We appreciate your input on our documentation. Please let us know how we could make it better.
You can submit feedback by filing a ticket in Bugzilla:
Navigate to the Bugzilla website.
In the Component field, use
Documentation
In the Description field, enter your suggestion for improvement. Include a link to the relevant parts of the documentation.
Click Submit Bug.
1. Load Balancing Solution Architecture
You can configure Satellite Server to use a load balancer to distribute client requests and network load across multiple Capsule Servers. This results in an overall performance improvement on Capsule Servers.
This guide outlines how to prepare Satellite Server and Capsule Server for load balancing, and provides guidelines on how to configure a load balancer and register clients in a load-balanced setup.
A load-balanced setup consists of the following components:
Satellite Server
Two or more Capsule Servers
A load balancer
Multiple clients
In a load-balanced setup, nearly all Capsule functionality continues to work as expected when one Capsule Server is down, for planned or unplanned maintenance. Load balancer works with the following services and features:
Registration using
subscription-manager
Content Management with
yum
repositories -
Optional: Puppet
In the load-balanced setup, a load balancer distributes load only for the services and features mentioned above. If other services, such as provisioning or virt-who, are running on the individual Capsules, you must access them directly through Capsules and not through the load balancer. |
Configure Puppet certificate signing on one Capsule Server, typically the first system where you configure Capsule Server for load balancing.
Configure the clients to send CA requests to port 8141 on a load balancer.
Configure a load balancer to redirect CA requests from port 8141 to port 8140 on the system where you configure Capsule Server to sign Puppet certificates.
2. Load Balancing Considerations
Distributing load between several Capsule Servers prevents any one Capsule from becoming a single point of failure. Configuring Capsules to use a load balancer can provide resilience against planned and unplanned outages. This improves availability and responsiveness.
Consider the following guidelines when configuring load balancing:
If you use Puppet, Puppet certificate signing is assigned to the first Capsule that you configure. If the first Capsule is down, clients cannot obtain Puppet content.
This solution does not use Pacemaker or other similar HA tools to maintain one state across all Capsules. To troubleshoot issues, reproduce the issue on each Capsule, bypassing the load balancer.
Configuring Capsules to use a load balancer results in a more complex environment and requires additional maintenance.
You must ensure that all Capsules have the same Content Views and synchronize all Capsules to the same Content View versions
You must upgrade each Capsule in sequence
You must backup each Capsule that you configure regularly
To upgrade Capsule Servers from 6.11 to 6.12, complete the Upgrading Capsule Servers procedure in Upgrading and Updating Red Hat Satellite. There are no additional steps required for Capsule Servers in a load balancing configuration.
3. Prerequisites for Configuring Capsule Servers for Load Balancing
To configure Capsule Servers for load balancing, complete the following procedures described in Installing Capsule Server. Satellite does not support configuring existing Capsule Servers for load balancing.
4. Configuring Capsule Servers for Load Balancing
This chapter outlines how to configure Capsule Servers for load balancing. Proceed to one of the following sections depending on your Satellite Server configuration:
Configuring Capsule Server with Default SSL Certificates for Load Balancing without Puppet
Configuring Capsule Server with Default SSL Certificates for Load Balancing with Puppet
Configuring Capsule Server with Custom SSL Certificates for Load Balancing without Puppet
Configuring Capsule Server with Custom SSL Certificates for Load Balancing with Puppet
Use different file names for the Katello certificates you create for each Capsule Server. For example, name the certificate archive file with Capsule Server FQDN.
4.1. Configuring Capsule Server with Default SSL Certificates for Load Balancing without Puppet
The following section describes how to configure Capsule Servers that use default SSL certificates for load balancing without Puppet. Complete this procedure on each Capsule Server that you want to configure for load balancing.
