With the Representational State Transfer (REST) API of Foreman, you can control your Foreman environment outside of the standard web interface. That way, you can integrate your Foreman with custom scripts or external applications over HTTP.
  • Broad client support – any programming language, framework, or system with support for HTTP protocol can use the API.
  • Self-descriptive – client applications require minimal knowledge of the Foreman infrastructure because a user discovers many details at runtime.
  • Resource-based model – the resource-based REST model provides a natural way to manage a virtualization platform.
  • Integrate with enterprise IT systems.
  • Integrate with third-party applications.
  • Perform automated maintenance or error checking tasks.
  • Automate repetitive tasks with scripts.
Hammer serves as a human-friendly interface to Foreman API. Use Hammer for interactive tasks and testing API calls, but use the API directly for better performance when executing many commands in scripts.
1.3. Getting help with Foreman API
You can use the API reference on your Foreman server to view information about API endpoints supported for Foreman API integrations.
View the full API reference on your Foreman server at the following URL:
https://foreman.example.com/apidoc/
2. API syntax
Understanding the basic syntax of API requests and JSON responses enables you to construct valid API calls and interpret the returned data.
Even though versions 1 and 2 of the Foreman API are available, Foreman community only supports version 2.
2.1. API request composition
You can use the built-in API reference documentation to compose valid API requests.
HTTP_METHOD API_ROUTE
$ curl \
--request HTTP_METHOD \
--insecure \
--user My_User_Name:My_Password \
--data @My_Input_File.json \
--header "Accept:application/json" \
--header "Content-Type:application/json" \
--output My_Output_File
API_ROUTE \
| python3 -m json.tool
--request
To use curl for the API call, specify an HTTP method with the --request option. For example, --request POST.
--insecure
Add the --insecure option to skip SSL peer certificate verification check. Foreman community recommends you to configure SSL authentication and use secured calls.
--user
Provide Foreman user credentials with the --user option.
--data
For POST and PUT requests, use the --data option to pass JSON-formatted data.
--header
When passing the JSON data with the --data option, you must specify the following headers with the --header option.
--output
When downloading content from Foreman server, specify the output file with the --output option.
API_ROUTE
Use the API route in the following format: https://foreman.example.com/api/architectures. In Foreman, version 2 of the API is the default. Therefore, it is not necessary to use v2 in the URL for API calls.
json.tool
Redirect the output to the Python json.tool module to make the output easier to read.
2.1.1. Using the GET HTTP method
  • Submit a GET request by using curl.
    Example API request:
    $ curl \
    --request GET \
    https://foreman.example.com/api/hosts \
    Example API response:
      "total": 2,
      "subtotal": 2,
      "page": 1,
      "per_page": 20,
      "search": null,
      "sort": {
        "by": null,
        "order": null
      "results":
        output truncated
    The response from the API indicates that there are two results in total, this is the first page of the results, and the maximum results per page is set to 20. For more information, see JSON response format.
2.2. JSON response format
Foreman API returns results in JSON format, which you can parse programmatically to extract data from single-object responses or collections responses.
2.2.1. JSON response format for single objects
You can use single-object JSON responses to work with a single object. API requests to a single object require the unique identifier :id of the object.
API request
$ curl \
--request GET \
https://foreman.example.com/api/domains/23 \
API response
    "id": 23,
    "name": "qa.lab.example.com",
    "fullname": "QA",
    "dns_id": 10,
    "created_at": "2024-08-13T09:02:31Z",
    "updated_at": "2024-08-13T09:02:31Z"
2.2.2. JSON response format for collections
Collections return lists of objects, such as hosts and domains. Each response includes pagination metadata and a results section containing the data you can iterate through.
Example API request
$ curl \
--request GET \
https://foreman.example.com/api/domains \
    "total": 3,
    "subtotal": 3,
    "page": 1,
    "per_page": 20,
    "search": null,
    "sort": {
        "by": null,
        "order": null
    "results": [
            "id": 23,
            "fullname": "QA",
            "dns_id": 10,
            "id": 25,
            "name": "dev.lab.example.com",
            "fullname": "DEVEL",
            "dns_id": 8,
            "created_at": "2024-08-13T08:32:48Z",
            "updated_at": "2024-08-14T07:04:03Z"
            "id": 32,
            "name": "hr.lab.example.com",
            "fullname": "HR",
            "dns_id": 8,
            "created_at": "2024-08-16T08:32:48Z",
            "updated_at": "2024-08-16T07:04:03Z"
2.2.3. JSON response metadata
Review the metadata fields in Foreman API responses to understand pagination, search results, and collection information when working with the API.
total
subtotal
page
The page number.
per_page
limit
offset
search
The search string based on scoped_scoped syntax.
sort
  • by – Specifies by what field the API sorts the collection.
