1. Use Case Considerations
Because Amazon Web Services is an image-only service, there are common Foreman use cases that do not work, or require extra configuration in an Amazon Web Service environment. If you plan to use Foreman on AWS, ensure that the use case scenarios that you want to use are available in an AWS environment.
1.1. Use Cases Known to Work
You can perform the following Foreman use cases on AWS:
Not all Red Hat subscriptions are eligible to run in public cloud environments. For more information about subscription eligibility, see the Red Hat Cloud Access Page. You can create additional organizations and then import additional manifests to the organizations. For more information, see Managing Organizations in Managing Organizations and Locations in Foreman.
One way to use multi-homed Smart Proxies is by configuring Smart Proxies with a load balancer. For more information, see Configuring Smart Proxies with a Load Balancer.
You must do this when Foreman server or Smart Proxy server has different internal and external DNS host names and there is no site-to-site VPN connection between the locations where you deploy Foreman server and Smart Proxy server.
You can use the On demand download policy to reduce the storage footprint of the server that runs Foreman. When you set the download policy to On Demand, content syncs to Foreman server or Smart Proxy server when a content host requests it.
For more information, see Importing Content in Managing Content.
1.2. Use Cases that Do Not Work
In AWS, you cannot manage the DHCP. Because of this, most of Foreman server’s kickstart and PXE provisioning models are unusable. This includes:
PXE Provisioning
Discovery and Discovery Rules
ISO Provisioning methods.
PXE-Less Discovery (iPXE)
Per-host ISO
Generic ISO
Full-host ISO
2. Deployment Scenarios
There are three deployment scenarios for Foreman in Amazon Web Services:
One region setup
Connecting on-premise and AWS region
Connecting different regions
The least complex configuration of Foreman server in Amazon Web Services consists of both Foreman server and the content hosts residing within the same region and within the Virtual Private Cloud (VPC).
You can also use a different availability zone.
Create a VPN connection between the on-premise location and the AWS region where the Smart Proxy resides.
It is also possible to use the external host name of Foreman server when you register the instance which runs Smart Proxy server.
Option 1: Site-to-Site VPN connection between the AWS region and the On-Premise Datacenter
Option 2: Direct connection using the External DNS host name
Create a site-to-site VPN connection between the different regions so that you can use the Internal DNS host name when you register the instance that runs Smart Proxy server to Foreman server.
If you do not establish a site-to-site VPN connection, use the external DNS host name when you register the instance that runs Smart Proxy server to Foreman server.
Most Public Cloud Providers do not charge for data being transferred into a region, or between availability zones within a single region; however, they do charge for data leaving the region to the Internet. |
Option 1: Site-to-Site VPN connection between AWS regions
3. Prerequisites
Before you can install and register Foreman and Smart Proxy, you must set up accounts with Amazon Web Services (AWS) and create and start Red Hat Enterprise Linux instances on AWS.
3.1. Amazon Web Service Assumptions
To use this guide, you must have a working knowledge of the following aspects of Amazon Web Services:
Creating and accessing Red Hat Enterprise Linux images in AWS
Editing network access in AWS Security
Creating EC2 instances and how to create EBS volumes
Launching instances
Importing and exporting virtual machines in AWS
Using AWS Direct Connect
To install Foreman in an AWS environment, you must ensure that your AWS set up meets the System Requirements in Installing Foreman Server with Katello 4.10 Plugin on CentOS/RHEL.
To install Smart Proxy in an AWS environment, you must ensure that your AWS set up meets the System Requirements in Installing a Smart Proxy Server 3.8 on CentOS/RHEL.
For more information about Amazon Web Services and terminology, see Amazon Elastic Compute Cloud Documentation.
For more information about Amazon Web Services Direct Connect, see What is AWS Direct Connect?
3.2. Red Hat Cloud prerequisites
To use this guide, you must complete the following steps:
Register with Red Hat Cloud Access.
Migrate any Red Hat subscriptions that you want to use.
Create an AWS instance and deploy a Red Hat Enterprise Linux virtual machine to the instance.
Ensure that your subscriptions are eligible for transfer to Red Hat Cloud. For more information, see Red Hat Cloud Access Program Details.
For more information about deploying Red Hat Enterprise Linux in AWS, see How to Locate Red Hat Cloud Access Gold Images on AWS EC2.
3.3. Foreman-specific prerequisites
Ensure that the Amazon EC2 instance type meets or exceeds the System Requirements in Installing Foreman Server with Katello 4.10 Plugin on CentOS/RHEL. For the best performance, use an AWS storage optimized instance.
Use Storage Requirements in Installing Foreman Server with Katello 4.10 Plugin on CentOS/RHEL to understand and assign the correct storage to your AWS EBS volumes.
Store the synced content on an EBS volume that is separate to the boot volume.
Mount the synced content EBS volume separately in the operating system.
Optional: Store other data on a separate EBS volume.
If you want Foreman server and Smart Proxy server to communicate using external DNS hostnames, open the required ports for communication in the AWS Security Group that is associated with the instance.
3.4. Preparing for the Foreman Installation
In your AWS environment, complete the following steps:
Launch an EC2 instance of a Red Hat Enterprise Linux AMI.
Connect to the newly created instance.
If you use a Red Hat Gold Image, remove the RHUI client and set the
enabledparameter in theproduct-id.confto1.# dnf remove -y rh-amazon-rhui-client* # dnf clean all # cat << EOF > /etc/yum/pluginconf.d/product-id.conf > [main] > enabled=1 > EOF
4. Installing Foreman server on AWS
On your AWS environment, complete the following steps:
Connect to the new instance.
Use Installing Foreman Server with Katello 4.10 Plugin on CentOS/RHEL to install Foreman server.
5. Installing Smart Proxy on AWS
Install Smart Proxy server. For more information, see Installing a Smart Proxy Server 3.8 on CentOS/RHEL.
6. Registering Hosts to Foreman
When you install Foreman server and Smart Proxy server, you must then register the hosts on EC2 instances to Foreman. For more information, see Registering Hosts in Managing Hosts.
