1. Introduction to Content Management
In the context of Foreman, content is defined as the software installed on systems. This includes, but is not limited to, the base operating system, middleware services, and end-user applications. With Foreman, you can manage the various types of content at every stage of the software life cycle.
The Katello plug-in provides content management features to Foreman. You can only use this guide if you have the Katello plug-in installed.
Foreman manages the following content:
Red Hat Subscription management
SUSE Subscription management
This provides organizations with a method to store SUSE content and organize it in various ways. Note that this requires the Foreman SCC Manager plug-in. For more information, see Managing SUSE Content.
Content management
This provides organizations with a method to store APT and YUM content and organize it in various ways.
2. Content Management Types Overview
With Foreman, you can manage the following content types:
RPM Packages
Import RPM packages from any repository, for example from Red Hat, SUSE, and custom repositories. Foreman server downloads the RPM files and stores them locally. You can use these repositories and their RPM files in Content Views.
DEB Packages
Import DEB packages from repositories, for example for Debian or Ubuntu. You can also import single DEB packages or synchronize custom repositories. You can use these repositories and their DEB files in Content Views.
Kickstart Trees
Import the kickstart trees for creating a system. New systems access these kickstart trees over a network to use as base content for their installation. Foreman also contains some predefined kickstart templates as well as the ability to create your own, which are used to provision systems and customize the installation.
You can also manage other types of content in Foreman. For example:
ISO and KVM Images
Download and manage media for installation and provisioning. For example, Foreman downloads, stores, and manages ISO images and guest images for specific Red Hat Enterprise Linux and non-Red Hat operating systems.
You can use the procedure to add content for any type of content you require, for example, SSL certificates and OVAL files.
3. Basic Content Management Workflow
This is a quick overview of the tasks involved in the basic content management workflow in Foreman. If you have installed Foreman with Katello and want to synchronize and manage Enterprise Linux content on your hosts, follow the steps in this chapter.
  • Create repository to mirror content from CentOS Stream.
  • Synchronize the Content.
  • Create Activation Keys.
  • Register Hosts to consume this content.
  • Manage RPMs on hosts using the katello-agent.
3.1. Creating Repositories to Synchronize
  2. Click Repo Discovery.
  3. In the Repository Type field, select Yum Repositories.
  4. In the URL to Discover field, enter the CentOS Stream URL http://mirror.centos.org/centos/8-stream.
  5. Click Discover.
  6. Select /AppStream/x86_64/os/ and /BaseOS/x86_64/os/ repositories.
  7. Click Create Selected.
  8. In the Product field select New Product.
  9. In the Name field enter CentOS Stream or desired product name.
  10. Click Run Repository Creation.
To view your newly created product, navigate to Content > Products, and select the name of the new product.
3.2. Synchronizing Content from an Upstream Repository
Use the following procedure to mirror the contents of the upstream CentOS repositories.
  1. In the Foreman web UI, navigate to Content > Products
  2. Select your new CentOS Stream product from the previous procedure.
  3. Locate the AppStream x86_64 os and BaseOS x86_64 os repositories.
  4. Select both repositories
  5. Click Sync Now
3.3. Creating an Activation Key
Use the following procedure to create an activation key that you can use to subscribe your hosts to content managed by Foreman.
  1. In the Foreman web UI, navigate to Content > Activation keys and click Create Activation Key.
  3. In the Description field, enter a description for the activation key.
  4. From the Environment list, select the Library.
  5. From the Content View list, select Default Organization View.
  6. Click Save.
  7. Click on the Subscriptions tab on the Activation Key’s details page.
  8. Click on the Add tab.
  9. Select all the product subscriptions in the table.
  10. Click Add Selected to save.
3.4. Registering a CentOS Stream Host to Foreman
Use the following procedure to register an existing CentOS Stream host to Foreman.
You can register hosts with Foreman using the host registration feature, the Foreman API, or Hammer CLI.
  2. Click Generate to create the registration command.
  3. Click on the files icon to copy the command to your clipboard.
  4. Log on to the host you want register and run the previously generated command.
  5. Check the /etc/yum.repos.d/redhat.repo and ensure that the appropriate repositories have been enabled.
CLI procedure
  2. Log on to the host you want register and run the previously generated command.
  3. Check the /etc/yum.repos.d/redhat.repo and ensure that the appropriate repositories have been enabled.
API procedure
    --user "My_User_Name" \
    Use an activation key to simplify specifying the environments. For more information, see Managing Activation Keys in the Content Management guide.
    To enter a password as command line argument, use username:password syntax. Keep in mind this can save the password in the shell history.
    For more information about registration see Registering a Host to Foreman.
3.5. Using Content Views
Foreman uses the concept of Content Views to create snapshots of a set of repositories and make them available to hosts registered to it. For example, if you want a group of hosts to have access to a specific version of a set of repositories, add those repositories to a Content View, publish and promote to a lifecycle environment. You can then register hosts to this Content View. These hosts have access only to repositories at the version specified in the Content View. This means that you can continue to update repositories on your server while your hosts still consume only the versions of the repositories that they are registered to. If you do not use Content Views and lifecycle environments, all your hosts consume content from the Default Content View and Library environment, which is a snapshot of the latest version of the content on your server. For more information about content management using Content Views and application lifecycles, see:
3.6. Creating a Content View
Use the following procedure to create a Content View.
  1. In the Foreman web UI, navigate to Content > Content Views and click Create New View.
  2. In the Name field, enter CentOS Content View.
  3. In the Description field, enter a description for the Content View.
  4. Click Save.
3.7. Adding Repositories
Use the following procedure to add the upstream CentOS repositories to your Content view.
  1. In the Foreman web UI, navigate to Content > Content Views > Select CentOS Content View > Yum Content Dropdown > Repositories.
  2. Click on Add section on the Repository selection page.
  5. Click Add Repositories
3.8. Publishing the Content View
Use the following procedure to publish the Content View.
  1. In the Foreman web UI, navigate to Content > Content Views, and select your new Content View.
  2. Click on Publish New Version button on the top right of page.
  3. Click Save
3.9. Creating an Activation Key to Consume the Content View
  2. In the Name field, enter CentOS or the name of your new activation key.
  5. From the Content View list, select Centos content view.
  6. Click Save.
  7. Click the Subscriptions tab on the Activation Key’s details page.
  8. Click the Add tab.
  9. Select your new CentOS Stream product in the table.
Use your activation key to register a host to the Content View. For more information on registering a host, see Registering a Host in the Managing Hosts guide.
3.10. Registering a CentOS Stream host to consume content from a published Content View
You can also register the host to the published Content View without an activation key using the following command:
# subscription-manager register \
--environment="Library/CentOS_Content_View"
--org="My_Organization" \
3.11. Managing the Lifecycle of the Content View
The default location of any new Content View is in the Library Environment. Optionally, you can add a new environment and promote your Content View to it. Use the following procedure to create a new Lifecycle Enviroment.
  1. In the Foreman web UI, navigate to Content > Lifecycle Environment and click Create Environment Path.
  2. In the Name field, enter Production or the name of your new environment to add to the end of Library environment.
  3. In the Description field, add an optional description for your new lifecycle environment.
  4. Click Save
3.12. Promoting your Content View to the New Lifecycle Environment
You can now promote your new Content View to the Production environment using the following procedure.
  1. In the Foreman web UI, navigate to Content > Content Views > Select your Content View
  2. On the Versions tab Click Promote for desired version under the Actions column.
  3. Select Production lifecycle environment from the available promotion paths.
  4. Add an optional Description
  5. Click Promote Version
3.13. Registering a CentOS Stream host to consume content from a promoted Content View in the production environment
To register a host to consume content from the Content View in the Production lifecycle environment, enter the following command:
--environment="Production/CentOS_Content_View" \
4. Managing Red Hat Subscriptions
Foreman can import content from the Red Hat Content Delivery Network (CDN). Foreman requires a Red Hat Subscription Manifest to find, access, and download content from the corresponding repositories. You must have a Red Hat Subscription Manifest containing a subscription allocation for each organization on Foreman server. All subscription information is available in your Red Hat Customer Portal account.
Before you can complete the tasks in this chapter, you must create a Red Hat Subscription Manifest in the Customer Portal.
+ To create, manage, and export a Red Hat Subscription Manifest in the Customer Portal, see Using Manifests in the Using Red Hat Subscription Management guide.
Use this chapter to import a Red Hat Subscription Manifest and manage the manifest within the Foreman web UI.
Subscription Allocations and Organizations
You can manage more than one organization if you have more than one subscription allocation. Foreman requires a single allocation for each organization configured in Foreman server. The advantage of this is that each organization maintains separate subscriptions so that you can support multiple organizations, each with their own Red Hat accounts.
Future-Dated subscriptions
Manually attach the future-dated subscriptions to your content hosts before the current subscriptions expire. Do not rely on the auto-attach method because this method is designed for a different purpose and might not work. For more information, see Attaching Red Hat Subscriptions to Content Hosts.
4.1. Importing a Red Hat Subscription Manifest into Foreman server
Use the following procedure to import a Red Hat Subscription Manifest into Foreman server.
This is for users of the Katello plug-in and Red Hat operating systems only.
  • You must have a Red Hat Subscription Manifest file exported from the Customer Portal. For more information, see Using Manifests in the Using Red Hat Subscription Management guide.
  1. In the Foreman web UI, ensure the context is set to the organization you want to use.
  2. In the Foreman web UI, navigate to Content > Subscriptions and click Manage Manifest.
  3. In the Manage Manifest window, click Browse.
  4. Navigate to the location that contains the Red Hat Subscription Manifest file, then click Open. If the Manage Manifest window does not close automatically, click Close to return to the Subscriptions window.
CLI procedure
  1. Copy the Red Hat Subscription Manifest file from your client to Foreman server:
  2. Log in to Foreman server as the root user and import the Red Hat Subscription Manifest file:
    # hammer subscription upload \
    --file ~/manifest_file.zip \
You can now enable repositories and import Red Hat content. For more information, see Importing Content in the Content Management guide.
4.2. Locating a Red Hat Subscription
When you import a Red Hat Subscription Manifest into Foreman server, the subscriptions from your manifest are listed in the Subscriptions window. If you have a high volume of subscriptions, you can filter the results to find a specific subscription.
Prerequisite
  2. In the Foreman web UI, navigate to Content > Subscriptions.
4.3. Adding Red Hat Subscriptions to Subscription Allocations
Use the following procedure to add Red Hat subscriptions to a subscription allocation in the Foreman web UI.
Prerequisite
  5. Click Submit
4.4. Removing Red Hat Subscriptions from Subscription Allocations
Use the following procedure to remove Red Hat subscriptions from a subscription allocation in the Foreman web UI.
Manifests must not be deleted. If you delete the manifest from the Red Hat Customer Portal or in the Foreman web UI, all of the entitlements for all of your content hosts will be removed.
Prerequisite
  3. On the row of each subscription you want to remove, select the corresponding check box.
4.5. Updating and Refreshing Red Hat Subscription Manifests
  • Renewing a subscription
4.6. Attaching Red Hat Subscriptions to Content Hosts
For more information about updating multiple hosts, see Updating Red Hat Subscriptions on Multiple Hosts. For more information about activation keys, see Managing Activation Keys.
Smart Management Subscriptions
In Foreman, you must maintain a Red Hat Enterprise Linux Smart Management subscription for every Red Hat Enterprise Linux host that you want to manage.
However, you are not required to attach Smart Management subscriptions to each content host. Smart Management subscriptions cannot attach automatically to content hosts in Foreman because they are not associated with any product certificates. Adding a Smart Management subscription to a content host does not provide any content or repository access. If you want, you can add a Smart Management subscription to a manifest for your own recording or tracking purposes.
Prerequisite
  • You must have a Red Hat Subscription Manifest file imported to Foreman server.
  2. In the Foreman web UI, navigate to Hosts > Content Hosts.
  3. On the row of each content host whose subscription you want to change, select the corresponding check box.
  4. From the Select Action list, select Manage Subscriptions.
  5. Optionally, enter a key and value in the Search field to filter the subscriptions displayed.
  6. Select the check box to the left of the subscriptions that you want to add or remove and click Add Selected or Remove Selected as required.
  7. Click Done to save the changes.
CLI procedure
  1. Connect to Foreman server as the root user, and then list the available subscriptions:
    # hammer subscription list \
    --organization-id 1
  2. Attach a subscription to the host:
    # hammer host subscription attach \
    --host host_name \
    --subscription-id subscription_id
4.7. Updating Red Hat Subscriptions on Multiple Hosts
  6. Select the check box to the left of the subscriptions to be added or removed and click Add Selected or Remove Selected as required.
5. Importing Content
This chapter outlines how you can import different types of content to Foreman. If you want to import RPMs, Files, or different content types to Foreman, it is done with largely the same procedures in this chapter.
For example, you can use the following chapters for information on specific types of content but the underlying procedures are the same:
5.1. Using Products and Repositories in Foreman
  • products require a subscription for clients to access, similar to subscriptions to Red Hat Products. Foreman creates a subscription for each product you create.
Red Hat Content is already organized into Products. For example, Red Hat Enterprise Linux Server is a Product in Foreman. The repositories for that Product consist of different versions, architectures, and add-ons. For Red Hat repositories, products are created automatically after enabling the repository. For more information, see Enabling Red Hat Repositories.
Other content can be organized into Products however you want. For example, you might create an EPEL (Extra Packages for Enterprise Linux) product and add an "EPEL 7 x86_64" repository to it.
5.2. Importing SSL Certificates
Before you synchronize content from an external source, you might need to import SSL certificates into your product. This might include client certs and keys or CA certificates for the upstream repositories you want to synchronize.
If you require SSL certificates and keys to download RPMs, you can add them to Foreman.
To use the CLI instead of the Foreman web UI, see the CLI procedure.
  1. In the Foreman web UI, navigate to Content > Content Credentials. In the Content Credentials window, click Create Content Credential.
  5. Click Save.
CLI procedure
  1. Copy the SSL certificate to your Foreman server:
    $ scp My_SSL_Certificate root@foreman.example.com:~/.
    Or download the SSL certificate to your Foreman server from an online source:
    $ wget -P ~ http://upstream-foreman.example.com/pub/katello-server-ca.crt
  2. Upload the SSL Certificate to Foreman:
    # hammer content-credential create \
    --content-type cert \
    --name "My_SSL_Certificate" \
    --path ~/My_SSL_Certificate
5.3. Creating a Product
Use this procedure to create a product that you can then add repositories to. To use the CLI instead of the Foreman web UI, see the CLI procedure.
  1. In the Foreman web UI, navigate to Content > Products, click Create Product.
  2. In the Name field, enter a name for the product. Foreman automatically completes the Label field based on what you have entered for Name.
  9. Click Save.
CLI procedure
# hammer product create \
--name "My_Product" \
--sync-plan "Example Plan" \
5.4. Adding RPM Repositories
Use this procedure to add RPM repositories in Foreman. To use the CLI instead of the Foreman web UI, see the CLI procedure.