  • order – The sort order, either ASC for ascending or DESC for descending.
results
The collection of objects.
2.3. Relating API error messages to the API reference
3. API call authentication
You must authenticate API calls to Foreman server by using SSL certificates and valid user credentials, with options for HTTP basic authentication, SSL client certificates, or personal access tokens.
3.1. SSL authentication overview
Foreman requires HTTPS for all API communications to provide encryption and identity verification. You can use either self-signed certificates or custom SSL certificates you configure.
Foreman 3.16 does not support non-SSL communications.
By default, Foreman server uses a self-signed certificate. This certificate acts as both the server certificate to verify the encryption key and the certificate authority (CA) to trust the identity of Foreman server.
3.2. HTTP authentication overview
You must provide valid Foreman credentials to access the Foreman API.
The API uses HTTP Basic authentication to send encoded user credentials in the Authorization header. If a request does not include an appropriate Authorization header, the API returns a 401 Authorization Required error.
Basic authentication involves potentially sensitive information, for example, it sends passwords as plain text. The REST API requires HTTPS for transport-level encryption of plain text requests.
Some base64 libraries break encoded credentials into multiple lines and terminate each line with a newline character. This invalidates the header and causes a faulty request. The Authorization header requires the encoded credentials to be on a single line within the header.
3.3. Token authentication overview
You can use Personal Access Tokens to authenticate API requests instead of passwords. Additionally, you can manage your security by setting expiration dates or revoking tokens at any time.
3.3.1. Creating a Personal Access Token
  • Your user account has a role that grants the create_personal_access_tokens permission.
    $ curl \
    {"foreman_version":"3.16.0","result":"ok","status":200,"version":"3.5.1.10","api_version":2}
3.3.2. Revoking a Personal Access Token
    $ curl \
4. API requests in various languages
You can interact with Foreman API using curl for quick testing, Ruby for automation scripts with apipie bindings, or Python for integration with existing Python-based workflows.
4.1. Calling the API in curl
You can use curl to test API endpoints, debug requests, and perform quick operations without writing scripts.
You can use curl to manipulate resources on your Foreman server. API calls to Foreman require data in json format.
Foreman requires the use of HTTPS, and by default, a certificate for host identification. If you have not added the Foreman server certificate, then you can use the --insecure option to bypass certificate checks.
For user authentication, you can use the --user option to provide Foreman user credentials in the form --user My_User_Name:_My_Password. If you do not include the password, the command prompts you to enter it. To reduce security risks, do not include the password as part of the command, because it then becomes part of your shell history. For simplicity, the examples in this section include the password.
4.1.1. Passing JSON data to the API request
You can pass JSON-formatted data to Foreman API requests either as inline strings or external files.
JSON-formatted string
Enclose the quoted JSON-formatted data in curly braces {}. When passing a value for a JSON type parameter, you must escape quotation marks " with backslashes \. For example, within curly braces, you must format "Example JSON Variable" as \"Example JSON Variable\":
--data {"id":44, "smart_class_parameter":{"override":"true", "parameter_type":"json", "default_value":"{\"GRUB_CMDLINE_LINUX\": {\"audit\":\"1\",\"crashkernel\":\"true\"}}"}}
JSON-formatted file
The unquoted JSON-formatted data enclosed in a file and specified by the @ sign and the filename. For example:
--data @file.json
  • You can use your favorite text editor.
  • You can use syntax checker to find and avoid mistakes.
  • You can use tools to check the validity of JSON data or to reformat it.
$ json_verify < file.json
4.1.2. Retrieving a list of resources
You can retrieve lists of Foreman resources such as users, hosts, or organizations using GET requests, with responses containing both metadata for pagination and the actual resource data.