On Satellite Server, generate Katello certificates for Capsule Server:
# capsule-certs-generate \ --certs-tar "/root/capsule.example.com-certs.tar" \ --foreman-proxy-cname loadbalancer.example.com \ --foreman-proxy-fqdn capsule.example.com
Retain a copy of the example
satellite-installer
command that is output by thecapsule-certs-generate
command for installing Capsule Server certificate. -
Copy the certificate archive file from Satellite Server to Capsule Server.
# scp /root/capsule.example.com-certs.tar root@capsule.example.com:/root/capsule.example.com-certs.tar
Append the following options to the
satellite-installer
command that you obtain from the output of thecapsule-certs-generate
command:--certs-cname "loadbalancer.example.com" \ --enable-foreman-proxy-plugin-remote-execution-script
On Capsule Server, enter the
satellite-installer
command:# satellite-installer --scenario capsule \ --certs-cname "loadbalancer.example.com" \ --certs-tar-file "capsule.example.com-certs.tar" \ --enable-foreman-proxy-plugin-remote-execution-script \ --foreman-proxy-foreman-base-url "https://satellite.example.com" \ --foreman-proxy-oauth-consumer-key "oauth key" \ --foreman-proxy-oauth-consumer-secret "oauth secret" \ --foreman-proxy-register-in-foreman "true" \ --foreman-proxy-trusted-hosts "satellite.example.com" \ --foreman-proxy-trusted-hosts "capsule.example.com"
4.2. Configuring Capsule Server with Default SSL Certificates for Load Balancing with Puppet
The following section describes how to configure Capsule Servers that use default SSL certificates for load balancing with Puppet.
If you use Puppet in your Satellite configuration, you must complete the following procedures:
4.2.1. Configuring Capsule Server with Default SSL Certificates to Generate and Sign Puppet Certificates
Complete this procedure only for the system where you want to configure Capsule Server to generate and sign Puppet certificates for all other Capsule Servers that you configure for load balancing.
On Satellite Server, generate Katello certificates for the system where you configure Capsule Server to generate and sign Puppet certificates:
# capsule-certs-generate \ --certs-tar "/root/capsule-ca.example.com-certs.tar" \ --foreman-proxy-cname loadbalancer.example.com \ --foreman-proxy-fqdn capsule-ca.example.com
satellite-installer
Copy the certificate archive file from Satellite Server to Capsule Server:
# scp /root/capsule-ca.example.com-certs.tar root@capsule-ca.example.com:capsule-ca.example.com-certs.tar
satellite-installer
command:--certs-cname "loadbalancer.example.com" \ --enable-foreman-proxy-plugin-remote-execution-script \ --foreman-proxy-puppetca "true" \ --puppet-ca-server "capsule-ca.example.com" \ --puppet-dns-alt-names "loadbalancer.example.com" \ --puppet-server-ca "true"
satellite-installer
command:# satellite-installer --scenario capsule \ --certs-cname "loadbalancer.example.com" \ --certs-tar-file "capsule-ca.example.com-certs.tar" \ --enable-foreman-proxy-plugin-remote-execution-script \ --enable-puppet \ --foreman-proxy-foreman-base-url "https://satellite.example.com" \ --foreman-proxy-oauth-consumer-key "oauth key" \ --foreman-proxy-oauth-consumer-secret "oauth secret" \ --foreman-proxy-puppetca "true" \ --foreman-proxy-register-in-foreman "true" \ --foreman-proxy-trusted-hosts "satellite.example.com" \ --foreman-proxy-trusted-hosts "capsule-ca.example.com" \ --puppet-ca-server "capsule-ca.example.com" \ --puppet-dns-alt-names "loadbalancer.example.com" \ --puppet-server true \ --puppet-server-ca "true" \ --puppet-server-foreman-url "https://satellite.example.com"
On Capsule Server, stop the Puppet server:
# puppet resource service puppetserver ensure=stopped
Generate Puppet certificates for all other Capsule Servers that you configure for load balancing, except the first system where you configure Puppet certificates signing:
# puppetserver ca generate \ --ca-client \ --certname capsule.example.com \ --subject-alt-names loadbalancer.example.com
This command creates the following files on the system where you configure Capsule Server to sign Puppet certificates:
/etc/puppetlabs/puppet/ssl/certs/capsule.example.com.pem
/etc/puppetlabs/puppet/ssl/certs/ca.pem
/etc/puppetlabs/puppet/ssl/private_keys/capsule.example.com.pem
/etc/puppetlabs/puppet/ssl/public_keys/capsule.example.com.pem
Resume the Puppet server:
# puppet resource service puppetserver ensure=running
4.2.2. Configuring Remaining Capsule Servers with Default SSL Certificates for Load Balancing
Complete this procedure on each Capsule Server excluding the system where you configure Capsule Server to sign Puppet certificates.
