We appreciate your input on our documentation. Please let us know how we could make it better.
You can submit feedback by filing a ticket in Bugzilla:
Navigate to the Bugzilla website.
In the Component field, use
Documentation. -
In the Description field, enter your suggestion for improvement. Include a link to the relevant parts of the documentation.
Click Submit Bug.
1. Accessing Red Hat Satellite
After Red Hat Satellite has been installed and configured, use the Satellite web UI interface to log in to Satellite for further configuration.
1.1. Importing the Katello Root CA Certificate
The first time you log in to Satellite, you might see a warning informing you that you are using the default self-signed certificate and you might not be able to connect this browser to Satellite until the root CA certificate is imported in the browser. Use the following procedure to locate the root CA certificate on Satellite and to import it into your browser.
To use the CLI instead of the Satellite web UI, see CLI Procedure.
Your Red Hat Satellite is installed and configured.
Identify the fully qualified domain name of your Satellite Server:
# hostname -f
Access the
pubdirectory on your Satellite Server using a web browser pointed to the fully qualified domain name:https://satellite.example.com/pub
When you access Satellite for the first time, an untrusted connection warning displays in your web browser. Accept the self-signed certificate and add the Satellite URL as a security exception to override the settings. This procedure might differ depending on the browser being used. Ensure that the Satellite URL is valid before you accept the security exception.
Select
katello-server-ca.crt. -
Import the certificate into your browser as a certificate authority and trust it to identify websites.
From the Satellite CLI, copy the
katello-server-ca.crtfile to the machine you use to access the Satellite web UI:# scp /var/www/html/pub/katello-server-ca.crt username@hostname:remotefile
In the browser, import the
katello-server-ca.crtcertificate as a certificate authority and trust it to identify websites.
1.2. Logging in to Satellite
Use the web user interface to log in to Satellite for further configuration.
Ensure that the Katello root CA certificate is installed in your browser. For more information, see Importing the Katello Root CA Certificate.
Access Satellite Server using a web browser pointed to the fully qualified domain name:
Enter the user name and password created during the configuration process. If a user was not created during the configuration process, the default user name is admin. If you have problems logging in, you can reset the password. For more information, see Resetting the Administrative User Password.
1.3. Navigation Tabs in the Satellite web UI
Use the navigation tabs to browse the Satellite web UI.
| Navigation Tabs | Description |
Any Context |
Clicking this tab changes the organization and location. If no organization or location is selected, the default organization is Any Organization and the default location is Any Location. Use this tab to change to different values. |
Monitor |
Content |
Provides content management tools. This includes Content Views, Activation Keys, and Life Cycle Environments. |
Hosts |
Configure |
Provides general configuration tools and data including Host Groups and Puppet data. |
Infrastructure |
Provides tools on configuring how Satellite interacts with the environment. |
User Name |
Provides user administration where users can edit their personal information. |
Administer |
Provides advanced configuration for settings such as Users and RBAC, as well as general settings. |
1.4. Changing the Password
Click your user name at the top right corner.
Select My Account from the menu.
In the Current Password field, enter the current password.
In the Password field, enter a new password.
In the Verify field, enter the new password again.
Click the Submit button to save your new password.
1.5. Resetting the Administrative User Password
Log in to the base operating system where Satellite Server is installed.
Enter the following command to reset the password:
# foreman-rake permissions:reset Reset to user: admin, password: qwJxBptxb7Gfcjj5
Use this password to reset the password in the Satellite web UI.
Edit the
~/.hammer/cli.modules.d/foreman.ymlfile on Satellite Server to add the new password:# vi ~/.hammer/cli.modules.d/foreman.yml
To set the password, enter the following command:
Edit the
1.6. Setting a Custom Message on the Login Page
In the Satellite web UI, navigate to Administer > Settings, and click the General tab.
Click the edit button next to Login page footer text, and enter the desired text to be displayed on the login page. For example, this text may be a warning message required by your company.
Click Save.
Log out of the Satellite web UI and verify that the custom text is now displayed on the login page below the Satellite version number.
2. Starting and Stopping Red Hat Satellite
Satellite provides the satellite-maintain service command to manage Satellite services from the command line.
This is useful when creating a backup of Satellite.
For more information on creating backups, see Backing Up Satellite Server and Capsule Server.
After installing Satellite with the satellite-installer command, all Satellite services are started and enabled automatically.
# satellite-maintain service list
# satellite-maintain service status
To stop Satellite services, execute:
To start Satellite services, execute:
To restart Satellite services, execute:
# satellite-maintain service restart
3. Migrating from Internal Satellite Databases to External Databases
When you install Red Hat Satellite, the satellite-installer command installs PostgreSQL databases on the same server as Satellite. If you are using the default internal databases but want to start using external databases to help with the server load, you can migrate your internal databases to external databases.
To confirm whether your Satellite Server has internal or external databases, you can query the status of your databases:
# satellite-maintain service status --only postgresql
Red Hat does not provide support or tools for external database maintenance. This includes backups, upgrades, and database tuning. You must have your own database administrator to support and maintain external databases.
Preparing a Host for External Databases. Prepare a Red Hat Enterprise Linux 8 server to host the external databases.
Installing PostgreSQL. Prepare PostgreSQL with databases for Satellite, Pulp and Candlepin with dedicated users owning them.
Migrating to External Databases. Edit the parameters of
satellite-installerto point to the new databases, and runsatellite-installer.
Foreman, Katello, and Candlepin use the PostgreSQL database. If you want to use PostgreSQL as an external database, the following information can help you decide if this option is right for your Satellite configuration. Satellite supports PostgreSQL version 12.
Increase in free memory and free CPU on Satellite
Flexibility to set
shared_bufferson the PostgreSQL database to a high number without the risk of interfering with other services on Satellite -
Flexibility to tune the PostgreSQL server’s system without adversely affecting Satellite operations
If either Satellite or the PostgreSQL database server suffers a hardware or storage failure, Satellite is not operational
If there is latency between the Satellite server and database server, performance can suffer
If you suspect that the PostgreSQL database on your Satellite is causing performance problems, use the information in Satellite 6: How to enable postgres query logging to detect slow running queries to determine if you have slow queries. Queries that take longer than one second are typically caused by performance issues with large installations, and moving to an external database might not help. If you have slow queries, contact Red Hat Support.
Install a freshly provisioned system with the latest Red Hat Enterprise Linux 8 to host the external databases.
Subscriptions for Red Hat Enterprise Linux do not provide the correct service level agreement for using Satellite with external databases. You must also attach a Satellite subscription to the base operating system that you want to use for the external databases.
The prepared host must meet Satellite’s Storage Requirements.
Use the instructions in Attaching the Satellite Infrastructure Subscription to attach a Satellite subscription to your server.
Disable all repositories and enable only the following repositories:
# subscription-manager repos --disable '*' # subscription-manager repos \ --enable=satellite-6.12-for-rhel-8-x86_64-rpms \ --enable=rhel-8-for-x86_64-baseos-rpms \ --enable=rhel-8-for-x86_64-appstream-rpms
Enable the following modules:
# dnf module enable satellite:el8
NoteEnablement of the module
satellite:el8warns about a conflict withpostgresql:10andruby:2.5as these modules are set to the default module versions on Red Hat Enterprise Linux 8. The modulesatellite:el8has a dependency for the modulespostgresql:12andruby:2.7that will be enabled with thesatellite:el8module. These warnings do not cause installation process failure, hence can be ignored safely. For more information about modules and lifecycle streams on Red Hat Enterprise Linux 8, see Red Hat Enterprise Linux Application Streams Life Cycle.
3.3. Installing PostgreSQL
You can install only the same version of PostgreSQL that is installed with the satellite-installer tool during an internal database installation.
To install PostgreSQL, enter the following command:
# dnf install postgresql-server postgresql-evr
To initialize PostgreSQL, enter the following command:
# postgresql-setup initdb
Edit the
Note that the default configuration of external PostgreSQL needs to be adjusted to work with Satellite. The base recommended external database configuration adjustments are as follows:
max_connections: 500
shared_buffers: 512MB
work_mem: 4MB
Remove the
Edit the
host all all Satellite_ip/32 md5
To start, and enable PostgreSQL service, enter the following commands:
Open the postgresql port on the external PostgreSQL server:
# firewall-cmd --add-service=postgresql # firewall-cmd --runtime-to-permanent
Switch to the
Create three databases and dedicated roles: one for Satellite, one for Candlepin, and one for Pulp:
CREATE USER "foreman" WITH PASSWORD 'Foreman_Password'; CREATE USER "candlepin" WITH PASSWORD 'Candlepin_Password'; CREATE USER "pulp" WITH PASSWORD 'Pulpcore_Password'; CREATE DATABASE foreman OWNER foreman; CREATE DATABASE candlepin OWNER candlepin; CREATE DATABASE pulpcore OWNER pulp;
Exit the
postgresuser:# \q
From Satellite Server, test that you can access the database. If the connection succeeds, the commands return
1.# PGPASSWORD='Foreman_Password' psql -h postgres.example.com -p 5432 -U foreman -d foreman -c "SELECT 1 as ping" # PGPASSWORD='Candlepin_Password' psql -h postgres.example.com -p 5432 -U candlepin -d candlepin -c "SELECT 1 as ping" # PGPASSWORD='Pulpcore_Password' psql -h postgres.example.com -p 5432 -U pulp -d pulpcore -c "SELECT 1 as ping"
Back up and transfer existing data, then use the satellite-installer command to configure Satellite to connect to an external PostgreSQL database server.
You have installed and configured a PostgreSQL server on a Red Hat Enterprise Linux server.
On Satellite Server, stop Satellite services:
Start the PostgreSQL services:
# systemctl start postgresql
# satellite-maintain backup online --skip-pulp-content --preserve-directory -y /var/migration_backup
PGPASSWORD='Foreman_Password' pg_restore -h postgres.example.com -U foreman -d foreman < /var/migration_backup/foreman.dump PGPASSWORD='Candlepin_Password' pg_restore -h postgres.example.com -U candlepin -d candlepin < /var/migration_backup/candlepin.dump PGPASSWORD='Pulpcore_Password' pg_restore -h postgres.example.com -U pulp -d pulpcore < /var/migration_backup/pulpcore.dump
Use the
satellite-installercommand to update Satellite to point to the new databases:satellite-installer --scenario satellite \ --foreman-db-host postgres.example.com \ --foreman-db-password Foreman_Password \ --foreman-db-database foreman \ --foreman-db-manage false \ --foreman-db-username foreman \ --katello-candlepin-db-host postgres.example.com \ --katello-candlepin-db-name candlepin \ --katello-candlepin-db-password Candlepin_Password \ --katello-candlepin-manage-db false \ --katello-candlepin-db-user candlepin \ --foreman-proxy-content-pulpcore-manage-postgresql false \ --foreman-proxy-content-pulpcore-postgresql-host postgres.example.com \ --foreman-proxy-content-pulpcore-postgresql-db-name pulpcore \ --foreman-proxy-content-pulpcore-postgresql-password Pulpcore_Password \ --foreman-proxy-content-pulpcore-postgresql-user pulp
4. Managing Satellite with Ansible Collections
Satellite Ansible Collections is a set of Ansible modules that interact with the Satellite API. You can use Satellite Ansible Collections to manage and automate many aspects of Satellite.
4.1. Installing the Satellite Ansible Modules
Use this procedure to install the Satellite Ansible modules.
Install the package using the following command:
# satellite-maintain packages install ansible-collection-redhat-satellite
4.2. Viewing the Satellite Ansible Modules
You can view the installed Satellite Ansible modules by running:
# ansible-doc -l redhat.satellite
Alternatively, you can also see the complete list of Satellite Ansible modules and other related information at Red Hat Ansible Automation Platform.
All modules are in the redhat.satellite namespace and can be referred to in the format redhat.satellite._module_name_.
For example, to display information about the activation_key module, enter the following command:
$ ansible-doc redhat.satellite.activation_key
5. Managing Organizations
Organizations divide Red Hat Satellite resources into logical groups based on ownership, purpose, content, security level, or other divisions. You can create and manage multiple organizations through Red Hat Satellite, then divide and assign your Red Hat subscriptions to each individual organization. This provides a method of managing the content of several individual organizations under one management system. Here are some examples of organization management:
- Single Organization
A small business with a simple system administration chain. In this case, you can create a single organization for the business and assign content to it.
- Multiple Organizations
A large company that owns several smaller business units. For example, a company with separate system administration and software development groups. In this case, you can create organizations for the company and each of the business units it owns. This keeps the system infrastructure for each separate. You can then assign content to each organization based on its needs.
- External Organizations
A company that manages external systems for other organizations. For example, a company offering cloud computing and web hosting resources to customers. In this case, you can create an organization for the company’s own system infrastructure and then an organization for each external business. You can then assign content to each organization where necessary.
A default installation of Red Hat Satellite has a default organization called Default Organization.
If a new user is not assigned a default organization, their access is limited. To grant systems rights to users, assign them to a default organization. The next time the user logs on to Satellite, the user’s account has the correct system rights.
5.1. Creating an Organization
Use this procedure to create an organization. To use the CLI instead of the Satellite web UI, see CLI procedure.
In the Satellite web UI, navigate to Administer > Organizations.
Click New Organization.
In the Name field, enter a name for the organization.
In the Label field, enter a unique identifier for the organization. This is used for creating and mapping certain assets, such as directories for content storage. Use letters, numbers, underscores, and dashes, but no spaces.
Optional: If you do not wish to enable Simple Content Access (SCA), uncheck the Simple Content Access checkbox. For more information on SCA, see Simple Content Access.
NoteRed Hat does not recommend disabling SCA as entitlement mode is deprecated.
Optional: in the Description field, enter a description for the organization.
Click Submit.
If you have hosts with no organization assigned, select the hosts that you want to add to the organization, then click Proceed to Edit.
In the Edit page, assign the infrastructure resources that you want to add to the organization. This includes networking resources, installation media, kickstart templates, and other parameters. You can return to this page at any time by navigating to Administer > Organizations and then selecting an organization to edit.
Click Submit.
To create an organization, enter the following command:
# hammer organization create \ --name "My_Organization" \ --label "My_Organization_Label" \ --description "My_Organization_Description"
NoteOrganizations created this way have Simple Content Access (SCA) enabled by default. If you wish to disable SCA, add the
--simple-content-access falseparameter to the command. Red Hat does not advise you to disable SCA because entitlement mode (not using SCA) is deprecated. -
Optional: To edit an organization, enter the
hammer organization updatecommand. For example, the following command assigns a compute resource to the organization:# hammer organization update \ --name "My_Organization" \ --compute-resource-ids 1
5.2. Setting the Organization Context
An organization context defines the organization to use for a host and its associated resources.
