1. Accessing Foreman
After Foreman has been installed and configured, use the web user interface to log in to Foreman for further configuration.
1.1. Installing the Katello Root CA Certificate
The first time you log on to Foreman, you might see a warning informing you that you are using the default self-signed certificate and you might not be able to connect this browser to Foreman until the root CA certificate is installed in the browser. Use the following procedure to locate the root CA certificate on Foreman and to install it in your browser.
Your Foreman is installed and configured.
Identify the fully qualified domain name of your Foreman server:
# hostname -f
Access the
pubdirectory on your Foreman server using a web browser pointed to the fully qualified domain name:https://foreman.example.com/pub
When you access Foreman for the first time, an untrusted connection warning displays in your web browser. Accept the self-signed certificate and add the Foreman URL as a security exception to override the settings. This procedure might differ depending on the browser being used. Ensure that the Foreman URL is valid before you accept the security exception.
Select
katello-server-ca.crt. -
Import the certificate into your browser as a certificate authority and trust it to identify websites.
If you cannot add a security exception in your browser, import the Katello root CA certificate manually.
From the Foreman CLI, copy the
katello-server-ca.crtfile to the machine you use to access the web UI:# scp /var/www/html/pub/katello-server-ca.crt \ username@hostname:remotefile
In the browser, import the
katello-server-ca.crtcertificate as a certificate authority and trust it to identify websites.
1.2. Logging on to Foreman
Use the web user interface to log on to Foreman for further configuration.
Ensure that the Katello root CA certificate is installed in your browser. For more information, see Installing the Katello Root CA Certificate.
Access Foreman server using a web browser pointed to the fully qualified domain name:
Enter the user name and password created during the configuration process. If a user was not created during the configuration process, the default user name is admin. If you have problems logging on, you can reset the password. For more information, see Resetting the Administrative User Password.
1.3. Navigation Tabs in the Foreman Web UI
| Navigation Tabs | Description |
Any Context |
Clicking this tab changes the organization and location. If no organization or location is selected, the default organization is Any Organization and the default location is Any Location. Use this tab to change to different values. |
Monitor |
Content |
Provides content management tools. This includes Content Views, Activation Keys, and Life Cycle Environments. |
Hosts |
Configure |
Provides general configuration tools and data including Host Groups and Puppet data. |
Infrastructure |
Provides tools on configuring how Foreman interacts with the environment. |
User Name |
Provides user administration where users can edit their personal information. |
Administer |
Provides advanced configuration for settings such as Users and RBAC, as well as general settings. |
1.4. Changing the Password
Click your user name at the top right corner.
Select My Account from the menu.
In the Current Password field, enter the current password.
In the Password field, enter a new password.
In the Verify field, enter the new password again.
Click the Submit button to save your new password.
1.5. Resetting the Administrative User Password
To reset the password to randomly generated characters, complete the following procedure:
Log on to the base operating system where Foreman server is installed.
Enter the following command to reset the password:
# foreman-rake permissions:reset Reset to user: admin, password: qwJxBptxb7Gfcjj5
Use this password to reset the password in the Foreman web UI.
Edit the
~/.hammer/cli.modules.d/foreman.ymlfile on Foreman server to add the new password:# vi ~/.hammer/cli.modules.d/foreman.yml
To change the administrative user password to a new password, complete the following steps:
To set the password, enter the following command:
Edit the
1.6. Setting a Custom Message on the Login Page
Navigate to Administer > Settings, and click the General tab.
Click the edit button next to Login page footer text, and enter the desired text to be displayed on the login page. For example, this text may be a warning message required by your company.
Click Save.
Log out of the Foreman’s web UI and verify that the custom text is now displayed on the login page below the Foreman version number.
Foreman provides the foreman-maintain service command to manage Foreman services from the command line.
This is useful when creating a backup of Foreman.
For more information on creating backups, see Backing Up Foreman server and Smart Proxy server.
After installing Foreman with the foreman-installer command, all Foreman services are started and enabled automatically.
To stop the foreman-maintain services, execute:
To start the foreman-maintain services, execute:
To restart the foreman-maintain services, execute:
For Red Hat systems only.
To confirm whether your Foreman server has internal or external databases, you can query the status of your databases:
Preparing a Host for External Databases. Prepare a Red Hat Enterprise Linux 7 server to host the external databases.
Installing PostgreSQL. Prepare PostgreSQL with databases for Foreman, Pulp and Candlepin with dedicated users owning them.
Migrating to External Databases. Edit the parameters of
foreman-installerto point to the new databases, and runforeman-installer.
Foreman, Katello, and Candlepin use the PostgreSQL database. If you want to use PostgreSQL as an external database, the following information can help you decide if this option is right for your Foreman configuration. Foreman supports PostgreSQL version 12.1.
Increase in free memory and free CPU on Foreman
Flexibility to set
shared_bufferson the PostgreSQL database to a high number without the risk of interfering with other services on Foreman -
Flexibility to tune the PostgreSQL server’s system without adversely affecting Foreman operations
If either Foreman or the PostgreSQL database server suffers a hardware or storage failure, Foreman is not operational
If there is latency between the Foreman server and database server, performance can suffer
Install a freshly provisioned system with the latest Red Hat Enterprise Linux 7 server to host the external databases.
Subscriptions for Red Hat Software Collections and Red Hat Enterprise Linux do not provide the correct service level agreement for using Foreman with external databases. You must also attach a Foreman subscription to the base operating system that you want to use for the external databases.
The Red Hat Enterprise Linux 7 server must meet Foreman’s Storage Requirements.
Use the instructions in Attaching the Foreman Infrastructure Subscription to attach a Foreman subscription to your server.
Disable all repositories and enable only the following repositories:
# subscription-manager repos --disable '*' # subscription-manager repos --enable=rhel-server-rhscl-7-rpms \ --enable=rhel-7-server-rpms --enable=rhel-7-server-satellite-6.10-rpms
3.3. Installing PostgreSQL
You can install only the same version of PostgreSQL that is installed with the foreman-installer tool during an internal database installation.
You can install PostgreSQL using Red Hat Enterprise Linux Server 7 repositories or from an external source, as long as the version is supported.
To install PostgreSQL, enter the following command:
# yum install rh-postgresql12-postgresql-server \ rh-postgresql12-syspaths \ rh-postgresql12-postgresql-evr
To initialize PostgreSQL, enter the following command:
# postgresql-setup initdb
Edit the
/var/opt/rh/rh-postgresql12/lib/pgsql/data/postgresql.conffile:# vi /var/opt/rh/rh-postgresql12/lib/pgsql/data/postgresql.conf
Remove the
Edit the
/var/opt/rh/rh-postgresql12/lib/pgsql/data/pg_hba.conffile:# vi /var/opt/rh/rh-postgresql12/lib/pgsql/data/pg_hba.conf
host all all Foreman_ip/24 md5
To start, and enable PostgreSQL service, enter the following commands:
# systemctl start postgresql # systemctl enable postgresql
Open the postgresql port on the external PostgreSQL server:
# firewall-cmd --add-service=postgresql # firewall-cmd --runtime-to-permanent
Switch to the
Create three databases and dedicated roles: one for Foreman, one for Candlepin, and one for Pulp:
CREATE USER "foreman" WITH PASSWORD 'Foreman_Password'; CREATE USER "candlepin" WITH PASSWORD 'Candlepin_Password'; CREATE USER "pulp" WITH PASSWORD 'Pulpcore_Password'; CREATE DATABASE foreman OWNER foreman; CREATE DATABASE candlepin OWNER candlepin; CREATE DATABASE pulpcore OWNER pulp;
Exit the
postgresuser:# \q
From Foreman server, test that you can access the database. If the connection succeeds, the commands return
1.# PGPASSWORD='Foreman_Password' psql -h postgres.example.com -p 5432 -U foreman -d foreman -c "SELECT 1 as ping" # PGPASSWORD='Candlepin_Password' psql -h postgres.example.com -p 5432 -U candlepin -d candlepin -c "SELECT 1 as ping" # PGPASSWORD='Pulpcore_Password' psql -h postgres.example.com -p 5432 -U pulp -d pulpcore -c "SELECT 1 as ping"
You have installed and configured a PostgreSQL server on a Red Hat Enterprise Linux server.
On Foreman server, stop the
foreman-maintainservices:# foreman-maintain service stop
Start the PostgreSQL services:
PGPASSWORD='Foreman_Password' pg_restore -h postgres.example.com -U foreman -d foreman < /var/migration_backup/foreman.dump PGPASSWORD='Candlepin_Password' pg_restore -h postgres.example.com -U candlepin -d candlepin < /var/migration_backup/candlepin.dump PGPASSWORD='Pulpcore_Password' pg_restore -h postgres.example.com -U pulp -d pulpcore < /var/migration_backup/pulpcore.dump
Use the
foreman-installercommand to update Foreman to point to the new databases:foreman-installer --scenario katello \ --foreman-db-host postgres.example.com \ --foreman-db-password Foreman_Password \ --foreman-db-database foreman \ --foreman-db-manage false \ --katello-candlepin-db-host postgres.example.com \ --katello-candlepin-db-name candlepin \ --katello-candlepin-db-password Candlepin_Password \ --katello-candlepin-manage-db false \ --foreman-proxy-content-pulpcore-manage-postgresql false \ --foreman-proxy-content-pulpcore-postgresql-host postgres.example.com \ --foreman-proxy-content-pulpcore-postgresql-db-name pulpcore \ --foreman-proxy-content-pulpcore-postgresql-password Pulpcore_Password
4.1. Installing the Foreman Ansible Modules from RPM
Install the RPM from the client repository on yum.theforeman.org using the following command:
Starting with Ansible 2.10, you can view the installed Foreman Ansible modules by running:
When using Ansible before 2.10, you can view the installed Foreman Ansible modules by listing the content of the following directory:
Alternatively, you can also see the complete list of Foreman Ansible modules and other related information at https://galaxy.ansible.com/theforeman/foreman.
All modules are in the theforeman.foreman namespace and can be referred to in the format theforeman.foreman._module_name_.
For example, to display information about the activation_key module, enter the following command:
5. Managing Users and Roles
You can manage permissions of several users at once by organizing them into user groups. User groups themselves can be further grouped to create a hierarchy of permissions. See Creating and Managing User Groups for more information on creating user groups.
5.1. User Management
5.1.1. Creating a User
Use this procedure to create a user. To use the CLI instead of the web UI, see the CLI procedure.
To create a user, complete the following steps:
Navigate to Administer > Users.
Click Create User.
In the Login field, enter a username for the user.
In the Firstname and Lastname fields, enter the real first name and last name of the user.
In the Mail field, enter the user’s email address.
In the Description field, add a description of the new user.
Select a specific language for the user from the Language list.
Select a timezone for the user from the Timezone list.
By default, Foreman server uses the language and timezone settings of the user’s browser.
Set a password for the user:
From the Authorized by list, select the source by which the user is authenticated.
INTERNAL: to enable the user to be managed inside Foreman server.
EXTERNAL: to configure external authentication as described in Configuring External Authentication.
Enter an initial password for the user in the Password field and the Verify field.
To create a user, enter the following command:
# hammer user create \ --login user_name \ --password user_password \ --mail user_mail \ --auth-source-id 1 \ --organization-ids org_ID1,org_ID2...
The
--auth-source-id 1setting means that the user is authenticated internally, you can specify an external authentication source as an alternative. Add the--adminoption to grant administrator privileges to the user. Specifying organization IDs is not required, you can modify the user details later using theupdatesubcommand.
Use this procedure to assign roles to a user. To use the CLI instead of the web UI, see the CLI procedure.
NoteIf a user account is not listed, check that you are currently viewing the correct organization. To list all the users in Foreman, click Default Organization and then Any Organization.
To grant all the available permissions, select the Admin check box.
Click Submit.
Ensure that you are logged on to the Foreman web UI as a user with administrator privileges for Foreman.
To impersonate a different user account, complete the following steps:
5.2. SSH Key Management
Adding SSH keys to a user allows deployment of SSH keys during provisioning.
For information on deploying SSH keys during provisioning, see Deploying SSH Keys during Provisioning in the Provisioning Guide.
For information on SSH keys and SSH key creation, see Using SSH-based Authentication in the Red Hat Enterprise Linux 7 System Administrator’s Guide.
Use this procedure to add or remove SSH keys for a user. To use the CLI instead of the web UI, see the CLI procedure.
Make sure that you are logged in to the web UI as an Admin user of Foreman or a user with the create_ssh_key permission enabled for adding SSH key and destroy_ssh_key permission for removing a key.
Click on the SSH Keys tab.
To Add SSH key
Click Add SSH Key.
Click Submit.
To Remove SSH key
# hammer user ssh-keys add \ --user-id user_id \ --name key_name \ --key-file ~/.ssh/id_rsa.pub
# hammer user ssh-keys add \ --user-id user_id \ --name key_name \ --key ecdsa-sha2-nistp256 AAAAE2VjZHNhLXNoYTItbmlzdHAyNTYAAAAIbmlzdHAyNtYAAABBBHHS2KmNyIYa27Qaa7EHp+2l99ucGStx4P77e03ZvE3yVRJEFikpoP3MJtYYfIe8k 1/46MTIZo9CPTX4CYUHeN8= host@user
5.3. Creating and Managing User Groups
5.3.1. User Groups
With Foreman, you can assign permissions to groups of users. You can also create user groups as collections of other user groups. If using an external authentication source, you can map Foreman user groups to external user groups as described in Configuring External User Groups.
5.3.2. Creating a User Group
Navigate to Administer > User Groups.
Click Create User group.
On the Roles tab, select the roles you want to assign to the user group. Alternatively, select the Admin check box to assign all available permissions.
Click Submit.
