1. Accessing Foreman
After Foreman has been installed and configured, use the web user interface to log in to Foreman for further configuration.
1.1. Installing the Katello Root CA Certificate
The first time you log on to Foreman, you might see a warning informing you that you are using the default self-signed certificate and you might not be able to connect this browser to Foreman until the root CA certificate is installed in the browser. Use the following procedure to locate the root CA certificate on Foreman and to install it in your browser.
Your Foreman is installed and configured.
  1. Identify the fully qualified domain name of your Foreman server:
    # hostname -f
  2. Access the pub directory on your Foreman server using a web browser pointed to the fully qualified domain name:
    https://foreman.example.com/pub
  3. When you access Foreman for the first time, an untrusted connection warning displays in your web browser. Accept the self-signed certificate and add the Foreman URL as a security exception to override the settings. This procedure might differ depending on the browser being used. Ensure that the Foreman URL is valid before you accept the security exception.
  4. Select katello-server-ca.crt.
  5. Import the certificate into your browser as a certificate authority and trust it to identify websites.
Importing the Katello Root CA Certificate Manually
If you cannot add a security exception in your browser, import the Katello root CA certificate manually.
  1. From the Foreman CLI, copy the katello-server-ca.crt file to the machine you use to access the web UI:
    # scp /var/www/html/pub/katello-server-ca.crt \
    username@hostname:remotefile
  2. In the browser, import the katello-server-ca.crt certificate as a certificate authority and trust it to identify websites.
1.2. Logging on to Foreman
Use the web user interface to log on to Foreman for further configuration.
Ensure that the Katello root CA certificate is installed in your browser. For more information, see Installing the Katello Root CA Certificate.
  2. Enter the user name and password created during the configuration process. If a user was not created during the configuration process, the default user name is admin. If you have problems logging on, you can reset the password. For more information, see Resetting the Administrative User Password.
1.3. Navigation Tabs in the Foreman Web UI
Table 1. Navigation Tabs
Navigation Tabs Description
Any Context
Monitor
Content
Hosts
Configure
Infrastructure
Insights
Provides Red Hat Insights management tools.
User Name
notfications1
Administer
1.4. Changing the Password
To Change your Foreman Password:
1.5. Resetting the Administrative User Password
To Reset the Administrative User Password:
To reset the password to randomly generated characters, complete the following procedure:
  1. Log on to the base operating system where Foreman server is installed.
    #  vi ~/.hammer/cli.modules.d/foreman.yml
To Set a New Administrative User Password:
To change the administrative user password to a new password, complete the following steps:
1.6. Setting a Custom Message on the Login Page
To Set a Custom Message on the Login Page:
  1. Navigate to Administer > Settings, and click the General tab.
  3. Click Save.
  4. Log out of the Foreman’s web UI and verify that the custom text is now displayed on the login page below the Foreman version number.
Foreman provides the foreman-maintain service command to manage Foreman services from the command line. This is useful when creating a backup of Foreman. For more information on creating backups, see Backing Up Foreman server and Smart Proxy server.
To stop the foreman-maintain services, execute:
To start the foreman-maintain services, execute:
To restart the foreman-maintain services, execute:
For Red Hat systems only.
  1. Preparing a Host for External Databases. Prepare a Red Hat Enterprise Linux 7 server to host the external databases.
Foreman, Katello, and Candlepin use the PostgreSQL database. If you want to use PostgreSQL as an external database, the following information can help you decide if this option is right for your Foreman configuration. Foreman supports PostgreSQL version 12.1.
Advantages of External PostgreSQL:
Install a freshly provisioned system with the latest Red Hat Enterprise Linux 7 server to host the external databases.
Subscriptions for Red Hat Software Collections and Red Hat Enterprise Linux do not provide the correct service level agreement for using Foreman with external databases. You must also attach a Foreman subscription to the base operating system that you want to use for the external databases.
    # subscription-manager repos --enable=rhel-server-rhscl-7-rpms \
    --enable=rhel-7-server-rpms --enable=rhel-server-7-satellite-6.9-rpms
3.3. Installing PostgreSQL
You can install only the same version of PostgreSQL that is installed with the foreman-installer tool during an internal database installation. You can install PostgreSQL using Red Hat Enterprise Linux Server 7 repositories or from an external source, as long as the version is supported. Foreman supports PostgreSQL version 12.1.
    # yum install rh-postgresql12-postgresql-server \
    rh-postgresql12-syspaths \
    rh-postgresql12-postgresql-evr
    # postgresql-setup initdb
  3. Edit the /var/opt/rh/rh-postgresql12/lib/pgsql/data/postgresql.conf file:
    # vi /var/opt/rh/rh-postgresql12/lib/pgsql/data/postgresql.conf
    listen_addresses = '*'
  5. Edit the /var/opt/rh/rh-postgresql12/lib/pgsql/data/pg_hba.conf file:
    # vi /var/opt/rh/rh-postgresql12/lib/pgsql/data/pg_hba.conf
      host  all   all   Foreman_ip/24   md5
    # systemctl start postgresql
    # systemctl enable postgresql
    $ su - postgres -c psql
  10. Create two databases and dedicated roles, one for Foreman and one for Candlepin:
  11. Exit the postgres user:
    # \q
  12. From Foreman server, test that you can access the database. If the connection succeeds, the commands return 1.
  1. On Foreman server, stop the foreman-maintain services:
    PGPASSWORD='Pulpcore_Password' pg_restore -h postgres.example.com -U pulpcore -d pulpcore < /var/migration_backup/pulpcore.dump
    foreman-installer --scenario foreman \
        --foreman-db-manage false \
        --foreman-proxy-content-pulpcore-postgresql-password Pulpcore_Password
4.1. Installing the Foreman Ansible Modules from RPM
  • Install the RPM from the client repository on yum.theforeman.org using the following command:
Starting with Ansible 2.10, you can view the installed Foreman Ansible modules by running:
# ansible-doc -l `theforeman.foreman`
When using Ansible before 2.10, you can view the installed Foreman Ansible modules by listing the content of the following directory:
Alternatively, you can also see the complete list of Foreman Ansible modules and other related information at https://galaxy.ansible.com/theforeman/foreman.
All modules are in the `theforeman.foreman` namespace and can be referred to in the format `theforeman.foreman._module_name_`. For example, to display information about the activation_key module, enter the following command:
5. Managing Users and Roles
You can manage permissions of several users at once by organizing them into user groups. User groups themselves can be further grouped to create a hierarchy of permissions. See Creating and Managing User Groups for more information on creating user groups.
5.1. User Management
5.1.1. Creating a User
Use this procedure to create a user. To use the CLI instead of the web UI, see the CLI procedure.
To create a user, complete the following steps:
  1. Navigate to Administer > Users.
  2. Click Create User.
CLI procedure
    # hammer user create \
    --login user_name \
    --password user_password \
    --mail user_mail \
    --auth-source-id 1 \
    --organization-ids org_ID1,org_ID2...
Use this procedure to assign roles to a user. To use the CLI instead of the web UI, see the CLI procedure.
    To grant all the available permissions, select the Admin check box.
  7. Click Submit.
CLI procedure
To impersonate a different user account, complete the following steps:
5.1.4. SSH Keys
Adding SSH keys to a user allows deployment of SSH keys during provisioning.
For information on deploying SSH keys during provisioning, see Deploying SSH Keys during Provisioning in the Provisioning Guide.
For information on SSH keys and SSH key creation, see Using SSH-based Authentication in the Red Hat Enterprise Linux 7 System Administrator’s Guide.
5.1.5. Managing SSH Keys for a User
Use this procedure to add or remove SSH keys for a user. To use the CLI instead of the web UI, see the CLI procedure.
Make sure that you are logged in to the web UI as an Admin user of Foreman or a user with the create_ssh_key permission enabled for adding SSH key and destroy_ssh_key permission for removing a key.
  3. Click on the SSH Keys tab.
    • To Add SSH key
      2. Click Add SSH Key.
      5. Click Submit.
    • To Remove SSH key
CLI procedure
    # hammer user ssh-keys add \
    --user-id user_id \
    --name key_name \
    --key-file ~/.ssh/id_rsa.pub
    --user-id user_id \
    --name key_name \
5.1.6. Email Notifications
The events that trigger a notification are the following:
  • Host build
  • Content View promotion
  • Error reported by host
  • Repository sync
If you want email notifications sent to a group’s email address, instead of an individual’s email address, create a user account with the group’s email address and minimal Foreman permissions, then subscribe the user account to the desired notification types.
Foreman server does not enable outgoing emails by default, therefore you must review your email configuration. For more information, see Configuring Foreman server for Outgoing Emails in Installing Foreman server from a Connected Network.
5.1.7. Configuring Email Notifications
  6. Click Submit.
5.1.8. Testing Email Delivery
  2. Click on the username.
5.1.9. Testing Email Notifications
    # foreman-rake reports:<frequency>
    Replace frequency with one of the following:
  • daily
  • weekly
  • monthly
5.1.10. Notification Types
The following are the notifications created by Foreman:
  • OpenSCAP policy summary: A summary of OpenSCAP policy reports and their results.
  • Puppet error state: A notification sent after a host reports an error related to Puppet.
  • Puppet summary: A summary of Puppet reports.
5.2. Creating and Managing User Groups
5.2.1. User Groups
With Foreman, you can assign permissions to groups of users. You can also create user groups as collections of other user groups. If using an external authentication source, you can map Foreman user groups to external user groups as described in Configuring External User Groups.
5.2.2. Creating a User Group
  1. Navigate to Administer > User Groups.
  2. Click Create User group.
  4. On the Roles tab, select the roles you want to assign to the user group. Alternatively, select the Admin check box to assign all available permissions.
  5. Click Submit.
CLI procedure
    # hammer user-group create \
    --name usergroup_name \
    --user-ids user_ID1,user_ID2... \
    --role-ids role_ID1,role_ID2...
5.2.3. Removing a User Group
5.3. Creating and Managing Roles
5.3.1. Creating a Role
  1. Navigate to Administer > Roles.
  2. Click Create Role.
CLI procedure
# hammer role create --name role_name
5.3.2. Cloning a Role
  1. Navigate to Administer > Roles and select Clone from the drop-down menu to the right of the required role.
5.3.3. Adding Permissions to a Role
Use this procedure to add permissions to a role. To use the CLI instead of the web UI, see the CLI procedure.
  5. Depending on the Resource type selected, you can select or deselect the Unlimited and Override check box. The Unlimited checkbox is selected by default, which means that the permission is applied on all resources of the selected type. When you disable the Unlimited check box, the Search field activates. In this field you can specify further filtering with use of the Foreman search syntax. See Granular Permission Filtering for details. When you enable the Override check box, you can add additional locations and organizations to allow the role to access the resource type in the additional locations and organizations; you can also remove an already associated location and organization from the resource type to restrict access.
  6. Click Next.
CLI procedure
  2. Add permissions to a role:
    # hammer filter create \
    --role role_name \
    --permission-ids perm_ID1,perm_ID2...
5.3.4. Viewing Permissions of a Role
The Filters page contains a table of permissions assigned to a role grouped by the resource type. It is also possible to generate a complete table of permissions and actions that you can use on your Foreman system. See Creating a Complete Permission Table for instructions.
5.3.5. Creating a Complete Permission Table
    # yum install foreman-console
    # foreman-rake console
    end.join("\n")
    f.write(result)
    </table>
5.3.6. Removing a Role
5.3.7. Predefined Roles Available in Foreman
Role Permissions Provided by Role footnote:[The exact set of allowed actions associated with predefined roles can be viewed by the privileged user as described in ]
Access Insights Admin
Add and edit Insights rules.
Access Insights Viewer
View Insight reports.
Ansible Roles Manager
Bookmarks manager
Boot disk access
Download the boot disk.
Compliance manager
Compliance viewer
Create ARF report
Create compliance reports.
