We appreciate your input on our documentation. Please let us know how we could make it better.
You can submit feedback by filing a ticket in Bugzilla:
  1. Navigate to the Bugzilla website.
  2. In the Component field, use Documentation.
  3. In the Description field, enter your suggestion for improvement. Include a link to the relevant parts of the documentation.
  4. Click Submit Bug.
1. Accessing Red Hat Satellite
After Red Hat Satellite has been installed and configured, use the Satellite web UI interface to log in to Satellite for further configuration.
1.1. Installing the Katello Root CA Certificate
The first time you log on to Satellite, you might see a warning informing you that you are using the default self-signed certificate and you might not be able to connect this browser to Satellite until the root CA certificate is installed in the browser. Use the following procedure to locate the root CA certificate on Satellite and to install it in your browser.
  • Your Red Hat Satellite is installed and configured.
  1. Identify the fully qualified domain name of your Satellite Server:
    # hostname -f
  2. Access the pub directory on your Satellite Server using a web browser pointed to the fully qualified domain name:
    https://satellite.example.com/pub
  3. When you access Satellite for the first time, an untrusted connection warning displays in your web browser. Accept the self-signed certificate and add the Satellite URL as a security exception to override the settings. This procedure might differ depending on the browser being used. Ensure that the Satellite URL is valid before you accept the security exception.
  4. Select katello-server-ca.crt.
  5. Import the certificate into your browser as a certificate authority and trust it to identify websites.
Importing the Katello Root CA Certificate Manually
  1. From the Satellite CLI, copy the katello-server-ca.crt file to the machine you use to access the Satellite web UI:
    # scp /var/www/html/pub/katello-server-ca.crt username@hostname:remotefile
  2. In the browser, import the katello-server-ca.crt certificate as a certificate authority and trust it to identify websites.
1.2. Logging on to Satellite
Use the web user interface to log on to Satellite for further configuration.
  1. Access Satellite Server using a web browser pointed to the fully qualified domain name:
  2. Enter the user name and password created during the configuration process. If a user was not created during the configuration process, the default user name is admin. If you have problems logging on, you can reset the password. For more information, see Resetting the Administrative User Password.
Use the navigation tabs to browse the Satellite web UI.
Navigation Tabs Description
Any Context
Monitor
Content
Hosts
Configure
Infrastructure
Provides tools on configuring how Satellite interacts with the environment.
User Name
notification bell
Administer
1.4. Changing the Password
1.5. Resetting the Administrative User Password
  1. Log on to the base operating system where Satellite Server is installed.
  3. Use this password to reset the password in the Satellite web UI.
  4. Edit the ~/.hammer/cli.modules.d/foreman.yml file on Satellite Server to add the new password:
  3. Edit the ~/.hammer/cli.modules.d/foreman.yml file on Satellite Server to add the new password:
1.6. Setting a Custom Message on the Login Page
  1. In the Satellite web UI, navigate to Administer > Settings, and click the General tab.
  3. Click Save.
  4. Log out of the Satellite web UI and verify that the custom text is now displayed on the login page below the Satellite version number.
2. Starting and Stopping Red Hat Satellite
Satellite provides the satellite-maintain service command to manage Satellite services from the command line. This is useful when creating a backup of Satellite. For more information on creating backups, see Backing Up Satellite Server and Capsule Server.
After installing Satellite with the satellite-installer command, all Satellite services are started and enabled automatically. View the list of these services by executing:
# satellite-maintain service list
# satellite-maintain service status
To stop Satellite services, execute:
To start Satellite services, execute:
To restart Satellite services, execute:
# satellite-maintain service restart
3. Migrating from Internal Satellite Databases to External Databases
When you install Red Hat Satellite, the satellite-installer command installs PostgreSQL databases on the same server as Satellite. If you are using the default internal databases but want to start using external databases to help with the server load, you can migrate your internal databases to external databases.
To confirm whether your Satellite Server has internal or external databases, you can query the status of your databases:
# satellite-maintain service status --only postgresql
Red Hat does not provide support or tools for external database maintenance. This includes backups, upgrades, and database tuning. You must have your own database administrator to support and maintain external databases.
  1. Preparing a Host for External Databases. Prepare a Red Hat Enterprise Linux 8 server to host the external databases.
  2. Installing PostgreSQL. Prepare PostgreSQL with databases for Satellite, Pulp and Candlepin with dedicated users owning them.
  3. Migrating to External Databases. Edit the parameters of satellite-installer to point to the new databases, and run satellite-installer.
Foreman, Katello, and Candlepin use the PostgreSQL database. If you want to use PostgreSQL as an external database, the following information can help you decide if this option is right for your Satellite configuration. Satellite supports PostgreSQL version 12.
Advantages of External PostgreSQL:
  • Increase in free memory and free CPU on Satellite
  • Flexibility to set shared_buffers on the PostgreSQL database to a high number without the risk of interfering with other services on Satellite
  • Flexibility to tune the PostgreSQL server’s system without adversely affecting Satellite operations
  • If either Satellite or the PostgreSQL database server suffers a hardware or storage failure, Satellite is not operational
  • If there is latency between the Satellite server and database server, performance can suffer
If you suspect that the PostgreSQL database on your Satellite is causing performance problems, use the information in Satellite 6: How to enable postgres query logging to detect slow running queries to determine if you have slow queries. Queries that take longer than one second are typically caused by performance issues with large installations, and moving to an external database might not help. If you have slow queries, contact Red Hat Support.
Install a freshly provisioned system with the latest Red Hat Enterprise Linux 8 to host the external databases.
Subscriptions for Red Hat Enterprise Linux do not provide the correct service level agreement for using Satellite with external databases. You must also attach a Satellite subscription to the base operating system that you want to use for the external databases.
  1. Use the instructions in Attaching the Satellite Infrastructure Subscription to attach a Satellite subscription to your server.
    --enable=satellite-6.11-for-rhel-8-x86_64-rpms \
    --enable=rhel-8-for-x86_64-baseos-rpms \
    --enable=rhel-8-for-x86_64-appstream-rpms
  3. Enable the following modules:
    # dnf module enable satellite:el8
    Enablement of the module satellite:el8 warns about a conflict with postgresql:10 and ruby:2.5 as these modules are set to the default module versions on Red Hat Enterprise Linux 8. The module satellite:el8 has a dependency for the modules postgresql:12 and ruby:2.7 that will be enabled with the satellite:el8 module. These warnings do not cause installation process failure, hence can be ignored safely. For more information about modules and lifecycle streams on Red Hat Enterprise Linux 8, see Red Hat Enterprise Linux Application Streams Life Cycle.
3.3. Installing PostgreSQL
You can install only the same version of PostgreSQL that is installed with the satellite-installer tool during an internal database installation. Satellite supports PostgreSQL version 12.
    # dnf install postgresql-server postgresql-evr
    # postgresql-setup initdb
    Note that the default configuration of external PostgreSQL needs to be adjusted to work with Satellite. The base recommended external database configuration adjustments are as follows:
    • max_connections: 500
    • shared_buffers: 512MB
    • work_mem: 4MB
    listen_addresses = '*'
  5. Edit the /var/lib/pgsql/data/pg_hba.conf file:
      host  all   all   Satellite_ip/32   md5
    # systemctl start postgresql
    # systemctl enable postgresql
    $ su - postgres -c psql
  10. Create three databases and dedicated roles: one for Satellite, one for Candlepin, and one for Pulp:
  11. Exit the postgres user:
    # \q
  12. From Satellite Server, test that you can access the database. If the connection succeeds, the commands return 1.
Back up and transfer existing data, then use the satellite-installer command to configure Satellite to connect to an external PostgreSQL database server.
  1. On Satellite Server, stop Satellite services:
    # satellite-maintain backup online --skip-pulp-content --preserve-directory -y /var/migration_backup
  5. Use the satellite-installer command to update Satellite to point to the new databases:
    satellite-installer --scenario satellite \
        --foreman-db-manage false \
        --foreman-proxy-content-pulpcore-postgresql-user pulp
4. Managing Satellite with Ansible Collections
Satellite Ansible Collections is a set of Ansible modules that interact with the Satellite API. You can use Satellite Ansible Collections to manage and automate many aspects of Satellite.
4.1. Installing the Satellite Ansible Modules
Use this procedure to install the Satellite Ansible modules.
    # satellite-maintain packages install ansible-collection-redhat-satellite
4.2. Viewing the Satellite Ansible Modules
You can view the installed Satellite Ansible modules by listing the content of the following directory:
# ls /usr/share/ansible/collections/ansible_collections/redhat/satellite/plugins/modules/
At the time of writing, the ansible-doc -l command does not list collections yet.
Alternatively, you can also see the complete list of Satellite Ansible modules and other related information at Red Hat Ansible Automation Platform.
All modules are in the redhat.satellite namespace and can be referred to in the format redhat.satellite._module_name_. For example, to display information about the activation_key module, enter the following command:
$ ansible-doc redhat.satellite.activation_key
5. Managing Users and Roles
Roles define a set of permissions and access levels. Each role contains one on more permission filters that specify the actions allowed for the role. Actions are grouped according to the Resource type. Once a role has been created, users and user groups can be associated with that role. This way, you can assign the same set of permissions to large groups of users. Satellite provides a set of predefined roles and also enables creating custom roles and permission filters as described in Creating and Managing Roles.
5.1. User Management
As an administrator, you can create, modify and remove Satellite users. You can also configure access permissions for a user or a group of users by assigning them different roles.
5.1.1. Creating a User
Use this procedure to create a user. To use the CLI instead of the Satellite web UI, see the CLI procedure.
  1. In the Satellite web UI, navigate to Administer > Users.
  2. Click Create User.
    By default, Satellite Server uses the language and timezone settings of the user’s browser.
CLI procedure
    # hammer user create \
    --login My_User_Name \
    --mail My_User_Mail \
    --password My_User_Password
Use this procedure to assign roles to a user. To use the CLI instead of the Satellite web UI, see the CLI procedure.
    If a user account is not listed, check that you are currently viewing the correct organization. To list all the users in Satellite, click Default Organization and then Any Organization.
  7. Click Submit.
CLI procedure
Administrators can impersonate other authenticated users for testing and troubleshooting purposes by temporarily logging on to the Satellite web UI as a different user. When impersonating another user, the administrator has permissions to access exactly what the impersonated user can access in the system, including the same menus.
  • Ensure that you are logged on to the Satellite web UI as a user with administrator privileges for Satellite.
5.1.4. Creating an API-Only User
You can create users that can interact only with the Satellite API.
Prerequisite
  1. You have created a user and assigned roles to them. Note that this user must be authorized internally. For more information, see Creating a User and Assigning Roles to a User.
  1. Log in to your Satellite as admin.
    # openssl rand -hex 32
5.2. SSH Key Management
Adding SSH keys to a user allows deployment of SSH keys during provisioning. For information on deploying SSH keys during provisioning, see Deploying SSH Keys during Provisioning in the Provisioning guide.
For information on SSH keys and SSH key creation, see Using SSH-based Authentication in the Red Hat Enterprise Linux 8 Configuring Basic System Settings Guide.
Use this procedure to add or remove SSH keys for a user. To use the CLI instead of the Satellite web UI, see the CLI procedure.
Ensure that you are logged in to the Satellite web UI as an Admin user of Red Hat Satellite or a user with the create_ssh_key permission enabled for adding SSH key and destroy_ssh_key permission for removing a key.
  3. Click on the SSH Keys tab.
    • To Add SSH key
      2. Click Add SSH Key.
      5. Click Submit.
    • To Remove SSH key
CLI procedure
    # hammer user ssh-keys add \
    --user-id user_id \
    --name key_name \
    --key-file ~/.ssh/id_rsa.pub
    --user-id user_id \
    --name key_name \
5.3. Managing Personal Access Tokens
5.3.1. Creating a Personal Access Token
  1. Make an API request to your Satellite Server and authenticate with your Personal Access Token:
    # curl https://satellite.example.com/api/status --user My_Username:My_Personal_Access_Token
    {"satellite_version":"6.11.0","result":"ok","status":200,"version":"3.5.1.10","api_version":2}
5.3.2. Revoking a Personal Access Token
  1. Make an API request to your Satellite Server and try to authenticate with the revoked Personal Access Token:
5.4. Creating and Managing User Groups
5.4.1. User Groups
With Satellite, you can assign permissions to groups of users. You can also create user groups as collections of other user groups. If using an external authentication source, you can map Satellite user groups to external user groups as described in Configuring External User Groups.
5.4.2. Creating a User Group
  1. In the Satellite web UI, navigate to Administer > User Groups.
  2. Click Create User group.
  5. Click Submit.
CLI procedure
    # hammer user-group create \
    --name My_User_Group_Name \
5.4.3. Removing a User Group
Use the Satellite web UI to remove a user group.
5.5. Creating and Managing Roles
Satellite provides a set of predefined roles with permissions sufficient for standard tasks, as listed in Predefined Roles Available in Satellite. It is also possible to configure custom roles, and assign one or more permission filters to them. Permission filters define the actions allowed for a certain resource type. Certain Satellite plug-ins create roles automatically.
5.5.1. Creating a Role
  1. In the Satellite web UI, navigate to Administer > Roles.
  2. Click Create Role.
CLI procedure
5.5.2. Cloning a Role
Use the Satellite web UI to clone a role.
  1. In the Satellite web UI, navigate to Administer > Roles and select Clone from the drop-down menu to the right of the required role.
5.5.3. Adding Permissions to a Role
Use this procedure to add permissions to a role. To use the CLI instead of the Satellite web UI, see the CLI procedure.
  5. Depending on the Resource type selected, you can select or deselect the Unlimited and Override checkbox. The Unlimited checkbox is selected by default, which means that the permission is applied on all resources of the selected type. When you disable the Unlimited checkbox, the Search field activates. In this field you can specify further filtering with use of the Satellite search syntax. For more information, see Granular Permission Filtering. When you enable the Override checkbox, you can add additional locations and organizations to allow the role to access the resource type in the additional locations and organizations; you can also remove an already associated location and organization from the resource type to restrict access.
  6. Click Next.
CLI procedure
  2. Add permissions to a role:
    # hammer filter create \
    --role My_Role_Name
5.5.4. Viewing Permissions of a Role
Use the Satellite web UI to view the permissions of a role.
The Filters page contains a table of permissions assigned to a role grouped by the resource type. It is also possible to generate a complete table of permissions and actions that you can use on your Satellite system. For more information, see Creating a Complete Permission Table.
5.5.5. Creating a Complete Permission Table
Use the Satellite CLI to create a permission table.
  1. Ensure that the required packages are installed. Execute the following command on Satellite Server:
    # satellite-maintain packages install foreman-console
  2. Start the Satellite console with the following command:
    # foreman-rake console
    end.join("\n")
    f.write(result)
  3. Press Ctrl + D to exit the Satellite console. Insert the following text at the first line of /tmp/table.html:
    </table>
5.5.6. Removing a Role
Use the Satellite web UI to remove a role.
5.6. Predefined Roles Available in Satellite
The following table provides an overview of permissions that predefined roles in Satellite grant to a user.
To view the exact set of permissions a predefined role grants, display the role in Satellite web UI as the privileged user. For more information, see Viewing Permissions of a Role.
Table 1. Permissions provided by role
Role Permissions Provided by Role
Access Insights Admin
Add and edit Insights rules.
Access Insights Viewer
View Insight reports.
Ansible Roles Manager
Bookmarks manager
Boot disk access
Download the boot disk.
Compliance manager
Compliance viewer
Create ARF report
Create compliance reports.
Default role
Discovery Manager
Discovery Reader
Edit hosts
Edit partition tables
Manager
Organization admin
Red Hat Access Logs
Remote Execution Manager
Control which roles have permission to run infrastructure jobs.
Remote Execution User
Run remote execution jobs against hosts.
Site manager
System admin
  • Edit global settings in Administer > Settings.
Tasks manager
View and edit Satellite tasks.
Tasks reader
A role that can only view Satellite tasks.
Viewer
A passive role that provides the ability to view the configuration of every element of the Satellite structure, logs, reports, and statistics.
View hosts
Virt-who Manager
Virt-who Reporter
Upload reports generated by virt-who to Satellite. It can be used if you configure virt-who manually and require a user role that has limited virt-who permissions.
Virt-who Viewer
5.7. Granular Permission Filtering
5.7.1. Granular Permission Filter
As mentioned in Adding Permissions to a Role, Red Hat Satellite provides the ability to limit the configured user permissions to selected instances of a resource type. These granular filters are queries to the Satellite database and are supported by the majority of resource types.
5.7.2. Creating a Granular Permission Filter
Use this procedure to create a granular filter. To use the CLI instead of the Satellite web UI, see the CLI procedure.
Satellite does not apply search conditions to create actions. For example, limiting the create_locations action with name = "Default Location" expression in the search field does not prevent the user from assigning a custom name to the newly created location.
field_name operator value
CLI procedure
    --permission-ids 91 \
    --search "name ~ ccv*" \
    --role qa-user
5.7.3. Examples of Using Granular Permission Filters
hostgroup = host-editors
name ^ (XXXX, Yyyy, zzzz)
Dev
Use the Satellite web UI to create an administrative role restricted to a single organization named org-1.