To create a user group, enter the following command:
# hammer user-group create \ --name usergroup_name \ --user-ids user_ID1,user_ID2... \ --role-ids role_ID1,role_ID2...
5.3.3. Removing a User Group
Click Delete to the right of the user group you want to delete.
In the alert box that appears, click OK to delete a user group.
5.4. Creating and Managing Roles
5.4.1. Creating a Role
Navigate to Administer > Roles.
Click Create Role.
Provide a Name for the role.
# hammer role create --name role_name
5.4.2. Cloning a Role
Navigate to Administer > Roles and select Clone from the drop-down menu to the right of the required role.
5.4.3. Adding Permissions to a Role
Use this procedure to add permissions to a role. To use the CLI instead of the web UI, see the CLI procedure.
Depending on the Resource type selected, you can select or deselect the Unlimited and Override check box. The Unlimited checkbox is selected by default, which means that the permission is applied on all resources of the selected type. When you disable the Unlimited check box, the Search field activates. In this field you can specify further filtering with use of the Foreman search syntax. See Granular Permission Filtering for details. When you enable the Override check box, you can add additional locations and organizations to allow the role to access the resource type in the additional locations and organizations; you can also remove an already associated location and organization from the resource type to restrict access.
Click Next.
Click Submit to save changes.
Add permissions to a role:
# hammer filter create \ --role role_name \ --permission-ids perm_ID1,perm_ID2...
5.4.4. Viewing Permissions of a Role
The Filters page contains a table of permissions assigned to a role grouped by the resource type. It is also possible to generate a complete table of permissions and actions that you can use on your Foreman system. See Creating a Complete Permission Table for instructions.
5.4.5. Creating a Complete Permission Table
Ensure that the required packages are installed. Execute the following command on Foreman server:
# yum install foreman-console
Start the Foreman console with the following command:
# foreman-rake console
/tmp/table.htmlfile. -
Press
Ctrl+Dto exit the Foreman console. Insert the following text at the first line of/tmp/table.html:<table border="1"><tr><td>Permission name</td><td>Actions</td><td>Resource type</td></tr>
/tmp/table.html:</table>
Open
5.4.6. Removing a Role
Select Delete from the drop-down list to the right of the role to be deleted.
In an alert box that appears, click OK to delete the role.
5.4.7. Predefined Roles Available in Foreman
| Role | Permissions Provided by Role footnote:[The exact set of allowed actions associated with predefined roles can be viewed by the privileged user as described in ] |
Access Insights Admin |
Add and edit Insights rules. |
Access Insights Viewer |
View Insight reports. |
Ansible Roles Manager |
Play roles on hosts and host groups. View, destroy, and import Ansible roles. View, edit, create, destroy, and import Ansible variables. |
Ansible Tower Inventory Reader |
View facts, hosts, and host groups. |
Bookmarks manager |
Create, edit, and delete bookmarks. |
Boot disk access |
Download the boot disk. |
Compliance manager |
View, create, edit, and destroy SCAP content files, compliance policies, and tailoring files. View compliance reports. |
Compliance viewer |
Create ARF report |
Create compliance reports. |
Default role |
The set of permissions that every user is granted, irrespective of any other roles. |
Discovery Manager |
View, provision, edit, and destroy discovered hosts and manage discovery rules. |
Discovery Reader |
View hosts and discovery rules. |
Edit hosts |
View, create, edit, destroy, and build hosts. |
Edit partition tables |
View, create, edit and destroy partition tables. |
Manager |
A role similar to administrator, but does not have permissions to edit global settings. In the Foreman web UI, global settings can be found under Administer > Settings. |
Organization admin |
An administrator role defined per organization. The role has no visibility into resources in other organizations. |
Red Hat Access Logs |
View the log viewer and the logs. |
Remote Execution Manager |
A role with full remote execution permissions, including modifying job templates. |
Remote Execution User |
Run remote execution jobs. |
Site manager |
System admin |
Users with this role can create users and assign all roles to them. Therefore, ensure to give this role only to trusted users. |
Tasks manager |
View and edit Foreman tasks. |
Tasks reader |
A role that can only view Foreman tasks. |
Viewer |
A passive role that provides the ability to view the configuration of every element of the Foreman structure, logs, reports, and statistics. |
View hosts |
A role that can only view hosts. |
Virt-who Manager |
A role with full virt-who permissions. |
Virt-who Reporter |
Upload reports generated by virt-who to Foreman. It can be used if you configure virt-who manually and require a user role that has limited virt-who permissions. |
Virt-who Viewer |
View virt-who configurations. Users with this role can deploy virt-who instances using existing virt-who configurations. |
5.5. Granular Permission Filtering
5.5.1. Granular Permission Filter
5.5.2. Creating a Granular Permission Filter
Use this procedure to create a granular filter. To use the CLI instead of the web UI, see the CLI procedure.
Specify a query in the Search field on the Edit Filter page. Deselect the Unlimited check box for the field to be active. Queries have the following form:
field_name operator value
operator specifies the type of comparison between field_name and value. See Supported Operators for Granular Search for an overview of applicable operators.
hammer filter createcommand with the--searchoption to limit permission filters, for example:# hammer filter create \ --permission-ids 91 \ --search "name ~ ccv*" \ --role qa-user
5.5.3. Examples of Using Granular Permission Filters
hostgroup = host-editors
name ^ (XXXX, Yyyy, zzzz)
Dev
You can limit user permissions to a certain organization or location with the use of the granular permission filter in the Search field. However, some resource types provide a GUI alternative, an Override check box that provides the Locations and Organizations tabs. On these tabs, you can select from the list of available organizations and locations. See Creating an Organization Specific Manager Role.
Use the Foreman UI to create an administrative role restricted to a single organization named org-1.
5.5.4. Supported Operators for Granular Search
Operator |
Description |
and |
Combines search criteria. |
not |
Negates an expression. |
has |
Operator |
Description |
6. Configuring Email Notifications
You can configure Foreman to send email messages to individual users registered to Foreman. Foreman sends the email to the email address that has beed added to the account, if present. Users can edit the email address by clicking on their name in the top-right of the Foreman web UI and selecting My account.
Click Submit.
6.1. Testing Email Delivery
Click on the username.
Verify Foreman server’s email configuration.
6.2. Testing Email Notifications
To trigger the notifications, execute the following command:
# foreman-rake reports:<frequency>
Replace frequency with one of the following:
daily
weekly
monthly
6.3. Notification Types
The following are the notifications created by Foreman:
Audit summary: A summary of all activity audited by Foreman server.
Host built: A notification sent when a host is built.
Host errata advisory: A summary of applicable and installable errata for hosts managed by the user.
OpenSCAP policy summary: A summary of OpenSCAP policy reports and their results.
Promote errata: A notification sent only after a Content View promotion. It contains a summary of errata applicable and installable to hosts registered to the promoted Content View. This allows a user to monitor what updates have been applied to which hosts.
Puppet error state: A notification sent after a host reports an error related to Puppet.
Puppet summary: A summary of Puppet reports.
Sync errata: A notification sent only after synchronizing a repository. It contains a summary of new errata introduced by the synchronization.
6.4. Changing email notification settings for a host
Foreman can send event notifications for a host to the host’s registered owner.
To view the notification status for a host, navigate to Hosts > All Hosts and click the host you want to view. In the host details page, click the Additional Information tab, you can view the email notification status.
To change the email notification settings for a host, complete the following steps.
In the Foreman web UI, navigate to Hosts > All Hosts, and select the host with the notification setting you want to change.
Select the host’s check box, and from the Select Action list, select Enable Notifications or Disable Notifcations, depending on what you want.
Security compliance management is the ongoing process of defining security policies, auditing for compliance with those policies and resolving instances of non-compliance. Any non-compliance is managed according to the organization’s configuration management policies. Security policies range in scope from host-specific to industry-wide, therefore, flexibility in their definition is required.
Foreman uses the Security Content Automation Protocol (SCAP) to define security configuration policies.
For example, a security policy might specify that for hosts running Red Hat Enterprise Linux, login via SSH is not permitted for the root account.
With Foreman you can schedule compliance auditing and reporting on all hosts under management.
For more information about SCAP, see the Red Hat Enterprise Linux 7 Security Guide.
7.1.1. SCAP Content
SCAP content is a datastream format containing the configuration and security baseline against which hosts are checked.
Checklists are described in the extensible checklist configuration description format (XCCDF) and vulnerabilities in the open vulnerability and assessment language (OVAL).
Checklist items, also known as rules express the desired configuration of a system item.
For example, you may specify that no one can log in to a host over SSH using the root user account.
Rules can be grouped into one or more profiles, allowing multiple profiles to share a rule.
SCAP content consists of both rules and profiles.
You can either create SCAP content or obtain it from a vendor. Supported profiles are provided for Red Hat Enterprise Linux in the scap-security-guide package. The creation of SCAP content is outside the scope of this guide, but see the Red Hat Enterprise Linux 7 Security Guide for information on how to download, deploy, modify, and create your own content.
The default SCAP content provided with the OpenSCAP components of Foreman depends on the version of Red Hat Enterprise Linux. On Red Hat Enterprise Linux 7, content for both Red Hat Enterprise Linux 6 and Red Hat Enterprise Linux 7 is installed.
7.1.2. XCCDF Profile
An XCCDF profile is a checklist against which a host or host group is evaluated. Profiles are created to verify compliance with an industry standard or custom standard.
The profiles provided with Foreman are obtained from the OpenSCAP project.
Listing Available XCCDF Profiles
In the Foreman UI, list the available XCCD profiles.
Navigate to Hosts > SCAP contents.
7.2. Configuring SCAP Content
7.2.1. Importing OpenSCAP Puppet Modules
If you do not use Puppet to configure OpenSCAP auditing on hosts, you can skip this procedure. |
To audit hosts with OpenSCAP, you must first import a Puppet environment. The Puppet environment contains the Puppet classes you must assign to each host to deploy the OpenSCAP configuration.
You must associate each host that you want to audit with the Puppet environment in the Foreman web UI.
In the Foreman web UI, navigate to Configure > Environments.
Click Import environments from foreman.example.com.
Select the Puppet environment check box associated with the host you want to audit.
If no Puppet environment exists, select the production environment check box. The Puppet classes that you require for OpenSCAP are in the production environment by default.
Click Update.
7.2.2. Loading the Default OpenSCAP Content
In the CLI, load the default OpenScap content.
Use the
foreman-rakecommand:# foreman-rake foreman_openscap:bulk_upload:default
7.2.3. Extra SCAP Content
You can upload extra SCAP content into Foreman server, either content created by yourself or obtained elsewhere.
SCAP content must be imported into Foreman server before being applied in a policy.
For example, the scap-security-guide RPM package available in the Red Hat Enterprise Linux 7.2 repositories includes a profile for the Payment Card Industry Data Security Standard (PCI-DSS) version 3.
You can upload this content into a Foreman server even if it is not running Red Hat Enterprise Linux 7.2 as the content is not specific to an operating system version.
Uploading Extra SCAP Content
In the Foreman web UI, upload the extra SCAP content.
Navigate to Hosts > SCAP contents and click New SCAP Content.
Enter a title in the Title text box.
Example:
RHEL 7.2 SCAP Content. -
Click Choose file, navigate to the location containing the SCAP content file and select Open.
Click Submit.
If the SCAP content file is loaded successfully, a message similar to Successfully created RHEL 7.2 SCAP Content is shown and the list of SCAP Contents includes the new title.
7.3. Managing Compliance Policies
7.3.1. Compliance Policy
A scheduled audit, also known as a compliance policy, is a scheduled task that checks the specified hosts for compliance against an XCCDF profile. The schedule for scans is specified by Foreman server and the scans are performed on the host. When a scan completes, an Asset Reporting File (ARF) is generated in XML format and uploaded to Foreman server. You can see the results of the scan in the compliance policy dashboard. No changes are made to the scanned host by the compliance policy. The SCAP content includes several profiles with associated rules but policies are not included by default.
7.3.2. Creating a Compliance Policy
With Foreman, you can create a compliance policy to scan your content hosts to ensure that the hosts remain compliant to your security requirements.
You can use either Puppet or Ansible to deploy the compliance policy to your hosts. Note that Puppet runs by default every 30 minutes. If you assign a new policy, the next Puppet run synchronizes the policy to the host. However Ansible does not perform scheduled runs. To add a new policy, you must run Ansible role manually or using remote execution. For more information about remote execution, see Configuring and Setting up Remote Jobs in the Managing Hosts guide.
Before you begin, you must decide whether you want to use a Puppet or Ansible deployment.
For Puppet deployment, ensure that each host that you want to audit is associated with a Puppet environment. For more information, see Importing OpenSCAP Puppet Modules.
For Ansible deployment, ensure that you import the
theforeman.foreman_scap_clientAnsible role. For more information about importing Ansible roles, see Getting Started with Ansible in Foreman in Configuring Foreman to use Ansible.
Navigate to Hosts > Policies, and select whether you want a manual, Ansible, or Puppet deployment.
Enter a name for this policy, a description (optional), then click Next.
Select the SCAP Content and XCCDF Profile to be applied, then click Next.
Until BZ#1704582 is resolved, note that the
Default XCCDF Profilemight return an empty report. -
Specify the scheduled time when the policy is to be applied, then click Next.
Select Weekly, Monthly, or Custom from the Period list.
If you select Weekly, also select the desired day of the week from the Weekday list.
If you select Monthly, also specify the desired day of the month in the Day of month field.
If you select Custom, enter a valid Cron expression in the Cron line field.
The Custom option allows for greater flexibility in the policy’s schedule than either the Weekly or Monthly options.
Select the locations to which the policy is to be applied, then click Next.
Select the organizations to which the policy is to be applied, then click Next.
Select the host groups to which the policy is to be applied, then click Submit.
When the Puppet agent runs on the hosts which belong to the selected host group, or hosts to which the policy has been applied, the OpenSCAP client will be installed and a Cron job added with the policy’s specified schedule.