Default role
Discovery Manager
Discovery Reader
Edit hosts
Edit partition tables
Manager
A role similar to administrator, but does not have permissions to edit global settings. In the Foreman web UI, global settings can be found under Administer > Settings.
Organization admin
Red Hat Access Logs
Remote Execution Manager
A role with full remote execution permissions, including modifying job templates.
Remote Execution User
Run remote execution jobs.
Site manager
System admin
  • Edit global settings in Administer > Settings
Tasks manager
View and edit Foreman tasks.
Tasks reader
Viewer
View hosts
Virt-who Manager
Virt-who Reporter
Virt-who Viewer
5.4. Granular Permission Filtering
5.4.1. Granular Permission Filter
5.4.2. Creating a Granular Permission Filter
Use this procedure to create a granular filter. To use the CLI instead of the web UI, see the CLI procedure.
Specify a query in the Search field on the Edit Filter page. Deselect the Unlimited check box for the field to be active. Queries have the following form:
field_name operator value
CLI procedure
    --permission-ids 91 \
    --search "name ~ ccv*" \
    --role qa-user
5.4.3. Examples of Using Granular Permission Filters
hostgroup = host-editors
name ^ (XXXX, Yyyy, zzzz)
Dev
You can limit user permissions to a certain organization or location with the use of the granular permission filter in the Search field. However, some resource types provide a GUI alternative, an Override check box that provides the Locations and Organizations tabs. On these tabs, you can select from the list of available organizations and locations. See Creating an Organization Specific Manager Role.
Use the Foreman UI to create an administrative role restricted to a single organization named org-1.
5.4.4. Supported Operators for Granular Search
Table 2. Logical Operators
Operator
and
Combines search criteria.
not
Negates an expression.
has
Table 3. Symbolic Operators
Operator
Not like. An inversion of the ~ operator.
Not in. An inversion of the ^ operator.
6. Managing Security Compliance
Security compliance management is the ongoing process of defining security policies, auditing for compliance with those policies and resolving instances of non-compliance. Any non-compliance is managed according to the organization’s configuration management policies. Security policies range in scope from host-specific to industry-wide, therefore, flexibility in their definition is required.
6.1. Security Content Automation Protocol
Foreman uses the Security Content Automation Protocol (SCAP) to define security configuration policies. For example, a security policy might specify that for hosts running Red Hat Enterprise Linux, login via SSH is not permitted for the root account. With Foreman you can schedule compliance auditing and reporting on all hosts under management. For more information about SCAP, see the Red Hat Enterprise Linux 7 Security Guide.
6.1.1. SCAP Content
SCAP content is a datastream format containing the configuration and security baseline against which hosts are checked. Checklists are described in the extensible checklist configuration description format (XCCDF) and vulnerabilities in the open vulnerability and assessment language (OVAL). Checklist items, also known as rules express the desired configuration of a system item. For example, you may specify that no one can log in to a host over SSH using the root user account. Rules can be grouped into one or more profiles, allowing multiple profiles to share a rule. SCAP content consists of both rules and profiles.
You can either create SCAP content or obtain it from a vendor. Supported profiles are provided for Red Hat Enterprise Linux in the scap-security-guide package. The creation of SCAP content is outside the scope of this guide, but see the Red Hat Enterprise Linux 7 Security Guide for information on how to download, deploy, modify, and create your own content.
The default SCAP content provided with the OpenSCAP components of Foreman depends on the version of Red Hat Enterprise Linux. On Red Hat Enterprise Linux 7, content for both Red Hat Enterprise Linux 6 and Red Hat Enterprise Linux 7 is installed.
6.1.2. XCCDF Profile
An XCCDF profile is a checklist against which a host or host group is evaluated. Profiles are created to verify compliance with an industry standard or custom standard.
The profiles provided with Foreman are obtained from the OpenSCAP project.
Listing Available XCCDF Profiles
In the Foreman UI, list the available XCCD profiles.
  • Navigate to Hosts > SCAP contents.
6.2. Configuring SCAP Content
6.2.1. Importing OpenSCAP Puppet Modules
If you do not use Puppet to configure OpenSCAP auditing on hosts, you can skip this procedure.
To audit hosts with OpenSCAP, you must first import a Puppet environment. The Puppet environment contains the Puppet classes you must assign to each host to deploy the OpenSCAP configuration.
You must associate each host that you want to audit with the Puppet environment in the Foreman web UI.
  1. In the Foreman web UI, navigate to Configure > Environments.
  2. Click Import environments from foreman.example.com.
  3. Select the Puppet environment check box associated with the host you want to audit.
    If no Puppet environment exists, select the production environment check box. The Puppet classes that you require for OpenSCAP are in the production environment by default.
  4. Click Update.
6.2.2. Loading the Default OpenSCAP Content
In the CLI, load the default OpenScap content.
  • Use the foreman-rake command:
    # foreman-rake foreman_openscap:bulk_upload:default
6.2.3. Extra SCAP Content
You can upload extra SCAP content into Foreman server, either content created by yourself or obtained elsewhere. SCAP content must be imported into Foreman server before being applied in a policy. For example, the scap-security-guide RPM package available in the Red Hat Enterprise Linux 7.2 repositories includes a profile for the Payment Card Industry Data Security Standard (PCI-DSS) version 3. You can upload this content into a Foreman server even if it is not running Red Hat Enterprise Linux 7.2 as the content is not specific to an operating system version.
Uploading Extra SCAP Content
In the Foreman web UI, upload the extra SCAP content.
  1. Navigate to Hosts > SCAP contents and click New SCAP Content.
  2. Enter a title in the Title text box.
    Example: RHEL 7.2 SCAP Content.
  3. Click Choose file, navigate to the location containing the SCAP content file and select Open.
  4. Click Submit.
If the SCAP content file is loaded successfully, a message similar to Successfully created RHEL 7.2 SCAP Content is shown and the list of SCAP Contents includes the new title.
6.3. Managing Compliance Policies
6.3.1. Compliance Policy
A scheduled audit, also known as a compliance policy, is a scheduled task that checks the specified hosts for compliance against an XCCDF profile. The schedule for scans is specified by Foreman server and the scans are performed on the host. When a scan completes, an Asset Reporting File (ARF) is generated in XML format and uploaded to Foreman server. You can see the results of the scan in the compliance policy dashboard. No changes are made to the scanned host by the compliance policy. The SCAP content includes several profiles with associated rules but policies are not included by default.
6.3.2. Creating a Compliance Policy
With Foreman, you can create a compliance policy to scan your content hosts to ensure that the hosts remain compliant to your security requirements.
You can use either Puppet or Ansible to deploy the compliance policy to your hosts. Note that Puppet runs by default every 30 minutes. If you assign a new policy, the next Puppet run synchronizes the policy to the host. However Ansible does not perform scheduled runs. To add a new policy, you must run Ansible role manually or using remote execution. For more information about remote execution, see Configuring and Setting up Remote Jobs in the Managing Hosts guide.
Before you begin, you must decide whether you want to use a Puppet or Ansible deployment.
  • For Puppet deployment, ensure that each host that you want to audit is associated with a Puppet environment. For more information, see Importing OpenSCAP Puppet Modules.
  • For Ansible deployment, ensure that you import the theforeman.foreman_scap_client Ansible role. For more information about importing Ansible roles, see Getting Started with Ansible in Satellite in Configuring Satellite to use Ansible.
  1. Navigate to Hosts > Policies, and select whether you want a manual, Ansible, or Puppet deployment.
  2. Enter a name for this policy, a description (optional), then click Next.
  3. Select the SCAP Content and XCCDF Profile to be applied, then click Next.
    Until BZ#1704582 is resolved, note that the Default XCCDF Profile might return an empty report.
  4. Specify the scheduled time when the policy is to be applied, then click Next.
    Select Weekly, Monthly, or Custom from the Period list.
      The Custom option allows for greater flexibility in the policy’s schedule than either the Weekly or Monthly options.
  5. Select the locations to which the policy is to be applied, then click Next.
  6. Select the organizations to which the policy is to be applied, then click Next.
  7. Select the host groups to which the policy is to be applied, then click Submit.
When the Puppet agent runs on the hosts which belong to the selected host group, or hosts to which the policy has been applied, the OpenSCAP client will be installed and a Cron job added with the policy’s specified schedule. The SCAP Content tab provides the name of the SCAP content file which will be distributed to the directory /var/lib/openscap/content/ on all target hosts.
6.3.3. Viewing a Compliance Policy
You can preview the rules which will be applied by specific OpenSCAP content and profile combination. This is useful when planning policies.
In the Foreman web UI, view the compliance policy.
  1. Navigate to Hosts > Policies.
  2. Click Show Guide.
6.3.4. Editing a Compliance Policy
In the Foreman web UI, edit the compliance policy.
  2. From the drop-down list to the right of the policy’s name, select Edit.
  4. Click Submit.
An edited policy is applied to the host when its Puppet agent next checks with Foreman server for updates. By default this occurs every 30 minutes.
6.3.5. Deleting a Compliance Policy
In the Foreman web UI, delete an existing policy.
  2. From the drop-down list to the right of the policy’s name, select Delete.
6.4. Tailoring Files
Tailoring Files allow existing OpenSCAP policies to be customized without forking or rewriting the policy. You can assign a Tailoring File to a policy when creating or updating a policy.
You can create a Tailoring File using the SCAP Workbench. For more information on using the SCAP Workbench tool, see Customizing SCAP Security Guide for your use-case.
6.4.1. Uploading a Tailoring File
In the Foreman web UI, upload a Tailoring file.
  1. Navigate to Hosts > Compliance - Tailoring Files and click New Tailoring File.
  3. Click Choose File, navigate to the location containing the SCAP DataStream Tailoring File and select Open.
  4. Click Submit to upload the chosen Tailoring File.
6.4.2. Assigning a Tailoring File to a Policy
In the Foreman web UI, assign a Tailoring file to a policy.
  1. Navigate to Hosts > Compliance - Policies.
  2. Click New Policy, or New Compliance Policy if there are existing Compliance Policies.
  3. Enter a name in the Name text box, and click Next.
  4. Select a Scap content from the dropdown menu.
  5. Select a XCCDF Profile from the dropdown menu.
  6. Select a Tailoring File from the dropdown menu.
  7. Select a XCCDF Profile in Tailoring File from the dropdown menu.
    It is important to select the XCCDF Profile because Tailoring Files are able to contain multiple XCCDF Profiles.
  8. Click Next.
  9. Select a Period from the dropdown menu.
  10. Select a Weekday from the dropdown menu, and click Next.
  11. Select a Location to move it to the Selected Items window, and click Next.
  12. Select an Organization to move it to the Selected Items window, and click Next.
  13. Select a Hostgroup to move it to the Selected Items window, and click Submit.
6.5. Configuring a host group for OpenSCAP
Use this procedure to configure all the OpenSCAP requirements for a host group.
OpenSCAP Setup Overview
You must complete the following tasks on Foreman server to assign the necessary components for a host group:
  • Enable OpenSCAP on Smart Proxy. For more information, see Enabling OpenSCAP on External Smart Proxies in the Installing Smart Proxy server guide.
  • Assign an OpenSCAP Smart Proxy.
  • Assign a Puppet environment that contains the Puppet classes to deploy the OpenSCAP policies.
  • Assign the foreman_scap_client and foreman_scap_client::params Puppet classes.
  • Assign any compliance policies that you want to add.
For information about creating and administering hosts, see the Managing Hosts guide.
  1. In the Foreman web UI, navigate to Configure > Host Groups, and either create a host group or click the host group that you want to configure for OpenSCAP reporting.
  2. From the Puppet Environment list, select the Puppet environment that contains the foreman_scap_client and foreman_scap_client::params Puppet classes.