5.7.4. Supported Operators for Granular Search
Table 2. Logical Operators
Operator
and
Combines search criteria.
not
Negates an expression.
has
Table 3. Symbolic Operators
Operator
6. Email Notifications
Email notifications are created by Satellite Server periodically or after completion of certain events. The periodic notifications can be sent daily, weekly or monthly.
The events that trigger a notification are the following:
  • Host build
  • Content View promotion
  • Error reported by host
  • Repository sync
If you want email notifications sent to a group’s email address, instead of an individual’s email address, create a user account with the group’s email address and minimal Satellite permissions, then subscribe the user account to the desired notification types.
Satellite Server does not enable outgoing emails by default, therefore you must review your email configuration. For more information, see Configuring Satellite Server for Outgoing Emails in Installing Satellite Server from a Connected Network.
6.1. Configuring Email Notifications
You can configure Satellite to send email messages to individual users registered to Satellite. Satellite sends the email to the email address that has been added to the account, if present. Users can edit the email address by clicking on their name in the top-right of the Satellite web UI and selecting My account.
Configure email notifications for a user from the Satellite web UI.
  6. Click Submit.
6.2. Testing Email Delivery
  2. Click on the username.
  2. Verify Satellite Server’s email configuration.
6.3. Testing Email Notifications
  • daily
  • weekly
  • monthly
6.4. Notification Types
The following are the notifications created by Satellite:
  • Audit summary: A summary of all activity audited by Satellite Server.
  • OpenSCAP policy summary: A summary of OpenSCAP policy reports and their results.
  • Puppet error state: A notification sent after a host reports an error related to Puppet.
  • Puppet summary: A summary of Puppet reports.
6.5. Changing Email Notification Settings for a Host
Satellite can send event notifications for a host to the host’s registered owner. You can configure Satellite to send email notifications either to an individual user or a user group. When set to a user group, all group members who are subscribed to the email type receive a message.
  1. In the Satellite web UI, navigate to Hosts > All Hosts, locate the host that you want to view, and click Edit in the Actions column.
  2. Go to the Additional Information tab. If the checkbox Include this host within Satellite reporting is checked, then the email notifications are enabled on that host.
Security compliance management is the ongoing process of defining security policies, auditing systems for compliance with those policies, and resolving instances of non-compliance. Any non-compliance is managed according to the organization’s configuration management policies. Security policies range in scope from host-specific to industry-wide, therefore, flexibility in their definition is required.
With Satellite, you can schedule compliance auditing and reporting on all registered hosts.
Satellite uses the Security Content Automation Protocol (SCAP) standard to define security policies.
SCAP is a framework of several specifications based on XML, such as checklists described in the Extensible Checklist Configuration Description Format (XCCDF) and vulnerabilities described in the Open Vulnerability and Assessment Language (OVAL). These specifications are encapsulated as data stream files.
Checklist items in XCCDF, also known as rules, express the desired configuration of a system item. For example, a rule may specify that no one can log in to a host over SSH using the root user account. Rules can be grouped into one or more XCCDF profiles, which allows multiple profiles to share a rule.
The OpenSCAP scanner tool evaluates system items on a host against the rules and generates a report in the Asset Reporting Format (ARF), which is then returned to Satellite for monitoring and analysis.
Table 4. Specifications in the SCAP Framework 1.3 supported by the OpenSCAP scanner
Title
Version
SCAP
1.3
XCCDF
Extensible Configuration Checklist Description Format
1.2
OVAL
5.11
Asset Identification
1.1
ARF
1.1
CCE
5.0
CPE
Common Platform Enumeration
2.3
CVE
2.0
CVSS
2.0
7.2. SCAP Content in Satellite
SCAP content is a SCAP data-stream file that contains implementation of compliance, configuration, or security baselines. A single data stream usually includes multiple XCCDF profiles. An XCCDF profile defines an industry standard or custom security standard against which you can evaluate compliance of host configuration in Satellite, such as Protection Profile for General Purpose Operating Systems (OSPP), Health Insurance Portability and Accountability Act (HIPAA), and PCI-DSS v3.2.1 Control Baseline for Red Hat Enterprise Linux 9. You can adapt existing XCCDF profiles according to your requirements using tailoring files.
In Satellite, you use an XCCDF profile from SCAP content and, eventually, a tailoring file, to define a compliance policy. Satellite includes default SCAP contents from SCAP Security Guide provided by the OpenSCAP project.
For more information on how to download, deploy, modify, and create your own content, see:
7.2.1. Supported SCAP Versions
Satellite supports content of SCAP versions 1.2 and 1.3.
7.3. Compliance Policy Deployment Options
You can use one of the following methods to deploy compliance policies:
Ansible deployment
You use an Ansible role to configure hosts for compliance scans.
Puppet deployment
You use a Puppet class and the Puppet agent to configure hosts for compliance scans.
Manual deployment
You manually configure hosts for compliance scans.
7.4. Configuring Compliance Policy Deployment Methods
Use one the following procedures to configure Satellite for the method that you have selected to deploy compliance policies. You will select one of these methods when you later create a compliance policy.
Procedure for Ansible deployment
  1. Import the theforeman.foreman_scap_client Ansible role.
  2. Assign the created policy and the theforeman.foreman_scap_client Ansible role to a host or host group.
  3. To trigger the deployment, run the Ansible role on the host or host group either manually, or set up a recurring job by using remote execution for regular policy updates.
    For more information, see Configuring and Setting Up Remote Jobs in Managing Hosts.
Procedure for Puppet deployment
  1. Ensure Puppet is enabled.
  2. Ensure the Puppet agent is installed on hosts.
  3. Import the Puppet environment that contains the foreman_scap_client Puppet module.
  4. Assign the created policy and the foreman_scap_client Puppet class to a host or host group.
    Puppet triggers the deployment on the next regular run or you can run Puppet manually. Puppet runs every 30 minutes by default.
Procedure for manual deployment
7.5. Listing Available SCAP Contents
Use this procedure to view what SCAP contents are already loaded in Satellite. To use the CLI instead of the Satellite web UI, see the CLI procedure.
Prerequisite
  • Your user account has the view_scap_contents permission.
  • In the Satellite web UI, navigate to Hosts > Compliance – SCAP contents.
CLI procedure
  • Run the following Hammer command on Satellite Server:
    # hammer scap-content list \
    --location "My_Location" \
7.6. Configuring SCAP Contents
You can upload SCAP data streams and tailoring files to define compliance policies.
7.6.1. Loading the Default SCAP Contents
By loading the default SCAP contents on Satellite Server, you ensure that the data streams from the SCAP Security Guide (SSG) are loaded and assigned to all organizations and locations.
SSG is provided by the operating system of Satellite Server and installed in /usr/share/xml/scap/ssg/content/. Note that the available data streams depend on the operating system version on which Satellite runs. You can only use this SCAP content to scan hosts that have the same minor RHEL version as your Satellite Server. For more information, see Getting Supported SCAP Contents for RHEL.
  • Your user account has a role assigned that has the create_scap_contents permission.
  • Use the following Hammer command on Satellite Server:
7.6.2. Getting Supported SCAP Contents for RHEL
You can get the latest SCAP Security Guide (SSG) for Red Hat Enterprise Linux on the Red Hat Customer Portal. You have to get a version of SSG that is designated for the minor RHEL version of your hosts.
  1. Access the SCAP Security Guide in the package browser.
  2. From the Version menu, select the latest SSG version for the minor version of RHEL that your hosts are running. For example, for RHEL 8.6, select a version named *.el8_6.
  3. Download the package RPM.
  4. Extract the data-stream file (*-ds.xml) from the RPM. For example:
    $ rpm2cpio scap-security-guide-0.1.69-3.el8_6.noarch.rpm \
    | cpio -iv --to-stdout ./usr/share/xml/scap/ssg/content/ssg-rhel8-ds.xml \
    > ssg-rhel-8.6-ds.xml
  5. Upload the data stream to Satellite. For more information, see Uploading Additional SCAP Content.
7.6.3. Uploading Additional SCAP Content
You can upload additional SCAP content into Satellite Server, either content created by yourself or obtained elsewhere. Note that Red Hat only provides support for SCAP content obtained from Red Hat. To use the CLI instead of the Satellite web UI, see the CLI procedure.
Prerequisite
  • Your user account has the create_scap_contents permission.
  • You have acquired a SCAP data-stream file.
  1. In the Satellite web UI, navigate to Hosts > Compliance > SCAP contents.
  2. Click Upload New SCAP Content.
  3. Enter a title in the Title text box, such as My SCAP Content.
  4. In Scap File, click Choose file, navigate to the location containing a SCAP data-stream file and click Open.
  5. On the Locations tab, select locations.
  6. On the Organizations tab, select organizations.
  7. Click Submit.
If the SCAP content file is loaded successfully, a message similar to Successfully created My SCAP Content is displayed.
CLI procedure
  1. Place the SCAP data-stream file to a directory on your Satellite Server, such as /usr/share/xml/scap/my_content/.
  2. Run the following Hammer command on Satellite Server:
    # hammer scap-content bulk-upload --type directory \
    --directory /usr/share/xml/scap/my_content/ \
7.6.4. Tailoring XCCDF Profiles
You can customize existing XCCDF profiles using tailoring files without editing the original SCAP content. A single tailoring file can contain customizations of multiple XCCDF profiles.
You can create a tailoring file using the SCAP Workbench tool. For more information on using the SCAP Workbench tool, see Customizing SCAP Security Guide for your use case.
Then you can assign a tailoring file to a compliance policy to customize an XCCDF profile in the policy.
7.6.5. Uploading a Tailoring File
After uploading a tailoring file, you can apply it in a compliance policy to customize an XCCDF profile.
Prerequisite
  • Your user account has the create_tailoring_files permission.
  1. In the Satellite web UI, navigate to Hosts > Compliance – Tailoring Files and click New Tailoring File.
  3. Click Choose File, navigate to the location containing the tailoring file and select Open.
  4. Click Submit to upload the chosen tailoring file.
7.7. Managing Compliance Policies
A compliance policy is a scheduled audit that checks the specified hosts for compliance against a specific XCCDF profile from a SCAP content.
You specify the schedule for scans on Satellite Server and the scans are performed on hosts. When a scan completes, a report in ARF format is generated and uploaded to Satellite Server. The compliance policy makes no changes to the scanned host.
A compliance policy defines a SCAP client configuration and a cron schedule. The policy is then deployed together with the SCAP client on hosts to which the policy is assigned.
7.7.1. Compliance Policy
A scheduled audit, also known as a compliance policy, is a scheduled task that checks the specified hosts for compliance against an XCCDF profile. The schedule for scans is specified by Satellite Server and the scans are performed on the host. When a scan completes, an Asset Reporting File (ARF) is generated in XML format and uploaded to Satellite Server. You can see the results of the scan in the compliance policy dashboard. No changes are made to the scanned host by the compliance policy. The SCAP content includes several profiles with associated rules but policies are not included by default.
7.7.2. Creating a Compliance Policy
By creating a compliance policy, you can define and plan your security compliance requirements, and ensure that your hosts remain compliant to your security policies.
  1. In the Satellite web UI, navigate to Hosts > Compliance – Policies.
  2. Click New Policy or New Compliance Policy.
  3. Select the deployment method: Ansible, Puppet, or Manual. Then click Next.
  4. Enter a name for this policy, a description (optional), then click Next.
  5. Select the SCAP Content and XCCDF Profile to be applied, then click Next.
    Note that Satellite does not detect whether the selected XCCDF profile contains any rules. An empty XCCDF profile, such as the Default XCCDF Profile, will return empty reports.
  6. Optional: To customize the XCCDF profile, select a Tailoring File and a XCCDF Profile in Tailoring File, then click Next.
  7. Specify the scheduled time when the policy is to be applied. Select Weekly, Monthly, or Custom from the Period list. The Custom option allows for greater flexibility in the policy’s schedule.
  8. Select the locations to which to apply the policy, then click Next.
  9. Select the organizations to which to apply the policy, then click Next.
  10. Optional: Select the host groups to which to assign the policy.
  11. Click Submit.
7.7.3. Viewing a Compliance Policy
You can preview the rules which will be applied by specific OpenSCAP content and profile combination. This is useful when you plan policies.
Prerequisite
  • Your user account has the view_policies permission.
  2. In the Actions column of the required policy, click Show Guide or select it from the list.
7.7.4. Editing a Compliance Policy
In the Satellite web UI, you can edit compliance policies.
Puppet agent applies an edited policy to the host on the next run. By default, this occurs every 30 minutes. If you use Ansible, you must run the Ansible role manually again or have configured a recurring remote execution job that runs the Ansible role on hosts.
Prerequisite
  • Your user account has the view_policies and edit_policies permissions.
  2. Click the name of the required policy.
  4. Click Submit.
7.7.5. Deleting a Compliance Policy
In the Satellite web UI, you can delete existing compliance policies.
Prerequisite
  • Your user account has the view_policies and destroy_policies permissions.
  2. In the Actions column of the required policy, select Delete from the list.
7.8. Deploying Compliance Policies
To deploy a compliance policy, you must install the SCAP client, update the cron schedule file, and upload the SCAP content selected in the policy onto a host.
7.8.1. Deploying a Policy in a Host Group Using Ansible
After you deploy a compliance policy in a host group using Ansible, the Ansible role installs the SCAP client and configures OpenSCAP scans on the hosts according to the selected compliance policy.
  • You have enabled OpenSCAP on your Capsule. For more information, see Enabling OpenSCAP on Capsule Servers in Installing Capsule Server.
  • You have enabled and synced the Satellite Client 6.11 repository to Satellite, and enabled it on the hosts.
  • You have created a compliance policy with the Ansible deployment option and assigned the host group.
  1. In the Satellite web UI, navigate to Configure > Host Groups.
  2. Click the host group that you want to configure for OpenSCAP reporting.
  3. From the OpenSCAP Capsule list, select the Capsule with OpenSCAP enabled that you want to use.
  4. On the Ansible Roles tab, assign the theforeman.foreman_scap_client Ansible role.
  5. Optional: On the Parameters tab, configure any Ansible variables of the role.
  6. Click Submit to save your changes.
  7. In the row of the required host group, navigate to the Actions column and select Run all Ansible roles.
7.8.2. Deploying a Policy on a Host Using Ansible
After you deploy a compliance policy on a host using Ansible, the Ansible role installs the SCAP client and configures OpenSCAP scans on the host according to the selected compliance policy.
  1. In the Satellite web UI, navigate to Hosts > All Hosts, and select Edit on the host you want to configure for OpenSCAP reporting.
  2. From the OpenSCAP Capsule list, select the Capsule with OpenSCAP enabled that you want to use.
  3. On the Ansible Roles tab, add the theforeman.foreman_scap_client Ansible role.
  4. Optional: On the Parameters tab, configure any Ansible variables of the role.
  6. Click the Hosts breadcrumbs link to navigate back to the host index page.
  8. Click Select Action.
  10. In the Assign Compliance Policy window, select Remember hosts selection for the next bulk action.
  11. Select the required policy from the list of available policies and click Submit.
  12. Click Select Action.
  13. Select Run all Ansible roles from the list.
7.8.3. Deploying a Policy in a Host Group Using Puppet
After you deploy a compliance policy in a host group using Puppet, the Puppet agent installs the SCAP client and configures OpenSCAP scans on the hosts on the next Puppet run according to the selected compliance policy.
  • You have created a compliance policy with the Puppet deployment option and assigned the host group.
  3. In the Environment list, select the Puppet environment that contains the foreman_scap_client* Puppet classes.
  4. In the OpenSCAP Capsule list, select the Capsule with OpenSCAP enabled that you want to use.
  5. On the Puppet ENC tab, add the foreman_scap_client Puppet class.
  6. Optional: Configure any Puppet Class Parameters.
7.8.4. Deploying a Policy on a Host Using Puppet
After you deploy a compliance policy on a host using Puppet, the Puppet agent installs the SCAP client and configures OpenSCAP scans on the host on the next Puppet run according to the selected compliance policy.
  2. From the Environment list, select the Puppet environment that contains the foreman_scap_client and foreman_scap_client::params Puppet classes.
  4. On the Puppet ENC tab, add the foreman_scap_client Puppet class.
  5. Optional: Configure any Puppet Class Parameters.
7.9. Running a Security Compliance Scan on Demand
Hosts perform OpenSCAP scans regularly by the CRON schedule defined in the compliance policies assigned to hosts. However, you can also run a scan on a host for all configured compliance policies manually at any time.
  • Your user account has the view_hosts, create_job_invocations, and view_job_invocations permissions.
  • You have created a compliance policy and deployed it on the host.
  1. Navigate to Hosts > All Hosts.
  2. Click the hostname of the required host.
  3. On the host details page, expand the Schedule a job dropdown menu.
  4. Select Run OpenSCAP scan.
  1. In the host details overview, locate the Recent jobs card.
  2. Select the Running tab. Unless the job has already finished, the table shows a job called Run scan for all OpenSCAP policies.
  3. On the Recent jobs card, select the Finished tab.
  4. If the job has finished successfully, you should see the succeeded status in the row of the job.
  5. Optional: Click the job name to review invocation details.
7.10. Monitoring Compliance
With Satellite, you can centralize compliance monitoring and management. A compliance dashboard provides an overview of compliance of hosts and the ability to view details for each host within the scope of that policy. Compliance reports provide a detailed analysis of compliance of each host with the applicable policy. With this information, you can evaluate the risks presented by each host and manage the resources required to bring hosts into compliance. By monitoring compliance with SCAP, you can verify policy compliance and detect changes in compliance.
