  3. Click Create.
1. Accessing Red Hat Satellite
After Red Hat Satellite has been installed and configured, use the Satellite web UI interface to log in to Satellite for further configuration.
1.1. Importing the Katello Root CA Certificate
The first time you log in to Satellite, you might see a warning informing you that you are using the default self-signed certificate and you might not be able to connect this browser to Satellite until the root CA certificate is imported in the browser. Use the following procedure to locate the root CA certificate on Satellite and to import it into your browser.
To use the CLI instead of the Satellite web UI, see CLI Procedure.
Prerequisite
  • Your Red Hat Satellite is installed and configured.
  1. Identify the fully qualified domain name of your Satellite Server:
    # hostname -f
  2. Access the pub directory on your Satellite Server using a web browser pointed to the fully qualified domain name:
    https://satellite.example.com/pub
  3. When you access Satellite for the first time, an untrusted connection warning displays in your web browser. Accept the self-signed certificate and add the Satellite URL as a security exception to override the settings. This procedure might differ depending on the browser being used. Ensure that the Satellite URL is valid before you accept the security exception.
  4. Select katello-server-ca.crt.
  5. Import the certificate into your browser as a certificate authority and trust it to identify websites.
CLI procedure
  1. From the Satellite CLI, copy the katello-server-ca.crt file to the machine you use to access the Satellite web UI:
    # scp /var/www/html/pub/katello-server-ca.crt username@hostname:remotefile
  2. In the browser, import the katello-server-ca.crt certificate as a certificate authority and trust it to identify websites.
1.2. Logging in to Satellite
Use the web user interface to log in to Satellite for further configuration.
Prerequisite
  1. Access Satellite Server using a web browser pointed to the fully qualified domain name:
  2. Enter the user name and password created during the configuration process. If a user was not created during the configuration process, the default user name is admin. If you have problems logging in, you can reset the password. For more information, see Resetting the Administrative User Password.
1.3. Using Red Hat Identity Management credentials to log in to the Satellite Hammer CLI
This section describes how to log in to your Satellite Hammer CLI with your Red Hat Identity Management (IdM) login and password.
  • You have enrolled your Satellite Server into Red Hat Identity Management and configured it to use Red Hat Identity Management for authentication. More specifically, you have enabled access both to the Satellite web UI and the Satellite API. For more information, see Using Red Hat Identity Management in Installing Satellite Server in a Connected Network Environment.
  • The host on which you run this procedure is configured to use Red Hat Identity Management credentials to log users in to your Satellite Hammer CLI. For more information, see Configuring the Hammer CLI to Use Red Hat Identity Management User Authentication in Installing Satellite Server in a Connected Network Environment.
  • The host is an Red Hat Identity Management client.
  • An Red Hat Identity Management server is running and reachable by the host.
  1. Obtain a Kerberos ticket-granting ticket (TGT) on behalf of a Satellite user:
    $ kinit idm_user
    Warning
    If, when you were setting Red Hat Identity Management to be the authentication provider, you enabled access to both the Satellite API and the Satellite web UI, an attacker can now obtain an API session after the user receives the Kerberos TGT. The attack is possible even if the user did not previously enter the Satellite login credentials anywhere, for example in the browser.
  2. If automatic negotiate authentication is not enabled, use the TGT to authenticate to Hammer manually:
    $ hammer auth login negotiate
  3. Optional: Destroy all cached Kerberos tickets in the collection:
    $ kdestroy -A
  • Use any hammer command to ensure that the system does not ask you to authenticate again:
    $ hammer host list
To log out of Hammer, enter: hammer auth logout.
1.4. Using Red Hat Identity Management credentials to log in to the Satellite web UI with a Firefox browser
This section describes how to use the Firefox browser to log in to your Satellite web UI with your Red Hat Identity Management (IdM) login and password.
  • You have enrolled your Satellite Server into Red Hat Identity Management and configured the server to use Red Hat Identity Management for authentication. For more information, see Using Red Hat Identity Management in Installing Satellite Server in a Connected Network Environment.
  • The host on which you are using a Firefox browser to log in to the Satellite web UI is an Red Hat Identity Management client.
  • You have a valid Red Hat Identity Management login and password.
  • Red Hat recommends using the latest stable Firefox browser.
  • Your Firefox browser is configured for Single Sign-On (SSO). For more information, see Configuring Firefox to use Kerberos for single sign-on in Configuring authentication and authorization in Red Hat Enterprise Linux.
  1. Obtain the Kerberos ticket granting ticket (TGT) for yourself using your Red Hat Identity Management credentials:
    $ kinit idm_user
    Password for idm_user@EXAMPLE.COM:
  2. In your browser address bar, enter the URL of your Satellite Server.
Alternatively, you can skip the first two steps and enter your login and password in the fields displayed on the Satellite web UI. This is also the only option if the host from which you are accessing the Satellite web UI is not an Red Hat Identity Management client.
1.5. Using Red Hat Identity Management credentials to log in to the Satellite web UI with a Chrome browser
This section describes how to use a Chrome browser to log in to your Satellite web UI with your Red Hat Identity Management login and password.
  • The host on which you are using the Chrome browser to log in to the Satellite web UI is an Red Hat Identity Management client.
  • Red Hat recommends using the latest stable Chrome browser.
  1. Enable the Chrome browser to use Kerberos authentication:
    Instead of allowlisting the whole domain, you can also allowlist a specific Satellite Server.
  2. Obtain the Kerberos ticket-granting ticket (TGT) for yourself using your Red Hat Identity Management credentials:
    $ kinit idm_user
    Password for idm_user@_EXAMPLE.COM:
  3. In your browser address bar, enter the URL of your Satellite Server.
Alternatively, you can skip the first three steps and enter your login and password in the fields displayed on the Satellite web UI. This is also the only option if the host from which you are accessing the Satellite web UI is not an Red Hat Identity Management client.
Use the navigation tabs to browse the Satellite web UI.
Navigation Tabs Description
Any Context
Monitor
Content
Hosts
Configure
Infrastructure
Provides tools on configuring how Satellite interacts with the environment.
User Name
notification bell
Administer
1.7. Changing the Password
1.8. Resetting the Administrative User Password
  1. Log in to the base operating system where Satellite Server is installed.
  3. Use this password to reset the password in the Satellite web UI.
  4. Edit the ~/.hammer/cli.modules.d/foreman.yml file on Satellite Server to add the new password:
  3. Edit the ~/.hammer/cli.modules.d/foreman.yml file on Satellite Server to add the new password:
1.9. Setting a Custom Message on the Login Page
  1. In the Satellite web UI, navigate to Administer > Settings, and click the General tab.
  3. Click Save.
  4. Log out of the Satellite web UI and verify that the custom text is now displayed on the login page below the Satellite version number.
2. Starting and Stopping Red Hat Satellite
Satellite provides the satellite-maintain service command to manage Satellite services from the command line. This is useful when creating a backup of Satellite. For more information on creating backups, see Backing Up Satellite Server and Capsule Server.
After installing Satellite with the satellite-installer command, all Satellite services are started and enabled automatically. View the list of these services by executing:
# satellite-maintain service list
# satellite-maintain service status
To stop Satellite services, execute:
To start Satellite services, execute:
To restart Satellite services, execute:
# satellite-maintain service restart
3. Cloning Satellite Server
You can clone your Satellite Server to create instances to test upgrades and migration of instances to a different machine or operating system. This is an optional step to provide more flexibility during the upgrade or migration.
You cannot use the Satellite clone tool on a Capsule Server. Instead, you must backup the existing Capsule Server, restore it on the target server, and then reconfigure Capsule Server.
If you create a new instance of the Satellite Server, decommission the old instances after restoring the backup. Cloned instances are not supposed to run in parallel in a production environment.
Terminology
Ensure that you understand the following terms:
Source server
The origin of the clone.
Target server
The new server that you copy files to and clone the source server to.
3.1. Cloning Process Overview
  1. Back up the source server.
  2. Clone the source server to the target server.
  3. Power off the source server.
  4. Update the network configuration on the target server to match the target server’s IP address with its new host name.
  5. If any content hosts use the deprecated Katello Agent, restart the goferd service on all those content hosts and their Capsules to refresh the connection.
  6. Test the new target server.
3.2. Prerequisites
To clone Satellite Server, ensure that you have the following resources available:
  • A minimal install of Red Hat Enterprise Linux 8 to become the target server. Do not install Red Hat Enterprise Linux 8 software groups or third-party applications. Ensure that your server complies with all the required specifications. For more information, see Preparing your Environment for Installation in Installing Satellite Server in a Connected Network Environment.
  • A backup of your Satellite Server that you make using the satellite-maintain backup script. You can use a backup with or without Pulp data.
  • A Satellite subscription for the target server.
Before you begin cloning, ensure the following conditions exist:
  • The target server is on an isolated network. This avoids unwanted communication with Capsule Servers and hosts.
  • The target server has at least the same storage capacity as the source server.
Customized configuration files
If you have any customized configurations on your source server that are not managed by the satellite-installer tool or Satellite backup process, you must manually back up these files.
3.3. Pulp Data Considerations
You can clone Satellite server without including Pulp data. However, for your cloned environment to work, you do require Pulp data. If the target server does not have Pulp data. it is not a fully working Satellite.
To transfer Pulp data to a target server, you have two options:
  • Clone using backup with Pulp data
  • Clone using backup without Pulp data and copy /var/lib/pulp manually from the source server.
If your pulp_data.tar file is greater than 500 GB, or if you use a slow storage system, such as NFS, and your pulp_data.tar file is greater than 100 GB, do not include pulp_data.tar in the backup because this can cause memory errors during extraction. Copy the pulp_data.tar file from the source server to the target server.
To back up without Pulp data
Follow the steps in the procedure in Cloning Satellite Server and replace the steps that involve cloning with Pulp data with the following steps:
  1. Perform a backup with PostgreSQL databases active excluding the Pulp data:
    # satellite-maintain backup offline --skip-pulp-content \
    --assumeyes /var/backup
  2. Stop and disable Satellite services:
    # satellite-maintain service disable
  3. Copy the Pulp data to the target server:
    # rsync --archive --partial --progress --compress \
    /var/lib/pulp/ target_server.example.com:/var/lib/pulp/
3.4. Cloning Satellite Server
Use the following procedures to clone Satellite Server. Note that because of the high volume of data that you must copy and transfer as part of these procedures, it can take a significant amount of time to complete.
3.4.1. Preparing the source server for cloning
On the source server, complete the following steps:
  1. Determine the size of the Pulp data:
    # du -sh /var/lib/pulp/
  2. If you have less than 500 GB of Pulp data, perform a backup with PostgreSQL databases active including the Pulp data. If you have more than 500 GB of Pulp data, skip the following steps and complete the steps in Pulp Data Considerations before you continue.
    # satellite-maintain backup offline --assumeyes /var/backup
  3. Stop and disable Satellite services:
3.4.2. Cloning to the Target Server
To clone your server, complete the following steps on your target server:
  1. The satellite-clone tool defaults to using /backup/ as the backup folder. If you copy to a different folder, update the backup_dir variable in the /etc/satellite-clone/satellite-clone-vars.yml file.
  2. Place the backup files from the source Satellite in the /backup/ folder on the target server. You can either mount the shared storage or copy the backup files to the /backup/ folder on the target server.
  4. Register your instance to the Red Hat Customer Portal and enable only the required repositories:
    # subscription-manager register your_customer_portal_credentials
    # subscription-manager repos --disable=*
    # subscription-manager repos --enable=rhel-8-for-x86_64-appstream-rpms \
    --enable=rhel-8-for-x86_64-baseos-rpms \
    --enable=satellite-maintenance-6.13-for-rhel-8-x86_64-rpms
    # dnf module enable satellite-maintenance:el8
  5. Install the satellite-clone package:
    # dnf install satellite-clone
    After you install the satellite-clone tool, you can adjust any configuration to suit your own deployment in the /etc/satellite-clone/satellite-clone-vars.yml file.
  6. Run the satellite-clone tool:
    # satellite-clone
  7. Reconfigure DHCP, DNS, TFTP, and remote execution services. The cloning process disables these services on the target Satellite Server to avoid conflict with the source Satellite Server.
