1. Foreman overview and concepts
Foreman is a centralized tool for provisioning, remote management, and monitoring of multiple Enterprise Linux deployments. With Foreman, you can deploy, configure, and maintain your systems across physical, virtual, and cloud environments.
2. Content and patch management with Foreman
With Foreman, you can provide content and apply patches to hosts systematically in all lifecycle stages.
2.1. Content flow in Foreman
Content flow in Foreman involves management and distribution of content from external sources to hosts.
Content in Foreman flows from external content sources to Foreman server. Smart Proxy servers mirror the content from Foreman server to hosts.
- External content sources
You can configure many content sources with Foreman. The supported content sources include the Red Hat Customer Portal, Git repositories, Ansible collections, Docker Hub, SCAP repositories, or internal data stores of your organization.
- Foreman server
On your Foreman server, you plan and manage the content lifecycle.
- Smart Proxy servers
By creating Smart Proxy servers, you can establish content sources in various locations based on your needs. For example, you can establish a content source for each geographical location or multiple content sources for a data center with separate networks.
- Hosts
By assigning a host system to a Smart Proxy server or directly to your Foreman server, you ensure the host receives the content they provide. Hosts can be physical or virtual.
See Major Foreman components for details.
2.2. Content views in Foreman
A content view is a deliberately curated subset of content that your hosts can access. By creating a content view, you can define the software versions used by a particular environment or Smart Proxy server.
Each content view creates a set of repositories across each environment. Your Foreman server stores and manages these repositories. For example, you can create content views in the following ways:
A content view with older package versions for a production environment and another content view with newer package versions for a Development environment.
A content view with a package repository required by an operating system and another content view with a package repository required by an application.
A composite content view for a modular approach to managing content views. For example, you can use one content view for content for managing an operating system and another content view for content for managing an application. By creating a composite content view that combines both content views, you create a new repository that merges the repositories from each of the content views. However, the repositories for the content views still exist and you can keep managing them separately as well.
You can access unprotected repositories in the Default Organization View content view.
The URL consists of your Smart Proxy FQDN, /pulp/content/, your organization label, /Library/custom/, your product label, /, your repository label, and a trailing /, for example, https://foreman.example.com/pulp/content/Example/Library/custom/AlmaLinux_9/BaseOS/.
| Development | Testing | Production | |
Version of the content view |
Version 2 |
Version 1 |
Version 1 |
Contents of the content view |
my-software-1.1-0.noarch.rpm |
my-software-1.0-0.noarch.rpm |
Version 2 |
Version 2 |
Version 1 |
With Distribute archived content view versions enabled, you can access unprotected repositories in published content view versions.
The URL consists of your Smart Proxy FQDN, /pulp/content/, your organization label, /content_views/, your content view, your content view version, /custom/, your product label, /, your repository label, and a trailing /, for example, https://foreman.example.com/pulp/content/Example/content_views/AlmaLinux_9/2.1/custom/AlmaLinux_9/BaseOS/.
If you want to access the latest published content view, the URL consists of your Smart Proxy FQDN, /pulp/content/, your organization label, your lifecycle, your content view, /custom/, your product label, /, your repository label, and a trailing /, for example, https://foreman.example.com/pulp/content/Example/Production/AlmaLinux_9/custom/AlmaLinux_9/AlmaLinux_9/.
For more information, see Managing content views in Managing content.
2.3. Lifecycle environments and environment paths
You can promote content along the environment path to the next lifecycle environment when required. When you promote a content view from one environment to the next environment in the application lifecycle, Foreman updates the repository and publishes the packages. For example, if development ends on a particular version of an application, you can promote this version to the testing environment and start development on the next version.
2.4. Content types in Foreman
With Foreman, you can import and manage many content types.
- RPM packages
Import RPM packages from any repository, for example from Amazon, Oracle, Red Hat, SUSE, and custom repositories. Foreman server downloads the RPM packages and stores them locally. You can use these repositories and their RPM packages in content views.
- Deb packages
- Kickstart trees
- Provisioning templates
Templates to provision hosts running EL based on synchronized content and Debian, Ubuntu, or SUSE Linux Enterprise Server based on local installation media. Foreman contains predefined AutoYaST, Kickstart, and Preseed templates as well as the ability to create your own, which are used to provision systems and customize the installation.
- ISO and KVM images
Download and manage media for installation and provisioning. For example, Foreman downloads, stores, and manages ISO images and guest images for specific Red Hat Enterprise Linux and non-Red Hat operating systems.
- OSTree
- Custom file type
2.5. Sources of content in Foreman
With Foreman, you can use content from Red Hat as well as from Canonical, Oracle, SUSE, and other custom content.