The organization menu is the first menu item in the menu bar, on the upper left of the Satellite web UI. If you have not selected a current organization, the menu says Any Organization. Click the Any Organization button and select the organization to use.
While using the CLI, include either --organization "My_Organization" or --organization-label "My_Organization_Label" as an option.
For example:
# hammer subscription list \ --organization "My_Organization"
This command outputs subscriptions allocated for the My_Organization.
5.3. Creating an Organization Debug Certificate
If you require a debug certificate for your organization, use the following procedure.
Select an organization that you want to generate a debug certificate for.
Click Generate and Download.
Save the certificate file in a secure location.
Debug Certificates are automatically generated for provisioning template downloads if they do not already exist in the organization for which they are being downloaded.
5.4. Browsing Repository Content Using an Organization Debug Certificate
You can view an organization’s repository content using a web browser or using the API if you have a debug certificate for that organization.
You created and downloaded an organization certificate. For more information, see Creating an Organization Debug Certificate.
Split the private and public keys from the certificate into two files.
Open the X.509 certificate, for example, for the default organization:
$ vi 'Default Organization-key-cert.pem'
Copy the contents of the file from
-----BEGIN RSA PRIVATE KEY-----to-----END RSA PRIVATE KEY-----, into akey.pemfile. -
-----BEGIN CERTIFICATE-----to-----END CERTIFICATE-----, into acert.pemfile.
To use a browser, you must first convert the X.509 certificate to a format your browser supports and then import the certificate.
Convert the certificate into the PKCS12 format using the following command:
$ openssl pkcs12 -keypbe PBE-SHA1-3DES -certpbe PBE-SHA1-3DES -export -in cert.pem -inkey key.pem -out My_Organization_Label.pfx -name My_Organization
In the Firefox browser, navigate to Edit > Preferences > Advanced Tab.
Select View Certificates and click the Your Certificates tab.
Click Import and select the
.pfxfile to load. -
Enter the following URL in the address bar to browse the accessible paths for all the repositories and check their contents:
https://satellite.example.com/pulp/content/
To use the organization debug certificate with CURL, enter the following command:
$ curl -k --cert cert.pem --key key.pem \ https://satellite.example.com/pulp/content/My_Organization_Label/Library/content/dist/rhel/server/7/7Server/x86_64/os/
Ensure that the paths to
cert.pemandkey.pemare the correct absolute paths otherwise the command fails silently. Pulp uses the organization label, therefore, you must enter the organization label into the URL.
5.5. Deleting an Organization
You can delete an organization if the organization is not associated with any life cycle environments or host groups. If there are any life cycle environments or host groups associated with the organization you are about to delete, remove them by navigating to Administer > Organizations and clicking the relevant organization. Do not delete the default organization created during installation because the default organization is a placeholder for any unassociated hosts in the Satellite environment. There must be at least one organization in the environment at any given time.
From the list to the right of the name of the organization you want to delete, select Delete.
Click OK to delete the organization.
Enter the following command to retrieve the ID of the organization that you want to delete:
# hammer organization list
From the output, note the ID of the organization that you want to delete.
Enter the following command to delete an organization:
# hammer organization delete --id Organization_ID
6. Managing Locations
Locations function similar to organizations: they provide a method to group resources and assign hosts. Organizations and locations have the following conceptual differences:
Locations are based on physical or geographical settings.
Locations have a hierarchical structure.
6.1. Creating a Location
Use this procedure to create a location so that you can manage your hosts and resources by location. To use the CLI instead of the Satellite web UI, see the CLI procedure.
In the Satellite web UI, navigate to Administer > Locations.
Click New Location.
Optional: from the Parent list, select a parent location. This creates a location hierarchy.
In the Name field, enter a name for the location.
Optional: in the Description field, enter a description for the location.
Click Submit.
If you have hosts with no location assigned, add any hosts that you want to assign to the new location, then click Proceed to Edit.
Assign any infrastructure resources that you want to add to the location. This includes networking resources, installation media, kickstart templates, and other parameters. You can return to this page at any time by navigating to Administer > Locations and then selecting a location to edit.
Click Submit to save your changes.
Enter the following command to create a location:
# hammer location create \ --description "My_Location_Description" \ --name "My_Location" \ --parent-id "My_Location_Parent_ID"
6.2. Creating Multiple Locations
The following example Bash script creates three locations – London, Munich, Boston – and assigns them to the Example Organization.
ORG="Example Organization"
LOCATIONS="London Munich Boston"
for LOC in ${LOCATIONS}
do
hammer location create --name "${LOC}"
hammer location add-organization --name "${LOC}" --organization "${ORG}"
done
6.3. Setting the Location Context
A location context defines the location to use for a host and its associated resources.
The location menu is the second menu item in the menu bar, on the upper left of the Satellite web UI. If you have not selected a current location, the menu displays Any Location. Click Any location and select the location to use.
While using the CLI, include either --location "My_Location" or --location-id "My_Location_ID" as an option.
For example:
# hammer host list --location "My_Location"
This command lists hosts associated with the My_Location location.
6.4. Deleting a Location
You can delete a location if the location is not associated with any life cycle environments or host groups. If there are any life cycle environments or host groups associated with the location you are about to delete, remove them by navigating to Administer > Locations and clicking the relevant location. Do not delete the default location created during installation because the default location is a placeholder for any unassociated hosts in the Satellite environment. There must be at least one location in the environment at any given time.
Select Delete from the list to the right of the name of the location you want to delete.
Click OK to delete the location.
Enter the following command to retrieve the ID of the location that you want to delete:
# hammer location list
From the output, note the ID of the location that you want to delete.
Enter the following command to delete the location:
# hammer location delete --id Location ID
7. Managing Users and Roles
Roles define a set of permissions and access levels. Each role contains one on more permission filters that specify the actions allowed for the role. Actions are grouped according to the Resource type. Once a role has been created, users and user groups can be associated with that role. This way, you can assign the same set of permissions to large groups of users. Satellite provides a set of predefined roles and also enables creating custom roles and permission filters as described in Creating and Managing Roles.
7.1. Managing Users
As an administrator, you can create, modify and remove Satellite users. You can also configure access permissions for a user or a group of users by assigning them different roles.
7.1.1. Creating a User
Use this procedure to create a user. To use the CLI instead of the Satellite web UI, see the CLI procedure.
In the Satellite web UI, navigate to Administer > Users.
Click Create User.
In the Login field, enter a username for the user.
In the Firstname and Lastname fields, enter the real first name and last name of the user.
In the Mail field, enter the user’s email address.
In the Description field, add a description of the new user.
Select a specific language for the user from the Language list.
Select a timezone for the user from the Timezone list.
By default, Satellite Server uses the language and timezone settings of the user’s browser.
Set a password for the user:
From the Authorized by list, select the source by which the user is authenticated.
INTERNAL: to enable the user to be managed inside Satellite Server.
EXTERNAL: to configure external authentication as described in Configuring External Authentication in Installing Satellite Server in a Connected Network Environment.
Enter an initial password for the user in the Password field and the Verify field.
To create a user, enter the following command:
# hammer user create \ --auth-source-id My_Authentication_Source \ --login My_User_Name \ --mail My_User_Mail \ --organization-ids My_Organization_ID_1,My_Organization_ID_2 \ --password My_User_Password
The
--auth-source-id 1setting means that the user is authenticated internally, you can specify an external authentication source as an alternative. Add the--adminoption to grant administrator privileges to the user. Specifying organization IDs is not required, you can modify the user details later using theupdatesubcommand.
7.1.2. Assigning Roles to a User
Use this procedure to assign roles to a user. To use the CLI instead of the Satellite web UI, see the CLI procedure.
NoteIf a user account is not listed, check that you are currently viewing the correct organization. To list all the users in Satellite, click Default Organization and then Any Organization.
Click Submit.
7.1.3. Impersonating a Different User Account
Administrators can impersonate other authenticated users for testing and troubleshooting purposes by temporarily logging on to the Satellite web UI as a different user. When impersonating another user, the administrator has permissions to access exactly what the impersonated user can access in the system, including the same menus.
Ensure that you are logged on to the Satellite web UI as a user with administrator privileges for Satellite.
7.1.4. Creating an API-Only User
You can create users that can interact only with the Satellite API.
You have created a user and assigned roles to them. Note that this user must be authorized internally. For more information, see Creating a User and Assigning Roles to a User.
Log in to your Satellite as admin.
# openssl rand -hex 32
7.2. Managing SSH Keys
For information on SSH keys and SSH key creation, see Using SSH-based Authentication in Red Hat Enterprise Linux 8 Configuring basic system settings.
7.2.1. Managing SSH Keys for a User
Use this procedure to add or remove SSH keys for a user. To use the CLI instead of the Satellite web UI, see the CLI procedure.
Ensure that you are logged in to the Satellite web UI as an Admin user of Red Hat Satellite or a user with the create_ssh_key permission enabled for adding SSH key and destroy_ssh_key permission for removing a key.
Click on the SSH Keys tab.
To Add SSH key
Click Add SSH Key.
Click Submit.
To Remove SSH key
# hammer user ssh-keys add \ --user-id user_id \ --name key_name \ --key-file ~/.ssh/id_rsa.pub
# hammer user ssh-keys add \ --user-id user_id \ --name key_name \ --key ecdsa-sha2-nistp256 AAAAE2VjZHNhLXNoYTItbmlzdHAyNTYAAAAIbmlzdHAyNtYAAABBBHHS2KmNyIYa27Qaa7EHp+2l99ucGStx4P77e03ZvE3yVRJEFikpoP3MJtYYfIe8k 1/46MTIZo9CPTX4CYUHeN8= host@user
7.3. Managing Personal Access Tokens
7.3.1. Creating a Personal Access Token
Make an API request to your Satellite Server and authenticate with your Personal Access Token:
# curl https://satellite.example.com/api/status --user My_Username:My_Personal_Access_Token
200, for example:{"satellite_version":"6.12.0","result":"ok","status":200,"version":"3.5.1.10","api_version":2}If you go back to Personal Access Tokens tab, you can see the updated Last Used time next to your Personal Access Token.
7.3.2. Revoking a Personal Access Token
Make an API request to your Satellite Server and try to authenticate with the revoked Personal Access Token:
7.4. Creating and Managing User Groups
7.4.1. User Groups
With Satellite, you can assign permissions to groups of users. You can also create user groups as collections of other user groups. If using an external authentication source, you can map Satellite user groups to external user groups as described in Configuring External User Groups in Installing Satellite Server in a Connected Network Environment.
7.4.2. Creating a User Group
In the Satellite web UI, navigate to Administer > User Groups.
Click Create User group.
Click Submit.
To create a user group, enter the following command:
# hammer user-group create \ --name My_User_Group_Name \ --role-ids My_Role_ID_1,My_Role_ID_2 \ --user-ids My_User_ID_1,My_User_ID_2
7.5. Creating and Managing Roles
Satellite provides a set of predefined roles with permissions sufficient for standard tasks, as listed in Predefined Roles Available in Satellite. It is also possible to configure custom roles, and assign one or more permission filters to them. Permission filters define the actions allowed for a certain resource type. Certain Satellite plug-ins create roles automatically.
7.5.1. Creating a Role
In the Satellite web UI, navigate to Administer > Roles.
Click Create Role.
Provide a Name for the role.
7.5.2. Cloning a Role
Use the Satellite web UI to clone a role.
In the Satellite web UI, navigate to Administer > Roles and select Clone from the drop-down menu to the right of the required role.
7.5.3. Adding Permissions to a Role
Use this procedure to add permissions to a role. To use the CLI instead of the Satellite web UI, see the CLI procedure.
Depending on the Resource type selected, you can select or deselect the Unlimited and Override checkbox. The Unlimited checkbox is selected by default, which means that the permission is applied on all resources of the selected type. When you disable the Unlimited checkbox, the Search field activates. In this field you can specify further filtering with use of the Satellite search syntax. For more information, see Granular Permission Filtering. When you enable the Override checkbox, you can add additional locations and organizations to allow the role to access the resource type in the additional locations and organizations; you can also remove an already associated location and organization from the resource type to restrict access.
Click Next.
Click Submit to save changes.
Add permissions to a role:
# hammer filter create \ --permission-ids My_Permission_ID_1,My_Permission_ID_2 \ --role My_Role_Name
7.5.4. Viewing Permissions of a Role
Use the Satellite web UI to view the permissions of a role.
The Filters page contains a table of permissions assigned to a role grouped by the resource type. It is also possible to generate a complete table of permissions and actions that you can use on your Satellite system. For more information, see Creating a Complete Permission Table.
7.5.5. Creating a Complete Permission Table
Use the Satellite CLI to create a permission table.
Ensure that the required packages are installed. Execute the following command on Satellite Server:
# satellite-maintain packages install foreman-console
Start the Satellite console with the following command:
# foreman-rake console
/tmp/table.htmlfile. -
Press
Ctrl+Dto exit the Satellite console. Insert the following text at the first line of/tmp/table.html:<table border="1"><tr><td>Permission name</td><td>Actions</td><td>Resource type</td></tr>
/tmp/table.html:</table>
Open
7.6. Predefined Roles Available in Satellite
The following table provides an overview of permissions that predefined roles in Satellite grant to a user.
To view the exact set of permissions a predefined role grants, display the role in Satellite web UI as the privileged user. For more information, see Viewing Permissions of a Role.
| Role | Permissions Provided by Role |
Access Insights Admin |
Add and edit Insights rules. |
Access Insights Viewer |
View Insight reports. |
Ansible Roles Manager |
Play roles on hosts and host groups. View, destroy, and import Ansible roles. View, edit, create, destroy, and import Ansible variables. |
Ansible Tower Inventory Reader |
View facts, hosts, and host groups. |
Bookmarks manager |
Create, edit, and delete bookmarks. |
Boot disk access |
Download the boot disk. |
Compliance manager |
View, create, edit, and destroy SCAP content files, compliance policies, and tailoring files. View compliance reports. |
Compliance viewer |
Create ARF report |
Create compliance reports. |
Default role |
The set of permissions that every user is granted, irrespective of any other roles. |
Discovery Manager |
View, provision, edit, and destroy discovered hosts and manage discovery rules. |
Discovery Reader |
View hosts and discovery rules. |
Edit hosts |
View, create, edit, destroy, and build hosts. |
Edit partition tables |
View, create, edit and destroy partition tables. |
Manager |
Organization admin |
All permissions except permissions for managing organizations. An administrator role defined per organization. The role has no visibility into resources in other organizations. By cloning this role and assigning an organization, you can delegate administration of that organization to a user. |
Red Hat Access Logs |
View the log viewer and the logs. |
Remote Execution Manager |
Control which roles have permission to run infrastructure jobs. |
Remote Execution User |
Run remote execution jobs against hosts. |
Site manager |
System admin |
Users with this role can create users and assign all roles to them. Therefore, ensure to give this role only to trusted users. |
Tasks manager |
View and edit Satellite tasks. |
Tasks reader |
A role that can only view Satellite tasks. |
Viewer |
A passive role that provides the ability to view the configuration of every element of the Satellite structure, logs, reports, and statistics. |
View hosts |
A role that can only view hosts. |
Virt-who Manager |
A role with full virt-who permissions. |
Virt-who Reporter |
Upload reports generated by virt-who to Satellite. It can be used if you configure virt-who manually and require a user role that has limited virt-who permissions. |
Virt-who Viewer |
View virt-who configurations. Users with this role can deploy virt-who instances using existing virt-who configurations. |
7.7. Granular Permission Filtering
As mentioned in Adding Permissions to a Role, Red Hat Satellite provides the ability to limit the configured user permissions to selected instances of a resource type. These granular filters are queries to the Satellite database and are supported by the majority of resource types.