  8. Reconfigure and enable DHCP, DNS, and TFTP in the Satellite web UI. For more information, see Configuring External Services on Satellite Server in Installing Satellite Server in a Connected Network Environment.
  9. Log in to the Satellite web UI, with the username admin and the password changeme. Immediately update the admin password to secure credentials.
  10. Ensure that the correct organization is selected.
  11. In the Satellite web UI, navigate to Content > Subscriptions, then click Manage Manifest.
  12. Click the Refresh button, then click Close to return to the list of subscriptions.
  13. Verify that the available subscriptions are correct.
  14. Follow the instructions in the /usr/share/satellite-clone/logs/reassociate_capsules.txt file to restore the associations between Capsules and their lifecycle environments.
  15. Update your network configuration, for example, DNS, to match the target server’s IP address with its new host name. The satellite-clone tool changes the host name to the source server’s host name. If you want to change the host name to something different, you can use the satellite-change-hostname tool. For more information, see Renaming a Satellite or Capsule Server in Administering Red Hat Satellite.
  16. If the source server uses the virt-who daemon, install and configure it on the target server. Copy all the virt-who configuration files in the /etc/virt-who.d/ directory from the source server to the same directory on the target server. For more information, see Configuring Virtual Machine Subscriptions in Red Hat Satellite. After you perform an upgrade using the following chapters, you can safely decommission the source server.
4. Tuning Satellite Server with Predefined Profiles
If your Satellite deployment includes more than 5000 hosts, you can use predefined tuning profiles to improve performance of Satellite.
Note that you cannot use tuning profiles on Capsules.
You can choose one of the profiles depending on the number of hosts your Satellite manages and available hardware resources.
When you run the satellite-installer command with the --tuning option, deployment configuration settings are applied to Satellite in the following order:
  1. The default tuning profile defined in the /usr/share/foreman-installer/config/foreman.hiera/tuning/common.yaml file
  2. The tuning profile that you want to apply to your deployment and is defined in the /usr/share/foreman-installer/config/foreman.hiera/tuning/sizes/ directory
  3. Optional: If you have configured a /etc/foreman-installer/custom-hiera.yaml file, Satellite applies these configuration settings.
default
Number of managed hosts: 0 – 5000
RAM: 20G
Number of CPU cores: 4
medium
Number of managed hosts: 5001 – 10000
RAM: 32G
Number of CPU cores: 8
large
Number of managed hosts: 10001 – 20000
RAM: 64G
Number of CPU cores: 16
extra-large
Number of managed hosts: 20001 – 60000
RAM: 128G
Number of CPU cores: 32
extra-extra-large
Number of managed hosts: 60000+
RAM: 256G
Number of CPU cores: 48+
  1. Optional: If you have configured the custom-hiera.yaml file on Satellite Server, back up the /etc/foreman-installer/custom-hiera.yaml file to custom-hiera.original. You can use the backup file to restore the /etc/foreman-installer/custom-hiera.yaml file to its original state if it becomes corrupted:
    # cp /etc/foreman-installer/custom-hiera.yaml \
    /etc/foreman-installer/custom-hiera.original
  2. Optional: If you have configured the custom-hiera.yaml file on Satellite Server, review the definitions of the default tuning profile in /usr/share/foreman-installer/config/foreman.hiera/tuning/common.yaml and the tuning profile that you want to apply in /usr/share/foreman-installer/config/foreman.hiera/tuning/sizes/. Compare the configuration entries against the entries in your /etc/foreman-installer/custom-hiera.yaml file and remove any duplicated configuration settings in your /etc/foreman-installer/custom-hiera.yaml file.
  3. Enter the satellite-installer command with the --tuning option for the profile that you want to apply. For example, to apply the medium tuning profile settings, enter the following command:
    # satellite-installer --tuning medium
5. Migrating from Internal Satellite Databases to External Databases
When you install Red Hat Satellite, the satellite-installer command installs PostgreSQL databases on the same server as Satellite. If you are using the default internal databases but want to start using external databases to help with the server load, you can migrate your internal databases to external databases.
To confirm whether your Satellite Server has internal or external databases, you can query the status of your databases:
# satellite-maintain service status --only postgresql
Red Hat does not provide support or tools for external database maintenance. This includes backups, upgrades, and database tuning. You must have your own database administrator to support and maintain external databases.
  1. Preparing a Host for External Databases. Prepare a Red Hat Enterprise Linux 8 server to host the external databases.
  2. Installing PostgreSQL. Prepare PostgreSQL with databases for Satellite, Pulp and Candlepin with dedicated users owning them.
  3. Migrating to External Databases. Edit the parameters of satellite-installer to point to the new databases, and run satellite-installer.
5.1. PostgreSQL as an External Database Considerations
Foreman, Katello, and Candlepin use the PostgreSQL database. If you want to use PostgreSQL as an external database, the following information can help you decide if this option is right for your Satellite configuration. Satellite supports PostgreSQL version 12.
Advantages of External PostgreSQL
  • Increase in free memory and free CPU on Satellite
  • Flexibility to set shared_buffers on the PostgreSQL database to a high number without the risk of interfering with other services on Satellite
  • Flexibility to tune the PostgreSQL server’s system without adversely affecting Satellite operations
  • If either Satellite or the PostgreSQL database server suffers a hardware or storage failure, Satellite is not operational
  • If there is latency between the Satellite server and database server, performance can suffer
If you suspect that the PostgreSQL database on your Satellite is causing performance problems, use the information in Satellite 6: How to enable postgres query logging to detect slow running queries to determine if you have slow queries. Queries that take longer than one second are typically caused by performance issues with large installations, and moving to an external database might not help. If you have slow queries, contact Red Hat Support.
5.2. Preparing a Host for External Databases
Install a freshly provisioned system with the latest Red Hat Enterprise Linux 8 to host the external databases.
Subscriptions for Red Hat Enterprise Linux do not provide the correct service level agreement for using Satellite with external databases. You must also attach a Satellite subscription to the base operating system that you want to use for the external databases.
Prerequisite
  1. Use the instructions in Attaching the Satellite Infrastructure Subscription to attach a Satellite subscription to your server.
    --enable=satellite-6.13-for-rhel-8-x86_64-rpms \
    --enable=satellite-maintenance-6.13-for-rhel-8-x86_64-rpms \
  3. Enable the following modules:
    # dnf module enable satellite:el8
    Enablement of the module satellite:el8 warns about a conflict with postgresql:10 and ruby:2.5 as these modules are set to the default module versions on Red Hat Enterprise Linux 8. The module satellite:el8 has a dependency for the modules postgresql:12 and ruby:2.7 that will be enabled with the satellite:el8 module. These warnings do not cause installation process failure, hence can be ignored safely. For more information about modules and lifecycle streams on Red Hat Enterprise Linux 8, see Red Hat Enterprise Linux Application Streams Life Cycle.
5.3. Installing PostgreSQL
You can install only the same version of PostgreSQL that is installed with the satellite-installer tool during an internal database installation. Satellite supports PostgreSQL version 12.
    # dnf install postgresql-server postgresql-evr postgresql-contrib
    # postgresql-setup initdb
    Note that the default configuration of external PostgreSQL needs to be adjusted to work with Satellite. The base recommended external database configuration adjustments are as follows:
    • max_connections: 500
    • shared_buffers: 512MB
    • work_mem: 4MB
    listen_addresses = '*'
  5. Edit the /var/lib/pgsql/data/pg_hba.conf file:
      host  all   all   Satellite_ip/32   md5
    $ su - postgres -c psql
  10. Create three databases and dedicated roles: one for Satellite, one for Candlepin, and one for Pulp:
  11. Connect to the Pulp database:
    postgres=# \c pulpcore
    You are now connected to database "pulpcore" as user "postgres".
  12. Create the hstore extension:
    pulpcore=# CREATE EXTENSION IF NOT EXISTS "hstore";
    CREATE EXTENSION
  13. Exit the postgres user:
    # \q
  14. From Satellite Server, test that you can access the database. If the connection succeeds, the commands return 1.
5.4. Migrating to External Databases
Back up and transfer existing data, then use the satellite-installer command to configure Satellite to connect to an external PostgreSQL database server.
Prerequisite
  1. On Satellite Server, stop Satellite services:
    # systemctl start postgresql
    # satellite-maintain backup online --skip-pulp-content --preserve-directory -y /var/migration_backup
  5. Use the satellite-installer command to update Satellite to point to the new databases:
    satellite-installer --scenario satellite \
        --foreman-db-manage false \
        --foreman-proxy-content-pulpcore-postgresql-user pulp
6. Managing Satellite with Ansible Collections
Satellite Ansible Collections is a set of Ansible modules that interact with the Satellite API. You can use Satellite Ansible Collections to manage and automate many aspects of Satellite.
6.1. Installing the Satellite Ansible Modules
Use this procedure to install the Satellite Ansible modules.
    # satellite-maintain packages install ansible-collection-redhat-satellite
6.2. Viewing the Satellite Ansible Modules
You can view the installed Satellite Ansible modules by running:
# ansible-doc -l redhat.satellite
Alternatively, you can also see the complete list of Satellite Ansible modules and other related information at Red Hat Ansible Automation Platform.
All modules are in the redhat.satellite namespace and can be referred to in the format redhat.satellite._module_name_. For example, to display information about the activation_key module, enter the following command:
$ ansible-doc redhat.satellite.activation_key
7. Managing Organizations
Organizations divide Red Hat Satellite resources into logical groups based on ownership, purpose, content, security level, or other divisions. You can create and manage multiple organizations through Red Hat Satellite, then divide and assign your Red Hat subscriptions to each individual organization. This provides a method of managing the content of several individual organizations under one management system. Here are some examples of organization management:
Single Organization
A small business with a simple system administration chain. In this case, you can create a single organization for the business and assign content to it.
Multiple Organizations
A large company that owns several smaller business units. For example, a company with separate system administration and software development groups. In this case, you can create organizations for the company and each of the business units it owns. This keeps the system infrastructure for each separate. You can then assign content to each organization based on its needs.
External Organizations
A company that manages external systems for other organizations. For example, a company offering cloud computing and web hosting resources to customers. In this case, you can create an organization for the company’s own system infrastructure and then an organization for each external business. You can then assign content to each organization where necessary.
A default installation of Red Hat Satellite has a default organization called Default Organization.
New Users
If a new user is not assigned a default organization, their access is limited. To grant systems rights to users, assign them to a default organization. The next time the user logs on to Satellite, the user’s account has the correct system rights.
7.1. Creating an Organization
Use this procedure to create an organization. To use the CLI instead of the Satellite web UI, see the CLI procedure.
  1. In the Satellite web UI, navigate to Administer > Organizations.
  2. Click New Organization.
  3. In the Name field, enter a name for the organization.
  4. In the Label field, enter a unique identifier for the organization. This is used for creating and mapping certain assets, such as directories for content storage. Use letters, numbers, underscores, and dashes, but no spaces.
  5. Optional: If you do not wish to enable Simple Content Access (SCA), uncheck the Simple Content Access checkbox. For more information on SCA, see Simple Content Access.
    Red Hat does not recommend disabling SCA as entitlement mode is deprecated.
  6. Optional: in the Description field, enter a description for the organization.
  7. Click Submit.
  8. If you have hosts with no organization assigned, select the hosts that you want to add to the organization, then click Proceed to Edit.
  9. In the Edit page, assign the infrastructure resources that you want to add to the organization. This includes networking resources, installation media, kickstart templates, and other parameters. You can return to this page at any time by navigating to Administer > Organizations and then selecting an organization to edit.
  10. Click Submit.
CLI procedure
  1. To create an organization, enter the following command:
    # hammer organization create \
    --name "My_Organization" \
    --label "My_Organization_Label" \
    --description "My_Organization_Description"
    Organizations created this way have Simple Content Access (SCA) enabled by default. If you wish to disable SCA, add the --simple-content-access false parameter to the command. Red Hat does not advise you to disable SCA because entitlement mode (not using SCA) is deprecated.
  2. Optional: To edit an organization, enter the hammer organization update command. For example, the following command assigns a compute resource to the organization:
    # hammer organization update \
    --compute-resource-ids 1
7.2. Setting the Organization Context
An organization context defines the organization to use for a host and its associated resources.