  4. Click the Puppet Classes tab, and add the foreman_scap_client and foreman_scap_client::params Puppet classes.
  6. Navigate to Hosts > Policies.
  7. Select the policy that you want to assign to the host group.
  8. Click the Host Groups tab.
  9. From the Host Groups list, select as many host groups as you want to assign to this policy.
  10. Click Submit to save your changes.
6.6. Configuring a host for OpenSCAP
Use this procedure to configure all the OpenSCAP requirements for a host.
You must complete the following tasks on Foreman server to assign the necessary components for a host:
  5. To add a compliance policy, navigate to one of the following locations:
  6. Navigate to Hosts > All Hosts.
  8. Click Select Action.
  10. In the Policy window, select the policy that you want from the list of available policies and click Submit.
6.7. Monitoring Compliance
Foreman enables centralized compliance monitoring and management. A compliance dashboard provides an overview of compliance of hosts and the ability to view details for each host within the scope of that policy. Compliance reports provide a detailed analysis of compliance of each host with the applicable policy. With this information, you can evaluate the risks presented by each host and manage the resources required to bring hosts into compliance.
Common objectives when monitoring compliance using SCAP include the following:
  • Verifying policy compliance.
  • Detecting changes in compliance.
6.7.1. Compliance Policy Dashboard
The compliance policy dashboard provides a statistical summary of compliance of hosts and the ability to view details for each host within the scope of that policy. For all hosts which were evaluated as non-compliant, the Failed statistic provides a useful metric for prioritizing compliance effort. The hosts detected as Never audited should also be a priority, since their status is unknown.
6.7.2. Viewing the Compliance Policy Dashboard
Use the Foreman web UI to verify policy compliance with the compliance policy dashboard.
  2. Click the required policy name. The dashboard provides the following information:
    • A ring chart illustrating a high-level view of compliance of hosts with the policy.
    • A statistical breakdown of compliance of hosts with the policy, in a tabular format.
    • Links to the latest policy report for each host.
6.7.3. Compliance Email Notifications
Foreman server sends an OpenSCAP Summary email to all users who subscribe to the Openscap policy summary email notifications. For more information on subscribing to email notifications, see Configuring Email Notifications. Each time a policy is run, Foreman checks the results against the previous run, noting any changes between them. The email is sent according to the frequency requested by each subscriber, providing a summary of each policy and its most recent result.
An OpenSCAP Summary email message contains the following information:
  • Details of the time period it covers.
  • Totals for all hosts by status: changed, compliant, and noncompliant.
  • A tabular breakdown of each host and the result of its latest policy, including totals of the rules that passed, failed, changed, or where results were unknown.
6.7.4. Compliance Report
A compliance report is the output of a policy run against a host. Each report includes the total number of rules passed or failed per policy. By default, reports are listed in descending date order.
In the Foreman web UI, navigate to Hosts > Reports to list all compliance reports.
  • Introduction
  • Evaluation Characteristics
  • Compliance and Scoring
  • Rule Overview
The Evaluation Characteristics area provides details about an evaluation against a specific profile, including the host that was evaluated, the profile used in the evaluation, and when the evaluation started and finished. For reference, the IPv4, IPv6, and MAC addresses of the host are also listed.
Name Description Example
Target machine
The fully-qualified domain name (FQDN) of the evaluated host.
test-system.example.com
Benchmark URL
The URL of the SCAP content against which the host was evaluated.
/var/lib/openscap/content/1fbdc87d24db51ca184419a2b6f
Benchmark ID
The identifier of the benchmark against which the host was evaluated. A benchmark is a set of profiles
xccdf_org.ssgproject.content_benchmark_RHEL_7
Profile ID
The identifier of the profile against which the host was evaluated.
xccdf_org.ssgproject_content_profile_rht-ccp
Started at
The date and time at which the evaluation started, in ISO 8601 format.
2015-09-12T14:40:02
Finished at
The date and time at which the evaluation finished, in ISO 8601 format.
2015-09-12T14:40:05
Performed by
The local account name under which the evaluation was performed on the host.
root
The Compliance and Scoring area provides an overview of whether or not the host is in compliance with the profile rules, a breakdown of compliance failures by severity, and an overall compliance score as a percentage. If compliance with a rule was not checked, this is categorized in the Rule results field as Other.
Rule Overview
The Rule Overview area provides details about every rule and the compliance result, with the rules presented in a hierarchical layout.
Select or clear the check boxes to narrow the list of rules included in the compliance report. For example, if the focus of your review is any non-compliance, clear the pass and informational check boxes.
To search all rules, enter a criterion in the Search field. The search is dynamically applied as you type. The Search field only accepts a single plain-text search term and it is applied as a case-insensitive search. When you perform a search, only those rules whose descriptions match the search criterion will be listed. To remove the search filter, delete the search criterion.
For an explanation of each result, hover the cursor over the status shown in the Result column.
6.7.5. Examining Compliance Failure of Hosts
Use the Foreman web UI to determine why a host failed compliance on a rule.
  2. Click View Report in the row of the specific host to view the details of an individual report.
  3. Click on the rule’s title to see further details:
    • The rationale for the rule.
Warning
Do not implement any of the recommended remedial actions or scripts without first testing them in a non-production environment.
6.7.6. Searching Compliance Reports
Use the Compliance Reports search field to filter the list of available reports on any given subset of hosts.
  • To apply a filter, enter the search query in the Search field and click Search. The search query is case insensitive.
Search Use Cases
  • The following search query finds all compliance reports for which more than five rules failed:
    failed > 5
  • The following search query finds all compliance reports created after January 1, YYYY, for hosts with host names that contain the prod- group of characters:
    host ~ prod- AND date > "Jan 1, YYYY"
  • The following search query finds all reports generated by the rhel7_audit compliance policy from an hour ago:
  • The following search query finds reports that pass an XCCDF rule:
  • The following search query finds reports that fail an XCCDF rule:
  • The following search query finds reports that have a result different than fail or pass for an XCCDF rule:
Additional Information
  • To see a list of available search parameters, click the empty Search field.
  • You can create complex queries with the following logical operators: and, not and has. For more information about logical operators, see Supported Operators for Granular Search.
  • You cannot use regular expressions in a search query. However, you can use multiple fields in a single search expression. For more information about all available search operators, see Supported Operators for Granular Search.
  • You can bookmark a search to reuse the same search query. For more information, see Creating Bookmarks.
6.7.7. Deleting a Compliance Report
To delete a compliance report, complete the following steps:
  3. Click OK.
6.7.8. Deleting Multiple Compliance Reports
You can delete multiple compliance policies simultaneously. However, in the Foreman web UI, compliance policies are paginated, so you must delete one page of reports at a time. If you want to delete all OpenSCAP reports, use the script in the Deleting OpenSCAP Reports section of the Foreman API Guide.
6.8. Specifications Supported by OpenSCAP
The following specifications are supported by OpenSCAP:
Title Description Version
XCCDF
The Extensible Configuration Checklist Description Format
1.2
OVAL
Open Vulnerability and Assessment Language
5.11
Asset Identification
1.1
ARF
Asset Reporting Format
1.1
CCE
5.0
CPE
Common Platform Enumeration
2.3
CVE
CVSS
2.0
7. Backing Up Foreman server and Smart Proxy server
Conventional Backup Methods
You can also use conventional backup methods. For more information, see System Backup and Recovery in the Red Hat Enterprise Linux 7 System Administrator’s Guide.
If you plan to use the foreman-maintain backup command to create a backup, do not stop the foreman-maintain services.
7.1. Estimating the Size of a Backup
    # du -sh /var/opt/rh/rh-postgresql12/lib/pgsql/data /var/lib/pulp
    100G  /var/opt/rh/rh-postgresql12/lib/pgsql/data
    100G	/var/lib/pulp
    886M  /var/lib/qpidd
    16M   /var/lib/tftpboot
    37M   /etc
    900K	/root/ssl-build
    100K	/var/www/html/pub
    2M	  /opt/puppetlabs
    942M  total
    Table 4. Backup Data Compression Ratio
    PostgreSQL database files
    80 - 85%
    100 GB → 20 GB
    Pulp RPM files
    /var/lib/pulp
    (not compressed)
    100 GB
    Configuration files
    /var/lib/qpidd
    /var/lib/tftpboot
    /etc
    /root/ssl-build
    /var/www/html/pub
    /opt/puppetlabs
    85%
    942 MB → 141 MB
    In this example, the compressed backup data occupies 180 GB in total.
    This example requires 681 GB plus 180 GB for the uncompressed and compressed backup data, 861 GB in total. With 172 GB of extra space, 1033 GB must be allocated for the backup location.
7.2. Performing a Full Backup of Foreman server or Smart Proxy server
Foreman 6.9 uses the foreman-maintain backup command to make backups.
  • Offline backup
  • Online backup
  • Snapshot backups
For offline backups:
For online backups:
For snapshots backups:
Directory creation
  • foreman-backup on Foreman
Note that if you use a local PgSQL database, the postgres user requires write access to the backup directory.
Remote databases
To perform a full offline backup of Foreman server or Smart Proxy server, complete one of the following steps:
Warning
7.3. Performing a Backup without Pulp Content
You can perform an offline backup that excludes the contents of the Pulp directory. The backup without Pulp content is useful for debugging purposes and is only intended to provide access to configuration files without backing up the Pulp database. You cannot restore from a directory that does not contain Pulp content.
Warning
7.4. Performing an Incremental Backup
Warning
    # foreman-maintain backup offline  /var/backup_directory
    # foreman-maintain backup offline --incremental /var/backup_directory/full_backup  /var/backup_directory
    # foreman-maintain backup offline --incremental /var/backup_directory/first_incremental_backup  /var/backup_directory
7.5. Example of a Weekly Full Backup Followed by Daily Incremental Backups
#!/bin/bash -e
else
fi
exit 0
7.6. Performing an Online Backup
Warning
7.7. Performing a Snapshot Backup
Warning
Before you perform the snapshot backup, ensure that the following conditions are met:
  • The system uses LVM for the directories that you snapshot: /var/lib/pulp/, and /var/opt/rh/rh-postgresql12/lib/pgsql.
7.8. White-listing and Skipping Steps When Performing Backups
    # foreman-maintain backup online --whitelist backup-metadata  -y /var/backup_directory
8. Restoring Foreman server or Smart Proxy server from a Backup
You can restore Foreman Server or Red Hat Smart Proxy server from the backup data that you create as part of Backing Up Foreman server and Smart Proxy server. This process outlines how to restore the backup on the same server that generated the backup, and all data covered by the backup is deleted on the target system. If the original system is unavailable, provision a system with the same configuration settings and host name.
8.1. Restoring from a Full Backup
    # df -h /var/backup_directory
    # restorecon -Rnv /
Additional Resources
8.2. Restoring from Incremental Backups
Use this procedure to restore Foreman or Smart Proxy server from incremental backups. If you have multiple branches of incremental backups, select your full backup and each incremental backup for the “branch” you want to restore, in chronological order.
    # foreman-maintain restore -i /var/backup_directory/FIRST_INCREMENTAL
    # foreman-maintain restore -i /var/backup_directory/SECOND_INCREMENTAL
    If you created the backup using the foreman-maintain backup command, you do not need to use -i option in the command.
8.3. Backup and Restore Smart Proxy server Using a Virtual Machine Snapshot
If required, deploy a new Smart Proxy server, ensuring the host name is the same as before, and then install the Smart Proxy certificates. You may still have them on Foreman server, the package name ends in -certs.tar, alternately create new ones. Follow the procedures in Installing Smart Proxy server until you can confirm, in the web UI, that Smart Proxy server is connected to Foreman server. Then use the procedure Synchronizing an External Smart Proxy to synchronize from Foreman.
8.3.1. Synchronizing an External Smart Proxy
  1. To synchronize an external Smart Proxy, select the relevant organization and location in the web UI, or choose Any Organization and Any Location.
  2. Navigate to Infrastructure > Smart Proxies and click the name of the Smart Proxy to synchronize.
9. Renaming Foreman server or Smart Proxy server
To rename Foreman server or Smart Proxy server, you must use the katello-change-hostname script.
