orcharhino overview and concepts
orcharhino is a centralized tool for provisioning, remote management, and monitoring of multiple Enterprise Linux deployments. With orcharhino, you can deploy, configure, and maintain your systems across physical, virtual, and cloud environments.
1. Content and patch management with orcharhino
With orcharhino, you can provide content and apply patches to hosts systematically in all lifecycle stages.
1.1. Content flow in orcharhino
Content flow in orcharhino involves management and distribution of content from external sources to hosts.
Content in orcharhino flows from external content sources to orcharhino Server. orcharhino Proxies mirror the content from orcharhino Server to hosts.
- External content sources
You can configure many content sources with orcharhino. The supported content sources include the Red Hat Customer Portal, Git repositories, Ansible collections, Docker Hub, SCAP repositories, or internal data stores of your organization.
- orcharhino Server
On your orcharhino Server, you plan and manage the content lifecycle.
- orcharhino Proxies
By creating orcharhino Proxies, you can establish content sources in various locations based on your needs. For example, you can establish a content source for each geographical location or multiple content sources for a data center with separate networks.
- Hosts
By assigning a host system to a orcharhino Proxy or directly to your orcharhino Server, you ensure the host receives the content they provide. Hosts can be physical or virtual.
See Major orcharhino components for details.
1.2. Content views in orcharhino
A content view is a deliberately curated subset of content that your hosts can access. By creating a content view, you can define the software versions used by a particular environment or orcharhino Proxy.
Each content view creates a set of repositories across each environment. Your orcharhino Server stores and manages these repositories. For example, you can create content views in the following ways:
A content view with older package versions for a production environment and another content view with newer package versions for a Development environment.
A content view with a package repository required by an operating system and another content view with a package repository required by an application.
A composite content view for a modular approach to managing content views. For example, you can use one content view for content for managing an operating system and another content view for content for managing an application. By creating a composite content view that combines both content views, you create a new repository that merges the repositories from each of the content views. However, the repositories for the content views still exist and you can keep managing them separately as well.
A Default Organization View is an application-controlled content view for all content that is synchronized to orcharhino. You can register a host to the Library environment on orcharhino to consume the Default Organization View without configuring content views and lifecycle environments.
You can access unprotected repositories in the Default Organization View content view.
The URL consists of your orcharhino Proxy FQDN, /pulp/content/
, your organization label, /Library/custom/
, your product label, /
, your repository label, and a trailing /
, for example, https://orcharhino.example.com/pulp/content/Example/Library/custom/AlmaLinux_9/BaseOS/
When you promote a content view from one environment to the next environment in the application lifecycle, orcharhino updates the repository and publishes the packages.
The repositories for Testing and Production contain the my-software-1.0-0.noarch.rpm
package:
Development | Testing | Production | |
Version of the content view |
Version 2 |
Version 1 |
Version 1 |
Contents of the content view |
my-software-1.1-0.noarch.rpm |
my-software-1.0-0.noarch.rpm |
If you promote Version 2 of the content view from Development to Testing, the repository for Testing updates to contain the my-software-1.1-0.noarch.rpm
package:
Version 2 |
Version 2 |
Version 1 |
With Distribute archived content view versions
enabled, you can access unprotected repositories in published content view versions.
, your organization label, /content_views/
, your content view, your content view version, /custom/
, for example, https://orcharhino.example.com/pulp/content/Example/content_views/AlmaLinux_9/2.1/custom/AlmaLinux_9/BaseOS/
If you want to access the latest published content view, the URL consists of your orcharhino Proxy FQDN, /pulp/content/
, your organization label, your lifecycle, your content view, /custom/
, for example, https://orcharhino.example.com/pulp/content/Example/Production/AlmaLinux_9/custom/AlmaLinux_9/AlmaLinux_9/
You can use these URLs to provide versioned orcharhino Clients during host registration.
For more information, see Managing content views in Managing content.
1.3. Content types in orcharhino
With orcharhino, you can import and manage many content types.
For example, orcharhino supports the following content types:
- RPM packages
Import RPM packages from any repository, for example from Amazon, Oracle, Red Hat, SUSE, and custom repositories. orcharhino Server downloads the RPM packages and stores them locally. You can use these repositories and their RPM packages in content views.
- Deb packages
- Kickstart trees
Import the Kickstart trees to provision a host. New systems access these Kickstart trees over a network to use as base content for their installation. orcharhino contains predefined Kickstart templates. You can also create your own Kickstart templates.
- Provisioning templates
Templates to provision hosts running EL based on synchronized content and Debian, Ubuntu, or SUSE Linux Enterprise Server based on local installation media. orcharhino contains predefined AutoYaST, Kickstart, and Preseed templates as well as the ability to create your own, which are used to provision systems and customize the installation.
- ISO and KVM images
Download and manage media for installation and provisioning. For example, orcharhino downloads, stores, and manages ISO images and guest images for specific Enterprise Linux operating systems.
- Custom file type
1.4. Additional resources
For information about how to manage content with orcharhino, see Managing content.
2. Subscription management with orcharhino
With orcharhino, you can track usage of software subscriptions and assign subscriptions according to your needs.
2.1. Simple content access (SCA) in orcharhino
Simple Content Access (SCA) in orcharhino simplifies management of software entitlements. With SCA, you can add valid subscriptions to a subscription allocation or manifest and refresh within orcharhino. Therefore, with SCA enabled, you do not need to attach subscriptions individually to hosts.
Simple Content Access (SCA) replaces the previous entitlement-based method of subscription management. New organizations default to having SCA enabled. Entitlement-based subscription management is deprecated. For more information, see Release notes. |
2.2. Additional resources
For more information about how to manage subscriptions with orcharhino, see Managing content.
3. Provisioning management with orcharhino
With orcharhino, you can provision hosts on various compute resources with many provisioning methods from a unified interface.
