2. Guide not ready yet
This guide is not ready yet.
Foreman is a community project. The source is maintained in foreman-documentation on GitHub where you can create issues and pull requests. Thanks for your contribution.
Appendix A: Glossary of terms used in Foreman
Foreman is a complete lifecycle management tool for physical hosts, virtual machines, and cloud instances. Key features include automated host provisioning, configuration management, and content management including patch and errata management. You can automate tasks and quickly provision hosts, all through a single unified interface.
- Ansible
For more information about using Ansible to configure hosts, see Configuring hosts by using Ansible. For more information about automating Foreman using Ansible, see Managing Foreman with Ansible in Administering Foreman.
- Answer file
- ARF report
- Audits
- Boot disk
- Catalog
A document that describes the desired system state for one specific host managed by Puppet. It lists all of the resources that need to be managed, as well as any dependencies between those resources. Catalogs are compiled by a Puppet server from Puppet Manifests and data from Puppet agents.
- Compliance policy
- Compute profile
- Compute resource
- Configuration Management
- Discovered host
- Discovery image
- Discovery plugin
- Discovery rule
- Enterprise Linux
AlmaLinux
CentOS Linux
CentOS Stream
Oracle Linux
Rocky Linux
- ERB
- External node classifier (ENC)
A construct that provides additional data for a server to use when configuring hosts. When Puppet obtains information about nodes from an external source instead of its own database, the external source is called External node classifier. If the Puppet plugin is installed, Foreman can act as an External node classifier to Puppet servers in a Foreman deployment.
- Facter
- Facts
- Foreman
- Full host image
- Generic image
- Hammer
- Host
- Host collection
- Host group
- Host image
- Job
- Location
- Migrating Foreman
- OpenSCAP
- Organization
- Parameter
- Permission
- Provisioning
The provisioning of a host is the deployment of the base operating system on the host and registration of the host to Foreman. Optionally, the process continues with the supply of content and configuration. This process is ideally automated. Provisioned hosts run on compute resources or bare metal, never Foreman server or Smart Proxy servers.
- Provisioning template
AutoYaST for SUSE Linux Enterprise Server
Kickstart for AlmaLinux, Amazon Linux, CentOS, Oracle Linux, Red Hat Enterprise Linux, and Rocky Linux
Preseed files for Debian and Ubuntu
- Puppet
- Puppet agent
- Puppet environment
An isolated set of Puppet agent nodes that can be associated with a specific set of Puppet Modules.
- Puppet manifest
- Puppet server
A Smart Proxy server component that provides a Puppet catalog to hosts for execution by the Puppet agent.
- Puppet module
- PXE
- Recurring logic
- Remote execution (REX)
- Resource type
- Role
- Salt
- SCAP content
SCAP stands for Security Content Automation Protocol and refers to
.xmlfiles containing the configuration and security baseline against which hosts are checked. Foreman uses SCAP content in compliance policies.
- Smart Proxy server
Smart Proxy servers can provide DHCP, DNS, and TFTP services and act as an Ansible control node, Puppet server, or Salt Master in separate networks. They interact with Foreman server in a client-server model.
Smart Proxy servers are required in Foreman deployments that manage IT infrastructure spanning across multiple networks and useful for Foreman deployments across various geographical locations.
- Subnet image
- Subscription Manager
- Tailoring files
- Task
- Trend
- Updating Foreman
The process of advancing your Foreman server and Smart Proxy server installations from one patch release to the next, for example Foreman 3.12.0 to Foreman 3.12.1.
- Upgrading Foreman
The process of advancing your Foreman server and Smart Proxy server installations from one minor release to the next, for example Foreman 3.11 to Foreman 3.12.
- User group
- User
- Virtualization
- virt-who
- XCCDF profiles
Appendix B: CLI help
Foreman offers multiple user interfaces: Foreman web UI, Hammer CLI, API, and through Ansible collection theforeman.foreman. If you want to administer Foreman on the command line, have a look at the following help output.
- Foreman services
foreman-maintaintool to manage these services. To see the full list of services, enter theforeman-maintain service listcommand on the machine where Foreman or Smart Proxy server is installed. For more information, runforeman-maintain --helpon your Foreman server or Smart Proxy server.
- Foreman plugins
You can extend Foreman by installing plugins. For more information, run
foreman-installer --full-helpon your Foreman server or Smart Proxy server.
- Hammer CLI
You can manage Foreman on the command line using
hammer. For more information on using Hammer CLI, see Using the Hammer CLI tool or runhammer --helpon your Foreman server or Smart Proxy server.