satellite-installer
On Capsule Server, install the
puppetserver
package:# satellite-maintain packages install puppetserver
On Capsule Server, create directories for puppet certificates:
# mkdir -p /etc/puppetlabs/puppet/ssl/certs/ \ /etc/puppetlabs/puppet/ssl/private_keys/ \ /etc/puppetlabs/puppet/ssl/public_keys/
On Capsule Server, copy the Puppet certificates for this Capsule Server from the system where you configure Capsule Server to sign Puppet certificates:
# scp root@capsule-ca.example.com:/etc/puppetlabs/puppet/ssl/certs/capsule.example.com.pem /etc/puppetlabs/puppet/ssl/certs/capsule.example.com.pem # scp root@capsule-ca.example.com:/etc/puppetlabs/puppet/ssl/certs/ca.pem /etc/puppetlabs/puppet/ssl/certs/ca.pem # scp root@capsule-ca.example.com:/etc/puppetlabs/puppet/ssl/private_keys/capsule.example.com.pem /etc/puppetlabs/puppet/ssl/private_keys/capsule.example.com.pem # scp root@capsule-ca.example.com:/etc/puppetlabs/puppet/ssl/public_keys/capsule.example.com.pem /etc/puppetlabs/puppet/ssl/public_keys/capsule.example.com.pem
On Capsule Server, change the
directory ownership to userpuppet
and grouppuppet
:# chown -R puppet:puppet /etc/puppetlabs/puppet/ssl/
On Capsule Server, set the SELinux context for the
directory:# restorecon -Rv /etc/puppetlabs/puppet/ssl/
satellite-installer
command:--certs-cname "loadbalancer.example.com" \ --enable-foreman-proxy-plugin-remote-execution-script \ --foreman-proxy-puppetca "false" \ --puppet-ca-server "capsule-ca.example.com" \ --puppet-dns-alt-names "loadbalancer.example.com" \ --puppet-server-ca "false"
satellite-installer
command:# satellite-installer --scenario capsule \ --certs-cname "loadbalancer.example.com" \ --certs-tar-file "capsule.example.com-certs.tar" \ --enable-foreman-proxy-plugin-remote-execution-script \ --foreman-proxy-foreman-base-url "https://satellite.example.com" \ --foreman-proxy-oauth-consumer-key "oauth key" \ --foreman-proxy-oauth-consumer-secret "oauth secret" \ --foreman-proxy-puppetca "false" \ --foreman-proxy-register-in-foreman "true" \ --foreman-proxy-trusted-hosts "satellite.example.com" \ --foreman-proxy-trusted-hosts "capsule.example.com" \ --puppet-ca-server "capsule-ca.example.com" \ --puppet-dns-alt-names "loadbalancer.example.com" \ --puppet-server-ca "false" \ --puppet-server-foreman-url "https://satellite.example.com"
4.3. Configuring Capsule Server with Custom SSL Certificates for Load Balancing without Puppet
The following section describes how to configure Capsule Servers that use custom SSL certificates for load balancing without Puppet.
4.3.1. Creating Custom SSL Certificates for Capsule Server
This procedure outlines how to create a configuration file for the Certificate Signing Request and include the load balancer and Capsule Server as Subject Alternative Names (SAN). Complete this procedure on each Capsule Server that you want to configure for load balancing.
