1. Introduction to Foreman
Foreman is a centralized tool for provisioning, content delivery, remote management, and monitoring of multiple Enterprise Linux deployments. With Foreman, you can deploy, configure, and maintain your systems across physical, virtual, and cloud environments.
2. Content and patch management with Foreman
With Foreman, you can provide content and apply patches to hosts systematically in all lifecycle stages.
2.1. Content flow in Foreman
Content flow in Foreman involves management and distribution of content from external sources to hosts.
Content in Foreman flows from external content sources to Foreman server. Smart Proxy servers mirror the content from Foreman server to hosts.
External content sources
You can configure many content sources with Foreman. The supported content sources include the Red Hat Customer Portal, custom Deb and Yum repositories, PyPI, Git repositories, Ansible collections, container registries, SCAP repositories, or internal data stores of your organization.
Foreman server
On your Foreman server, you plan and manage the content lifecycle.
Smart Proxy servers
By creating Smart Proxy servers, you can establish content sources in various locations based on your needs. For example, you can establish a content source for each geographical location or multiple content sources for a data center with separate networks.
Hosts
By assigning a host system to a Smart Proxy server or directly to your Foreman server, you ensure the host receives the content they provide. Hosts can be physical or virtual.
2.2. Content views in Foreman
    Default Organization View
Version of the content view
Version 2
Version 1
Version 1
Contents of the content view
my-software-1.1-0.noarch.rpm
my-software-1.0-0.noarch.rpm
Version 2
Version 2
Version 1
2.3. Lifecycle environments and environment paths
You can promote content along the environment path to the next lifecycle environment when required. When you promote a content view from one environment to the next environment in the application lifecycle, Foreman updates the repository and publishes the packages. For example, if development ends on a particular version of an application, you can promote this version to the testing environment and start development on the next version.
An environment path containing four environments
Figure 1. An environment path containing four environments
2.4. Content types in Foreman
You can import and manage various content types, such as packages and ISO images, in Foreman. Organize content from Red Hat, Canonical, Oracle, SUSE, or any custom content into products to streamline your software distribution.
RPM packages
Import RPM packages from any repository, for example from Amazon, Oracle, Red Hat, SUSE, and custom repositories. Foreman server downloads the RPM packages and stores them locally. You can use these repositories and their RPM packages in content views.
Deb packages
Kickstart trees
Provisioning templates
Templates to provision hosts running EL based on synchronized content and Debian, Ubuntu, or SUSE Linux Enterprise Server based on local installation media. Foreman contains predefined AutoYaST, Kickstart, and Preseed templates as well as the ability to create your own, which are used to provision systems and customize the installation.
ISO and KVM images
Download and manage media for installation and provisioning. For example, Foreman downloads, stores, and manages ISO images and guest images for specific Red Hat Enterprise Linux and non-Red Hat operating systems.
OSTree
Custom file type
3. Provisioning management with Foreman
3.1. Provisioning methods in Foreman
Network based
This method uses an operating system installer, such as Anaconda, Debian Installer, or YaST, and template-generated file with installation options downloaded from Foreman, such as Kickstart, Preseed, or AutoYaST.
PXE-less Discovery with kexec
Boot disk based
Image based
Figure 2. Choosing a provisioning method
4. Major Foreman components
A typical Foreman deployment consists of the following components: a Foreman server, Smart Proxy servers, and hosts that receive content and configuration from Foreman server and Smart Proxy servers.
4.1. Foreman server overview
Foreman server is the central component of a Foreman deployment.
  • Configuration of hosts
  • Host provisioning
  • Patch management
  • Subscription management
Foreman server delegates content distribution, host provisioning, and communication to Smart Proxy servers. Foreman server itself also includes a Smart Proxy.
4.2. Smart Proxy overview
  • Mirroring content from Foreman server to establish content sources in various geographical or logical locations. By registering a host to a Smart Proxy server, you can configure this host to receive content and configuration from the Smart Proxy in their location instead of from the central Foreman server.