The Products window in the Foreman web UI also provides a Repo Discovery function that finds all repositories from a URL and you can select which ones to add to your product. For example, you can use the Repo Discovery to search http://yum.postgresql.org/9.5/redhat/ and list all repositories for different Red Hat Enterprise Linux versions and architectures. This helps users save time importing multiple repositories from a single source.
  1. In the Foreman web UI, navigate to Content > Products and select the product that you want to use, and then click New Repository.
  2. In the Name field, enter a name for the repository. Foreman automatically completes the Label field based on what you have entered for Name.
  6. Optional: From the Restrict to OS Version list, select the OS version. If you want to make the repository available to all hosts regardless of the OS version, ensure to select No restriction.
  7. Optional: In the Upstream URL field, enter the URL of the external repository to use as a source.
  8. Optional: Check the Ignore SRPMs check box to exclude source RPM packages from being synchronized to Foreman.
  9. Select the Verify SSL check box if you want to verify that the upstream repository’s SSL certificates are signed by a trusted CA.
  10. Optional: In the Upstream Username field, enter the user name for the upstream repository if required for authentication. Clear this field if the repository does not require authentication.
  11. Optional: In the Upstream Password field, enter the corresponding password for the upstream repository. Clear this field if the repository does not require authentication.
  12. Optional: In the Upstream Authentication Token field, provide the token of the upstream repository user for authentication. Leave this field empty if the repository does not require authentication.
  13. From the Download Policy list, select the type of synchronization Foreman server performs. For more information, see Download Policies Overview.
  14. From the Mirroring Policy list, select the type of content synchronization Foreman server performs. For more information, see Mirroring Policies Overview.
  15. Optional: In the Retain package versions field, enter the number of versions you want to retain per package.
  16. Optional: In the HTTP Proxy Policy field, select an HTTP proxy.
  17. From the Checksum list, select the checksum type for the repository.
  18. Optional: You can clear the Unprotected check box to require a subscription entitlement certificate for accessing this repository. By default, the repository is published through HTTP.
  19. Optional: From the GPG Key list, select the GPG key for the product.
  20. Optional: In the SSL CA Cert field, select the SSL CA Certificate for the repository.
  21. Optional: In the SSL Client cert field, select the SSL Client Certificate for the repository.
  22. Optional: In the SSL Client Key field, select the SSL Client Key for the repository.
  23. Click Save to create the repository.
CLI procedure
    # hammer repository create \
    --arch "My_Architecture" \
    --content-type "yum" \
    --gpg-key-id My_GPG_Key_ID \
    --name "My_Repository" \
    --os-version "My_OS_Version" \
    --product "My_Product" \
    --publish-via-http true \
    --url My_Upstream_URL
5.5. Extracting GPG Public Key Fingerprints from a Release Files
You can use GPG public keys the verify the authenticity of APT repositories by verifying the signature of the Release file. This example verifies the signature for the Release file from Debian 11.
  1. Download the Release and Release.gpg files:
    $ wget https://ftp.debian.org/debian/dists/bullseye/Release
    $ wget https://ftp.debian.org/debian/dists/bullseye/Release.gpg
  2. Verify the signature:
  3. If you cannot verify the signature, import the missing GPG public keys based on the output of the command above:
    $ gpg --keyserver hkp://keyserver.ubuntu.com --recv-keys 0146DC6D4A0B2914BDED34DB648ACFD622F3D138
    $ gpg --keyserver hkp://keyserver.ubuntu.com --recv-keys A7236886F3CCCAAD148A27F80E98404D386FA1D9
    $ gpg --keyserver hkp://keyserver.ubuntu.com --recv-keys A4285295FC7B1A81600062A9605C66F00D6C9793
  4. Optional: Verify the signature again:
  5. Export the ASCII-armored GPG public keys to a file:
    $ gpg --armor --export 0146DC6D4A0B2914BDED34DB648ACFD622F3D138 A7236886F3CCCAAD148A27F80E98404D386FA1D9 A4285295FC7B1A81600062A9605C66F00D6C9793 > debian_11.txt
    Use this .txt file and upload it to Foreman as described below.
Continue to import the custom GPG public key into Foreman.
5.6. Adding DEB Repositories
Use this procedure to add DEB repositories in Foreman. To use the CLI instead of the Foreman web UI, see the CLI procedure.
  4. From the Type list, select deb as type of repository.
  5. Optional: In the Upstream URL field, enter the URL of the external repository to use as a source. You can find the upstream URLs on Debian-based systems in /etc/apt/sources.list.
  6. In the Releases/Distributions field, set one or multiple releases separated by whitespace. The distributions specify the path from the repository root to the Release file. Repositories that omit the dists directory are using the deprecated flat repository structure. To synchronize a flat repository, you must specify exactly one distribution that ends with a /.
    For official Debian repositories, set a codename in the Releases/Distributions field, for example buster for Debian 10 or bullseye for Debian 11. Avoid using stable or testing because the codename they reference changes over time. This helps to avoid drastic changes once a new Debian version is released and the reference is changed. To keep things easy to manage and to avoid potential performance and network issues during synchronization, create one repository per release in Foreman. For official Ubuntu repositories, use the Ubuntu suite, for example focal or focal-updates.
  7. Optional: In the Components field, enter a component. This indicates the licensing terms of the software packages.
    In Debian, it is divided into main, contrib, and non-free. For official Debian or Ubuntu repositories, Foreman developers recommends leaving this field empty to synchronize all available components. Note that some third party Debian repositories use the components in ways that may require setting an explicit selection.
    Caution
    Ensure that you enter both Releases and Components exactly as they are in an /etc/apt/sources.list file.
  8. Optional: In the Architectures field, enter one or multiple architectures. If you want to make the repository available to all hosts regardless of the architecture, ensure to select No restriction.
  9. Optional: Select the Verify SSL check box if you want to verify that the upstream repository’s SSL certificates are signed by a trusted CA.
  15. Optional: In the HTTP Proxy Policy field, select an HTTP proxy.
  16. Optional: You can clear the Unprotected check box to require a subscription entitlement certificate for accessing this repository. By default, the repository is published through HTTP.
  17. Optional: From the GPG Key list, select the GPG key if you want to verify the signatures of the Release files associated with the Debian repository.
  18. Optional: In the SSL CA Cert field, select the SSL CA Certificate for the repository.
  19. Optional: In the SSL Client cert field, select the SSL Client Certificate for the repository.
  20. Optional: In the SSL Client Key field, select the SSL Client Key for the repository.
  21. Click Save to create the repository.
CLI procedure
    --content-type "deb" \
    --deb-architectures "My_DEB_Architectures" \
    --deb-components "_My_DEB_Components" \
    --deb-releases "My_DEB_Releases" \
    --gpg-key-id "My_GPG_Key_ID" \
    --name "_My_Repository" \
5.7. Adding DEB Repository Example for Debian 11
This example creates a product and repositories for Debian 11.
  1. Extract the GPG public keys from the Release file
  2. Import the content credentials into Foreman
  2. Click Create Product to create a product named Debian 11. For more information, see Creating a Product.
  3. On the Repositories tab, click New Repository to create three repositories of type deb as follows:
    • Debian 11 main
      • URL: http://ftp.debian.org/debian/
      • Releases/Distributions: bullseye
      • Component: main
      • Architecture: amd64
    • Debian 11 updates
      • Releases/Distributions: bullseye-updates
      • Component: main
    • Debian 11 security
      • URL: http://deb.debian.org/debian-security/
      • Releases/Distributions: bullseye-security
      • Component: main
  4. Click Create Product to create a product named Debian 11 client. For more information, see Creating a Product.
  5. On the Repositories tab, click New Repository to create a repository of type deb as follows:
    • Debian 11 client
      • URL: https://apt.atix.de/Debian11/
      • Releases/Distributions: stable
      • Component: main
5.8. Enabling Red Hat Repositories
If outside network access requires usage of an HTTP Proxy, configure a default HTTP Proxy for your server. See Adding a default HTTP Proxy
To select the repositories to synchronize, you must first identify the product that contains the repository, and then enable that repository based on the relevant release version and base architecture. For Red Hat Enterprise Linux 8, you must enable both AppStream and BaseOS repositories.
Repository Versioning
The difference between associating Red Hat Enterprise Linux operating system with either 7 Server repositories or 7.X repositories is that 7 Server repositories contain all the latest updates while Red Hat Enterprise Linux 7.X repositories stop getting updates after the next minor version release. Note that Kickstart repositories only have minor versions.
For Red Hat Enterprise Linux 8 Clients
To provision Red Hat Enterprise Linux 8 clients, you require the Red Hat Enterprise Linux 8 for x86_64 - AppStream (RPMS) and Red Hat Enterprise Linux 8 for x86_64 - BaseOS (RPMs) repositories.
For Red Hat Enterprise Linux 7 Clients
To provision Red Hat Enterprise Linux 7 clients, you require the Red Hat Enterprise Linux 7 Server (RPMs) repository.
  1. In the Foreman web UI, navigate to Content > Red Hat Repositories.
CLI procedure
  1. To search for your product, enter the following command:
    # hammer repository-set list \
  3. Enable the repository using either the name or ID number. Include the release version, for example,7Server and base architecture, for example, x86_64. For example:
    # hammer repository-set enable \
    --releasever "7Server" \
    --basearch "x86_64" \
5.9. Synchronizing Repositories
  1. In the Foreman web UI, navigate to Content > Products and select the product that contains the repositories that you want to synchronize.
To view the progress of the synchronization in the Foreman web UI, navigate to Content > Sync Status and expand the corresponding product or repository tree.
CLI procedure
  • Synchronize an entire Product:
    # hammer product synchronize \
    # hammer repository synchronize \
    --product "My Product"
256 Kbps
5 Mins 27 Secs
6 Hrs 49 Mins 36 Secs
2 Days 7 Hrs 55 Mins
512 Kbps
2 Mins 43.84 Secs
3 Hrs 24 Mins 48 Secs
1 Day 3 Hrs 57 Mins
T1 (1.5 Mbps)
54.33 Secs
1 Hr 7 Mins 54.78 Secs
9 Hrs 16 Mins 20.57 Secs
10 Mbps
8.39 Secs
10 Mins 29.15 Secs
1 Hr 25 Mins 53.96 Secs
100 Mbps
0.84 Secs
1 Min 2.91 Secs
8 Mins 35.4 Secs
1000 Mbps
0.08 Secs
6.29 Secs
51.54 Secs
Create a sync plan to ensure updates on a regular basis. See Creating a Sync Plan.
5.9.1. Synchronizing All Repositories in an Organization
To synchronize all repositories within an organization, run the following Bash script on your Foreman server:
ORG="Your_Organization"
for i in $(hammer --no-headers --csv repository list --organization $ORG | awk -F, {'print $1'})
do
done
5.10. Download Policies Overview
Foreman provides multiple download policies for synchronizing RPM and DEB content and container images. For example, you might want to download only the content metadata while deferring the actual content download for later.
Foreman server has the following policies:
Immediate
Foreman server downloads all metadata and packages during synchronization.
On Demand
Foreman server downloads only the metadata during synchronization. Foreman server only fetches and stores packages on the file system when Smart Proxies or directly connected clients request them. This setting has no effect if you set a corresponding repository on a Smart Proxy to Immediate because Foreman server is forced to download all the packages.
The On Demand policy acts as a Lazy Synchronization feature because they save time synchronizing content. The lazy synchronization feature must be used only for deb and yum repositories. You can add the packages to Content Views and promote to life cycle environments as normal.
Smart Proxy server has the following policies:
Immediate
Smart Proxy server downloads all metadata and packages during synchronization. Do not use this setting if the corresponding repository on Foreman server is set to On Demand as Foreman server is forced to download all the packages.
On Demand
Smart Proxy server only downloads the metadata during synchronization. Smart Proxy server fetches and stores packages only on the file system when directly connected clients request them. When you use an On Demand download policy, content is downloaded from Foreman server if it is not available on Smart Proxy server.
Inherit
Smart Proxy server inherits the download policy for the repository from the corresponding repository on Foreman server.
5.11. Changing the Default Download Policy
You can set the default download policy that Foreman applies to repositories that you create in all organizations.
Depending on whether it is a Red Hat, SUSE, or repository, Foreman uses separate settings. Changing the default value does not change existing settings.
  2. Click the Content tab.
    • To change the default download policy for a non-Red Hat repository, change the value of the Default Custom Repository download policy setting.
CLI procedure
    # hammer settings set \
    --value immediate
  • To change the default download policy for a repository to one of immediate or on_demand, enter the following command:
    --value immediate
5.12. Changing the Download Policy for a Repository
CLI procedure
    # hammer repository list \
    # hammer repository update \
    --download-policy immediate \
5.13. Mirroring Policies Overview
Foreman server has the following mirroring policies:
Additive
Content Only
Complete Mirroring
5.14. Changing the Mirroring Policy for a Repository
  2. Select the product name.
5.15. Uploading Content to RPM Repositories
You can upload individual RPMs and source RPMs to RPM repositories. You can upload RPMs using the Foreman web UI or the Hammer CLI. You must use the Hammer CLI to upload source RPMs.
  1. In the Foreman web UI, click Content > Products.
  2. Click the name of the product.
  3. In the Repositories tab, click the name of the RPM repository.
  5. Click Upload.
CLI procedure
    # hammer repository upload-content \
    --id Repository_ID \
    --content-type srpm \
5.16. Configuring SELinux to Permit Content Synchronization on Custom Ports
SELinux permits access of Foreman for content synchronization only on specific ports. By default, connecting to web servers running on the following ports is permitted: 80, 81, 443, 488, 8008, 8009, 8443, and 9000.
  1. On Foreman, to verify the ports that are permitted by SELinux for content synchronization, enter a command as follows:
5.17. Recovering a Corrupted Repository
Optimized Sync
Synchronizes the repository bypassing RPMs that have no detected differences from the upstream RPMs.
Complete Sync
Synchronizes all RPMs regardless of detected changes. Use this option if specific RPMs could not be downloaded to the local repository even though they exist in the upstream repository.
Verify Content Checksum
Synchronizes all RPMs and then verifies the checksum of all RPMs locally. If the checksum of an RPM differs from the upstream, it re-downloads the RPM. This option is relevant only for yum repositories. Use this option if you have one of the following errors:
  • Specific RPMs cause a 404 error while synchronizing with yum.
  • Package does not match intended download error, which means that specific RPMs are corrupted.
CLI procedure
      --id My_ID
      --id My_ID \
      --skip-metadata-check true
      --id My_ID \
      --validate-contents true
5.18. Adding an HTTP Proxy
Use this procedure to add HTTP proxies to Foreman. You can then specify which HTTP proxy to use for Products, repositories, and supported compute resources.
If Foreman server uses a proxy to communicate with subscription.rhsm.redhat.com or subscription.rhn.redhat.com, and cdn.redhat.com then the proxy must not perform SSL inspection on these communications.
  1. In the Foreman web UI, navigate to Infrastructure > HTTP Proxies and select New HTTP Proxy.
  3. In the URL field, enter the URL for the HTTP proxy, including the port number. The following host names are available:
    Host name Port Protocol
    HTTPS
    HTTPS
    cdn.redhat.com
    HTTPS
  4. If your HTTP proxy requires authentication, enter a Username and Password.
  5. Optional: In the Test URL field, enter the HTTP proxy URL, then click Test Connection to ensure that you can connect to the HTTP proxy from Foreman.