On Capsule Server, create a directory to contain all the source certificate files, accessible to only the
root
user:# mkdir /root/capsule_cert # cd /root/capsule_cert
Create a private key with which to sign the Certificate Signing Request (CSR).
Note that the private key must be unencrypted. If you use a password-protected private key, remove the private key password.
If you already have a private key for this Capsule Server, skip this step.
# openssl genrsa -out /root/capsule_cert/capsule_cert_key.pem 4096
Create the certificate request configuration file with the following content:
[ req ] default_bits = 4096 distinguished_name = req_distinguished_name req_extensions = req_ext prompt = no [ req_distinguished_name ] countryName=2 Letter Country Code stateOrProvinceName=State or Province Full Name localityName=Locality Name 0.organizationName=Organization Name organizationalUnitName=Capsule Organization Unit Name commonName=capsule.example.com (1) emailAddress=Email Address [ req_ext ] #authorityKeyIdentifier=keyid,issuer #basicConstraints=CA:FALSE keyUsage = digitalSignature, nonRepudiation, keyEncipherment, dataEncipherment subjectAltName = @alt_names [alt_names] (2) DNS.1 = loadbalancer.example.com DNS.2 = capsule.example.com
The certificate’s common name must match the FQDN of Capsule Server. Ensure to change this when running the command on each Capsule Server that you configure for load balancing. You can also set a wildcard value
. If you set a wildcard value, you must add the-t capsule
option when you use thekatello-certs-check
command. -
Under
[alt_names]
, include the FQDN of the load balancer asDNS.1
and the FQDN of Capsule Server asDNS.2
Create a Certificate Signing Request (CSR) for the SAN certificate:
# openssl req -new \ -key /root/capsule_cert/capsule_cert_key.pem \ (1) -config SAN_config.cfg \ (2) -out /root/capsule_cert/capsule_cert_csr.pem (3)
Capsule Server’s private key, used to sign the certificate
The certificate request configuration file
Certificate Signing Request file
Send the certificate request to the Certificate Authority:
When you submit the request, specify the lifespan of the certificate. The method for sending the certificate request varies, so consult the Certificate Authority for the preferred method. In response to the request, you can expect to receive a Certificate Authority bundle and a signed certificate, in separate files.
Copy the Certificate Authority bundle and Capsule Server certificate file that you receive from the Certificate Authority, and Capsule Server private key to your Satellite Server.
On Satellite Server, validate Capsule Server certificate input files:
# katello-certs-check \ -c /root/capsule_cert/capsule_cert.pem \ (1) -k /root/capsule_cert/capsule_cert_key.pem \ (2) -b /root/capsule_cert/ca_cert_bundle.pem (3)
Capsule Server certificate file, provided by your Certificate Authority
Capsule Server’s private key that you used to sign the certificate
Certificate Authority bundle, provided by your Certificate Authority
If you set the
commonName=
to a wildcard value*
option to thekatello-certs-check
command.Retain a copy of the example
command that is output by thekatello-certs-check
command for creating the Certificate Archive File for this Capsule Server.
4.3.2. Configuring Capsule Server with Custom SSL Certificates for Load Balancing without Puppet
The following section describes how to configure Capsule Servers that use custom SSL certificates for load balancing without Puppet. Complete this procedure on each Capsule Server that you want to configure for load balancing.
