1. Introduction to Foreman
Foreman is a centralized tool for provisioning, remote management, and monitoring of multiple Enterprise Linux deployments. With Foreman, you can deploy, configure, and maintain your systems across physical, virtual, and cloud environments.
2. Provisioning management with Foreman
2.1. Provisioning methods in Foreman
- Network based
You must configure the necessary network booting services, such as DHCP or TFTP. When you create a host entry, you select a PXE loader that can configure DHCP options for network booting if Smart Proxy is set up to configure the DHCP service automatically.
This method uses an operating system installer, such as Anaconda, Debian Installer, Agama, or AutoYaST, and a template-generated file with installation options downloaded from Foreman, such as
Agama,AutoYaST,Kickstart,Preseed, orPreseed Autoinstalltemplates.- Network based with PXE Discovery
- PXE-less Discovery with kexec
Kernel execute is a Technology Preview feature only. Technology Preview features are not supported by Foreman community. Foreman community does not recommend using them in production. These features provide early access to upcoming product features, enabling customers to test functionality and provide feedback during the development process. |
- Boot disk based
- Image based
3. Major Foreman components
A typical Foreman deployment consists of the following components: a Foreman server, Smart Proxy servers, and hosts that receive configuration from Foreman server and Smart Proxy servers.
3.1. Foreman server overview
Foreman server is the central component of a Foreman deployment.
A typical Foreman deployment includes one Foreman server on which you perform the following operations:
Configuration of Smart Proxy servers
Configuration of hosts
Host provisioning
Foreman server delegates host provisioning and communication to Smart Proxy servers. Foreman server itself also includes a Smart Proxy.
Foreman server also contains a fine-grained authentication system. You can grant Foreman users permissions to access precisely the parts of the infrastructure for which they are responsible.
3.2. Smart Proxy overview
With Smart Proxy servers, you can extend the reach and scalability of your Foreman deployment. Smart Proxy servers provide the following functionalities in a Foreman deployment:
Running localized services to discover, provision, control, and configure hosts.
3.3. Overview of hosts in Foreman
With Foreman, you can manage hosts at scale, including monitoring, provisioning, remote execution, and configuration management. You can also group hosts by using features such as host groups and host collections.
3.4. List of key open source components of Foreman
- Foreman
- Katello
- Candlepin
- Pulp
3.5. Smart Proxy features
Smart Proxy servers provide local host management services.
Smart Proxies provide the following functionalities:
- DHCP
Smart Proxy can manage a DHCP server, including integration with an existing solution, such as ISC DHCP servers, Active Directory, and Libvirt instances.
- DNS
Smart Proxy can manage a DNS server, including integration with an existing solution, such as ISC BIND and Active Directory.
- TFTP
Smart Proxy can integrate with any UNIX-based TFTP server.
- Realm
Smart Proxy can manage Kerberos realms or domains so that hosts can join them automatically during provisioning. Smart Proxy can integrate with an existing infrastructure, including FreeIPA and Active Directory.
- Puppet server
Smart Proxy can act as a configuration management server by running an OpenVox server.
- Puppet Certificate Authority
Smart Proxy can integrate with the Puppet certificate authority (CA) to provide certificates to hosts.
Smart Proxy can provide power management for hosts by using the Intelligent Platform Management Interface (IPMI) or Redfish standards.
- Provisioning template proxy
Smart Proxy can serve provisioning templates to hosts.
- OpenSCAP
Smart Proxy can perform security compliance scans on hosts.
- Remote Execution (REX)
Smart Proxy can run remote job execution on hosts.
You can configure a Smart Proxy server for a specific limited purpose by enabling only selected features on that Smart Proxy. Common configurations include the following:
- Infrastructure Smart Proxies: DNS + DHCP + TFTP
Smart Proxies with these services provide infrastructure services for hosts and have all necessary services for provisioning new hosts.
4. Tools for administration of Foreman
4.1. Foreman web UI overview
4.2. Hammer CLI overview
You can configure and manage your Foreman server with CLI commands by using Hammer.
Create shell scripts based on Hammer commands for basic task automation.
Redirect output from Hammer to other tools.
Use the
--debugoption with Hammer to test responses to API calls before applying the API calls in a script. For example:hammer --debug organization list.
To issue Hammer commands, a user must have access to your Foreman server.