7.7.1. Creating a Granular Permission Filter
Use this procedure to create a granular filter. To use the CLI instead of the Satellite web UI, see the CLI procedure.
Satellite does not apply search conditions to create actions. For example, limiting the create_locations action with name = "Default Location" expression in the search field does not prevent the user from assigning a custom name to the newly created location.
field_name operator value
operator specifies the type of comparison between field_name and value. See Supported Operators for Granular Search for an overview of applicable operators.
hammer filter createcommand with the--searchoption to limit permission filters, for example:# hammer filter create \ --permission-ids 91 \ --search "name ~ ccv*" \ --role qa-user
7.7.2. Examples of Using Granular Permission Filters
hostgroup = host-editors
name ^ (XXXX, Yyyy, zzzz)
Dev
Use the Satellite web UI to create an administrative role restricted to a single organization named org-1.
7.7.3. Supported Operators for Granular Search
Operator |
Description |
and |
Combines search criteria. |
not |
Negates an expression. |
has |
Operator |
Description |
8. Configuring Email Notifications
Email notifications are created by Satellite Server periodically or after completion of certain events. The periodic notifications can be sent daily, weekly or monthly.
Satellite Server does not enable outgoing emails by default, therefore you must review your email configuration. For more information, see Configuring Satellite Server for Outgoing Emails in Installing Satellite Server in a Connected Network Environment. |
8.1. Email Notification Types
Satellite can create the following email notifications:
Audit summary: A summary of all activity audited by Satellite Server.
Host built: A notification sent when a host is built.
Host errata advisory: A summary of applicable and installable errata for hosts managed by the user.
Compliance policy summary: A summary of OpenSCAP policy reports and their results.
Promote errata: A notification sent only after a Content View promotion. It contains a summary of errata applicable and installable to hosts registered to the promoted Content View. This allows a user to monitor what updates have been applied to which hosts.
Sync errata: A notification sent only after synchronizing a repository. It contains a summary of new errata introduced by the synchronization.
For a complete list of email notification types, navigate to Administer > Users in the Satellite web UI, click the Username of the required user, and select the Email Preferences tab.
8.2. Configuring Email Notification Preferences
You can configure Satellite to send email messages to individual users registered to Satellite. Satellite sends the email to the email address that has been added to the account, if present. Users can edit the email address by clicking on their name in the top-right of the Satellite web UI and selecting My account.
Configure email notifications for a user from the Satellite web UI.
If you want to send email notifications to a group email address instead of an individual email address, create a user account with the group email address and minimal Satellite permissions, then subscribe the user account to the desired notification types. |
Click Submit.
8.3. Testing Email Delivery
Click on the username.
Verify Satellite Server’s email configuration.
8.4. Testing Email Notifications
To trigger the notifications, execute the following command:
daily
weekly
monthly
8.5. Changing Email Notification Settings for a Host
Satellite can send event notifications for a host to the host’s registered owner. You can configure Satellite to send email notifications either to an individual user or a user group. When set to a user group, all group members who are subscribed to the email type receive a message.
In the Satellite web UI, navigate to Hosts > All Hosts, locate the host that you want to view, and click Edit in the Actions column.
Go to the Additional Information tab. If the checkbox Include this host within Satellite reporting is checked, then the email notifications are enabled on that host.
9. Managing Security Compliance
Security compliance management is the ongoing process of defining security policies, auditing systems for compliance with those policies, and resolving instances of non-compliance. Any non-compliance is managed according to the organization’s configuration management policies. Security policies range in scope from host-specific to industry-wide, therefore, flexibility in their definition is required.
With Satellite, you can schedule compliance auditing and reporting on all registered hosts.
9.1. Security Content Automation Protocol
Satellite uses the Security Content Automation Protocol (SCAP) standard to define security policies.
SCAP is a framework of several specifications based on XML, such as checklists described in the Extensible Checklist Configuration Description Format (XCCDF) and vulnerabilities described in the Open Vulnerability and Assessment Language (OVAL). These specifications are encapsulated as data stream files.
Checklist items in XCCDF, also known as rules, express the desired configuration of a system item.
For example, a rule may specify that no one can log in to a host over SSH using the root user account.
Rules can be grouped into one or more XCCDF profiles, which allows multiple profiles to share a rule.
The OpenSCAP scanner tool evaluates system items on a host against the rules and generates a report in the Asset Reporting Format (ARF), which is then returned to Satellite for monitoring and analysis.
Title |
Description |
Version |
SCAP |
Security Content Automation Protocol |
1.3 |
XCCDF |
Extensible Configuration Checklist Description Format |
1.2 |
OVAL |
Open Vulnerability and Assessment Language |
5.11 |
Asset Identification |
1.1 |
ARF |
Asset Reporting Format |
1.1 |
CCE |
Common Configuration Enumeration |
5.0 |
CPE |
Common Platform Enumeration |
2.3 |
CVE |
Common Vulnerabilities and Exposures |
2.0 |
CVSS |
Common Vulnerability Scoring System |
2.0 |
For more information about SCAP, see the OpenSCAP project.
9.2. SCAP Content in Satellite
SCAP content is a SCAP data-stream file that contains implementation of compliance, configuration, or security baselines. A single data stream usually includes multiple XCCDF profiles. An XCCDF profile defines an industry standard or custom security standard against which you can evaluate compliance of host configuration in Satellite, such as Protection Profile for General Purpose Operating Systems (OSPP), Health Insurance Portability and Accountability Act (HIPAA), and PCI-DSS v3.2.1 Control Baseline for Red Hat Enterprise Linux 9. You can adapt existing XCCDF profiles according to your requirements using tailoring files.
In Satellite, you use an XCCDF profile from SCAP content and, eventually, a tailoring file, to define a compliance policy. Satellite includes default SCAP contents from SCAP Security Guide provided by the OpenSCAP project.
For more information on how to download, deploy, modify, and create your own content, see:
9.3. Compliance Policy Deployment Options
You can use one of the following methods to deploy compliance policies:
- Ansible deployment
You use an Ansible role to configure hosts for compliance scans.
- Puppet deployment
You use a Puppet class and the Puppet agent to configure hosts for compliance scans.
- Manual deployment
You manually configure hosts for compliance scans.
9.4. Configuring Compliance Policy Deployment Methods
Use one the following procedures to configure Satellite for the method that you have selected to deploy compliance policies. You will select one of these methods when you later create a compliance policy.
Import the
theforeman.foreman_scap_clientAnsible role.For more information, see Managing Configurations Using Ansible Integration in Red Hat Satellite.
Assign the created policy and the
theforeman.foreman_scap_clientAnsible role to a host or host group. -
To trigger the deployment, run the Ansible role on the host or host group either manually, or set up a recurring job by using remote execution for regular policy updates.
For more information, see Configuring and Setting Up Remote Jobs in Managing Hosts.
Ensure Puppet is enabled.
Ensure the Puppet agent is installed on hosts.
Import the Puppet environment that contains the
foreman_scap_clientPuppet module.For more information, see Managing Configurations Using Puppet Integration in Red Hat Satellite.
foreman_scap_clientPuppet class to a host or host group.Puppet triggers the deployment on the next regular run or you can run Puppet manually. Puppet runs every 30 minutes by default.
For the manual deployment method, no additional Satellite configuration is required.
For information on manual deployment, see How to set up OpenSCAP Policies using Manual Deployment option in the Red Hat Knowledgebase.
9.5. Listing Available SCAP Contents
Use this procedure to view what SCAP contents are already loaded in Satellite. To use the CLI instead of the Satellite web UI, see the CLI procedure.
Your user account has the
view_scap_contentspermission.
In the Satellite web UI, navigate to Hosts > Compliance – SCAP contents.
Run the following Hammer command on Satellite Server:
# hammer scap-content list \ --location "My_Location" \ --organization "My_Organization"
9.6. Configuring SCAP Contents
You can upload SCAP data streams and tailoring files to define compliance policies.
9.6.1. Loading the Default SCAP Contents
By loading the default SCAP contents on Satellite Server, you ensure that the data streams from the SCAP Security Guide (SSG) are loaded and assigned to all organizations and locations.
SSG is provided by the operating system of Satellite Server and installed in /usr/share/xml/scap/ssg/content/.
Note that the available data streams depend on the operating system version on which Satellite runs.
You can only use this SCAP content to scan hosts that have the same minor RHEL version as your Satellite Server.
For more information, see Getting Supported SCAP Contents for RHEL.
Your user account has a role assigned that has the
create_scap_contentspermission.
Use the following Hammer command on Satellite Server:
9.6.2. Getting Supported SCAP Contents for RHEL
You can get the latest SCAP Security Guide (SSG) for Red Hat Enterprise Linux on the Red Hat Customer Portal. You have to get a version of SSG that is designated for the minor RHEL version of your hosts.
Access the SCAP Security Guide in the package browser.
From the Version menu, select the latest SSG version for the minor version of RHEL that your hosts are running. For example, for RHEL 8.6, select a version named
*.el8_6. -
Download the package RPM.
Extract the data-stream file (
*-ds.xml) from the RPM. For example:$ rpm2cpio scap-security-guide-0.1.69-3.el8_6.noarch.rpm \ | cpio -iv --to-stdout ./usr/share/xml/scap/ssg/content/ssg-rhel8-ds.xml \ > ssg-rhel-8.6-ds.xml
Upload the data stream to Satellite. For more information, see Uploading Additional SCAP Content.
Supported versions of the SCAP Security Guide in RHEL in the Red Hat Knowledgebase
SCAP Security Guide profiles supported in RHEL 9 in Red Hat Enterprise Linux 9 Security hardening
SCAP Security Guide profiles supported in RHEL 8 in Red Hat Enterprise Linux 8 Security hardening
SCAP Security Guide profiles supported in RHEL 7 in Red Hat Enterprise Linux 7 Security Guide
9.6.3. Uploading Additional SCAP Content
You can upload additional SCAP content into Satellite Server, either content created by yourself or obtained elsewhere. Note that Red Hat only provides support for SCAP content obtained from Red Hat. To use the CLI instead of the Satellite web UI, see the CLI procedure.
create_scap_contentspermission. -
You have acquired a SCAP data-stream file.
In the Satellite web UI, navigate to Hosts > Compliance > SCAP contents.
Click Upload New SCAP Content.
Enter a title in the Title text box, such as
My SCAP Content. -
In Scap File, click Choose file, navigate to the location containing a SCAP data-stream file and click Open.
On the Locations tab, select locations.
On the Organizations tab, select organizations.
Click Submit.
If the SCAP content file is loaded successfully, a message similar to Successfully created My SCAP Content is displayed.
Place the SCAP data-stream file to a directory on your Satellite Server, such as
/usr/share/xml/scap/my_content/. -
# hammer scap-content bulk-upload --type directory \ --directory /usr/share/xml/scap/my_content/ \ --location "My_Location" \ --organization "My_Organization"
List the available SCAP contents. The list of SCAP contents includes the new title.
9.6.4. Tailoring XCCDF Profiles
You can customize existing XCCDF profiles using tailoring files without editing the original SCAP content. A single tailoring file can contain customizations of multiple XCCDF profiles.
You can create a tailoring file using the SCAP Workbench tool. For more information on using the SCAP Workbench tool, see Customizing SCAP Security Guide for your use case.
Then you can assign a tailoring file to a compliance policy to customize an XCCDF profile in the policy.
9.6.5. Uploading a Tailoring File
After uploading a tailoring file, you can apply it in a compliance policy to customize an XCCDF profile.
create_tailoring_filespermission.
In the Satellite web UI, navigate to Hosts > Compliance – Tailoring Files and click New Tailoring File.
Enter a name in the Name text box.
Click Choose File, navigate to the location containing the tailoring file and select Open.
Click Submit to upload the chosen tailoring file.
9.7. Managing Compliance Policies
A compliance policy is a scheduled audit that checks the specified hosts for compliance against a specific XCCDF profile from a SCAP content.
You specify the schedule for scans on Satellite Server and the scans are performed on hosts. When a scan completes, a report in ARF format is generated and uploaded to Satellite Server. The compliance policy makes no changes to the scanned host.
A compliance policy defines a SCAP client configuration and a cron schedule. The policy is then deployed together with the SCAP client on hosts to which the policy is assigned.
9.7.1. Creating a Compliance Policy
By creating a compliance policy, you can define and plan your security compliance requirements, and ensure that your hosts remain compliant to your security policies.
You have configured Satellite for your selected compliance policy deployment method.
You have available SCAP contents, and eventually tailoring files, in Satellite.
To verify what SCAP contents are available, see Listing Available SCAP Contents.
To upload SCAP contents and tailoring files, see Configuring SCAP Contents.
view_policiesandcreate_policiespermissions.
In the Satellite web UI, navigate to Hosts > Compliance – Policies.
Click New Policy or New Compliance Policy.
Select the deployment method: Ansible, Puppet, or Manual. Then click Next.
Enter a name for this policy, a description (optional), then click Next.
Select the SCAP Content and XCCDF Profile to be applied, then click Next.
Note that Satellite does not detect whether the selected XCCDF profile contains any rules. An empty XCCDF profile, such as the
Default XCCDF Profile, will return empty reports. -
Optional: To customize the XCCDF profile, select a Tailoring File and a XCCDF Profile in Tailoring File, then click Next.
Specify the scheduled time when the policy is to be applied. Select Weekly, Monthly, or Custom from the Period list. The Custom option allows for greater flexibility in the policy’s schedule.
If you select Weekly, also select the desired day of the week from the Weekday list.
If you select Monthly, also specify the desired day of the month in the Day of month field.
If you select Custom, enter a valid Cron expression in the Cron line field.