Example API request
$ curl \
--request GET \
https://foreman.example.com/api/users \
    "page": 1,
    "per_page": 20,
    "results": [
            "admin": false,
            "auth_source_id": 1,
            "auth_source_name": "Internal",
            "created_at": "2024-09-21 08:59:22 UTC",
            "default_location": null,
            "default_organization": null,
            "description": "",
            "effective_admin": false,
            "firstname": "",
            "id": 5,
            "last_login_on": "2024-09-21 09:03:25 UTC",
            "lastname": "",
            "locale": null,
            "locations": [],
            "login": "test",
            "mail": "test@example.com",
            "organizations": [
                    "id": 1,
                    "name": "Default Organization"
            "ssh_keys": [],
            "timezone": null,
            "updated_at": "2024-09-21 09:04:45 UTC"
            "admin": true,
            "created_at": "2024-09-20 07:09:41 UTC",
            "default_organization": {
                "description": null,
                "id": 1,
                "name": "Default Organization",
                "title": "Default Organization"
            "description": "",
            "effective_admin": true,
            "firstname": "Admin",
            "id": 4,
            "last_login_on": "2024-12-07 07:31:09 UTC",
            "lastname": "User",
            "locale": null,
            "locations": [
                    "id": 2,
                    "name": "Default Location"
            "login": "admin",
            "mail": "admin@example.com",
            "organizations": [
                    "id": 1,
            "ssh_keys": [],
            "timezone": null,
            "updated_at": "2024-11-14 08:19:46 UTC"
    "search": null,
    "sort": {
        "by": null,
        "order": null
    "subtotal": 2,
    "total": 2
4.1.3. Creating a user
You can create Foreman user accounts using POST requests.
Example API request
$ curl \
--request POST \
4.1.4. Modifying a user
You can modify Foreman user accounts using PUT requests by specifying the user ID and the fields you want to update, such as login name or email address.
This example changes the given name and login for the test_user account.
Example API request
$ curl \
--request PUT \
--data "{\"firstname\":\"New Test Name\",\"mail\":\"test@example.com\",\"login\":\"new_test_user\",\"password\":\"password123\",\"auth_source_id\":1}" \
https://foreman.example.com/api/users/8 \
4.2. Calling the API in Ruby
You can use Ruby to automate complex Foreman workflows. Use REST client libraries or apipie bindings to get type-safe API calls with built-in validation.
These are example scripts and commands. Ensure you review these scripts carefully before use, and replace any variables, user names, passwords, and other information to suit your own deployment.
4.3. Calling the API in Python
You can use Python with the requests module to integrate Foreman API calls into existing Python automation workflows, data processing pipelines, or DevOps tooling.
5. API cheat sheet
Use the Foreman API to automate host management and searches.
You can use the API on Foreman server via HTTPS on port 443.
For example, in Ruby, you can specify the Foreman server URL as follows:
url = 'https://foreman.example.com/api/v2/'
The following examples use curl for sending API requests.
5.1. Working with hosts
You can use API requests to manage hosts. Namely, you can list, query, search, and delete hosts programmatically.
5.1.1. Listing hosts
You can retrieve a list of all registered hosts from Foreman.
Example API request
$ curl \
--request GET \
https://foreman.example.com/api/v2/hosts \
API response
       "total" => 2,
    "subtotal" => 2,
        "page" => 1,
    "per_page" => 1000,
      "search" => nil,
        "sort" => {
           "by" => nil,
        "order" => nil
     "results" => [
5.1.2. Requesting information for a host
You can retrieve detailed information about a specific host, including architecture, build status, and capabilities.
This request returns information for host.example.com.
Example API request
$ curl \
--request GET \
https://foreman.example.com/api/v2/hosts/host.example.com \
    "all_puppetclasses": [],
    "architecture_id": 1,
    "architecture_name": "x86_64",
    "build": false,
    "capabilities": [
        "build"
    "certname": "host.example.com",
    "comment": null,
    "compute_profile_id": null,
5.1.3. Listing host facts
You can retrieve system facts such as hardware details, BIOS version, and installed software for a specific host.
This request returns all facts for the host foreman.example.com.
Example API request
$ curl \
--request GET \
https://foreman.example.com/api/v2/hosts/foreman.example.com/facts \
    "results": {
        "foreman.example.com": {
            "augeasversion": "1.0.0",
            "bios_release_date": "01/01/2007",
            "bios_version": "0.5.1",
            "blockdevice_sr0_size": "1073741312",
            "facterversion": "1.7.6",
5.1.4. Searching for hosts with matching patterns
You can filter hosts by hostname patterns or other matching criteria.
