Foreman Architecture
1. Introduction to Foreman
This guide contains information about features provided by the Katello plug-in. If you do not plan to install the Katello plug-in, ignore these references.
Foreman is a system management solution that enables you to deploy, configure, and maintain your systems across physical, virtual, and cloud environments. Foreman provides provisioning, remote management and monitoring of multiple Red Hat Enterprise Linux deployments with a single, centralized tool. Foreman Server synchronizes the content from Red Hat Customer Portal and other sources, and provides functionality including fine-grained life cycle management, user and group role-based access control, integrated subscription management, as well as advanced GUI, CLI, or API access.
Foreman Smart Proxy server mirrors content from Foreman Server to facilitate content federation across various geographical locations. Host systems can pull content and configuration from Smart Proxy server in their location and not from the central Foreman server. Smart Proxy server also provides localized services such as Puppet Master, DHCP, DNS, or TFTP. Smart Proxy servers assist you in scaling your Foreman environment as the number of your managed systems increases.
Smart Proxy servers decrease the load on the central server, increase redundancy, and reduce bandwidth usage. For more information, see Smart Proxy server Overview.
1.1. System Architecture
The following diagram represents the high-level architecture of Foreman.
There are four stages through which content flows in this architecture:
- External Content Sources
The Foreman Server can consume diverse types of content from various sources. The Red Hat Customer Portal is the primary source of software packages, errata, and container images. In addition, you can use other supported content sources (Git repositories, Docker Hub, Puppet Forge, SCAP repositories) as well as your organization’s internal data store.
- Foreman Server
The Foreman Server enables you to plan and manage the content life cycle and the configuration of Smart Proxy servers and hosts through GUI, CLI, or API.
Foreman server organizes the life cycle management by using organizations as principal division units. Organizations isolate content for groups of hosts with specific requirements and administration tasks. For example, the OS build team can use a different organization than the web development team.
Foreman server also contains a fine-grained authentication system to provide Foreman operators with permissions to access precisely the parts of the infrastructure that lie in their area of responsibility.
- Smart Proxy servers
Smart Proxy servers mirror content from Foreman server to establish content sources in various geographical locations. This enables host systems to pull content and configuration from Smart Proxy servers in their location and not from the central Foreman server. The recommended minimum number of Smart Proxy servers is therefore given by the number of geographic regions where the organization that uses Foreman operates.
Using Content Views, you can specify the exact subset of content that Smart Proxy server makes available to hosts. See Content Life Cycle in Foreman for a closer look at life cycle management with the use of Content Views.
The communication between managed hosts and Foreman server is routed through Smart Proxy server that can also manage multiple services on behalf of hosts. Many of these services use dedicated network ports, but Smart Proxy server ensures that a single source IP address is used for all communications from the host to Foreman server, which simplifies firewall administration. For more information on Smart Proxy servers see Smart Proxy server Overview.
- Managed Hosts
Hosts are the recipients of content from Smart Proxy servers. Hosts can be either physical or virtual. Foreman server can have directly managed hosts. The base system running a Smart Proxy server is also a managed host of Foreman server.
The following diagram provides a closer look at the distribution of content from Foreman server to Smart Proxies.
By default, each organization has a Library of content from external sources. Content Views are subsets of content from the Library created by intelligent filtering. You can publish and promote Content Views into life cycle environments (typically Dev, QA, and Production). When creating a Smart Proxy server, you can choose which life cycle environments will be copied to that Smart Proxy and made available to managed hosts.
Content Views can be combined to create Composite Content Views. It can be beneficial to have a separate Content View for a repository of packages required by an operating system and a separate one for a repository of packages required by an application. One advantage is that any updates to packages in one repository only requires republishing the relevant Content View. You can then use Composite Content Views to combine published Content Views for ease of management.
Which Content Views should be promoted to which Smart Proxy server depends on the Smart Proxy’s intended functionality. Any Smart Proxy server can run DNS, DHCP, and TFTP as infrastructure services that can be supplemented, for example, with content or configuration services.