  8. Click Submit.
CLI procedure
  • On Foreman server, enter the following command to add an HTTP proxy:
    # hammer http-proxy create --name proxy-name \
    --url proxy-URL:port-number
    If your HTTP proxy requires authentication, add the --username name and --password password options.
5.19. Changing the HTTP Proxy Policy for a Product
  1. In the Foreman web UI, navigate to Content > Products and select the check box next to each of the Products that you want to change.
    • Use specific HTTP Proxy: Select an HTTP Proxy from the list. You must add HTTP proxies to Foreman before you can select a proxy from this list. For more information, see Adding an HTTP Proxy.
  4. Click Update.
5.20. Changing the HTTP Proxy Policy for a Repository
For granular control over network traffic, you can set an HTTP proxy policy for each repository. To use the CLI instead of the Foreman web UI, see the CLI procedure.
  1. In the Foreman web UI, navigate to Content > Products and click the name of the Product that contains the repository.
  5. Click Save.
CLI procedure
  • On Foreman server, enter the following command, specifying the HTTP proxy policy you want to use:
    # hammer repository update --id repository-ID \
    --http-proxy-policy policy
    • use_selected_http_proxy: Specify an HTTP proxy using either --http-proxy proxy-name or --http-proxy-id proxy-ID. To add a new HTTP proxy to Foreman, see Adding an HTTP Proxy.
5.21. Creating a Sync Plan
  1. In the Foreman web UI, navigate to Content > Sync Plans and click New Sync Plan.
  6. Click Save.
CLI procedure
    # hammer sync-plan create \
    --name "Red Hat Products 2" \
    --description "Example Plan for Red Hat Products" \
    --interval daily \
    --sync-date "2016-02-01 01:00:00" \
    --enabled true \
    # hammer sync-plan list --organization "Default Organization"
5.22. Assigning a Sync Plan to a Product
  2. Select a product.
CLI procedure
    # hammer product set-sync-plan \
    --name "Product_Name" \
    --sync-plan "Sync_Plan_Name" \
5.23. Assigning a Sync Plan to Multiple Products
    for i in $(hammer --no-headers --csv product list --organization $ORG --per-page 999 | grep -vi not_synced | awk -F, {'{ if ($5!=0) print $1}'})
    do
      hammer sync-plan create --name $SYNC_PLAN --interval daily --sync-date "2018-06-20 03:00:00" --enabled true --organization $ORG
    done
5.24. Limiting Synchronization Concurrency
CLI procedure
--download-concurrency 5 \
5.25. Importing a GPG Key
When clients are consuming signed content, ensure that the clients are configured to validate the installation of packages with the appropriate GPG Key. This helps to ensure that only packages from authorized sources can be installed.
Ensure that you have a copy of the GPG key used to sign the RPM content that you want to use and manage in Foreman. Most RPM distribution providers provide their GPG Key on their website. You can also extract this manually from an RPM:
  1. Download a copy of the version specific repository package to your client system:
  1. In the Foreman web UI, navigate to Content > Content Credentials and in the upper-right of the window, click Create Content Credential.
  2. Enter the name of your repository and select GPG Key from the Type list.
  3. Either paste the GPG key into the Content Credential Contents field, or click Browse and select the GPG key file that you want to import.
    If your repository contains content signed by multiple GPG keys, you must enter all required GPG keys in the Content Credential Contents field with new lines between each key, for example:
    =F6VG
    =WPpI
  4. Click Save.
CLI procedure
  1. Copy the GPG key to your Foreman server:
  2. Upload the GPG key to Foreman:
    # hammer content-credentials create \
    --content-type gpg_key \
    --name "My_GPG_Key" \
5.26. Restricting Custom Repository Sets to RHEL 9 in Foreman
  1. In the Foreman web UI, navigate to Content > Products and click the product that contains the repository sets that you want to restrict.
  2. In the Repositories tab, click the repository that you want to restrict.
  3. Navigate to Sync Settings > Restrict to OS and select the operating system from the list to include Red Hat Enterprise Linux operating systems for their corresponding Red Hat Enterprise Linux repositories and click Save.
6. Managing Application Life Cycles
This chapter outlines the application life cycle in Foreman and how to create and remove application life cycles for Foreman and Smart Proxy.
6.1. Introduction to Application Life Cycle
The application life cycle is a concept central to Foreman’s content management functions. The application life cycle defines how a particular system and its software look at a particular stage. For example, an application life cycle might be simple; you might only have a development stage and production stage. In this case the application life cycle might look like this:
  • Development
  • Production
However, a more complex application life cycle might have further stages, such as a phase for testing or a beta release. This adds extra stages to the application life cycle:
  • Development
  • Testing
  • Beta Release
  • Production
Foreman provides methods to customize each application life cycle stage so that it suits your specifications.
Each stage in the application life cycle is called an environment in Foreman. Each environment uses a specific collection of content. Foreman defines these content collections as a Content View. Each Content View acts as a filter where you can define what repositories, and packages to include in a particular environment. This provides a method for you to define specific sets of content to designate to each environment.
For example, an email server might only require a simple application life cycle where you have a production-level server for real-world use and a test server for trying out the latest mail server packages. When the test server passes the initial phase, you can set the production-level server to use the new packages.
Another example is a development life cycle for a software product. To develop a new piece of software in a development environment, test it in a quality assurance environment, pre-release as a beta, then release the software as a production-level application.
The Foreman Application Life Cycle
Figure 1. The Foreman Application Life Cycle
6.2. Promoting Content across the Application Life Cycle
In the application life cycle chain, when content moves from one environment to the next, this is called promotion.
Example Content Promotion Across Foreman Life Cycle Environments
This example uses a .rpm package, but you can promote any type of content across the application life cycle.
After completing development on the patch, you promote the package to the Testing environment so the Quality Engineering team can review the patch. The application life cycle then contains the following package versions in each environment:
While the Quality Engineering team reviews the patch, the Development team starts work on example_software 2.0. This results in the following application life cycle:
exampleware-2.0-0.noarch.rpm
exampleware-1.1-0.noarch.rpm
exampleware-1.0-0.noarch.rpm
6.3. Creating a Life Cycle Environment Path
To create an application life cycle for developing and releasing software, use the Library environment as the initial environment to create environment paths. Then optionally add additional environments to the environment paths.
  1. In the Foreman web UI, navigate to Content > Lifecycle Environments.
  2. Click New Environment Path to start a new application life cycle.
  5. Click Save.
CLI procedure
  1. To create an environment path, enter the hammer lifecycle-environment create command and specify the Library environment with the --prior option:
    # hammer lifecycle-environment create \
    --name "Environment Path Name" \
    --prior "Library" \
  2. Optional: To add an environment to the environment path, enter the hammer lifecycle-environment create command and specify the parent environment with the --prior option:
    --name "Environment Name" \
    --prior "Prior Environment Name" \
  3. To view the chain of the life cycle environment, enter the following command:
6.4. Removing Life Cycle Environments from Foreman server
Use this procedure to remove a life cycle environment.
  1. In the Foreman web UI, navigate to Content > Life Cycle Environments.
  2. Click the name of the life cycle environment that you want to remove, and then click Remove Environment.
CLI procedure
  1. List the life cycle environments for your organization and note the name of the life cycle environment you want to remove:
    # hammer lifecycle-environment list \
    # hammer lifecycle-environment delete \
    --name "My_Environment" \
6.5. Removing Life Cycle Environments from Smart Proxy server
When life cycle environments are no longer relevant to the host system or environments are added incorrectly to Smart Proxy server, you can remove the life cycle environments from Smart Proxy server.
You can use both the Foreman web UI and the Hammer CLI to remove life cycle environments from Smart Proxy.
  1. In the Foreman web UI, navigate to Infrastructure > Smart Proxies, and select the Smart Proxy that you want to remove a life cycle from.
  2. Click Edit and click the Life Cycle Environments tab.
  3. From the right menu, select the life cycle environments that you want to remove from Smart Proxy, and then click Submit.
  4. To synchronize Smart Proxy’s content, click the Overview tab, and then click Synchronize.
CLI procedure
  1. Select Smart Proxy server that you want from the list and take note of its id:
    # hammer capsule list
  2. To verify Smart Proxy server’s details, enter the following command:
    # hammer capsule info \
    --id Smart Proxy_ID
  3. Verify the list of life cycle environments currently attached to Smart Proxy server and take note of the Environment ID:
    --id Smart Proxy_ID
  4. Remove the life cycle environment from Smart Proxy server:
    --id Smart Proxy_ID
    --lifecycle-environment-id Lifecycle_Environment_ID
    Repeat this step for every life cycle environment that you want to remove from Smart Proxy server.
  5. Synchronize the content from Foreman server’s environment to Smart Proxy server:
    --id Smart Proxy_ID
6.6. Adding Life Cycle Environments to Smart Proxy servers
If your Smart Proxy server has the content functionality enabled, you must add an environment so that Smart Proxy can synchronize content from Foreman server and provide content to host systems.
Do not assign the Library lifecycle environment to your Smart Proxy server because it triggers an automated Smart Proxy sync every time the CDN updates a repository. This might consume multiple system resources on Smart Proxies, network bandwidth between Foreman and Smart Proxies, and available disk space on Smart Proxies.
You can use Hammer CLI on Foreman server or the Foreman web UI.
  1. In the Foreman web UI, navigate to Infrastructure > Smart Proxies, and select the Smart Proxy that you want to add a life cycle to.
  3. From the left menu, select the life cycle environments that you want to add to Smart Proxy and click Submit.
  4. To synchronize the content on the Smart Proxy, click the Overview tab and click Synchronize.
CLI procedure
  1. To display a list of all Smart Proxy servers, on Foreman server, enter the following command:
    Note the Smart Proxy ID of the Smart Proxy that you want to add a life cycle to.
  2. Using the ID, verify the details of your Smart Proxy:
    # hammer capsule info --id capsule_id
  3. To view the life cycle environments available for your Smart Proxy server, enter the following command and note the ID and the organization name:
    # hammer capsule content available-lifecycle-environments --id capsule_id
  4. Add the life cycle environment to your Smart Proxy server:
    # hammer capsule content add-lifecycle-environment \
    --id capsule_id --organization "My_Organization" \
    --lifecycle-environment-id lifecycle-environment_id
    Repeat for each life cycle environment you want to add to Smart Proxy server.
  5. Synchronize the content from Foreman to Smart Proxy.
    • To synchronize all content from your Foreman server environment to Smart Proxy server, enter the following command:
      # hammer capsule content synchronize --id capsule_id
    • To synchronize a specific life cycle environment from your Foreman server to Smart Proxy server, enter the following command:
      # hammer capsule content synchronize --id external_capsule_id \
7. Managing Content Views
Foreman uses Content Views to create customized repositories from the repositories. To do this, you must define which repositories to use and then apply certain filters to the content. These filters include both package filters, package group filters, errata filters, and module stream filters. You can use Content Views to define which software versions a particular environment uses. For example, a Production environment might use a Content View containing older package versions, while a Development environment might use a Content View containing newer package versions.
Alternatively, a Default Organization View is an application-controlled Content View for all content that is synchronized to Foreman. This type is useful if you want to register a host to Foreman and access content using a subscription, without manipulating content views and lifecycle environments.
Each Content View creates a set of repositories across each environment, which Foreman server stores and manages. When you promote a Content View from one environment to the next environment in the application life cycle, the respective repository on Foreman server updates and publishes the packages.
Content View Version and Contents
Version 2 - example_software-1.1-0.noarch.rpm
Version 1 - example_software-1.0-0.noarch.rpm
The repositories for Testing and Production contain the example_software-1.0-0.noarch.rpm package. If you promote Version 2 of the Content View from Development to Testing, the repository for Testing regenerates and then contains the example_software-1.1-0.noarch.rpm package:
  1. Create a Content View.
  2. Add one or more repositories that you want to the Content View.
  3. Optionally, create one or more filters to refine the content of the Content View.
  4. Optionally, resolve any package dependencies for a Content View.
  5. Publish the Content View.
  6. Optionally, promote the Content View to another environment.
  7. Attach the content host to the Content View.
If a repository is not associated with the Content View, the file /etc/yum.repos.d/redhat.repo remains empty and systems registered to it cannot receive updates.
Package Dependency Resolution
Package dependency is a complication of package management. For more information about how to manage package dependencies within Content Views, see Resolving Package Dependencies.
7.1. Creating a Content View
Use this procedure to create a simple Content View. To use the CLI instead of the Foreman web UI, see the CLI procedure.
While you can stipulate whether you want to resolve any package dependencies on a Content View by Content View basis, you might want to change the default Foreman settings to enable or disable package resolution for all Content Views. For more information, see Resolving Package Dependencies.
  2. In the Name field, enter a name for the view. Foreman automatically completes the Label field from the name you enter.
  3. In the Description field, enter a description of the view.
  4. Optional: if you want to solve dependencies automatically every time you publish this Content View, select the Solve Dependencies check box. Dependency solving slows the publishing time and might ignore any Content View filters you use. This can also cause errors when resolving dependencies for errata.
  5. Click Save to create the Content View.
  6. In the Repository Selection area, select the repositories that you want to add to your Content View, then click Add Repositories.
  7. Click Publish New Version and in the Description field, enter information about the version to log changes.
  8. Click Save.
  9. Optional: to force metadata regeneration on Yum repositories, from the Actions list for your Content View versions, select Regenerate Repository Metadata.
You can view the Content View in the Content Views window. To view more information about the Content View, click the Content View name.
To register a host to your Content View, see Registering Hosts in the Managing Hosts guide.
CLI procedure
  2. Create the Content View and add repositories:
    # hammer content-view create \
    --name "My_Content_View" \
    --repository-ids 1,2
  3. Publish the view:
    # hammer content-view publish \
  4. Optional: To add a repository to an existing Content View, enter the following command:
    # hammer content-view add-repository \
    --repository-id repository_ID
Foreman server creates the new version of the view and publishes it to the Library environment.
7.2. Viewing Module Streams
In Foreman, you can view the module streams of the repositories in your Content Views.
  1. In the Foreman web UI, navigate to Content > Content Views, and select the Content View that contains the modules you want to view.
  2. Click the Versions tab and select the Content View version that you want to view.
  3. Click the Module Streams tab to view the module streams that are available for the Content View.
  4. Use the Filter field to refine the list of modules.
  5. To view the information about the module, click the module.
7.3. Promoting a Content View
Use this procedure to promote Content Views across different lifecycle environments. To use the CLI instead of the Foreman web UI, see the CLI procedure.
Permission Requirements for Content View Promotion
The promote_or_remove_content_views permission restricts which Content Views a user can promote.
The promote_or_remove_content_views_to_environment permission restricts the environments to which a user can promote Content Views.