By using content views, you can specify the exact subset of content that Smart Proxy server makes available to hosts.
4.3. Overview of hosts in Foreman
You can deploy virtual hosts on any platform supported by Foreman, such as Amazon EC2, Google Compute Engine, KVM, libvirt, Microsoft Azure, OpenStack, Proxmox, Rackspace Cloud Services, or VMware vSphere.
With Foreman, you can manage hosts at scale, including monitoring, provisioning, remote execution, subscription management, content management, and configuration management. You can also group hosts by using features such as host groups and host collections.
4.4. List of key open source components of Foreman
Foreman
Katello
Candlepin
Pulp
4.5. Smart Proxy features
Smart Proxy servers provide local host management services and can mirror content from Foreman server.
To mirror content from Foreman server, Smart Proxy servers provide the following functionalities:
Repository synchronization
Smart Proxy servers pull content for selected lifecycle environments from Foreman server and make this content available to the hosts they manage.
Content delivery
Hosts configured to use Smart Proxy server download content from that Smart Proxy rather than from Foreman server.
Host action delivery
Smart Proxy server executes scheduled actions on hosts.
Hosts are registered to their associated Smart Proxy servers rather than to the central Foreman server or the Red Hat Customer Portal.
You can use Smart Proxy to run the following services for infrastructure and host management:
DHCP
DNS
TFTP
Realm
Puppet server
Puppet Certificate Authority
Provisioning template proxy
OpenSCAP
Remote Execution (REX)
Infrastructure Smart Proxies: DNS + DHCP + TFTP
Smart Proxies with these services provide infrastructure services for hosts and have all necessary services for provisioning new hosts.
Content Smart Proxies: Pulp
Smart Proxies with this service provide content synchronized from Foreman server to hosts.
Configuration Smart Proxies: Pulp + Puppet + PuppetCA
Smart Proxies with these services provide content and run configuration services for hosts.
Smart Proxies with DNS + DHCP + TFTP + Pulp + Puppet + PuppetCA
Smart Proxies with these services provide a full set of Smart Proxy features. By configuring a Smart Proxy with all these features, you can isolate hosts assigned to that Smart Proxy by providing a single point of connection for the hosts.
5. Tools for administration of Foreman
5.1. Foreman web UI overview
5.2. Hammer CLI overview
5.3. Foreman API overview
You can write custom scripts and external applications that access the Foreman API over HTTP with the Representational State Transfer (REST) API provided by Foreman server.
  • Create client applications that require minimal knowledge of the Foreman infrastructure because users discover many details at runtime.
5.4. Remote execution in Foreman
5.5. Automating Foreman management with Foreman Ansible Collection
5.6. Kickstart workflow
You can automate the installation process of a Foreman server or Smart Proxy server by creating a Kickstart file that contains all the information that is required for the installation.
When you run a Foreman Kickstart script, the script performs the following actions:
  1. It specifies the installation location of a Foreman server or a Smart Proxy server.
  2. It installs the predefined packages.
  3. It installs Subscription Manager.
  4. It uses Activation Keys to subscribe the hosts to Foreman.
  5. It installs Puppet, and configures a puppet.conf file to indicate the Foreman or Smart Proxy instance.
  6. It enables Puppet to run and request a certificate.
  7. It runs user defined snippets.
6. Supported usage and versions of Foreman components
6.1. Foreman operating system
You can install Foreman on the following supported operating systems.
You can run Foreman server and Smart Proxy servers on Enterprise Linux 9, Debian 12, and Ubuntu 22.04. Katello plugin packages, which provide content management capabilities, are only available for Enterprise Linux.
6.2. Client operating systems
  • Amazon Linux
  • Debian
  • Fedora
  • OpenSUSE
  • SUSE Linux Enterprise Server
  • Ubuntu
  • Ansible
  • OpenSCAP
  • OpenSSH
  • Puppet
  • Salt
  • Katello host tools
  • Subscription Manager
  • Tracer utility
7. Security considerations in Foreman
Foreman supports multiple security mechanisms to provide additional layers of protection. Implementing these security features enhances the overall security of your Foreman deployment.