3.1. Provisioning methods in orcharhino
With orcharhino, you can provision hosts by using the following methods.
- Bare-metal hosts
orcharhino provisions bare-metal hosts primarily by using PXE boot and MAC address identification. When provisioning bare-metal hosts with orcharhino, you can do the following:
Create host entries and specify the MAC address of the physical host to provision.
Boot blank hosts to use the orcharhino Discovery service, which creates a pool of hosts that are ready for provisioning.
Boot and provision hosts by using PXE-less methods.
- Cloud providers
orcharhino connects to private and public cloud providers to provision instances of hosts from images stored in the cloud environment. When provisioning from cloud with orcharhino, you can do the following:
Select which hardware profile to use.
Provision cloud instances from specific providers by using their APIs.
- Virtualization infrastructure
orcharhino connects to virtualization infrastructure services, such as oVirt and VMware. When provisioning virtual machines with orcharhino, you can do the following:
Provision virtual machines from virtual image templates.
Use the same PXE-based boot methods that you use to provision bare-metal hosts.
For more information, see compute resources.
3.2. Additional resources
For information about how to provision hosts with orcharhino, see Provisioning hosts.
4. Major orcharhino components
A typical orcharhino deployment consists of the following components: a orcharhino Server, orcharhino Proxies that mirror content from orcharhino Server, and hosts that receive content and configuration from orcharhino Server and orcharhino Proxies.
4.1. orcharhino Server overview
orcharhino Server is the central component of a orcharhino deployment where you plan and manage the content lifecycle.
A typical orcharhino deployment includes one orcharhino Server on which you perform the following operations:
Content lifecycle management
Configuration of orcharhino Proxies
Configuration of hosts
Host provisioning
Patch management
orcharhino Server delegates content distribution, host provisioning, and communication to orcharhino Proxies. orcharhino Server itself also includes a orcharhino Proxy.
orcharhino Server also contains a fine-grained authentication system. You can grant orcharhino users permissions to access precisely the parts of the infrastructure for which they are responsible.
For more information about managing permissions, see Managing Users and Roles in Administering orcharhino.
4.2. Organizations and locations in orcharhino
On your orcharhino Server, you can define multiple organizations and locations to help organize content, hosts, and configurations.
- Organizations
Organizations typically represent different business units, departments, or teams, such as Finance, Marketing, or Web Development.
- Locations
Locations typically represent physical locations, such as countries or cities.
4.3. orcharhino Proxy overview
With orcharhino Proxies, you can extend the reach and scalability of your orcharhino deployment. orcharhino Proxies provide the following functionalities in a orcharhino deployment:
Mirroring content from orcharhino Server to establish content sources in various geographical or logical locations. By registering a host to a orcharhino Proxy, you can configure this host to receive content and configuration from the orcharhino Proxy in their location instead of from the central orcharhino Server.
Running localized services to discover, provision, control, and configure hosts.
By using content views, you can specify the exact subset of content that orcharhino Proxy makes available to hosts. For more information, see Content and patch management with orcharhino.
4.4. Overview of hosts in orcharhino
A host is any Linux client that orcharhino manages. Hosts can be physical or virtual.
You can deploy virtual hosts on any platform supported by orcharhino, such as Amazon EC2, Google Compute Engine, libvirt, Microsoft Azure, Oracle Linux Virtualization Manager, oVirt, Proxmox, RHV, and VMware vSphere.
With orcharhino, you can manage hosts at scale, including monitoring, provisioning, remote execution, configuration management, software management, and subscription management.
4.5. List of key open source components of orcharhino Server
orcharhino consists of several open source projects integrated with each other, such as the following:
- Foreman
- Katello
Katello is an optional plugin of Foreman that extends Foreman capabilities with additional features for content, subscription, and repository management. Katello enables orcharhino to subscribe to repositories and to download content.
- Candlepin
- Pulp
4.6. orcharhino Proxy features
orcharhino Proxies provide local host management services and can mirror content from orcharhino Server.
To mirror content from orcharhino Server, orcharhino Proxy provides the following functionalities:
- Repository synchronization
orcharhino Proxies pull content for selected lifecycle environments from orcharhino Server and make this content available to the hosts they manage.
- Content delivery
Hosts configured to use orcharhino Proxy download content from that orcharhino Proxy rather than from orcharhino Server.
- Host action delivery
orcharhino Proxy executes scheduled actions on hosts.
- Red Hat Subscription Management (RHSM) proxy
Hosts are registered to their associated orcharhino Proxies rather than to the central orcharhino Server or the Red Hat Customer Portal.
You can use orcharhino Proxy to run the following services for infrastructure and host management:
- DHCP
orcharhino Proxy can manage a DHCP server, including integration with an existing solution, such as ISC DHCP servers, Active Directory, and Libvirt instances.
- DNS
orcharhino Proxy can manage a DNS server, including integration with an existing solution, such as ISC BIND and Active Directory.
- TFTP
orcharhino Proxy can integrate with any UNIX-based TFTP server.
- Realm
orcharhino Proxy can manage Kerberos realms or domains so that hosts can join them automatically during provisioning. orcharhino Proxy can integrate with an existing infrastructure, including FreeIPA and Active Directory.
- Puppet server
orcharhino Proxy can act as a configuration management server by running a Puppet server.
- Puppet Certificate Authority
orcharhino Proxy can integrate with the Puppet certificate authority (CA) to provide certificates to hosts.
orcharhino Proxy can provide power management for hosts by using the Intelligent Platform Management Interface (IPMI) or Redfish standards.
- Provisioning template proxy
orcharhino Proxy can serve provisioning templates to hosts.
- OpenSCAP
orcharhino Proxy can perform security compliance scans on hosts.
- Remote Execution (REX)
orcharhino Proxy can run remote job execution on hosts.