The SCAP Content tab provides the name of the SCAP content file which will be distributed to the directory /var/lib/openscap/content/ on all target hosts.
7.3.3. Viewing a Compliance Policy
You can preview the rules which will be applied by specific OpenSCAP content and profile combination. This is useful when planning policies.
In the Foreman web UI, view the compliance policy.
Navigate to Hosts > Policies.
Click Show Guide.
7.3.4. Editing a Compliance Policy
In the Foreman web UI, edit the compliance policy.
From the drop-down list to the right of the policy’s name, select Edit.
Edit the necessary attributes.
Click Submit.
An edited policy is applied to the host when its Puppet agent next checks with Foreman server for updates. By default this occurs every 30 minutes.
7.3.5. Deleting a Compliance Policy
In the Foreman web UI, delete an existing policy.
From the drop-down list to the right of the policy’s name, select Delete.
Click OK in the confirmation message.
7.4. Tailoring Files
Tailoring Files allow existing OpenSCAP policies to be customized without forking or rewriting the policy. You can assign a Tailoring File to a policy when creating or updating a policy.
You can create a Tailoring File using the SCAP Workbench. For more information on using the SCAP Workbench tool, see Customizing SCAP Security Guide for your use-case.
7.4.1. Uploading a Tailoring File
In the Foreman web UI, upload a Tailoring file.
Navigate to Hosts > Compliance - Tailoring Files and click New Tailoring File.
Enter a name in the Name text box.
Click Choose File, navigate to the location containing the SCAP DataStream Tailoring File and select Open.
Click Submit to upload the chosen Tailoring File.
7.4.2. Assigning a Tailoring File to a Policy
In the Foreman web UI, assign a Tailoring file to a policy.
Navigate to Hosts > Compliance - Policies.
Click New Policy, or New Compliance Policy if there are existing Compliance Policies.
Enter a name in the Name text box, and click Next.
Select a Scap content from the dropdown menu.
Select a XCCDF Profile from the dropdown menu.
Select a Tailoring File from the dropdown menu.
Select a XCCDF Profile in Tailoring File from the dropdown menu.
It is important to select the XCCDF Profile because Tailoring Files are able to contain multiple XCCDF Profiles.
Click Next.
Select a Period from the dropdown menu.
Select a Weekday from the dropdown menu, and click Next.
Select a Location to move it to the Selected Items window, and click Next.
Select an Organization to move it to the Selected Items window, and click Next.
Select a Hostgroup to move it to the Selected Items window, and click Submit.
7.5. Configuring a host group for OpenSCAP
Use this procedure to configure all the OpenSCAP requirements for a host group.
You must complete the following tasks on Foreman server to assign the necessary components for a host group:
Enable OpenSCAP on Smart Proxy. For more information, see Enabling OpenSCAP on External Smart Proxies in the Installing Smart Proxy server guide.
Assign an OpenSCAP Smart Proxy.
Assign a Puppet environment that contains the Puppet classes to deploy the OpenSCAP policies.
Assign the
foreman_scap_clientandforeman_scap_client::paramsPuppet classes. -
Assign any compliance policies that you want to add.
For information about creating and administering hosts, see the Managing Hosts guide.
In the Foreman web UI, navigate to Configure > Host Groups, and either create a host group or click the host group that you want to configure for OpenSCAP reporting.
From the Puppet Environment list, select the Puppet environment that contains the
From the OpenSCAP Smart Proxy list, select the Smart Proxy with OpenSCAP enabled that you want to use.
Click the Puppet Classes tab, and add the
Click Submit to save your changes.
Select the policy that you want to assign to the host group.
Click the Host Groups tab.
From the Host Groups list, select as many host groups as you want to assign to this policy.
7.6. Configuring a host for OpenSCAP
Use this procedure to configure all the OpenSCAP requirements for a host.
You must complete the following tasks on Foreman server to assign the necessary components for a host:
Assign the
In the Foreman web UI, navigate to Hosts > All Hosts, and select Edit on the host you want to configure for OpenSCAP reporting.
To add a compliance policy, navigate to one of the following locations:
Navigate to Hosts > All Hosts.
Select the host or hosts to which you want to add the policy.
Click Select Action.
Select Assign Compliance Policy from the list.
In the Policy window, select the policy that you want from the list of available policies and click Submit.
7.7. Monitoring Compliance
Foreman enables centralized compliance monitoring and management. A compliance dashboard provides an overview of compliance of hosts and the ability to view details for each host within the scope of that policy. Compliance reports provide a detailed analysis of compliance of each host with the applicable policy. With this information, you can evaluate the risks presented by each host and manage the resources required to bring hosts into compliance.
Common objectives when monitoring compliance using SCAP include the following:
Verifying policy compliance.
Detecting changes in compliance.
7.7.1. Compliance Policy Dashboard
The compliance policy dashboard provides a statistical summary of compliance of hosts and the ability to view details for each host within the scope of that policy.
For all hosts which were evaluated as non-compliant, the Failed statistic provides a useful metric for prioritizing compliance effort.
The hosts detected as Never audited should also be a priority, since their status is unknown.
7.7.2. Viewing the Compliance Policy Dashboard
Use the Foreman web UI to verify policy compliance with the compliance policy dashboard.
In the Foreman web UI, navigate to Hosts > Policies.
Click the required policy name. The dashboard provides the following information:
A ring chart illustrating a high-level view of compliance of hosts with the policy.
A statistical breakdown of compliance of hosts with the policy, in a tabular format.
Links to the latest policy report for each host.
7.7.3. Compliance Email Notifications
Foreman server sends an OpenSCAP Summary email to all users who subscribe to the Openscap policy summary email notifications. For more information on subscribing to email notifications, see Configuring Email Notifications. Each time a policy is run, Foreman checks the results against the previous run, noting any changes between them. The email is sent according to the frequency requested by each subscriber, providing a summary of each policy and its most recent result.
An OpenSCAP Summary email message contains the following information:
Details of the time period it covers.
Totals for all hosts by status: changed, compliant, and noncompliant.
A tabular breakdown of each host and the result of its latest policy, including totals of the rules that passed, failed, changed, or where results were unknown.
7.7.4. Compliance Report
A compliance report is the output of a policy run against a host. Each report includes the total number of rules passed or failed per policy. By default, reports are listed in descending date order.
In the Foreman web UI, navigate to Hosts > Reports to list all compliance reports.
Introduction
Evaluation Characteristics
Compliance and Scoring
Rule Overview
The Evaluation Characteristics area provides details about an evaluation against a specific profile, including the host that was evaluated, the profile used in the evaluation, and when the evaluation started and finished. For reference, the IPv4, IPv6, and MAC addresses of the host are also listed.
| Name | Description | Example |
Target machine |
The fully-qualified domain name (FQDN) of the evaluated host. |
Benchmark URL |
The URL of the SCAP content against which the host was evaluated. |
Benchmark ID |
The identifier of the benchmark against which the host was evaluated. A benchmark is a set of profiles |
Profile ID |
The identifier of the profile against which the host was evaluated. |
Started at |
The date and time at which the evaluation started, in ISO 8601 format. |
Finished at |
The date and time at which the evaluation finished, in ISO 8601 format. |
Performed by |
The local account name under which the evaluation was performed on the host. |
The Compliance and Scoring area provides an overview of whether or not the host is in compliance with the profile rules, a breakdown of compliance failures by severity, and an overall compliance score as a percentage. If compliance with a rule was not checked, this is categorized in the Rule results field as Other.
The Rule Overview area provides details about every rule and the compliance result, with the rules presented in a hierarchical layout.
Select or clear the check boxes to narrow the list of rules included in the compliance report. For example, if the focus of your review is any non-compliance, clear the pass and informational check boxes.
To search all rules, enter a criterion in the Search field. The search is dynamically applied as you type. The Search field only accepts a single plain-text search term and it is applied as a case-insensitive search. When you perform a search, only those rules whose descriptions match the search criterion will be listed. To remove the search filter, delete the search criterion.
For an explanation of each result, hover the cursor over the status shown in the Result column.
7.7.5. Examining Compliance Failure of Hosts
Use the Foreman web UI to determine why a host failed compliance on a rule.
Click View Report in the row of the specific host to view the details of an individual report.
Click on the rule’s title to see further details:
A description of the rule with instructions for bringing the host into compliance if available.
The rationale for the rule.
In some cases, a remediation script.
Warning
Do not implement any of the recommended remedial actions or scripts without first testing them in a non-production environment. |
7.7.6. Searching Compliance Reports
Use the Compliance Reports search field to filter the list of available reports on any given subset of hosts.
To apply a filter, enter the search query in the Search field and click Search. The search query is case insensitive.
The following search query finds all compliance reports for which more than five rules failed:
failed > 5
The following search query finds all compliance reports created after January 1, YYYY, for hosts with host names that contain the
prod-group of characters:host ~ prod- AND date > "Jan 1, YYYY"
The following search query finds all reports generated by the
rhel7_auditcompliance policy from an hour ago:"1 hour ago" AND compliance_policy = date = "1 hour ago" AND compliance_policy = rhel7_audit
The following search query finds reports that pass an XCCDF rule:
The following search query finds reports that fail an XCCDF rule:
The following search query finds reports that have a result different than fail or pass for an XCCDF rule:
To see a list of available search parameters, click the empty Search field.
You can create complex queries with the following logical operators:
and,notandhas. For more information about logical operators, see Supported Operators for Granular Search. -
You cannot use regular expressions in a search query. However, you can use multiple fields in a single search expression. For more information about all available search operators, see Supported Operators for Granular Search.
You can bookmark a search to reuse the same search query. For more information, see Creating Bookmarks.
7.7.7. Deleting a Compliance Report
To delete a compliance report, complete the following steps:
In the Foreman web UI, navigate to Hosts > Reports.
In the Compliance Reports window, identify the policy that you want to delete and, on the right of the policy’s name, select Delete.
Click OK.
7.7.8. Deleting Multiple Compliance Reports
You can delete multiple compliance policies simultaneously. However, in the Foreman web UI, compliance policies are paginated, so you must delete one page of reports at a time. If you want to delete all OpenSCAP reports, use the script in the Deleting OpenSCAP Reports section of the Foreman API Guide.
In the Compliance Reports window, select the compliance reports that you want to delete.
In the upper right of the list, select Delete reports.
Repeat these steps for as many pages as you want to delete.
7.8. Specifications Supported by OpenSCAP
The following specifications are supported by OpenSCAP:
| Title | Description | Version |
XCCDF |
The Extensible Configuration Checklist Description Format |
1.2 |
OVAL |
Open Vulnerability and Assessment Language |
5.11 |
Asset Identification |
1.1 |
ARF |
Asset Reporting Format |
1.1 |
CCE |
Common Configuration Enumeration |
5.0 |
CPE |
Common Platform Enumeration |
2.3 |
CVE |
Common Vulnerabilities and Exposures |
CVSS |
Common Vulnerability Scoring System |
2.0 |
8. Backing Up Foreman server and Smart Proxy server
To create a backup of your Foreman server or Smart Proxy server and all associated data, use the foreman-maintain backup command.
Foreman services are unavailable during the backup.
You can schedule a backup using cron.
For more information, see the Example of a Weekly Full Backup Followed by Daily Incremental Backups.
A backup contains sensitive information from the /root/ssl-build directory.
You can also use conventional backup methods. For more information, see System Backup and Recovery in the Red Hat Enterprise Linux 7 System Administrator’s Guide.
If you plan to use the foreman-maintain backup command to create a backup, do not stop the foreman-maintain services.
When creating a snapshot or conventional backup, you must stop all services as follows:
Start the services after creating a snapshot or conventional backup:
8.1. Estimating the Size of a Backup
Uncompressed Foreman database and configuration files
Compressed Foreman database and configuration files
Enter the
ducommand to estimate the size of uncompressed directories containing Foreman database and configuration files:# du -sh /var/opt/rh/rh-postgresql12/lib/pgsql/data /var/lib/pulp 100G /var/opt/rh/rh-postgresql12/lib/pgsql/data 100G /var/lib/pulp # du -csh /var/lib/qpidd /var/lib/tftpboot /etc /root/ssl-build \ /var/www/html/pub /opt/puppetlabs 886M /var/lib/qpidd 16M /var/lib/tftpboot 37M /etc 900K /root/ssl-build 100K /var/www/html/pub 2M /opt/puppetlabs 942M total
Table 4. Backup Data Compression Ratio Data type Directory Ratio Example results PostgreSQL database files
/var/opt/rh/rh-postgresql12/lib/pgsql/data80 - 85%
100 GB → 20 GB
Pulp RPM files
/var/lib/pulp(not compressed)
100 GB
Configuration files
/var/lib/qpidd
/var/lib/tftpboot
/etc
/root/ssl-build
/var/www/html/pub
/opt/puppetlabs85%
942 MB → 141 MB
In this example, the compressed backup data occupies 180 GB in total.
This example requires 681 GB plus 180 GB for the uncompressed and compressed backup data, 861 GB in total. With 172 GB of extra space, 1033 GB must be allocated for the backup location.
8.2. Performing a Full Backup of Foreman server or Smart Proxy server
Foreman 6.10 uses the foreman-maintain backup command to make backups.
There are three main methods of backing up Foreman server:
Offline backup
Online backup
Snapshot backups
For offline backups:
For online backups:
For snapshots backups:
foreman-backupon Foreman -
foreman-proxy-backupon Smart Proxy
Note that if you use a local PgSQL database, the postgres user requires write access to the backup directory.
Ensure that your backup location has sufficient available disk space to store the backup. For more information, see Estimating the Size of a Backup.
