Log in to Atlassian Jira.
Click the following link: Create Issue.
Complete the Summary, Description, and Reporter fields. In the Description field, include the documentation URL, chapter or section number, and a detailed description of the issue. Do not modify any other fields in the form.
Click Create.
1. Starting and stopping Red Hat Satellite
Satellite provides the satellite-maintain service command to manage Satellite services from the command line.
This is useful when creating a backup of Satellite.
For more information on creating backups, see Backing up Satellite Server and Capsule Server.
After installing Satellite with the satellite-installer command, all Satellite services are started and enabled automatically.
# satellite-maintain service list
# satellite-maintain service status
To stop Satellite services, execute:
To start Satellite services, execute:
To restart Satellite services, execute:
# satellite-maintain service restart
2. Cloning Satellite Server
You can clone your Satellite Server to create instances to test upgrades and migration of instances to a different machine or operating system. This is an optional step to provide more flexibility during the upgrade or migration.
You cannot use the Satellite clone tool on a Capsule Server. Instead, you must backup the existing Capsule Server, restore it on the target server, and then reconfigure Capsule Server.
If you create a new instance of the Satellite Server, decommission the old instances after restoring the backup. Cloned instances are not supposed to run in parallel in a production environment. |
Ensure that you understand the following terms:
- Source server
The origin of the clone.
- Target server
The new server that you copy files to and clone the source server to.
2.1. Cloning process overview
Back up the source server.
Clone the source server to the target server.
Power off the source server.
Update the network configuration on the target server to match the target server’s IP address with its new host name.
Test the new target server.
2.2. Prerequisites
To clone Satellite Server, ensure that you have the following resources available:
A minimal install of Red Hat Enterprise Linux 8 or 9 to become the target server. Do not install Red Hat Enterprise Linux 8 or 9 software groups or third-party applications. Ensure that your server complies with all the required specifications. For more information, see Preparing your Environment for Installation in Installing Satellite Server in a connected network environment.
A backup of your Satellite Server that you make using the
satellite-maintain backupscript. You can use a backup with or without Pulp data. -
A Satellite subscription for the target server.
Before you begin cloning, ensure the following conditions exist:
The target server is on an isolated network. This prevents the cloned Satellite Server from accidentally communicating with the source Satellite Server, Capsule Servers, and hosts.
The target server has at least the same storage capacity as the source server.
If you have any customized configurations on your source server that are not managed by the satellite-installer tool or Satellite backup process, you must manually back up these files.
2.3. Pulp data considerations
You can clone Satellite server without including Pulp data. However, for your cloned environment to work, you do require Pulp data. If the target server does not have Pulp data, it is not a fully working Satellite.
To transfer Pulp data to a target server, you have two options:
Clone using backup with Pulp data
Clone using backup without Pulp data and copy
/var/lib/pulpmanually from the source server.
If your pulp_data.tar file is greater than 500 GB, or if you use a slow storage system, such as NFS, and your pulp_data.tar file is greater than 100 GB, do not include pulp_data.tar in the backup because this can cause memory errors during extraction.
Copy the pulp_data.tar file from the source server to the target server.
Follow the steps in the procedure in Cloning Satellite Server and replace the steps that involve cloning with Pulp data with the following steps:
Perform a backup with PostgreSQL databases active excluding the Pulp data:
# satellite-maintain backup offline --skip-pulp-content \ --assumeyes /var/backup
Stop and disable Satellite services:
# satellite-maintain service stop # satellite-maintain service disable
Copy the Pulp data to the target server:
# rsync --archive --partial --progress --compress \ /var/lib/pulp/ target_server.example.com:/var/lib/pulp/
Proceed to Cloning to the target server.
2.4. Cloning Satellite Server
Use the following procedures to clone Satellite Server. Note that because of the high volume of data that you must copy and transfer as part of these procedures, it can take a significant amount of time to complete.
2.4.1. Preparing the source server for cloning
On the source server, complete the following steps:
Determine the size of the Pulp data:
# du -sh /var/lib/pulp/
If you have less than 500 GB of Pulp data, perform a backup with PostgreSQL databases active including the Pulp data. If you have more than 500 GB of Pulp data, skip the following steps and complete the steps in Pulp data considerations before you continue.
# satellite-maintain backup offline --assumeyes /var/backup
2.4.2. Cloning to the target server
To clone your server, complete the following steps on your target server:
The
satellite-clonetool defaults to using/backup/as the backup folder. If you copy to a different folder, update thebackup_dirvariable in the/etc/satellite-clone/satellite-clone-vars.ymlfile. -
Place the backup files from the source Satellite in the
/backup/folder on the target server. You can either mount the shared storage or copy the backup files to the/backup/folder on the target server. -
Register your instance to the Red Hat Customer Portal and enable only the required repositories:
If the target server runs Red Hat Enterprise Linux 9, enter the following commands:
# subscription-manager register # subscription-manager repos --disable=* # subscription-manager repos --enable=rhel-9-for-x86_64-appstream-rpms \ --enable=rhel-9-for-x86_64-baseos-rpms \ --enable=satellite-maintenance-6.16-for-rhel-9-x86_64-rpms
If the target server runs Red Hat Enterprise Linux 8, enter the following commands:
# subscription-manager register # subscription-manager repos --disable=* # subscription-manager repos --enable=rhel-8-for-x86_64-appstream-rpms \ --enable=rhel-8-for-x86_64-baseos-rpms \ --enable=satellite-maintenance-6.16-for-rhel-8-x86_64-rpms # dnf module enable satellite-maintenance:el8
Install the
satellite-clonepackage:# dnf install satellite-clone
After you install the
satellite-clonetool, you can adjust any configuration to suit your own deployment in the/etc/satellite-clone/satellite-clone-vars.ymlfile. -
Run the
satellite-clonetool:# satellite-clone
Reconfigure DHCP, DNS, TFTP, and remote execution services. The cloning process disables these services on the target Satellite Server to avoid conflict with the source Satellite Server.
Reconfigure and enable DHCP, DNS, and TFTP in the Satellite web UI. For more information, see Configuring External Services on Satellite Server in Installing Satellite Server in a connected network environment.
Log in to the Satellite web UI, with the username
adminand the passwordchangeme. Immediately update the admin password to secure credentials. -
Ensure that the correct organization is selected.
In the Satellite web UI, navigate to Content > Subscriptions.
Click Manage Manifest.
Click Refresh and then click Close to return to the list of subscriptions.
Verify that the available subscriptions are correct.
Follow the instructions in the
/usr/share/satellite-clone/logs/reassociate_capsules.txtfile to restore the associations between Capsules and their lifecycle environments. -
Update your network configuration, for example, DNS, to match the target server’s IP address with its new host name. The
satellite-clonetool changes the host name to the source server’s host name. If you want to change the host name to something different, you can use thesatellite-change-hostnametool. For more information, see Renaming Satellite Server in Administering Red Hat Satellite. -
If the source server uses the
virt-whodaemon, install and configure it on the target server. Copy all thevirt-whoconfiguration files in the/etc/virt-who.d/directory from the source server to the same directory on the target server. For more information, see Configuring virtual machine subscriptions. After you perform an upgrade using the following chapters, you can safely decommission the source server.
3. Tuning Satellite Server with predefined profiles
If your Satellite deployment includes more than 5000 hosts, you can use predefined tuning profiles to improve performance of Satellite.
Note that you cannot use tuning profiles on Capsules.
You can choose one of the profiles depending on the number of hosts your Satellite manages and available hardware resources.
When you run the satellite-installer command with the --tuning option, deployment configuration settings are applied to Satellite in the following order:
The default tuning profile defined in the
/usr/share/foreman-installer/config/foreman.hiera/tuning/common.yamlfile -
The tuning profile that you want to apply to your deployment and is defined in the
/usr/share/foreman-installer/config/foreman.hiera/tuning/sizes/directory -
Optional: If you have configured a
/etc/foreman-installer/custom-hiera.yamlfile, Satellite applies these configuration settings.
- default
Number of hosts: 0 – 5000
RAM: 20G
Number of CPU cores: 4
- medium
Number of hosts: 5001 – 10000
RAM: 32G
Number of CPU cores: 8
- large
Number of hosts: 10001 – 20000
RAM: 64G
Number of CPU cores: 16
- extra-large
Number of hosts: 20001 – 60000
RAM: 128G
Number of CPU cores: 32
- extra-extra-large
Number of hosts: 60000+
RAM: 256G
Number of CPU cores: 48+
Optional: If you have configured the
custom-hiera.yamlfile on Satellite Server, back up the/etc/foreman-installer/custom-hiera.yamlfile tocustom-hiera.original. You can use the backup file to restore the/etc/foreman-installer/custom-hiera.yamlfile to its original state if it becomes corrupted:# cp /etc/foreman-installer/custom-hiera.yaml \ /etc/foreman-installer/custom-hiera.original
custom-hiera.yamlfile on Satellite Server, review the definitions of the default tuning profile in/usr/share/foreman-installer/config/foreman.hiera/tuning/common.yamland the tuning profile that you want to apply in/usr/share/foreman-installer/config/foreman.hiera/tuning/sizes/. Compare the configuration entries against the entries in your/etc/foreman-installer/custom-hiera.yamlfile and remove any duplicated configuration settings in your/etc/foreman-installer/custom-hiera.yamlfile. -
Enter the
satellite-installercommand with the--tuningoption for the profile that you want to apply. For example, to apply the medium tuning profile settings, enter the following command:# satellite-installer --tuning medium
4. Migrating from internal Satellite databases to external databases
When you install Red Hat Satellite, the satellite-installer command installs PostgreSQL databases on the same server as Satellite. If you are using the default internal databases but want to start using external databases to help with the server load, you can migrate your internal databases to external databases.
To confirm whether your Satellite Server has internal or external databases, you can query the status of your databases:
# satellite-maintain service status --only postgresql
Red Hat does not provide support or tools for external database maintenance. This includes backups, upgrades, and database tuning. You must have your own database administrator to support and maintain external databases.
Preparing a host for external databases. Prepare a Red Hat Enterprise Linux 8 server to host the external databases.
Installing PostgreSQL. Prepare PostgreSQL with databases for Foreman, Pulp, and Candlepin with dedicated users owning them.
Migrating to external databases. Edit the parameters of
satellite-installerto point to the new databases, and runsatellite-installer.
4.1. PostgreSQL as an external database considerations
Foreman, Katello, and Candlepin use the PostgreSQL database. If you want to use PostgreSQL as an external database, the following information can help you decide if this option is right for your Satellite configuration. Satellite supports PostgreSQL version 13.
Increase in free memory and free CPU on Satellite
Flexibility to set
shared_bufferson the PostgreSQL database to a high number without the risk of interfering with other services on Satellite -
Flexibility to tune the PostgreSQL server’s system without adversely affecting Satellite operations
If either Satellite or the PostgreSQL database server suffers a hardware or storage failure, Satellite is not operational
If there is latency between the Satellite server and database server, performance can suffer
If you suspect that the PostgreSQL database on your Satellite is causing performance problems, use the information in Satellite 6: How to enable postgres query logging to detect slow running queries to determine if you have slow queries. Queries that take longer than one second are typically caused by performance issues with large installations, and moving to an external database might not help. If you have slow queries, contact Red Hat Support.
4.2. Preparing a host for external databases
Install a freshly provisioned system with the latest Red Hat Enterprise Linux 9 or Red Hat Enterprise Linux 8 to host the external databases.
Subscriptions for Red Hat Enterprise Linux do not provide the correct service level agreement for using Satellite with external databases. You must also attach a Satellite subscription to the base operating system that you want to use for the external databases.
The prepared host must meet Satellite’s Storage Requirements.
You must attach a Satellite subscription to your server. For more information about subscription, see Attaching the Satellite Infrastructure Subscription in Installing Satellite Server in a connected network environment.
Select the operating system and version you are installing external database on:
4.2.1. Red Hat Enterprise Linux 9
Disable all repositories:
# subscription-manager repos --disable "*"
Enable the following repositories:
# subscription-manager repos \ --enable=satellite-6.16-for-rhel-9-x86_64-rpms \ --enable=satellite-maintenance-6.16-for-rhel-9-x86_64-rpms \ --enable=rhel-9-for-x86_64-baseos-rpms \ --enable=rhel-9-for-x86_64-appstream-rpms
Verify that the required repositories are enabled:
# dnf repolist enabled
4.2.2. Red Hat Enterprise Linux 8
# subscription-manager repos \ --enable=satellite-6.16-for-rhel-8-x86_64-rpms \ --enable=satellite-maintenance-6.16-for-rhel-8-x86_64-rpms \ --enable=rhel-8-for-x86_64-baseos-rpms \ --enable=rhel-8-for-x86_64-appstream-rpms
Enable the following module:
# dnf module enable satellite:el8
NoteEnablement of the module
satellite:el8warns about a conflict withpostgresql:10andruby:2.5as these modules are set to the default module versions on Red Hat Enterprise Linux 8. The modulesatellite:el8has a dependency for the modulespostgresql:12andruby:2.7that will be enabled with thesatellite:el8module. These warnings do not cause installation process failure, hence can be ignored safely. For more information about modules and lifecycle streams on Red Hat Enterprise Linux 8, see Red Hat Enterprise Linux Application Streams Lifecycle.
4.3. Installing PostgreSQL
You can install only the same version of PostgreSQL that is installed with the satellite-installer tool during an internal database installation.
Satellite supports PostgreSQL version 12.
