1. Metrics overview
You can set up a third-party solution to collect live metrics from Foreman server, archive them for a fixed period of time, and analyze them. Obtaining metrics from Foreman is useful for capacity planning and troubleshooting performance issues.
Basic statistics from the operating system, including system load, memory utilization, and input/output operations
Process statistics, including memory and CPU utilization
Apache HTTP Server activity statistics
PostgreSQL activity statistics
Foreman application statistics
- Performance Co-Pilot (PCP)
- Performance Metric Domain Agents (PMDA)
- Grafana
Install PCP packages and configure PCP data collection. You can use the PCP CLI tools to retrieve metrics in the command line. Optionally, you can install Grafana to enable web UI access to metrics.
3.1. Installing PCP
Install the PCP packages on your Foreman server and enable PCP daemons.
Ensure you have the minimum of 20 GB space available in the
/var/log/pcpdirectory.With the default PCP data retention settings, data storage is estimated to use between 100 MB and 500 MB of disk space per day, but may use up to several gigabytes over time. For more information, see Metrics data retention.
Install the PCP packages:
# dnf install pcp \ pcp-pmda-apache \ pcp-pmda-openmetrics \ pcp-pmda-postgresql \ pcp-pmda-redis \ pcp-system-tools \ foreman-pcp
Enable and start the Performance Metrics Collector daemon and Performance Metrics Logger daemon:
Symlink the Foreman specific configuration to PMDA process monitoring:
Java
PostgreSQL
Redis
Dynflow
Puma
Install the process monitoring PMDA:
# cd /var/lib/pcp/pmdas/proc # ./Install
Configure PCP to collect metrics from Apache HTTP Server.
Enable the Apache HTTP Server extended status module:
Enable the Apache HTTP Server PMDA:
# cd /var/lib/pcp/pmdas/apache # ./Install
Configure PCP to collect metrics from PostgreSQL:
# cd /var/lib/pcp/pmdas/postgresql # ./Install
Enable the telemetry feature in Foreman:
Configure PCP to collect data from Foreman:
# cd /var/lib/pcp/pmdas/openmetrics # echo "https://foreman.example.com/metrics" > config.d/foreman.url # ./Install
Restart PCP to begin data collection:
Print a summary of the active PCP configuration:
# pcp
Example output of the
pcpcommand:Performance Co-Pilot configuration on foreman.example.com: platform: Linux foreman.example.com 4.18.0-372.32.1.el8_6.x86_64 #1 SMP Fri Oct 7 12:35:10 EDT 2022 x86_64 hardware: 16 cpus, 2 disks, 1 node, 31895MB RAM timezone: UTC services: pmcd pmproxy pmcd: Version 5.3.7-17, 13 agents, 4 clients pmda: root pmcd proc pmproxy xfs redis linux apache mmv kvm postgresql jbd2 openmetrics pmlogger: primary logger: /var/log/pcp/pmlogger/foreman.example.com/20230831.00.10 pmie: primary engine: /var/log/pcp/pmie/foreman.example.com/pmie.logIn this example, both the Performance Metrics Collector Daemon (pmcd) and Performance Metrics Proxy Daemon (pmproxy) services are running. It also confirms the PMDA that are collecting metrics. Finally, it lists the active log file, in which
pmloggeris currently storing metrics.
You can enable web UI access to metrics collected by PCP by installing Grafana.
Install Grafana and the Grafana PCP plugin on your Foreman server:
Start and enable the Grafana web service and the PCP proxy service:
Open the firewall port to allow access to the Grafana web interface:
Reload the firewall configuration to apply the changes:
# firewall-cmd --reload
Install PCP Redis and configure Grafana to load it. For more information, see Configuring PCP Redis in Red Hat Enterprise Linux 9 Monitoring and managing system status and performance.
Access the Grafana web UI, enable the PCP plugin, and add PCP Redis as a data source. For more information, see Accessing the Grafana web UI in Red Hat Enterprise Linux 9 Monitoring and managing system status and performance.
