2. Guide not ready yet
This guide is not ready yet.
Foreman is a community project. The source is maintained in foreman-documentation on GitHub where you can create issues and pull requests. Thanks for your contribution.
Appendix A: Glossary of terms used in Foreman
- Activation key
- Answer file
- ARF report
- Audits
- Boot disk
- Catalog
A document that describes the desired system state for one specific host managed by Puppet. It lists all of the resources that need to be managed, as well as any dependencies between those resources. Catalogs are compiled by a Puppet server from Puppet Manifests and data from Puppet agents.
- Candlepin
- Compliance policy
- Compute profile
- Compute resource
- Container (Docker container)
- Container image
- Content
A general term for everything Foreman distributes to hosts. Includes software packages (RPM files), or Docker images. Content is synchronized into the Library and then promoted into lifecycle environments using content views so that they can be consumed by hosts.
- Content delivery network (CDN)
- Content host
- Content view
A subset of Library content created by intelligent filtering. Once a content view is published, it can be promoted through the lifecycle environment path, or modified using incremental upgrades.
- Discovered host
- Discovery image
- Discovery plugin
- Discovery rule
- Docker tag
- Enterprise Linux
AlmaLinux
CentOS Linux
CentOS Stream
Oracle Linux
Rocky Linux
- ERB
- Errata
- External node classifier
The External Node Classifier will be removed in a future Foreman version.
- Facter
- Facts
- Foreman
The component mainly responsible for provisioning and content lifecycle management.
- Foreman hook
- Full host image
- Generic image
- Hammer
- Host
- Host collection
- Host group
A template for building a host. Host groups hold shared parameters, such as subnet or lifecycle environment, that are inherited by host group members. Host groups can be nested to create a hierarchical structure.
- Host image
- Job
- Katello
A Foreman plugin responsible for subscription and repository management.
- Lazy sync
- Location
- Library
A container for content from all synchronized repositories on Foreman server. Libraries exist by default for each organization as the root of every lifecycle environment path and the source of content for every content view.
- Lifecycle environment
A container for content view versions consumed by the content hosts. A Lifecycle Environment represents a step in the lifecycle environment path. Content moves through lifecycle environments by publishing and promoting content views.
- Lifecycle environment path
A sequence of lifecycle environments through which the content views are promoted. You can promote a content view through a typical promotion path; for example, from development to test to production.
- Manifest (Red Hat subscription manifest)
A mechanism for transferring subscriptions from the Red Hat Customer Portal to Foreman. Do not confuse with Puppet manifest.
- Migrating Foreman
- OpenSCAP
- Organization
- Parameter
- Permission
- Product
- Promote (a content view)
- Provisioning template
Defines host provisioning settings. Provisioning templates can be associated with host groups, lifecycle environments, or operating systems.
- Publish (a content view)
- Pulp
- Pulp mirror
- Puppet
- Puppet agent
- Puppet environment
An isolated set of Puppet agent nodes that can be associated with a specific set of Puppet Modules.
- Puppet manifest
- Puppet server
A Smart Proxy server component that provides a Puppet catalog to hosts for execution by the Puppet agent.
- Puppet module
- Recurring logic
- Registry
- Repository
- Resource type
- Role
- SCAP content
- Smart Proxy
A Smart Proxy component that can integrate with external services, such as DNS or DHCP. Smart Proxies are useful for Foreman deployment across various geographical locations.
- Subnet image
- Subscription
- Synchronization
- Sync plan
- Task
- Trend
- Updating Foreman
The process of advancing your Foreman server and Smart Proxy server installations from a z-stream release to the next, for example Foreman 3.10.0 to Foreman 3.10.1.
- Upgrading Foreman
The process of advancing your Foreman server and Smart Proxy server installations from a y-stream release to the next, for example Foreman 3.9 to Foreman 3.10.
- User group
- User
- virt-who
Appendix B: CLI help
Foreman offers multiple user interfaces: Foreman web UI, Hammer CLI, API, and through Ansible collection theforeman.foreman. If you want to administer Foreman on the command line, have a look at the following help output.
- Foreman services
foreman-maintaintool to manage these services. To see the full list of services, enter theforeman-maintain service listcommand on the machine where Foreman or Smart Proxy server is installed. For more information, runforeman-maintain --helpon your Foreman server or Smart Proxy server.
- Foreman plugins
You can extend Foreman by installing plugins. For more information, run
foreman-installer --full-helpon your Foreman server or Smart Proxy server.
- Hammer CLI
You can manage Foreman on the command line using
hammer. For more information on using Hammer CLI, runhammer --helpon your Foreman server or Smart Proxy server.