To ensure a user-friendly and intuitive experience, the Foreman web UI takes priority when developing new functionality. Therefore, some features that are available in the Foreman web UI might not yet be available for Hammer. |
4.3. Foreman API overview
You can write custom scripts and external applications that access the Foreman API over HTTP with the Representational State Transfer (REST) API provided by Foreman server.
Configure any programming language, framework, or system with support for HTTP protocol to use the API.
Create client applications that require minimal knowledge of the Foreman infrastructure because users discover many details at runtime.
Adopt the resource-based REST model for intuitively managing a virtualization platform.
API commands differ between versions of Foreman. When you prepare to upgrade Foreman server, update all the scripts that contain Foreman API commands. |
4.4. MCP server overview
Foreman provides a Model Context Protocol (MCP) server so that you can query and manage your Foreman inventory from MCP-compatible AI applications by using natural language.
You deploy the MCP server from a container image that Foreman community provides and connect it to the AI application that runs your MCP client. The MCP server accesses Foreman with your credentials, so your MCP client cannot obtain data that you do not have permission to access.
By default, the MCP server is read-only. You can query your inventory and generate reports from it, for example, a report of all subnets and the hosts that are assigned to them.
When you start the MCP server, you can also grant it permissions to change your Foreman. For example, you can start remote execution jobs on your hosts, and publish and promote content views.
4.5. Remote execution in Foreman
With remote execution, you can run jobs on hosts from Smart Proxies by using shell scripts or Ansible roles and playbooks.
Run jobs on multiple hosts at once.
Use variables in your commands for more granular control over the jobs you run.
Use host facts and parameters to populate the variable values.
Specify custom values for templates when you run the command.
Communication for remote execution occurs through Smart Proxy server, which means that Foreman server does not require direct access to the target host, and can scale to manage many hosts.
5. Supported usage and versions of Foreman components
5.1. Foreman operating system
You can install Foreman on the following supported operating systems.
You can run Foreman server and Smart Proxy servers on Enterprise Linux 9, Debian 12, and Ubuntu 22.04. Katello plugin packages, which provide content management capabilities, are only available for Enterprise Linux.
5.2. Client operating systems
Amazon Linux
Debian
Enterprise Linux 10, 9, and 8
Fedora
openSUSE/SUSE Linux Enterprise Server
Ubuntu
Ansible
OpenSCAP
OpenSSH
Puppet
Salt
Windows Remote Management (WinRM)
Operating system installers that can perform unattended installations, such as Anaconda or Debian-installer
Katello host tools
Subscription Manager
Tracer utility
6. Security considerations in Foreman
Foreman supports multiple security mechanisms to provide additional layers of protection. Implementing these security features enhances the overall security of your Foreman deployment.
These security considerations apply to both Foreman server and Smart Proxy server environments. |
- Federal Information Processing Standards (FIPS) Mode
Foreman supports running on FIPS-enabled Red Hat Enterprise Linux hosts to comply with security standards for cryptographic modules. However, Foreman itself is not FIPS-certified. In addition, you cannot enable FIPS mode after the installation of Foreman.
NoteForeman supports DEFAULT and FIPS crypto-policies. The FUTURE crypto-policy is not supported for Foreman server and Smart Proxy server installations. The FUTURE policy is a stricter forward-looking security level intended for testing a possible future policy.
- File Access Policy Daemon (
fapolicyd) -
By enabling
fapolicydon your Foreman server, you can monitor and control file and directory access, which provides an additional security layer.This feature helps prevent unauthorized code execution and enhances system integrity. You can enable or disable
fapolicydon both Foreman server and Smart Proxy server at any time, depending on your security requirements. - Post-Quantum Cryptography (PQC)
Foreman community does not support PQC compatibility for Foreman.
- Security-Enhanced Linux (SELinux)
Foreman requires SELinux, a mandatory access control system that restricts system access and reduces the risk of security vulnerabilities. SELinux enforces policies that define which processes can access specific system resources, providing protection against unauthorized access and exploitation.
To maintain a high-security environment, Foreman community recommends running Foreman with SELinux in enforcing mode. It ensures that access control policies are strictly enforced, minimizing the risk of privilege escalation or unauthorized actions.
- Additional Security Recommendations
7. Networking considerations in Foreman
For the components of Foreman architecture to communicate, the required network ports must be open to enable incoming and outgoing traffic between the components.