You can update Smart Proxy server by creating a new version of a Content View using synchronized content from the Library. The new Content View version is then promoted through life cycle environments. You can also create in-place updates of Content Views. This means creating a minor version of the Content View in its current life cycle environment without promoting it from the Library. For example, if you need to apply a security erratum to a Content View used in Production, you can update the Content View directly without promoting to other life cycles. For more information on content management see the Content Management Guide.
1.2. System Components
Foreman consists of the following open source projects:
- Foreman
Foreman is an open source application used for provisioning and life cycle management of physical and virtual systems. Foreman automatically configures these systems using various methods, including kickstart and Puppet modules. Foreman also provides historical data for reporting, auditing, and troubleshooting.
- Katello
Katello is an optional Foreman plug-in for subscription and repository management. It provides a means to subscribe to repositories and download content. You can create and manage different versions of this content and apply them to specific systems within user-defined stages of the application life cycle.
- Candlepin
Candlepin is a service within Katello that handles subscription management.
- Pulp
Pulp is a service within Katello that handles repository and content management. Pulp ensures efficient storage space by not duplicating RPM packages even when requested by Content Views in different organizations.
- Hammer
Hammer is a CLI tool that provides command line and shell equivalents of most Web UI functions.
- REST API
Foreman includes a RESTful API service that allows system administrators and developers to write custom scripts and third-party applications that interface with Foreman.
The terminology used in Foreman and its components is extensive. For explanations of frequently used terms, see Glossary of Terms.
1.3. Supported Operating Systems and Architectures
1.3.1. Foreman server Operating System
Foreman has packages for CentOS 7 and clones, and Debian and clones. Katello plug-in packages, which provide content management capabilities, are only available for CentOS.
The only architecture Foreman has packages for is x86_64.
1.3.2. Client Operating Systems
Foreman can help to manage any kind of operating systems that have clients Foreman can integrate with. For example:
Operating system installers that can perform unattended installations (such as Anaconda in Fedora and CentOS, or Debian-installer in Debian and Ubuntu)
Puppet
Ansible
OpenSCAP
OpenSSH
Other clients where integration is provided by external plug-ins
Foreman is actively tested with the following client operating systems:
CentOS 5, 6, 7 and 8
Debian stable
Ubuntu LTS
The Katello plug-in provides functionality for content and subscription management. The following utilities are provided for selected CentOS and SLES operating systems:
Katello agent
Subscription manager
Katello host tools
Tracer utility
For Red Hat family operating systems, SELinux must not be set to disabled mode.
2. Smart Proxy server Overview
Smart Proxy servers provide content federation and run localized services to discover, provision, control, and configure hosts. You can use Smart Proxies to extend the Foreman deployment to various geographical locations. This section contains an overview of features that can be enabled on Smart Proxies as well as their simple classification.
For more information about Smart Proxy requirements, installation process, and scalability considerations, see Installing Smart Proxy server.
2.1. Smart Proxy Features
There are two sets of features provided by Smart Proxy servers. You can use Smart Proxy to run services required for host management. If you have the Katello plug-in installed, you can also configure Smart Proxy to mirror content from Foreman server.
Infrastructure and host management services:
DHCP – Smart Proxy can manage a DHCP server, including integration with an existing solution such as ISC DHCP servers, Active Directory, and Libvirt instances.
DNS – Smart Proxy can manage a DNS server, including integration with an existing solution such as ISC BIND and Active Directory.
TFTP – Smart Proxy can integrate with any UNIX-based TFTP server.
Realm – Smart Proxy can manage Kerberos realms or domains so that hosts can join them automatically during provisioning. Smart Proxy can integrate with an existing infrastructure, including FreeIPA and Active Directory.
Puppet Master – Smart Proxy can act as a configuration management server by running Puppet Master.
Puppet Certificate Authority – Smart Proxy can integrate with Puppet’s CA to provide certificates to hosts.
Baseboard Management Controller (BMC) – Smart Proxy can provide power management for hosts using IPMI or Redfish.
Provisioning template proxy – Smart Proxy can serve provisioning templates to hosts.
OpenSCAP – Smart Proxy can perform security compliance scans on hosts.
Content related features, provided by the Katello plug-in:
Repository synchronization – the content from Foreman server (more precisely from selected life cycle environments) is pulled to Smart Proxy server for content delivery (enabled by Pulp).