On your new database server, install PostgreSQL:
# dnf install postgresql-server postgresql-evr postgresql-contrib
Initialize the PostgreSQL database:
# postgresql-setup --initdb
Edit the
Note that the default configuration of external PostgreSQL needs to be adjusted to work with Satellite. The base recommended external database configuration adjustments are as follows:
max_connections: 500
shared_buffers: 512MB
work_mem: 4MB
Remove the
Add the following line to the end of the file to use SCRAM for authentication:
Edit the
host all all Satellite_ip/32 scram-sha-256
Start and enable the PostgreSQL service:
Open the postgresql port:
Make the changes persistent:
Switch to the
Create three databases and dedicated roles: one for Foreman, one for Candlepin, and one for Pulp:
CREATE USER "foreman" WITH PASSWORD 'Foreman_Password'; CREATE USER "candlepin" WITH PASSWORD 'Candlepin_Password'; CREATE USER "pulp" WITH PASSWORD 'Pulpcore_Password'; CREATE DATABASE foreman OWNER foreman; CREATE DATABASE candlepin OWNER candlepin; CREATE DATABASE pulpcore OWNER pulp;
Exit the
postgresuser:# \q
From Satellite Server, test that you can access the database. If the connection succeeds, the commands return
1.# PGPASSWORD='Foreman_Password' psql -h postgres.example.com -p 5432 -U foreman -d foreman -c "SELECT 1 as ping" # PGPASSWORD='Candlepin_Password' psql -h postgres.example.com -p 5432 -U candlepin -d candlepin -c "SELECT 1 as ping" # PGPASSWORD='Pulpcore_Password' psql -h postgres.example.com -p 5432 -U pulp -d pulpcore -c "SELECT 1 as ping"
4.4. Migrating to external databases
Back up and transfer existing data, then use the satellite-installer command to configure Satellite to connect to an external PostgreSQL database server.
You have installed and configured a PostgreSQL server on a Red Hat Enterprise Linux server.
On Satellite Server, stop all Satellite services except for PostgreSQL:
# satellite-maintain service stop --exclude postgresql
Create your target directory for the Satellite backup:
# mkdir /var/My_Migration_Backup_Directory
# satellite-maintain backup online \ --preserve-directory \ --skip-pulp-content \ /var/My_Migration_Backup_Directory
PGPASSWORD='Foreman_Password' pg_restore -h postgres.example.com -U foreman -d foreman < /var/My_Migration_Backup_Directory/foreman.dump PGPASSWORD='Candlepin_Password' pg_restore -h postgres.example.com -U candlepin -d candlepin < /var/My_Migration_Backup_Directory/candlepin.dump PGPASSWORD='Pulpcore_Password' pg_restore -h postgres.example.com -U pulp -d pulpcore < /var/My_Migration_Backup_Directory/pulpcore.dump
Use the
satellite-installercommand to update Satellite to point to the new databases:# satellite-installer \ --katello-candlepin-manage-db false \ --katello-candlepin-db-host postgres.example.com \ --katello-candlepin-db-name candlepin \ --katello-candlepin-db-user candlepin \ --katello-candlepin-db-password Candlepin_Password \ --foreman-proxy-content-pulpcore-manage-postgresql false \ --foreman-proxy-content-pulpcore-postgresql-host postgres.example.com \ --foreman-proxy-content-pulpcore-postgresql-db-name pulpcore \ --foreman-proxy-content-pulpcore-postgresql-user pulp \ --foreman-proxy-content-pulpcore-postgresql-password Pulpcore_Password \ --foreman-db-manage false \ --foreman-db-host postgres.example.com \ --foreman-db-database foreman \ --foreman-db-username foreman \ --foreman-db-password Foreman_Password
Remove the PostgreSQL package on Satellite Server:
# satellite-maintain packages remove postgresql-server
Remove the PostgreSQL data directory:
# rm -fr /var/lib/pgsql/data
5. Managing Satellite with Ansible
Satellite Ansible Collections is a set of Ansible modules that interact with the Satellite API. You can manage and automate many aspects of Satellite with Satellite Ansible collections.
5.1. Installing the Satellite Ansible modules
Use this procedure to install the Satellite Ansible modules.
Install the package using the following command:
# satellite-maintain packages install ansible-collection-redhat-satellite
5.2. Viewing the Satellite Ansible modules
You can view the installed Satellite Ansible modules by running:
# ansible-doc -l redhat.satellite
Alternatively, you can also see the complete list of Satellite Ansible modules and other related information at Red Hat Ansible Automation Platform.
All modules are in the redhat.satellite namespace and can be referred to in the format redhat.satellite.module_name.
For example, to display information about the activation_key module, enter the following command:
$ ansible-doc redhat.satellite.activation_key
6. Preparing for disaster recovery and recovering from data loss
Red Hat recommends preparing a disaster recovery plan to ensure the continuity of Satellite services in case of a disruptive event. These guidelines help ensure that you will be able to restore your Satellite deployment to an operational state after an incident.
6.1. Overview of recommended disaster recovery plans
Choose a disaster recovery plan that best helps ensure the continuity of Satellite services in your deployment.
- Snapshots of virtualized Satellite Server
- How do I back up?
Virtualize your Satellite Server and use the hypervisor tools to take virtual machine snapshots of the server. This method is suitable if you can run Satellite in a virtual machine.
To recover Satellite services, restore a virtual machine snapshot.
- Active and passive Satellite Server, with external storage
- How do I back up?
/var/lib/pulpand database in/var/lib/pgsql. Replicate this storage into a different data center. Attach the storage to a Satellite Server that is a clone of the primary Satellite Server but runs passively. - How will I recover in case of a disruptive event?
To recover Satellite services, switch DNS records of the active Satellite Server with the passive Satellite Server. This ensures that the passive server becomes the active server. All hosts remain connected without configuration updates.
- Active and passive Satellite Server, with backup and restore
- How do I back up?
Ensure periodic backups of your Satellite Server. Copy this backup to a passive Satellite Server and restore it on the passive server.
- Dual active Satellite Server
- How do I back up?
Operate an active, independent Satellite Server per data center. Hosts from each data center are registered to the Satellite Server in that data center. Then configure automation to ensure recovery in case of a disruptive event. For example, you can periodically run a health check and if the health check discovers that the current Satellite Server a host is registered to does not resolve, the host is re-registered to the other Satellite Server.
To minimize downtime, you can automate the recovery in various ways. For example, you can use the Satellite Ansible collection. For more information, see Managing Satellite with Ansible in Administering Red Hat Satellite.
To recover Satellite services, re-register all hosts to the Satellite Server in the other data center.
You must ensure that content synchronization and content view creation are synchronized to create the same content view in each Satellite and prevent content drift. Content drift occurs when available content deviates from the intended state defined by a content view. If you fail to prevent content drift, expect inconsistency in the content that is available to hosts.
6.2. Disaster recovery by virtualizing your Satellite Server
If you virtualize your Satellite Server and ensure that you take regular snapshots of the virtual machine (VM), you can respond to various disaster scenarios by restoring your Satellite deployment from one of your snapshots.
The details for how to implement this scenario depend on your choice of a virtualization platform. Due to the variety of different hypervisors and their capabilities, Red Hat does not provide detailed instructions for any specific virtualization platform. |
6.2.1. Prerequisites
Review Overview of recommended disaster recovery plans to make sure that this disaster recovery plan works for you.
Your Satellite Server is deployed as a VM.
6.2.2. Preparing for disaster recovery by virtualizing your Satellite Server
Implement a reliable process for regularly taking VM snapshots of your virtualized Satellite Server and for backing up your snapshots for long-term storage.
Define a schedule for taking periodic snapshots of your virtualized Satellite Server. Consider your tolerance for potential data loss: Taking snapshots frequently will result in smaller amounts of data loss in case of a disaster. However, creating a snapshot takes time, and the snapshots also require storage space.
Using your hypervisor, schedule periodic snapshots of your Satellite Server.
If you are using an external database that runs on a different machine than your Satellite Server, create snapshots and backups on the same schedule as your Satellite Server.
Use the latest snapshot of your Satellite Server and restore it in an isolated environment.
To verify that you will be able to restore Satellite services in case of a disaster, assess the functionality of the test Satellite Server. See Retrieving the status of services.
6.2.3. Recovering from disaster by restoring a VM snapshot of Satellite Server
In case of a disaster, use a virtual machine (VM) snapshot of your Satellite Server to restore Satellite services.
Ensure that the hostname of your Satellite Server does not change during recovery. The IP address can change. |
If you are using an external database that runs on a different machine than your Satellite Server, ensure that you restore the database from a snapshot taken at the same time as or before the Satellite Server snapshot.
Update DNS records so that the Satellite Server hostname resolves to the new IP address. This redirects traffic from the old server to the new server and you will not need to re-register your hosts.
Assess the functionality of your restored Satellite Server. See Retrieving the status of services.
6.2.4. Retrieving the status of services
Satellite uses a set of back-end services. When troubleshooting, you can check the status of Satellite services.
In the Satellite web UI, navigate to Administer > About.
On the Smart Proxies tab, view the status of all Capsules.
On the Compute Resources tab, view the status of attached compute resource providers.
In the Backend System Status table, view the status of all back-end services.
Get information from the database and Satellite services:
# hammer ping
Run
satellite-maintain service --helpfor more information. -
Perform a health check:
$ satellite-maintain health check
Run
satellite-maintain health --helpfor more information.
6.3. Disaster recovery for active and passive Satellite Server with external storage
To prepare for disaster recovery, you can configure two Satellite Servers and store critical data externally on shared storage. The primary server is active while the secondary server remains passive. If the primary server fails, the shared storage is attached to your secondary server, which turns the secondary server into your new primary server.
6.3.1. Prerequisites
Review Overview of recommended disaster recovery plans to ensure that this disaster recovery plan works for you.
Review Storage requirements and Storage guidelines in Installing Satellite Server in a connected network environment. Ensure that your shared storage meets the requirements of holding the contents of
/var/lib/pulpand/var/lib/pgsql. -
You have configured your Satellite Server to use external databases. For more information, see Using external databases in Installing Satellite Server in a connected network environment.
6.3.2. Preparing for disaster recovery with active and passive Satellite Server with external storage
Create your passive Satellite Server as a clone of your active Satellite Server.
Replicate the
/var/lib/pulpand/var/lib/pgsqldirectories from the active Satellite Server to your shared storage. -
Clone your active Satellite Server. For more information, see Cloning Satellite Server.
Assess the functionality of the test Satellite Server. For more information, see Retrieving the status of services.
For more information on mounting directories, see Mounting file systems on demand in Red Hat Enterprise Linux 9 Managing file systems.
6.3.3. Recovering from disaster with active and passive server with external storage
If your active Satellite Server fails, detach it from the shared storage and make sure your passive server can access the data stored on the shared storage. This turns the passive server into your new active server.
Assess the functionality of your new active Satellite Server. For more information, see Retrieving the status of services.
6.3.4. Retrieving the status of services
# hammer ping
Run
Run
6.4. Disaster recovery for active and passive Satellite Server with backup and restore
To prepare for disaster recovery, you can configure two Satellite Servers: an active primary server and a passive secondary server. You configure periodic backups of the primary server. If the primary server fails, you can restore a backup on the secondary server to turn it into your new primary server.
6.4.1. Prerequisites
You have a Satellite Server installed.
6.4.2. Preparing for disaster recovery with active and passive Satellite Server and backup and restore
Create your passive Satellite Server by restoring a backup of your active Satellite Server. Configure periodic backups of the active server.
Define a schedule for periodic offline backups of your active Satellite Server. Consider your tolerance for potential data loss and your storage options: Taking backups frequently will result in smaller amounts of data loss in case of a disaster, but backups require a significant amount of storage space. For information about the size of Satellite backups, see Estimating the size of a backup.
cronjob that ensures regular backups, see Example of a weekly full backup followed by daily incremental backups. -
Schedule periodic offline backups of your active Satellite Server to be taken according to the schedule you defined. For information about performing backups, see Backing up Satellite Server and Capsule Server.
Ensure that the backup directories are encrypted and regularly synchronized to a secure location. By default, Satellite stores the backups in the
/var/satellite-backupdirectory.ImportantSatellite Server backups contain sensitive information from the
/root/ssl-builddirectory. For example, they can contain hostnames, ssh keys, request files, and SSL certificates. Encrypting or moving the backups to a secure location helps minimize the risk of damage or unauthorized access to the hosts. -
Restore the most recent backup on a system that will serve as your passive Satellite Server. For information about restoring backups, see Restoring Satellite Server or Capsule Server from a backup.
Verify that Satellite takes backups according to the schedule you defined.
6.4.3. Recovering from disaster with active and passive server and backup and restore
If your active Satellite Server fails, activate your passive secondary server.
6.4.4. Retrieving the status of services
# hammer ping
Run
Run
6.4.5. Example of a weekly full backup followed by daily incremental backups
#!/bin/bash -e
satellite-maintain backup offline --assumeyes $DESTINATION
else
satellite-maintain backup offline --assumeyes --incremental "$LAST" $DESTINATION
fi
exit 0
Note that the satellite-maintain backup command requires /sbin and /usr/sbin directories to be in PATH and the --assumeyes option is used to skip the confirmation prompt.
6.5. Disaster recovery with two active Satellite Servers
To prepare for disaster recovery, you can configure two Satellite Servers and operate each server in a different data center. If one of the servers fails, you can re-register all hosts from the failed server to the other server.
6.5.1. Prerequisites
6.5.2. Preparing for disaster recovery with two active Satellite Servers
Create a second Satellite Server by restoring a backup of your first Satellite Server. Configure both servers to operate independently in their respective data centers, but ensure that their content does not drift apart over time.
Back up your Satellite Server. For more information, see Backing up Satellite Server and Capsule Server.
Restore the backup on a system that will serve as your other Satellite Server. For more information, see Restoring Satellite Server or Capsule Server from a backup.
redhat.satellite.repository_syncandredhat.satellite.sync_plan. -
If your disaster recovery site has network access to your primary site, use Inter-Satellite Synchronization (ISS) to ensure your disaster recovery server synchronizes its content from the primary server.
Register hosts to your servers so that each server manages hosts in its respective data center. For example, register all hosts in My_Data_Center_1 to one Satellite Server and all hosts in My_Data_Center_2 to the other Satellite Server.
Automate running the
satellite-maintain health checkcommand on both servers. The health check verifies whether the servers remain fully operational.