7.1. Smart Proxy networking
The communication between Foreman server and hosts registered to a Smart Proxy server is routed through that Smart Proxy server. Smart Proxy server also provides Foreman services to hosts.
In a topology with hosts connecting to a Smart Proxy server, Smart Proxy server provides a single endpoint for all host network communications so that in remote network segments, only firewall ports to the Smart Proxy server itself must be open. Hosts do not need direct access to Foreman server.
In a topology with hosts connecting directly to Foreman server, hosts need direct network access to Foreman server. This applies to all Smart Proxy servers because they are hosts of Foreman server.
7.2. Foreman server port and firewall requirements
The following tables indicate the destination port and the direction of incoming and outgoing traffic for Foreman server.
| Destination Port | Protocol | Service | Source | Required For | Description |
53 |
TCP and UDP |
DNS |
DNS Servers and clients |
Name resolution |
DNS (optional) |
67 |
UDP |
DHCP |
Client |
Dynamic IP |
DHCP (optional) |
69 |
UDP |
TFTP |
Client |
TFTP Server (optional) |
443 |
TCP |
HTTPS |
Smart Proxy |
Foreman API |
Communication from Smart Proxy |
443, 80 |
TCP |
HTTPS, HTTP |
Client |
Global Registration |
Registering hosts to Foreman Port 443 is required for registration initiation, and uploading facts. Port 80 notifies Foreman on the |
4505 – 4506 |
TCP |
MQTT |
Client |
Salt (optional) |
Salt Master to Salt Minions |
5910 – 5930 |
TCP |
HTTPS |
Browsers |
Compute Resource’s virtual console |
8000 |
TCP |
HTTP |
Client |
Provisioning templates |
Template retrieval for client installers, iPXE or UEFI HTTP Boot |
8000 |
TCP |
HTTPS |
Client |
PXE Boot |
Installation |
8140 |
TCP |
HTTPS |
Client |
OpenVox agent |
Client updates (optional) |
8443 |
TCP |
HTTPS |
Foreman |
Smart Proxy API |
Smart Proxy functionality |
8443 |
TCP |
HTTPS |
Client |
OpenSCAP |
Configure Client (if the OpenSCAP plugin is installed) |
8443 |
TCP |
HTTPS |
Discovered Node |
Discovery |
Host discovery and provisioning (if the discovery plugin is installed) |
9191 |
TCP |
HTTPS |
Client |
Salt (optional) |
Salt API |
| Destination Port | Protocol | Service | Destination | Required For | Description |
ICMP |
ping |
Client |
DHCP |
Free IP checking (optional) |
7 |
TCP |
echo |
Client |
DHCP |
22 |
TCP |
SSH |
Target host |
Remote execution |
Run jobs |
22, 16514 |
TCP |
SSH SSH/TLS |
Compute Resource |
Foreman originated communications, for compute resources in libvirt |
53 |
TCP and UDP |
DNS |
DNS Servers on the internet |
DNS Server |
Resolve DNS records (optional) |
53 |
TCP and UDP |
DNS |
DNS Server |
Smart Proxy DNS |
Validation of DNS conflicts (optional) |
53 |
TCP and UDP |
DNS |
DNS Server |
Orchestration |
Validation of DNS conflicts |
68 |
UDP |
DHCP |
Client |
Dynamic IP |
DHCP (optional) |
80 |
TCP |
HTTP |
Remote repository |
Content Sync |
Remote repositories |
389, 636 |
TCP |
LDAP, LDAPS |
External LDAP Server |
LDAP |
LDAP authentication, necessary only if external authentication is enabled.
The port can be customized if |
443 |
TCP |
HTTPS |
Amazon EC2, Azure, Google Compute Engine |
Compute resources |
Virtual machine interactions (query/create/destroy) (optional) |
443 |
TCP |
HTTPS |
Infoblox DHCP Server |
DHCP management |
When using Infoblox for DHCP, management of the DHCP leases (optional) |
623 |
Client |
Power management |
BMC On/Off/Cycle/Status |
5000 |
TCP |
HTTPS |
OpenStack Compute Resource |
Compute resources |
5900 – 5930 |
TCP |
SSL/TLS |
Hypervisor |
noVNC console |
Launch noVNC console |
5985 |
TCP |
HTTP |
Client |
WinRM |
Configure Client running Windows |
5986 |
TCP |
HTTPS |
Client |
WinRM |
7911 |
TCP |
DHCP, OMAPI |
DHCP Server |
DHCP |
The DHCP target is configured using ISC and |
8443 |
TCP |
HTTPS |
Client |
Discovery |
Smart Proxy sends reboot command to the discovered host (optional) |
8443 |
TCP |
HTTPS |
Smart Proxy |
Smart Proxy API |
Management of Smart Proxies |
7.3. Smart Proxy port and firewall requirements
The following tables indicate the destination port and the direction of incoming and outgoing traffic for Smart Proxy servers.