To perform a full offline backup of Foreman server or Smart Proxy server, complete one of the following steps:
Warning
Request other users of Foreman server or Smart Proxy server to save any changes and warn them that Foreman services are unavailable for the duration of the backup. Ensure no other tasks are scheduled for the same time as the backup. |
On Foreman server, enter the following command:
On Smart Proxy server, enter the following command:
8.3. Performing a Backup without Pulp Content
You can perform an offline backup that excludes the contents of the Pulp directory. The backup without Pulp content is useful for debugging purposes and is only intended to provide access to configuration files without backing up the Pulp database. You cannot restore from a directory that does not contain Pulp content.
Warning
8.4. Performing an Incremental Backup
Warning
To perform a full offline backup, enter the following command:
To create a directory within your backup directory to store the first incremental back up, enter the
foreman-maintain backupcommand with the--incrementaloption:# foreman-maintain backup offline --incremental /var/backup_directory/full_backup /var/backup_directory
To create the second incremental backup, enter the
foreman-maintain backupcommand with the--incrementaloption and include the path to the first incremental backup to indicate the starting point for the next increment. This creates a directory for the second incremental backup in your backup directory:# foreman-maintain backup offline --incremental /var/backup_directory/first_incremental_backup /var/backup_directory
8.5. Example of a Weekly Full Backup Followed by Daily Incremental Backups
#!/bin/bash -e PATH=/sbin:/bin:/usr/sbin:/usr/bin DESTINATION=/var/backup_directory if [[ $(date +%w) == 0 ]]; then foreman-maintain backup offline --assumeyes $DESTINATION else LAST=$(ls -td -- $DESTINATION/*/ | head -n 1) foreman-maintain backup offline --assumeyes --incremental "$LAST" $DESTINATION fi exit 0
8.6. Performing an Online Backup
Warning
To perform an online backup, enter the following command:
8.7. Performing a Snapshot Backup
Warning
Request other Foreman server or Smart Proxy server users to save any changes and warn them that Foreman services are unavailable for the duration of the backup. Ensure no other tasks are scheduled for the same time as the backup. |
Before you perform the snapshot backup, ensure that the following conditions are met:
The system uses LVM for the directories that you snapshot:
/var/lib/pulp/, and/var/opt/rh/rh-postgresql12/lib/pgsql. -
The free disk space in the relevant volume group (VG) is three times the size of the snapshot. More precisely, the VG must have enough space unreserved by the member logical volumes (LVs) to accommodate new snapshots. In addition, one of the LVs must have enough free space for the backup directory.
The target backup directory is on a different LV than the directories that you snapshot.
To perform a snapshot backup, enter the
foreman-maintain backup snapshotcommand:# foreman-maintain backup snapshot /var/backup_directory
The foreman-maintain backup snapshot command creates snapshots when the services are active, and stops all services which can impact the backup.
This makes the maintenance window shorter.
After the successful snapshot, all services are restarted and LVM snapshots are removed.
8.8. White-listing and Skipping Steps When Performing Backups
A backup using the foreman-maintain backup command proceeds in a sequence of steps.
To skip part of the backup add the --whitelist option to the command and add the step label that you want to omit.
To display a list of available step labels, enter the following command:
To skip a step of the backup, enter the
foreman-maintain backupcommand with the--whitelistoption. For example:# foreman-maintain backup online --whitelist backup-metadata -y /var/backup_directory
9. Restoring Foreman server or Smart Proxy server from a Backup
You can restore Foreman Server or Red Hat Smart Proxy server from the backup data that you create as part of Backing Up Foreman server and Smart Proxy server. This process outlines how to restore the backup on the same server that generated the backup, and all data covered by the backup is deleted on the target system. If the original system is unavailable, provision a system with the same configuration settings and host name.
9.1. Restoring from a Full Backup
Use this procedure to restore Foreman or Smart Proxy server from a full backup. When the restore process completes, all processes are online, and all databases and system configuration revert to the state at the time of the backup.
Ensure that you are restoring to the correct instance. The Foreman instance must have the same host name, configuration, and be the same minor version (X.Y) as the original system.
Ensure that you have enough space to store this data on the base system of Foreman server or Smart Proxy server as well as enough space after the restoration to contain all the data in the
/etc/and/var/directories contained within the backup.To check the space used by a directory, enter the following command:
# df -h /var/backup_directory
Add the
# restorecon -Rv /
Choose the appropriate method to install Foreman or Smart Proxy:
To install Foreman server from a connected network, follow the procedures in Installing Foreman server from a Connected Network.
To install a Smart Proxy server, follow the procedures in the Installing Smart Proxy server.
Copy the backup data to Foreman server’s local file system. Use
/var/or/var/tmp/. -
Run the restoration script.
For troubleshooting, you can check
/var/log/foreman/production.logand/var/log/messages.
9.2. Restoring from Incremental Backups
Use this procedure to restore Foreman or Smart Proxy server from incremental backups. If you have multiple branches of incremental backups, select your full backup and each incremental backup for the “branch” you want to restore, in chronological order.
Restore the last full backup using the instructions in Restoring from a Full Backup.
Remove the full backup data from Foreman server’s local file system, for example,
/var/or/var/tmp/. -
Copy the incremental backup data to Foreman server’s local file system, for example,
/var/or/var/tmp/. -
# foreman-maintain restore -i /var/backup_directory/FIRST_INCREMENTAL # foreman-maintain restore -i /var/backup_directory/SECOND_INCREMENTAL
If you created the backup using the
foreman-maintain backupcommand, you do not need to use-ioption in the command.
9.3. Backup and Restore Smart Proxy server Using a Virtual Machine Snapshot
If your Smart Proxy server is a virtual machine, you can restore it from a snapshot. Creating weekly snapshots to restore from is recommended. In the event of failure, you can install, or configure a new Smart Proxy server, and then synchronize the database content from Foreman server.
If required, deploy a new Smart Proxy server, ensuring the host name is the same as before, and then install the Smart Proxy certificates. You may still have them on Foreman server, the package name ends in -certs.tar, alternately create new ones. Follow the procedures in Installing Smart Proxy server until you can confirm, in the web UI, that Smart Proxy server is connected to Foreman server. Then use the procedure Synchronizing an External Smart Proxy to synchronize from Foreman.
9.3.1. Synchronizing an External Smart Proxy
Synchronize an external Smart Proxy with Foreman.
To synchronize an external Smart Proxy, select the relevant organization and location in the web UI, or choose Any Organization and Any Location.
Navigate to Infrastructure > Smart Proxies and click the name of the Smart Proxy to synchronize.
On the Overview tab, select Synchronize.
10. Renaming Foreman server or Smart Proxy server
To rename Foreman server or Smart Proxy server, you must use the katello-change-hostname script.
If you rename Foreman server, you must reregister all Foreman clients and configure each Smart Proxy server to point them to the new Foreman host name. If you use custom SSL certificates, you must regenerate them with the new host name. If you use virt-who, you must update the virt-who configuration files with the new host name.
If you rename Smart Proxy server, you must reregister all Smart Proxy clients and update the Smart Proxy host name in the Foreman web UI. If you use custom SSL certificates, you must regenerate them with the new host name.
Warning
The renaming process shuts down all Foreman server services on the host being renamed. When the renaming is complete, all services are restarted. |
10.1. Renaming Foreman server
The host name of Foreman server is used by Foreman server components, all Smart Proxy servers, and hosts registered to it for communication. This procedure ensures that you update all references to the new host name.
If you use external authentication, you must reconfigure Foreman server for external authentication after you run the katello-change-hostname script.
The katello-change-hostname script breaks external authentication for Foreman server.
For more information about configuring external authentication, see Configuring External Authentication.
If you use virt-who, you must update the virt-who configuration files with the new host name after you run the katello-change-hostname script.
For more information, see Modifying a virt-who Configuration in Configuring Virtual Machine Subscriptions in Foreman.
Both the
hostnameandhostname -fcommands must return the FQDN of Foreman server or thekatello-change-hostnamescript will fail to complete. If thehostnamecommand returns the shortname of Foreman server instead of the FQDN, usehostnamectl set-hostname old_fqdnto set the old FQDN correctly before attempting to use thekatello-change-hostnamescript. -
Perform a backup of Foreman server before changing a host name. If the renaming process is not successful, you must restore it from a backup. For more information, see Backing Up Foreman server and Smart Proxy server.
Optional: If Foreman server has a custom SSL certificate installed, a new certificate must be obtained for the host’s new name. For more information, see Configuring Foreman server with a Custom SSL Certificate in Installing Foreman server from a Connected Network.
On Foreman server, choose the appropriate method to run the
katello-change-hostnamescript, providing the new host name and Foreman credentials:-
If your Foreman server is installed with default self-signed SSL certificates, enter the following command:
# katello-change-hostname new-foreman \ --username admin \ --password password
If your Foreman server is installed with custom SSL certificates:
# katello-change-hostname new-foreman \ --username admin \ --password password \ --custom-cert "/root/ownca/test.com/test.com.crt" \ --custom-key "/root/ownca/test.com/test.com.key"
Optional: If you have created a custom SSL certificate for the new Foreman server host name, run the Foreman installation script to install the certificate. For more information about installing a custom SSL certificate, see Deploying a Custom SSL Certificate to Foreman server in Installing Foreman server from a Connected Network.
On all Foreman clients, enter the following commands to reinstall the bootstrap RPM, reregister clients, and refresh their subscriptions.
You can use remote execution feature to perform this step. For more information, see Configuring and Setting up Remote Jobs in Managing Hosts.
# yum remove -y katello-ca-consumer* # rpm -Uvh http://new-foreman.example.com/pub/katello-ca-consumer-latest.noarch.rpm # subscription-manager register \ --org="Default_Organization" \ --environment="Library" \ --force # subscription-manager refresh
On all Smart Proxy servers, run the Foreman installation script to update references to the new host name:
# foreman-installer \ --foreman-proxy-foreman-base-url https://new-foreman.example.com \ --foreman-proxy-trusted-hosts new-foreman.example.com \ --puppet-server-foreman-url new-foreman.example.com
On Foreman server, list all Smart Proxy servers:
# hammer proxy list
On Foreman server, synchronize content for each Smart Proxy server:
# hammer proxy_content synchronize \ --id proxy_id_number
10.2. Renaming Smart Proxy server
The host name of Smart Proxy server is referenced by Foreman server components, and all hosts registered to it. This procedure ensures that you update all references to the new host name.
Backup Smart Proxy server. The
katello-change-hostnamescript makes irreversible changes to Smart Proxy server. If the renaming process is not successful, you must restore it from a backup.Perform a backup before changing a host name. For more information, see Backing Up Foreman server and Smart Proxy server.
Warning
Until BZ#1829115 is resolved, you must edit the STDOUT.puts "updating hostname in hammer configuration"
self.run_cmd("sed -i.bak -e 's/#{@old_hostname} \
/#{@new_hostname}/g' #{hammer_root_config_path}/*.yml")
/#{@new_hostname>/g' #{hammer_config_path}/*.yml")
On Foreman server, generate a new certificates archive file for Smart Proxy server.
If you are using the default SSL certificate, enter the following command:
# foreman-proxy-certs-generate \ --foreman-proxy-fqdn new-smartproxy.example.com \ --certs-tar /root/new-smartproxy.example.com-certs.tar
.tarfile. -
If you are using a custom SSL certificate, create a new SSL certificate for Smart Proxy server. For more information, see Configuring Smart Proxy server with a Custom SSL Certificate in Installing Smart Proxy server.
On Foreman server, copy the certificates archive file to Smart Proxy server, providing the
rootuser’s password when prompted. In this example the archive file is copied to therootuser’s home directory, but you may prefer to copy it elsewhere.# scp /root/new-smartproxy.example.com-certs.tar root@smartproxy.example.com:
On Smart Proxy server, run the
katello-change-hostnamescript and provide the host’s new name, Foreman credentials, and certificates archive filename.# katello-change-hostname new-smart-proxy --username admin \ --password password \ --certs-tar /root/new-smartproxy.example.com-certs.tar
.tarfile. -
Optional: If you have created a custom certificate for Smart Proxy server, on Smart Proxy server, to deploy the certificate, enter the
foreman-installercommand that theforeman-proxy-certs-generatecommand returns. For more information, see Deploying a Custom SSL Certificate to Smart Proxy server in Installing Smart Proxy server. -
On all Smart Proxy clients, enter the following commands to reinstall the bootstrap RPM, reregister clients, and refresh their subscriptions.
# yum remove -y katello-ca-consumer* # rpm -Uvh http://new-smartproxy.example.com/pub/katello-ca-consumer-latest.noarch.rpm # subscription-manager register --org="Default_Organization" \ --environment="Library" \ --force # subscription-manager refresh
In the Foreman web UI, navigate to Infrastructure > Smart Proxies.
Locate Smart Proxy server in the list, and click Edit to the right of it.
Edit the Name and URL fields to match Smart Proxy server’s new host name, then click Submit.
On your DNS server, add a record for Smart Proxy server’s new host name, and delete the record for the previous host name.
11. Maintaining Foreman server
This chapter provides information on how to maintain a Foreman Server, including information on how to work with audit records, how to clean unused tasks, and how to recover Pulp from a full disk.
11.1. Deleting Audit Records
Audit records are created automatically in Foreman.
You can use the foreman-rake audits:expire command to remove audits at any time.
You can also use a cron job to schedule audit record deletions at the set interval that you want.
By default, using the foreman-rake audits:expire command removes audit records that are older than 90 days.
You can specify the number of days to keep the audit records by adding the days option and add the number of days.
11.2. Anonymizing Audit Records
You can use the foreman-rake audits:anonymize command to remove any user account or IP information while maintaining the audit records in the database.
You can also use a cron job to schedule anonymizing the audit records at the set interval that you want.
By default, using the foreman-rake audits:anonymize command anonymizes audit records that are older than 90 days.