These security considerations apply to both Foreman server and Smart Proxy server environments.
Foreman supports running on FIPS-enabled Red Hat Enterprise Linux hosts to comply with security standards for cryptographic modules. However, Foreman itself is not FIPS-certified. In addition, you cannot enable FIPS mode after the installation of Foreman.
Foreman supports DEFAULT and FIPS crypto-policies. The FUTURE crypto-policy is not supported for Foreman server and Smart Proxy server installations. The FUTURE policy is a stricter forward-looking security level intended for testing a possible future policy.
By enabling fapolicyd on your Foreman server, you can monitor and control file and directory access, which provides an additional security layer.
This feature helps prevent unauthorized code execution and enhances system integrity. You can enable or disable fapolicyd on both Foreman server and Smart Proxy server at any time, depending on your security requirements.
Foreman community does not support PQC compatibility for Foreman.
Foreman requires SELinux, a mandatory access control system that restricts system access and reduces the risk of security vulnerabilities. SELinux enforces policies that define which processes can access specific system resources, providing protection against unauthorized access and exploitation.
To maintain a high-security environment, Foreman community recommends running Foreman with SELinux in enforcing mode. It ensures that access control policies are strictly enforced, minimizing the risk of privilege escalation or unauthorized actions.
8. Networking considerations in Foreman
For the components of Foreman architecture to communicate, the required network ports must be open to enable incoming and outgoing traffic between the components.
8.1. Smart Proxy networking
8.2. Foreman server port and firewall requirements
53
TCP and UDP
DNS
DNS Servers and clients
Name resolution
DNS (optional)
67
UDP
DHCP
Client
Dynamic IP
DHCP (optional)
69
UDP
TFTP
Client
TFTP Server (optional)
TCP
HTTPS
Smart Proxy
Foreman API
443, 80
TCP
HTTPS, HTTP
Client
Global Registration
Registering hosts to Foreman
Port 80 notifies Foreman on the /unattended/built endpoint that registration has finished
TCP
HTTPS
Foreman
Content Mirroring
Management
TCP
HTTPS
Foreman
Smart Proxy API
Smart Proxy functionality
443, 80
TCP
HTTPS, HTTP
Smart Proxy
Content Retrieval
Content
443, 80
TCP
HTTPS, HTTP
Client
Content Retrieval
Content
1883
TCP
MQTT
Client
Pull based REX (optional)
Content hosts for REX job notification (optional)
4505 – 4506
TCP
MQTT
Client
Salt (optional)
Salt Master to Salt Minions
5910 – 5930
TCP
HTTPS
Browsers
8000
TCP
HTTP
Client
8000
TCP
HTTPS
Client
PXE Boot
Installation
8140
TCP
HTTPS
Client
OpenVox agent
Client updates (optional)
9090
TCP
HTTPS
Foreman
Smart Proxy API
9090
TCP
HTTPS
Client
OpenSCAP
9090
TCP
HTTPS
Discovered Node
Discovery
9090
TCP
HTTPS
Client
9191
TCP
HTTPS
Client
Salt (optional)
Salt API
ICMP
ping
Client
DHCP
Free IP checking (optional)
7
TCP
echo
Client
DHCP
22
TCP
SSH
Target host
Remote execution
Run jobs
22, 16514
TCP
SSH SSH/TLS
Compute Resource
53
TCP and UDP
DNS
DNS Servers on the internet
DNS Server
53
TCP and UDP
DNS
DNS Server
Smart Proxy DNS
53
TCP and UDP
DNS
DNS Server
Orchestration
Validation of DNS conflicts
68
UDP
DHCP
Client
Dynamic IP
DHCP (optional)