Select the locations to which to apply the policy, then click Next.
Select the organizations to which to apply the policy, then click Next.
Optional: Select the host groups to which to assign the policy.
Click Submit.
9.7.2. Viewing a Compliance Policy
You can preview the rules which will be applied by specific OpenSCAP content and profile combination. This is useful when you plan policies.
view_policiespermission.
In the Actions column of the required policy, click Show Guide or select it from the list.
9.7.3. Editing a Compliance Policy
In the Satellite web UI, you can edit compliance policies.
Puppet agent applies an edited policy to the host on the next run. By default, this occurs every 30 minutes. If you use Ansible, you must run the Ansible role manually again or have configured a recurring remote execution job that runs the Ansible role on hosts.
view_policiesandedit_policiespermissions.
Click the name of the required policy.
Edit the necessary attributes.
Click Submit.
9.7.4. Deleting a Compliance Policy
In the Satellite web UI, you can delete existing compliance policies.
view_policiesanddestroy_policiespermissions.
In the Actions column of the required policy, select Delete from the list.
Click OK in the confirmation message.
9.8. Deploying Compliance Policies
To deploy a compliance policy, you must install the SCAP client, update the cron schedule file, and upload the SCAP content selected in the policy onto a host.
9.8.1. Deploying a Policy in a Host Group Using Ansible
After you deploy a compliance policy in a host group using Ansible, the Ansible role installs the SCAP client and configures OpenSCAP scans on the hosts according to the selected compliance policy.
You have enabled OpenSCAP on your Capsule. For more information, see Enabling OpenSCAP on Capsule Servers in Installing Capsule Server.
You have enabled and synced the operating system repositories to Satellite, and enabled them on the hosts:
Red Hat Enterprise Linux 9 for x86_64 - BaseOS and Appstream (RPMs) –
rhel-9-for-x86_64-baseos-rpmsandrhel-9-for-x86_64-appstream-rpms -
Red Hat Enterprise Linux 8 for x86_64 - BaseOS and Appstream (RPMs) –
rhel-8-for-x86_64-baseos-rpmsandrhel-8-for-x86_64-appstream-rpms -
Red Hat Enterprise Linux 7 Server and Extras (RPMs) –
rhel-7-server-rpmsandrhel-7-server-extras-rpms
You have enabled and synced the Satellite Client 6 repository to Satellite, and enabled it on the hosts.
You have created a compliance policy with the Ansible deployment option and assigned the host group.
In the Satellite web UI, navigate to Configure > Host Groups.
Click the host group that you want to configure for OpenSCAP reporting.
From the OpenSCAP Capsule list, select the Capsule with OpenSCAP enabled that you want to use.
On the Ansible Roles tab, assign the
theforeman.foreman_scap_clientAnsible role. -
Optional: On the Parameters tab, configure any Ansible variables of the role.
In the row of the required host group, navigate to the Actions column and select Run all Ansible roles.
9.8.2. Deploying a Policy on a Host Using Ansible
After you deploy a compliance policy on a host using Ansible, the Ansible role installs the SCAP client and configures OpenSCAP scans on the host according to the selected compliance policy.
You have enabled and synced the Satellite Client 6 repository to Satellite, and enabled it on the host.
You have created a compliance policy with the Ansible deployment option.
In the Satellite web UI, navigate to Hosts > All Hosts, and select Edit on the host you want to configure for OpenSCAP reporting.
On the Ansible Roles tab, add the
Click the Hosts breadcrumbs link to navigate back to the host index page.
Select the host or hosts to which you want to add the policy.
Click Select Action.
Select Assign Compliance Policy from the list.
In the Assign Compliance Policy window, select Remember hosts selection for the next bulk action.
Select the required policy from the list of available policies and click Submit.
Select Run all Ansible roles from the list.
9.8.3. Deploying a Policy in a Host Group Using Puppet
After you deploy a compliance policy in a host group using Puppet, the Puppet agent installs the SCAP client and configures OpenSCAP scans on the hosts on the next Puppet run according to the selected compliance policy.
You have created a compliance policy with the Puppet deployment option and assigned the host group.
In the Environment list, select the Puppet environment that contains the
foreman_scap_client*Puppet classes. -
In the OpenSCAP Capsule list, select the Capsule with OpenSCAP enabled that you want to use.
On the Puppet ENC tab, add the
foreman_scap_clientPuppet class. -
Optional: Configure any Puppet Class Parameters.
9.8.4. Deploying a Policy on a Host Using Puppet
After you deploy a compliance policy on a host using Puppet, the Puppet agent installs the SCAP client and configures OpenSCAP scans on the host on the next Puppet run according to the selected compliance policy.
You have created a compliance policy with the Puppet deployment option.
From the Environment list, select the Puppet environment that contains the
foreman_scap_clientandforeman_scap_client::paramsPuppet classes. -
9.9. Running a Security Compliance Scan on Demand
Hosts perform OpenSCAP scans regularly by the CRON schedule defined in the compliance policies assigned to hosts. However, you can also run a scan on a host for all configured compliance policies manually at any time.
view_hosts,create_job_invocations, andview_job_invocationspermissions. -
You have created a compliance policy and deployed it on the host.
For more information about managing policies, see Managing Compliance Policies.
For more information about deploying policies, see Deploying Compliance Policies.
Navigate to Hosts > All Hosts.
Click the hostname of the required host.
On the host details page, expand the Schedule a job dropdown menu.
Select Run OpenSCAP scan.
In the host details overview, locate the Recent jobs card.
Select the Running tab. Unless the job has already finished, the table shows a job called Run scan for all OpenSCAP policies.
On the Recent jobs card, select the Finished tab.
If the job has finished successfully, you should see the succeeded status in the row of the job.
Optional: Click the job name to review invocation details.
9.10. Monitoring Compliance
With Satellite, you can centralize compliance monitoring and management. A compliance dashboard provides an overview of compliance of hosts and the ability to view details for each host within the scope of that policy. Compliance reports provide a detailed analysis of compliance of each host with the applicable policy. With this information, you can evaluate the risks presented by each host and manage the resources required to bring hosts into compliance. By monitoring compliance with SCAP, you can verify policy compliance and detect changes in compliance.
9.10.1. Searching Compliance Reports
Use the Compliance Reports search field to filter the list of available reports on any subset of hosts.
In the Satellite web UI, navigate to Hosts > Reports.
Optional: To see a list of available search parameters, click the empty Search field.
Enter the search query in the Search field and click Search. The search query is case insensitive.
- Find all compliance reports for which more than five rules failed
failed > 5
- Find all compliance reports created after January 1, 2023, for hosts with hostnames that contain
prod-
host ~ prod- AND date > "Jan 1, 2023"
- Find all reports generated by the
rhel7_auditcompliance policy from an hour ago
- Find reports that pass an XCCDF rule
- Find reports that fail an XCCDF rule
- Find reports that have a result different than fail or pass for an XCCDF rule
You can create complex queries with the following logical operators:
and,notandhas. For more information about logical operators, see Supported Operators for Granular Search in Administering Red Hat Satellite. -
You cannot use regular expressions in a search query. However, you can use multiple fields in a single search expression. For more information about all available search operators, see Supported Operators for Granular Search in Administering Red Hat Satellite.
You can bookmark a search to reuse the same search query. For more information, see Creating Bookmarks in Administering Red Hat Satellite.
9.10.2. Compliance Email Notifications
Satellite Server sends an OpenSCAP Summary email to all users who subscribe to the Compliance policy summary email notifications. For more information on subscribing to email notifications, see Configuring Email Notification Preferences.
Each time a policy is run, Satellite checks the results against the previous run, noting any changes between them. The email is sent according to the frequency requested by each subscriber, providing a summary of each policy and its most recent result.
9.10.3. Viewing Compliance Policy Statistics
You can view a compliance policy dashboard to verify compliance reports of a particular policy. The compliance policy dashboard provides a statistical summary of compliance of hosts and the ability to view report details for each host within the scope of that policy.
Consider prioritizing the following hosts when viewing compliance reports:
Hosts which were evaluated as
Failed -
Hosts labelled as
Never auditedbecause their status is unknown
In the Satellite web UI, navigate to Hosts > Policies.
In the row of the required policy, navigate to the Actions column and click Dashboard.
9.10.4. Examining Hosts per Rule Compliance Result
You can examine a simplified report and use policy rules to list hosts that have a certain compliance result, such as failing a particular rule.
view_arf_reportsandview_hostspermissions.
In the Reported At column, navigate to the report of the required host and compliance policy, and click the time link.
Satellite displays a simplified list of policy rules with the results of the scan.
Optional: Filter the rules by check result. From the Show log messages dropdown list, select one of the following filters:
Failed and othered – to view rules that have failed or have not been checked during the scan,
Failed only – to view only rules that have failed.
Optional: Examine the details of the rule. In the Message column, click the icon next to the name of the rule.
In the row of the required rule, navigate to the Actions column and click Hosts failing this rule.
9.10.5. Examining Compliance Failures of a Host
You can examine a full compliance report, determine why a host failed compliance on a rule, and, in some cases, see how to remediate a case of non-compliance.
Warning
Do not implement any of the recommended remedial actions or scripts without first testing them in a non-production environment. Remediation might render the system non-functional. |
Introduction
Evaluation Characteristics
Compliance and Scoring
Rule Overview
In the Satellite web UI, navigate to Hosts > Reports to list all compliance reports.
In the row of the required host, navigate to the Actions column and click Full Report to view the complete details of an evaluation report.
Navigate to the Evaluation Characteristics area to review basic details about the evaluation of the host against a specific profile.
Navigate to the Compliance and Scoring area to review evaluation statistics and the host compliance score.
Navigate to the Rule Overview to examine the rules.
Optional: Deselect the check statuses that you want to hide, such as pass, notapplicable, or fixed.
Optional: From the Group rule by dropdown menu, select the criterion for the grouping of rules, such as Severity.
Optional: Enter a search string into the search field to filter rules by title. The search is case insensitive and applied dynamically as you type.
Click the title of a rule to inspect further result details:
A description of the rule with instructions for bringing the host into compliance if available.
The rationale for the rule.
In some cases, a remediation script.
9.10.6. Deleting a Compliance Report
You can delete compliance reports on your Satellite.
view_arf_reportsanddestroy_arf_reportspermissions.
In the Compliance Reports window, identify the policy that you want to delete and, on the right of the policy’s name, select Delete.
Click OK.
9.10.7. Deleting Multiple Compliance Reports
You can delete multiple compliance policies simultaneously. However, in the Satellite web UI, compliance policies are paginated, so you must delete one page of reports at a time. If you want to delete all OpenSCAP reports, use the script in Deleting OpenSCAP Reports in the API Guide.
In the Compliance Reports window, select the compliance reports that you want to delete.
In the upper right of the list, select Delete reports.
Repeat these steps for as many pages as you want to delete.
10. Backing Up Satellite Server and Capsule Server
You can back up your Satellite deployment to ensure the continuity of your Red Hat Satellite deployment and associated data in the event of a disaster. If your deployment uses custom configurations, you must consider how to handle these custom configurations when you plan your backup and disaster recovery policy.
If you create a new instance of the Satellite Server, decomission the old instances after restoring the backup. Cloned instances are not supposed to run in parallel in a production environment. |
To create a backup of your Satellite Server or Capsule Server and all associated data, use the satellite-maintain backup command.
Satellite services are unavailable during the backup.
You can schedule a backup using cron.
For more information, see the Example of a Weekly Full Backup Followed by Daily Incremental Backups.
During offline or snapshot backups, the services are inactive and Satellite is in a maintenance mode. All the traffic from outside on port 443 is rejected by a firewall to ensure there are no modifications triggered.
A backup contains sensitive information from the /root/ssl-build directory.
You can also use conventional backup methods. For more information, see Recovering and restoring a system in Red Hat Enterprise Linux 8 Configuring basic system settings.
If you plan to use the |
When creating a snapshot or conventional backup, you must stop all services as follows:
Start the services after creating a snapshot or conventional backup:
10.1. Estimating the Size of a Backup
The full backup creates uncompressed archives of PostgreSQL and Pulp database files, and Satellite configuration files. Compression occurs after the archives are created to decrease the time when Satellite services are unavailable.
Uncompressed Satellite database and configuration files
Compressed Satellite database and configuration files
Enter the
ducommand to estimate the size of uncompressed directories containing Satellite database and configuration files:# du -sh /var/lib/pgsql/data /var/lib/pulp 100G /var/lib/pgsql/data 100G /var/lib/pulp # du -csh /var/lib/qpidd /var/lib/tftpboot /etc /root/ssl-build \ /var/www/html/pub /opt/puppetlabs 886M /var/lib/qpidd 16M /var/lib/tftpboot 37M /etc 900K /root/ssl-build 100K /var/www/html/pub 2M /opt/puppetlabs 942M total
Table 5. Backup Data Compression Ratio Data type Directory Ratio Example results PostgreSQL database files
/var/lib/pgsql/data80 – 85%
100 GB → 20 GB
Pulp RPM files
/var/lib/pulp(not compressed)
100 GB
Configuration files
/var/lib/qpidd
/var/lib/tftpboot
/etc
/root/ssl-build
/var/www/html/pub
/opt/puppetlabs85%
942 MB → 141 MB
10.2. Performing a Full Backup of Satellite Server or Capsule Server
Red Hat Satellite uses the satellite-maintain backup command to make backups.
There are three main methods of backing up Satellite Server:
Offline backup
Online backup
Snapshot backups
# satellite-maintain backup offline --help
# satellite-maintain backup online --help
# satellite-maintain backup snapshot --help
The satellite-maintain backup command creates a time-stamped subdirectory in the backup directory that you specify.
The satellite-maintain backup command does not overwrite backups, therefore you must select the correct directory or subdirectory when restoring from a backup or an incremental backup.
The satellite-maintain backup command stops and restarts services as required.
When you run the satellite-maintain backup offline command, the following default backup directories are created:
satellite-backupon Satellite -
foreman-proxy-backupon Capsule
You can use the satellite-maintain backup command to back up remote databases.
You can use both online and offline methods to back up remote databases, but if you use offline methods, such as snapshot, the satellite-maintain backup command performs a database dump.
Ensure that your backup location has sufficient available disk space to store the backup. For more information, see Estimating the Size of a Backup.