If you rename Foreman server, you must reregister all Foreman clients and configure each Smart Proxy server to point them to the new Foreman host name. If you use custom SSL certificates, you must regenerate them with the new host name. If you use virt-who, you must update the virt-who configuration files with the new host name.
If you rename Smart Proxy server, you must reregister all Smart Proxy clients and update the Smart Proxy host name in the Foreman web UI. If you use custom SSL certificates, you must regenerate them with the new host name.
Warning
The renaming process shuts down all Foreman server services on the host being renamed. When the renaming is complete, all services are restarted.
9.1. Renaming Foreman server
The host name of Foreman server is used by Foreman server components, all Smart Proxy servers, and hosts registered to it for communication. This procedure ensures that you update all references to the new host name.
If you use external authentication, you must reconfigure Foreman server for external authentication after you run the katello-change-hostname script. The katello-change-hostname script breaks external authentication for Foreman server. For more information about configuring external authentication, see Configuring External Authentication.
If you use virt-who, you must update the virt-who configuration files with the new host name after you run the katello-change-hostname script. For more information, see Modifying a virt-who Configuration in Configuring Virtual Machine Subscriptions in Foreman.
  • Both the hostname and hostname -f commands must return the FQDN of Foreman server or the katello-change-hostname script will fail to complete. If the hostname command returns the shortname of Foreman server instead of the FQDN, use hostnamectl set-hostname old_fqdn to set the old FQDN correctly before attempting to use the katello-change-hostname script.
  • Perform a backup of Foreman server before changing a host name. If the renaming process is not successful, you must restore it from a backup. For more information, see Backing Up Foreman server and Smart Proxy server.
  • Optional: If Foreman server has a custom SSL certificate installed, a new certificate must be obtained for the host’s new name. For more information, see Configuring Foreman server with a Custom SSL Certificate in Installing Foreman server from a Connected Network.
  1. On Foreman server, choose the appropriate method to run the katello-change-hostname script, providing the new host name and Foreman credentials:
    • If your Foreman server is installed with default self-signed SSL certificates, enter the following command:
      --username admin \
      --password password
      --username admin \
      --password password \
  2. Optional: If you have created a custom SSL certificate for the new Foreman server host name, run the Foreman installation script to install the certificate. For more information about installing a custom SSL certificate, see Deploying a Custom SSL Certificate to Foreman server in Installing Foreman server from a Connected Network.
  3. On all Foreman clients, enter the following commands to reinstall the bootstrap RPM, reregister clients, and refresh their subscriptions.
    You can use remote execution feature to perform this step. For more information, see Configuring and Setting up Remote Jobs in Managing Hosts.
    # yum remove -y katello-ca-consumer*
    # rpm -Uvh http://new-foreman.example.com/pub/katello-ca-consumer-latest.noarch.rpm
    # subscription-manager register \
    --org="Default_Organization" \
    --environment="Library" \
    --force
    # subscription-manager refresh
    # foreman-installer \
    --foreman-proxy-content-parent-fqdn new-foreman.example.com \
    --foreman-proxy-trusted-hosts new-foreman.example.com
    # hammer proxy list
    # hammer proxy_content synchronize \
    --id proxy_id_number
9.2. Renaming Smart Proxy server
The host name of Smart Proxy server is referenced by Foreman server components, and all hosts registered to it. This procedure ensures that you update all references to the new host name.
  • Both the hostname and hostname -f commands must return the FQDN of Smart Proxy server or the katello-change-hostname script will fail to complete.
  • If the hostname command returns the shortname of Smart Proxy server instead of the FQDN, use hostnamectl set-hostname old_fqdn to set the old FQDN correctly before attempting to use the katello-change-hostname script.
  • Backup Smart Proxy server. The katello-change-hostname script makes irreversible changes to Smart Proxy server. If the renaming process is not successful, you must restore it from a backup.
    Perform a backup before changing a host name. For more information, see Backing Up Foreman server and Smart Proxy server.
Warning
Until BZ#1829115 is resolved, you must edit the usr/share/katello/hostname-change.rb file on Smart Proxy server and comment out the following lines before attempting to rename Smart Proxy server:
STDOUT.puts "updating hostname in hammer configuration"
self.run_cmd("sed -i.bak -e 's/#{@old_hostname} \
/#{@new_hostname}/g' #{hammer_root_config_path}/*.yml")
/#{@new_hostname>/g' #{hammer_config_path}/*.yml")
  1. On Foreman server, generate a new certificates archive file for Smart Proxy server.
    • If you are using the default SSL certificate, enter the following command:
      --foreman-proxy-fqdn new-smartproxy.example.com \
      --certs-tar /root/new-smartproxy.example.com-certs.tar
    • If you are using a custom SSL certificate, create a new SSL certificate for Smart Proxy server. For more information, see Configuring Smart Proxy server with a Custom SSL Certificate in Installing Smart Proxy server.
  2. On Foreman server, copy the certificates archive file to Smart Proxy server, providing the root user’s password when prompted. In this example the archive file is copied to the root user’s home directory, but you may prefer to copy it elsewhere.
  3. On Smart Proxy server, run the katello-change-hostname script and provide the host’s new name, Foreman credentials, and certificates archive filename.
    # katello-change-hostname new-smart-proxy --username admin \
  4. Optional: If you have created a custom certificate for Smart Proxy server, on Smart Proxy server, to deploy the certificate, enter the foreman-installer command that the foreman-proxy-certs-generate command returns. For more information, see Deploying a Custom SSL Certificate to Smart Proxy server in Installing Smart Proxy server.
  5. On all Smart Proxy clients, enter the following commands to reinstall the bootstrap RPM, reregister clients, and refresh their subscriptions.
    # rpm -Uvh http://new-smartproxy.example.com/pub/katello-ca-consumer-latest.noarch.rpm
    # subscription-manager register --org="Default_Organization" \
    --force
  6. In the Foreman web UI, navigate to Infrastructure > Smart Proxies.
  7. Locate Smart Proxy server in the list, and click Edit to the right of it.
  8. Edit the Name and URL fields to match Smart Proxy server’s new host name, then click Submit.
  9. On your DNS server, add a record for Smart Proxy server’s new host name, and delete the record for the previous host name.
10. Maintaining Foreman server
This chapter provides information on how to maintain a Foreman Server, including information on how to work with audit records, how to clean unused tasks, and how to recover Pulp from a full disk.
10.1. Deleting Audit Records
Audit records are created automatically in Foreman. You can use the foreman-rake audits:expire command to remove audits at any time. You can also use a cron job to schedule audit record deletions at the set interval that you want.
By default, using the foreman-rake audits:expire command removes audit records that are older than 90 days. You can specify the number of days to keep the audit records by adding the days option and add the number of days.
10.2. Anonymizing Audit Records
10.3. Configuring the Cleaning Unused Tasks Feature
For Foremans Upgraded from Previous Versions
Until BZ#1788615 is resolved, this functionality works only on fresh installations of Foreman 1.22 and later. If you upgrade Foreman from previous versions, this functionality is disabled by default. To enable Foreman to perform regular cleaning, enter the following command:
Optionally use this procedure to adjust the configuration to serve your needs.
  1. Optional: To configure the time at which Foreman runs the cron job, set the --foreman-plugin-tasks-cron-line parameter to the time you want in cron format. For example, to schedule the cron job to run every day at 15:00, enter the following command:
  2. Optional: To configure the period after which Foreman deletes the tasks, edit the :rules: section in the /etc/foreman/plugins/foreman-tasks.yaml file.
10.4. Recovering from a Full Disk
To recover from a full disk
    1. Remove orphaned content:
    3. Grow the file system on the LV with the /var/lib/pulp directory on it. For more information, see Growing a File System on a Logical Volume in the Red Hat Enterprise Linux 7 Logical Volume Manager Administration Guide.
      1. Stop the foreman-maintain services:
      3. Start the foreman-maintain services:
10.5. Reclaiming PostgreSQL Space
    # su - postgres -c 'vacuumdb --full --dbname=foreman'
11. Logging and Reporting Problems
This chapter provides information on how to log and report problems in Foreman Server, including information on relevant log files, how to enable debug logging, how to open a support case and attach the relevant log tar files, and how to access support cases within the Foreman web UI.
You can use the log files and other information described in this chapter to do your own troubleshooting, or you can capture these and many more files, as well as diagnostic and configuration information, to send to Red Hat Support if you need further assistance.
11.1. Enabling Debug Logging
Debug logging provides the most detailed log information and can help with troubleshooting issues that can arise with Foreman 6.9 and its components.
In the Foreman CLI, enable debug logging to log detailed debugging information for Foreman 6.9.
To enable debug logging, complete the following steps on your Foreman server.
  1. To enable debug logging, enter the following command :
11.2. Enabling Individual Loggers
app
audit
ldap
permissions
sql
To enable individual loggers, complete the following steps.
    # foreman-installer --foreman-loggers sql:true --foreman-loggers ldap:true
11.3. Configuring Logging to Journal
You can configure Foreman to manage logging with Journal. Journal then forwards log messages to rsyslog and rsyslog writes the log messages to /var/log/messages. Note that after this change the log messages do not appear in /var/log/foreman/production.log or /var/log/foreman-proxy.log any more.
For more information about Journal, see https://github.com/lzap/foreman-elasticsearch.
To configure Foreman server logging with Journal, complete the following steps:
  1. Enter the following foreman-installer command to configure logging to journald:
    # foreman-installer --foreman-logging-level info \
    --foreman-logging-layout pattern --foreman-proxy-log JOURNAL
  2. Restart the Apache daemon:
    # foreman-maintain service restart --only httpd
11.4. Log File Directories Provided by Foreman
Table 5. Log File Directories for Reporting and Troubleshooting
/var/log/candlepin
Subscription management
/var/log/foreman
Foreman
Foreman proxy
/var/log/httpd
Apache HTTP server
/var/log/foreman-installer
Installer
/var/log/puppet
Configuration management
/var/log/rhsm
/var/log/tomcat
Candlepin webservice logs
/var/log/messages
Various other log messages
11.5. Utilities for Collecting Log Information
There are two utilities available to collect information from log files.
Table 6. Log Collecting Utilities
Command Description
foreman-debug
The foreman-debug command collects configuration and log file data for Foreman, its back-end services, and system information. This information is collected and written to a tar file. By default, the output tar file is located at /tmp/foreman-debug-xxx.tar.xz.
Additionally, the foreman-debug command exports tasks run during the last 60 days. By default, the output tar file is located at /tmp/task-export-xxx.tar.xz. If the file is missing, see the file /tmp/task-export.log to learn why task export was unsuccessful.
For more information, run foreman-debug --help.
There is no timeout when running this command.
sosreport
The sosreport command is a tool that collects configuration and diagnostic information from a Red Hat Enterprise Linux system, such as the running kernel version, loaded modules, and system and service configuration files. The command also runs external programs (for example: foreman-debug -g) to collect Foreman-specific information, and stores this output in a tar file.
By default, the output tar file is located at /var/tmp/sosreport-XXX-20171002230919.tar.xz. For more information, run sosreport --help or see What is a sosreport and how can I create one?.
The sosreport command calls the foreman-debug -g and times out after 500 seconds. If your Foreman server has large log files or many Foreman tasks, support engineers may require the output of sosreport and foreman-debug when you open a support case.
Both foreman-debug and sosreport remove security information such as passwords, tokens, and keys while collecting information. However, the tar files can still contain sensitive information about the Foreman Server. Red Hat recommends that you send this information directly to the intended recipient and not to a public target.
12. Configuring External Authentication
By using external authentication you can derive user and user group permissions from user group membership in an external identity provider. When you use external authentication, you do not have to create these users and maintain their group membership manually on Foreman server.
Important User and Group Account Information
All user and group accounts must be local accounts. This is to ensure that there are no authentication conflicts between local accounts on your Foreman server and accounts in your Active Directory domain.