80
TCP
HTTP
Remote repository
Content Sync
Remote repositories
389, 636
TCP
LDAP, LDAPS
External LDAP Server
LDAP
TCP
HTTPS
Compute resources
TCP
HTTPS
Smart Proxy
Content mirroring
Initiation
TCP
HTTPS
Infoblox DHCP Server
DHCP management
623
Client
Power management
BMC On/Off/Cycle/Status
5000
TCP
HTTPS
OpenStack Compute Resource
Compute resources
5900 – 5930
TCP
SSL/TLS
Hypervisor
noVNC console
Launch noVNC console
5985
TCP
HTTP
Client
WinRM
5986
TCP
HTTPS
Client
WinRM
7911
TCP
DHCP, OMAPI
DHCP Server
DHCP
8443
TCP
HTTPS
Client
Discovery
9090
TCP
HTTPS
Smart Proxy
Smart Proxy API
Management of Smart Proxies
8.3. Smart Proxy port and firewall requirements
53
TCP and UDP
DNS
Name resolution
DNS (optional)
67
UDP
DHCP
Client
Dynamic IP
DHCP (optional)
69
UDP
TFTP
Client
443, 80
TCP
HTTPS, HTTP
Client
Content Retrieval
Content
443, 80
TCP
HTTPS, HTTP
Client
Content Host Registration
Smart Proxy CA RPM installation
TCP
HTTPS
Foreman
Content Mirroring
Management
TCP
HTTPS
Foreman
Smart Proxy API
TCP
HTTPS
Client
Content Host registration
Initiation
Uploading facts
1883
TCP
MQTT
Client
8000
TCP
HTTP
Client
8000
TCP
HTTP
Client
PXE Boot
Installation
8140
TCP
HTTPS
Client
OpenVox agent
8443
TCP
HTTPS
Client
9090
TCP
HTTPS
Foreman
Smart Proxy API
9090
TCP
HTTPS
Client
Register Endpoint
9090
TCP
HTTPS
Client
OpenSCAP
9090
TCP
HTTPS
Discovered Node
Discovery
9090
TCP
HTTPS
Client
ICMP
ping
Client
DHCP
7
TCP
echo
Client
DHCP
22
TCP
SSH
Target host
Remote execution
Run jobs
53
TCP and UDP
DNS
DNS Server
53
TCP and UDP
DNS
DNS Server
Smart Proxy DNS
68
UDP
DHCP
Client
Dynamic IP
DHCP (optional)
TCP
HTTPS
Foreman
Smart Proxy
Smart Proxy
Configuration management
Template retrieval
OpenSCAP
TCP
HTTPS
Foreman
Content
Sync
TCP
HTTPS
Foreman
Client communication
Forward requests from Client to Foreman
TCP
HTTPS
DHCP management
623
Client
Power management
7911
TCP
DHCP, OMAPI
DHCP Server
DHCP
8443
TCP
HTTPS
Client
Discovery
9. Deployment path for Foreman
9.1. Installing a Foreman server
9.1.1. Configuring Foreman server with external database
  • High disk I/O workloads from frequent repository synchronization or content view publishing. This requires Foreman to create a record in PostgreSQL for each job.
  • High volume of hosts.
9.2. Configuring external authentication in Foreman
FreeIPA
Yes (Linux users only)
Quarkus-based Keycloak
Wildfly-based Keycloak
LDAP
9.3. Planning organization and location context
Organizations and locations enable you to arrange Foreman resources into logically structured groups. For example, you can create groups based on ownership, purpose, content, or security level. You can create and manage multiple organizations through Foreman, then divide and assign subscriptions to each individual organization.
Organizations
Organizations can represent different business units, departments, or teams, such as Finance, Marketing, or Web Development. To manage Red Hat content, each organization requires a separate Red Hat subscription manifest.
Locations
Foreman server defines all locations and organizations. Each Smart Proxy server synchronizes content and handles configuration of hosts in a different location.
Your Foreman server retains the management function, while the content and configuration is synchronized between your Foreman server and Smart Proxy servers assigned to certain locations.