You can configure a orcharhino Proxy for a specific limited purpose by enabling only selected features on that orcharhino Proxy. Common configurations include the following:
- Infrastructure orcharhino Proxies: DNS + DHCP + TFTP
orcharhino Proxies with these services provide infrastructure services for hosts and have all necessary services for provisioning new hosts.
- Content orcharhino Proxies: Pulp
orcharhino Proxies with this service provide content synchronized from orcharhino Server to hosts.
- Configuration orcharhino Proxies: Pulp + Puppet + PuppetCA
orcharhino Proxies with these services provide content and run configuration services for hosts.
- orcharhino Proxies with DNS + DHCP + TFTP + Pulp + Puppet + PuppetCA
orcharhino Proxies with these services provide a full set of orcharhino Proxy features. By configuring a orcharhino Proxy with all these features, you can isolate hosts assigned to that orcharhino Proxy by providing a single point of connection for the hosts.
4.7. orcharhino Proxy networking
The communication between orcharhino Server and hosts registered to a orcharhino Proxy is routed through that orcharhino Proxy. orcharhino Proxy also provides orcharhino services to hosts.
Many of the services that orcharhino Proxy manages use dedicated network ports. However, orcharhino Proxy ensures that all communications from the host to orcharhino Server use a single source IP address, which simplifies firewall administration.
In this topology, orcharhino Proxy provides a single endpoint for all host network communications so that in remote network segments, only firewall ports to the orcharhino Proxy itself must be open.
In this topology, hosts connect to orcharhino Server rather than a orcharhino Proxy. This applies also to orcharhino Proxies themselves because the orcharhino Proxy is a host of orcharhino Server.
You can find complete instructions for configuring the host-based firewall to open the required ports in the following documents:
Ports and Firewalls Requirements in Installing orcharhino Server
Ports and Firewalls Requirements in Installing orcharhino Proxy
4.8. Additional resources
See Installing orcharhino Proxy for details on orcharhino Proxy requirements, installation, and scalability considerations.
See Configuring orcharhino Proxies with a load balancer for details on distributing load among orcharhino Proxies.
5. Tools for administration of orcharhino
You can use multiple tools to manage orcharhino.
5.1. orcharhino management UI overview
You can manage and monitor your orcharhino infrastructure from a browser with the orcharhino management UI. For example, you can use the following navigation features in the orcharhino management UI:
Navigation feature | Description |
Organization dropdown |
Choose the organization you want to manage. |
Location dropdown |
Choose the location you want to manage. |
Monitor |
Content |
Provides content management tools. This includes content views, activation keys, and lifecycle environments. |
Hosts |
Configure |
Provides general configuration tools and data, including host groups and Ansible content. |
Infrastructure |
Provides tools on configuring how orcharhino interacts with the environment. |
Administer |
Provides advanced configuration for settings such as users, role-based access control (RBAC), and general settings. |
See Administering orcharhino for details on using the orcharhino management UI.
5.2. Hammer CLI overview
You can configure and manage your orcharhino Server with CLI commands by using Hammer.
Create shell scripts based on Hammer commands for basic task automation.
Redirect output from Hammer to other tools.
Use the
--debug
option with Hammer to test responses to API calls before applying the API calls in a script. For example:hammer --debug organization list
To issue Hammer commands, a user must have access to your orcharhino Server.
To ensure a user-friendly and intuitive experience, the orcharhino management UI takes priority when developing new functionality. Therefore, some features that are available in the orcharhino management UI might not yet be available for Hammer. |
In the background, each Hammer command first establishes a binding to the API, then sends a request. This can have performance implications when executing a large number of Hammer commands in sequence. In contrast, scripts that use API commands communicate directly with the Satellite API and they establish the binding only once.
5.3. orcharhino API overview
You can write custom scripts and external applications that access the orcharhino API over HTTP with the Representational State Transfer (REST) API provided by orcharhino Server. Use the REST API to integrate with enterprise IT systems and third-party applications, perform automated maintenance or error checking tasks, and automate repetitive tasks with scripts.
Configure any programming language, framework, or system with support for HTTP protocol to use the API.
Create client applications that require minimal knowledge of the orcharhino infrastructure because users discover many details at runtime.
Adopt the resource-based REST model for intuitively managing a virtualization platform.
Scripts based on API commands communicate directly with the orcharhino API, which makes them faster than scripts based on Hammer commands or Ansible playbooks relying on modules within theforeman.foreman.
API commands differ between versions of orcharhino. When you prepare to upgrade orcharhino Server, update all the scripts that contain orcharhino API commands. |
5.4. Remote execution in orcharhino
With remote execution, you can run jobs on hosts remotely from orcharhino Proxies using shell scripts or Ansible tasks and playbooks.
Use remote execution for the following benefits in orcharhino:
Run jobs on multiple hosts at once.
Use variables in your commands for more granular control over the jobs you run.
Use host facts and parameters to populate the variable values.
Specify custom values for templates when you run the command.
Communication for remote execution occurs through orcharhino Proxy, which means that orcharhino Server does not require direct access to the target host, and can scale to manage many hosts.
orcharhino uses ERB syntax job templates. For more information, see Template Writing Reference in Managing hosts.
By default, orcharhino includes several job templates for shell scripts and Ansible. For more information, see Setting up Job Templates in Managing hosts.
See Executing a Remote Job in Managing hosts.
See Configuring and Setting Up Remote Jobs in Configuring hosts using Ansible.
5.5. Managing orcharhino with Ansible collections
orcharhino Ansible Collections is a set of Ansible modules that interact with the orcharhino API. You can manage and automate many aspects of orcharhino with orcharhino Ansible collections.
5.6. Kickstart workflow
You can automate the installation process of a orcharhino Server or orcharhino Proxy by creating a Kickstart file that contains all the information that is required for the installation.
When you run a orcharhino Kickstart script, the script performs the following actions:
It specifies the installation location of a orcharhino Server or a orcharhino Proxy.