Your system is not affected by this conflict if your user and group accounts exist in both /etc/passwd and /etc/group files. For example, to check if entries for puppet, apache, foreman and foreman-proxy groups exist in both /etc/passwd and /etc/group files, enter the following commands:
# cat /etc/passwd | grep 'puppet\|apache\|foreman\|foreman-proxy'
# cat /etc/group | grep 'puppet\|apache\|foreman\|foreman-proxy'
Scenarios for Configuring External Authentication
Foreman supports the following general scenarios for configuring external authentication:
  • Using Lightweight Directory Access Protocol (LDAP) server as an external identity provider. LDAP is a set of open protocols used to access centrally stored information over a network. With Foreman, you can manage LDAP entirely through the Foreman web UI. For more information, see Using LDAP. Though you can use LDAP to connect to a FreeIPA or AD server, the setup does not support server discovery, cross-forest trusts, or single sign-on with Kerberos in Foreman’s web UI.
  • Using a FreeIPA server as an external identity provider. FreeIPA deals with the management of individual identities, their credentials and privileges used in a networking environment. Configuration using FreeIPA cannot be completed using only the Foreman web UI and requires some interaction with the CLI. For more information see Using FreeIPA.
  • Using Active Directory (AD) integrated with FreeIPA through cross-forest Kerberos trust as an external identity provider. For more information see Active Directory with Cross-Forest Trust.
  • Using Keycloak as an OpenID provider for external authentication to Foreman. For more information, see Configuring Foreman with Keycloak Authentication.
  • Using Keycloak as an OpenID provider for external authentication to Foreman with TOTP. For more information, see Configuring Keycloak Authentication with TOTP.
  • Using Keycloak as an OpenID provider for external authentication to Foreman with PIV cards. For more information, see Configuring Keycloak Authentication with PIV Cards.
As well as providing access to Foreman server, hosts provisioned with Foreman can also be integrated with FreeIPA realms. Foreman has a realm feature that automatically manages the life cycle of any system registered to a realm or domain provider. For more information, see External Authentication for Provisioned Hosts.
Table 7. Authentication Overview
Type Authentication User Groups
FreeIPA
Kerberos or LDAP
Active Directory
Kerberos or LDAP
POSIX
LDAP
12.1. Using LDAP
Foreman supports LDAP authentication using one or multiple LDAP directories.
If you require Foreman to use TLS to establish a secure LDAP connection (LDAPS), first obtain certificates used by the LDAP server you are connecting to and mark them as trusted on the base operating system of your Foreman server as described below. If your LDAP server uses a certificate chain with intermediate certificate authorities, all of the root and intermediate certificates in the chain must be trusted, so ensure all certificates are obtained. If you do not require secure LDAP at this time, proceed to Configuring Foreman to use LDAP.
Using SSSD Configuration
Though direct LDAP integration is covered in this section, Red Hat recommends that you use SSSD and configure it against FreeIPA, AD, or an LDAP server. SSSD improves the consistency of the authentication process. For more information about the preferred configurations, see Using Active Directory. You can also cache the SSSD credentials and use them for LDAP authentication. For more information on SSSD, see Configuring SSSD in the Red Hat Enterprise Linux 7 System-Level Authentication Guide.
12.1.1. Configuring TLS for Secure LDAP
Use the Foreman CLI to configure TLS for secure LDAP (LDAPS).
  1. Obtain the Certificate from the LDAP Server.
    1. If you use Active Directory Certificate Services, export the Enterprise PKI CA Certificate using the Base-64 encoded X.509 format. See How to configure Active Directory authentication with TLS on Foreman for information on creating and exporting a CA certificate from an Active Directory server.
    2. Download the LDAP server certificate to a temporary location on the Red Hat Enterprise Linux system where Foreman server is installed and remove it when finished.
      For example, /tmp/example.crt. The filename extensions .cer and .crt are only conventions and can refer to DER binary or PEM ASCII format certificates.
  2. Trust the Certificate from the LDAP Server.
    Foreman Server requires the CA certificates for LDAP authentication to be individual files in /etc/pki/tls/certs/ directory.
    1. Use the install command to install the imported certificate into the /etc/pki/tls/certs/ directory with the correct permissions:
      # install /tmp/example.crt /etc/pki/tls/certs/
    2. Enter the following command as root to trust the example.crt certificate obtained from the LDAP server:
      # ln -s example.crt /etc/pki/tls/certs/$(openssl \
      x509 -noout -hash -in \
      /etc/pki/tls/certs/example.crt).0
    3. Restart the httpd service:
      # systemctl restart httpd
12.1.2. Configuring Foreman to use LDAP
In the Foreman web UI, configure Foreman to use LDAP.
Note that if you need single sign-on functionality with Kerberos on Foreman’s web UI, you should use FreeIPA and AD external authentication instead. See Using FreeIPA or Using Active Directory for more information on those options.
  1. Set the Network Information System (NIS) service boolean to true to prevent SELinux from stopping outgoing LDAP connections:
    # setsebool -P nis_enabled on
  2. Navigate to Administer > LDAP Authentication.
  3. Click Create Authentication Source.
  4. On the LDAP server tab, enter the LDAP server’s name, host name, port, and server type. The default port is 389, the default server type is POSIX (alternatively you can select FreeIPA or Active Directory depending on the type of authentication server). For TLS encrypted connections, select the LDAPS check box to enable encryption. The port should change to 636, which is the default for LDAPS.
  5. On the Account tab, enter the account information and domain name details. See Description of LDAP Settings for descriptions and examples.
  6. On the Attribute mappings tab, map LDAP attributes to Foreman attributes. You can map login name, first name, last name, email address, and photo attributes. See Example Settings for LDAP Connections for examples.
  7. On the Locations tab, select locations from the left table. Selected locations are assigned to users created from the LDAP authentication source, and available after their first login.
  8. On the Organizations tab, select organizations from the left table. Selected organizations are assigned to users created from the LDAP authentication source, and available after their first login.
  9. Click Submit.
  10. Configure new accounts for LDAP users:
    • If you did not select Automatically Create Accounts In Foreman check box, see Creating a User to create user accounts manually.
    • If you selected the Automatically Create Accounts In Foreman check box, LDAP users can now log in to Foreman using their LDAP accounts and passwords. After they log in for the first time, the Foreman administrator has to assign roles to them manually. See Assigning Roles to a User to assign user accounts appropriate roles in Foreman.
12.1.3. Description of LDAP Settings
Table 8. Account Tab Settings
Setting Description
Account
The user name of the LDAP account that has read access to the LDAP server. User name is not required if the server allows anonymous reading, otherwise use the full path to the user’s object. For example:
uid=$login,cn=users,cn=accounts,dc=example,dc=com
The $login variable stores the username entered on the login page as a literal string. The value is accessed when the variable is expanded.
The variable cannot be used with external user groups from an LDAP source because Foreman needs to retrieve the group list without the user logging in. Use either an anonymous, or dedicated service user.
Account password
The LDAP password for the user defined in the Account username field. This field can remain blank if the Account username is using the $login variable.
Base DN
The top level domain name of the LDAP directory.
Groups base DN
The top level domain name of the LDAP directory tree that contains groups.
LDAP filter
A filter to restrict LDAP queries.
If this check box is selected, Foreman creates user accounts for LDAP users when they log in to Foreman for the first time. After they log in for the first time, the Foreman administrator has to assign roles to them manually. See Assigning Roles to a User to assign user accounts appropriate roles in Foreman.
Usergroup Sync
If this option is selected, the user group membership of a user is automatically synchronized when the user logs in, which ensures the membership is always up to date. If this option is cleared, Foreman relies on a cron job to regularly synchronize group membership (every 30 minutes by default). See To Configure an External User Group: for further context.
12.1.4. Example Settings for LDAP Connections
Table 9. Example Settings for Active Directory, Free IPA or Red Hat Identity Management and POSIX LDAP Connections
Setting Active Directory FreeIPA or Red Hat Identity Management POSIX (OpenLDAP)
Account
DOMAIN\redhat
uid=redhat,cn=users, cn=accounts,dc=example, dc=com
uid=redhat,ou=users, dc=example,dc=com
Account password
P@ssword
Base DN
DC=example,DC=COM
dc=example,dc=com
dc=example,dc=com
Groups Base DN
CN=Users,DC=example,DC=com
cn=groups,cn=accounts, dc=example,dc=com
cn=employee,ou=userclass, dc=example,dc=com
Login name attribute
userPrincipalName
uid
uid
First name attribute
givenName
givenName
givenName
Last name attribute
sn
sn
sn
Email address attribute
mail
mail
mail
userPrincipalName allows the use of whitespace in usernames. The login name attribute sAMAccountName (which is not listed in the table above) provides backwards compatibility with legacy Microsoft systems. sAMAccountName does not allow the use of whitespace in usernames.
12.1.5. Example LDAP Filters
As an administrator, you can create LDAP filters to restrict the access of specific users to Foreman.
Table 10. Example filters for allowing specific users to login
User Filter
User1, User3
(memberOf=cn=Group1,cn=Users,dc=domain,dc=example)
User2, User3
(memberOf=cn=Group2,cn=Users,dc=domain,dc=example)
User1, User2, User3
(|(memberOf=cn=Group1,cn=Users,dc=domain,dc=example)(memberOf=cn=Group2,cn=Users,dc=domain,dc=example))
LDAP directory structure
DC=Domain,DC=Example
   |----- CN=Users
         |----- CN=Group1
         |----- CN=Group2
         |----- CN=User1
         |----- CN=User2
         |----- CN=User3
LDAP group membership
Group Members
Group1
User1, User3
Group2
User2, User3
12.2. Using FreeIPA
This section shows how to integrate Foreman Server with a FreeIPA server and how to enable host-based access control.
You can attach FreeIPA as an external authentication source with no single sign-on support. For more information, see Using LDAP.
  • Foreman server has to run on Red Hat Enterprise Linux 7.1 or later.
  • The base operating system of Foreman server must be enrolled in the FreeIPA domain by the FreeIPA administrator of your organization.
The examples in this chapter assume separation between FreeIPA and Foreman configuration. However, if you have administrator privileges for both servers, you can configure FreeIPA as described in Red Hat Enterprise Linux 7 Linux Domain Identity, Authentication, and Policy Guide.
12.2.1. Configuring FreeIPA Authentication on Foreman server
In the Foreman CLI, configure FreeIPA authentication by first creating a host entry on the FreeIPA server.
  1. On the FreeIPA server, to authenticate, enter the following command and enter your password when prompted:
    # kinit admin
  2. To verify that you have authenticated, enter the following command:
    # klist
  3. On the FreeIPA server, create a host entry for Foreman server and generate a one-time password, for example:
    The generated one-time password must be used on the client to complete FreeIPA-enrollment.
    For more information on host configuration properties, see About Host Entry Configuration Properties in the Red Hat Enterprise Linux 7 Linux Domain Identity, Authentication, and Policy guide.
  4. Create an HTTP service for Foreman server, for example:
    # ipa service-add HTTP/hostname
    For more information on managing services, see Managing Services in the Red Hat Enterprise Linux 7 Linux Domain Identity, Authentication, and Policy guide.
  5. On Foreman server, install the IPA client:
    # yum install ipa-client
  6. On Foreman server, enter the following command as root to configure FreeIPA-enrollment:
  7. If Foreman server is running on Red Hat Enterprise Linux 7, execute the following command:
    The installer is dependent on packages which, on Red Hat Enterprise Linux 7, are in the optional repository rhel-7-server-optional-rpms.
  8. Set foreman-ipa-authentication to true, using the following command:
    # foreman-installer --foreman-ipa-authentication=true
  9. Restart the foreman-maintain services:
External users can now log in to Foreman using their FreeIPA credentials. They can now choose to either log in to Foreman server directly using their username and password or take advantage of the configured Kerberos single sign-on and obtain a ticket on their client machine and be logged in automatically. The two-factor authentication with one-time password (2FA OTP) is also supported. If the user in FreeIPA is configured for 2FA, and Foreman server is running on Red Hat Enterprise Linux 7, this user can also authenticate to Foreman with an OTP.