Example 2. Example of using organizations and locations in Foreman
  • Finance
  • Marketing
  • Sales
  • United States
  • United Kingdom
  • Japan
  • Boston
  • Phoenix
  • San Francisco
9.4. Installing Smart Proxy servers
9.5. Adding a Red Hat subscription to Foreman
A Red Hat subscription manifest is a set of encrypted files that contains your subscription information. Adding a Red Hat subscription ensures you can use Red Hat content in your Foreman deployment.
If you want to manage hosts running Red Hat Enterprise Linux, import a Red Hat manifest.
Foreman server uses information from the Red Hat subscription manifest to access the Red Hat CDN and find what repositories are available for the associated subscription.
Warning
Deleting a subscription manifest removes all the subscriptions attached to running hosts and activation keys.
9.6. Defining your content library
To ensure that your Foreman server can manage software and provide it to your hosts, you must create repositories and synchronize them.
Your Foreman content library can include the following types of content:
Red Hat content
The Red Hat subscription manifest determines what Red Hat repositories your Foreman server can access. Red Hat content is already organized into products.
For example, Red Hat Enterprise Linux Server is a product in Foreman. The repositories for the Red Hat Enterprise Linux Server product consist of different versions, architectures, and add-ons. When you enable a Red Hat repository, Foreman automatically creates an associated product.
Oracle ULN content
You can use Foreman to manage hosts running Oracle Linux.
SUSE content
You can use Foreman to manage hosts running SUSE Linux Enterprise Server.
Ubuntu ESM content
You can use Foreman to manage hosts running Ubuntu.
Other sources of content
To distribute content from custom sources, you must create products and repositories manually. You can organize other content into products however you want.
For example, you can create an EPEL (Extra Packages for Enterprise Linux) product and add an "EPEL 9 x86_64" repository to it.
Creating repositories allows you to choose the specific software required for your environment. By creating only the necessary repositories, you avoid downloading unnecessary content.
Synchronizing repositories downloads the content from Red Hat CDN or another source to your Foreman server. The synchronized content is stored on your Foreman server, eliminating the need for hosts to access the repositories. You can synchronize repositories manually, or you can create a sync plan to ensure synchronization runs on a regular basis.
9.7. Defining content access strategies for hosts
When defining your content lifecycle in Foreman, you can use content views and lifecycle environments to define which hosts can access which content and content versions.
By default, Foreman includes the Default Organization View content view and the Library lifecycle environment.
The Default Organization View is the default content view in Foreman that contains all the content that is synchronized to Foreman. After you update your content, such as by adding or removing a repository, the update is immediately reflected in Default Organization View.
Library
The Library lifecycle environment is the default lifecycle environment in Foreman. Every newly published content view version is automatically published to the Library lifecycle environment. You can also promote specific content view versions to the Library lifecycle environment if needed.
9.8. Defining role-based access control policies
9.8.1. Roles in Foreman
9.8.2. Best practices for role-based access control in Foreman
When implementing role-based access control in Foreman, consider the following guidelines for optimal results.
  • Define the expected tasks and responsibilities: Define the subset of the Foreman infrastructure that you want the role to access as well as actions permitted on this subset. Think of the responsibilities of the role and how it differs from other roles.
  • Use predefined roles whenever possible: Foreman provides several sample roles that you can use. Copying and editing an existing role can be a good start for creating a custom role.
  • Consider areas of interest and granting read-only access: Even though a role has a limited area of responsibility, it might need a wider set of permissions. Therefore, you can grant the role a read-only access to parts of Foreman infrastructure that influence its area of responsibility.
9.9. Configuring provisioning
How do I back up?
How do I back up?
Store the following critical data on network attached storage: content in /var/lib/pulp and database in /var/lib/pgsql. Replicate this storage into a different data center. Attach the storage to a Foreman server that is a clone of the primary Foreman server but runs passively.
How do I back up?
