1. Metrics overview
You can set up a third-party solution to collect live metrics from Foreman server, archive them for a fixed period of time, and analyze them. Obtaining metrics from Foreman is useful for capacity planning and troubleshooting performance issues.
  • Basic statistics from the operating system, including system load, memory utilization, and input/output operations
  • Process statistics, including memory and CPU utilization
  • Apache HTTP Server activity statistics
  • PostgreSQL activity statistics
  • Foreman application statistics
Performance Co-Pilot (PCP)
Performance Metric Domain Agents (PMDA)
Install PCP packages and configure PCP data collection. You can use the PCP CLI tools to retrieve metrics in the command line.
3.1. Installing PCP
Install the PCP packages on your Foreman server and enable PCP daemons.
  • Ensure you have the minimum of 20 GB space available in the /var/log/pcp directory.
    With the default PCP data retention settings, data storage is estimated to use between 100 MB and 500 MB of disk space per day, but might use up to several gigabytes over time. For more information, see Metrics data retention.
  1. Install the PCP packages:
    # apt install pcp \
    foreman-pcp
  2. Enable and start the Performance Metrics Collector daemon and Performance Metrics Logger daemon:
  1. Symlink the Foreman specific configuration to PMDA process monitoring:
    • Java
    • PostgreSQL
    • Redis
    • Dynflow
    • Puma
  2. Install the process monitoring PMDA:
    # cd /var/lib/pcp/pmdas/proc
    # ./Install
  3. Configure PCP to collect metrics from Apache HTTP Server.
    1. Enable the Apache HTTP Server extended status module:
    2. Enable the Apache HTTP Server PMDA:
      # cd /var/lib/pcp/pmdas/apache
      # ./Install
  4. Configure PCP to collect metrics from PostgreSQL:
    # cd /var/lib/pcp/pmdas/postgresql
    # ./Install
  5. Configure PCP to collect metrics from Redis:
    # cd /var/lib/pcp/pmdas/redis
    # ./Install
  6. Enable the telemetry feature in Foreman:
  7. Configure PCP to collect data from Foreman:
    # cd /var/lib/pcp/pmdas/openmetrics
    # echo "https://foreman.example.com/metrics" > config.d/foreman.url
    # ./Install
  8. Restart PCP to begin data collection:
  • Print a summary of the active PCP configuration:
    # pcp
    Example output of the pcp command:
    Performance Co-Pilot configuration on foreman.example.com:
     platform: Linux foreman.example.com 4.18.0-372.32.1.el8_6.x86_64 #1 SMP Fri Oct 7 12:35:10 EDT 2022 x86_64
     hardware: 16 cpus, 2 disks, 1 node, 31895MB RAM
     timezone: UTC
     services: pmcd pmproxy
         pmcd: Version 5.3.7-17, 13 agents, 4 clients
         pmda: root pmcd proc pmproxy xfs redis linux apache mmv kvm
               postgresql jbd2 openmetrics
     pmlogger: primary logger: /var/log/pcp/pmlogger/foreman.example.com/20230831.00.10
         pmie: primary engine: /var/log/pcp/pmie/foreman.example.com/pmie.log
    In this example, both the Performance Metrics Collector Daemon (pmcd) and Performance Metrics Proxy Daemon (pmproxy) services are running. It also confirms the PMDA that are collecting metrics. Finally, it lists the active log file, in which pmlogger is currently storing metrics.
4. Metrics data retention
  • The logged metrics
  • The logging interval
  • The retention policy
  1. Open the /etc/pcp/pmlogger/control.d/local configuration file.
  2. Locate the LOCALHOSTNAME line.
  3. Append -t XXs, where XX is the required time interval in seconds.
  4. Save the file.
  5. Restart the pmlogger service:
    # systemctl restart pmlogger
  1. Open the /etc/default/pmlogger_timers file.
  2. Locate the PMLOGGER_DAILY_PARAMS line.
  3. If the line is commented, uncomment the line.
  4. Configure the following parameters:
    • Ensure the default -E parameter is present.
    • Append the -x parameter and add a value for the required number of days after which data is archived.
    • Append the -k parameter and add a value for the number of days after which data is deleted.
    For example, the parameters -x 4 -k 7 specify that data will be compressed after 4 days and deleted after 7 days.
  5. Save the file.
Example storage statistics:
  • On your Foreman server, view data storage statistics:
5. PCP metrics
Metrics are stored in a tree-like structure. For example, all network metrics are stored in a node named network. Each metric can be a single value, or a list of values, known as instances. For example, kernel load has three instances, a 1-minute, 5-minute, and 15-minute average.
Metric Description
hotproc.*
Basic metrics of key Foreman processes
apache.*
Apache HTTP Server metrics
postgresql.*
Basic PostgreSQL statistics
openmetrics.foreman.fm_rails_*
Foreman metrics
You can use the PCP CLI tools to identify available metrics.
  • List all metrics available through PCP:
    # pminfo
  • List all Foreman metrics and their descriptions:
  • List the archived metrics:
  • The pmlogger daemon archives data as received, according to its configuration. Retrieve the name of the active log file:
    # pcp | grep logger
5.2. Retrieving live metrics
  • To print current values of a particular metric, enter the following command:
    In this example, metric instances on writes to disk partitions are displayed. PCP converts the number of writes to disk partitions from a counter value to a rate value. The -f 1 argument specifies to abbreviate the values to one decimal place.
    Example output:
    metric:    disk.partitions.write
    host:      foreman.example.com
    semantics: cumulative counter (converting to rate)
    units:     count (converting to count / sec)
    samples:   all
                     vda1                  vda2                   sr0
                      0.0                  12.0                   0.0
                      0.0                   1.0                   0.0
                      0.0                   1.0                   0.0
                      0.0                   2.0                   0.0
  • To print system performance summary every 2 seconds, enter the following command:
    # pmstat -t 2sec
  • List all metrics that were enabled when the archive file was created:
  • View the host and time period covered by an archive file:
    # pmdumplog -l archive_file
  • List disk writes for each partition, over the time period covered by the archive file:
    # pmval --archive /var/log/pcp/pmlogger/foreman.example.com/20230831.00.10 \
  • List disk write operations per partition, with a 2-second interval, over the time period between 14:00 and 14:15:
      -d -t 2sec \
      -f 3 disk.partitions.write \
      -S @14:00 -T @14:15
  • List average values of all performance metrics, including the time and value of the minimum/maximum, over the time period between 14:00 and 14:30, and format the values as a table:
    # pmlogsummary /var/log/pcp/pmlogger/foreman.example.com/20230831.00.10 \
      -HlfiImM \
      -S @14:00 \
      -T @14:30 \
      mem.freemem
  • Display system metrics stored in an archive, starting from 14:00, in an interactive manner similar to the top tool:
    # pcp --archive /var/log/pcp/pmlogger/foreman.example.com/20230831.00.10 \
      -S @14:00 \
      atop
Unsupported version