12.2.2. Configuring Host-Based Authentication Control
HBAC rules define which machine within the domain a FreeIPA user is allowed to access. You can configure HBAC on the FreeIPA server to prevent selected users from accessing Foreman server. With this approach, you can prevent Foreman from creating database entries for users that are not allowed to log in. For more information on HBAC, see Configuring Host-Based Access Control in the Red Hat Enterprise Linux 7 Linux Domain Identity, Authentication, and Policy guide.
    # kinit admin
    # klist
  3. Create HBAC service and rule on the FreeIPA server and link them together. The following examples use the PAM service name foreman-prod. Execute the following commands on the FreeIPA server:
    # ipa hbacsvc-add foreman-prod
    # ipa hbacrule-add allow_foreman_prod
    # ipa hbacrule-add-service allow_foreman_prod --hbacsvcs=foreman-prod
  4. Add the user who is to have access to the service foreman-prod, and the hostname of Foreman server:
    # ipa hbacrule-add-user allow_foreman_prod --user=username
    # ipa hbacrule-add-host allow_foreman_prod --hosts=foreman.example.com
    Alternatively, host groups and user groups can be added to the allowforeman_prod_ rule.
  5. To check the status of the rule, execute:
    # ipa hbacrule-find foreman-prod
    # ipa hbactest --user=username --host=foreman.example.com --service=foreman-prod
  6. Ensure the allow_all rule is disabled on the FreeIPA server. For instructions on how to do so without disrupting other services see the How to configure HBAC rules in IdM article on the Red Hat Customer Portal.
  7. Configure the FreeIPA integration with Foreman server as described in Configuring FreeIPA Authentication on Foreman server. On Foreman server, define the PAM service as root:
    # foreman-installer --foreman-pam-service=foreman-prod
12.3. Using Active Directory
This section shows how to use direct Active Directory (AD) as an external authentication source for Foreman server.
You can attach Active Directory as an external authentication source with no single sign-on support. For more information, see Using LDAP. For an example configuration, see How to configure Active Directory authentication with TLS on Foreman.
Direct AD integration means that Foreman server is joined directly to the AD domain where the identity is stored. The recommended setup consists of two steps:
12.3.1. GSS-Proxy
The traditional process of Kerberos authentication in Apache requires the Apache process to have read access to the keytab file. GSS-Proxy allows you to implement stricter privilege separation for the Apache server by removing access to the keytab file while preserving Kerberos authentication functionality. When using AD as an external authentication source for Foreman, it is recommended to implement GSS-proxy, because the keys in the keytab file are the same as the host keys.
The AD integration requires Foreman Server to be deployed on Red Hat Enterprise Linux 7.1 or later.
Perform the following procedures on Red Hat Enterprise Linux that acts as a base operating system for your Foreman server. For the examples in this section EXAMPLE.ORG is the Kerberos realm for the AD domain. By completing the procedures, users that belong to the EXAMPLE.ORG realm can log in to Foreman server.
12.3.2. Enrolling Foreman server with the AD Server
In the Foreman CLI, enroll Foreman server with the Active Directory server.
  • GSS-proxy and nfs-utils are installed.
    # yum install gssproxy nfs-utils
  1. Install the required packages:
  2. Enroll Foreman server with the AD server. You may need to have administrator permissions to perform the following command:
    # realm join -v EXAMPLE.ORG
12.3.3. Configuring Direct AD Integration with GSS-proxy
In the Foreman CLI, configure the direct Active Directory integration with GSS-proxy.
Prerequisite
  1. Create the /etc/ipa/ directory and the default.conf file:
    # mkdir /etc/ipa
    # touch /etc/ipa/default.conf
  2. To the default.conf file, add the following content:
    [global]
    server = unused
    realm = EXAMPLE.ORG
  3. Create the /etc/net-keytab.conf file with the following content:
    [global]
    workgroup = EXAMPLE
    realm = EXAMPLE.ORG
    kerberos method = system keytab
    security = ads
  4. Determine the effective user ID of the Apache user:
    # id apache
  5. Create the /etc/gssproxy/00-http.conf file with the following content:
    [service/HTTP]
    mechs = krb5
    cred_store = keytab:/etc/krb5.keytab
    cred_store = ccache:/var/lib/gssproxy/clients/krb5cc_%U
    euid = ID_of_Apache_User
  6. Create a keytab entry:
    # KRB5_KTNAME=FILE:/etc/httpd/conf/http.keytab net ads keytab add HTTP -U administrator -d3 -s /etc/net-keytab.conf
    # chown root.apache /etc/httpd/conf/http.keytab
    # chmod 640 /etc/httpd/conf/http.keytab
  7. Enable IPA authenication in Foreman:
  8. Start and enable the gssproxy service:
    # systemctl restart gssproxy.service
    # systemctl enable gssproxy.service
  9. Configure the Apache server to use the gssproxy service:
    1. Create the /etc/systemd/system/httpd.service file with the following content:
      .include /lib/systemd/system/httpd.service
      [Service]
      Environment=GSS_USE_PROXY=1
    2. Apply changes to the service:
      # systemctl daemon-reload
  10. Start and enable the httpd service:
    # systemctl restart httpd.service
  11. Verify that SSO is working as expected.
    1. Retrieve the Kerberos ticket of the LDAP user, using the following command:
      # kinit ldapuser
    2. View the Kerberos ticket, using the following command:
      # klist
    3. View output from successful SSO-based authentication, using the following command:
      # curl -k -u : --negotiate https://foreman.example.com/users/extlogin
      <html><body>You are being <a href="https://foreman.example.com/users/4-ldapuserexample-com/edit">redirected</a>.</body></html>
12.3.4. Kerberos Configuration in Web Browsers
For information on configuring the Firefox browser see Configuring Firefox to Use Kerberos for Single Sign-On in the Red Hat Enterprise Linux System-Level Authentication guide.
If you use the Internet Explorer browser, add Foreman server to the list of Local Intranet or Trusted sites, and turn on the Enable Integrated Windows Authentication setting. See the Internet Explorer documentation for details.
With direct AD integration, HBAC through FreeIPA is not available. As an alternative, you can use Group Policy Objects (GPO) that enable administrators to centrally manage policies in AD environments. To ensure correct GPO to PAM service mapping, use the following sssd configuration:
access_provider = ad
ad_gpo_access_control = enforcing
ad_gpo_map_service = +foreman
Here, foreman is the PAM service name. For more information on GPOs, please refer to the Red Hat Enterprise Linux Windows Integration Guide.
12.3.5. Active Directory with Cross-Forest Trust
Kerberos can create cross-forest trust that defines a relationship between two otherwise separate domain forests. A domain forest is a hierarchical structure of domains; both AD and FreeIPA constitute a forest. With a trust relationship enabled between AD and FreeIPA, users of AD can access Linux hosts and services using a single set of credentials. For more information on cross-forest trusts, see Creating Cross-forest Trusts with Active Directory and Identity Management in the Red Hat Enterprise Linux Windows Integration guide.
From the Foreman point of view, the configuration process is the same as integration with FreeIPA server without cross-forest trust configured. Foreman server has to be enrolled in the IPM domain and integrated as described in Using FreeIPA.
12.3.6. Configuring the FreeIPA Server to Use Cross-Forest Trust
  1. Enable HBAC:
    1. Create an external group and add the AD group to it.
    2. Add the new external group to a POSIX group.
    3. Use the POSIX group in a HBAC rule.
  2. Configure sssd to transfer additional attributes of AD users.
    • Add the AD user attributes to the nss and domain sections in /etc/sssd/sssd.conf.
      For example:
      [nss]
      user_attributes=+mail, +sn, +givenname
      [domain/EXAMPLE]
      ldap_user_extra_attrs=mail, sn, givenname
12.4. Configuring External User Groups
Foreman does not associate external users with their user group automatically. You must create a user group with the same name as in the external source on Foreman. Members of the external user group then automatically become members of the Foreman user group and receive the associated permissions.
  • If you use an LDAP server, configure Foreman to use LDAP authentication. For more information see Using LDAP.
    When using external user groups from an LDAP source, you cannot use the $login variable as a substitute for the account user name. You must use either an anonymous or dedicated service user.
  • If you use a FreeIPA or AD server, configure Foreman to use FreeIPA or AD authentication. For more information, see Configuring External Authentication.
  • Ensure that at least one external user authenticates for the first time.
  • Retain a copy of the external group names you want to use. To find the group membership of external users, enter the following command:
    # id username
  1. In the Foreman web UI, navigate to Administer > User Groups, and click Create User Group.
  2. Specify the name of the new user group. Do not select any users to avoid adding users automatically when you refresh the external user group.
  3. Click the Roles tab and select the roles you want to assign to the user group. Alternatively, select the Administrator check box to assign all available permissions.
  4. Click the External groups tab, then click Add external user group, and select an authentication source from the Auth source drop-down menu.
  5. Click Submit.
12.5. Refreshing External User Groups for LDAP
  1. Navigate to Administer > Usergroups and select a user group.
  2. Navigate to the External Groups tab and click Refresh to the right of the required user group.
CLI procedure
  • Enter the following command:
12.6. Refreshing External User Groups for FreeIPA or AD
External user groups based on FreeIPA or AD are refreshed only when a group member logs in to Foreman. It is not possible to alter user membership of external user groups in the Foreman web UI, such changes are overwritten on the next group refresh.
12.7. External Authentication for Provisioned Hosts
Use this section to configure Foreman server or Smart Proxy server for FreeIPA realm support, then add hosts to the FreeIPA realm group.
You require the following setup to configure external authentication for provisioned hosts:
  • Foreman server that is registered to the Content Delivery Network or an external Smart Proxy server that is registered to Foreman server.
  • A deployed realm or domain provider such as FreeIPA.
To install and configure FreeIPA packages on Foreman Server or Foreman Smart Proxy server:
To use FreeIPA for provisioned hosts, complete the following steps to install and configure FreeIPA packages on Foreman Server or Foreman Smart Proxy server:
  1. Install the ipa-client package on Foreman server or Smart Proxy server:
  2. Configure the server as a FreeIPA client:
  3. Create a realm proxy user, realm-smart-proxy, and the relevant roles in FreeIPA:
    # foreman-prepare-realm admin realm-smart-proxy
To configure Foreman server or Smart Proxy server for FreeIPA Realm Support:
Complete the following procedure on Foreman and every Smart Proxy that you want to use:
  1. Copy the /root/freeipa.keytab file to any Smart Proxy server that you want to include in the same principal and realm:
    # scp /root/freeipa.keytab root@smartproxy.example.com:/etc/foreman-proxy/freeipa.keytab
  2. Move the /root/freeipa.keytab file to the /etc/foreman-proxy directory and set the ownership settings to the foreman-proxy user:
    # mv /root/freeipa.keytab /etc/foreman-proxy
    # chown foreman-proxy:foreman-proxy /etc/foreman-proxy/freeipa.keytab
  3. Enter the following command on all Smart Proxies that you want to include in the realm. If you use the integrated Smart Proxy on Foreman, enter this command on Foreman server:
    # foreman-installer --foreman-proxy-realm true \
    --foreman-proxy-realm-keytab /etc/foreman-proxy/freeipa.keytab \
    --foreman-proxy-realm-principal realm-smart-proxy@EXAMPLE.COM \
    --foreman-proxy-realm-provider freeipa
    You can also use these options when you first configure the Foreman Server.