7.10.1. Searching Compliance Reports
Use the Compliance Reports search field to filter the list of available reports on any subset of hosts.
  1. In the Satellite web UI, navigate to Hosts > Reports.
  2. Optional: To see a list of available search parameters, click the empty Search field.
  3. Enter the search query in the Search field and click Search. The search query is case insensitive.
Search Query Examples
Find all compliance reports for which more than five rules failed
failed > 5
Find all compliance reports created after January 1, 2023, for hosts with hostnames that contain prod-
host ~ prod- AND date > "Jan 1, 2023"
Find all reports generated by the rhel7_audit compliance policy from an hour ago
Find reports that pass an XCCDF rule
Find reports that fail an XCCDF rule
Find reports that have a result different than fail or pass for an XCCDF rule
  • You can create complex queries with the following logical operators: and, not and has. For more information about logical operators, see Supported Operators for Granular Search in Administering Red Hat Satellite.
  • You cannot use regular expressions in a search query. However, you can use multiple fields in a single search expression. For more information about all available search operators, see Supported Operators for Granular Search in Administering Red Hat Satellite.
  • You can bookmark a search to reuse the same search query. For more information, see Creating Bookmarks in Administering Red Hat Satellite.
7.10.2. Compliance Email Notifications
Satellite Server sends an OpenSCAP Summary email to all users who subscribe to the Compliance policy summary email notifications. For more information on subscribing to email notifications, see Configuring Email Notifications.
Each time a policy is run, Satellite checks the results against the previous run, noting any changes between them. The email is sent according to the frequency requested by each subscriber, providing a summary of each policy and its most recent result.
7.10.3. Viewing Compliance Policy Statistics
You can view a compliance policy dashboard to verify compliance reports of a particular policy. The compliance policy dashboard provides a statistical summary of compliance of hosts and the ability to view report details for each host within the scope of that policy.
Consider prioritizing the following hosts when viewing compliance reports:
  • Hosts which were evaluated as Failed
  • Hosts labelled as Never audited because their status is unknown
Prerequisite
  1. In the Satellite web UI, navigate to Hosts > Policies.
  2. In the row of the required policy, navigate to the Actions column and click Dashboard.
7.10.4. Examining Hosts per Rule Compliance Result
You can examine a simplified report and use policy rules to list hosts that have a certain compliance result, such as failing a particular rule.
Prerequisite
  • Your user account has the view_arf_reports and view_hosts permissions.
  2. In the Reported At column, navigate to the report of the required host and compliance policy, and click the time link.
  3. Satellite displays a simplified list of policy rules with the results of the scan.
  4. Optional: Filter the rules by check result. From the Show log messages dropdown list, select one of the following filters:
    • Failed and othered – to view rules that have failed or have not been checked during the scan,
    • Failed only – to view only rules that have failed.
  5. Optional: Examine the details of the rule. In the Message column, click the icon next to the name of the rule.
  6. In the row of the required rule, navigate to the Actions column and click Hosts failing this rule.
7.10.5. Examining Compliance Failures of a Host
You can examine a full compliance report, determine why a host failed compliance on a rule, and, in some cases, see how to remediate a case of non-compliance.
Warning
Do not implement any of the recommended remedial actions or scripts without first testing them in a non-production environment. Remediation might render the system non-functional.
  • Introduction
  • Evaluation Characteristics
  • Compliance and Scoring
  • Rule Overview
Prerequisite
  1. In the Satellite web UI, navigate to Hosts > Reports to list all compliance reports.
  2. In the row of the required host, navigate to the Actions column and click Full Report to view the complete details of an evaluation report.
  3. Navigate to the Evaluation Characteristics area to review basic details about the evaluation of the host against a specific profile.
  4. Navigate to the Compliance and Scoring area to review evaluation statistics and the host compliance score.
  5. Navigate to the Rule Overview to examine the rules.
  6. Optional: Deselect the check statuses that you want to hide, such as pass, notapplicable, or fixed.
  7. Optional: From the Group rule by dropdown menu, select the criterion for the grouping of rules, such as Severity.
  8. Optional: Enter a search string into the search field to filter rules by title. The search is case insensitive and applied dynamically as you type.
  9. Click the title of a rule to inspect further result details:
    • The rationale for the rule.
7.10.6. Deleting a Compliance Report
You can delete compliance reports on your Satellite.
Prerequisite
  • Your user account has the view_arf_reports and destroy_arf_reports permissions.
  3. Click OK.
7.10.7. Deleting Multiple Compliance Reports
You can delete multiple compliance policies simultaneously. However, in the Satellite web UI, compliance policies are paginated, so you must delete one page of reports at a time. If you want to delete all OpenSCAP reports, use the script in Deleting OpenSCAP Reports in the API Guide.
Prerequisite
8. Backing Up Satellite Server and Capsule Server
You can back up your Satellite deployment to ensure the continuity of your Red Hat Satellite deployment and associated data in the event of a disaster. If your deployment uses custom configurations, you must consider how to handle these custom configurations when you plan your backup and disaster recovery policy.
To create a backup of your Satellite Server or Capsule Server and all associated data, use the satellite-maintain backup command. Backing up to a separate storage device on a separate system is highly recommended.
Satellite services are unavailable during the backup. Therefore, you must ensure that no other tasks are scheduled by other administrators. You can schedule a backup using cron. For more information, see the Example of a Weekly Full Backup Followed by Daily Incremental Backups.
During offline or snapshot backups, the services are inactive and Satellite is in a maintenance mode. All the traffic from outside on port 443 is rejected by a firewall to ensure there are no modifications triggered.
Conventional Backup Methods
You can also use conventional backup methods. For more information, see Recovering and restoring a system in the Red Hat Enterprise Linux 8 Configuring Basic System Settings Guide.
If you plan to use the satellite-maintain backup command to create a backup, do not stop Satellite services.
8.1. Estimating the Size of a Backup
The full backup creates uncompressed archives of PostgreSQL and Pulp database files, and Satellite configuration files. Compression occurs after the archives are created to decrease the time when Satellite services are unavailable.
  • Uncompressed Satellite database and configuration files
  • Compressed Satellite database and configuration files
  1. Enter the du command to estimate the size of uncompressed directories containing Satellite database and configuration files:
    For Red Hat Enterprise Linux 8:
    100G    /var/lib/pgsql/data
    100G	/var/lib/pulp
    886M  /var/lib/qpidd
    16M   /var/lib/tftpboot
    37M   /etc
    900K  /root/ssl-build
    100K  /var/www/html/pub
    2M    /opt/puppetlabs
    942M  total
    For Red Hat Enterprise Linux 7:
    # du -sh /var/opt/rh/rh-postgresql12/lib/pgsql/data /var/lib/pulp
    100G    /var/opt/rh/rh-postgresql12/lib/pgsql/data
    100G	/var/lib/pulp
    886M  /var/lib/qpidd
    37M   /etc
    2M    /opt/puppetlabs
    942M  total
    Table 5. Backup Data Compression Ratio for Red Hat Enterprise Linux 8
    PostgreSQL database files
    /var/lib/pgsql/data
    80 – 85%
    100 GB → 20 GB
    Pulp RPM files
    /var/lib/pulp
    (not compressed)
    100 GB
    Configuration files
    /var/lib/qpidd
    /var/lib/tftpboot
    /etc
    /root/ssl-build
    /var/www/html/pub
    /opt/puppetlabs
    85%
    942 MB → 141 MB
    Table 6. Backup Data Compression Ratio for Red Hat Enterprise Linux 7
    80 - 85%
    100 GB → 20 GB
    Pulp RPM files
    /var/lib/pulp
    (not compressed)
    100 GB
    Configuration files
    /var/lib/qpidd
    /var/lib/tftpboot
    /etc
    /root/ssl-build
    /var/www/html/pub
    /opt/puppetlabs
    85%
    942 MB → 141 MB
8.2. Performing a Full Backup of Satellite Server or Capsule Server
Red Hat Satellite uses the satellite-maintain backup command to make backups.
There are three main methods of backing up Satellite Server:
  • Offline backup
  • Online backup
  • Snapshot backups
Offline backups
# satellite-maintain backup offline --help
Online backups
# satellite-maintain backup online --help
Snapshots backups
# satellite-maintain backup snapshot --help
Directory creation
The satellite-maintain backup command creates a time-stamped subdirectory in the backup directory that you specify. The satellite-maintain backup command does not overwrite backups, therefore you must select the correct directory or subdirectory when restoring from a backup or an incremental backup. The satellite-maintain backup command stops and restarts services as required.
When you run the satellite-maintain backup offline command, the following default backup directories are created:
  • satellite-backup on Satellite
  • foreman-proxy-backup on Capsule
Remote databases
You can use the satellite-maintain backup command to back up remote databases.
You can use both online and offline methods to back up remote databases, but if you use offline methods, such as snapshot, the satellite-maintain backup command performs a database dump.
Warning
Request other users of Satellite Server or Capsule Server to save any changes and warn them that Satellite services are unavailable for the duration of the backup. Ensure no other tasks are scheduled for the same time as the backup.
  • On Satellite Server, enter the following command:
    # satellite-maintain backup offline /var/satellite-backup
  • On Capsule Server, enter the following command:
    # satellite-maintain backup offline /var/foreman-proxy-backup
8.3. Performing a Backup without Pulp Content
Warning
    # satellite-maintain backup offline --skip-pulp-content /var/backup_directory
8.4. Performing an Incremental Backup
Warning
    # satellite-maintain backup offline /var/backup_directory
  2. To create a directory within your backup directory to store the first incremental back up, enter the satellite-maintain backup command with the --incremental option:
    # satellite-maintain backup offline --incremental /var/backup_directory/full_backup /var/backup_directory
  3. To create the second incremental backup, enter the satellite-maintain backup command with the --incremental option and include the path to the first incremental backup to indicate the starting point for the next increment. This creates a directory for the second incremental backup in your backup directory:
    # satellite-maintain backup offline --incremental /var/backup_directory/first_incremental_backup /var/backup_directory
8.5. Example of a Weekly Full Backup Followed by Daily Incremental Backups
#!/bin/bash -e
  satellite-maintain backup offline --assumeyes $DESTINATION
else
  satellite-maintain backup offline --assumeyes --incremental "$LAST" $DESTINATION
fi
exit 0
Note that the satellite-maintain backup command requires /sbin and /usr/sbin directories to be in PATH and the --assumeyes option is used to skip the confirmation prompt.
8.6. Performing an Online Backup
When performing an online backup, if there are procedures affecting the Pulp database, the Pulp part of the backup procedure repeats until it is no longer being altered. Because the backup of the Pulp database is the most time consuming part of backing up Satellite, if you make a change that alters the Pulp database during this time, the backup procedure keeps restarting.
Warning
    # satellite-maintain backup online /var/backup_directory
8.7. Performing a Snapshot Backup
The snapshot backup method is faster than a full offline backup and therefore reduces Satellite downtime.
satellite-maintain backup snapshot -h
Warning
Request other Satellite Server or Capsule Server users to save any changes and warn them that Satellite services are unavailable for the duration of the backup. Ensure no other tasks are scheduled for the same time as the backup.
  • The system uses LVM for the directories that you snapshot: /var/lib/pulp/, and /var/opt/rh/rh-postgresql12/lib/pgsql.
  • To perform a snapshot backup, enter the satellite-maintain backup snapshot command:
    # satellite-maintain backup snapshot /var/backup_directory
The satellite-maintain backup snapshot command creates snapshots when the services are active, and stops all services which can impact the backup. This makes the maintenance window shorter. After the successful snapshot, all services are restarted and LVM snapshots are removed.
8.8. White-listing and Skipping Steps When Performing Backups
A backup using the satellite-maintain backup command proceeds in a sequence of steps. To skip part of the backup add the --whitelist option to the command and add the step label that you want to omit.
    # satellite-maintain advanced procedure run -h
  • To skip a step of the backup, enter the satellite-maintain backup command with the --whitelist option. For example:
    # satellite-maintain backup online --whitelist backup-metadata -y /var/backup_directory
9. Restoring Satellite Server or Capsule Server from a Backup
You can restore Satellite Server or Capsule Server from the backup data that you create as part of Backing Up Satellite Server and Capsule Server. This process outlines how to restore the backup on the same server that generated the backup, and all data covered by the backup is deleted on the target system. If the original system is unavailable, provision a system with the same configuration settings and host name.
9.1. Restoring from a Full Backup
Use this procedure to restore Red Hat Satellite or Capsule Server from a full backup. When the restore process completes, all processes are online, and all databases and system configuration revert to the state at the time of the backup.
  • Ensure that you are restoring to the correct instance. The Red Hat Satellite instance must have the same host name, configuration, and be the same minor version (X.Y) as the original system.
  • Ensure that you have enough space to store this data on the base system of Satellite Server or Capsule Server as well as enough space after the restoration to contain all the data in the /etc/ and /var/ directories contained within the backup.
    # df -h /var/backup_directory
    # restorecon -Rnv /
  1. Choose the appropriate method to install Satellite or Capsule:
  2. Copy the backup data to Satellite Server’s local file system. Use /var/ or /var/tmp/.
    # satellite-maintain restore /var/backup_directory
Additional Resources
9.2. Restoring from Incremental Backups
Use this procedure to restore Satellite or Capsule Server from incremental backups. If you have multiple branches of incremental backups, select your full backup and each incremental backup for the branch you want to restore, in chronological order.
  2. Remove the full backup data from Satellite Server’s local file system, for example, /var/ or /var/tmp/.
  3. Copy the incremental backup data to Satellite Server’s local file system, for example, /var/ or /var/tmp/.
    # satellite-maintain restore /var/backup_directory/FIRST_INCREMENTAL
    # satellite-maintain restore /var/backup_directory/SECOND_INCREMENTAL
9.3. Backup and Restore Capsule Server Using a Virtual Machine Snapshot
If your Capsule Server is a virtual machine, you can restore it from a snapshot. Creating weekly snapshots to restore from is recommended. In the event of failure, you can install, or configure a new Capsule Server, and then synchronize the database content from Satellite Server.
If required, deploy a new Capsule Server, ensuring the host name is the same as before, and then install the Capsule certificates. You may still have them on Satellite Server, the package name ends in -certs.tar, alternately create new ones. Follow the procedures in Installing Capsule Server until you can confirm, in the Satellite web UI, that Capsule Server is connected to Satellite Server. Then use the procedure Synchronizing an External Capsule to synchronize from Satellite.
9.3.1. Synchronizing an External Capsule
Synchronize an external Capsule with Satellite.
  1. To synchronize an external Capsule, select the relevant organization and location in the Satellite web UI, or choose Any Organization and Any Location.
  2. In the Satellite web UI, navigate to Infrastructure > Capsules and click the name of the Capsule to synchronize.
10. Renaming Satellite Server or Capsule Server
To rename Satellite Server or Capsule Server, you must use the satellite-change-hostname script.
If you rename Satellite Server, you must reregister all Satellite clients and configure each Capsule Server to point them to the new Satellite host name. If you use custom SSL certificates, you must regenerate them with the new host name. If you use virt-who, you must update the virt-who configuration files with the new host name.
If you rename Capsule Server, you must reregister all Capsule clients and update the Capsule host name in the Satellite web UI. If you use custom SSL certificates, you must regenerate them with the new host name.
Warning
The renaming process shuts down all Satellite Server services on the host being renamed. When the renaming is complete, all services are restarted.
10.1. Renaming Satellite Server
The host name of Satellite Server is used by Satellite Server components, all Capsule Servers, and hosts registered to it for communication. This procedure ensures that you update all references to the new host name.
If you use external authentication, you must reconfigure Satellite Server for external authentication after you run the satellite-change-hostname script. The satellite-change-hostname script breaks external authentication for Satellite Server. For more information about configuring external authentication, see Configuring External Authentication.
If you use virt-who, you must update the virt-who configuration files with the new host name after you run the satellite-change-hostname script. For more information, see Modifying a virt-who Configuration in Configuring Virtual Machine Subscriptions in Red Hat Satellite.
  • Both the hostname and hostname -f commands must return the FQDN of Satellite Server or the satellite-change-hostname script will fail to complete. If the hostname command returns the shortname of Satellite Server instead of the FQDN, use hostnamectl set-hostname old_fqdn to set the old FQDN correctly before attempting to use the satellite-change-hostname script.
  • Perform a backup of Satellite Server before changing a host name. If the renaming process is not successful, you must restore it from a backup. For more information, see Backing Up Satellite Server and Capsule Server.
  • Optional: If Satellite Server has a custom SSL certificate installed, a new certificate must be obtained for the host’s new name. For more information, see Configuring Satellite Server with a Custom SSL Certificate in Installing Satellite Server from a Connected Network.
  1. On Satellite Server, choose the appropriate method to run the satellite-change-hostname script, providing the new host name and Satellite credentials:
    • If your Satellite Server is installed with default self-signed SSL certificates, enter the following command:
      # satellite-change-hostname new-satellite \
      --username admin \
      --password password
    • If your Satellite Server is installed with custom SSL certificates:
      --username admin \
      --password password \
  2. Optional: If you have created a custom SSL certificate for the new Satellite Server host name, run the Satellite installation script to install the certificate. For more information about installing a custom SSL certificate, see Deploying a Custom SSL Certificate to Satellite Server in Installing Satellite Server from a Connected Network.