ICMP to Port 7 UDP and TCP must not be rejected, but can be dropped. The DHCP Smart Proxy sends an ECHO REQUEST to the Client network to verify that an IP address is free. A response prevents IP addresses from being allocated. |
53 |
TCP and UDP |
DNS |
Name resolution |
DNS (optional) |
67 |
UDP |
DHCP |
Client |
Dynamic IP |
DHCP (optional) |
69 |
UDP |
TFTP |
Client |
8000 |
TCP |
HTTP |
Client |
8000 |
TCP |
HTTP |
Client |
PXE Boot |
Installation |
8140 |
TCP |
HTTPS |
Client |
OpenVox agent |
8443 |
TCP |
HTTPS |
Foreman |
Smart Proxy API |
8443 |
TCP |
HTTPS |
Client |
Register Endpoint |
Client registration with Smart Proxy servers |
8443 |
TCP |
HTTPS |
Client |
OpenSCAP |
8443 |
TCP |
HTTPS |
Discovered Node |
Discovery |
ICMP |
ping |
Client |
DHCP |
7 |
TCP |
echo |
Client |
DHCP |
22 |
TCP |
SSH |
Target host |
Remote execution |
Run jobs |
53 |
TCP and UDP |
DNS |
DNS Server |
53 |
TCP and UDP |
DNS |
DNS Server |
Smart Proxy DNS |
68 |
UDP |
DHCP |
Client |
Dynamic IP |
DHCP (optional) |
443 |
TCP |
HTTPS |
Foreman |
Smart Proxy |
Smart Proxy Configuration management Template retrieval OpenSCAP Remote Execution result upload |
443 |
TCP |
HTTPS |
DHCP management |
623 |
Client |
Power management |
7911 |
TCP |
DHCP, OMAPI |
DHCP Server |
DHCP |
8443 |
TCP |
HTTPS |
Client |
Discovery |
8. Deployment path for Foreman
8.1. Installing a Foreman server
Installing an instance of Foreman server on a dedicated server is the first step to a working Foreman infrastructure.
8.1.1. Configuring Foreman server with external database
A default Foreman server installation includes installing PostgreSQL databases on the server. However, you can configure your Foreman server to use external databases instead. Moving to external databases distributes the workload and can reduce overall Foreman memory usage.
Frequent remote execution tasks. This requires a high volume of records in PostgreSQL and generates heavy database workloads.
High volume of hosts.
8.2. Configuring external authentication in Foreman
Foreman includes native support for authentication with a username and password. If you require additional methods of authentication, configure your Foreman server to use an external authentication source.
| Username and password | Single sign-on (SSO) | One-time password (OTP) | Time-based one-time password (TOTP) | PIV cards | |
Active Directory (direct integration) |
Yes |
Yes |
No |
No |
No |
FreeIPA |
Yes (Linux and Active Directory users) |
Yes (Linux users only) |
No |
No |
No |
Quarkus-based Keycloak |
Yes |
Yes |
Yes |
Yes |
Yes |
Wildfly-based Keycloak |
Yes |
Yes |
Yes |
Yes |
Yes |
LDAP |
Yes |
No |
No |
No |
No |
8.3. Planning organization and location context
Organizations and locations enable you to arrange Foreman resources into logically structured groups. For example, you can create groups based on ownership, purpose, or security level.
- Organizations
Organizations can represent different business units, departments, or teams, such as Finance, Marketing, or Web Development.
- Locations
You can use locations to map the network infrastructure to prevent incorrect host placement or configuration. While you cannot assign a subnet, domain, or compute resources directly to a Smart Proxy server, you can assign them to a location.