The organization menu is the first menu item in the menu bar, on the upper left of the Satellite web UI. If you have not selected a current organization, the menu says Any Organization. Click the Any Organization button and select the organization to use.
CLI procedure
While using the CLI, include either --organization "My_Organization" or --organization-label "My_Organization_Label" as an option. For example:
# hammer subscription list \
This command outputs subscriptions allocated for the My_Organization.
7.3. Creating an Organization Debug Certificate
If you require a debug certificate for your organization, use the following procedure.
  2. Select an organization that you want to generate a debug certificate for.
  3. Click Generate and Download.
  4. Save the certificate file in a secure location.
Debug Certificates for Provisioning Templates
Debug Certificates are automatically generated for provisioning template downloads if they do not already exist in the organization for which they are being downloaded.
7.4. Browsing Repository Content Using an Organization Debug Certificate
You can view an organization’s repository content using a web browser or using the API if you have a debug certificate for that organization.
Prerequisite
  1. Split the private and public keys from the certificate into two files.
    1. Open the X.509 certificate, for example, for the default organization:
      $ vi 'Default Organization-key-cert.pem'
    2. Copy the contents of the file from -----BEGIN RSA PRIVATE KEY----- to -----END RSA PRIVATE KEY-----, into a key.pem file.
    3. Copy the contents of the file from -----BEGIN CERTIFICATE----- to -----END CERTIFICATE-----, into a cert.pem file.
  2. To use a browser, you must first convert the X.509 certificate to a format your browser supports and then import the certificate.
For Firefox Users
  1. Convert the certificate into the PKCS12 format using the following command:
    $ openssl pkcs12 -keypbe PBE-SHA1-3DES -certpbe PBE-SHA1-3DES -export -in cert.pem -inkey key.pem -out My_Organization_Label.pfx -name My_Organization
  2. In the Firefox browser, navigate to Edit > Preferences > Advanced Tab.
  3. Select View Certificates and click the Your Certificates tab.
  4. Click Import and select the .pfx file to load.
  5. Enter the following URL in the address bar to browse the accessible paths for all the repositories and check their contents:
    https://satellite.example.com/pulp/content/
For CURL Users
  • To use the organization debug certificate with CURL, enter the following command:
    $ curl -k --cert cert.pem --key key.pem \
    https://satellite.example.com/pulp/content/My_Organization_Label/Library/content/dist/rhel/server/7/7Server/x86_64/os/
    Ensure that the paths to cert.pem and key.pem are the correct absolute paths otherwise the command fails silently. Pulp uses the organization label, therefore, you must enter the organization label into the URL.
7.5. Deleting an Organization
You can delete an organization if the organization is not associated with any life cycle environments or host groups. If there are any life cycle environments or host groups associated with the organization you are about to delete, remove them by navigating to Administer > Organizations and clicking the relevant organization. Do not delete the default organization created during installation because the default organization is a placeholder for any unassociated hosts in the Satellite environment. There must be at least one organization in the environment at any given time.
  2. From the list to the right of the name of the organization you want to delete, select Delete.
  3. Click OK to delete the organization.
CLI procedure
  1. Enter the following command to retrieve the ID of the organization that you want to delete:
    # hammer organization list
    From the output, note the ID of the organization that you want to delete.
  2. Enter the following command to delete an organization:
    # hammer organization delete --id Organization_ID
8. Managing Locations
Locations function similar to organizations: they provide a method to group resources and assign hosts. Organizations and locations have the following conceptual differences:
  • Locations are based on physical or geographical settings.
  • Locations have a hierarchical structure.
8.1. Creating a Location
Use this procedure to create a location so that you can manage your hosts and resources by location. To use the CLI instead of the Satellite web UI, see the CLI procedure.
  1. In the Satellite web UI, navigate to Administer > Locations.
  2. Click New Location.
  3. Optional: from the Parent list, select a parent location. This creates a location hierarchy.
  4. In the Name field, enter a name for the location.
  5. Optional: in the Description field, enter a description for the location.
  6. Click Submit.
  7. If you have hosts with no location assigned, add any hosts that you want to assign to the new location, then click Proceed to Edit.
  8. Assign any infrastructure resources that you want to add to the location. This includes networking resources, installation media, kickstart templates, and other parameters. You can return to this page at any time by navigating to Administer > Locations and then selecting a location to edit.
  9. Click Submit to save your changes.
CLI procedure
  • Enter the following command to create a location:
    # hammer location create \
    --description "My_Location_Description" \
    --name "My_Location" \
    --parent-id "My_Location_Parent_ID"
8.2. Creating Multiple Locations
The following example Bash script creates three locations – London, Munich, Boston – and assigns them to the Example Organization.
ORG="Example Organization"
LOCATIONS="London Munich Boston"
for LOC in ${LOCATIONS}
do
  hammer location create --name "${LOC}"
  hammer location add-organization --name "${LOC}" --organization "${ORG}"
done
8.3. Setting the Location Context
A location context defines the location to use for a host and its associated resources.
The location menu is the second menu item in the menu bar, on the upper left of the Satellite web UI. If you have not selected a current location, the menu displays Any Location. Click Any location and select the location to use.
CLI procedure
While using the CLI, include either --location "My_Location" or --location-id "My_Location_ID" as an option. For example:
This command outputs subscriptions allocated for the My_Location.
8.4. Deleting a Location
You can delete a location if the location is not associated with any life cycle environments or host groups. If there are any life cycle environments or host groups associated with the location you are about to delete, remove them by navigating to Administer > Locations and clicking the relevant location. Do not delete the default location created during installation because the default location is a placeholder for any unassociated hosts in the Satellite environment. There must be at least one location in the environment at any given time.
  2. Select Delete from the list to the right of the name of the location you want to delete.
  3. Click OK to delete the location.
CLI procedure
  1. Enter the following command to retrieve the ID of the location that you want to delete:
    # hammer location list
    From the output, note the ID of the location that you want to delete.
  2. Enter the following command to delete the location:
    # hammer location delete --id Location ID
9. Managing Users and Roles
Roles define a set of permissions and access levels. Each role contains one on more permission filters that specify the actions allowed for the role. Actions are grouped according to the Resource type. Once a role has been created, users and user groups can be associated with that role. This way, you can assign the same set of permissions to large groups of users. Satellite provides a set of predefined roles and also enables creating custom roles and permission filters as described in Creating and Managing Roles.
9.1. Managing Users
As an administrator, you can create, modify and remove Satellite users. You can also configure access permissions for a user or a group of users by assigning them different roles.
9.1.1. Creating a User
Use this procedure to create a user. To use the CLI instead of the Satellite web UI, see the CLI procedure.
  1. In the Satellite web UI, navigate to Administer > Users.
  2. Click Create User.
    By default, Satellite Server uses the language and timezone settings of the user’s browser.
      • INTERNAL: to enable the user to be managed inside Satellite Server.
      • EXTERNAL: to configure external authentication as described in Configuring External Authentication in Installing Satellite Server in a Connected Network Environment.
CLI procedure
    # hammer user create \
    --login My_User_Name \
    --mail My_User_Mail \
    --password My_User_Password
9.1.2. Assigning Roles to a User
Use this procedure to assign roles to a user. To use the CLI instead of the Satellite web UI, see the CLI procedure.
    If a user account is not listed, check that you are currently viewing the correct organization. To list all the users in Satellite, click Default Organization and then Any Organization.
  7. Click Submit.
CLI procedure
9.1.3. Impersonating a Different User Account
Administrators can impersonate other authenticated users for testing and troubleshooting purposes by temporarily logging on to the Satellite web UI as a different user. When impersonating another user, the administrator has permissions to access exactly what the impersonated user can access in the system, including the same menus.
  • Ensure that you are logged on to the Satellite web UI as a user with administrator privileges for Satellite.
9.1.4. Creating an API-Only User
You can create users that can interact only with the Satellite API.
Prerequisite
  1. Log in to your Satellite as admin.
    # openssl rand -hex 32
9.2. Managing SSH Keys
For information on SSH keys and SSH key creation, see Using SSH-based Authentication in Red Hat Enterprise Linux 8 Configuring basic system settings.
9.2.1. Managing SSH Keys for a User
Use this procedure to add or remove SSH keys for a user. To use the CLI instead of the Satellite web UI, see the CLI procedure.
  • Ensure that you are logged in to the Satellite web UI as an Admin user of Red Hat Satellite or a user with the create_ssh_key permission enabled for adding SSH key and destroy_ssh_key permission for removing a key.
  3. Click on the SSH Keys tab.
    • To Add SSH key
      2. Click Add SSH Key.
      5. Click Submit.
    • To Remove SSH key
CLI procedure
    # hammer user ssh-keys add \
    --user-id user_id \
    --name key_name \
    --key-file ~/.ssh/id_rsa.pub
    --user-id user_id \
    --name key_name \
9.3. Managing Personal Access Tokens
9.3.1. Creating a Personal Access Token
  1. Make an API request to your Satellite Server and authenticate with your Personal Access Token:
    # curl https://satellite.example.com/api/status --user My_Username:My_Personal_Access_Token
    {"satellite_version":"6.13.0","result":"ok","status":200,"version":"3.5.1.10","api_version":2}
9.3.2. Revoking a Personal Access Token
  1. Make an API request to your Satellite Server and try to authenticate with the revoked Personal Access Token:
9.4. Creating and Managing User Groups
9.4.1. User Groups
With Satellite, you can assign permissions to groups of users. You can also create user groups as collections of other user groups. If using an external authentication source, you can map Satellite user groups to external user groups as described in Configuring External User Groups in Installing Satellite Server in a Connected Network Environment.
9.4.2. Creating a User Group
  1. In the Satellite web UI, navigate to Administer > User Groups.
  2. Click Create User group.
  5. Click Submit.
CLI procedure
    # hammer user-group create \
    --name My_User_Group_Name \
9.4.3. Removing a User Group
Use the following procedure to remove a user group from Satellite.
9.5. Creating and Managing Roles
Satellite provides a set of predefined roles with permissions sufficient for standard tasks, as listed in Predefined Roles Available in Satellite. It is also possible to configure custom roles, and assign one or more permission filters to them. Permission filters define the actions allowed for a certain resource type. Certain Satellite plug-ins create roles automatically.
9.5.1. Creating a Role
  1. In the Satellite web UI, navigate to Administer > Roles.
  2. Click Create Role.
CLI procedure
9.5.2. Cloning a Role
Use the Satellite web UI to clone a role.
  1. In the Satellite web UI, navigate to Administer > Roles and select Clone from the drop-down menu to the right of the required role.
9.5.3. Adding Permissions to a Role
Use this procedure to add permissions to a role. To use the CLI instead of the Satellite web UI, see the CLI procedure.
  5. Depending on the Resource type selected, you can select or deselect the Unlimited and Override checkbox. The Unlimited checkbox is selected by default, which means that the permission is applied on all resources of the selected type. When you disable the Unlimited checkbox, the Search field activates. In this field you can specify further filtering with use of the Satellite search syntax. For more information, see Granular Permission Filtering. When you enable the Override checkbox, you can add additional locations and organizations to allow the role to access the resource type in the additional locations and organizations; you can also remove an already associated location and organization from the resource type to restrict access.
  6. Click Next.
CLI procedure
  2. Add permissions to a role:
    # hammer filter create \
    --role My_Role_Name
9.5.4. Viewing Permissions of a Role
Use the Satellite web UI to view the permissions of a role.
The Filters page contains a table of permissions assigned to a role grouped by the resource type. It is also possible to generate a complete table of permissions and actions that you can use on your Satellite system. For more information, see Creating a Complete Permission Table.
9.5.5. Creating a Complete Permission Table
Use the Satellite CLI to create a permission table.
  1. Start the Satellite console with the following command:
    # foreman-rake console
    end.join("\n")
    f.write(result)
  3. Press Ctrl + D to exit the Satellite console.
    </table>
9.5.6. Removing a Role
Use the following procedure to remove a role from Satellite.
9.6. Predefined Roles Available in Satellite
The following table provides an overview of permissions that predefined roles in Satellite grant to a user.
To view the exact set of permissions a predefined role grants, display the role in Satellite web UI as the privileged user. For more information, see Viewing Permissions of a Role.
Table 1. Permissions provided by role
Role Permissions Provided by Role
Access Insights Admin
Add and edit Insights rules.