11.3. Configuring the Cleaning Unused Tasks Feature
Until BZ#1788615 is resolved, this functionality works only on fresh installations of Foreman 1.22 and later. If you upgrade Foreman from previous versions, this functionality is disabled by default. To enable Foreman to perform regular cleaning, enter the following command:
Optionally use this procedure to adjust the configuration to serve your needs.
Optional: To configure the time at which Foreman runs the cron job, set the
Optional: To configure the period after which Foreman deletes the tasks, edit the
:rules:section in the/etc/foreman/plugins/foreman-tasks.yamlfile.
11.4. Recovering from a Full Disk
Ensure that the LV with the
Remove orphaned content:
Change the download policy from Immediate to On Demand for as many repositories as possible and remove already downloaded packages. See the Red Hat Knowledgebase solution How to change syncing policy for Repositories on Satellite from "Immediate" to "On-Demand" on the Red Hat Customer Portal for instructions.
/var/lib/pulpdirectory on it. For more information, see Growing a File System on a Logical Volume in the Red Hat Enterprise Linux 7 Logical Volume Manager Administration Guide.NoteIf you use an untypical file system (other than for example ext3, ext4, or xfs), you might need to unmount the file system so that it is not in use. In that case, complete the following steps:
Stop the
foreman-maintainservices:# foreman-maintain service stop
Start the
foreman-maintainservices:# foreman-maintain service start
11.5. Reclaiming PostgreSQL Space
Switch to the
postgresuser and reclaim space on the database:# su - postgres -c 'vacuumdb --full --dbname=foreman'
Confirm that the files exist in the
/var/lib/pgsql/directory:# ls -l /var/lib/pgsql/ # du -sh /var/lib/pgsql/
Delete the data from the
/var/lib/pgsql/directory:# rm -rf /var/lib/pgsql/*
12. Logging and Reporting Problems
This chapter provides information on how to log and report problems in Foreman Server, including information on relevant log files, how to enable debug logging, how to open a support case and attach the relevant log tar files, and how to access support cases within the Foreman web UI.
You can use the log files and other information described in this chapter to do your own troubleshooting, or you can capture these and many more files, as well as diagnostic and configuration information, to send to Red Hat Support if you need further assistance.
12.1. Enabling Debug Logging
Debug logging provides the most detailed log information and can help with troubleshooting issues that can arise with Foreman 6.10 and its components.
In the Foreman CLI, enable debug logging to log detailed debugging information for Foreman 6.10.
To enable debug logging, complete the following steps on your Foreman server.
To enable debug logging, enter the following command :
12.2. Enabling Individual Loggers
app-
audit-
ldap-
permissions-
sql-
To enable individual loggers, complete the following steps.
Enable the individual loggers that you want. For example, to enable
sqlandldaploggers, enter the following command:# foreman-installer --foreman-loggers sql:true --foreman-loggers ldap:true
Optional: To reset loggers to their default values, enter the following command:
12.3. Configuring Logging to Journal
You can configure Foreman to manage logging with Journal.
Journal then forwards log messages to rsyslog and rsyslog writes the log messages to /var/log/messages.
Note that after this change the log messages do not appear in /var/log/foreman/production.log or /var/log/foreman-proxy.log any more.
For more information about Journal, see https://github.com/lzap/foreman-elasticsearch.
To configure Foreman server logging with Journal, complete the following steps:
Enter the following
foreman-installercommand to configure logging tojournald:# foreman-installer --foreman-logging-level info \ --foreman-logging-type journald \ --foreman-logging-layout pattern --foreman-proxy-log JOURNAL
Restart the Apache daemon:
# foreman-maintain service restart --only httpd
12.4. Log File Directories Provided by Foreman
| Log File Directories | Description of Log File Content |
Subscription management |
Foreman |
Foreman proxy |
Apache HTTP server |
Installer |
Configuration management |
Candlepin webservice logs |
Various other log messages |
You can also use the foreman-tail command to follow many of the log files related to Foreman.
You can run foreman-tail -l to list the processes and services that it follows.
12.5. Utilities for Collecting Log Information
There are two utilities available to collect information from log files.
| Command | Description |
The Additionally, the For more information, run There is no timeout when running this command. |
The By default, the output tar file is located at The |
Both |
13. Configuring External Authentication
By using external authentication you can derive user and user group permissions from user group membership in an external identity provider. When you use external authentication, you do not have to create these users and maintain their group membership manually on Foreman server.
All user and group accounts must be local accounts. This is to ensure that there are no authentication conflicts between local accounts on your Foreman server and accounts in your Active Directory domain.
Your system is not affected by this conflict if your user and group accounts exist in both /etc/passwd and /etc/group files.
For example, to check if entries for puppet, apache, foreman and foreman-proxy groups exist in both /etc/passwd and /etc/group files, enter the following commands:
# cat /etc/passwd | grep 'puppet\|apache\|foreman\|foreman-proxy' # cat /etc/group | grep 'puppet\|apache\|foreman\|foreman-proxy'
Foreman supports the following general scenarios for configuring external authentication:
Using Lightweight Directory Access Protocol (LDAP) server as an external identity provider. LDAP is a set of open protocols used to access centrally stored information over a network. With Foreman, you can manage LDAP entirely through the Foreman web UI. For more information, see Using LDAP. Though you can use LDAP to connect to a FreeIPA or AD server, the setup does not support server discovery, cross-forest trusts, or single sign-on with Kerberos in Foreman’s web UI.
Using a FreeIPA server as an external identity provider. FreeIPA deals with the management of individual identities, their credentials and privileges used in a networking environment. Configuration using FreeIPA cannot be completed using only the Foreman web UI and requires some interaction with the CLI. For more information see Using FreeIPA.
Using Active Directory (AD) integrated with FreeIPA through cross-forest Kerberos trust as an external identity provider. For more information see Active Directory with Cross-Forest Trust.
Using Keycloak as an OpenID provider for external authentication to Foreman. For more information, see Configuring Foreman with Keycloak Authentication.
Using Keycloak as an OpenID provider for external authentication to Foreman with TOTP. For more information, see Configuring Keycloak Authentication with TOTP.
Using Keycloak as an OpenID provider for external authentication to Foreman with PIV cards. For more information, see Configuring Keycloak Authentication with PIV Cards.
As well as providing access to Foreman server, hosts provisioned with Foreman can also be integrated with FreeIPA realms. Foreman has a realm feature that automatically manages the life cycle of any system registered to a realm or domain provider. For more information, see External Authentication for Provisioned Hosts.
| Type | Authentication | User Groups |
FreeIPA |
Kerberos or LDAP |
Yes |
Active Directory |
Kerberos or LDAP |
Yes |
POSIX |
LDAP |
Yes |
13.1. Using LDAP
Foreman supports LDAP authentication using one or multiple LDAP directories.
If you require Foreman to use TLS to establish a secure LDAP connection (LDAPS), first obtain certificates used by the LDAP server you are connecting to and mark them as trusted on the base operating system of your Foreman server as described below.
If your LDAP server uses a certificate chain with intermediate certificate authorities, all of the root and intermediate certificates in the chain must be trusted, so ensure all certificates are obtained.
If you do not require secure LDAP at this time, proceed to Configuring Foreman to use LDAP.
Though direct LDAP integration is covered in this section, Red Hat recommends that you use SSSD and configure it against FreeIPA, AD, or an LDAP server. SSSD improves the consistency of the authentication process. For more information about the preferred configurations, see Using Active Directory. You can also cache the SSSD credentials and use them for LDAP authentication. For more information on SSSD, see Configuring SSSD in the Red Hat Enterprise Linux 7 System-Level Authentication Guide.
13.1.1. Configuring TLS for Secure LDAP
Use the Foreman CLI to configure TLS for secure LDAP (LDAPS).
Obtain the Certificate from the LDAP Server.
If you use Active Directory Certificate Services, export the Enterprise PKI CA Certificate using the Base-64 encoded X.509 format. See How to configure Active Directory authentication with
TLSon Foreman for information on creating and exporting a CA certificate from an Active Directory server. -
Download the LDAP server certificate to a temporary location on the Red Hat Enterprise Linux system where Foreman server is installed and remove it when finished.
For example,
/tmp/example.crt. The filename extensions.cerand.crtare only conventions and can refer to DER binary or PEM ASCII format certificates.
Trust the Certificate from the LDAP Server.
Foreman Server requires the CA certificates for LDAP authentication to be individual files in
/etc/pki/tls/certs/directory.-
Use the
installcommand to install the imported certificate into the/etc/pki/tls/certs/directory with the correct permissions:# install /tmp/example.crt /etc/pki/tls/certs/
Enter the following command as
rootto trust the example.crt certificate obtained from the LDAP server:# ln -s example.crt /etc/pki/tls/certs/$(openssl \ x509 -noout -hash -in \ /etc/pki/tls/certs/example.crt).0
Restart the
httpdservice:# systemctl restart httpd
13.1.2. Configuring Foreman to use LDAP
In the Foreman web UI, configure Foreman to use LDAP.
Note that if you need single sign-on functionality with Kerberos on Foreman’s web UI, you should use FreeIPA and AD external authentication instead. See Using FreeIPA or Using Active Directory for more information on those options.
Set the Network Information System (NIS) service boolean to true to prevent SELinux from stopping outgoing LDAP connections:
# setsebool -P nis_enabled on
Navigate to Administer > LDAP Authentication.
Click Create Authentication Source.
On the LDAP server tab, enter the LDAP server’s name, host name, port, and server type. The default port is 389, the default server type is POSIX (alternatively you can select FreeIPA or Active Directory depending on the type of authentication server). For
TLSencrypted connections, select the LDAPS check box to enable encryption. The port should change to 636, which is the default for LDAPS. -
On the Account tab, enter the account information and domain name details. See Description of LDAP Settings for descriptions and examples.
On the Attribute mappings tab, map LDAP attributes to Foreman attributes. You can map login name, first name, last name, email address, and photo attributes. See Example Settings for LDAP Connections for examples.
On the Locations tab, select locations from the left table. Selected locations are assigned to users created from the LDAP authentication source, and available after their first login.
On the Organizations tab, select organizations from the left table. Selected organizations are assigned to users created from the LDAP authentication source, and available after their first login.
Click Submit.
Configure new accounts for LDAP users:
If you did not select Automatically Create Accounts In Foreman check box, see Creating a User to create user accounts manually.
If you selected the Automatically Create Accounts In Foreman check box, LDAP users can now log in to Foreman using their LDAP accounts and passwords. After they log in for the first time, the Foreman administrator has to assign roles to them manually. See Assigning Roles to a User to assign user accounts appropriate roles in Foreman.
13.1.3. Description of LDAP Settings
| Setting | Description |
Account |
The user name of the LDAP account that has read access to the LDAP server. User name is not required if the server allows anonymous reading, otherwise use the full path to the user’s object. For example: uid=$login,cn=users,cn=accounts,dc=example,dc=com The The variable cannot be used with external user groups from an LDAP source because Foreman needs to retrieve the group list without the user logging in. Use either an anonymous, or dedicated service user. |
Account password |
The LDAP password for the user defined in the Account username field.
This field can remain blank if the Account username is using the |
Base DN |
The top level domain name of the LDAP directory. |
Groups base DN |
The top level domain name of the LDAP directory tree that contains groups. |
LDAP filter |
A filter to restrict LDAP queries. |
Automatically Create Accounts In Foreman |
If this check box is selected, Foreman creates user accounts for LDAP users when they log in to Foreman for the first time. After they log in for the first time, the Foreman administrator has to assign roles to them manually. See Assigning Roles to a User to assign user accounts appropriate roles in Foreman. |
Usergroup Sync |
If this option is selected, the user group membership of a user is automatically synchronized when the user logs in, which ensures the membership is always up to date. If this option is cleared, Foreman relies on a cron job to regularly synchronize group membership (every 30 minutes by default). See To Configure an External User Group: for further context. |
13.1.4. Example Settings for LDAP Connections
| Setting | Active Directory | FreeIPA or Red Hat Identity Management | POSIX (OpenLDAP) |
Account |
DOMAIN\redhat |
uid=redhat,cn=users, cn=accounts,dc=example, dc=com |
uid=redhat,ou=users, dc=example,dc=com |
Account password |
P@ssword |
Base DN |
DC=example,DC=COM |
dc=example,dc=com |
dc=example,dc=com |
Groups Base DN |
CN=Users,DC=example,DC=com |
cn=groups,cn=accounts, dc=example,dc=com |
cn=employee,ou=userclass, dc=example,dc=com |
Login name attribute |
userPrincipalName |
uid |
uid |
First name attribute |
givenName |
givenName |
givenName |
Last name attribute |
sn |
sn |
sn |
Email address attribute |
Photo attribute |
thumbnailPhoto |
13.1.5. Example LDAP Filters
As an administrator, you can create LDAP filters to restrict the access of specific users to Foreman.
| User | Filter |
User1, User3 |
(memberOf=cn=Group1,cn=Users,dc=domain,dc=example) |
User2, User3 |
(memberOf=cn=Group2,cn=Users,dc=domain,dc=example) |
User1, User2, User3 |
(|(memberOf=cn=Group1,cn=Users,dc=domain,dc=example)(memberOf=cn=Group2,cn=Users,dc=domain,dc=example)) |
DC=Domain,DC=Example
|----- CN=Users
|----- CN=Group1
|----- CN=Group2
|----- CN=User1
|----- CN=User2
|----- CN=User3
| Group | Members |
Group1 |
User1, User3 |
Group2 |
User2, User3 |
13.2. Using FreeIPA
This section shows how to integrate Foreman Server with a FreeIPA server and how to enable host-based access control.
You can attach FreeIPA as an external authentication source with no single sign-on support. For more information, see Using LDAP. |
Foreman server has to run on Red Hat Enterprise Linux 7.1 or later.