Append the following option to the
command that you obtain from the output of thekatello-certs-check
command:--foreman-proxy-cname loadbalancer.example.com
On Satellite Server, enter the
command to generate Capsule certificates:# capsule-certs-generate \ --certs-tar /root/capsule_cert/capsule.tar \ --foreman-proxy-cname loadbalancer.example.com \ --foreman-proxy-fqdn capsule.example.com \ --server-ca-cert /root/capsule_cert/ca_cert_bundle.pem \ --server-cert /root/capsule_cert/capsule.pem \ --server-key /root/capsule_cert/capsule.pem
satellite-installer
command from the output for installing Capsule Server certificates. -
# scp /root/capsule.example.com-certs.tar root@capsule.example.com:capsule.example.com-certs.tar
satellite-installer
satellite-installer
4.4. Configuring Capsule Server with Custom SSL Certificates for Load Balancing with Puppet
If you use Puppet in your Satellite configuration, then you must complete the following procedures:
4.4.1. Creating Custom SSL Certificates for Capsule Server
root
command. -
Under
[alt_names]
If you set the
commonName=
4.4.2. Configuring Capsule Server with Custom SSL Certificates to Generate and Sign Puppet Certificates
Complete this procedure only for the system where you want to configure Capsule Server to generate Puppet certificates for all other Capsule Servers that you configure for load balancing.
command to generate Capsule certificates:# capsule-certs-generate \ --certs-tar /root/capsule_cert/capsule-ca.tar \ --foreman-proxy-cname loadbalancer.example.com \ --foreman-proxy-fqdn capsule-ca.example.com \ --server-ca-cert /root/capsule_cert/ca_cert_bundle.pem \ --server-cert /root/capsule_cert/capsule-ca.pem \ --server-key /root/capsule_cert/capsule-ca.pem
satellite-installer
satellite-installer
command:--enable-foreman-proxy-plugin-remote-execution-script \ --foreman-proxy-puppetca "true" \ --puppet-ca-server "capsule-ca.example.com" \ --puppet-dns-alt-names "loadbalancer.example.com" \ --puppet-server-ca "true"
satellite-installer
command:# satellite-installer --scenario capsule \ --certs-cname "loadbalancer.example.com" \ --certs-tar-file "certs.tgz" \ --enable-foreman-proxy-plugin-remote-execution-script \ --enable-puppet \ --foreman-proxy-foreman-base-url "https://satellite.example.com" \ --foreman-proxy-oauth-consumer-key "oauth key" \ --foreman-proxy-oauth-consumer-secret "oauth secret" \ --foreman-proxy-puppetca "true" \ --foreman-proxy-register-in-foreman "true" \ --foreman-proxy-trusted-hosts "satellite.example.com" \ --foreman-proxy-trusted-hosts "capsule-ca.example.com" \ --puppet-ca-server "capsule-ca.example.com" \ --puppet-dns-alt-names "loadbalancer.example.com" \ --puppet-server true \ --puppet-server-ca "true" \ --puppet-server-foreman-url "https://satellite.example.com"
On Capsule Server, generate Puppet certificates for all other Capsules that you configure for load balancing, except this first system where you configure Puppet certificates signing:
# puppet cert generate capsule.example.com \ --dns_alt_names=loadbalancer.example.com
This command creates the following files on the Puppet certificate signing Capsule Server instance:
4.4.3. Configuring Remaining Capsule Servers with Custom SSL Certificates for Load Balancing
Complete this procedure for each Capsule Server excluding the system where you configure Capsule Server to sign Puppet certificates.
satellite-installer
puppetserver
and grouppuppet
satellite-installer
satellite-installer
5. Installing the Load Balancer
The following example provides general guidance for configuring an HAProxy load balancer using Red Hat Enterprise Linux 8 server. However, you can install any suitable load balancing software solution that supports TCP forwarding.