Content delivery – hosts configured to use Smart Proxy server download content from that Smart Proxy rather than from the central Foreman server (enabled by Pulp).
Host action delivery – Smart Proxy server executes scheduled actions on hosts.
Red Hat Subscription Management (RHSM) proxy – hosts are registered to their associated Smart Proxy servers rather than to the central Foreman server or the Red Hat Customer Portal (provided by Candlepin).
2.2. Smart Proxy Types
Not all Smart Proxy features have to be enabled at once. You can configure a Smart Proxy server for a specific limited purpose. Some common configurations include:
Infrastructure Smart Proxies [DNS + DHCP + TFTP] – provide infrastructure services for hosts. With provisioning template proxy enabled, infrastructure Smart Proxy has all necessary services for provisioning new hosts.
Content Smart Proxies [Pulp] – provide content synchronized from Foreman server to hosts.
Configuration Smart Proxies [Pulp + Puppet + PuppetCA] – provide content and run configuration services for hosts.
All-in-one Smart Proxies [DNS + DHCP + TFTP + Pulp + Puppet + PuppetCA] – provide a full set of Smart Proxy features. All-in-one Smart Proxies enable host isolation by providing a single point of connection for managed hosts.
2.3. Smart Proxy Networking
The goal of Smart Proxy isolation is to provide a single endpoint for all of the host’s network communications, so that in remote network segments, you need only open firewall ports to the Smart Proxy itself. The following diagram shows how the Foreman components interact in the scenario with hosts connecting to an isolated Smart Proxy.
The following diagram shows how the Foreman components interact when hosts connect directly to Foreman server. Note that as the base system of an external Smart Proxy is a Client of the Foreman, this diagram is relevant even if you do not intend to have directly connected hosts.
The Ports and Firewalls Requirements in Installing Foreman 2.5 server with Katello 4.1 plugin on Enterprise Linux and Ports and Firewalls Requirements in Installing an External Smart Proxy Server 2.5 contain complete instructions for configuring the host-based firewall to open the ports required.
3. Organizations, Locations, and Life Cycle Environments
Foreman takes a consolidated approach to Organization and Location management. System administrators define multiple Organizations and multiple Locations in a single Foreman server. For example, a company might have three Organizations (Finance, Marketing, and Sales) across three countries (United States, United Kingdom, and Japan). In this example, Foreman server manages all Organizations across all geographical Locations, creating nine distinct contexts for managing systems. In addition, users can define specific locations and nest them to create a hierarchy. For example, Foreman administrators might divide the United States into specific cities, such as Boston, Phoenix, or San Francisco.
Foreman server defines all locations and organizations. Each respective Foreman Smart Proxy server synchronizes content and handles configuration of systems in a different location.
The main Foreman server retains the management function, while the content and configuration is synchronized between the main Foreman server and a Foreman Smart Proxy server assigned to certain locations.
3.1. Organizations
3.2. Locations
3.3. Life Cycle Environments
Application life cycles are divided into life cycle environments which represent each stage of the application life cycle. Life cycle environments are linked to form an environment path. You can promote content along the environment path to the next life cycle environment when required. For example, if development ends on a particular version of an application, you can promote this version to the testing environment and start development on the next version.
4. Host Grouping Concepts
Apart from the physical topology of Smart Proxy servers, Foreman provides several logical units for grouping hosts. Hosts that are members of those groups inherit the group configuration. For example, the simple parameters that define the provisioning environment can be applied at the following levels:
Organizations – the highest level logical groups for hosts. Organizations provide a strong separation of content and configuration. Each organization requires a separate Subscription Manifest, and can be thought of as a separate virtual instance of a Foreman server. Avoid the use of organizations if a lower level host grouping is applicable.
Locations – a grouping of hosts that should match the physical location. Locations can be used to map the network infrastructure to prevent incorrect host placement or configuration. For example, you cannot assign a subnet, domain, or compute resources directly to a Smart Proxy server, only to a location.
