1. Performance metrics in Foreman
Metrics help you monitor Foreman performance, plan capacity, and troubleshoot issues by collecting data on system resources, database activity, and application behavior.
You can set up a third-party solution to collect live metrics from Foreman server, archive them for a fixed period of time, and analyze them.
  • Basic statistics from the operating system, including system load, memory utilization, and input/output operations
  • Process statistics, including memory and CPU utilization
  • Apache HTTP Server activity statistics
  • PostgreSQL activity statistics
  • Foreman application statistics
The metrics monitoring solution uses multiple components to collect, store, and visualize Foreman performance data for analysis and troubleshooting.
Performance Co-Pilot (PCP)
Performance Metric Domain Agents (PMDA)
A Performance Metric Domain Agent is a PCP add-on that enables access to metrics of an application or service. To gather all metrics relevant to Foreman, you have to install PMDA for Apache HTTP Server and PostgreSQL.
Grafana
3. Set up the metrics monitoring solution
The metrics monitoring solution uses Performance Co-Pilot (PCP) to collect and analyze system performance data, helping you find slowdowns and improve resource usage.
3.1. Enable performance metrics collection with PCP
Install Performance Co-Pilot (PCP) packages and enable the data collection daemons to begin gathering system performance metrics on your Foreman server.
  • Ensure you have a minimum of 20 GB space available in the /var/log/pcp directory.
    With the default PCP data retention settings, data storage is estimated to use between 100 MB and 500 MB of disk space per day, but might use up to several gigabytes over time. For more information, see Manage metrics storage and retention.
  1. Install the PCP packages:
    # dnf install pcp \
    pcp-pmda-apache \
    pcp-pmda-openmetrics \
    pcp-pmda-postgresql \
    pcp-pmda-redis \
    pcp-system-tools \
    foreman-pcp
  2. Enable and start the Performance Metrics Collector daemon and Performance Metrics Logger daemon:
3.2. Configure PCP data collection
Configure PCP to collect detailed performance data from Foreman processes and services, such as Apache HTTP Server, PostgreSQL, and Redis to enable complete monitoring.
  1. Symlink the Foreman-specific configuration to PMDA process monitoring:
    • Java
    • PostgreSQL
    • Redis
    • Dynflow
    • Puma
    • Pulpcore
  2. Install the process monitoring PMDA:
    # cd /var/lib/pcp/pmdas/proc
    # ./Install
  3. Configure PCP to collect metrics from Apache HTTP Server.
    1. Enable the Apache HTTP Server extended status module:
    2. Enable the Apache HTTP Server PMDA:
      # cd /var/lib/pcp/pmdas/apache
      # ./Install
  4. Configure PCP to collect metrics from PostgreSQL:
    # cd /var/lib/pcp/pmdas/postgresql
    # ./Install
  5. Configure PCP to collect metrics from Redis:
    # cd /var/lib/pcp/pmdas/redis
    # ./Install
  6. Enable the telemetry feature in Foreman:
  7. Configure PCP to collect data from Foreman:
    # cd /var/lib/pcp/pmdas/openmetrics
    # echo "https://foreman.example.com/metrics" > config.d/foreman.url
    # ./Install
  8. Restart PCP to begin data collection:
3.3. Verify PCP configuration
Verify that PCP is configured correctly and all monitoring services are running to ensure data collection is working as expected.
  • Print a summary of the active PCP configuration:
    # pcp
    Example output of the pcp command:
    Performance Co-Pilot configuration on foreman.example.com:
     platform: Linux foreman.example.com 4.18.0-372.32.1.el8_6.x86_64 #1 SMP Fri Oct 7 12:35:10 EDT 2022 x86_64
     hardware: 16 cpus, 2 disks, 1 node, 31895MB RAM
     timezone: UTC
     services: pmcd pmproxy
         pmcd: Version 5.3.7-17, 13 agents, 4 clients
         pmda: root pmcd proc pmproxy xfs redis linux apache mmv kvm
               postgresql jbd2 openmetrics
     pmlogger: primary logger: /var/log/pcp/pmlogger/foreman.example.com/20230831.00.10
         pmie: primary engine: /var/log/pcp/pmie/foreman.example.com/pmie.log
    In this example, both the Performance Metrics Collector Daemon (pmcd) and Performance Metrics Proxy Daemon (pmproxy) services are running. It also confirms the PMDA that are collecting metrics. Finally, it lists the active log file, in which pmlogger is currently storing metrics.