Access Insights Viewer
View Insight reports.
Ansible Roles Manager
Bookmarks manager
Boot disk access
Download the boot disk.
Compliance manager
Compliance viewer
Create ARF report
Create compliance reports.
Default role
Discovery Manager
Discovery Reader
Edit hosts
Edit partition tables
Manager
Organization admin
Red Hat Access Logs
Remote Execution Manager
Control which roles have permission to run infrastructure jobs.
Remote Execution User
Run remote execution jobs against hosts.
Site manager
System admin
  • Edit global settings in Administer > Settings.
Tasks manager
View and edit Satellite tasks.
Tasks reader
A role that can only view Satellite tasks.
Viewer
A passive role that provides the ability to view the configuration of every element of the Satellite structure, logs, reports, and statistics.
View hosts
Virt-who Manager
Virt-who Reporter
Upload reports generated by virt-who to Satellite. It can be used if you configure virt-who manually and require a user role that has limited virt-who permissions.
Virt-who Viewer
9.7. Granular Permission Filtering
As mentioned in Adding Permissions to a Role, Red Hat Satellite provides the ability to limit the configured user permissions to selected instances of a resource type. These granular filters are queries to the Satellite database and are supported by the majority of resource types.
9.7.1. Creating a Granular Permission Filter
Use this procedure to create a granular filter. To use the CLI instead of the Satellite web UI, see the CLI procedure.
Satellite does not apply search conditions to create actions. For example, limiting the create_locations action with name = "Default Location" expression in the search field does not prevent the user from assigning a custom name to the newly created location.
field_name operator value
CLI procedure
    --permission-ids 91 \
    --search "name ~ ccv*" \
    --role qa-user
9.7.2. Examples of Using Granular Permission Filters
hostgroup = host-editors
name ^ (XXXX, Yyyy, zzzz)
Dev
Use the Satellite web UI to create an administrative role restricted to a single organization named org-1.
9.7.3. Supported Operators for Granular Search
Table 2. Logical Operators
Operator
and
Combines search criteria.
not
Negates an expression.
has
Table 3. Symbolic Operators
Operator
10. Configuring Email Notifications
Email notifications are created by Satellite Server periodically or after completion of certain events. The periodic notifications can be sent daily, weekly or monthly.
Satellite Server does not enable outgoing emails by default, therefore you must review your email configuration. For more information, see Configuring Satellite Server for Outgoing Emails in Installing Satellite Server in a Connected Network Environment.
10.1. Email Notification Types
Satellite can create the following email notifications:
  • Audit summary: A summary of all activity audited by Satellite Server.
  • Compliance policy summary: A summary of OpenSCAP policy reports and their results.
For a complete list of email notification types, navigate to Administer > Users in the Satellite web UI, click the Username of the required user, and select the Email Preferences tab.
10.2. Configuring Email Notification Preferences
You can configure Satellite to send email messages to individual users registered to Satellite. Satellite sends the email to the email address that has been added to the account, if present. Users can edit the email address by clicking on their name in the top-right of the Satellite web UI and selecting My account.
Configure email notifications for a user from the Satellite web UI.
If you want to send email notifications to a group email address instead of an individual email address, create a user account with the group email address and minimal Satellite permissions, then subscribe the user account to the desired notification types.
  6. Click Submit.
10.3. Testing Email Delivery
  2. Click on the username.
  2. Verify Satellite Server’s email configuration.
  4. If your Satellite Server uses the Postfix service for email delivery, the test email might be held in the queue. To verify, enter the mailq command to list the current mail queue. If the test email is held in the queue, mailq displays the following message:
    BE68482A783    1922 Thu Oct  3 05:13:36  satellite-noreply@example.com
    To fix the problem, start the Postfix service on your Satellite Server:
    # systemctl start postfix
10.4. Testing Email Notifications
  • daily
  • weekly
  • monthly
10.5. Changing Email Notification Settings for a Host
Satellite can send event notifications for a host to the host’s registered owner. You can configure Satellite to send email notifications either to an individual user or a user group. When set to a user group, all group members who are subscribed to the email type receive a message.
  1. In the Satellite web UI, navigate to Hosts > All Hosts, locate the host that you want to view, and click Edit in the Actions column.
  2. Go to the Additional Information tab. If the checkbox Include this host within Satellite reporting is checked, then the email notifications are enabled on that host.
11. Backing Up Satellite Server and Capsule Server
You can back up your Satellite deployment to ensure the continuity of your Red Hat Satellite deployment and associated data in the event of a disaster. If your deployment uses custom configurations, you must consider how to handle these custom configurations when you plan your backup and disaster recovery policy.
If you create a new instance of the Satellite Server, decommission the old instances after restoring the backup. Cloned instances are not supposed to run in parallel in a production environment.
To create a backup of your Satellite Server or Capsule Server and all associated data, use the satellite-maintain backup command. Backing up to a separate storage device on a separate system is highly recommended.
Satellite services are unavailable during the backup. Therefore, you must ensure that no other tasks are scheduled by other administrators. You can schedule a backup using cron. For more information, see the Example of a Weekly Full Backup Followed by Daily Incremental Backups.
During offline or snapshot backups, the services are inactive and Satellite is in a maintenance mode. All the traffic from outside on port 443 is rejected by a firewall to ensure there are no modifications triggered.
Conventional Backup Methods
You can also use conventional backup methods. For more information, see Recovering and restoring a system in Red Hat Enterprise Linux 8 Configuring basic system settings.
If you plan to use the satellite-maintain backup command to create a backup, do not stop Satellite services.
11.1. Estimating the Size of a Backup
The full backup creates uncompressed archives of PostgreSQL and Pulp database files, and Satellite configuration files. Compression occurs after the archives are created to decrease the time when Satellite services are unavailable.
  • Uncompressed Satellite database and configuration files
  • Compressed Satellite database and configuration files
  1. Enter the du command to estimate the size of uncompressed directories containing Satellite database and configuration files:
    100G    /var/lib/pgsql/data
    100G	/var/lib/pulp
    886M  /var/lib/qpidd
    16M   /var/lib/tftpboot
    37M   /etc
    900K  /root/ssl-build
    100K  /var/www/html/pub
    2M    /opt/puppetlabs
    942M  total
    Table 4. Backup Data Compression Ratio
    PostgreSQL database files
    /var/lib/pgsql/data
    80 – 85%
    100 GB → 20 GB
    Pulp RPM files
    /var/lib/pulp
    (not compressed)
    100 GB
    Configuration files
    /var/lib/qpidd
    /var/lib/tftpboot
    /etc
    /root/ssl-build
    /var/www/html/pub
    /opt/puppetlabs
    85%
    942 MB → 141 MB
11.2. Performing a Full Backup of Satellite Server or Capsule Server
Red Hat Satellite uses the satellite-maintain backup command to make backups.
There are three main methods of backing up Satellite Server:
  • Offline backup
  • Online backup
  • Snapshot backups
Offline backups
# satellite-maintain backup offline --help
Online backups
# satellite-maintain backup online --help
Snapshots backups
# satellite-maintain backup snapshot --help
Directory creation
The satellite-maintain backup command creates a time-stamped subdirectory in the backup directory that you specify. The satellite-maintain backup command does not overwrite backups, therefore you must select the correct directory or subdirectory when restoring from a backup or an incremental backup. The satellite-maintain backup command stops and restarts services as required.
When you run the satellite-maintain backup offline command, the following default backup directories are created:
  • satellite-backup on Satellite
  • foreman-proxy-backup on Capsule
Remote databases
You can use the satellite-maintain backup command to back up remote databases.
You can use both online and offline methods to back up remote databases, but if you use offline methods, such as snapshot, the satellite-maintain backup command performs a database dump.
Backing up to a remote NFS share
To enable Satellite to save the backup to an NFS share, ensure that the root user of your Satellite Server or Capsule Server can write to the NFS share. NFS export options such as root_squash and all_squash are known to prevent this.
Warning
Request other users of Satellite Server or Capsule Server to save any changes and warn them that Satellite services are unavailable for the duration of the backup. Ensure no other tasks are scheduled for the same time as the backup.
  • On Satellite Server, enter the following command:
    # satellite-maintain backup offline /var/satellite-backup
  • On Capsule Server, enter the following command:
    # satellite-maintain backup offline /var/foreman-proxy-backup
11.3. Performing a Backup without Pulp Content
Warning
    # satellite-maintain backup offline --skip-pulp-content /var/backup_directory
11.4. Performing an Incremental Backup
Warning
    # satellite-maintain backup offline /var/backup_directory
  2. To create a directory within your backup directory to store the first incremental back up, enter the satellite-maintain backup command with the --incremental option:
    # satellite-maintain backup offline --incremental /var/backup_directory/full_backup /var/backup_directory
  3. To create the second incremental backup, enter the satellite-maintain backup command with the --incremental option and include the path to the first incremental backup to indicate the starting point for the next increment. This creates a directory for the second incremental backup in your backup directory:
    # satellite-maintain backup offline --incremental /var/backup_directory/first_incremental_backup /var/backup_directory
11.5. Example of a Weekly Full Backup Followed by Daily Incremental Backups
#!/bin/bash -e
  satellite-maintain backup offline --assumeyes $DESTINATION
else
  satellite-maintain backup offline --assumeyes --incremental "$LAST" $DESTINATION
fi
exit 0
Note that the satellite-maintain backup command requires /sbin and /usr/sbin directories to be in PATH and the --assumeyes option is used to skip the confirmation prompt.
11.6. Performing an Online Backup
When performing an online backup, if there are procedures affecting the Pulp database, the Pulp part of the backup procedure repeats until it is no longer being altered. Because the backup of the Pulp database is the most time consuming part of backing up Satellite, if you make a change that alters the Pulp database during this time, the backup procedure keeps restarting.
Warning
    # satellite-maintain backup online /var/backup_directory
11.7. Performing a Snapshot Backup
The snapshot backup method is faster than a full offline backup and therefore reduces Satellite downtime.
satellite-maintain backup snapshot -h
Warning
Request other Satellite Server or Capsule Server users to save any changes and warn them that Satellite services are unavailable for the duration of the backup. Ensure no other tasks are scheduled for the same time as the backup.
  • The system uses LVM for the directories that you snapshot: /var/lib/pulp/, and /var/lib/pgsql.
  • To perform a snapshot backup, enter the satellite-maintain backup snapshot command:
    # satellite-maintain backup snapshot /var/backup_directory
The satellite-maintain backup snapshot command creates snapshots when the services are active, and stops all services which can impact the backup. This makes the maintenance window shorter. After the successful snapshot, all services are restarted and LVM snapshots are removed.
11.8. White-listing and Skipping Steps When Performing Backups
A backup using the satellite-maintain backup command proceeds in a sequence of steps. To skip part of the backup add the --whitelist option to the command and add the step label that you want to omit.
    # satellite-maintain advanced procedure run -h
  • To skip a step of the backup, enter the satellite-maintain backup command with the --whitelist option. For example:
    # satellite-maintain backup online --whitelist backup-metadata -y /var/backup_directory
12. Restoring Satellite Server or Capsule Server from a Backup
You can restore Satellite Server or Capsule Server from the backup data that you create as part of Backing Up Satellite Server and Capsule Server. This process outlines how to restore the backup on the same server that generated the backup, and all data covered by the backup is deleted on the target system. If the original system is unavailable, provision a system with the same configuration settings and host name.
12.1. Restoring from a Full Backup
Use this procedure to restore Red Hat Satellite or Capsule Server from a full backup. When the restore process completes, all processes are online, and all databases and system configuration revert to the state at the time of the backup.
  • Ensure that you are restoring to the correct instance. The Red Hat Satellite instance must have the same host name, configuration, and be the same minor version (X.Y) as the original system.
  • Ensure that you have enough space to store this data on the base system of Satellite Server or Capsule Server as well as enough space after the restoration to contain all the data in the /etc/ and /var/ directories contained within the backup.
    # df -h /var/backup_directory
    # restorecon -Rv /
  1. Choose the appropriate method to install Satellite or Capsule:
  2. Copy the backup data to Satellite Server’s local file system. Use /var/ or /var/tmp/.
    # satellite-maintain restore /var/backup_directory
Additional Resources
12.2. Restoring from Incremental Backups
Use this procedure to restore Satellite or Capsule Server from incremental backups. If you have multiple branches of incremental backups, select your full backup and each incremental backup for the branch you want to restore, in chronological order.