  1. In the Foreman web UI, navigate to Content > Content Views and select the Content View that you want to promote.
  2. Click the Versions tab for the Content View.
  3. Select the version that you want to promote and in the Actions column, click Promote.
  4. Select the environment where you want to promote the Content View, and click Promote Version.
  5. Click the Promote button again. This time select the Testing environment and click Promote Version.
  6. Finally click on the Promote button again. Select the Production environment and click Promote Version.
CLI procedure
  • Promote the Content View using the hammer content-view version promote each time:
    # hammer content-view version promote \
    --content-view "Database" \
    --version 1 \
    --version 1 \
    --version 1 \
7.4. Promoting a Content View Across All Life Cycle Environments within an Organization
Use this procedure to promote Content Views across all lifecycle environments within an organization.
  1. To promote a selected Content View version from Library across all life cycle environments within an organization, run the following Bash script:
    CVV_ID=3
    do
    done
  2. Display information about your Content View version to verify that it is promoted to the required lifecycle environments:
    # hammer content-view version info --id 3
7.5. Composite Content Views Overview
example_software
Application
Database
Operating System
  • PostgreSQL (Database)
  • MariaDB (Database)
Composite Content View 1 - example_software on PostgreSQL
Composite Content View 2 - example_software on MariaDB
MariaDB (Database)
Repository Restrictions
You cannot include more than one of each repository in Composite Content Views. For example, if you attempt to include two Content Views using the same repository in a Composite Content View, Foreman server reports an error.
7.6. Creating a Composite Content View
Use this procedure to create a composite content view. To use the CLI instead of the Foreman web UI, see the CLI procedure.
  4. Select the Composite View? check box to create a Composite Content View.
  5. Optional: select the Auto Publish check box if you want the Composite Content View to be republished automatically when a Content View is republished.
  6. Click Save.
  7. In the Add Content Views area, select the Content Views that you want to add to the Composite Content View, and then click Add Content Views.
  8. Click Publish New Version to publish the Composite Content View. In the Description field, enter a description and click Save.
  9. Click Promote and select the lifecycle environments to promote the Composite Content View to, enter a description, and then click Promote Version.
CLI procedure
  1. Before you create the Composite Content Views, list the version IDs for your existing Content Views:
    # hammer content-view version list \
  2. Create a new Composite Content View. When the --auto-publish option is set to yes, the Composite Content View is automatically republished when a Content View it includes is republished:
    --composite \
    --auto-publish yes \
    --description "Example Composite Content View" \
  3. Add a component Content View to the Composite Content View. You must include the Content View Version ID and use the --latest option. To include multiple component Content Views to the Composite Content View, repeat this step for every Content View you want to include:
    # hammer content-view component add \
    --component-content-view-id Content_View_Version_ID \
    --latest \
    --composite-content-view "Example_Composite_Content_View"
  4. Publish the Composite Content View:
    --description "Initial version of Composite Content View" \
  5. Promote the Composite Content View across all environments:
    --version 1 \
    --version 1 \
    --version 1 \
7.7. Content Filter Overview
Content Views also use filters to include or restrict certain RPM and DEB content. Without these filters, a Content View includes everything from the selected repositories.
Table 1. Filter Types
Filter Type Description
Include
Exclude
You start with all content from selected repositories, then select which content to remove. Use this filter when you want to use most of a particular content repository but exclude certain packages, such as blacklisted packages. The filter uses all content in the repository except for the content you select.
Include and Exclude Filter Combinations
Content Types
There are also five types of content to filter:
Table 2. Content Types
Content Type Description
Package
Filter packages based on their name and version number. The Package option filters non-modular RPM packages and errata.
Package Group
Filter packages based on package groups. The list of package groups is based on the repositories added to the Content View.
Erratum (by ID)
Select which specific errata to add to the filter. The list of Errata is based on the repositories added to the Content View.
Erratum (by Date and Type)
Module Streams
7.8. Resolving Package Dependencies
In Foreman, you can use the package dependency resolution feature to ensure that any dependencies that packages have within a Content View are added to the dependent repository as part of the Content View publication process.
You can select to resolve package dependencies for any Content View that you want, or you can change the default setting to enable or disable resolving package dependencies for all new Content Views.
Note that resolving package dependencies can cause significant delays to Content View promotion. The package dependency resolution feature does not consider packages that are installed on your system independently of the Content View or solve dependencies across repositories.
Resolving Package Dependencies and Filters
Filters do not resolve any dependencies of the packages listed in the filters. This might require some level of testing to determine what dependencies are required.
If you add a filter that excludes some packages that are required and the Content View has dependency resolution enabled, Foreman ignores the rules you create in your filter in favor of resolving the package dependency.
If you create a content filter for security purposes, to resolve a package dependency, Foreman can add packages that you might consider insecure.
To resolve package dependencies by default, complete the following steps:
  1. In the Foreman web UI, navigate to Administer > Settings and click the Content tab.
  2. Locate the Content View Dependency Solving Default, and select Yes.
You can also set the default level of dependency resolution that you want. You can select between adding packages to solve dependencies only if the required package does not exist, or to add the latest packages to resolve the dependency even if the package exists in the repository.
To set the default level of dependency resolution, complete the following steps:
  2. Locate the Content View Dependency Solving Algorithm and select one of the following options:
    • To add the package that resolves the dependency only if it does not exist in the repository, select Conservative.
    • To add the package that resolves the dependency regardless of whether or not it exists in the repository, select Greedy.
7.9. Content Filter Examples
Example 1
Create a repository with the base Red Hat Enterprise Linux packages. This filter requires a Red Hat Enterprise Linux repository added to the Content View.
Filter:
  • Inclusion Type: Include
  • Content Type: Package Group
Example 2
Create a repository that excludes all errata, except for security updates, after a certain date. This is useful if you want to perform system updates on a regular basis with the exception of critical security updates, which must be applied immediately. This filter requires a Red Hat Enterprise Linux repository added to the Content View.
Filter:
  • Inclusion Type: Exclude
Example 3
Filter 1:
Filter 2:
Example 4
Filter 1:
  • Content Type: Module Stream
  • Filter: Select only the specific module stream that you want for the Content View, for example ant, and click Add Module Stream.
Filter 2:
  • Filter: Add a rule to filter any non-modular packages that you want to exclude from the Content View. If you do not filter the packages, the Content View filter includes all non-modular packages associated with the module stream ant. Add a rule to exclude all * packages, or specify the package names that you want to exclude.
7.10. Creating a Content Filter for Yum Content
You can filter Content Views containing Yum content to include or exclude specific packages, package groups, errata, or module streams. Filters are based on a combination of the name, version, and architecture.
  1. In the Foreman web UI, navigate to Content > Content Views and select a Content View.
  2. Select Yum Content > Filters and click New Filter.
  3. In the Name field, enter a name for your filter.
  4. From the Content Type list, select the content type that you want to filter. Depending on what you select for the new filter’s content type, different options appear.
  5. From the Inclusion Type list, select either Include or Exclude.
  6. Optional: In the Description field, enter a description for the filter.
  7. Click Save to create your content filter.
  8. Depending on what you enter for Content Type, add rules to create the filter that you want.
  9. Click the Affected repositories tab to select which specific repositories use this filter.
  10. Click Publish New Version to publish the filtered repository.
  11. Optional: In the Description field, enter a description of the changes.
  12. Click Save to publish a new version of the Content View.
CLI procedure
  1. Add a filter to the Content View. Use the --inclusion false option to set the filter to an Exclude filter:
    # hammer content-view filter create \
    --name "Errata Filter" \
    --inclusion false \
  2. Add a rule to the filter:
    # hammer content-view filter rule create \
    --start-date "YYYY-MM-DD" \
    --types enhancement,bugfix \
    --date-type updated \
  3. Publish the Content View:
    --version 1 \
    --version 1 \
    --version 1 \
7.11. Creating a Content Filter for APT Content
You can filter Content Views containing deb content to include or exclude specific packages or package groups. Filters are based on a combination of the name and the architecture.
  2. Select APT Content > Filters and click New Filter.
CLI procedure
    --description "My_Content_View_Filter_Description" \
    --inclusion false \
    --type erratum
    --content-view-filter "My_Errata_Filter" \
    --version 1
    --version 1
    --version 1
8. Synchronizing Content Between Foreman Servers
In a Foreman setup with multiple Foreman servers, you can use Inter-Server Synchronization (ISS) to synchronize content from one upstream server to one or more downstream servers.
ISS Network Sync
Configure your Foreman to synchronize content over a network. For more information, see Configuring Foreman Server to Synchronize Content over a Network.
ISS Export Sync
If your upstream and downstream servers are air-gapped, you can synchronize content using export and import.
Configure your Foreman to synchronize content using export and import. For more information, see Configuring Foreman Server to Synchronize Content Using Exports.
Additional Resources
8.1. How to Synchronize Content Using Export and Import
There are multiple approaches for synchronizing content using the export and import workflow:
  • You employ the upstream Foreman server as a content store, which means that you sync the whole Library rather than Content View versions. This approach offers the simplest export/import workflow. In such case, you can manage the versions downstream. For more information, see Using an Upstream Foreman server as a Content Store.
  • You use the upstream Foreman server to sync Content View versions. This approach offers more control over what content is synced between Foreman servers. For more information, see Using an Upstream Foreman server to Sync Content View Versions.
  • You sync a single repository. This can be useful if you use the Content-View syncing approach, but you want to sync an additional repository without adding it to an existing Content View. For more information, see Synchronizing a Single Repository.
8.1.1. Using an Upstream Foreman server as a Content Store
In this scenario, you use the upstream Foreman server as a content store for updates rather than to manage content. You use the downstream Foreman server to manage content for all infrastructure behind the isolated network. You export the Library content from the upstream Foreman server and import it into the downstream Foreman server.
On the upstream Foreman server
  2. Enable the content that you want to synchronize. For more information, see Enabling Red Hat Repositories.
    1. On the first export, perform a complete Library export so that all the synchronized content is exported. This generates content archives that you can later import into one or more downstream Foreman servers. For more information on performing a complete Library export, see Exporting the Library Environment.
    2. Export all future updates on the upstream Foreman server incrementally. This generates leaner content archives that contain only a recent set of updates. For example, if you enable and synchronize a new repository, the next exported content archive contains content only from the newly enabled repository. For more information on performing an incremental Library export, see Exporting the Library Environment Incrementally.
On the downstream Foreman server
  1. Bring the content exported from the upstream Foreman server over to the hard disk.
  3. Import the content to an organization using the procedure outlined in Importing into the Library Environment.
    You can then manage content using Content Views or Lifecycle Environments as you require.
8.1.2. Using an Upstream Foreman server to Sync Content View Versions
In this scenario, you use the upstream Foreman server not only as a content store, but also to synchronize content for all infrastructure behind the isolated network. You curate updates coming from the CDN into Content Views and Lifecycle Environments. Once you promote content to a designated Lifecycle Environment, you can export the content from the upstream Foreman server and import it into the downstream Foreman server.
    1. For the first export, perform a complete Version export on the Content View Version that you want to export. For more information see, Exporting a Content View Version. This generates content archives that you can import into one or more downstream Foreman servers.
    2. Export all future updates in the connected Foreman servers incrementally. This generates leaner content archives that contain changes only from the recent set of updates. For example, if your Content View has a new repository, this exported content archive contains only the latest changes. For more information, see Exporting a Content View Version Incrementally.
    3. When you have new content, republish the Content Views that include this content before exporting the increment. For more information, see Managing Content Views. This creates a new Content View Version with the appropriate content to export.
  3. Import the content to the organization that you want. For more information, see Importing a Content View Version. This will create a Content View Version from the exported content archives and then import content appropriately.
8.1.3. Synchronizing a Single Repository
    1. On the first export, perform a complete repository export so that all the synchronized content is exported. This generates content archives that you can later import into one or more downstream Foreman servers. For more information on performing a complete repository export, see Exporting a Repository.
    2. Export all future updates on the upstream Foreman server incrementally. This generates leaner content archives that contain only a recent set of updates. For more information on performing an incremental repository export, see Exporting a Repository Incrementally.
  3. Import the content to an organization. See Importing a Repository.
8.2. Exporting the Library Environment
You can export contents of all Yum repositories in the Library environment of an organization to an archive file from Foreman server and use this archive file to create the same repositories in another Foreman server or in another Foreman server organization. The exported archive file contains the following data:
  • A JSON file containing Content View version metadata
Foreman server exports only RPM and kickstart files included in a Content View version. Foreman does not export the following content:
  • Docker content
To export the contents of the Library lifecycle environment of the organization, ensure that Foreman server where you want to export meets the following conditions:
  • Ensure that you set download policy to Immediate for all repositories within the Library lifecycle environment you export. For more information, see Download Policies Overview.
  • Ensure that you synchronize Products that you export to the required date.
Export the Library Content of an Organization
  2. Verify that the archive containing the exported version of a Content View is located in the export directory:
    total 68M
  3. A new Content View Export-Library is created in the organization. This content view contains all the repositories belonging to this organization. A new version of this Content View is published and exported automatically.
Export with chunking
# hammer content-export complete library \
--chunk-size-gb=2 \
8.3. Exporting the Library Environment Incrementally
Exporting Library content can be a very expensive operation in terms of system resources. Organizations that have multiple Red Hat Enterprise Linux trees can occupy several gigabytes of space on Foreman server.
    # hammer content-export incremental library --organization="My_Organization"
    Generated /var/lib/pulp/exports/My_Organization/Export-Library/3.0/2021-03-02T04-22-14-00-00/metadata.json
    # ls -lh /var/lib/pulp/exports/My_Organization/Export-Library/3.0/2021-03-02T04-22-14-00-00/
    total 172K
    -rw-r--r--. 1 pulp pulp 161K Mar  2 04:22 export-436882d8-de5a-48e9-a30a-17169318f908-20210302_0422.tar.gz
    -rw-r--r--. 1 pulp pulp  492 Mar  2 04:22 metadata.json
8.4. Exporting a Content View Version
You can export a version of a Content View to an archive file from Foreman server and use this archive file to create the same Content View version on another Foreman server or on another Foreman server organization. Foreman exports composite Content Views as normal content views. The composite nature is not retained. On importing the exported archive, a regular Content View is created or updated on your downstream Foreman server. The exported archive file contains the following data:
  • An archive file containing all the repositories included into the Content View version
Foreman server exports only RPM and kickstart files added to a version of a Content View. Foreman does not export the following content:
  • Docker content
  • Content View definitions and metadata, such as package filters.
To export a Content View, ensure that Foreman server where you want to export meets the following conditions:
  • Ensure that you set download policy to Immediate for all repositories within the Content View you export. For more information, see Download Policies Overview.
To Export a Content View Version
  1. List versions of the Content View that are available for export:
Export a Content View version
    # hammer content-export complete version \
    --version=1.0 \
--chunk-size-gb=2 \
--version=1.0
8.5. Exporting a Content View Version Incrementally
Exporting complete versions can be a very expensive operation in terms of system resources. Content View versions that have multiple Red Hat Enterprise Linux trees can occupy several gigabytes of space on Foreman server.
The example below targets the version 2.0 for export, because the version 1.0 was exported previously.
    # hammer content-export incremental version \
    --version=2.0
  2. Optional: View the exported Content View:
    # ls -lh /var/lib/pulp/exports/My_Organization/view/2.0/2021-02-25T21-45-34-00-00/
8.6. Exporting a Repository
You can export the content of a repository in the Library environment of an organization from Foreman server. You can use this archive file to create the same repository in another Foreman server or in another Foreman server organization.