Host groups – the main carriers of host definitions including assigned Puppet classes, Content View, or operating system. Find the complete list of host group parameters in Parameters in the Puppet Guide. It is recommended to configure the majority of settings at the host group level instead of defining hosts directly. Configuring a new host then largely becomes a matter of adding it to the right host group. As host groups can be nested, you can create a structure that best fits your requirements (see Host Group Structures).
Host collections – a host registered to Foreman server for the purpose of subscription and content management is called content host. Content hosts can be organized into host collections, which enables performing bulk actions such as package management or errata installation.
Locations and host groups can be nested, organizations and host collections are flat.
4.1. Host Group Structures
Flat Structure
Life Cycle Environment Based Structure
In this hierarchy, the first host group level is reserved for parameters specific to a life cycle environment. The second level contains operating system related definitions, and the third level contains application specific settings. Such structure is useful in scenarios where responsibilities are divided among life cycle environments (for example, a dedicated owner for the Development, QA, and Production life cycle stages).
Application Based Structure
Location Based Structure
5. Provisioning Concepts
5.1. PXE Booting
5.1.1. PXE Sequence
initrdand Kickstart. -
For an example of using PXE Booting by Foreman server, see Provisioning Workflow in the Provisioning Guide.
5.1.2. PXE Booting Requirements
Ensure that all the network-based firewalls are configured to allow clients on the subnet to access the Smart Proxy. For more information, see Foreman Topology with Isolated Smart Proxy.
5.2. HTTP Booting
5.2.1. HTTP Booting Requirements with managed DHCP
All the network-based firewalls are configured to allow clients on the subnet to access the Smart Proxy. For more information, see Foreman Topology with Isolated Smart Proxy.
Although TFTP protocol is not used for HTTP UEFI Booting, Foreman uses TFTP Smart Proxy API to deploy bootloader configuration.
Ensure that the TCP port 8000 is open for the client to download the bootloader and Kickstart templates from the Smart Proxy.
The TCP port 9090 is open for the client to download the bootloader from the Smart Proxy using the HTTPS protocol.
The subnet that functions as the host’s provisioning interface has a DHCP Smart Proxy, a HTTP Boot Smart Proxy, a TFTP Smart Proxy, and a Templates Smart Proxy
The
grub2-efipackage is updated to the latest version. To update thegrub2-efipackage to the latest version and execute the installer to copy the recent bootloader from/bootinto/var/lib/tftpbootdirectory, enter the following commands:# yum install grub2-efi # foreman-installer
5.2.2. HTTP Booting Requirements with unmanaged DHCP
http://{smartproxy.example.com}:8000 -
https://{smartproxy.example.com}:9090
Although TFTP protocol is not used for HTTP UEFI Booting, Foreman use TFTP Smart Proxy API to deploy bootloader configuration.
Ensure that the TCP port 8000 is open for the client to download bootloader and Kickstart templates from the Smart Proxy.
Ensure that the TCP port 9090 is open for the client to download the bootloader from the Smart Proxy via HTTPS protocol.
Ensure that the host provisioning interface subnet has a HTTP Boot Smart Proxy set.
Update the
grub2-efipackage to the latest version and execute the installer to copy the recent bootloader from the/bootdirectory into the/var/lib/tftpbootdirectory:# yum install grub2-efi # foreman-installer
5.3. Secure Boot
When Foreman is installed on Red Hat Enterprise Linux or compatible operating systems using foreman-installer, grub2 and shim bootloaders that are signed by Red Hat are deployed into the TFTP and HTTP UEFI Boot directory. PXE loader options named "SecureBoot" configure hosts to load shim.efi.
On Debian and Ubuntu operating systems, the grub2 bootloader is created using the grub2-mkimage unsigned. To perform the Secure Boot, the bootloader must be manually signed and key enrolled into the EFI firmware. Alternatively, grub2 from Ubuntu or Red Hat Enterprise Linux can be copied to perform booting.
Grub2 in Red Hat Enterprise Linux 8.0-8.3 were updated to mitigate [Boot Hole Vulnerability](https://access.redhat.com/security/vulnerabilities/grub2bootloader) and keys of existing Red Hat Enterprise Linux kernels were invalidated. To boot any of the affected Red Hat Enterprise Linux kernel (or OS installer), you must enroll keys manually into the EFI firmware for each host:
5.4. Kickstart
You can use Kickstart to automate the installation process of a Foreman or Smart Proxy server by creating a Kickstart file that contains all the information that is required for the installation. For more information about Kickstart, see Kickstart Installations in the Red Hat Enterprise Linux 7 Installation Guide.