Example API request
$ curl \
--request GET \
https://foreman.example.com/api/v2/hosts?search=example \
    "results": [
            "name": "foreman.example.com",
    "search": "example",
5.1.5. Searching for hosts in an environment
You can filter hosts by environment to retrieve all hosts assigned to a specific environment.
Example API request
$ curl \
--request GET \
https://foreman.example.com/api/v2/hosts?search=environment=production \
    "results": [
            "environment_name": "production",
    "search": "environment=production",
5.1.6. Searching for hosts with a specific fact value
You can filter hosts by specific fact values such as host group, operating system, or custom facts.
This query returns all hosts with the host group My Host Group.
Example API request
$ curl \
--request GET \
https://foreman.example.com/api/v2/hosts?search=hostgroup=%22My+Host+Group%22 \
    "results": [
            "hostgroup_id": 1,
            "hostgroup_name": "My Host Group",
            "name": "my-host.example.com",
    "search": "hostgroup=\"My Host Group\"",
5.1.7. Deleting a host
You can permanently remove a host from Foreman when decommissioning a server, reclaiming software subscriptions, or clearing out stale inventory data to maintain accurate compliance reporting.
This example request deletes a host with a name host1.example.com.
Example API request
$ curl \
--request DELETE \
https://foreman.example.com/api/v2/hosts/host1.example.com \
5.1.8. Downloading a full-host boot disk image
You can download a bootable ISO image for a host to handle provisioning or recovery scenarios.
This request downloads a full boot disk image for a host by its ID.
Example API request
$ curl \
--request GET \
--output My_Image.iso \
https://foreman.example.com/api/bootdisk/hosts/host_ID?full=true
5.2. Using extended searches
You can combine search parameters in your API queries to filter hosts. This way you can target specific hosts by their operating system or hardware model.
For more information, see Working efficiently with Foreman web UI in Administering Foreman.
  2. Click the Search field to display a list of search parameters.
  3. Locate the search parameters that you want to use. For this example, locate os_title and model.
  4. Combine the search parameters in your API query as follows:
    Example request:
    $ curl \
    --get \
    --data-urlencode 'search=os_title="RedHat 7.7",model="PowerEdge R330"' \
    Example response:
        "results": [
                "model_id": 1,
                "model_name": "PowerEdge R330",
                "operatingsystem_id": 1,
                "operatingsystem_name": "RedHat 7.7",
        "search": "os_title=\"RedHat 7.7\",model=\"PowerEdge R330\"",
        "subtotal": 1,
        "total": 11
5.3. Using searches with pagination control
You can control how many results an API query returns per page and which page to retrieve in order to manage large datasets efficiently.
The number of items to be presented is set using the setting entries_per_page, which defaults to 20. However, you can change it per request by using the parameter per_page.
This example returns a list of architectures for an organization with ID 1 in pages. The list contains 5 entries per page and returns the second page.
Example API request
$ curl \
--request GET \
'https://foreman.example.com/api/architectures?organization_id=1&per_page=5&page=2'
5.4. Overriding Smart Class parameters
You can override Smart Class parameters to customize Puppet configuration values for specific hosts or host groups. This way you customize different environments without changing the original Puppet classes.
You can find the full list of attributes that you can modify in the built-in API reference at https://foreman.example.com/apidoc/v2/smart_class_parameters/update.html.
  1. Find the ID of the Smart Class parameter you want to change:
    • List all Smart Class Parameters.
      Example request:
      $ curl \
      --request GET \
      https://foreman.example.com/api/smart_class_parameters
    • If you know the Puppet class ID, for example 5, you can restrict the scope: Example request:
      $ curl \
      --request GET \
      https://foreman.example.com/api/puppetclasses/5/smart_class_parameters
      Both calls accept a search parameter. You can view the full list of searchable fields in the Foreman web UI. Navigate to Configure > Smart variables and click in the search query box to reveal the list of fields.
      Two particularly useful search parameters are puppetclass_name and key, which you can use to search for a specific parameter. For example, use the --data option to pass URL encoded data.
      Example request:
      $ curl \
      --request GET \
      --data 'search=puppetclass_name = access_insights_client and key = authmethod' \
      Foreman supports standard scoped-search syntax.
