processes can access specific system resources, providing protection against unauthorized access and exploitation.
To maintain a high-security environment, Foreman community recommends running Foreman with SELinux in enforcing mode. This ensures that access control policies are strictly enforced and minimizes the risk of privilege escalation or unauthorized actions.
In addition to these security capabilities, regularly updating security policies and configurations, as well as monitoring system logs, can help detect and respond to potential threats effectively on both Foreman server and Smart Proxy server.
6. Networking considerations in Foreman
For the components of Foreman architecture to communicate, the required network ports must be open to enable incoming and outgoing traffic between the components. Identify firewall port and networking requirements to ensure Foreman components can communicate properly.
6.1. Smart Proxy server networking
6.2. Foreman server port and firewall requirements
53
TCP and UDP
DNS
DNS Servers and clients
Name resolution
DNS (optional)
67
UDP
DHCP
Client
Dynamic IP
DHCP (optional)
69
UDP
TFTP
Client
TFTP Server (optional)
TCP
HTTPS
Smart Proxy
Foreman API
TCP
HTTPS
Client
Global Registration
Registering hosts to Foreman
Port 443 is required for registration initiation, and uploading facts.
1883
TCP
MQTT
Client
Pull based REX (optional)
Hosts for REX job notification (optional)
4505 – 4506
TCP
MQTT
Client
Salt (optional)
Salt Master to Salt Minions
5910 – 5930
TCP
HTTPS
Browsers
8000
TCP
HTTP
Client
Provisioning templates
8000
TCP
HTTPS
Client
PXE Boot
Installation
8140
TCP
HTTPS
Client
OpenVox agent
Client updates (optional)
8443
TCP
HTTPS
Foreman
Smart Proxy API
Smart Proxy functionality
8443
TCP
HTTPS
Client
OpenSCAP
8443
TCP
HTTPS
Discovered Node
Discovery
Host Discovery and provisioning (if the Discovery plugin is installed)
9191
TCP
HTTPS
Client
Salt (optional)
Salt API
ICMP
ping
Client
DHCP
Free IP checking (optional)
7
TCP
echo
Client
DHCP
22
TCP
SSH
Target host
Remote execution
Run jobs
22, 16514
TCP
SSH SSH/TLS
Compute Resource
53
TCP and UDP
DNS
DNS Servers on the internet
DNS Server
53
TCP and UDP
DNS
DNS Server
Smart Proxy DNS
53
TCP and UDP
DNS
DNS Server
Orchestration
Validation of DNS conflicts
68
UDP
DHCP
Client
Dynamic IP
DHCP (optional)
80
TCP
HTTP
Remote repository
Content Sync
Remote repositories
389, 636
TCP
LDAP, LDAPS
External LDAP Server
LDAP
TCP
HTTPS
Compute resources
TCP
HTTPS
Infoblox DHCP Server
DHCP management
623
Client
Power management
BMC On/Off/Cycle/Status
5000
TCP
HTTPS
OpenStack Compute Resource
Compute resources
5900 – 5930
TCP
SSL/TLS
Hypervisor
noVNC console
Launch noVNC console
5985
TCP
HTTP
Client
WinRM
5986
TCP
HTTPS
Client
WinRM
7911
TCP
DHCP, OMAPI
DHCP Server
DHCP
8443
TCP
HTTPS
Client
Discovery
8443
TCP
HTTPS
Smart Proxy
Smart Proxy API
Management of Smart Proxies
6.3. Smart Proxy port and firewall requirements
8000
TCP
HTTP
Client
8000
TCP
HTTP
Client
PXE Boot
Installation
8140
TCP
HTTPS
Client
OpenVox agent
8443
TCP
HTTPS
Foreman
Smart Proxy API
8443
TCP
HTTPS
Client
Register Endpoint
8443
TCP
HTTPS
Client
OpenSCAP
8443
TCP
HTTPS
Discovered host
Discovery
ICMP
ping
Client
DHCP
7
TCP
echo
Client
DHCP
22
TCP
SSH
Target host
Remote execution
Run jobs (optional)
TCP
HTTPS
Foreman
Smart Proxy
Smart Proxy
Configuration management Template retrieval
OpenSCAP Remote execution result upload
TCP
HTTPS
DHCP management
623
Client
Power management
7911
TCP
DHCP, OMAPI
DHCP Server
DHCP
9090
TCP
HTTPS
Client
Discovery
7. Provisioning methods in Foreman
Network based
This method uses an operating system installer, such as Anaconda, Debian Installer, Agama, or AutoYaST, and a template-generated file with installation options downloaded from Foreman, such as Agama, AutoYaST, Kickstart, Preseed, or Preseed Autoinstall templates.
PXE-less Discovery with kexec
Boot disk based
Image based
Figure 1. Choosing a provisioning method
8. Deployment path for Foreman
8.1. Foreman server installation overview
  • High volume of hosts.
8.2. External authentication methods available in Foreman
FreeIPA
Yes (Linux users only)
Quarkus-based Keycloak
Wildfly-based Keycloak
LDAP
8.3. Organization and location planning and assignment
Organizations and locations enable you to arrange Foreman resources into logically structured groups. For example, you can create groups based on ownership, purpose, or security level.