  4. Ensure that the most updated versions of the ca-certificates package is installed and trust the FreeIPA Certificate Authority:
    # cp /etc/ipa/ca.crt /etc/pki/ca-trust/source/anchors/ipa.crt
    # update-ca-trust enable
    # update-ca-trust
  5. Optional: If you configure FreeIPA on an existing Foreman server or Smart Proxy server, complete the following steps to ensure that the configuration changes take effect:
    1. Restart the foreman-proxy service:
    2. In the Foreman web UI, navigate to Infrastructure > Smart Proxies.
    3. Locate the Smart Proxy you have configured for FreeIPA and from the list in the Actions column, select Refresh.
To create a realm for the FreeIPA-enabled Smart Proxy
After you configure your integrated or external Smart Proxy with FreeIPA, you must create a realm and add the FreeIPA-configured Smart Proxy to the realm.
To create a realm, complete the following steps:
  1. In the Foreman web UI, navigate to Infrastructure > Realms and click Create Realm.
  2. In the Name field, enter a name for the realm.
  3. From the Realm Type list, select the type of realm.
  4. From the Realm Smart Proxy list, select Smart Proxy server where you have configured FreeIPA.
  5. Click the Locations tab and from the Locations list, select the location where you want to add the new realm.
  6. Click the Organizations tab and from the Organizations list, select the organization where you want to add the new realm.
  7. Click Submit.
Updating Host Groups with Realm Information
  1. Navigate to Configure > Host Groups, select the host group that you want to update, and click the Network tab.
  2. From the Realm list, select the realm you create as part of this procedure, and then click Submit.
Adding Hosts to a FreeIPA Host Group
FreeIPA supports the ability to set up automatic membership rules based on a system’s attributes. Foreman’s realm feature provides administrators with the ability to map the Foreman host groups to the FreeIPA parameter userclass which allow administrators to configure automembership.
When nested host groups are used, they are sent to the FreeIPA server as they are displayed in the Foreman User Interface. For example, "Parent/Child/Child".
Foreman server or Smart Proxy server sends updates to the FreeIPA server, however automembership rules are only applied at initial registration.
To Add Hosts to a FreeIPA Host Group:
  1. On the FreeIPA server, create a host group:
  2. Create an automembership rule:
    # ipa automember-add --type=hostgroup hostgroup_name automember_rule
    • automember-add flags the group as an automember group.
    • --type=hostgroup identifies that the target group is a host group, not a user group.
    • automember_rule adds the name you want to identify the automember rule by.
  3. Define an automembership condition based on the userclass attribute:
    # ipa automember-add-condition --key=userclass --type=hostgroup --inclusive-regex=^webserver hostgroup_name
    Added condition(s) to "hostgroup_name"
    Automember Rule: automember_rule
    Inclusive Regex: userclass=^webserver
    Number of conditions added 1
    • automember-add-condition adds regular expression conditions to identify group members.
    • --key=userclass specifies the key attribute as userclass.
    • --inclusive-regex= ^webserver identifies matching values with a regular expression pattern.
    • hostgroup_name - identifies the target host group’s name.
When a system is added to Foreman server’s hostgroup_name host group, it is added automatically to the FreeIPA server’s "hostgroup_name" host group. FreeIPA host groups allow for Host-Based Access Controls (HBAC), sudo policies and other FreeIPA functions.
12.8. Configuring Foreman with Keycloak Authentication
Use this section to configure Foreman to use Keycloak as an OpenID provider for external authentication.
12.8.1. Prerequisites for Configuring Foreman with Keycloak Authentication
Before configuring Foreman with Keycloak external authentication, ensure that you meet the following requirements:
  • A working installation of Keycloak server that uses HTTPS instead of HTTP.
  • A Keycloak account with admin privileges.
  • A realm for Foreman user accounts created in Keycloak.
  • If the certificates or the CA are self-signed, ensure that they are added to the end-user certificate trust store.
  • Users imported or added to Keycloak.
    If you have an existing user database configured such as LDAP or Kerberos, you can import users from it by configuring user federation. For more information, see User Storage Federation in the Red Hat Single Sign-On Server Administration Guide.
    If you do not have an existing user database configured, you can manually create users in Keycloak. For more information, see Creating New Users in the Red Hat Single Sign-On Server Administration Guide.
12.8.2. Registering Foreman as a Keycloak Client
Use this procedure to register Foreman to Keycloak as a client and configure Foreman to use Keycloak as an authentication source.
You can configure Foreman and Keycloak with two different authentication methods:
  1. Users authenticate to Foreman using the Foreman web UI.
  2. Users authenticate to Foreman using the Foreman CLI.
You must decide on how you want your users to authenticate in advance because both methods require different Foreman clients to be registered to Keycloak and configured. The steps to register and configure Foreman client in Keycloak are distinguished within the procedure.
You can also register two different Foreman clients to Keycloak if you want to use both authentication methods and configure both clients accordingly.
  1. On the Foreman server, install the following packages:
  2. Register Foreman to Keycloak as a client. Note that you the registration process for logging in using the web UI and the CLI are different. You can register two clients Foreman clients to Keycloak to be able to log in to Foreman from the web UI and the CLI.
    • If you want you users to authenticate to Foreman using the web UI, create a client as follows:
      # keycloak-httpd-client-install --app-name foreman-openidc \
      --keycloak-server-url "https://Keycloak.example.com" \
      --keycloak-admin-username "admin" \
      --keycloak-realm "Foreman_Realm" \
      --keycloak-admin-realm master \
      --keycloak-auth-role root-admin \
      -t openidc -l /users/extlogin --force
      Enter the password for the administer account when prompted. This command creates a client for Foreman in Keycloak.
      Then, configure Foreman to use Keycloak as an authentication source:
      # satellite-installer --foreman-keycloak true \
      --foreman-keycloak-app-name "foreman-openidc" \
      --foreman-keycloak-realm "Foreman_Realm"
    • If you want your users to authenticate to Foreman using the CLI, create a client as follows:
      # keycloak-httpd-client-install --app-name hammer-openidc \
12.8.3. Configuring the Foreman Client in Keycloak
Use this procedure to configure the Foreman client in the Keycloak web UI and create group and audience mappers for the Foreman client.
  1. In the Keycloak web UI, navigate to Clients and click the Foreman client.
  2. Configure access type:
    • If you want your users to authenticate to Foreman using the web UI, from the Access Type list, select confidential.
    • If you want your users to authenticate to Foreman using the CLI, from the Access Type list, select public.
  3. In the Valid redirect URI fields, add a valid redirect URI.
    • If you want your users to authenticate to Foreman using the web UI, in the blank field below the existing URI, enter a URI in the form https://foreman.example.com/users/extlogin. Note that you must add the string /users/extlogin after the Foreman FQDN.
      After completing this step, the Foreman client for logging in using the web UI must have the following Valid Redirect URIs:
      https://foreman.example.com/users/extlogin/redirect_uri
    • If you want your users to authenticate to Foreman using the CLI, in the blank field below the existing URI, enter urn:ietf:wg:oauth:2.0:oob.
      After completing this step, the Foreman client for logging in using the CLI must have the following Valid Redirect URIs:
  4. Click Save.
  5. Click the Mappers tab and click Create to add an audience mapper.
  6. In the Name field, enter a name for the audience mapper.
  7. From the Mapper Type list, select Audience.
  8. From the Included Client Audience list, select the Foreman client.
  9. Click Save.
  10. Click Create to add a group mapper so that you can specify authorization in Foreman based on group membership.
  11. In the Name field, enter a name for the group mapper.
  12. From the Mapper Type list, select Group Membership.
  13. In the Token Claim Name field, enter groups.
  14. Set the Full group path setting to OFF.
  15. Click Save.
12.8.4. Configuring Foreman Settings for Keycloak Authentication
Use this section to configure Foreman for Keycloak authentication using the Foreman web UI or the CLI.
Configuring Foreman Settings for Keycloak Authentication Using the Web UI
Use this procedure to configure Foreman settings for Keycloak authentication using the Foreman web UI.
Note that you can navigate to the following URL within your realm to obtain values to configure Foreman settings: https://Keycloak.example.com/auth/realms/Foreman_Realm/.well-known/openid-configuration
Prerequisite
  • Ensure that the Access Type setting in the Foreman client in the Keycloak web UI is set to confidential
  1. In the Foreman web UI, navigate to Administer > Settings, and click the Authentication tab.
  2. Locate the Authorize login delegation row, and in the Value column, set the value to Yes.
  3. Locate the Authorize login delegation auth source user autocreate row, and in the Value column, set the value to External.
  4. Locate the Login delegation logout URL row, and in the Value column, set the value to https://foreman.example.com/users/extlogout.
  5. Locate the OIDC Algorithm row, and in the Value column, set the algorithm for encoding on Keycloak to RS256.
  6. Locate the OIDC Audience row, and in the Value column, set the value to the client ID for Keycloak.
  7. Locate the OIDC Issuer row, and in the Value column, set the value to https://Keycloak.example.com/auth/realms/Foreman_Realm.
  8. Locate the OIDC JWKs URL row, and in the Value column, set the value to https://Keycloak.example.com/auth/realms/Foreman_Realm/protocol/openid-connect/certs.
  9. Navigate to Administer > Authentication Sources and click External.
  10. Click Create LDAP Authentication Source and select the Keycloak server.
  11. Click the Locations tab and add locations that can use the Keycloak authentication source.
  12. Click the Organizations tab and add organizations that can use the Keycloak authentication source.
  13. Click Submit.
Configuring Foreman Settings for Keycloak Authentication Using the CLI
Use this procedure to configure Foreman settings for Keycloak authentication using the Foreman CLI.
Prerequisite
  • Ensure that the Access Type setting in the Foreman client in the Keycloak web UI is set to public
  1. On Foreman, set the login delegation to true so that users can authenticate using the Open IDC protocol:
    # hammer settings set --name authorize_login_delegation --value true
  2. Set the login delegation logout URL:
    # hammer settings set --name login_delegation_logout_url \
    --value https://foreman.example.com/users/extlogout
  3. Set the algorithm for encoding on Keycloak, for example, RS256:
    # hammer settings set --name oidc_algorithm --value 'RS256'
  4. Open the Keycloak.example.com/auth/realms/Keycloak_REALM/.well-known/openid-configuration URL and note the values to populate the options in the following steps.
  5. Add the value for the Hammer client in the Open IDC audience:
    # hammer settings set --name oidc_audience \
    --value "['foreman.example.com-hammer-openidc']"
    If you register several Keycloak clients to Foreman, ensure that you append all audiences in the array. For example:
    --value "['foreman.example.com-foreman-openidc', 'foreman.example.com-hammer-openidc']"
  6. Set the value for the Open IDC issuer:
    # hammer settings set --name oidc_issuer \
    --value "Keycloak.example.com/auth/realms/Keycloak_Realm"
  7. Set the value for Open IDC Java Web Token (JWT):
    # hammer settings set --name oidc_jwks_url \
    --value "Keycloak.example.com/auth/realms/Keycloak_Realm/protocol/openid-connect/certs"
  8. Retrieve the ID of the Keycloak authentication source:
  9. Set the location and organization:
    # hammer auth-source external update --id Authentication Source ID \
    --location-ids Location ID --organization-ids Organization ID
12.8.5. Logging in to the Foreman Web UI Using Keycloak
Use this procedure to log in to the Foreman web UI using Keycloak.
  • In your browser, log in to Foreman and enter your credentials.
12.8.6. Logging in to the Foreman CLI Using Keycloak
Use this procedure to authenticate to the Foreman CLI using the code grant type.