Warning
Request other users of Satellite Server or Capsule Server to save any changes and warn them that Satellite services are unavailable for the duration of the backup. Ensure no other tasks are scheduled for the same time as the backup. |
On Satellite Server, enter the following command:
# satellite-maintain backup offline /var/satellite-backup
On Capsule Server, enter the following command:
# satellite-maintain backup offline /var/foreman-proxy-backup
10.3. Performing a Backup without Pulp Content
Warning
# satellite-maintain backup offline --skip-pulp-content /var/backup_directory
10.4. Performing an Incremental Backup
Warning
To perform a full offline backup, enter the following command:
# satellite-maintain backup offline /var/backup_directory
To create a directory within your backup directory to store the first incremental back up, enter the
satellite-maintain backupcommand with the--incrementaloption:# satellite-maintain backup offline --incremental /var/backup_directory/full_backup /var/backup_directory
To create the second incremental backup, enter the
satellite-maintain backupcommand with the--incrementaloption and include the path to the first incremental backup to indicate the starting point for the next increment. This creates a directory for the second incremental backup in your backup directory:# satellite-maintain backup offline --incremental /var/backup_directory/first_incremental_backup /var/backup_directory
10.5. Example of a Weekly Full Backup Followed by Daily Incremental Backups
#!/bin/bash -e PATH=/sbin:/bin:/usr/sbin:/usr/bin DESTINATION=/var/backup_directory if [[ $(date +%w) == 0 ]]; then satellite-maintain backup offline --assumeyes $DESTINATION else LAST=$(ls -td -- $DESTINATION/*/ | head -n 1) satellite-maintain backup offline --assumeyes --incremental "$LAST" $DESTINATION fi exit 0
Note that the satellite-maintain backup command requires /sbin and /usr/sbin directories to be in PATH and the --assumeyes option is used to skip the confirmation prompt.
10.6. Performing an Online Backup
When performing an online backup, if there are procedures affecting the Pulp database, the Pulp part of the backup procedure repeats until it is no longer being altered. Because the backup of the Pulp database is the most time consuming part of backing up Satellite, if you make a change that alters the Pulp database during this time, the backup procedure keeps restarting.
Warning
To perform an online backup, enter the following command:
# satellite-maintain backup online /var/backup_directory
10.7. Performing a Snapshot Backup
The snapshot backup method is faster than a full offline backup and therefore reduces Satellite downtime.
satellite-maintain backup snapshot -h
Warning
Request other Satellite Server or Capsule Server users to save any changes and warn them that Satellite services are unavailable for the duration of the backup. Ensure no other tasks are scheduled for the same time as the backup. |
The system uses LVM for the directories that you snapshot:
/var/lib/pulp/, and/var/lib/pgsql. -
The free disk space in the relevant volume group (VG) is three times the size of the snapshot. More precisely, the VG must have enough space unreserved by the member logical volumes (LVs) to accommodate new snapshots. In addition, one of the LVs must have enough free space for the backup directory.
The target backup directory is on a different LV than the directories that you snapshot.
To perform a snapshot backup, enter the
satellite-maintain backup snapshotcommand:# satellite-maintain backup snapshot /var/backup_directory
The satellite-maintain backup snapshot command creates snapshots when the services are active, and stops all services which can impact the backup.
This makes the maintenance window shorter.
After the successful snapshot, all services are restarted and LVM snapshots are removed.
10.8. White-listing and Skipping Steps When Performing Backups
A backup using the satellite-maintain backup command proceeds in a sequence of steps.
To skip part of the backup add the --whitelist option to the command and add the step label that you want to omit.
To display a list of available step labels, enter the following command:
# satellite-maintain advanced procedure run -h
To skip a step of the backup, enter the
satellite-maintain backupcommand with the--whitelistoption. For example:# satellite-maintain backup online --whitelist backup-metadata -y /var/backup_directory
11. Restoring Satellite Server or Capsule Server from a Backup
You can restore Satellite Server or Capsule Server from the backup data that you create as part of Backing Up Satellite Server and Capsule Server. This process outlines how to restore the backup on the same server that generated the backup, and all data covered by the backup is deleted on the target system. If the original system is unavailable, provision a system with the same configuration settings and host name.
11.1. Restoring from a Full Backup
Use this procedure to restore Red Hat Satellite or Capsule Server from a full backup. When the restore process completes, all processes are online, and all databases and system configuration revert to the state at the time of the backup.
Ensure that you are restoring to the correct instance. The Red Hat Satellite instance must have the same host name, configuration, and be the same minor version (X.Y) as the original system.
Ensure that you have enough space to store this data on the base system of Satellite Server or Capsule Server as well as enough space after the restoration to contain all the data in the
/etc/and/var/directories contained within the backup.To check the space used by a directory, enter the following command:
# df -h /var/backup_directory
Add the
# restorecon -Rv /
Choose the appropriate method to install Satellite or Capsule:
To install Satellite Server from a connected network, follow the procedures in Installing Satellite Server in a Connected Network Environment.
To install Satellite Server from a disconnected network, follow the procedures in Installing Satellite Server in a Disconnected Network Environment.
To install a Capsule Server, follow the procedures in Installing Capsule Server.
Copy the backup data to Satellite Server’s local file system. Use
/var/or/var/tmp/. -
Run the restoration script.
# satellite-maintain restore /var/backup_directory
For troubleshooting, you can check
/var/log/foreman/production.logand/var/log/messages.
11.2. Restoring from Incremental Backups
Use this procedure to restore Satellite or Capsule Server from incremental backups. If you have multiple branches of incremental backups, select your full backup and each incremental backup for the branch you want to restore, in chronological order.
Restore the last full backup using the instructions in Restoring from a Full Backup.
Remove the full backup data from Satellite Server’s local file system, for example,
/var/or/var/tmp/. -
Copy the incremental backup data to Satellite Server’s local file system, for example,
/var/or/var/tmp/. -
# satellite-maintain restore /var/backup_directory/FIRST_INCREMENTAL # satellite-maintain restore /var/backup_directory/SECOND_INCREMENTAL
11.3. Backup and Restore Capsule Server Using a Virtual Machine Snapshot
If your Capsule Server is a virtual machine, you can restore it from a snapshot. Creating weekly snapshots to restore from is recommended. In the event of failure, you can install, or configure a new Capsule Server, and then synchronize the database content from Satellite Server.
If required, deploy a new Capsule Server, ensuring the host name is the same as before, and then install the Capsule certificates. You may still have them on Satellite Server, the package name ends in -certs.tar, alternately create new ones. Follow the procedures in Installing Capsule Server until you can confirm, in the Satellite web UI, that Capsule Server is connected to Satellite Server. Then use the procedure Synchronizing an External Capsule to synchronize from Satellite.
11.3.1. Synchronizing an External Capsule
Synchronize an external Capsule with Satellite.
To synchronize an external Capsule, select the relevant organization and location in the Satellite web UI, or choose Any Organization and Any Location.
In the Satellite web UI, navigate to Infrastructure > Capsules and click the name of the Capsule to synchronize.
On the Overview tab, select Synchronize.
12. Renaming Satellite Server or Capsule Server
To rename Satellite Server or Capsule Server, use the satellite-change-hostname script.
When changing the domain name of your Satellite Server or Capsule Server, update the hostname using |
12.1. Renaming Satellite Server
The host name of Satellite Server is used by Satellite Server components, all Capsule Servers, and hosts registered to it for communication. This procedure ensures that in addition to renaming Satellite Server, you also update all references to point to the new host name.
Warning
Renaming your Satellite Server host shuts down all Satellite services on that host. The services restart after the renaming is complete. |
Back up your Satellite Server before changing its host name. If you fail to successfully rename it, restore it from the backup. For more information, see Backing Up Satellite Server and Capsule Server.
Run the
hostnameandhostname -fcommands on Satellite Server. If both commands do not return the FQDN of Satellite Server, thesatellite-change-hostnamescript will fail to complete.If the
hostnamecommand returns the shortname of Satellite Server instead of the FQDN, usehostnamectl set-hostname My_Old_FQDNto set the old FQDN correctly before using thesatellite-change-hostnamescript. -
If Satellite Server has a custom SSL certificate installed, obtain a new certificate for the new FQDN of the host. For more information, see Configuring Satellite Server with a Custom SSL Certificate in Installing Satellite Server in a Connected Network Environment.
On Satellite Server, run the
satellite-change-hostnamescript, and provide the new host name. Choose one of the following methods:-
If your Satellite Server is installed with the default self-signed SSL certificates, enter the following command:
# satellite-change-hostname new-satellite \ --username admin \ --password password
If your Satellite Server is installed with custom SSL certificates:
# satellite-change-hostname new-satellite \ --username admin \ --password password \ --custom-cert "/root/ownca/test.com/test.com.crt" \ --custom-key "/root/ownca/test.com/test.com.key"
If you have created a custom SSL certificate for the new Satellite Server host name, run the Satellite installation script to install the certificate. For more information about installing a custom SSL certificate, see Deploying a Custom SSL Certificate to Satellite Server in Installing Satellite Server in a Connected Network Environment.
Reregister all Satellite hosts. For more information, see Registering Hosts in Managing Hosts.
On all Capsule Servers, run the Satellite installation script to update references to the new host name:
# satellite-installer \ --foreman-proxy-foreman-base-url https://new-satellite.example.com \ --foreman-proxy-trusted-hosts new-satellite.example.com \ --puppet-server-foreman-url https://new-satellite.example.com
On Satellite Server, list all Capsule Servers:
# hammer capsule list
On Satellite Server, synchronize content for each Capsule Server:
# hammer capsule content synchronize \ --id Mycapsule_ID_
If you use the virt-who agent, update the virt-who configuration files with the new host name. For more information, see Modifying a virt-who Configuration in Configuring Virtual Machine Subscriptions in Red Hat Satellite.
If you use external authentication, reconfigure Satellite Server for external authentication after you run the
satellite-change-hostnamescript. For more information, see Configuring External Authentication in Installing Satellite Server in a Connected Network Environment.
12.2. Renaming Capsule Server
The host name of Capsule Server is referenced by Satellite Server components and all hosts registered to it. This procedure ensures that in addition to renaming Capsule Server, you also update all references to the new host name.
Warning
Renaming your Capsule Server host shuts down all Satellite services on that host. The services restart after the renaming is complete. |
Back up your Capsule Server before renaming. If you fail to successfully rename it, restore it from the backup. For more information, see Backing Up Satellite Server and Capsule Server.
Run the
hostnameandhostname -fcommands on Capsule Server. If both commands do not return the FQDN of Capsule Server, thesatellite-change-hostnamescript will fail to complete.If the
hostnamecommand returns the shortname of Capsule Server instead of the FQDN, usehostnamectl set-hostname My_Old_FQDNto set the old FQDN correctly before attempting to use thesatellite-change-hostnamescript.
On Satellite Server, generate a new certificates archive file for Capsule Server.
If you are using the default SSL certificate, enter the following command:
# capsule-certs-generate \ --foreman-proxy-fqdn new-capsule.example.com \ --certs-tar /root/new-capsule.example.com-certs.tar
.tarfile. -
If you are using a custom SSL certificate, create a new SSL certificate for Capsule Server. For more information, see Configuring Capsule Server with a Custom SSL Certificate in Installing Capsule Server.
On Satellite Server, copy the certificates archive file to Capsule Server. For example, to copy the archive file to the
rootuser’s home directory:# scp /root/new-capsule.example.com-certs.tar root@capsule.example.com:
On Capsule Server, run the
satellite-change-hostnamescript and provide the host’s new name, Satellite credentials, and certificates archive file name.# satellite-change-hostname new-capsule.example.com --username admin \ --password password \ --certs-tar /root/new-capsule.example.com-certs.tar
.tarfile. -
If you have created a custom certificate for Capsule Server, deploy the certificate on Capsule Server by entering the
satellite-installercommand that thecapsule-certs-generatecommand returned in a previous step. For more information, see Deploying a Custom SSL Certificate to Capsule Server in Installing Capsule Server. -
On all Capsule clients, enter the following commands to reinstall the bootstrap RPM, reregister clients, and refresh their subscriptions.
You can use the remote execution feature to perform this step. For more information, see Configuring and Setting up Remote Jobs in Managing Hosts.
# dnf remove katello-ca-consumer* # dnf install http://new-capsule.example.com/pub/katello-ca-consumer-latest.noarch.rpm # subscription-manager register --org="My_Organization" \ --environment="Library" \ --force # subscription-manager refresh
Update the Capsule host name in the Satellite web UI.
In the Satellite web UI, navigate to Infrastructure > Capsules.
Locate Capsule Server in the list, and click Edit.
Edit the Name and URL fields to match Capsule Server’s new host name, then click Submit.
On your DNS server, add a record for the new hostname of your Capsule Server, and delete the record of the previous host name.
13. Maintaining Satellite Server
This chapter provides information on how to maintain a Satellite Server, including information on how to work with audit records, how to clean unused tasks, and how to recover Pulp from a full disk.
13.1. Deleting Audit Records Manually
Number_Of_Days.
13.2. Deleting Audit Records Automatically
This setting is empty by default, meaning Satellite does not automatically delete the audit records.
In the Satellite web UI, navigate to Administer > Settings.
Set the value of the setting to the number of days after which you want Satellite to delete the audit records.
13.3. Anonymizing Audit Records
You can use the foreman-rake audits:anonymize command to remove any user account or IP information while maintaining the audit records in the database.
You can also use a cron job to schedule anonymizing the audit records at the set interval that you want.
By default, using the foreman-rake audits:anonymize command anonymizes audit records that are older than 90 days.
You can specify the number of days to keep the audit records by adding the days option and add the number of days.
13.4. Deleting Report Records
Report records are created automatically in Satellite.
You can use the foreman-rake reports:expire command to remove reports at any time.
You can also use a cron job to schedule report record deletions at the set interval that you want.
By default, using the foreman-rake reports:expire command removes report records that are older than 90 days.
You can specify the number of days to keep the report records by adding the days option and add the number of days.
13.5. Configuring the Cleaning Unused Tasks Feature
Satellite performs regular cleaning to reduce disc space in the database and limit the rate of disk growth. As a result, Satellite backup completes faster and overall performance is higher.
By default, Satellite executes a cron job that cleans tasks every day at 19:45. Satellite removes the following tasks during the cleaning:
To configure the time at which Satellite runs the cron job, set the
--foreman-plugin-tasks-cron-lineparameter to the time you want in cron format. For example, to schedule the cron job to run every day at 15:00, enter the following command:# satellite-installer --foreman-plugin-tasks-cron-line "00 15 * * *"
To configure the period after which Satellite deletes the tasks, edit the
To disable regular task cleanup on Satellite, enter the following command:
# satellite-installer --foreman-plugin-tasks-automatic-cleanup false
To reenable regular task cleanup on Satellite, enter the following command:
# satellite-installer --foreman-plugin-tasks-automatic-cleanup true
13.6. Deleting Task Records
Task records are created automatically in Satellite.
You can use the foreman-rake foreman_tasks:cleanup command to remove tasks at any time.