Dual active Foreman server
How do I back up?
9.11. Additional deployment tasks
Load balancing
10. Common deployment scenarios
10.1. Single location with segregated subnets
10.2. Multiple locations
Create at least one Smart Proxy server per geographic location to save bandwidth by having hosts obtain content locally. Only your Smart Proxy server synchronizes content from remote repositories, making your provisioning infrastructure more reliable and easier to configure.
Foreman community recommends to create at least one Smart Proxy server per geographic location. This practice can save bandwidth since hosts obtain content from a local Smart Proxy server. Synchronization of content from remote repositories is done only by the Smart Proxy, not by each host in a location. In addition, this layout makes the provisioning infrastructure more reliable and easier to configure.
10.3. Content view scenarios
10.4. Foreman server with multiple manifests
You can use many Red Hat Network subscription manifests in one Foreman server to manage systems from different Red Hat Network accounts or entities. This allows you to assign subscriptions to separate organizations and manage those organizations independently.
If you plan to have more than one Red Hat Network account, or if you want to manage systems belonging to another entity that is also a Red Hat Network account holder, then you and the other account holder can assign subscriptions, as required, to manifests. A customer that does not have a Foreman subscription can create a Subscription Asset Manager manifest, which can be used with Foreman, if they have other valid subscriptions. You can then use the multiple manifests in one Foreman server to manage multiple organizations.
The following diagram shows two Red Hat Network account holders, who want their systems to be managed by the same Foreman installation. In this scenario, Example Corporation 1 can allocate any subset of their 60 subscriptions, in this example they have allocated 30, to a manifest. This can be imported into the Foreman as a distinct Organization. This allows system administrators the ability to manage Example Corporation 1’s systems using Foreman completely independently of Example Corporation 2’s organizations (R&D, Operations, and Engineering).
Figure 3. Foreman server with multiple manifests
  • Add the subscription for Foreman server to the manifest if planning a disconnected or self-registered Foreman server. This is not necessary for a connected Foreman server that is subscribed using the Subscription Manager utility on the base system.
  • Add subscriptions for all Smart Proxy servers you want to create.
  • Add subscriptions for all Red Hat products you want to manage with Foreman.
Foreman allows the use of future-dated subscriptions in the manifest. This enables uninterrupted access to repositories when future-dated subscriptions are added to a manifest before the expiry date of existing subscriptions.
Note that the Red Hat subscription manifest can be modified and reloaded to Foreman server in case of any changes in your infrastructure, or when adding more subscriptions. Manifests should not be deleted. If you delete the manifest from the Red Hat Customer Portal or in the Foreman web UI it will unregister all of your hosts.
10.5. Host group structures
Figure 4. Host group structuring examples
Flat structure
Application based structure
Location based structure
In this hierarchy, the distribution of locations is aligned with the host group structure. In a scenario where the location or Smart Proxy server topology determines many other attributes, this approach is the best option. However, this structure complicates sharing parameters across locations, therefore in complex environments with a large number of applications, the number of host group changes required for each configuration change increases significantly.
10.6. Inter-Server Synchronization scenarios
You can use Inter-Server Synchronization to synchronize content between Foreman servers, including air-gapped servers. In these scenarios, you copy selected content views or all Library content from an upstream server to downstream servers over a network or through physical export.
Foreman uses Inter-Server Synchronization (ISS) to synchronize content between two Foreman servers including those that are air gapped.
  • If you want to copy some but not all content from your Foreman server to other Foreman servers. For example, you have content views that your IT department consumes from Foreman server, and you want to copy content from those content views to other Foreman servers.
  • If you want to copy all Library content from your Foreman server to other Foreman servers. For example, you have products and repositories that your IT department consumes from Foreman server in the Library, and you want to copy all products and repositories in that organization to other Foreman servers.
You cannot use ISS to synchronize content from Foreman server to Smart Proxy server. Smart Proxy server supports synchronization natively.