Foreman server defines all locations and organizations. Each Smart Proxy server handles configuration of hosts in a different location.
Your Foreman server retains the management function, while the configuration is synchronized between your Foreman server and Smart Proxy servers assigned to certain locations.
If you use host groups to bundle provisioning and configuration information, avoid mismatching resources from mutually exclusive contexts. For example, setting a subnet from one organization or location and a compute resource from a different organization or location creates an invalid host group. |
Some resources in Foreman, such as Ansible roles and operating systems, are not part of any organization or location context.
The system administrator creates the following organizations on their Foreman server:
Finance
Marketing
Sales
Additionally, the administrator creates the following locations on their Foreman server:
United States
United Kingdom
Japan
Boston
Phoenix
San Francisco
8.4. Installing Smart Proxy servers
By installing Smart Proxy servers, you extend the reach and scalability of your Foreman deployment. You register each Smart Proxy server to Foreman server and configure it to provide the required services within your Foreman deployment.
You can install a Smart Proxy server in each of your geographic locations. By assigning a Smart Proxy to each location, you decrease the load on Foreman server, increase redundancy, and reduce bandwidth usage.
The maximum number of Smart Proxy servers that Foreman server can support has no fixed limit. It was tested that a Foreman server can support 17 Smart Proxy servers with 2 vCPUs. |
Decide what services you want to enable on each Smart Proxy server. You can configure the DNS, DHCP, and TFTP services on one of your Smart Proxy servers or you can use an external server to provide these services to your Smart Proxy servers.
8.5. Defining role-based access control policies
8.5.1. Roles in Foreman
One of the predefined roles is the Default role. Foreman assigns the Default role to every user in the system. By default, the Default role grants only a limited set of permissions. Be aware that if you add a permission to the Default role, every Foreman users will gain that permission. Assigning a different role to a user does not remove the Default role from the user. |
- Roles related to applications or parts of infrastructure
- Roles related to a particular stage of the software lifecycle
- Roles related to specific tasks
8.5.2. Best practices for role-based access control in Foreman
When implementing role-based access control in Foreman, consider the following guidelines for optimal results.
Define the expected tasks and responsibilities: Define the subset of the Foreman infrastructure that you want the role to access as well as actions permitted on this subset. Think of the responsibilities of the role and how it differs from other roles.
Use predefined roles whenever possible: Foreman provides several sample roles that you can use. Copying and editing an existing role can be a good start for creating a custom role.
Adopt a granular approach to user role management: Define roles with specific and well-scoped permissions. Note that each user can have multiple roles assigned and that permissions from these roles are cumulative.
Add permissions gradually and test the results: When creating a custom role, start with a limited set of permissions and add permissions one by one, while testing continuously. Ensure to test your custom role to verify that it works as intended.
Consider areas of interest and granting read-only access: Even though a role has a limited area of responsibility, it might need a wider set of permissions. Therefore, you can grant the role a read-only access to parts of Foreman infrastructure that influence its area of responsibility.
8.6. Configuring provisioning
Provisioning templates enable you to define the way Foreman installs an operating system on your hosts.
The Discovery service enables you to detect unknown hosts and virtual machines on the provisioning network.
Host groups enable you to standardize provisioning of host configurations.
8.7. Overview of recommended disaster recovery plans
- Snapshots of virtualized Foreman server
- How do I back up?
Virtualize your Foreman server and use the hypervisor tools to take virtual machine snapshots of the server. This method is suitable if you can run Foreman in a virtual machine.
- Active and passive Foreman server, with external storage
- How do I back up?
Store the following critical data on network attached storage: database in
/var/lib/pgsql. Replicate this storage into a different data center. Attach the storage to a Foreman server that is a clone of the primary Foreman server but runs passively. - How will I recover in case of a disruptive event?
To recover Foreman services, switch DNS records of the active Foreman server with the passive Foreman server. This ensures that the passive server becomes the active server. All hosts remain connected without configuration updates.
- Active and passive Foreman server, with backup and restore
- How do I back up?
Ensure periodic backups of your Foreman server. Copy this backup to a passive Foreman server and restore it on the passive server.
- Dual active Foreman server
- How do I back up?
Operate an active, independent Foreman server per data center. Hosts from each data center are registered to the Foreman server in that data center. Then configure automation to ensure recovery in case of a disruptive event. For example, you can periodically run a health check and if the health check discovers that the current Foreman server a host is registered to does not resolve, the host is re-registered to the other Foreman server.