It uses Activation Keys to subscribe the hosts to orcharhino.
puppet.conf
file to indicate the orcharhino or orcharhino Proxy instance. -
For more information about Kickstart, see Automated installation workflow in Automatically installing RHEL 9.
6. Supported usage and versions of orcharhino components
orcharhino supports the following use cases, architectures, and versions.
6.1. orcharhino Server operating system
orcharhino has packages for Enterprise Linux 8 and 9, Debian 11 and Ubuntu 20.04. Katello plugin packages, which provide content management capabilities, are only available for Enterprise Linux.
ATIX AG only packages orcharhino for x86_64.
6.2. Client operating systems
Using orcharhino, you can manage multiple operating systems that have clients orcharhino can integrate with: For example:
Ansible
OpenSCAP
OpenSSH
Puppet
Windows Remote Management (WinRM)
Operating system installers that can perform unattended installations, such as Anaconda or Debian-installer
Other clients where integration is provided by external plugins
orcharhino is actively tested with the following client operating systems:
CentOS 7 and 8
Debian stable
Ubuntu LTS
Katello host tools
Subscription manager
Tracer utility
orcharhino deployment planning
7. Common deployment scenarios
This section provides a brief overview of common deployment scenarios for orcharhino. Note that many variations and combinations of the following layouts are possible.
7.1. Single location
An integrated orcharhino Proxy is a virtual orcharhino Proxy that is created by default in orcharhino Server during the installation process. This means orcharhino Server can be used to provision directly connected hosts for orcharhino deployment in a single geographical location, therefore only one physical server is needed. The base systems of isolated orcharhino Proxies can be directly managed by orcharhino Server, however it is not recommended to use this layout to manage other hosts in remote locations.
7.2. Single location with segregated subnets
Your infrastructure might require multiple isolated subnets even if orcharhino is deployed in a single geographic location. This can be achieved for example by deploying multiple orcharhino Proxies with DHCP and DNS services, but the recommended way is to create segregated subnets using a single orcharhino Proxy. This orcharhino Proxy is then used to manage hosts and compute resources in those segregated networks to ensure they only have to access the orcharhino Proxy for provisioning, configuration, errata, and general management. For more information on configuring subnets see Managing Hosts.
7.3. Multiple locations
It is recommended to create at least one orcharhino Proxy per geographic location. This practice can save bandwidth since hosts obtain content from a local orcharhino Proxy. Synchronization of content from remote repositories is done only by the orcharhino Proxy, not by each host in a location. In addition, this layout makes the provisioning infrastructure more reliable and easier to configure.
7.4. orcharhino Proxy with external services
You can configure a orcharhino Proxy (integrated or standalone) to use external DNS, DHCP, or TFTP service. If you already have a server that provides these services in your environment, you can integrate it with your orcharhino deployment. For information about how to configure a orcharhino Proxy with external services, see Configuring orcharhino Proxy with External Services in Installing orcharhino Proxy.
8. Deployment considerations
This section provides an overview of general topics to be considered when planning a orcharhino deployment together with recommendations and references to more specific documentation.
8.1. orcharhino Server with external database
When you install orcharhino, the foreman-installer
command creates databases on the same server that you install orcharhino.
Depending on your requirements, moving to external databases can provide increased working memory for orcharhino, which can improve response times for database operating requests.
Consider using external databases if you plan to use your orcharhino deployment for the following scenarios:
High disk I/O workloads from frequent repository synchronization or Content View publishing. This causes orcharhino to create a record in PostgreSQL for each job.
High volume of hosts.
For more information about using an external database, see Using External Databases with orcharhino in Installing orcharhino Server.
8.2. Locations and topology
This section outlines general considerations that should help you to specify your orcharhino deployment scenario. The most common deployment scenarios are listed in Common deployment scenarios. The defining questions are:
How many orcharhino Proxies do I need? – The number of geographic locations where your organization operates should translate to the number of orcharhino Proxies. By assigning a orcharhino Proxy to each location, you decrease the load on orcharhino Server, increase redundancy, and reduce bandwidth usage. orcharhino Server itself can act as a orcharhino Proxy (it contains an integrated orcharhino Proxy by default). This can be used in single location deployments and to provision the base system’s of orcharhino Proxies. Using the integrated orcharhino Proxy to communicate with hosts in remote locations is not recommended as it can lead to suboptimal network utilization.
What services will be provided by orcharhino Proxies? – After establishing the number of orcharhino Proxies, decide what services will be enabled on each orcharhino Proxy. Even though the whole stack of content and configuration management capabilities is available, some infrastructure services (DNS, DHCP, TFTP) can be outside of a orcharhino administrator’s control. In such case, orcharhino Proxies have to integrate with those external services (see orcharhino Proxy with external services).
What compute resources do I need for my hosts? – Apart from provisioning bare-metal hosts, you can use various compute resources supported by orcharhino. To learn about provisioning on different compute resources see Provisioning hosts.
8.3. Content sources
The Red Hat Subscription Manifest determines what Red Hat repositories are accessible from your orcharhino Server. Once you enable a Red Hat repository, an associated orcharhino Product is created automatically. For distributing content from custom sources you need to create products and repositories manually. Red Hat repositories are signed with GPG keys by default, and it is recommended to create GPG keys also for your custom repositories.
Yum repositories that contain only RPM packages support the On demand download policy, which reduces synchronization time and storage space. The On demand download policy saves space and time by only downloading packages when requested by hosts. For detailed instructions on setting up content sources, see Importing Content in Managing content.
A custom repository within orcharhino Server is in most cases populated with content from an external staging server. Such servers lie outside of the orcharhino infrastructure, however, it is recommended to use a revision control system (such as Git) on these servers to have better control over the custom content.
