1. Scenarios for Foreman on AWS
You can deploy Foreman on Amazon Web Services (AWS) in several scenarios.
One-region setup
One-region setup
Connecting different regions
Most public cloud providers do not charge for data being transferred into a region or between availability zones within a single region. However, they charge for data leaving the region to the Internet.
2. Use case considerations for Foreman on AWS
Amazon Web Services (AWS) is an image-only compute resource which means that there are common Foreman use cases that do not work or require extra configuration in your AWS environment. If you plan to deploy Foreman to AWS, ensure that the use case scenarios that you want to use are available in your AWS environment.
2.1. Supported use cases for Foreman on AWS
You can perform the following Foreman use cases on Amazon Web Services (AWS):
Multi-homed Foreman and Smart Proxy
Multi-homed Foreman server is not supported.
Multi-homed Smart Proxy servers are supported by configuring Smart Proxies with a load balancer. For more information, see Configuring Smart Proxies with a Load Balancer.
For a multi-homed Smart Proxy servers setup, ensure you meet these requirements:
  • Foreman server or Smart Proxy server have different internal and external DNS host names
  • No site-to-site VPN connection exists between the locations where you deploy Foreman server and Smart Proxy server
2.2. Unsupported use cases for Foreman on AWS
In Amazon Web Services (AWS), you cannot manage the DHCP service. Because of this, you cannot use Kickstart and PXE provisioning models of Foreman. This includes:
  • PXE Provisioning
  • Discovery and Discovery Rules
  • ISO Provisioning methods
    • PXE-Less Discovery (iPXE)
    • Per-host ISO
    • Generic ISO
    • Full-host ISO
3. Prerequisites for Foreman on AWS
Installing and running Foreman server and Smart Proxy servers on Amazon Web Services (AWS) has additional requirements to your environment.
Amazon Web Service requirements
  • Use Storage requirements in Installing Foreman Server 3.13 on Enterprise Linux to understand and assign the correct storage to your AWS EBS volumes. See also an AWS storage optimized instance for further guidance.
  • Create EBS volumes for directories expected to contain larger amounts of data like /var/lib/pulp and ensure they are correctly mounted on start-up and before continuing the installation.
  • Optional: Store other data on a separate EBS volume.
  • If you want Foreman server and Smart Proxy server to communicate using external DNS hostnames, open the required ports for communication in the AWS Security Group that is associated with the instance.
AWS permission requirements
  • Create and access Enterprise Linux images in AWS
  • Edit network access in AWS Security
  • Create EC2 instances and EBS volumes
  • Launch EC2 instances
  • Import and export of virtual machines in AWS
  • Usage of AWS Direct Connect
Foreman requirements
Ensure that your Amazon EC2 instance meets or exceeds requirements for Foreman:
4. Deploying Foreman on AWS
You can run Foreman server, Smart Proxy servers, and hosts on your Amazon Web Services (AWS) environment. If you want to provision cloud instances on Amazon EC2, see Provisioning cloud instances in Amazon EC2 in Provisioning hosts.
4.1. Installing Foreman server on AWS
You can install Foreman server on your AWS environment.
  1. Launch an EC2 instance running Enterprise Linux AMI.
  2. Connect to the newly created instance.
  3. If you use a Red Hat Gold Image, remove the RHUI client and enable repository managing using subscription-manager:
    # dnf remove -y rh-amazon-rhui-client*
    # dnf clean all
    # subscription-manager config --rhsm.manage_repos=1
  4. Install Foreman server. For more information, see Installing Foreman Server 3.13 on Enterprise Linux.
Next steps
4.2. Installing Smart Proxy server on AWS
You can install Smart Proxy server on your AWS environment.
  1. Create a new EC2 instance and connect to it.
    As with Foreman server, there are additional steps required when using the Red Hat Gold Image. For more information, see Installing Foreman server on AWS.
  2. Install Smart Proxy server. For more information, see Installing a Smart Proxy Server 3.13 on Enterprise Linux.
Next steps
4.3. Registering hosts on AWS to Foreman
When you install Foreman server and Smart Proxy server, you must then register the hosts on EC2 instances to Foreman.
Unsupported version