The base operating system of Foreman server must be enrolled in the FreeIPA domain by the FreeIPA administrator of your organization.
The examples in this chapter assume separation between FreeIPA and Foreman configuration. However, if you have administrator privileges for both servers, you can configure FreeIPA as described in Red Hat Enterprise Linux 7 Linux Domain Identity, Authentication, and Policy Guide.
13.2.1. Configuring FreeIPA Authentication on Foreman server
In the Foreman CLI, configure FreeIPA authentication by first creating a host entry on the FreeIPA server.
On the FreeIPA server, to authenticate, enter the following command and enter your password when prompted:
# kinit admin
To verify that you have authenticated, enter the following command:
# klist
On the FreeIPA server, create a host entry for Foreman server and generate a one-time password, for example:
NoteThe generated one-time password must be used on the client to complete FreeIPA-enrollment.
For more information on host configuration properties, see About Host Entry Configuration Properties in the Red Hat Enterprise Linux 7 Linux Domain Identity, Authentication, and Policy guide.
Create an HTTP service for Foreman server, for example:
# ipa service-add HTTP/hostname
For more information on managing services, see Managing Services in the Red Hat Enterprise Linux 7 Linux Domain Identity, Authentication, and Policy guide.
On Foreman server, install the IPA client:
# yum install ipa-client
On Foreman server, enter the following command as root to configure FreeIPA-enrollment:
If Foreman server is running on Red Hat Enterprise Linux 7, execute the following command:
The installer is dependent on packages which, on Red Hat Enterprise Linux 7, are in the optional repository
rhel-7-server-optional-rpms. -
Set
foreman-ipa-authenticationto true, using the following command:# foreman-installer --foreman-ipa-authentication=true
Restart the
foreman-maintainservices:# foreman-maintain service restart
External users can now log in to Foreman using their FreeIPA credentials. They can now choose to either log in to Foreman server directly using their username and password or take advantage of the configured Kerberos single sign-on and obtain a ticket on their client machine and be logged in automatically. The two-factor authentication with one-time password (2FA OTP) is also supported. If the user in FreeIPA is configured for 2FA, and Foreman server is running on Red Hat Enterprise Linux 7, this user can also authenticate to Foreman with an OTP.
13.2.2. Configuring Host-Based Authentication Control
HBAC rules define which machine within the domain a FreeIPA user is allowed to access. You can configure HBAC on the FreeIPA server to prevent selected users from accessing Foreman server. With this approach, you can prevent Foreman from creating database entries for users that are not allowed to log in. For more information on HBAC, see Configuring Host-Based Access Control in the Red Hat Enterprise Linux 7 Linux Domain Identity, Authentication, and Policy guide.
# kinit admin
# klist
Create HBAC service and rule on the FreeIPA server and link them together. The following examples use the PAM service name foreman-prod. Execute the following commands on the FreeIPA server:
# ipa hbacsvc-add foreman-prod # ipa hbacrule-add allow_foreman_prod # ipa hbacrule-add-service allow_foreman_prod --hbacsvcs=foreman-prod
Add the user who is to have access to the service foreman-prod, and the hostname of Foreman server:
# ipa hbacrule-add-user allow_foreman_prod --user=username # ipa hbacrule-add-host allow_foreman_prod --hosts=foreman.example.com
Alternatively, host groups and user groups can be added to the allowforeman_prod_ rule.
To check the status of the rule, execute:
# ipa hbacrule-find foreman-prod # ipa hbactest --user=username --host=foreman.example.com --service=foreman-prod
Ensure the allow_all rule is disabled on the FreeIPA server. For instructions on how to do so without disrupting other services see the How to configure HBAC rules in IdM article on the Red Hat Customer Portal.
Configure the FreeIPA integration with Foreman server as described in Configuring FreeIPA Authentication on Foreman server. On Foreman server, define the PAM service as root:
# foreman-installer --foreman-pam-service=foreman-prod
13.3. Using Active Directory
This section shows how to use direct Active Directory (AD) as an external authentication source for Foreman server.
You can attach Active Directory as an external authentication source with no single sign-on support. For more information, see Using LDAP. For an example configuration, see How to configure Active Directory authentication with TLS on Foreman. |
Direct AD integration means that Foreman server is joined directly to the AD domain where the identity is stored. The recommended setup consists of two steps:
Enrolling Foreman server with the Active Directory server as described in Enrolling Foreman server with the AD Server.
Configuring direct Active Directory integration with GSS-proxy as described in Configuring Direct AD Integration with GSS-proxy.
13.3.1. GSS-Proxy
The traditional process of Kerberos authentication in Apache requires the Apache process to have read access to the keytab file. GSS-Proxy allows you to implement stricter privilege separation for the Apache server by removing access to the keytab file while preserving Kerberos authentication functionality. When using AD as an external authentication source for Foreman, it is recommended to implement GSS-proxy, because the keys in the keytab file are the same as the host keys.
The AD integration requires Foreman Server to be deployed on Red Hat Enterprise Linux 7.1 or later. |
Perform the following procedures on Red Hat Enterprise Linux that acts as a base operating system for your Foreman server. For the examples in this section EXAMPLE.ORG is the Kerberos realm for the AD domain. By completing the procedures, users that belong to the EXAMPLE.ORG realm can log in to Foreman server.
13.3.2. Enrolling Foreman server with the AD Server
In the Foreman CLI, enroll Foreman server with the Active Directory server.
GSS-proxy and nfs-utils are installed.
# yum install gssproxy nfs-utils
Install the required packages:
Enroll Foreman server with the AD server. You may need to have administrator permissions to perform the following command:
# realm join -v EXAMPLE.ORG
13.3.3. Configuring Direct AD Integration with GSS-proxy
In the Foreman CLI, configure the direct Active Directory integration with GSS-proxy.
Foreman is enrolled with the Active Directory server.
For more information, see Enrolling Foreman server with the AD Server.
Create the
/etc/ipa/directory and thedefault.conffile:# mkdir /etc/ipa # touch /etc/ipa/default.conf
To the
default.conffile, add the following content:[global] server = unused realm = EXAMPLE.ORG
Create the
/etc/net-keytab.conffile with the following content:[global] workgroup = EXAMPLE realm = EXAMPLE.ORG kerberos method = system keytab security = ads
Determine the effective user ID of the Apache user:
# id apache
Create the
/etc/gssproxy/00-http.conffile with the following content:[service/HTTP] mechs = krb5 cred_store = keytab:/etc/krb5.keytab cred_store = ccache:/var/lib/gssproxy/clients/krb5cc_%U euid = ID_of_Apache_User
Create a keytab entry:
# KRB5_KTNAME=FILE:/etc/httpd/conf/http.keytab net ads keytab add HTTP -U administrator -d3 -s /etc/net-keytab.conf # chown root.apache /etc/httpd/conf/http.keytab # chmod 640 /etc/httpd/conf/http.keytab
Enable IPA authenication in Foreman:
Start and enable the
gssproxyservice:# systemctl restart gssproxy.service # systemctl enable gssproxy.service
Configure the Apache server to use the gssproxy service:
Create the
/etc/systemd/system/httpd.servicefile with the following content:.include /lib/systemd/system/httpd.service [Service] Environment=GSS_USE_PROXY=1
Apply changes to the service:
# systemctl daemon-reload
httpdservice:# systemctl restart httpd.service
Verify that SSO is working as expected.
Retrieve the Kerberos ticket of the LDAP user, using the following command:
# kinit ldapuser
View the Kerberos ticket, using the following command:
# klist
View output from successful SSO-based authentication, using the following command:
# curl -k -u : --negotiate https://foreman.example.com/users/extlogin
<html><body>You are being <a href="https://foreman.example.com/users/4-ldapuserexample-com/edit">redirected</a>.</body></html>
13.3.4. Kerberos Configuration in Web Browsers
For information on configuring the Firefox browser see Configuring Firefox to Use Kerberos for Single Sign-On in the Red Hat Enterprise Linux System-Level Authentication guide.
If you use the Internet Explorer browser, add Foreman server to the list of Local Intranet or Trusted sites, and turn on the Enable Integrated Windows Authentication setting. See the Internet Explorer documentation for details.
With direct AD integration, HBAC through FreeIPA is not available. As an alternative, you can use Group Policy Objects (GPO) that enable administrators to centrally manage policies in AD environments. To ensure correct GPO to PAM service mapping, use the following sssd configuration: access_provider = ad ad_gpo_access_control = enforcing ad_gpo_map_service = +foreman Here, foreman is the PAM service name. For more information on GPOs, please refer to the Red Hat Enterprise Linux Windows Integration Guide. |
13.3.5. Active Directory with Cross-Forest Trust
Kerberos can create cross-forest trust that defines a relationship between two otherwise separate domain forests.
A domain forest is a hierarchical structure of domains; both AD and FreeIPA constitute a forest.
With a trust relationship enabled between AD and FreeIPA, users of AD can access Linux hosts and services using a single set of credentials.
For more information on cross-forest trusts, see Creating Cross-forest Trusts with Active Directory and Identity Management in the Red Hat Enterprise Linux Windows Integration guide.
From the Foreman point of view, the configuration process is the same as integration with FreeIPA server without cross-forest trust configured. Foreman server has to be enrolled in the IPM domain and integrated as described in Using FreeIPA.
13.3.6. Configuring the FreeIPA Server to Use Cross-Forest Trust
Enable HBAC:
Create an external group and add the AD group to it.
Add the new external group to a POSIX group.
Use the POSIX group in a HBAC rule.
Configure sssd to transfer additional attributes of AD users.
Add the AD user attributes to the nss and domain sections in
/etc/sssd/sssd.conf.For example:
[nss] user_attributes=+mail, +sn, +givenname [domain/EXAMPLE] ldap_user_extra_attrs=mail, sn, givenname
13.4. Configuring External User Groups
Foreman does not associate external users with their user group automatically. You must create a user group with the same name as in the external source on Foreman. Members of the external user group then automatically become members of the Foreman user group and receive the associated permissions.
If you use an LDAP server, configure Foreman to use LDAP authentication. For more information see Using LDAP.
When using external user groups from an LDAP source, you cannot use the
$loginvariable as a substitute for the account user name. You must use either an anonymous or dedicated service user. -
If you use a FreeIPA or AD server, configure Foreman to use FreeIPA or AD authentication. For more information, see Configuring External Authentication.
Ensure that at least one external user authenticates for the first time.
Retain a copy of the external group names you want to use. To find the group membership of external users, enter the following command:
# id username
In the Foreman web UI, navigate to Administer > User Groups, and click Create User Group.
Specify the name of the new user group. Do not select any users to avoid adding users automatically when you refresh the external user group.
Click the Roles tab and select the roles you want to assign to the user group. Alternatively, select the Administrator check box to assign all available permissions.
Click the External groups tab, then click Add external user group, and select an authentication source from the Auth source drop-down menu.
Click Submit.
13.5. Refreshing External User Groups for LDAP
Navigate to Administer > Usergroups and select a user group.
Navigate to the External Groups tab and click Refresh to the right of the required user group.
Enter the following command:
13.6. Refreshing External User Groups for FreeIPA or AD
External user groups based on FreeIPA or AD are refreshed only when a group member logs in to Foreman. It is not possible to alter user membership of external user groups in the Foreman web UI, such changes are overwritten on the next group refresh.
13.7. External Authentication for Provisioned Hosts
Use this section to configure Foreman server or Smart Proxy server for FreeIPA realm support, then add hosts to the FreeIPA realm group.
You require the following setup to configure external authentication for provisioned hosts:
Foreman server that is registered to the Content Delivery Network or an external Smart Proxy server that is registered to Foreman server.
A deployed realm or domain provider such as FreeIPA.
To use FreeIPA for provisioned hosts, complete the following steps to install and configure FreeIPA packages on Foreman Server or Foreman Smart Proxy server:
Install the
ipa-clientpackage on Foreman server or Smart Proxy server:# yum install ipa-client
Configure the server as a FreeIPA client:
Create a realm proxy user,
realm-smart-proxy, and the relevant roles in FreeIPA:# foreman-prepare-realm admin realm-smart-proxy
Complete the following procedure on Foreman and every Smart Proxy that you want to use:
Copy the
/root/freeipa.keytabfile to any Smart Proxy server that you want to include in the same principal and realm:# scp /root/freeipa.keytab root@smartproxy.example.com:/etc/foreman-proxy/freeipa.keytab
Move the
/root/freeipa.keytabfile to the/etc/foreman-proxydirectory and set the ownership settings to theforeman-proxyuser:# mv /root/freeipa.keytab /etc/foreman-proxy # chown foreman-proxy:foreman-proxy /etc/foreman-proxy/freeipa.keytab
Enter the following command on all Smart Proxies that you want to include in the realm. If you use the integrated Smart Proxy on Foreman, enter this command on Foreman server:
# foreman-installer --foreman-proxy-realm true \ --foreman-proxy-realm-keytab /etc/foreman-proxy/freeipa.keytab \ --foreman-proxy-realm-principal realm-smart-proxy@EXAMPLE.COM \ --foreman-proxy-realm-provider freeipa
You can also use these options when you first configure the Foreman Server.
Ensure that the most updated versions of the ca-certificates package is installed and trust the FreeIPA Certificate Authority:
# cp /etc/ipa/ca.crt /etc/pki/ca-trust/source/anchors/ipa.crt # update-ca-trust enable # update-ca-trust
Optional: If you configure FreeIPA on an existing Foreman server or Smart Proxy server, complete the following steps to ensure that the configuration changes take effect:
Restart the foreman-proxy service:
Locate the Smart Proxy you have configured for FreeIPA and from the list in the Actions column, select Refresh.
After you configure your integrated or external Smart Proxy with FreeIPA, you must create a realm and add the FreeIPA-configured Smart Proxy to the realm.
To create a realm, complete the following steps:
In the Foreman web UI, navigate to Infrastructure > Realms and click Create Realm.