Verify that your
satellite-maintain health checkautomation reported an error. -
Ansible playbooks can help you automate failover, re-registration, and synchronization. For more information, see Managing Satellite with Ansible in Administering Red Hat Satellite.
For more information on synchronizing repositories, see Synchronizing repositories in Managing content.
For more information on synchronizing content between Satellite Servers, including ISS, export, and import, see Synchronizing content between Satellite Servers in Managing content.
6.5.3. Recovering from disaster with two active Satellite Servers
If the health checks implemented in Preparing for disaster recovery with two active Satellite Servers report an issue on one of your Satellite Servers, it might mean that the server has failed. If the server is down, you must re-register hosts to the other server.
# satellite-maintain health check
If
satellite-maintain health checkreported a problem, ensure that the server is powered off. -
7. Managing organizations
Organizations divide Red Hat Satellite resources into logical groups based on ownership, purpose, content, security level, or other divisions. You can create and manage multiple organizations through Red Hat Satellite, then divide and assign your Red Hat subscriptions to each individual organization. This provides a method of managing the content of several individual organizations under one management system.
7.1. Examples of using organizations in Satellite
- Single Organization
Using a single organization is well suited for a small business with a simple system administration chain.
In this case, you create a single organization for the business and assign content to it. You can also use the Default Organization for this purpose.
- Multiple Organizations
Using multiple organizations is well suited for a large company that owns several smaller business units. For example, a company with separate system administration and software development groups.
In this case, you create one organization for the company and then an organization for each of the business units it owns. You then assign content to each organization based on its needs.
- External Organizations
Using external organizations is well suited for a company that manages external systems for other organizations. For example, a company offering cloud computing and web hosting resources to customers.
In this case, you create an organization for the company’s own system infrastructure and then an organization for each external business. You then assign content to each organization where necessary.
7.2. Creating an organization
Use this procedure to create an organization. To use the CLI instead of the Satellite web UI, see the CLI procedure.
In the Satellite web UI, navigate to Administer > Organizations.
Click New Organization.
In the Name field, enter a name for the organization.
In the Label field, enter a unique identifier for the organization. This is used for creating and mapping certain assets, such as directories for content storage. Use letters, numbers, underscores, and dashes, but no spaces.
Optional: In the Description field, enter a description for the organization.
Click Submit.
If you have hosts with no organization assigned, select the hosts that you want to add to the organization, then click Proceed to Edit.
In the Edit page, assign the infrastructure resources that you want to add to the organization. This includes networking resources, installation media, Kickstart templates, and other parameters. You can return to this page at any time by navigating to Administer > Organizations and then selecting an organization to edit.
Click Submit.
To create an organization, enter the following command:
# hammer organization create \ --name "My_Organization" \ --label "My_Organization_Label" \ --description "My_Organization_Description"
Optional: To edit an organization, enter the
hammer organization updatecommand. For example, the following command assigns a compute resource to the organization:# hammer organization update \ --name "My_Organization" \ --compute-resource-ids 1
7.3. Creating an organization debug certificate
If you require a debug certificate for your organization, use the following procedure.
Select an organization that you want to generate a debug certificate for.
Click Generate and Download.
Save the certificate file in a secure location.
Debug Certificates are automatically generated for provisioning template downloads if they do not already exist in the organization for which they are being downloaded.
7.4. Browsing repository content using an organization debug certificate
You can view an organization’s repository content using a web browser or using the API if you have a debug certificate for that organization.
You created and downloaded an organization certificate. For more information, see Creating an organization debug certificate.
Split the private and public keys from the certificate into two files.
Open the X.509 certificate, for example, for the default organization:
$ vi 'Default Organization-key-cert.pem'
Copy the contents of the file from
-----BEGIN RSA PRIVATE KEY-----to-----END RSA PRIVATE KEY-----, into akey.pemfile. -
-----BEGIN CERTIFICATE-----to-----END CERTIFICATE-----, into acert.pemfile.
To use a browser, you must first convert the X.509 certificate to a format your browser supports and then import the certificate.
Convert the certificate into the PKCS12 format using the following command:
$ openssl pkcs12 -keypbe PBE-SHA1-3DES -certpbe PBE-SHA1-3DES -export -in cert.pem -inkey key.pem -out My_Organization_Label.pfx -name My_Organization
In the Firefox browser, navigate to Edit > Preferences > Advanced Tab.
Select View Certificates and click the Your Certificates tab.
Click Import and select the
.pfxfile to load. -
Enter the following URL in the address bar to browse the accessible paths for all the repositories and check their contents:
https://satellite.example.com/pulp/content/
To use the organization debug certificate with CURL, enter the following command:
$ curl -k --cert cert.pem --key key.pem \ https://satellite.example.com/pulp/content/My_Organization_Label/Library/content/dist/rhel/server/7/7Server/x86_64/os/
Ensure that the paths to
cert.pemandkey.pemare the correct absolute paths otherwise the command fails silently. Pulp uses the organization label, therefore, you must enter the organization label into the URL.
7.5. Deleting an organization
You can delete an organization if the organization is not associated with any lifecycle environments or host groups. If there are any lifecycle environments or host groups associated with the organization you are about to delete, remove them by navigating to Administer > Organizations and clicking the relevant organization.
Do not delete Default Organization created during installation because the default organization is a placeholder for any unassociated hosts in your Satellite environment. There must be at least one organization in the environment at any given time. |
From the list to the right of the name of the organization you want to delete, select Delete.
Click OK to delete the organization.
Enter the following command to retrieve the ID of the organization that you want to delete:
# hammer organization list
From the output, note the ID of the organization that you want to delete.
Enter the following command to delete an organization:
# hammer organization delete --id Organization_ID
8. Managing locations
Locations function similar to organizations: they provide a method to group resources and assign hosts. Organizations and locations have the following conceptual differences:
Locations are based on physical or geographical settings.
Locations have a hierarchical structure.
8.1. Creating a location
Use this procedure to create a location so that you can manage your hosts and resources by location. To use the CLI instead of the Satellite web UI, see the CLI procedure.
In the Satellite web UI, navigate to Administer > Locations.
Click New Location.
Optional: From the Parent list, select a parent location. This creates a location hierarchy.
In the Name field, enter a name for the location.
Optional: In the Description field, enter a description for the location.
Click Submit.
If you have hosts with no location assigned, add any hosts that you want to assign to the new location, then click Proceed to Edit.
Assign any infrastructure resources that you want to add to the location. This includes networking resources, installation media, Kickstart templates, and other parameters. You can return to this page at any time by navigating to Administer > Locations and then selecting a location to edit.
Click Submit to save your changes.
Enter the following command to create a location:
# hammer location create \ --description "My_Location_Description" \ --name "My_Location" \ --parent-id "My_Location_Parent_ID"
8.2. Creating multiple locations
The following example Bash script creates three locations – London, Munich, Boston – and assigns them to the Example Organization.
ORG="Example Organization"
LOCATIONS="London Munich Boston"
for LOC in ${LOCATIONS}
do
hammer location create --name "${LOC}"
hammer location add-organization --name "${LOC}" --organization "${ORG}"
done
8.3. Setting the location context
A location context defines the location to use for a host and its associated resources.
The location menu is the second menu item in the menu bar, on the upper left of the Satellite web UI. If you have not selected a current location, the menu displays Any Location. Click Any location and select the location to use.
While using the CLI, include either --location "My_Location" or --location-id "My_Location_ID" as an option.
For example:
# hammer host list --location "My_Location"
This command lists hosts associated with the My_Location location.
8.4. Deleting a location
You can delete a location if the location is not associated with any lifecycle environments or host groups. If there are any lifecycle environments or host groups associated with the location you are about to delete, remove them by navigating to Administer > Locations and clicking the relevant location. Do not delete the default location created during installation because the default location is a placeholder for any unassociated hosts in the Satellite environment. There must be at least one location in the environment at any given time.
Select Delete from the list to the right of the name of the location you want to delete.
Click OK to delete the location.
Enter the following command to retrieve the ID of the location that you want to delete:
# hammer location list
From the output, note the ID of the location that you want to delete.
Enter the following command to delete the location:
# hammer location delete --id Location ID
9. Managing users and roles
A User defines a set of details for individuals who use the system. Users can be associated with organizations and environments, so that when they create new entities, the default settings are automatically used. Users can also have one or more roles attached, which grants them rights to view and manage organizations and environments. See Managing users for more information on working with users.
You can manage permissions of several users at once by organizing them into user groups. User groups themselves can be further grouped to create a hierarchy of permissions. For more information on creating user groups, see Creating and managing user groups.
Roles define a set of permissions and access levels. Each role contains one on more permission filters that specify the actions allowed for the role. Actions are grouped according to the Resource type. Once a role has been created, users and user groups can be associated with that role. This way, you can assign the same set of permissions to large groups of users. Satellite provides a set of predefined roles and also enables creating custom roles and permission filters as described in Creating and managing roles.
9.1. Managing users
As an administrator, you can create, modify and remove Satellite users. You can also configure access permissions for a user or a group of users by assigning them different roles.
9.1.1. Creating a user
Use this procedure to create a user. To use the CLI instead of the Satellite web UI, see the CLI procedure.
In the Satellite web UI, navigate to Administer > Users.
Click Create User.
Enter the account details for the new user.
On the User tab, select an authentication source from the Authorized by list:
INTERNAL: to manage the user inside Satellite Server.
EXTERNAL: to manage the user with external authentication. For more information, see Configuring authentication for Red Hat Satellite users.
On the Organizations tab, select an organization for the user. Specify the default organization Satellite selects for the user after login from the Default on login list.
ImportantIf a user is not assigned to an organization, their access is limited.
Create a user:
# hammer user create \ --auth-source-id My_Authentication_Source \ --login My_User_Name \ --mail My_User_Mail \ --organization-ids My_Organization_ID_1,My_Organization_ID_2 \ --password My_User_Password
The
--auth-source-id 1setting means that the user is authenticated internally, you can specify an external authentication source as an alternative. Add the--adminoption to grant administrator privileges to the user. Specifying organization IDs is not required.You can modify the user details later by using the
hammer user updatecommand.
For more information about creating user accounts by using Hammer, enter
hammer user create --help.
9.1.2. Assigning roles to a user
Use this procedure to assign roles to a user. To use the CLI instead of the Satellite web UI, see the CLI procedure.
NoteIf a user account is not listed, check that you are currently viewing the correct organization. To list all the users in Satellite, click Default Organization and then Any Organization.
Click Submit.
9.1.3. Impersonating a different user account
Administrators can impersonate other authenticated users for testing and troubleshooting purposes by temporarily logging on to the Satellite web UI as a different user. When impersonating another user, the administrator has permissions to access exactly what the impersonated user can access in the system, including the same menus.
Ensure that you are logged on to the Satellite web UI as a user with administrator privileges for Satellite.
9.1.4. Creating an API-only user
You can create users that can interact only with the Satellite API.
You have created a user and assigned roles to them. Note that this user must be authorized internally. For more information, see the following sections:
Log in to your Satellite as admin.
# openssl rand -hex 32
9.2. Managing SSH keys
For information on SSH keys and SSH key creation, see Using SSH-based Authentication in Red Hat Enterprise Linux 8 Configuring basic system settings.
9.2.1. Managing SSH keys for a user
Use this procedure to add or remove SSH keys for a user. To use the CLI instead of the Satellite web UI, see the CLI procedure.
Ensure that you are logged in to the Satellite web UI as an Admin user of Red Hat Satellite or a user with the create_ssh_key permission enabled for adding SSH key and destroy_ssh_key permission for removing a key.
Click on the SSH Keys tab.
To Add SSH key
Click Add SSH Key.
Click Submit.
To Remove SSH key
# hammer user ssh-keys add \ --user-id user_id \ --name key_name \ --key-file ~/.ssh/id_rsa.pub
# hammer user ssh-keys add \ --user-id user_id \ --name key_name \ --key ecdsa-sha2-nistp256 AAAAE2VjZHNhLXNoYTItbmlzdHAyNTYAAAAIbmlzdHAyNtYAAABBBHHS2KmNyIYa27Qaa7EHp+2l99ucGStx4P77e03ZvE3yVRJEFikpoP3MJtYYfIe8k 1/46MTIZo9CPTX4CYUHeN8= host@user
9.3. Managing Personal Access Tokens
9.3.1. Creating a Personal Access Token
Make an API request to your Satellite Server and authenticate with your Personal Access Token:
# curl https://satellite.example.com/api/status --user My_Username:My_Personal_Access_Token
200, for example:{"satellite_version":"6.16.0","result":"ok","status":200,"version":"3.5.1.10","api_version":2}If you go back to Personal Access Tokens tab, you can see the updated Last Used time next to your Personal Access Token.
9.3.2. Revoking a Personal Access Token
Make an API request to your Satellite Server and try to authenticate with the revoked Personal Access Token:
9.4. Creating and managing user groups
9.4.1. User groups
With Satellite, you can assign permissions to groups of users. You can also create user groups as collections of other user groups. If you use an external authentication source, you can map Satellite user groups to external user groups as described in Configuring external user groups in Configuring authentication for Red Hat Satellite users.
9.4.2. Creating a user group
In the Satellite web UI, navigate to Administer > User Groups.
Click Create User group.
Click Submit.
To create a user group, enter the following command:
# hammer user-group create \ --name My_User_Group_Name \ --role-ids My_Role_ID_1,My_Role_ID_2 \ --user-ids My_User_ID_1,My_User_ID_2
9.5. Creating and managing roles
Satellite provides a set of predefined roles with permissions sufficient for standard tasks, as listed in Predefined roles available in Satellite. It is also possible to configure custom roles, and assign one or more permission filters to them. Permission filters define the actions allowed for a certain resource type. Certain Satellite plugins create roles automatically.
9.5.1. Creating a role
In the Satellite web UI, navigate to Administer > Roles.
Click Create Role.
Provide a Name for the role.