You can export the following content from Foreman server:
  • RPM repositories
  • Kickstart repositories
  • Ansible repositories
  • file repositories
You cannot export Docker content nor DEB repositories from Foreman server.
To export the contents of a repository, ensure that Foreman server from which you want to export, meets the following conditions:
  • Ensure that the /var/lib/pulp/exports directory has enough free storage space equivalent to the size of the repositories being exported for temporary files created during the export process.
  • Ensure that you set download policy to Immediate for the repository within the Library lifecycle environment you export. For more information, see Download Policies Overview.
Export a Repository
  1. Use the repository name or ID to export.
    # hammer content-export complete repository \
     --product="My_Product" \
     --name="My_Repository"
    # ls -lh /var/lib/pulp/exports/My_Organization/Export-My_Repository/1.0/2021-03-02T03-35-24-00-00
    total 68M
    -rw-r--r--. 1 root root 443 Mar  2 03:35 metadata.json
Export a Repository with Chunking
In many cases the exported content archive may be several gigabytes in size. If you want to split it into chunks of smaller size, you can use the --chunk-size-gb argument in the export command and limit the size by an integer value in gigabytes.
  1. Export content into archive chunks of a limited size, such as 2 GB:
    --chunk-size-gb=2 \
    Generated /var/lib/pulp/exports/My_Organization/Export-My_Repository/1.0/2021-03-02T03-35-24-00-00/metadata.json
    # ls -lh /var/lib/pulp/exports/My_Organization/Export-My_Repository/1.0/2021-03-02T03-35-24-00-00/
8.7. Exporting a Repository Incrementally
Exporting a repository can be a very expensive operation in terms of system resources. A typical Red Hat Enterprise Linux tree may occupy several gigabytes of space on Foreman server.
    # hammer content-export incremental repository \
    Generated /var/lib/pulp/exports/My_Organization/Export-My_Repository/3.0/2021-03-02T03-35-24-00-00/metadata.json
    total 172K
8.8. Keeping Track of Your Exports
Foreman keeps records of all exports. Each time you export content on the upstream Foreman server, the export is recorded and maintained for future querying. You can use the records to organize and manage your exports, which is useful especially when exporting incrementally.
When exporting content from the upstream Foreman server for several downstream Foreman servers, you can also keep track of content exported for specific servers. This helps you track which content was exported and to where.
Tracking Destinations of Library Exports
    --version=1.0
Tracking Destinations of Content View Exports
  • Specify the destination server when exporting a Content View version:
    --version=1.0
Querying Export Records
8.9. Importing into the Library Environment
You can import exported Library content into the Library lifecycle environment of an organization on another Foreman server. For more information about exporting contents from the Library environment, see Exporting the Library Environment.
  1. Copy the exported files to a subdirectory of /var/lib/pulp/imports on Foreman server where you want to import.
    total 68M
  3. Identify the Organization that you wish to import into.
  4. To import the Library content to Foreman server, enter the following command:
    # hammer content-import library \
  5. To verify that you imported the Library content, check the contents of the Product and Repositories. A new Content View called Import-Library is created in the target organization. This Content View is used to facilitate the Library content import.
    By default, this Content View is not shown in the Foreman web UI. Import-Library is not meant to be assigned directly to hosts. Instead, assign your hosts to Default Organization View or another Content View as you would normally.
8.10. Importing a Content View Version
You can import an exported Content View version to create a version with the same content in an organization on another Foreman server. For more information about exporting a Content View version, see Exporting a Content View Version.
When you import a Content View version, it has the same major and minor version numbers and contains the same repositories with the same packages and errata. Custom Repositories, Products and Content Views are automatically created if they do not exist in the importing organization.
  • The user importing the Content View version must have the Content Importer Role.
  4. To import the Content View version to Foreman server, enter the following command:
    # hammer content-import version \
    --organization-id=My_Organization_ID \
  5. To verify that you imported the Content View version successfully, list Content View versions for your organization:
8.11. Importing a Repository
You can import an exported repository into an organization on another Foreman server. For more information about exporting content of a repository, see Exporting a Repository.
    total 68M
    # hammer content-import repository \
  5. To verify that you imported the repository, check the contents of the Product and Repository.
8.12. Exporting and Importing Content using Hammer CLI Cheat Sheet
Table 3. Export
Intent Command
Fully export a Content View version
Export a Content View version promoted to the Dev Environment
Export a Content View in smaller chunks (2-GB slabs)
Incrementally export a Content View version (assuming you have exported something previously)
Fully export a Repository
List exports
Table 4. Import
Intent Command
Import to a Content View version
Import a Repository
9. Managing Activation Keys
Activation keys provide a method to automate system registration and subscription attachment. You can create multiple keys and associate them with different environments and Content Views. For example, you might create a basic activation key with a subscription for Red Hat Enterprise Linux workstations and associate it with Content Views from a particular environment.
  • Associated subscriptions and subscription attachment behavior
  • A life cycle environment and a Content View
  • Host collection membership
  • System purpose
Content View Conflicts between Host Creation and Registration
When you provision a host, Foreman uses provisioning templates and other content from the Content View that you set in the host group or host settings. When the host is registered, the Content View from the activation key overwrites the original Content View from the host group or host settings. Then Foreman uses the Content View from the activation key for every future task, for example, rebuilding a host.
Using the Same Activation Key with Multiple Content Hosts
Using Multiple Activation Keys with a Content Host
--hostgroup "My_Host_Group" \
--name "My_Activation_Key" \
9.1. Creating an Activation Key
  • Are there any subscriptions associated with the activation key?
  • Is the auto-attach option enabled?
  • For Red Hat Enterprise Linux 8 hosts: Is there system purpose set on the activation key?
Note that Foreman automatically attaches subscriptions only for the products installed on a host. For subscriptions that do not list products installed on Red Hat Enterprise Linux by default, such as the Extended Update Support (EUS) subscription, use an activation key specifying the required subscriptions and with the auto-attach disabled.
  1. Activation key that attaches subscriptions automatically.
    With no subscriptions specified and auto-attach enabled, hosts using the activation key search for the best fitting subscription from the ones provided by the Content View associated with the activation key. This is similar to entering the subscription-manager --auto-attach command. For Red Hat Enterprise Linux 8 hosts, you can configure the activation key to set system purpose on hosts during registration to enhance the automatic subscriptions attachment.
  2. Activation key providing a custom set of subscription for auto-attach.
  3. Activation key with the exact set of subscriptions.
Products
If a product, typically containing content not provided by Red Hat, is assigned to an activation key, this product is always enabled for the registered content host regardless of the auto-attach setting.
  1. In the Foreman web UI, navigate to Content > Activation keys and click Create Activation Key.
  3. If you want to set a limit, clear the Unlimited hosts check box, and in the Limit field, enter the maximum number of systems you can register with the activation key. If you want unlimited hosts to register with the activation key, ensure the Unlimited Hosts check box is selected.
  6. From the Content View list, select a Content View to use. If you intend to use the deprecated Katello Agent instead of Remote Execution, the Content View must contain the https://yum.theforeman.org/client/3.2/ repository because it contains the katello-agent package.
  7. If Simple Content Access (SCA) is not enabled:
    1. Click the Subscriptions tab, then click the Add submenu.
    2. Click the checkbox under the subscription you created before.
    3. Click Add Selected.
  8. If SCA is enabled:
    1. In the Repository Sets tab, ensure only your named repository is enabled.
  9. Click Save.
  10. Optional: For Red Hat Enterprise Linux 8 hosts, in the System Purpose section, you can configure the activation key with system purpose to set on hosts during registration to enhance subscriptions auto attachment.
CLI procedure
  1. Create the activation key:
    # hammer activation-key create \
    --unlimited-hosts \
    --lifecycle-environment "Development" \
    --content-view "Stack" \
  2. Optional: For Red Hat Enterprise Linux 8 hosts, enter the following command to configure the activation key with system purpose to set on hosts during registration to enhance subscriptions auto attachment.
    # hammer activation-key update \
    --service-level "Standard" \
    --purpose-role "Red Hat Enterprise Linux Server" \
    --purpose-addons "addons"
  3. Obtain a list of your subscription IDs:
  4. Attach the Red Hat Enterprise Linux subscription UUID to the activation key:
    # hammer activation-key add-subscription \
    --subscription-id My_Subscription_ID \
  5. List the product content associated with the activation key:
    # hammer activation-key product-content \
  6. Override the default auto-enable status for the https://yum.theforeman.org/client/3.2/ repository. The default status is set to disabled. To enable, enter the following command:
    # hammer activation-key content-override \
    --content-label https://yum.theforeman.org/client/3.2/el7/x86_64/foreman-client-release.rpm \
    --value 1 \
9.2. Updating Subscriptions Associated with an Activation Key
Use this procedure to change the subscriptions associated with an activation key. To use the CLI instead of the Foreman web UI, see the CLI procedure.
Note that changes to an activation key apply only to machines provisioned after the change. To update subscriptions on existing content hosts, see Updating Red Hat Subscriptions on Multiple Hosts.
  1. In the Foreman web UI, navigate to Content > Activation keys and click the name of the activation key.
  2. Click the Subscriptions tab.
  3. To remove subscriptions, select List/Remove, and then select the check boxes to the left of the subscriptions to be removed and then click Remove Selected.
  4. To add subscriptions, select Add, and then select the check boxes to the left of the subscriptions to be added and then click Add Selected.
  5. Click the Repository Sets tab and review the repositories' status settings.
  6. To enable or disable a repository, select the check box for a repository and then change the status using the Select Action list.
  7. Click the Details tab, select a Content View for this activation key, and then click Save.
CLI procedure
  1. List the subscriptions that the activation key currently contains:
    # hammer activation-key subscriptions \
    --name My_Activation_Key \
  2. Remove the required subscription from the activation key:
    # hammer activation-key remove-subscription \
    --subscription-id ff808181533518d50152354246e901aa \
    For the --subscription-id option, you can use either the UUID or the ID of the subscription.
  3. Attach new subscription to the activation key:
  4. List the product content associated with the activation key:
  5. Override the default auto-enable status for the required repository:
    --content-label content_label \
    --value 1 \
    For the --value option, enter 1 for enable, 0 for disable.
9.3. Using Activation Keys for Host Registration
  • Registering new hosts during provisioning through Foreman. The kickstart provisioning templates in Foreman contain commands to register the host using an activation key that is defined when creating a host.
  • Registering existing Red Hat Enterprise Linux hosts. Configure Subscription Manager to use Foreman server for registration and specify the activation key when running the subscription-manager register command.
You can register hosts with Foreman using the host registration feature, the Foreman API, or Hammer CLI.
  2. Click Generate to create the registration command.
  3. Click on the files icon to copy the command to your clipboard.
  4. Log on to the host you want register and run the previously generated command.
  5. Check the /etc/yum.repos.d/redhat.repo and ensure that the appropriate repositories have been enabled.
CLI procedure
  2. Log on to the host you want register and run the previously generated command.
  3. Check the /etc/yum.repos.d/redhat.repo and ensure that the appropriate repositories have been enabled.
API procedure
    --user "My_User_Name" \
    Use an activation key to simplify specifying the environments. For more information, see Managing Activation Keys in the Content Management guide.
    To enter a password as command line argument, use username:password syntax. Keep in mind this can save the password in the shell history.
    For more information about registration see Registering a Host to Foreman.
# subscription-manager register --org="My_Organization" \
--activationkey="ak-VDC,ak-OpenShift"
Settings Conflicts
  • Settings that do not conflict and the host gets the union of them: Subscriptions and Host Collections.
  • Settings that influence the behavior of the key itself and not the host configuration: Content Host Limit and Auto-Attach.
9.4. Enabling Auto-Attach
You can enable auto-attach and have no subscriptions associated with the key. This type of key is commonly used to register virtual machines when you do not want the virtual machine to consume a physical subscription, but to inherit a host-based subscription from the hypervisor. For more information, see Configuring Virtual Machine Subscriptions in Foreman.
  1. In the Foreman web UI, navigate to Content > Activation Keys.
  2. Click the activation key name that you want to edit.
  3. Click the Subscriptions tab.
  4. Click the edit icon next to Auto-Attach.
  5. Select or clear the check box to enable or disable auto-attach.
  6. Click Save.
CLI procedure
  • Enter the following command to enable auto-attach on the activation key:
    # hammer activation-key update --name "My_Activation_Key" \
    --organization "My_Organization" --auto-attach true
9.5. Setting the Service Level
  5. Click Save.
CLI procedure
  • Enter the following command to set a default service level to Premium on the activation key:
    --organization "My_Organization" --service-level premium
10. Managing SUSE Content
You can use the SCC Manager plug-in to comfortably manage content from SUSE using your Foreman.
10.1. Preparing SUSE Installation Media
Extract the SUSE installation medium on your Foreman server to perform offline installations. This example prepares the installation medium for SUSE Linux Enterprise Server 15 SP3.
  1. Download the SLES 15 SP3 installation medium from suse.com/download/sles.
  2. Download the signature and checksum from suse.com.
  3. Transfer the .iso image, the signature, and the checksum from your local machine to Foreman server using scp:
    # scp SLE-15-SP3-Full-x86_64-GM-Media1.iso root@foreman.example.com:/tmp/
    # scp SLE-15-SP3-Full-x86_64-GM-Media1.iso.sha256 root@foreman.example.com:/tmp/
    # scp sles_15_sp3.signature root@foreman.example.com:/tmp/
  4. On your Foreman server, verify the integrity and authenticity of the .iso image using GPG public keys:
    # cd /tmp
    # gpg --verify sles_15_sp3.signature SLE-15-SP3-Full-x86_64-GM-Media1.iso.sha256
    # echo '2a6259fc849fef6ce6701b8505f64f89de0d2882857def1c9e4379d26e74fa56 SLE-15-SP3-Full-x86_64-GM-Media1.iso' | sha256sum --check
  5. Mount the .iso image:
    # mount SLE-15-SP3-Full-x86_64-GM-Media1.iso /mnt
  6. Copy the content of the mounted installation medium to the pub directory:
    # mkdir -p /var/www/html/pub/installation_media/sles/15sp3
    # cp -a /mnt/* /var/www/html/pub/installation_media/sles/15sp3/
  7. Unmount and delete the .iso image:
    # cd
    # umount /mnt
    # rm -f /tmp/SLE-15-SP3-Full-x86_64-GM-Media1.iso
    # rm -f /tmp/SLE-15-SP3-Full-x86_64-GM-Media1.iso.sha256
    # rm -f /tmp/sles_15_sp3.signature
Use the path to the local installation media files when creating an installation medium, for example http://foreman.example.com/pub/installation_media/sles/15sp3/.
10.2. Creating a SUSE Operating System
Create an installation media and operating system entry for SLES 15 SP3.
Prerequisite
  • An extracted .iso image on Foreman or an HTTP server that can be reached during the host provisioning process.
  1. In the Foreman web UI, navigate to Hosts > Installation Media and click Create Medium.
  2. Set a Name for the installation medium for SLES 15 SP3. Add local to the name as the path of the extracted .iso image points to your Foreman.