You can also use a cron job to schedule Task record deletions at the set interval that you want.
13.7. Deleting a Task by ID
Connect to your Satellite Server using SSH:
# ssh root@satellite.example.com
Optional: View the task:
Delete the task:
Optional: Ensure the task has been removed from Satellite Server:
13.8. Recovering from a Full Disk
Ensure that the LV with the
Remove orphaned content:
Change the download policy from Immediate to On Demand for as many repositories as possible and remove already downloaded packages. See the Red Hat Knowledgebase solution How to change syncing policy for Repositories on Satellite from "Immediate" to "On-Demand" on the Red Hat Customer Portal for instructions.
/var/lib/pulpdirectory on it. For more information, see Growing a logical volume and file system in Red Hat Enterprise Linux 8 Configuring and managing logical volumes.NoteIf you use an untypical file system (other than for example ext3, ext4, or xfs), you might need to unmount the file system so that it is not in use. In that case, complete the following steps:
Stop Satellite services:
Start Satellite services:
13.9. Managing Packages on the Base Operating System of Satellite Server or Capsule Server
To install and update packages on the Satellite Server or Capsule Server base operating system, you must enter the satellite-maintain packages command.
Satellite prevents users from installing and updating packages with yum because yum might also update the packages related to Satellite Server or Capsule Server and result in system inconsistency.
The |
You can manage packages using the satellite-maintain packages command as follows:
To install packages on Satellite Server or Capsule Server:
# satellite-maintain packages install package_1 package_2
To check for available package updates on Satellite Server or Capsule Server:
# satellite-maintain packages check-update
To update all packages on Satellite Server or Capsule Server:
# satellite-maintain packages update
To update specific packages on Satellite Server or Capsule Server:
# satellite-maintain packages update package_1 package_2
Updating packages individually can lead to package inconsistencies on Satellite Server or Capsule Server. For more information about updating packages on Satellite Server, see Updating Satellite Server to the Next Minor Version in Upgrading and Updating Red Hat Satellite.
13.10. Reclaiming PostgreSQL Space
The PostgreSQL database can use a large amount of disk space especially in heavily loaded deployments. Use this procedure to reclaim some of this disk space on Satellite.
postgresqlservice:# satellite-maintain service stop --exclude postgresql
Switch to the
13.11. Reclaiming Space From On Demand Repositories
If you set the download policy to on demand, Satellite downloads packages only when the clients request them. You can clean up these packages to reclaim space.
In the Satellite web UI, navigate to Content > Products.
Select a product.
Select the product name.
Select the Capsule Server.
Click Reclaim space.
14. Renewing the Custom SSL Certificate
This chapter provides information on how to renew the custom SSL certificate on Satellite Server as well as on Capsule Server.
14.1. Renewing a Custom SSL Certificate on Satellite Server
Use this procedure to update your custom SSL certificate for Satellite Server.
You must create a new Certificate Signing Request (CSR) and send it to the Certificate Authority to sign the certificate. Refer to the Configuring Satellite Server with a Custom SSL Certificate guide before creating a new CSR because the Server certificate must have X.509 v3
Key UsageandExtended Key Usageextensions with required values. In return, you will receive the Satellite Server certificate and CA bundle.
Before deploying a renewed custom certificate on your Satellite Server, validate the custom SSL input files. Note that for the
katello-certs-checkcommand to work correctly, Common Name (CN) in the certificate must match the FQDN of Satellite Server:# katello-certs-check -t satellite \ -b /root/satellite_cert/ca_cert_bundle.pem \ -c /root/satellite_cert/satellite_cert.pem \ -k /root/satellite_cert/satellite_cert_key.pem
If the command is successful, it returns the following
satellite-installercommand. You can use this command to deploy the renewed CA certificates to Satellite Server:# satellite-installer --scenario satellite \ --certs-server-cert "/root/satellite_cert/satellite_cert.pem" \ --certs-server-key "/root/satellite_cert/satellite_key.pem" \ --certs-server-ca-cert "/root/satellite_cert/ca_cert_bundle.pem" \ --certs-update-server \ --certs-update-server-ca
Do not delete the certificate files after you deploy the certificate. They are required when upgrading Satellite Server. |
If a new consumer package |
Access the Satellite web UI from your local machine. For example, https://satellite.example.com.
14.2. Renewing a Custom SSL certificate on Capsule Server
Use this procedure to update your custom SSL certificate for Capsule Server.
The satellite-installer command, which the capsule-certs-generate command returns, is unique to each Capsule Server.
You cannot use the same command on more than one Capsule Server.
You must create a new Certificate Signing Request and send it to the Certificate Authority to sign the certificate. Refer to the Configuring Satellite Server with a Custom SSL Certificate guide before creating a new CSR because the Satellite Server certificate must have X.509 v3
Key UsageandExtended Key Usageextensions with required values. In return, you will receive the Capsule Server certificate and CA bundle.
On your Satellite Server, validate the custom SSL certificate input files:
# katello-certs-check -t capsule \ -b /root/capsule_cert/ca_cert_bundle.pem \ -c /root/capsule_cert/capsule_cert.pem \ -k /root/capsule_cert/capsule_cert_key.pem
On your Satellite Server, generate the certificate archive file for your Capsule Server:
capsule-certs-generate --foreman-proxy-fqdn "capsule.example.com" \ --certs-tar "/root/My_Certificates/capsule.example.com-certs.tar" \ --server-cert "/root/My_Certificates/capsule_cert.pem" \ --server-key "/root/My_Certificates/capsule_cert_key.pem" \ --server-ca-cert "/root/My_Certificates/ca_cert_bundle.pem" \ --certs-update-server
On your Satellite Server, copy the certificate archive file to your Capsule Server:
# scp /root/My_Certificates/capsule.example.com-certs.tar user@capsule.example.com:
Retain a copy of the
satellite-installercommand that thecapsule-certs-generatecommand returns for deploying the certificate to your Capsule Server. -
Deploy the certificate on your Capsule Server using the
satellite-installercommand returned by thecapsule-certs-generatecommand:# satellite-installer --scenario capsule \ --foreman-proxy-register-in-foreman "true" \ --foreman-proxy-foreman-base-url "https://satellite.example.com" \ --certs-tar-file "/root/My_Certificates/capsule.example.com-certs.tar" \ --certs-update-server
Do not delete the certificate archive file on the Capsule Server after you deploy the certificate. They are required when upgrading Capsule Server. |
15. Logging and Reporting Problems
This chapter provides information on how to log and report problems in Satellite, including information on relevant log files, how to enable debug logging, how to open a support case and attach the relevant log tar files, and how to access support cases within the Satellite web UI.
You can use the log files and other information described in this chapter to do your own troubleshooting, or you can capture these and many more files, as well as diagnostic and configuration information, to send to Red Hat Support if you need further assistance.
For more information about Satellite logging settings, use satellite-installer with the --full-help option:
# satellite-installer --full-help | grep logging
15.1. Enabling Debug Logging
Debug logging provides the most detailed log information and can help with troubleshooting issues that can arise with Satellite and its components. In the Satellite CLI, enable debug logging to log detailed debugging information for Satellite.
To enable debug logging, enter the following command:
# satellite-installer --foreman-logging-level debug
# satellite-installer --reset-foreman-logging-level
15.2. Increasing the Logging Levels to Help with Debugging
By default, Satellite comes with :INFO level logging enabled.
You can increase or decrease the log levels on your Satellite.
# hammer admin logging --all --level-debug # satellite-maintain service restart
INFO# hammer admin logging --all --level-production # satellite-maintain service restart
# hammer admin logging --list -----------|-------------------------------------|------------------------------------- COMPONENT | AUTO-DETECTED BY EXISTENCE OF | DESTINATIONS -----------|-------------------------------------|------------------------------------- dhcpd | /etc/dhcp/dhcpd.conf | syslog /var/log/dhcpd-debug.log postgresql | /var/lib/pgsql/data/postgresql.conf | syslog /var/lib/pgsql/data/pg_log/ proxy | /etc/foreman-proxy/settings.yml | /var/log/foreman-proxy/proxy.log qpidd | /etc/qpid/qpidd.conf | syslog rails | /etc/foreman/settings.yaml | /var/log/foreman/production.log tomcat | /etc/candlepin/candlepin.conf | /var/log/candlepin/ /var/log/tomcat/ virt-who | /etc/sysconfig/virt-who | syslog -----------|-------------------------------------|-------------------------------------
15.2.1. Increasing the Logging Level For Hammer
You can find the log for Hammer in ~/.hammer/log/hammer.log.
Edit /etc/hammer/cli_config.yml and set the :log_level::
:log_level: 'debug'
15.2.2. Increasing the Logging Level On Capsule
You can find the log for Capsule in /var/log/foreman-proxy/proxy.log.
Uncomment the DEBUG line in /etc/foreman-proxy/settings.yml:
:log_level: DEBUG
Caution
Running the installer will revert this change back. |
15.2.3. Increasing the Logging Level For Candlepin
You can find the log for Candlepin in /var/log/candlepin/candlepin.log.
Errors are also logged to a separate file for easier debugging /var/log/candlepin/error.log.
Extend /etc/candlepin/candlepin.conf:
log4j.logger.org.candlepin=DEBUG
Ensure to restart the tomcat service afterwards:
# systemctl restart tomcat
log4j.logger.org.candlepin.resource.ConsumerResource=WARN log4j.logger.org.candlepin.resource.HypervisorResource=WARN
15.2.4. Increasing the Logging Level On Satellite
You can find the log for Satellite in /var/log/foreman/production.log.
Satellite stores logs for Apache in:
/var/log/httpd/foreman_error.log -
/var/log/httpd/foreman_access.log -
/var/log/httpd/foreman_ssl_error.log -
/var/log/httpd/foreman_ssl_access.log
Set the logging level in
/etc/foreman/settings.yaml::logging: :production: :type: file :layout: pattern :level: debug -
Enable selected loggers in
/etc/foreman/settings.yaml::loggers: :ldap: :enabled: true :permissions: :enabled: true :sql: :enabled: trueNote that to see logging from some area, debug logging has to be set.
Restart Satellite services:
15.2.5. Increasing the Logging Level For Qpid Dispatch Router
Qpid logs to syslog and can be viewed in /var/log/messages or with journalctl.
Enable debug logging in /etc/qpid-dispatch/qdrouterd.conf:
enable: debug+
Ensure to restart the Qpid Dispatch Router afterwards:
# systemctl restart qdrouterd
Caution
15.2.6. Increasing the Logging Level For Qpid Broker
Set the log level in /etc/qpid/qpidd.conf:
log-enable=debug+
Ensure to restart the Qpid Broker afterwards:
# systemctl restart qpidd
Caution
Running the installer will revert this change. |
15.2.7. Increasing the Logging Level For Redis
Set the log level in /etc/opt/rh/rh-redis5/redis.conf:
loglevel debug
15.2.8. Increasing the Logging Level For Postgres
You can find the log for Postgres in /var/lib/pgsql/data/log.
Uncomment the log_statement in /var/lib/pgsql/data/postgresql.conf:
log_statement = 'all'
Ensure to restart Satellite services afterwards:
Caution
Based on the size of your Satellite installation, this can cause disk space to fill up very quickly. Only turn this on if absolutely needed. |
15.2.9. Increasing the Logging Level For Satellite Installer
You can find the log files in /var/log/foreman-installer/.
To increase the log level of the Satellite Installer during an install:
# satellite-installer --verbose-log-level debug
15.2.10. Increasing the Logging Level For Pulp
By default, Pulp logs to syslog and can be viewed in /var/log/messages or with journalctl.
Add the following config to the /etc/pulp/settings.py file:
Ensure to restart the Pulp services afterwards:
# systemctl restart \ pulpcore-api \ pulpcore-content \ pulpcore-resource-manager \ pulpcore-worker@1 \ pulpcore-worker@2 \ rh-redis5-redis
15.2.11. Increasing the Logging Level For Puppet Agent
You can increase the logging level for Puppet agent on your Satellite Server.
Add the following line to the
[agent]block in the/etc/puppetlabs/puppet/puppet.conffile:[agent] log_level = debug
15.2.12. Increasing the Logging Level For Puppet Server
You can increase the logging level for Puppet server on your Satellite Server.
Puppet must be enabled in your Satellite. For more information, see Enabling Puppet Integration with Satellite in Managing Configurations Using Puppet Integration in Red Hat Satellite.
[master]block in/etc/puppetlabs/puppet/puppet.conffile:[master] log_level = debug -
Restart the Puppet server:
# satellite-maintain service restart --only puppetserver
15.3. Retrieving the Status of Services
In the Satellite web UI, navigate to Administer > About.
On the Smart Proxies tab, you can view the status of all Capsules.
On the Compute Resources tab, you can view the status of attached compute resource providers.
In the Backend System Status table, you can view the status of all back-end services.
Run
hammer pingto get information from the database and Satellite services:# hammer ping
Use
satellite-maintainto check the status of the services running in systemd:# satellite-maintain service status
Use
satellite-maintainto perform a health check:$ satellite-maintain health check
15.4. Restarting Services
Satellite uses a set of back-end services to perform tasks. You you experience an issue with your Satellite, check the status of Satellite services.
Use
satellite-maintainto restart Satellite services:# satellite-maintain service restart
Tip
Run |
15.5. Enabling Individual Loggers
You can enable individual loggers for selective logging. Satellite uses the following loggers:
app-
audit-
background-
blob-
ImportantThe bloblogger might contain sensitive data. dynflow-
ldap-
notifications-
permissions-
sql-
telemetry-
templates-
Enable the individual loggers that you want. For example, to enable
sqlandldaploggers, enter the following command:# satellite-installer \ --foreman-loggers ldap:true \ --foreman-loggers sql:true
Optional: To reset loggers to their default values, enter the following command:
# satellite-installer --reset-foreman-loggers
15.6. Configuring Logging to Journal or File-based Logging
Satellite uses file-based logging by default.
You can use the satellite-installer command to reconfigure logging.
Enter the following
satellite-installercommand to configure logging to thejournaldservice:# satellite-installer \ --foreman-logging-layout pattern \ --foreman-logging-type journald \ --foreman-proxy-log JOURNAL
Optional: To inspect the log messages, use the
Enter the following
satellite-installercommand to configure file-based logging:# satellite-installer \ --reset-foreman-logging-layout \ --reset-foreman-logging-type \ --reset-foreman-proxy-log
Optional: To inspect the log messages, view these files:
/var/log/foreman-proxy.log
For more information about Journal, see Viewing logs using the command line in the Red Hat Enterprise Linux 8 Configuring Basic System Settings Guide.