8.4. Content lifecycle
orcharhino provides features for precise management of the content lifecycle. A lifecycle environment represents a stage in the content lifecycle, a Content View is a filtered set of content, and can be considered as a defined subset of content. By associating Content Views with lifecycle environments, you make content available to hosts in a defined way.
For a detailed overview of the content management process see Importing Custom Content in Managing content. The following section provides general scenarios for deploying content views as well as lifecycle environments.
A single lifecycle environment – content from Library is promoted directly to the production stage. This approach limits the complexity but still allows for testing the content within the Library before making it available to hosts.
A single lifecycle environment path – both operating system and applications content is promoted through the same path. The path can consist of several stages (for example Development, QA, Production), which enables thorough testing but requires additional effort.
Application specific lifecycle environment paths – each application has a separate path, which allows for individual application release cycles. You can associate specific compute resources with application lifecycle stages to facilitate testing. On the other hand, this scenario increases the maintenance complexity.
8.5. Content deployment
Content deployment manages errata and packages on content hosts. orcharhino can be configured to perform remote execution over MQTT/HTTPS (pull-based) or SSH (push-based). While remote execution is enabled on orcharhino Server by default, it is disabled on orcharhino Proxies and content hosts. You must enable it manually.
8.6. Provisioning
orcharhino provides several features to help you automate the host provisioning, including provisioning templates, configuration management with Puppet, and host groups for standardized provisioning of host roles. For a description of the provisioning workflow see Provisioning Workflow in Provisioning hosts. The same guide contains instructions for provisioning on various compute resources.
8.7. Role based authentication
Assigning a role to a user enables controlling access to orcharhino components based on a set of permissions. You can think of role based authentication as a way of hiding unnecessary objects from users who are not supposed to interact with them.
Roles related to a particular stage of the software lifecycle – for example, roles divided among the development, testing, and production phases, where each phase has one or more owners.
Define the expected tasks and responsibilities – define the subset of the orcharhino infrastructure that will be accessible to the role as well as actions permitted on this subset. Think of the responsibilities of the role and how it would differ from other roles.
Use predefined roles whenever possible – orcharhino provides a number of sample roles that can be used alone or as part of a role combination. Copying and editing an existing role can be a good start for creating a custom role.
Consider all affected entities – for example, a content view promotion automatically creates new Puppet Environments for the particular lifecycle environment and content view combination. Therefore, if a role is expected to promote content views, it also needs permissions to create and edit Puppet Environments.
Consider areas of interest – even though a role has a limited area of responsibility, there might be a wider area of interest. Therefore, you can grant the role a read only access to parts of orcharhino infrastructure that influence its area of responsibility. This allows users to get earlier access to information about potential upcoming changes.
For instructions on defining roles and assigning them to users, see Managing Users and Roles in Administering orcharhino. The same guide contains information on configuring external authentication sources.
8.8. Additional tasks
This section provides a short overview of selected orcharhino capabilities that can be used for automating certain tasks or extending the core usage of orcharhino:
Discovering bare-metal hosts – the orcharhino Discovery plugin enables automatic bare-metal discovery of unknown hosts on the provisioning network. These new hosts register themselves to orcharhino Server and the Puppet agent on the client uploads system facts collected by Facter, such as serial ID, network interface, memory, and disk information. After registration you can initialize provisioning of those discovered hosts. For more information, see Creating Hosts from Discovered Hosts in Provisioning hosts.
Backup management – backup and disaster recovery instructions, see Backing Up orcharhino Server and orcharhino Proxy in Administering orcharhino. Using remote execution, you can also configure recurring backup tasks on hosts. For more information on remote execution see Configuring and Setting up Remote Jobs in Managing hosts.
Security management – orcharhino supports security management in various ways, including update and errata management, OpenSCAP integration for system verification, update and security compliance reporting, and fine grained role based authentication. Find more information on errata management and OpenSCAP concepts in Managing hosts.
Incident management – orcharhino supports the incident management process by providing a centralized overview of all systems including reporting and email notifications. Detailed information on each host is accessible from orcharhino Server, including the event history of recent changes.
Scripting with Hammer and API – orcharhino provides a command line tool called Hammer that provides a CLI equivalent to the majority of web UI procedures. In addition, you can use the access to the orcharhino API to write automation scripts in a selected programming language.
9. Organizations, locations, and lifecycle environments
orcharhino takes a consolidated approach to Organization and Location management. System administrators define multiple Organizations and multiple Locations in a single orcharhino Server. For example, a company might have three Organizations (Finance, Marketing, and Sales) across three countries (United States, United Kingdom, and Japan). In this example, orcharhino Server manages all Organizations across all geographical Locations, creating nine distinct contexts for managing systems. In addition, users can define specific locations and nest them to create a hierarchy. For example, orcharhino administrators might divide the United States into specific cities, such as Boston, Phoenix, or San Francisco.
orcharhino Server defines all locations and organizations. Each respective orcharhino orcharhino Proxy synchronizes content and handles configuration of systems in a different location.
The main orcharhino Server retains the management function, while the content and configuration is synchronized between the main orcharhino Server and a orcharhino orcharhino Proxy assigned to certain locations.
9.1. Organizations
Organizations divide orcharhino resources into logical groups based on ownership, purpose, content, security level, or other divisions. You can create and manage multiple organizations through orcharhino, then divide and assign your subscriptions to each individual organization. This provides a method of managing the content of several individual organizations under one management system.
9.2. Locations
9.3. Lifecycle environments
Application lifecycles are divided into lifecycle environments which represent each stage of the application lifecycle. Lifecycle environments are linked to form an environment path. You can promote content along the environment path to the next lifecycle environment when required. For example, if development ends on a particular version of an application, you can promote this version to the testing environment and start development on the next version.