  3. Set the Path of the extracted .iso image. The content of /var/www/html/pub/ is publicly available on http://foreman.example.com/pub/. If you extract the .iso image to /var/www/html/pub/installation_media/sles/15sp3/, the path is http://foreman.example.com/pub/installation_media/sles/15sp3/.
  4. Set the Operating System Family to SUSE for all SLES systems.
  5. Set a location and organization context for the installation media.
  6. On the Parameters tab, add the sle-module-basesystem-url parameter, select the string type, and enter the value http://foreman.example.com/pub/installation_media/sles/15sp3/. Note that the value depends on the path of the extracted .iso image.
    (SLES 12 only) Add the parameter additional_media, select the string type, and enter the value "".
  7. Click Submit to save the installation media entry for SLES 15 SP3.
  8. In the Foreman web UI, navigate to Hosts > Operating Systems and click Create Operating System.
  9. Set the Name of the operating system. Choose a name as reported by Ansible, Puppet, or Salt as fact.
  10. Set the Major Version of SLES, for example 15.
  11. Set the Minor Version of SLES, for example 3 for SLES 15 SP3.
  12. Optional: Add an arbitrary Description.
  13. Set the Family to SUSE for all SLES systems.
  14. Set the Root Password Hash to SHA256 for SLES 15 SP3.
  15. Assign the Architectures to SLES 15 SP3.
  16. Click Submit to save the operating system entry.
  17. In the Foreman web UI, navigate to Hosts > Partition Tables and click Create Partition Table. The partition tables are stored in the /usr/share/foreman/app/views/unattended/partition_tables_templates/ directory on your Foreman server.
    For more information, see Partition Tables in the Provisioning guide.
  18. In the Foreman web UI, navigate to Hosts > Provisioning Templates and click Create Template. The provisioning templates are stored in the /usr/share/foreman/app/views/unattended/provisioning_templates/ directory on your Foreman server.
    For more information, see Provisioning Templates in the Provisioning guide.
  19. In the Foreman web UI, navigate to Hosts > Operating Systems.
  20. Select the previously created operating system.
  21. On the Partition Table tab, select the previously created partition table.
  22. On the Templates tab, select the previously created provisioning template.
  23. Click Submit to save the operating system entry.
10.3. Installing the SCC Manager Plug-in
Perform the following steps to install the SCC Manager plug-in on your Foreman.
  2. Install the SCC Manager plug-in on your Foreman:
    # yum install -y tfm-rubygem-foreman_scc_manager
  3. Run database migrations on your Foreman:
    # foreman-rake db:migrate
    # foreman-rake db:seed
  4. Restart Foreman services:
Continue with adding your SCC account to Foreman.
10.4. Adding SCC Accounts to Foreman
Prerequisite
  1. In the Foreman web UI, navigate to Content > Content Credentials and click Create Content Credential.
    Add the GPG public key for SLES 15 SP3 from suse.com.
  2. In the Foreman web UI, navigate to Content > SUSE Subscriptions.
  3. Click Add SCC Account.
  4. Enter your account name and password.
  5. Optional: Set a Sync interval to periodically update the SCC authentication tokens. Note that this does not refer to synchronizing content to Foreman.
  6. Assign a GPG key for SUSE products to the SCC products. zypper automatically verifies the signatures of each software package to ensure their authenticity.
    You can also set the GPG public key for SUSE repositories at a later stage. However, changing it does not affect already synchronized products. If you already have synchronized products in Foreman, navigate to Content > Products and replace the GPG key in each respective product.
  7. Click Test connection to verify your account information. Note that you have to re-enter your password if you are trying to check the connection to an SCC account that has already been saved to Foreman.
  8. Click Submit to save your SCC account to Foreman.
  9. In the Foreman web UI, navigate to Content > SUSE Subscriptions, select the previously added SCC account, and click Sync to fetch a list of products associated to your SCC account.
Continue with importing products from your newly added SCC account.
10.5. Switching SCC Accounts
Warning
If you want to switch your SCC account and retain the synchronized content, do not immediately delete your old SCC account, even if it is expired. If you delete your old SCC account, you cannot reuse existing repositories, products, content views, and composite content views.
  1. In the Foreman web UI, navigate to Content > SUSE Subscriptions.
  2. Select your SCC account.
  3. Enter a new Login and Password.
  4. Click Submit to change your SCC account.
10.6. Importing SUSE Products
  2. Click Select products on your previously synchronized SCC account.
  3. Select all SUSE products you want to synchronize to Foreman. This guide assumes you have access to and select the SUSE Linux Enterprise Server 15 SP3 x86_64 product.
  4. Click Submit to create the selected SUSE products in Foreman.
10.7. Synchronizing SUSE Content
You can use Foreman to synchronize SUSE content to deploy, attach, and serve content to managed hosts.
  2. Select the SUSE Linux Enterprise Server 15 SP3 x86_64 product and click Sync Now to synchronize the SUSE repositories for SLES 15 SP3 to Foreman.
  3. In the Foreman web UI, navigate to Content > Content Views.
  4. Create a Content View called SLES 15 SP3 comprising the SLES repositories created in the SLES 15 SP3 product and a Content View called SLES 15 SP3 Foreman client comprising the Foreman client repository created in the SLES 15 SP3 Foreman client product.
    For more information, see creating a Content View.
  5. Publish a new version of both Content Views.
    For more information, see promoting a Content View.
  6. In the Foreman web UI, navigate to Content > Content Views.
  7. Click Create Content View to create a Composite Content View called Composite SLES 15 SP3 comprising the previously published SLES 15 SP3 Content View, the SLES 15 SP3 Foreman client Content View, and optionally further Content Views of your choice, for example a Content View containing Puppet. For more information, see creating a Composite Content View.
  8. Publish a new version and promote this version to the Life Cycle Environment of your choice.
  9. In the Foreman web UI, navigate to Content > Activation Keys.
  10. Click Create Activation Key to create an Activation Key called sles-15-sp3.
    For more information, see creating an Activation Key.
  11. On the Details tab, select a Life Cycle Environment and Composite Content View.
  12. On the Subscriptions tab, select the necessary subscriptions, for example SLES 15 SP3, SLES 15 SP3 Foreman client, and Puppet.
You can now create a Host Group and assign the previously created Activation Key to it to deploy hosts running SLES 15 SP3 more comfortably.
11. Managing Errata
Red Hat Enterprise Linux users receive errata for each release of official Red Hat RPMs. SUSE Linux Enterprise Server users receive errata for each release of official SUSE RPMs. There are three types of advisories (in order of importance):
Security Advisory
Bug Fix Advisory
Product Enhancement Advisory
For Red Hat Enterprise Linux, Foreman imports errata information when synchronizing repositories with Red Hat’s Content Delivery Network (CDN). For SUSE Linux Enterprise Server, Foreman imports errata information when synchronizing repositories with SUSE Customer Center. For Alma Linux and Rocky Linux, Foreman imports errata information when synchronizing repositories with upstream repositories. Foreman also provides tools to inspect and filter errata, allowing for precise update management. This way, you can select relevant updates and propagate them through Content Views to selected content hosts.
In Foreman, there are two keywords that describe an erratum’s relationship to the available content hosts:
Applicable
Installable
An erratum that applies to one or more content hosts and is available to install on the content host. Installable errata are available to a content host from life cycle environment and the associated Content View, but are not yet installed.
11.1. Inspecting Available Errata
The following procedure describes how to view and filter the available errata and how to display metadata of the selected advisory. To use the CLI instead of the Foreman web UI, see the CLI procedure.
  1. In the Foreman web UI, navigate to Content > Errata to view the list of available errata.
    • The Applicable check box is selected by default to view only applicable errata in the selected repository. Select the Installable check box to view only errata marked as installable.
      parameter operator value
      See Parameters Available for Errata Search for the list of parameters available for search. Find the list of applicable operators in Supported Operators for Granular Search in Administering Foreman. Automatic suggestion works as you type. You can also combine queries with the use of and and or operators. For example, to display only security advisories related to the kernel package, type:
    • On the Content Hosts tab, you can apply the erratum to selected content hosts as described in Applying Errata to Multiple Hosts.
    • The Repositories tab lists repositories that already contain the erratum. You can filter repositories by the environment and Content View, and search for them by the repository name.
  1. In the Foreman web UI, navigate to Hosts > All Hosts and select the host you require.
  7. Using the vertical ellipsis icon next to the errata you want to add to the host, select Apply via Katello agent if you have no connectivity to the target host using SSH.
  8. Select Apply via Remote Execution to use Remote Execution, or Apply via customized remote execution if you want to customize the remote execution.
  9. Click Submit.
CLI procedure
    # hammer erratum list
    # hammer erratum list \
    --product-id 7 \
    --order "type desc"
11.2. Parameters Available for Errata Search
Parameter Description Example
bug
bug = 1172165
cve
Search by the CVE number.
cve = CVE-2015-0235
id
id = RHBA-2014:2004
issued
issued < "Jan 12,2015"
package
package_name
package_name = glib2
severity
severity = Critical
title
Search by the advisory title.
title ~ openssl
type
type = bugfix
updated
updated = "6 days ago"
11.3. Applying Installable Errata
Use the following procedure to view a list of installable errata and select errata to install. .Procedure
  2. If there are errata associated with the host they are displayed in an Installable Errata card on the new Host page.
  5. Using the vertical ellipsis icon next to the errata you want to add to the host, select Apply via Remote Execution to use Remote Execution. Select Apply via customized remote execution if you want to customize the remote execution, or select Apply via Katello agent if you have no connectivity to the target host using SSH.
  6. Click Submit.
11.4. Subscribing to Errata Notifications
You can configure email notifications for Foreman users. Users receive a summary of applicable and installable errata, notifications on Content View promotion or after synchronizing a repository. For more information, see Configuring Email Notifications in the Administering Foreman guide.
11.5. Limitations to Repository Dependency Resolution
With Foreman, using incremental updates to your Content Views solves some repository dependency problems. However, dependency resolution at a repository level still remains problematic on occasion.
When a repository update becomes available with a new dependency, Foreman retrieves the newest version of the package to solve the dependency, even if there are older versions available in the existing repository package. This can create further dependency resolution problems when installing packages.
Example scenario
After an incremental Content View update, the example_tools-1.1, example_tools-1.0, and example_repository-libs-1.1 are now in the repository. The repository also has the packages example_repository-1.0 and example_repository-libs-1.0. Note that the incremental update to the Content View did not add the package example_repository-1.1. Because you can install all these packages using yum, no potential problem is detected. However, when the client installs the example_tools-1.1 package, a dependency resolution problem occurs because both example_repository-libs-1.0 and example_repository-libs-1.1 cannot be installed.
There is currently no workaround for this problem. The larger the time frame, and major Y releases between the base set of RPMs and the errata being applied, the higher the chance of a problem with dependency resolution.
11.6. Creating a Content View Filter for Errata
  • ID - Select specific erratum to allow into your resulting repositories.
  • Date Range - Define a date range and include a set of errata released during that date range.
  • Type - Select the type of errata to include such as bug fixes, enhancements, and security updates.
Create a content filter to exclude errata after a certain date. This ensures your production systems in the application life cycle are kept up to date to a certain point. Then you can modify the filter’s start date to introduce new errata into your testing environment to test the compatibility of new packages into your application life cycle.
  • A Content View with the repositories that contain required errata is created. For more information, see Creating a Content View.
  1. In the Foreman web UI, navigate to Content > Content Views and select a Content View that you want to use for applying errata.
  3. In the Name field, enter Errata Filter.
  4. From the Content Type list, select Erratum - Date and Type.
  5. From the Inclusion Type list, select Exclude.
  6. In the Description field, enter Exclude errata items from YYYY-MM-DD.
  7. Click Save.
  8. For Errata Type, select the check boxes of errata types you want to exclude. For example, select the Enhancement and Bugfix check boxes and clear the Security check box to exclude enhancement and bugfix errata after certain date, but include all the security errata.
  9. For Date Type, select one of two check boxes:
    • Updated On for the date of the erratum’s last update.
  10. Select the Start Date to exclude all errata on or after the selected date.
  11. Leave the End Date field blank.
  12. Click Save.
  13. Click Publish New Version to publish the resulting repository.
  14. Enter Adding errata filter in the Description field.
  15. Click Save.
  16. Click the Versions tab.
  17. Click Promote to the right of the published version.
  18. Select the environments you want to promote the Content View version to.
  19. In the Description field, enter the description for promoting.
  20. Click Promote Version to promote this Content View version across the required environments.
CLI procedure
    # hammer content-view filter create --name "Filter Name" \
    --content-view "CV Name" --organization "Default Organization" \
    --type "erratum"
    # hammer content-view filter rule create --start-date "YYYY-MM-DD" \
    --content-view "CV Name" --content-view-filter="Filter Name" \
    --organization "Default Organization" --types=security,enhancement,bugfix
    # hammer content-view publish --name "CV Name" \
  4. Promote the Content View to the lifecycle environment so that the included errata are available to that lifecycle environment:
    --content-view "CV Name" \
    --to-lifecycle-environment "Lifecycle Environment Name"
11.7. Adding Errata to an Incremental Content View
  1. In the Foreman web UI, navigate to Content > Errata.
  3. Select the content hosts that you want to apply the errata to, and click Apply to Hosts. This creates the incremental update to the Content View.
  4. If you want to apply the errata to the content host, select the Apply Errata to Content Hosts immediately after publishing check box.
CLI procedure
    # hammer content-view version incremental-update \
11.8. Applying Errata to a Host
Use these procedures to review and apply errata to a host.
  • Register the host to an environment and Content View on Foreman server. For more information, see Registering Hosts in the Managing Hosts guide.
  • Configure the host for remote execution. For more information about running remote execution jobs, see Configuring and Setting Up Remote Jobs in the Managing Hosts guide.
If the host is already configured to receive content updates with the deprecated Katello Agent, migrate to remote execution instead. For more information, see Migrating From Katello Agent to Remote Execution in the Managing Hosts guide.
The procedure to apply an erratum to a managed host depends on its operating system.
11.8.1. Applying Errata to a Host running CentOS 7
Use these procedures to review and apply errata to a host running CentOS 7.
  1. In the Foreman web UI, navigate to Hosts > Content Hosts and select the host you want to apply errata to.
CLI procedure
    # hammer host errata list \
    --host client.example.com
  2. Apply the most recent erratum to the host. Identify the erratum to apply using the erratum ID:
    # hammer job-invocation create \
11.8.2. Applying Errata to a Host running Debian or Ubuntu
Use these procedures to review and apply errata to a host running Debian or Ubuntu.
CLI procedure
    Using Remote Execution
11.8.3. Applying Errata to a Host running Red Hat Enterprise Linux 7
Use these procedures to review and apply errata to a host running Red Hat Enterprise Linux 7.
CLI procedure
    Using Katello Agent (deprecated)
    # hammer host errata apply --host "client.example.com" \
    --errata-ids ERRATUM_ID1,ERRATUM_ID2...