To recover Foreman services, re-register all hosts to the Foreman server in the other data center.
8.8. Additional deployment tasks
- Remote execution commands on hosts
- Automating tasks with a configuration management tool
- Security management with OpenSCAP
You can enable the OpenSCAP plugin on your Foreman server and any Smart Proxy servers. With OpenSCAP, you can manage compliance policies and run security compliance scans on your hosts. After the scan completes, a compliance report is uploaded to your Foreman server.
- Load balancing
With load balancing configured on your Smart Proxy servers, you can improve performance on Smart Proxy servers while also improving performance and stability for host connections to Foreman.
For more information, see Configuring Smart Proxies with a load balancer.
9. Common deployment scenarios
9.1. Single location with segregated subnets
If your infrastructure requires multiple isolated networks in one geographic location, you can create segregated subnets and manage them with a single Smart Proxy.
Your infrastructure might require multiple isolated subnets even if Foreman is deployed in a single geographic location. This can be achieved for example by deploying multiple Smart Proxy servers with DHCP and DNS services, but the recommended way is to create segregated subnets using a single Smart Proxy. This Smart Proxy is then used to manage hosts and compute resources in those segregated networks to ensure they only have to access the Smart Proxy for provisioning, configuration, errata, and general management.
9.2. Deploying Foreman on AWS
You can deploy Foreman server, Smart Proxy servers, and hosts in Amazon Web Services (AWS) using various configurations. Options range from simple single-region setups to multi-region deployments with VPN connections or direct connections between on-premises and cloud environments.
You can run Foreman server, Smart Proxy servers, and hosts in your Amazon Web Services (AWS) environment. You can deploy Foreman on Amazon Web Services (AWS) in several scenarios.
- One-region setup
This is the least complex configuration of Foreman in AWS. Deploy both Foreman server and the hosts residing within the same region and within the Virtual Private Cloud (VPC) You can also use a different availability zone.
Figure 2. One-region setup - Connecting on-premises and AWS region
Create a VPN connection between the on-premises location and the AWS region where your Smart Proxy server is located. It is also possible to use the external host name of Foreman server when you register the instance that runs Smart Proxy.
Figure 3. Site-to-site VPN connection between the AWS region and the on-premises data center
Figure 4. Direct connection using the external DNS host name - Connecting different regions
Create a site-to-site VPN connection between different regions so that you can use the internal DNS host name when you register the instance that runs Smart Proxy to Foreman server. If you do not establish a site-to-site VPN connection, use the external DNS host name when you register the instance that runs Smart Proxy to Foreman server.
NoteMost public cloud providers do not charge for data being transferred into a region or between availability zones within a single region. However, they charge for data leaving the region to the internet.
Figure 5. Site-to-site VPN connection between AWS regions
Figure 6. Direct connection using the external DNS host name
10. Provisioning requirements in Foreman
10.1. PXE booting in Foreman
- PXE sequence
initrdand Kickstart. -
- PXE booting requirements
Network requirements:
Client requirements:
Ensure that all the network-based firewalls are configured to allow clients on the subnet to access the Smart Proxy.
Foreman requirements:
10.2. HTTP booting in Foreman
- HTTP booting requirements with managed DHCP
All the network-based firewalls are configured to allow clients on the subnet to access the Smart Proxy. For more information, see Networking considerations in Foreman.
NoteAlthough TFTP protocol is not used for HTTP UEFI Booting, Foreman uses TFTP Smart Proxy API to deploy boot loader configuration.
Ensure that the TCP port 8000 is open for the client to download the boot loader and Kickstart templates from the Smart Proxy.
The TCP port 8443 is open for the client to download the boot loader from the Smart Proxy using the HTTPS protocol.
The subnet that functions as the host’s provisioning interface has a DHCP Smart Proxy, an HTTP Boot Smart Proxy, a TFTP Smart Proxy, and a Templates Smart Proxy
- HTTP booting requirements with unmanaged DHCP
http://smartproxy.example.com:8000 -
https://smartproxy.example.com:8443
Ensure that all the network-based firewalls are configured to allow clients on the subnet to access the Smart Proxy. For more information, see Networking considerations in Foreman.