- Red Hat content
The Red Hat subscription manifest determines what Red Hat repositories your Foreman server can access. Red Hat content is already organized into products.
For example, Red Hat Enterprise Linux Server is a product in Foreman. The repositories for the Red Hat Enterprise Linux Server product consist of different versions, architectures, and add-ons. When you enable a Red Hat repository, Foreman automatically creates an associated product.
- Other sources of content
To distribute content from custom sources, you must create products and repositories manually. You can organize other content into products however you want.
For example, you can create an EPEL (Extra Packages for Enterprise Linux) product and add an "EPEL 9 x86_64" repository to it.
2.6. Additional resources
For information about how to manage content with Foreman, see Managing content.
3. Provisioning management with Foreman
3.1. Provisioning methods in Foreman
With Foreman, you can provision hosts by using the following methods.
- Bare-metal hosts
Foreman provisions bare-metal hosts primarily by using PXE boot and MAC address identification. When provisioning bare-metal hosts with Foreman, you can do the following:
Create host entries and specify the MAC address of the physical host to provision.
Boot blank hosts to use the Foreman Discovery service, which creates a pool of hosts that are ready for provisioning.
Boot and provision hosts by using PXE-less methods.
- Cloud providers
Foreman connects to private and public cloud providers to provision instances of hosts from images stored in the cloud environment. When provisioning from cloud with Foreman, you can do the following:
Select which hardware profile to use.
Provision cloud instances from specific providers by using their APIs.
- Virtualization infrastructure
Foreman connects to virtualization infrastructure services, such as oVirt and VMware. When provisioning virtual machines with Foreman, you can do the following:
Provision virtual machines from virtual image templates.
Use the same PXE-based boot methods that you use to provision bare-metal hosts.
3.2. Additional resources
For information about how to provision hosts with Foreman, see Provisioning hosts.
4. Major Foreman components
A typical Foreman deployment consists of the following components: a Foreman server, Smart Proxy servers that mirror content from Foreman server, and hosts that receive content and configuration from Foreman server and Smart Proxy servers.
4.1. Foreman Server overview
Foreman server is the central component of a Foreman deployment where you plan and manage the content lifecycle.
A typical Foreman deployment includes one Foreman server on which you perform the following operations:
Content lifecycle management
Configuration of Smart Proxy servers
Configuration of hosts
Host provisioning
Patch management
Subscription management
Foreman server delegates content distribution, host provisioning, and communication to Smart Proxy servers. Foreman server itself also includes a Smart Proxy.
Foreman server also contains a fine-grained authentication system. You can grant Foreman users permissions to access precisely the parts of the infrastructure for which they are responsible.
For more information about managing permissions, see Managing Users and Roles in Administering Foreman.
4.2. Smart Proxy overview
With Smart Proxy servers, you can extend the reach and scalability of your Foreman deployment. Smart Proxy servers provide the following functionalities in a Foreman deployment:
Mirroring content from Foreman server to establish content sources in various geographical or logical locations. By registering a host to a Smart Proxy server, you can configure this host to receive content and configuration from the Smart Proxy in their location instead of from the central Foreman server.
Running localized services to discover, provision, control, and configure hosts.
By using content views, you can specify the exact subset of content that Smart Proxy server makes available to hosts. For more information, see Content and patch management with Foreman.
4.3. Overview of hosts in Foreman
With Foreman, you can manage hosts at scale, including monitoring, provisioning, remote execution, configuration management, software management, and subscription management.
4.4. List of key open source components of Foreman Server
- Foreman
- Katello
- Candlepin
- Pulp
4.5. Smart Proxy features
Smart Proxy servers provide local host management services. With the Katello plugin, they can also mirror content from Foreman server.
If you have the Katello plugin installed, you can use Smart Proxy to mirror content from Foreman server:
- Repository synchronization
Smart Proxy servers pull content for selected lifecycle environments from Foreman server and make this content available to the hosts they manage.
- Content delivery
Hosts configured to use Smart Proxy server download content from that Smart Proxy rather than from Foreman server.
- Host action delivery
Smart Proxy server executes scheduled actions on hosts.
- Red Hat Subscription Management (RHSM) proxy
Hosts are registered to their associated Smart Proxy servers rather than to the central Foreman server or the Red Hat Customer Portal.
You can use Smart Proxy to run the following services for infrastructure and host management:
- DHCP
Smart Proxy can manage a DHCP server, including integration with an existing solution, such as ISC DHCP servers, Active Directory, and Libvirt instances.
- DNS
Smart Proxy can manage a DNS server, including integration with an existing solution, such as ISC BIND and Active Directory.