11.8.4. Applying Errata to a Host running Red Hat Enterprise Linux 8
CLI procedure
  1. On Foreman, list all errata for the host:
    # yum update Module_Stream_Name
11.8.5. Applying Errata to a Host Running SLES 15
Use this procedure to review and apply errata to a host running SUSE Linux Enterprise Server 15.
  2. Navigate to the Errata tab to view the list of errata.
CLI procedure
11.9. Applying Errata to Multiple Hosts
Use these procedures to review and apply errata to multiple RHEL 7 hosts.
  • Synchronize Foreman repositories with the latest errata available from Red Hat. For more information, see Synchronizing Repositories.
  • Register the hosts to an environment and Content View on Foreman server. For more information, see Registering Hosts in the Managing Hosts guide.
  5. Click Confirm.
CLI procedure
    --inputs errata=ERRATUM_ID \
    Identify the erratum you want to use and list the hosts that this erratum is applicable to:
    # hammer host list \
    --search "applicable_errata = ERRATUM_ID" \
    do
    done
    # hammer task list
11.10. Applying Errata to a Host Collection
# hammer host-collection erratum install \
--errata "erratum_ID1,erratum_ID2,..." \
--name "host_collection_name"\
--organization "Your_Organization"
12. Managing OSTree Content
You can create an OSTree image using an image builder and expose it in an OSTree repository on an HTTP server. Then you can use your Foreman to synchronize and manage OSTree branches from the exposed OSTree repository.
  • OSTree content is supported only when running Foreman on Red Hat Enterprise Linux 8 or CentOS 8.
  • In Foreman server, OSTree management tools are not enabled by default. To enable OSTree, enter the following command:
    # foreman-installer --foreman-proxy-content-enable-ostree=true
  • If you want to use Hammer CLI, you must enable the hammer-cli-katello plugin on Foreman server.
12.1. Importing OSTree Content
You can import and synchronize OSTree content from custom online sources over HTTPS.
Prerequisite
  • A published HTTP location, known as an upstream URL, for the OSTree to import.
  1. In the Foreman web UI, navigate to Content > Products and click Create Product.
  2. In the Name field, enter a name for your OSTree content. This automatically populates the Label field.
  8. Optional: In the Description field, enter a description of the product.
  9. Click Save.
  10. When the product creation completes, click New Repository.
  11. In the Name field, enter a name for the repository. This automatically populates the Label field.
  12. From the Type list, select ostree.
  13. In the Upstream URL field, enter the URL of the external repository to use as a source. For example http://www.example.com/rpm-ostree/.
  14. Optional: Select the Verify SSL check box if you want to verify that the upstream repository’s SSL certificates are signed by a trusted CA.
  15. In the Upstream Username field, enter the user name for the upstream repository if required for authentication. Clear this field if the repository does not require authentication.
  16. In the Upstream Password field, enter the corresponding password for the upstream repository.
  17. In the Upstream Authentication Token field, enter the corresponding token for the upstream repository.
  18. From the Mirroring Policy menu, select one of the following policies to mirror OSTree content for this repository:
    • Additive - new content available during sync will be added to the repository, and no content will be removed.
    • Mirror Content Only - any new content available during sync will be added to the repository and any content removed from the upstream repository will be removed from the local repository.
  19. Optional: In the HTTP Proxy Policy field, select an HTTP proxy.
  20. Optional: Disable the Unprotected checkbox to require a subscription entitlement certificate for accessing the published repository.
  24. Click Save.
  25. When the repository creation completes, select the new repository and click Sync Now to start the synchronization process.
  26. To view the synchronization status, navigate to Content > Sync Status and expand the entry that you want to view.
CLI Procedure
  1. Create a product for your OSTree content:
    # hammer product create \
    --name "OSTree" \
    --sync-plan "Example_Plan" \
    --description "OSTree Content" \
  2. Create the repository for the OSTree:
    # hammer repository create \
    --name "OSTree" \
    --content-type "ostree" \
    --url "http://www.example.com/rpm-ostree/" \
    --product "OSTree Content" \
    # hammer repository synchronize \
    --name "OSTree" \
12.2. Uploading OSTree Content with Hammer CLI
In deployments in which the Foreman server does not have internet access, you can upload OSTree image archives using Hammer CLI.
# wget --no-parent -r https://repos.example.com/ostree/repo_name/
# tar --exclude="index.html" -cvf "example_archive_repo.tar" -C repos.example.com/ostree "repo_name"
Prerequisite
  • You have an OSTree image archive ready and present on your file system.
  1. Connect to your Foreman server using SSH.
  2. Upload your OSTree archive with the hammer command:
    # hammer repository upload-content --id repository_id \
    --content-type ostree_ref \
    --path /path/to/image/file.tar \
    --ostree-repository-name example_repo_name
    The value of --ostree-repository-name must match the name of the OSTree repository in the archive.
12.3. Managing OSTree Content with Content Views
Use Content Views to manage OSTree branches across the application life cycle. This process uses the same publication and promotion method as RPMs or Puppet modules.
Prerequisite
  • You have created a Product and added an OSTree repository to it.
  1. In the Foreman web UI, navigate to Content > Content Views and click Create New View.
  2. In the Name field, enter a plain text name for the view. This automatically populates the Label field.
  3. In the Description field, enter a description of the OSTree Content View.
  4. If you want to use a Composite Content View, select the Composite View check box.
  5. Optional: If you want to solve dependencies automatically every time you publish this Content View, select the Solve Dependencies check box. Dependency solving slows the publishing time and might ignore any Content View filters you use.
  6. Optional: If this Content View is for importing from an upstream server only, select the Import only check box. You cannot publish import-only Content Views directly.
  7. Click Save to complete.
  8. Navigate to the Repositories tab.
  9. Select the OSTree repository that you want to use. Click Add Repository to add the OSTree content from this repository to the Content View.
  10. Click Publish new version.
  11. Optional: In the Description field, enter a description for the version.
  12. Optional: Enable the Promote switch to promote this Content View across environments in the application life cycle.
  13. Click Next.
  14. Review details and click Finish.
CLI Procedure
  2. Create the Content View and add the repository:
    # hammer content-view create \
    --name "OSTree" \
    --description "Example Content View for the OSTree" \
    --repository-ids 5 \
    # hammer content-view publish \
    --name "OSTree" \
13. Managing Container Images
With Foreman, you can import container images from various sources and distribute them to external containers using Content Views.
For information about containers, see Getting Started with Containers in Red Hat Enterprise Linux Atomic Host 7.
13.1. Importing Container Images
This procedure uses repository discovery to find container images and import them as repositories. For more information about creating a product and repository manually, see Importing Content.
  1. In the Foreman web UI, navigate to Content > Products and click Repo Discovery.
  9. Optional: To change the download policy for this docker repository to on demand, see Changing the Download Policy for a Repository.
  15. Optional: To filter the content you import to a repository, click a repository, and then navigate to Limit Sync Tags. Click to edit, and add any tags that you want to limit the content that synchronizes to Foreman.
  16. In the Foreman web UI, navigate to Content > Products and select the name of your product.
To view the progress of the synchronization, navigate to Content > Sync Status and expand the repository tree.
When the synchronization completes, you can click Container Image Manifests to list the available manifests. From the list, you can also remove any manifests that you do not require.
CLI procedure
    --description "Red Hat Container Catalog content" \
    --sync-plan "My_Sync_Plan"
    --name "RHEL7" \
    --content-type "docker" \
    --url "http://registry.access.redhat.com/" \
    --name "RHEL7" \
13.2. Managing Container Name Patterns
When you use Foreman to create and manage your containers, as the container moves through Content View versions and different stages of the Foreman lifecycle environment, the container name changes at each stage. For example, if you synchronize a container image with the name ssh from an upstream repository, when you add it to a Foreman product and organization and then publish as part of a Content View, the container image can have the following name: my_organization_production-custom_spin-my_product-custom_ssh. This can create problems when you want to pull a container image because container registries can contain only one instance of a container name. To avoid problems with Foreman naming conventions, you can set a registry name pattern to override the default name to ensure that your container name is clear for future use.
Limitations
  • If you set the repository.docker_upstream_name registry name pattern, you cannot publish or promote Content Views with container content with identical repository names to the Production lifecycle.
  1. In the Foreman web UI, navigate to Content > Lifecycle Environments, and either create a lifecycle environment or select a lifecycle environment to edit.
  2. In the Container Image Registry area, click the edit icon to the right of Registry Name Pattern area.
  3. Use the list of variables and examples to determine which registry name pattern you require.
  4. In the Registry Name Pattern field, enter the registry name pattern that you want to use. For example, to use the repository.docker_upstream_name:
  5. Click Save.
13.3. Managing Container Registry Authentication
You can manage the authentication settings for accessing containers images from Foreman. By default, users must authenticate to access containers images in Foreman.
You can specify whether you want users to authenticate to access container images in Foreman in a lifecycle environment. For example, you might want to permit users to access container images from the Production lifecycle without any authentication requirement and restrict access the Development and QA environments to authenticated users.
  1. In the Foreman web UI, navigate to Content > Lifecycle Environments.
  3. To permit unauthenticated access to the containers in this lifecycle environment, select the Unauthenticated Pull check box. To restrict unauthenticated access, clear the Unauthenticated Pull check box.
  4. Click Save.
13.4. Configuring Podman and Docker to trust the Certificate Authority
In the following examples, replace hostname.example.com with foreman-server.example.com or smart-proxy-server.example.com, depending on your use case.
    or
  • For podman, use:
Username: admin
Password:
Login Succeeded!
13.5. Using Container Registries
Container Registries on Smart Proxies
On Smart Proxies with content, the Container Gateway Smart Proxy plugin acts as the container registry. It caches authentication information from Katello and proxies incoming requests to Pulp. The Container Gateway is available by default on Smart Proxies with content.
# podman login foreman.example.com
Listing container images:
# podman search foreman.example.com/
Pulling container images:
# podman pull foreman.example.com/my-image:<optional_tag>
14. Managing ISO Images
You can use Foreman to store ISO images, either from Red Hat’s Content Delivery Network or other sources. You can also upload other files, such as virtual machine images, and publish them in repositories.
14.1. Importing ISO Images from Red Hat
  1. In the Foreman web UI, navigate to Content > Red Hat Repositories.
  5. In the Foreman web UI, navigate to Content > Products and click Red Hat Enterprise Linux Server.
To view the Synchronization Status
  • In the Foreman web UI, navigate to Content > Sync Status and expand Red Hat Enterprise Linux Server.
CLI procedure
    # hammer repository-set list \
    # hammer repository-set enable \
    --releasever 7.2 \
    --basearch x86_64 \
    # hammer repository list \
14.2. Importing Individual ISO Images and Files
Use this procedure to manually import ISO content and other files to Foreman server. To import files, you can complete the following steps in the Foreman web UI or using the Hammer CLI. However, if the size of the file that you want to upload is larger than 15 MB, you must use the Hammer CLI to upload it to a repository.
  1. In the Foreman web UI, navigate to Content > Products, and in the Products window, click Create Product.
  6. Click Save.
  11. Click Save.
CLI procedure
  1. Create the product:
    --name "My_ISOs" \
    --sync-plan "Example Plan" \
    --description "My_Product" \
  2. Create the repository:
    --name "My_ISOs" \
    --content-type "file" \
    --product "My_Product" \
    # hammer repository upload-content \
    --path ~/bootdisk.iso \
    --id repo_ID \
15. Managing File Type Content
In Foreman, you might require methods of managing and distributing SSH keys and source code files or larger files such as virtual machine images and ISO files. To achieve this, products in Foreman include repositories for file types. This provides a generic method to incorporate arbitrary files in a product.
You can upload files to the repository and synchronize files from an upstream Foreman server. When you add files to a file type repository, you can use the normal Foreman management functions such as adding a specific version to a Content View to provide version control and making the repository of files available on various Smart Proxy servers. Clients must download the files over HTTP or HTTPS using curl -O.
You can create a file type repository in Foreman server only in a product, but there is flexibility in how you create the file type repository. You can create an independent file type repository in a directory on the system where Foreman is installed, or on a remote HTTP server, and then synchronize the contents of that directory into Foreman. This method is useful when you have multiple files to add to a Foreman repository.
15.1. Creating a File Type Repository
The procedure for creating a file type repository is the same as the procedure for creating any content, except that when you create the repository, you select the file type. You must create a product and then add a repository.
  4. In the Name field, enter a name for the repository. Foreman automatically completes the Label field based on the name.
  7. Optional: In the Upstream URL field, enter the URL of the upstream repository to use as a source.
  8. Select the Verify SSL check box if you want to verify that the upstream repository’s SSL certificates are signed by a trusted CA.
  12. From the Mirroring Policy list, select the type of content synchronization Foreman server performs. For more information, see Mirroring Policies Overview.
  13. Optional: In the HTTP Proxy Policy field, select or unselect using a HTTP proxy. By default, it uses the Global Default HTTP proxy.
  14. Optional: You can clear the Unprotected check box to require a subscription entitlement certificate for accessing this repository. By default, the repository is published through HTTP.
  15. Optional: In the SSL CA Cert field, select the SSL CA Certificate for the repository.
  16. Optional: In the SSL Client Cert field, select the SSL Client Certificate for the repository.
  17. Optional: In the SSL Client Key field, select the SSL Client Key for the repository.
  18. Click Save to create the repository.
CLI procedure
  1. Create a product:
    --description "My_Files" \
    --name "My_File_Product" \
    Table 5. Optional Parameters for the hammer product create Command
    Option Description
    --gpg-key-id gpg_key_id
    GPG key numeric identifier
    --sync-plan sync_plan_name
    Sync plan name to search by
    --sync-plan-id sync_plan_id
    Sync plan numeric identifier
    --name "My_Files" \
    --product "My_File_Product"
    Table 6. Optional Parameters for the hammer repository create Command
    Option Description
    --checksum-type sha_version
    Repository checksum, currently 'sha1' & 'sha256' are supported
    --download-policy policy_name
    Download policy for yum repos (either 'immediate' or 'on_demand').
    --gpg-key gpg_key_name
    Key name to search by
    --mirror-on-sync boolean
    Must this repo be mirrored from the source, and stale RPMs removed, when synced? Set to true or false, yes or no, 1 or 0.
    --publish-via-http boolean
    --url source_repo_url
    URL of the Source repository
    --verify-ssl-on-sync boolean
    Must Katello verify that the upstream URL’s SSL certificates are signed by a trusted CA? Set to true or false, yes or no, 1 or 0.
15.2. Creating a File Type Repository in a Local Directory
You can create a file type repository, from a directory of files, on the base system where Foreman is installed using the pulp-manifest command. You can then synchronize the files into Foreman server. When you add files to a file type repository, you can work with the files as with any other repository.
Use this procedure to configure a repository in a directory on the base system where Foreman is installed. To create a file type repository in a directory on a remote server, see Creating a Remote File Type Repository.