Install HAProxy:
# dnf install haproxy
Install the following package that includes the
semanage
tool:# dnf install policycoreutils-python-utils
Configure SELinux to allow HAProxy to bind any port:
Configure the load balancer to balance the network load for the ports as described in Ports Configuration for the Load Balancer. For example, to configure ports for HAProxy, edit the
/etc/haproxy/haproxy.cfg
file to correspond with the table. For more information, see Configuration example for haproxy.cfg for HAProxy load balancer with Satellite 6 in the Red Hat Knowledgebase.Table 1. Ports Configuration for the Load Balancer Service Port Mode Balance Mode Destination HTTP
80
TCP
roundrobin
port 80 on all Capsule Servers
HTTPS and RHSM
TCP
source
port 443 on all Capsule Servers
AMQP
5647
TCP
roundrobin
port 5647 on all Capsule Servers
Puppet (Optional)
8140
TCP
roundrobin
port 8140 on all Capsule Servers
PuppetCA (Optional)
8141
TCP
roundrobin
port 8140 only on the system where you configure Capsule Server to sign Puppet certificates
SmartProxy (Optional for OpenScap)
9090
TCP
roundrobin
port 9090 on all Capsule Servers
Configure the load balancer to disable SSL offloading and allow client-side SSL certificates to pass through to back end servers. This is required because communication from clients to Capsule Servers depends on client-side SSL certificates.
Start and enable the HAProxy service:
6. Verifying the Load Balancing Configuration
Use this procedure to verify the load balancing configuration for each Capsule Server.
Shut down the base operating system for your Capsule Server.
Verify that content or subscription management features are available on clients registered to this Capsule. For example, enter the
subscription-manager refresh
command on a client. -
Restart the base operating system for your Capsule Server.
7. Registering Clients to the Load Balancer
To register clients, proceed with one of the following procedures:
7.1. Registering Clients Using Host Registration
You can register hosts with Satellite using the host registration feature, the Satellite API, or Hammer CLI.
In the Satellite web UI, navigate to Hosts > Register Host.
Click Generate to create the registration command.
Click on the files icon to copy the command to your clipboard.
Log in to the host you want register and run the previously generated command.
Update subscription manager configuration for
rhsm.baseurl
andserver.hostname
:# subscription-manager config \ --rhsm.baseurl=https://loadbalancer.example.com/pulp/content \ --server.hostname=loadbalancer.example.com
Check the
/etc/yum.repos.d/redhat.repo
file and ensure that the appropriate repositories have been enabled.
Generate the host registration command using the Hammer CLI:
# hammer host-registration generate-command \ --activation-keys "My_Activation_Key"
If your hosts do not trust the SSL certificate of Satellite Server, you can disable SSL validation by adding the
--insecure
flag to the registration command.# hammer host-registration generate-command \ --activation-keys "My_Activation_Key" \ --insecure true
rhsm.baseurl
andserver.hostname
Check the
Generate the host registration command using the Satellite API:
# curl -X POST https://satellite.example.com/api/registration_commands \ --user "My_User_Name" \ -H 'Content-Type: application/json' \ -d '{ "registration_command": { "activation_keys": ["My_Activation_Key_1, My_Activation_Key_2"] }}'
--insecure
flag to the registration command.# curl -X POST https://satellite.example.com/api/registration_commands \ --user "My_User_Name" \ -H 'Content-Type: application/json' \ -d '{ "registration_command": { "activation_keys": ["My_Activation_Key_1, My_Activation_Key_2"], "insecure": true }}'
Use an activation key to simplify specifying the environments. For more information, see Managing Activation Keys in Managing Content.
To enter a password as command line argument, use
username:password
syntax. Keep in mind this can save the password in the shell history.For more information about registration see Registering a Host to Red Hat Satellite in Managing Hosts.
rhsm.baseurl
andserver.hostname
Check the
7.2. (Deprecated) Registering Clients Using the Bootstrap Script
To register clients, enter the following command on the client. You must complete the registration procedure for each client.
Ensure that you install the bootstrap script on the client and change file permissions of the script to executable. For more information, see Registering Hosts to Red Hat Satellite Using The Bootstrap Script in Managing Hosts.
On Red Hat Enterprise Linux 8, enter the following command:
# /usr/libexec/platform-python bootstrap.py \ --activationkey="My_Activation_Key" \ --enablerepos=satellite-client-6-for-rhel-8-<arch>-rpms \ (1) --force \ (2) --hostgroup="My_Hostgroup" \ --location="My_Location" \ --login=admin \ --organization="My_Organization" \ --puppet-ca-port 8141 \ (3) --server loadbalancer.example.com
Replace
<arch>
with the client architecture, for examplex86
Include the
--force
option to register the client that has been previously registered to a standalone Capsule. -
Include the
option if you use Puppet.