In the Name field, enter a name for the realm.
From the Realm Type list, select the type of realm.
From the Realm Smart Proxy list, select Smart Proxy server where you have configured FreeIPA.
Click the Locations tab and from the Locations list, select the location where you want to add the new realm.
Click the Organizations tab and from the Organizations list, select the organization where you want to add the new realm.
Click Submit.
Navigate to Configure > Host Groups, select the host group that you want to update, and click the Network tab.
From the Realm list, select the realm you create as part of this procedure, and then click Submit.
FreeIPA supports the ability to set up automatic membership rules based on a system’s attributes.
Foreman’s realm feature provides administrators with the ability to map the Foreman host groups to the FreeIPA parameter userclass which allow administrators to configure automembership.
When nested host groups are used, they are sent to the FreeIPA server as they are displayed in the Foreman User Interface. For example, "Parent/Child/Child".
Foreman server or Smart Proxy server sends updates to the FreeIPA server, however automembership rules are only applied at initial registration.
On the FreeIPA server, create a host group:
Create an
automembershiprule:# ipa automember-add --type=hostgroup hostgroup_name automember_rule
automember-addflags the group as an automember group. -
--type=hostgroupidentifies that the target group is a host group, not a user group. -
automember_ruleadds the name you want to identify the automember rule by.
Define an automembership condition based on the
userclassattribute:# ipa automember-add-condition --key=userclass --type=hostgroup --inclusive-regex=^webserver hostgroup_name ---------------------------------- Added condition(s) to "hostgroup_name" ---------------------------------- Automember Rule: automember_rule Inclusive Regex: userclass=^webserver ---------------------------- Number of conditions added 1 ----------------------------
automember-add-conditionadds regular expression conditions to identify group members. -
--key=userclassspecifies the key attribute asuserclass. -
--inclusive-regex=^webserver identifies matching values with a regular expression pattern. -
hostgroup_name - identifies the target host group’s name.
When a system is added to Foreman server’s hostgroup_name host group, it is added automatically to the FreeIPA server’s "hostgroup_name" host group. FreeIPA host groups allow for Host-Based Access Controls (HBAC), sudo policies and other FreeIPA functions.
13.8. Configuring Foreman with Keycloak Authentication
Use this section to configure Foreman to use Keycloak as an OpenID provider for external authentication.
13.8.1. Prerequisites for Configuring Foreman with Keycloak Authentication
Before configuring Foreman with Keycloak external authentication, ensure that you meet the following requirements:
A working installation of Keycloak server that uses HTTPS instead of HTTP.
A Keycloak account with admin privileges.
A realm for Foreman user accounts created in Keycloak.
If the certificates or the CA are self-signed, ensure that they are added to the end-user certificate trust store.
Users imported or added to Keycloak.
If you have an existing user database configured such as LDAP or Kerberos, you can import users from it by configuring user federation. For more information, see User Storage Federation in the Red Hat Single Sign-On Server Administration Guide.
If you do not have an existing user database configured, you can manually create users in Keycloak. For more information, see Creating New Users in the Red Hat Single Sign-On Server Administration Guide.
13.8.2. Registering Foreman as a Keycloak Client
Use this procedure to register Foreman to Keycloak as a client and configure Foreman to use Keycloak as an authentication source.
You can configure Foreman and Keycloak with two different authentication methods:
Users authenticate to Foreman using the Foreman web UI.
Users authenticate to Foreman using the Foreman CLI.
You must decide on how you want your users to authenticate in advance because both methods require different Foreman clients to be registered to Keycloak and configured. The steps to register and configure Foreman client in Keycloak are distinguished within the procedure.
You can also register two different Foreman clients to Keycloak if you want to use both authentication methods and configure both clients accordingly.
On the Foreman server, install the following packages:
Register Foreman to Keycloak as a client. Note that you the registration process for logging in using the web UI and the CLI are different. You can register two clients Foreman clients to Keycloak to be able to log in to Foreman from the web UI and the CLI.
If you want you users to authenticate to Foreman using the web UI, create a client as follows:
# keycloak-httpd-client-install --app-name foreman-openidc \ --keycloak-server-url "https://Keycloak.example.com" \ --keycloak-admin-username "admin" \ --keycloak-realm "Foreman_Realm" \ --keycloak-admin-realm master \ --keycloak-auth-role root-admin \ -t openidc -l /users/extlogin --force
Enter the password for the administer account when prompted. This command creates a client for Foreman in Keycloak.
Then, configure Foreman to use Keycloak as an authentication source:
# foreman-installer --foreman-keycloak true \ --foreman-keycloak-app-name "foreman-openidc" \ --foreman-keycloak-realm "Foreman_Realm"
If you want your users to authenticate to Foreman using the CLI, create a client as follows:
# keycloak-httpd-client-install --app-name hammer-openidc \ --keycloak-server-url "https://Keycloak.example.com" \ --keycloak-admin-username "admin" \ --keycloak-realm "Foreman_Realm" \ --keycloak-admin-realm master \ --keycloak-auth-role root-admin \ -t openidc -l /users/extlogin --force
Restart the
13.8.3. Configuring the Foreman Client in Keycloak
Use this procedure to configure the Foreman client in the Keycloak web UI and create group and audience mappers for the Foreman client.
In the Keycloak web UI, navigate to Clients and click the Foreman client.
Configure access type:
If you want your users to authenticate to Foreman using the web UI, from the Access Type list, select confidential.
If you want your users to authenticate to Foreman using the CLI, from the Access Type list, select public.
In the Valid redirect URI fields, add a valid redirect URI.
If you want your users to authenticate to Foreman using the web UI, in the blank field below the existing URI, enter a URI in the form
https://foreman.example.com/users/extlogin. Note that you must add the string/users/extloginafter the Foreman FQDN.After completing this step, the Foreman client for logging in using the web UI must have the following Valid Redirect URIs:
https://foreman.example.com/users/extlogin/redirect_uri https://foreman.example.com/users/extlogin
If you want your users to authenticate to Foreman using the CLI, in the blank field below the existing URI, enter urn:ietf:wg:oauth:2.0:oob.
After completing this step, the Foreman client for logging in using the CLI must have the following Valid Redirect URIs:
https://foreman.example.com/users/extlogin/redirect_uri urn:ietf:wg:oauth:2.0:oob
Click Save.
Click the Mappers tab and click Create to add an audience mapper.
In the Name field, enter a name for the audience mapper.
From the Mapper Type list, select Audience.
From the Included Client Audience list, select the Foreman client.
Click Save.
Click Create to add a group mapper so that you can specify authorization in Foreman based on group membership.
In the Name field, enter a name for the group mapper.
From the Mapper Type list, select Group Membership.
In the Token Claim Name field, enter groups.
Set the Full group path setting to OFF.
Click Save.
13.8.4. Configuring Foreman Settings for Keycloak Authentication
Use this section to configure Foreman for Keycloak authentication using the Foreman web UI or the CLI.
Configuring Foreman Settings for Keycloak Authentication Using the Web UI
Use this procedure to configure Foreman settings for Keycloak authentication using the Foreman web UI.
Note that you can navigate to the following URL within your realm to obtain values to configure Foreman settings: https://Keycloak.example.com/auth/realms/Foreman_Realm/.well-known/openid-configuration
Ensure that the Access Type setting in the Foreman client in the Keycloak web UI is set to confidential
In the Foreman web UI, navigate to Administer > Settings, and click the Authentication tab.
Locate the Authorize login delegation row, and in the Value column, set the value to Yes.
Locate the Authorize login delegation auth source user autocreate row, and in the Value column, set the value to External.
Locate the Login delegation logout URL row, and in the Value column, set the value to https://foreman.example.com/users/extlogout.
Locate the OIDC Algorithm row, and in the Value column, set the algorithm for encoding on Keycloak to RS256.
Locate the OIDC Audience row, and in the Value column, set the value to the client ID for Keycloak.
Locate the OIDC Issuer row, and in the Value column, set the value to https://Keycloak.example.com/auth/realms/Foreman_Realm.
Locate the OIDC JWKs URL row, and in the Value column, set the value to https://Keycloak.example.com/auth/realms/Foreman_Realm/protocol/openid-connect/certs.
Navigate to Administer > Authentication Sources and click External.
Click Create LDAP Authentication Source and select the Keycloak server.
Click the Locations tab and add locations that can use the Keycloak authentication source.
Click the Organizations tab and add organizations that can use the Keycloak authentication source.
Click Submit.
Configuring Foreman Settings for Keycloak Authentication Using the CLI
Use this procedure to configure Foreman settings for Keycloak authentication using the Foreman CLI.
Ensure that the Access Type setting in the Foreman client in the Keycloak web UI is set to public
On Foreman, set the login delegation to
trueso that users can authenticate using the Open IDC protocol:# hammer settings set --name authorize_login_delegation --value true
Set the login delegation logout URL:
# hammer settings set --name login_delegation_logout_url \ --value https://foreman.example.com/users/extlogout
Set the algorithm for encoding on Keycloak, for example,
RS256:# hammer settings set --name oidc_algorithm --value 'RS256'
Open the
Keycloak.example.com/auth/realms/Keycloak_REALM/.well-known/openid-configurationURL and note the values to populate the options in the following steps. -
Add the value for the Hammer client in the Open IDC audience:
# hammer settings set --name oidc_audience \ --value "['foreman.example.com-hammer-openidc']"
NoteIf you register several Keycloak clients to Foreman, ensure that you append all audiences in the array. For example:
# hammer settings set --name oidc_audience \ --value "['foreman.example.com-foreman-openidc', 'foreman.example.com-hammer-openidc']"
Set the value for the Open IDC issuer:
# hammer settings set --name oidc_issuer \ --value "Keycloak.example.com/auth/realms/Keycloak_Realm"
Set the value for Open IDC Java Web Token (JWT):
# hammer settings set --name oidc_jwks_url \ --value "Keycloak.example.com/auth/realms/Keycloak_Realm/protocol/openid-connect/certs"
Retrieve the ID of the Keycloak authentication source:
Set the location and organization:
# hammer auth-source external update --id Authentication Source ID \ --location-ids Location ID --organization-ids Organization ID
13.8.5. Logging in to the Foreman Web UI Using Keycloak
Use this procedure to log in to the Foreman web UI using Keycloak.
In your browser, log in to Foreman and enter your credentials.
13.8.6. Logging in to the Foreman CLI Using Keycloak
Use this procedure to authenticate to the Foreman CLI using the code grant type.
To authenticate to the Foreman CLI using the code grant type, enter the following command:
# hammer auth login oauth \ --two-factor \ --oidc-token-endpoint 'https://Keycloak.example.com/auth/realms/ssl-realm/protocol/openid-connect/token' \ --oidc-authorization-endpoint 'https://Keycloak.example.com/auth' \ --oidc-client-id 'foreman.example.com-foreman-openidc' \ --oidc-redirect-uri urn:ietf:wg:oauth:2.0:oob
To retrieve the success code, navigate to the URL that the command returns and provide the required information.
Copy the success code that the web UI returns.
In the command prompt of
hammer auth login oauth, enter the success code to authenticate to the Foreman CLI.
13.8.7. Configuring Group Mapping for Keycloak Authentication
Optionally, to implement the Role Based Access Control (RBAC), create a group in Foreman, assign a role to this group, and then map an Active Directory group to the Foreman group. As a result, anyone in the given group in Keycloak are logged in under the corresponding Foreman group. This example configures users of the Foreman-admin user group in the Active Directory to authenticate as users with administrator privileges on Foreman.
In the Foreman web UI, navigate to Administer > User Groups, and click the Create User Group button.
In the Name field, enter a name for the user group. The name should not be the same as in the Active Directory.
Do not add users and user groups to the right-hand columns. Click the Roles tab.
Select the Administer check box.
Click the External Groups tab.
Click Add external user group.
In the Name field, enter the name of the Active Directory group.
From the list, select EXTERNAL.
13.9. Configuring Keycloak Authentication with TOTP
Use this section to configure Foreman to use Keycloak as an OpenID provider for external authentication with TOTP cards.
13.9.1. Prerequisites for Configuring Foreman with Keycloak Authentication
13.9.2. Registering Foreman as a Keycloak Client
Restart the
13.9.3. Configuring the Foreman Client in Keycloak
Click Save.
Click Save.
Click Save.
13.9.4. Configuring Foreman Settings for Keycloak Authentication
Click Submit.
Open the
13.9.5. Configuring Foreman with Keycloak for TOTP Authentication
Use this procedure to configure Foreman to use Keycloak as an OpenID provider for external authentication with Time-based One-time Password (TOTP).
In the Keycloak web UI, navigate to the Foreman realm.
Navigate to Authentication, and click the OTP Policy tab.
Ensure that the Supported Applications field includes FreeOTP or Google Authenticator.
Configure the OTP settings to suit your requirements.
Optional: If you want to use TOTP authentication as a default authentication method for all users, click the Flows tab, and to the right of the OTP Form setting, select REQUIRED.
Click the Required Actions tab.
To the right of the Configure OTP row, select the Default Action check box.
13.9.6. Logging in to the Foreman Web UI Using Keycloak TOTP Authentication
Use this procedure to log in to the Foreman web UI using Keycloak TOTP authentication.
Log in to Foreman, Foreman redirects you to the Keycloak login screen.
Enter your username and password, and click Log In.
The first attempt to log in, Keycloak requests you to configure your client by scanning the barcode and entering the pin displayed.
After you configure your client and enter a valid PIN, Keycloak redirects you to Foreman and logs you in.
13.9.7. Logging in to the Foreman CLI Using Keycloak
13.9.8. Configuring Group Mapping for Keycloak Authentication
13.10. Configuring Keycloak Authentication with PIV Cards
Use this section to configure Foreman to use Keycloak as an OpenID provider for external authentication with PIV cards.