4. Enable web-based metrics visualization with Grafana
Enable web UI access to metrics by installing Grafana to visualize performance data through interactive dashboards.
  1. Install Grafana and the Grafana PCP plugin on your Foreman server:
  2. Start and enable the Grafana web service and the PCP proxy service:
  3. Open the firewall port to allow access to the Grafana web interface:
  4. Reload the firewall configuration to apply the changes:
    # firewall-cmd --reload
  5. Install PCP Redis and configure Grafana to load it. For more information, see Configuring PCP Redis in Red Hat Enterprise Linux 9 Monitoring and managing system status and performance.
  6. Access the Grafana web UI, enable the PCP plugin, and add PCP Redis as a data source. For more information, see Accessing the Grafana web UI in Red Hat Enterprise Linux 9 Monitoring and managing system status and performance.
5. Manage metrics storage and retention
PCP data retention is controlled by three factors: logged metrics, logging interval, and retention policy. Understanding these settings helps you balance monitoring detail with available disk space.
The following factors determine the storage capacity required by PCP data logging:
  • The logged metrics
  • The logging interval
  • The retention policy
5.1. Change default logging interval
Change the default logging interval to adjust how often PCP collects metrics, allowing you to save disk space with longer intervals or capture more detailed data with shorter intervals.
  1. Open the /etc/pcp/pmlogger/control.d/local configuration file.
  2. Locate the LOCALHOSTNAME line.
  3. Append -t XXs, where XX is the required time interval in seconds.
  4. Save the file.
  5. Restart the pmlogger service:
    # systemctl restart pmlogger
5.2. Change data retention policy
Change the data retention policy to control how long PCP keeps archived data, allowing you to save disk space by deleting older data sooner or retain data longer for analysis.
  1. Open the /etc/sysconfig/pmlogger_timers file.
  2. Locate the PMLOGGER_DAILY_PARAMS line.
  3. If the line is commented, uncomment the line.
  4. Configure the following parameters:
    • Ensure the default -E parameter is present.
    • Append the -x parameter and add a value for the required number of days after which data is archived.
    • Append the -k parameter and add a value for the number of days after which data is deleted.
    For example, the parameters -x 4 -k 7 specify that data will be compressed after 4 days and deleted after 7 days.
  5. Save the file.
5.3. View data storage statistics
View data storage statistics to see how much disk space each metric uses per day, helping you plan storage capacity and adjust retention settings.
Example storage statistics:
  • On your Foreman server, view data storage statistics:
6. Retrieve and analyze performance metrics
You can monitor Foreman performance using PCP metrics, which provide system-level data (CPU, memory, network) and Foreman-specific data (processes, PostgreSQL, Rails) in a structured format. Understanding PCP metrics helps you identify performance bottlenecks and optimize your deployment.
Metrics are stored in a tree-like structure. For example, all network metrics are stored in a node named network. Each metric can be a single value, or a list of values, known as instances. For example, kernel load has three instances, the 1-minute, 5-minute, and 15-minute average.
Metric Description
hotproc.*
Basic metrics of key Foreman processes
apache.*
Apache HTTP Server metrics
postgresql.*
Basic PostgreSQL statistics
openmetrics.foreman.fm_rails_*
Foreman metrics
6.1. Identify available metrics
Use these commands to discover what PCP metrics are available on your system, including both system-level metrics and Foreman-specific telemetry data, and to locate archived metric logs for historical analysis.
  • List all metrics available through PCP:
    # pminfo
  • List all Foreman metrics and their descriptions:
  • List the archived metrics:
  • The pmlogger daemon archives data as received, according to its configuration. Retrieve the name of the active log file:
    # pcp | grep logger
6.2. Retrieve live metrics
You can retrieve real-time performance data using PCP command-line tools to monitor disk activity, system performance, and other metrics while troubleshooting or analyzing Foreman performance issues.
  • To print current values of a particular metric, enter the following command:
    # pmrep -P 1 disk.partitions.write
    In this example, metric instances on writes to disk partitions are displayed. PCP converts the number of writes to disk partitions from a counter value to a rate value. The -P 1 argument specifies to abbreviate the values to one decimal place.