  3. Reregister all Satellite hosts. For more information, see Registering Hosts in Managing Hosts.
  4. On all Capsule Servers, run the Satellite installation script to update references to the new host name:
    # satellite-installer \
    --foreman-proxy-foreman-base-url https://new-satellite.example.com \
    --foreman-proxy-trusted-hosts new-satellite.example.com \
    --puppet-server-foreman-url https://new-satellite.example.com
  5. On Satellite Server, list all Capsule Servers:
    # hammer capsule list
  6. On Satellite Server, synchronize content for each Capsule Server:
    --id capsule_id_number
10.2. Renaming Capsule Server
The host name of Capsule Server is referenced by Satellite Server components, and all hosts registered to it. This procedure ensures that you update all references to the new host name.
  • Both the hostname and hostname -f commands must return the FQDN of Capsule Server or the satellite-change-hostname script will fail to complete.
  • If the hostname command returns the shortname of Capsule Server instead of the FQDN, use hostnamectl set-hostname old_fqdn to set the old FQDN correctly before attempting to use the satellite-change-hostname script.
  • Backup Capsule Server. The satellite-change-hostname script makes irreversible changes to Capsule Server. If the renaming process is not successful, you must restore it from a backup.
    Perform a backup before changing a host name. For more information, see Backing Up Satellite Server and Capsule Server.
  1. On Satellite Server, generate a new certificates archive file for Capsule Server.
    • If you are using the default SSL certificate, enter the following command:
      # capsule-certs-generate \
      --foreman-proxy-fqdn new-capsule.example.com \
      --certs-tar /root/new-capsule.example.com-certs.tar
    • If you are using a custom SSL certificate, create a new SSL certificate for Capsule Server. For more information, see Configuring Capsule Server with a Custom SSL Certificate in Installing Capsule Server.
  2. On Satellite Server, copy the certificates archive file to Capsule Server, providing the root user’s password when prompted. In this example the archive file is copied to the root user’s home directory, but you may prefer to copy it elsewhere.
    # scp /root/new-capsule.example.com-certs.tar root@capsule.example.com:
  3. On Capsule Server, run the satellite-change-hostname script and provide the host’s new name, Satellite credentials, and certificates archive filename.
    # satellite-change-hostname new-capsule.example.com --username admin \
  4. Optional: If you have created a custom certificate for Capsule Server, on Capsule Server, to deploy the certificate, enter the satellite-installer command that the capsule-certs-generate command returns. For more information, see Deploying a Custom SSL Certificate to Capsule Server in Installing Capsule Server.
  5. On all Capsule clients, enter the following commands to reinstall the bootstrap RPM, reregister clients, and refresh their subscriptions.
    You can use remote execution feature to perform this step. For more information, see Configuring and Setting up Remote Jobs in the Managing Hosts Guide.
    # yum remove -y katello-ca-consumer*
    # rpm -Uvh http://new-capsule.example.com/pub/katello-ca-consumer-latest.noarch.rpm
    # subscription-manager register --org="My_Organization" \
    --environment="Library" \
    --force
    # subscription-manager refresh
  6. In the Satellite web UI, navigate to Infrastructure > Capsules.
  7. Locate Capsule Server in the list, and click Edit to the right of it.
  8. Edit the Name and URL fields to match Capsule Server’s new host name, then click Submit.
  9. On your DNS server, add a record for Capsule Server’s new host name, and delete the record for the previous host name.
11. Maintaining Satellite Server
This chapter provides information on how to maintain a Satellite Server, including information on how to work with audit records, how to clean unused tasks, and how to recover Pulp from a full disk.
11.1. Deleting Audit Records
Audit records are created automatically in Satellite. You can use the foreman-rake audits:expire command to remove audits at any time. You can also use a cron job to schedule audit record deletions at the set interval that you want.
By default, using the foreman-rake audits:expire command removes audit records that are older than 90 days. You can specify the number of days to keep the audit records by adding the days option and add the number of days.
11.2. Anonymizing Audit Records
11.3. Deleting Report Records
Report records are created automatically in Satellite. You can use the foreman-rake reports:expire command to remove reports at any time. You can also use a cron job to schedule report record deletions at the set interval that you want.
11.4. Configuring the Cleaning Unused Tasks Feature
Satellite performs regular cleaning to reduce disc space in the database and limit the rate of disk growth. As a result, Satellite backup completes faster and overall performance is higher.
By default, Satellite executes a cron job that cleans tasks every day at 19:45. Satellite removes the following tasks during the cleaning:
  • To configure the time at which Satellite runs the cron job, set the --foreman-plugin-tasks-cron-line parameter to the time you want in cron format. For example, to schedule the cron job to run every day at 15:00, enter the following command:
    # satellite-installer --foreman-plugin-tasks-cron-line "00 15 * * *"
  • To configure the period after which Satellite deletes the tasks, edit the :rules: section in the /etc/foreman/plugins/foreman-tasks.yaml file.
  • To disable regular task cleanup on Satellite, enter the following command:
    # satellite-installer --foreman-plugin-tasks-automatic-cleanup false
  • To reenable regular task cleanup on Satellite, enter the following command:
    # satellite-installer --foreman-plugin-tasks-automatic-cleanup true
11.5. Deleting Task Records
Task records are created automatically in Satellite. You can use the foreman-rake foreman_tasks:cleanup command to remove tasks at any time. You can also use a cron job to schedule Task record deletions at the set interval that you want.
11.6. Deleting a Task by ID
  1. Connect to your Satellite Server using SSH:
    # ssh root@satellite.example.com
  2. Optional: View the task:
  3. Delete the task:
  4. Optional: Ensure the task has been removed from Satellite Server:
11.7. Recovering from a Full Disk
    1. Remove orphaned content:
    3. Grow the file system on the LV with the /var/lib/pulp directory on it. For more information, see Growing a logical volume and file system in the Red Hat Enterprise Linux 8 Configuring and Managing Logical Volumes Guide.
      1. Stop Satellite services:
      3. Start Satellite services:
11.8. Managing Packages on the Base Operating System of Satellite Server or Capsule Server
To install and update packages on the Satellite Server or Capsule Server base operating system, you must enter the satellite-maintain packages command. Satellite prevents users from installing and updating packages with yum because yum might also update the packages related to Satellite Server or Capsule Server and result in system inconsistency.
The satellite-maintain packages command restarts some services on the operating system where you run it because it runs the satellite-installer command after installing packages.
  • To install packages on Satellite Server or Capsule Server, enter the following command:
    # satellite-maintain packages install package_1 package_2
  • To update specific packages on Satellite Server or Capsule Server, enter the following command:
    # satellite-maintain packages update package_1 package_2
  • To update all packages on Satellite Server or Capsule Server, enter the following command:
Using yum to Check for Package Updates
If you want to check for updates using yum, enter the command to install and update packages manually and then you can use yum to check for updates:
# yum check update
Updating packages individually can lead to package inconsistencies in Satellite Server or Capsule Server. For more information about updating packages in Satellite Server, see Updating Satellite Server.
Enabling yum for Satellite Server or Capsule Server Package Management
If you want to install and update packages on your system using yum directly and control the stability of the system yourself, enter the following command:
Restoring Package Management to the Default Settings
If you want to restore the default settings and enable Satellite Server or Capsule Server to prevent users from installing and updating packages with yum and ensure the stability of the system, enter the following command:
11.9. Reclaiming PostgreSQL Space
The PostgreSQL database can use a large amount of disk space especially in heavily loaded deployments. Use this procedure to reclaim some of this disk space on Satellite.
    # satellite-maintain service stop --exclude postgresql
12. Renewing the Custom SSL Certificate
This chapter provides information on how to renew the custom SSL certificate on Satellite Server as well as on Capsule Server.
12.1. Renewing a Custom SSL Certificate on Satellite Server
Use this procedure to update your custom SSL certificate for Satellite Server.
Prerequisite
  • You must create a new Certificate Signing Request (CSR) and send it to the Certificate Authority to sign the certificate. Refer to the Configuring Satellite Server with a Custom SSL Certificate guide before creating a new CSR because the Server certificate must have X.509 v3 Key Usage and Extended Key Usage extensions with required values. In return, you will receive the Satellite Server certificate and CA bundle.
  • Before deploying a renewed custom certificate on your Satellite Server, validate the custom SSL input files. Note that for the katello-certs-check command to work correctly, Common Name (CN) in the certificate must match the FQDN of Satellite Server:
    # katello-certs-check -t satellite \
    -b /root/satellite_cert/ca_cert_bundle.pem \
    -c /root/satellite_cert/satellite_cert.pem \
    -k /root/satellite_cert/satellite_cert_key.pem
    If the command is successful, it returns the following satellite-installer command. You can use this command to deploy the renewed CA certificates to Satellite Server:
    # satellite-installer --scenario satellite \
    --certs-server-cert "/root/satellite_cert/satellite_cert.pem" \
    --certs-server-key "/root/satellite_cert/satellite_key.pem" \
    --certs-server-ca-cert "/root/satellite_cert/ca_cert_bundle.pem" \
    --certs-update-server \
    --certs-update-server-ca
Do not delete the certificate files after you deploy the certificate. They are required when upgrading Satellite Server.
If a new consumer package katello-ca-consumer-latest.noarch.rpm is generated due to a different Certificate Signing Authority, all the clients registered to Satellite Server must be updated.
  1. Access the Satellite web UI from your local machine. For example, https://satellite.example.com.
  2. In your browser, view the certificate details to verify the deployed certificate.
12.2. Renewing a Custom SSL certificate on Capsule Server
Use this procedure to update your custom SSL certificate for Capsule Server. The satellite-installer command, which the capsule-certs-generate command returns, is unique to each Capsule Server. You cannot use the same command on more than one Capsule Server.
Prerequisite
  • You must create a new Certificate Signing Request and send it to the Certificate Authority to sign the certificate. Refer to the Configuring Satellite Server with a Custom SSL Certificate guide before creating a new CSR because the Satellite Server certificate must have X.509 v3 Key Usage and Extended Key Usage extensions with required values. In return, you will receive the Capsule Server certificate and CA bundle.
  1. On your Satellite Server, validate the custom SSL certificate input files:
    # katello-certs-check -t capsule \
    -b /root/capsule_cert/ca_cert_bundle.pem \
    -c /root/capsule_cert/capsule_cert.pem \
    -k /root/capsule_cert/capsule_cert_key.pem
  2. On your Satellite Server, generate the certificate archive file for your Capsule Server:
    capsule-certs-generate --foreman-proxy-fqdn "capsule.example.com" \
    --certs-tar  "/root/My_Certificates/capsule.example.com-certs.tar" \
    --server-cert "/root/My_Certificates/capsule_cert.pem" \
    --server-key "/root/My_Certificates/capsule_cert_key.pem" \
    --server-ca-cert "/root/My_Certificates/ca_cert_bundle.pem" \
  3. On your Satellite Server, copy the certificate archive file to your Capsule Server:
    # scp /root/My_Certificates/capsule.example.com-certs.tar user@capsule.example.com:
  4. Retain a copy of the satellite-installer command that the capsule-certs-generate command returns for deploying the certificate to your Capsule Server.
  5. Deploy the certificate on your Capsule Server using the satellite-installer command returned by the capsule-certs-generate command:
    # satellite-installer --scenario capsule \
    --foreman-proxy-register-in-foreman "true" \
    --foreman-proxy-foreman-base-url "https://satellite.example.com" \
    --certs-tar-file "/root/My_Certificates/capsule.example.com-certs.tar" \
Do not delete the certificate archive file on the Capsule Server after you deploy the certificate. They are required when upgrading Capsule Server.
If a new consumer package katello-ca-consumer-latest.noarch.rpm is generated due to a different Certificate Signing Authority, all the clients registered to Capsule Server must be updated.
13. Logging and Reporting Problems
This chapter provides information on how to log and report problems in Satellite, including information on relevant log files, how to enable debug logging, how to open a support case and attach the relevant log tar files, and how to access support cases within the Satellite web UI.
You can use the log files and other information described in this chapter to do your own troubleshooting, or you can capture these and many more files, as well as diagnostic and configuration information, to send to Red Hat Support if you need further assistance.
For more information about Satellite logging settings, use satellite-installer with the --full-help option:
# satellite-installer --full-help | grep logging
13.1. Enabling Debug Logging
Debug logging provides the most detailed log information and can help with troubleshooting issues that can arise with Satellite and its components. In the Satellite CLI, enable debug logging to log detailed debugging information for Satellite.
    # satellite-installer --foreman-logging-level debug
    # satellite-installer --reset-foreman-logging-level
13.2. Increasing the Logging Levels to Help with Debugging
By default, Satellite comes with :INFO level logging enabled. You can increase or decrease the log levels on your Satellite.
# satellite-maintain service restart
# hammer admin logging --list
13.2.1. Increasing the Logging Level For Hammer
:log_level: 'debug'
13.2.2. Increasing the Logging Level On Capsule
You can find the log for Capsule in /var/log/foreman-proxy/proxy.log. Uncomment the DEBUG line in /etc/foreman-proxy/settings.yml:
:log_level: DEBUG
Caution
13.2.3. Increasing the Logging Level For Candlepin
You can find the log for Candlepin in /var/log/candlepin/candlepin.log. Errors are also logged to a separate file for easier debugging /var/log/candlepin/error.log.
Extend /etc/candlepin/candlepin.conf:
log4j.logger.org.candlepin=DEBUG
Ensure to restart the tomcat service afterwards:
# systemctl restart tomcat
log4j.logger.org.candlepin.resource.ConsumerResource=WARN
log4j.logger.org.candlepin.resource.HypervisorResource=WARN
13.2.4. Increasing the Logging Level On Satellite
You can find the log for Satellite in /var/log/foreman/production.log.
Satellite stores logs for Apache in:
    :logging:
      :production:
        :type: file
        :layout: pattern
        :level: debug
    :loggers:
      :ldap:
        :enabled: true
      :permissions:
        :enabled: true
      :sql:
        :enabled: true
  3. Restart Satellite services:
13.2.5. Increasing the Logging Level For Qpid Dispatch Router
Qpid logs to syslog and can be viewed in /var/log/messages or with journalctl. Enable debug logging in /etc/qpid-dispatch/qdrouterd.conf:
enable: debug+
Ensure to restart the Qpid Dispatch Router afterwards:
# systemctl restart qdrouterd
Caution
13.2.6. Increasing the Logging Level For Qpid Broker
Qpid logs to syslog and can be viewed in /var/log/messages or with journalctl. Set the log level in /etc/qpid/qpidd.conf:
log-enable=debug+
Ensure to restart the Qpid Broker afterwards:
# systemctl restart qpidd
Caution
Running the installer will revert this change.
13.2.7. Increasing the Logging Level For Redis
loglevel debug
13.2.8. Increasing the Logging Level For Postgres
You can find the log for Postgres in /var/opt/rh/rh-postgresql12/lib/pgsql/data/log/. Uncomment the log_statement in /var/opt/rh/rh-postgresql12/lib/pgsql/data/postgresql.conf:
log_statement = 'all'
Ensure to restart Satellite services afterwards:
Caution
Based on the size of your Satellite installation, this can cause disk space to fill up very quickly. Only turn this on if absolutely needed.
13.2.9. Increasing the Logging Level For Satellite Installer
You can find the log files in /var/log/foreman-installer/. To increase the log level of the Satellite Installer during an install:
# satellite-installer --verbose-log-level debug
13.2.10. Increasing the Logging Level For Pulp
By default, Pulp logs to syslog and can be viewed in /var/log/messages or with journalctl. Add the following config to the /etc/pulp/settings.py file:
Ensure to restart the Pulp services afterwards:
# systemctl restart \
pulpcore-api \
pulpcore-content \
pulpcore-resource-manager \
pulpcore-worker@1 \
pulpcore-worker@2 \
rh-redis5-redis
13.2.11. Increasing the Logging Level For Puppet Agent
You can increase the logging level for Puppet agent on your Satellite Server.
  1. Add the following line to the [agent] block in the /etc/puppetlabs/puppet/puppet.conf file:
    [agent]
        log_level = debug
13.2.12. Increasing the Logging Level For Puppet Server
You can increase the logging level for Puppet server on your Satellite Server.
Prerequisite
    [master]
        log_level = debug
  2. Restart the Puppet server:
    # satellite-maintain service restart --only puppetserver
13.3. Retrieving the Status of Services
  1. In the Satellite web UI, navigate to Administer > About.
  2. On the Smart Proxies tab, you can view the status of all Capsules.
CLI procedure
  • Run hammer ping to get information from the database and Satellite services:
    # hammer ping
  • Use satellite-maintain to check the status of the services running in systemd:
    # satellite-maintain service status
  • Use satellite-maintain to perform a health check:
    $ satellite-maintain health check
13.4. Restarting Services
Satellite uses a set of back-end services to perform tasks. You you experience an issue with your Satellite, check the status of Satellite services.
  • Use satellite-maintain to restart Satellite services:
Tip
13.5. Enabling Individual Loggers
You can enable individual loggers for selective logging. Satellite uses the following loggers:
app
audit
background
blob
dynflow
ldap
notifications
permissions
sql
telemetry
templates
    --foreman-loggers ldap:true \
    --foreman-loggers sql:true
    # satellite-installer --reset-foreman-loggers
13.6. Configuring Logging to Journal or File-based Logging
Satellite uses file-based logging by default. You can use the satellite-installer command to reconfigure logging.