  2. When you find the ID of the parameter, list the full details including current override values.
    Example request:
    $ curl \
    --request GET \
    https://foreman.example.com/api/smart_class_parameters/63
  3. Enable overriding of parameter values.
    Example request:
    $ curl \
    --request PUT \
    --data '{"smart_class_parameter":{"override":true}}' \
    Note that you cannot create or delete the parameters manually. You can only modify their attributes. Foreman creates and deletes parameters only upon class import from Smart Proxies.
  4. Add custom override matchers.
    Example request:
    $ curl \
    --request PUT \
    --data '{"smart_class_parameter":{"override_value":{"match":"hostgroup=Test","value":"2.4.6"}}}' \
    For more information about override values, see https://foreman.example.com/apidoc/v2/override_values.html.
  5. You can delete override values.
    Example request:
    $ curl \
    --request DELETE \
    https://foreman.example.com/api/smart_class_parameters/63/override_values/3
5.5. Modifying a Smart Class parameter by using an external file
You can modify Puppet Smart Class parameters by using external JSON files to simplify working with complex parameter values. That way, you can enable syntax highlighting and error detection in your editor.
This example uses a MOTD Puppet manifest.
  1. Search for the Puppet Class by name, motd in this case.
    Example request:
    $ curl \
    --request GET \
    https://foreman.example.com/api/smart_class_parameters?search=puppetclass_name=motd \
  2. Examine the following output. Each Smart Class Parameter has an ID that is global for the same Foreman instance. The content parameter of the motd class has id=3. Do not confuse this with the Puppet Class ID that displays before the Puppet Class name.
    Example response:
    	"avoid_duplicates": false,
    		"created_at": "2024-02-06 12:37:48 UTC", # Remove this line.
    			"default_value": "", # Add a new value here.
    			"description": "",
    		"hidden_value": "",
    		"hidden_value?": false,
    		"id": 3,
    		"merge_default": false,
    		"merge_overrides": false,
    		"override": false, # Set the override value to true.
    			"override_value_order": "fqdn\nhostgroup\nos\ndomain",
    		"override_values": [], # Remove this line.
    			"override_values_count": 0,
    		"parameter": "content",
    		"parameter_type": "string",
    		"puppetclass_id": 3,
    		"puppetclass_name": "motd",
    		"required": false,
    		"updated_at": "2024-02-07 11:56:55 UTC", # Remove this line.
    			"use_puppet_default": false,
    		"validator_rule": null,
    		"validator_type": ""
  3. Use the parameter ID 3 to get the information specific to the motd parameter and redirect the output to a file, for example, output_file.json.
    Example request:
    $ curl \
    --request GET \
    https://foreman.example.com/api/smart_class_parameters/3 \
    | python3 -m json.tool > output_file.json
  4. Copy the file created in the previous step to a new file for editing, for example, changed_file.json:
    $ cp output_file.json changed_file.json
  5. Modify the required values in the file. In this example, change the content parameter of the motd module, which requires changing the override option from false to true:
    			"description": "",
    		"hidden_value": "",
    		"id": 3,
    		"required": false,
  6. After editing the file, verify that it looks as follows and then save the changes:
    		"default_value": "No Unauthorized Access Allowed",
    			"description": "",
    		"hidden_value": "",
    		"id": 3,
    		"override": true,
    		"required": false,
  7. Submit the file to Foreman:
    $ curl \
    --request PUT \
    --data @changed_file.json \
5.6. Deleting OpenSCAP reports
Delete OpenSCAP compliance reports to free up storage space or remove outdated scan results, either individually by ID or in bulk using a bash script for large-scale cleanup.