Ensure that the TCP port 8000 is open for the client to download boot loader and Kickstart templates from the Smart Proxy.
Ensure that the TCP port 8443 is open for the client to download the boot loader from the Smart Proxy through HTTPS.
Ensure that the host provisioning interface subnet has an HTTP Boot Smart Proxy set.
10.3. Secure Boot in Foreman
When Foreman is installed on Enterprise Linux using foreman-installer, grub2 and shim boot loaders that are signed by Red Hat are deployed into the TFTP and HTTP UEFI Boot directory.
PXE loader options named "SecureBoot" configure hosts to load shim.efi.
On Debian and Ubuntu operating systems, the grub2 boot loader is created using the grub2-mkimage unsigned.
To perform the Secure Boot, the boot loader must be manually signed and key enrolled into the EFI firmware.
Alternatively, grub2 from Ubuntu or Enterprise Linux can be copied to perform booting.
foreman |
N/A |
foreman |
N/A |
yes |
/usr/share/foreman |
/sbin/nologin |
foreman-proxy |
N/A |
foreman-proxy |
N/A |
yes |
/usr/share/foreman-proxy |
/sbin/nologin |
apache |
48 |
apache |
48 |
no |
/usr/share/httpd |
/sbin/nologin |
postgres |
26 |
postgres |
26 |
no |
/var/lib/pgsql |
/bin/bash |
puppet |
52 |
puppet |
52 |
no |
/sbin/nologin |
unbound |
N/A |
unbound |
N/A |
yes |
/etc/unbound |
/sbin/nologin |
- Ansible
- Answer file
- ARF report
- Audits
- Boot disk
- Catalog
- Compliance policy
- Compute profile
- Compute resource
- Configuration Management
- Discovered host
- Discovery image
- Discovery plugin
- Discovery rule
- Enterprise Linux
AlmaLinux
CentOS Stream
Oracle Linux
Rocky Linux
- ERB
- External node classifier (ENC)
- Facter
- Facts
- Foreman
- Full host image
- Generic image
A boot disk for PXE-less provisioning that is not tied to a specific host. The generic image sends the MAC address of your host to Foreman server, which matches it against the host entry.
- Hammer
- Host
- Host collection
- Host group
- Host image
- Job
- Location
- Migrating Foreman
- OpenSCAP
- Organization
- Parameter
- Permission
- Provisioning
The provisioning of a host is the deployment of the base operating system on the host and registration of the host to Foreman. Optionally, the process continues with the supply of content and configuration. This process is ideally automated. Provisioned hosts run on compute resources or bare metal, never Foreman server or Smart Proxy servers.
Agamatemplates for SUSE Linux Enterprise Server 16 -
AutoYaSTtemplates for SUSE Linux Enterprise Server 15 and 12 -
Kickstarttemplates for AlmaLinux, Amazon Linux, CentOS, Oracle Linux, Red Hat Enterprise Linux, and Rocky Linux -
Preseed Autoinstalltemplates for Ubuntu -
Preseedtemplates for Debian
- Puppet
- OpenVox agent
- Puppet environment
- Puppet manifest
- OpenVox server
A Smart Proxy server component that provides a Puppet catalog to hosts for execution by the OpenVox agent.
- Puppet module
- PXE
- Recurring logic
- Remote execution (REX)
- Resource type
- Role
- Salt
- SCAP content
SCAP stands for Security Content Automation Protocol and refers to
.xmlfiles containing the configuration and security baseline against which hosts are checked. Foreman uses SCAP content in compliance policies.
- Smart Proxy server
Smart Proxy servers can provide DHCP, DNS, and TFTP services and act as an Ansible control node, OpenVox server, or Salt Master in separate networks. They interact with Foreman server in a client-server model.
Smart Proxy servers are required in Foreman deployments that manage IT infrastructure spanning across multiple networks and useful for Foreman deployments across various geographical locations.
- Subnet image
- Subscription Manager
- Tailoring files
- Task
- Trend
- Updating Foreman
The process of advancing your Foreman server and Smart Proxy server installations from one patch release to the next, for example Foreman 3.18.0 to Foreman 3.18.1.
- Upgrading Foreman
The process of advancing your Foreman server and Smart Proxy server installations from one minor release to the next, for example Foreman 3.17 to Foreman 3.18.
- User group
- User
- Virtualization
- virt-who
- XCCDF profiles