  2. Remove the full backup data from Satellite Server’s local file system, for example, /var/ or /var/tmp/.
  3. Copy the incremental backup data to Satellite Server’s local file system, for example, /var/ or /var/tmp/.
    # satellite-maintain restore /var/backup_directory/FIRST_INCREMENTAL
    # satellite-maintain restore /var/backup_directory/SECOND_INCREMENTAL
12.3. Backup and Restore Capsule Server Using a Virtual Machine Snapshot
If your Capsule Server is a virtual machine, you can restore it from a snapshot. Creating weekly snapshots to restore from is recommended. In the event of failure, you can install, or configure a new Capsule Server, and then synchronize the database content from Satellite Server.
If required, deploy a new Capsule Server, ensuring the host name is the same as before, and then install the Capsule certificates. You may still have them on Satellite Server, the package name ends in -certs.tar, alternately create new ones. Follow the procedures in Installing Capsule Server until you can confirm, in the Satellite web UI, that Capsule Server is connected to Satellite Server. Then use the procedure Synchronizing an External Capsule to synchronize from Satellite.
12.3.1. Synchronizing an External Capsule
Synchronize an external Capsule with Satellite.
  1. To synchronize an external Capsule, select the relevant organization and location in the Satellite web UI, or choose Any Organization and Any Location.
  2. In the Satellite web UI, navigate to Infrastructure > Capsules and click the name of the Capsule to synchronize.
13. Renaming Satellite Server or Capsule Server
To rename Satellite Server or Capsule Server, use the satellite-change-hostname script.
When changing the domain name of your Satellite Server or Capsule Server, update the hostname using satellite-change-hostname to avoid networking issues.
13.1. Renaming Satellite Server
The host name of Satellite Server is used by Satellite Server components, all Capsule Servers, and hosts registered to it for communication. This procedure ensures that in addition to renaming Satellite Server, you also update all references to point to the new host name.
Warning
Renaming your Satellite Server host shuts down all Satellite services on that host. The services restart after the renaming is complete.
  • Back up your Satellite Server before changing its host name. If you fail to successfully rename it, restore it from the backup. For more information, see Backing Up Satellite Server and Capsule Server.
  • Run the hostname and hostname -f commands on Satellite Server. If both commands do not return the FQDN of Satellite Server, the satellite-change-hostname script will fail to complete.
    If the hostname command returns the shortname of Satellite Server instead of the FQDN, use hostnamectl set-hostname My_Old_FQDN to set the old FQDN correctly before using the satellite-change-hostname script.
  • If Satellite Server has a custom SSL certificate installed, obtain a new certificate for the new FQDN of the host. For more information, see Configuring Satellite Server with a Custom SSL Certificate in Installing Satellite Server in a Connected Network Environment.
  1. On Satellite Server, run the satellite-change-hostname script, and provide the new host name. Choose one of the following methods:
    • If your Satellite Server is installed with the default self-signed SSL certificates, enter the following command:
      # satellite-change-hostname new-satellite \
      --username admin \
      --password password
    • If your Satellite Server is installed with custom SSL certificates:
      --username admin \
      --password password \
  2. If you have created a custom SSL certificate for the new Satellite Server host name, run the Satellite installation script to install the certificate. For more information about installing a custom SSL certificate, see Deploying a Custom SSL Certificate to Satellite Server in Installing Satellite Server in a Connected Network Environment.
  3. Reregister all Satellite hosts. For more information, see Registering Hosts in Managing Hosts.
  4. On all Capsule Servers, run the Satellite installation script to update references to the new host name:
    # satellite-installer \
    --foreman-proxy-foreman-base-url https://new-satellite.example.com \
    --foreman-proxy-trusted-hosts new-satellite.example.com \
    --puppet-server-foreman-url https://new-satellite.example.com
  5. On Satellite Server, list all Capsule Servers:
    # hammer capsule list
  6. On Satellite Server, synchronize content for each Capsule Server:
    --id Mycapsule_ID_
  7. If you use the virt-who agent, update the virt-who configuration files with the new host name. For more information, see Modifying a virt-who Configuration in Configuring Virtual Machine Subscriptions in Red Hat Satellite.
  8. If you use external authentication, reconfigure Satellite Server for external authentication after you run the satellite-change-hostname script. For more information, see Configuring External Authentication in Installing Satellite Server in a Connected Network Environment.
13.2. Renaming Capsule Server
The host name of Capsule Server is referenced by Satellite Server components and all hosts registered to it. This procedure ensures that in addition to renaming Capsule Server, you also update all references to the new host name.
Warning
Renaming your Capsule Server host shuts down all Satellite services on that host. The services restart after the renaming is complete.
  • Back up your Capsule Server before renaming. If you fail to successfully rename it, restore it from the backup. For more information, see Backing Up Satellite Server and Capsule Server.
  • Run the hostname and hostname -f commands on Capsule Server. If both commands do not return the FQDN of Capsule Server, the satellite-change-hostname script will fail to complete.
    If the hostname command returns the shortname of Capsule Server instead of the FQDN, use hostnamectl set-hostname My_Old_FQDN to set the old FQDN correctly before attempting to use the satellite-change-hostname script.
  1. On Satellite Server, generate a new certificates archive file for Capsule Server.
    • If you are using the default SSL certificate, enter the following command:
      # capsule-certs-generate \
      --foreman-proxy-fqdn new-capsule.example.com \
      --certs-tar /root/new-capsule.example.com-certs.tar
    • If you are using a custom SSL certificate, create a new SSL certificate for Capsule Server. For more information, see Configuring Capsule Server with a Custom SSL Certificate in Installing Capsule Server.
  2. On Satellite Server, copy the certificates archive file to Capsule Server. For example, to copy the archive file to the root user’s home directory:
    # scp /root/new-capsule.example.com-certs.tar root@capsule.example.com:
  3. On Capsule Server, run the satellite-change-hostname script and provide the host’s new name, Satellite credentials, and certificates archive file name.
    # satellite-change-hostname new-capsule.example.com --username admin \
  4. If you have created a custom certificate for Capsule Server, deploy the certificate on Capsule Server by entering the satellite-installer command that the capsule-certs-generate command returned in a previous step. For more information, see Deploying a Custom SSL Certificate to Capsule Server in Installing Capsule Server.
  5. On all Capsule clients, enter the following commands to reinstall the bootstrap RPM, reregister clients, and refresh their subscriptions.
    You can use the remote execution feature to perform this step. For more information, see Configuring and Setting up Remote Jobs in Managing Hosts.
    # dnf remove katello-ca-consumer*
    # dnf install http://new-capsule.example.com/pub/katello-ca-consumer-latest.noarch.rpm
    # subscription-manager register --org="My_Organization" \
    --environment="Library" \
    --force
    # subscription-manager refresh
  6. Update the Capsule host name in the Satellite web UI.
    1. In the Satellite web UI, navigate to Infrastructure > Capsules.
    2. Locate Capsule Server in the list, and click Edit.
    3. Edit the Name and URL fields to match Capsule Server’s new host name, then click Submit.
    4. On your DNS server, add a record for the new hostname of your Capsule Server, and delete the record of the previous host name.
14. Maintaining Satellite Server
This chapter provides information on how to maintain a Satellite Server, including information on how to work with audit records, how to clean unused tasks, and how to recover Pulp from a full disk.
14.1. Deleting Audit Records Manually
14.2. Deleting Audit Records Automatically
You can automatically delete audit records using the Saved audits interval setting. This setting is empty by default, meaning Satellite does not automatically delete the audit records.
  3. Set the value of the setting to the number of days after which you want Satellite to delete the audit records.
14.3. Anonymizing Audit Records
14.4. Deleting Report Records
Report records are created automatically in Satellite. You can use the foreman-rake reports:expire command to remove reports at any time. You can also use a cron job to schedule report record deletions at the set interval that you want.
14.5. Configuring the Cleaning Unused Tasks Feature
Satellite performs regular cleaning to reduce disc space in the database and limit the rate of disk growth. As a result, Satellite backup completes faster and overall performance is higher.
By default, Satellite executes a cron job that cleans tasks every day at 19:45. Satellite removes the following tasks during the cleaning:
  • To configure the time at which Satellite runs the cron job, set the --foreman-plugin-tasks-cron-line parameter to the time you want in cron format. For example, to schedule the cron job to run every day at 15:00, enter the following command:
    # satellite-installer --foreman-plugin-tasks-cron-line "00 15 * * *"
  • To configure the period after which Satellite deletes the tasks, edit the :rules: section in the /etc/foreman/plugins/foreman-tasks.yaml file.
  • To disable regular task cleanup on Satellite, enter the following command:
    # satellite-installer --foreman-plugin-tasks-automatic-cleanup false
  • To reenable regular task cleanup on Satellite, enter the following command:
    # satellite-installer --foreman-plugin-tasks-automatic-cleanup true
14.6. Deleting Task Records
Task records are created automatically in Satellite. You can use the foreman-rake foreman_tasks:cleanup command to remove tasks at any time. You can also use a cron job to schedule Task record deletions at the set interval that you want.
14.7. Deleting a Task by ID
  1. Connect to your Satellite Server using SSH:
    # ssh root@satellite.example.com
  2. Optional: View the task:
  3. Delete the task:
  4. Optional: Ensure the task has been removed from Satellite Server:
14.8. Recovering from a Full Disk
    1. Remove orphaned content:
    3. Grow the file system on the LV with the /var/lib/pulp directory on it. For more information, see Growing a logical volume and file system in Red Hat Enterprise Linux 8 Configuring and managing logical volumes.
      1. Stop Satellite services:
      3. Start Satellite services:
14.9. Managing Packages on the Base Operating System of Satellite Server or Capsule Server
To install and update packages on the Satellite Server or Capsule Server base operating system, you must enter the satellite-maintain packages command. Satellite prevents users from installing and updating packages with yum because yum might also update the packages related to Satellite Server or Capsule Server and result in system inconsistency.
The satellite-maintain packages command restarts some services on the operating system where you run it because it runs the satellite-installer command after installing packages.
You can manage packages using the satellite-maintain packages command as follows:
  • To install packages on Satellite Server or Capsule Server:
    # satellite-maintain packages install package_1 package_2
  • To check for available package updates on Satellite Server or Capsule Server:
    # satellite-maintain packages check-update
  • To update all packages on Satellite Server or Capsule Server:
    # satellite-maintain packages update
  • To update specific packages on Satellite Server or Capsule Server:
    # satellite-maintain packages update package_1 package_2
Updating packages individually can lead to package inconsistencies on Satellite Server or Capsule Server. For more information about updating packages on Satellite Server, see Updating Satellite Server to the Next Minor Version in Upgrading and Updating Red Hat Satellite.
14.10. Reclaiming PostgreSQL Space
The PostgreSQL database can use a large amount of disk space especially in heavily loaded deployments. Use this procedure to reclaim some of this disk space on Satellite.
    # satellite-maintain service stop --exclude postgresql
14.11. Reclaiming Space From On Demand Repositories
If you set the download policy to on demand, Satellite downloads packages only when the clients request them. You can clean up these packages to reclaim space.
Space reclamation requires an existing repository. For deleted repositories, wait for the next scheduled orphan cleanup or remove orphaned content manually:
For a single repository
  • In the Satellite web UI, navigate to Content > Products.
  • Select a product.
  • On the Repositories tab, click the repository name.
  • From the Select Actions list, select Reclaim Space.
For multiple repositories
  • Select the product name.
  • On the Repositories tab, select the checkbox of the repositories.
  • Click Reclaim Space at the top right corner.
For Capsules
  • In the Satellite web UI, navigate to Infrastructure > Capsules.
  • Select the Capsule Server.
  • Click Reclaim space.
15. Renewing the Custom SSL Certificate
This chapter provides information on how to renew the custom SSL certificate on Satellite Server as well as on Capsule Server.
15.1. Renewing a Custom SSL Certificate on Satellite Server
Use this procedure to update your custom SSL certificate for Satellite Server.