4. Metrics data retention
The logged metrics
The logging interval
The retention policy
Open the
/etc/pcp/pmlogger/control.d/localconfiguration file. -
Locate the
LOCALHOSTNAMEline. -
Append
-t XXs, where XX is the required time interval in seconds. -
Save the file.
Restart the
pmloggerservice:# systemctl restart pmlogger
Open the
/etc/sysconfig/pmlogger_timersfile. -
Locate the
PMLOGGER_DAILY_PARAMSline. -
If the line is commented, uncomment the line.
Configure the following parameters:
Ensure the default
-Eparameter is present. -
Append the
-xparameter and add a value for the required number of days after which data is archived. -
Append the
-kparameter and add a value for the number of days after which data is deleted.
For example, the parameters
-x 4 -k 7specify that data will be compressed after 4 days and deleted after 7 days. -
Save the file.
Example storage statistics:
To view data storage statistics, enter the following command on your Foreman server:
5. PCP metrics
Metrics are stored in a tree-like structure.
For example, all network metrics are stored in a node named network.
Each metric may be a single value, or a list of values, known as instances.
For example, kernel load has three instances, a 1-minute, 5-minute, and 15-minute average.
| Metric | Description |
hotproc.* |
Basic metrics of key Foreman processes |
apache.* |
Apache HTTP Server metrics |
postgresql.* |
Basic PostgreSQL statistics |
openmetrics.foreman.fm_rails_* |
Foreman metrics |
To list all metrics available through PCP, enter the following command:
# pminfo
To list all Foreman metrics and their descriptions, enter the following command:
To list the archived metrics, enter the following command:
The
pmloggerdaemon archives data as received, according to its configuration. To retrieve the name of the active log file, enter the following command:# pcp | grep logger
5.2. Retrieving live metrics
To print current values of a particular metric, enter the following command:
In this example, metric instances on writes to disk partitions are displayed. PCP converts the number of writes to disk partitions from a counter value to a rate value. The
-f 1argument specifies to abbreviate the values to one decimal place.Example output:
metric: disk.partitions.write host: foreman.example.com semantics: cumulative counter (converting to rate) units: count (converting to count / sec) samples: all vda1 vda2 sr0 0.0 12.0 0.0 0.0 1.0 0.0 0.0 1.0 0.0 0.0 2.0 0.0 -
To print system performance summary every 2 seconds, enter the following command:
# pmstat -t 2sec
To list all metrics that were enabled when the archive file was created, enter the following command:
To view the host and time period covered by an archive file, enter the following command:
# pmdumplog -l archive_file
To list disk writes for each partition, over the time period covered by the archive file:
# pmval --archive /var/log/pcp/pmlogger/foreman.example.com/20230831.00.10 \ -f 1 disk.partitions.write
To list disk write operations per partition, with a 2-second interval, over the time period between 14:00 and 14:15:
# pmval --archive /var/log/pcp/pmlogger/foreman.example.com/20230831.00.10 \ -d -t 2sec \ -f 3 disk.partitions.write \ -S @14:00 -T @14:15
To list average values of all performance metrics, including the time and value of the minimum/maximum, over the time period between 14:00 and 14:30, and format the values as a table:
# pmlogsummary /var/log/pcp/pmlogger/foreman.example.com/20230831.00.10 \ -HlfiImM \ -S @14:00 \ -T @14:30 \ disk.partitions.write \ mem.freemem
To display system metrics stored in an archive, starting from 14:00, in an interactive manner similar to the
toptool:# pcp --archive /var/log/pcp/pmlogger/foreman.example.com/20230831.00.10 \ -S @14:00 \ atop
You can view the Grafana dashboard, which displays widgets with the values of metrics. You can add and remove metrics to suit your requirements. You can also select the time span displayed for each widget.
Open the following URL in a browser: http://foreman.example.com:3000
For more details on using Grafana, see the Grafana Labs website.