10. Host grouping concepts
Apart from the physical topology of orcharhino Proxies, orcharhino provides several logical units for grouping hosts. Hosts that are members of those groups inherit the group configuration. For example, the simple parameters that define the provisioning environment can be applied at the following levels:
The main logical groups in orcharhino are:
Organizations – the highest level logical groups for hosts. Organizations provide a strong separation of content and configuration. Each organization requires a separate Red Hat Subscription Manifest, and can be thought of as a separate virtual instance of a orcharhino Server. Avoid the use of organizations if a lower level host grouping is applicable.
Locations – a grouping of hosts that should match the physical location. Locations can be used to map the network infrastructure to prevent incorrect host placement or configuration. For example, you cannot assign a subnet, domain, or compute resources directly to a orcharhino Proxy, only to a location.
Host groups – the main carriers of host definitions including assigned Puppet classes, Content View, or operating system. It is recommended to configure the majority of settings at the host group level instead of defining hosts directly. Configuring a new host then largely becomes a matter of adding it to the right host group. As host groups can be nested, you can create a structure that best fits your requirements (see Host group structures).
Host collections – a host registered to orcharhino Server for the purpose of subscription and content management is called content host. Content hosts can be organized into host collections, which enables performing bulk actions such as package management or errata installation.
Locations and host groups can be nested. Organizations and host collections are flat.
10.1. Host group structures
Flat structure
In this hierarchy, the first host group level is reserved for parameters specific to a lifecycle environment. The second level contains operating system related definitions, and the third level contains application specific settings. Such structure is useful in scenarios where responsibilities are divided among lifecycle environments (for example, a dedicated owner for the Development, QA, and Production lifecycle stages).
Application based structure
Location based structure
In this hierarchy, the distribution of locations is aligned with the host group structure. In a scenario where the location (orcharhino Proxy) topology determines many other attributes, this approach is the best option. On the other hand, this structure complicates sharing parameters across locations, therefore in complex environments with a large number of applications, the number of host group changes required for each configuration change increases significantly.
11. Provisioning concepts
An important feature of orcharhino is unattended provisioning of hosts. To achieve this, orcharhino uses DNS and DHCP infrastructures, PXE booting, TFTP, and Kickstart. Use this chapter to understand the working principle of these concepts.
11.1. PXE booting
11.1.1. PXE sequence
image/pxelinux.0
and the configuration filepxelinux.cfg/00:MA:CA:AD:D
from the TFTP server. -
initrd
and Kickstart. -
For an example of using PXE Booting by orcharhino Server, see Provisioning Workflow in Provisioning hosts.
11.1.2. PXE booting requirements
Ensure that all the network-based firewalls are configured to allow clients on the subnet to access the orcharhino Proxy. For more information, see orcharhino Proxy networking.
Ensure that both orcharhino Server and orcharhino Proxy have DNS configured and are able to resolve provisioned host names.
Ensure that the UDP port 69 is accessible by the client so that the client can access the TFTP server on the orcharhino Proxy.
Ensure that the TCP port 80 is accessible by the client to allow the client to download files and Kickstart templates from the orcharhino Proxy.
Ensure that the host provisioning interface subnet has a DHCP orcharhino Proxy set.
Ensure that the host provisioning interface subnet has a TFTP orcharhino Proxy set.
Ensure that the host provisioning interface subnet has a Templates orcharhino Proxy set.
Ensure that DHCP with the correct subnet is enabled using the orcharhino installer.
Enable TFTP using the orcharhino installer.
11.2. HTTP booting
11.2.1. HTTP booting requirements with managed DHCP
All the network-based firewalls are configured to allow clients on the subnet to access the orcharhino Proxy. For more information, see orcharhino Proxy networking.
Your client has access to the HTTP UEFI Boot orcharhino Proxy.
Although TFTP protocol is not used for HTTP UEFI Booting, orcharhino uses TFTP orcharhino Proxy API to deploy bootloader configuration.
For HTTP booting to work, ensure that orcharhino has the following configurations:
Both orcharhino Server and orcharhino Proxy have DNS configured and are able to resolve provisioned host names.
Ensure that the TCP port 8000 is open for the client to download the bootloader and Kickstart templates from the orcharhino Proxy.
The TCP port 9090 is open for the client to download the bootloader from the orcharhino Proxy using the HTTPS protocol.
The subnet that functions as the host’s provisioning interface has a DHCP orcharhino Proxy, an HTTP Boot orcharhino Proxy, a TFTP orcharhino Proxy, and a Templates orcharhino Proxy
The
grub2-efi
package is updated to the latest version. To update thegrub2-efi
package to the latest version and execute the installer to copy the recent bootloader from/boot
into/var/lib/tftpboot
directory, enter the following commands:# dnf upgrade grub2-efi # foreman-installer
11.2.2. HTTP booting requirements with unmanaged DHCP
http://orcharhino-proxy.example.com:8000
https://orcharhino-proxy.example.com:9090
Ensure that your client has access to the HTTP UEFI Boot orcharhino Proxy.
Although TFTP protocol is not used for HTTP UEFI Booting, orcharhino use TFTP orcharhino Proxy API to deploy bootloader configuration.
Ensure that the TCP port 8000 is open for the client to download bootloader and Kickstart templates from the orcharhino Proxy.
Ensure that the TCP port 9090 is open for the client to download the bootloader from the orcharhino Proxy through HTTPS.
Ensure that the host provisioning interface subnet has an HTTP Boot orcharhino Proxy set.
Update the
grub2-efi
package to the latest version and execute the installer to copy the recent bootloader from the/boot
directory into the/var/lib/tftpboot
directory:# dnf upgrade grub2-efi # foreman-installer
11.3. Secure boot
When orcharhino is installed on Enterprise Linux using foreman-installer
, grub2 and shim bootloaders that are signed by Red Hat are deployed into the TFTP and HTTP UEFI Boot directory.
PXE loader options named "SecureBoot" configure hosts to load shim.efi
On Debian and Ubuntu operating systems, the grub2 bootloader is created using the grub2-mkimage
unsigned.