5.4.1. Workflow
When you run a Foreman Kickstart script, the following workflow occurs:
It installs Red Hat Subscription Manager.
Foreman Deployment Planning
6. Deployment Considerations
6.1. Foreman server with External Database
When you install Foreman, the foreman-installer command creates databases on the same server that you install Foreman.
Depending on your requirements, moving to external databases can provide increased working memory for Foreman, which can improve response times for database operating requests.
High disk I/O workloads from frequent repository synchronization or Content View publishing. This causes Foreman to create a record in PostgreSQL for each job.
High volume of hosts.
For more information about using an external database, see Using External Databases with Foreman in Installing Foreman 2.5 server with Katello 4.1 plugin on Enterprise Linux.
6.2. Locations and Topology
This section outlines general considerations that should help you to specify your Foreman deployment scenario. The most common deployment scenarios are listed in Common Deployment Scenarios. The defining questions are:
How many Smart Proxy servers do I need? – The number of geographic locations where your organization operates should translate to the number of Smart Proxy servers. By assigning a Smart Proxy to each location, you decrease the load on Foreman server, increase redundancy, and reduce bandwidth usage. Foreman server itself can act as a Smart Proxy (it contains an integrated Smart Proxy by default). This can be used in single location deployments and to provision the base system’s of Smart Proxy servers. Using the integrated Smart Proxy to communicate with hosts in remote locations is not recommended as it can lead to suboptimal network utilization.
What services will be provided by Smart Proxy servers? – After establishing the number of Smart Proxies, decide what services will be enabled on each Smart Proxy. Even though the whole stack of content and configuration management capabilities is available, some infrastructure services (DNS, DHCP, TFTP) can be outside of a Foreman administrator’s control. In such case, Smart Proxies have to integrate with those external services (see Smart Proxy with External Services).
What compute resources do I need for my hosts? – Apart from provisioning bare metal hosts, you can use various compute resources supported by Foreman. To learn about provisioning on different compute resources see the Provisioning Guide.
6.3. Content Sources
The Subscription Manifest determines what Red Hat repositories are accessible from your Foreman server. Once you enable a Red Hat repository, an associated Foreman Product is created automatically. For distributing content from custom sources you need to create products and repositories manually. Red Hat repositories are signed with GPG keys by default, and it is recommended to create GPG keys also for your custom repositories. The configuration of custom repositories depends on the type of content they hold (RPM packages, or Docker images).
Repositories configured as yum repositories, that contain only RPM packages, can make use of the new download policy setting to save on synchronization time and storage space.
This setting enables selecting from Immediate and On demand.
The On demand setting saves space and time by only downloading packages when requested by clients.
For detailed instructions on setting up content sources see Importing Content in the Content Management Guide.
A custom repository within Foreman server is in most cases populated with content from an external staging server. Such servers lie outside of the Foreman infrastructure, however, it is recommended to use a revision control system (such as Git) on these servers to have better control over the custom content.
6.4. Content Life Cycle
Foreman provides features for precise management of the content life cycle. A life cycle environment represents a stage in the content life cycle, a Content View is a filtered set of content, and can be considered as a defined subset of content. By associating Content Views with life cycle environments, you make content available to hosts in a defined way (see Content Life Cycle in Foreman for visualization of the process). For a detailed overview of the content management process see Importing Custom Content in the Content Management Guide. The following section provides general scenarios for deploying content views as well as life cycle environments.
The default life cycle environment called Library gathers content from all connected sources. It is not recommended to associate hosts directly with the Library as it prevents any testing of content before making it available to hosts. Instead, create a life cycle environment path that suits your content workflow. The following scenarios are common:
A single life cycle environment – content from Library is promoted directly to the production stage. This approach limits the complexity but still allows for testing the content within the Library before making it available to hosts.
A single life cycle environment path – both operating system and applications content is promoted through the same path. The path can consist of several stages (for example Development, QA, Production), which enables thorough testing but requires additional effort.