Prerequisite
  • You must create a new Certificate Signing Request (CSR) and send it to the Certificate Authority to sign the certificate. Refer to the Configuring Satellite Server with a Custom SSL Certificate guide before creating a new CSR because the Server certificate must have X.509 v3 Key Usage and Extended Key Usage extensions with required values. In return, you will receive the Satellite Server certificate and CA bundle.
  • Before deploying a renewed custom certificate on your Satellite Server, validate the custom SSL input files. Note that for the katello-certs-check command to work correctly, Common Name (CN) in the certificate must match the FQDN of Satellite Server:
    # katello-certs-check -t satellite \
    -b /root/satellite_cert/ca_cert_bundle.pem \
    -c /root/satellite_cert/satellite_cert.pem \
    -k /root/satellite_cert/satellite_cert_key.pem
    If the command is successful, it returns the following satellite-installer command. You can use this command to deploy the renewed CA certificates to Satellite Server:
    # satellite-installer --scenario satellite \
    --certs-server-cert "/root/satellite_cert/satellite_cert.pem" \
    --certs-server-key "/root/satellite_cert/satellite_key.pem" \
    --certs-server-ca-cert "/root/satellite_cert/ca_cert_bundle.pem" \
    --certs-update-server \
    --certs-update-server-ca
Do not delete the certificate files after you deploy the certificate. They are required when upgrading Satellite Server.
If a new consumer package katello-ca-consumer-latest.noarch.rpm is generated due to a different Certificate Signing Authority, all the clients registered to Satellite Server must be updated.
  1. Access the Satellite web UI from your local machine. For example, https://satellite.example.com.
  2. In your browser, view the certificate details to verify the deployed certificate.
15.2. Renewing a Custom SSL certificate on Capsule Server
Use this procedure to update your custom SSL certificate for Capsule Server. The satellite-installer command, which the capsule-certs-generate command returns, is unique to each Capsule Server. You cannot use the same command on more than one Capsule Server.
Prerequisite
  • You must create a new Certificate Signing Request and send it to the Certificate Authority to sign the certificate. Refer to the Configuring Satellite Server with a Custom SSL Certificate guide before creating a new CSR because the Satellite Server certificate must have X.509 v3 Key Usage and Extended Key Usage extensions with required values. In return, you will receive the Capsule Server certificate and CA bundle.
  1. On your Satellite Server, validate the custom SSL certificate input files:
    # katello-certs-check -t capsule \
    -b /root/capsule_cert/ca_cert_bundle.pem \
    -c /root/capsule_cert/capsule_cert.pem \
    -k /root/capsule_cert/capsule_cert_key.pem
  2. On your Satellite Server, generate the certificate archive file for your Capsule Server:
    capsule-certs-generate --foreman-proxy-fqdn "capsule.example.com" \
    --certs-tar  "/root/My_Certificates/capsule.example.com-certs.tar" \
    --server-cert "/root/My_Certificates/capsule_cert.pem" \
    --server-key "/root/My_Certificates/capsule_cert_key.pem" \
    --server-ca-cert "/root/My_Certificates/ca_cert_bundle.pem" \
  3. On your Satellite Server, copy the certificate archive file to your Capsule Server:
    # scp /root/My_Certificates/capsule.example.com-certs.tar user@capsule.example.com:
  4. Retain a copy of the satellite-installer command that the capsule-certs-generate command returns for deploying the certificate to your Capsule Server.
  5. Deploy the certificate on your Capsule Server using the satellite-installer command returned by the capsule-certs-generate command:
    # satellite-installer --scenario capsule \
    --foreman-proxy-register-in-foreman "true" \
    --foreman-proxy-foreman-base-url "https://satellite.example.com" \
    --certs-tar-file "/root/My_Certificates/capsule.example.com-certs.tar" \
Do not delete the certificate archive file on the Capsule Server after you deploy the certificate. They are required when upgrading Capsule Server.
If a new consumer package katello-ca-consumer-latest.noarch.rpm is generated due to a different Certificate Signing Authority, all the clients registered to Capsule Server must be updated.
16. Logging and Reporting Problems
This chapter provides information on how to log and report problems in Satellite, including information on relevant log files, how to enable debug logging, how to open a support case and attach the relevant log tar files, and how to access support cases within the Satellite web UI.
You can use the log files and other information described in this chapter to do your own troubleshooting, or you can capture these and many more files, as well as diagnostic and configuration information, to send to Red Hat Support if you need further assistance.
For more information about Satellite logging settings, use satellite-installer with the --full-help option:
# satellite-installer --full-help | grep logging
16.1. Enabling Debug Logging
Debug logging provides the most detailed log information and can help with troubleshooting issues that can arise with Satellite and its components. In the Satellite CLI, enable debug logging to log detailed debugging information for Satellite.
    # satellite-installer --foreman-logging-level debug
    # satellite-installer --reset-foreman-logging-level
16.2. Increasing the Logging Levels to Help with Debugging
By default, Satellite comes with :INFO level logging enabled. You can increase or decrease the log levels on your Satellite.
# satellite-maintain service restart
# hammer admin logging --list
16.2.1. Increasing the Logging Level For Hammer
:log_level: 'debug'
16.2.2. Increasing the Logging Level On Capsule
You can find the log for Capsule in /var/log/foreman-proxy/proxy.log. Uncomment the DEBUG line in /etc/foreman-proxy/settings.yml:
:log_level: DEBUG
Caution
16.2.3. Increasing the Logging Level For Candlepin
You can find the log for Candlepin in /var/log/candlepin/candlepin.log. Errors are also logged to a separate file for easier debugging /var/log/candlepin/error.log.
Extend /etc/candlepin/candlepin.conf:
log4j.logger.org.candlepin=DEBUG
Ensure to restart the tomcat service afterwards:
# systemctl restart tomcat
log4j.logger.org.candlepin.resource.ConsumerResource=WARN
log4j.logger.org.candlepin.resource.HypervisorResource=WARN
16.2.4. Increasing the Logging Level On Satellite
You can find the log for Satellite in /var/log/foreman/production.log.
Satellite stores logs for Apache in:
    :logging:
      :production:
        :type: file
        :layout: pattern
        :level: debug
    :loggers:
      :ldap:
        :enabled: true
      :permissions:
        :enabled: true
      :sql:
        :enabled: true
  3. Restart Satellite services:
16.2.5. Increasing the Logging Level For Qpid Dispatch Router
Qpid logs to syslog and can be viewed in /var/log/messages or with journalctl. Enable debug logging in /etc/qpid-dispatch/qdrouterd.conf:
enable: debug+
Ensure to restart the Qpid Dispatch Router afterwards:
# systemctl restart qdrouterd
Caution
16.2.6. Increasing the Logging Level For Qpid Broker
Qpid logs to syslog and can be viewed in /var/log/messages or with journalctl. Set the log level in /etc/qpid/qpidd.conf:
log-enable=debug+
Ensure to restart the Qpid Broker afterwards:
# systemctl restart qpidd
Caution
Running the installer will revert this change.
16.2.7. Increasing the Logging Level For Redis
loglevel debug
16.2.8. Increasing the Logging Level For Postgres
You can find the log for Postgres in /var/lib/pgsql/data/log. Uncomment the log_statement in /var/lib/pgsql/data/postgresql.conf:
log_statement = 'all'
Ensure to restart Satellite services afterwards:
Caution
Based on the size of your Satellite installation, this can cause disk space to fill up very quickly. Only turn this on if absolutely needed.
16.2.9. Increasing the Logging Level For Satellite Installer
You can find the log files in /var/log/foreman-installer/. To increase the log level of the Satellite Installer during an install:
# satellite-installer --verbose-log-level debug
16.2.10. Increasing the Logging Level For Pulp
By default, Pulp logs to syslog and can be viewed in /var/log/messages or with journalctl. Add the following config to the /etc/pulp/settings.py file:
Ensure to restart the Pulp services afterwards:
# systemctl restart \
pulpcore-api \
pulpcore-content \
pulpcore-resource-manager \
pulpcore-worker@1 \
pulpcore-worker@2 \
rh-redis5-redis
16.2.11. Increasing the Logging Level For Puppet Agent
You can increase the logging level for Puppet agent on your Satellite Server.
  1. Add the following line to the [agent] block in the /etc/puppetlabs/puppet/puppet.conf file:
    [agent]
        log_level = debug
16.2.12. Increasing the Logging Level For Puppet Server
You can increase the logging level for Puppet server on your Satellite Server.
Prerequisite
    [master]
        log_level = debug
  2. Restart the Puppet server:
    # satellite-maintain service restart --only puppetserver
16.3. Retrieving the Status of Services
  1. In the Satellite web UI, navigate to Administer > About.
  2. On the Smart Proxies tab, you can view the status of all Capsules.
CLI procedure
  • Run hammer ping to get information from the database and Satellite services:
    # hammer ping
  • Use satellite-maintain to check the status of the services running in systemd:
    # satellite-maintain service status
  • Use satellite-maintain to perform a health check:
    $ satellite-maintain health check
16.4. Restarting Services
Satellite uses a set of back-end services to perform tasks. You you experience an issue with your Satellite, check the status of Satellite services.
  • Use satellite-maintain to restart Satellite services:
Tip
16.5. Enabling Individual Loggers
You can enable individual loggers for selective logging. Satellite uses the following loggers:
app
audit
background
blob
dynflow
ldap
notifications
permissions
sql
telemetry
templates
    --foreman-loggers ldap:true \
    --foreman-loggers sql:true
    # satellite-installer --reset-foreman-loggers
16.6. Configuring Logging to Journal or File-based Logging
Satellite uses file-based logging by default. You can use the satellite-installer command to reconfigure logging.
Procedure for configuring logging with Journal
  1. Enter the following satellite-installer command to configure logging to the journald service:
    --foreman-proxy-log JOURNAL
  1. Enter the following satellite-installer command to configure file-based logging:
    --reset-foreman-logging-layout \
    --reset-foreman-proxy-log
    • /var/log/foreman-proxy.log
For more information about Journal, see Viewing logs using the command line in the Red Hat Enterprise Linux 8 Configuring Basic System Settings Guide.
16.7. Log File Directories Provided by Satellite
Red Hat Satellite provides system information in the form of notifications and log files.
Table 5. Log File Directories for Reporting and Troubleshooting
/var/log/candlepin
Subscription management
Installer
/var/log/foreman-maintain
Foreman maintain
Foreman proxy
/var/log/foreman
Foreman
/var/log/httpd
Apache HTTP server
/var/log/messages
Various other log messages
Configuration management
/var/log/rhsm
/var/log/tomcat
Candlepin webservice logs
You can also use the foreman-tail command to follow many of the log files related to Satellite. You can run foreman-tail -l to list the processes and services that it follows.
16.8. Utilities for Collecting Log Information
You can collect information from log files to troubleshoot Satellite.
sosreport
The collection process removes security information such as passwords, tokens, and keys while collecting information. However, the tar files can still contain sensitive information about the Satellite Server. Red Hat recommends that you send this information directly to the intended recipient and not to a public target.
16.9. System Journal Metadata
The following table lists metadata that the journald service uses in Satellite. You can use this metadata to filter your queries.
Table 6. System Journal Metadata
Name Description
AUDIT_ACTION
Audit action performed
AUDIT_TYPE
Audit resource type
AUDIT_ID
AUDIT_ATTRIBUTE
AUDIT_FIELD_OLD
AUDIT_FIELD_NEW
AUDIT_ID
AUDIT_ATTRIBUTE
Example: Name or description
EXCEPTION_MESSAGE
EXCEPTION_CLASS
EXCEPTION_BACKTRACE
LOC_ID
Location database ID
LOC_NAME
Location name
LOC_LABEL
Location label
LOGGER
Logger name
ORG_ID
Organization database ID
ORG_NAME
Organization name
ORG_LABEL
Organization label
REMOTE_IP
Remote IP address of a client
REQUEST
SESSION
TEMPLATE_NAME
Template name
TEMPLATE_DIGEST
TEMPLATE_HOST_NAME
TEMPLATE_HOST_ID
USER_LOGIN
User login name
17. Monitoring Resources
17.1. Using the Red Hat Satellite Content Dashboard
The Red Hat Satellite content dashboard contains various widgets which provide an overview of the host configuration, Content Views, compliance reports, subscriptions and hosts currently registered, promotions and synchronization, and a list of the latest notifications.