- TFTP
Smart Proxy can integrate with any UNIX-based TFTP server.
- Realm
Smart Proxy can manage Kerberos realms or domains so that hosts can join them automatically during provisioning. Smart Proxy can integrate with an existing infrastructure, including FreeIPA and Active Directory.
- Puppet server
Smart Proxy can act as a configuration management server by running an OpenVox server.
- Puppet Certificate Authority
Smart Proxy can integrate with the Puppet certificate authority (CA) to provide certificates to hosts.
Smart Proxy can provide power management for hosts by using the Intelligent Platform Management Interface (IPMI) or Redfish standards.
- Provisioning template proxy
Smart Proxy can serve provisioning templates to hosts.
- OpenSCAP
Smart Proxy can perform security compliance scans on hosts.
- Remote Execution (REX)
Smart Proxy can run remote job execution on hosts.
You can configure a Smart Proxy server for a specific limited purpose by enabling only selected features on that Smart Proxy. Common configurations include the following:
- Infrastructure Smart Proxies: DNS + DHCP + TFTP
Smart Proxies with these services provide infrastructure services for hosts and have all necessary services for provisioning new hosts.
- Content Smart Proxies: Pulp
Smart Proxies with this service provide content synchronized from Foreman server to hosts.
- Configuration Smart Proxies: Pulp + Puppet + PuppetCA
Smart Proxies with these services provide content and run configuration services for hosts.
- Smart Proxies with DNS + DHCP + TFTP + Pulp + Puppet + PuppetCA
Smart Proxies with these services provide a full set of Smart Proxy features. By configuring a Smart Proxy with all these features, you can isolate hosts assigned to that Smart Proxy by providing a single point of connection for the hosts.
4.6. Smart Proxy networking
The communication between Foreman server and hosts registered to a Smart Proxy server is routed through that Smart Proxy server. Smart Proxy server also provides Foreman services to hosts.
Many of the services that Smart Proxy server manages use dedicated network ports. However, Smart Proxy server ensures that all communications from the host to Foreman server use a single source IP address, which simplifies firewall administration.
In this topology, Smart Proxy provides a single endpoint for all host network communications so that in remote network segments, only firewall ports to the Smart Proxy itself must be open.
In this topology, hosts connect to Foreman server rather than a Smart Proxy. This applies also to Smart Proxies themselves because the Smart Proxy server is a host of Foreman server.
You can find complete instructions for configuring the host-based firewall to open the required ports in the following documents:
Ports and Firewalls Requirements in Installing Foreman Server with Katello 4.15 plugin on Enterprise Linux
Ports and Firewalls Requirements in Installing a Smart Proxy Server 3.13 on Enterprise Linux
4.7. Additional resources
See Installing a Smart Proxy Server 3.13 on Enterprise Linux for details on Smart Proxy server requirements, installation, and scalability considerations.
See Configuring Smart Proxies with a load balancer for details on distributing load among Smart Proxy servers.
5. Foreman infrastructure organization concepts
You can use several elements to structure and organize the resources within your Foreman environment.
5.1. Organizations and locations in Foreman
On your Foreman server, you can define organizations and locations to help organize content, hosts, and configurations. Organizations and locations enable you to arrange Foreman resources into logically structured groups. For example, you can create groups based on ownership, purpose, content, or security level. You can create and manage multiple organizations through Foreman, then divide and assign subscriptions to each individual organization.
- Organizations
Organizations typically represent different business units, departments, or teams, such as Finance, Marketing, or Web Development. Each organization requires a separate Red Hat subscription manifest.
- Locations
Locations typically represent physical locations, such as countries or cities.
You can use locations to map the network infrastructure to prevent incorrect host placement or configuration. While you cannot assign a subnet, domain, or compute resources directly to a Smart Proxy server, you can assign them to a location.
Unlike organizations, locations can have a hierarchical structure.
Foreman server defines all locations and organizations. Each Smart Proxy server synchronizes content and handles configuration of hosts in a different location.
Your Foreman server retains the management function, while the content and configuration is synchronized between your Foreman server and Smart Proxy servers assigned to certain locations.
The system administrator creates the following organizations on their Foreman server:
Finance
Marketing
Sales
Additionally, the administrator creates the following locations on their Foreman server:
United States
United Kingdom
Japan
Boston
Phoenix
San Francisco
5.2. Host groups overview
A host group acts as a template for common host settings.
With host groups, you can define many settings for hosts, such as lifecycle environment, content view, or Ansible roles that are available to the hosts. Instead of defining the settings individually for each host, you can use host groups to define common settings once and apply them to multiple hosts.