Application specific life cycle environment paths – each application has a separate path, which allows for individual application release cycles. You can associate specific compute resources with application life cycle stages to facilitate testing. On the other hand, this scenario increases the maintenance complexity.
6.5. Content Deployment
Content deployment is the management of errata and packages on content hosts. There are two methods for content deployment on Foreman; the default is remote execution, and the second is the deprecated katello agent.
Remote execution - Remote execution via SSH transport allows the install, update, or removal of packages, the bootstrap of configuration management agents, and the trigger of Puppet runs. This is the preferred method for content deployment.
While Foreman server has remote execution enabled by default, it is disabled by default on Smart Proxy servers and content hosts and has to be manually enabled.
Katello agent - Uses the goferd service which communicates to and from the Foreman server and is primarily tasked with installing and updating packages. It is enabled and started automatically on content hosts after successfully installing the katello-agent package.
Note that the Katello agent is deprecated and will be removed in a future Foreman version.
6.6. Provisioning
Foreman provides several features to help you automate the host provisioning, including provisioning templates, configuration management with Puppet, and host groups for standardized provisioning of host roles. For a description of the provisioning workflow see Provisioning Workflow in the Provisioning Guide. The same guide contains instructions for provisioning on various compute resources.
6.7. Role Based Authentication
Roles related to a particular stage of the software life cycle – for example, roles divided among the development, testing, and production phases, where each phase has one or more owners.
Define the expected tasks and responsibilities – define the subset of the Foreman infrastructure that will be accessible to the role as well as actions permitted on this subset. Think of the responsibilities of the role and how it would differ from other roles.
Use predefined roles whenever possible – Foreman provides a number of sample roles that can be used alone or as part of a role combination. Copying and editing an existing role can be a good start for creating a custom role.
Consider all affected entities – for example, a content view promotion automatically creates new Puppet Environments for the particular life cycle environment and content view combination. Therefore, if a role is expected to promote content views, it also needs permissions to create and edit Puppet Environments.
Consider areas of interest – even though a role has a limited area of responsibility, there might be a wider area of interest. Therefore, you can grant the role a read only access to parts of Foreman infrastructure that influence its area of responsibility. This allows users to get earlier access to information about potential upcoming changes.
For instructions on defining roles and assigning them to users, see Managing Users and Roles in the Administering Foreman guide. The same guide contains information on configuring external authentication sources.
6.8. Additional Tasks
Discovering bare metal hosts – the Foreman Discovery plug-in enables automatic bare-metal discovery of unknown hosts on the provisioning network. These new hosts register themselves to Foreman server and the Puppet Agent on the client uploads system facts collected by Facter, such as serial ID, network interface, memory, and disk information. After registration you can initialize provisioning of those discovered hosts. For details, see Creating Hosts from Discovered Hosts in the Provisioning Guide.
Backup management – backup and disaster recovery instructions, see Backing Up Foreman server and Smart Proxy server in Administering Foreman. Using remote execution, you can also configure recurring backup tasks on managed hosts. For more information on remote execution see Configuring and Setting up Remote Jobs in Managing Hosts.
Security management – Foreman supports security management in various ways, including update and errata management, OpenSCAP integration for system verification, update and security compliance reporting, and fine grained role based authentication. Find more information on errata management and OpenSCAP concepts in Managing Hosts.
Incident management – Foreman supports the incident management process by providing a centralized overview of all systems including reporting and email notifications. Detailed information on each host is accessible from Foreman server, including the event history of recent changes.
Scripting with Hammer and API – Foreman provides a command line tool called Hammer that provides a CLI equivalent to the majority of web UI procedures. In addition, you can use the access to the Foreman API to write automation scripts in a selected programming language. For more information see the Hammer CLI Guide and API Guide.
7. Common Deployment Scenarios
7.1. Single Location
An integrated Smart Proxy is a virtual Smart Proxy server that is created by default in Foreman server during the installation process. This means Foreman server can be used to provision directly connected hosts for Foreman deployment in a single geographical location, therefore only one physical server is needed. The base systems of isolated Smart Proxies can be directly managed by Foreman server, however it is not recommended to use this layout to manage other hosts in remote locations.