  1. List all OpenSCAP reports. Note the IDs of the reports that you want to delete.
    Example request:
    $ curl \
    https://foreman.example.com/api/v2/compliance/arf_reports/ \
    Example response:
        "page": 1,
        "per_page": 20,
        "results": [
                "created_at": "2024-05-16 13:27:09 UTC",
                "failed": 0,
                "host": "host1.example.com",
                "id": 404,
                "othered": 0,
                "passed": 0,
                "updated_at": "2024-05-16 13:27:09 UTC"
                "created_at": "2024-05-16 13:26:07 UTC",
                "failed": 0,
                "host": "host2.example.com,
                "id": 405,
                "othered": 0,
                "passed": 0,
                "updated_at": "2024-05-16 13:26:07 UTC"
                "created_at": "2024-05-16 13:25:07 UTC",
                "failed": 0,
                "host": "host3.example.com",
                "id": 406,
                "othered": 0,
                "passed": 0,
                "updated_at": "2024-05-16 13:25:07 UTC"
                "created_at": "2024-05-16 13:24:07 UTC",
                "failed": 0,
                "host": "host4.example.com",
                "id": 407,
                "othered": 0,
                "passed": 0,
                "updated_at": "2024-05-16 13:24:07 UTC"
        "search": null,
        "sort": {
            "by": null,
            "order": null
        "subtotal": 29,
        "total": 29
  2. Using an ID from the previous step, delete the OpenSCAP report. Repeat for each ID that you want to delete.
    Example request:
    $ curl \
    --request DELETE \
    https://foreman.example.com/api/v2/compliance/arf_reports/405
    Example response:
    HTTP/1.1 200 OK
    Date: Thu, 18 May 2024 07:14:36 GMT
    Server: Apache/2.4.6 (Enterprise Linux)
    X-Frame-Options: SAMEORIGIN
    X-XSS-Protection: 1; mode=block
    X-Content-Type-Options: nosniff
    Foreman_version: 3.11.0.76
    Foreman_api_version: 2
    Apipie-Checksum: 2d39dc59aed19120d2359f7515e10d76
    Cache-Control: max-age=0, private, must-revalidate
    X-Request-Id: f47eb877-35c7-41fe-b866-34274b56c506
    X-Runtime: 0.661831
    X-Powered-By: Phusion Passenger 4.0.18
    Set-Cookie: request_method=DELETE; path=/
    Set-Cookie: _session_id=d58fe2649e6788b87f46eabf8a461edd; path=/; secure; HttpOnly
    ETag: "2574955fc0afc47cb5394ce95553f428"
    Status: 200 OK
    Vary: Accept-Encoding
    Transfer-Encoding: chunked
    Content-Type: application/json; charset=utf-8
Example 1. Example BASH script to delete all OpenSCAP reports
#!/bin/bash
# this script removes all ARF reports from your Foreman server
# settings
USER="My_User_Name"
PASS="My_Password"
URI="https://foreman.example.com"
# check amount of reports
 while [ $(curl --user $USER:$PASS $URI/api/v2/compliance/arf_reports/ | python3 -m json.tool | grep \"\total\": | cut --fields=2 --delimiter":" | cut --fields=1 --delimiter"," | sed "s/ //g") -gt 0 ]; do
# fetch reports
 for i in $(curl --user $USER:$PASS $URI/api/v2/compliance/arf_reports/ | python3 -m json.tool | grep \"\id\": | cut --fields=2 --delimiter":" | cut --fields=1 --delimiter"," | sed "s/ //g")
# delete reports
  do
  curl --user $USER:$PASS --header "Content-Type: application/json" --request DELETE $URI/api/v2/compliance/arf_reports/$i
  done
done
Appendix A: API response codes
Table 1. API response codes
Response Explanation
200 OK
For a successful request action: show, index, update, or delete (GET, PUT, DELETE requests).
201 Created
For a successful create action (POST request).
301 Moved Permanently
Redirect when Foreman is restricted to use HTTPS and HTTP is attempted.
400 Bad Request
A required parameter is missing or the search query has invalid syntax.
401 Unauthorized
Failed to authorize the user, for example, due to incorrect credentials.
403 Forbidden
The user has insufficient permissions to perform the action or read the resource, or the action is unsupported in general.
404 Not Found
The record with the given ID does not exist. It can appear in show and delete actions when the requested record does not exist; or in create, update and delete actions when one of the associated records does not exist.
409 Conflict
Could not delete the record due to existing dependencies, for example, host groups that still contain hosts.
415 Unsupported Media Type
The content type of the HTTP request is not JSON.
422 Unprocessable Entity
Failed to create an entity due to some validation errors. Applies to create or update actions only.
500 Internal Server Error
Unexpected internal server error.
503 Service Unavailable
The server is not running.
Appendix B: Creating a complete permission table
Generate a complete permission table from the Foreman console to review all available permissions and actions on your Foreman.
  • The foreman-console package is installed on Foreman server.
  1. Start the Foreman console:
    # foreman-rake console
    end.join("\n")
    f.write(result)
    </table>
Unsupported version