When you change the settings of an existing host group, the new settings do not propagate to the hosts assigned to the host group. Only Puppet class settings get updated on hosts after you change them in the host group. |
5.3. Host collections overview
A host collection is a group of content hosts.
With host collections, you can perform the same action on multiple hosts at once. These actions include installing, removing, and updating packages and errata, and assigning content view environments.
For example, you can use host collections to group hosts by function, department, or business unit.
5.4. Additional resources
For examples of Foreman deployment, see Foreman deployment planning.
6. Tools for administration of Foreman
6.1. Foreman web UI overview
You can manage and monitor your Foreman infrastructure from a browser with the Foreman web UI. For example, you can use the following navigation features in the Foreman web UI:
| Navigation feature | Description |
Organization dropdown |
Choose the organization you want to manage. |
Location dropdown |
Choose the location you want to manage. |
Monitor |
Content |
Provides content management tools. This includes content views, activation keys, and lifecycle environments. |
Hosts |
Configure |
Provides general configuration tools and data, including host groups and Ansible content. |
Infrastructure |
Provides tools on configuring how Foreman interacts with the environment. |
Administer |
Provides advanced configuration for settings such as users, role-based access control (RBAC), and general settings. |
6.2. Hammer CLI overview
You can configure and manage your Foreman server with CLI commands by using Hammer.
Create shell scripts based on Hammer commands for basic task automation.
Redirect output from Hammer to other tools.
Use the
--debugoption with Hammer to test responses to API calls before applying the API calls in a script. For example:hammer --debug organization list.
To issue Hammer commands, a user must have access to your Foreman server.
To ensure a user-friendly and intuitive experience, the Foreman web UI takes priority when developing new functionality. Therefore, some features that are available in the Foreman web UI might not yet be available for Hammer. |
See Using the Hammer CLI tool for details on using Hammer CLI.
6.3. Foreman API overview
You can write custom scripts and external applications that access the Foreman API over HTTP with the Representational State Transfer (REST) API provided by Foreman server. Use the REST API to integrate with enterprise IT systems and third-party applications, perform automated maintenance or error checking tasks, and automate repetitive tasks with scripts.
Configure any programming language, framework, or system with support for HTTP protocol to use the API.
Create client applications that require minimal knowledge of the Foreman infrastructure because users discover many details at runtime.
Adopt the resource-based REST model for intuitively managing a virtualization platform.
API commands differ between versions of Foreman. When you prepare to upgrade Foreman server, update all the scripts that contain Foreman API commands. |
See Using the Foreman REST API for details on using the Foreman API.
6.4. Remote execution in Foreman
With remote execution, you can run jobs on hosts from Smart Proxies by using shell scripts or Ansible roles and playbooks.
Run jobs on multiple hosts at once.
Use variables in your commands for more granular control over the jobs you run.
Use host facts and parameters to populate the variable values.
Specify custom values for templates when you run the command.
Communication for remote execution occurs through Smart Proxy server, which means that Foreman server does not require direct access to the target host, and can scale to manage many hosts.
Foreman uses ERB syntax job templates. For more information, see Template Writing Reference in Managing hosts.
See Configuring and Setting Up Remote Jobs in Configuring hosts by using Ansible.
6.5. Managing Foreman with Ansible
Foreman Ansible Collections is a set of Ansible modules that interact with the Foreman API. You can manage and automate many aspects of Foreman with Foreman Ansible collections.
For more information about using Ansible to configure hosts, see Configuring hosts by using Ansible.
For more information about automating Foreman using Ansible, see Managing Foreman with Ansible in Administering Foreman.
6.6. Kickstart workflow
You can automate the installation process of a Foreman server or Smart Proxy server by creating a Kickstart file that contains all the information that is required for the installation.
When you run a Foreman Kickstart script, the script performs the following actions:
For more information about Kickstart, see Automated installation workflow in Automatically installing RHEL 9.
7. Supported usage and versions of Foreman components
7.1. Foreman server operating system
Foreman has packages for Enterprise Linux 9, Debian 11, Debian 12 and Ubuntu 22.04. Katello plugin packages, which provide content management capabilities, are only available for Enterprise Linux.
7.2. Client operating systems
Using Foreman, you can manage multiple operating systems that have Foreman clients:
Amazon Linux
Debian
Enterprise Linux 9 and 8
Fedora
OpenSUSE
Ubuntu
Ansible
OpenSCAP
OpenSSH
Puppet
Salt
Windows Remote Management (WinRM)
Operating system installers that can perform unattended installations, such as Anaconda or Debian-installer
Katello host tools
Tracer utility
9. Common deployment scenarios
9.1. Single location
An integrated Smart Proxy is a virtual Smart Proxy server that is created by default in Foreman server during the installation process. This means Foreman server can be used to provision directly connected hosts for Foreman deployment in a single geographical location, therefore only one physical server is needed. The base systems of isolated Smart Proxies can be directly managed by Foreman server, however it is not recommended to use this layout to manage other hosts in remote locations.