Procedure for configuring logging with Journal
  1. Enter the following satellite-installer command to configure logging to the journald service:
    --foreman-proxy-log JOURNAL
  1. Enter the following satellite-installer command to configure file-based logging:
    --reset-foreman-logging-layout \
    --reset-foreman-proxy-log
    • /var/log/foreman-proxy.log
For more information about Journal, see Viewing logs using the command line in the Red Hat Enterprise Linux 8 Configuring Basic System Settings Guide.
13.7. Log File Directories Provided by Satellite
Red Hat Satellite provides system information in the form of notifications and log files.
Table 7. Log File Directories for Reporting and Troubleshooting
/var/log/candlepin
Subscription management
Installer
/var/log/foreman-maintain
Foreman maintain
Foreman proxy
/var/log/foreman
Foreman
/var/log/httpd
Apache HTTP server
/var/log/messages
Various other log messages
Configuration management
/var/log/rhsm
/var/log/tomcat
Candlepin webservice logs
You can also use the foreman-tail command to follow many of the log files related to Satellite. You can run foreman-tail -l to list the processes and services that it follows.
13.8. Utilities for Collecting Log Information
You can collect information from log files to troubleshoot Satellite.
sosreport
The collection process removes security information such as passwords, tokens, and keys while collecting information. However, the tar files can still contain sensitive information about the Satellite Server. Red Hat recommends that you send this information directly to the intended recipient and not to a public target.
13.9. System Journal Metadata
The following table lists metadata that the journald service uses in Satellite. You can use this metadata to filter your queries.
Table 8. System Journal Metadata
Name Description
AUDIT_ACTION
Audit action performed
AUDIT_TYPE
Audit resource type
AUDIT_ID
AUDIT_ATTRIBUTE
AUDIT_FIELD_OLD
AUDIT_FIELD_NEW
AUDIT_ID
AUDIT_ATTRIBUTE
Example: Name or description
EXCEPTION_MESSAGE
EXCEPTION_CLASS
EXCEPTION_BACKTRACE
LOC_ID
Location database ID
LOC_NAME
Location name
LOC_LABEL
Location label
LOGGER
Logger name
ORG_ID
Organization database ID
ORG_NAME
Organization name
ORG_LABEL
Organization label
REMOTE_IP
Remote IP address of a client
REQUEST
SESSION
TEMPLATE_NAME
Template name
TEMPLATE_DIGEST
TEMPLATE_HOST_NAME
TEMPLATE_HOST_ID
USER_LOGIN
User login name
14. Configuring External Authentication
By using external authentication you can derive user and user group permissions from user group membership in an external identity provider. When you use external authentication, you do not have to create these users and maintain their group membership manually on Satellite Server. In case the external source does not provide email, it will be requested during the first login through Satellite web UI.
Important User and Group Account Information
All user and group accounts must be local accounts. This is to ensure that there are no authentication conflicts between local accounts on your Satellite Server and accounts in your Active Directory domain.
Your system is not affected by this conflict if your user and group accounts exist in both /etc/passwd and /etc/group files. For example, to check if entries for puppet, apache, foreman and foreman-proxy groups exist in both /etc/passwd and /etc/group files, enter the following commands:
# cat /etc/passwd | grep 'puppet\|apache\|foreman\|foreman-proxy'
# cat /etc/group | grep 'puppet\|apache\|foreman\|foreman-proxy'
Scenarios for Configuring External Authentication
Red Hat Satellite supports the following general scenarios for configuring external authentication:
  • Using Lightweight Directory Access Protocol (LDAP) server as an external identity provider. LDAP is a set of open protocols used to access centrally stored information over a network. With Satellite, you can manage LDAP entirely through the Satellite web UI. For more information, see Using LDAP. Though you can use LDAP to connect to a Red Hat Identity Management or AD server, the setup does not support server discovery, cross-forest trusts, or single sign-on with Kerberos in Satellite’s web UI.
  • Using a Red Hat Identity Management server as an external identity provider. Red Hat Identity Management deals with the management of individual identities, their credentials and privileges used in a networking environment. Configuration using Red Hat Identity Management cannot be completed using only the Satellite web UI and requires some interaction with the CLI. For more information see Using Red Hat Identity Management.
  • Using Active Directory (AD) integrated with Red Hat Identity Management through cross-forest Kerberos trust as an external identity provider. For more information see Active Directory with Cross-Forest Trust.
  • Using Red Hat Single Sign-On as an OpenID provider for external authentication to Satellite. For more information, see Configuring Satellite with Red Hat Single Sign-On Authentication.
  • Using Red Hat Single Sign-On as an OpenID provider for external authentication to Satellite with TOTP. For more information, see Configuring Red Hat Single Sign-On Authentication with TOTP.
As well as providing access to Satellite Server, hosts provisioned with Satellite can also be integrated with Red Hat Identity Management realms. Red Hat Satellite has a realm feature that automatically manages the life cycle of any system registered to a realm or domain provider. For more information, see External Authentication for Provisioned Hosts.
Table 9. Authentication Overview
Type Authentication User Groups
Kerberos or LDAP
Active Directory
Kerberos or LDAP
POSIX
LDAP
14.1. Using LDAP
Satellite supports LDAP authentication using one or multiple LDAP directories.
If you require Red Hat Satellite to use TLS to establish a secure LDAP connection (LDAPS), first obtain certificates used by the LDAP server you are connecting to and mark them as trusted on the base operating system of your Satellite Server as described below. If your LDAP server uses a certificate chain with intermediate certificate authorities, all of the root and intermediate certificates in the chain must be trusted, so ensure all certificates are obtained. If you do not require secure LDAP at this time, proceed to Configuring Red Hat Satellite to use LDAP.
Users cannot use both Red Hat Identity Management and LDAP as an authentication method. Once a user authenticates using one method, they cannot use the other method.
To change the authentication method for a user, you have to remove the automatically created user from Satellite.
For more information on using Red Hat Identity Management as an authentication method, see Using Red Hat Identity Management.
14.1.1. Configuring TLS for Secure LDAP
Use the Satellite CLI to configure TLS for secure LDAP (LDAPS).
  1. Obtain the Certificate from the LDAP Server.
    1. If you use Active Directory Certificate Services, export the Enterprise PKI CA Certificate using the Base-64 encoded X.509 format. See How to configure Active Directory authentication with TLS on Satellite for information on creating and exporting a CA certificate from an Active Directory server.
    2. Download the LDAP server certificate to a temporary location onto Satellite Server and remove it when finished.
      For example, /tmp/example.crt. The filename extensions .cer and .crt are only conventions and can refer to DER binary or PEM ASCII format certificates.
  2. Trust the Certificate from the LDAP Server.
    Satellite Server requires the CA certificates for LDAP authentication to be individual files in /etc/pki/tls/certs/ directory.
    1. Use the install command to install the imported certificate into the /etc/pki/tls/certs/ directory with the correct permissions:
      # install /tmp/example.crt /etc/pki/tls/certs/
    2. Enter the following command as root to trust the example.crt certificate obtained from the LDAP server:
      # ln -s example.crt /etc/pki/tls/certs/$(openssl \
      x509 -noout -hash -in \
      /etc/pki/tls/certs/example.crt).0
    3. Restart the httpd service:
      # systemctl restart httpd
14.1.2. Configuring Red Hat Satellite to use LDAP
In the Satellite web UI, configure Satellite to use LDAP.
Note that if you need single sign-on functionality with Kerberos on Satellite web UI, you should use Red Hat Identity Management and AD external authentication instead. For more information, see:
  1. Set the Network Information System (NIS) service boolean to true to prevent SELinux from stopping outgoing LDAP connections:
    # setsebool -P nis_enabled on
  2. In the Satellite web UI, navigate to Administer > Authentication Sources.
  3. Click Create LDAP Authentication Source.
  4. On the LDAP server tab, enter the LDAP server’s name, host name, port, and server type. The default port is 389, the default server type is POSIX (alternatively you can select FreeIPA or Active Directory depending on the type of authentication server). For TLS encrypted connections, select the LDAPS checkbox to enable encryption. The port should change to 636, which is the default for LDAPS.
  5. On the Account tab, enter the account information and domain name details. See Description of LDAP Settings for descriptions and examples.
  6. On the Attribute mappings tab, map LDAP attributes to Satellite attributes. You can map login name, first name, last name, email address, and photo attributes. See Example Settings for LDAP Connections for examples.
  7. On the Locations tab, select locations from the left table. Selected locations are assigned to users created from the LDAP authentication source, and available after their first login.
  8. On the Organizations tab, select organizations from the left table. Selected organizations are assigned to users created from the LDAP authentication source, and available after their first login.
  9. Click Submit.
  10. Configure new accounts for LDAP users:
    • If you did not select Automatically Create Accounts In Satellite checkbox, see Creating a User to create user accounts manually.
    • If you selected the Automatically Create Accounts In Satellite checkbox, LDAP users can now log in to Satellite using their LDAP accounts and passwords. After they log in for the first time, the Satellite administrator has to assign roles to them manually. See Assigning Roles to a User to assign user accounts appropriate roles in Satellite.
14.1.3. Description of LDAP Settings
Table 10. Account Tab Settings
Setting Description
Account
The user name of the LDAP account that has read access to the LDAP server. User name is not required if the server allows anonymous reading, otherwise use the full path to the user’s object. For example:
uid=$login,cn=users,cn=accounts,dc=example,dc=com
The $login variable stores the username entered on the login page as a literal string. The value is accessed when the variable is expanded.
The variable cannot be used with external user groups from an LDAP source because Satellite needs to retrieve the group list without the user logging in. Use either an anonymous, or dedicated service user.
Account password
The LDAP password for the user defined in the Account username field. This field can remain blank if the Account username is using the $login variable.
Base DN
The top level domain name of the LDAP directory.
Groups base DN
The top level domain name of the LDAP directory tree that contains groups.
LDAP filter
A filter to restrict LDAP queries.
If this checkbox is selected, Satellite creates user accounts for LDAP users when they log in to Satellite for the first time. After they log in for the first time, the Satellite administrator has to assign roles to them manually. See Assigning Roles to a User to assign user accounts appropriate roles in Satellite.
Usergroup Sync
If this option is selected, the user group membership of a user is automatically synchronized when the user logs in, which ensures the membership is always up to date. If this option is cleared, Satellite relies on a cron job to regularly synchronize group membership (every 30 minutes by default). For more information, see Configuring External User Groups.
14.1.4. Example Settings for LDAP Connections
Table 11. Example Settings for Active Directory, Free IPA or Red Hat Identity Management and POSIX LDAP Connections
Setting Active Directory FreeIPA or Red Hat Identity Management POSIX (OpenLDAP)
Account
DOMAIN\redhat
uid=redhat,cn=users, cn=accounts,dc=example, dc=com
uid=redhat,ou=users, dc=example,dc=com
Account password
P@ssword
Base DN
DC=example,DC=COM
dc=example,dc=com
dc=example,dc=com
Groups Base DN
CN=Users,DC=example,DC=com
cn=groups,cn=accounts, dc=example,dc=com
cn=employee,ou=userclass, dc=example,dc=com
Login name attribute
userPrincipalName
uid
uid
First name attribute
givenName
givenName
givenName
Last name attribute
sn
sn
sn
Email address attribute
mail
mail
mail
Photo attribute
thumbnailPhoto
userPrincipalName allows the use of whitespace in usernames. The login name attribute sAMAccountName (which is not listed in the table above) provides backwards compatibility with legacy Microsoft systems. sAMAccountName does not allow the use of whitespace in usernames.
14.1.5. Example LDAP Filters
As an administrator, you can create LDAP filters to restrict the access of specific users to Satellite.
Table 12. Example filters for allowing specific users to login
User Filter
User1
(distinguishedName=cn=User1,cn=Users,dc=domain,dc=example)
User1, User3
(memberOf=cn=Group1,cn=Users,dc=domain,dc=example)
User2, User3
(memberOf=cn=Group2,cn=Users,dc=domain,dc=example)
User1, User2, User3
(|(memberOf=cn=Group1,cn=Users,dc=domain,dc=example)(memberOf=cn=Group2,cn=Users,dc=domain,dc=example))
User1, User2, User3
(memberOf:1.2.840.113556.1.4.1941:=cn=Users,dc=domain,dc=example)
Group Users is a nested group that contains groups Group1 and Group2. If you want to filter all users from a nested group, you must add memberOf:1.2.840.113556.1.4.1941:= before the nested group name. See the last example in the table above.
LDAP directory structure
DC=Domain,DC=Example
   |----- CN=Users
         |----- CN=Group1
         |----- CN=Group2
         |----- CN=User1
         |----- CN=User2
         |----- CN=User3
LDAP group membership
Group Members
Group1
User1, User3
Group2
User2, User3
14.2. Using Red Hat Identity Management
This section shows how to integrate Satellite Server with a Red Hat Identity Management server and how to enable host-based access control.
You can attach Red Hat Identity Management as an external authentication source with no single sign-on support. For more information, see Using LDAP.
Prerequisite
  • The base operating system of Satellite Server must be enrolled in the Red Hat Identity Management domain by the Red Hat Identity Management administrator of your organization.
The examples in this chapter assume separation between Red Hat Identity Management and Satellite configuration. However, if you have administrator privileges for both servers, you can configure Red Hat Identity Management as described in Red Hat Enterprise Linux 8 Installing Identity Management Guide.
14.2.1. Configuring Red Hat Identity Management Authentication on Satellite Server
In the Satellite CLI, configure Red Hat Identity Management authentication by first creating a host entry on the Red Hat Identity Management server.
  1. On the Red Hat Identity Management server, to authenticate, enter the following command and enter your password when prompted:
    # kinit admin
  2. To verify that you have authenticated, enter the following command:
    # klist
  3. On the Red Hat Identity Management server, create a host entry for Satellite Server and generate a one-time password, for example:
    The generated one-time password must be used on the client to complete Red Hat Identity Management-enrollment.
    For more information on host configuration properties, see About Host Entry Configuration Properties in the Red Hat Enterprise Linux 7 Linux Domain Identity, Authentication, and Policy guide.
  4. Create an HTTP service for Satellite Server, for example:
    # ipa service-add HTTP/hostname
    For more information on managing services, see Managing Services in the Red Hat Enterprise Linux 7 Linux Domain Identity, Authentication, and Policy guide.
  5. On Satellite Server, install the IPA client:
    Warning
    This command might restart Satellite services during the installation of the package. For more information about installing and updating packages on Satellite, see Managing Packages on the Base Operating System of Satellite Server or Capsule Server.
    # satellite-maintain packages install ipa-client
  6. On Satellite Server, enter the following command as root to configure Red Hat Identity Management-enrollment:
    Replace OTP with the one-time password provided by the Red Hat Identity Management administrator.
  7. If Satellite Server is running on Red Hat Enterprise Linux 7, execute the following command:
    The installer is dependent on packages which, on Red Hat Enterprise Linux 7, are in the optional repository rhel-7-server-optional-rpms.
  8. Set foreman-ipa-authentication to true, using the following command:
    # satellite-installer --foreman-ipa-authentication=true
  9. Restart Satellite services:
External users can now log in to Satellite using their Red Hat Identity Management credentials. They can now choose to either log in to Satellite Server directly using their username and password or take advantage of the configured Kerberos single sign-on and obtain a ticket on their client machine and be logged in automatically. The two-factor authentication with one-time password (2FA OTP) is also supported. If the user in Red Hat Identity Management is configured for 2FA, and Satellite Server is running on Red Hat Enterprise Linux 7, this user can also authenticate to Satellite with an OTP.
14.2.2. Configuring Host-Based Authentication Control
HBAC rules define which machine within the domain a Red Hat Identity Management user is allowed to access. You can configure HBAC on the Red Hat Identity Management server to prevent selected users from accessing Satellite Server. With this approach, you can prevent Satellite from creating database entries for users that are not allowed to log in. For more information on HBAC, see Managing IdM Users, Groups, Hosts, and Access Control Rules Guide.
On the Red Hat Identity Management server, configure Host-Based Authentication Control (HBAC).
    # kinit admin
    # klist
  3. Create HBAC service and rule on the Red Hat Identity Management server and link them together. The following examples use the PAM service name satellite-prod. Execute the following commands on the Red Hat Identity Management server:
    # ipa hbacsvc-add satellite-prod
    # ipa hbacrule-add allow_satellite_prod
    # ipa hbacrule-add-service allow_satellite_prod --hbacsvcs=satellite-prod
  4. Add the user who is to have access to the service satellite-prod, and the hostname of Satellite Server:
    # ipa hbacrule-add-user allow_satellite_prod --user=username
    # ipa hbacrule-add-host allow_satellite_prod --hosts=satellite.example.com
    Alternatively, host groups and user groups can be added to the allowsatellite_prod_ rule.
  5. To check the status of the rule, execute:
    # ipa hbacrule-find satellite-prod
    # ipa hbactest --user=username --host=satellite.example.com --service=satellite-prod
  6. Ensure the allow_all rule is disabled on the Red Hat Identity Management server. For instructions on how to do so without disrupting other services see the How to configure HBAC rules in IdM article on the Red Hat Customer Portal.