To serve its purpose, a role must contain permissions. After creating a role, proceed to Adding permissions to a role.
9.5.2. Cloning a role
Use the Satellite web UI to clone a role.
In the Satellite web UI, navigate to Administer > Roles and select Clone from the drop-down menu to the right of the required role.
9.5.3. Adding permissions to a role
Use this procedure to add permissions to a role. To use the CLI instead of the Satellite web UI, see the CLI procedure.
Depending on the Resource type selected, you can select or deselect the Unlimited and Override checkbox. The Unlimited checkbox is selected by default, which means that the permission is applied on all resources of the selected type. When you disable the Unlimited checkbox, the Search field activates. In this field you can specify further filtering with use of the Satellite search syntax. For more information, see Granular permission filtering. When you enable the Override checkbox, you can add additional locations and organizations to allow the role to access the resource type in the additional locations and organizations; you can also remove an already associated location and organization from the resource type to restrict access.
Click Next.
Click Submit to save changes.
Add permissions to a role:
# hammer filter create \ --permission-ids My_Permission_ID_1,My_Permission_ID_2 \ --role My_Role_Name
9.5.4. Viewing permissions of a role
Use the Satellite web UI to view the permissions of a role.
The Filters page contains a table of permissions assigned to a role grouped by the resource type. It is also possible to generate a complete table of permissions and actions that you can use on your Satellite system. For more information, see Creating a complete permission table.
9.5.5. Creating a complete permission table
Use the Satellite CLI to create a permission table.
Start the Satellite console with the following command:
# foreman-rake console
/tmp/table.htmlfile. -
Press
Ctrl+Dto exit the Satellite console. -
/tmp/table.html:<table border="1"><tr><td>Permission name</td><td>Actions</td><td>Resource type</td></tr>
/tmp/table.html:</table>
Open
9.6. Predefined roles available in Satellite
The following table provides an overview of permissions that predefined roles in Satellite grant to a user.
For a complete set of predefined roles and the permissions they grant, log in to Satellite web UI as the privileged user and navigate to Administer > Roles. For more information, see Viewing permissions of a role.
Auditor |
View the Audit log. |
Default role |
Satellite automatically assigns this role to every user in the system. |
Manager |
Organization admin |
Site manager |
System admin |
Viewer |
View the configuration of every element of the Satellite structure, logs, reports, and statistics. |
9.7. Granular permission filtering
As mentioned in Adding permissions to a role, Red Hat Satellite provides the ability to limit the configured user permissions to selected instances of a resource type. These granular filters are queries to the Satellite database and are supported by the majority of resource types.
9.7.1. Creating a granular permission filter
Use this procedure to create a granular filter. To use the CLI instead of the Satellite web UI, see the CLI procedure.
Satellite does not apply search conditions to create actions. For example, limiting the create_locations action with name = "Default Location" expression in the search field does not prevent the user from assigning a custom name to the newly created location.
field_name operator value
operator specifies the type of comparison between field_name and value. See Supported operators for granular search for an overview of applicable operators.
hammer filter createcommand with the--searchoption to limit permission filters, for example:# hammer filter create \ --permission-ids 91 \ --search "name ~ ccv*" \ --role qa-user
This command adds to the qa-user role a permission to view, create, edit, and destroy content views that only applies to content views with name starting with ccv.
9.7.2. Examples of using granular permission filters
Applying permissions for the host resource type
hostgroup = host-editors
name ^ (XXXX, Yyyy, zzzz)
Dev
You can limit user permissions to a certain organization or location with the use of the granular permission filter in the Search field. However, some resource types provide a GUI alternative, an Override checkbox that provides the Locations and Organizations tabs. On these tabs, you can select from the list of available organizations and locations. For more information, see Creating an organization-specific manager role.
Use the Satellite web UI to create an administrative role restricted to a single organization named org-1.
9.7.3. Supported operators for granular search
Operator |
Description |
and |
Combines search criteria. |
not |
Negates an expression. |
has |
Operator |
Description |
10. Configuring email notifications
Email notifications are created by Satellite Server periodically or after completion of certain events. The periodic notifications can be sent daily, weekly or monthly.
For an overview of available notification types, see Email notification types.
Satellite Server does not enable outgoing emails by default, therefore you must review your email configuration. For more information, see Configuring Satellite Server for Outgoing Emails in Installing Satellite Server in a connected network environment. |
10.1. Email notification types
Satellite can create the following email notifications:
- Audit summary
A summary of all activity audited by Satellite Server.
- Capsule sync failure
A notification sent after Capsule synchronization fails.
- Compliance policy summary
- Content view promote failure
- Content view publish failure
- Host built
- Host errata advisory
- Promote errata
- Repository sync failure
- Sync errata
For a complete list of email notification types, navigate to Administer > Users in the Satellite web UI, click the Username of the required user, and select the Email Preferences tab.
10.2. Configuring email notification preferences
You can configure Satellite to send email messages to individual users registered to Satellite. Satellite sends the email to the email address that has been added to the account, if present. Users can edit the email address by clicking on their name in the top-right of the Satellite web UI and selecting My account.
Configure email notifications for a user from the Satellite web UI.
If you want to send email notifications to a group email address instead of an individual email address, create a user account with the group email address and minimal Satellite permissions, then subscribe the user account to the desired notification types. |
view_mail_notifications.
Click Submit.
10.3. Testing email delivery
Click on the username.
Verify Satellite Server’s email configuration.
If your Satellite Server uses the Postfix service for email delivery, the test email might be held in the queue. To verify, enter the
mailqcommand to list the current mail queue. If the test email is held in the queue,mailqdisplays the following message:postqueue: warning: Mail system is down -- accessing queue directly -Queue ID- --Size-- ----Arrival Time---- -Sender/Recipient------- BE68482A783 1922 Thu Oct 3 05:13:36 satellite-noreply@example.com
To fix the problem, start the Postfix service on your Satellite Server:
# systemctl start postfix
10.4. Testing email notifications
To trigger the notifications, execute the following command:
daily
weekly
monthly
10.5. Changing email notification settings for a host
Satellite can send event notifications for a host to the host’s registered owner. You can configure Satellite to send email notifications either to an individual user or a user group. When set to a user group, all group members who are subscribed to the email type receive a message.
In the Satellite web UI, navigate to Hosts > All Hosts, locate the host that you want to view, and click Edit in the Actions column.
Go to the Additional Information tab. If the checkbox Include this host within Satellite reporting is checked, then the email notifications are enabled on that host.
11. Backing up Satellite Server and Capsule Server
You can back up your Satellite deployment to ensure the continuity of your Red Hat Satellite deployment and associated data in the event of a disaster. If your deployment uses custom configurations, you must consider how to handle these custom configurations when you plan your backup and disaster recovery policy.
If you create a new instance of the Satellite Server, decommission the old instances after restoring the backup. Cloned instances are not supposed to run in parallel in a production environment. |
To create a backup of your Satellite Server or Capsule Server and all associated data, use the satellite-maintain backup command.
Satellite services are unavailable during the backup.
You can schedule a backup by using cron.
For more information, see the Example of a weekly full backup followed by daily incremental backups.
During offline backups, the services are inactive and Satellite is in a maintenance mode. All the traffic from outside on port 443 is rejected by a firewall to ensure there are no modifications triggered.
A backup contains sensitive information from the /root/ssl-build directory.
You can also use conventional backup methods. For more information, see Recovering and restoring a system in Red Hat Enterprise Linux 8 Configuring basic system settings.
If you plan to use the |
When creating a snapshot or conventional backup, you must stop all services as follows:
Start the services after creating a snapshot or conventional backup:
11.1. Estimating the size of a backup
The full backup creates uncompressed archives of PostgreSQL and Pulp database files, and Satellite configuration files. Compression occurs after the archives are created to decrease the time when Satellite services are unavailable.
Uncompressed Satellite database and configuration files
Compressed Satellite database and configuration files
Enter the
ducommand to estimate the size of uncompressed directories containing Satellite database and configuration files:# du -sh /var/lib/pgsql/data /var/lib/pulp 100G /var/lib/pgsql/data 100G /var/lib/pulp # du -csh /var/lib/tftpboot /etc /root/ssl-build \ /var/www/html/pub /opt/puppetlabs 16M /var/lib/tftpboot 37M /etc 900K /root/ssl-build 100K /var/www/html/pub 2M /opt/puppetlabs 942M total
Table 3. Backup data compression ratio Data type Directory Ratio Example results PostgreSQL database files
/var/lib/pgsql/data80 – 85%
100 GB → 20 GB
Pulp RPM files
/var/lib/pulp(not compressed)
100 GB
Configuration files
/var/lib/tftpboot
/etc
/root/ssl-build
/var/www/html/pub
/opt/puppetlabs85%
942 MB → 141 MB
11.2. Performing a full backup of Satellite Server or Capsule Server
Red Hat Satellite uses the satellite-maintain backup command to make backups.
There are two main methods of backing up Satellite Server:
Offline backup
All Satellite services are shut down during an offline backup.
Online backup
Only Satellite services that affect the consistency of the backup, including all background workers, are shut down while the backup process is running. Online backups check for consistency and require more time than offline backups.
# satellite-maintain backup offline --help
# satellite-maintain backup online --help
The satellite-maintain backup command creates a time-stamped subdirectory in the backup directory that you specify.
The satellite-maintain backup command does not overwrite backups, therefore you must select the correct directory or subdirectory when restoring from a backup or an incremental backup.
The satellite-maintain backup command stops and restarts services as required.
When you run the satellite-maintain backup offline command, the following default backup directories are created:
satellite-backupon Satellite -
foreman-proxy-backupon Capsule
You can use the satellite-maintain backup command to back up remote databases.
You can use both online and offline methods to back up remote databases, but if you use offline method, the satellite-maintain backup command performs a database dump.
To enable Satellite to save the backup to an NFS share, ensure that the root user of your Satellite Server or Capsule Server can write to the NFS share.
NFS export options such as root_squash and all_squash are known to prevent this.
For more information, see Red Hat Enterprise Linux Configuring and using network files services and Red Hat Enterprise Linux Securing network services.
Ensure that your backup location has sufficient available disk space to store the backup. For more information, see Estimating the size of a backup.
Warning
Request other users of Satellite Server or Capsule Server to save any changes and warn them that Satellite services are unavailable for the duration of the backup. Ensure no other tasks are scheduled for the same time as the backup. |
On Satellite Server, enter the following command:
# satellite-maintain backup offline /var/satellite-backup
On Capsule Server, enter the following command:
# satellite-maintain backup offline /var/foreman-proxy-backup
11.3. Performing a backup without Pulp content
Warning
# satellite-maintain backup offline --skip-pulp-content /var/backup_directory
11.4. Performing an incremental backup
Warning
To perform a full offline backup, enter the following command:
# satellite-maintain backup offline /var/backup_directory
To create a directory within your backup directory to store the first incremental back up, enter the
satellite-maintain backupcommand with the--incrementaloption:# satellite-maintain backup offline --incremental /var/backup_directory/full_backup /var/backup_directory
To create the second incremental backup, enter the
satellite-maintain backupcommand with the--incrementaloption and include the path to the first incremental backup to indicate the starting point for the next increment. This creates a directory for the second incremental backup in your backup directory:# satellite-maintain backup offline --incremental /var/backup_directory/first_incremental_backup /var/backup_directory
11.5. Example of a weekly full backup followed by daily incremental backups
#!/bin/bash -e
else
fi
exit 0
11.6. Performing an online backup
When you perform an online backup, most Satellite services remain running and usable.
Background workers are shut down to ensure consistent backups.
Operations that require background workers remain in pending state.
The backup process ensures that the Pulp data (/var/lib/pulp) is not altered during the backup.
Any changes to the Pulp data during the backup will result in restart of the backup process, taking additional time.
Warning
Request other users of Satellite Server or Capsule Server to save any changes and warn them that some Satellite services may be unavailable for the duration of the backup. Ensure no other tasks are scheduled for the same time as the backup. |
To perform an online backup, enter the following command:
# satellite-maintain backup online /var/backup_directory
12. Restoring Satellite Server or Capsule Server from a backup
You can restore Satellite Server or Capsule Server from the backup data that you create as part of Backing up Satellite Server and Capsule Server. This process outlines how to restore the backup on the same server that generated the backup, and all data covered by the backup is deleted on the target system. If the original system is unavailable, provision a system with the same configuration settings and host name.
You cannot restore backups of a system without FIPS enabled on a FIPS enabled system. |
12.1. Restoring from a full backup
Use this procedure to restore Red Hat Satellite or Capsule Server from a full backup. When the restore process completes, all processes are online, and all databases and system configuration revert to the state at the time of the backup.
Ensure that you are restoring to the correct instance. The Red Hat Satellite instance must have the same host name, configuration, and be the same minor version (X.Y) as the original system.
Ensure that you have enough space to store this data on the base system of Satellite Server or Capsule Server as well as enough space after the restoration to contain all the data in the
/etc/and/var/directories contained within the backup.To check the space used by a directory, enter the following command:
# df -h /var/backup_directory
Add the
# restorecon -Rv /
Choose the appropriate method to install Satellite or Capsule:
To install Satellite Server from a connected network, follow the procedures in Installing Satellite Server in a connected network environment.
To install Satellite Server from a disconnected network, follow the procedures in Installing Satellite Server in a disconnected network environment.
To install a Capsule Server, follow the procedures in Installing Capsule Server.
Copy the backup data to Satellite Server’s local file system. Use
/var/or/var/tmp/. -
Run the restoration script.
# satellite-maintain restore /var/backup_directory
For troubleshooting, you can check
/var/log/foreman/production.logand/var/log/messages.
12.2. Restoring from incremental backups
Use this procedure to restore Satellite or Capsule Server from incremental backups. If you have multiple branches of incremental backups, select your full backup and each incremental backup for the branch you want to restore, in chronological order.
Restore the last full backup using the instructions in Restoring from a full backup.