7.2. Single Location with Segregated Subnets
Your infrastructure might require multiple isolated subnets even if Foreman is deployed in a single geographic location. This can be achieved for example by deploying multiple Smart Proxy servers with DHCP and DNS services, but the recommended way is to create segregated subnets using a single Smart Proxy. This Smart Proxy is then used to manage hosts and compute resources in those segregated networks to ensure they only have to access the Smart Proxy for provisioning, configuration, errata, and general management. For more information on configuring subnets see Managing Hosts.
7.3. Multiple Locations
It is recommended to create at least one Smart Proxy server per geographic location. This practice can save bandwidth since hosts obtain content from a local Smart Proxy server. Synchronization of content from remote repositories is done only by the Smart Proxy, not by each host in a location. In addition, this layout makes the provisioning infrastructure more reliable and easier to configure. See Foreman System Architecture for an illustration of this approach.
7.4. Smart Proxy with External Services
You can configure a Smart Proxy server (integrated or standalone) to use external DNS, DHCP, or TFTP service. If you already have a server that provides these services in your environment, you can integrate it with your Foreman deployment. For information about how to configure a Smart Proxy with external services, see Configuring Smart Proxy server with External Services in Installing an External Smart Proxy Server 2.5.
Appendix A: Technical Users Provided and Required by Foreman
foreman |
N/A |
foreman |
N/A |
yes |
/usr/share/foreman |
/sbin/nologin |
foreman-proxy |
N/A |
foreman-proxy |
N/A |
yes |
/usr/share/foreman-proxy |
/sbin/nologin |
puppet |
N/A |
puppet |
N/A |
yes |
/sbin/nologin |
qdrouterd |
N/A |
qdrouterd |
N/A |
yes |
N/A |
/sbin/nologin |
qpidd |
N/A |
qpidd |
N/A |
yes |
/var/lib/qpidd |
/sbin/nologin |
unbound |
N/A |
unbound |
N/A |
yes |
/etc/unbound |
/sbin/nologin |
postgres |
26 |
postgres |
26 |
no |
/var/lib/pgsql |
/bin/bash |
apache |
48 |
apache |
48 |
no |
/usr/share/httpd |
/sbin/nologin |
tomcat |
53 |
tomcat |
53 |
no |
/usr/share/tomcat |
/bin/nologin |
saslauth |
N/A |
saslauth |
76 |
no |
N/A |
/sbin/nologin |
Appendix B: Glossary of Terms
This glossary documents various terms used in relation to Foreman.
- Activation Key
- Answer File
A configuration file that defines settings for an installation scenario. Answer files are defined in the YAML format and stored in the /etc/foreman-installer/scenarios.d/ directory.
- ARF Report
- Audits
- Boot Disk
- Smart Proxy (Smart Proxy server)
An additional server that can be used in a Foreman deployment to facilitate content federation and distribution (act as a Pulp mirror), and to run other localized services (Puppet Master, DHCP, DNS, TFTP, and more). Smart Proxies are useful for Foreman deployment across various geographical locations.
- Catalog
A document that describes the desired system state for one specific host managed by Puppet. It lists all of the resources that need to be managed, as well as any dependencies between those resources. Catalogs are compiled by a Puppet Master from Puppet Manifests and data from Puppet Agents.
- Candlepin
- Compliance Policy
- Compute Profile
- Compute Resource
- Container (Docker Container)
- Container Image
- Content
A general term for everything Foreman distributes to hosts. Includes software packages (RPM files), or Docker images. Content is synchronized into the Library and then promoted into life cycle environments using content views so that they can be consumed by hosts.
- Content Delivery Network (CDN)
- Content Host
- Content View
A subset of Library content created by intelligent filtering. Once a content view is published, it can be promoted through the life cycle environment path, or modified using incremental upgrades.
- Discovered Host
A bare-metal host detected on the provisioning network by the Discovery plug-in.
- Discovery Image
Refers to the minimal operating system based on Red Hat Enterprise Linux that is PXE-booted on hosts to acquire initial hardware information and to communicate with Foreman server before starting the provisioning process.