On Red Hat Enterprise Linux 7 or 6, enter the following command:
# python bootstrap.py --login=admin \ --activationkey="My_Activation_Key" \ --enablerepos=rhel-7-server-satellite-client-6-rpms \ --force \ (1) --hostgroup="My_Hostgroup" \ --location="My_Location" \ --organization="My_Organization" \ --puppet-ca-port 8141 \ (2) --server loadbalancer.example.com
Include the
--force
Include the
The script prompts for the password corresponding to the Satellite user name you entered with the --login
option.
7.3. (Deprecated) Registering Clients Manually Using katello-ca-consumer RPM
To register clients manually, complete the following procedure on each client that you want to register.
Remove the
katello-ca-consumer
package if it is installed:# dnf remove 'katello-ca-consumer*'
Install the
katello-ca-consumer
package from the load balancer:# dnf install http://loadbalancer.example.com/pub/katello-ca-consumer-latest.noarch.rpm
Register the client and include the
--serverurl
and--baseurl
options:# subscription-manager register \ --activationkey="My_Activation_Key" \ --baseurl=https://loadbalancer.example.com/pulp/content/ \ --org="My_Organization" \ --serverurl=https://loadbalancer.example.com/rhsm
8. Propagating SCAP Content through the Load Balancer
If you use OpenSCAP to manage security compliance on your clients, you must configure the SCAP client to send ARF reports to the load balancer instead of Capsule. The configuration procedure depends on the method you have selected to deploy compliance policies.
8.1. Propagating SCAP Content using Ansible Deployment
Using this procedure, you can promote Security Content Automation Protocol (SCAP) content through the load balancer in the scope of the Ansible deployment method.
Ensure that you have configured Satellite for Ansible deployment of compliance policies. For more information, see Configuring Compliance Policy Deployment Methods in Administering Red Hat Satellite.
In the Satellite web UI, navigate to Configure > Variables.
Search for the
foreman_scap_client_port
variable and click its name. -
In the Default Behavior area, ensure that the Override checkbox is selected.
In the Parameter Type list, ensure that
integer
is selected. -
In the Default Value field, enter
9090
In the Specify Matchers area, remove all matchers that override the default value.
Click Submit.
Search for the
foreman_scap_client_server
string
is selected. -
In the Default Value field, enter the FQDN of your load balancer, such as
Click Submit.
Continue with deploying a compliance policy using Ansible. For more information, see:
Deploying a Policy in a Host Group Using Ansible in Administering Red Hat Satellite
Deploying a Policy on a Host Using Ansible in Administering Red Hat Satellite
On the client, verify that the
/etc/foreman_scap_client/config.yaml
file contains the following lines:# Foreman proxy to which reports should be uploaded :server: 'loadbalancer.example.com' :port: 9090
8.2. Propagating SCAP Content using Puppet Deployment
Using this procedure, you can promote Security Content Automation Protocol (SCAP) content through the load balancer in the scope of the Puppet deployment method.
Ensure that you have configured Satellite for Puppet deployment of compliance policies. For more information, see Configuring Compliance Policy Deployment Methods in Administering Red Hat Satellite.
In the Satellite web UI, navigate to Configure > Classes and click
foreman_scap_client
Click the Smart Class Parameter tab.
In the pane to the left of the Smart Class Parameter window, click
port
In the Default Behavior area, select the Override checkbox.
From the Key Type list, select
integer
9090
server
string
In the lower left of the Smart Class Parameter window, click Submit.
Continue with deploying a compliance policy using Puppet. For more information, see:
Deploying a Policy in a Host Group Using Puppet in Administering Red Hat Satellite
Deploying a Policy on a Host Using Puppet in Administering Red Hat Satellite