To create a file type repository in a local directory, complete the following procedure:
  1. Ensure the Server and https://yum.theforeman.org/client/3.2/ repositories are enabled.
    # yum install python3-pulp_manifest
    # mkdir my_file_repo
    # touch my_file_repo/test.txt
  5. Enter the Pulp Manifest command to create the manifest:
    # pulp-manifest my_file_repo
    # ls my_file_repo
    PULP_MANIFEST test.txt
Importing Files from a File Type Repository
To import files from a file type repository in a local directory, complete the following procedure:
  1. Ensure a product exists in Foreman server.
  2. In the Foreman web UI, navigate to Content > Products.
  3. Select the name of a product.
  4. Click the Repositories tab and select New Repository.
  5. In the Name field, enter a name for the repository. Foreman automatically completes this field based on what you enter for Name.
  6. From the Type list, select the content type of the repository.
  7. In the Upstream URL field, enter the local directory with the repository to use as the source, in the form file:///my_file_repo.
  8. Select the Verify SSL check box to check the SSL certificate for the repository or clear the Verify SSL check box.
  9. Optional: In the Upstream Username field, enter the upstream user name that you require.
  10. Optional: In the Upstream Password field, enter the corresponding password for your upstream user name.
  13. Optional: In the HTTP Proxy Policy field, select the desired HTTP proxy. The default value is Global Default.
  15. Optional: In the GPG Key field, select the GPG key for the repository.
  17. Optional: In the SSL Client cert field, select the SSL Client Certificate for the repository.
  19. Select Save to save this repository entry.
Updating a File Type Repository
To update the file type repository, complete the following steps:
  2. Select the name of a product.
  3. Select the name of the repository you want to update.
  4. From the Select Action menu, select Sync Now.
  5. Visit the URL where the repository is published to see the files.
15.3. Creating a Remote File Type Repository
You can create a file type repository from a directory of files that is external to Foreman server using the pulp-manifest command. You can then synchronize the files into Foreman server over HTTP or HTTPS. When you add files to a file type repository, you can work with the files as with any other repository.
Use this procedure to configure a repository in a directory on a remote server. To create a file type repository in a directory on the base system where Foreman server is installed, see Creating a File Type Repository in a Local Directory.
Before you create a remote file type repository, ensure the following conditions exist:
  • You have a Red Hat Enterprise Linux 7 server registered to your Foreman or the Red Hat CDN.
  • You have installed an HTTP server. For more information about configuring a web server, see The Apache HTTP Server in the Red Hat Enterprise Linux 7 System Administrator’s Guide.
To create a file type repository in a remote directory, complete the following procedure:
  1. On your remote server, ensure that the Server and https://yum.theforeman.org/client/3.2/ repositories are enabled.
Importing Files from a Remote a File Type Repository
To import files from a remote file type repository, complete the following procedure:
  1. Ensure a product exists in Foreman server, or create a product. For more information see Creating a File Type Repository
  6. From the Type list, select file.
  7. In the Upstream URL field, enter the URL of the upstream repository to use as a source.
  19. Click Save.
  20. To update the file type repository, navigate to Content > Products. Select the name of a product that contains the repository that you want to update.
  21. In the product’s window, select the name of the repository you want to update.
  22. From the Select Action menu, select Sync Now.
Visit the URL where the repository is published to view the files.
15.4. Uploading Files To a File Type Repository
Use this procedure to upload files to a file type repository.
  2. Select a product by name.
  5. Click Upload to upload the selected file to Foreman server.
CLI procedure
--id repo_ID \
--path example_file
15.5. Downloading Files to a Host From a File Type Repository
  4. Ensure to select the Unprotected check box to access the repository is published through HTTP.
  5. Copy the URL where the repository is published.
CLI procedure
    # hammer repository list --content-type file
    7  | My_Files | My_File_Product | file         |
    # hammer repository info \
    --name "My_Files" \
    Publish Via HTTP:   yes
    Published At:       http://foreman.example.com/pulp/isos/uuid/
    Publish Via HTTP:   no
    Published At:       https://foreman.example.com/pulp/isos/uuid/
  3. On the client, enter a command in the appropriate format for HTTP or HTTPS:
    For HTTP:
    # curl -O foreman.example.com/pulp/isos/uuid/my_file
    For HTTPS:
    # curl -O --cert ./Default\ Organization-key-cert.pem --cacert katello-server-ca.crt foreman.example.com/pulp/isos/uuid/my_file
Your environment requires adequate hard disk space to fulfill content storage. In some situations, it is useful to use an NFS share to store this content. This appendix shows how to mount the NFS share on your Foreman server’s content management component.
Use high-bandwidth, low-latency storage for the /var/lib/pulp file system. Foreman has many I/O-intensive operations; therefore, high-latency, low-bandwidth storage might have issues with performance degradation.
  1. Create the NFS share. This example uses a share at nfs.example.com:/Foreman/pulp. Ensure this share provides the appropriate permissions to Foreman server and its apache user.
  2. Stop the foreman-maintain services on the Foreman host:
  3. Ensure Foreman server has the nfs-utils package installed:
    # yum install nfs-utils
    # mkdir /mnt/temp
    # mount -o rw nfs.example.com:/{Project}/pulp /mnt/temp
    # umount /mnt/temp
    # rm -rf /var/lib/pulp/*
    nfs.example.com:/{Project}/pulp    /var/lib/pulp   nfs    rw,hard,intr,context="system_u:object_r:pulpcore_var_lib_t:s0"
  9. Enable the mount:
    # mount -a
    # df
    nfs.example.com:/{Project}/pulp 309506048 58632800 235128224  20% /var/lib/pulp
    # ls /var/lib/pulp
  11. Start the foreman-maintain services on the Foreman host:
Foreman server now uses the NFS share to store content. Run a content synchronization to ensure the NFS share works as expected. For more information, see Synchronizing Repositories.
Appendix B: Importing Content ISOs into a Connected Foreman
Even if Foreman server can connect directly to the Red Hat Customer Portal, you can perform the initial synchronization from locally mounted content ISOs. When the initial synchronization is completed from the content ISOs, you can switch back to downloading content through the network connection. To accomplish this, download the Content ISOs for Foreman from the Red Hat Customer Portal and import them into Foreman server. For locations with bandwidth limitations, using an On Demand download policy might be more efficient than downloading and importing Content ISOs.
Note that Content ISOs previously hosted at redhat.com for import into Foreman server have been deprecated and will be removed in the next Foreman version.
You can only import content ISO images for Red Hat Enterprise Linux 8 because repodata checksum from CDN does not match the repodata checksum from the content ISO images for Red Hat Enterprise Linux 7 and lower.
Note that if you synchronize a Red Hat Enterprise Linux ISO, all minor versions of Red Hat Enterprise Linux also synchronize. You require adequate storage on your Foreman to account for this.
This section is not required if your Foreman server is connected to the Internet.
This example procedure performs the first synchronization of the Red Hat Enterprise Linux 8 repository from content ISO images.
  1. Log in to the Red Hat Customer Portal at access.redhat.com.
  2. In the upper left of the window, click Downloads and select Red Hat Satellite.
  3. Click the Content ISOs tab. This page lists all the products that are available in your subscription.
  4. Click the link for the product name, such as RHEL 8 (x86_64), to reveal links to download ISO images.
  5. Download the ISO images.
  6. On Foreman, create a directory to act as a temporary store for all of the required Foreman content ISO images. This example uses /tmp/isos/rhel8:
    # mkdir -p /tmp/isos/rhel8
  7. On your workstation, copy the ISO files to Foreman server:
    $ scp ~/Downloads/iso_file root@foreman.example.com:/tmp/isos/rhel8
  8. On Foreman server, create a directory to serve as a mount point for the ISOs:
    # mkdir /mnt/iso
  9. Create a working directory to store ISO images:
    # mkdir /mnt/rhel8
  10. Temporarily mount the first ISO image:
    # mount -o loop /tmp/isos/iso_file /mnt/iso
  11. Recursively copy the contents of the first ISO to the working directory:
    # cp -ruv /mnt/iso/* /mnt/rhel8/
  12. Unmount the ISO image:
    # umount /mnt/iso
  13. Repeat the above step for each ISO until you have copied all the data from the Content ISO images into /mnt/rhel8.
  14. If required, remove the empty directory used as the mount point:
    # rmdir /mnt/iso
  15. If required, remove the temporary working directory and its contents to regain space:
    # rm -rf /tmp/isos/
  16. Set the owner and the SELinux context for the directory and its contents to be the same as /var/lib/pulp:
    # chcon -R --reference /var/lib/pulp  /mnt/rhel8/
    # chown -R apache:apache /mnt/rhel8/
  17. Create or edit the /etc/pulp/content/sources/conf.d/local.conf file. Append the following text into the file:
    [rhel-8-server]
    enabled: 1
    priority: 0
    expires: 3d
    name: Red Hat Enterprise Linux 8
    type: yum
    base_url: file:///mnt/rhel8/content/dist/rhel/server/8/x86_64/os/
    The base_url path might differ in your content ISO. The directory specified in base_url must contain the repodata directory, otherwise the synchronization fails. To synchronize multiple repositories, create a separate entry for each of them in the configuration file /etc/pulp/content/sources/conf.d/local.conf.
  18. In the Foreman web UI, navigate to Content > Red Hat Repositories and enable the following repositories:
    • Red Hat Enterprise Linux 8 for x86_64 - BaseOS RPMs 8
    • Red Hat Enterprise Linux 8 for x86_64 - AppStream RPMs 8
  19. Under Content > Sync Status select the repositories to be synchronized and click Synchronize Now.
Note that the Foreman web UI does not indicate which source is being used. In case of problems with a local source, Foreman pulls content through the network. To monitor the process, enter the following command on Foreman:
# journalctl -f -l SYSLOG_IDENTIFIER=pulp | grep -v worker[\-,\.]heartbeat
The above command displays interactive logs. First, Foreman server connects to the Red Hat Customer Portal to download and process repository metadata. Then, the local repository is loaded. In case of any errors, cancel the synchronization in the Foreman web UI and verify your configuration.
After successful synchronization you can detach the local source by removing its entry from /etc/pulp/content/sources/conf.d/local.conf.
Appendix C: Configuring Inter-Server Synchronization in Foreman
C.1. How to Configure Inter-Server Synchronization
Foreman uses Inter-Server Synchronization (ISS) to synchronize content between two Foreman servers in a multi-server Foreman setup.
  • If you want to copy some but not all content from your Foreman server to other Foreman servers. For example, you have Content Views that your IT department consumes from Foreman server, and you want to copy content from those Content Views to other Foreman servers.
  • If you want to copy all Library content from your Foreman server to other Foreman servers. For example, you have Products and repositories that your IT department consumes from Foreman server in the Library, and you want to copy all Products and repositories in that organization to other Foreman servers.
You cannot use ISS to synchronize content from Foreman server to Smart Proxy server. Smart Proxy server supports synchronization natively. For more information, see Smart Proxy server Overview in Planning for Foreman.
C.1.1. ISS Network Sync in a Disconnected Scenario
  • The upstream Foreman server is connected to the Internet. This server consumes content from the Red Hat Content Delivery Network (CDN) or custom sources.
  • The downstream Foreman server is completely isolated from all external networks.
  • The downstream Foreman server can communicate with a connected upstream Foreman server over an internal network.
The Foreman ISS Disconnected Scenario
Figure 2. The Foreman ISS Disconnected Scenario
You can configure your downstream Foreman server to synchronize content from the upstream Foreman server over the network. See Configuring Foreman Server to Synchronize Content over a Network.
C.1.2. ISS Export Sync in an Air-Gapped Scenario
  • The upstream Foreman server is connected to the Internet. This server consumes content from the Red Hat CDN or custom sources.
  • The downstream Foreman server does not have a network connection to a connected upstream Foreman server.
The Foreman ISS Air-Gapped Scenario
Figure 3. The Foreman ISS Air-Gapped Scenario
The only way for an air-gapped downstream Foreman server to receive content updates is by exporting payload from the upstream Foreman server, bringing it physically to the downstream Foreman server, and importing the payload. For more information, see Synchronizing Content Between Foreman servers in the Content Management Guide.
Configure your downstream Foreman server to synchronize content using exports. See Configuring Foreman Server to Synchronize Content Using Exports.
C.2. Configuring Foreman Server to Synchronize Content Using Exports
If you deployed your downstream Foreman server as air-gapped, configure your Foreman server as such to avoid attempts to consume content from a network.
  1. In the Foreman web UI, navigate to Content > Subscriptions.
  2. Click the Manage Manifest button.
  3. Switch to the CDN Configuration tab.
  4. Select the Export Sync tab.
  5. Click Update.
CLI Procedure
  1. Log in to your Foreman server using SSH.
  2. Set CDN configuration to sync using exports:
    # hammer organization configure-cdn --name="My_Organization" --type=export_sync
C.3. Configuring Foreman Server to Synchronize Content over a Network
Configure a downstream Foreman server to synchronize repositories from a connected upstream Foreman server over HTTPS.
  • A network connection exists between the upstream Foreman server and the downstream Foreman server.
  • You imported the subscription manifest on both the upstream and downstream Foreman server.
  • On the upstream Foreman server, you enabled the required repositories for the organization.
  • The upstream user is an admin or has the following permissions:
    • view_organizations
    • view_products
    • edit_organizations (to download the CA certificate)
    • view_lifecycle_environments
    • view_content_views
  • On the downstream Foreman server, you have imported the SSL certificate of the upstream Foreman server using the contents of http://upstream-foreman.example.com/pub/katello-server-ca.crt. For more information, see Importing SSL Certificates in the Content Management Guide.
  • The downstream user is an admin or has the permissions to create product repositories and organizations.
  1. Navigate to Content > Subscriptions.
  3. Navigate to the CDN Configuration tab.
  4. Select the Network Sync tab.
  5. In the URL field, enter the address of the upstream Foreman server.
  6. In the Username, enter your username for upstream login.
  7. In the Password, enter your password or personal access token for upstream login.
  8. In the Organization label field, enter the label of the upstream organization.
  9. Optional: In the Lifecycle Environment Label field, enter the label of the upstream lifecycle environment. Default is Library.
  10. Optional: In the Content view label field, enter the label of the upstream Content View. Default is Default_Organization_View.
  11. From the SSL CA Content Credential menu, select a CA certificate used by the upstream Foreman server.
  12. Click Update.
  13. In the Foreman web UI, navigate to Content > Products.
  14. Click Sync Now to synchronize the repositories.
    You can also create a synchronization plan to ensure updates on a regular basis. For more information, see Creating a Synchronization Plan in the Content Management Guide.
CLI Procedure
  1. Connect to your downstream Foreman server using SSH.
  2. View information about the upstream CA certificate:
    # hammer content-credential show \
    --name="My_Upstream_CA_Cert" \
    --organization="My_Downstream_Organization"
  3. Set CDN configuration to an upstream Foreman server:
    # hammer organization configure-cdn --name="My_Downstream_Organization" \
    --type=network_sync \
    --url https://upstream-{foreman-example-com} \
    --username upstream_username --password upstream_password \
    --ssl-ca-credential-id "My_Upstream_CA_Cert_ID" \
    --upstream-organization-label="_My_Upstream_Organization" \
    [--upstream-lifecycle-environment-label="My_Lifecycle_Environment"] \
    [--upstream-content-view-label="My_Content_View"]
    The default lifecycle environment label is Library. The default Content View label is Default_Organization_View.