Remove the full backup data from Satellite Server’s local file system, for example,
/var/or/var/tmp/. -
Copy the incremental backup data to Satellite Server’s local file system, for example,
/var/or/var/tmp/. -
# satellite-maintain restore /var/backup_directory/FIRST_INCREMENTAL # satellite-maintain restore /var/backup_directory/SECOND_INCREMENTAL
12.3. Backup and restore Capsule Server by using a virtual machine snapshot
If your Capsule Server is a virtual machine, you can restore it from a snapshot. Creating weekly snapshots to restore from is recommended. In the event of failure, you can install, or configure a new Capsule Server, and then synchronize the database content from Satellite Server.
If required, deploy a new Capsule Server, ensuring the host name is the same as before, and then install the Capsule certificates. You may still have them on Satellite Server, the package name ends in -certs.tar, alternately create new ones. Follow the procedures in Installing Capsule Server until you can confirm, in the Satellite web UI, that Capsule Server is connected to Satellite Server. Then use the procedure Synchronizing content from Satellite Server to Capsule Servers to synchronize from Satellite.
12.3.1. Synchronizing content from Satellite Server to Capsule Servers
Use this procedure to synchronize content from your Satellite Server to your Capsule Server.
Ensure that you either select the relevant organization and location context of your Capsule Server or choose Any Organization and Any Location.
In the Satellite web UI, navigate to Infrastructure > Capsules.
Select your Capsule Server.
Select Optimized Sync to synchronize content from your Satellite Server to your Capsule Server that bypasses unnecessary steps to speed up performance.
Select Complete Sync to perform a complete sync from your Satellite Server to your Capsule Server that synchronizes content even if the metadata has not changed.
13. Renaming Satellite Server or Capsule Server
To rename Satellite Server or Capsule Server, use the satellite-change-hostname script.
If you change the domain name of your Satellite Server or Capsule Server, you must update the hostname by using the |
13.1. Renaming Satellite Server
The host name of Satellite Server is used by Satellite Server components, all Capsule Servers, and hosts registered to it for communication. This procedure ensures that in addition to renaming Satellite Server, you also update all references to point to the new host name.
Warning
Renaming your Satellite Server host shuts down all Satellite services on that host. The services restart after the renaming is complete. |
Back up your Satellite Server before changing its host name. If you fail to successfully rename it, restore it from the backup. For more information, see Backing up Satellite Server and Capsule Server.
Run the
hostnameandhostname -fcommands on Satellite Server. If both commands do not return the FQDN of Satellite Server, thesatellite-change-hostnamescript will fail to complete.If the
hostnamecommand returns the shortname of Satellite Server instead of the FQDN, usehostnamectl set-hostname My_Old_FQDNto set the old FQDN correctly before using thesatellite-change-hostnamescript. -
If Satellite Server has a custom SSL certificate installed, obtain a new certificate for the new FQDN of the host. For more information, see Configuring Satellite Server with a Custom SSL Certificate in Installing Satellite Server in a connected network environment.
On Satellite Server, run the
satellite-change-hostnamescript, and provide the new host name. Choose one of the following methods:-
If your Satellite Server is installed with the default self-signed SSL certificates:
# satellite-change-hostname new-satellite \ --username My_Username \ --password 'My_Password'
If your Satellite Server is installed with custom SSL certificates:
# satellite-change-hostname new-satellite \ --username My_Username \ --password 'My_Password' \ --custom-cert "/root/ownca/test.com/test.com.crt" \ --custom-key "/root/ownca/test.com/test.com.key"
If you have created a custom SSL certificate for the new Satellite Server host name, run the Satellite installation script to install the certificate. For more information about installing a custom SSL certificate, see Deploying a Custom SSL Certificate to Satellite Server in Installing Satellite Server in a connected network environment.
Reregister all hosts and Capsule Servers that are registered to Satellite Server. For more information, see Registering hosts by using global registration in Managing hosts.
On all Capsule Servers, run the Satellite installation script to update references to the new host name:
# satellite-installer \ --foreman-proxy-foreman-base-url https://new-satellite.example.com \ --foreman-proxy-trusted-hosts new-satellite.example.com
On Satellite Server, list all Capsule Servers:
# hammer capsule list
On Satellite Server, synchronize content for each Capsule Server:
# hammer capsule content synchronize \ --id My_Capsule_ID
If you use the virt-who agent, update the virt-who configuration files with the new host name. For more information, see Modifying a virt-who Configuration in Configuring virtual machine subscriptions.
If you use external authentication, reconfigure Satellite Server for external authentication after you run the
satellite-change-hostnamescript. For more information, see Configuring authentication for Red Hat Satellite users.
13.2. Renaming Capsule Server
The host name of Capsule Server is referenced by Satellite Server components and all hosts registered to it. This procedure ensures that in addition to renaming Capsule Server, you also update all references to the new host name.
Warning
Renaming your Capsule Server host shuts down all Satellite services on that host. The services restart after the renaming is complete. |
Back up your Capsule Server before renaming. If you fail to successfully rename it, restore it from the backup. For more information, see Backing up Satellite Server and Capsule Server.
Run the
hostnameandhostname -fcommands on Capsule Server. If both commands do not return the FQDN of Capsule Server, thesatellite-change-hostnamescript will fail to complete.If the
hostnamecommand returns the shortname of Capsule Server instead of the FQDN, usehostnamectl set-hostname My_Old_FQDNto set the old FQDN correctly before attempting to use thesatellite-change-hostnamescript.
On your Satellite Server, generate a new certificates archive file for your Capsule Server.
If you are using the default SSL certificate, regenerate the default SSL certificates:
# capsule-certs-generate \ --certs-tar /root/new-capsule.example.com-certs.tar \ --foreman-proxy-fqdn new-capsule.example.com
.tarfile. -
If you are using a custom SSL certificate, create a new SSL certificate for your Capsule Server. For more information, see Configuring Capsule Server with a Custom SSL Certificate in Installing Capsule Server.
On your Satellite Server, copy the certificates archive file to your Capsule Server. For example, to copy the archive file to the
rootuser’s home directory:# scp /root/new-capsule.example.com-certs.tar root@capsule.example.com:
On your Capsule Server, run the
satellite-change-hostnamescript and provide the host’s new name, Satellite credentials, and certificates archive file name.# satellite-change-hostname new-capsule.example.com \ --certs-tar /root/new-capsule.example.com-certs.tar \ --password 'My_Password' \ --username My_Username
.tarfile. -
If you have created a custom certificate for your Capsule Server, deploy the certificate to your Capsule Server by entering the
satellite-installercommand that thecapsule-certs-generatecommand returned in a previous step. For more information, see Deploying a Custom SSL Certificate to Capsule Server in Installing Capsule Server. -
Reregister all hosts that are registered to your Capsule Server. For more information, see Registering hosts and setting up host integration in Managing hosts.
Update the Capsule host name in the Satellite web UI.
Locate Capsule Server in the list, and click Edit.
Edit the Name and URL fields to match Capsule Server’s new host name, then click Submit.
On your DNS server, add a record for the new hostname of your Capsule Server, and delete the record of the previous host name.
14. Maintaining Satellite Server
This chapter provides information on how to maintain Satellite Server, including information on how to recover Pulp from a full disk, how to work with audit records, and how to clean unused tasks.
14.1. Deleting audit records manually
Number_Of_Days.
14.2. Deleting audit records automatically
This setting is empty by default, meaning Satellite does not automatically delete the audit records.
In the Satellite web UI, navigate to Administer > Settings.
Set the value of the setting to the number of days after which you want Satellite to delete the audit records.
14.3. Anonymizing audit records
You can use the foreman-rake audits:anonymize command to remove any user account or IP information while maintaining the audit records in the database.
You can also use a cron job to schedule anonymizing the audit records at the set interval that you want.
By default, using the foreman-rake audits:anonymize command anonymizes audit records that are older than 90 days.
You can specify the number of days to keep the audit records by adding the days option and add the number of days.
14.4. Deleting report records
Report records are created automatically in Satellite.
You can use the foreman-rake reports:expire command to remove reports at any time.
You can also use a cron job to schedule report record deletions at the set interval that you want.
By default, using the foreman-rake reports:expire command removes report records that are older than 90 days.
You can specify the number of days to keep the report records by adding the days option and add the number of days.
14.5. Configuring the cleaning unused tasks feature
Satellite performs regular cleaning to reduce disc space in the database and limit the rate of disk growth. As a result, Satellite backup completes faster and overall performance is higher.
By default, Satellite executes a cron job that cleans tasks every day at 19:45. Satellite removes the following tasks during the cleaning:
To configure the time at which Satellite runs the cron job, set the
--foreman-plugin-tasks-cron-lineparameter to the time you want in cron format. For example, to schedule the cron job to run every day at 15:00, enter the following command:# satellite-installer --foreman-plugin-tasks-cron-line "00 15 * * *"
To configure the period after which Satellite deletes the tasks, edit the
To disable regular task cleanup on Satellite, enter the following command:
# satellite-installer --foreman-plugin-tasks-automatic-cleanup false
To reenable regular task cleanup on Satellite, enter the following command:
# satellite-installer --foreman-plugin-tasks-automatic-cleanup true
14.6. Deleting task records
Task records are created automatically in Satellite.
You can use the foreman-rake foreman_tasks:cleanup command to remove tasks at any time.
You can also use a cron job to schedule Task record deletions at the set interval that you want.
14.7. Deleting a task by ID
Connect to your Satellite Server using SSH:
# ssh root@satellite.example.com
Optional: View the task:
Delete the task:
Optional: Ensure the task has been removed from Satellite Server:
14.8. Recovering from a full disk
Ensure that the LV with the
Remove orphaned content:
Change the download policy from Immediate to On Demand for as many repositories as possible and remove already downloaded packages. See the Red Hat Knowledgebase solution How to change syncing policy for Repositories on Satellite from "Immediate" to "On-Demand" on the Red Hat Customer Portal for instructions.
/var/lib/pulpdirectory on it. For more information, see Growing a logical volume and file system in Red Hat Enterprise Linux 8 Configuring and managing logical volumes.NoteIf you use an untypical file system (other than for example ext3, ext4, or xfs), you might need to unmount the file system so that it is not in use. In that case, complete the following steps:
Stop Satellite services:
Start Satellite services:
14.9. Reclaiming PostgreSQL space
The PostgreSQL database can use a large amount of disk space especially in heavily loaded deployments. Use this procedure to reclaim some of this disk space on Satellite.
postgresqlservice:# satellite-maintain service stop --exclude postgresql
Switch to the
14.10. Reclaiming space from on demand repositories
If you set the download policy to on demand, Satellite downloads packages only when the clients request them. You can clean up these packages to reclaim space.
In the Satellite web UI, navigate to Content > Products.
Select a product.
Select the product name.
Select the Capsule Server.
Click Reclaim space.
15. Renewing certificates
You can renew the CA certificate on Satellite Server or the custom SSL certificate on Satellite Server as well as on Capsule Server.
15.1. Planning for self-signed CA certificate renewal
If you need to update the Certification Authority (CA) certificate on your Satellite Server, add the new CA certificate and use a temporary dual CA certificate file to retain the HTTPS connections to your Satellite Server during the renewal.
Add the new SSL certificate to the CA certificate file on Satellite Server and keep the old SSL certificate.
Renew the certificates on Satellite Server and any Capsule Servers.
Deploy the dual CA certificate on hosts.
Remove the old certificate from the CA certificates file on Satellite Server, so the CA certificate file contains only the new SSL certificate.
Deploy the new CA certificate on hosts.
Refreshing the self-signed CA certificate on hosts in Managing hosts
15.2. Renewing a custom SSL certificate on Satellite Server
Use this procedure to update your custom SSL certificate for Satellite Server.
You must create a new Certificate Signing Request (CSR) and send it to the Certificate Authority to sign the certificate. Refer to the Configuring Satellite Server with a custom SSL certificate guide before creating a new CSR because the Server certificate must have X.509 v3
Key UsageandExtended Key Usageextensions with required values. In return, you will receive the Satellite Server certificate and CA bundle.
Before deploying a renewed custom certificate on your Satellite Server, validate the custom SSL input files. Note that for the
katello-certs-checkcommand to work correctly, Common Name (CN) in the certificate must match the FQDN of Satellite Server:# katello-certs-check -t satellite \ -b /root/satellite_cert/ca_cert_bundle.pem \ -c /root/satellite_cert/satellite_cert.pem \ -k /root/satellite_cert/satellite_cert_key.pem
If the command is successful, it returns the following
satellite-installercommand. You can use this command to deploy the renewed CA certificates to Satellite Server:# satellite-installer --scenario satellite \ --certs-server-cert "/root/satellite_cert/satellite_cert.pem" \ --certs-server-key "/root/satellite_cert/satellite_cert_key.pem" \ --certs-server-ca-cert "/root/satellite_cert/ca_cert_bundle.pem" \ --certs-update-server \ --certs-update-server-ca
Do not delete the certificate files after you deploy the certificate. They are required when upgrading Satellite Server. |
Access the Satellite web UI from your local machine. For example,
https://satellite.example.com. -
If you have changed the CA certificate on Satellite Server, refresh the CA certificate on your hosts. For more information, see Refreshing the self-signed CA certificate on hosts in Managing hosts.
15.3. Renewing a custom SSL certificate on Capsule Server
Use this procedure to update your custom SSL certificate for Capsule Server.
The satellite-installer command, which the capsule-certs-generate command returns, is unique to each Capsule Server.
You cannot use the same command on more than one Capsule Server.
You must create a new Certificate Signing Request and send it to the Certificate Authority to sign the certificate. Refer to the Configuring Satellite Server with a custom SSL certificate guide before creating a new CSR because the Satellite Server certificate must have X.509 v3
Key UsageandExtended Key Usageextensions with required values. In return, you will receive the Capsule Server certificate and CA bundle.