15.7. Log File Directories Provided by Satellite
Red Hat Satellite provides system information in the form of notifications and log files.
| Log File Directories | Description of Log File Content |
Subscription management |
Installer |
Foreman maintain |
Foreman proxy |
Foreman |
Apache HTTP server |
Various other log messages |
Configuration management |
Candlepin webservice logs |
You can also use the foreman-tail command to follow many of the log files related to Satellite.
You can run foreman-tail -l to list the processes and services that it follows.
15.8. Utilities for Collecting Log Information
You can collect information from log files to troubleshoot Satellite.
- sosreport
The
sosreportcommand collects configuration and diagnostic information from a Linux system, such as the running Kernel version, loaded modules, running services, and system and service configuration files. This output is stored in a tar file located at/var/tmp/sosreport-XXX-20171002230919.tar.xz. For more information, runsosreport --helpor see What is a sosreport and how can I create one?.
The collection process removes security information such as passwords, tokens, and keys while collecting information. However, the tar files can still contain sensitive information about the Satellite Server. Red Hat recommends that you send this information directly to the intended recipient and not to a public target. |
15.9. System Journal Metadata
The following table lists metadata that the journald service uses in Satellite.
You can use this metadata to filter your queries.
| Name | Description |
AUDIT_ACTION |
Audit action performed Example: Create, update, or delete |
AUDIT_TYPE |
Audit resource type Example: Host, Subnet, or ContentView |
AUDIT_ID |
Audit resource database ID as a number |
AUDIT_ATTRIBUTE |
Audit resource field or an updated database column |
AUDIT_FIELD_OLD |
Old audit value of an update action |
AUDIT_FIELD_NEW |
New audit value of an update action |
AUDIT_ID |
Record database ID of the audit subject |
AUDIT_ATTRIBUTE |
Attribute name or column on which an action was performed Example: Name or description |
EXCEPTION_MESSAGE |
Exception message when error is logged |
EXCEPTION_CLASS |
Exception Ruby class when error is logged |
EXCEPTION_BACKTRACE |
Exception backtrace as a multiline string when error is logged |
LOC_ID |
Location database ID |
LOC_NAME |
Location name |
LOC_LABEL |
Location label |
LOGGER |
Logger name To see the current list of loggers enabled by default, enter this command: # awk '/add_loggers/,/^$/' /usr/share/foreman/config/application.rb |
ORG_ID |
Organization database ID |
ORG_NAME |
Organization name |
ORG_LABEL |
Organization label |
REMOTE_IP |
Remote IP address of a client |
REQUEST |
Request ID generated by the Action Dispatch module |
SESSION |
Random ID generated per session or a request for a sessionless request |
TEMPLATE_NAME |
Template name |
TEMPLATE_DIGEST |
Digest (SHA256) of rendered template contents |
TEMPLATE_HOST_NAME |
Host name for a rendered template if present |
TEMPLATE_HOST_ID |
Host database ID for a rendered template if present |
USER_LOGIN |
User login name |
16. Monitoring Resources
16.1. Using the Red Hat Satellite Content Dashboard
The Red Hat Satellite content dashboard contains various widgets which provide an overview of the host configuration, Content Views, compliance reports, subscriptions and hosts currently registered, promotions and synchronization, and a list of the latest notifications.
In the Satellite web UI, navigate to Monitor > Dashboard to access the content dashboard. The dashboard can be rearranged by clicking on a widget and dragging it to a different position. The following widgets are available:
- Host Configuration Status
Table 8. Host Configuration States Icon State Description
Hosts in error state
noopmode.
Out of sync hosts
Hosts with no reports
Hosts with alerts disabled
- Host Configuration Chart
- Latest Events
- New Hosts
- Task Status
- Latest Warning/Error Tasks
- Discovered Hosts
- Latest Errata
A list of all errata available for hosts registered to Satellite.
- Content Views
A list of all Content Views in Satellite and their publish status.
- Sync Overview
An overview of all products or repositories enabled in Satellite and their synchronization status. All products that are in the queue for synchronization, are unsynchronized or have been previously synchronized are listed in this section.
- Host Subscription Status
An overview of the subscriptions currently consumed by the hosts registered to Satellite. A subscription is a purchased certificate that unlocks access to software, upgrades, and security fixes for hosts. The following table shows the possible states of subscriptions.
Table 9. Host Subscription States Icon State Description
Invalid
Partial
Valid
- Subscription Status
- Host Collections
A list of all host collections in Satellite and their status, including the number of content hosts in each host collection.
virt-whodaemon running on hosts in the environment. The following table shows the possible states.Table 10. Virt-who Configuration States State Description No Reports
No report has been received because either an error occurred during the virt-who configuration deployment, or the configuration has not been deployed yet, or virt-who cannot connect to Satellite during the scheduled interval.
No Change
OK
Total Configurations
- Latest Compliance Reports
- Red Hat Insights Actions
Red Hat Insights is a tool embedded in Satellite that checks the environment and suggests actions you can take. The actions are divided into 4 categories: Availability, Stability, Performance, and Security.
- Red Hat Insights Risk Summary
NoteIt is not possible to change the date format displayed in the Satellite web UI.
16.1.1. Managing Tasks
Red Hat Satellite keeps a complete log of all planned or performed tasks, such as repositories synchronised, errata applied, and Content Views published. To review the log, navigate to Monitor > Tasks.
Adjusting the %_finish_timeout values might help in case of low bandwidth. Adjusting the %_accept_timeout values might help in case of high latency. |
Click Save.
16.2. Configuring RSS Notifications
To view Satellite event notification alerts, click the Notifications icon in the upper right of the screen.
By default, the Notifications area displays RSS feed events published in the Red Hat Satellite Blog.
You can configure the RSS feed notifications by changing the URL feed. The supported feed format is RSS 2.0 and Atom. For an example of the RSS 2.0 feed structure, see the Red Hat Satellite Blog feed. For an example of the Atom feed structure, see the Foreman blog feed.
In the Satellite web UI, navigate to Administer > Settings and select the Notifications tab.
16.3. Monitoring Satellite Server
Audit records list the changes made by all users on Satellite. This information can be used for maintenance and troubleshooting.
In the Satellite web UI, navigate to Monitor > Audits to view the audit records.
To obtain a list of all the audit attributes, use the following command:
16.4. Monitoring Capsule Server
The following section shows how to use the Satellite web UI to find Capsule information valuable for maintenance and troubleshooting.
16.4.1. Viewing General Capsule Information
In the Satellite web UI, navigate to Infrastructure > Capsules to view a table of Capsule Servers registered to Satellite Server. The information contained in the table answers the following questions:
- Is Capsule Server running?
This is indicated by a green icon in the Status column. A red icon indicates an inactive Capsule, use the
service foreman-proxy restartcommand on Capsule Server to activate it. - What services are enabled on Capsule Server?
In the Features column you can verify if Capsule for example provides a DHCP service or acts as a Pulp mirror. Capsule features can be enabled during installation or configured in addition. For more information, see Installing Capsule Server.
- What organizations and locations is Capsule Server assigned to?
A Capsule Server can be assigned to multiple organizations and locations, but only Capsules belonging to the currently selected organization are displayed. To list all Capsules, select Any Organization from the context menu in the top left corner.
After changing the Capsule configuration, select Refresh from the drop-down menu in the Actions column to ensure the Capsule table is up to date.
Click the Capsule name to view further details. At the Overview tab, you can find the same information as in the Capsule table. In addition, you can answer to the following questions:
- Which hosts are managed by Capsule Server?
- How much storage space is available on Capsule Server?
/var/lib/pulpis displayed. Also the remaining storage space available on the Capsule can be ascertained.
16.4.2. Monitoring Services
In the Satellite web UI, navigate to Infrastructure > Capsules and click the name of the selected Capsule. At the Services tab, you can find basic information on Capsule services, such as the list of DNS domains, or the number of Pulp workers. The appearance of the page depends on what services are enabled on Capsule Server. Services providing more detailed status information can have dedicated tabs at the Capsule page. For more information, see Monitoring Puppet.
16.4.3. Monitoring Puppet
In the Satellite web UI, navigate to Infrastructure > Capsules and click the name of the selected Capsule. At the Puppet tab you can find the following:
A table of CA certificates associated with the Capsule at the Certificates sub-tab. Here you can inspect the certificate expiry data, or cancel the certificate by clicking Revoke.
The Puppet and Puppet CA tabs are available only if you have Puppet enabled in your Satellite. For more information, see Enabling Puppet Integration with Satellite in Managing Configurations Using Puppet Integration in Red Hat Satellite. |
17. Using Webhooks
A webhook is a way for a web page or web application to provide other applications with information in real time. Webhooks are only triggered after an event occurs. The request usually contains details of the event. An event triggers callbacks, such as sending an e-mail confirming a host has been provisioned. Webhooks enable you to define a call to an external API based on Satellite internal event using a fire-and-forget message exchange pattern. The application sending the request does not wait for the response, or ignores it.
The typical use case for webhooks in Satellite is making a call to a monitoring system when a host is created or deleted.
Webhooks are useful where the action you want to perform in the external system can be achieved through its API. Where it is necessary to run additional commands or edit files, the shellhooks plugin for Capsules is available. The shellhooks plugin enables you to define a shell script on the Capsule that can be executed through the API.
17.1. Migrating to Webhooks
Webhooks are processed asynchronously so there is minimal risk of tampering with internals of the system.
It is not possible to migrate from foreman_hooks without creating payloads for each individual webhook script.
However, the webhooks plugin comes with several example payload templates.
You can also use the example payloads with shellhooks to simplify migration.
17.2. Installing Webhooks
Use the following procedure to install webhooks. After installing webhooks, you can configure Satellite Server to send webhook requests.
Install webhooks using the following command:
# satellite-installer --enable-foreman-plugin-webhooks
Optional: you can install the CLI plugin using the following command:
# satellite-installer --enable-foreman-cli-webhooks
17.3. Creating a Webhook Template
Webhook templates are used to generate the body of HTTP request to a configured target when a webhook is triggered. Use the following procedure to create a webhook template in the Satellite web UI.
In the Satellite web UI, navigate to Administer > Webhook Templates.
A webhook HTTP payload must be created using Satellite template syntax. The webhook template can use a special variable called
@objectthat can represent the main object of the event.@objectcan be missing in case of certain events. You can determine what data are actually available with the@payloadvariable.For more information, see Template Writing Reference in Managing Hosts and for available template macros and methods, visit
/templates_docon Satellite Server. -
Click Submit.
17.4. Creating a Webhook
You can customize events, payloads, HTTP authentication, content type, and headers through the Satellite web UI.
Use the following procedure to create a webhook in the Satellite web UI.
In the Satellite web UI, navigate to Administer > Webhooks.
Click Create new.
Click Template to select a template. Webhook templates are used to generate the body of the HTTP request to Satellite Server when a webhook is triggered.
Enter an HTTP method.
Click the Credentials tab.
Optional: Uncheck Verify SSL if you do not want to verify the server certificate against the system certificate store or Satellite CA.
When configuring webhooks with endpoints with non-standard HTTP or HTTPS ports, an SELinux port must be assigned, see Configuring SELinux to Ensure Access to Satellite on Custom Ports in Installing Satellite Server in a Connected Network Environment.
17.5. Available Webhook Events
The following table contains a list of webhook events that are available from the Satellite web UI.
A Content View was successfully promoted. |
Actions::Katello::ContentView::Promote |
Actions::Katello::ContentView::Publish |
Run OpenSCAP scan. |
Runs an Ansible playbook containing all the roles defined for a host. |
Actions Remote Execution Run Host Job Ansible Run Capsule Upgrade Succeeded |
Upgrade Capsules on given Capsule server hosts. |
Actions Remote Execution Run Host Job Ansible Run Insights Plan Succeeded |
Runs a given maintenance plan from Red Hat Access Insights given an ID. |
Run an Ansible playbook against given hosts. |
Run an Ansible playbook to enable the web console on given hosts. |
Build Entered |
Custom event: |
Build Exited |
Custom event: |
Common database operations on a Content View. |
Katello::ContentView |
Domain |
Host |
Hostgroup |
Model |
Status Changed |
Custom event: |
Subnet |
Template Render Performed |
Template |
User |
17.6. Shellhooks
With webhooks, you can only map one Satellite event to one API call. For advanced integrations, where a single shell script can contain multiple commands, you can install a Capsule shellhooks plugin that exposes executables using a REST HTTP API.
You can then configure a webhook to reach out to a Capsule API to run a predefined shellhook. A shellhook is an executable script that can be written in any language as long as it can be executed. The shellhook can for example contain commands or edit files.
You can pass arguments to shellhook script using HTTP headers in format X-Shellhook-Arg-1 to X-Shellhook-Arg-99.
For more information on passing arguments to shellhook script, see:
The HTTP method must be POST.
An example URL would be: https://capsule.example.com:9090/shellhook/My_Script.
Unlike the |
You must enable Capsule Authorization for each webhook connected to a shellhook to enable it to authorize a call.
Standard output and standard error output are redirected to the Capsule logs as messages with debug or warning levels respectively.
17.7. Installing the Shellhooks Plugin
Optionally, you can install and enable the shellhooks plugin on each Capsule used for shellhooks, using the following command:
# satellite-installer --enable-foreman-proxy-plugin-shellhooks
17.8. Passing Arguments to Shellhook Script Using Webhooks
17.9. Passing Arguments to Shellhook Script Using Curl
# curl -sX POST -H 'Content-Type: text/plain' \ -H "X-Shellhook-Arg-1: Version 1.0" \ -H "X-Shellhook-Arg-2: My Content View" \ --data "" https://capsule.example.com:9090/shellhook/My_Script
17.10. Creating a Shellhook to Print Arguments
You have the
webhooksandshellhooksplug-ins installed. For more information, see:
Modify the
/var/lib/foreman-proxy/shellhooks/print_argsscript to print arguments to standard error output so you can see them in the Capsule logs:#!/bin/sh # # Prints all arguments to stderr # echo "$@" >&2
Click Create new.
In the Target URL field, enter the URL of your Capsule Server followed by
:9090/shellhook/print_args:https://capsule.example.com:9090/shellhook/print_args
Note that
On the Credentials tab, check Capsule Authorization.
Click Submit. You now have successfully created a shellhook that prints "Hello World!" to Capsule logs every time you a remote execution job succeeds.
timeas a command. For more information, see Executing a Remote Job in Managing Hosts. -
Verify that the shellhook script was triggered and printed "Hello World!" to Capsule Server logs:
18. Searching and Bookmarking
Satellite features powerful search functionality on most pages of the Satellite web UI. It enables you to search all kinds of resources that Satellite manages. Searches accept both free text and syntax-based queries, which can be built using extensive input prediction. Search queries can be saved as bookmarks for future reuse.