  7. Configure the Red Hat Identity Management integration with Satellite Server as described in Configuring Red Hat Identity Management Authentication on Satellite Server. On Satellite Server, define the PAM service as root:
    # satellite-installer --foreman-pam-service=satellite-prod
14.3. Using Active Directory
This section shows how to use direct Active Directory (AD) as an external authentication source for Satellite Server.
You can attach Active Directory as an external authentication source with no single sign-on support. For more information, see Using LDAP. For an example configuration, see How to configure Active Directory authentication with TLS on Satellite.
Direct AD integration means that Satellite Server is joined directly to the AD domain where the identity is stored. The recommended setup consists of two steps:
14.3.1. GSS-Proxy
The traditional process of Kerberos authentication in Apache requires the Apache process to have read access to the keytab file. GSS-Proxy allows you to implement stricter privilege separation for the Apache server by removing access to the keytab file while preserving Kerberos authentication functionality. When using AD as an external authentication source for Satellite, it is recommended to implement GSS-proxy, because the keys in the keytab file are the same as the host keys.
Perform the following procedures on Red Hat Enterprise Linux that acts as a base operating system for your Satellite Server. For the examples in this section EXAMPLE.ORG is the Kerberos realm for the AD domain. By completing the procedures, users that belong to the EXAMPLE.ORG realm can log in to Satellite Server.
14.3.2. Enrolling Satellite Server with the AD Server
In the Satellite CLI, enroll Satellite Server with the Active Directory server.
Prerequisite
  • GSS-proxy and nfs-utils are installed.
    # satellite-maintain packages install gssproxy nfs-utils
  1. Install the required packages:
    # satellite-maintain packages install sssd adcli realmd ipa-python-compat krb5-workstation samba-common-tools
  2. Enroll Satellite Server with the AD server. You may need to have administrator permissions to perform the following command:
    # realm join -v EXAMPLE.ORG --membership-software=samba -U Administrator
14.3.3. Configuring Direct AD Integration with GSS-Proxy
In the Satellite CLI, configure the direct Active Directory integration with GSS-proxy.
Prerequisite
  1. Create the /etc/ipa/ directory and the default.conf file:
    # mkdir /etc/ipa
    # touch /etc/ipa/default.conf
  2. To the default.conf file, add the following content:
    [global]
    server = unused
    realm = EXAMPLE.ORG
  3. Create the /etc/net-keytab.conf file with the following content:
    [global]
    workgroup = EXAMPLE
    realm = EXAMPLE.ORG
    kerberos method = system keytab
    security = ads
  4. Determine the effective user ID of the Apache user:
    # id apache
  5. Create the /etc/gssproxy/00-http.conf file with the following content:
    [service/HTTP]
    mechs = krb5
    cred_store = keytab:/etc/httpd/conf/http.keytab
    cred_store = ccache:/var/lib/gssproxy/clients/krb5cc_%U
    euid = ID_of_Apache_User
  6. Create a keytab entry:
    # KRB5_KTNAME=FILE:/etc/httpd/conf/http.keytab net ads keytab add HTTP -U administrator -d3 -s /etc/net-keytab.conf
    # chown root.apache /etc/httpd/conf/http.keytab
    # chmod 640 /etc/httpd/conf/http.keytab
  7. Enable IPA authentication in Satellite:
  8. Start and enable the gssproxy service:
    # systemctl restart gssproxy.service
    # systemctl enable gssproxy.service
  9. To configure the Apache server to use the gssproxy service, create a systemd drop-in file and add the following content to it:
    # mkdir -p /etc/systemd/system/httpd.service.d/
    # vi /etc/systemd/system/httpd.service.d/gssproxy.conf
    [Service]
    Environment=GSS_USE_PROXY=1
  10. Apply changes to the service:
    # systemctl daemon-reload
  11. Start and enable the httpd service:
    # systemctl restart httpd.service
With direct AD integration, HBAC through Red Hat Identity Management is not available. As an alternative, you can use Group Policy Objects (GPO) that enable administrators to centrally manage policies in AD environments. To ensure correct GPO to PAM service mapping, add the following SSSD configuration to /etc/sssd/sssd.conf:
access_provider = ad
ad_gpo_access_control = enforcing
ad_gpo_map_service = +foreman
Here, foreman is the PAM service name. For more information on GPOs, see How SSSD interprets GPO access control rules in Integrating RHEL systems directly with Windows Active Directory.
Verify that SSO is working as expected.
  1. Retrieve the Kerberos ticket of the LDAP user, using the following command:
    # kinit ldapuser
  2. View the Kerberos ticket, using the following command:
    # klist
  3. View output from successful SSO-based authentication, using the following command:
    # curl -k -u : --negotiate https://satellite.example.com/users/extlogin
    <html><body>You are being <a href="https://satellite.example.com/users/4-ldapuserexample-com/edit">redirected</a>.</body></html>
14.3.4. Kerberos Configuration in Web Browsers
For information on configuring the Firefox browser see Configuring Firefox to Use Kerberos for Single Sign-On in the Red Hat Enterprise Linux System-Level Authentication guide.
If you use the Internet Explorer browser, add Satellite Server to the list of Local Intranet or Trusted sites, and turn on the Enable Integrated Windows Authentication setting. See the Internet Explorer documentation for details.
14.3.5. Active Directory with Cross-Forest Trust
Kerberos can create cross-forest trust that defines a relationship between two otherwise separate domain forests. A domain forest is a hierarchical structure of domains; both AD and Red Hat Identity Management constitute a forest. With a trust relationship enabled between AD and Red Hat Identity Management, users of AD can access Linux hosts and services using a single set of credentials. For more information on cross-forest trusts, see Creating Cross-forest Trusts with Active Directory and Identity Management in the Red Hat Enterprise Linux Windows Integration guide.
From the Satellite point of view, the configuration process is the same as integration with Red Hat Identity Management server without cross-forest trust configured. Satellite Server has to be enrolled in the IdM domain and integrated as described in Using Red Hat Identity Management.
14.3.6. Configuring the Red Hat Identity Management Server to Use Cross-Forest Trust
On the Red Hat Identity Management server, configure the server to use cross-forest trust.
  1. Enable HBAC:
    1. Create an external group and add the AD group to it.
    2. Add the new external group to a POSIX group.
    3. Use the POSIX group in a HBAC rule.
  2. Configure sssd to transfer additional attributes of AD users.
    • Add the AD user attributes to the nss and domain sections in /etc/sssd/sssd.conf. For example:
      [nss]
      user_attributes=+mail, +sn, +givenname
      [domain/EXAMPLE.com]
      krb5_store_password_if_offline = True
      ldap_user_extra_attrs=email:mail, lastname:sn, firstname:givenname
      [ifp]
      allowed_uids = ipaapi, root
      user_attributes=+email, +firstname, +lastname
    • Verify the AD attributes value.
      # dbus-send --print-reply --system --dest=org.freedesktop.sssd.infopipe /org/freedesktop/sssd/infopipe org.freedesktop.sssd.infopipe.GetUserAttr string:ad-user@ad-domain array:string:email,firstname,lastname
14.4. Configuring External User Groups
Satellite does not associate external users with their user group automatically. You must create a user group with the same name as in the external source on Satellite. Members of the external user group then automatically become members of the Satellite user group and receive the associated permissions.
  • If you use an LDAP server, configure Satellite to use LDAP authentication. For more information see Using LDAP.
    When using external user groups from an LDAP source, you cannot use the $login variable as a substitute for the account user name. You must use either an anonymous or dedicated service user.
  • If you use a Red Hat Identity Management or AD server, configure Satellite to use Red Hat Identity Management or AD authentication. For more information, see Configuring External Authentication.
  • Ensure that at least one external user authenticates for the first time.
  • Retain a copy of the external group names you want to use. To find the group membership of external users, enter the following command:
    # id username
  1. In the Satellite web UI, navigate to Administer > User Groups, and click Create User Group.
  2. Specify the name of the new user group. Do not select any users to avoid adding users automatically when you refresh the external user group.
  3. Click the Roles tab and select the roles you want to assign to the user group. Alternatively, select the Administrator checkbox to assign all available permissions.
  4. Click the External groups tab, then click Add external user group, and select an authentication source from the Auth source drop-down menu.
  5. Click Submit.
14.5. Refreshing External User Groups for LDAP
  1. In the Satellite web UI, navigate to Administer > Usergroups and select a user group.
  2. On the External Groups tab, click Refresh to the right of the required user group.
CLI procedure
  • Enter the following command:
14.6. Refreshing External User Groups for Red Hat Identity Management or AD
External user groups based on Red Hat Identity Management or AD are refreshed only when a group member logs in to Satellite. It is not possible to alter user membership of external user groups in the Satellite web UI, such changes are overwritten on the next group refresh.
14.7. External Authentication for Provisioned Hosts
Use this section to configure Satellite Server or Capsule Server for Red Hat Identity Management realm support, then add hosts to the Red Hat Identity Management realm group.
  • Satellite Server that is registered to the Content Delivery Network or an external Capsule Server that is registered to Satellite Server.
  • A deployed realm or domain provider such as Red Hat Identity Management.
To install and configure Red Hat Identity Management packages on Satellite Server or Capsule Server:
To use Red Hat Identity Management for provisioned hosts, complete the following steps to install and configure Red Hat Identity Management packages on Satellite Server or Capsule Server:
  1. Install the ipa-client package on Satellite Server or Capsule Server:
  2. Configure the server as a Red Hat Identity Management client:
  3. Create a realm proxy user, realm-capsule, and the relevant roles in Red Hat Identity Management:
    # foreman-prepare-realm admin realm-capsule
    Note the principal name that returns and your Red Hat Identity Management server configuration details because you require them for the following procedure.
To configure Satellite Server or Capsule Server for Red Hat Identity Management Realm Support:
Complete the following procedure on Satellite and every Capsule that you want to use:
  1. Copy the /root/freeipa.keytab file to any Capsule Server that you want to include in the same principal and realm:
    # scp /root/freeipa.keytab root@capsule.example.com:/etc/foreman-proxy/freeipa.keytab
  2. Move the /root/freeipa.keytab file to the /etc/foreman-proxy directory and set the ownership settings to the foreman-proxy user:
    # mv /root/freeipa.keytab /etc/foreman-proxy
    # chown foreman-proxy:foreman-proxy /etc/foreman-proxy/freeipa.keytab
  3. Enter the following command on all Capsules that you want to include in the realm. If you use the integrated Capsule on Satellite, enter this command on Satellite Server:
    # satellite-installer --foreman-proxy-realm true \
    --foreman-proxy-realm-keytab /etc/foreman-proxy/freeipa.keytab \
    --foreman-proxy-realm-principal realm-capsule@EXAMPLE.COM \
    --foreman-proxy-realm-provider freeipa
    You can also use these options when you first configure the Satellite Server.
  4. Ensure that the most updated versions of the ca-certificates package is installed and trust the Red Hat Identity Management Certificate Authority:
    # cp /etc/ipa/ca.crt /etc/pki/ca-trust/source/anchors/ipa.crt
    # update-ca-trust enable
    # update-ca-trust
  5. Optional: If you configure Red Hat Identity Management on an existing Satellite Server or Capsule Server, complete the following steps to ensure that the configuration changes take effect:
    1. Restart the foreman-proxy service:
    2. In the Satellite web UI, navigate to Infrastructure > Capsules.
    3. Locate the Capsule you have configured for Red Hat Identity Management and from the list in the Actions column, select Refresh.
To create a realm for the Red Hat Identity Management-enabled Capsule
After you configure your integrated or external Capsule with Red Hat Identity Management, you must create a realm and add the Red Hat Identity Management-configured Capsule to the realm.
  1. In the Satellite web UI, navigate to Infrastructure > Realms and click Create Realm.
  2. In the Name field, enter a name for the realm.
  3. From the Realm Type list, select the type of realm.
  4. From the Realm Capsule list, select Capsule Server where you have configured Red Hat Identity Management.
  5. Click the Locations tab and from the Locations list, select the location where you want to add the new realm.
  6. Click the Organizations tab and from the Organizations list, select the organization where you want to add the new realm.
  7. Click Submit.
Updating Host Groups with Realm Information
  1. In the Satellite web UI, navigate to Configure > Host Groups, select the host group that you want to update, and click the Network tab.
  2. From the Realm list, select the realm you create as part of this procedure, and then click Submit.
Adding Hosts to a Red Hat Identity Management Host Group
Red Hat Identity Management supports the ability to set up automatic membership rules based on a system’s attributes. Red Hat Satellite’s realm feature provides administrators with the ability to map the Red Hat Satellite host groups to the Red Hat Identity Management parameter userclass which allow administrators to configure automembership.
When nested host groups are used, they are sent to the Red Hat Identity Management server as they are displayed in the Red Hat Satellite User Interface. For example, "Parent/Child/Child".
Satellite Server or Capsule Server sends updates to the Red Hat Identity Management server, however automembership rules are only applied at initial registration.
To Add Hosts to a Red Hat Identity Management Host Group:
  1. On the Red Hat Identity Management server, create a host group:
  2. Create an automembership rule:
    # ipa automember-add --type=hostgroup hostgroup_name automember_rule
    • automember-add flags the group as an automember group.
    • --type=hostgroup identifies that the target group is a host group, not a user group.
    • automember_rule adds the name you want to identify the automember rule by.
  3. Define an automembership condition based on the userclass attribute:
    # ipa automember-add-condition --key=userclass --type=hostgroup --inclusive-regex=^webserver hostgroup_name
    Added condition(s) to "hostgroup_name"
    Automember Rule: automember_rule
    Inclusive Regex: userclass=^webserver
    Number of conditions added 1
    • automember-add-condition adds regular expression conditions to identify group members.
    • --key=userclass specifies the key attribute as userclass.
    • --inclusive-regex= ^webserver identifies matching values with a regular expression pattern.
    • hostgroup_name – identifies the target host group’s name.
When a system is added to Satellite Server’s hostgroup_name host group, it is added automatically to the Red Hat Identity Management server’s "hostgroup_name" host group. Red Hat Identity Management host groups allow for Host-Based Access Controls (HBAC), sudo policies and other Red Hat Identity Management functions.
14.8. Configuring Satellite with Red Hat Single Sign-On Authentication
Use this section to configure Satellite to use Red Hat Single Sign-On as an OpenID provider for external authentication.
14.8.1. Prerequisites for Configuring Satellite with Red Hat Single Sign-On Authentication
Before configuring Satellite with Red Hat Single Sign-On external authentication, ensure that you meet the following requirements:
  • A working installation of Red Hat Single Sign-On server that uses HTTPS instead of HTTP.
  • A Red Hat Single Sign-On account with admin privileges.
  • A realm for Satellite user accounts created in Red Hat Single Sign-On.
  • If the certificates or the CA are self-signed, ensure that they are added to the end-user certificate trust store.
  • Users imported or added to Red Hat Single Sign-On.
    If you have an existing user database configured such as LDAP or Kerberos, you can import users from it by configuring user federation. For more information, see User Storage Federation in the Red Hat Single Sign-On Server Administration Guide.
    If you do not have an existing user database configured, you can manually create users in Red Hat Single Sign-On. For more information, see Creating New Users in the Red Hat Single Sign-On Server Administration Guide.
14.8.2. Registering Satellite as a Red Hat Single Sign-On Client
Use this procedure to register Satellite to Red Hat Single Sign-On as a client and configure Satellite to use Red Hat Single Sign-On as an authentication source.
You can configure Satellite and Red Hat Single Sign-On with two different authentication methods:
  1. Users authenticate to Satellite using the Satellite web UI.
  2. Users authenticate to Satellite using the Satellite CLI.
You must decide on how you want your users to authenticate in advance because both methods require different Satellite clients to be registered to Red Hat Single Sign-On and configured. The steps to register and configure Satellite client in Red Hat Single Sign-On are distinguished within the procedure.
You can also register two different Satellite clients to Red Hat Single Sign-On if you want to use both authentication methods and configure both clients accordingly.
  1. On the Satellite server, install the following packages:
    # satellite-maintain packages install mod_auth_openidc keycloak-httpd-client-install
  2. Register Satellite to Red Hat Single Sign-On as a client. Note that you the registration process for logging in using the web UI and the CLI are different. You can register two clients Satellite clients to Red Hat Single Sign-On to be able to log in to Satellite from the web UI and the CLI.
    • If you want you users to authenticate to Satellite using the web UI, create a client as follows:
      # keycloak-httpd-client-install --app-name foreman-openidc \
      --keycloak-server-url "https://RHSSO.example.com" \
      --keycloak-admin-username "admin" \
      --keycloak-realm "Satellite_Realm" \
      --keycloak-admin-realm master \
      --keycloak-auth-role root-admin \
      -t openidc -l /users/extlogin --force
      Enter the password for the administer account when prompted. This command creates a client for Satellite in Red Hat Single Sign-On.
      Then, configure Satellite to use Red Hat Single Sign-On as an authentication source:
      # satellite-installer --foreman-keycloak true \
      --foreman-keycloak-app-name "foreman-openidc" \
      --foreman-keycloak-realm "Satellite_Realm"
    • If you want your users to authenticate to Satellite using the CLI, create a client as follows:
      # keycloak-httpd-client-install --app-name hammer-openidc \
14.8.3. Configuring the Satellite Client in Red Hat Single Sign-On
Use this procedure to configure the Satellite client in the Red Hat Single Sign-On web UI and create group and audience mappers for the Satellite client.