On your Satellite Server, validate the custom SSL certificate input files:
# katello-certs-check -t capsule \ -b /root/capsule_cert/ca_cert_bundle.pem \ -c /root/capsule_cert/capsule_cert.pem \ -k /root/capsule_cert/capsule_cert_key.pem
On your Satellite Server, generate the certificate archive file for your Capsule Server:
# capsule-certs-generate \ --certs-tar "/root/My_Certificates/capsule.example.com-certs.tar" \ --certs-update-server \ --foreman-proxy-fqdn "capsule.example.com" \ --server-ca-cert "/root/My_Certificates/ca_cert_bundle.pem" \ --server-cert "/root/My_Certificates/capsule_cert.pem" \ --server-key "/root/My_Certificates/capsule_cert_key.pem"
On your Satellite Server, copy the certificate archive file to your Capsule Server:
# scp /root/My_Certificates/capsule.example.com-certs.tar user@capsule.example.com:
Retain a copy of the
satellite-installercommand that thecapsule-certs-generatecommand returns for deploying the certificate to your Capsule Server. -
Deploy the certificate on your Capsule Server using the
satellite-installercommand returned by thecapsule-certs-generatecommand:# satellite-installer --scenario capsule \ --certs-tar-file "/root/My_Certificates/capsule.example.com-certs.tar" \ --certs-update-server \ --foreman-proxy-foreman-base-url "https://satellite.example.com" \ --foreman-proxy-register-in-foreman "true"
Do not delete the certificate archive file on the Capsule Server after you deploy the certificate. They are required when upgrading Capsule Server. |
16. Synchronizing template repositories
In Satellite, you can synchronize repositories of job templates, provisioning templates, report templates, and partition table templates between Satellite Server and a version control system or local directory.
This section details the workflow for installing and configuring the Template Sync plugin and performing exporting and importing tasks.
16.1. Synchronizing templates with an existing repository
If you store templates in a repository under a version control system, you can synchronize the templates between your Satellite Server and the repository.
If you want to use HTTPS to connect to the repository and you use a self-signed certificate authority (CA) on your Git server:
Create a new directory under the
/usr/share/foreman/directory to store the Git configuration for the certificate:# mkdir --parents /usr/share/foreman/.config/git
Create a file named
configin the new directory:# touch /usr/share/foreman/.config/git/config
Allow the
foremanuser access to the.configdirectory:# chown --recursive foreman /usr/share/foreman/.config
Update the Git global configuration for the
foremanuser with the path to your self-signed CA certificate:# sudo --user foreman git config --global http.sslCAPath Path_To_CA_Certificate
If you want to use SSH to connect to the repository:
Create an SSH key pair if you do not already have it. Do not specify a passphrase.
Configure your version control server with the public key from your Satellite, which resides in
/usr/share/foreman/.ssh/id_rsa.pub. -
Accept the Git SSH host key as the
foremanuser:# sudo --user foreman ssh git.example.com
Configure the Template Sync plugin settings on a Template Sync tab.
Change the Branch setting to match the target branch on a Git server.
Change the Repo setting to match the Git repository. For example, for the repository located in
git@git.example.com/templates.gitset the setting intogit@git.example.com/templates.git.
16.2. Synchronizing templates with a local directory
If you store templates in a local directory that is tracked under a version control system, you can synchronize the templates between your Satellite Server and the local directory.
Each template must contain the location and organization that the template belongs to. This applies to all template types. Before you import a template, ensure that you add the following section to the template:
<%# kind: provision name: My_Provisioning_Template oses: - My_first_Operating_System - My_second_Operating_System locations: - My_first_Location - My_second_Location organizations: - My_first_Organization - My_second_Organization %>
On your Satellite Server, in
/var/lib/foreman, create a directory for storing templates:# mkdir /var/lib/foreman/My_Templates_Dir
NoteYou can place your templates to a custom directory outside
/var/lib/foreman, but you have to ensure that theForemanservice can read its contents. The directory must have the correct file permissions and theforeman_lib_tSELinux label. -
Change the owner of the new templates directory to the
foremanuser:# chown foreman /var/lib/foreman/My_Templates_Dir
Change the Repo setting on the Template Sync tab to match the
/var/lib/foreman/My_Templates_Dir/directory.
16.3. Importing templates
You can import templates from a repository of your choice.
You can use different protocols to point to your repository, for example /tmp/dir, git://example.com, https://example.com, and ssh://example.com.
The templates provided by Satellite are locked and you cannot import them by default.
To overwrite this behavior, change the |
To use the API, see the API procedure.
To use Ansible, see the Ansible procedure.
In the Satellite web UI, navigate to Hosts > Templates > Sync Templates.
Click Import.
Each field is populated with values configured in Administer > Settings > Template Sync. Change the values as required for the templates you want to import. For more information about each field, see Template sync settings.
Click Submit.
The Satellite web UI displays the status of the import. The status is not persistent; if you leave the status page, you cannot return to it.
To import a template from a repository, enter the following command:
$ hammer import-templates \ --branch "My_Branch" \ --filter '.*Template Name$' \ --organization "My_Organization" \ --prefix "[Custom Index] " \ --repo "https://git.example.com/path/to/repository"
For better indexing and management of your templates, use
--prefixto set a category for your templates. To select certain templates from a large repository, use--filterto define the title of the templates that you want to import. For example--filter '.*Ansible Default$'imports various Ansible Default templates.
Send a
POSTrequest toapi/v2/templates/import:# curl -H "Accept:application/json" \ -H "Content-Type:application/json" \ -u login:password \ -k https://satellite.example.com/api/v2/templates/import \ -X POST
If the import is successful, you receive
{"message":"Success"}.
Use the
redhat.satellite.templates_importmodule.
For more information, see the Ansible module documentation with ansible-doc redhat.satellite.templates_import.
16.4. Exporting templates
You can export templates to an existing repository.
Click Export.
Each field is populated with values configured in Administer > Settings > Template Sync. Change the values as required for the templates you want to export. For more information about each field, see Template sync settings.
Click Submit.
The Satellite web UI displays the status of the export. The status is not persistent; if you leave the status page, you cannot return to it.
To export the templates to a repository, enter the following command:
# hammer export-templates \ --organization "My_Organization" \ --repo "https://git.example.com/path/to/repository"
NoteThis command clones the repository, makes changes in a commit, and pushes back to the repository. You can use the
--branch "My_Branch"option to export the templates to a specific branch.
Send a
POSTrequest toapi/v2/templates/export:# curl -H "Accept:application/json" \ -H "Content-Type:application/json" \ -u login:password \ -k https://satellite.example.com/api/v2/templates/export \ -X POST
If the export is successful, you receive
You can override default API settings by specifying them in the request with the # curl -H "Accept:application/json" \
-u login:password \
-X POST \
-d "{\"repo\":\"git.example.com/templates\"}"
17. Logging and reporting problems
The following sections describe the most commonly used log files and debugging tools available in Satellite.
17.1. Increasing logging levels to help with debugging
You can increase the logging level of Satellite components to troubleshoot Satellite.
Increasing the logging level to debug provides the most detailed information.
The default logging level is info.
17.1.1. Increasing the logging level for the Foreman application
To increase logging for the Foreman application:
Set the logging level to
debug:# satellite-installer --foreman-logging-level debug
# satellite-installer --reset-foreman-logging-level
For more information about Satellite logging settings, use satellite-installer with the --full-help option:
# satellite-installer --full-help | grep logging
17.1.2. Increasing the logging level for Hammer
In
/etc/hammer/cli_config.yml, set the:log_level:option todebug:
:log_level: 'debug'
17.1.3. Increasing the logging level for Capsule
You can find the log in /var/log/foreman-proxy/proxy.log.
To increase logging for Capsule:
debug:# satellite-installer --foreman-proxy-log-level DEBUG
# satellite-installer --reset-foreman-proxy-log-level
Running satellite-installer will revert the setting back to default. |
17.1.4. Increasing the logging level for Candlepin
You can find the logs in /var/log/candlepin/candlepin.log and /var/log/candlepin/error.log.
To increase logging for Candlepin:
DEBUG:# satellite-installer --katello-candlepin-loggers log4j.logger.org.candlepin:DEBUG
# satellite-installer \ --katello-candlepin-loggers log4j.logger.org.candlepin:DEBUG \ --katello-candlepin-loggers log4j.logger.org.candlepin.resource.ConsumerResource:WARN \ --katello-candlepin-loggers log4j.logger.org.candlepin.resource.HypervisorResource:WARN
# satellite-installer --reset-katello-candlepin-loggers
17.1.5. Increasing the logging level for Redis
To increase logging for Redis:
In
/etc/redis.conf, set the logging level todebug:loglevel debug
Restart the Redis service:
# systemctl restart redis
Running satellite-installer will revert the setting to default. |
17.1.6. Increasing the logging level for Satellite installer
You can find the log files in /var/log/foreman-installer/.
To increase the logging level of the Satellite installer, add the --verbose-log-level debug option during the installation:
# satellite-installer --verbose-log-level debug
17.1.7. Increasing the logging level for Pulp
By default, Pulp logs to syslog.
You can view the log in /var/log/messages or with journalctl.
To increase logging for Pulp:
In
/etc/pulp/settings.py, set the logging level toDEBUG:LOGGING = {"dynaconf_merge": True, "loggers": {'': {'handlers': ['console'], 'level': 'DEBUG'}}} -
Restart the Pulp services:
# systemctl restart \ pulpcore-api \ pulpcore-content \ pulpcore-resource-manager \ pulpcore-worker@1 \ pulpcore-worker@2 \ redis
17.1.8. Increasing the logging level for Puppet agent
To increase logging for Puppet agent:
Ensure Puppet is enabled in your Satellite. For more information, see Enabling Puppet Integration with Satellite in Managing configurations by using Puppet integration.
debug:# satellite-installer --puppet-agent-additional-settings log_level:debug
17.1.9. Increasing the logging level for Puppet server
To increase logging for Puppet server:
debug:# satellite-installer --puppet-server-additional-settings log_level:debug
Restart the Puppet server:
# satellite-maintain service restart --only puppetserver
17.2. Configuring logging levels with Hammer CLI
You can use Hammer to log debugging information for various Satellite components.
The default logging level is INFO.
To list the components whose logging level you can change by using
hammer:# hammer admin logging --list
To set
DEBUGlevel logging for all components:# hammer admin logging --all --level-debug # satellite-maintain service restart
To set
PRODUCTIONlevel logging for all components:# hammer admin logging --all --level-production # satellite-maintain service restart
To set
DEBUGlevel logging for a specific component:# hammer admin logging --components My_Component --level-debug # satellite-maintain service restart
To list all available logging options:
# hammer admin logging --help
17.3. Configuring logging type and layout
By default, Satellite uses file-based logging.
You can use satellite-installer to change the logging type and logging layout.
Enter the following
satellite-installercommand to configure logging to thejournaldservice:# satellite-installer \ --foreman-logging-type journald \ --foreman-proxy-log JOURNAL
Optional: To inspect the log messages, use the
Enter the following
satellite-installercommand to configure file-based logging:# satellite-installer \ --reset-foreman-logging-type \ --reset-foreman-proxy-log
Optional: To inspect the log messages, view these files:
/var/log/foreman-proxy.log
On your Satellite Server, enable logging to JSON output for
satellite-installer:# satellite-installer \ --foreman-logging-layout json \ --foreman-logging-type file
Optional: Inspect the log messages using
jq:# cat /var/log/foreman/production.log | jq
For more information about Journal, see Viewing logs using the command line in Red Hat Enterprise Linux 8 Configuring basic system settings.
17.4. Selective debugging with individual loggers
sqlandldaploggers, enter the following command:# satellite-installer \ --foreman-loggers ldap:true \ --foreman-loggers sql:true
# satellite-installer --reset-foreman-loggers
17.5. Overview of individual loggers
The following list provides an overview of selected loggers.
app-
Default value: true.
audit-
background-
blob-
ImportantThe
bloblogger might contain sensitive data. dynflow-
ldap-
Default value: false.
notifications-
permissions-
sql-
telemetry-
templates-
17.6. Retrieving the status of services
Satellite uses a set of back-end services. When troubleshooting, you can check the status of Satellite services.
In the Satellite web UI, navigate to Administer > About.
On the Smart Proxies tab, view the status of all Capsules.
On the Compute Resources tab, view the status of attached compute resource providers.
In the Backend System Status table, view the status of all back-end services.
Get information from the database and Satellite services:
# hammer ping
# satellite-maintain service status
Run
satellite-maintain service --helpfor more information. -
Perform a health check:
$ satellite-maintain health check
Run
satellite-maintain health --helpfor more information.
17.7. Restarting services
Satellite uses a set of back-end services. When troubleshooting, you can restart the services if needed.
Restart Satellite services:
17.8. Utilities for processing log information
You can collect information from log files to troubleshoot Satellite.
- sosreport
The
sos reportcommand collects configuration and diagnostic information from a Linux system, such as the running kernel version, loaded modules, running services, and system and service configuration files. Additionally, it collects information about Red Hat Satellite, such as its back-end services and tasks. This output is stored in a tar file located at/var/tmp/sosreport-XXX-20171002230919.tar.xz.For more information, run
sos report --helpor see What is a sosreport and how can I create one? in the Red Hat Knowledgebase.ImportantThe
sos reportcommand removes security information such as passwords, tokens, and keys while collecting information. However, the tar files can still contain sensitive information about the Satellite Server. Send the tar files directly to the intended recipient and not to a public target. - foreman-tail
The
foreman-tailcommand displays Satellite logs in real time.For more information, see the
foreman-tail(8)man page.
17.9. Log file directories
The following table provides an overview of selected log directories on Satellite Server:
Subscription management |
Installer |
Foreman maintain |
Foreman proxy |
Foreman |
Apache HTTP server |
Various other log messages |
Puppet |
Candlepin web service logs |
17.10. System journal metadata
The following table lists metadata that the journald service uses in Satellite.
You can use this metadata to filter your queries.