- Discovery Plug-in
Enables automatic bare-metal discovery of unknown hosts on the provisioning network. The plug-in consists of three components: services running on Foreman server and Smart Proxy server, and the Discovery image running on host.
- Discovery Rule
- Docker Tag
- ERB
- Errata
- External Node Classifier
Note that the External Node Classifier will be removed in the next Foreman version.
- Facter
- Facts
- Foreman
The component mainly responsible for provisioning and content life cycle management.
- foreman-maintain services
foreman-maintaintool to manage these services. To see the full list of services, enter theforeman-maintain service listcommand on the machine where Foreman or Smart Proxy server is installed.
- Foreman Hook
- Full Host Image
- Generic Image
- Hammer
- Host
- Host Collection
- Host Group
A template for building a host. Host groups hold shared parameters, such as subnet or life cycle environment, that are inherited by host group members. Host groups can be nested to create a hierarchical structure.
- Host Image
- Incremental Upgrade (of a Content View)
The act of creating a new (minor) content view version in a life cycle environment. Incremental upgrades provide a way to make in-place modification of an already published content view. Useful for rapid updates, for example when applying security errata.
- Job
- Job Template
Defines properties of a job.
- Katello
A Foreman plug-in responsible for subscription and repository management.
- Lazy Sync
The ability to change a
yumrepository’s default download policy of Immediate to On Demand. The On Demand setting saves storage space and synchronization time by only downloading the packages when requested by a client.
- Location
- Library
A container for content from all synchronized repositories on Foreman server. Libraries exist by default for each organization as the root of every life cycle environment path and the source of content for every content view.
- Life Cycle Environment
A container for content view versions consumed by the content hosts. A Life Cycle Environment represents a step in the life cycle environment path. Content moves through life cycle environments by publishing and promoting content views.
- Life Cycle Environment Path
A sequence of life cycle environments through which the content views are promoted. You can promote a content view through a typical promotion path; for example, from development to test to production.
- Manifest (Subscription Manifest)
A mechanism for transferring subscriptions from the Red Hat Customer Portal to Foreman. Do not confuse with Puppet Manifest.
- OpenSCAP
A project implementing security compliance auditing according to the Security Content Automation Protocol (SCAP). OpenSCAP is integrated in Foreman to provide compliance auditing for managed hosts.
- Organization
- Parameter
- Parametrized Class (Smart Class Parameter)
A parameter created by importing a class from Puppet Master.
- Permission
- Product
- Promote (a Content View)
The act of moving a content view from one life cycle environment to another.
- Provisioning Template
Defines host provisioning settings. Provisioning templates can be associated with host groups, life cycle environments, or operating systems.
- Publish (a Content View)
The act of making a content view version available in a life cycle environment and usable by hosts.
- Pulp
- Pulp Mirror
- Puppet
- Puppet Agent
- Puppet Environment
- Puppet Manifest
Do not confuse with Manifest (Subscription Manifest).
- Puppet Master
- Puppet Module
- Recurring Logic
- Registry
- Repository
- Resource Type
Refers to a part of Foreman infrastructure, for example host, capsule, or architecture. Used in permission filtering.
- Role
- SCAP content
- Scenario
A set of predefined settings for the Foreman CLI installer. Scenario defines the type of installation, for example to install Smart Proxy server execute
foreman-installer --scenario foreman-proxy-content. Every scenario has its own answer file to store the scenario settings.
- Smart Proxy
A Smart Proxy server component that can integrate with external services, such as DNS or DHCP. In upstream Foreman terminology, Smart Proxy is a synonym of Smart Proxy.
- Smart Variable
A configuration value used by classes in Puppet modules.
- Standard Operating Environment (SOE)
A controlled version of the operating system on which applications are deployed.
- Subnet Image
- Subscription
- Synchronization
- Synchronization Plan
- Task
A background process executed on the Foreman or Smart Proxy server, such as repository synchronization or content view publishing. You can monitor the task status in the Foreman web UI under Monitor > Tasks.
- Trend
A means of tracking changes in specific parts of Foreman infrastructure. Configure trends in Foreman web UI under Monitor > Trends.
- User Group
- User
- virt-who