9.2. Single location with segregated subnets
Your infrastructure might require multiple isolated subnets even if Foreman is deployed in a single geographic location. This can be achieved for example by deploying multiple Smart Proxy servers with DHCP and DNS services, but the recommended way is to create segregated subnets using a single Smart Proxy. This Smart Proxy is then used to manage hosts and compute resources in those segregated networks to ensure they only have to access the Smart Proxy for provisioning, configuration, errata, and general management. For more information on configuring subnets see Managing Hosts.
9.3. Multiple locations
It is recommended to create at least one Smart Proxy server per geographic location. This practice can save bandwidth since hosts obtain content from a local Smart Proxy server. Synchronization of content from remote repositories is done only by the Smart Proxy, not by each host in a location. In addition, this layout makes the provisioning infrastructure more reliable and easier to configure.
9.4. Smart Proxy with external services
You can configure a Smart Proxy server (integrated or standalone) to use external DNS, DHCP, or TFTP service. If you already have a server that provides these services in your environment, you can integrate it with your Foreman deployment. For information about how to configure a Smart Proxy with external services, see Configuring Smart Proxy server with External Services in Installing a Smart Proxy Server 3.13 on Enterprise Linux.
10. Deployment considerations
10.1. Foreman server with external database
When you install Foreman, the foreman-installer command creates databases on the same server that you install Foreman.
Depending on your requirements, moving to external databases can provide increased working memory for Foreman, which can improve response times for database operating requests.
High disk I/O workloads from frequent repository synchronization or Content View publishing. This causes Foreman to create a record in PostgreSQL for each job.
High volume of hosts.
For more information about using an external database, see Using External Databases with Foreman in Installing Foreman Server with Katello 4.15 plugin on Enterprise Linux.
10.2. Locations and topology
This section outlines general considerations that should help you to specify your Foreman deployment scenario. The most common deployment scenarios are listed in Common deployment scenarios. The defining questions are:
How many Smart Proxy servers do I need? – The number of geographic locations where your organization operates should translate to the number of Smart Proxy servers. By assigning a Smart Proxy to each location, you decrease the load on Foreman server, increase redundancy, and reduce bandwidth usage. Foreman server itself can act as a Smart Proxy (it contains an integrated Smart Proxy by default). This can be used in single location deployments and to provision the base system’s of Smart Proxy servers. Using the integrated Smart Proxy to communicate with hosts in remote locations is not recommended as it can lead to suboptimal network utilization.
What services will be provided by Smart Proxy servers? – After establishing the number of Smart Proxies, decide what services will be enabled on each Smart Proxy. Even though the whole stack of content and configuration management capabilities is available, some infrastructure services (DNS, DHCP, TFTP) can be outside of a Foreman administrator’s control. In such case, Smart Proxies have to integrate with those external services (see Smart Proxy with external services).
What compute resources do I need for my hosts? – Apart from provisioning bare-metal hosts, you can use various compute resources supported by Foreman. To learn about provisioning on different compute resources see Provisioning hosts.
10.3. Content lifecycle
Foreman provides features for precise management of the content lifecycle. A lifecycle environment represents a stage in the content lifecycle, a Content View is a filtered set of content, and can be considered as a defined subset of content. By associating Content Views with lifecycle environments, you make content available to hosts in a defined way.
For a detailed overview of the content management process see Importing Custom Content in Managing content. The following section provides general scenarios for deploying content views as well as lifecycle environments.
A single lifecycle environment – content from Library is promoted directly to the production stage. This approach limits the complexity but still allows for testing the content within the Library before making it available to hosts.
A single lifecycle environment path – both operating system and applications content is promoted through the same path. The path can consist of several stages (for example Development, QA, Production), which enables thorough testing but requires additional effort.
Application specific lifecycle environment paths – each application has a separate path, which allows for individual application release cycles. You can associate specific compute resources with application lifecycle stages to facilitate testing. On the other hand, this scenario increases the maintenance complexity.
10.4. Content deployment
Content deployment manages errata and packages on content hosts. Foreman can be configured to perform remote execution over MQTT/HTTPS (pull-based) or SSH (push-based). While remote execution is enabled on Foreman server by default, it is disabled on Smart Proxy servers and content hosts. You must enable it manually.