  • The upstream Foreman server is connected to the internet. This server consumes content from the Red Hat Content Delivery Network (CDN) or custom sources.
  • The downstream Foreman server is completely isolated from all external networks.
  • The downstream Foreman server can communicate with a connected upstream Foreman server over an internal network.
Foreman ISS disconnected scenario
Figure 5. Foreman ISS disconnected scenario
You can configure your downstream Foreman server to synchronize content from the upstream Foreman server over the network.
  • The upstream Foreman server is connected to the internet. This server consumes content from the Red Hat CDN or custom sources.
  • The downstream Foreman server does not have a network connection to a connected upstream Foreman server.
The Foreman ISS air-gapped scenario
Figure 6. Foreman ISS air-gapped scenario
The only way for an air-gapped downstream Foreman server to receive content updates is by exporting payload from the upstream Foreman server, bringing it physically to the downstream Foreman server, and importing the payload.
You can configure your downstream Foreman server to synchronize content by using exports.
10.7. Deploying Foreman on AWS
One-region setup
One-region setup
Figure 7. One-region setup
Figure 8. Site-to-site VPN connection between the AWS region and the on-premises data center
Figure 9. Direct connection using the external DNS host name
Connecting different regions
Figure 10. Site-to-site VPN connection between AWS regions
Figure 11. Direct connection using the external DNS host name
11. Provisioning requirements in Foreman
11.1. PXE booting in Foreman
PXE sequence
PXE booting requirements
  • Network requirements:
  • Client requirements:
  • Foreman requirements:
11.2. HTTP booting in Foreman
    • The TCP port 9090 is open for the client to download the boot loader from the Smart Proxy using the HTTPS protocol.
      • https://smartproxy.example.com:9090
    • Ensure that the TCP port 9090 is open for the client to download the boot loader from the Smart Proxy through HTTPS.
11.3. Secure Boot in Foreman
# reboot
foreman
N/A
foreman
N/A
yes
/usr/share/foreman
/sbin/nologin
foreman-proxy
N/A
foreman-proxy
N/A
yes
/usr/share/foreman-proxy
/sbin/nologin
apache
48
apache
48
no
/usr/share/httpd
/sbin/nologin
postgres
26
postgres
26
no
/var/lib/pgsql
/bin/bash
pulp
N/A
pulp
N/A
no
N/A
/sbin/nologin
puppet
52
puppet
52
no
/sbin/nologin
saslauth
N/A
saslauth
76
no
/run/saslauthd
/sbin/nologin
tomcat
53
tomcat
53
no
/usr/share/tomcat
/bin/nologin
unbound
N/A
unbound
N/A
yes
/etc/unbound
/sbin/nologin
Activation key
Activation keys are used by Subscription Manager to register hosts to Foreman. They define content view and lifecycle environment associations, content overrides, system purpose attributes, and other parameters to be associated with a newly created host.
They are associated to exactly one lifecycle environment and exactly one content view, though this may be a composite content view. You can use them on multiple machines and they behave like configuration information rather than traditional software license keys. You can also use multiple activation keys with a single host. When you register a host using an activation key, certain content from Foreman is provided to the host. The content that is made available depends on the content in the activation key’s content view and lifecycle environment, any content overrides present, any repository-level restrictions such as operating system or architecture, and system purpose attributes such as release version.
Activation key
Ansible
Answer file
ARF report
Audits
Boot disk
Catalog
Candlepin
Compliance policy
Compute profile
Compute resource
Configuration Management
Container (Docker container)
Container image
Content
A general term for everything Foreman distributes to hosts. Content includes software packages such as .rpm packages, errata, or Docker images. Content is synchronized into the Library and then promoted into lifecycle environments using content views so that they can be consumed by hosts.
The mechanism used to deliver Red Hat content to Foreman server.
Content view
Content views are named and versioned collections of repositories. When you publish a content view, Foreman creates a new content view version. This content view version is a frozen snapshot of the current state of the repositories within the content view. Any subsequent changes to the underlying repositories will no longer affect the published content view version. Once a content view is published, it can be promoted through the lifecycle environment path, or modified using incremental upgrades.