    Example output:
    metric:    disk.partitions.write
    host:      foreman.example.com
    semantics: cumulative counter (converting to rate)
    units:     count (converting to count / sec)
    samples:   all
                     vda1                  vda2                   sr0
                      0.0                  12.0                   0.0
                      0.0                   1.0                   0.0
                      0.0                   1.0                   0.0
                      0.0                   2.0                   0.0
  • To print system performance summary every 2 seconds, enter the following command:
    # pmrep -t 2sec :pmstat
    The :pmstat metricset provides a system performance summary equivalent to pmstat, including CPU, memory, swap, I/O, and load average metrics.
6.3. Retrieve archived metrics
Use these commands to analyze historical performance data from PCP archive files, including viewing specific metrics over time ranges, comparing time periods, and investigating past performance issues on your Foreman.
The archive file name depends on your pmlogger configuration and can differ from the examples below. Use the path shown when you verify your PCP configuration.
  • List all metrics that were enabled when the archive file was created:
  • View the host and time period covered by an archive file:
    # pmdumplog -l archive_file
  • List disk writes for each partition, over the time period covered by the archive file:
    # pmrep -a /var/log/pcp/pmlogger/foreman.example.com/20230831.00.10 \
  • List disk write operations per partition, with a 2-second interval, over the time period between 14:00 and 14:15:
      -d -t 2sec \
      -p \
      -P 3 \
      -S @14:00 -T @14:15 \
  • List average values of all performance metrics, including the time and value of the minimum/maximum, over the time period between 14:00 and 14:30, and format the values as a table:
    # pmlogsummary /var/log/pcp/pmlogger/foreman.example.com/20230831.00.10 \
      -HlfiImM \
      -S @14:00 \
      -T @14:30 \
      disk.partitions.write \
      mem.freemem
  • Display system metrics stored in an archive, starting from 14:00, in an interactive manner similar to the top tool:
    # pcp --archive /var/log/pcp/pmlogger/foreman.example.com/20230831.00.10 \
      -S @14:00 \
      atop
6.4. Retrieve metrics in the Grafana web UI
You can access the Grafana web interface to visualize Foreman performance metrics through customizable dashboards, making it easier to monitor trends and identify issues without using command-line tools.
  • Open the following URL in a browser: http://foreman.example.com:3000
7. Access Grafana remotely
By default, Grafana runs on http://localhost:3000 on the Foreman server and is only accessible locally. To access Grafana from a remote workstation, you can create an SSH tunnel that forwards your local port 3000 to the Foreman server port 3000.
Choose the procedure that matches your workstation’s operating system and tools.
7.1. Access Grafana remotely on Linux or macOS
By default, Grafana runs on http://localhost:3000 on the Foreman server and is only accessible locally. To access Grafana from a remote workstation, create an SSH tunnel that forwards your local port 3000 to the Foreman server port 3000.
  1. On your local workstation, create an SSH tunnel:
    # ssh -L 3000:localhost:3000 root@foreman.example.com -N
    The -L flag creates the port forwarding tunnel, and -N prevents executing any remote commands. Keep this terminal session open while accessing Grafana.
    To run the tunnel in the background, add the -f flag: ssh -f -L 3000:localhost:3000 root@foreman.example.com -N. To close a background tunnel, find its PID with ps aux | grep "3000:localhost[:]3000" and then run kill PID.
  2. Open your web browser and navigate to http://localhost:3000.
7.2. Access Grafana remotely on Windows with PuTTY
  1. Open PuTTY and enter your Foreman server hostname or IP address.
  2. In the left menu, navigate to Connection → SSH → Tunnels.
  3. Configure the port forwarding:
    • Source port: 3000
    • Destination: localhost:3000
    • Click Add.
  4. Return to the Session category and connect to your Foreman server.
  5. After connecting, open your web browser and navigate to http://localhost:3000.
7.3. Access Grafana remotely on Windows with PowerShell or Command Prompt
  1. If you have OpenSSH installed on Windows 10 or later, open PowerShell or Command Prompt and create an SSH tunnel:
    Keep this window open while accessing Grafana.
Report issue