In the Satellite web UI, navigate to Monitor > Dashboard to access the content dashboard. The dashboard can be rearranged by clicking on a widget and dragging it to a different position. The following widgets are available:
Host Configuration Status
Table 7. Host Configuration States
Icon State Description
host state config okay
host state config error
Hosts in error state
host state config report
host state config pending
host state config outofsync
Out of sync hosts
host state config noreport
Hosts with no reports
host state config noalert
Hosts with alerts disabled
Host Configuration Chart
Latest Events
New Hosts
Task Status
Latest Warning/Error Tasks
Discovered Hosts
Latest Errata
A list of all errata available for hosts registered to Satellite.
Content Views
A list of all Content Views in Satellite and their publish status.
Sync Overview
An overview of all products or repositories enabled in Satellite and their synchronization status. All products that are in the queue for synchronization, are unsynchronized or have been previously synchronized are listed in this section.
Host Subscription Status
An overview of the subscriptions currently consumed by the hosts registered to Satellite. A subscription is a purchased certificate that unlocks access to software, upgrades, and security fixes for hosts. The following table shows the possible states of subscriptions.
Table 8. Host Subscription States
host state sub invalid
Invalid
host state sub partial
Partial
host state sub valid
Valid
Subscription Status
Host Collections
A list of all host collections in Satellite and their status, including the number of content hosts in each host collection.
Virt-who Configuration Status
Table 9. Virt-who Configuration States
State Description
No Reports
No report has been received because either an error occurred during the virt-who configuration deployment, or the configuration has not been deployed yet, or virt-who cannot connect to Satellite during the scheduled interval.
No Change
OK
Total Configurations
Latest Compliance Reports
Compliance Reports Breakdown
Red Hat Insights Actions
Red Hat Insights is a tool embedded in Satellite that checks the environment and suggests actions you can take. The actions are divided into 4 categories: Availability, Stability, Performance, and Security.
Red Hat Insights Risk Summary
It is not possible to change the date format displayed in the Satellite web UI.
17.1.1. Managing Tasks
Red Hat Satellite keeps a complete log of all planned or performed tasks, such as repositories synchronised, errata applied, and Content Views published. To review the log, navigate to Monitor > Tasks.
To Adjust Timeout Settings:
  5. Click Save.
17.2. Configuring RSS Notifications
To view Satellite event notification alerts, click the Notifications icon in the upper right of the screen.
By default, the Notifications area displays RSS feed events published in the Red Hat Satellite Blog.
You can configure the RSS feed notifications by changing the URL feed. The supported feed format is RSS 2.0 and Atom. For an example of the RSS 2.0 feed structure, see the Red Hat Satellite Blog feed. For an example of the Atom feed structure, see the Foreman blog feed.
  1. In the Satellite web UI, navigate to Administer > Settings and select the Notifications tab.
17.3. Monitoring Satellite Server
Audit records list the changes made by all users on Satellite. This information can be used for maintenance and troubleshooting.
  1. In the Satellite web UI, navigate to Monitor > Audits to view the audit records.
17.4. Monitoring Capsule Server
The following section shows how to use the Satellite web UI to find Capsule information valuable for maintenance and troubleshooting.
17.4.1. Viewing General Capsule Information
In the Satellite web UI, navigate to Infrastructure > Capsules to view a table of Capsule Servers registered to Satellite Server. The information contained in the table answers the following questions:
Is Capsule Server running?
This is indicated by a green icon in the Status column. A red icon indicates an inactive Capsule, use the service foreman-proxy restart command on Capsule Server to activate it.
What services are enabled on Capsule Server?
In the Features column you can verify if Capsule for example provides a DHCP service or acts as a Pulp mirror. Capsule features can be enabled during installation or configured in addition. For more information, see Installing Capsule Server.
What organizations and locations is Capsule Server assigned to?
A Capsule Server can be assigned to multiple organizations and locations, but only Capsules belonging to the currently selected organization are displayed. To list all Capsules, select Any Organization from the context menu in the top left corner.
After changing the Capsule configuration, select Refresh from the drop-down menu in the Actions column to ensure the Capsule table is up to date.
Click the Capsule name to view further details. At the Overview tab, you can find the same information as in the Capsule table. In addition, you can answer to the following questions:
Which hosts are managed by Capsule Server?
How much storage space is available on Capsule Server?
The amount of storage space occupied by the Pulp content in /var/lib/pulp is displayed. Also the remaining storage space available on the Capsule can be ascertained.
17.4.2. Monitoring Services
In the Satellite web UI, navigate to Infrastructure > Capsules and click the name of the selected Capsule. At the Services tab, you can find basic information on Capsule services, such as the list of DNS domains, or the number of Pulp workers. The appearance of the page depends on what services are enabled on Capsule Server. Services providing more detailed status information can have dedicated tabs at the Capsule page. For more information, see Monitoring Puppet.
17.4.3. Monitoring Puppet
In the Satellite web UI, navigate to Infrastructure > Capsules and click the name of the selected Capsule. At the Puppet tab you can find the following:
  • A table of CA certificates associated with the Capsule at the Certificates sub-tab. Here you can inspect the certificate expiry data, or cancel the certificate by clicking Revoke.
The Puppet and Puppet CA tabs are available only if you have Puppet enabled in your Satellite. For more information, see Enabling Puppet Integration with Satellite in Managing Configurations Using Puppet Integration in Red Hat Satellite.
18. Using Webhooks
A webhook is a way for a web page or web application to provide other applications with information in real time. Webhooks are only triggered after an event occurs. The request usually contains details of the event. An event triggers callbacks, such as sending an e-mail confirming a host has been provisioned. Webhooks enable you to define a call to an external API based on Satellite internal event using a fire-and-forget message exchange pattern. The application sending the request does not wait for the response, or ignores it.
The typical use case for webhooks in Satellite is making a call to a monitoring system when a host is created or deleted.
Webhooks are useful where the action you want to perform in the external system can be achieved through its API. Where it is necessary to run additional commands or edit files, the shellhooks plugin for Capsules is available. The shellhooks plugin enables you to define a shell script on the Capsule that can be executed through the API.
18.1. Migrating to Webhooks
18.2. Installing Webhooks
Use the following procedure to install webhooks. After installing webhooks, you can configure Satellite Server to send webhook requests.
    # satellite-installer --enable-foreman-plugin-webhooks
  • Optional: you can install the CLI plugin using the following command:
    # satellite-installer --enable-foreman-cli-webhooks
18.3. Creating a Webhook Template
Webhook templates are used to generate the body of HTTP request to a configured target when a webhook is triggered. Use the following procedure to create a webhook template in the Satellite web UI.
  1. In the Satellite web UI, navigate to Administer > Webhook Templates.
    A webhook HTTP payload must be created using Satellite template syntax. The webhook template can use a special variable called @object that can represent the main object of the event. @object can be missing in case of certain events. You can determine what data are actually available with the @payload variable.
    For more information, see Template Writing Reference in Managing Hosts and for available template macros and methods, visit /templates_doc on Satellite Server.
  7. Click Submit.
Examples
Running remote execution jobs
Creating users
18.4. Creating a Webhook
You can customize events, payloads, HTTP authentication, content type, and headers through the Satellite web UI.
Use the following procedure to create a webhook in the Satellite web UI.
  1. In the Satellite web UI, navigate to Administer > Webhooks.
  2. Click Create new.
  6. Click Template to select a template. Webhook templates are used to generate the body of the HTTP request to Satellite Server when a webhook is triggered.
  7. Enter an HTTP method.
  9. Click the Credentials tab.
  11. Optional: Uncheck Verify SSL if you do not want to verify the server certificate against the system certificate store or Satellite CA.
When configuring webhooks with endpoints with non-standard HTTP or HTTPS ports, an SELinux port must be assigned, see Configuring SELinux to Ensure Access to Satellite on Custom Ports in Installing Satellite Server in a Connected Network Environment.
18.5. Available Webhook Events
The following table contains a list of webhook events that are available from the Satellite web UI. Action events trigger webhooks only on success, so if an action fails, a webhook is not triggered.
A Content View was successfully promoted.
Run OpenSCAP scan.
Actions Remote Execution Run Host Job Ansible Run Insights Plan Succeeded
Runs a given maintenance plan from Red Hat Access Insights given an ID.
Perform a single Puppet run.
Build Entered
Build Exited
Common database operations on a Content View.
Domain
Host
Hostgroup
Model
Status Changed
Subnet
Template Render Performed
Template
User
18.6. Shellhooks
With webhooks, you can only map one Satellite event to one API call. For advanced integrations, where a single shell script can contain multiple commands, you can install a Capsule shellhooks plugin that exposes executables using a REST HTTP API.
You can then configure a webhook to reach out to a Capsule API to run a predefined shellhook. A shellhook is an executable script that can be written in any language as long as it can be executed. The shellhook can for example contain commands or edit files.
The HTTP method must be POST. An example URL would be: https://capsule.example.com:9090/shellhook/My_Script.
You must enable Capsule Authorization for each webhook connected to a shellhook to enable it to authorize a call.
Standard output and standard error output are redirected to the Capsule logs as messages with debug or warning levels respectively.
18.7. Installing the Shellhooks Plugin
Optionally, you can install and enable the shellhooks plugin on each Capsule used for shellhooks, using the following command:
# satellite-installer --enable-foreman-proxy-plugin-shellhooks
18.8. Passing Arguments to Shellhook Script Using Webhooks
      "X-Shellhook-Arg-1": "VALUE",
      "X-Shellhook-Arg-2": "VALUE"
Example
18.9. Passing Arguments to Shellhook Script Using Curl
    "X-Shellhook-Arg-1: VALUE"
    "X-Shellhook-Arg-2: VALUE"
Example
-H "X-Shellhook-Arg-2: My Content View" \
--data "" https://capsule.example.com:9090/shellhook/My_Script
18.10. Creating a Shellhook to Print Arguments
Prerequisite
  1. Modify the /var/lib/foreman-proxy/shellhooks/print_args script to print arguments to standard error output so you can see them in the Capsule logs:
    #!/bin/sh
    echo "$@" >&2
  2. In the Satellite web UI, navigate to Administer > Webhooks.
  3. Click Create new.
  6. In the Target URL field, enter the URL of your Capsule Server followed by :9090/shellhook/print_args:
    https://capsule.example.com:9090/shellhook/print_args
  8. On the Credentials tab, check Capsule Authorization.
        "X-Shellhook-Arg-1": "Hello",
        "X-Shellhook-Arg-2": "World!"
  10. Click Submit. You now have successfully created a shellhook that prints "Hello World!" to Capsule logs every time you a remote execution job succeeds.
  1. Run a remote execution job on any host. You can use time as a command. For more information, see Executing a Remote Job in Managing Hosts.
  2. Verify that the shellhook script was triggered and printed "Hello World!" to Capsule Server logs:
    [W] [3520] Hello World!
19. Searching and Bookmarking
Satellite features powerful search functionality on most pages of the Satellite web UI. It enables you to search all kinds of resources that Satellite manages. Searches accept both free text and syntax-based queries, which can be built using extensive input prediction. Search queries can be saved as bookmarks for future reuse.
19.1. Building Search Queries
19.1.1. Query Syntax
parameter operator value
19.1.2. Query Operators
Table 10. Comparison Operators Accepted by Search
EQUALS
hostgroup = RHEL7
NOT EQUALS
LIKE
hostgroup ~ rhel%
NOT LIKE
GREATER THAN
registered_at <= Yesterday
LESS THAN
IN
release_version !^ 7
NOT IN
HAS or set?
NOT HAS or null?
Table 11. Logical Operators Accepted by Search
and
<whitespace>
or
not
19.1.3. Query Values
Text Values
Examples:
hostgroup = "Web servers"
hostgroup = Web servers
Temporal Values
  • "10 January 2017"
  • "10 Jan 2017"
  • 10-January-2017
  • 10/January/2017
  • "January 10, 2017"
Warning
19.2. Using Free Text Search
19.3. Managing Bookmarks
19.3.1. Creating Bookmarks
  1. In the Satellite web UI, navigate to the page where you want to create a bookmark.
  7. Click Submit.
19.3.2. Deleting Bookmarks
  1. In the Satellite web UI, navigate to Administer > Bookmarks.
This section contains information about settings that you can edit in the Satellite web UI by navigating to Administer > Settings.