- AUDIT_ACTION
Audit action performed
- AUDIT_TYPE
Audit resource type
- AUDIT_ID
- AUDIT_ATTRIBUTE
- AUDIT_FIELD_OLD
- AUDIT_FIELD_NEW
- AUDIT_ID
- AUDIT_ATTRIBUTE
Example: Name or description
- EXCEPTION_MESSAGE
- EXCEPTION_CLASS
- EXCEPTION_BACKTRACE
- LOC_ID
Location database ID
- LOC_NAME
Location name
- LOC_LABEL
Location label
- LOGGER
Logger name
- ORG_ID
Organization database ID
- ORG_NAME
Organization name
- ORG_LABEL
Organization label
- REMOTE_IP
Remote IP address of a client
- REQUEST
- SESSION
- TEMPLATE_NAME
Template name
- TEMPLATE_DIGEST
- TEMPLATE_HOST_NAME
- TEMPLATE_HOST_ID
- USER_LOGIN
User login name
18. Monitoring resources
The following chapter details how to configure monitoring and reporting for managed systems. This includes host configuration, content views, compliance, registered hosts, promotions, and synchronization.
18.1. Using the Red Hat Satellite content dashboard
The Red Hat Satellite content dashboard contains various widgets which provide an overview of the host configuration, content views, compliance reports, and hosts currently registered, promotions and synchronization, and a list of the latest notifications.
In the Satellite web UI, navigate to Monitor > Dashboard to access the content dashboard. The dashboard can be rearranged by clicking on a widget and dragging it to a different position. The following widgets are available:
- Host Configuration Status
Table 4. Host configuration states Icon State Description
Hosts in error state
noopmode.
Out of sync hosts
Hosts with no reports
Hosts with alerts disabled
- Host Configuration Chart
- Latest Events
- New Hosts
- Task Status
- Latest Warning/Error Tasks
- Discovered Hosts
- Latest Errata
A list of all errata available for hosts registered to Satellite.
- Content Views
A list of all content views in Satellite and their publish status.
- Sync Overview
An overview of all products or repositories enabled in Satellite and their synchronization status. All products that are in the queue for synchronization, are unsynchronized or have been previously synchronized are listed in this section.
- Host Collections
A list of all host collections in Satellite and their status, including the number of content hosts in each host collection.
virt-whodaemon running on hosts in the environment. The following table shows the possible states.Table 5. virt-who configuration states State Description No Reports
No report has been received because either an error occurred during the virt-who configuration deployment, or the configuration has not been deployed yet, or virt-who cannot connect to Satellite during the scheduled interval.
No Change
OK
Total Configurations
- Latest Compliance Reports
- Red Hat Insights Actions
Red Hat Insights is a tool embedded in Satellite that checks the environment and suggests actions you can take. The actions are divided into 4 categories: Availability, Stability, Performance, and Security.
- Red Hat Insights Risk Summary
NoteIt is not possible to change the date format displayed in the Satellite web UI.
18.1.1. Managing tasks
Red Hat Satellite keeps a complete log of all planned or performed tasks, such as repositories synchronised, errata applied, and content views published. To review the log, navigate to Monitor > Satellite Tasks > Tasks.
Adjusting the %_finish_timeout values might help in case of low bandwidth. Adjusting the %_accept_timeout values might help in case of high latency. |
Click Save.
18.2. Configuring RSS notifications
To view Satellite event notification alerts, click the Notifications icon in the upper right of the screen.
By default, the Notifications area displays RSS feed events published in the Red Hat Satellite Blog.
You can configure the RSS feed notifications by changing the URL feed. The supported feed format is RSS 2.0 and Atom. For an example of the RSS 2.0 feed structure, see the Red Hat Satellite Blog feed. For an example of the Atom feed structure, see the Foreman blog feed.
In the Satellite web UI, navigate to Administer > Settings and select the Notifications tab.
18.3. Monitoring Satellite Server
Audit records list the changes made by all users on Satellite. This information can be used for maintenance and troubleshooting.
In the Satellite web UI, navigate to Monitor > Audits to view the audit records.
To obtain a list of all the audit attributes, use the following command:
18.4. Monitoring Capsule Server
The following section shows how to use the Satellite web UI to find Capsule information valuable for maintenance and troubleshooting.
18.4.1. Viewing general Capsule information
In the Satellite web UI, navigate to Infrastructure > Capsules to view a table of Capsule Servers registered to Satellite Server. The information contained in the table answers the following questions:
- Is Capsule Server running?
This is indicated by a green icon in the Status column. A red icon indicates an inactive Capsule, use the
service foreman-proxy restartcommand on Capsule Server to activate it. - What services are enabled on Capsule Server?
In the Features column, you can verify if, for example, your Capsule provides a DHCP service or acts as a Pulp mirror. Capsule features can be enabled during installation or configured in addition. For more information, see Installing Capsule Server.
- What organizations and locations is Capsule Server assigned to?
A Capsule Server can be assigned to multiple organizations and locations, but only Capsules belonging to the currently selected organization are displayed. To list all Capsules, select Any Organization from the context menu in the top left corner.
After changing the Capsule configuration, select Refresh from the drop-down menu in the Actions column to ensure the Capsule table is up to date.
Click the Capsule name to view further details. At the Overview tab, you can find the same information as in the Capsule table. In addition, you can answer to the following questions:
- Which hosts are managed by Capsule Server?
- How much storage space is available on Capsule Server?
/var/lib/pulpis displayed. Also the remaining storage space available on the Capsule can be ascertained.
18.4.2. Monitoring services
In the Satellite web UI, navigate to Infrastructure > Capsules and click the name of the selected Capsule. At the Services tab, you can find basic information on Capsule services, such as the list of DNS domains, or the number of Pulp workers. The appearance of the page depends on what services are enabled on Capsule Server. Services providing more detailed status information can have dedicated tabs at the Capsule page. For more information, see Monitoring Puppet.
18.4.3. Monitoring Puppet
In the Satellite web UI, navigate to Infrastructure > Capsules and click the name of the selected Capsule. At the Puppet tab you can find the following:
A table of CA certificates associated with the Capsule at the Certificates sub-tab. Here you can inspect the certificate expiry data, or cancel the certificate by clicking Revoke.
The Puppet and Puppet CA tabs are available only if you have Puppet enabled in your Satellite. |
19. Using webhooks
A webhook is a way for a web page or web application to provide other applications with information in real time. Webhooks are only triggered after an event occurs. The request usually contains details of the event. An event triggers callbacks, such as sending an e-mail confirming a host has been provisioned. You can use webhooks to define a call to an external API based on Satellite internal event by using a fire-and-forget message exchange pattern. The application sending the request does not wait for the response, or ignores it.
The typical use case for webhooks in Satellite is making a call to a monitoring system when a host is created or deleted.
Webhooks are useful where the action you want to perform in the external system can be achieved through its API. Where it is necessary to run additional commands or edit files, the shellhooks plugin for Capsules is available. The shellhooks plugin enables you to define a shell script on the Capsule that can be executed through the API.
19.1. Creating a webhook template
Webhook templates are used to generate the body of HTTP request to a configured target when a webhook is triggered. Use the following procedure to create a webhook template in the Satellite web UI.
In the Satellite web UI, navigate to Administer > Webhook > Webhook Templates.
A webhook HTTP payload must be created using Satellite template syntax. The webhook template can use a special variable called
@objectthat can represent the main object of the event.@objectcan be missing in case of certain events. You can determine what data are actually available with the@payloadvariable.For more information, see Template Writing Reference in Managing hosts and for available template macros and methods, visit
/templates_docon Satellite Server. -
Click Submit.
19.2. Creating a webhook
You can customize events, payloads, HTTP authentication, content type, and headers through the Satellite web UI.
Use the following procedure to create a webhook in the Satellite web UI.
In the Satellite web UI, navigate to Administer > Webhook > Webhooks.
Click Create new.
Click Template to select a template. Webhook templates are used to generate the body of the HTTP request to Satellite Server when a webhook is triggered.
Enter an HTTP method.
Click the Credentials tab.
Optional: Uncheck Verify SSL if you do not want to verify the server certificate against the system certificate store or Satellite CA.
When configuring webhooks with endpoints with non-standard HTTP or HTTPS ports, an SELinux port must be assigned, see Configuring SELinux to Ensure Access to Satellite on Custom Ports in Installing Satellite Server in a connected network environment.
19.3. Available webhook events
The following table contains a list of webhook events that are available from the Satellite web UI.
A content view was successfully promoted. |
Actions::Katello::ContentView::Promote |
Actions::Katello::ContentView::Publish |
Run OpenSCAP scan. |
Runs an Ansible Playbook containing all the roles defined for a host. |
Actions Remote Execution Run Host Job Ansible Run Capsule Upgrade Succeeded |
Upgrade Capsules on given Capsule Servers. |
Actions Remote Execution Run Host Job Ansible Run Insights Plan Succeeded |
Runs a given maintenance plan from Red Hat Access Insights given an ID. |
Run an Ansible Playbook against given hosts. |
Run an Ansible Playbook to enable the web console on given hosts. |
Build Entered |
Custom event: |
Build Exited |
Custom event: |
Common database operations on a content view. |
Katello::ContentView |
Domain |
Host |
Hostgroup |
Model |
Status Changed |
Custom event: |
Subnet |
Template Render Performed |
Template |
User |
19.4. Shellhooks
With webhooks, you can only map one Satellite event to one API call. For advanced integrations, where a single shell script can contain multiple commands, you can install a Capsule shellhooks plug-in that exposes executables by using a REST HTTP API.
You can then configure a webhook to reach out to a Capsule API to run a predefined shellhook. A shellhook is an executable script that can be written in any language provided that it can be executed. The shellhook can for example contain commands or edit files.
You can pass arguments to shellhook script by using HTTP headers in format X-Shellhook-Arg-1 to X-Shellhook-Arg-99.
For more information on passing arguments to shellhook script, see:
The HTTP method must be POST.
An example URL would be: https://capsule.example.com:9090/shellhook/My_Script.
Unlike the |
You must enable Capsule Authorization for each webhook connected to a shellhook to enable it to authorize a call.
Standard output and standard error output are redirected to the Capsule logs as messages with debug or warning levels respectively.
For an example on creating a shellhook script, see Creating a shellhook to print arguments.
19.5. Installing the shellhooks plugin
Optionally, you can install and enable the shellhooks plugin on each Capsule used for shellhooks.
Run the following command:
# satellite-installer --enable-foreman-proxy-plugin-shellhooks
19.6. Passing arguments to shellhook script using webhooks
19.7. Passing arguments to shellhook script using curl
$ curl \ --data "" \ --header "Content-Type: text/plain" \ --header "X-Shellhook-Arg-1: Version 1.0" \ --header "X-Shellhook-Arg-2: My content view" \ --request POST \ --show-error \ --silent \ https://capsule.example.com:9090/shellhook/My_Script
19.8. Creating a shellhook to print arguments
You have the webhooks and shellhooks plugins installed. For more information, see:
Modify the
/var/lib/foreman-proxy/shellhooks/print_argsscript to print arguments to standard error output so you can see them in the Capsule logs:#!/bin/sh # # Prints all arguments to stderr # echo "$@" >&2 -
Click Create new.
In the Target URL field, enter the URL of your Capsule Server followed by
:9090/shellhook/print_args:https://capsule.example.com:9090/shellhook/print_args
Note that
On the Credentials tab, check Capsule Authorization.
Click Submit. You now have successfully created a shellhook that prints "Hello World!" to Capsule logs every time you a remote execution job succeeds.
timeas a command. For more information, see Executing a Remote Job in Managing hosts. -
Verify that the shellhook script was triggered and printed "Hello World!" to Capsule Server logs:
20. Searching and bookmarking
Satellite features powerful search functionality on most pages of the Satellite web UI. It enables you to search all kinds of resources that Satellite manages. Searches accept both free text and syntax-based queries, which can be built by using input prediction. Search queries can be saved as bookmarks for future reuse.
20.1. Building search queries
As you start typing a search query, a list of valid options to complete the current part of the query appears. You can either select an option from the list and keep building the query by using the prediction, or continue typing. To learn how free text is interpreted by the search engine, see Using free text search.
20.1.1. Query syntax
parameter operator value
20.1.2. Query operators
| Operator | Short Name | Description | Example |
EQUALS |
NOT EQUALS |
LIKE |
NOT LIKE |
GREATER THAN |
LESS THAN |
IN |
NOT IN |
HAS or set? |
NOT HAS or null? |
| Operator | Alternative Notations | Example | ||
and |
<whitespace> |
or |
not |
20.1.3. Query values
- Text Values
Examples:
hostgroup = "Web servers"The search will return hosts with assigned host group named "Web servers".
hostgroup = Web serversThe search will return hosts in the host group Web with any field matching %servers%.
- Temporal Values
"10 January 2017"
"10 Jan 2017"
10-January-2017
10/January/2017
"January 10, 2017"
Warning
20.2. Using free text search
20.3. Managing bookmarks
On some pages, there are default bookmarks available for the common searches, for example, all active or disabled hosts.
20.3.1. Creating bookmarks
In the Satellite web UI, navigate to the page where you want to create a bookmark.
Ensure the Public checkbox is set correctly:
Select the Public checkbox to set the bookmark as public and visible to all users.
Clear the Public checkbox to set the bookmark as private and only visible to the user who created it.
Click Submit.
20.3.2. Deleting bookmarks
In the Satellite web UI, navigate to Administer > Bookmarks.
Appendix A: Managing packages on the base operating system of Satellite Server or Capsule Server
Satellite provides the satellite-maintain packages command to install and update packages on the base operating system of your Satellite Server or Capsule Servers.
Warning
Installing and updating individual packages with |
After installing or updating a package on the base operating system, it is required to run satellite-installer.
The satellite-maintain packages command automatically runs satellite-installer after you use it to install or update a package.