To perform the Secure Boot, the bootloader must be manually signed and key enrolled into the EFI firmware.
Alternatively, grub2 from Ubuntu or Enterprise Linux can be copied to perform booting.
Grub2 in Enterprise Linux 8.0-8.3 were updated to mitigate Boot Hole Vulnerability and keys of existing Enterprise Linux kernels were invalidated. To boot any of the affected Enterprise Linux kernel (or OS installer), you must enroll keys manually into the EFI firmware for each host:
Appendix A: Technical users provided and required by orcharhino
During the installation of orcharhino, system accounts are created. They are used to manage files and process ownership of the components integrated into orcharhino. Some of these accounts have fixed UIDs and GIDs, while others take the next available UID and GID on the system instead. To control the UIDs and GIDs assigned to accounts, you can define accounts before installing orcharhino. Because some of the accounts have hard-coded UIDs and GIDs, it is not possible to do this with all accounts created during orcharhino installation.
The following table lists all the accounts created by orcharhino during installation. You can predefine accounts that have Yes in the Flexible UID and GID column with custom UID and GID before installing orcharhino.
Do not change the home and shell directories of system accounts because they are requirements for orcharhino to work correctly.
Because of potential conflicts with local users that orcharhino creates, you cannot use external identity providers for the system users of the orcharhino base operating system.
User name | UID | Group name | GID | Flexible UID and GID | Home | Shell |
foreman |
N/A |
foreman |
N/A |
yes |
/usr/share/foreman |
/sbin/nologin |
foreman-proxy |
N/A |
foreman-proxy |
N/A |
yes |
/usr/share/foreman-proxy |
/sbin/nologin |
apache |
48 |
apache |
48 |
no |
/usr/share/httpd |
/sbin/nologin |
postgres |
26 |
postgres |
26 |
no |
/var/lib/pgsql |
/bin/bash |
pulp |
N/A |
pulp |
N/A |
no |
N/A |
/sbin/nologin |
puppet |
52 |
puppet |
52 |
no |
/sbin/nologin |
saslauth |
N/A |
saslauth |
76 |
no |
/run/saslauthd |
/sbin/nologin |
tomcat |
53 |
tomcat |
53 |
no |
/usr/share/tomcat |
/bin/nologin |
unbound |
N/A |
unbound |
N/A |
yes |
/etc/unbound |
/sbin/nologin |
Appendix B: Glossary of terms used in orcharhino
- Activation key
- Answer file
/etc/foreman-installer/scenarios.d/
directory. To see the default values for installation scenario parameters, use theforeman-installer --full-help
command on your orcharhino Server.
- ARF report
The result of an OpenSCAP audit. Summarizes the security compliance of hosts managed by orcharhino.
- Audits
Provide a report on changes made by a specific user. Audits can be viewed in the orcharhino management UI under Monitor > Audits.
Enables remote power management of bare-metal hosts. In orcharhino, you can create a BMC interface to manage selected hosts.
- Boot disk
An ISO image used for PXE-less provisioning. This ISO enables the host to connect to orcharhino Server, boot the installation media, and install the operating system. There are several kinds of boot disks: host image, full host image, generic image, and subnet image.
- Catalog
A document that describes the desired system state for one specific host managed by Puppet. It lists all of the resources that need to be managed, as well as any dependencies between those resources. Catalogs are compiled by a Puppet server from Puppet Manifests and data from Puppet agents.
- Candlepin
- Compliance policy
Refers to a scheduled task executed on orcharhino Server that checks the specified hosts for compliance against SCAP content.
- Compute profile
- Compute resource
A virtual or cloud infrastructure, which orcharhino uses for deployment of hosts and systems. Examples include oVirt, OpenStack, EC2, and VMWare.
- Container (Docker container)
An isolated application sandbox that contains all runtime dependencies required by an application. orcharhino supports container provisioning on a dedicated compute resource.
- Container image
A static snapshot of the container’s configuration. orcharhino supports various methods of importing container images as well as distributing images to hosts through content views.
- Content
A general term for everything orcharhino distributes to hosts. Includes software packages (RPM files), or Docker images. Content is synchronized into the Library and then promoted into lifecycle environments using content views so that they can be consumed by hosts.
- Content delivery network (CDN)
The mechanism used to deliver Red Hat content to orcharhino Server.
- Content host
- Content view
A subset of Library content created by intelligent filtering. Once a content view is published, it can be promoted through the lifecycle environment path, or modified using incremental upgrades.
- Discovered host
- Discovery image
Refers to the minimal operating system based on Enterprise Linux that is PXE-booted on hosts to acquire initial hardware information and to communicate with orcharhino Server before starting the provisioning process.
- Discovery plugin
Enables automatic bare-metal discovery of unknown hosts on the provisioning network. The plugin consists of three components: services running on orcharhino Server and orcharhino Proxy, and the Discovery image running on host.
- Discovery rule
- Docker tag
A mark used to differentiate container images, typically by the version of the application stored in the image. In the orcharhino management UI, you can filter images by tag under Content > Docker Tags.
- Enterprise Linux
AlmaLinux
CentOS Linux
CentOS Stream
Oracle Linux
Rocky Linux
- ERB
- Errata
- External node classifier
A construct that provides additional data for a server to use when configuring hosts. orcharhino acts as an External Node Classifier to Puppet servers in a orcharhino deployment.
The External Node Classifier will be removed in a future orcharhino version.
- Facter
- Facts
- Foreman
The component mainly responsible for provisioning and content lifecycle management.
- Foreman hook
Foreman hook functionality is deprecated and will be removed in a future orcharhino version.
- Full host image
- Generic image
A boot disk for PXE-less provisioning that is not tied to a specific host. The generic image sends the host’s MAC address to orcharhino Server, which matches it against the host entry.
- Hammer
A command line tool for managing orcharhino. You can execute Hammer commands from the command line or utilize them in scripts. Hammer also provides an interactive shell.