  1. To authenticate to the Foreman CLI using the code grant type, enter the following command:
    # hammer auth login oauth \
    --two-factor \
    --oidc-token-endpoint 'https://Keycloak.example.com/auth/realms/ssl-realm/protocol/openid-connect/token' \
    --oidc-authorization-endpoint 'https://Keycloak.example.com/auth' \
    --oidc-client-id 'foreman.example.com-foreman-openidc' \
    --oidc-redirect-uri urn:ietf:wg:oauth:2.0:oob
  2. To retrieve the success code, navigate to the URL that the command returns and provide the required information.
  3. Copy the success code that the web UI returns.
  4. In the command prompt of hammer auth login oauth, enter the success code to authenticate to the Foreman CLI.
12.8.7. Configuring Group Mapping for Keycloak Authentication
Optionally, to implement the Role Based Access Control (RBAC), create a group in Foreman, assign a role to this group, and then map an Active Directory group to the Foreman group. As a result, anyone in the given group in Keycloak are logged in under the corresponding Foreman group. This example configures users of the Foreman-admin user group in the Active Directory to authenticate as users with administrator privileges on Foreman.
  1. In the Foreman web UI, navigate to Administer > User Groups, and click the Create User Group button.
  2. In the Name field, enter a name for the user group. The name should not be the same as in the Active Directory.
  3. Do not add users and user groups to the right-hand columns. Click the Roles tab.
  4. Select the Administer check box.
  5. Click the External Groups tab.
  6. Click Add external user group.
  7. In the Name field, enter the name of the Active Directory group.
  8. From the list, select EXTERNAL.
12.9. Configuring Keycloak Authentication with TOTP
Use this section to configure Foreman to use Keycloak as an OpenID provider for external authentication with TOTP cards.
12.9.1. Prerequisites for Configuring Foreman with Keycloak Authentication
12.9.2. Registering Foreman as a Keycloak Client
12.9.3. Configuring the Foreman Client in Keycloak
  4. Click Save.
  9. Click Save.
  15. Click Save.
12.9.4. Configuring Foreman Settings for Keycloak Authentication
Prerequisite
  13. Click Submit.
Prerequisite
12.9.5. Configuring Foreman with Keycloak for TOTP Authentication
Use this procedure to configure Foreman to use Keycloak as an OpenID provider for external authentication with Time-based One-time Password (TOTP).
  1. In the Keycloak web UI, navigate to the Foreman realm.
  2. Navigate to Authentication, and click the OTP Policy tab.
  3. Ensure that the Supported Applications field includes FreeOTP or Google Authenticator.
  4. Configure the OTP settings to suit your requirements.
  5. Optional: If you want to use TOTP authentication as a default authentication method for all users, click the Flows tab, and to the right of the OTP Form setting, select REQUIRED.
  6. Click the Required Actions tab.
  7. To the right of the Configure OTP row, select the Default Action check box.
12.9.6. Logging in to the Foreman Web UI Using Keycloak TOTP Authentication
Use this procedure to log in to the Foreman web UI using Keycloak TOTP authentication.
  1. Log in to Foreman, Foreman redirects you to the Keycloak login screen.
  2. Enter your username and password, and click Log In.
  3. The first attempt to log in, Keycloak requests you to configure your client by scanning the barcode and entering the pin displayed.
  4. After you configure your client and enter a valid PIN, Keycloak redirects you to Foreman and logs you in.
12.9.7. Logging in to the Foreman CLI Using Keycloak
    --two-factor \
12.9.8. Configuring Group Mapping for Keycloak Authentication
12.10. Configuring Keycloak Authentication with PIV Cards
Use this section to configure Foreman to use Keycloak as an OpenID provider for external authentication with PIV cards.
12.10.1. Prerequisites for Configuring Foreman with Keycloak Authentication
12.10.2. Registering Foreman as a Keycloak Client
12.10.3. Configuring the Foreman Client in Keycloak
  4. Click Save.
  9. Click Save.
  15. Click Save.
12.10.4. Configuring Foreman Settings for Keycloak Authentication
Prerequisite
  13. Click Submit.
Prerequisite
12.10.5. Configuring Keycloak Settings for Authentication With PIV Cards
You must configure Keycloak settings for authentication with PIV cards.
  1. In the Keycloak web UI, navigate to the Authentication tab.
  2. From the Flows list, select Browser.
  3. Click Copy to copy this flow.
  4. In the Copy Authentication Flow window, enter a new name for the flow and click OK.
  5. In the copied flow, delete Username Password Form and OTP Form entries.
  6. Click Add execution.
  7. From the Provider list, select X509/Validate Username Form.
  8. Click Save.
  9. In the X509/Validate Username Form raw, select ALTERNATIVE.
  10. In the X509/Validate Username Form raw, click Actions > Config.
  11. In the Alias field, enter a name for this configuration.
  12. From the User Identity Source list, select Subject’s Common Name,
  13. From the User mapping method list, select Username or Email.
  14. Click Save.
  15. Navigate to Authentication > Bindings.
  16. From the Browser Flow list, select the created flow.
12.10.6. Configuring Users' OS for Keycloak Authentication with PIV Cards
Complete this procedure on each system from which you want to be able to log in to Foreman using Keycloak PIV cards.
  1. Install required packages:
    yum install opensc -y
  2. Install the Firefox browser if not installed.
  3. Launch Firefox and navigate to Preferences.
  4. Click the Privacy and Security tab.
  5. Click Security Devices.
  6. Click Load.
  7. In the Load PKCS#11 Device Driver window, in the Module Name field, enter a name for this device.
  8. In the Module filename field, enter /usr/lib64/pkcs11/opensc-pkcs11.so.
  9. Click OK.
  10. If the PIV card is connected to system, restart the pcscd service.
12.10.7. Logging in to the Foreman Web UI Using Keycloak PIV Cards
Use this procedure to log in to the Foreman web UI using the Keycloak PIV cards.
  1. In Firefox, log in to Foreman and enter your credentials.
  2. When prompted, enter the PIN of the PIV card.
  3. Choose the certificate for authentication. Browser verifies this certificate with Keycloak. Once authenticated, browser redirects you back to Foreman and logs you in.
12.10.8. Logging in to the Foreman CLI Using Keycloak
    --two-factor \
12.10.9. Configuring Group Mapping for Keycloak Authentication
12.11. Disabling Keycloak Authentication
If you want to disable Keycloak authentication in Foreman, complete this procedure.
  • Enter the following command to disable Keycloak Authentication:
    # foreman-installer --reset-foreman-keycloak
13. Monitoring Resources
The following chapter details how to configure monitoring and reporting for managed systems. This includes host configuration, content views, compliance, subscriptions, registered hosts, promotions and synchronization.
13.1. Using the Foreman Content Dashboard
Navigate to Monitor > Dashboard to access the content dashboard. The dashboard can be rearranged by clicking on a widget and dragging it to a different position. The following widgets are available:
Host Configuration Status
Table 11. Host Configuration States
Icon State Description
1
2
Hosts in error state
3
4
5
Out of sync hosts
6
Hosts with no reports
7
Hosts with alerts disabled
Host Configuration Chart
Latest Events
New Hosts
Task Status
Latest Warning/Error Tasks
Discovered Hosts
Latest Errata
Content Views
Sync Overview
Host Subscription Status
Table 12. Host Subscription States
1229
Invalid
1230
Partial
1228
Valid
Subscription Status
Host Collections
Virt-who Configuration Status
Table 13. Virt-who Configuration States
State Description
No Reports
No Change
OK
Total Configurations
Latest Compliance Reports
Compliance Reports Breakdown
Red Hat Insights Actions
Red Hat Insights Risk Summary
13.1.1. Managing Tasks
To Adjust Timeout Settings:
  1. Navigate to Administer > Settings.
  5. Click Save.
13.2. Configuring RSS Notifications
  1. Navigate to Administer > Settings and select the Notifications tab.
13.3. Monitoring Foreman server
From the About page in Foreman server web UI, you can find an overview of the following:
  • System Status, including Smart Proxies, Available Providers, Compute Resources, and Plug-ins
  • Support information
  • System Information
  • Backend System Status
  • Installed packages
  • In the upper right corner of Foreman server web UI, click Administer > About.
After Pulp failure, the status of Pulp might show OK instead of Error for up to 10 minutes due to synchronization delay.
13.4. Monitoring Smart Proxy server
13.4.1. Viewing General Smart Proxy Information
Navigate to Infrastructure > Smart Proxies to view a table of Smart Proxy servers registered to Foreman server. The information contained in the table answers the following questions:
After changing the Smart Proxy configuration, select Refresh from the drop-down menu in the Actions column to make sure the Smart Proxy table is up to date.
13.4.2. Monitoring Services
Navigate to Infrastructure > Smart Proxies and click the name of the selected Smart Proxy. At the Services tab, you can find basic information on Smart Proxy services, such as the list of DNS domains, or the number of Pulp workers. The appearance of the page depends on what services are enabled on Smart Proxy server. Services providing more detailed status information can have dedicated tabs at the Smart Proxy page (see Monitoring Puppet).
13.4.3. Monitoring Puppet
Navigate to Infrastructure > Smart Proxies and click the name of the selected Smart Proxy. At the Puppet tab you can find the following:
14. Searching and Bookmarking
The Foreman web UI features powerful search functionality which is available on most pages of the web UI. It enables you to search all kinds of resources that Foreman server manages. Searches accept both free text and syntax-based queries, which can be built using extensive input prediction. Search queries can be saved as bookmarks for future reuse.
14.1. Building Search Queries
14.1.1. Query Syntax
parameter operator value
Available fields, resources to search, and the way the query is interpreted all depend on context, that is, the page where you perform the search. For example, the field "hostgroup" on the Hosts page is equivalent to the field "name" on the Host Groups page. The field type also determines available operators and accepted values. For a list of all operators, see Operators. For descriptions of value formats, see Values.
14.1.2. Operators
Table 14. Comparison Operators Accepted by Search
EQUALS
hostgroup = RHEL7
NOT EQUALS
LIKE
hostgroup ~ rhel%
NOT LIKE
GREATER THAN
registered_at <= Yesterday
LESS THAN
IN
release_version !^ 7
NOT IN
HAS or set?
NOT HAS or null?
Table 15. Logical Operators Accepted by Search
and
<whitespace>
or
not
14.1.3. Values
Text Values
Examples:
hostgroup = "Web servers"
hostgroup = Web servers
Temporal Values
  • "10 January 2017"
  • "10 Jan 2017"
  • 10-January-2017
  • 10/January/2017
  • "January 10, 2017"
Warning
14.3. Managing Bookmarks
14.3.1. Creating Bookmarks
To Create a Bookmark:
  1. Navigate to the page where you want to create a bookmark.
  6. Ensure the Public check box is set correctly:
    • Select the Public check box to set the bookmark as public and visible to all users.
    • Clear the Public check box to set the bookmark as private and only visible to the user who created it.
  7. Click Submit.
14.3.2. Deleting Bookmarks
To Delete a Bookmark:
  1. Navigate to Administer > Bookmarks.
Appendix A: Foreman Settings
This section contains noteworthy information or known issues about settings that you can edit in the Foreman web UI by navigating to Administer > Settings.
Table 16. General Settings Information
Setting Description
Fix DB cache
Table 17. Provisioning Settings Information
Setting Description
Type of name generator
Specifies the method used to generate a host name when creating a new host.
The default Random-based option generates a unique random host name which you can but do not have to use. This is useful for users who create many hosts and do not know how to name them.
The MAC-based option is for bare-metal hosts only. If you delete a host and create it later on, it receives the same host name based on the MAC address. This can be useful for users who recycle servers and want them to always get the same host name.
The Off option disables the name generator function and leaves the host name field blank.
Safemode rendering
Enables safe mode rendering of provisioning templates. The default and recommended option Yes denies the access to variables and any object that is not whitelisted within Foreman.
When set to No, any object may be accessed by a user with permission to use templating features, either via editing of templates, parameters or smart variables. This permits users full remote code execution on Foreman server, effectively disabling all authorization. This is not a safe option, especially in bigger companies.
Until BZ#1759111 is resolved, note that if you use the wildcard value, for example docker*, to exclude all facts beginning with docker, this also excludes facts that contain the excluded term in any part of the name.
Until BZ#1759111 is resolved, note that if you use the wildcard value, for example docker*, to ignore all facts beginning with docker, this also excludes facts that contain the ignored term in any part of the name.