10.5. Provisioning
Foreman provides several features to help you automate the host provisioning, including provisioning templates, configuration management with Puppet, and host groups for standardized provisioning of host roles. For a description of the provisioning workflow see Provisioning Workflow in Provisioning hosts. The same guide contains instructions for provisioning on various compute resources.
10.6. Role based authentication
Roles related to a particular stage of the software lifecycle – for example, roles divided among the development, testing, and production phases, where each phase has one or more owners.
Define the expected tasks and responsibilities – define the subset of the Foreman infrastructure that will be accessible to the role as well as actions permitted on this subset. Think of the responsibilities of the role and how it would differ from other roles.
Use predefined roles whenever possible – Foreman provides a number of sample roles that can be used alone or as part of a role combination. Copying and editing an existing role can be a good start for creating a custom role.
Consider all affected entities – for example, a content view promotion automatically creates new Puppet Environments for the particular lifecycle environment and content view combination. Therefore, if a role is expected to promote content views, it also needs permissions to create and edit Puppet Environments.
Consider areas of interest – even though a role has a limited area of responsibility, there might be a wider area of interest. Therefore, you can grant the role a read only access to parts of Foreman infrastructure that influence its area of responsibility. This allows users to get earlier access to information about potential upcoming changes.
For instructions on defining roles and assigning them to users, see Managing Users and Roles in Administering Foreman. The same guide contains information on configuring external authentication sources.
10.7. Additional tasks
Discovering bare-metal hosts – the Foreman Discovery plugin enables automatic bare-metal discovery of unknown hosts on the provisioning network. These new hosts register themselves to Foreman server and the Puppet agent on the client uploads system facts collected by Facter, such as serial ID, network interface, memory, and disk information. After registration you can initialize provisioning of those discovered hosts. For more information, see Creating Hosts from Discovered Hosts in Provisioning hosts.
Backup management – backup and disaster recovery instructions, see Backing Up Foreman server and Smart Proxy server in Administering Foreman. Using remote execution, you can also configure recurring backup tasks on hosts. For more information on remote execution see Configuring and Setting up Remote Jobs in Managing hosts.
Security management – Foreman supports security management in various ways, including update and errata management, OpenSCAP integration for system verification, update and security compliance reporting, and fine grained role based authentication. Find more information on errata management and OpenSCAP concepts in Managing hosts.
Incident management – Foreman supports the incident management process by providing a centralized overview of all systems including reporting and email notifications. Detailed information on each host is accessible from Foreman server, including the event history of recent changes.
Scripting with Hammer and API – Foreman provides a command line tool called Hammer that provides a CLI equivalent to the majority of web UI procedures. In addition, you can use the access to the Foreman API to write automation scripts in a selected programming language.
10.8. Host group structures
Flat structure
In this hierarchy, the first host group level is reserved for parameters specific to a lifecycle environment. The second level contains operating system related definitions, and the third level contains application specific settings. Such structure is useful in scenarios where responsibilities are divided among lifecycle environments (for example, a dedicated owner for the Development, QA, and Production lifecycle stages).
Application based structure
Location based structure
11. Provisioning concepts
11.1. PXE booting
11.1.1. PXE sequence
initrdand Kickstart. -
For an example of using PXE Booting by Foreman server, see Provisioning Workflow in Provisioning hosts.
11.1.2. PXE booting requirements
Ensure that all the network-based firewalls are configured to allow clients on the subnet to access the Smart Proxy. For more information, see Smart Proxy networking.
11.2. HTTP booting
11.2.1. HTTP booting requirements with managed DHCP
All the network-based firewalls are configured to allow clients on the subnet to access the Smart Proxy. For more information, see Smart Proxy networking.
Although TFTP protocol is not used for HTTP UEFI Booting, Foreman uses TFTP Smart Proxy API to deploy boot loader configuration.
Ensure that the TCP port 8000 is open for the client to download the boot loader and Kickstart templates from the Smart Proxy.
The TCP port 9090 is open for the client to download the boot loader from the Smart Proxy using the HTTPS protocol.
The subnet that functions as the host’s provisioning interface has a DHCP Smart Proxy, an HTTP Boot Smart Proxy, a TFTP Smart Proxy, and a Templates Smart Proxy
11.2.2. HTTP booting requirements with unmanaged DHCP
http://smartproxy.example.com:8000 -
https://smartproxy.example.com:9090
Although TFTP protocol is not used for HTTP UEFI Booting, Foreman use TFTP Smart Proxy API to deploy boot loader configuration.
Ensure that the TCP port 8000 is open for the client to download boot loader and Kickstart templates from the Smart Proxy.