Organizations
Organizations can represent different business units, departments, or teams, such as Finance, Marketing, or Web Development.
Locations
Foreman server defines all locations and organizations. Each Smart Proxy server handles configuration of hosts in a different location.
Your Foreman server retains the management function, while the configuration is synchronized between your Foreman server and Smart Proxy servers assigned to certain locations.
Some resources in Foreman, such as Ansible roles and operating systems, are not part of any organization or location context.
Example 1. Example of using organizations and locations in Foreman
  • Finance
  • Marketing
  • Sales
  • United States
  • United Kingdom
  • Japan
  • Boston
  • Phoenix
  • San Francisco
8.4. Smart Proxy servers installation overview
8.5. Role-based access control policies
8.6. Provisioning configuration in Foreman
8.7. Additional deployment tasks
For more information, see Run automated workflows on hosts.
Load balancing
Preparing for disaster recovery
By preparing a disaster recovery plan, you can ensure the continuity of Foreman services in case of a disruptive event. This helps you restore your Foreman deployment to an operational state after an incident.
9. Common deployment scenarios
9.1. Single location scenario with segregated subnets
9.2. Foreman deployment scenarios on AWS
One-region setup
One-region setup
Figure 2. One-region setup
Figure 3. Site-to-site VPN connection between the AWS region and the on-premises data center
Figure 4. Direct connection using the external DNS host name
Connecting different regions
Figure 5. Site-to-site VPN connection between AWS regions
Figure 6. Direct connection using the external DNS host name
10. Provisioning requirements in Foreman
10.1. PXE booting in Foreman
PXE sequence
PXE booting requirements
  • Network requirements:
  • Client requirements:
  • Foreman requirements:
10.2. HTTP booting in Foreman
    • The TCP port 8443 is open for the client to download the boot loader from the Smart Proxy using the HTTPS protocol.
      • https://smartproxy.example.com:8443
    • Ensure that the TCP port 8443 is open for the client to download the boot loader from the Smart Proxy through HTTPS.
10.3. Secure Boot in Foreman
pesign -P -h -i /boot/vmlinuz-<version>
mokutil --import-hash <hash value returned from pesign>
reboot
foreman
N/A
foreman
N/A
yes
/usr/share/foreman
/sbin/nologin
foreman-proxy
N/A
foreman-proxy
N/A
yes
/usr/share/foreman-proxy
/sbin/nologin
apache
48
apache
48
no
/usr/share/httpd
/sbin/nologin
postgres
26
postgres
26
no
/var/lib/pgsql
/bin/bash
puppet
52
puppet
52
no
/sbin/nologin
unbound
N/A
unbound
N/A
yes
/etc/unbound
/sbin/nologin
Ansible
Answer file
ARF report
Audits
Boot disk
Catalog
Compliance policy
Compute profile
Compute resource
Configuration Management
Discovered host
Discovery image
Discovery plugin
Enables automatic bare-metal discovery of unknown hosts on the provisioning network. The plugin consists of three components: services running on Foreman server and Smart Proxy server, and the Discovery image running on host.
Discovery rule
Enterprise Linux
  • AlmaLinux
  • CentOS Stream
  • Oracle Linux
  • Red Hat Enterprise Linux
  • Rocky Linux
ERB
Facter
Facts
Foreman
Full host image
Generic image
Hammer
Host
Host collection
Host group
A host group is a template to build hosts that holds shared parameters, such as subnet or lifecycle environment. It helps to unify configuration management in Ansible, Puppet, and Salt by grouping hosts. You can nest host groups to create a hierarchical structure. For more information, see Working with host groups.
Host image
Job
Location
Migrating Foreman
OpenSCAP
Organization
Parameter
Permission
Provisioning
  • Agama templates for SUSE Linux Enterprise Server 16
  • AutoYaST templates for SUSE Linux Enterprise Server 15 and 12
  • Kickstart templates for AlmaLinux, Amazon Linux, CentOS, Oracle Linux, Red Hat Enterprise Linux, and Rocky Linux
  • Preseed Autoinstall templates for Ubuntu
  • Preseed templates for Debian
Puppet
OpenVox agent
Puppet environment
Puppet manifest
OpenVox server
Puppet module
PXE
Recurring logic
Resource type
Role
Salt
SCAP content
Smart Proxy server
Smart Proxy servers can provide DHCP, DNS, and TFTP services and act as an Ansible control node, OpenVox server, or Salt Master in separate networks. They interact with Foreman server in a client-server model.
Subnet image
Tailoring files
Task
Trend
Updating Foreman
The process of advancing your Foreman server and Smart Proxy server installations from one patch release to the next, for example Foreman 5.0.0 to Foreman 5.0.1.
Upgrading Foreman
The process of advancing your Foreman server and Smart Proxy server installations from one minor release to the next, for example Foreman 3.19 to Foreman 5.0.
User group
User
Virtualization
virt-who
XCCDF profiles
Report issue