  1. In the Red Hat Single Sign-On web UI, navigate to Clients and click the Satellite client.
  2. Configure access type:
    • If you want your users to authenticate to Satellite using the Satellite web UI, from the Access Type list, select confidential.
    • If you want your users to authenticate to Satellite using the CLI, from the Access Type list, select public.
  3. In the Valid redirect URI fields, add a valid redirect URI.
    • If you want your users to authenticate to Satellite using the Satellite web UI, in the blank field below the existing URI, enter a URI in the form https://satellite.example.com/users/extlogin. Note that you must add the string /users/extlogin after the Satellite FQDN.
      After completing this step, the Satellite client for logging in using the Satellite web UI must have the following Valid Redirect URIs:
      https://satellite.example.com/users/extlogin/redirect_uri
    • If you want your users to authenticate to Satellite using the CLI, in the blank field below the existing URI, enter urn:ietf:wg:oauth:2.0:oob.
      After completing this step, the Satellite client for logging in using the CLI must have the following Valid Redirect URIs:
  4. Click Save.
  5. Click the Mappers tab and click Create to add an audience mapper.
  6. In the Name field, enter a name for the audience mapper.
  7. From the Mapper Type list, select Audience.
  8. From the Included Client Audience list, select the Satellite client.
  9. Click Save.
  10. Click Create to add a group mapper so that you can specify authorization in Satellite based on group membership.
  11. In the Name field, enter a name for the group mapper.
  12. From the Mapper Type list, select Group Membership.
  13. In the Token Claim Name field, enter groups.
  14. Set the Full group path setting to OFF.
  15. Click Save.
14.8.4. Configuring Satellite Settings for Red Hat Single Sign-On Authentication
Use this section to configure Satellite for Red Hat Single Sign-On authentication using the Satellite web UI or the CLI.
Configuring Satellite Settings for Red Hat Single Sign-On Authentication Using the Web UI
Use this procedure to configure Satellite settings for Red Hat Single Sign-On authentication using the Satellite web UI.
Note that you can navigate to the following URL within your realm to obtain values to configure Satellite settings: https://RHSSO.example.com/auth/realms/Satellite_Realm/.well-known/openid-configuration
Prerequisite
  • Ensure that the Access Type setting in the Satellite client in the Red Hat Single Sign-On web UI is set to confidential
  1. In the Satellite web UI, navigate to Administer > Settings, and click the Authentication tab.
  2. Locate the Authorize login delegation row, and in the Value column, set the value to Yes.
  3. Locate the Authorize login delegation auth source user autocreate row, and in the Value column, set the value to External.
  4. Locate the Login delegation logout URL row, and in the Value column, set the value to https://satellite.example.com/users/extlogout.
  5. Locate the OIDC Algorithm row, and in the Value column, set the algorithm for encoding on Red Hat Single Sign-On to RS256.
  6. Locate the OIDC Audience row, and in the Value column, set the value to the client ID for Red Hat Single Sign-On.
  7. Locate the OIDC Issuer row, and in the Value column, set the value to https://RHSSO.example.com/auth/realms/Satellite_Realm.
  8. Locate the OIDC JWKs URL row, and in the Value column, set the value to https://RHSSO.example.com/auth/realms/Satellite_Realm/protocol/openid-connect/certs.
  9. In the Satellite web UI, navigate to Administer > Authentication Sources, click the vertical ellipsis on the External card, and select Edit.
  10. Click the Locations tab and add locations that can use the Red Hat Single Sign-On authentication source.
  11. Click the Organizations tab and add organizations that can use the Red Hat Single Sign-On authentication source.
  12. Click Submit.
Configuring Satellite Settings for Red Hat Single Sign-On Authentication Using the CLI
Use this procedure to configure Satellite settings for Red Hat Single Sign-On authentication using the Satellite CLI.
Prerequisite
  • Ensure that the Access Type setting in the Satellite client in the Red Hat Single Sign-On web UI is set to public
  1. On Satellite, set the login delegation to true so that users can authenticate using the Open IDC protocol:
    # hammer settings set --name authorize_login_delegation --value true
  2. Set the login delegation logout URL:
    # hammer settings set --name login_delegation_logout_url \
    --value https://satellite.example.com/users/extlogout
  3. Set the algorithm for encoding on Red Hat Single Sign-On, for example, RS256:
    # hammer settings set --name oidc_algorithm --value 'RS256'
  4. Open the RHSSO.example.com/auth/realms/RHSSO_REALM/.well-known/openid-configuration URL and note the values to populate the options in the following steps.
  5. Add the value for the Hammer client in the Open IDC audience:
    # hammer settings set --name oidc_audience \
    --value "['satellite.example.com-hammer-openidc']"
    If you register several Red Hat Single Sign-On clients to Satellite, ensure that you append all audiences in the array. For example:
    --value "['satellite.example.com-foreman-openidc', 'satellite.example.com-hammer-openidc']"
  6. Set the value for the Open IDC issuer:
    # hammer settings set --name oidc_issuer \
    --value "RHSSO.example.com/auth/realms/RHSSO_Realm"
  7. Set the value for Open IDC Java Web Token (JWT):
    # hammer settings set --name oidc_jwks_url \
    --value "RHSSO.example.com/auth/realms/RHSSO_Realm/protocol/openid-connect/certs"
  8. Retrieve the ID of the Red Hat Single Sign-On authentication source:
  9. Set the location and organization:
    # hammer auth-source external update --id Authentication Source ID \
    --location-ids Location ID --organization-ids Organization ID
14.8.5. Logging in to the Satellite web UI Using Red Hat Single Sign-On
Use this procedure to log in to the Satellite web UI using Red Hat Single Sign-On.
  • In your browser, log in to Satellite and enter your credentials.
14.8.6. Logging in to the Satellite CLI Using Red Hat Single Sign-On
Use this procedure to authenticate to the Satellite CLI using the code grant type.
  1. To authenticate to the Satellite CLI using the code grant type, enter the following command:
    # hammer auth login oauth \
    --two-factor \
    --oidc-token-endpoint 'https://RHSSO.example.com/auth/realms/ssl-realm/protocol/openid-connect/token' \
    --oidc-authorization-endpoint 'https://RHSSO.example.com/auth' \
    --oidc-client-id 'satellite.example.com-foreman-openidc' \
    --oidc-redirect-uri urn:ietf:wg:oauth:2.0:oob
  2. To retrieve the success code, navigate to the URL that the command returns and provide the required information.
  3. Copy the success code that the web UI returns.
  4. In the command prompt of hammer auth login oauth, enter the success code to authenticate to the Satellite CLI.
14.8.7. Configuring Group Mapping for Red Hat Single Sign-On Authentication
Optionally, to implement the Role Based Access Control (RBAC), create a group in Satellite, assign a role to this group, and then map an Active Directory group to the Satellite group. As a result, anyone in the given group in Red Hat Single Sign-On are logged in under the corresponding Satellite group. This example configures users of the Satellite-admin user group in the Active Directory to authenticate as users with administrator privileges on Satellite.
  1. In the Satellite web UI, navigate to Administer > User Groups, and click the Create User Group button.
  2. In the Name field, enter a name for the user group. The name should not be the same as in the Active Directory.
  3. Do not add users and user groups to the right-hand columns. Click the Roles tab.
  4. Select the Administer checkbox.
  5. Click the External Groups tab.
  6. Click Add external user group.
  7. In the Name field, enter the name of the Active Directory group.
  8. From the list, select EXTERNAL.
14.9. Configuring Red Hat Single Sign-On Authentication with TOTP
Use this section to configure Satellite to use Red Hat Single Sign-On as an OpenID provider for external authentication with TOTP cards.
14.9.1. Prerequisites for Configuring Satellite with Red Hat Single Sign-On Authentication
14.9.2. Registering Satellite as a Red Hat Single Sign-On Client
14.9.3. Configuring the Satellite Client in Red Hat Single Sign-On
  4. Click Save.
  9. Click Save.
  15. Click Save.
14.9.4. Configuring Satellite Settings for Red Hat Single Sign-On Authentication
Prerequisite
  12. Click Submit.
Prerequisite
14.9.5. Configuring Satellite with Red Hat Single Sign-On for TOTP Authentication
Use this procedure to configure Satellite to use Red Hat Single Sign-On as an OpenID provider for external authentication with Time-based One-time Password (TOTP).
  1. In the Red Hat Single Sign-On web UI, navigate to the Satellite realm.
  2. Navigate to Authentication, and click the OTP Policy tab.
  3. Ensure that the Supported Applications field includes FreeOTP or Google Authenticator.
  4. Configure the OTP settings to suit your requirements.
  5. Optional: If you want to use TOTP authentication as a default authentication method for all users, click the Flows tab, and to the right of the OTP Form setting, select REQUIRED.
  6. Click the Required Actions tab.
  7. To the right of the Configure OTP row, select the Default Action checkbox.
14.9.6. Logging in to the Satellite web UI Using Red Hat Single Sign-On TOTP Authentication
Use this procedure to log in to the Satellite web UI using Red Hat Single Sign-On TOTP authentication.
  1. Log in to Satellite, Satellite redirects you to the Red Hat Single Sign-On login screen.
  2. Enter your username and password, and click Log In.
  3. The first attempt to log in, Red Hat Single Sign-On requests you to configure your client by scanning the barcode and entering the pin displayed.
  4. After you configure your client and enter a valid PIN, Red Hat Single Sign-On redirects you to Satellite and logs you in.
14.9.7. Logging in to the Satellite CLI Using Red Hat Single Sign-On
    --two-factor \
14.9.8. Configuring Group Mapping for Red Hat Single Sign-On Authentication
14.10. Disabling Red Hat Single Sign-On Authentication
If you want to disable Red Hat Single Sign-On authentication in Satellite, complete this procedure.
  • Enter the following command to disable Red Hat Single Sign-On Authentication:
    # satellite-installer --reset-foreman-keycloak
15. Monitoring Resources
The following chapter details how to configure monitoring and reporting for managed systems. This includes host configuration, content views, compliance, subscriptions, registered hosts, promotions and synchronization.
15.1. Using the Red Hat Satellite Content Dashboard
The Red Hat Satellite content dashboard contains various widgets which provide an overview of the host configuration, Content Views, compliance reports, subscriptions and hosts currently registered, promotions and synchronization, and a list of the latest notifications.
In the Satellite web UI, navigate to Monitor > Dashboard to access the content dashboard. The dashboard can be rearranged by clicking on a widget and dragging it to a different position. The following widgets are available:
Host Configuration Status
Table 13. Host Configuration States
Icon State Description
host state config okay
host state config error
Hosts in error state
host state config report
host state config pending
host state config outofsync
Out of sync hosts
host state config noreport
Hosts with no reports
host state config noalert
Hosts with alerts disabled
Host Configuration Chart
Latest Events
New Hosts
Task Status
Latest Warning/Error Tasks
Discovered Hosts
Latest Errata
A list of all errata available for hosts registered to Satellite.
Content Views
A list of all Content Views in Satellite and their publish status.
Sync Overview
An overview of all products or repositories enabled in Satellite and their synchronization status. All products that are in the queue for synchronization, are unsynchronized or have been previously synchronized are listed in this section.
Host Subscription Status
An overview of the subscriptions currently consumed by the hosts registered to Satellite. A subscription is a purchased certificate that unlocks access to software, upgrades, and security fixes for hosts. The following table shows the possible states of subscriptions.
Table 14. Host Subscription States
host state sub invalid
Invalid
host state sub partial
Partial
host state sub valid
Valid
Subscription Status
Host Collections
A list of all host collections in Satellite and their status, including the number of content hosts in each host collection.
Virt-who Configuration Status
Table 15. Virt-who Configuration States
State Description
No Reports
No report has been received because either an error occurred during the virt-who configuration deployment, or the configuration has not been deployed yet, or virt-who cannot connect to Satellite during the scheduled interval.
No Change
OK
Total Configurations
Latest Compliance Reports
Compliance Reports Breakdown
Red Hat Insights Actions
Red Hat Insights is a tool embedded in Satellite that checks the environment and suggests actions you can take. The actions are divided into 4 categories: Availability, Stability, Performance, and Security.
Red Hat Insights Risk Summary
It is not possible to change the date format displayed in the Satellite web UI.
15.1.1. Managing Tasks
Red Hat Satellite keeps a complete log of all planned or performed tasks, such as repositories synchronised, errata applied, and Content Views published. To review the log, navigate to Monitor > Tasks.
To Adjust Timeout Settings:
  5. Click Save.
15.2. Configuring RSS Notifications
To view Satellite event notification alerts, click the Notifications icon in the upper right of the screen.
By default, the Notifications area displays RSS feed events published in the Red Hat Satellite Blog.
You can configure the RSS feed notifications by changing the URL feed. The supported feed format is RSS 2.0 and Atom. For an example of the RSS 2.0 feed structure, see the Red Hat Satellite Blog feed. For an example of the Atom feed structure, see the Foreman blog feed.
  1. In the Satellite web UI, navigate to Administer > Settings and select the Notifications tab.
15.3. Monitoring Satellite Server
From the About page in Satellite web UI, you can find an overview of the following:
  • System Status, including Capsules, Available Providers, Compute Resources, and Plug-ins
  • Support Information
  • System Information
  • Backend System Status
  • Installed Packages
  • In the upper right corner of Satellite web UI, click Administer > About.
After Pulp failure, the status of Pulp might show OK instead of Error for up to 10 minutes due to synchronization delay.
15.4. Monitoring Capsule Server
The following section shows how to use the Satellite web UI to find Capsule information valuable for maintenance and troubleshooting.
15.4.1. Viewing General Capsule Information
In the Satellite web UI, navigate to Infrastructure > Capsules to view a table of Capsule Servers registered to Satellite Server. The information contained in the table answers the following questions:
Is Capsule Server running?
This is indicated by a green icon in the Status column. A red icon indicates an inactive Capsule, use the service foreman-proxy restart command on Capsule Server to activate it.
What services are enabled on Capsule Server?
In the Features column you can verify if Capsule for example provides a DHCP service or acts as a Pulp mirror. Capsule features can be enabled during installation or configured in addition. For more information, see Installing Capsule Server.
What organizations and locations is Capsule Server assigned to?
A Capsule Server can be assigned to multiple organizations and locations, but only Capsules belonging to the currently selected organization are displayed. To list all Capsules, select Any Organization from the context menu in the top left corner.
After changing the Capsule configuration, select Refresh from the drop-down menu in the Actions column to ensure the Capsule table is up to date.
Click the Capsule name to view further details. At the Overview tab, you can find the same information as in the Capsule table. In addition, you can answer to the following questions:
Which hosts are managed by Capsule Server?
How much storage space is available on Capsule Server?
The amount of storage space occupied by the Pulp content in /var/lib/pulp is displayed. Also the remaining storage space available on the Capsule can be ascertained.
15.4.2. Monitoring Services
In the Satellite web UI, navigate to Infrastructure > Capsules and click the name of the selected Capsule. At the Services tab, you can find basic information on Capsule services, such as the list of DNS domains, or the number of Pulp workers. The appearance of the page depends on what services are enabled on Capsule Server. Services providing more detailed status information can have dedicated tabs at the Capsule page. For more information, see Monitoring Puppet.
15.4.3. Monitoring Puppet
In the Satellite web UI, navigate to Infrastructure > Capsules and click the name of the selected Capsule. At the Puppet tab you can find the following:
  • A table of CA certificates associated with the Capsule at the Certificates sub-tab. Here you can inspect the certificate expiry data, or cancel the certificate by clicking Revoke.
The Puppet and Puppet CA tabs are available only if you have Puppet enabled in your Satellite. For more information, see Enabling Puppet Integration with Satellite in Managing Configurations Using Puppet Integration in Red Hat Satellite.
16. Using Webhooks
A webhook is a way for a web page or web application to provide other applications with information in real time. Webhooks are only triggered after an event occurs. The request usually contains details of the event. An event triggers callbacks, such as sending an e-mail confirming a host has been provisioned. Webhooks enable you to define a call to an external API based on Satellite internal event using a fire-and-forget message exchange pattern. The application sending the request does not wait for the response, or ignores it.
The typical use case for webhooks in Satellite is making a call to a monitoring system when a host is created or deleted.
Webhooks are useful where the action you want to perform in the external system can be achieved through its API. Where it is necessary to run additional commands or edit files, the shellhooks plugin for Capsules is available. The shellhooks plugin enables you to define a shell script on the Capsule that can be executed through the API.
16.1. Migrating to Webhooks
16.2. Installing Webhooks
Use the following procedure to install webhooks. After installing webhooks, you can configure Satellite Server to send webhook requests.
    # satellite-installer --enable-foreman-plugin-webhooks
  • Optional: you can install the CLI plugin using the following command:
    # satellite-installer --enable-foreman-cli-webhooks
16.3. Creating a Webhook Template
Webhook templates are used to generate the body of HTTP request to a configured target when a webhook is triggered. Use the following procedure to create a webhook template in the Satellite web UI.
  1. In the Satellite web UI, navigate to Administer > Webhook Templates.
    A webhook HTTP payload must be created using Satellite template syntax. The webhook template can use a special variable called @object that can represent the main object of the event. @object can be missing in case of certain events. You can determine what data are actually available with the @payload variable.
    For more information, see Template Writing Reference in Managing Hosts and for available template macros and methods, visit /templates_doc on Satellite Server.