Ensure that the TCP port 9090 is open for the client to download the boot loader from the Smart Proxy through HTTPS.
Ensure that the host provisioning interface subnet has an HTTP Boot Smart Proxy set.
11.3. Secure boot
When Foreman is installed on Enterprise Linux using foreman-installer, grub2 and shim boot loaders that are signed by Red Hat are deployed into the TFTP and HTTP UEFI Boot directory.
PXE loader options named "SecureBoot" configure hosts to load shim.efi.
On Debian and Ubuntu operating systems, the grub2 boot loader is created using the grub2-mkimage unsigned.
To perform the Secure Boot, the boot loader must be manually signed and key enrolled into the EFI firmware.
Alternatively, grub2 from Ubuntu or Enterprise Linux can be copied to perform booting.
foreman |
N/A |
foreman |
N/A |
yes |
/usr/share/foreman |
/sbin/nologin |
foreman-proxy |
N/A |
foreman-proxy |
N/A |
yes |
/usr/share/foreman-proxy |
/sbin/nologin |
apache |
48 |
apache |
48 |
no |
/usr/share/httpd |
/sbin/nologin |
postgres |
26 |
postgres |
26 |
no |
/var/lib/pgsql |
/bin/bash |
pulp |
N/A |
pulp |
N/A |
no |
N/A |
/sbin/nologin |
puppet |
52 |
puppet |
52 |
no |
/sbin/nologin |
saslauth |
N/A |
saslauth |
76 |
no |
/run/saslauthd |
/sbin/nologin |
tomcat |
53 |
tomcat |
53 |
no |
/usr/share/tomcat |
/bin/nologin |
unbound |
N/A |
unbound |
N/A |
yes |
/etc/unbound |
/sbin/nologin |
Foreman is a complete lifecycle management tool for physical hosts, virtual machines, and cloud instances. Key features include automated host provisioning, configuration management, and content management including patch and errata management. You can automate tasks and quickly provision hosts, all through a single unified interface.
- Activation key
Activation keys are used by Subscription Manager to register hosts to Foreman. They define content view and lifecycle environment associations, content overrides, system purpose attributes, and other parameters to be associated with a newly created host.
They are associated to exactly one lifecycle environment and exactly one content view, though this may be a composite content view. You can use them on multiple machines and they behave like configuration information rather than traditional software license keys. You can also use multiple activation keys with a single host. When you register a host using an activation key, certain content from Foreman is provided to the host. The content that is made available depends on the content in the activation key’s content view and lifecycle environment, any content overrides present, any repository-level restrictions such as operating system or architecture, and system purpose attributes such as release version.
- Ansible
For more information about using Ansible to configure hosts, see Configuring hosts by using Ansible. For more information about automating Foreman using Ansible, see Managing Foreman with Ansible in Administering Foreman.
- Answer file
- ARF report
- Audits
- Boot disk
- Catalog
A document that describes the desired system state for one specific host managed by Puppet. It lists all of the resources that need to be managed, as well as any dependencies between those resources. Catalogs are compiled by an OpenVox server from Puppet Manifests and data from OpenVox agents.
- Candlepin
- Compliance policy
- Compute profile
- Compute resource
- Configuration Management
- Container (Docker container)
- Container image
- Content
A general term for everything Foreman distributes to hosts. Content includes software packages such as
.rpmpackages, errata, or Docker images. Content is synchronized into the Library and then promoted into lifecycle environments using content views so that they can be consumed by hosts.
- Content delivery network (CDN)
- Content view
Content views are named and versioned collections of repositories. When you publish a content view, Foreman creates a new content view version. This content view version is a frozen snapshot of the current state of the repositories within the content view. Any subsequent changes to the underlying repositories will no longer affect the published content view version. Once a content view is published, it can be promoted through the lifecycle environment path, or modified using incremental upgrades.
- Composite content view
- Discovered host
- Discovery image
- Discovery plugin
- Discovery rule
- Docker tag
- Enterprise Linux
AlmaLinux
CentOS Linux
CentOS Stream
Oracle Linux
Rocky Linux
- ERB
- Errata
- External node classifier (ENC)
- Facter
- Facts
- Foreman
- Full host image
- Generic image
- Hammer
- Host
- Host collection
- Host group
- Host image
- Installation Media
Installation media are sets of installation files used to install the base operating system during the provisioning process. An installation medium in Foreman represents the installation files for one or more operating systems, which must be accessible over the network, either through an URL or an NFS server location. It is usually either a mirror or a CD or DVD image.
Every operating system depends on exactly one path of an installation medium, whereas installation media paths may serve different operating systems at the same time. You can use operating system parameters such as
$version,$major, and$minorto parameterize the URL.