- Host
Refers to any system, either physical or virtual, that orcharhino manages.
- Host collection
- Host group
A template for building a host. Host groups hold shared parameters, such as subnet or lifecycle environment, that are inherited by host group members. Host groups can be nested to create a hierarchical structure.
- Host image
A boot disk used for PXE-less provisioning of a specific host. The host image only contains the boot files necessary to access the installation media on orcharhino Server.
- Job
A command executed remotely on a host from orcharhino Server. Every job is defined in a job template.
- Katello
A Foreman plugin responsible for subscription and repository management.
- Lazy sync
- Location
- Library
A container for content from all synchronized repositories on orcharhino Server. Libraries exist by default for each organization as the root of every lifecycle environment path and the source of content for every content view.
- Lifecycle environment
A container for content view versions consumed by the content hosts. A Lifecycle Environment represents a step in the lifecycle environment path. Content moves through lifecycle environments by publishing and promoting content views.
- Lifecycle environment path
A sequence of lifecycle environments through which the content views are promoted. You can promote a content view through a typical promotion path; for example, from development to test to production.
- Manifest (Red Hat subscription manifest)
A mechanism for transferring subscriptions from the Red Hat Customer Portal to orcharhino. Do not confuse with Puppet manifest.
- Migrating orcharhino
The process of moving an existing orcharhino installation to a new instance.
- OpenSCAP
A project implementing security compliance auditing according to the Security Content Automation Protocol (SCAP). OpenSCAP is integrated in orcharhino to provide compliance auditing for hosts.
- orcharhino Proxy
An additional server that can be used in a orcharhino deployment to facilitate content federation and distribution (act as a Pulp mirror), and to run other localized services (Puppet server, DHCP, DNS, TFTP, and more). orcharhino Proxies are useful for orcharhino deployment across various geographical locations. In upstream Foreman terminology, orcharhino Proxy is referred to as Smart Proxy.
- Organization
An isolated collection of systems, content, and other functionality within a orcharhino deployment.
- Parameter
Defines the behavior of orcharhino components during provisioning. Depending on the parameter scope, we distinguish between global, domain, host group, and host parameters. Depending on the parameter complexity, we distinguish between simple parameters (key-value pair) and smart parameters (conditional arguments, validation, overrides).
- Permission
Defines an action related to a selected part of orcharhino infrastructure (resource type). Each resource type is associated with a set of permissions, for example the Architecture resource type has the following permissions: view_architectures, create_architectures, edit_architectures, and destroy_architectures. You can group permissions into roles and associate them with users or user groups.
- Product
A collection of content repositories. Products are either provided by Red Hat CDN or created by the orcharhino administrator to group custom repositories.
- Promote (a content view)
Defines host provisioning settings. Provisioning templates can be associated with host groups, lifecycle environments, or operating systems.
- Publish (a content view)
- Pulp
- Pulp mirror
A orcharhino Proxy component that mirrors content.
- Puppet
The configuration management component of orcharhino.
- Puppet agent
- Puppet environment
An isolated set of Puppet agent nodes that can be associated with a specific set of Puppet Modules.
- Puppet manifest
- Puppet server
A orcharhino Proxy component that provides a Puppet catalog to hosts for execution by the Puppet agent.
- Puppet module
- Recurring logic
A job executed automatically according to a schedule. In the orcharhino management UI, you can view those jobs under Monitor > Recurring logics.
- Registry
An archive of container images. orcharhino supports importing images from local and external registries. orcharhino itself can act as an image registry for hosts. However, hosts cannot push changes back to the registry.
- Repository
- Resource type
Refers to a part of orcharhino infrastructure, for example host, orcharhino Proxy, or architecture. Used in permission filtering.
- Role
Specifies a collection of permissions that are applied to a set of resources, such as hosts. Roles can be assigned to users and user groups. orcharhino provides a number of predefined roles.
- SCAP content
- Subnet image
A type of generic image for PXE-less provisioning that communicates through orcharhino Proxy.
- Subscription
- Synchronization
Refers to mirroring content from external resources into the orcharhino Library.
- Sync plan
- Task
A background process executed on the orcharhino or orcharhino Proxy, such as repository synchronization or content view publishing. You can monitor the task status in the orcharhino management UI under Monitor > orcharhino Tasks > Tasks.
- Updating orcharhino
The process of advancing your orcharhino Server and orcharhino Proxy installations from a z-stream release to the next, for example orcharhino 6.7.0 to orcharhino 6.7.1.
- Upgrading orcharhino
The process of advancing your orcharhino Server and orcharhino Proxy installations from a y-stream release to the next, for example orcharhino 6.6 to orcharhino 6.7.
- User group
- User
Anyone registered to use orcharhino. Authentication and authorization is possible through built-in logic, through external resources (LDAP, Identity Management, or Active Directory), or with Kerberos.
- virt-who
An agent for retrieving IDs of virtual machines from the hypervisor. When used with orcharhino, virt-who reports those IDs to orcharhino Server so that it can provide subscriptions for hosts provisioned on virtual machines.
Appendix C: CLI help
orcharhino offers multiple user interfaces: orcharhino management UI, Hammer CLI, API, and through Ansible collection theforeman.foreman. If you want to administer orcharhino on the command line, have a look at the following help output.
- orcharhino services
A set of services that orcharhino Server and orcharhino Proxies use for operation. You can use the
foreman-maintain
tool to manage these services. To see the full list of services, enter theforeman-maintain service list
command on the machine where orcharhino or orcharhino Proxy is installed. For more information, runforeman-maintain --help
on your orcharhino Server or orcharhino Proxy.
- orcharhino plugins
You can extend orcharhino by installing plugins. For more information, run
- Hammer CLI
You can manage orcharhino on the command line using
hammer
. For more information on using Hammer CLI, see Using Hammer CLI or runhammer --help