13.10.1. Prerequisites for Configuring Foreman with Keycloak Authentication
13.10.2. Registering Foreman as a Keycloak Client
Restart the
13.10.3. Configuring the Foreman Client in Keycloak
Click Save.
Click Save.
Click Save.
13.10.4. Configuring Foreman Settings for Keycloak Authentication
Click Submit.
Open the
13.10.5. Configuring Keycloak Settings for Authentication With PIV Cards
You must configure Keycloak settings for authentication with PIV cards.
In the Keycloak web UI, navigate to the Authentication tab.
From the Flows list, select Browser.
Click Copy to copy this flow.
In the Copy Authentication Flow window, enter a new name for the flow and click OK.
In the copied flow, delete Username Password Form and OTP Form entries.
Click Add execution.
From the Provider list, select X509/Validate Username Form.
Click Save.
In the X509/Validate Username Form raw, select ALTERNATIVE.
In the X509/Validate Username Form raw, click Actions > Config.
In the Alias field, enter a name for this configuration.
From the User Identity Source list, select Subject’s Common Name,
From the User mapping method list, select Username or Email.
Click Save.
Navigate to Authentication > Bindings.
From the Browser Flow list, select the created flow.
13.10.6. Configuring Users' OS for Keycloak Authentication with PIV Cards
Complete this procedure on each system from which you want to be able to log in to Foreman using Keycloak PIV cards.
Install required packages:
yum install opensc -y
Install the Firefox browser if not installed.
Launch Firefox and navigate to Preferences.
Click the Privacy and Security tab.
Click Security Devices.
Click Load.
In the Load PKCS#11 Device Driver window, in the Module Name field, enter a name for this device.
In the Module filename field, enter /usr/lib64/pkcs11/opensc-pkcs11.so.
Click OK.
If the PIV card is connected to system, restart the
pcscdservice.
13.10.7. Logging in to the Foreman Web UI Using Keycloak PIV Cards
Use this procedure to log in to the Foreman web UI using the Keycloak PIV cards.
In Firefox, log in to Foreman and enter your credentials.
When prompted, enter the PIN of the PIV card.
Choose the certificate for authentication. Browser verifies this certificate with Keycloak. Once authenticated, browser redirects you back to Foreman and logs you in.
13.10.8. Logging in to the Foreman CLI Using Keycloak
13.10.9. Configuring Group Mapping for Keycloak Authentication
13.11. Disabling Keycloak Authentication
If you want to disable Keycloak authentication in Foreman, complete this procedure.
Enter the following command to disable Keycloak Authentication:
# foreman-installer --reset-foreman-keycloak
14. Monitoring Resources
The following chapter details how to configure monitoring and reporting for managed systems. This includes host configuration, content views, compliance, subscriptions, registered hosts, promotions and synchronization.
14.1. Using the Foreman Content Dashboard
Navigate to Monitor > Dashboard to access the content dashboard. The dashboard can be rearranged by clicking on a widget and dragging it to a different position. The following widgets are available:
- Host Configuration Status
Table 11. Host Configuration States Icon State Description
Hosts in error state
noopmode.
Out of sync hosts
Hosts with no reports
Hosts with alerts disabled
- Host Configuration Chart
- Latest Events
- New Hosts
- Task Status
- Latest Warning/Error Tasks
- Discovered Hosts
- Latest Errata
- Content Views
- Sync Overview
- Host Subscription Status
Table 12. Host Subscription States Icon State Description
Invalid
Partial
Valid
- Subscription Status
- Host Collections
virt-whodaemon running on hosts in the environment. The following table shows the possible states.Table 13. Virt-who Configuration States State Description No Reports
No Change
OK
Total Configurations
- Latest Compliance Reports
- Red Hat Insights Actions
Red Hat Insights is a tool embedded in Foreman that checks the environment and suggests actions you can take. The actions are divided into 4 categories: Availability, Stability, Performance, and Security.
- Red Hat Insights Risk Summary
NoteIt is not possible to change the date format displayed in the Foreman web UI.
14.1.1. Managing Tasks
Navigate to Administer > Settings.
Adjusting the %_finish_timeout values might help in case of low bandwidth. Adjusting the %_accept_timeout values might help in case of high latency. |
Click Save.
14.2. Configuring RSS Notifications
Navigate to Administer > Settings and select the Notifications tab.
14.3. Monitoring Foreman server
From the About page in Foreman server web UI, you can find an overview of the following:
System Status, including Smart Proxies, Available Providers, Compute Resources, and Plug-ins
Support information
System Information
Backend System Status
Installed packages
In the upper right corner of Foreman server web UI, click Administer > About.
After Pulp failure, the status of Pulp might show OK instead of Error for up to 10 minutes due to synchronization delay. |
14.4. Monitoring Smart Proxy server
The following section shows how to use the Foreman web UI to find Smart Proxy information valuable for maintenance and troubleshooting.
14.4.1. Viewing General Smart Proxy Information
Navigate to Infrastructure > Smart Proxies to view a table of Smart Proxy servers registered to Foreman server. The information contained in the table answers the following questions:
- Is Smart Proxy server running?
This is indicated by a green icon in the Status column. A red icon indicates an inactive Smart Proxy, use the
service foreman-proxy restartcommand on Smart Proxy server to activate it. - What services are enabled on Smart Proxy server?
In the Features column you can verify if Smart Proxy for example provides a DHCP service or acts as a Pulp mirror. Smart Proxy features can be enabled during installation or configured in addition. For more information, see Installing Smart Proxy server.
- What organizations and locations is Smart Proxy server assigned to?
A Smart Proxy server can be assigned to multiple organizations and locations, but only Smart Proxies belonging to the currently selected organization are displayed. To list all Smart Proxies, select Any Organization from the context menu in the top left corner.
After changing the Smart Proxy configuration, select Refresh from the drop-down menu in the Actions column to make sure the Smart Proxy table is up to date.
Click the Smart Proxy name to view further details. At the Overview tab, you can find the same information as in the Smart Proxy table. In addition, you can answer to the following questions:
- Which hosts are managed by Smart Proxy server?
- How much storage space is available on Smart Proxy server?
/var/lib/pulpis displayed. Also the remaining storage space available on the Smart Proxy can be ascertained.
14.4.2. Monitoring Services
Navigate to Infrastructure > Smart Proxies and click the name of the selected Smart Proxy. At the Services tab, you can find basic information on Smart Proxy services, such as the list of DNS domains, or the number of Pulp workers. The appearance of the page depends on what services are enabled on Smart Proxy server. Services providing more detailed status information can have dedicated tabs at the Smart Proxy page (see Monitoring Puppet).
14.4.3. Monitoring Puppet
Navigate to Infrastructure > Smart Proxies and click the name of the selected Smart Proxy. At the Puppet tab you can find the following:
A table of CA certificates associated with the Smart Proxy at the Certificates sub-tab. Here you can inspect the certificate expiry data, or cancel the certificate by clicking Revoke.
15. Using Webhooks
Webhooks are useful where the action you want to perform in the external system can be achieved through its API. Where it is necessary to run additional commands or edit files, the shellhooks plugin for Smart Proxies is available. The shellhooks plugin enables you to define a shell script on the Smart Proxy that can be executed through the API.
15.1. Migrating to Webhooks
Webhooks are processed asynchronously so there is minimal risk of tampering with internals of the system.
It is not possible to migrate from foreman_hooks without creating payloads for each individual webhook script.
However, the webhooks plugin comes with several example payload templates.
You can also use the example payloads with shellhooks to simplify migration.
15.2. Installing Webhooks
Use the following procedure to install webhooks. After installing webhooks, you can configure Foreman server to send webhook requests.
Install webhooks using the following command:
Optionally, you can install the CLI plugin using the following command:
# yum install tfm-rubygem-hammer_cli_foreman_webhooks
15.3. Creating a Webhook Template
Use the following procedure to create a webhook template in the Foreman web UI.
In the Foreman web UI, navigate to Administer > Webhooks Templates.
A webhook HTTP payload must be created using Foreman template syntax. The webhook template can use a special variable called
@objectthat can represent the main object of the event.For more information, see Template Writing Reference in Managing Hosts and for available template macros and methods, visit
/templates_docon Foreman server. -
Click Submit.
15.4. Creating a Webhook
In the Foreman web UI, click Administer > Webhooks.
Click Create Webhook.
Click Subscribe to to select an event.
Enter a name.
Enter a target URL. Webhooks make HTTP requests to pre-configured URLs. The target URL can be a dynamic URL. When using the shellhooks plugin, the URL should be in the form
https://smartproxy.example.com:9090/shellhook/my_script. -
Click Template to select a template.
Enter an HTTP method.
Check the Enabled flag if you want to create an active webhook.
Click the Credentials tab.
Optional: If HTTP authentication is required, enter the username and password.
Select Verify SSL if the server certificate should be verified against the system certificate store or Foreman CA.
Select Proxy Authorization when using shellhooks, otherwise clear this box.
When configuring webhooks with endpoints with non-standard HTTP or HTTPS ports, an SELinux port must be assigned, see Configuring SELinux to Ensure Access to Foreman on Custom Ports in Installing Foreman 2.5 server with Katello 4.1 plugin on Enterprise Linux.
15.5. Available Webhook Events
The following table contains a list of webhook events that are available from the Foreman web UI.
A content view was successfully promoted. |
Actions::Katello::ContentView::Promote |
Actions::Katello::ContentView::Publish |
Run OpenSCAP scan. |
Runs an Ansible playbook containing all the roles defined for a host. |
Actions Remote Execution Run Host Job Ansible Run Capsule Upgrade Succeeded |
Upgrade Capsules on given Capsule server hosts. |
Run an Ansible playbook against given hosts. |
Run an Ansible playbook to enable the web console on given hosts. |
Build Entered |
Custom event: |
Build Exited |
Custom event: |
Common database operations on a content view. |
Katello::ContentView |
Domain |
Host |
Hostgroup |
Model |
Status Changed |
Custom event: |
Subnet |
Template Render Performed |
Template |
User |
15.6. Shellhooks
With webhooks, one Foreman event can only be mapped to one API call. For advanced integrations, where a single shell script can contain multiple commands, you can install a Smart Proxy shellhooks plugin that exposes executables using a REST HTTP API.
A webhook can then be configured to reach out to a Smart Proxy API to run a predefined shellhook, which, for example, can contain commands or edit files.
Scripts must be placed in /var/lib/foreman-proxy/shellhooks as executables with only alphanumeric characters and underscores in the name.
The HTTPS payload is passed using standard input, optional command line arguments can be provided using X-Shellhook-Arg-1 to N.
The HTTP method must be POST.
An example URL would be: https://smartproxy.example.com:9090/shellhook/my_script.
You must enable Proxy Authorization for each webhook that is connected to a shellhook, to enable it to authorize a call.
Standard output and error are redirected to the Smart Proxy log as messages with debug or warning levels respectively.
There is no return value from shellhook HTTPS calls.
15.7. Installing the Shellhooks Plugin
Optionally, you can install and enable the shellhooks plugin on each Smart Proxy used for shellhooks, using the following command:
15.8. Using Shellhook Arguments
To pass arguments into a shellhook script, create the following HTTP headers:
"X-Shellhook-Arg-1": "<%= @object.content_view_version_id %>,
"X-Shellhook-Arg-2": "<%= @object.content_view_name %>
Ensure the content renders to a valid JSON. Also, only pass safe fields like database ID, name, or labels which do not include new lines or quote characters.
16. Searching and Bookmarking
The Foreman web UI features powerful search functionality which is available on most pages of the web UI. It enables you to search all kinds of resources that Foreman server manages. Searches accept both free text and syntax-based queries, which can be built using extensive input prediction. Search queries can be saved as bookmarks for future reuse.
16.1. Building Search Queries
16.1.1. Query Syntax
parameter operator value
Available fields, resources to search, and the way the query is interpreted all depend on context, that is, the page where you perform the search. For example, the field "hostgroup" on the Hosts page is equivalent to the field "name" on the Host Groups page. The field type also determines available operators and accepted values. For a list of all operators, see Operators. For descriptions of value formats, see Values.
16.1.2. Operators
| Operator | Short Name | Description | Example |
EQUALS |
NOT EQUALS |
LIKE |
NOT LIKE |
GREATER THAN |
LESS THAN |
IN |
NOT IN |
HAS or set? |
NOT HAS or null? |
| Operator | Alternative Notations | Example | ||
and |
<whitespace> |
or |
not |
16.1.3. Values
- Text Values
Examples:
hostgroup = "Web servers"The search will return hosts with assigned host group named "Web servers".
hostgroup = Web serversThe search will return hosts in the host group Web with any field matching %servers%.
- Temporal Values
"10 January 2017"
"10 Jan 2017"
10-January-2017
10/January/2017
"January 10, 2017"
Warning
16.2. Using Free Text Search
16.3. Managing Bookmarks
On some pages, there are default bookmarks available for the common searches, for example, all active or disabled hosts.
16.3.1. Creating Bookmarks
Navigate to the page where you want to create a bookmark.
Ensure the Public check box is set correctly:
Select the Public check box to set the bookmark as public and visible to all users.
Clear the Public check box to set the bookmark as private and only visible to the user who created it.
Click Submit.
16.3.2. Deleting Bookmarks
Navigate to Administer > Bookmarks.
Appendix A: Foreman Settings
This section contains noteworthy information or known issues about settings that you can edit in the Foreman web UI by navigating to Administer > Settings.
| Setting | Description |
Fix DB cache |
Foreman maintains a cache of permissions and roles.
When set to |
Type of name generator |
Specifies the method used to generate a host name when creating a new host. The default The The |
Safemode rendering |
Exclude pattern for facts stored in Foreman |
Until BZ#1759111 is resolved, note that if you use the wildcard value, for example |