- Job
- Katello
Katello is an open-source plugin to perform content management and subscription handling. It depends on Pulp for content management, which fetches software from repositories and stores various versions of it. It also depends on Candlepin for host registration and managing subscription manifests.
- Lazy sync
- Location
- Library
A container for content from all synchronized repositories on Foreman server. Libraries exist by default for each organization as the root of every lifecycle environment path and the source of content for every content view.
- Lifecycle environment
- Lifecycle environment path
- Manifest (Red Hat subscription manifest)
A mechanism for transferring subscriptions from the Red Hat Customer Portal to Foreman. Do not confuse with Puppet manifest.
- Migrating Foreman
- OpenSCAP
- Organization
- Parameter
- Patch and release management
Patch and release management describes the process of acquiring, managing, and installing patches and software updates to your infrastructure. Using Foreman, you can keep control of the package versions available to your hosts and deliver applicable errata.
- Permission
- Product
Products are named collections of one or more repositories. If you manage Red Hat content and upload a Red Hat manifest, Foreman automatically groups Red Hat content within products. If you manage SUSE content using SCC Manager plugin, Foreman automatically groups SUSE content within products. For more information, see Managing SUSE content in Managing content.
- Promote (a content view)
- Provisioning
The provisioning of a host is the deployment of the base operating system on the host and registration of the host to Foreman. Optionally, the process continues with the supply of content and configuration. This process is ideally automated. Provisioned hosts run on compute resources or bare metal, never Foreman server or Smart Proxy servers.
AutoYaST for SUSE Linux Enterprise Server
Kickstart for AlmaLinux, Amazon Linux, CentOS, Oracle Linux, Red Hat Enterprise Linux, and Rocky Linux
Preseed files for Debian and Ubuntu
- Publish (a content view)
- Pulp
- Puppet
- OpenVox agent
- Puppet environment
- Puppet manifest
- OpenVox server
A Smart Proxy server component that provides a Puppet catalog to hosts for execution by the OpenVox agent.
- Puppet module
- PXE
- Recurring logic
- Registry
- Remote execution (REX)
- Repository
A repository is a single source and the smallest unit of content in Foreman. You can either synchronize a repository with a URL or manually upload content to Foreman. Foreman supports multiple content types. For more information, see Content types in Foreman in Managing content. One or more repositories form a product.
- Resource type
- Role
- Salt
- SCAP content
SCAP stands for Security Content Automation Protocol and refers to
.xmlfiles containing the configuration and security baseline against which hosts are checked. Foreman uses SCAP content in compliance policies.
Smart Proxy servers can provide DHCP, DNS, and TFTP services and act as an Ansible control node, OpenVox server, or Salt Master in separate networks. They interact with Foreman server in a client-server model. Foreman server always comes bundled with an integrated Smart Proxy.
Smart Proxy servers are required in Foreman deployments that manage IT infrastructure spanning across multiple networks and useful for Foreman deployments across various geographical locations.
- Subnet image
- Subscription
- Subscription Manager
subscription-manageruses activation keys to consume content on hosts.
- SUSE Subscription
You can use Foreman to manage SUSE content. For more information, see Managing SUSE content in Managing content.
- Synchronization
Synchronization describes the process of fetching content from external repositories into the Foreman server.
- Sync plan
- Tailoring files
- Task
- Trend
- Updating Foreman
The process of advancing your Foreman server and Smart Proxy server installations from one patch release to the next, for example Foreman 3.13.0 to Foreman 3.13.1.
- Upgrading Foreman
The process of advancing your Foreman server and Smart Proxy server installations from one minor release to the next, for example Foreman 3.12 to Foreman 3.13.
- User group
- User
- Virtualization
- virt-who
- XCCDF profiles
Appendix C: CLI help
Foreman offers multiple user interfaces: Foreman web UI, Hammer CLI, API, and through Ansible collection theforeman.foreman. If you want to administer Foreman on the command line, have a look at the following help output.
- Foreman services
foreman-maintaintool to manage these services. To see the full list of services, enter theforeman-maintain service listcommand on the machine where Foreman or Smart Proxy server is installed. For more information, runforeman-maintain --helpon your Foreman server or Smart Proxy server.
- Foreman plugins
You can extend Foreman by installing plugins. For more information, run
foreman-installer --full-helpon your Foreman server or Smart Proxy server.
- Hammer CLI
You can manage Foreman on the command line using
hammer. For more information on using Hammer CLI, see Using the Hammer CLI tool or runhammer --helpon your Foreman server or Smart Proxy server.