18.1. Building Search Queries
18.1.1. Query Syntax
parameter operator value
18.1.2. Query Operators
| Operator | Short Name | Description | Example |
EQUALS |
NOT EQUALS |
LIKE |
NOT LIKE |
GREATER THAN |
LESS THAN |
IN |
NOT IN |
HAS or set? |
NOT HAS or null? |
| Operator | Alternative Notations | Example | ||
and |
<whitespace> |
or |
not |
18.1.3. Query Values
- Text Values
Examples:
hostgroup = "Web servers"The search will return hosts with assigned host group named "Web servers".
hostgroup = Web serversThe search will return hosts in the host group Web with any field matching %servers%.
- Temporal Values
"10 January 2017"
"10 Jan 2017"
10-January-2017
10/January/2017
"January 10, 2017"
Warning
18.2. Using Free Text Search
18.3. Managing Bookmarks
On some pages, there are default bookmarks available for the common searches, for example, all active or disabled hosts.
18.3.1. Creating Bookmarks
In the Satellite web UI, navigate to the page where you want to create a bookmark.
Ensure the Public checkbox is set correctly:
Select the Public checkbox to set the bookmark as public and visible to all users.
Clear the Public checkbox to set the bookmark as private and only visible to the user who created it.
Click Submit.
18.3.2. Deleting Bookmarks
In the Satellite web UI, navigate to Administer > Bookmarks.
This section contains information about settings that you can edit in the Satellite web UI by navigating to Administer > Settings.
A.1. General Settings
Administrator email address |
Satellite URL |
URL where your Satellite instance is reachable. See also Provisioning > Unattended URL. |
Entries per page |
20 |
Number of records shown per page in Satellite |
Fix DB cache |
No |
Satellite maintains a cache of permissions and roles.
When set to |
DB pending seed |
No |
Should the |
Capsule request timeout |
60 |
Open and read timeout for HTTP requests from Satellite to Capsule (in seconds). |
Login page footer text |
Show host power status |
Yes |
Show power status on the host index page. This feature calls to compute resource providers which may lead to decreased performance on the host listing page. |
HTTP(S) proxy |
Set a proxy for outgoing HTTP(S) connections from the Satellite product. System-wide proxies must be configured at the operating system level. |
HTTP(S) proxy except hosts |
Show Experimental Labs |
No |
Append domain names to the host |
Yes |
If set to |
Out of sync interval |
30 |
Managed hosts report periodically, and if the time between reports exceeds this duration in minutes, hosts are considered out of sync.
Satellite UUID |
Satellite instance ID. Uniquely identifies a Satellite instance. |
Default language |
Default timezone |
The timezone to use for new users. |
Instance title |
Saved audits interval |
New host details UI |
Yes |
Satellite loads the new UI for host details. |
A.2. Satellite Task Settings
Sync task timeout |
120 |
Enable dynflow console |
Yes |
Enable the dynflow console ( |
Yes |
The user must be authenticated as having administrative rights before accessing the dynflow console. |
Capsule action retry count |
4 |
Number of attempts permitted to start a task on the Capsule before failing. |
Capsule action retry interval |
15 |
Allow Capsule batch tasks |
Yes |
Enable batch triggering of tasks on the Capsule. |
Capsule tasks batch size |
100 |
Number of tasks included in one request to the Capsule if |
Tasks troubleshooting URL |
It should contain a |
1 |
A.3. Template Sync Settings
Associate |
New |
Associate templates with OS, organization and location. |
Branch |
Default branch in Git repo. |
Commit message |
Templates export made by a Satellite user |
Dirname |
Filter |
Force import |
No |
If set to |
Lock templates |
Keep, do not lock new |
Metadata export mode |
Refresh |
Negate |
No |
Prefix |
Repo |
When exporting to |
Verbosity |
No |
A.4. Discovered Settings
Discovery location |
Discovery organization |
Interface fact |
discovery_bootif |
Create bond interfaces |
No |
Clean all facts |
No |
Hostname facts |
discovery_bootif |
Auto provisioning |
No |
Reboot |
Yes |
Hostname prefix |
mac |
Fact columns |
Highlighted facts |
Storage facts |
Software facts |
Hardware facts |
Network facts |
IPMI facts |
Lock PXE |
No |
pxelinux_discovery |
Locked PXEGrub template name |
pxegrub_discovery |
PXEGrub template to be used when pinning a host to discovery. |
pxegrub2_discovery |
Force DNS |
Yes |
Error on existing NIC |
No |
Do not permit to discover an existing managed host matching the MAC of a provisioning Network Interface Card (NIC) (errors out early). |
Type of name generator |
Fact + prefix |
Prefer IPv6 |
No |
A.5. Boot Disk Settings
iPXE directory |
ISOLINUX directory |
SYSLINUX directory |
Grub2 directory |
Host image template |
Boot disk iPXE - host |
Generic image template |
ISO generation command |
genisoimage |
Installation media caching |
Yes |
Allowed bootdisk types |
A.6. Red Hat Cloud Settings
Automatic inventory upload |
Yes |
Enable automatic upload of your host inventory to the Red Hat cloud. |
Synchronize recommendations Automatically |
No |
Enable automatic synchronization of Insights recommendations from the Red Hat cloud. |
Obfuscate host names |
No |
Obfuscate hostnames sent to the Red Hat cloud. |
Obfuscate host ipv4 addresses |
No |
Obfuscate IPv4 addresses sent to the Red Hat cloud. |
ID of the RHC daemon |
RHC daemon id. |
A.7. Content Settings
Default HTTP Proxy |
CDN SSL version |
SSL version used to communicate with the CDN. |
Kickstart default |
Kickstart default finish |
Default synced OS user-data |
Kickstart default user data |
Kickstart default PXELinux |
Default synced OS PXEGrub template |
Kickstart default PXEGrub |
Default PXEGrub template for new operating systems created from synced content. |
Kickstart default PXEGrub2 |
Kickstart default iPXE |
Kickstart default |
Discovery Red Hat kexec |
Atomic Kickstart default |
Manifest refresh timeout |
1200 |
Accept action timeout |
20 |
Time in seconds to wait for a host to pick up a remote action. |
Finish action timeout |
3600 |
Time in seconds to wait for a host to finish a remote action. |
Yes |
Can communicate with the Red Hat Portal for subscriptions. |
No |
Calculate errata host status based only on errata in a host’s Content View and Lifecycle Environment. |
No |
Yes |
100 |
How many repositories should be synced concurrently on a Capsule. A smaller number may lead to longer sync times. A larger number will increase dynflow load. |
Sync Capsules after Content View promotion |
Yes |
Whether or not to auto sync Capsules after a Content View promotion. |
Either |
Default Red Hat Repository download policy |
Default download policy for enabled Red Hat repositories.
Either |
Default Capsule download policy |
Default download policy for Capsule syncs.
Either |
Pulp export destination filepath |
On-disk location for exported repositories. |
Pulp client key |
Pulp client cert |
Sync Connection Timeout |
300 |
Use remote execution by default |
No |
If enabled, remote execution is used instead of katello-agent for remote actions. |
Delete Host upon unregister |
No |
No |
If this is enabled, and |
Default Location |
Expire soon days |
120 |
No |
Host Duplicate DMI UUIDs |
Host Profile Assume |
Yes |
Enable new host registrations to assume registered profiles with matching hostname as long as the registering DMI UUID is not used by another host. |
No |
Enable host registrations to bypass Host Profile Assume as long as the host is in build mode. |
No |
5 |
Applicability Batch Size |
50 |
Autosearch |
Yes |
Autosearch delay |
500 |
Pulp bulk load size |
2000 |
Yes |
1440 |
Prefer registered through Capsule for remote execution |
No |
Yes |
Enable removal of repositories that the user has previously published in one or more Content View versions. |
A.8. Authentication Settings
OAuth active |
Yes |
Satellite will use OAuth for API authorization. |
OAuth consumer key |
OAuth consumer key. |
OAuth consumer secret |
OAuth consumer secret. |
OAuth map users |
No |
Satellite maps users by username in the request-header. If this is disabled, OAuth requests have administrator rights. |
Failed login attempts limit |
30 |
Satellite blocks user logins from an incoming IP address for 5 minutes after the specified number of failed login attempts. Set to 0 to disable brute force protection. |
Restrict registered Capsules |
Yes |
Only known Capsules can access features that use Capsule authentication. |
Require SSL for capsules |
Yes |
Client SSL certificates are used to identify Capsules ( |
Trusted hosts |
List of hostnames, IPv4, IPv6 addresses or subnets to be trusted in addition to Capsules for access to fact/report importers and ENC output. |
SSL certificate |
SSL Certificate path that Satellite uses to communicate with its proxies. |
SSL CA file |
SSL CA file path that Satellite uses to communicate with its proxies. |
SSL private key |
SSL Private Key path that Satellite uses to communicate with its proxies. |
SSL client DN env |
HTTP_SSL_CLIENT_S_DN |
SSL client verify env |
HTTP_SSL_CLIENT_VERIFY |
SSL client cert env |
HTTP_SSL_CLIENT_CERT |
Server CA file |
SSL CA file path used in templates to verify the connection to Satellite. |
Websockets SSL key |
Private key file path that Satellite uses to encrypt websockets. |
Websockets SSL certificate |
Certificate path that Satellite uses to encrypt websockets. |
Websockets encryption |
Yes |
Login delegation logout URL |
External |
Authorize login delegation |
No |
No |
Idle timeout |
60 |
BCrypt password cost |
9 |
BMC credentials access |
Yes |
OIDC JWKs URL |
Typically |
OIDC Audience |
OIDC Issuer |
OIDC Algorithm |
A.9. Email Settings
Email reply address |
Email reply address for emails that Satellite is sending. |
Email subject prefix |
Send welcome email |
No |
Delivery method |
Sendmail |
SMTP enable StartTLS auto |
Yes |
SMTP OpenSSL verify mode |
Default verification mode |
SMTP address |
SMTP address to connect to. |
SMTP port |
25 |
SMTP port to connect to. |
SMTP HELO/EHLO domain |
HELO/EHLO domain. |
SMTP username |
SMTP password |
SMTP authentication |
none |
Sendmail arguments |
-i |
Sendmail location |
A.10. Notifications Settings
RSS enable |
Yes |
Pull RSS notifications. |
RSS URL |
https://www.redhat.com/en/rss/blog/channel/red-hat-satellite |
A.11. Provisioning Settings
Host owner |
Default owner on provisioned hosts, if empty Satellite uses the current user. |
Root password |
Unattended URL |
Safemode rendering |
No |
Query local nameservers |
No |
Satellite queries the locally configured resolver instead of the SOA/NS authorities. |
Installation token lifetime |
360 |
SSH timeout |
120 |
0.0.0.0 |
No |
Satellite updates the host IP with the IP that made the build request. |
Use short name for VMs |
No |
Satellite uses the short hostname instead of the FQDN for creating new virtual machines. |
DNS timeout |
[5, 10, 15, 20] |
Clean up failed deployment |
Yes |
Satellite deletes the virtual machine if the provisioning script ends with a non-zero exit code. |
iPXE intermediate script |
No |
Destroy associated VM on host delete. When enabled, VMs linked to hosts are deleted on Compute Resource. When disabled, VMs are unlinked when the host is deleted, meaning they remain on Compute Resource and can be re-associated or imported back to Satellite again. This does not automatically power off the VM |
Maximum structured facts |
100 |
Global Registration |
PXEGrub2 global default |
PXELinux global default |
Global default PXEGrub template |
PXEGrub global default |
Global default PXEGrub template. This template is deployed to all configured TFTP servers. It is not affected by upgrades. |
iPXE global default |
PXEGrub2 default local boot |
PXELinux default local boot |
Local boot PXEGrub template |
PXEGrub default local boot |
Template that is selected as PXEGrub default for local boot. |
Local boot iPXE template |
iPXE default local boot |
Manage PuppetCA |
Yes |
Satellite automates certificate signing upon provision of a new host. |
Use UUID for certificates |
No |
Satellite uses random UUIDs for certificate signing instead of hostnames. |
Show unsupported provisioning templates |
No |
Show unsupported provisioning templates. When enabled, all the available templates are shown. When disabled, only Red Hat supported templates are shown. |
A.12. Facts Settings
Yes |
Satellite creates the host when new facts are received. |
Location fact |
satellite_location |
Organization fact |
satellite_organization |
Default location |
Default Location |
Default organization |
Default Organization |
Update hostgroup from facts |
Yes |
Satellite updates a host’s hostgroup from its facts. |
No |
Ignore facts for domain |
No |
Update subnets from facts |
None |
Satellite updates a host’s subnet from its facts. |
No |
Exclude pattern for facts stored in satellite |
Those facts are not stored in the satellite database.
A.13. Configuration Management Settings
Yes |
Satellite creates the host when a report is received. |
Matchers inheritance |
Yes |
Satellite matchers are inherited by children when evaluating smart class parameters for hostgroups, organizations, and locations. |
Satellite evaluates host smart class parameters in this order by default. |
Yes |
Satellite parses ERB in parameters value in the ENC output. |
No |
All hosts show a configuration status even when a Puppet Capsule is not assigned. |
A.14. Remote Execution Settings
Fallback to Any Capsule |
No |
Enable Global Capsule |
Yes |
SSH User |
root |
Default user to use for SSH.
Effective User |
root |
Effective User Method |
sudo |
One of [ |
Effective user password |
Sync Job Templates |
Yes |
SSH Port |
22 |
Default port 22.
Connect by IP |
No |
Prefer IPv6 over IPv4 |
No |
Default SSH password |
Default SSH key passphrase |
Workers pool size |
5 |
Restart of the |
Cleanup working directories |
Yes |
Cockpit URL |
Form Job Template |
Run Command - SSH Default |
A.15. Ansible Settings
Private Key Path |
Override with the |
Connection type |
ssh |
Use this connection type by default when running Ansible playbooks.
WinRM cert Validation |
validate |
Enable or disable WinRM server certificate validation when running Ansible playbooks.
Default verbosity level |
Disabled |
Satellite adds this level of verbosity for additional debugging output when running Ansible playbooks. |
Post-provision timeout |
360 |
Timeout (in seconds) to set when Satellite triggers an Ansible roles task playbook after a host is fully provisioned. Set this to the maximum time you expect a host to take until it is ready after a reboot. |
Ansible report timeout |
30 |
No |
Ansible - Ansible Inventory |
Satellite uses this template to schedule the report with Ansible inventory. |
Ansible roles to ignore |
The roles to exclude when importing roles from Capsule.
For example: |
Capsule tasks batch size for Ansible |
Number of tasks which should be sent to the Capsule in one request if |