Note that running satellite-installer might trigger service restarts if updating a package affected service configurations.
| Subcommand | Description |
satellite-maintain packages install My_Package |
Installs packages on Satellite Server or Capsule Server |
satellite-maintain packages check-update |
Checks for available package updates on Satellite Server or Capsule Server |
satellite-maintain packages update |
Updates all packages on Satellite Server or Capsule Server |
satellite-maintain packages update My_Package |
Updates specific packages on Satellite Server or Capsule Server |
satellite-maintain packages lock |
Enables package locking to ensure the stability of the base operating system by preventing users from managing packages with |
For information about updating Satellite to the next patch version, see Updating Red Hat Satellite.
For a complete reference about using
satellite-maintain packages, see the help withsatellite-maintain packages --help.
Appendix B: Administration settings
This section contains information about settings that you can edit in the Satellite web UI by navigating to Administer > Settings.
B.1. General settings
Administrator email address |
Satellite URL |
URL where your Satellite instance is reachable. See also Provisioning > Unattended URL. |
Entries per page |
20 |
Number of records shown per page in Satellite |
Fix DB cache |
No |
Satellite maintains a cache of permissions and roles.
When set to |
DB pending seed |
No |
Should the |
Capsule request timeout |
60 |
Open and read timeout for HTTP requests from Satellite to Capsule (in seconds). |
Login page footer text |
HTTP(S) proxy |
Set a proxy for outgoing HTTP(S) connections from the Satellite product. System-wide proxies must be configured at the operating system level. |
HTTP(S) proxy except hosts |
Show Experimental Labs |
No |
Display FQDN for hosts |
Yes |
If set to |
Out of sync interval |
30 |
Hosts report periodically, and if the time between reports exceeds this duration in minutes, hosts are considered out of sync.
Satellite UUID |
Satellite instance ID. Uniquely identifies a Satellite instance. |
Default language |
Default timezone |
The timezone to use for new users. |
Instance title |
Saved audits interval |
New host details UI |
Yes |
Satellite loads the new UI for host details. |
B.2. Satellite task settings
Sync task timeout |
120 |
Enable dynflow console |
Yes |
Enable the dynflow console ( |
Yes |
The user must be authenticated as having administrative rights before accessing the dynflow console. |
Capsule action retry count |
4 |
Number of attempts permitted to start a task on the Capsule before failing. |
Capsule action retry interval |
15 |
Allow Capsule batch tasks |
Yes |
Enable batch triggering of tasks on the Capsule. |
Capsule tasks batch size |
100 |
Number of tasks included in one request to the Capsule if |
Tasks troubleshooting URL |
It should contain a |
1 |
B.3. Template sync settings
Associate |
New |
Associate templates with operating system, organization and location. |
Branch |
Default branch in Git repo. |
Commit message |
Templates export made by a Satellite user |
Dirname |
Filter |
Force import |
No |
If set to |
Lock templates |
Keep, do not lock new |
Metadata export mode |
Refresh |
Negate |
No |
Prefix |
Repo |
When exporting to |
Verbosity |
No |
B.4. Discovery settings
Discovery location |
Discovery organization |
Interface fact |
discovery_bootif |
Create bond interfaces |
No |
Clean all facts |
No |
Hostname facts |
discovery_bootif |
Auto provisioning |
No |
Reboot |
Yes |
Hostname prefix |
mac |
Fact columns |
Highlighted facts |
Storage facts |
Software facts |
Hardware facts |
Network facts |
IPMI facts |
Lock PXE |
No |
pxelinux_discovery |
Locked PXEGrub template name |
pxegrub_discovery |
PXEGrub template to be used when pinning a host to discovery. |
pxegrub2_discovery |
Force DNS |
Yes |
Error on existing NIC |
No |
Do not permit to discover an existing host matching the MAC of a provisioning Network Interface Card (NIC) (errors out early). |
Type of name generator |
Fact + prefix |
Prefer IPv6 |
No |
B.5. Boot disk settings
iPXE directory |
ISOLINUX directory |
SYSLINUX directory |
Grub2 directory |
Host image template |
Boot disk iPXE - host |
Generic image template |
ISO generation command |
genisoimage |
Installation media caching |
Yes |
Allowed bootdisk types |
B.6. Red Hat Cloud settings
Automatic inventory upload |
Yes |
Enable automatic upload of your host inventory to the Red Hat cloud. |
Synchronize recommendations Automatically |
No |
Enable automatic synchronization of Insights recommendations from the Red Hat cloud. |
Obfuscate host names |
No |
Obfuscate hostnames sent to the Red Hat cloud. |
Obfuscate host ipv4 addresses |
No |
Obfuscate IPv4 addresses sent to the Red Hat cloud. |
ID of the RHC daemon |
RHC daemon id. |
B.7. Content settings
Default HTTP Proxy |
Kickstart default |
Kickstart default finish |
Default synced OS user-data |
Kickstart default user data |
Kickstart default PXELinux |
Default synced OS PXEGrub template |
Kickstart default PXEGrub |
Default PXEGrub template for new operating systems created from synced content. |
Kickstart default PXEGrub2 |
Kickstart default iPXE |
Kickstart default |
Discovery Red Hat kexec |
Atomic Kickstart default |
Manifest refresh timeout |
1200 |
Yes |
Can communicate with the Red Hat Portal for subscriptions. |
No |
Calculate errata host status based only on errata in a host’s content view and lifecycle environment. |
No |
Yes |
100 |
How many repositories should be synced concurrently on a Capsule. A smaller number may lead to longer sync times. A larger number will increase dynflow load. |
Sync Capsules after Content View promotion |
Yes |
Whether or not to auto sync Capsules after a content view promotion. |
Either |
Default Red Hat Repository download policy |
Default download policy for enabled Red Hat repositories.
Either |
Default Capsule download policy |
Default download policy for Capsule syncs.
Either |
Pulp export destination filepath |
On-disk location for exported repositories. |
Pulp client key |
Pulp client cert |
Sync Connection Timeout |
300 |
Delete Host upon unregister |
No |
No |
If this is enabled, and |
Default Location |
Expire soon days |
120 |
No |
Host Duplicate DMI UUIDs |
Host Profile Assume |
Yes |
Enable new host registrations to assume registered profiles with matching hostname if the registering DMI UUID is not used by another host. |
No |
Enable host registrations to bypass Host Profile Assume if the host is in build mode. |
No |
5 |
Applicability Batch Size |
50 |
Autosearch |
Yes |
Autosearch delay |
500 |
Pulp bulk load size |
2000 |
Yes |
1440 |
Prefer registered through Capsule for remote execution |
No |
Yes |
Enable removal of repositories that the user has previously published in one or more content view versions. |
B.8. Authentication settings
OAuth active |
Yes |
Satellite will use OAuth for API authorization. This setting is for internal Satellite use only. Red Hat does not support using it to configure OAuth authentication for API calls. |
OAuth consumer key |
OAuth consumer key. This setting is for internal Satellite use only. Red Hat does not support using it to configure OAuth authentication for API calls. |
OAuth consumer secret |
OAuth consumer secret. This setting is for internal Satellite use only. Red Hat does not support using it to configure OAuth authentication for API calls. |
OAuth map users |
No |
Satellite maps users by username in the request-header. If this is disabled, OAuth requests have administrator rights. This setting is for internal Satellite use only. Red Hat does not support using it to configure OAuth authentication for API calls. |
Failed login attempts limit |
30 |
Satellite blocks user logins from an incoming IP address for 5 minutes after the specified number of failed login attempts. Set to 0 to disable brute force protection. |
Restrict registered Capsules |
Yes |
Only known Capsules can access features that use Capsule authentication. |
Require SSL for capsules |
Yes |
Client SSL certificates are used to identify Capsules ( |
Trusted hosts |
List of hostnames, IPv4, IPv6 addresses or subnets to be trusted in addition to Capsules for access to fact/report importers and ENC output. |
SSL certificate |
SSL Certificate path that Satellite uses to communicate with its proxies. |
SSL CA file |
SSL CA file path that Satellite uses to communicate with its proxies. |
SSL private key |
SSL Private Key path that Satellite uses to communicate with its proxies. |
SSL client DN env |
HTTP_SSL_CLIENT_S_DN |
SSL client verify env |
HTTP_SSL_CLIENT_VERIFY |
SSL client cert env |
HTTP_SSL_CLIENT_CERT |
Server CA file |
SSL CA file path used in templates to verify the connection to Satellite. |
Websockets SSL key |
Private key file path that Satellite uses to encrypt websockets. |
Websockets SSL certificate |
Certificate path that Satellite uses to encrypt websockets. |
Websockets encryption |
Yes |
Login delegation logout URL |
External |
Authorize login delegation |
No |
No |
Idle timeout |
60 |
BCrypt password cost |
9 |
BMC credentials access |
Yes |
OIDC JWKs URL |
Typically |
OIDC Audience |
OIDC Issuer |
OIDC Algorithm |
B.9. Email settings
Email reply address |
Email reply address for emails that Satellite is sending. |
Email subject prefix |
Send welcome email |
No |
Delivery method |
Sendmail |
SMTP enable StartTLS auto |
Yes |
SMTP OpenSSL verify mode |
Default verification mode |
SMTP address |
SMTP address to connect to. |
SMTP port |
25 |
SMTP port to connect to. |
SMTP HELO/EHLO domain |
HELO/EHLO domain. |
SMTP username |
SMTP password |
SMTP authentication |
none |
Sendmail arguments |
-i |
Sendmail location |
B.10. Notifications settings
RSS enable |
Yes |
Pull RSS notifications. |
RSS URL |
https://www.redhat.com/en/rss/blog/channel/red-hat-satellite |
B.11. Provisioning settings
Host owner |
Default owner on provisioned hosts, if empty Satellite uses the current user. |
Root password |
Unattended URL |
Safemode rendering |
No |
Query local nameservers |
No |
Satellite queries the locally configured resolver instead of the SOA/NS authorities. |
Installation token lifetime |
360 |
SSH timeout |
120 |
0.0.0.0 |
No |
Satellite updates the host IP with the IP that made the build request. |
Use short name for VMs |
No |
Satellite uses the short hostname instead of the FQDN for creating new virtual machines. |
DNS timeout |
[5, 10, 15, 20] |
Clean up failed deployment |
Yes |
Satellite deletes the virtual machine if the provisioning script ends with a non-zero exit code. |
iPXE intermediate script |
No |
Destroy associated VM on host delete. When enabled, VMs linked to hosts are deleted on Compute Resource. When disabled, VMs are unlinked when the host is deleted, meaning they remain on Compute Resource and can be re-associated or imported back to Satellite again. This does not automatically power off the VM |
Maximum structured facts |
100 |
Global Registration |
PXEGrub2 global default |
PXELinux global default |
Global default PXEGrub template |
PXEGrub global default |
Global default PXEGrub template. This template is deployed to all configured TFTP servers. It is not affected by upgrades. |
iPXE global default |
PXEGrub2 default local boot |
PXELinux default local boot |
Local boot PXEGrub template |
PXEGrub default local boot |
Template that is selected as PXEGrub default for local boot. |
Local boot iPXE template |
iPXE default local boot |
Manage PuppetCA |
Yes |
Satellite automates certificate signing upon provision of a new host. |
Use UUID for certificates |
No |
Satellite uses random UUIDs for certificate signing instead of hostnames. |
Show unsupported provisioning templates |
No |
Show unsupported provisioning templates. When enabled, all the available templates are shown. When disabled, only Red Hat supported templates are shown. |
B.12. Facts settings
Yes |
Satellite creates the host when new facts are received. |
Location fact |
satellite_location |
Organization fact |
satellite_organization |
Default location |
Default Location |
Default organization |
Default Organization |
Update hostgroup from facts |
Yes |
Satellite updates a host’s hostgroup from its facts. |
No |
Ignore facts for domain |
No |
Update subnets from facts |
None |
Satellite updates a host’s subnet from its facts. |
No |
Exclude pattern for facts stored in Satellite |
Those facts are not stored in the satellite database.
B.13. Configuration management settings
Yes |
Satellite creates the host when a report is received. |
Matchers inheritance |
Yes |
Satellite matchers are inherited by children when evaluating smart class parameters for hostgroups, organizations, and locations. |
Satellite evaluates host smart class parameters in this order by default. |
Yes |
Satellite parses ERB in parameters value in the ENC output. |
No |
All hosts show a configuration status even when a Puppet Capsule is not assigned. |
B.14. Remote execution settings
Fallback to Any Capsule |
No |
Enable Global Capsule |
Yes |
SSH User |
root |
Default user to use for SSH.
Effective User |
root |
Effective User Method |
sudo |
One of [ |
Effective user password |
Sync Job Templates |
Yes |
SSH Port |
22 |
Default port 22.
Connect by IP |
No |
Prefer IPv6 over IPv4 |
No |
Default SSH password |
Default SSH key passphrase |
Workers pool size |
5 |
Restart of the |
Cleanup working directories |
Yes |
Cockpit URL |
Form Job Template |
Run Command - SSH Default |
Time to pickup |
86400 |
Time in seconds within which the host has to pick up a job. If the job is not picked up within this limit, the job will be cancelled. Applies only to pull-mqtt based jobs. Defaults to one day. |
B.15. Ansible settings
Private Key Path |
Override with the |
Connection type |
ssh |
Use this connection type by default when running Ansible Playbooks.
WinRM cert Validation |
validate |
Enable or disable WinRM server certificate validation when running Ansible Playbooks.
Default verbosity level |
Disabled |
Satellite adds this level of verbosity for additional debugging output when running Ansible Playbooks. |
Post-provision timeout |
360 |
Timeout (in seconds) to set when Satellite triggers an Ansible roles task playbook after a host is fully provisioned. Set this to the maximum time you expect a host to take until it is ready after a reboot. |
Ansible report timeout |
30 |
No |
Ansible - Ansible Inventory |
Satellite uses this template to schedule the report with Ansible inventory. |
Ansible roles to ignore |
The roles to exclude when importing roles from Capsule.
For example: |
Capsule tasks batch size for Ansible |
Number of tasks which should be sent to the Capsule in one request if |