  7. Click Submit.
16.4. Creating a Webhook
You can customize events, payloads, HTTP authentication, content type, and headers through the Satellite web UI.
Use the following procedure to create a webhook in the Satellite web UI.
  1. In the Satellite web UI, navigate to Administer > Webhooks.
  2. Click Create new.
  6. Click Template to select a template. Webhook templates are used to generate the body of the HTTP request to Satellite Server when a webhook is triggered.
  7. Enter an HTTP method.
  9. Click the Credentials tab.
  11. Optional: Uncheck Verify SSL if you do not want to verify the server certificate against the system certificate store or Satellite CA.
When configuring webhooks with endpoints with non-standard HTTP or HTTPS ports, an SELinux port must be assigned, see Configuring SELinux to Ensure Access to Satellite on Custom Ports in Installing Satellite Server in a Connected Network Environment.
16.5. Available Webhook Events
The following table contains a list of webhook events that are available from the Satellite web UI. Action events trigger webhooks only on success, so if an action fails, a webhook is not triggered.
A content view was successfully promoted.
Actions Remote Execution Run Host Job Succeeded
Run OpenSCAP scan.
Actions Remote Execution Run Host Job Ansible Run Insights Plan Succeeded
Runs a given maintenance plan from Red Hat Access Insights given an ID.
Perform a single Puppet run.
Build Entered
Build Exited
Common database operations on a content view.
Domain
Host
Hostgroup
Model
Status Changed
Subnet
Template Render Performed
Template
User
16.6. Shellhooks
With webhooks, you can only map one Satellite event to one API call. For advanced integrations, where a single shell script can contain multiple commands, you can install a Capsule shellhooks plugin that exposes executables using a REST HTTP API.
You can then configure a webhook to reach out to a Capsule API to run a predefined shellhook. A shellhook is an executable script that can be written in any language as long as it can be executed. The shellhook can for example contain commands or edit files.
The HTTP method must be POST. An example URL would be: https://capsule.example.com:9090/shellhook/My_Script.
You must enable Capsule Authorization for each webhook connected to a shellhook to enable it to authorize a call.
Standard output and standard error output are redirected to the Capsule logs as messages with debug or warning levels respectively.
16.7. Installing the Shellhooks Plugin
Optionally, you can install and enable the shellhooks plugin on each Capsule used for shellhooks, using the following command:
# satellite-installer --enable-foreman-proxy-plugin-shellhooks
16.8. Passing Arguments to Shellhook Script Using Webhooks
      "X-Shellhook-Arg-1": "VALUE",
      "X-Shellhook-Arg-2": "VALUE"
Example
16.9. Passing Arguments to Shellhook Script Using Curl
    "X-Shellhook-Arg-1: VALUE"
    "X-Shellhook-Arg-2: VALUE"
Example
-H "X-Shellhook-Arg-2: My Content View" \
--data "" https://capsule.example.com:9090/shellhook/My_Script
16.10. Creating a Shellhook to Print Arguments
Prerequisite
  1. Modify the /var/lib/foreman-proxy/shellhooks/print_args script to print arguments to standard error output so you can see them in the Capsule logs:
    #!/bin/sh
    echo "$@" >&2
  2. In the Satellite web UI, navigate to Administer > Webhooks.
  3. Click Create new.
  6. In the Target URL field, enter the URL of your Capsule Server followed by :9090/shellhook/print_args:
    https://capsule.example.com:9090/shellhook/print_args
  8. On the Credentials tab, check Capsule Authorization.
        "X-Shellhook-Arg-1": "Hello",
        "X-Shellhook-Arg-2": "World!"
  10. Click Submit. You now have successfully created a shellhook that prints "Hello World!" to Capsule logs every time you a remote execution job succeeds.
  1. Run a remote execution job on any host. You can use time as a command. For more information, see Executing a Remote Job in Managing Hosts.
  2. Verify that the shellhook script was triggered and printed "Hello World!" to Capsule Server logs:
    [W] [3520] Hello World!
17. Searching and Bookmarking
Satellite features powerful search functionality on most pages of the Satellite web UI. It enables you to search all kinds of resources that Satellite manages. Searches accept both free text and syntax-based queries, which can be built using extensive input prediction. Search queries can be saved as bookmarks for future reuse.
17.1. Building Search Queries
17.1.1. Query Syntax
parameter operator value
17.1.2. Query Operators
Table 16. Comparison Operators Accepted by Search
EQUALS
hostgroup = RHEL7
NOT EQUALS
LIKE
hostgroup ~ rhel%
NOT LIKE
GREATER THAN
registered_at <= Yesterday
LESS THAN
IN
release_version !^ 7
NOT IN
HAS or set?
NOT HAS or null?
Table 17. Logical Operators Accepted by Search
and
<whitespace>
or
not
17.1.3. Query Values
Text Values
Examples:
hostgroup = "Web servers"
hostgroup = Web servers
Temporal Values
  • "10 January 2017"
  • "10 Jan 2017"
  • 10-January-2017
  • 10/January/2017
  • "January 10, 2017"
Warning
17.2. Using Free Text Search
17.3. Managing Bookmarks
17.3.1. Creating Bookmarks
  1. In the Satellite web UI, navigate to the page where you want to create a bookmark.
  7. Click Submit.
17.3.2. Deleting Bookmarks
  1. In the Satellite web UI, navigate to Administer > Bookmarks.
This section contains information about settings that you can edit in the Satellite web UI by navigating to Administer > Settings.
A.1. General Settings
Administrator email address
Satellite URL
URL where your Satellite instance is reachable. See also Provisioning > Unattended URL.
Entries per page
20
Number of records shown per page in Satellite
Fix DB cache
Satellite maintains a cache of permissions and roles. When set to Yes, Satellite recreates this cache on the next restart.
DB pending seed
Capsule request timeout
60
Open and read timeout for HTTP requests from Satellite to Capsule (in seconds).
Login page footer text
Show host power status
Show power status on the host index page. This feature calls to compute resource providers which may lead to decreased performance on the host listing page.
HTTP(S) proxy
Set a proxy for outgoing HTTP(S) connections from the Satellite product. System-wide proxies must be configured at the operating system level.
HTTP(S) proxy except hosts
Show Experimental Labs
If set to Yes, Satellite appends domain names when new hosts are provisioned.
Out of sync interval
30
Satellite UUID
Satellite instance ID. Uniquely identifies a Satellite instance.
Default language
Default timezone
Instance title
Saved audits interval
New host details UI
Satellite loads the new UI for host details.
A.2. Satellite Task Settings
Sync task timeout
120
Enable dynflow console
Capsule action retry count
4
Number of attempts permitted to start a task on the Capsule before failing.
Capsule action retry interval
15
Allow Capsule batch tasks
Enable batch triggering of tasks on the Capsule.
Capsule tasks batch size
100
Number of tasks included in one request to the Capsule if foreman_tasks_proxy_batch_trigger is enabled.
Tasks troubleshooting URL
Polling intervals multiplier
1
A.3. Template Sync Settings
Associate
Branch
Default branch in Git repo.
Commit message
Templates export made by a Satellite user
Dirname
Filter
Force import
Lock templates
Keep, do not lock new
Metadata export mode
Refresh
Default metadata export mode.
Possible options:
refresh re-renders metadata.
keep keeps existing metadata.
Negate
Prefix
Repo
/tmp/dir
git://example.com
https://example.com
ssh://example.com
Verbosity
A.4. Discovered Settings
Discovery location
Discovery organization
Interface fact
discovery_bootif
Create bond interfaces
Clean all facts
Hostname facts
discovery_bootif
Auto provisioning
Reboot
Hostname prefix
mac
Fact columns
Highlighted facts
Storage facts
Software facts
Hardware facts
Network facts
IPMI facts
Lock PXE
Locked PXELinux template name
pxelinux_discovery
Locked PXEGrub template name
pxegrub_discovery
Locked PXEGrub2 template name
pxegrub2_discovery
Force DNS
Error on existing NIC
Type of name generator
Fact + prefix
Prefer IPv6
A.5. Boot Disk Settings
iPXE directory
/usr/share/ipxe
ISOLINUX directory
/usr/share/syslinux
SYSLINUX directory
/usr/share/syslinux
Grub2 directory
/var/lib/tftpboot/grub2
Host image template
Boot disk iPXE - host
Generic image template
Boot disk iPXE - generic host
ISO generation command
genisoimage
Installation media caching
Allowed bootdisk types
A.6. Red Hat Cloud Settings
Automatic inventory upload
Enable automatic upload of your host inventory to the Red Hat cloud.
Synchronize recommendations Automatically
Enable automatic synchronization of Insights recommendations from the Red Hat cloud.
Obfuscate host names
Obfuscate hostnames sent to the Red Hat cloud.
Obfuscate host ipv4 addresses
Obfuscate IPv4 addresses sent to the Red Hat cloud.
ID of the RHC daemon
RHC daemon id.
A.7. Content Settings
Default HTTP Proxy
CDN SSL version
Kickstart default
Kickstart default finish
Default synced OS user-data
Kickstart default user data
Kickstart default PXELinux
Kickstart default PXEGrub
Kickstart default PXEGrub2
Kickstart default iPXE
Kickstart default
Discovery Red Hat kexec
Atomic Kickstart default
Manifest refresh timeout
1200
Accept action timeout
20
Finish action timeout
3600
Can communicate with the Red Hat Portal for subscriptions.
If this is enabled, a composite content view cannot be published or promoted, unless the component content view versions that it includes exist in the target environment.
Check services before actions
100
How many repositories should be synced concurrently on a Capsule. A smaller number may lead to longer sync times. A larger number will increase dynflow load.
Sync Capsules after Content View promotion
Whether or not to auto sync Capsules after a Content View promotion.
immediate
Default Red Hat Repository download policy
on_demand
Default download policy for enabled Red Hat repositories. Either immediate or on_demand.
Default Capsule download policy
on_demand
Default download policy for Capsule syncs. Either inherit, immediate, or on_demand.
/var/lib/pulp/katello-export
/var/lib/pulp/exports
Pulp client key
Pulp client cert
Sync Connection Timeout
300
Delete Host upon unregister
Default Location
Expire soon days
120
Host Duplicate DMI UUIDs
Host Profile Assume
Host Tasks Workers Pool Size
5
Applicability Batch Size
50
Autosearch
Autosearch delay
500
Pulp bulk load size
2000
1440
Prefer registered through Capsule for remote execution
A.8. Authentication Settings
OAuth active
Satellite will use OAuth for API authorization.
OAuth consumer key
OAuth consumer key.
OAuth consumer secret
OAuth consumer secret.
OAuth map users
Satellite maps users by username in the request-header. If this is disabled, OAuth requests have administrator rights.
Failed login attempts limit
30
Satellite blocks user logins from an incoming IP address for 5 minutes after the specified number of failed login attempts. Set to 0 to disable brute force protection.
Restrict registered Capsules
Only known Capsules can access features that use Capsule authentication.
Require SSL for capsules
Client SSL certificates are used to identify Capsules (:require_ssl should also be enabled).
Trusted hosts
List of hostnames, IPv4, IPv6 addresses or subnets to be trusted in addition to Capsules for access to fact/report importers and ENC output.
SSL certificate
/etc/foreman/client_cert.pem
SSL Certificate path that Satellite uses to communicate with its proxies.
SSL CA file
/etc/foreman/proxy_ca.pem
SSL CA file path that Satellite uses to communicate with its proxies.
SSL private key
/etc/foreman/client_key.pem
SSL Private Key path that Satellite uses to communicate with its proxies.
SSL client DN env
HTTP_SSL_CLIENT_S_DN
SSL client verify env
HTTP_SSL_CLIENT_VERIFY
SSL client cert env
HTTP_SSL_CLIENT_CERT
Server CA file
SSL CA file path used in templates to verify the connection to Satellite.
Websockets SSL key
Private key file path that Satellite uses to encrypt websockets.
Websockets SSL certificate
Certificate path that Satellite uses to encrypt websockets.
Websockets encryption
External
Idle timeout
60
BCrypt password cost
9
BMC credentials access
OIDC JWKs URL
OIDC Audience
OIDC Issuer
OIDC Algorithm
A.9. Email Settings
Email reply address
Email reply address for emails that Satellite is sending.
Email subject prefix
Send welcome email
Delivery method
Sendmail
Method used to deliver email.
SMTP enable StartTLS auto
SMTP OpenSSL verify mode
Default verification mode
SMTP address
SMTP address to connect to.
SMTP port
25
SMTP port to connect to.
SMTP HELO/EHLO domain
HELO/EHLO domain.
SMTP username
SMTP password
SMTP authentication
none
Sendmail arguments
-i
Sendmail location
/usr/sbin/sendmail
A.10. Notifications Settings
RSS enable
Pull RSS notifications.
RSS URL
https://www.redhat.com/en/rss/blog/channel/red-hat-satellite
A.11. Provisioning Settings
Host owner
Default owner on provisioned hosts, if empty Satellite uses the current user.
Root password
Unattended URL
Safemode rendering
Enables safe mode rendering of provisioning templates. The default and recommended option Yes denies access to variables and any object that is not listed in Satellite.
When set to No, any object may be accessed by a user with permission to use templating features, either by editing templates, parameters or smart variables. This permits users full remote code execution on Satellite Server, effectively disabling all authorization. This is not a safe option, especially in larger companies.
Query local nameservers
Satellite queries the locally configured resolver instead of the SOA/NS authorities.
Installation token lifetime
360
SSH timeout
120
0.0.0.0
Update IP from built request
Satellite updates the host IP with the IP that made the build request.
Use short name for VMs
Satellite uses the short hostname instead of the FQDN for creating new virtual machines.
DNS timeout
[5, 10, 15, 20]
Clean up failed deployment
Satellite deletes the virtual machine if the provisioning script ends with a non-zero exit code.
Random-based
iPXE intermediate script
Destroy associated VM on host delete. When enabled, VMs linked to hosts are deleted on Compute Resource. When disabled, VMs are unlinked when the host is deleted, meaning they remain on Compute Resource and can be re-associated or imported back to Satellite again. This does not automatically power off the VM
Maximum structured facts
100
Maximum number of keys in structured subtree, statistics stored in satellite::dropped_subtree_facts.
Global Registration
Global Registration template.
PXEGrub2 global default
PXELinux global default
PXEGrub global default
Global default iPXE template
iPXE global default
Local boot PXEGrub2 template
PXEGrub2 default local boot
Local boot PXELinux template
PXELinux default local boot
Local boot PXEGrub template
PXEGrub default local boot
Local boot iPXE template
iPXE default local boot
Manage PuppetCA
Satellite automates certificate signing upon provision of a new host.
Use UUID for certificates
Satellite uses random UUIDs for certificate signing instead of hostnames.
Show unsupported provisioning templates
Show unsupported provisioning templates. When enabled, all the available templates are shown. When disabled, only Red Hat supported templates are shown.
A.12. Facts Settings
Satellite creates the host when new facts are received.
Location fact
satellite_location
Organization fact
satellite_organization
Default location
Default Location
Default organization
Default Organization
Update hostgroup from facts
Satellite updates a host’s hostgroup from its facts.
Ignore facts for domain
Update subnets from facts
None
Satellite updates a host’s subnet from its facts.
Exclude pattern for facts stored in satellite
Exclude pattern for all types of imported facts (Puppet, Ansible, rhsm). Those facts are not stored in the satellite database. You can use a * wildcard to match names with indexes, e.g. ignore* filters out ignore, ignore123 as well as a::ignore or even a::ignore123::b.
A.13. Configuration Management Settings
Satellite creates the host when a report is received.
Matchers inheritance
Satellite matchers are inherited by children when evaluating smart class parameters for hostgroups, organizations, and locations.
[fqdn, hostgroup, os, domain]
Satellite evaluates host smart class parameters in this order by default.
Interpolate ERB in parameters
Satellite parses ERB in parameters value in the ENC output.
All hosts show a configuration status even when a Puppet Capsule is not assigned.
A.14. Remote Execution Settings
Fallback to Any Capsule
Enable Global Capsule
SSH User
root
Effective User
root
Effective User Method
sudo
Effective user password
Sync Job Templates
SSH Port
22
Connect by IP
Prefer IPv6 over IPv4
Default SSH password
Default SSH key passphrase
Workers pool size
5
Number of workers in the pool to handle the execution of the remote execution jobs. Restart of the dynflowd/satellite-tasks service is required.
Cleanup working directories
Cockpit URL
Form Job Template
Run Command - SSH Default
A.15. Ansible Settings
Private Key Path
Connection type
ssh
WinRM cert Validation
validate
Default verbosity level
Disabled
Satellite adds this level of verbosity for additional debugging output when running Ansible playbooks.
Post-provision timeout
360
Timeout (in seconds) to set when Satellite triggers an Ansible roles task playbook after a host is fully provisioned. Set this to the maximum time you expect a host to take until it is ready after a reboot.
Ansible report timeout
30
Ansible out of sync disabled
Ansible - Ansible Inventory
Satellite uses this template to schedule the report with Ansible inventory.
Ansible roles to ignore
The roles to exclude when importing roles from Capsule. The expected input is comma separated values and you can use * wildcard metacharacters. For example: foo*, *b*, *bar.
Capsule tasks batch size for Ansible
Number of tasks which should be sent to the Capsule in one request if satellite_tasks_proxy_batch_trigger is enabled. If set, it overrides satellite_tasks_proxy_batch_size setting for Ansible jobs.