A.1. General Settings
Administrator email address
Satellite URL
URL where your Satellite instance is reachable. See also Provisioning > Unattended URL.
Entries per page
20
Number of records shown per page in Satellite
Fix DB cache
Satellite maintains a cache of permissions and roles. When set to Yes, Satellite recreates this cache on the next restart.
DB pending seed
Capsule request timeout
60
Open and read timeout for HTTP requests from Satellite to Capsule (in seconds).
Login page footer text
HTTP(S) proxy
Set a proxy for outgoing HTTP(S) connections from the Satellite product. System-wide proxies must be configured at the operating system level.
HTTP(S) proxy except hosts
Show Experimental Labs
If set to Yes, Satellite appends domain names when new hosts are provisioned.
Out of sync interval
30
Satellite UUID
Satellite instance ID. Uniquely identifies a Satellite instance.
Default language
Default timezone
Instance title
Saved audits interval
New host details UI
Satellite loads the new UI for host details.
A.2. Satellite Task Settings
Sync task timeout
120
Enable dynflow console
Capsule action retry count
4
Number of attempts permitted to start a task on the Capsule before failing.
Capsule action retry interval
15
Allow Capsule batch tasks
Enable batch triggering of tasks on the Capsule.
Capsule tasks batch size
100
Number of tasks included in one request to the Capsule if foreman_tasks_proxy_batch_trigger is enabled.
Tasks troubleshooting URL
Polling intervals multiplier
1
A.3. Template Sync Settings
Associate
Branch
Default branch in Git repo.
Commit message
Templates export made by a Satellite user
Dirname
Filter
Force import
Lock templates
Keep, do not lock new
Metadata export mode
Refresh
Default metadata export mode.
Possible options:
refresh re-renders metadata.
keep keeps existing metadata.
Negate
Prefix
Repo
/tmp/dir
git://example.com
https://example.com
ssh://example.com
Verbosity
A.4. Discovery Settings
Discovery location
Discovery organization
Interface fact
discovery_bootif
Create bond interfaces
Clean all facts
Hostname facts
discovery_bootif
Auto provisioning
Reboot
Hostname prefix
mac
Fact columns
Highlighted facts
Storage facts
Software facts
Hardware facts
Network facts
IPMI facts
Lock PXE
Locked PXELinux template name
pxelinux_discovery
Locked PXEGrub template name
pxegrub_discovery
Locked PXEGrub2 template name
pxegrub2_discovery
Force DNS
Error on existing NIC
Type of name generator
Fact + prefix
Prefer IPv6
A.5. Boot Disk Settings
iPXE directory
/usr/share/ipxe
ISOLINUX directory
/usr/share/syslinux
SYSLINUX directory
/usr/share/syslinux
Grub2 directory
/var/lib/tftpboot/grub2
Host image template
Boot disk iPXE - host
Generic image template
Boot disk iPXE - generic host
ISO generation command
genisoimage
Installation media caching
Allowed bootdisk types
A.6. Red Hat Cloud Settings
Automatic inventory upload
Enable automatic upload of your host inventory to the Red Hat cloud.
Synchronize recommendations Automatically
Enable automatic synchronization of Insights recommendations from the Red Hat cloud.
Obfuscate host names
Obfuscate hostnames sent to the Red Hat cloud.
Obfuscate host ipv4 addresses
Obfuscate IPv4 addresses sent to the Red Hat cloud.
ID of the RHC daemon
RHC daemon id.
A.7. Content Settings
Default HTTP Proxy
CDN SSL version
Kickstart default
Kickstart default finish
Default synced OS user-data
Kickstart default user data
Kickstart default PXELinux
Kickstart default PXEGrub
Kickstart default PXEGrub2
Kickstart default iPXE
Kickstart default
Discovery Red Hat kexec
Atomic Kickstart default
Manifest refresh timeout
1200
Accept action timeout
20
Finish action timeout
3600
Can communicate with the Red Hat Portal for subscriptions.
Check services before actions
100
How many repositories should be synced concurrently on a Capsule. A smaller number may lead to longer sync times. A larger number will increase dynflow load.
Sync Capsules after Content View promotion
Whether or not to auto sync Capsules after a Content View promotion.
immediate
Default Red Hat Repository download policy
on_demand
Default download policy for enabled Red Hat repositories. Either immediate or on_demand.
Default Capsule download policy
on_demand
Default download policy for Capsule syncs. Either inherit, immediate, or on_demand.
/var/lib/pulp/katello-export
/var/lib/pulp/exports
Pulp client key
Pulp client cert
Sync Connection Timeout
300
Delete Host upon unregister
Default Location
Expire soon days
120
Host Duplicate DMI UUIDs
Host Profile Assume
Host Tasks Workers Pool Size
5
Applicability Batch Size
50
Autosearch
Autosearch delay
500
Pulp bulk load size
2000
1440
Prefer registered through Capsule for remote execution
A.8. Authentication Settings
OAuth active
Satellite will use OAuth for API authorization.
OAuth consumer key
OAuth consumer key.
OAuth consumer secret
OAuth consumer secret.
OAuth map users
Satellite maps users by username in the request-header. If this is disabled, OAuth requests have administrator rights.
Failed login attempts limit
30
Satellite blocks user logins from an incoming IP address for 5 minutes after the specified number of failed login attempts. Set to 0 to disable brute force protection.
Restrict registered Capsules
Only known Capsules can access features that use Capsule authentication.
Require SSL for capsules
Client SSL certificates are used to identify Capsules (:require_ssl should also be enabled).
Trusted hosts
List of hostnames, IPv4, IPv6 addresses or subnets to be trusted in addition to Capsules for access to fact/report importers and ENC output.
SSL certificate
/etc/foreman/client_cert.pem
SSL Certificate path that Satellite uses to communicate with its proxies.
SSL CA file
/etc/foreman/proxy_ca.pem
SSL CA file path that Satellite uses to communicate with its proxies.
SSL private key
/etc/foreman/client_key.pem
SSL Private Key path that Satellite uses to communicate with its proxies.
SSL client DN env
HTTP_SSL_CLIENT_S_DN
SSL client verify env
HTTP_SSL_CLIENT_VERIFY
SSL client cert env
HTTP_SSL_CLIENT_CERT
Server CA file
SSL CA file path used in templates to verify the connection to Satellite.
Websockets SSL key
Private key file path that Satellite uses to encrypt websockets.
Websockets SSL certificate
Certificate path that Satellite uses to encrypt websockets.
Websockets encryption
Login delegation logout URL
External
Idle timeout
60
BCrypt password cost
9
BMC credentials access
OIDC JWKs URL
OIDC Audience
OIDC Issuer
OIDC Algorithm
A.9. Email Settings
Email reply address
Email reply address for emails that Satellite is sending.
Email subject prefix
Send welcome email
Delivery method
Sendmail
Method used to deliver email.
SMTP enable StartTLS auto
SMTP OpenSSL verify mode
Default verification mode
SMTP address
SMTP address to connect to.
SMTP port
25
SMTP port to connect to.
SMTP HELO/EHLO domain
HELO/EHLO domain.
SMTP username
SMTP password
SMTP authentication
none
Sendmail arguments
-i
Sendmail location
/usr/sbin/sendmail
A.10. Notifications Settings
RSS enable
Pull RSS notifications.
RSS URL
https://www.redhat.com/en/rss/blog/channel/red-hat-satellite
A.11. Provisioning Settings
Host owner
Default owner on provisioned hosts, if empty Satellite uses the current user.
Root password
Unattended URL
Safemode rendering
Enables safe mode rendering of provisioning templates. The default and recommended option Yes denies access to variables and any object that is not listed in Satellite.
When set to No, any object may be accessed by a user with permission to use templating features, either by editing templates, parameters or smart variables. This permits users full remote code execution on Satellite Server, effectively disabling all authorization. This is not a safe option, especially in larger companies.
Query local nameservers
Satellite queries the locally configured resolver instead of the SOA/NS authorities.
Installation token lifetime
360
SSH timeout
120
0.0.0.0
Update IP from built request
Satellite updates the host IP with the IP that made the build request.
Use short name for VMs
Satellite uses the short hostname instead of the FQDN for creating new virtual machines.
DNS timeout
[5, 10, 15, 20]
Clean up failed deployment
Satellite deletes the virtual machine if the provisioning script ends with a non-zero exit code.
Random-based
iPXE intermediate script
Destroy associated VM on host delete. When enabled, VMs linked to hosts are deleted on Compute Resource. When disabled, VMs are unlinked when the host is deleted, meaning they remain on Compute Resource and can be re-associated or imported back to Satellite again. This does not automatically power off the VM
Maximum structured facts
100
Maximum number of keys in structured subtree, statistics stored in satellite::dropped_subtree_facts.
Global Registration
Global Registration template.
PXEGrub2 global default
PXELinux global default
PXEGrub global default
Global default iPXE template
iPXE global default
Local boot PXEGrub2 template
PXEGrub2 default local boot
Local boot PXELinux template
PXELinux default local boot
Local boot PXEGrub template
PXEGrub default local boot
Local boot iPXE template
iPXE default local boot
Manage PuppetCA
Satellite automates certificate signing upon provision of a new host.
Use UUID for certificates
Satellite uses random UUIDs for certificate signing instead of hostnames.
Show unsupported provisioning templates
Show unsupported provisioning templates. When enabled, all the available templates are shown. When disabled, only Red Hat supported templates are shown.
A.12. Facts Settings
Satellite creates the host when new facts are received.
Location fact
satellite_location
Organization fact
satellite_organization
Default location
Default Location
Default organization
Default Organization
Update hostgroup from facts
Satellite updates a host’s hostgroup from its facts.
Ignore facts for domain
Update subnets from facts
None
Satellite updates a host’s subnet from its facts.
Exclude pattern for facts stored in Satellite
Exclude pattern for all types of imported facts (Puppet, Ansible, rhsm). Those facts are not stored in the satellite database. You can use a * wildcard to match names with indexes, e.g. ignore* filters out ignore, ignore123 as well as a::ignore or even a::ignore123::b.
A.13. Configuration Management Settings
Satellite creates the host when a report is received.
Matchers inheritance
Satellite matchers are inherited by children when evaluating smart class parameters for hostgroups, organizations, and locations.
[fqdn, hostgroup, os, domain]
Satellite evaluates host smart class parameters in this order by default.
Interpolate ERB in parameters
Satellite parses ERB in parameters value in the ENC output.
All hosts show a configuration status even when a Puppet Capsule is not assigned.
A.14. Remote Execution Settings
Fallback to Any Capsule
Enable Global Capsule
SSH User
root
Effective User
root
Effective User Method
sudo
Effective user password
Sync Job Templates
SSH Port
22
Connect by IP
Prefer IPv6 over IPv4
Default SSH password
Default SSH key passphrase
Workers pool size
5
Number of workers in the pool to handle the execution of the remote execution jobs. Restart of the dynflowd/satellite-tasks service is required.
Cleanup working directories
Cockpit URL
Form Job Template
Run Command - SSH Default
Time to pickup
86400
Time in seconds within which the host has to pick up a job. If the job is not picked up within this limit, the job will be cancelled. Applies only to pull-mqtt based jobs. Defaults to one day.
A.15. Ansible Settings
Private Key Path
Connection type
ssh
WinRM cert Validation
validate
Default verbosity level
Disabled
Satellite adds this level of verbosity for additional debugging output when running Ansible playbooks.
Post-provision timeout
360
Timeout (in seconds) to set when Satellite triggers an Ansible roles task playbook after a host is fully provisioned. Set this to the maximum time you expect a host to take until it is ready after a reboot.
Ansible report timeout
30
Ansible out of sync disabled
Ansible - Ansible Inventory
Satellite uses this template to schedule the report with Ansible inventory.
Ansible roles to ignore
The roles to exclude when importing roles from Capsule. The expected input is comma separated values and you can use * wildcard metacharacters. For example: foo*, *b*, *bar.
Capsule tasks batch size for Ansible
Number of tasks which should be sent to the Capsule in one request if satellite_tasks_proxy_batch_trigger is enabled. If set, it overrides satellite_tasks_proxy_batch_size setting for Ansible jobs.