Composite content view
Discovered host
Discovery image
Discovery plugin
Enables automatic bare-metal discovery of unknown hosts on the provisioning network. The plugin consists of three components: services running on Foreman server and Smart Proxy server, and the Discovery image running on host.
Discovery rule
Docker tag
Enterprise Linux
  • AlmaLinux
  • CentOS Linux
  • CentOS Stream
  • Oracle Linux
  • Red Hat Enterprise Linux
  • Rocky Linux
ERB
Errata
Facter
Facts
Foreman
Full host image
Generic image
Hammer
Host
Host collection
Host group
Host image
Installation Media
Installation media are sets of installation files used to install the base operating system during the provisioning process. An installation medium in Foreman represents the installation files for one or more operating systems, which must be accessible over the network, either through an URL or an NFS server location. It is usually either a mirror or a CD or DVD image.
Job
Katello
Katello is an open-source plugin to perform content management and subscription handling. It depends on Pulp for content management, which fetches software from repositories and stores various versions of it. It also depends on Candlepin for host registration and managing subscription manifests.
Lazy sync
Location
Library
A container for content from all synchronized repositories on Foreman server. Libraries exist by default for each organization as the root of every lifecycle environment path and the source of content for every content view.
Lifecycle environment path
A mechanism for transferring subscriptions from the Red Hat Customer Portal to Foreman. Do not confuse with Puppet manifest.
Migrating Foreman
OpenSCAP
Organization
Parameter
Patch and release management
Patch and release management describes the process of acquiring, managing, and installing patches and software updates to your infrastructure. Using Foreman, you can keep control of the package versions available to your hosts and deliver applicable errata.
Permission
Product
Products are named collections of one or more repositories. If you manage Red Hat content and upload a Red Hat manifest, Foreman automatically groups Red Hat content within products. If you manage SUSE content using SCC Manager plugin, Foreman automatically groups SUSE content within products. For more information, see Managing SUSE content in Managing content.
Promote (a content view)
Provisioning
  • AutoYaST for SUSE Linux Enterprise Server
  • Kickstart for AlmaLinux, Amazon Linux, CentOS, Oracle Linux, Red Hat Enterprise Linux, and Rocky Linux
  • Preseed files for Debian and Ubuntu
Publish (a content view)
Pulp
Puppet
OpenVox agent
Puppet environment
Puppet manifest
OpenVox server
Puppet module
PXE
Recurring logic
Registry
Remote execution (REX)
Repository
A repository is a single source and the smallest unit of content in Foreman. You can either synchronize a repository with a URL or manually upload content to Foreman. Foreman supports multiple content types. For more information, see Content types in Foreman in Managing content. One or more repositories form a product.
Resource type
Role
Salt
SCAP content
Smart Proxy server
Smart Proxy servers can provide DHCP, DNS, and TFTP services and act as an Ansible control node, OpenVox server, or Salt Master in separate networks. They interact with Foreman server in a client-server model. Foreman server always comes bundled with an integrated Smart Proxy.
Subnet image
Subscription
Subscription Manager is a client application to register hosts to Foreman. subscription-manager uses activation keys to consume content on hosts.
SUSE Subscription
You can use Foreman to manage SUSE content. For more information, see Managing SUSE content in Managing content.
Synchronization
Synchronization describes the process of fetching content from external repositories into the Foreman server.
Sync plan
Tailoring files
Task
Trend
Updating Foreman
The process of advancing your Foreman server and Smart Proxy server installations from one patch release to the next, for example Foreman 3.16.0 to Foreman 3.16.1.
Upgrading Foreman
The process of advancing your Foreman server and Smart Proxy server installations from one minor release to the next, for example Foreman 3.15 to Foreman 3.16.
User group
User
Virtualization
virt-who
XCCDF profiles
Unsupported version
